[GRASS-SVN] r68301 - grass/trunk/scripts/r.fillnulls
Fri Apr 22 08:02:05 PDT 2016
Author: wenzeslaus
Date: 2016-04-22 08:02:05 -0700 (Fri, 22 Apr 2016)
New Revision: 68301
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
r.fillnulls: add lambda parameter of r.resamp.bspline (#1088) [news]
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2016-04-22 07:17:28 UTC (rev 68300)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2016-04-22 15:02:05 UTC (rev 68301)
@@ -14,7 +14,7 @@
 # PURPOSE:      fills NULL (no data areas) in raster maps
 #               The script respects a user mask (MASK) if present.
-# COPYRIGHT:    (C) 2001-2014 by the GRASS Development Team
+# COPYRIGHT:    (C) 2001-2016 by the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
@@ -84,7 +84,18 @@
 #% options : 2-10000
 #% guisection: RST options
 #%end
+#%option
+#% key: lambda
+#% type: double
+#% required: no
+#% multiple: no
+#% label: Tykhonov regularization parameter (affects smoothing)
+#% description: Used in bilinear and bicubic spline interpolation
+#% answer: 0.01
+#% guisection: Spline options
+#%end
 import sys
 import os
 import atexit
@@ -119,6 +130,7 @@
     edge = int(options['edge'])
     segmax = int(options['segmax'])
     npmin = int(options['npmin'])
+    lambda_ = float(options['lambda'])
     quiet = True # FIXME
     mapset = grass.gisenv()['MAPSET']
@@ -392,12 +404,12 @@
             grass.run_command('r.resamp.bspline', input = input, mask = usermask,
                 output = prefix + 'filled', method = method,
                 ew_step = 3 * reg['ewres'], ns_step = 3 * reg['nsres'],
-                lambda_ = 0.01, flags = 'n')
+                lambda_=lambda_, flags='n')
         else:
     # restoring user's mask, if present:
     if usermask:
