[GRASS-SVN] r68236 - in grass/branches/releasebranch_7_0: general/g.proj lib/proj raster/r.solute.transport raster3d/r3.gwflow temporal/t.rast.algebra vector/v.out.ogr
Sat Apr 9 09:46:53 PDT 2016
Author: martinl
Date: 2016-04-09 09:46:53 -0700 (Sat, 09 Apr 2016)
New Revision: 68236
   grass/branches/releasebranch_7_0/general/g.proj/datumtrans.c
   grass/branches/releasebranch_7_0/lib/proj/convert.c
   grass/branches/releasebranch_7_0/raster/r.solute.transport/r.solute.transport.html
   grass/branches/releasebranch_7_0/raster3d/r3.gwflow/r3.gwflow.html
   grass/branches/releasebranch_7_0/temporal/t.rast.algebra/t.rast.algebra.html
   grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c
spelling errors (#2985)
         (merge r68235 from trunk)
Modified: grass/branches/releasebranch_7_0/general/g.proj/datumtrans.c
--- grass/branches/releasebranch_7_0/general/g.proj/datumtrans.c	2016-04-09 16:43:25 UTC (rev 68235)
+++ grass/branches/releasebranch_7_0/general/g.proj/datumtrans.c	2016-04-09 16:46:53 UTC (rev 68236)
@@ -91,7 +91,7 @@
  *        co-ordinate system definition
  * \param datumtrans  Index number of parameter set to use, 0 to leave
- *                    unspecifed (or remove specific parameters, leaving just
+ *                    unspecified (or remove specific parameters, leaving just
  *                    the datum name), -1 to list the available parameter
  *                    sets for this datum and exit.
Modified: grass/branches/releasebranch_7_0/lib/proj/convert.c
--- grass/branches/releasebranch_7_0/lib/proj/convert.c	2016-04-09 16:43:25 UTC (rev 68235)
+++ grass/branches/releasebranch_7_0/lib/proj/convert.c	2016-04-09 16:46:53 UTC (rev 68236)
@@ -267,7 +267,7 @@
  * \param hSRS        OGRSpatialReferenceH object containing the co-ordinate
  *                    system to be converted
  * \param datumtrans  Index number of datum parameter set to use, 0 to leave
- *                    unspecifed
+ *                    unspecified
  * \return            2 if a projected or lat/long co-ordinate system has been
  *                    defined
@@ -685,7 +685,7 @@
  * \param wkt         Well-known Text (WKT) description of the co-ordinate
- *                    unspecifed
+ *                    unspecified
  *                    defined
Modified: grass/branches/releasebranch_7_0/raster/r.solute.transport/r.solute.transport.html
--- grass/branches/releasebranch_7_0/raster/r.solute.transport/r.solute.transport.html	2016-04-09 16:43:25 UTC (rev 68235)
+++ grass/branches/releasebranch_7_0/raster/r.solute.transport/r.solute.transport.html	2016-04-09 16:46:53 UTC (rev 68236)
@@ -60,7 +60,7 @@
 The following states are supportet:
 <ul>
-<li>0 == inactive - the cell with status 0 will not be calulated, active cells will have a no flow boundary to an inactive cell</li>
+<li>0 == inactive - the cell with status 0 will not be calculated, active cells will have a no flow boundary to an inactive cell</li>
 <li>1 == active - this cell is used for sloute transport calculation, inner sources can be defined for those cells</li>
 <li>2 == Dirichlet - cells of this type will have a fixed concentration value which do not change over time </li>
 <li>3 == Transmission - cells of this type should be placed on out-flow boundaries to assure the flow of the solute stream out </li>
Modified: grass/branches/releasebranch_7_0/raster3d/r3.gwflow/r3.gwflow.html
--- grass/branches/releasebranch_7_0/raster3d/r3.gwflow/r3.gwflow.html	2016-04-09 16:43:25 UTC (rev 68235)
+++ grass/branches/releasebranch_7_0/raster3d/r3.gwflow/r3.gwflow.html	2016-04-09 16:46:53 UTC (rev 68236)
@@ -47,7 +47,7 @@
 cell states are supported:
 <ul>
 <li>1 == active - this cell is used for groundwater calculation,
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.algebra/t.rast.algebra.html
--- grass/branches/releasebranch_7_0/temporal/t.rast.algebra/t.rast.algebra.html	2016-04-09 16:43:25 UTC (rev 68235)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.algebra/t.rast.algebra.html	2016-04-09 16:46:53 UTC (rev 68236)
@@ -246,7 +246,7 @@
 the related maps.
 For complex relations the comparison operator can be used to combine conditions:
 <br>
-The structure is similar to the select operator with the extention of an aggregation operator:
+The structure is similar to the select operator with the extension of an aggregation operator:
 {"comparison operator", "topological relations", aggregation operator, "temporal operator"}
 <br>
 This aggregation operator (| or &) define the behaviour if a map is related the more
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c	2016-04-09 16:43:25 UTC (rev 68235)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c	2016-04-09 16:46:53 UTC (rev 68236)
@@ -77,7 +77,7 @@
                        * not labeled */
-        /* find correspoding area */
+        /* find corresponding area */
         area = Vect_get_centroid_area(In, centroid);
         if (area == 0)
             continue;
@@ -184,7 +184,7 @@
                                 "Category %d not found in line %d, field %d"),
                               cat, line, field);
             area = Vect_get_centroid_area(In, line);
             if (area == 0)
                 continue;
@@ -241,7 +241,7 @@
                        * not labeled */
 	line = Vect_get_next_line_id(In);
         if (area == 0)
