[GRASS-SVN] r68201 - grass/trunk/gui/wxpython/gmodeler
Fri Apr 1 06:47:24 PDT 2016
Author: martinl
Date: 2016-04-01 06:47:24 -0700 (Fri, 01 Apr 2016)
New Revision: 68201
   grass/trunk/gui/wxpython/gmodeler/frame.py
   grass/trunk/gui/wxpython/gmodeler/model.py
wxGUI/gmodeler: avoid recursive deletion when undefining module parameters
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py	2016-04-01 12:39:45 UTC (rev 68200)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py	2016-04-01 13:47:24 UTC (rev 68201)
@@ -838,7 +838,7 @@
                 if not p.get('value', ''):
                     data = layer.FindData(p.get('name', ''))
                     if data:
-                        remList, upList = self.model.RemoveItem(data)
+                        remList, upList = self.model.RemoveItem(data, layer)
                         for item in remList:
                             self.canvas.diagram.RemoveShape(item)
                             item.__del__()
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py	2016-04-01 12:39:45 UTC (rev 68200)
+++ grass/trunk/gui/wxpython/gmodeler/model.py	2016-04-01 13:47:24 UTC (rev 68201)
@@ -192,17 +192,18 @@
         """Reset model"""
         self.items = list()
-    def RemoveItem(self, item):
+    def RemoveItem(self, item, reference=None):
         """Remove item from model
+        :item: item to be removed
+        :reference: reference item valid for deletion
         :return: list of related items to remove/update
         relList = list()
         upList = list()
+        doRemove = True
-        if item in self.items:
-            self.items.remove(item)
         if isinstance(item, ModelAction):
             for rel in item.GetRelations():
                 relList.append(rel)
@@ -214,17 +215,24 @@
         elif isinstance(item, ModelData):
+                otherItem = rel.GetTo() if rel.GetFrom() == item else rel.GetFrom()
+                if reference and reference != otherItem:
+                    doRemove = False
+                    continue # avoid recursive deletion
                 relList.append(rel)
-                if rel.GetFrom() == self:
-                    relList.append(rel.GetTo())
-                else:
-                    relList.append(rel.GetFrom())
+                    relList.append(otherItem)
+            if not doRemove:
+                upList.append(item)
         elif isinstance(item, ModelLoop):
                 relList.append(rel)
             for action in self.GetItems():
                 action.UnSetBlock(item)
+        if doRemove and item in self.items:
+            self.items.remove(item)
         return relList, upList
