[GRASS-SVN] r66348 - grass/branches/releasebranch_7_0/temporal/t.remove
svn_grass at osgeo.org
Sun Sep 27 04:11:04 PDT 2015
Author: neteler
Date: 2015-09-27 04:11:04 -0700 (Sun, 27 Sep 2015)
New Revision: 66348
grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.html
grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.py
t.remove: msgs added to tell user what it does; enhance manual
Modified: grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.html
--- grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.html 2015-09-27 11:10:53 UTC (rev 66347)
+++ grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.html 2015-09-27 11:11:04 UTC (rev 66348)
@@ -1,22 +1,24 @@
<h2>DESCRIPTION</h2>
The module <em>t.remove</em> removes space time datasets (STRDS, STR3DS,
-STVDS) from the temporal database. In other words, it deletes the relevant
-database entries and not the maps.
+STVDS) from the temporal database. In other words, by default it deletes
+the relevant database entries but not the maps.
<p>
Optionally, also the raster, 3D raster and vector maps of the space time
-datasets can be removed using the <b>-r</b> (recursive) and <b>-f</b>
-(force) flags. Recursive removal works only if both flags are checked
-(use <b>-rf</b>).
+datasets can be removed from the current mapset using the <b>-r</b> (recursive)
+and <b>-f</b> (force) flags. This recursive removal only works if both flags
+are checked together (use <b>-rf</b>).
<h2>EXAMPLE</h2>
In this example a space time raster dataset (STRDS) named
<b>precip_months_sum</b> will be created using a subset of the monthly
precipitation raster maps from the North Carolina climate sample data set.
-In order to be able to show case recursive removal without deleting original
-sample data, new data is generated by means of computing yearly precipitation
-sums. Finally, all newly produced data (STRDS and raster maps) is removed again.
+<br>
+In order to be able to show the case of recursive removal without deleting
+the original sample data, we generate new data by means of computing
+yearly precipitation sums. Eventually, all newly produced data (STRDS and
+raster maps) are removed:
<div class="code"><pre>
#Create new and empty STRDS
@@ -36,7 +38,7 @@
years" method=sum
#Remove all newly produced data:
-# a) the aggregated STRDS with 1 years granularity together with its raster maps
+# a) the aggregated STRDS with 1 years granularity along with its raster maps
t.remove -rf type=strds input=precip_years_sum
# b) the STRDS with 1 months granularity, but not the original sample data
Modified: grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.py
--- grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.py 2015-09-27 11:10:53 UTC (rev 66347)
+++ grass/branches/releasebranch_7_0/temporal/t.remove/t.remove.py 2015-09-27 11:11:04 UTC (rev 66348)
@@ -47,7 +47,7 @@
#%flag
#% key: r
-#% description: Remove all registered maps from the temporal and spatial database
+#% description: Remove all registered maps from the temporal and also from the spatial database
#%end
#%flag
@@ -115,7 +115,7 @@
sp = tgis.open_old_stds(name, type, dbif)
if recursive and force:
- grass.message(_("Removing registered maps"))
+ grass.message(_("Removing registered maps and %s" % type))
maps = sp.get_registered_maps_as_objects(dbif=dbif)
map_statement = ""
count = 1
@@ -151,6 +151,8 @@
remove(type="vector", name=name_list, run_=True)
if type == "str3ds":
remove(type="raster_3d", name=name_list, run_=True)
+ else:
+ grass.message(_("Note: registered maps themselves have not been removed, only the %s" % type))
statement += sp.delete(dbif=dbif, execute=False)
