[GRASS-SVN] r68290 - grass/trunk/raster3d/r3.in.lidar
Wed Apr 20 11:19:45 PDT 2016
Author: wenzeslaus
Date: 2016-04-20 11:19:45 -0700 (Wed, 20 Apr 2016)
New Revision: 68290
Added:
   grass/trunk/raster3d/r3.in.lidar/rast_segment.c
   grass/trunk/raster3d/r3.in.lidar/rast_segment.h
   grass/trunk/raster3d/r3.in.lidar/main.c
   grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
r3.in.lidar: add base raster to reduce height to the ground level (using r.in.lidar code from r66094, r66151, r66593)
Modified: grass/trunk/raster3d/r3.in.lidar/main.c
--- grass/trunk/raster3d/r3.in.lidar/main.c	2016-04-20 16:00:13 UTC (rev 68289)
+++ grass/trunk/raster3d/r3.in.lidar/main.c	2016-04-20 18:19:45 UTC (rev 68290)
@@ -1,3 +1,4 @@
 * MODULE:       r3.in.Lidar
@@ -21,8 +22,19 @@
 #include <grass/glocale.h>
 #include <liblas/capi/liblas.h>
-static void raster3d_set_value_float(RASTER3D_Map *raster, RASTER3D_Region *region, float value)
+#include "rast_segment.h"
+struct PointBinning3D
+    RASTER3D_Region region, flat_region;
+    RASTER3D_Map *count_raster, *sum_raster, *mean_raster;
+    RASTER3D_Map *count_flat_raster, *sum_flat_raster;
+    RASTER3D_Map *prop_count_raster, *prop_sum_raster;
+static void raster3d_set_value_float(RASTER3D_Map * raster,
+                                     RASTER3D_Region * region, float value)
     int col, row, depth;
     for (depth = 0; depth < region->depths; depth++)
@@ -32,7 +44,8 @@
 /* c = a / b */
-static void raster3d_divide(RASTER3D_Map *a, RASTER3D_Map *b, RASTER3D_Map *c, RASTER3D_Region *region)
+static void raster3d_divide(RASTER3D_Map * a, RASTER3D_Map * b,
+                            RASTER3D_Map * c, RASTER3D_Region * region)
     double tmp;
@@ -55,7 +68,9 @@
 /* c = a / b where b has depth 1 */
-static void raster3d_divide_by_flat(RASTER3D_Map *a, RASTER3D_Map *b, RASTER3D_Map *c, RASTER3D_Region *region)
+static void raster3d_divide_by_flat(RASTER3D_Map * a, RASTER3D_Map * b,
+                                    RASTER3D_Map * c,
+                                    RASTER3D_Region * region)
     double tmp;
@@ -78,25 +93,42 @@
+void binning_add_point(struct PointBinning3D binning, int row, int col,
+                       int depth, double value)
+    double tmp;                 /* TODO: check if these should be in binning struct */
+    tmp = Rast3d_get_double(binning.count_raster, col, row, depth);
+    Rast3d_put_double(binning.count_raster, col, row, depth, tmp + 1);
+    tmp = Rast3d_get_double(binning.count_flat_raster, col, row, 0);
+    Rast3d_put_double(binning.count_flat_raster, col, row, 0, tmp + 1);
+    tmp = Rast3d_get_double(binning.sum_raster, col, row, depth);
+    Rast3d_put_double(binning.sum_raster, col, row, depth, tmp + value);
+    tmp = Rast3d_get_double(binning.sum_flat_raster, col, row, 0);
+    Rast3d_put_double(binning.sum_flat_raster, col, row, 0, tmp + value);
 int main(int argc, char *argv[])
     struct GModule *module;
     struct Option *input_opt;
     struct Option *count_output_opt, *sum_output_opt, *mean_output_opt;
     struct Option *prop_count_output_opt, *prop_sum_output_opt;
+    struct Option *base_raster_opt;
+    struct Flag *base_rast_res_flag;
     G_gisinit(argv[0]);
     module = G_define_module();
     G_add_keyword(_("3D raster"));
     G_add_keyword(_("import"));
     G_add_keyword(_("LIDAR"));
-    module->description =
-        _("Creates a 3D raster map from LAS LiDAR points");
+    module->description = _("Creates a 3D raster map from LAS LiDAR points");
     input_opt = G_define_standard_option(G_OPT_F_BIN_INPUT);
     input_opt->required = YES;
     input_opt->label = _("LAS input file");
-    input_opt->description = _("LiDAR input file in LAS format (*.las or *.laz)");
+    input_opt->description =
+        _("LiDAR input file in LAS format (*.las or *.laz)");
     input_opt->guisection = _("Input");
     count_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
@@ -138,10 +170,27 @@
           " vertical column");
     prop_sum_output_opt->guisection = _("Proportional output");
+    base_raster_opt = G_define_standard_option(G_OPT_R_INPUT);
+    base_raster_opt->key = "base_raster";
+    base_raster_opt->required = NO;
+    base_raster_opt->label =
+        _("Subtract raster values from the z coordinates");
+    base_raster_opt->description =
+        _("The scale for z is applied beforehand, the filter afterwards");
+    base_raster_opt->guisection = _("Transform");
+    base_rast_res_flag = G_define_flag();
+    base_rast_res_flag->key = 'd';
+    base_rast_res_flag->description =
+        _("Use base raster actual resolution instead of computational region");
+    G_option_requires(base_rast_res_flag, base_raster_opt, NULL);
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
     LASReaderH LAS_reader;
     LAS_reader = LASReader_Create(input_opt->answer);
     if (LAS_reader == NULL)
         G_fatal_error(_("Unable to open file <%s>"), input_opt->answer);
@@ -149,73 +198,103 @@
     Rast3d_init_defaults();
     Rast3d_set_error_fun(Rast3d_fatal_error_noargs);
-    RASTER3D_Region region, flat_region;
-    RASTER3D_Map *count_raster, *sum_raster, *mean_raster;
-    RASTER3D_Map *count_flat_raster, *sum_flat_raster;
-    RASTER3D_Map *prop_count_raster, *prop_sum_raster;
+    /* TODO: rename */
+    struct Cell_head input_region;
+    SEGMENT base_segment;
+    RASTER_MAP_TYPE base_raster_data_type;
+    int use_segment = FALSE;
+    int use_base_raster_res = FALSE;
-    Rast3d_get_window(&region);
-    Rast3d_get_window(&flat_region);
-    flat_region.depths = 1;
-    Rast3d_adjust_region(&flat_region);
+    if (base_rast_res_flag->answer)
+        use_base_raster_res = TRUE;
+    if (base_raster_opt->answer) {
+        use_segment = TRUE;
+        if (use_base_raster_res) {
+            /* read raster's actual extent and resolution */
+            Rast_get_cellhd(base_raster_opt->answer, "", &input_region);
+            /* TODO: make it only as small as the output */
+            Rast_set_input_window(&input_region);       /* we use split window */
+        else {
+            Rast_get_input_window(&input_region);
+        rast_segment_open(&base_segment, base_raster_opt->answer,
+                          &base_raster_data_type);
-    count_raster = Rast3d_open_new_opt_tile_size(count_output_opt->answer,
-                                           RASTER3D_USE_CACHE_DEFAULT,
-                                           &region, FCELL_TYPE, 32);
-    if (!count_raster)
+    struct PointBinning3D binning;
+    int cache = RASTER3D_USE_CACHE_DEFAULT;
+    int type = FCELL_TYPE;
+    int max_tile_size = 32;
+    Rast3d_get_window(&binning.region);
+    Rast3d_get_window(&binning.flat_region);
+    binning.flat_region.depths = 1;
+    Rast3d_adjust_region(&binning.flat_region);
+    binning.count_raster =
+        Rast3d_open_new_opt_tile_size(count_output_opt->answer, cache,
+                                      &binning.region, type, max_tile_size);
+    if (!binning.count_raster)
         Rast3d_fatal_error(_("Unable to create 3D raster map <%s>"),
                            count_output_opt->answer);
-    sum_raster = Rast3d_open_new_opt_tile_size(sum_output_opt->answer,
-    if (!sum_raster)
+    binning.sum_raster = Rast3d_open_new_opt_tile_size(sum_output_opt->answer,
+                                                       cache,
+                                                       max_tile_size);
+    if (!binning.sum_raster)
                            sum_output_opt->answer);
-    mean_raster = Rast3d_open_new_opt_tile_size(mean_output_opt->answer,
-    if (!mean_raster)
+    binning.mean_raster =
+        Rast3d_open_new_opt_tile_size(mean_output_opt->answer, cache,
+    if (!binning.mean_raster)
                            mean_output_opt->answer);
-    count_flat_raster = Rast3d_open_new_opt_tile_size("r3_in_lidar_tmp_sum_flat",
-                                           &flat_region, FCELL_TYPE, 32);
-    if (!count_flat_raster)
+    binning.count_flat_raster =
+        Rast3d_open_new_opt_tile_size("r3_in_lidar_tmp_sum_flat", cache,
+                                      &binning.flat_region, type,
+                                      max_tile_size);
+    if (!binning.count_flat_raster)
-    sum_flat_raster = Rast3d_open_new_opt_tile_size("r3_in_lidar_tmp_count_flat",
-    if (!sum_flat_raster)
+    binning.sum_flat_raster =
+        Rast3d_open_new_opt_tile_size("r3_in_lidar_tmp_count_flat", cache,
+                                      max_tile_size);
+    if (!binning.sum_flat_raster)
-    prop_count_raster = Rast3d_open_new_opt_tile_size(prop_count_output_opt->answer,
-    if (!prop_count_raster)
+    binning.prop_count_raster =
+        Rast3d_open_new_opt_tile_size(prop_count_output_opt->answer, cache,
+    if (!binning.prop_count_raster)
                            prop_count_output_opt->answer);
-    prop_sum_raster = Rast3d_open_new_opt_tile_size(prop_sum_output_opt->answer,
-    if (!prop_sum_raster)
+    binning.prop_sum_raster =
+        Rast3d_open_new_opt_tile_size(prop_sum_output_opt->answer, cache,
+    if (!binning.prop_sum_raster)
                            prop_sum_output_opt->answer);
-    raster3d_set_value_float(count_raster, &region, 0);
-    raster3d_set_value_float(sum_raster, &region, 0);
-    raster3d_set_value_float(count_flat_raster, &flat_region, 0);
-    raster3d_set_value_float(sum_flat_raster, &flat_region, 0);
+    raster3d_set_value_float(binning.count_raster, &binning.region, 0);
+    raster3d_set_value_float(binning.sum_raster, &binning.region, 0);
+    raster3d_set_value_float(binning.count_flat_raster, &binning.flat_region,
+                             0);
+    raster3d_set_value_float(binning.sum_flat_raster, &binning.flat_region,
+                             0);
     LASPointH LAS_point;
     double east, north, top;
     int row, col, depth;
     double value;
-    double tmp;
+    double base_z;
     /* TODO: use long long */
     long unsigned inside = 0;
     long unsigned outside = 0;
+    long unsigned in_nulls = 0; /* or outside */
     while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
         if (!LASPoint_IsValid(LAS_point))
@@ -225,41 +304,58 @@
         north = LASPoint_GetY(LAS_point);
         top = LASPoint_GetZ(LAS_point);
-        Rast3d_location2coord(&region, north, east, top, &col, &row, &depth);
-        if (col >= region.cols || row >= region.rows || depth >= region.depths
-            || col < 0 || row < 0 || depth < 0) {
+        if (use_segment) {
+            if (rast_segment_get_value_xy(&base_segment, &input_region,
+                                          base_raster_data_type, east, north,
+                                          &base_z)) {
+                top -= base_z;
+            else {
+                in_nulls += 1;
+                continue;
+        Rast3d_location2coord(&binning.region, north, east, top, &col, &row,
+                              &depth);
+        if (col >= binning.region.cols || row >= binning.region.rows ||
+            depth >= binning.region.depths || col < 0 || row < 0 ||
+            depth < 0) {
             outside += 1;
             continue;
         value = LASPoint_GetIntensity(LAS_point);
-        tmp = Rast3d_get_double(count_raster, col, row, depth);
-        Rast3d_put_double(count_raster, col, row, depth, tmp + 1);
-        tmp = Rast3d_get_double(count_flat_raster, col, row, 0);
-        Rast3d_put_double(count_flat_raster, col, row, 0, tmp + 1);
-        tmp = Rast3d_get_double(sum_raster, col, row, depth);
-        Rast3d_put_double(sum_raster, col, row, depth, tmp + value);
-        tmp = Rast3d_get_double(sum_flat_raster, col, row, 0);
-        Rast3d_put_double(sum_flat_raster, col, row, 0, tmp + value);
+        binning_add_point(binning, row, col, depth, value);
         inside += 1;
-    raster3d_divide_by_flat(count_raster, count_flat_raster, prop_count_raster, &region);
-    raster3d_divide_by_flat(sum_raster, sum_flat_raster, prop_sum_raster, &region);
+    raster3d_divide_by_flat(binning.count_raster, binning.count_flat_raster,
+                            binning.prop_count_raster, &binning.region);
+    raster3d_divide_by_flat(binning.sum_raster, binning.sum_flat_raster,
+                            binning.prop_sum_raster, &binning.region);
-    raster3d_divide(sum_raster, count_raster, mean_raster, &region);
+    raster3d_divide(binning.sum_raster, binning.count_raster,
+                    binning.mean_raster, &binning.region);
-    G_message("Number of point inside: %lu", inside);
-    G_message("Number of point outside: %lu", outside);
+    G_message("Number of points inside: %lu", inside);
+    if (use_segment)
+        G_message
+            ("Number of points outside or in base raster NULL cells: %lu",
+             outside + in_nulls);
+    else
+        G_message("Number of points outside: %lu", outside);
-    Rast3d_close(prop_sum_raster);
-    Rast3d_close(prop_count_raster);
-    Rast3d_close(sum_flat_raster);  /* TODO: delete */
-    Rast3d_close(count_flat_raster);  /* TODO: delete */
-    Rast3d_close(mean_raster);
-    Rast3d_close(sum_raster);
-    Rast3d_close(count_raster);
+    Rast3d_close(binning.prop_sum_raster);
+    Rast3d_close(binning.prop_count_raster);
+    Rast3d_close(binning.sum_flat_raster);      /* TODO: delete */
+    Rast3d_close(binning.count_flat_raster);    /* TODO: delete */
+    Rast3d_close(binning.mean_raster);
+    Rast3d_close(binning.sum_raster);
+    Rast3d_close(binning.count_raster);
+    if (use_segment)
+        Segment_close(&base_segment);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
--- grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html	2016-04-20 16:00:13 UTC (rev 68289)
+++ grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html	2016-04-20 18:19:45 UTC (rev 68290)
@@ -56,7 +56,31 @@
     proportional_sum=points_sum_prop
 </pre></div>
+<h3>Point density vertical structure reduced to the terrain</h3>
+Create ground raster:
+<div class="code"><pre>
+r.in.lidar input=points.las output=ground method=mean class_filter=2
+</pre></div>
+Set vertical extent of computational region to (relative) coordinates
+above ground:
+g.region rast=secref b=0 t=47 -p3
+</pre></div>
+Compute point density:
+r3.in.lidar input=points.las n=points_n sum=points_sum \
+    mean=points_mean proportional_n=points_n_prop \
+    proportional_sum=points_sum_prop \
+    base_raster=ground
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Copied: grass/trunk/raster3d/r3.in.lidar/rast_segment.c (from rev 68277, grass/trunk/raster/r.in.lidar/rast_segment.c)
--- grass/trunk/raster3d/r3.in.lidar/rast_segment.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/rast_segment.c	2016-04-20 18:19:45 UTC (rev 68290)
@@ -0,0 +1,86 @@
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+#include <grass/segment.h>
+static void rast_segment_load(SEGMENT * segment, int rowio,
+                              RASTER_MAP_TYPE map_type)
+    void *raster_row = Rast_allocate_input_buf(map_type);
+    int row;
+    for (row = 0; row < Rast_input_window_rows(); row++) {
+        /* TODO: free mem */
+        Rast_get_row(rowio, raster_row, row, map_type);
+        Segment_put_row(segment, raster_row, row);
+/* TODO: close function */
+void rast_segment_open(SEGMENT * segment, const char *name,
+                       RASTER_MAP_TYPE * map_type)
+    /* TODO: check if not passing the mapset is OK */
+    int rowio = Rast_open_old(name, "");
+    *map_type = Rast_get_map_type(rowio);
+    int segment_rows = 64;
+    /* we use long segments because this is how the values a binned */
+    int segment_cols = Rast_input_window_cols();
+    int segments_in_memory = 4;
+    if (Segment_open(segment, G_tempfile(), Rast_input_window_rows(),
+                     Rast_input_window_cols(), segment_rows, segment_cols,
+                     Rast_cell_size(*map_type), segments_in_memory) != 1)
+        G_fatal_error(_("Cannot create temporary file with segments of a raster map"));
+    rast_segment_load(segment, rowio, *map_type);
+    Rast_close(rowio);          /* we won't need the raster again */
+/* 0 on out of region or NULL, 1 on success */
+int rast_segment_get_value_xy(SEGMENT * base_segment,
+                              struct Cell_head *input_region,
+                              RASTER_MAP_TYPE rtype, double x, double y,
+                              double *value)
+    /* Rast gives double, Segment needs off_t */
+    off_t base_row = Rast_northing_to_row(y, input_region);
+    off_t base_col = Rast_easting_to_col(x, input_region);
+    /* skip points which are outside the base raster
+     * (null propagation) */
+    if (base_row < 0 || base_col < 0 ||
+        base_row >= input_region->rows || base_col >= input_region->cols)
+        return 0;
+    if (rtype == DCELL_TYPE) {
+        DCELL tmp;
+        Segment_get(base_segment, &tmp, base_row, base_col);
+        if (Rast_is_d_null_value(&tmp))
+            return 0;
+        *value = (double)tmp;
+    else if (rtype == FCELL_TYPE) {
+        FCELL tmp;
+        if (Rast_is_f_null_value(&tmp))
+            return 0;
+    else {
+        CELL tmp;
+        if (Rast_is_c_null_value(&tmp))
+            return 0;
+    return 1;
Copied: grass/trunk/raster3d/r3.in.lidar/rast_segment.h (from rev 68277, grass/trunk/raster/r.in.lidar/rast_segment.h)
--- grass/trunk/raster3d/r3.in.lidar/rast_segment.h	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/rast_segment.h	2016-04-20 18:19:45 UTC (rev 68290)
@@ -0,0 +1,14 @@
+#ifndef GRASS_RAST_SEGMENT_H
+#define GRASS_RAST_SEGMENT_H
+                       RASTER_MAP_TYPE * map_type);
+                              double *value);
+#endif /* GRASS_RAST_SEGMENT_H */
