[GRASS-SVN] r68328 - in grass-addons/grass7/imagery: . i.lswt
Fri Apr 29 03:30:35 PDT 2016
Author: spareeth
Date: 2016-04-29 03:30:35 -0700 (Fri, 29 Apr 2016)
New Revision: 68328
Added:
   grass-addons/grass7/imagery/i.lswt/
   grass-addons/grass7/imagery/i.lswt/Makefile
   grass-addons/grass7/imagery/i.lswt/i.lswt.html
   grass-addons/grass7/imagery/i.lswt/i.lswt.py
i.lswt: add new addon to compute lake surface water temperature from moderate resolution satellite data
Added: grass-addons/grass7/imagery/i.lswt/Makefile
--- grass-addons/grass7/imagery/i.lswt/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.lswt/Makefile	2016-04-29 10:30:35 UTC (rev 68328)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.lswt
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/imagery/i.lswt/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/imagery/i.lswt/i.lswt.html
--- grass-addons/grass7/imagery/i.lswt/i.lswt.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.lswt/i.lswt.html	2016-04-29 10:30:35 UTC (rev 68328)
@@ -0,0 +1,46 @@
+<h2>DESCRIPTION</h2>
+<em>i.lswt</em> computes Lake Water Surface Temperature (LSWT) from
+moderate resolution polar orbiting satellites with dual thermal channels.
+Given the Top Of Atmosphere(TOA) Brightness Temperatures (BT) derived
+from the thermal channels of the supported satellites, the module
+computes surface temperature. For water surface
+(lakes/inland water bodies), the module uses a simplified
+non-linear split-window algorithm.
+<h2>NOTES</h2>
+The non-linear split window equation used here is:
+<div class="code"><pre>LSWT = Ti + c1 * (Ti - Tj) + c2 * (Ti - Tj) ^ 2 + c0</pre></div>
+Where Ti and Tj are Brightness temperatures derived from dual thermal
+channels 10.5 - 11.5 micro m and 11.5 - 12.5 micro m respectively.
+The split window equation and the coefficients c0,c1,c2 are taken from Jimenez-Munoz et.al (2008).
+<h2>EXAMPLE</h2>
+r.mask vect=watermask cats=1 --o
+i.lswt in1=NSS.LHRR.NP.D14177.S1312_b4 in2=NSS.LHRR.NP.D14177.S1312_b5 basename=NSS.LHRR.NP.D14177.S1312 satellite=NOAA19-AVHRR
+</pre></div>
+<h2>REFERENCES</h2>
+The satellite specific split-window coefficients are taken from:
+<ul>
+<li>Jimenez-Munoz, J.-C., Sobrino, J.A., 2008. Split-Window Coefficients for Land Surface Temperature Retrieval From Low-Resolution Thermal Infrared Sensors.
+IEEE Geoscience and Remote Sensing Letters 5, 806-809. doi:10.1109/LGRS.2008.2001636
+</ul>
+A new method to develop continuos time series of LSWT from historical AVHRR is explained below, uses the same split window technique implemented here:
+<ul>
+<li>Pareeth, S., Delucchi, L., Metz, M., Rocchini, D., Devasthale, A., Raspaud, M., Adrian, R., Salmaso, N., Neteler, M., 2016.
+New Automated Method to Develop Geometrically Corrected Time Series of Brightness Temperatures from Historical AVHRR LAC Data. Remote Sensing 8, 169.
+doi:10.3390/rs8030169
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="i.landsat8.swlst.html">i.landsat8.swlst</a>,
+  <a href="i.emissivity.html">i.emissivity</a>
+</em>
+<h2>AUTHORS</h2>
+Sajid Pareeth; Fondazione Edmund Mach
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/imagery/i.lswt/i.lswt.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/imagery/i.lswt/i.lswt.py
--- grass-addons/grass7/imagery/i.lswt/i.lswt.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.lswt/i.lswt.py	2016-04-29 10:30:35 UTC (rev 68328)
@@ -0,0 +1,151 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	i.lswt
+# AUTHOR(S):	Sajid Pareeth
+# PURPOSE:	Compute Lake Surface Water Temperature (inland waters) from TOA Brightness Temperatures(BT)
+# COPYRIGHT:	(C) 1997-2014 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+# References:
+# The satellite specific split-window coefficients are taken from:
+# Jimenez-Munoz, J.-C., Sobrino, J.A., 2008. Split-Window Coefficients for
+# Land Surface Temperature Retrieval From Low-Resolution Thermal Infrared Sensors.
+# IEEE Geoscience and Remote Sensing Letters 5, 806–809. doi:10.1109/LGRS.2008.2001636
+# A new method to develop continuos time series of LSWT from historical AVHRR
+# is explained below, uses the same split window technique implemented here:
+# Pareeth, S., Delucchi, L., Metz, M., Rocchini, D., Devasthale, A., Raspaud,
+# M., Adrian, R., Salmaso, N., Neteler, M., 2016.
+# New Automated Method to Develop Geometrically Corrected Time Series of
+# Brightness Temperatures from Historical AVHRR LAC Data. Remote Sensing 8, 169
+# doi:10.3390/rs8030169
+#%Module
+#% description: Compute LSWT from TOA Brightness Temperatures
+#% keyword: imagery
+#% keyword: LSWT
+#% keyword: MODIS
+#% keyword: AVHRR
+#% keyword: AATSR
+#% keyword: SEVIRI
+#% keyword: IMG
+#%end
+#%option G_OPT_R_INPUT
+#% key: ainput
+#% description: Brightness Temperature (10.5 - 11.5 micro m)
+#%end
+#% key: binput
+#% description: Brightness Temperature (11.5 - 12.5 micro m)
+#%end
+#%option G_OPT_R_BASENAME_OUTPUT
+#% key: basename
+#% description: Name for output basename raster map(s)
+#%end
+#%option
+#% key: satellite
+#% type: string
+#% description: Satellite name
+#% required: yes
+#% multiple: no
+#% options: NOAA07-AVHRR,NOAA09-AVHRR,NOAA11-AVHRR,NOAA12-AVHRR,NOAA14-AVHRR,NOAA15-AVHRR,NOAA16-AVHRR,NOAA17-AVHRR,NOAA18-AVHRR,NOAA19-AVHRR,METOPA-AVHRR,ERS1-ATSR1,ERS2-ATSR2,Envisat-AATSR,Terra-MODIS,Aqua-MODIS,GOES8-IMG,GOES9-IMG,GOES10-IMG,GOES11-IMG,GOES12-IMG,GOES13-IMG,MSG1-SEVIRI,MSG2-SEVIRI
+#% descriptions: NOAA07-AVHRR;Use split-window coefficients for NOAA07-AVHRR;
+#%end
+#%flag
+#% key: i
+#% description: Display split-window coefficients and exit
+#%end
+import grass.script as grass
+coeffs = {
+    'NOAA07-AVHRR': {'c0': [-0.060], 'c1': [1.752], 'c2': [0.326],
+                     'c3': [45.2], 'c4': [-0.88], 'c5': [-152], 'c6': [18.9]},
+    'NOAA09-AVHRR': {'c0': [-0.003], 'c1': [2.054], 'c2': [0.333],
+                     'c3': [47.3], 'c4': [-1.64], 'c5': [-164], 'c6': [20.6]},
+    'NOAA11-AVHRR': {'c0': [-0.037], 'c1': [1.897], 'c2': [0.329],
+                     'c3': [46.3], 'c4': [-1.30], 'c5': [-158], 'c6': [19.7]},
+    'NOAA12-AVHRR': {'c0': [0.027], 'c1': [1.602], 'c2': [0.352],
+                     'c3': [42.5], 'c4': [0.04], 'c5': [-147], 'c6': [18.1]},
+    'NOAA14-AVHRR': {'c0': [0.025], 'c1': [1.458], 'c2': [0.273],
+                     'c3': [44.0], 'c4': [-0.47], 'c5': [-133], 'c6': [16.4]},
+    'NOAA15-AVHRR': {'c0': [-0.031], 'c1': [1.826], 'c2': [0.327],
+                     'c3': [44.7], 'c4': [-0.71], 'c5': [-155], 'c6': [19.3]},
+    'NOAA16-AVHRR': {'c0': [-0.110], 'c1': [1.277], 'c2': [0.321],
+                     'c3': [40.1], 'c4': [0.86], 'c5': [-134], 'c6': [16.3]},
+    'NOAA17-AVHRR': {'c0': [-0.032], 'c1': [1.783], 'c2': [0.311],
+                     'c3': [45.1], 'c4': [-0.87], 'c5': [-151], 'c6': [18.9]},
+    'NOAA18-AVHRR': {'c0': [-0.098], 'c1': [1.281], 'c2': [0.276],
+                     'c3': [42.0], 'c4': [0.18], 'c5': [-129], 'c6': [15.7]},
+    'NOAA19-AVHRR': {'c0': [-0.031], 'c1': [1.212], 'c2': [0.235],
+                     'c3': [41.03], 'c4': [0.450], 'c5': [-120.24], 'c6': [14.77]},
+    'METOPA-AVHRR': {'c0': [-0.045], 'c1': [1.733], 'c2': [0.307],
+                     'c3': [44.3], 'c4': [-0.61], 'c5': [-150], 'c6': [18.7]},
+    'ERS1-ATSR1': {'c0': [-0.131], 'c1': [1.697], 'c2': [0.427],
+                   'c3': [42.58], 'c4': [0.026], 'c5': [-159.88], 'c6': [19.62]},
+    'ERS2-ATSR2': {'c0': [-0.151], 'c1': [1.064], 'c2': [0.342],
+                   'c3': [37.1], 'c4': [1.81], 'c5': [-131], 'c6': [15.7]},
+    'Envisat-AATSR': {'c0': [-0.172], 'c1': [1.016], 'c2': [0.299],
+                      'c3': [39.7], 'c4': [0.97], 'c5': [-124], 'c6': [14.8]},
+    'Terra-MODIS': {'c0': [-0.004], 'c1': [2.625], 'c2': [0.424],
+                    'c3': [41.4], 'c4': [0.04], 'c5': [-201], 'c6': [26.6]},
+    'Aqua-MODIS': {'c0': [0.012], 'c1': [2.601], 'c2': [0.424],
+                   'c3': [41.3], 'c4': [0.14], 'c5': [-199], 'c6': [26.3]},
+    'GOES8-IMG': {'c0': [0.048], 'c1': [1.447], 'c2': [0.244],
+                  'c3': [45.4], 'c4': [-0.97], 'c5': [-129], 'c6': [15.8]},
+    'GOES9-IMG': {'c0': [-0.011], 'c1': [1.335], 'c2': [0.236],
+                  'c3': [44.2], 'c4': [-0.53], 'c5': [-124], 'c6': [15.3]},
+    'GOES10-IMG': {'c0': [-0.111], 'c1': [1.083], 'c2': [0.219],
+                   'c3': [43.0], 'c4': [-0.21], 'c5': [-114], 'c6': [13.9]},
+    'GOES11-IMG': {'c0': [-0.030], 'c1': [1.275], 'c2': [0.245],
+                   'c3': [43.0], 'c4': [-0.15], 'c5': [-123], 'c6': [15.1]},
+    'GOES12-IMG': {'c0': [1.815], 'c1': [-0.311], 'c2': [0.020],
+                   'c3': [-46.3], 'c4': [27.26], 'c5': [-50], 'c6': [7.6]},
+    'GOES13-IMG': {'c0': [1.833], 'c1': [-0.331], 'c2': [0.022],
+                   'c3': [-40.7], 'c4': [25.64], 'c5': [-51], 'c6': [7.9]},
+    'MSG1-SEVIRI': {'c0': [0.006], 'c1': [1.736], 'c2': [0.297],
+                    'c3': [45.3], 'c4': [-0.97], 'c5': [-147], 'c6': [18.3]},
+    'MSG2-SEVIRI': {'c0': [-0.021], 'c1': [1.503], 'c2': [0.273],
+                    'c3': [44.2], 'c4': [-0.58], 'c5': [-135], 'c6': [16.7]}
+def main():
+    options, flags = grass.parser()
+    bt1 = options['ainput']
+    bt2 = options['binput']
+    basename = options['basename']
+    output = basename + '_lswt'
+    satellite = options['satellite']
+    c0 = coeffs.get(satellite).get('c0')[0]
+    c1 = coeffs.get(satellite).get('c1')[0]
+    c2 = coeffs.get(satellite).get('c2')[0]
+    coeff = flags['i']
+    if coeff:
+        grass.message("Split window coefficients for {satellite} are "
+                      "c0={c0};c1={c1};c2={c2}".format(satellite=satellite,
+                                                       c0=c0, c1=c1, c2=c2))
+        return
+    elif (bool(bt1) == 0) or (bool(bt2) == 0) or (bool(basename) == 0):
+        # logging.error('error: ', message)
+        grass.error('in1, in2 and basename are required for computing lswt')
+    else:
+        grass.message("Computing water surface temperature - Remember to set"
+                      " water mask: Output file is {basename}_lswt".format(basename=basename))
+        # Split window equation for water surface
+        grass.mapcalc(exp="{out} = {bt1} + {c1} * ({bt1} - {bt2}) + {c2} *"
+                          " ({bt1} - {bt2})^2 + {c0}".format(out=output,
+                                                             bt1=bt1, bt2=bt2,
+if __name__ == '__main__':
+    main()
Property changes on: grass-addons/grass7/imagery/i.lswt/i.lswt.py
Added: svn:executable
   + text/x-python
   + native
