[GRASS-SVN] r66381 - grass-addons/grass7/raster/r.stream.distance
svn_grass at osgeo.org
Wed Sep 30 08:43:34 PDT 2015
Author: hcho
Date: 2015-09-30 08:43:34 -0700 (Wed, 30 Sep 2015)
New Revision: 66381
grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html
r.stream.distance: duplicate words
Modified: grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html
--- grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html 2015-09-30 02:31:39 UTC (rev 66380)
+++ grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html 2015-09-30 15:43:34 UTC (rev 66381)
@@ -70,7 +70,7 @@
Alternatively, in <em>outlet</em> mode, it's the raster map of the outlet.</dd>
<dt><b>direction</b></dt>
-<dd>Flow direction: name of input input raster map with flow direction,
+<dd>Flow direction: name of input raster map with flow direction,
produced using either <em>r.watershed</em> or <em>r.stream.extract</em>.
If <em>r.stream.extract</em> output map is used, it is non-NULL only
where streams occur and NULL elsewhere. NULL (nodata) cells are ignored,
