[GRASS-SVN] r68192 - grass/branches/releasebranch_7_0/lib/pngdriver
svn_grass at osgeo.org
Fri Apr 1 03:20:58 PDT 2016
Author: martinl
Date: 2016-04-01 03:20:58 -0700 (Fri, 01 Apr 2016)
New Revision: 68192
grass/branches/releasebranch_7_0/lib/pngdriver/read_png.c
png driver: i18n cosmetics (merge r68191 from trunk)
Modified: grass/branches/releasebranch_7_0/lib/pngdriver/read_png.c
--- grass/branches/releasebranch_7_0/lib/pngdriver/read_png.c 2016-04-01 10:19:08 UTC (rev 68191)
+++ grass/branches/releasebranch_7_0/lib/pngdriver/read_png.c 2016-04-01 10:20:58 UTC (rev 68192)
@@ -16,6 +16,8 @@
#include <png.h>
#include <grass/gis.h>
+#include <grass/glocale.h>
#include "pngdriver.h"
static void read_data(png_structp png_ptr, png_bytep data, png_size_t length)
@@ -37,7 +39,7 @@
check = fread(data, 1, length, fp);
if (check != length)
- G_fatal_error("PNG: Read Error");
+ G_fatal_error(_("Unable to read PNG"));
void read_png(void)
@@ -55,18 +57,18 @@
png_ptr =
png_create_read_struct(PNG_LIBPNG_VER_STRING, &jbuf, NULL, NULL);
if (!png_ptr)
- G_fatal_error("PNG: couldn't allocate PNG structure");
+ G_fatal_error(_("Unable allocate PNG structure"));
info_ptr = png_create_info_struct(png_ptr);
if (!info_ptr)
+ G_fatal_error(_("Unable to allocate PNG structure"));
if (setjmp(png_jmpbuf(png_ptr)))
- G_fatal_error("error reading PNG file");
+ G_fatal_error(_("Unable to readi PNG file"));
input = fopen(png.file_name, "rb");
if (!input)
- G_fatal_error("PNG: couldn't open output file %s", png.file_name);
+ G_fatal_error(_("Unable to open output file <%s>"), png.file_name);
png_set_read_fn(png_ptr, input, read_data);
@@ -76,20 +78,20 @@
&depth, &color_type, NULL, NULL, NULL);
if (depth != 8)
- G_fatal_error("PNG: input file is not 8-bit");
+ G_fatal_error(_("Input PNG file is not 8-bit"));
- if (i_width != png.width || i_height != png.height)
+ if (i_width != (unsigned int)png.width || i_height != (unsigned int)png.height)
G_fatal_error
- ("PNG: input file has incorrect dimensions: expected: %dx%d got: %lux%lu",
+ (_("Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"),
png.width, png.height, (unsigned long) i_width, (unsigned long) i_height);
if (png.true_color) {
if (color_type != PNG_COLOR_TYPE_RGB_ALPHA)
- G_fatal_error("PNG: input file is not RGBA");
+ G_fatal_error(_("Input PNG file is not RGBA"));
else {
if (color_type != PNG_COLOR_TYPE_PALETTE)
- G_fatal_error("PNG: input file is not indexed color");
+ G_fatal_error(_("Input PNG file is not indexed color"));
if (!png.true_color && png.has_alpha) {
@@ -99,7 +101,7 @@
png_get_tRNS(png_ptr, info_ptr, &trans, &num_trans, NULL);
if (num_trans != 1 || trans[0] != 0)
- G_fatal_error("PNG: input file has invalid palette");
+ G_fatal_error(_("Input PNG file has invalid palette"));
if (png.true_color)
