[GRASS-SVN] r66332 - in grass/trunk: gui/wxpython/vnet lib/python/pygrass/raster lib/python/temporal locale/po scripts/v.what.strds vector/v.net
svn_grass at osgeo.org
Fri Sep 25 06:48:44 PDT 2015
Author: neteler
Date: 2015-09-25 06:48:44 -0700 (Fri, 25 Sep 2015)
New Revision: 66332
grass/trunk/gui/wxpython/vnet/dialogs.py
grass/trunk/lib/python/pygrass/raster/__init__.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/locale/po/grasslibs_ar.po
grass/trunk/locale/po/grasslibs_cs.po
grass/trunk/locale/po/grasslibs_de.po
grass/trunk/locale/po/grasslibs_el.po
grass/trunk/locale/po/grasslibs_es.po
grass/trunk/locale/po/grasslibs_fi.po
grass/trunk/locale/po/grasslibs_fr.po
grass/trunk/locale/po/grasslibs_it.po
grass/trunk/locale/po/grasslibs_ja.po
grass/trunk/locale/po/grasslibs_ko.po
grass/trunk/locale/po/grasslibs_lv.po
grass/trunk/locale/po/grasslibs_ml.po
grass/trunk/locale/po/grasslibs_pl.po
grass/trunk/locale/po/grasslibs_pt.po
grass/trunk/locale/po/grasslibs_pt_br.po
grass/trunk/locale/po/grasslibs_ro.po
grass/trunk/locale/po/grasslibs_ru.po
grass/trunk/locale/po/grasslibs_sl.po
grass/trunk/locale/po/grasslibs_th.po
grass/trunk/locale/po/grasslibs_tr.po
grass/trunk/locale/po/grasslibs_vi.po
grass/trunk/locale/po/grasslibs_zh.po
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fi.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
grass/trunk/locale/po/grasswxpy_cs.po
grass/trunk/locale/po/grasswxpy_de.po
grass/trunk/locale/po/grasswxpy_el.po
grass/trunk/locale/po/grasswxpy_es.po
grass/trunk/locale/po/grasswxpy_fi.po
grass/trunk/locale/po/grasswxpy_fr.po
grass/trunk/locale/po/grasswxpy_id.po
grass/trunk/locale/po/grasswxpy_it.po
grass/trunk/locale/po/grasswxpy_ja.po
grass/trunk/locale/po/grasswxpy_ko.po
grass/trunk/locale/po/grasswxpy_lv.po
grass/trunk/locale/po/grasswxpy_ml.po
grass/trunk/locale/po/grasswxpy_pl.po
grass/trunk/locale/po/grasswxpy_pt.po
grass/trunk/locale/po/grasswxpy_pt_br.po
grass/trunk/locale/po/grasswxpy_ro.po
grass/trunk/locale/po/grasswxpy_ru.po
grass/trunk/locale/po/grasswxpy_th.po
grass/trunk/locale/po/grasswxpy_tr.po
grass/trunk/locale/po/grasswxpy_vi.po
grass/trunk/locale/po/grasswxpy_zh.po
grass/trunk/scripts/v.what.strds/v.what.strds.py
grass/trunk/vector/v.net/turntable.c
fix msg grammar
Modified: grass/trunk/gui/wxpython/vnet/dialogs.py
--- grass/trunk/gui/wxpython/vnet/dialogs.py 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/gui/wxpython/vnet/dialogs.py 2015-09-25 13:48:44 UTC (rev 66332)
@@ -795,7 +795,7 @@
if "input" in err_params:
GMessage(parent = self,
- message = _("Input vector map does not exists."))
+ message = _("Input vector map does not exist."))
if ["turn_layer", "turn_cat_layer"] in err_params:
GMessage(parent = self, message = "Please choose existing turntable layer and unique categories layer in Parameters tab.")
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py 2015-09-25 13:48:44 UTC (rev 66332)
@@ -558,7 +558,7 @@
self._fd = libraster.Rast_open_new(self.name, self._gtype)
else:
if self.mode == "r":
- str_err = _("Raster map <{0}> does not exists")
+ str_err = _("Raster map <{0}> does not exist")
raise OpenError(str_err.format(self.name))
self._gtype = RTYPE[self.mtype]['grass type']
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2015-09-25 13:48:44 UTC (rev 66332)
@@ -327,7 +327,7 @@
dbif, connected = init_dbif(dbif)
- # We need to create the register table if it does not exists
+ # We need to create the register table if it does not exist
stds_register_table = self.get_map_register()
# Create the map register table
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/lib/python/temporal/core.py 2015-09-25 13:48:44 UTC (rev 66332)
@@ -463,7 +463,7 @@
# exists
if driver == "sqlite" and not os.path.exists(database):
message_interface.warning("Temporal database connection defined as:\n" + \
- database + "\nBut database file does not exists.")
+ database + "\nBut database file does not exist.")
return tgis_mapsets
@@ -474,7 +474,7 @@
"""This function set the correct database backend from GRASS environmental
variables and creates the grass temporal database structure for raster,
vector and raster3d maps as well as for the space-time datasets strds,
- str3ds and stvds in case it does not exists.
+ str3ds and stvds in case it does not exist.
Several global variables are initiated and the messenger and C-library
interface subprocesses are spawned.
@@ -759,7 +759,7 @@
msgr.message(_("Creating temporal database: %s" % (str(tgis_database_string))))
if tgis_backend == "sqlite":
- # We need to create the sqlite3 database path if it does not exists
+ # We need to create the sqlite3 database path if it does not exist
tgis_dir = os.path.dirname(tgis_database_string)
if not os.path.exists(tgis_dir):
try:
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2015-09-25 13:48:44 UTC (rev 66332)
@@ -171,7 +171,7 @@
the map will be exported using r.out.bin to a temporary location
and assigned to the memmap object that is returned by this function.
- In case the raster map does not exists, an empty temporary
+ In case the raster map does not exist, an empty temporary
binary file will be created and assigned to the memap object.
You need to call the write function to write the memmap
@@ -505,7 +505,7 @@
the map will be exported using r3.out.bin to a temporary location
- In case the 3D raster map does not exists, an empty temporary
+ In case the 3D raster map does not exist, an empty temporary
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_ar.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3640,7 +3640,7 @@
#: ../lib/python/pygrass/raster/__init__.py:432
#, fuzzy, python-brace-format
-msgid "Raster map <{0}> does not exists"
+msgid "Raster map <{0}> does not exist"
msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ø§ÙØªØ§Ø±ÙØ® ÙÙÙÙÙØªÙر"
#: ../lib/python/pygrass/raster/abstract.py:274
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_cs.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3692,7 +3692,7 @@
msgstr "Tabulka <%s> pÅipojená k vektorové mapÄ <%s> neexistuje"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_de.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3686,7 +3686,7 @@
msgstr "Tabelle <%s> verknüpft mit Vektorkarte <%s> existiert nicht."
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_el.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3680,7 +3680,7 @@
msgstr ""
"Î ÏÎ¯Î½Î±ÎºÎ±Ï <%s> ÏοÏ
είναι ÏÏ
νδεδεμÎÎ½Î¿Ï Î¼Îµ Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s> δεν "
"Ï
ÏάÏÏει"
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_es.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3826,7 +3826,7 @@
msgstr "La tabla <%s> enlazada con el mapa vectorial <%s> no existe."
Modified: grass/trunk/locale/po/grasslibs_fi.po
--- grass/trunk/locale/po/grasslibs_fi.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_fi.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3503,7 +3503,7 @@
#, python-brace-format
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_fr.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3718,7 +3718,7 @@
msgstr "La table <%s> liée à la carte vecteur <%s> n'existe pas "
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_it.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3696,7 +3696,7 @@
msgstr "Tabella <%s> collegata al vettoriale <%s> non esiste"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_ja.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3685,7 +3685,7 @@
msgstr "ãã¯ãã«ããã <%s> ã«ãªã³ã¯ãããã¼ãã« <%s> ã¯åå¨ãã¾ãã"
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_ko.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3599,7 +3599,7 @@
msgstr "ììíì¼ì ì´ ì ììµëë¤"
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_lv.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3628,7 +3628,7 @@
msgstr "Nevar atvÄrt vÄsturi vektoram '%s'"
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_ml.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3566,7 +3566,7 @@
msgstr "à´àµà´°àµà´ªàµà´ªàµ <%s> à´à´¾à´²à´¿à´¯à´¾à´£àµâ \n"
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_pl.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3657,7 +3657,7 @@
msgstr "Tabela <%s> podÅÄ
czona do mapy wektorowej <%s> nie istnieje"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_pt.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3678,7 +3678,7 @@
msgstr "Impossível abrir topologia para mapa vetorial <%s>"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_pt_br.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3663,7 +3663,7 @@
msgstr "Não consegui abrir histórico para o vetor %s"
Modified: grass/trunk/locale/po/grasslibs_ro.po
--- grass/trunk/locale/po/grasslibs_ro.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_ro.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3569,7 +3569,7 @@
msgstr "Harta raster <%s> nu este gÄsitÄ"
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_ru.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3694,7 +3694,7 @@
msgstr "ТаблиÑа <%s> ÑвÑÐ·Ð°Ð½Ð½Ð°Ñ Ñ Ð²ÐµÐºÑоÑнÑм Ñлоем <%s> не ÑÑÑеÑÑвÑеÑ"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_sl.po 2015-09-25 13:48:44 UTC (rev 66332)
msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_th.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3682,7 +3682,7 @@
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸à¸«à¸²à¸à¸²à¸£à¸²à¸ <%s> à¸à¸µà¹à¹à¸à¸·à¹à¸à¸¡à¸à¸±à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s>"
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_tr.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3611,7 +3611,7 @@
msgstr "<%s> raster haritası boÅ"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_vi.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -3684,7 +3684,7 @@
msgstr "Bảng <%s> ÄÆ°á»£c liên kết và o bản Äá» vec-tÆ¡ <%s> không tá»n tại"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasslibs_zh.po 2015-09-25 13:48:44 UTC (rev 66332)
msgstr "æ æ³æå¼ç¢é'%s'çåå²è®°å½"
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_ar.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10644,7 +10644,7 @@
#: ../vector/v.net/turntable.c:670
#, fuzzy, c-format
-msgid "Arc layer <%s> does not exists in map <%s>."
+msgid "Arc layer <%s> does not exist in map <%s>."
msgstr "Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø·ÙÙØ¨ Ø§ÙØ¶Ø¨Ø· عÙÙÙØ§"
#: ../vector/v.net/turntable.c:675
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_cs.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10620,7 +10620,7 @@
#, fuzzy, c-format
msgstr "Tabulka <%s> v databázi <%s> neexistuje"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_de.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10557,7 +10557,7 @@
#, fuzzy, c-format
msgstr "Die Tabelle <%s> existiert nicht in der Datenbank <%s>."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_el.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10208,7 +10208,7 @@
#, fuzzy, c-format
msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_es.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10632,7 +10632,7 @@
#, fuzzy, c-format
msgstr "La tabla <%s> no existe en la base de datos <%s>"
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_fi.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -9805,7 +9805,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_fr.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -11082,7 +11082,7 @@
#, fuzzy, c-format
msgstr "La table <%s> n'existe pas dans la base de données <%s>"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_it.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10488,7 +10488,7 @@
#, fuzzy, c-format
msgstr "La tabella <%s> non esiste nel database <%s>"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_ja.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10503,7 +10503,7 @@
#, fuzzy, c-format
msgstr "ãã¼ãã« <%s> ã¯ãã¼ã¿ãã¼ã¹ <%s> ä¸ã«ããã¾ãã"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_ko.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10266,7 +10266,7 @@
#, fuzzy, c-format
msgstr "ì¶ë ¥í 격ìì§ë"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_lv.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10625,7 +10625,7 @@
#, fuzzy, c-format
msgstr "PÄrkodÄt rastra kartes."
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_pl.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10530,7 +10530,7 @@
# kolejnoÅÄ %s ma chyba znaczenie -> zmiana wypacza sens
#, fuzzy, c-format
msgstr "Tabela <%s> nie istnieje w bazie danych <%s>"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_pt.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10761,7 +10761,7 @@
#, fuzzy, c-format
msgstr "Tabela <%s> não existe no banco de dados <%s>"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10757,7 +10757,7 @@
#, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_ro.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -9902,7 +9902,7 @@
#, fuzzy, c-format
msgstr "<%s> deja existÄ Ã®n mapset <%s>"
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_ru.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10624,7 +10624,7 @@
#, fuzzy, c-format
msgstr "ТаблиÑа <%s> не ÑÑÑеÑÑвÑÐµÑ Ð² базе даннÑÑ
<%s>"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_sl.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10674,7 +10674,7 @@
#, fuzzy, c-format
msgstr "Rastrski sloj kateremu naj se regija prilagodi"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_th.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10609,7 +10609,7 @@
#, fuzzy, c-format
msgstr "à¸à¸²à¸£à¸²à¸ <%s> à¹à¸¡à¹à¸¡à¸µà¸à¸¢à¸¹à¹à¹à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥ <%s>"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_tr.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10471,7 +10471,7 @@
#, fuzzy, c-format
msgstr "<%s> tablosu <%s> veritabanında yok"
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_vi.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10615,7 +10615,7 @@
#, fuzzy, c-format
msgstr "Bảng <%s> không có trong CSDL <%s>"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grassmods_zh.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -10618,7 +10618,7 @@
#, fuzzy, c-format
msgstr "å
å«ç»æçæ
æ ¼å¾çåç§°"
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_cs.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6870,7 +6870,7 @@
#: ../gui/wxpython/vnet/dialogs.py:798
#, fuzzy
-msgid "Input vector map does not exists."
+msgid "Input vector map does not exist."
msgstr "Vektorová mapa <%s> nebyla nalezena."
#: ../gui/wxpython/vnet/dialogs.py:816
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_de.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6755,7 +6755,7 @@
#, fuzzy
msgstr "Verzeichnis %s existiert nicht."
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_el.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6463,7 +6463,7 @@
#, fuzzy
msgstr "Î ÏÎ¬ÎºÎµÎ»Î¿Ï %s δεν Ï
ÏάÏÏει,"
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_es.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6835,7 +6835,7 @@
msgstr "Cargando datos."
msgstr "Mapa vectorial de entrada no existe."
Modified: grass/trunk/locale/po/grasswxpy_fi.po
--- grass/trunk/locale/po/grasswxpy_fi.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_fi.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6285,7 +6285,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_fr.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6698,7 +6698,7 @@
msgstr ""
msgstr "La couche vecteur entrée n'existe pas."
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_id.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6971,7 +6971,7 @@
#, fuzzy
msgstr "ERROR: Mapset <%s> tidak ada"
Modified: grass/trunk/locale/po/grasswxpy_it.po
--- grass/trunk/locale/po/grasswxpy_it.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_it.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6567,7 +6567,7 @@
msgstr "Creando la tabella delle svolte..."
msgstr "Il vettoriale di input non esiste."
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_ja.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6778,7 +6778,7 @@
#, fuzzy
msgstr "ãã¯ãã«ããã <%s> ãè¦ã¤ããã¾ãã"
Modified: grass/trunk/locale/po/grasswxpy_ko.po
--- grass/trunk/locale/po/grasswxpy_ko.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_ko.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6268,7 +6268,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_lv.po
--- grass/trunk/locale/po/grasswxpy_lv.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_lv.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6432,7 +6432,7 @@
#, fuzzy
msgstr "Īpašība %s neeksistÄ"
Modified: grass/trunk/locale/po/grasswxpy_ml.po
--- grass/trunk/locale/po/grasswxpy_ml.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_ml.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6709,7 +6709,7 @@
#, fuzzy
msgstr "മാപàµà´ªàµ <%s> à´à´£àµà´®à´¨à´¿à´²àµà´²"
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_pl.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6650,7 +6650,7 @@
#, fuzzy
msgstr "Katalog %s nie istnieje."
Modified: grass/trunk/locale/po/grasswxpy_pt.po
--- grass/trunk/locale/po/grasswxpy_pt.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_pt.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -7008,7 +7008,7 @@
#, fuzzy
msgstr "Mapa <%s> não encontrado"
Modified: grass/trunk/locale/po/grasswxpy_pt_br.po
--- grass/trunk/locale/po/grasswxpy_pt_br.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_pt_br.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -7149,7 +7149,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grasswxpy_ro.po
--- grass/trunk/locale/po/grasswxpy_ro.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_ro.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6796,7 +6796,7 @@
#, fuzzy
msgstr "Directorul %s nu existÄ."
Modified: grass/trunk/locale/po/grasswxpy_ru.po
--- grass/trunk/locale/po/grasswxpy_ru.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_ru.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6931,7 +6931,7 @@
#, fuzzy
msgstr "Слой <%s> не найден."
Modified: grass/trunk/locale/po/grasswxpy_th.po
--- grass/trunk/locale/po/grasswxpy_th.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_th.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6683,7 +6683,7 @@
#, fuzzy
msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¹à¸¡à¹à¹à¸à¹ 3มิà¸à¸´"
Modified: grass/trunk/locale/po/grasswxpy_tr.po
--- grass/trunk/locale/po/grasswxpy_tr.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_tr.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6946,7 +6946,7 @@
#, fuzzy
msgstr "<%s>haritası bulunamadı."
Modified: grass/trunk/locale/po/grasswxpy_vi.po
--- grass/trunk/locale/po/grasswxpy_vi.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_vi.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6945,7 +6945,7 @@
#, fuzzy
msgstr "Không tìm thấy bản Äá» <%s>."
Modified: grass/trunk/locale/po/grasswxpy_zh.po
--- grass/trunk/locale/po/grasswxpy_zh.po 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/locale/po/grasswxpy_zh.po 2015-09-25 13:48:44 UTC (rev 66332)
@@ -6837,7 +6837,7 @@
#, fuzzy
msgstr "æ
æ ¼å°å¾ [%s] æªåç°"
Modified: grass/trunk/scripts/v.what.strds/v.what.strds.py
--- grass/trunk/scripts/v.what.strds/v.what.strds.py 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/scripts/v.what.strds/v.what.strds.py 2015-09-25 13:48:44 UTC (rev 66332)
@@ -22,6 +22,7 @@
#% keyword: position
#% keyword: querying
#% keyword: attribute table
+#% keyword: time
#%end
#%option G_OPT_V_INPUT
Modified: grass/trunk/vector/v.net/turntable.c
--- grass/trunk/vector/v.net/turntable.c 2015-09-25 13:19:52 UTC (rev 66331)
+++ grass/trunk/vector/v.net/turntable.c 2015-09-25 13:48:44 UTC (rev 66332)
@@ -667,17 +667,17 @@
tucfield = Vect_get_field_number(&InMap, opt->tucfield->answer);
if (!Vect_get_field(&InMap, afield))
- G_fatal_error(_("Arc layer <%s> does not exists in map <%s>."),
+ G_fatal_error(_("Arc layer <%s> does not exist in map <%s>."),
opt->afield_opt->answer, opt->output->answer);
if (Vect_get_field(&InMap, tfield))
G_warning(_
- ("Layer <%s> already exists in map <%s>.\nIt will be overwritten by tlayer data."),
+ ("Layer <%s> already exist in map <%s>.\nIt will be overwritten by tlayer data."),
opt->tfield->answer, opt->output->answer);
if (Vect_get_field(&InMap, tucfield))
G_warning(_
- ("Layer <%s> already exists in map <%s>.\nIt will be overwritten by tuclayer data."),
+ ("Layer <%s> already exist in map <%s>.\nIt will be overwritten by tuclayer data."),
opt->tucfield->answer, opt->output->answer);
ttb_name = NULL;
