[GRASS-SVN] r68224 - in grass/trunk/gui/wxpython: core datacatalog
svn_grass at osgeo.org
Fri Apr 8 07:25:18 PDT 2016
Author: martinl
Date: 2016-04-08 07:25:18 -0700 (Fri, 08 Apr 2016)
New Revision: 68224
Added:
grass/trunk/gui/wxpython/datacatalog/toolbars.py
grass/trunk/gui/wxpython/core/treemodel.py
grass/trunk/gui/wxpython/datacatalog/catalog.py
grass/trunk/gui/wxpython/datacatalog/frame.py
grass/trunk/gui/wxpython/datacatalog/tree.py
wxGUI/datacatalog: add toolbar and implement two functions - reload whole tree or current mapset only (new feature)
Modified: grass/trunk/gui/wxpython/core/treemodel.py
--- grass/trunk/gui/wxpython/core/treemodel.py 2016-04-07 08:15:06 UTC (rev 68223)
+++ grass/trunk/gui/wxpython/core/treemodel.py 2016-04-08 14:25:18 UTC (rev 68224)
@@ -132,6 +132,10 @@
"""Removes node."""
if node.parent:
node.parent.children.remove(node)
+ else:
+ # node is root
+ for n in node.children:
+ node.children.remove(n)
def SortChildren(self, node):
"""Sorts children alphabetically based on label."""
Modified: grass/trunk/gui/wxpython/datacatalog/catalog.py
--- grass/trunk/gui/wxpython/datacatalog/catalog.py 2016-04-07 08:15:06 UTC (rev 68223)
+++ grass/trunk/gui/wxpython/datacatalog/catalog.py 2016-04-08 14:25:18 UTC (rev 68224)
@@ -21,6 +21,7 @@
from core.debug import Debug
from datacatalog.tree import DataCatalogTree
from core.utils import _
+from datacatalog.toolbars import DataCatalogToolbar
from grass.pydispatch.signal import Signal
@@ -36,7 +37,10 @@
self.SetName("DataCatalog")
Debug.msg(1, "DataCatalog.__init__()")
+ # toolbar
+ self.toolbar = DataCatalogToolbar(parent = self)
# tree with layers
self.tree = DataCatalogTree(self, giface=giface)
self.thread = gThread()
@@ -50,6 +54,9 @@
"""Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
+ sizer.Add(item = self.toolbar, proportion = 0,
+ flag = wx.EXPAND)
sizer.Add(item = self.tree.GetControl(), proportion = 1,
flag = wx.EXPAND)
@@ -61,10 +68,19 @@
def LoadItems(self):
if self._loaded:
return
self.thread.Run(callable=self.tree.InitTreeItems,
ondone=lambda event: self.LoadItemsDone())
def LoadItemsDone(self):
self._loaded = True
self.tree.ExpandCurrentMapset()
+ def OnReloadTree(self, event):
+ """Reload whole tree"""
+ self.tree.ReloadTreeItems()
+ self.tree.ExpandCurrentMapset()
+ def OnReloadCurrentMapset(self, event):
+ """Reload current mapset tree only"""
+ self.tree.ReloadCurrentMapset()
Modified: grass/trunk/gui/wxpython/datacatalog/frame.py
--- grass/trunk/gui/wxpython/datacatalog/frame.py 2016-04-07 08:15:06 UTC (rev 68223)
+++ grass/trunk/gui/wxpython/datacatalog/frame.py 2016-04-08 14:25:18 UTC (rev 68224)
@@ -6,24 +6,26 @@
Classes:
- datacatalog::DataCatalogFrame
-(C) 2014-2015 by Tereza Fiedlerova, and the GRASS Development Team
+(C) 2014-2016 by Tereza Fiedlerova, and the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
- at author Tereza Fiedlerova
+ at author Tereza Fiedlerova (original author)
+ at author Martin Landa <landa.martin gmail.com> (various improvements)
import os
+import sys
import wx
from core.globalvar import ICONDIR
class DataCatalogFrame(wx.Frame):
"""Frame for testing purposes only."""
def __init__(self, parent, giface=None):
@@ -35,6 +37,11 @@
self._giface = giface
self.panel = wx.Panel(self)
+ # workaround for http://trac.wxwidgets.org/ticket/13888
+ if sys.platform != 'darwin':
+ self.SetToolBar(self.toolbar)
# tree
self.tree = DataCatalogTree(parent=self.panel, giface=self._giface)
self.tree.InitTreeItems()
@@ -74,3 +81,12 @@
self.Destroy()
event.Skip()
Added: grass/trunk/gui/wxpython/datacatalog/toolbars.py
--- grass/trunk/gui/wxpython/datacatalog/toolbars.py (rev 0)
+++ grass/trunk/gui/wxpython/datacatalog/toolbars.py 2016-04-08 14:25:18 UTC (rev 68224)
@@ -0,0 +1,48 @@
+ at package datacatalog.toolbars
+ at brief Data Catalog toolbars
+Classes:
+ - toolbars::DataCatalogToolbar(BaseToolbar)
+(C) 2016 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+import wx
+from gui_core.toolbars import BaseToolbar, BaseIcons
+from icons.icon import MetaIcon
+from core.utils import _
+icons = {
+ 'reloadTree': MetaIcon(img='redraw', label=_("Reload GRASS locations")),
+ 'reloadMapset': MetaIcon(img='reload', label=_("Reload current GRASS mapset only"))
+class DataCatalogToolbar(BaseToolbar):
+ """Main data catalog toolbar
+ def __init__(self, parent):
+ """Main toolbar constructor
+ BaseToolbar.__init__(self, parent)
+ self.InitToolbar(self._toolbarData())
+ # realize the toolbar
+ self.Realize()
+ def _toolbarData(self):
+ """Returns toolbar data (name, icon, handler)"""
+ # BaseIcons are a set of often used icons. It is possible
+ # to reuse icons in ./trunk/gui/icons/grass or add new ones there.
+ return self._getToolbarData((("reloadTree", icons["reloadTree"],
+ self.parent.OnReloadTree),
+ ("reloadMapset", icons["reloadMapset"],
+ self.parent.OnReloadCurrentMapset)
Property changes on: grass/trunk/gui/wxpython/datacatalog/toolbars.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2016-04-07 08:15:06 UTC (rev 68223)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2016-04-08 14:25:18 UTC (rev 68224)
@@ -50,7 +50,7 @@
return tmp_gisrc_file, env
-def getLocationTree(gisdbase, location, queue):
+def getLocationTree(gisdbase, location, queue, mapsets=[]):
"""Creates dictionary with mapsets, elements, layers for given location.
Returns tuple with the dictionary and error (or None)"""
tmp_gisrc_file, env = getEnvironment(gisdbase, location, 'PERMANENT')
@@ -59,7 +59,8 @@
maps_dict = {}
elements = ['raster', 'raster_3d', 'vector']
try:
- mapsets = gscript.read_command('g.mapsets', flags='l', quiet=True, env=env).strip()
+ if not mapsets:
+ mapsets = gscript.read_command('g.mapsets', flags='l', quiet=True, env=env).strip()
except CalledModuleError:
queue.put((maps_dict, _("Failed to read mapsets from location <{l}>.").format(l=location)))
gscript.try_remove(tmp_gisrc_file)
@@ -175,16 +176,11 @@
proc_list[i].join()
if error:
errors.append(error)
for key in sorted(maps.keys()):
mapset_node = self._model.AppendNode(parent=location_nodes[i], label=key,
data=dict(type='mapset', name=key))
- for elem in maps[key]:
- if maps[key][elem]:
- element_node = self._model.AppendNode(parent=mapset_node, label=elem,
- data=dict(type='element', name=elem))
- for layer in maps[key][elem]:
- self._model.AppendNode(parent=element_node, label=layer,
- data=dict(type=elem, name=layer))
+ self._populateMapsetItem(mapset_node, maps[key])
proc_count = 0
proc_list = []
@@ -198,9 +194,55 @@
self.RefreshItems()
def InitTreeItems(self):
- """Create popup menu for layers"""
+ """Load locations, mapsets and layers in the tree."""
raise NotImplementedError()
+ def ReloadTreeItems(self):
+ """Reload locations, mapsets and layers in the tree."""
+ self._model.RemoveNode(self._model.root)
+ self.RefreshNode(self._model.root)
+ self.InitTreeItems()
+ def ReloadCurrentMapset(self):
+ """Reload current mapset tree only."""
+ def get_first_child(node):
+ try:
+ child = mapsetItem.children[0]
+ except IndexError:
+ child = None
+ return child
+ locationItem, mapsetItem = self.GetCurrentLocationMapsetNode()
+ if not locationItem or not mapsetItem:
+ return
+ if mapsetItem.children:
+ node = get_first_child(mapsetItem)
+ while node:
+ self._model.RemoveNode(node)
+ q = Queue()
+ p = Process(target=getLocationTree,
+ args=(self.gisdbase, locationItem.data['name'], q, mapsetItem.data['name']))
+ p.start()
+ maps, error = q.get()
+ if error:
+ raise CalledModuleError(e)
+ self._populateMapsetItem(mapsetItem, maps[mapsetItem.data['name']])
+ self.RefreshNode(mapsetItem)
+ self.RefreshItems()
+ def _populateMapsetItem(self, mapset_node, data):
+ for elem in data:
+ if data[elem]:
+ element_node = self._model.AppendNode(parent=mapset_node, label=elem,
+ data=dict(type='element', name=elem))
+ for layer in data[elem]:
+ self._model.AppendNode(parent=element_node, label=layer,
+ data=dict(type=elem, name=layer))
def _popupMenuLayer(self):
@@ -279,20 +321,27 @@
else:
Debug.msg(1, "Location <%s> not found" % location)
- def ExpandCurrentMapset(self):
- """Expand current mapset"""
+ def GetCurrentLocationMapsetNode(self):
+ """Get current mapset node"""
gisenv = gscript.gisenv()
location = gisenv['LOCATION_NAME']
mapset = gisenv['MAPSET']
locationItem = self._model.SearchNodes(name=location, type='location')
- mapsetItem = None
- if locationItem:
- mapsetItem = self._model.SearchNodes(parent=locationItem[0], name=mapset, type='mapset')
+ if not locationItem:
+ return None, None
+ mapsetItem = self._model.SearchNodes(parent=locationItem[0], name=mapset, type='mapset')
+ if not mapsetItem:
+ return locationItem[0], None
+ return locationItem[0], mapsetItem[0]
+ def ExpandCurrentMapset(self):
+ """Expand current mapset"""
if mapsetItem:
- self.Select(mapsetItem[0], select=True)
- self.ExpandNode(mapsetItem[0], recursive=True)
- else:
- Debug.msg(1, "Mapset <%s> not found" % mapset)
+ self.Select(mapsetItem, select=True)
+ self.ExpandNode(mapsetItem, recursive=True)
class DataCatalogTree(LocationMapTree):
@@ -336,7 +385,7 @@
"""Add locations, mapsets and layers to the tree."""
self._initTreeItems()
def OnCopy(self, event):
"""Copy layer or mapset (just save it temporarily, copying is done by paste)"""
self.copy_layer = self.selected_layer
