[GRASS-SVN] r68303 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Sun Apr 24 09:51:02 PDT 2016
Author: neteler
Date: 2016-04-24 09:51:02 -0700 (Sun, 24 Apr 2016)
New Revision: 68303
grass/trunk/general/g.proj/g.proj.html
g.proj manual: sub headings for examples
Modified: grass/trunk/general/g.proj/g.proj.html
--- grass/trunk/general/g.proj/g.proj.html 2016-04-24 16:28:34 UTC (rev 68302)
+++ grass/trunk/general/g.proj/g.proj.html 2016-04-24 16:51:02 UTC (rev 68303)
@@ -110,19 +110,32 @@
<h2>EXAMPLES</h2>
+<h3>Print information</h3>
Print the projection information for the current location:<br>
<div class="code"><pre>
g.proj -p
</pre></div>
-<p>Create a '.prj' file in ESRI format corresponding to the current location:<br>
+<p>
+List the possible datum transformation parameters for the current location:<br>
+g.proj -t datumtrans=-1
+</pre></div>
+<h3>Create projection (PRJ) file</h3>
+Create a '.prj' file in ESRI format corresponding to the current location:<br>
+<div class="code"><pre>
g.proj -wef > irish_grid.prj
</pre></div>
-<p>Read the projection information from a geotiff file and print it in PROJ.4
+<h3>Read projection from file</h3>
+Read the projection information from a GeoTIFF file and print it in PROJ.4
format:<br>
@@ -136,6 +149,8 @@
cat proj4.description | g.proj -w proj4=-
</pre></div>
+<h3>Create new location</h3>
<p>Create a new location with the co-ordinate system referred to by EPSG code
4326 (Latitude-Longitude/WGS84), without explicitly specifying datum
transformation parameters:<br>
@@ -155,6 +170,8 @@
29900 (Irish Grid), selecting datum transformation parameter set no. 2:<br>
+# list available datums for EPSG code 29900
+g.proj -t datumtrans=-1 epsg=29900
g.proj -c epsg=29900 datumtrans=2 location=irish_grid
</pre></div>
@@ -165,12 +182,6 @@
g.proj -c location=newloc -t datumtrans=1
</pre></div>
-<p>List the possible datum transformation parameters for the current location:<br>
-<div class="code"><pre>
-g.proj -t datumtrans=-1
-</pre></div>
<p>Create a new location with the co-ordinate system from a WKT definition
stored in a text file:<br>
@@ -186,6 +197,8 @@
g.proj -c location=spain proj4="+proj=utm +zone=30 +ellps=intl" datum=eur50 datumtrans=0
</pre></div>
+<h3>Using g.proj output for GDAL/OGR tools</h3>
<p>Reproject external raster map to current GRASS projection (does not always make sense!)
using the GDAL 'gdalwarp' tool. We recommend to use the ERDAS/Img format and not
to use the ESRI style of WKT:<br>
