[GRASS-SVN] r68338 - grass/branches/releasebranch_7_0/vector/v.net
svn_grass at osgeo.org
Sat Apr 30 11:59:58 PDT 2016
Author: neteler
Date: 2016-04-30 11:59:58 -0700 (Sat, 30 Apr 2016)
New Revision: 68338
grass/branches/releasebranch_7_0/vector/v.net/v.net.html
v.net manual: fix example
Modified: grass/branches/releasebranch_7_0/vector/v.net/v.net.html
--- grass/branches/releasebranch_7_0/vector/v.net/v.net.html 2016-04-30 18:59:21 UTC (rev 68337)
+++ grass/branches/releasebranch_7_0/vector/v.net/v.net.html 2016-04-30 18:59:58 UTC (rev 68338)
@@ -39,7 +39,7 @@
category. In order to assign unique costs to each line, a new layer
needs to be created with<br>
<!-- like this it is rather useless, still to be improved (eg as a full example below!) -->
-<tt>v.category map=yourmap operation=add cat=1 step=1 layer=3</tt><br>
+<tt>v.category map=yourmap option=add cat=1 step=1 layer=3</tt><br>
followed by<br>
<tt>v.db.addtable map=yourmap layer=3 table=tablename</tt>.</li>
@@ -132,7 +132,7 @@
<div class="code"><pre>
v.net input=streets_wake output=streets_node operation=nodes
# verify result
-v.category streets_node operation=report
+v.category streets_node option=report
</pre></div>
<h3>Merge in nodes from a separate map within given threshold</h3>
@@ -141,7 +141,7 @@
v.net input=streets_wake points=firestations out=streets_net \
operation=connect threshold=500
# verify result
-v.category streets_net operation=report
+v.category streets_net option=report
</pre></div>
The nodes are stored in layer 2 unless <tt>node_layer=1</tt> is used.
@@ -161,7 +161,7 @@
v.net points=geodetic_swwake_pts output=geodetic_swwake_pts_net \
operation=arcs file=points.txt
# verify result
-v.category geodetic_swwake_pts_net operation=report
+v.category geodetic_swwake_pts_net option=report
</pre></div>
<p>
@@ -175,7 +175,7 @@
EOF
# verify result
</pre></div>
<h2>SEE ALSO</h2>
