[GRASS-SVN] r68309 - grass/trunk/raster/r.in.xyz
Mon Apr 25 16:10:14 PDT 2016
Author: neteler
Date: 2016-04-25 16:10:14 -0700 (Mon, 25 Apr 2016)
New Revision: 68309
   grass/trunk/raster/r.in.xyz/r.in.xyz.html
r.in.xyz manual: example for x,y,z ASCII file import
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html	2016-04-25 22:11:51 UTC (rev 68308)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html	2016-04-25 23:10:14 UTC (rev 68309)
@@ -202,8 +202,35 @@
 coordinate as a fake z column for <b>method</b>=<tt>n</tt> (count
 number of points per grid cell), the z values are ignored anyway.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
+<h3>Import of x,y,z ASCII into DEM</h3>
+Sometimes elevation data are delivered as x,y,z ASCII files instead of
+a raster matrix:
+<div class="code"><pre>
+# ASCII file format (example):
+# 630007.5 228492.5 141.99614
+# 630022.5 228492.5 141.37904
+# 630037.5 228492.5 142.29822
+# 630052.5 228492.5 143.97987
+# detect extent, print result as g.region parameters
+r.in.xyz input=elevation.xyz separator=space -s output=dummy -g
+# ... n=228492.5 s=215007.5 e=644992.5 w=630007.5 b=55.578793 t=156.32986
+# set computational region
+g.region n=228492.5 s=215007.5 e=644992.5 w=630007.5 -p
+# import XYZ ASCII file, with z values as raster cell values
+r.in.xyz input=elevation.xyz separator=space method=mean output=myelev
+# univariate statistics for verification of raster values
+r.univar myelev
+</pre></div>
+<h3>Import of LiDAR data and DEM creation</h3>
 Import the <a href="http://www.grassbook.org/ncexternal/index.html">Jockey's
 Ridge, NC, LIDAR dataset</a> (compressed file "lidaratm2.txt.gz"), and process it
 into a clean DEM:
