[GRASS-SVN] r68298 - grass-addons/grass7/imagery/i.landsat8.swlst
Thu Apr 21 10:15:49 PDT 2016
Author: hellik
Date: 2016-04-21 10:15:49 -0700 (Thu, 21 Apr 2016)
New Revision: 68298
   grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html
i.landsat8.swlst.html: fix typo
Modified: grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html
--- grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html	2016-04-21 15:18:23 UTC (rev 68297)
+++ grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html	2016-04-21 17:15:49 UTC (rev 68298)
@@ -1,5 +1,5 @@
 <h2 id="description">DESCRIPTION</h2>
-<p><em>i.landsat8.swlst</em> is an implementation of a robust and practical Slit-Window (SW) algorithm estimating land surface temperature (LST), from the Thermal Infra-Red Sensor (TIRS) aboard Landsat 8 with an accuracy of better than 1.0 K. [1]</p>
+<p><em>i.landsat8.swlst</em> is an implementation of a robust and practical Split-Window (SW) algorithm estimating land surface temperature (LST), from the Thermal Infra-Red Sensor (TIRS) aboard Landsat 8 with an accuracy of better than 1.0 K. [1]</p>
 <h3 id="overview">Overview</h3>
 <p>The components of the algorithm estimating LST values are at-satellite brightness temperature (BT); land surface emissivity (LSE); and the coefficients of the main Split-Window equation (SWC).</p>
 <p>LSEs are derived from an established look-up table linking the FROM-GLC classification scheme to average emissivities. The NDVI and the FVC are <em>not</em> computed each time an LST estimation is requested. Read [0] for details.</p>
