[GRASS-SVN] r68204 - in grass/trunk/gui/wxpython: core gui_core location_wizard
Sat Apr 2 03:21:40 PDT 2016
Author: martinl
Date: 2016-04-02 03:21:40 -0700 (Sat, 02 Apr 2016)
New Revision: 68204
   grass/trunk/gui/wxpython/core/utils.py
   grass/trunk/gui/wxpython/gui_core/preferences.py
   grass/trunk/gui/wxpython/location_wizard/wizard.py
wxGUI: ReadEpsgCodes() raise OpenError exception of failure (no need for backport)
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py	2016-04-02 10:01:24 UTC (rev 68203)
+++ grass/trunk/gui/wxpython/core/utils.py	2016-04-02 10:21:40 UTC (rev 68204)
@@ -23,6 +23,7 @@
 from grass.script import core as grass
 from grass.script import task as gtask
+from grass.exceptions import OpenError
 from core import globalvar
 from core.gcmd  import RunCommand
@@ -496,15 +497,16 @@
     :param path: full path to the file with EPSG codes
+    Raise OpenError on failure.
     :return: dictionary of EPSG code
-    :return: string on error
     epsgCodeDict = dict()
     try:
         try:
             f = open(path, "r")
         except IOError:
-            return _("failed to open '%s'" % path)
+            raise OpenError(_("failed to open '{}'").format(path))
         code = None
         for line in f.readlines():
@@ -519,7 +521,7 @@
                 try:
                     code = int(code.replace('<', '').replace('>', ''))
                 except ValueError as e:
-                    return e
+                    raise OpenError('{}'.format(e))
             if code is not None:
                 epsgCodeDict[code] = (descr, params)
@@ -527,7 +529,7 @@
         f.close()
     except StandardError as e:
-        return e
     return epsgCodeDict
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py	2016-04-02 10:01:24 UTC (rev 68203)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py	2016-04-02 10:21:40 UTC (rev 68204)
@@ -41,8 +41,8 @@
 import wx.lib.scrolledpanel as SP
 from grass.pydispatch.signal import Signal
 from core.gcmd     import RunCommand, GError
@@ -1373,10 +1373,17 @@
         """Load EPSG codes from the file"""
         win = self.FindWindowById(self.winId['projection:statusbar:projFile'])
         path = win.GetValue()
+        epsgCombo = self.FindWindowById(self.winId['projection:statusbar:epsg'])
         wx.BeginBusyCursor()
-        self.epsgCodeDict = ReadEpsgCodes(path)
+        try:
+            self.epsgCodeDict = ReadEpsgCodes(path)
+        except OpenError as e:
+            wx.EndBusyCursor()
+            epsgCombo.SetItems([])
+            GError(parent = self,
+                   message = _("Unable to read EPGS codes: {}").format(e), showTraceback=False)
+            return
-        epsgCombo = self.FindWindowById(self.winId['projection:statusbar:epsg'])
         if type(self.epsgCodeDict) == type(''):
             wx.MessageBox(parent = self,
                           message = _("Unable to read EPSG codes: %s") % self.epsgCodeDict,
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py	2016-04-02 10:01:24 UTC (rev 68203)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py	2016-04-02 10:21:40 UTC (rev 68204)
@@ -50,6 +50,7 @@
 from location_wizard.dialogs import SelectTransformDialog
 global coordsys
 global north
@@ -1449,8 +1450,9 @@
             self.epsgcode = None
         nextButton = wx.FindWindowById(wx.ID_FORWARD)
-        if self.epsgcode and self.epsgcode in self.epsgCodeDict.keys():
+        if self.epsgcode and self.epsgCodeDict and \
+                self.epsgcode in self.epsgCodeDict.keys():
             self.epsgdesc = self.epsgCodeDict[self.epsgcode][0]
             self.epsgparams = self.epsgCodeDict[self.epsgcode][1]
             if not nextButton.IsEnabled():
@@ -1512,12 +1514,11 @@
     def OnBrowseCodes(self, event, search = None):
         """Browse EPSG codes"""
-        self.epsgCodeDict = utils.ReadEpsgCodes(self.tfile.GetValue())
-        if type(self.epsgCodeDict) != dict:
-            wx.MessageBox(parent = self,
-                          message = _("Unable to read EPGS codes: %s") % self.epsgCodeDict,
-                          caption = _("Error"),  style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
+        try:
+            self.epsgCodeDict = utils.ReadEpsgCodes(self.tfile.GetValue())
             self.epsglist.Populate(list(), update = True)
             return
@@ -1738,12 +1739,11 @@
         """Browse IAU codes"""
-                          message = _("Unable to read IAU codes: %s") % self.epsgCodeDict,
+        try:
+                   message = _("Unable to read IAU codes: {}").format(e), showTraceback=False)
             return
