[GRASS-SVN] r66334 - in grass-addons/grass7: . temporal temporal/t.rast.whatcsv temporal/t.rast.whatcsv/testsuite
svn_grass at osgeo.org
Fri Sep 25 08:39:47 PDT 2015
Author: neteler
Date: 2015-09-25 08:39:47 -0700 (Fri, 25 Sep 2015)
New Revision: 66334
Added:
grass-addons/grass7/temporal/
grass-addons/grass7/temporal/Makefile
grass-addons/grass7/temporal/t.rast.whatcsv/
grass-addons/grass7/temporal/t.rast.whatcsv/Makefile
grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.html
grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.py
grass-addons/grass7/temporal/t.rast.whatcsv/testsuite/
grass-addons/grass7/temporal/t.rast.whatcsv/testsuite/test_whatcsv.py
grass-addons/grass7/Makefile
t.rast.whatcsv Addon: new prototype module by Soeren Gebbert
Modified: grass-addons/grass7/Makefile
--- grass-addons/grass7/Makefile 2015-09-25 13:59:13 UTC (rev 66333)
+++ grass-addons/grass7/Makefile 2015-09-25 15:39:47 UTC (rev 66334)
@@ -7,7 +7,8 @@
general \
imagery \
raster \
- vector
+ vector \
+ temporal
include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass7/temporal/Makefile
--- grass-addons/grass7/temporal/Makefile (rev 0)
+++ grass-addons/grass7/temporal/Makefile 2015-09-25 15:39:47 UTC (rev 66334)
@@ -0,0 +1,8 @@
+MODULE_TOPDIR = ..
+SUBDIRS = \
+ t.rast.whatcsv
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: subdirs
Property changes on: grass-addons/grass7/temporal/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/temporal/t.rast.whatcsv/Makefile
--- grass-addons/grass7/temporal/t.rast.whatcsv/Makefile (rev 0)
+++ grass-addons/grass7/temporal/t.rast.whatcsv/Makefile 2015-09-25 15:39:47 UTC (rev 66334)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.whatcsv
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Property changes on: grass-addons/grass7/temporal/t.rast.whatcsv/Makefile
+ text/x-makefile
+ native
Added: grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.html
--- grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.html (rev 0)
+++ grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.html 2015-09-25 15:39:47 UTC (rev 66334)
@@ -0,0 +1,133 @@
+<h2>DESCRIPTION</h2>
+<em>t.rast.what</em> is designed to sample space time raster datasets
+at specific point coordinates using <a href="r.what.html">r.what</a> internally.
+The output of <a href="r.what.html">r.what</a>
+is transformed to different output layouts.
+The output layouts can be specified using the <em>layout</em> option.
+<p>
+Three layouts can be specified:
+<ul>
+ <li><em>row</em> - Row order, one vector sample point value per row</li>
+ <li><em>col</em> - Column order, create a column for each vector sample point of a single time step/raster layer</li>
+ <li><em>timerow</em> - Time order, create a column for each time step, this order is the original r.what output, except that the column names are the time stamps</li>
+</ul>
+Please have a look at the example to see the supported layouts.
+<p>
+This module is designed to run several instances of r.what to sample
+subsets of a space time raster dataset in parallel. Several intermediate
+text files will be created that are merged into a single file at the
+end of the processing.
+<p>
+Coordinates can be provided as vector map using the <em>points</em> option
+or as comma separated coordinate list with the <em>coordinates </em>option.
+<p>
+An output file can be specified using the <em>output</em> option.
+Stdout will be used if no output is specified or if the
+<em>output</em> option is set to "-".
+<h2>EXAMPLES</h2>
+<h3>Data preparation</h3>
+In the following examples we sample a space time raster dataset that contains
+4 raster map layers. First we create the STRDS that will be sampled with t.rast.what.
+<div class="code"><pre>
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10
+# Generate data
+r.mapcalc expression="a_1 = 1" -s
+r.mapcalc expression="a_2 = 2" -s
+r.mapcalc expression="a_3 = 3" -s
+r.mapcalc expression="a_4 = 4" -s
+t.create type=strds output=A title="A test" descr="A test"
+t.register -i type=raster input=A maps=a_1,a_2,a_3,a_4 \
+ start='1990-01-01' increment="1 month"
+</pre></div>
+<h3>Example 1</h3>
+The first approach uses text coordinates as input and stdout as output,
+the layout is one coordinate(point per column:
+t.rast.what strds=A coordinates="115,36,79,45" layout=col -n
+start|end|115.0000000000;36.0000000000|79.0000000000;45.0000000000
+1990-01-01 00:00:00|1990-02-01 00:00:00|1|1
+1990-02-01 00:00:00|1990-03-01 00:00:00|2|2
+1990-03-01 00:00:00|1990-04-01 00:00:00|3|3
+1990-04-01 00:00:00|1990-05-01 00:00:00|4|4
+</pre></div>
+<h3>Example 2</h3>
+A vector map layer can be used as input to sample the STRDS. All
+three available layouts are demonstrated using the vector map for sampling.
+# First create the vector map layer based on random points
+v.random output=points n=3 seed=1
+# Row layout using a text file as output
+t.rast.what strds=A points=points output=result.txt layout=row -n
+cat result.txt
+115.0043586274|36.3593955783|1990-01-01 00:00:00|1990-02-01 00:00:00|1
+115.0043586274|36.3593955783|1990-02-01 00:00:00|1990-03-01 00:00:00|2
+115.0043586274|36.3593955783|1990-03-01 00:00:00|1990-04-01 00:00:00|3
+115.0043586274|36.3593955783|1990-04-01 00:00:00|1990-05-01 00:00:00|4
+79.6816763826|45.2391522853|1990-01-01 00:00:00|1990-02-01 00:00:00|1
+79.6816763826|45.2391522853|1990-02-01 00:00:00|1990-03-01 00:00:00|2
+79.6816763826|45.2391522853|1990-03-01 00:00:00|1990-04-01 00:00:00|3
+79.6816763826|45.2391522853|1990-04-01 00:00:00|1990-05-01 00:00:00|4
+97.4892579600|79.2347263950|1990-01-01 00:00:00|1990-02-01 00:00:00|1
+97.4892579600|79.2347263950|1990-02-01 00:00:00|1990-03-01 00:00:00|2
+97.4892579600|79.2347263950|1990-03-01 00:00:00|1990-04-01 00:00:00|3
+97.4892579600|79.2347263950|1990-04-01 00:00:00|1990-05-01 00:00:00|4
+# Column layout order using stdout as output
+t.rast.what strds=A points=points layout=col -n
+start|end|115.0043586274;36.3593955783|79.6816763826;45.2391522853|97.4892579600;79.2347263950
+1990-01-01 00:00:00|1990-02-01 00:00:00|1|1|1
+1990-02-01 00:00:00|1990-03-01 00:00:00|2|2|2
+1990-03-01 00:00:00|1990-04-01 00:00:00|3|3|3
+1990-04-01 00:00:00|1990-05-01 00:00:00|4|4|4
+# Timerow layout, one time series per row
+# using the where statement to select a subset of the STRDS
+# and stdout as output
+t.rast.what strds=A points=points \
+ where="start_time >= '1990-03-01'" layout=timerow -n
+x|y|1990-03-01 00:00:00;1990-04-01 00:00:00|1990-04-01 00:00:00;1990-05-01 00:00:00
+115.004358627375|36.3593955782903|3|4
+79.681676382576|45.2391522852909|3|4
+97.4892579600048|79.2347263950131|3|4
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.what.html">r.what</a> ,
+<a href="r.neighbors.html">r.neighbors</a>,
+<a href="t.rast.aggregate.ds.html">t.rast.aggregate.ds</a>,
+<a href="t.rast.extract.html">t.rast.extract</a>,
+<a href="t.info.html">t.info</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.mask.html">r.mask</a>
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert, Thünen Institute of Climate-Smart Agriculture
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.py
--- grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.py (rev 0)
+++ grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.py 2015-09-25 15:39:47 UTC (rev 66334)
@@ -0,0 +1,158 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.whatcsv
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Sample a space time raster dataset at specific vector point
+# coordinates and write the output to stdout using different
+# layouts
+# COPYRIGHT: (C) 2015 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Sample a space time raster dataset at specific space-time point coordinates from a csv file and write the output to stdout
+#% keyword: temporal
+#% keyword: raster
+#% keyword: sampling
+#% keyword: time
+#%end
+#%option G_OPT_F_INPUT
+#% key: csv
+#% description: Name for the output input csv file
+#%end
+#%option G_OPT_STRDS_INPUT
+#% key: strds
+#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#% description: Name for the output file or "-" in case stdout should be used
+#% answer: -
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option G_OPT_M_NULL_VALUE
+#%end
+#%option G_OPT_F_SEP
+#%end
+#%option
+#% key: skip
+#% type: integer
+#% description: Number of header lines to skip in the csv file
+#% required: yes
+#%end
+#%flag
+#% key: n
+#% description: Output header row
+#%end
+## Temporary disabled the r.what flags due to test issues
+##%flag
+##% key: f
+##% description: Show the category labels of the grid cell(s)
+##%end
+##%flag
+##% key: r
+##% description: Output color values as RRR:GGG:BBB
+##%end
+##%flag
+##% key: i
+##% description: Output integer category values, not cell values
+##%end
+import sys
+import copy
+import csv
+import grass.script as gscript
+import grass.temporal as tgis
+import grass.pygrass.modules as pymod
+from grass.gunittest.gmodules import SimpleModule
+def main(options, flags):
+ # Get the options
+ csv_file = options["csv"]
+ strds = options["strds"]
+ output = options["output"]
+ where = options["where"]
+ null_value = options["null_value"]
+ separator = options["separator"]
+ write_header = flags["n"]
+ #output_cat_label = flags["f"]
+ #output_color = flags["r"]
+ #output_cat = flags["i"]
+ overwrite = gscript.overwrite()
+ # Make sure the temporal database exists
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ sp = tgis.open_old_stds(strds, "strds", dbif)
+ # Setup separator
+ if separator == "pipe":
+ separator = "|"
+ if separator == "comma":
+ separator = ","
+ if separator == "space":
+ separator = " "
+ if separator == "tab":
+ separator = "\t"
+ if separator == "newline":
+ separator = "\n"
+ r_what = SimpleModule("r.what", map="dummy",
+ output="-",
+ separator=separator,
+ quiet=True)
+ reader = csv.reader(open(csv_file, "r"), delimiter=separator)
+ for line in reader:
+ id_, x, y, timestamp = line
+ start = tgis.string_to_datetime(timestamp)
+ where = "start_time <= \'" + str(start) + "\' AND end_time > \'" + str(start) + "\'"
+ rows = sp.get_registered_maps(columns="id", where=where,
+ dbif=dbif)
+ for entry in rows:
+ r_what.inputs.map = entry[0]
+ r_what.inputs.coordinates = [x,y]
+ r_what.run()
+ out = "%s%s%s"%(id_, separator, r_what.outputs.stdout)
+ sys.stdout.write(out)
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ main(options, flags)
Property changes on: grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.py
Added: svn:executable
+ text/x-python
+ native
Added: grass-addons/grass7/temporal/t.rast.whatcsv/testsuite/test_whatcsv.py
--- grass-addons/grass7/temporal/t.rast.whatcsv/testsuite/test_whatcsv.py (rev 0)
+++ grass-addons/grass7/temporal/t.rast.whatcsv/testsuite/test_whatcsv.py 2015-09-25 15:39:47 UTC (rev 66334)
@@ -0,0 +1,66 @@
+"""Test t.rast.whatcsv
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+class TestRasterWhatCSV(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10)
+ cls.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_2 = 200", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
+ csv_file = open("test.csv", "w")
+ csv_file.write("1|115.0043586274|36.3593955783|2001-01-01 00:00:00\n")
+ csv_file.write("2|79.6816763826|45.2391522853|2001-04-01 00:00:00\n")
+ csv_file.write("3|97.4892579600|79.2347263950|2001-07-01 00:00:00\n")
+ csv_file.write("4|115.0043586274|36.3593955783|2001-11-01 00:00:00\n")
+ csv_file.close()
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
+ overwrite=True)
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ maps="a_1,a_2,a_3,a_4", start="2001-01-01",
+ increment="3 months", overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", type="strds",
+ inputs="A")
+ cls.del_temp_region()
+ def test_1t(self):
+ t_rast_whatcsv = SimpleModule("t.rast.whatcsv", strds="A",
+ csv="test.csv", overwrite=True,
+ skip=0, verbose=True)
+ self.assertModule(t_rast_whatcsv)
+ text="""1|115.0043586274|36.3593955783||100
+2|79.6816763826|45.2391522853||200
+3|97.4892579600|79.2347263950||300
+4|115.0043586274|36.3593955783||400
+ self.assertLooksLike(text, t_rast_whatcsv.outputs.stdout)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Property changes on: grass-addons/grass7/temporal/t.rast.whatcsv/testsuite/test_whatcsv.py
+ text/x-python
+ native
