[GRASS-SVN] r68240 - grass/trunk/scripts/v.report
svn_grass at osgeo.org
Sun Apr 10 04:44:28 PDT 2016
Author: hcho
Date: 2016-04-10 04:44:28 -0700 (Sun, 10 Apr 2016)
New Revision: 68240
grass/trunk/scripts/v.report/v.report.py
v.report: Don't print extra newlines for vectors with no db links
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2016-04-10 03:27:03 UTC (rev 68239)
+++ grass/trunk/scripts/v.report/v.report.py 2016-04-10 11:44:28 UTC (rev 68240)
@@ -145,11 +145,12 @@
#make pre-table
p = grass.pipe_command('v.to.db', flags = 'p',
+ quiet = True,
map = mapname, option = option, columns = columns,
layer = layer, units = unitsp)
records3 = []
for line in p.stdout:
- fields = line.split('|')
+ fields = line.rstrip('\r\n').split('|')
if fields[0] in ['cat', '-1', '0']:
continue
records3.append([int(fields[0])] + fields[1:])
