[GRASS-SVN] r68324 - grass/branches/releasebranch_7_0/vector/v.db.select
svn_grass at osgeo.org
Thu Apr 28 04:17:32 PDT 2016
Author: martinl
Date: 2016-04-28 04:17:32 -0700 (Thu, 28 Apr 2016)
New Revision: 68324
grass/branches/releasebranch_7_0/vector/v.db.select/main.c
v.db.select: use DB_SQL_MAX rather than hardcoded values - see r68321
Modified: grass/branches/releasebranch_7_0/vector/v.db.select/main.c
--- grass/branches/releasebranch_7_0/vector/v.db.select/main.c 2016-04-28 11:15:22 UTC (rev 68323)
+++ grass/branches/releasebranch_7_0/vector/v.db.select/main.c 2016-04-28 11:17:32 UTC (rev 68324)
@@ -43,7 +43,7 @@
struct field_info *Fi;
int ncols, col, more;
struct Map_info Map;
- char query[4096];
+ char query[DB_SQL_MAX];
struct ilist *list_lines;
char *fs, *vs;
struct bound_box *min_box, *line_box;
