[GRASS-SVN] r68341 - grass/trunk/lib/proj
Sat Apr 30 14:08:30 PDT 2016
Author: neteler
Date: 2016-04-30 14:08:30 -0700 (Sat, 30 Apr 2016)
New Revision: 68341
Removed:
   grass/trunk/lib/proj/coordinate_axis.csv
   grass/trunk/lib/proj/ellipsoid.csv
   grass/trunk/lib/proj/gcs.csv
   grass/trunk/lib/proj/gcs.override.csv
   grass/trunk/lib/proj/gdal_datum.csv
   grass/trunk/lib/proj/gt_datum.csv
   grass/trunk/lib/proj/gt_ellips.csv
   grass/trunk/lib/proj/iau2000.csv
   grass/trunk/lib/proj/iau2009.csv
   grass/trunk/lib/proj/pcs.csv
   grass/trunk/lib/proj/pcs.override.csv
   grass/trunk/lib/proj/prime_meridian.csv
   grass/trunk/lib/proj/projop_wparm.csv
   grass/trunk/lib/proj/stateplane.csv
   grass/trunk/lib/proj/unit_of_measure.csv
   grass/trunk/lib/proj/Makefile
   grass/trunk/lib/proj/README.txt
libproj: outdated CSV files removed (trac #2456)
Modified: grass/trunk/lib/proj/Makefile
--- grass/trunk/lib/proj/Makefile	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/Makefile	2016-04-30 21:08:30 UTC (rev 68341)
@@ -16,16 +16,12 @@
 NT_TABLES = ntv1_can.dat nzgd2kgrid0005.gsb
-#CSV_FILES := $(wildcard *.csv)
 PROJ_DIR = $(ETC)/proj
 NAD_DIR  = $(ETC)/proj/nad
-#CSV_DIR  = $(ETC)/proj/ogr_csv
 NAD_DSTFILES := $(patsubst %.lla,$(NAD_DIR)/%,$(NAD_TABLES))
 NAD_BINFILES := $(patsubst %.lla,$(OBJDIR)/%,$(NAD_TABLES))
 NT_DSTFILES  := $(patsubst %,$(NAD_DIR)/%,$(NT_TABLES))
-#CSV_DSTFILES := $(patsubst %,$(CSV_DIR)/%,$(CSV_FILES))
 NAD_SRCDIR = $(ETC)/proj/nad/src
 NAD_SRCFILES := $(patsubst %.lla,$(NAD_SRCDIR)/%.lla,$(NAD_TABLES))
@@ -36,8 +32,6 @@
 default: lib $(FTOL_OBJ)
 	$(MAKE) $(NAD_DSTFILES) $(PROJ_DSTFILES) $(NAD_SRCFILES)
-#  $(CSV_DSTFILES)
 ifdef MINGW
 $(FTOL_OBJ): $(OBJDIR)/ftol.o
 	$(INSTALL) $< $@
@@ -52,9 +46,6 @@
 $(NT_DSTFILES): $(NAD_DIR)/%: % | $(NAD_DIR)
 	$(INSTALL_DATA) $< $@
-#$(CSV_DSTFILES): $(CSV_DIR)/%.csv: %.csv | $(CSV_DIR)
-#	$(INSTALL_DATA) $< $@
 $(NAD_SRCFILES): $(NAD_SRCDIR)/%.lla: %.lla | $(NAD_SRCDIR)
@@ -67,9 +58,6 @@
 $(NAD_DIR): | $(PROJ_DIR)
 	$(MKDIR) $@
-#$(CSV_DIR): | $(PROJ_DIR)
-#	$(MKDIR) $@
 $(NAD_SRCDIR): | $(PROJ_DIR)
 	$(MKDIR) $@
Modified: grass/trunk/lib/proj/README.txt
--- grass/trunk/lib/proj/README.txt	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/README.txt	2016-04-30 21:08:30 UTC (rev 68341)
@@ -4,5 +4,5 @@
 according to this procedure:
 http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
-alternative:
-ls `gdal-config --datadir`
+The CSV files are used via GDAL/OGR API from
+gdal-config --datadir
Deleted: grass/trunk/lib/proj/coordinate_axis.csv
--- grass/trunk/lib/proj/coordinate_axis.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/coordinate_axis.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,231 +0,0 @@
-coord_sys_code,coord_axis_name_code,coord_axis_orientation,coord_axis_abbreviation,uom_code,coord_axis_order
-4400,9906,east,E,9001,1
-4400,9907,north,N,9001,2
-4401,9906,east,E,9062,1
-4401,9907,north,N,9062,2
-4402,9906,east,E,9042,1
-4402,9907,north,N,9042,2
-4403,9906,east,E,9005,1
-4403,9907,north,N,9005,2
-4404,9906,east,E,9094,1
-4404,9907,north,N,9094,2
-4405,9906,east,E,9041,1
-4405,9907,north,N,9041,2
-4406,9906,east,X,9036,1
-4406,9907,north,Y,9036,2
-4407,9906,east,E,9039,1
-4407,9907,north,N,9039,2
-4408,9906,east,E,9084,1
-4408,9907,north,N,9084,2
-4409,9906,east,E,9040,1
-4409,9907,north,N,9040,2
-4410,9906,east,E,9301,1
-4410,9907,north,N,9301,2
-4460,9906,South along 90°E.,E,9001,1
-4460,9907,South along 180°E,N,9001,2
-4461,9929,up,W,9001,3
-4461,9930,east,U,9001,1
-4461,9931,north,V,9001,2
-4462,9906,South along 180°W,X,9001,1
-4462,9907,South along 90°W,Y,9001,2
-4463,9906,South along 100°E,X,9001,1
-4463,9907,South along 170°W,Y,9001,2
-4464,9906,South along 90°W,X,9001,1
-4464,9907,South along 0°E,Y,9001,2
-4465,9906,South along 50°E,X,9001,1
-4465,9907,South along 140°E,Y,9001,2
-4466,9906,South along 10°W,X,9001,1
-4466,9907,South along 80°E,Y,9001,2
-4467,9906,South along 60°W,X,9001,1
-4467,9907,South along 30°E,Y,9001,2
-4468,9906,South along 45°E,X,9001,1
-4468,9907,South along 135°E,Y,9001,2
-4469,9906,South along 90°E,X,9001,1
-4469,9907,South along 180°E,Y,9001,2
-4470,9906,North along 90°E,X,9001,1
-4470,9907,North along 0°E,Y,9001,2
-4471,9906,North along 75°W,E,9001,1
-4471,9907,North along 165°W,N,9001,2
-4472,9906,North along 60°W,E,9001,1
-4472,9907,North along 150°W,N,9001,2
-4473,9906,North along 45°W,E,9001,1
-4473,9907,North along 135°W,N,9001,2
-4474,9906,North along 15°W,E,9001,1
-4474,9907,North along 105°W,N,9001,2
-4475,9906,North along 0°E,E,9001,1
-4475,9907,North along 90°W,N,9001,2
-4476,9906,North along 15°E,E,9001,1
-4476,9907,North along 75°W,N,9001,2
-4477,9906,North along 45°E,E,9001,1
-4477,9907,North along 45°W,N,9001,2
-4478,9906,North along 60°E,E,9001,1
-4478,9907,North along 30°W,N,9001,2
-4479,9906,North along 75°E,E,9001,1
-4479,9907,North along 15°W,N,9001,2
-4480,9906,North along 105°E,E,9001,1
-4480,9907,North along 15°E,N,9001,2
-4481,9906,North along 120°E,E,9001,1
-4481,9907,North along 30°E,N,9001,2
-4482,9906,North along 135°E,E,9001,1
-4482,9907,North along 45°E,N,9001,2
-4483,9906,North along 165°E,E,9001,1
-4483,9907,North along 75°E,N,9001,2
-4484,9906,North along 180°E,E,9001,1
-4484,9907,North along 90°E,N,9001,2
-4485,9906,North along 165°W,E,9001,1
-4485,9907,North along 105°E,N,9001,2
-4486,9906,North along 135°W,E,9001,1
-4486,9907,North along 135°E,N,9001,2
-4487,9906,North along 120°W,E,9001,1
-4487,9907,North along 150°E,N,9001,2
-4488,9906,North along 105°W,E,9001,1
-4488,9907,North along 165°E,N,9001,2
-4489,9906,North along 160°E,E,9001,1
-4489,9907,North along 70°E,N,9001,2
-4490,9906,North along 90°E,E,9001,1
-4490,9907,North along 0°E,N,9001,2
-4491,9907,north,N,9001,2
-4491,9908,west,W,9001,1
-4492,9913,North along 130°W,X,9001,1
-4492,9914,North along 140°E,Y,9001,2
-4493,9906,South along 90°E,E,9001,2
-4493,9907,South along 180°E,N,9001,1
-4494,9906,North along 90°E,E,9001,2
-4494,9907,North along 0°E,N,9001,1
-4495,9906,east,X,9002,1
-4495,9907,north,Y,9002,2
-4496,9906,east,E(X),9001,1
-4496,9907,north,N(Y),9001,2
-4497,9906,east,X,9003,1
-4497,9907,north,Y,9003,2
-4498,9906,east,Y,9001,1
-4498,9907,north,X,9001,2
-4499,9906,east,X,9001,1
-4499,9907,north,Y,9001,2
-4500,9906,east,E,9001,2
-4500,9907,north,N,9001,1
-4501,9907,north,N,9001,1
-4501,9908,west,E,9001,2
-4502,9906,east,E,9005,2
-4502,9907,north,N,9005,1
-4530,9906,east,Y,9001,2
-4530,9907,north,X,9001,1
-4531,9906,east,y,9001,2
-4531,9907,north,x,9001,1
-4532,9906,east,X,9001,2
-4532,9907,north,Y,9001,1
-4533,9906,east,Y,9098,2
-4533,9907,north,X,9098,1
-4534,9906,east,none,9001,2
-4534,9907,north,none,9001,1
-6401,9901,north,Lat,9108,1
-6401,9902,east,Long,9108,2
-6401,9903,up,h,9001,3
-6402,9901,north,Lat,9108,1
-6402,9902,east,Long,9108,2
-6403,9901,north,Lat,9105,1
-6403,9902,east,Long,9105,2
-6404,9926,north,Lat,9122,1
-6404,9927,east,Long,9122,2
-6404,9928,up,R,9001,3
-6405,9901,north,Lat,9102,1
-6405,9902,east,Long,9102,2
-6406,9901,north,Lat,9116,1
-6406,9902,east,Long,9116,2
-6407,9901,north,Lat,9117,1
-6407,9902,east,Long,9117,2
-6408,9901,north,Lat,9115,1
-6408,9902,east,Long,9115,2
-6409,9901,north,Lat,9118,1
-6409,9902,east,Long,9118,2
-6410,9901,north,Lat,9119,1
-6410,9902,east,Long,9119,2
-6411,9901,north,Lat,9107,1
-6411,9902,east,Long,9107,2
-6412,9901,north,Lat,9120,1
-6412,9902,east,Long,9120,2
-6413,9901,north,Lat,9102,1
-6413,9902,east,Long,9102,2
-6413,9903,up,h,9001,3
-6414,9901,north,Lat,9116,1
-6414,9902,east,Long,9116,2
-6414,9903,up,h,9001,3
-6415,9901,north,Lat,9117,1
-6415,9902,east,Long,9117,2
-6415,9903,up,h,9001,3
-6416,9901,north,Lat,9115,1
-6416,9902,east,Long,9115,2
-6416,9903,up,h,9001,3
-6417,9901,north,Lat,9118,1
-6417,9902,east,Long,9118,2
-6417,9903,up,h,9001,3
-6418,9901,north,Lat,9119,1
-6418,9902,east,Long,9119,2
-6418,9903,up,h,9001,3
-6419,9901,north,Lat,9107,1
-6419,9902,east,Long,9107,2
-6419,9903,up,h,9001,3
-6420,9901,north,Lat,9120,1
-6420,9902,east,Long,9120,2
-6420,9903,up,h,9001,3
-6421,9901,north,Lat,9105,1
-6421,9902,east,Long,9105,2
-6421,9903,up,h,9001,3
-6422,9901,north,Lat,9122,1
-6422,9902,east,Long,9122,2
-6423,9901,north,Lat,9122,1
-6423,9902,east,Long,9122,2
-6423,9903,up,h,9001,3
-6424,9901,north,Lat,9122,2
-6424,9902,east,Long,9122,1
-6425,9901,north,Lat,9105,2
-6425,9902,east,Long,9105,1
-6426,9901,north,Lat,9122,2
-6426,9902,east,Long,9122,1
-6426,9903,up,h,9001,3
-6427,9901,north,Lat,9105,2
-6427,9902,east,Long,9105,1
-6427,9903,up,h,9001,3
-6428,9901,north,Lat,9101,1
-6428,9902,east,Long,9101,2
-6429,9901,north,Lat,9101,2
-6429,9902,east,Long,9101,1
-6430,9901,north,Lat,9101,1
-6430,9902,east,Long,9101,2
-6430,9903,up,h,9001,3
-6431,9901,north,Lat,9101,2
-6431,9902,east,Long,9101,1
-6431,9903,up,h,9001,3
-6495,9905,down,D,9002,1
-6496,9904,up,H,9095,1
-6497,9904,up,H,9003,1
-6498,9905,down,D,9001,1
-6499,9904,up,H,9001,1
-6500,9910,Geocentre > equator/0°E,X,9001,1
-6500,9911,Geocentre > equator/90°E,Y,9001,2
-6500,9912,Geocentre > north pole,Z,9001,3
-6501,9908,west,Y,9001,2
-6501,9909,south,X,9001,1
-6502,9908,west,Y,9031,1
-6502,9909,south,X,9031,2
-6503,9908,west,Y,9001,1
-6503,9909,south,X,9001,2
-6504,9918,north-east,e,9001,2
-6504,9919,north-west,n,9001,1
-6505,9913,north-west,n,9001,1
-6505,9914,north-east,e,9001,2
-6506,9913,east-south-east,I,9205,1
-6506,9914,north-north-east,J,9204,2
-6507,9913,north,X,9001,1
-6507,9914,west,Y,9001,2
-6508,9920,east south east,I,9208,2
-6508,9921,north north east,J,9209,1
-6509,9908,west,M,9001,2
-6509,9909,south,P,9001,1
-6510,9918,north-east,x,9001,1
-6510,9919,north-west,y,9001,2
-6511,9922,Along receiver lines,I,9208,1
-6511,9923,Across receiver lines,J,9209,2
-6512,9916,up,z,9001,3
-6512,9918,east,x,9001,1
-6512,9919,north,y,9001,2
Deleted: grass/trunk/lib/proj/ellipsoid.csv
--- grass/trunk/lib/proj/ellipsoid.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/ellipsoid.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,53 +0,0 @@
-ellipsoid_code,ellipsoid_name,semi_major_axis,uom_code,inv_flattening,semi_minor_axis,ellipsoid_shape,remarks,information_source,data_source,revision_date,change_id,deprecated
-7001,Airy 1830,6377563.396,9001,299.3249646,,1,"Original definition is a=20923713, b=20853810 feet of 1796. 1/f is given to 7 decimal places. For the 1936 retriangulation OSGB defines the relationship of 10 feet of 1796 to the International metre through ([10^0.48401603]/10) exactly = 0.3048007491...",Ordnance Survey of Great Britain.,OGP,2006-11-27,1998.321 1998.340 2006.932,0
-7002,Airy Modified 1849,6377340.189,9001,299.3249646,,1,OSGB Airy 1830 figure (ellipsoid code 7001) rescaled by 0.999965 to best fit the scale of the 19th century primary triangulation of Ireland.,"""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",OGP,2003-06-27,1998.321 2002.622,0
-7003,Australian National Spheroid,6378160,9001,298.25,,1,Based on the GRS 1967 figure but with 1/f taken to 2 decimal places exactly.  The dimensions are also used as the GRS 1967 Modified ellipsoid (see code 7050).,"""Australian Map Grid Technical Manual""; National Mapping Council of Australia Special Publication #7; 1972",OGP,2008-08-11,2002.500 2008.017,0
-7004,Bessel 1841,6377397.155,9001,299.1528128,,1,"Original Bessel definition is a=3272077.14 and b=3261139.33 toise. This used a weighted mean of values from several authors but did not account for differences in the length of the various toise: the ""Bessel toise"" is therefore of uncertain length.",US Army Map Service Technical Manual; 1943.,OGP,1999-04-22,1998.321 1998.340,0
-7005,Bessel Modified,6377492.018,9001,299.1528128,,1,Used in Norway and also in Sweden with a 1mm increase in semi-major axis.,,OGP,1999-04-22,1998.321,0
-7006,Bessel Namibia,6377483.865,9001,299.1528128,,1,a = 6377397.155 German legal metres. This is the same value as the Bessel 1841 figure (code 7004) but in different units.  Used in Namibia.,"Chief Directorate: Surveys and Mapping, Mowbray, South Africa.",OGP,1999-04-22,1997.160,1
-7007,Clarke 1858,20926348,9005,,20855233,1,Clarke's 1858/II solution. Derived parameters: a = 6378293.645m using his 1865 ratio of 0.3047972654 feet per metre; 1/f = 294.26068…  In Australia and Amoco Trinidad 1/f taken to two decimal places (294.26 exactly); elsewhere a and b used to derive 1/f.,"""Ellipsoidisch Parameter der Erdfigur (1800-1950)"" by Georg Strasser.",OGP,2005-08-14,1999.700 2005.370,0
-7008,Clarke 1866,6378206.4,9001,,6356583.8,1,Original definition a=20926062 and b=20855121 (British) feet. Uses Clarke's 1865 inch-metre ratio of 39.370432 to obtain metres. (Metric value then converted to US survey feet for use in the United States using 39.37 exactly giving a=20925832.16 ft US).,US Army Map Service Technical Manual No. 7; 1943.,OGP,1995-06-02,1998.340,0
-7009,Clarke 1866 Michigan,20926631.531,9003,,20855688.674,1,Used for Michigan NAD27 State Plane zones.  Radius = ellipsoid radius + 800 feet; this approximates the average elevation of the state.   Derived parameter: 1/f = 294.97870,USGS Professional Paper #1395.,OGP,1995-06-02,1998.220,0
-7010,Clarke 1880 (Benoit),6378300.789,9001,,6356566.435,1,Adopts Clarke's values for a and b.  Uses Benoit's 1895 ratio of 0.9143992 metres per yard to convert to metres.,,OGP,1995-06-02,,0
-7011,Clarke 1880 (IGN),6378249.2,9001,,6356515,1,Adopts Clarke's values for a and b using his 1865 ratio of 39.370432 inches per metre to convert axes to metres.,,OGP,1998-04-16,1998.120,0
-7012,Clarke 1880 (RGS),6378249.145,9001,293.465,,1,Adopts Clarke's values for a and 1/f.  Adopts his 1865 ratio of 39.370432 inches per metre to convert semi-major axis to metres. Also known as Clarke Modified 1880.,Empire Survey Review #32; 1939.,OGP,1995-06-02,,0
-7013,Clarke 1880 (Arc),6378249.145,9001,293.4663077,,1,Adopts Clarke's value for a with derived 1/f.  Uses his 1865 ratio of 39.370432 inch per metre to convert semi-major axis to metres.,"Chief Directorate: Surveys and Mapping, Mowbray, South Africa.",OGP,2001-06-05,2001.052,0
-7014,Clarke 1880 (SGA 1922),6378249.2,9001,293.46598,,1,Used in Old French Triangulation (ATF).   Uses Clarke's 1865 inch-metre ratio of 39.370432 to convert axes to metres.,,OGP,1995-06-02,,0
-7015,Everest 1830 (1937 Adjustment),6377276.345,9001,300.8017,,1,Used for the 1937 readjustment of Indian triangulation.  Clarke's 1865 Indian-British foot ratio (0.99999566) and Benoit's 1898 British inch-metre ratio (39.370113) rounded as 0.30479841 exactly and applied to Everest's 1830 definition taken as a and 1/f,Survey of India professional paper #28; 1939,OGP,1996-10-18,1996.200,0
-7016,Everest 1830 (1967 Definition),6377298.556,9001,300.8017,,1,Adopted 1967 for use in East Malaysia.  Applies Sears 1922 inch-metre ratio of 39.370147 to Everest 1830 original definition of a and 1/f but with a taken to be in British rather than Indian feet.,,OGP,1995-06-02,,0
-7018,Everest 1830 Modified,6377304.063,9001,300.8017,,1,Adopted 1967 for use in West Malaysia.  Applies Benoit 1898 inch-metre ratio of 39.370113 to Everest 1830 original definition of a and 1/f but with a taken to be in British rather than Indian feet.,,OGP,1995-06-02,,0
-7019,GRS 1980,6378137,9001,298.257222101,,1,Adopted by IUGG 1979 Canberra.  Inverse flattening is derived from geocentric gravitational constant GM = 3986005e8 m*m*m/s/s; dynamic form factor J2 = 108263e8 and Earth's angular velocity = 7292115e-11 rad/s.,"""Geodetic Reference System 1980"" by H. Moritz; Bulletin Geodesique",OGP,1998-11-11,1998.110 1998.320,0
-7020,Helmert 1906,6378200,9001,298.3,,1,Helmert 1906/III solution.,"""Ellipsoidisch Parameter der Erdfigur (1800-1950)"" by Georg Strasser",OGP,1995-06-02,,0
-7021,Indonesian National Spheroid,6378160,9001,298.247,,1,Based on the GRS 1967 figure but with 1/f taken to 3 decimal places exactly.,Rais paper.,OGP,1995-06-02,,0
-7022,International 1924,6378388,9001,297,,1,Adopted by IUGG 1924 in Madrid. Based on Hayford 1909/1910 figures. ,,OGP,1995-06-02,,0
-7024,Krassowsky 1940,6378245,9001,298.3,,1,,,OGP,1995-06-02,,0
-7025,NWL 9D,6378145,9001,298.25,,1,Used by Transit Precise Ephemeris between October 1971 and January 1987.,,OGP,1995-06-02,,0
-7027,Plessis 1817,6376523,9001,308.64,,1,Rescaling of Delambre 1810 figure (a=6376985 m) to make meridional arc from equator to pole equal to 10000000 metres exactly. (Ref: Strasser).,"IGN Paris ""Constants d'Ellipsoides"" February 1972.",OGP,1995-06-02,,0
-7028,Struve 1860,6378298.3,9001,294.73,,1,"Original definition of semi-major axis given as 3272539 toise.  In ""Ellipsoidisch Parameter der Erdfigur (1800-1950)"" , Strasser suggests a conversion factor of 1.94903631 which gives a=6378297.337 metres.","""Geodesia y Cartografia Matematica"" by Fernando Martin Asin; ISBN 84-398-0248-X.",OGP,1998-11-11,1998.070 1998.340,0
-7029,War Office,6378300,9001,296,,1,"In non-metric form, a=20926201 Gold Coast feet.","Tables for the use of the Gold Coast Survey Department, 1935.",OGP,2000-10-12,,0
-7030,WGS 84,6378137,9001,298.257223563,,1,Inverse flattening derived from four defining parameters (semi-major axis; C20 = -484.16685*10e-6; earth's angular velocity w = 7292115e11 rad/sec; gravitational constant GM = 3986005e8 m*m*m/s/s).,DMA Technical Manual 8350.2-B ,OGP,1998-11-11,1998.320,0
-7031,GEM 10C,6378137,9001,298.257223563,,1,Used for  GEM 10C Gravity Potential Model.,,OGP,1995-06-02,1998.320,0
-7032,OSU86F,6378136.2,9001,298.257223563,,1,Used for OSU86 gravity potential (geoidal) model.,,OGP,1995-06-02,1998.320,0
-7033,OSU91A,6378136.3,9001,298.257223563,,1,Used for OSU91 gravity potential (geoidal) model.,,OGP,1995-06-02,1998.320,0
-7034,Clarke 1880,20926202,9005,,20854895,1,Clarke gave a and b and also 1/f=293.465 (to 3 decimal places exactly). In the 19th century b was normally given as the second defining parameter.,"""Ellipsoidisch Parameter der Erdfigur (1800-1950)"" by Georg Strasser.",OGP,2008-06-26,2008.057,0
-7035,Sphere,6371000,9001,,6371000,0,Authalic sphere.  1/f is infinite. Superseded by GRS 1980 authalic sphere (code 7047).,,OGP,1995-06-02,,1
-7036,GRS 1967,6378160,9001,298.247167427,,1,Adopted by IUGG 1967 Lucerne.  Inverse flattening given is derived from geocentric gravitational constant (GM)= 398603e9 m*m*m/s/s; dynamic form factor (J2) = 0.0010827 and Earth's angular velocity w = 7.2921151467e-5 rad/s. See also GRS 1967 (SAD69).,"""Geodetic Reference System 1967""; International Association of Geodesy special publication number 3; August 1971.",OGP,2002-09-19,1996.090 1997.252 1998.320 2002.500,0
-7041,Average Terrestrial System 1977,6378135,9001,298.257,,1,,New Brunswick Geographic Information Corporation land and water information standards manual,OGP,1997-07-22,1998.321,0
-7042,Everest (1830 Definition),20922931.8,9080,,20853374.58,1,Everest gave a and b to 2 decimal places and also 1/f=300.8017 (to 4 decimal places exactly). In the 19th century b was normally given as the second defining parameter.,"""Ellipsoidisch Parameter der Erdfigur (1800-1950)"" by Georg Strasser",OGP,2008-06-26,1997.231 2008.057,0
-7043,WGS 72,6378135,9001,298.26,,1,,,OGP,1999-04-22,1999.030,0
-7044,Everest 1830 (1962 Definition),6377301.243,9001,300.8017255,,1,Used by Pakistan since metrication.  Clarke's 1865 Indian foot-British foot ratio (0.99999566) and his 1865 British inch-metre ratio (39.369971) rounded with slight error as 1 Ind ft = 0.3047995m exactly and applied to Everest's 1830 definition of a & b.,,OGP,1999-10-20,,0
-7045,Everest 1830 (1975 Definition),6377299.151,9001,300.8017255,,1,Used by India since metrication.  Clarke's 1865 Indian foot-British foot ratio (0.99999566) and his 1865 British inch-metre ratio (39.369971) rounded as 1 Ind ft = 0.3047995m exactly applied to Everest's 1830 original definition taken as a and b.,,OGP,1999-10-20,,0
-7046,Bessel Namibia (GLM),6377397.155,9031,299.1528128,,1,The semi-major axis has the same value as the Bessel 1841 ellipsoid (code 7004) but is in different units - German Legal Metres rather than International metres - hence a different size.  a = 6377483.865 International metres. Used in Namibia.,"Chief Directorate: Surveys and Mapping, Mowbray, South Africa.",OGP,2007-09-21,2007.091,0
-7047,GRS 1980 Authalic Sphere,6370997,9001,,6370997,0,Authalic sphere derived from Clarke 1866 ellipsoid (code 7008).  Deprecated as name and parameter values do not match; replaced by 7048.,OGP,OGP,2001-06-05,,1
-7048,GRS 1980 Authalic Sphere,6371007,9001,,6371007,0,Authalic sphere derived from GRS 1980 ellipsoid (code 7019).  (An authalic sphere is one with a surface area equal to the surface area of the ellipsoid). 1/f is infinite.,OGP,OGP,2001-06-25,,0
-7049,Xian 1980,6378140,9001,298.257,,1,,BP,OGP,2002-02-12,,0
-7050,GRS 1967 Modified,6378160,9001,298.25,,1,Based on the GRS 1967 figure (code 7036) but with 1/f taken to 2 decimal places exactly. Used with SAD69 and TWD67 datums. The dimensions are also used as the Australian National Spheroid (code 7003).,"""Geodetic Reference System 1967""; International Association of Geodesy special publication number 3; August 1971.",OGP,2008-08-11,2008.017,0
-7051,Danish 1876,6377019.27,9001,300,,1,Semi-major axis originally given as 3271883.25 toise. Uses toise to French metre ratio of 1.94903631 to two decimal place precision. An alternative ratio with the German legal metre of 1.9490622 giving 6377104m has not been used in Danish work.,"Kort og Matrikelstyrelsen (KMS), Copenhagen.",OGP,2003-06-27,,0
-7052,Clarke 1866 Authalic Sphere,6370997,9001,,6370997,0,Authalic sphere derived from Clarke 1866 ellipsoid (code 7008).,OGP,OGP,2004-04-27,,0
-7053,Hough 1960,6378270,9001,297,,1,,DMA / NIMA / NGA TR8350.2,OGP,2006-01-26,,0
-7054,PZ-90,6378136,9001,298.257839303,,1,,"Geodeziya i Katografiya, 1993.",OGP,2006-02-03,,0
-7055,Clarke 1880 (international foot),20926202,9002,,20854895,1,Clark'es 1880 definition in feet assumed for the purposes of metric conversion to be international foot. a = 6378306.370…metres. 1/f derived from a and b = 293.4663077… Used in Fiji.,"Department of Lands and Survey, Fiji.",OGP,2006-07-14,,0
-7056,Everest 1830 (RSO 1969),6377295.664,9001,300.8017,,1,Adopted for 1969 metrication of peninsula Malaysia RSO grid.  Uses Sears 1922 yard-metre ratio truncated to 6 significant figures applied to Everest 1830 original definition of a and 1/f but with a taken to be in British rather than Indian feet.,Defence Geographic Centre,OGP,2006-07-24,,0
-7057,International 1924 Authalic Sphere,6371228,9001,,6371228,0,Authalic sphere derived from International 1924 ellipsoid (code 7022).,OGP,OGP,2006-09-22,,0
-7058,Hughes 1980,6378273,9001,,6356889.449,1,Used in US DMSP SSM/I microwave sensor processing software. Semi-minor axis derived from eccentricity=0.081816153. Semi-major axis (a) sometimes given as 3443.992nm which OGP suspects is a derived approximation. OGP conversion assumes 1nm=1852m exactly.,US National Snow and Ice Data Center,OGP,2006-09-22,,0
-7059,Popular Visualisation Sphere,6378137,9001,,6378137,0,Sphere with radius equal to the semi-major axis of the GRS80 and WGS 84 ellipsoids. Used only for Web approximate mapping and visualisation. Not recognised by geodetic authorities.,Microsoft.,OGP,2008-03-14,2008.114,1
Deleted: grass/trunk/lib/proj/gcs.csv
--- grass/trunk/lib/proj/gcs.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/gcs.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,430 +0,0 @@
-"COORD_REF_SYS_CODE","COORD_REF_SYS_NAME","DATUM_CODE","DATUM_NAME","GREENWICH_DATUM","UOM_CODE","ELLIPSOID_CODE","PRIME_MERIDIAN_CODE","SHOW_CRS","DEPRECATED","COORD_SYS_CODE","COORD_OP_METHOD_CODE","DX","DY","DZ","RX","RY","RZ","DS"
-3819,HD1909,1024,Hungarian Datum 1909,1024,9122,7004,8901,1,0,6422,9607,595.48,121.69,515.35,-4.115,2.9383,-0.853,-3.408
-3821,TWD67,1025,Taiwan Datum 1967,1025,9122,7050,8901,1,0,6422,,,,,,,,
-3824,TWD97,1026,Taiwan Datum 1997,1026,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-3889,IGRS,1029,Iraqi Geospatial Reference System,1029,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-3906,MGI 1901,1031,MGI 1901,1031,9122,7004,8901,1,0,6422,,,,,,,,
-4001,Unknown datum based upon the Airy 1830 ellipsoid,6001,"Not specified (based on Airy 1830 ellipsoid)",6001,9122,7001,8901,0,0,6422,,,,,,,,
-4002,Unknown datum based upon the Airy Modified 1849 ellipsoid,6002,"Not specified (based on Airy Modified 1849 ellipsoid)",6002,9122,7002,8901,0,0,6422,,,,,,,,
-4003,Unknown datum based upon the Australian National Spheroid,6003,"Not specified (based on Australian National Spheroid)",6003,9122,7003,8901,0,0,6422,,,,,,,,
-4004,Unknown datum based upon the Bessel 1841 ellipsoid,6004,"Not specified (based on Bessel 1841 ellipsoid)",6004,9122,7004,8901,0,0,6422,,,,,,,,
-4005,Unknown datum based upon the Bessel Modified ellipsoid,6005,"Not specified (based on Bessel Modified ellipsoid)",6005,9122,7005,8901,0,0,6422,,,,,,,,
-4006,Unknown datum based upon the Bessel Namibia ellipsoid,6006,"Not specified (based on Bessel Namibia ellipsoid)",6006,9122,7046,8901,0,0,6422,,,,,,,,
-4007,Unknown datum based upon the Clarke 1858 ellipsoid,6007,"Not specified (based on Clarke 1858 ellipsoid)",6007,9122,7007,8901,0,0,6422,,,,,,,,
-4008,Unknown datum based upon the Clarke 1866 ellipsoid,6008,"Not specified (based on Clarke 1866 ellipsoid)",6008,9122,7008,8901,0,0,6422,,,,,,,,
-4009,Unknown datum based upon the Clarke 1866 Michigan ellipsoid,6009,"Not specified (based on Clarke 1866 Michigan ellipsoid)",6009,9122,7009,8901,0,0,6422,,,,,,,,
-4010,"Unknown datum based upon the Clarke 1880 (Benoit) ellipsoid",6010,"Not specified (based on Clarke 1880 (Benoit) ellipsoid)",6010,9122,7010,8901,0,0,6422,,,,,,,,
-4011,"Unknown datum based upon the Clarke 1880 (IGN) ellipsoid",6011,"Not specified (based on Clarke 1880 (IGN) ellipsoid)",6011,9122,7011,8901,0,0,6422,,,,,,,,
-4012,"Unknown datum based upon the Clarke 1880 (RGS) ellipsoid",6012,"Not specified (based on Clarke 1880 (RGS) ellipsoid)",6012,9122,7012,8901,0,0,6422,,,,,,,,
-4013,"Unknown datum based upon the Clarke 1880 (Arc) ellipsoid",6013,"Not specified (based on Clarke 1880 (Arc) ellipsoid)",6013,9122,7013,8901,0,0,6422,,,,,,,,
-4014,"Unknown datum based upon the Clarke 1880 (SGA 1922) ellipsoid",6014,"Not specified (based on Clarke 1880 (SGA 1922) ellipsoid)",6014,9122,7014,8901,0,0,6422,,,,,,,,
-4015,"Unknown datum based upon the Everest 1830 (1937 Adjustment) ellipsoid",6015,"Not specified (based on Everest 1830 (1937 Adjustment) ellipsoid)",6015,9122,7015,8901,0,0,6422,,,,,,,,
-4016,"Unknown datum based upon the Everest 1830 (1967 Definition) ellipsoid",6016,"Not specified (based on Everest 1830 (1967 Definition) ellipsoid)",6016,9122,7016,8901,0,0,6422,,,,,,,,
-4018,Unknown datum based upon the Everest 1830 Modified ellipsoid,6018,"Not specified (based on Everest 1830 Modified ellipsoid)",6018,9122,7018,8901,0,0,6422,,,,,,,,
-4019,Unknown datum based upon the GRS 1980 ellipsoid,6019,"Not specified (based on GRS 1980 ellipsoid)",6019,9122,7019,8901,0,0,6422,,,,,,,,
-4020,Unknown datum based upon the Helmert 1906 ellipsoid,6020,"Not specified (based on Helmert 1906 ellipsoid)",6020,9122,7020,8901,0,0,6422,,,,,,,,
-4021,Unknown datum based upon the Indonesian National Spheroid,6021,"Not specified (based on Indonesian National Spheroid)",6021,9122,7021,8901,0,0,6422,,,,,,,,
-4022,Unknown datum based upon the International 1924 ellipsoid,6022,"Not specified (based on International 1924 ellipsoid)",6022,9122,7022,8901,0,0,6422,,,,,,,,
-4023,MOLDREF99,1032,MOLDREF99,1032,9122,7019,8901,1,0,6422,,,,,,,,
-4024,Unknown datum based upon the Krassowsky 1940 ellipsoid,6024,"Not specified (based on Krassowsky 1940 ellipsoid)",6024,9122,7024,8901,0,0,6422,,,,,,,,
-4025,Unknown datum based upon the NWL 9D ellipsoid,6025,"Not specified (based on NWL 9D ellipsoid)",6025,9122,7025,8901,0,0,6422,,,,,,,,
-4027,Unknown datum based upon the Plessis 1817 ellipsoid,6027,"Not specified (based on Plessis 1817 ellipsoid)",6027,9122,7027,8901,0,0,6422,,,,,,,,
-4028,Unknown datum based upon the Struve 1860 ellipsoid,6028,"Not specified (based on Struve 1860 ellipsoid)",6028,9122,7028,8901,0,0,6422,,,,,,,,
-4029,Unknown datum based upon the War Office ellipsoid,6029,"Not specified (based on War Office ellipsoid)",6029,9122,7029,8901,0,0,6422,,,,,,,,
-4030,Unknown datum based upon the WGS 84 ellipsoid,6030,"Not specified (based on WGS 84 ellipsoid)",6030,9122,7030,8901,0,0,6422,,,,,,,,
-4031,Unknown datum based upon the GEM 10C ellipsoid,6031,"Not specified (based on GEM 10C ellipsoid)",6031,9122,7031,8901,0,0,6422,,,,,,,,
-4032,Unknown datum based upon the OSU86F ellipsoid,6032,"Not specified (based on OSU86F ellipsoid)",6032,9122,7032,8901,0,0,6422,,,,,,,,
-4033,Unknown datum based upon the OSU91A ellipsoid,6033,"Not specified (based on OSU91A ellipsoid)",6033,9122,7033,8901,0,0,6422,,,,,,,,
-4034,Unknown datum based upon the Clarke 1880 ellipsoid,6034,"Not specified (based on Clarke 1880 ellipsoid)",6034,9122,7034,8901,0,0,6422,,,,,,,,
-4035,Unknown datum based upon the Authalic Sphere,6035,"Not specified (based on Authalic Sphere)",6035,9108,7035,8901,0,1,6402,,,,,,,,
-4036,Unknown datum based upon the GRS 1967 ellipsoid,6036,"Not specified (based on GRS 1967 ellipsoid)",6036,9122,7036,8901,0,0,6422,,,,,,,,
-4041,Unknown datum based upon the Average Terrestrial System 1977 ellipsoid,6041,"Not specified (based on Average Terrestrial System 1977 ellipsoid)",6041,9122,7041,8901,0,0,6422,,,,,,,,
-4042,"Unknown datum based upon the Everest (1830 Definition) ellipsoid",6042,"Not specified (based on Everest (1830 Definition) ellipsoid)",6042,9122,7042,8901,0,0,6422,,,,,,,,
-4043,Unknown datum based upon the WGS 72 ellipsoid,6043,"Not specified (based on WGS 72 ellipsoid)",6043,9122,7043,8901,0,0,6422,,,,,,,,
-4044,"Unknown datum based upon the Everest 1830 (1962 Definition) ellipsoid",6044,"Not specified (based on Everest 1830 (1962 Definition) ellipsoid)",6044,9122,7044,8901,0,0,6422,,,,,,,,
-4045,"Unknown datum based upon the Everest 1830 (1975 Definition) ellipsoid",6045,"Not specified (based on Everest 1830 (1975 Definition) ellipsoid)",6045,9122,7045,8901,0,0,6422,,,,,,,,
-4046,RGRDC 2005,1033,Reseau Geodesique de la RDC 2005,1033,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4047,Unspecified datum based upon the GRS 1980 Authalic Sphere,6047,"Not specified (based on GRS 1980 Authalic Sphere)",6047,9122,7048,8901,0,0,6422,,,,,,,,
-4052,Unspecified datum based upon the Clarke 1866 Authalic Sphere,6052,"Not specified (based on Clarke 1866 Authalic Sphere)",6052,9122,7052,8901,0,0,6422,,,,,,,,
-4053,Unspecified datum based upon the International 1924 Authalic Sphere,6053,"Not specified (based on International 1924 Authalic Sphere)",6053,9122,7057,8901,0,0,6422,,,,,,,,
-4054,Unspecified datum based upon the Hughes 1980 ellipsoid,6054,"Not specified (based on Hughes 1980 ellipsoid)",6054,9122,7058,8901,0,0,6422,,,,,,,,
-4055,Popular Visualisation CRS,6055,Popular Visualisation Datum,6055,9122,7059,8901,1,1,6422,9603,0,0,0,,,,
-4075,SREF98,1034,Serbian Reference Network 1998,1034,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4081,REGCAN95,1035,Red Geodesica de Canarias 1995,1035,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4120,Greek,6120,Greek,6120,9122,7004,8901,1,0,6422,,,,,,,,
-4121,GGRS87,6121,Greek Geodetic Reference System 1987,6121,9122,7019,8901,1,0,6422,9603,-199.87,74.79,246.62,,,,
-4122,ATS77,6122,Average Terrestrial System 1977,6122,9122,7041,8901,1,0,6422,,,,,,,,
-4123,KKJ,6123,"Kartastokoordinaattijarjestelma (1966)",6123,9122,7022,8901,1,0,6422,,,,,,,,
-4124,RT90,6124,Rikets koordinatsystem 1990,6124,9122,7004,8901,1,0,6422,,,,,,,,
-4125,Samboja,6125,Samboja,6125,9108,7004,8901,1,1,6402,9603,-404.78,685.68,45.47,,,,
-4126,"LKS94 (ETRS89)",6126,"Lithuania 1994 (ETRS89)",6126,9108,7019,8901,1,1,6402,,,,,,,,
-4127,Tete,6127,Tete,6127,9122,7008,8901,1,0,6422,,,,,,,,
-4128,Madzansua,6128,Madzansua,6128,9122,7008,8901,1,0,6422,,,,,,,,
-4129,Observatario,6129,Observatario,6129,9122,7008,8901,1,0,6422,,,,,,,,
-4130,Moznet,6130,"Moznet (ITRF94)",6130,9122,7030,8901,1,0,6422,9607,0,0,0,0,0,0,0
-4131,Indian 1960,6131,Indian 1960,6131,9122,7015,8901,1,0,6422,,,,,,,,
-4132,FD58,6132,Final Datum 1958,6132,9122,7012,8901,1,0,6422,,,,,,,,
-4133,EST92,6133,Estonia 1992,6133,9122,7019,8901,1,0,6422,9607,0.055,-0.541,-0.185,-0.0183,0.0003,0.007,-0.014
-4134,PSD93,6134,PDO Survey Datum 1993,6134,9122,7012,8901,1,0,6422,,,,,,,,
-4135,Old Hawaiian,6135,Old Hawaiian,6135,9122,7008,8901,1,0,6422,,,,,,,,
-4136,St. Lawrence Island,6136,St. Lawrence Island,6136,9122,7008,8901,1,0,6422,,,,,,,,
-4137,St. Paul Island,6137,St. Paul Island,6137,9122,7008,8901,1,0,6422,,,,,,,,
-4138,St. George Island,6138,St. George Island,6138,9122,7008,8901,1,0,6422,,,,,,,,
-4139,Puerto Rico,6139,Puerto Rico,6139,9122,7008,8901,1,0,6422,9603,11,72,-101,,,,
-4140,"NAD83(CSRS98)",6140,NAD83 Canadian Spatial Reference System,6140,9108,7019,8901,1,1,6402,9603,0,0,0,,,,
-4141,Israel,6141,Israel,6141,9122,7019,8901,1,0,6422,9603,-48,55,52,,,,
-4142,Locodjo 1965,6142,Locodjo 1965,6142,9122,7012,8901,1,0,6422,9603,-125,53,467,,,,
-4143,Abidjan 1987,6143,Abidjan 1987,6143,9122,7012,8901,1,0,6422,9603,-124.76,53,466.79,,,,
-4144,Kalianpur 1937,6144,Kalianpur 1937,6144,9122,7015,8901,1,0,6422,,,,,,,,
-4145,Kalianpur 1962,6145,Kalianpur 1962,6145,9122,7044,8901,1,0,6422,,,,,,,,
-4146,Kalianpur 1975,6146,Kalianpur 1975,6146,9122,7045,8901,1,0,6422,9603,295,736,257,,,,
-4147,Hanoi 1972,6147,Hanoi 1972,6147,9122,7024,8901,1,0,6422,9603,-17.51,-108.32,-62.39,,,,
-4148,Hartebeesthoek94,6148,Hartebeesthoek94,6148,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4149,CH1903,6149,CH1903,6149,9122,7004,8901,1,0,6422,,,,,,,,
-4150,"CH1903+",6150,"CH1903+",6150,9122,7004,8901,1,0,6422,9603,674.374,15.056,405.346,,,,
-4151,CHTRF95,6151,Swiss Terrestrial Reference Frame 1995,6151,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4152,"NAD83(HARN)",6152,"NAD83 (High Accuracy Regional Network)",6152,9122,7019,8901,1,0,6422,,,,,,,,
-4153,Rassadiran,6153,Rassadiran,6153,9122,7022,8901,1,0,6422,9603,-133.63,-157.5,-158.62,,,,
-4154,"ED50(ED77)",6154,"European Datum 1950(1977)",6154,9122,7022,8901,1,0,6422,,,,,,,,
-4155,Dabola 1981,6155,Dabola 1981,6155,9122,7011,8901,1,0,6422,9603,-83,37,124,,,,
-4156,S-JTSK,6156,Jednotne Trigonometricke Site Katastralni,6156,9122,7004,8901,1,0,6422,,,,,,,,
-4157,Mount Dillon,6157,Mount Dillon,6157,9122,7007,8901,1,0,6422,,,,,,,,
-4158,Naparima 1955,6158,Naparima 1955,6158,9122,7022,8901,1,0,6422,,,,,,,,
-4159,ELD79,6159,European Libyan Datum 1979,6159,9122,7022,8901,1,0,6422,,,,,,,,
-4160,Chos Malal 1914,6160,Chos Malal 1914,6160,9122,7022,8901,1,0,6422,,,,,,,,
-4161,Pampa del Castillo,6161,Pampa del Castillo,6161,9122,7022,8901,1,0,6422,9603,27.5,14,186.4,,,,
-4162,Korean 1985,6162,Korean Datum 1985,6162,9122,7004,8901,1,0,6422,,,,,,,,
-4163,Yemen NGN96,6163,Yemen National Geodetic Network 1996,6163,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4164,South Yemen,6164,South Yemen,6164,9122,7024,8901,1,0,6422,9603,-76,-138,67,,,,
-4165,Bissau,6165,Bissau,6165,9122,7022,8901,1,0,6422,9603,-173,253,27,,,,
-4166,Korean 1995,6166,Korean Datum 1995,6166,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4167,NZGD2000,6167,New Zealand Geodetic Datum 2000,6167,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4168,Accra,6168,Accra,6168,9122,7029,8901,1,0,6422,,,,,,,,
-4169,American Samoa 1962,6169,American Samoa 1962,6169,9122,7008,8901,1,0,6422,9603,-115,118,426,,,,
-4170,SIRGAS 1995,6170,Sistema de Referencia Geocentrico para America del Sur 1995,6170,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4171,RGF93,6171,Reseau Geodesique Francais 1993,6171,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4172,POSGAR,6172,Posiciones Geodesicas Argentinas,6172,9108,7019,8901,1,1,6402,9603,0,0,0,,,,
-4173,IRENET95,6173,IRENET95,6173,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4174,Sierra Leone 1924,6174,Sierra Leone Colony 1924,6174,9122,7029,8901,1,0,6422,,,,,,,,
-4175,Sierra Leone 1968,6175,Sierra Leone 1968,6175,9122,7012,8901,1,0,6422,9603,-88,4,101,,,,
-4176,Australian Antarctic,6176,Australian Antarctic Datum 1998,6176,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4178,"Pulkovo 1942(83)",6178,"Pulkovo 1942(83)",6178,9122,7024,8901,1,0,6422,,,,,,,,
-4179,"Pulkovo 1942(58)",6179,"Pulkovo 1942(58)",6179,9122,7024,8901,1,0,6422,,,,,,,,
-4180,EST97,6180,Estonia 1997,6180,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4181,Luxembourg 1930,6181,Luxembourg 1930,6181,9122,7022,8901,1,0,6422,9606,-193,13.7,-39.3,-0.41,-2.933,2.688,0.43
-4182,Azores Occidental 1939,6182,Azores Occidental Islands 1939,6182,9122,7022,8901,1,0,6422,,,,,,,,
-4183,Azores Central 1948,6183,Azores Central Islands 1948,6183,9122,7022,8901,1,0,6422,9603,-104,167,-38,,,,
-4184,Azores Oriental 1940,6184,Azores Oriental Islands 1940,6184,9122,7022,8901,1,0,6422,9603,-203,141,53,,,,
-4185,Madeira 1936,6185,Madeira 1936,6185,9108,7022,8901,1,1,6402,,,,,,,,
-4188,OSNI 1952,6188,OSNI 1952,6188,9122,7001,8901,1,0,6422,9606,482.5,-130.6,564.6,-1.042,-0.214,-0.631,8.15
-4189,REGVEN,6189,Red Geodesica Venezolana,6189,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4190,POSGAR 98,6190,Posiciones Geodesicas Argentinas 1998,6190,9122,7019,8901,1,0,6422,,,,,,,,
-4191,Albanian 1987,6191,Albanian 1987,6191,9122,7024,8901,1,0,6422,,,,,,,,
-4192,Douala 1948,6192,Douala 1948,6192,9122,7022,8901,1,0,6422,9603,-206.1,-174.7,-87.7,,,,
-4193,Manoca 1962,6193,Manoca 1962,6193,9122,7011,8901,1,0,6422,9603,-70.9,-151.8,-41.4,,,,
-4194,Qornoq 1927,6194,Qornoq 1927,6194,9122,7022,8901,1,0,6422,,,,,,,,
-4195,Scoresbysund 1952,6195,Scoresbysund 1952,6195,9122,7022,8901,1,0,6422,9606,105,326,-102.5,0,0,0.814,-0.6
-4196,Ammassalik 1958,6196,Ammassalik 1958,6196,9122,7022,8901,1,0,6422,9606,-45,417,-3.5,0,0,0.814,-0.6
-4197,Garoua,6197,Garoua,6197,9122,7012,8901,1,0,6422,,,,,,,,
-4198,Kousseri,6198,Kousseri,6198,9122,7012,8901,1,0,6422,,,,,,,,
-4199,Egypt 1930,6199,Egypt 1930,6199,9122,7022,8901,1,0,6422,,,,,,,,
-4200,Pulkovo 1995,6200,Pulkovo 1995,6200,9122,7024,8901,1,0,6422,9607,24.82,-131.21,-82.66,0,0,-0.16,-0.12
-4201,Adindan,6201,Adindan,6201,9122,7012,8901,1,0,6422,,,,,,,,
-4202,AGD66,6202,Australian Geodetic Datum 1966,6202,9122,7003,8901,1,0,6422,,,,,,,,
-4203,AGD84,6203,Australian Geodetic Datum 1984,6203,9122,7003,8901,1,0,6422,,,,,,,,
-4204,Ain el Abd,6204,Ain el Abd 1970,6204,9122,7022,8901,1,0,6422,,,,,,,,
-4205,Afgooye,6205,Afgooye,6205,9122,7024,8901,1,0,6422,9603,-43,-163,45,,,,
-4206,Agadez,6206,Agadez,6206,9122,7011,8901,1,0,6422,,,,,,,,
-4207,Lisbon,6207,Lisbon 1937,6207,9122,7022,8901,1,0,6422,,,,,,,,
-4208,Aratu,6208,Aratu,6208,9122,7022,8901,1,0,6422,,,,,,,,
-4209,Arc 1950,6209,Arc 1950,6209,9122,7013,8901,1,0,6422,,,,,,,,
-4210,Arc 1960,6210,Arc 1960,6210,9122,7012,8901,1,0,6422,,,,,,,,
-4211,Batavia,6211,Batavia,6211,9122,7004,8901,1,0,6422,,,,,,,,
-4212,Barbados 1938,6212,Barbados 1938,6212,9122,7012,8901,1,0,6422,9603,31.95,300.99,419.19,,,,
-4213,Beduaram,6213,Beduaram,6213,9122,7011,8901,1,0,6422,9603,-106,-87,188,,,,
-4214,Beijing 1954,6214,Beijing 1954,6214,9122,7024,8901,1,0,6422,,,,,,,,
-4215,Belge 1950,6215,Reseau National Belge 1950,6215,9122,7022,8901,1,0,6422,,,,,,,,
-4216,Bermuda 1957,6216,Bermuda 1957,6216,9122,7008,8901,1,0,6422,,,,,,,,
-4218,Bogota 1975,6218,Bogota 1975,6218,9122,7022,8901,1,0,6422,,,,,,,,
-4219,Bukit Rimpah,6219,Bukit Rimpah,6219,9122,7004,8901,1,0,6422,9603,-384,664,-48,,,,
-4220,Camacupa,6220,Camacupa,6220,9122,7012,8901,1,0,6422,,,,,,,,
-4221,Campo Inchauspe,6221,Campo Inchauspe,6221,9122,7022,8901,1,0,6422,,,,,,,,
-4222,Cape,6222,Cape,6222,9122,7013,8901,1,0,6422,,,,,,,,
-4223,Carthage,6223,Carthage,6223,9122,7011,8901,1,0,6422,,,,,,,,
-4224,Chua,6224,Chua,6224,9122,7022,8901,1,0,6422,,,,,,,,
-4225,Corrego Alegre,6225,Corrego Alegre,6225,9122,7022,8901,1,0,6422,9603,-206,172,-6,,,,
-4226,"Cote d'Ivoire",6226,"Cote d'Ivoire",6226,9108,7011,8901,1,1,6402,,,,,,,,
-4227,Deir ez Zor,6227,Deir ez Zor,6227,9122,7011,8901,1,0,6422,,,,,,,,
-4228,Douala,6228,Douala,6228,9108,7011,8901,1,1,6402,,,,,,,,
-4229,Egypt 1907,6229,Egypt 1907,6229,9122,7020,8901,1,0,6422,,,,,,,,
-4230,ED50,6230,European Datum 1950,6230,9122,7022,8901,1,0,6422,,,,,,,,
-4231,ED87,6231,European Datum 1987,6231,9122,7022,8901,1,0,6422,,,,,,,,
-4232,Fahud,6232,Fahud,6232,9122,7012,8901,1,0,6422,,,,,,,,
-4233,Gandajika 1970,6233,Gandajika 1970,6233,9122,7022,8901,1,1,6422,9603,-133,-321,50,,,,
-4234,Garoua,6234,Garoua,6234,9108,7011,8901,1,1,6402,,,,,,,,
-4235,Guyane Francaise,6235,Guyane Francaise,6235,9108,7022,8901,1,1,6402,,,,,,,,
-4236,Hu Tzu Shan 1950,6236,Hu Tzu Shan 1950,6236,9122,7022,8901,1,0,6422,9603,-637,-549,-203,,,,
-4237,HD72,6237,Hungarian Datum 1972,6237,9122,7036,8901,1,0,6422,,,,,,,,
-4238,ID74,6238,Indonesian Datum 1974,6238,9122,7021,8901,1,0,6422,,,,,,,,
-4239,Indian 1954,6239,Indian 1954,6239,9122,7015,8901,1,0,6422,9603,217,823,299,,,,
-4240,Indian 1975,6240,Indian 1975,6240,9122,7015,8901,1,0,6422,,,,,,,,
-4241,Jamaica 1875,6241,Jamaica 1875,6241,9122,7034,8901,1,0,6422,,,,,,,,
-4242,JAD69,6242,Jamaica 1969,6242,9122,7008,8901,1,0,6422,,,,,,,,
-4243,Kalianpur 1880,6243,Kalianpur 1880,6243,9122,7042,8901,1,0,6422,,,,,,,,
-4244,Kandawala,6244,Kandawala,6244,9122,7015,8901,1,0,6422,9603,-97,787,86,,,,
-4245,Kertau 1968,6245,Kertau 1968,6245,9122,7018,8901,1,0,6422,9603,-11,851,5,,,,
-4246,KOC,6246,Kuwait Oil Company,6246,9122,7012,8901,1,0,6422,9603,-294.7,-200.1,525.5,,,,
-4247,La Canoa,6247,La Canoa,6247,9122,7022,8901,1,0,6422,9603,-273.5,110.6,-357.9,,,,
-4248,PSAD56,6248,Provisional South American Datum 1956,6248,9122,7022,8901,1,0,6422,,,,,,,,
-4249,Lake,6249,Lake,6249,9122,7022,8901,1,0,6422,,,,,,,,
-4250,Leigon,6250,Leigon,6250,9122,7012,8901,1,0,6422,9603,-130,29,364,,,,
-4251,Liberia 1964,6251,Liberia 1964,6251,9122,7012,8901,1,0,6422,9603,-90,40,88,,,,
-4252,Lome,6252,Lome,6252,9122,7011,8901,1,0,6422,,,,,,,,
-4253,Luzon 1911,6253,Luzon 1911,6253,9122,7008,8901,1,0,6422,,,,,,,,
-4254,Hito XVIII 1963,6254,Hito XVIII 1963,6254,9122,7022,8901,1,0,6422,,,,,,,,
-4255,Herat North,6255,Herat North,6255,9122,7022,8901,1,0,6422,9603,-333,-222,114,,,,
-4256,Mahe 1971,6256,Mahe 1971,6256,9122,7012,8901,1,0,6422,9603,41,-220,-134,,,,
-4257,Makassar,6257,Makassar,6257,9122,7004,8901,1,0,6422,9603,-587.8,519.75,145.76,,,,
-4258,ETRS89,6258,European Terrestrial Reference System 1989,6258,9122,7019,8901,1,0,6422,,,,,,,,
-4259,Malongo 1987,6259,Malongo 1987,6259,9122,7022,8901,1,0,6422,,,,,,,,
-4260,Manoca,6260,Manoca,6260,9108,7012,8901,1,1,6402,9603,-70.9,-151.8,-41.4,,,,
-4261,Merchich,6261,Merchich,6261,9122,7011,8901,1,0,6422,9603,31,146,47,,,,
-4262,Massawa,6262,Massawa,6262,9122,7004,8901,1,0,6422,9603,639,405,60,,,,
-4263,Minna,6263,Minna,6263,9122,7012,8901,1,0,6422,,,,,,,,
-4264,Mhast,6264,Mhast,6264,9122,7022,8901,1,1,6422,9603,-252.95,-4.11,-96.38,,,,
-4265,Monte Mario,6265,Monte Mario,6265,9122,7022,8901,1,0,6422,,,,,,,,
-4266,"M'poraloko",6266,"M'poraloko",6266,9122,7011,8901,1,0,6422,,,,,,,,
-4267,NAD27,6267,North American Datum 1927,6267,9122,7008,8901,1,0,6422,,,,,,,,
-4268,NAD27 Michigan,6268,NAD Michigan,6268,9122,7009,8901,1,0,6422,,,,,,,,
-4269,NAD83,6269,North American Datum 1983,6269,9122,7019,8901,1,0,6422,,,,,,,,
-4270,Nahrwan 1967,6270,Nahrwan 1967,6270,9122,7012,8901,1,0,6422,,,,,,,,
-4271,Naparima 1972,6271,Naparima 1972,6271,9122,7022,8901,1,0,6422,,,,,,,,
-4272,NZGD49,6272,New Zealand Geodetic Datum 1949,6272,9122,7022,8901,1,0,6422,,,,,,,,
-4273,NGO 1948,6273,NGO 1948,6273,9122,7005,8901,1,0,6422,9606,278.3,93,474.5,7.889,0.05,-6.61,6.21
-4274,Datum 73,6274,Datum 73,6274,9122,7022,8901,1,0,6422,,,,,,,,
-4275,NTF,6275,Nouvelle Triangulation Francaise,6275,9122,7011,8901,1,0,6422,9603,-168,-60,320,,,,
-4276,NSWC 9Z-2,6276,NSWC 9Z-2,6276,9122,7025,8901,1,0,6422,,,,,,,,
-4277,OSGB 1936,6277,OSGB 1936,6277,9122,7001,8901,1,0,6422,,,,,,,,
-4278,OSGB70,6278,"OSGB 1970 (SN)",6278,9122,7001,8901,1,0,6422,,,,,,,,
-4279,"OS(SN)80",6279,"OS (SN) 1980",6279,9122,7001,8901,1,0,6422,,,,,,,,
-4280,Padang,6280,Padang 1884,6280,9122,7004,8901,1,0,6422,,,,,,,,
-4281,Palestine 1923,6281,Palestine 1923,6281,9122,7010,8901,1,0,6422,9606,-275.7224,94.7824,340.8944,-8.001,-4.42,-11.821,1
-4282,Pointe Noire,6282,Congo 1960 Pointe Noire,6282,9122,7011,8901,1,0,6422,,,,,,,,
-4283,GDA94,6283,Geocentric Datum of Australia 1994,6283,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4284,Pulkovo 1942,6284,Pulkovo 1942,6284,9122,7024,8901,1,0,6422,,,,,,,,
-4285,Qatar 1974,6285,Qatar 1974,6285,9122,7022,8901,1,0,6422,,,,,,,,
-4286,Qatar 1948,6286,Qatar 1948,6286,9122,7020,8901,1,0,6422,,,,,,,,
-4287,Qornoq,6287,Qornoq,6287,9108,7022,8901,1,1,6402,9603,164,138,-189,,,,
-4288,Loma Quintana,6288,Loma Quintana,6288,9122,7022,8901,1,0,6422,,,,,,,,
-4289,Amersfoort,6289,Amersfoort,6289,9122,7004,8901,1,0,6422,,,,,,,,
-4291,SAD69,6291,South American Datum 1969,6291,9108,7036,8901,1,1,6402,,,,,,,,
-4292,Sapper Hill 1943,6292,Sapper Hill 1943,6292,9122,7022,8901,1,0,6422,9603,-355,21,72,,,,
-4293,Schwarzeck,6293,Schwarzeck,6293,9122,7046,8901,1,0,6422,,,,,,,,
-4294,Segora,6294,Segora,6294,9108,7004,8901,1,1,6402,,,,,,,,
-4295,Serindung,6295,Serindung,6295,9122,7004,8901,1,0,6422,,,,,,,,
-4296,Sudan,6296,Sudan,6296,9108,7011,8901,1,1,6402,,,,,,,,
-4297,Tananarive,6297,Tananarive 1925,6297,9122,7022,8901,1,0,6422,9603,-189,-242,-91,,,,
-4298,Timbalai 1948,6298,Timbalai 1948,6298,9122,7016,8901,1,0,6422,,,,,,,,
-4299,TM65,6299,TM65,6299,9122,7002,8901,1,0,6422,,,,,,,,
-4300,TM75,6300,Geodetic Datum of 1965,6300,9122,7002,8901,1,0,6422,,,,,,,,
-4301,Tokyo,6301,Tokyo,6301,9122,7004,8901,1,0,6422,,,,,,,,
-4302,Trinidad 1903,6302,Trinidad 1903,6302,9122,7007,8901,1,0,6422,,,,,,,,
-4303,"TC(1948)",6303,Trucial Coast 1948,6303,9122,7020,8901,1,0,6422,,,,,,,,
-4304,Voirol 1875,6304,Voirol 1875,6304,9122,7011,8901,1,0,6422,9603,-73,-247,227,,,,
-4306,Bern 1938,6306,Bern 1938,6306,9122,7004,8901,1,0,6422,,,,,,,,
-4307,Nord Sahara 1959,6307,Nord Sahara 1959,6307,9122,7012,8901,1,0,6422,,,,,,,,
-4308,RT38,6308,Stockholm 1938,6308,9122,7004,8901,1,0,6422,,,,,,,,
-4309,Yacare,6309,Yacare,6309,9122,7022,8901,1,0,6422,9603,-155,171,37,,,,
-4310,Yoff,6310,Yoff,6310,9122,7011,8901,1,0,6422,,,,,,,,
-4311,Zanderij,6311,Zanderij,6311,9122,7022,8901,1,0,6422,9603,-265,120,-358,,,,
-4312,MGI,6312,Militar-Geographische Institut,6312,9122,7004,8901,1,0,6422,,,,,,,,
-4313,Belge 1972,6313,Reseau National Belge 1972,6313,9122,7022,8901,1,0,6422,,,,,,,,
-4314,DHDN,6314,Deutsches Hauptdreiecksnetz,6314,9122,7004,8901,1,0,6422,,,,,,,,
-4315,Conakry 1905,6315,Conakry 1905,6315,9122,7011,8901,1,0,6422,9603,-23,259,-9,,,,
-4316,Dealul Piscului 1930,6316,Dealul Piscului 1930,6316,9122,7022,8901,1,0,6422,,,,,,,,
-4317,Dealul Piscului 1970,6317,Dealul Piscului 1970,6317,9122,7024,8901,1,1,6422,,,,,,,,
-4318,NGN,6318,National Geodetic Network,6318,9122,7030,8901,1,0,6422,9603,-3.2,-5.7,2.8,,,,
-4319,KUDAMS,6319,Kuwait Utility,6319,9122,7019,8901,1,0,6422,,,,,,,,
-4322,WGS 72,6322,World Geodetic System 1972,6322,9122,7043,8901,1,0,6422,,,,,,,,
-4324,WGS 72BE,6324,WGS 72 Transit Broadcast Ephemeris,6324,9122,7043,8901,1,0,6422,9606,0,0,1.9,0,0,0.814,-0.38
-4326,WGS 84,6326,World Geodetic System 1984,6326,9122,7030,8901,1,0,6422,,,,,,,,
-4600,Anguilla 1957,6600,Anguilla 1957,6600,9122,7012,8901,1,0,6422,,,,,,,,
-4601,Antigua 1943,6601,Antigua 1943,6601,9122,7012,8901,1,0,6422,,,,,,,,
-4602,Dominica 1945,6602,Dominica 1945,6602,9122,7012,8901,1,0,6422,9603,725,685,536,,,,
-4603,Grenada 1953,6603,Grenada 1953,6603,9122,7012,8901,1,0,6422,9603,72,213.7,93,,,,
-4604,Montserrat 1958,6604,Montserrat 1958,6604,9122,7012,8901,1,0,6422,9603,174,359,365,,,,
-4605,St. Kitts 1955,6605,St. Kitts 1955,6605,9122,7012,8901,1,0,6422,,,,,,,,
-4606,St. Lucia 1955,6606,St. Lucia 1955,6606,9122,7012,8901,1,0,6422,9603,-149,128,296,,,,
-4607,St. Vincent 1945,6607,St. Vincent 1945,6607,9122,7012,8901,1,0,6422,9603,195.671,332.517,274.607,,,,
-4608,"NAD27(76)",6608,"North American Datum 1927 (1976)",6608,9122,7008,8901,1,0,6422,,,,,,,,
-4609,"NAD27(CGQ77)",6609,"North American Datum 1927 (CGQ77)",6609,9122,7008,8901,1,0,6422,,,,,,,,
-4610,Xian 1980,6610,Xian 1980,6610,9122,7049,8901,1,0,6422,,,,,,,,
-4611,Hong Kong 1980,6611,Hong Kong 1980,6611,9122,7022,8901,1,0,6422,9606,-162.619,-276.959,-161.764,0.067753,-2.243649,-1.158827,-1.094246
-4612,JGD2000,6612,Japanese Geodetic Datum 2000,6612,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4613,Segara,6613,Gunung Segara,6613,9122,7004,8901,1,0,6422,,,,,,,,
-4614,QND95,6614,Qatar National Datum 1995,6614,9122,7022,8901,1,0,6422,9606,-119.4248,-303.65872,-11.00061,1.164298,0.174458,1.096259,3.657065
-4615,Porto Santo,6615,Porto Santo 1936,6615,9122,7022,8901,1,0,6422,9603,-499,-249,314,,,,
-4616,Selvagem Grande,6616,Selvagem Grande,6616,9122,7022,8901,1,0,6422,,,,,,,,
-4617,"NAD83(CSRS)",6140,NAD83 Canadian Spatial Reference System,6140,9122,7019,8901,1,0,6422,,,,,,,,
-4618,SAD69,6618,South American Datum 1969,6618,9122,7050,8901,1,0,6422,,,,,,,,
-4619,SWEREF99,6619,SWEREF99,6619,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4620,Point 58,6620,Point 58,6620,9122,7012,8901,1,0,6422,9603,-106,-129,165,,,,
-4621,Fort Marigot,6621,Fort Marigot,6621,9122,7022,8901,1,0,6422,9603,137,248,-430,,,,
-4622,Guadeloupe 1948,6622,Guadeloupe 1948,6622,9122,7022,8901,1,0,6422,,,,,,,,
-4623,CSG67,6623,Centre Spatial Guyanais 1967,6623,9122,7022,8901,1,0,6422,9603,-186,230,110,,,,
-4624,RGFG95,6624,Reseau Geodesique Francais Guyane 1995,6624,9122,7019,8901,1,0,6422,9603,2,2,-2,,,,
-4625,Martinique 1938,6625,Martinique 1938,6625,9122,7022,8901,1,0,6422,,,,,,,,
-4626,Reunion 1947,6626,Reunion 1947,6626,9122,7022,8901,1,0,6422,,,,,,,,
-4627,RGR92,6627,Reseau Geodesique de la Reunion 1992,6627,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4628,Tahiti 52,6628,Tahiti 52,6628,9122,7022,8901,1,0,6422,9603,162,117,154,,,,
-4629,Tahaa 54,6629,Tahaa 54,6629,9122,7022,8901,1,0,6422,,,,,,,,
-4630,IGN72 Nuku Hiva,6630,IGN72 Nuku Hiva,6630,9122,7022,8901,1,0,6422,,,,,,,,
-4631,K0 1949,6631,K0 1949,6631,9122,7022,8901,1,1,6422,9603,145,-187,103,,,,
-4632,Combani 1950,6632,Combani 1950,6632,9122,7022,8901,1,0,6422,9603,-382,-59,-262,,,,
-4633,IGN56 Lifou,6633,IGN56 Lifou,6633,9122,7022,8901,1,0,6422,,,,,,,,
-4634,IGN72 Grand Terre,6634,IGN72 Grande Terre,6634,9108,7022,8901,1,1,6402,,,,,,,,
-4635,ST87 Ouvea,6635,ST87 Ouvea,6635,9122,7022,8901,1,1,6422,9606,-122.383,-188.696,103.344,3.5107,-4.9668,-5.7047,4.4798
-4636,Petrels 1972,6636,Petrels 1972,6636,9122,7022,8901,1,0,6422,9603,365,194,166,,,,
-4637,Perroud 1950,6637,Pointe Geologie Perroud 1950,6637,9122,7022,8901,1,0,6422,9603,325,154,172,,,,
-4638,Saint Pierre et Miquelon 1950,6638,Saint Pierre et Miquelon 1950,6638,9122,7008,8901,1,0,6422,9603,30,430,368,,,,
-4639,MOP78,6639,MOP78,6639,9122,7022,8901,1,0,6422,,,,,,,,
-4640,RRAF 1991,6640,Reseau de Reference des Antilles Francaises 1991,6640,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4641,IGN53 Mare,6641,IGN53 Mare,6641,9122,7022,8901,1,0,6422,,,,,,,,
-4642,ST84 Ile des Pins,6642,ST84 Ile des Pins,6642,9122,7022,8901,1,0,6422,,,,,,,,
-4643,ST71 Belep,6643,ST71 Belep,6643,9122,7022,8901,1,0,6422,9606,-480.26,-438.32,-643.429,16.3119,20.1721,-4.0349,-111.7002
-4644,NEA74 Noumea,6644,NEA74 Noumea,6644,9122,7022,8901,1,0,6422,,,,,,,,
-4645,RGNC 1991,6645,Reseau Geodesique Nouvelle Caledonie 1991,6645,9122,7022,8901,1,1,6422,9603,0,0,0,,,,
-4646,Grand Comoros,6646,Grand Comoros,6646,9122,7022,8901,1,0,6422,,,,,,,,
-4657,Reykjavik 1900,6657,Reykjavik 1900,6657,9122,7051,8901,1,0,6422,9603,-28,199,5,,,,
-4658,Hjorsey 1955,6658,Hjorsey 1955,6658,9122,7022,8901,1,0,6422,9603,-73,46,-86,,,,
-4659,ISN93,6659,Islands Network 1993,6659,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4660,Helle 1954,6660,Helle 1954,6660,9122,7022,8901,1,0,6422,9606,982.6087,552.753,-540.873,32.39344,-153.25684,-96.2266,16.805
-4661,LKS92,6661,Latvia 1992,6661,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4662,IGN72 Grande Terre,6634,IGN72 Grande Terre,6634,9122,7022,8901,1,0,6422,,,,,,,,
-4663,Porto Santo 1995,6663,Porto Santo 1995,6663,9122,7022,8901,1,0,6422,,,,,,,,
-4664,Azores Oriental 1995,6664,Azores Oriental Islands 1995,6664,9122,7022,8901,1,0,6422,,,,,,,,
-4665,Azores Central 1995,6665,Azores Central Islands 1995,6665,9122,7022,8901,1,0,6422,,,,,,,,
-4666,Lisbon 1890,6666,Lisbon 1890,6666,9122,7004,8901,1,0,6422,,,,,,,,
-4667,IKBD-92,6667,Iraq-Kuwait Boundary Datum 1992,6667,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4668,ED79,6668,European Datum 1979,6668,9122,7022,8901,1,0,6422,9603,-86,-98,-119,,,,
-4669,LKS94,6126,"Lithuania 1994 (ETRS89)",6126,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4670,IGM95,6670,Istituto Geografico Militaire 1995,6670,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4671,Voirol 1879,6671,Voirol 1879,6671,9122,7011,8901,1,0,6422,,,,,,,,
-4672,Chatham Islands 1971,6672,Chatham Islands Datum 1971,6672,9122,7022,8901,1,0,6422,9603,175,-38,113,,,,
-4673,Chatham Islands 1979,6673,Chatham Islands Datum 1979,6673,9122,7022,8901,1,0,6422,9607,174.05,-25.49,112.57,0,0,-0.554,0.2263
-4674,SIRGAS 2000,6674,Sistema de Referencia Geocentrico para America del Sur 2000,6674,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4675,Guam 1963,6675,Guam 1963,6675,9122,7008,8901,1,0,6422,9603,-100,-248,259,,,,
-4676,Vientiane 1982,6676,Vientiane 1982,6676,9122,7024,8901,1,0,6422,,,,,,,,
-4677,Lao 1993,6677,Lao 1993,6677,9122,7024,8901,1,0,6422,,,,,,,,
-4678,Lao 1997,6678,Lao National Datum 1997,6678,9122,7024,8901,1,0,6422,9603,44.585,-131.212,-39.544,,,,
-4679,Jouik 1961,6679,Jouik 1961,6679,9122,7012,8901,1,0,6422,9603,-80.01,253.26,291.19,,,,
-4680,Nouakchott 1965,6680,Nouakchott 1965,6680,9122,7012,8901,1,0,6422,9603,124.5,-63.5,-281,,,,
-4681,Mauritania 1999,6681,Mauritania 1999,6681,9122,7012,8901,1,1,6422,,,,,,,,
-4682,Gulshan 303,6682,Gulshan 303,6682,9122,7015,8901,1,0,6422,,,,,,,,
-4683,PRS92,6683,Philippine Reference System 1992,6683,9122,7008,8901,1,0,6422,9607,-127.62,-67.24,-47.04,3.068,-4.903,-1.578,-1.06
-4684,Gan 1970,6684,Gan 1970,6684,9122,7022,8901,1,0,6422,9603,-133,-321,50,,,,
-4685,Gandajika,6685,Gandajika,6685,9122,7022,8901,1,1,6422,,,,,,,,
-4686,MAGNA-SIRGAS,6686,Marco Geocentrico Nacional de Referencia,6686,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4687,RGPF,6687,Reseau Geodesique de la Polynesie Francaise,6687,9122,7019,8901,1,0,6422,,,,,,,,
-4688,Fatu Iva 72,6688,Fatu Iva 72,6688,9122,7022,8901,1,0,6422,9607,347.103,1078.125,2623.922,33.8875,-70.6773,9.3943,186.074
-4689,IGN63 Hiva Oa,6689,IGN63 Hiva Oa,6689,9122,7022,8901,1,0,6422,,,,,,,,
-4690,Tahiti 79,6690,Tahiti 79,6690,9122,7022,8901,1,0,6422,,,,,,,,
-4691,Moorea 87,6691,Moorea 87,6691,9122,7022,8901,1,0,6422,9607,215.525,149.593,176.229,3.2624,1.692,1.1571,10.4773
-4692,Maupiti 83,6692,Maupiti 83,6692,9122,7022,8901,1,0,6422,9603,217.037,86.959,23.956,,,,
-4693,Nakhl-e Ghanem,6693,Nakhl-e Ghanem,6693,9122,7030,8901,1,0,6422,9603,0,-0.15,0.68,,,,
-4694,POSGAR 94,6694,Posiciones Geodesicas Argentinas 1994,6694,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4695,Katanga 1955,6695,Katanga 1955,6695,9122,7008,8901,1,0,6422,9603,-103.746,-9.614,-255.95,,,,
-4696,Kasai 1953,6696,Kasai 1953,6696,9122,7012,8901,1,0,6422,,,,,,,,
-4697,IGC 1962 6th Parallel South,6697,IGC 1962 Arc of the 6th Parallel South,6697,9122,7012,8901,1,0,6422,,,,,,,,
-4698,IGN 1962 Kerguelen,6698,IGN 1962 Kerguelen,6698,9122,7022,8901,1,0,6422,9603,145,-187,103,,,,
-4699,Le Pouce 1934,6699,Le Pouce 1934,6699,9122,7012,8901,1,0,6422,9603,-770.1,158.4,-498.2,,,,
-4700,IGN Astro 1960,6700,IGN Astro 1960,6700,9122,7012,8901,1,0,6422,,,,,,,,
-4701,IGCB 1955,6701,Institut Geographique du Congo Belge 1955,6701,9122,7012,8901,1,0,6422,9603,-79.9,-158,-168.9,,,,
-4702,Mauritania 1999,6702,Mauritania 1999,6702,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4703,Mhast 1951,6703,Missao Hidrografico Angola y Sao Tome 1951,6703,9122,7012,8901,1,0,6422,,,,,,,,
-4704,"Mhast (onshore)",6704,"Mhast (onshore)",6704,9122,7022,8901,1,0,6422,,,,,,,,
-4705,"Mhast (offshore)",6705,"Mhast (offshore)",6705,9122,7022,8901,1,0,6422,,,,,,,,
-4706,Egypt Gulf of Suez S-650 TL,6706,Egypt Gulf of Suez S-650 TL,6706,9122,7020,8901,1,0,6422,9603,-146.21,112.63,4.05,,,,
-4707,Tern Island 1961,6707,Tern Island 1961,6707,9122,7022,8901,1,0,6422,9603,114,-116,-333,,,,
-4708,Cocos Islands 1965,6708,Cocos Islands 1965,6708,9122,7003,8901,1,0,6422,9603,-491,-22,435,,,,
-4709,Iwo Jima 1945,6709,Iwo Jima 1945,6709,9122,7022,8901,1,0,6422,9603,145,75,-272,,,,
-4710,St. Helena 1971,6710,St. Helena 1971,6710,9122,7022,8901,1,0,6422,9603,-320,550,-494,,,,
-4711,Marcus Island 1952,6711,Marcus Island 1952,6711,9122,7022,8901,1,0,6422,9603,124,-234,-25,,,,
-4712,Ascension Island 1958,6712,Ascension Island 1958,6712,9122,7022,8901,1,0,6422,9603,-205,107,53,,,,
-4713,Ayabelle Lighthouse,6713,Ayabelle Lighthouse,6713,9122,7012,8901,1,0,6422,9603,-79,-129,145,,,,
-4714,Bellevue,6714,Bellevue,6714,9122,7022,8901,1,0,6422,9603,-127,-769,472,,,,
-4715,Camp Area Astro,6715,Camp Area Astro,6715,9122,7022,8901,1,0,6422,9603,-104,-129,239,,,,
-4716,Phoenix Islands 1966,6716,Phoenix Islands 1966,6716,9122,7022,8901,1,0,6422,9603,298,-304,-375,,,,
-4717,Cape Canaveral,6717,Cape Canaveral,6717,9122,7008,8901,1,0,6422,9603,-2,151,181,,,,
-4718,Solomon 1968,6718,Solomon 1968,6718,9122,7022,8901,1,0,6422,,,,,,,,
-4719,Easter Island 1967,6719,Easter Island 1967,6719,9122,7022,8901,1,0,6422,9603,211,147,111,,,,
-4720,Fiji 1986,6720,Fiji Geodetic Datum 1986,6720,9122,7043,8901,1,0,6422,,,,,,,,
-4721,Fiji 1956,6721,Fiji 1956,6721,9122,7022,8901,1,0,6422,9603,265.025,384.929,-194.046,,,,
-4722,South Georgia 1968,6722,South Georgia 1968,6722,9122,7022,8901,1,0,6422,9603,-794,119,-298,,,,
-4723,Grand Cayman 1959,6723,Grand Cayman 1959,6723,9122,7008,8901,1,0,6422,9603,67.8,106.1,138.8,,,,
-4724,Diego Garcia 1969,6724,Diego Garcia 1969,6724,9122,7022,8901,1,0,6422,9603,208,-435,-229,,,,
-4725,Johnston Island 1961,6725,Johnston Island 1961,6725,9122,7022,8901,1,0,6422,9603,189,-79,-202,,,,
-4726,Little Cayman 1961,6726,Little Cayman 1961,6726,9122,7008,8901,1,0,6422,,,,,,,,
-4727,Midway 1961,6727,Midway 1961,6727,9122,7022,8901,1,0,6422,,,,,,,,
-4728,Pico de las Nieves 1984,6728,Pico de las Nieves 1984,6728,9122,7022,8901,1,0,6422,9603,-307,-92,127,,,,
-4729,Pitcairn 1967,6729,Pitcairn 1967,6729,9122,7022,8901,1,0,6422,9603,185,165,42,,,,
-4730,Santo 1965,6730,Santo 1965,6730,9122,7022,8901,1,0,6422,9603,170,42,84,,,,
-4731,Viti Levu 1916,6731,Viti Levu 1916,6731,9122,7012,8901,1,1,6422,9603,51,391,-36,,,,
-4732,Marshall Islands 1960,6732,Marshall Islands 1960,6732,9122,7053,8901,1,0,6422,9603,102,52,-38,,,,
-4733,Wake Island 1952,6733,Wake Island 1952,6733,9122,7022,8901,1,0,6422,9603,276,-57,149,,,,
-4734,Tristan 1968,6734,Tristan 1968,6734,9122,7022,8901,1,0,6422,9603,-632,438,-609,,,,
-4735,Kusaie 1951,6735,Kusaie 1951,6735,9122,7022,8901,1,0,6422,9603,647,1777,-1124,,,,
-4736,Deception Island,6736,Deception Island,6736,9122,7012,8901,1,0,6422,9603,260,12,-147,,,,
-4737,Korea 2000,6737,Geocentric datum of Korea,6737,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4738,Hong Kong 1963,6738,Hong Kong 1963,6738,9122,7007,8901,1,0,6422,,,,,,,,
-4739,"Hong Kong 1963(67)",6739,"Hong Kong 1963(67)",6739,9122,7022,8901,1,0,6422,9603,-156,-271,-189,,,,
-4740,PZ-90,6740,Parametrop Zemp 1990,6740,9122,7054,8901,1,0,6422,,,,,,,,
-4741,FD54,6741,Faroe Datum 1954,6741,9122,7022,8901,1,0,6422,,,,,,,,
-4742,GDM2000,6742,Geodetic Datum of Malaysia 2000,6742,9122,7019,8901,1,0,6422,,,,,,,,
-4743,Karbala 1979,6743,Karbala 1979,6743,9122,7012,8901,1,0,6422,9603,84.1,-320.1,218.7,,,,
-4744,Nahrwan 1934,6744,Nahrwan 1934,6744,9122,7012,8901,1,0,6422,,,,,,,,
-4745,"RD/83",6745,"Rauenberg Datum/83",6745,9122,7004,8901,1,0,6422,,,,,,,,
-4746,"PD/83",6746,"Potsdam Datum/83",6746,9122,7004,8901,1,0,6422,,,,,,,,
-4747,GR96,6747,Greenland 1996,6747,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4748,Vanua Levu 1915,6748,Vanua Levu 1915,6748,9122,7055,8901,1,0,6422,9603,51,391,-36,,,,
-4749,RGNC91-93,6749,Reseau Geodesique de Nouvelle Caledonie 91-93,6749,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4750,ST87 Ouvea,6750,ST87 Ouvea,6750,9122,7030,8901,1,0,6422,9603,-56.263,16.136,-22.856,,,,
-4751,"Kertau (RSO)",6751,"Kertau (RSO)",6751,9122,7056,8901,1,0,6422,,,,,,,,
-4752,Viti Levu 1912,6752,Viti Levu 1912,6752,9122,7055,8901,1,0,6422,9603,51,391,-36,,,,
-4753,fk89,6753,fk89,6753,9122,7022,8901,1,0,6422,,,,,,,,
-4754,LGD2006,6754,Libyan Geodetic Datum 2006,6754,9122,7022,8901,1,0,6422,9603,-208.4058,-109.8777,-2.5764,,,,
-4755,DGN95,6755,Datum Geodesi Nasional 1995,6755,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4756,VN-2000,6756,Vietnam 2000,6756,9122,7030,8901,1,0,6422,,,,,,,,
-4757,SVY21,6757,SVY21,6757,9122,7030,8901,1,0,6422,,,,,,,,
-4758,JAD2001,6758,Jamaica 2001,6758,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4759,"NAD83(NSRS2007)",6759,"NAD83 (National Spatial Reference System 2007)",6759,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4760,WGS 66,6760,World Geodetic System 1966,6760,9122,7025,8901,1,0,6422,,,,,,,,
-4761,HTRS96,6761,Croatian Terrestrial Reference System,6761,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4762,BDA2000,6762,Bermuda 2000,6762,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4763,Pitcairn 2006,6763,Pitcairn 2006,6763,9122,7030,8901,1,0,6422,9603,0,0,0,,,,
-4764,RSRGD2000,6764,Ross Sea Region Geodetic Datum 2000,6764,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4765,Slovenia 1996,6765,Slovenia Geodetic Datum 1996,6765,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
-4801,"Bern 1898 (Bern)",6801,"CH1903 (Bern)",6149,9122,7004,8907,1,0,6422,,,,,,,,
-4802,"Bogota 1975 (Bogota)",6802,"Bogota 1975 (Bogota)",6218,9122,7022,8904,1,0,6422,,,,,,,,
-4803,"Lisbon (Lisbon)",6803,"Lisbon 1937 (Lisbon)",6207,9122,7022,8902,1,0,6422,,,,,,,,
-4804,"Makassar (Jakarta)",6804,"Makassar (Jakarta)",6257,9122,7004,8908,1,0,6422,9603,-587.8,519.75,145.76,,,,
-4805,"MGI (Ferro)",6805,"Militar-Geographische Institut (Ferro)",1031,9122,7004,8909,1,0,6422,,,,,,,,
-4806,"Monte Mario (Rome)",6806,"Monte Mario (Rome)",6265,9122,7022,8906,1,0,6422,,,,,,,,
-4807,"NTF (Paris)",6807,"Nouvelle Triangulation Francaise (Paris)",6275,9105,7011,8903,1,0,6403,9603,-168,-60,320,,,,
-4808,"Padang (Jakarta)",6808,"Padang 1884 (Jakarta)",6280,9122,7004,8908,1,0,6422,,,,,,,,
-4809,"Belge 1950 (Brussels)",6809,"Reseau National Belge 1950 (Brussels)",6215,9122,7022,8910,1,0,6422,,,,,,,,
-4810,"Tananarive (Paris)",6810,"Tananarive 1925 (Paris)",6297,9105,7022,8903,1,0,6403,9603,-189,-242,-91,,,,
-4811,"Voirol 1875 (Paris)",6811,"Voirol 1875 (Paris)",6304,9105,7011,8903,1,0,6403,9603,-73,-247,227,,,,
-4813,"Batavia (Jakarta)",6813,"Batavia (Jakarta)",6211,9122,7004,8908,1,0,6422,,,,,,,,
-4814,"RT38 (Stockholm)",6814,"Stockholm 1938 (Stockholm)",6308,9122,7004,8911,1,0,6422,,,,,,,,
-4815,"Greek (Athens)",6815,"Greek (Athens)",6120,9122,7004,8912,1,0,6422,,,,,,,,
-4816,"Carthage (Paris)",6816,"Carthage (Paris)",6223,9105,7011,8903,1,0,6403,,,,,,,,
-4817,"NGO 1948 (Oslo)",6817,"NGO 1948 (Oslo)",6273,9122,7005,8913,1,0,6422,9606,278.3,93,474.5,7.889,0.05,-6.61,6.21
-4818,"S-JTSK (Ferro)",6818,"S-JTSK (Ferro)",6156,9122,7004,8909,1,0,6422,,,,,,,,
-4819,"Nord Sahara 1959 (Paris)",6819,"Nord Sahara 1959 (Paris)",6307,9105,7012,8903,1,1,6403,,,,,,,,
-4820,"Segara (Jakarta)",6820,"Gunung Segara (Jakarta)",6613,9122,7004,8908,1,0,6422,,,,,,,,
-4821,"Voirol 1879 (Paris)",6821,"Voirol 1879 (Paris)",6821,9105,7011,8903,1,0,6403,,,,,,,,
-4901,"ATF (Paris)",6901,"Ancienne Triangulation Francaise (Paris)",6901,9105,7027,8914,1,0,6403,,,,,,,,
-4902,"NDG (Paris)",6902,"Nord de Guerre (Paris)",6902,9105,7027,8903,1,1,6403,,,,,,,,
-4903,"Madrid 1870 (Madrid)",6903,"Madrid 1870 (Madrid)",6903,9122,7028,8905,1,0,6422,,,,,,,,
-4904,"Lisbon 1890 (Lisbon)",6904,"Lisbon 1890 (Lisbon)",6666,9122,7004,8902,1,0,6422,,,,,,,,
Deleted: grass/trunk/lib/proj/gcs.override.csv
--- grass/trunk/lib/proj/gcs.override.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/gcs.override.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,47 +0,0 @@
-# NOTICE: The master version of this file is in the libgeotiff subversion at:
-# https://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/gcs.override.csv
-# Do *not* change other copies without upstreaming the results to libgeotiff.
-# See http://bugzilla.remotesensing.org/show_bug.cgi?id=339
-# Or http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/geodeticdatums/index.jsp
-4272,NZGD49,6272,New Zealand Geodetic Datum 1949,6272,9122,7022,8901,1,0,6422,9606,59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
-# Use the seven-parameter transformation from the BEV (1618) for MGI (bug 870)
-4312,MGI,6312,Militar-Geographische Institut,6312,9108,7004,8901,1,0,6422,9606,577.326,90.129,463.919,5.137,1.474,5.297,2.4232
-# Bart van den Eijnden and Jan Hartmann suggest this datum shift value:
-#4289,Amersfoort,6289,Amersfoort,6289,9122,7004,8901,1,0,9606,565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
-# Per http://bugzilla.remotesensing.org/show_bug.cgi?id=1305
-4218,Bogota 1975,6218,Bogota 1975,6218,9122,7022,8901,1,0,6422,9603,307,304,-318,,,,
-# Per http://bugzilla.remotesensing.org/show_bug.cgi?id=957
-4149,CH1903,6149,CH1903,6149,9122,7004,8901,1,0,6422,9603,674.374,15.056,405.346,,,,
-# From Jan: http://bugzilla.remotesensing.org/show_bug.cgi?id=1336
-4313,Belge 1972,6313,Reseau National Belge 1972,6313,9122,7022,8901,1,0,6422,9606,106.868628,-52.297783,103.723893,-0.336570,0.456955,-1.842183,1.0000012747
-# Seven-parameter transformation for Pulkovo 1942
-# as defined by the GOST P 51794-2001.
-# See http://trac.osgeo.org/gdal/ticket/3176 for details.
-4284,Pulkovo 1942,6284,Pulkovo 1942,6284,9122,7024,8901,1,0,6422,9607,23.9,-141.3,-80.9,0,-0.37,-0.85,-0.12
-# Forward-ported from 1.6 (and consistant with 1.8dev) (see ticket #3579)
-4179,"Pulkovo 1942(58)",6179,"Pulkovo 1942/58",6179,9122,7024,8901,1,0,6422,9606,33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
-# Backported from 1.8dev (see ticket #3579)
-4258,ETRS89,6258,European Terrestrial Reference System 1989,6258,9122,7019,8901,1,0,6422,9603,0,0,0,,,,
Deleted: grass/trunk/lib/proj/gdal_datum.csv
--- grass/trunk/lib/proj/gdal_datum.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/gdal_datum.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,571 +0,0 @@
-"DATUM_CODE","DATUM_NAME","DATUM_TYPE","ORIGIN_DESCRIPTION","REALIZATION_EPOCH","ELLIPSOID_CODE","PRIME_MERIDIAN_CODE","AREA_OF_USE_CODE","DATUM_SCOPE","REMARKS","INFORMATION_SOURCE","DATA_SOURCE","REVISION_DATE","CHANGE_ID","DEPRECATED","ESRI_DATUM_NAME"
-1024,Hungarian Datum 1909,geodetic,"Fundamental point not given in information source, but presumably Szolohegy which is origin of later HD72.",1909,7004,8901,1119,Topographic mapping.,"Replaced earlier HD1863 adjustment also on Bessel ellipsoid. Both HD1863 and HD1909 were originally on Ferro Prime Meridian but subsequently converted to Greenwich. Replaced by HD72 (datum code 6237).","Timár, Molnár and Márta in Geodezia es Kartografia 55(3) pp16-21. www.fomi.hu/internet/magyar/szaklap/geodkart.htm",OGP,2008-08-02,,0,
-1025,Taiwan Datum 1967,geodetic,"Fundamental point: Hu Tzu Shan. Latitude: 23°58'32.34""N, longitude: 120°58'25.975""E (of Greenwich).",1967,7050,8901,3315,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Adopted in 1980. TWD67 uses the GRS 1967 ellipsoid but with 1/f to exactly 2 decimal places.","National Land Surveying and Mapping Center (NLSC), http://www.nlsc.gov.tw",OGP,2008-08-11,,0,
-1026,Taiwan Datum 1997,geodetic,ITRF94 at epoch 1997.0,1997,7019,8901,1228,"Geodetic survey, GIS, topographic mapping, engineering survey.",Adopted in 1998.,"National Land Surveying and Mapping Center (NLSC), http://www.nlsc.gov.tw",OGP,2008-08-11,,0,
-1027,EGM2008 geoid,vertical,WGS 84 ellipsoid.,2008,,,1262,Geodesy.,,"http://earth-info.nga.mil/GandG/wgs84/gravitymod/egm2008/egm08_wgs84.html",OGP,2009-01-30,2008.097,0,
-1028,Fao 1979,vertical,"Average sea level at Fao during two-year period in mid/late 1970s.",1979,,,3625,"Topographic mapping, geodetic survey.","Replaces Fao (datum code 5149) in Iraq.","Survey Division, Ministry of Water Resources (MoWR).",OGP,2009-03-01,2009.003,0,
-1029,Iraqi Geospatial Reference System,geodetic,ITRF2000 at epoch 1997.0,2000,7019,8901,1124,Geodetic survey.,,"Survey Division, Ministry of Water Resources (MoWR).",OGP,2009-02-03,2009.003,0,
-1031,MGI 1901,geodetic,"Fundamental point: Hermannskogel. Latitude: 48°16'15.29""N, longitude: 16°17'55.04""E (of Greenwich).",1901,7004,8901,2370,Geodetic survey.,"The longitude of the datum origin equates to the Albrecht 1902 value for the Ferro meridian of 17°39'46.02"" west of Greenwich. Densified in 1948.","The Ferro prime meridian, Gabor Timar (2007), Geodezia es Kartografia vol 59 issue 12 pages 3-7.",OGP,2009-05-10,2009.015,0,
-1032,MOLDREF99,geodetic,Densification of ETRS89.,1999,7019,8901,1162,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"State Agency for Land Relations & Cadastre.",OGP,2009-05-11,2009.026,0,"D_International_1967"
-1033,Reseau Geodesique de la RDC 2005,geodetic,ITRF2000 at epoch 2005.4.,2005,7019,8901,3613,Geodetic survey.,,"""Revision du Tiers Meridional du Reseau Geodesique de la RDC"", COPIREP Reclus project report, 2005.",OGP,2009-04-16,2009.011,0,
-1034,Serbian Reference Network 1998,geodetic,"Densification of ETRS89 in Serbia at epoch 1998.7 based on coordinates of 6 stations in Serbia of Yugoslav Reference Frame (YUREF) 1998 campaign.",1998,7019,8901,3534,Geodesy.,Observed 1998-2003.,"Delcev et al, FIG Working Week May 2009; http://www.gig.net/pub",OGP,2009-05-11,2009.015,0,
-1035,Red Geodesica de Canarias 1995,geodetic,ITRF93 at epoch 1994.9 at VLBI station Maspalomas on Grand Canary.,1995,7019,8901,3199,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Pico de las Nieves 1984 (PN84).","IGN Madrid. http://www.fomento.es.",OGP,2009-05-15,2009.033,0,
-5100,Mean Sea Level,vertical,,,,,1262,Hydrography.,"msl has geographic and temporal components.  Users are advised to not use this generic vertical datum but to define specific instances of msl based on knowledge of these components; for instance ""msl at xxx during 19yy"".",,OGP,1996-04-12,,0,"D_Mean_Sea_Level"
-5101,Ordnance Datum Newlyn,vertical,Mean Sea Level at Newlyn between 1915 and 1921.,,,,2792,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2004-06-16,2004.100,0,"D_Ordnance_Datum_Newlyn"
-5102,National Geodetic Vertical Datum 1929,vertical,26 tide gauges in the US and Canada.,1929,,,1323,"Topographic mapping, geodetic survey.",Normal orthometric heights.,,OGP,1996-09-12,,0,
-5103,North American Vertical Datum 1988,vertical,"Father's Point, Rimouski, Quebec.",1988,,,1325,"Topographic mapping, geodetic survey.",Helmert orthometric heights.,,OGP,2006-01-16,2005.880,0,
-5104,Yellow Sea 1956,vertical,2 years tide readings at Qingdao.,1956,,,3228,"Topographic mapping, geodetic survey.",Replaced by Yellow Sea 1985 datum.,,OGP,2002-06-22,2002.160,0,
-5105,Baltic Sea,vertical,"Datum: average water level at Kronstadt 1833. Network adjusted in 1977.",1977,,,1284,"Topographic mapping, geodetic survey.",Uses Normal heights.,,OGP,2005-05-27,2004.100 2005.180,0,
-5106,Caspian Sea,vertical,Defined as -28.0m Baltic datum,,,,1291,Hydrography.,,,OGP,1996-09-12,,0,
-5107,Nivellement general de la France,vertical,Mean sea level at Marseille,,,,1326,"Topographic mapping, geodetic survey.",The CNIG states that NGF is a general term applying to all vertical network readjustments of France and recommends more specific terminology. See codes 5118-5120.,"Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",OGP,1996-09-12,,1,
-5109,Normaal Amsterdams Peil,vertical,Mean high tide at Amsterdams Peil in 1684.,,,,1275,"Topographic mapping, geodetic survey, hydrography.",Orthometric heights.,"Nederlandse Commissie voor Geodesie publication 30; 1993",OGP,2006-01-16,2004.100 2005.880,0,
-5110,Oostende,vertical,Mean low water during 1958,1958,,,1347,"Topographic mapping, geodetic survey.",,"Nederlandse Commissie voor Geodesie publication 30; 1993",OGP,2006-01-16,2005.880,0,
-5111,Australian Height Datum,vertical,MSL 1966-68 at 30 gauges around coast.,1968,,,1281,"Topographic mapping, geodetic survey.",,Australian Land Information Group  www.auslig.gov.au,OGP,2005-09-06,2005.460,0,
-5112,"Australian Height Datum (Tasmania)",vertical,MSL 1972 at Hobart and Burnie.,1972,,,1282,"Topographic mapping, geodetic survey.",,,OGP,1996-09-12,,0,
-5113,Sea Level,vertical,,,,,1262,Hydrography.,An unspecified local vertical datum not recommended for use.,,OGP,1996-09-12,,0,
-5114,Canadian Geodetic Vertical Datum of 1928,vertical,Based on the mean sea level determined from several tidal gauges located in strategic areas of the country,1928,,,1289,"Topographic mapping, geodetic survey.",,"Geodetic Survey Division, Natural Resources Canada. http://maps.nrcan.gc.ca/asdb/asdb_datum.html and http://www.geod.nrcan.gc.ca/index_e/help_e/acron_e.html",OGP,2004-11-26,2004.723,0,
-5115,Piraeus Harbour 1986,vertical,MSL determined during 1986.,1986,,,3254,"Topographic mapping, geodetic survey.",,"Geodesy Department; Public Pertoleum Corporation of Greece",OGP,1997-06-16,,0,
-5116,Helsinki 1960,vertical,MSL at Helsinki during 1960.,1960,,,3333,"Topographic mapping, geodetic survey.",,"National Land Survey of Finland;¶http://www.maanmittauslaitos.fi",OGP,1997-07-22,,0,
-5117,Rikets hojdsystem 1970,vertical,"Adjustment is referenced to mean high tide at Amsterdams Peil in 1684. To account for land level movements caused by isostatic rebound, heights are reduced to epoch 1970.0 using uplift values computed from repeated levelling observations.",1970,,,3313,"Topographic mapping, geodetic survey.",Realised through the second precise levelling network of 1951-1967. Uses Normal heights. Replaces RH00. Replaced in 2005 by RH2000.,National Land Survey of Sweden,OGP,2008-03-14,2002.480 2004.100 2008.013,0,
-5118,Nivellement General de la France - Lallemand,vertical,"Rivet number M.ac O-VIII on the Marseille tide gauge site, with the height fixed in 1897 at 1.661 metre above mean sea level between February 2nd 1885 and January 1st 1897.",,,,1326,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",OGP,1997-11-13,2001.470 2004.060,0,
-5119,Nivellement General de la France - IGN69,vertical,"Rivet number M.ac O-VIII on the Marseille tide gauge site, with the height fixed in 1897 at 1.661 metre above mean sea level between February 2nd 1885 and January 1st 1897.",1969,,,1326,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights.,"Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",OGP,1997-11-13,2001.470,0,
-5120,IGN78 Corsica,vertical,Marker MM3 situated on the tide gauge site of Ajaccio. Height is 3.640 metre above mean sea level.,1978,,,1327,"Geodetic survey, topographic mapping, engineering survey.","Uses Normal heights. Replaces NGC (datum code 5189).","Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",OGP,2004-10-14,2001.470 2004.060 2004.564,0,
-5121,Maputo,vertical,Mean sea level at Maputo.,,,,3281,Topographic mapping.,,"Direcção Nacional de Geografia e Cadastral (DINAGECA).",OGP,1998-04-16,,0,
-5122,Japanese Standard Levelling Datum 1949,vertical,24.4140 metres above mean sea level Tokyo Bay.,1949,,,3263,"Topographic mapping, geodetic survey.",,"Ministry of Construction; Japan.  http://vldb.gsi.go.jp/sokuchi/datum/tokyodatum.html",OGP,2004-05-09,2002.080 2004.380,0,
-5123,PDO Height Datum 1993,vertical,,1993,,,3288,Oil industry mapping.,"Misclosure between Muscat and Salalah less than .5 meters with differences from of up to 5 meters from old Fahud Datum.  The PHD93 adjustment was initially known as the Spine.  Replaces Fahud Vertical Datum (code 5124) from 1993.",Petroleum Development Oman,OGP,1999-04-22,,0,
-5124,Fahud Height Datum,vertical,Single MSL determination at Mina Al Fahal.,,,,3288,Oil industry mapping.,"Based on reciprocal trigonometric heighting. Replaced by PHD93 Datum (code 5123) in 1993.",Petroleum Development Oman,OGP,2004-04-07,2004.212,0,
-5125,Ha Tien 1960,vertical,,1960,,,1302,"Topographic mapping, geodetic survey.",In Vietnam replaced by Hon Dau in 1992.,,OGP,1999-10-20,,0,
-5126,Hon Dau 1992,vertical,,1992,,,3328,"Topographic mapping, geodetic survey.",Replaces Ha Tien in Vietnam.,,OGP,1999-10-20,,0,
-5127,Landesnivellement 1902,vertical,"Origin at Repere Pierre du Niton (RPN) defined as 373.6 metres above msl. This value derived from msl at Marseille in 1897 through the French Lallemand network.",1902,,,1286,"Topographic mapping, cadastral survey.","Levelling observations not corrected for gravity field. For scientific purposes, replaced by LHHN95.","Bundesamt für Landestopographie",OGP,2004-06-16,2004.100,0,
-5128,Landeshohennetz 1995,vertical,"Origin at Repere Pierre du Niton (RPN) defined as 373.6 metres above msl. This value derived from msl at Marseille in 1897 through the French Lallemand network.",1995,,,1286,Geodetic survey and scientific studies.,"Orthometric heights. For scientific purposes only, replaces LN02.","Bundesamt für Landestopographie",OGP,2004-06-16,2004.100,0,
-5129,European Vertical Reference Frame 2000,vertical,"Height at Normaal Amsterdams Peil (NAP) is zero, defined through height at UELN bench mark 13600 (52°22'53""N 4°54'34""E) of 0.71599m. Datum at NAP is mean high tide in 1684.",2000,,,1299,Geodesy.,"Realised by geopotential numbers and Normal heights of the United European Levelling Network. Replaced by EVRF2007 (datum code 5215).","European veritical data centre at Bundesamt für Kartographie und Geodäsie (BKG), Leipzig branch. http://crs.bkg.bund.de/evrs/",OGP,2008-06-24,2008.045 2008.101,0,
-5130,Malin Head,vertical,Mean sea level between January 1960 and December 1969.,1970,,,1305,Topographic mapping,Orthometric heights.,Ordnance Survey of Ireland,OGP,2001-11-06,,0,
-5131,Belfast Lough,vertical,"Mean sea level between 1951 and 1956 at Clarendon Dock, Belfast.",1957,,,2530,"Large scale (1:1,250, 1:2,500 and 1:10,000) topographic mapping.","Orthometric heights. Malin Head (datum code 5130) used for 1:50,000 and smaller mapping.",Ordnance Survey of Northern Ireland,OGP,2002-09-19,2002.620,0,
-5132,Dansk Normal Nul,vertical,Mean Sea Level at 10 gauges.,,,,3237,Topographic mapping and engineering survey,Orthometric heights.,"Kort & Matrikelstyrelsen",OGP,2001-11-06,,0,
-5133,AIOC 1995,vertical,Average level of Caspian Sea at the Oil Rocks tide gauge June-September 1995.,1995,,,2592,Oil industry mapping.,AIOC 1995 datum is 1.7m above Caspian datum and 26.3m below Baltic datum.,BP,OGP,2002-02-12,,0,
-5134,Black Sea,vertical,,,,,1102,Hydrographic surveying and since break-up of Former Soviet Union also topographic mapping.,Black Sea datum is 0.4m below Baltic datum.,BP,OGP,2002-02-12,,0,
-5135,Hong Kong Principal Datum,vertical,"1.23m below the mean of 19 years (1965-83) observations of tide levels at North Point, Victoria Harbour.",1980,,,3334,"Geodetic survey, engineering survey, cadastre.",,"Survey and Mapping Office, Lands Department. Http://www.info.gov.hk/landsd/mapping/tindex.htm",OGP,2002-06-22,,0,
-5136,Hong Kong Chart Datum,vertical,"Approximates to Lowest Astronomic Tide level (LAT).",,,,3335,Hydrographic survey and charting.,"Chart datum is 0.15 metres below Hong Kong Principal Datum (code 5135) and 1.38m below MSL at Quarry Bay.","Survey and Mapping Office, Lands Department. Http://www.info.gov.hk/landsd/mapping/tindex.htm",OGP,2009-05-21,2009.022,0,
-5137,Yellow Sea 1985,vertical,20 years tide readings at Qingdao.,1985,,,3228,"Topographic mapping, geodetic survey.",Replaces Yellow Sea 1956 datum.,Guangdong Province Land Resource Information Centre,OGP,2002-06-22,,0,
-5138,"Ordnance Datum Newlyn (Orkney Isles)",vertical,Connected to Newlyn datum by triangulation from the British mainland.,,,,2793,"Topographic mapping, geodetic survey.",Considered as separate from Newlyn because the accuracy of the trigonometric connection across the Pentland Firth does not meet geodetic levelling specifications. Orthometric heights.,Ordnance Survey of Great Britain,OGP,2004-06-16,2004.100,0,
-5139,Fair Isle,vertical,,,,,2794,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5140,Lerwick,vertical,,,,,2795,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5141,Foula,vertical,,,,,2796,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5142,Sule Skerry,vertical,,,,,2797,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5143,North Rona,vertical,,,,,2798,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5144,Stornoway,vertical,,,,,2799,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5145,St Kilda,vertical,,,,,2800,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5146,Flannan Isles,vertical,,,,,2801,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2006-01-16,2005.880,0,
-5147,St Marys,vertical,,,,,2802,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5148,Douglas,vertical,,,,,2803,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,OGP,2002-09-19,,0,
-5149,Fao,vertical,,,,,3390,"Topographic mapping, geodetic survey.","Established by Hunting Surveys for IPC. In Iran replaced by Bandar Abbas (code 5150). At time of record creation NIOC data in Ahwaz area still usually referenced to Fao. In Iraq replaced by Fao 1979 (code 1028).","National Iranian Oil Company (NIOC).",OGP,2009-05-21,2009.003,0,
-5150,Bandar Abbas,vertical,Average sea level at Bandar Abbass 1995-2001.,2001,,,3336,"Topographic mapping, geodetic survey.","Replaces Fao (code 5149).",National Cartographic Centre of Iran,OGP,2002-09-19,,0,
-5151,Nivellement General de Nouvelle Caledonie,vertical,"Rivet AB01 established by SHOM (Service Hydrographique de la Marine)  in 1937 on the Quai des Volontaires in Noumea. Height i: 1.885 metre above mean sea level.",1969,,,2822,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,Service Topographique de la Nouvelle Caledonie.,OGP,2004-03-15,2004.060,0,
-5152,Poolbeg,vertical,"Low water mark of the spring tide on the 8 April 1837 at Poolbeg Lighthouse, Dublin.",1837,,,1305,Topographic mapping before 1956 in Northern Ireland and 1970 in the Republic of Ireland.,"Replaced by Belfast Lough and Malin Head (datum codes 5130-31).","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",OGP,2003-06-27,,0,
-5153,Nivellement General Guyanais 1977,vertical,"Mean sea level 1936 at Cayenne. Origin = marker BM35 on stone on St Francois battery, Cayenne, with defined elevation of 1.64m above msl. NGG1977 height 0.00m is 1.96m above sounding datum defined at Cayenne in 1936 by SHM.",1977,,,3146,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,IGN Paris,OGP,2008-09-17,2008.087,0,
-5154,Martinique 1987,vertical,"Mean sea level 1939 at Fort de France. Origin = marker Nbc2 on rebuilt quay wall with defined elevation of 1.38m above msl. Martinique 1987 height 0.00m is 0.56m above SHOM sounding datum.",1987,,,3276,"Geodetic survey, topographic mapping, engineering survey.","Orthometric heights. Replaces Martinique 1955 (datum code 5192).",IGN Paris,OGP,2008-09-19,2004.561 2008.087,0,
-5155,Guadeloupe 1988,vertical,"Mean sea level July 1947 to June 1948 at Pointe-Fouillole (Pointe-à-Pitre harbour). Origin = marker GO-7 (formerly AO'-5) with defined height of 2.67m above msl adopted from 1951 value. Guadeloupe 1988 height 0.00m is 0.46m above 1984 sounding datum.",1988,,,2892,"Geodetic survey, topographic mapping, engineering survey.","Orthometric heights. Replaces Guadeloupe 1951 (datum code 5193).",IGN Paris,OGP,2008-09-17,2004.561 2008.087,0,
-5156,Reunion 1989,vertical,"Mean sea level during part of November 1949 at port of Saint-Pierre. Origin = marker AB-100 with defined elevation of 13.808m above msl.",1989,,,3337,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights. Replaces Reunion IGN58. Value of marker AB-100 retains height from 1958 adjustment.,IGN Paris,OGP,2008-09-17,2004.561 2008.087,0,
-5157,Auckland 1946,vertical,MSL at Auckland harbour 1909-1923.,1946,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5158,Bluff 1955,vertical,MSL at Invercargill harbour over 8 years between 1918 and 1934.,1955,,,1501,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5159,Dunedin 1958,vertical,MSL at Dunedin harbour 1918-1937.,1958,,,1501,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5160,Gisborne 1926,vertical,MSL at Gisborne harbour 1926.,1926,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5161,Lyttelton 1937,vertical,MSL at Lyttelton harbour over 9 years between 1918 and 1933.,1937,,,1501,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5162,Moturiki 1953,vertical,MSL at Moturiki Island February 1949 to December 1952.,1953,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5163,Napier 1962,vertical,MSL at Napier harbour. Period of derivation unknown.,1962,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5164,Nelson 1955,vertical,MSL at Nelson harbour 1939-1942.,1955,,,1501,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5165,One Tree Point 1964,vertical,MSL at Whangarei harbour 1960-1963.,1964,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5166,Tararu 1952,vertical,MSL at Tararu Point 1922-1923.,1952,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5167,Taranaki 1970,vertical,MSL at Taranaki harbour 1918-1921.,1970,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5168,Wellington 1953,vertical,MSL at Wellington harbour 1909-1946.,1953,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",OGP,2008-04-04,2008.023,0,
-5169,"Waitangi (Chatham Island) 1959",vertical,MSL at Waitangi harbour collected in 1959.,1959,,,2889,"Geodetic survey, topographic mapping, engineering survey.",,"Interim Report GEO/T1/19/51 for LINZ by John Hannah, ""An Assessment of New Zealand's Height Systems and Options for a Future Height System"", January 2001.",OGP,2008-04-04,2008.023,0,
-5170,Stewart Island 1977,vertical,MSL at 3-5 high and low tides at two different locations.,1977,,,3338,"Geodetic survey, topographic mapping, engineering survey.",,"Interim Report GEO/T1/19/51 for LINZ by John Hannah, ""An Assessment of New Zealand's Height Systems and Options for a Future Height System"", January 2001.",OGP,2008-04-04,2008.023,0,
-5171,EGM96 geoid,vertical,WGS 84 ellipsoid.,1996,,,1262,Geodesy.,,"NASA http://cddis.gsfc.nasa.gov/926/egm96/egm96.html",OGP,2004-04-27,,0,
-5172,Nivellement General du Luxembourg,vertical,"Reference point Wemperhardt defined as 528.030m above Normaal Amsterdams Peil (NAP). Datum at NAP is mean high tide in 1684. Network adjusted in 1995.",1995,,,1146,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Administration du Cadastre et de la Topographie. http://www.etat.lu/ACT",OGP,2004-03-09,,0,
-5173,Antalya,vertical,Mean sea Level at Antalya 1936-71.,,,,3322,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-11-26,2004.722,0,
-5174,Norway Normal Nul 1954,vertical,MSL defined by regression at 7 gauges with between 17 and 67 years observations.,1974,,,1352,"Geodetic survey, topographic mapping, engineering survey.",Includes initial NN1954 system and NNN1957 system. Former name retained. Normal-orthometric heights.,Statoil,OGP,2004-03-09,,0,
-5175,Durres,vertical,Mean Sea Level at Durres.,,,,3212,"Geodetic survey, topographic mapping, engineering survey.",Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5176,Gebrauchshohen ADRIA,vertical,Reference point Hutbiegl defined relative to mean sea level at Trieste in 1875.,,,,1037,"Geodetic survey, topographic mapping, engineering survey.",Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5177,National Vertical Network 1999,vertical,Reference point Ruse defined relative to mean sea level at Trieste in 1875.,1999,,,3307,"Geodetic survey, topographic mapping, engineering survey.",Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5178,Cascais,vertical,Mean Sea Level at Cascais 1938.,1938,,,1294,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5179,Constanta,vertical,Mean Sea Level at Constanta.,,,,3295,"Geodetic survey, topographic mapping, engineering survey.",Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/evrs/Relations.html",OGP,2004-03-09,,0,
-5180,Alicante,vertical,Mean Sea Level at Alicante between 1870 and 1882.,,,,2366,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5181,Deutches Haupthohennetz 1992,vertical,"Network adjusted in 1992. Geopotential number at reference point Wallenhorst defined as value from the UELN-73/86 adjustment. Datum at Normaal Amsterdams Peil (NAP) is mean high tide in 1684.",1992,,,3339,"Geodetic survey, topographic mapping, engineering survey.",Replaces DHHN85 in West Germany and SNN76 in East Germany. Uses Normal heights.,"Bundesamt für Kartographie und Geodäsie (BKG), http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5182,Deutches Haupthohennetz 1985,vertical,"Network adjusted in 1985. Height of reference point Wallenhorst defined as value from 1928 adjustment. Datum at Normaal Amsterdams Peil (NAP) is mean high tide in 1684.",1985,,,2326,"Geodetic survey, topographic mapping, engineering survey.",Replaced by DHHN92. Uses Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5183,SNN76,vertical,Network adjusted in 1976. Height at reference point Hoppegarten defined as 1957 value from the UPLN adjustment. Datum at Kronstadt is mean sea level of Baltic in 1833.,1976,,,1343,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights. Replaced by DHHN92.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5184,Baltic 1982,vertical,Network adjusted in 1982. Height at reference point Varna defined as 1958 value from the UPLN adjustment. Datum at Kronstadt is mean sea level of Baltic in 1833.,1982,,,3224,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5185,Baltic 1980,vertical,,,,,1119,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",OGP,2004-03-09,,0,
-5186,Kuwait PWD,vertical,"Mean Low Low Water (MLLW) at Kuwait City.",,,,3267,Municipality and military purposes.,Approximately 1.03m below MSL.,Kuwait Oil Company.,OGP,2004-06-16,,0,
-5187,KOC Well Datum,vertical,,1937,,,3267,KOC exploration and field development subsurface work.,Approximately 3.22m above MSL.,Kuwait Oil Company.,OGP,2004-06-16,,0,
-5188,KOC Construction Datum,vertical,,1952,,,3267,KOC survey control and facilities engineering.,Approximately 1.52m below MSL. Created for the construction of the Mina al Ahmadi refinery.,Kuwait Oil Company.,OGP,2004-06-16,,0,
-5189,Nivellement General de la Corse 1948,vertical,Mean sea level at Ajaccio between 1912 and 1937.,1948,,,1327,"Geodetic survey, topographic mapping, engineering survey.","Replaced by IGN78 Corsica (datum 5120).",IGN Paris,OGP,2004-10-14,,0,
-5190,Danger 1950,vertical,Marker near tide gauge at port of Saint Pierre. Height is 1.26 metres above zero of tide gauge.,1950,,,3299,"Geodetic survey, topographic mapping, engineering survey.",,IGN Paris,OGP,2004-10-14,,0,
-5191,Mayotte 1950,vertical,Marker on Issoufali jetty at Dzaoudzi. Height is 2.18m above zero of tide gauge.,1950,,,3340,"Geodetic survey, topographic mapping, engineering survey.",,IGN Paris,OGP,2004-10-14,,0,
-5192,Martinique 1955,vertical,Mean sea level at Fort de France 1939. Marker DO-4-II on quay wall with elevation of 1.38m above msl.,1955,,,3276,"Geodetic survey, topographic mapping, engineering survey.","Orthometric heights. Replaced by Martinique 1987 (datum code 5154).",IGN Paris,OGP,2008-09-17,2008.087,0,
-5193,Guadeloupe 1951,vertical,"Mean sea level July 1947 to June 1948 at Pointe-Fouillole (Pointe-à-Pitre harbour). Origin = marker AO'-12 with height of 1.917m above msl.",1955,,,2892,"Geodetic survey, topographic mapping, engineering survey.","Orthometric heights. Replaced by Guadeloupe 1988 (datum code 5155). Guadeloupe 1951 height 0.00m is 0.629m above 1947-48 sounding datum.",IGN Paris,OGP,2008-09-17,2008.087,0,
-5194,Lagos 1955,vertical,"Mean sea level at Lagos, 1912-1928.",1955,,,3287,"Geodetic survey, topographic mapping, engineering survey.",,"Ebong et al, AVN International, 1991.",OGP,2004-10-14,,0,
-5195,Nivellement General de Polynesie Francaise,vertical,,,,,3134,"Geodetic survey, topographic mapping, engineering survey.",The collection of heterogeneous levelling networks throughout the Society Islands of French Polynesia.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5196,IGN 1966,vertical,"Fundamental benchmark: RN501",1966,,,3124,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5197,Moorea SAU 1981,vertical,"Fundamental benchmark: RN225",1981,,,3125,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5198,Raiatea SAU 2001,vertical,"Fundamental benchmark: RN1",2001,,,3136,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5199,Maupiti SAU 2001,vertical,"Fundamental benchmark: RN11",2001,,,3126,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5200,Huahine SAU 2001,vertical,"Fundamental benchmark: SHOM B3",2001,,,3135,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5201,Tahaa SAU 2001,vertical,"Fundamental benchmark: RN16",2001,,,3138,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5202,Bora Bora SAU 2001,vertical,"Fundamental benchmark: Vaitape quay SHOM benchmark B.",2001,,,3137,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,
-5203,EGM84 geoid,vertical,WGS 84 ellipsoid.,1984,,,1262,Geodesy.,,"US National Geospatial-Intelligence Agency (NGA); http://earth-info.nga.mil/GandG/",OGP,2005-09-30,,0,
-5204,International Great Lakes Datum 1955,vertical,"Pointe-au-Père (Father's Point), Quebec",1955,,,3468,Hydrology.,Dynamic heights. Adopted in 1962. Replaced by IGLD 1985 in January 1992.,Coordinating Committee on Great Lakes Basic Hydraulic and Hydrologic Data,OGP,2006-11-11,,0,
-5205,International Great Lakes Datum 1985,vertical,"Rimouski, Quebec.",1985,,,3468,Hydrology.,Dynamic heights. Replaces IGLD 1955 from January 1992.,Coordinating Committee on Great Lakes Basic Hydraulic and Hydrologic Data,OGP,2006-11-11,,0,
-5206,Dansk Vertikal Reference 1990,vertical,"Benchmark at Århus cathedral referenced to mean sea level determined during 1990 at 10 tide gauges: Esbjerg, Fredericia, Frederikshavn, Gedser, Hirtshals, Hornbæk, Korsør, København, Slipshavn and Århus.",,,,3237,Topographic mapping and engineering survey,Normal Orthometric heights.,"Kort & Matrikelstyrelsen",OGP,2006-12-01,,0,
-5207,Croatian Vertical Reference System 1971,vertical,"Mean sea level at five tide gauges in Dubrovnik, Split, Bakar, Rovinj and Kopar at epoch 1971.5",1971,,,3234,Geodesy.,,State Geodetic Administration of the Republic of Croatia.,OGP,2008-06-09,2008.043,0,
-5208,Rikets hojdsystem 2000,vertical,"Adjustment is referenced to mean high tide at Amsterdams Peil in 1684. To account for land level movements caused by isostatic rebound, heights are reduced to epoch 2000.0 using values computed from the RH 2000 LU (=NKG2005LU) uplift model.",2000,,,3313,"Topographic mapping, geodetic survey.","Realised through the third precise levelling network of 1979-2003. Adopted in 2005, replacing RH70. Uses Normal heights.",National Land Survey of Sweden,OGP,2008-03-14,,0,
-5209,Rikets hojdsystem 1900,vertical,"Adjustment is referenced to mean sea level at Slussen, Stockholm.",1900,,,3313,"Topographic mapping, engineering survey.",Realised through the first precise levelling network of 1886-1905. Replaced by RH70.,National Land Survey of Sweden,OGP,2008-03-14,,0,
-5210,IGN 1988 LS,vertical,"Mean sea level 1984 at Terre de Haut. Origin = marker O de -5 with defined height of 1.441m above msl. IGN 1988 LS height 0.00m is 0.46m above 1987 sounding datum; this approximately corresponds with msl at Pointe-à-Pitre (see datum code 5155, CRS 5757).",1988,,,2895,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,IGN Paris,OGP,2008-09-17,,0,
-5211,IGN 1988 MG,vertical,"Mean sea level 1987 at Grand-Bourg. Origin = marker M0-I with defined height of 0.832m above msl. IGN 1988 MG height 0.00m is 0.46m above 1987 sounding datum; this approximately corresponds with msl at Pointe-à-Pitre (see datum code 5155, CRS code 5757).",1988,,,2894,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,IGN Paris,OGP,2008-09-17,,0,
-5212,IGN 1992 LD,vertical,"Mean sea level at Pointe-à-Pitre. Origin = marker A with defined height of 0.792m above msl. IGN 1992 LD height 0.00m is 0.629m above sounding datum at Pointe-à-Pitre.",1992,,,2893,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,IGN Paris,OGP,2008-09-17,,0,
-5213,IGN 1988 SB,vertical,"Mean sea level 1988 at port of Gustavia. Origin = marker A.ef-2 with defined height of 0.621m above msl. IGN 1988 SB height 0.00m deduced to be 0.201m above mean sea level at Pointe-à-Pitre.",1988,,,2891,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,IGN Paris,OGP,2008-09-17,,0,
-5214,IGN 1988 SM,vertical,"Mean sea level 1949-1950 deduced at Fort Marigot. Origin = marker AS-13 with defined height of 6.990m above msl. IGN 1988 SM height 0.00m deduced to be 0.41m above sounding datum.",1988,,,2890,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,IGN Paris,OGP,2008-09-17,,0,
-5215,European Vertical Reference Frame 2007,vertical,"13 stations (to be completed)",2007,,,3594,Geodesy.,"Realised by geopotential numbers and Normal heights of the United European Levelling Network. Replaces EVRF2000 (datum code 5129).","European veritical data centre at Bundesamt für Kartographie und Geodäsie (BKG), Leipzig branch. http://crs.bkg.bund.de/evrs/",OGP,2008-11-21,,0,
-6001,"Not specified (based on Airy 1830 ellipsoid)",geodetic,,,7001,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Airy_1830"
-6002,"Not specified (based on Airy Modified 1849 ellipsoid)",geodetic,,,7002,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Airy_Modified"
-6003,"Not specified (based on Australian National Spheroid)",geodetic,,,7003,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Australian"
-6004,"Not specified (based on Bessel 1841 ellipsoid)",geodetic,,,7004,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Bessel_1841"
-6005,"Not specified (based on Bessel Modified ellipsoid)",geodetic,,,7005,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Bessel_Modified"
-6006,"Not specified (based on Bessel Namibia ellipsoid)",geodetic,,,7046,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2001-01-21,1996.080 2000.420 2001.150,0,"D_Bessel_Namibia"
-6007,"Not specified (based on Clarke 1858 ellipsoid)",geodetic,,,7007,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1858"
-6008,"Not specified (based on Clarke 1866 ellipsoid)",geodetic,,,7008,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1866"
-6009,"Not specified (based on Clarke 1866 Michigan ellipsoid)",geodetic,,,7009,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1866_Michigan"
-6010,"Not specified (based on Clarke 1880 (Benoit) ellipsoid)",geodetic,,,7010,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1880_Benoit"
-6011,"Not specified (based on Clarke 1880 (IGN) ellipsoid)",geodetic,,,7011,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1880_IGN"
-6012,"Not specified (based on Clarke 1880 (RGS) ellipsoid)",geodetic,,,7012,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1880_RGS"
-6013,"Not specified (based on Clarke 1880 (Arc) ellipsoid)",geodetic,,,7013,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1880_Arc"
-6014,"Not specified (based on Clarke 1880 (SGA 1922) ellipsoid)",geodetic,,,7014,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1880_SGA"
-6015,"Not specified (based on Everest 1830 (1937 Adjustment) ellipsoid)",geodetic,,,7015,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,
-6016,"Not specified (based on Everest 1830 (1967 Definition) ellipsoid)",geodetic,,,7016,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Everest_Def_1967"
-6018,"Not specified (based on Everest 1830 Modified ellipsoid)",geodetic,,,7018,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Everest_Modified"
-6019,"Not specified (based on GRS 1980 ellipsoid)",geodetic,,,7019,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_GRS_1980"
-6020,"Not specified (based on Helmert 1906 ellipsoid)",geodetic,,,7020,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Helmert_1906"
-6021,"Not specified (based on Indonesian National Spheroid)",geodetic,,,7021,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Indonesian"
-6022,"Not specified (based on International 1924 ellipsoid)",geodetic,,,7022,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_International_1924"
-6024,"Not specified (based on Krassowsky 1940 ellipsoid)",geodetic,,,7024,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Krasovsky_1940"
-6025,"Not specified (based on NWL 9D ellipsoid)",geodetic,,,7025,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_NWL_9D"
-6027,"Not specified (based on Plessis 1817 ellipsoid)",geodetic,,,7027,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Plessis_1817"
-6028,"Not specified (based on Struve 1860 ellipsoid)",geodetic,,,7028,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Struve_1860"
-6029,"Not specified (based on War Office ellipsoid)",geodetic,,,7029,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_War_Office"
-6030,"Not specified (based on WGS 84 ellipsoid)",geodetic,,,7030,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,
-6031,"Not specified (based on GEM 10C ellipsoid)",geodetic,,,7031,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_GEM_10C"
-6032,"Not specified (based on OSU86F ellipsoid)",geodetic,,,7032,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_OSU_86F"
-6033,"Not specified (based on OSU91A ellipsoid)",geodetic,,,7033,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_OSU_91A"
-6034,"Not specified (based on Clarke 1880 ellipsoid)",geodetic,,,7034,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,1996.080 2000.420,0,"D_Clarke_1880"
-6035,"Not specified (based on Authalic Sphere)",geodetic,,,7035,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown. Deprecated and replaced by 6047.,OGP,OGP,2001-06-05,1996.080 2000.420,1,"D_Sphere"
-6036,"Not specified (based on GRS 1967 ellipsoid)",geodetic,,,7036,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,2000.420,0,"D_GRS_1967"
-6041,"Not specified (based on Average Terrestrial System 1977 ellipsoid)",geodetic,,,7041,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,2000.420,0,
-6042,"Not specified (based on Everest (1830 Definition) ellipsoid)",geodetic,,,7042,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,2000.420,0,"D_Everest_1830"
-6043,"Not specified (based on WGS 72 ellipsoid)",geodetic,,,7043,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,2000.420,0,
-6044,"Not specified (based on Everest 1830 (1962 Definition) ellipsoid)",geodetic,,,7044,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,2000.420,0,"D_Everest_Def_1962"
-6045,"Not specified (based on Everest 1830 (1975 Definition) ellipsoid)",geodetic,,,7045,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2000-05-03,2000.420,0,"D_Everest_Def_1975"
-6047,"Not specified (based on GRS 1980 Authalic Sphere)",geodetic,,,7048,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2004-04-27,2001.190 2003.330,0,
-6052,"Not specified (based on Clarke 1866 Authalic Sphere)",geodetic,,,7052,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2004-04-27,,0,"D_Sphere_Clarke_1866_Authalic"
-6053,"Not specified (based on International 1924 Authalic Sphere)",geodetic,,,7057,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2006-09-22,,0,
-6054,"Not specified (based on Hughes 1980 ellipsoid)",geodetic,,,7058,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2006-09-22,,0,
-6055,Popular Visualisation Datum,geodetic,Not specified in the classical sense of defining a geodetic datum.,,7059,8901,1262,Used by certain popular Web mapping and visualisation applications.,Not recognised by geodetic authorities.,Microsoft.,OGP,2008-03-13,2008.114,1,
-6120,Greek,geodetic,"Fundamental point: Athens Observatory. Latitude 37°58'20.132""N, longitude 23°42'58.815""E (of Greenwich)",,7004,8901,1106,Topographic mapping.,"See geodetic datum alias 6404.  Used as basis of topographic mapping based on Hatt projection. Replaced by GGRS87 (code 6121).","Topography Department; National Technical University of Athens",OGP,2008-06-24,2004.183 2008.045,0,"D_Greek"
-6121,Greek Geodetic Reference System 1987,geodetic,"Fundamental point: Dionysos. Latitude 38°04'33.8""N, longitude 23°55'51.0""E of Greenwich; geoid height 7.0 m.",1987,7019,8901,1106,Topographic mapping.,"Replaced (old) Greek datum.  Oil industry work based on ED50.","L. Portokalakis; Public Petroleum Corporation of Greece",OGP,2008-06-24,2008.045,0,"D_GGRS_1987"
-6122,Average Terrestrial System 1977,geodetic,,1977,7041,8901,1283,Topographic mapping.,"In use from 1979.  To be phased out in late 1990's.",New Brunswick Geographic Information Corporation land and water information standards manual.,OGP,1997-07-02,,0,"D_ATS_1977"
-6123,"Kartastokoordinaattijarjestelma (1966)",geodetic,Adjustment with fundamental point SF31 based on ED50 transformed to best fit the older VVJ adjustment.,1966,7022,8901,1095,"Geodetic survey, cadastre, topographic mapping, engineering survey.",Adopted in 1970.,"National Land Survey of Finland;¶http://www.maanmittauslaitos.fi",OGP,2006-03-31,2006.270,0,"D_KKJ"
-6124,Rikets koordinatsystem 1990,geodetic,,1982,7004,8901,1225,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces RT38 adjustment (datum code 6308)",National Land Survey of Sweden,OGP,1997-11-13,,0,"D_RT_1990"
-6125,Samboja,geodetic,Original origin station P2 Exc now destroyed.  Extensions recomputed using Toran station T9 as origin.,,7004,8901,1328,Topographic mapping.,,Total Indonesia.,OGP,1997-11-13,,1,"D_Samboja"
-6126,"Lithuania 1994 (ETRS89)",geodetic,Constrained to 4 ETRS89 points in Lithuania from the EUREF Baltic 1992 campaign..,1994,7019,8901,1145,"Topographic mapping, geodetic survey.",Densification of ETRS89 during the 1992 Baltic campaign.,HNIT-Baltic GeoInfoServisas,OGP,1998-03-12,,0,"D_Lithuania_1994"
-6127,Tete,geodetic,"Fundamental point: Tete.",,7008,8901,3281,Topographic mapping.,,"Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",OGP,1998-04-16,,0,"D_Tete"
-6128,Madzansua,geodetic,"Fundamental point: Madzansua.",,7008,8901,1315,Topographic mapping.,"Replaced by transformation to Tete datum (datum code 6127).","Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",OGP,1998-04-16,,0,"D_Madzansua"
-6129,Observatario,geodetic,"Fundamental point: Maputo observatory.",,7008,8901,1329,Topographic mapping.,"Replaced by transformation to Tete datum (datum code 6127).","Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",OGP,1998-04-16,,0,"D_Observatario"
-6130,"Moznet (ITRF94)",geodetic,ITRF94 at epoch 1996.9,,7030,8901,1167,Topographic mapping.,,"Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",OGP,2006-08-18,2006.770,0,"D_Moznet"
-6131,Indian 1960,geodetic,DMA extension over IndoChina of the Indian 1954 network adjusted  to better fit local geoid.,,7015,8901,1302,Topographic mapping.,"Also known as Indian (DMA Reduced).",,OGP,2003-12-31,2003.361,0,"D_Indian_1960"
-6132,Final Datum 1958,geodetic,"Fundamental point: Maniyur.  Latitude: 31°23'59.19""N, longitude: 48°32'31.38""E (of Greenwich).",,7012,8901,1300,Oil industry mapping.,Network included in Nahrwan 1967 adjustment.,IOEPC records,OGP,2008-06-24,2008.045,0,"D_FD_1958"
-6133,Estonia 1992,geodetic,Densification from 4 ETRS89 points.,1992,7019,8901,1090,"Topographic mapping, Geodetic survey.","Based on ETRS89 as established during the 1992 Baltic campaign. Replaced by Estonia 1997 adjustment (code 6180).","http://www.geo.ut.ee",OGP,2005-09-06,2005.460,0,"D_Estonia_1992"
-6134,PDO Survey Datum 1993,geodetic,Adjustment best fitted to Fahud network.,1993,7012,8901,3288,Oil industry mapping.,"Replaces Fahud datum (code 6232). Maximum differences to Fahud adjustment are 20 metres.",Petroleum Development Oman,OGP,1999-04-22,,0,"D_PDO_1993"
-6135,Old Hawaiian,geodetic,"Fundamental point: Oahu West Base Astro.  Latitude: 21°18'13.89""N, longitude 157°50'55.79""W (of Greenwich)",,7008,8901,1334,Topographic mapping.,"Hawaiian Islands were never on NAD27 but rather on Old Hawaiian Datum.  NADCON conversion program provides transformation from Old Hawaiian Datum to NAD83 (original 1986 realization) but making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file).",OGP,2008-06-24,2005.460 2008.045,0,"D_Old_Hawaiian"
-6136,St. Lawrence Island,geodetic,,,7008,8901,1332,Topographic mapping.,"Many Alaskan islands were never on NAD27 but rather on independent datums.  NADCON conversion program provides transformation from St. Lawrence Island Datum to NAD83 (original 1986 realization) - making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file)",OGP,1999-05-24,,0,"D_St_Lawrence_Island"
-6137,St. Paul Island,geodetic,"Fundamental point latitude: 57°07'16.86""N, longitude: 170°16'24.00""W (of Greenwich).",,7008,8901,1333,Topographic mapping.,"Many Alaskan islands were never on NAD27 but rather on independent datums.  NADCON conversion program provides transformation from St. Paul Island Datum to NAD83 (original 1986 realization) - making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file)",OGP,2008-06-24,2008.045,0,"D_St_Paul_Island"
-6138,St. George Island,geodetic,"Fundamental point latitude: 56°36'11.31""N, longitude: 169°32'36.00""W (of Greenwich).",,7008,8901,1331,Topographic mapping.,"Many Alaskan islands were never on NAD27 but rather on independent datums.  NADCON conversion program provides transformation from St. George Island Datum to NAD83 (original 1986 realization) - making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file)",OGP,2008-06-24,2003.362 2008.045,0,"D_St_George_Island"
-6139,Puerto Rico,geodetic,"Fundamental point: Cardona Island Lighthouse. Latitude:17°57'31.40""N, longitude: 66°38'07.53""W (of Greenwich).",1901,7008,8901,1335,Topographic mapping.,"NADCON conversion program provides transformation from Puerto Rico Datum to NAD83 (original 1986 realization) but making the transformation appear to user as if from NAD27.","Ordnance Survey of Great Britain and http://www.ngs.noaa.gov/ (NADCON readme file).",OGP,2008-06-24,2003.362 2008.045,0,"D_Puerto_Rico"
-6140,NAD83 Canadian Spatial Reference System,geodetic,,1998,7019,8901,1061,Geodetic survey.,,"Natural Resources of Canada, CSRS website.  http://www.geod.nrcan.gc.ca",OGP,2007-09-25,2005.880 2006.461 2007.026 2007.092,0,"D_North_American_1983_CSRS98"
-6141,Israel,geodetic,"Fundamental point:  Latitude: 31°44'03.817""N, longitude: 35°12'16.261""E (of Greenwich).",,7019,8901,2603,Topographic mapping.,,Survey of Israel.,OGP,2008-06-24,2002.340 2004.150 2008.045,0,"D_Israel"
-6142,Locodjo 1965,geodetic,"Fundamental point: T5 Banco. Latitude: 5°18'50.5""N, longitude: 4°02'05.1""W (of Greenwich).",1965,7012,8901,1075,Topographic mapping.,,IGN Paris.,OGP,2008-06-24,2008.045,0,"D_Locodjo_1965"
-6143,Abidjan 1987,geodetic,"Fundamental point: Abidjan I. Latitude: 5°18'51.01""N, longitude: 4°02'06.04""W (of Greenwich).",1987,7012,8901,1075,Topographic mapping.,,IGN Paris.,OGP,2008-06-24,2008.045,0,"D_Abidjan_1987"
-6144,Kalianpur 1937,geodetic,"Fundamental point: Kalianpur. Latitude: 24° 07'11.260""N, longitude: 77°39'17.570""E (of Greenwich).",1937,7015,8901,1308,Topographic mapping.,Replaces 1880 adjustment except for topographic mapping.  Replaced in Bangladesh and Pakistan by 1962 metrication conversion and in India by 1975 metrication conversion.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",OGP,2008-06-24,2008.045,0,"D_Kalianpur_1937"
-6145,Kalianpur 1962,geodetic,"Fundamental point: Kalianpur. Latitude: 24° 07'11.260""N, longitude: 77°39'17.570""E (of Greenwich).",1962,7044,8901,3289,Topographic mapping.,"1937 adjustment rescaled by ratio metric conversions of Indian foot (1937) to Indian foot (1962).",,OGP,2008-06-24,2008.045,0,"D_Kalianpur_1962"
-6146,Kalianpur 1975,geodetic,"Fundamental point: Kalianpur. Latitude: 24° 07'11.260""N, longitude: 77°39'17.570""E (of Greenwich).",1975,7045,8901,3341,Topographic mapping.,"1937 adjustment rescaled by ratio metric conversions of Indian foot (1937) to Indian foot (1975).",,OGP,2008-06-24,2008.045,0,"D_Kalianpur_1975"
-6147,Hanoi 1972,geodetic,,1972,7024,8901,3328,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,PetroVietnam,OGP,1999-10-20,,0,"D_Hanoi_1972"
-6148,Hartebeesthoek94,geodetic,Coincident with ITRF91 at epoch 1994.0 at Hartebeesthoek astronomical observatory near Pretoria.,1994,7030,8901,1215,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Cape datum (code 6222).","Directorate of Surveys and Mapping; http://w3sli.wcape.gov.za/surveys/mapping/wgs84.htm",OGP,2006-08-18,1999.960 2006.770,0,"D_Hartebeesthoek_1994"
-6149,CH1903,geodetic,"Fundamental point: Old Bern observatory. Latitude: 46°57'08.660""N, longitude: 7°26'22.500""E (of Greenwich).",1903,7004,8901,1286,Topographic mapping.,,"Bundesamt für Landestopographie",OGP,2008-06-24,2008.045,0,"D_CH1903"
-6150,"CH1903+",geodetic,"Fundamental point: Zimmerwald observatory.",,7004,8901,1286,"Geodetic survey, topographic mapping.",,"Bundesamt für Landestopographie.  Aufbau der Landesvermessung der Schweiz 'LV95' Teil 3: Terrestrische Bezugssysteme und Bezugsrahmen. L+T 1999.",OGP,2001-11-06,2001.520,0,"D_CH1903+"
-6151,Swiss Terrestrial Reference Frame 1995,geodetic,ETRF89 at epoch 1993.0,1995,7019,8901,1286,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Bundesamt für Landestopographie.  Aufbau der Landesvermessung der Schweiz 'LV95' Teil 3: Terrestrische Bezugssysteme und Bezugsrahmen. L+T 1999.",OGP,2006-08-18,2006.770,0,"D_Swiss_TRF_1995"
-6152,"NAD83 (High Accuracy Regional Network)",geodetic,,,7019,8901,1337,Geodetic survey.,,National Geodetic Survey,OGP,1999-10-20,,0,"D_North_American_1983_HARN"
-6153,Rassadiran,geodetic,"Fundamental point: Total1. Latitude: 27°31'07.784""N, longitude: 52°36'12.741""E (of Greenwich).",1998,7022,8901,1338,Oil industry mapping.,,Total-Fina,OGP,2008-06-24,2008.045,0,"D_Rassadiran"
-6154,"European Datum 1950(1977)",geodetic,Extension of ED50 over Iran.,1977,7022,8901,1123,Topographic mapping.,Sometimes referred to as ED50-ED77.,National Cartographic Centre of Iran,OGP,1999-11-20,,0,"D_European_1950_ED77"
-6155,Dabola 1981,geodetic,,1981,7011,8901,3257,Topographic mapping.,,IGN Paris,OGP,1999-12-09,,0,"D_Dabola_1981"
-6156,Jednotne Trigonometricke Site Katastralni,geodetic,"Modification of Austrian MGI datum, code 6312.",,7004,8901,1306,"Geodetic survey, cadastre, topographic mapping, engineering survey.","S-JTSK = System of the Unified Trigonometrical Cadastral Network.","Research Institute for Geodesy Topography and Cartography (VUGTK); Prague.",OGP,2001-11-06,2001.260 2001.510,0,"D_S_JTSK"
-6157,Mount Dillon,geodetic,"Fundamental point: Mount Dillon triangulation station. Latitude: 11°15'07.843""N, longitude: 60°41'09.632""W (of Greenwich).",,7007,8901,1322,Topographic mapping.,,University of the West Indies Geodetic Services.,OGP,2008-06-24,2003.361 2008.045,0,"D_Mount_Dillon"
-6158,Naparima 1955,geodetic,"Fundamental point: Naparima. Latitude: 10°16'44.860""N, longitude: 61°27'34.620""W (of Greenwich).",1955,7022,8901,3143,Topographic mapping.,Naparima 1972 is an extension of the Naparima 1955 network of Trinidad to include Tobago.,Ordnance Survey International.,OGP,2008-06-24,2008.045,0,"D_Naparima_1955"
-6159,European Libyan Datum 1979,geodetic,Extension of ED50 over Libya.,1979,7022,8901,1143,Topographic mapping.,,Brown and Root,OGP,2003-12-31,2003.362,0,"D_European_Libyan_1979"
-6160,Chos Malal 1914,geodetic,Chos Malal police station.,1914,7022,8901,1292,Oil industry mapping.,"Also known as Quini-Huao.  Replaced by Campo Inchauspe (code 6221).",Various oil company records.,OGP,2000-03-07,,0,"D_Chos_Malal_1914"
-6161,Pampa del Castillo,geodetic,,,7022,8901,1265,Oil industry mapping.,"Used in Comodoro Rivadavia area.  Replaced by Campo Inchauspe (code 6221).",Various oil company records.,OGP,2000-03-07,,0,"D_Pampa_del_Castillo"
-6162,Korean Datum 1985,geodetic,"Fundamental point: Suwon. Latitude 37°16'31.9034""N, longitude 127°03'05.1451""E of Greenwich.",1985,7004,8901,3266,Topographic mapping.,,"Clifford J. Mugnier; in Photogrammetric Engineering & Remote Sensing November 1999. http://www.asprs.org/",OGP,2008-06-24,2001.280 2005.460 2008.045,0,"D_Korean_Datum_1985"
-6163,Yemen National Geodetic Network 1996,geodetic,"Sana'a IGN reference marker.",1996,7030,8901,1257,Topographic mapping.,,IGN Paris,OGP,2000-03-07,,0,"D_Yemen_NGN_1996"
-6164,South Yemen,geodetic,,,7024,8901,1340,Topographic mapping.,,IGN Paris,OGP,2000-03-07,,0,"D_South_Yemen"
-6165,Bissau,geodetic,,,7022,8901,3258,Topographic mapping.,,"NIMA TR8350.2  ftp://164.214.2.65/pub/gig/tr8350.2/changes.pdf",OGP,2005-09-05,2005.460,0,"D_Bissau"
-6166,Korean Datum 1995,geodetic,,1995,7030,8901,3266,Topographic mapping.,,"NIMA TR8350.2  ftp://164.214.2.65/pub/gig/tr8350.2/changes.pdf",OGP,2005-09-05,2005.460,0,"D_Korean_Datum_1995"
-6167,New Zealand Geodetic Datum 2000,geodetic,Based on ITRF96 at epoch 2000.0,2000,7019,8901,1175,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces New Zealand Geodetic Datum 1949 (code 6272) and Chatham Islands Datum 1979 (code 6673) from March 2000.","Land Information New Zealand. http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd2000factsheet/index.jsp",OGP,2007-09-29,2004.110 2007.090,0,"D_NZGD_2000"
-6168,Accra,geodetic,"Fundamental point: GCS Station 547. Latitude: 5°23'43.3""N, longitude: 0°11'52.3""W (of Greenwich).",,7029,8901,1104,Topographic mapping.,"Replaced in 1978 by Leigon datum (code 6250).",Ordnance Survey International,OGP,2008-06-24,2008.045,0,"D_Accra"
-6169,American Samoa 1962,geodetic,"Fundamental point: Betty 13 eccentric. Latitude: 14°20'08.34""S, longitude: 170°42'52.25""W (of Greenwich).",1962,7008,8901,3109,Topographic mapping.,,NIMA TR8350.2 revision of January 2000. Oil industry sources for origin description details.,OGP,2008-06-24,2003.362 2005.230 2008.045,0,"D_American_Samoa_1962"
-6170,Sistema de Referencia Geocentrico para America del Sur 1995,geodetic,ITRF94 at epoch 1995.42.,1995,7019,8901,3448,Geodetic survey.,Realised by a frame of 58 stations observed in 1995 and adjusted in the ITRF94. Replaced by SIRGAS 2000.,"NIMA TR8350.2 revision of January 2000. Also http://www1.ibge.gov.br/",OGP,2006-08-18,2004.250 2005.460 2006.465 2006.770,0,"D_SIRGAS"
-6171,Reseau Geodesique Francais 1993,geodetic,Coincident with ETRS89 at epoch 1993.0,1993,7019,8901,1096,Geodetic survey.,,"http://www.ign.fr/ via TotalFinaElf",OGP,2005-09-05,2001.510 2005.460,0,"D_RGF_1993"
-6172,Posiciones Geodesicas Argentinas,geodetic,,1994,7019,8901,1033,"Topographic mapping, geodetic survey.","Una red geodésica de 127 puntos materializados¶en el terreno que definen el Sistema Geodésico Nacional.  [A geodetic network of 127 points defining the National Geodetic System.] Replaced by POSGAR98 (code 6190).","http://www.igm.gov.ar/posgar.html",OGP,2000-10-19,,1,"D_POSGAR"
-6173,IRENET95,geodetic,ETRS89 stations in Ireland,1995,7019,8901,1305,Geodetic survey.,Densification of ETRS89,Ordnance Survey of Ireland,OGP,2004-04-07,2004.220,0,"D_IRENET95"
-6174,Sierra Leone Colony 1924,geodetic,"Fundamental point: Kortright. Latitude: 8°28'44.4""N, longitude: 13°13'03.81""W (of Greenwich).",1924,7029,8901,1342,"Topographic mapping, engineering survey.",,Ordnance Survey International.,OGP,2008-06-24,2008.045,0,"D_Sierra_Leone_1924"
-6175,Sierra Leone 1968,geodetic,"Fundamental point: SLX2 Astro. Latitude: 8°27'17.567""N, longitude: 12°49'40.186""W (of Greenwich).",1968,7012,8901,3306,"Topographic mapping, engineering survey.",Extension and readjustment with additional observations of 1960 network.  Coordinates of 1960 stations change by less than 3 metres.,Ordnance Survey International.,OGP,2008-06-24,2008.045,0,"D_Sierra_Leone_1968"
-6176,Australian Antarctic Datum 1998,geodetic,,1998,7019,8901,1278,Topographic mapping.,,Standards Australia,OGP,2006-01-30,2006.080,0,"D_Australian_Antarctic_1998"
-6178,"Pulkovo 1942(83)",geodetic,"Fundamental point: Pulkovo observatory. Latitude: 59°46'18.550""N, longitude: 30°19'42.090""E (of Greenwich).",1983,7024,8901,3574,"Geodetic survey, cadastre, topographic mapping, engineering survey.",1983 international adjustment of Uniform Astro-Geodetic Network of countries of central and eastern Europe.,"Bundesamt für Kartographie und Geodäsie via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2008-09-24,2008.045 2008.011,0,"D_Pulkovo_1942_Adj_1983"
-6179,"Pulkovo 1942(58)",geodetic,"Fundamental point: Pulkovo observatory. Latitude: 59°46'18.550""N, longitude: 30°19'42.090""E (of Greenwich).",1956,7024,8901,3574,"Geodetic survey, cadastre, topographic mapping, engineering survey.",1956 international adjustment of Uniform Astro-Geodetic Network of countries of central and eastern Europe. Locally densified during 1957 and 1958.,"Glowny Urzad Geodezji i Kartografii via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2008-09-24,2008.011 2008.045,0,"D_Pulkovo_1942_Adj_1958"
-6180,Estonia 1997,geodetic,Densification of ETRS89 during EUREF-ESTONIA97 campaign through transformation from ITRF96 at epoch 1997.56.,1997,7019,8901,1090,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Estonia 1992 adjustment (code 6133).","Estonian National Land Board via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2006-08-18,2006.770,0,"D_Estonia_1997"
-6181,Luxembourg 1930,geodetic,"Fundamental point: northern station of Habay-la-Neuve baseline in Belgium. Latitude: 49°43'24.408""N, longitude: 5°38'22.470""E (of Greenwich).",1930,7022,8901,1146,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Administration du Cadastre et de la Topographie via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2008-06-24,2008.045,0,"D_Luxembourg_1930"
-6182,Azores Occidental Islands 1939,geodetic,"Fundamental point: Observatario Meteorologico Flores.",1939,7022,8901,1344,Topographic mapping.,,"Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2005-12-30,2005.850,0,"D_Azores_Occidental_Islands_1939"
-6183,Azores Central Islands 1948,geodetic,"Fundamental point: Graciosa south west base. Latitude: 39°03'54.934""N, longitude: 28°02'23.882""W (of Greenwich).",1948,7022,8901,1301,Topographic mapping.,"Replaced by 1995 adjustment (datum code 6665).","Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/  Oil industry sources for origin description details.",OGP,2008-06-24,2002.250 2003.231 2003.362 2008.045,0,"D_Azores_Central_Islands_1948"
-6184,Azores Oriental Islands 1940,geodetic,"Fundamental point: Forte de São Bras.",1940,7022,8901,1345,Topographic mapping.,"Replaced by 1995 adjustment (datum code 6664).","Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2003-08-14,2003.231,0,"D_Azores_Oriental_Islands_1940"
-6185,Madeira 1936,geodetic,"Fundamental point: Madeira SE Base.",1936,7022,8901,1314,Topographic mapping.,,"Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2001-06-05,,1,"D_Madeira_1936"
-6188,OSNI 1952,geodetic,Position fixed to the coordinates from the 19th century Principle Triangulation of station Divis. Scale and orientation controlled by position of Principle Triangulation stations Knocklayd and Trostan.,1952,7001,8901,2530,Geodetic survey and topographic mapping.,"Replaced by Geodetic Datum of 1965 alias 1975 Mapping Adjustment or TM75 (datum code 6300).",Ordnance Survey of Northern Ireland.,OGP,2001-11-06,,0,"D_OSNI_1952"
-6189,Red Geodesica Venezolana,geodetic,Realised by a frame of 67 stations observed in 1995 as a densification of the SIRGAS campaign and adjusted in the ITRF94.,2000,7019,8901,1251,Geodetic survey.,,Servicio Autonomo de Geografia y Cartografia Nacional.,OGP,2001-06-11,,0,"D_REGVEN"
-6190,Posiciones Geodesicas Argentinas 1998,geodetic,"A geodetic network of 136 high accuracy surveyed points. Densification of SIRGAS 1995; ITRF94 at epoch 1995.42.",1998,7019,8901,1033,Geodetic survey.,"Technically, but at this record revision date not legally, replaces the 1994 POSGAR adjustment (code 6694).","Instituto Geográfico Militar de la República Argentina, http://www.igm.gov.ar",OGP,2005-09-12,2003.361 2005.460 2005.480 2006.770,0,"D_POSGAR_1998"
-6191,Albanian 1987,geodetic,,1987,7024,8901,1025,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2001-11-06,,0,"D_Albanian_1987"
-6192,Douala 1948,geodetic,"South pillar of Douala base; 4°00'40.64""N, 9°42'30.41""E (of Greenwich).",1948,7022,8901,2555,Topographic mapping.,"Replaced  by Manoca 1962 datum (code 6193).",TotalFinaElf,OGP,2008-06-24,2005.830 2008.045,0,"D_Douala_1948"
-6193,Manoca 1962,geodetic,"Reservoir centre at the  Manoca tower (""tube Suel""), 3°51'49.896""N, 9°36'49.347""E (of Greenwich).",1962,7011,8901,2555,Topographic mapping.,"The intent of the Bukavu 1953 conference was to adopt the Clarke 1880 (RGS) ellipsoid (code 7012) but in practice this datum has used the IGN version.  Replaces Douala 1948 (code 6192).",TotalFinaElf,OGP,2008-06-24,2008.045,0,"D_Manoca_1962"
-6194,Qornoq 1927,geodetic,"Fundamental point: Station 7008. Latitude: 64°31'06.27""N, longitude: 51°12'24.86""W (of Greenwich).",1927,7022,8901,3362,Topographic mapping.,,"Kort & Matrikelstyrelsen, Copenhagen. Origin coordinates from NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.362 2005.460 2006.220 2008.045,0,"D_Qornoq_1927"
-6195,Scoresbysund 1952,geodetic,,1952,7022,8901,2570,Topographic mapping.,,"Kort & Matrikelstyrelsen, Copenhagen.",OGP,2002-01-18,,0,"D_Scoresbysund_1952"
-6196,Ammassalik 1958,geodetic,,1958,7022,8901,2571,Topographic mapping.,,"Kort & Matrikelstyrelsen, Copenhagen.",OGP,2002-01-18,,0,"D_Ammassalik_1958"
-6197,Garoua,geodetic,"Fundamental point: IGN astronomical station and benchmark no. 16 at Tongo. Latitude 8°55'08.74""N, longitude 13°30'43.19""E (of Greenwich).",,7012,8901,2590,Topographic mapping.,,TotalFinaElf,OGP,2008-06-24,2008.045,0,"D_Garoua"
-6198,Kousseri,geodetic,"IGN astronomical station Dabanga; 11°55'05.9""N  14°38'40.8""E (of Greenwich).",,7012,8901,2591,Topographic mapping.,,TotalFinaElf,OGP,2008-06-24,2008.045,0,"D_Kousseri"
-6199,Egypt 1930,geodetic,"Fundamental point: Station F1 (Venus). Latitude: 30°01'42.86""N, longitude: 31°16'37.05""E (of Greenwich).",1930,7022,8901,3242,Used for scientific purposes only.,"Note that Egypt 1930 uses the International 1924 ellipsoid, unlike the Egypt 1907 datum (code 6229) which uses the Helmert ellipsoid. Oil industry references to the Egypt 1930 datum name and the Helmert ellipsoid probably mean Egypt 1907 datum.",,OGP,2008-06-24,2008.045,0,"D_Egypt_1930"
-6200,Pulkovo 1995,geodetic,"Fundamental point: Pulkovo observatory. Latitude: 59°46'15.359""N, longitude: 30°19'28.318""E (of Greenwich).",1995,7024,8901,1198,Scientific adjustment.,,"""Main Terms of Reference for the State Geodetic Network""; Federal Geodetic Service of Russia; 1994",OGP,2008-06-24,2008.045,0,"D_Pulkovo_1995"
-6201,Adindan,geodetic,"Fundamental point: Station 15; Adindan. Latitude: 22°10'07.110""N, longitude: 31°29'21.608""E (of Greenwich).",,7012,8901,1271,Topographic mapping.,"The 12th parallel traverse of 1966-70 (Point 58 datum, code 6620) is connected to the Adindan network in western Sudan. This has given rise to misconceptions that the Adindan network is used in west Africa.",,OGP,2008-06-24,2002.431 2003.361 2008.045,0,"D_Adindan"
-6202,Australian Geodetic Datum 1966,geodetic,"Fundamental point: Johnson Memorial Cairn. Latitude: 25°56'54.5515""S, longitude: 133°12'30.0771""E (of Greenwich).",1966,7003,8901,1279,Topographic mapping.,,"Australian Map Grid Technical Manual. National Mapping Council of Australia Technical Publication 7; 1972.",OGP,2008-06-24,2003.361 2008.045,0,"D_Australian_1966"
-6203,Australian Geodetic Datum 1984,geodetic,"Fundamental point: Johnson Memorial Cairn. Latitude: 25°56'54.5515""S, longitude: 133°12'30.0771""E (of Greenwich).",1984,7003,8901,2576,Topographic mapping.,"Uses all data from 1966 adjustment with additional observations, improved software and a geoid model.","""GDA technical manual v2_2"", Intergovernmental Committee on Surveying and Mapping. www.anzlic.org.au/icsm/gdtm/",OGP,2008-06-24,2003.290 2003.361 2008.045,0,"D_Australian_1984"
-6204,Ain el Abd 1970,geodetic,"Fundamental point: Ain El Abd.  Latitude: 28°14'06.171""N, longitude: 48°16'20.906""E (of Greenwich).",1970,7022,8901,1272,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_Ain_el_Abd_1970"
-6205,Afgooye,geodetic,,,7024,8901,1214,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Afgooye"
-6206,Agadez,geodetic,,,7011,8901,1177,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Agadez"
-6207,Lisbon 1937,geodetic,"Fundamental point: Castelo Sao Jorge, Lisbon. Latitude: 38°42'43.631""N, longitude: 9°07'54.862""W (of Greenwich).",1937,7022,8901,1294,Topographic mapping.,"Replaces Lisbon 1890 adjustment (which used Bessel 1841 ellipsoid).","Instituto Geografico e Cadastral; Lisbon",OGP,2008-06-24,2001.551 2008.045,0,"D_Lisbon"
-6208,Aratu,geodetic,,,7022,8901,1274,Oil industry geodetic purposes.,,,OGP,1995-06-02,,0,"D_Aratu"
-6209,Arc 1950,geodetic,"Fundamental point: Buffelsfontein. Latitude: 33°59'32.000""S, longitude: 25°30'44.622""E (of Greenwich).",1950,7013,8901,1276,"Topographic mapping, geodetic survey.",,,OGP,2008-06-24,2008.045,0,"D_Arc_1950"
-6210,Arc 1960,geodetic,"Fundamental point: Buffelsfontein. Latitude: 33°59'32.000""S, longitude: 25°30'44.622""E (of Greenwich).",1960,7012,8901,1277,"Topographic mapping, geodetic survey.",,,OGP,2008-06-24,2008.045,0,"D_Arc_1960"
-6211,Batavia,geodetic,"Fundamental point: Longitude at Batavia Astro. Station. Latitude: 6°07'39.522""S, longitude: 106°48'27.790""E (of Greenwich). Latitude and azimuth at Genuk.",,7004,8901,1285,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_Batavia"
-6212,Barbados 1938,geodetic,"Fundamental point: HMS Challenger astro station M1, St. Anne's Tower. Latitude 13°04'32.53""N, longitude 59°36'29.34""W (of Greenwich).",1938,7012,8901,1042,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,2008-06-24,1999.170 2006.030 2008.045,0,"D_Barbados_1938"
-6213,Beduaram,geodetic,,,7011,8901,2771,Topographic mapping.,,,OGP,2004-09-01,2004.490,0,"D_Beduaram"
-6214,Beijing 1954,geodetic,,1954,7024,8901,1067,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Beijing_1954"
-6215,Reseau National Belge 1950,geodetic,"Fundamental point: Lommel (tower). Latitude: 51°13'47.334""N, longitude: 5°18'49.483""E (of Greenwich).",1950,7022,8901,1347,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_Belge_1950"
-6216,Bermuda 1957,geodetic,"Fundamental point: Fort George base. Latitude 32°22'44.36""N, longitude 64°40'58.11""W (of Greenwich).",1957,7008,8901,1047,Topographic mapping.,,Various oil industry sources.,OGP,2008-06-24,2003.362 2008.045,0,"D_Bermuda_1957"
-6218,Bogota 1975,geodetic,"Fundamental point: Bogota observatory. Latitude: 4°35'56.570""N, longitude: 74°04'51.300""W (of Greenwich).",1975,7022,8901,3229,Topographic mapping.,"Replaces 1951 adjustment. Replaced by MAGNA-SIRGAS (datum code 6685).","Instituto Geografico Agustin Codazzi (IGAC) special publication no. 1, 4th edition (1975) ""Geodesia: Resultados Definitvos de Parte de las Redes Geodesicas Establecidas en el Pais"".",OGP,2008-06-24,2000.200 2005.060 2007.060 2008.045,0,"D_Bogota"
-6219,Bukit Rimpah,geodetic,"2°00'40.16""S, 105°51'39.76""E (of Greenwich).",,7004,8901,1287,Topographic mapping.,,,OGP,2008-06-24,2008.045,0,"D_Bukit_Rimpah"
-6220,Camacupa,geodetic,"Fundamental point: Campo de Aviaçao. Latitude: 12°01'09.070""S, Longitude = 17°27'19.800""E (of Greenwich)",1948,7012,8901,1288,Coastal hydrography.,,"Portuguese Hydrographic Institute and Clifford J. Mugnier, PE&RS journal, March 2001.",OGP,2008-06-24,2003.361 2006.973 2008.045,0,"D_Camacupa"
-6221,Campo Inchauspe,geodetic,"Fundamental point: Campo Inchauspe. Latitude: 35°58'16.56""S, longitude: 62°10'12.03""W (of Greenwich).",,7022,8901,1033,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.361 2005.460 2008.045,0,"D_Campo_Inchauspe"
-6222,Cape,geodetic,"Fundamental point: Buffelsfontein. Latitude: 33°59'32.000""S, longitude: 25°30'44.622""E (of Greenwich).",,7013,8901,1290,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Private Communication, Directorate of Surveys and Land Information, Cape Town.",OGP,2008-06-24,1996.250 1999.690 2008.045,0,"D_Cape"
-6223,Carthage,geodetic,"Fundamental point: Carthage. Latitude: 40.9464506g = 36°51'06.50""N, longitude: 8.8724368g E of Paris = 10°19'20.72""E (of Greenwich).",1925,7011,8901,1236,Topographic mapping.,Fundamental point astronomic coordinates determined in 1878.,,OGP,2008-06-24,2003.362 2003.050 2008.045,0,"D_Carthage"
-6224,Chua,geodetic,"Fundamental point: Chua. Latitude: 19°45'41.160""S, longitude: 48°06'07.560""W (of Greenwich).",,7022,8901,3356,Geodetic survey.,The Chua origin and associated network is in Brazil with a connecting traverse through northern Paraguay. It was used in Brazil only as input into the Corrego Allegre adjustment and for government work in Distrito Federal.,"NIMA http://earth-info.nima.mil/",OGP,2009-05-21,2003.361 2005.460 2005.840 2006.490 2008.045 2009.021,0,"D_Chua"
-6225,Corrego Alegre,geodetic,"Fundamental point: Corrego Alegre. Latitude: 19°50'15.140""S, longitude: 48°57'42.750""W (of Greenwich).",,7022,8901,1293,"Topographic mapping, geodetic survey. Superseded by SAD69.","NIMA gives coordinates of origin as latitude: 19°50'15.140""S, longitude: 48°57'42.750""W.","IBGE and NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2005.841 2008.045,0,"D_Corrego_Alegre"
-6226,"Cote d'Ivoire",geodetic,,,7011,8901,1075,Topographic mapping.,,,OGP,1995-06-02,2001.110,1,"D_Cote_d_Ivoire"
-6227,Deir ez Zor,geodetic,"Fundamental point: Trig. 254 Deir. Latitude: 35°21'49.975""N, longitude: 40°05'46.770""E (of Greenwich).",,7011,8901,1623,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_Deir_ez_Zor"
-6228,Douala,geodetic,,,7011,8901,1060,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Douala"
-6229,Egypt 1907,geodetic,"Fundamental point: Station F1 (Venus). Latitude: 30°01'42.86""N, longitude: 31°16'33.60""E (of Greenwich).",1907,7020,8901,1086,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,,OGP,2008-06-24,2008.045,0,"D_Egypt_1907"
-6230,European Datum 1950,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52°22'51.4456""N, longitude: 13°03'58.9283""E (of Greenwich).",1950,7022,8901,1296,"Topographic mapping, geodetic survey.",,"EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2008-06-24,2003.361 2008.045,0,"D_European_1950"
-6231,European Datum 1987,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52°22'51.4456""N, longitude: 13°03'58.9283""E (of Greenwich).",1987,7022,8901,1297,Scientific network.,,,OGP,2008-06-24,2003.362 2008.045,0,"D_European_1987"
-6232,Fahud,geodetic,"Fundamental point: Station NO68-024 Fahud. Latitude: 22°17'31.182""N, longitude: 56°29'18.820""E (of Greenwich).",,7012,8901,3288,Oil industry mapping.,"Replaced by PSD93 (code 6134).",Petroleum Development Oman.,OGP,2008-06-24,2008.045,0,"D_Fahud"
-6233,Gandajika 1970,geodetic,,1970,7022,8901,1152,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Gandajika_1970"
-6234,Garoua,geodetic,,,7011,8901,1060,Topographic mapping.,"The intent of the Bukavu 1953 conference was to adopt the Clarke 1880 (RGS) ellipsoid (code 7012) but in practice this datum has used the IGN version.",,OGP,1995-06-02,,1,"D_Garoua"
-6235,Guyane Francaise,geodetic,,,7022,8901,1097,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Guyane_Francaise"
-6236,Hu Tzu Shan 1950,geodetic,"Fundamental point: Hu Tzu Shan. Latitude: 23°58'32.34""N, longitude: 120°58'25.975""E (of Greenwich).",1950,7022,8901,3315,Topographic mapping.,,"NIMA ¶US NGA, http://earth-info.nga.mil/GandG/index.html",OGP,2008-08-12,2003.362 2005.460 2005.830 2008.017 2008.045,0,"D_Hu_Tzu_Shan"
-6237,Hungarian Datum 1972,geodetic,"Fundamental point: Szolohegy. Latitude: 47°17'32,6156""N, longitude 19°36'09.9865""E (of Greenwich); geoid height 6.56m.",1972,7036,8901,1119,Topographic mapping.,"Replaced Hungarian Datum 1909 (EPSG datum code 1024).","http://lazarus.elte.hu/gb/geodez/geod3.htm",OGP,2008-08-02,1996.090 2008.045 2008.047,0,"D_Hungarian_1972"
-6238,Indonesian Datum 1974,geodetic,"Fundamental point: Padang. Latitude: 0°56'38.414""S, longitude: 100°22' 8.804""E (of Greenwich). Ellipsoidal height 3.190m, gravity-related height 14.0m above mean sea level.",1974,7021,8901,1122,Topographic mapping.,Replaced by DGN95.,Bakosurtanal 1979 paper by Jacob Rais.,OGP,2008-06-24,2002.151 2006.810 2008.045,0,"D_Indonesian_1974"
-6239,Indian 1954,geodetic,Extension of Kalianpur 1937 over Myanmar and Thailand.,1954,7015,8901,1304,Topographic mapping.,,,OGP,2003-12-31,2003.361,0,"D_Indian_1954"
-6240,Indian 1975,geodetic,"Fundamental point: Khau Sakaerang.",1975,7015,8901,1231,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Indian_1975"
-6241,Jamaica 1875,geodetic,"Fundamental point: Fort Charles Flagstaff. Latitude: 17°55'55.800""N, longitude: 76°56'37.260""W (of Greenwich).",1875,7034,8901,3342,Topographic mapping.,,"Survey Department, Government of Jamaica, 1983.",OGP,2008-06-24,2004.510 2008.045,0,"D_Jamaica_1875"
-6242,Jamaica 1969,geodetic,"Fundamental point: Fort Charles Flagstaff. Latitude: 17°55'55.800""N, longitude: 76°56'37.260""W (of Greenwich).",1969,7008,8901,3342,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Survey Department, Government of Jamaica, 1983.",OGP,2008-06-24,2004.510 2008.045,0,"D_Jamaica_1969"
-6243,Kalianpur 1880,geodetic,"Fundamental point: Kalianpur. Latitude: 24°07'11.260""N, longitude: 77°39'17.570""E (of Greenwich).",1880,7042,8901,1307,Topographic mapping.,"Includes 1916 extension into Burma (Myanmar).  Replaced by 1937 adjustment.","G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",OGP,2008-06-24,1997.231 2004.290 2008.045,0,"D_Kalianpur_1880"
-6244,Kandawala,geodetic,,,7015,8901,3310,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Kandawala"
-6245,Kertau 1968,geodetic,"Fundamental point: Kertau. Latitude: 3°27'50.710""N, longitude: 102°37'24.550""E (of Greenwich).",1968,7018,8901,1309,"Geodetic survey, cadastre.","Replaces MRT48 and earlier adjustments. Adopts metric conversion of 39.370113 inches per metre. Not used for 1969 metrication of RSO grid - see Kertau (RSO) (code 6751).",Defence Geographic Centre.,OGP,2008-06-24,2006.251 2008.045,0,"D_Kertau"
-6246,Kuwait Oil Company,geodetic,"Fundamental point: K28.  Latitude: 29°03'42.348""N, longitude: 48°08'42.558""E (of Greenwich).",1952,7012,8901,3267,Oil industry mapping.,,,OGP,2008-06-24,2004.410 2008.045,0,"D_Kuwait_Oil_Company"
-6247,La Canoa,geodetic,"Fundamental point: La Canoa. Latitude: 8°34'17.170""N, longitude: 63°51'34.880""W (of Greenwich).",,7022,8901,3327,"Geodetic survey, topographic mapping, engineering survey.",Origin also adopted for PSAD56.,,OGP,2008-06-24,2008.045,0,"D_La_Canoa"
-6248,Provisional South American Datum 1956,geodetic,"Fundamental point: La Canoa. Latitude: 8°34'17.170""N, longitude: 63°51'34.880""W (of Greenwich).",1956,7022,8901,1348,Topographic mapping.,Same origin as La Canoa datum.,,OGP,2008-06-24,2008.045,0,"D_Provisional_S_American_1956"
-6249,Lake,geodetic,"Fundamental point: Maracaibo Cathedral. Latitude: 10°38'34.678""N, longitude: 71°36'20.224""W (of Greenwich).",,7022,8901,1312,Oil industry mapping.,,,OGP,2008-06-24,2008.045,0,"D_Lake"
-6250,Leigon,geodetic,"Fundamental point: GCS Station 121, Leigon. Latitude: 5°38'52.27""N, longitude: 0°11'46.08""W (of Greenwich).",,7012,8901,1104,Topographic mapping.,"Replaced Accra datum (code 6168) from 1978.  Coordinates at Leigon fundamental point defined as Accra datum values for that point.",Ordnance Survey International,OGP,2008-06-24,2008.045,0,"D_Leigon"
-6251,Liberia 1964,geodetic,"Fundamental point: Robertsfield. Latitude: 6°13'53.02""N, longitude: 10°21'35.44""W (of Greenwich).",1964,7012,8901,3270,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.362 2005.460 2008.045,0,"D_Liberia_1964"
-6252,Lome,geodetic,,,7011,8901,1232,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Lome"
-6253,Luzon 1911,geodetic,"Fundamental point: Balacan. Latitude: 13°33'41.000""N, longitude: 121°52'03.000""E (of Greenwich).",1911,7008,8901,1190,Topographic mapping.,"Replaced by Philippine Reference system of 1992 (datum code 6683).",Coast and Geodetic Survey,OGP,2008-06-24,2004.730 2008.045,0,"D_Luzon_1911"
-6254,Hito XVIII 1963,geodetic,Chile-Argentina boundary survey.,1963,7022,8901,1303,Geodetic survey.,Used in Tierra del Fuego.,Various oil company records.,OGP,1995-06-02,,0,"D_Hito_XVIII_1963"
-6255,Herat North,geodetic,"Fundamental point: Herat North. Latitude: 34°23'09.08""N, longitude: 64°10'58.94""E (of Greenwich).",,7022,8901,1024,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.362 2005.460 2008.045,0,"D_Herat_North"
-6256,Mahe 1971,geodetic,"Fundamental point: Mahe.",1971,7012,8901,1208,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Mahe_1971"
-6257,Makassar,geodetic,"Fundamental point: station P1, Moncongloe. Latitude: 5°08'41.42""S, long 119°24'14.94""E (of Greenwich).",,7004,8901,1316,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.361 2005.460 2008.045,0,"D_Makassar"
-6258,European Terrestrial Reference System 1989,geodetic,Fixed to the stable part of the Eurasian continental plate and consistent with ITRS at the epoch 1989.0.,1989,7019,8901,1298,Geodetic survey.,"The distinction in usage between ETRF89 and ETRS89 is confused: although in principle conceptually different in practice both are used for the realisation.",,OGP,2003-08-14,1997.110 1997.550 1999.111 2000.720 2003.260,0,"D_ETRS_1989"
-6259,Malongo 1987,geodetic,"Fundamental point: Station Y at Malongo base camp. Latitude: 5°23'30.810""S, longitude: 12°12'01.590""E (of Greenwich).",1987,7022,8901,3180,Oil industry offshore exploration and production from 1987.,"Replaced Mhast (offshore) (code 6705) in 1987. Origin coordinates constrained to those of Mhast (offshore) but other station coordinates differ. References to ""Mhast"" since 1987 often should have stated ""Malongo 1987"".",Chevron Petroleum Technology.,OGP,2008-06-24,2005.751 2008.045,0,"D_Malongo_1987"
-6260,Manoca,geodetic,,,7012,8901,1060,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Manoca"
-6261,Merchich,geodetic,"Fundamental point: Merchich. Latitude: 33°26'59.672""N, longitude: 7°33'27.295""W (of Greenwich).",1922,7011,8901,3280,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_Merchich"
-6262,Massawa,geodetic,,,7004,8901,1089,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Massawa"
-6263,Minna,geodetic,"Fundamental point: Minna base station L40. Latitude: 9°38'08.87""N, longitude: 6°30'58.76""E (of Greenwich).",,7012,8901,1178,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.361 2005.460 2008.045,0,"D_Minna"
-6264,Mhast,geodetic,,,7022,8901,1318,Coastal hydrography.,,,OGP,1995-06-02,,1,"D_Mhast"
-6265,Monte Mario,geodetic,"Fundamental point: Monte Mario. Latitude: 41°55'25.51""N, longitude: 12°27'08.4""E (of Greenwich).",1940,7022,8901,3343,Topographic mapping.,"Replaced Genova datum, Bessel 1841 ellipsoid, from 1940.",,OGP,2008-06-24,2003.360 2008.045,0,"D_Monte_Mario"
-6266,"M'poraloko",geodetic,,,7011,8901,1100,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Mporaloko"
-6267,North American Datum 1927,geodetic,"Fundamental point: Meade's Ranch. Latitude: 39°13'26.686""N, longitude: 98°32'30.506""W (of Greenwich).",1927,7008,8901,1349,Topographic mapping.,"In North America, replaced by North American Datum 1983 (NAD83)",,OGP,2008-06-24,2008.024 2008.045,0,"D_North_American_1927"
-6268,NAD Michigan,geodetic,"Fundamental point: Meade's Ranch. Latitude: 39°13'26.686""N, longitude: 98°32'30.506""W (of Greenwich).",,7009,8901,1391,Topographic mapping.,,,OGP,2008-06-24,2008.045,0,"D_North_American_Michigan"
-6269,North American Datum 1983,geodetic,Origin at geocentre.,1986,7019,8901,1350,Topographic mapping.,"Although the 1986 adjustment included connections to Greenland and Mexico, it has not been adopted there. In Canada and US, replaced NAD27.",,OGP,2008-04-11,2006.464 2008.024,0,"D_North_American_1983"
-6270,Nahrwan 1967,geodetic,"Fundamental point: Nahrwan south base.  Latitude: 33°19'10.87""N, longitude: 44°43'25.54""E (of Greenwich).",1967,7012,8901,1351,Topographic mapping.,"In Iraq, replaces Nahrwan 1934.",,OGP,2008-06-24,2006.340 2008.045,0,"D_Nahrwan_1967"
-6271,Naparima 1972,geodetic,"Fundamental point: Naparima. Latitude: 10°16'44.860""N, longitude: 61°27'34.620""W (of Greenwich).",1972,7022,8901,1322,Topographic mapping.,Naparima 1972 is an extension of the Naparima 1955 network of Trinidad to include Tobago.,Ordnance Survey International.,OGP,2008-06-24,2008.045,0,"D_Naparima_1972"
-6272,New Zealand Geodetic Datum 1949,geodetic,"Fundamental point: Papatahi. Latitude: 41°19' 8.900""S, longitude: 175°02'51.000""E (of Greenwich).",1949,7022,8901,3285,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by New Zealand Geodetic Datum 2000 (code 6167) from March 2000.","Land Information New Zealand. http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd2000factsheet/index.jsp",OGP,2008-06-24,2000.702 2004.110 2008.045,0,"D_New_Zealand_1949"
-6273,NGO 1948,geodetic,"Fundamental point: Oslo observatory. Latitude: 59°54'43.7""N, longitude: 10°43'22.5""E (of Greenwich).",1948,7005,8901,1352,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"EuroGeographics; http://crs.bkg.bund.de/crs-eu/",OGP,2008-06-24,2003.362 2008.045,0,"D_NGO_1948"
-6274,Datum 73,geodetic,"Fundamental point:  TF4, Melrica. Latitude: 39°41'37.30""N, longitude: 8°07'53.31""W (of Greenwich).",1964,7022,8901,1294,Topographic mapping.,,"Instituto Geografico e Cadastral; Lisbon",OGP,2008-06-24,2008.045,0,"D_Datum_73"
-6275,Nouvelle Triangulation Francaise,geodetic,"Fundamental point: Pantheon. Latitude: 48°50'46.522""N, longitude: 2°20'48.667""E (of Greenwich).",1895,7011,8901,1326,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_NTF"
-6276,NSWC 9Z-2,geodetic,,,7025,8901,1262,Satellite navigation.,Transit precise ephemeris before 1991.,,OGP,1995-06-02,,0,"D_NSWC_9Z_2"
-6277,OSGB 1936,geodetic,"Fundamental point: Pre 2002: Herstmonceux, Latitude: 50°51'55.271""N, longitude: 0°20'45.882""E (of Greenwich). From April 2002 the datum is defined through the application of the OSTN02 transformation (tfm code 1039) to ETRS89.",1936,7001,8901,1264,Topographic mapping.Topographic mapping.Topographic mapping.Topographic mapping.,,Ordnance Survey of Great Britain,OGP,2008-06-24,2002.620 2008.045,0,"D_OSGB_1936"
-6278,"OSGB 1970 (SN)",geodetic,"Fundamental point: Herstmonceux. Latitude: 50°51'55.271""N, longitude: 0°20'45.882""E (of Greenwich).",1970,7001,8901,1264,Scientific network.,,,OGP,2008-06-24,2005.880 2008.045,0,"D_OSGB_1970_SN"
-6279,"OS (SN) 1980",geodetic,"Fundamental point: Herstmonceux. Latitude: 50°51'55.271""N, longitude: 0°20'45.882""E (of Greenwich).",1980,7001,8901,1354,Scientific network.,,,OGP,2008-06-24,2008.045,0,"D_OS_SN_1980"
-6280,Padang 1884,geodetic,"Fundamental point: Padang.",1884,7004,8901,1355,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Padang_1884"
-6281,Palestine 1923,geodetic,"Fundamental point: Point 82'M  Jerusalem. Latitude: 31°44' 2.749""N, longitude: 35°12'43.490""E (of Greenwich).",1923,7010,8901,1356,Topographic mapping.,,,OGP,2008-06-24,2004.150 2008.045,0,"D_Palestine_1923"
-6282,Congo 1960 Pointe Noire,geodetic,"Fundamental point: Point Noire Astro. Latitude: 4°47'00.10""S, longitude: 11°51'01.55""E (of Greenwich).",1960,7011,8901,1072,Topographic mapping.,,Elf,OGP,2008-06-24,2002.050 2003.361 2008.045,0,"D_Pointe_Noire"
-6283,Geocentric Datum of Australia 1994,geodetic,ITRF92 at epoch 1994.0.,1994,7019,8901,2575,"Topographic mapping, geodetic survey.",Coincident with WGS84 to within 1 metre.,"Australian Surveying and Land Information Group Internet WWW page. http://www.auslig.gov.au/geodesy/datums/gda.htm#specs",OGP,1995-06-02,,0,"D_GDA_1994"
-6284,Pulkovo 1942,geodetic,"Fundamental point: Pulkovo observatory. Latitude: 59°46'18.550""N, longitude: 30°19'42.090""E (of Greenwich).",1942,7024,8901,2423,Topographic mapping.,,,OGP,2008-09-24,2008.011 2008.045,0,"D_Pulkovo_1942"
-6285,Qatar 1974,geodetic,"Fundamental point: Station G3.",1974,7022,8901,1346,Topographic mapping.,,,OGP,2001-08-28,2001.270,0,"D_Qatar"
-6286,Qatar 1948,geodetic,"Fundamental point: Sokey 0 M. Latitude: 25°22'56.500""N, longitude: 50°45'41.000""E (of Greenwich).",1948,7020,8901,1346,Topographic mapping.,,,OGP,2008-06-24,2008.045,0,"D_Qatar_1948"
-6287,Qornoq,geodetic,,1927,7022,8901,1107,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Qornoq"
-6288,Loma Quintana,geodetic,"Fundamental point: Loma Quintana.",,7022,8901,1313,Topographic mapping.,"Replaced by La Canoa (code 6247).",,OGP,1995-06-02,,0,"D_Loma_Quintana"
-6289,Amersfoort,geodetic,"Fundamental point: Amersfoort. Latitude: 52°09'22.178""N, longitude: 5°23'15.478""E (of Greenwich).",,7004,8901,1275,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"http://www.rdnap.nl/",OGP,2008-06-24,2000.560 2003.361 2005.460 2008.045,0,"D_Amersfoort"
-6291,South American Datum 1969,geodetic,,1969,7036,8901,1358,Topographic mapping.,"SAD69 uses GRS67 ellipsoid with 1/f to exactly 2 decimal places.  Precision of ellipsoid entry increased from 2 to 5 dp with change id 97.252.  Error introduced if not using the truncated precision is 0 to 31mm.",,OGP,1996-10-18,1996.090 1997.252,1,"D_South_American_1969"
-6292,Sapper Hill 1943,geodetic,,1943,7022,8901,3247,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Sapper_Hill_1943"
-6293,Schwarzeck,geodetic,"Fundamental point: Schwarzeck. Latitude: 22°45'35.820""S, longitude: 18°40'34.549""E (of Greenwich). Fixed during German South West Africa-British Bechuanaland boundary survey of 1898-1903.",,7046,8901,1169,Topographic mapping.,,"Private Communication, Directorate of Surveys and Land Information, Cape Town.",OGP,2008-06-24,2001.150 2003.362 2008.045,0,"D_Schwarzeck"
-6294,Segora,geodetic,,,7004,8901,1359,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Segora"
-6295,Serindung,geodetic,"Fundamental point: Ep A. Latitude: 1°06'10.60""N, longitude: 105°00'59.82""E (of Greenwich).",,7004,8901,1360,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.362 2005.460 2008.045,0,"D_Serindung"
-6296,Sudan,geodetic,,,7011,8901,1361,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Sudan"
-6297,Tananarive 1925,geodetic,"Fundamental point: Tananarive observatory. Latitude: 18°55'02.10""S, longitude: 47°33'06.75""E (of Greenwich).",2025,7022,8901,3273,Topographic mapping.,,IGN Paris,OGP,2008-06-24,2003.361 2008.045,0,"D_Tananarive_1925"
-6298,Timbalai 1948,geodetic,"Fundamental point: Station P85 at Timbalai. Latitude: 5°17' 3.548""N, longitude: 115°10'56.409""E (of Greenwich).",1948,7016,8901,1362,Topographic mapping.,"In 1968, the original adjustment was densified in Sarawak and extended to Sabah.",Defence Geographic Centre.,OGP,2008-06-24,2006.252 2008.045,0,"D_Timbalai_1948"
-6299,TM65,geodetic,Adjusted to best mean fit 12 stations of the OSNI 1952 primary adjustment.,1965,7002,8901,1305,Topographic mapping.,"Differences between OSNI 1952 and TM65 at these stations are RMS 0.25m east, 0.23m north, maximum vector 0.57m. TM65 replaced by and not to be confused with Geodetic Datum of 1965 alias 1975 Mapping Adjustment or TM75 (datum code 6300).","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",OGP,2003-06-27,2002.621,0,"D_TM65"
-6300,Geodetic Datum of 1965,geodetic,Adjusted to best mean fit 9 stations of the OSNI 1952 primary adjustment in Northern Ireland plus the 1965 values of 3 stations in the Republic of Ireland.,1975,7002,8901,1305,"Geodetic survey, topographic mapping and engineering survey.","Differences from the 1965 adjustment (datum code 6299) are: average difference in Eastings 0.092m; average difference in Northings 0.108m; maximum vector difference 0.548m.","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",OGP,2003-06-27,2002.621,0,"D_TM75"
-6301,Tokyo,geodetic,"Fundamental point: Nikon-Keido-Genten. Latitude: 35°39'17.5148""N, longitude: 139°44'40.5020""E (of Greenwich).",,7004,8901,1364,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by Japanese Geodetic Datum 2000 (code 6611).","Geographic Survey Institute; Japan; Bulletin 40 (March 1994).  Also http://vldb.gsi.go.jp/sokuchi/datum/tokyodatum.html",OGP,2008-06-24,1998.460 2002.080 2008.045,0,"D_Tokyo"
-6302,Trinidad 1903,geodetic,"Station 00, Harbour Master's Flagstaff, Port of Spain. ¶Trinidad 1903 / Trinidad Grid coordinates (Clarke's links): 333604.30 E, 436366.91 N (Latitude: 10°38'39.01""N,  Longitude: 61°30'38.00""W of Greenwich)",1903,7007,8901,1339,Topographic mapping.,,"""Land Surveyor's Handbook"", 1935, published under the direction of JW MacGillivray, Surveyor General, Land & Survey's Department, Trinidad & Tobago.",OGP,2008-06-24,2003.362 2004.130 2008.045,0,"D_Trinidad_1903"
-6303,Trucial Coast 1948,geodetic,"Fundamental point: TC1. Latitude: 25°23'50.190""N, longitude: 55°26'43.950""E (of Greenwich).",1948,7020,8901,1363,Oil industry mapping.,,,OGP,2008-06-24,2008.045,0,"D_Trucial_Coast_1948"
-6304,Voirol 1875,geodetic,"Fundamental point: Voirol. Latitude: 36°45'07.927""N, longitude: 3°02'49.435""E of Greenwich. Uses RGS (and old IGN) value of 2°20'13.95""for Greenwich-Paris meridian difference.",1875,7011,8901,1365,Topographic mapping.,"Replaced by Voirol 1879 (code 6671).",IGN Paris,OGP,2008-06-24,2003.361 2008.045,0,"D_Voirol_1875"
-6306,Bern 1938,geodetic,"Fundamental point: Old Bern observatory. Latitude: 46°57'07.890""N, longitude: 7°26'22.335""E (of Greenwich).",1938,7004,8901,1286,Topographic mapping.,"This redetermination of the coordinates of fundamental point is used for scientific purposes and as the graticule overprinted on topographic maps constructed on the CH1903 / LV03 projected CS (code 21781).","""Die Projektionen der schweizerischen Plan- und Kartenwerke""; J. Bolliger 1967",OGP,2008-06-24,2008.045,0,"D_Bern_1938"
-6307,Nord Sahara 1959,geodetic,"Coordinates of primary network readjusted on ED50 datum and then transformed conformally to Clarke 1880 (RGS) ellipsoid.",1959,7012,8901,1365,Topographic mapping.,"Sometimes incorrectly referred to as Voirol Unifie 1960. Voirol Unifie 1960 is NOT a datum:  it is two projected coordinate systems based on  Nord Sahara 1959.  See coordinate system codes 30791 and 30792.","""Le System Geodesique Nord-Sahara""; IGN Paris",OGP,2006-01-16,1999.620 2003.361 2005.880,0,"D_Nord_Sahara_1959"
-6308,Stockholm 1938,geodetic,"Fundamental point: Stockholm observatory.",1938,7004,8901,3313,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RT90 adjustment (datum code 6124)",,OGP,1996-04-12,,0,"D_Stockholm_1938"
-6309,Yacare,geodetic,"Fundamental point: Yacare. Latitude: 30°35'53.68""S, longitude: 57°25'01.30""W (of Greenwich).",,7022,8901,1247,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",OGP,2008-06-24,2003.362 2005.460 2008.045,0,"D_Yacare"
-6310,Yoff,geodetic,"Fundamental point: Yoff. Latitude: 14°44'41.62""N, longitude: 17°29'07.02""W (of Greenwich).",,7011,8901,1207,Topographic mapping.,,,OGP,2008-06-24,2003.362 2008.045,0,"D_Yoff"
-6311,Zanderij,geodetic,,,7022,8901,1222,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Zanderij"
-6312,Militar-Geographische Institut,geodetic,"Fundamental point: Hermannskogel. Latitude: 48°16'15.29""N, longitude: 16°17'41.06""E (of Greenwich).",1901,7004,8901,1037,Geodetic survey.,"The longitude of the datum origin equates to a value for the Ferro meridian of 17°40' exactly west of Greenwich.","Bundesamt fur Eich- und Vermessungswesen; Wien",OGP,2009-05-21,2008.045 2009.015,0,"D_MGI"
-6313,Reseau National Belge 1972,geodetic,"Fundamental point: Uccle observatory. Latitude: 50°47'57.704""N, longitude: 4°21'24.983""E (of Greenwich).",1972,7022,8901,1347,Topographic mapping.,,,OGP,2008-06-24,2008.045,0,"D_Belge_1972"
-6314,Deutsches Hauptdreiecksnetz,geodetic,"Fundamental point: Rauenberg. Latitude: 52°27'12.021""N, longitude: 13°22'04.928""E (of Greenwich).  This station was destroyed in 1910 and the station at Potsdam substituted as the fundamental point.",,7004,8901,2326,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"BKG via EuroGeographics. http://crs.bkg.bund.de",OGP,2008-06-24,2001.511 2006.410 2008.045,0,"D_Deutsches_Hauptdreiecksnetz"
-6315,Conakry 1905,geodetic,"Fundamental point: Conakry. Latitude: 10.573766g N, longitude: 17.833682g W (of Paris).",1905,7011,8901,3257,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Conakry_1905"
-6316,Dealul Piscului 1930,geodetic,"Fundamental point: latitude 44°24'33.9606""N, longitude 26°06'44.8772""E (of Greenwich).",1930,7022,8901,3295,Topographic mapping.,"Replaced by Pulkovo 1942(58) (datum code 6179)",Institute for Geodesy Photogrametry and Land Management,OGP,2008-09-24,2008.011 2008.045,0,"D_Dealul_Piscului_1933"
-6317,Dealul Piscului 1970,geodetic,"Fundamental point: latitude 44°24'23.7709""N, longitude 26°06'44.1265""E (of Greenwich).",1970,7024,8901,1197,Topographic mapping.,"Replaces 1933 adjustment (datum code 6316)",Institute for Geodesy Photogrametry and Land Management,OGP,2008-06-24,2008.045,1,"D_Dealul_Piscului_1970"
-6318,National Geodetic Network,geodetic,,1993,7030,8901,3267,Geodetic survey.,Replaces 1984 adjustment which used the WGS72 ellipsoid.,,OGP,2004-06-16,2004.410,0,"D_NGN"
-6319,Kuwait Utility,geodetic,,,7019,8901,1310,"Cadastre, engineering survey.",,,OGP,1996-04-12,,0,"D_Kuwait_Utility"
-6322,World Geodetic System 1972,geodetic,Developed from a worldwide distribution of terrestrial and geodetic satellite observations and defined through a set of station coordinates.,1972,7043,8901,1262,Satellite navigation.,Used by GPS before 1987. For Transit satellite positioning see also WGS 72BE.,"NIMA http://earth-info.nima.mil/",OGP,2006-08-24,1999.030 2003.362 2005.460 2006.820,0,"D_WGS_1972"
-6324,WGS 72 Transit Broadcast Ephemeris,geodetic,,1972,7043,8901,1262,Satellite navigation.,Alleged datum for use with Transit broadcast ephemeris prior to 1989. Relationship to WGS 72 has changed over time.,,OGP,2006-08-24,1999.030 2006.820,0,"D_WGS_1972_BE"
-6326,World Geodetic System 1984,geodetic,"Defined through a consistent set of station coordinates. These have changed with time: by 0.7m on 29/6/1994 [WGS 84 (G730)], a further 0.2m on 29/1/1997 [WGS 84 (G873)] and a further 0.06m on 20/1/2002 [WGS 84 (G1150)].",1984,7030,8901,1262,Satellite navigation.,"EPSG's WGS 84 datum has been the then current realisation. No distinction is made between the original WGS 84 frame, WGS 84 (G730), WGS 84 (G873) and WGS 84 (G1150). Since 1997, WGS 84 has been maintained within 10cm of the then current ITRF.","NIMA TR8350.2 June 2004 revision. http://earth-info.nga.mil/GandG/publications/tr8350.2/tr8350_2.html and ¶http://gis-lab.info/docs/nima-tr8350.2-addendum.pdf",OGP,2006-08-25,2002.151 2002.890 2003.270 2005.460 2005.550 2006.810,0,"D_WGS_1984"
-6600,Anguilla 1957,geodetic,"Fundamental point: station A4, Police.",1957,7012,8901,3214,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,1999-04-22,,0,"D_Anguilla_1957"
-6601,Antigua 1943,geodetic,"Fundamental point: station A14.",1943,7012,8901,1273,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,1999-04-22,,0,"D_Antigua_1943"
-6602,Dominica 1945,geodetic,"Fundamental point: station M12.",1945,7012,8901,3239,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,1999-04-22,,0,"D_Dominica_1945"
-6603,Grenada 1953,geodetic,"Fundamental point: station GS8, Sante Marie.",1953,7012,8901,1551,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,2006-02-09,2006.030,0,"D_Grenada_1953"
-6604,Montserrat 1958,geodetic,"Fundamental point: station M36.",1958,7012,8901,3279,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,1999-04-22,,0,"D_Montserrat_1958"
-6605,St. Kitts 1955,geodetic,"Fundamental point: station K12.",1955,7012,8901,3297,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,1999-04-22,,0,"D_St_Kitts_1955"
-6606,St. Lucia 1955,geodetic,"Fundamental point: station DCS3.",1955,7012,8901,3298,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,1999-04-22,,0,"D_St_Lucia_1955"
-6607,St. Vincent 1945,geodetic,"Fundamental point: station V1, Fort Charlotte.",1945,7012,8901,3300,Topographic mapping.,,Ordnance Survey of Great Britain.,OGP,2006-02-09,2006.030,0,"D_St_Vincent_1945"
-6608,"North American Datum 1927 (1976)",geodetic,"Fundamental point: Meade's Ranch. Latitude: 39°13'26.686""N, longitude: 98°32'30.506""W (of Greenwich).",1976,7008,8901,1367,"Geodetic survey, cadastre, topographic mapping, engineering survey.","NAD27(76) used in Ontario for all maps at scale 1/20 000 and larger; elsewhere in Canada for selected purposes.",Geodetic Survey of Canada.,OGP,2008-06-24,2008.045,0,"D_NAD_1927_Definition_1976"
-6609,"North American Datum 1927 (CGQ77)",geodetic,"Fundamental point: Meade's Ranch. Latitude: 39°13'26.686""N, longitude: 98°32'30.506""W (of Greenwich).",1977,7008,8901,1368,"Geodetic survey, cadastre, topographic mapping, engineering survey.","NAD27 (CGQ77) used in Quebec for all maps at scale 1/20 000 and larger; generally for maps issued by the Quebec cartography office whose reference system is CGQ77.","Geodetic Service of Quebec.  Contact alain.bernard at mrn.gouv.qc.ca",OGP,2008-06-24,2008.045,0,"D_NAD_1927_CGQ77"
-6610,Xian 1980,geodetic,,1980,7049,8901,3228,"Geodetic survey, topographic and engineering survey.",,BP,OGP,2002-02-12,,0,"D_Xian_1980"
-6611,Hong Kong 1980,geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22°18'12.82"", longitude 114°10'18.75""E (of Greenwich).",1980,7022,8901,1118,"Geodetic survey, topgraphic and engineering survey, cadastre.","Replaces Hong Kong 1963 and Hong Kong 1963(67).","Survey and Mapping Office, Lands Department. http://www.info.gov.hk/landsd/mapping/tindex.htm",OGP,2008-06-24,2005.260 2008.045,0,"D_Hong_Kong_1980"
-6612,Japanese Geodetic Datum 2000,geodetic,ITRF94 at epoch 1997.0,2000,7019,8901,1129,"Geodetic survey, topographic and engineering survey.","Instigated under amendment to the Japanese Surveying Law with effect from April 2002. Replaces Tokyo datum (code 6301).","Japanese Survey Federation and Geographical Survey Institute http://www.gsi.go.jp/ENGLISH/RESEARCH/BULLETIN/vol-45/45abst1.htm",OGP,2002-06-22,,0,"D_JGD_2000"
-6613,Gunung Segara,geodetic,"Station P5 (Gunung Segara). Latitude 0°32'12.83""S, longitude 117°08'48.47""E (of Greenwich).",,7004,8901,1360,Topographic mapping.,,TotalFinaElf.,OGP,2008-06-24,2008.045,0,"D_Gunung_Segara"
-6614,Qatar National Datum 1995,geodetic,Defined by transformation from WGS 84 - see coordinate operation code 1840.,1995,7022,8901,1346,Topographic mapping.,,Qatar Centre for Geographic Information.,OGP,2002-06-28,,0,"D_QND_1995"
-6615,Porto Santo 1936,geodetic,SE Base on Porto Santo island.,1936,7022,8901,1314,Topographic mapping.,"Replaced by 1995 adjustment (datum code 6663). For Selvagens see Selvagem Grande (code 6616).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",OGP,2003-08-14,2003.231 2003.232,0,"D_Porto_Santo_1936"
-6616,Selvagem Grande,geodetic,,,7022,8901,2779,Topographic mapping.,,"Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",OGP,2003-08-14,2003.232,0,
-6618,South American Datum 1969,geodetic,"Fundamental point: Chua. Geodetic latitude: 19°45'41.6527""S; geodetic longitude: 48°06'04.0639""W (of Greenwich). (Astronomic coordinates: Latitude 19°45'41.34""S +/- 0.05"", longitude 48°06'07.80""W +/- 0.08"").",1969,7050,8901,1358,Topographic mapping.,"SAD69 uses GRS 1967 ellipsoid but with 1/f to exactly 2 decimal places.",DMA 1974.,OGP,2008-06-24,2003.362 2008.045,0,"D_South_American_1969"
-6619,SWEREF99,geodetic,Densification of ETRS89.,1982,7019,8901,1225,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"National Land Survey of Sweden http://www.lantmateriet.se",OGP,2002-09-19,,0,"D_SWEREF99"
-6620,Point 58,geodetic,"Fundamental point: Point 58. Latitude: 3°58'37.040""N, longitude: 12°52'44.045""E (of Greenwich).",1969,7012,8901,2790,Geodetic survey,Used as the basis for computation of the 12th Parallel traverse conducted 1966-70 from Senegal to Chad and connecting to the Adindan triangulation in Sudan.,IGN Paris.,OGP,2008-06-24,2008.045,0,"D_Point_58"
-6621,Fort Marigot,geodetic,,,7022,8901,2828,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RRAF 1991 (datum code 6640).",IGN Paris.,OGP,2002-11-29,,0,"D_Fort_Marigot"
-6622,Guadeloupe 1948,geodetic,,1948,7022,8901,2829,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RRAF 1991 (datum code 6640).",IGN Paris.,OGP,2004-10-14,2004.561,0,"D_Sainte_Anne"
-6623,Centre Spatial Guyanais 1967,geodetic,"Fundamental point: Kourou-Diane. Latitude: 5°15'53.699""N, longitude: 52°48'09.149""W (of Greenwich).",1967,7022,8901,3105,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGFG95 (code 6624).",IGN Paris.,OGP,2008-06-24,2004.562 2008.045,0,"D_CSG_1967"
-6624,Reseau Geodesique Francais Guyane 1995,geodetic,ITRF93 at epoch 1995.0,1995,7019,8901,1097,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces CSG67 (datum code 6623).",IGN Paris.,OGP,2002-11-29,,0,"D_RGFG_1995"
-6625,Martinique 1938,geodetic,"Fundamental point: Fort Desaix. Latitude: 14°36'54.090""N, longitude: 61°04'04.030""W (of Greenwich).",1938,7022,8901,3276,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RRAF 1991 (datum code 6640).",IGN Paris.,OGP,2008-06-24,2004.561 2008.045,0,"D_Fort_Desaix"
-6626,Reunion 1947,geodetic,"Fundamental point: Piton des Neiges (Borne). Latitude: 21°05'13.119""S, longitude: 55°29'09.193""E (of Greenwich).",1947,7022,8901,3337,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGR92 (datum code 6627).",IGN Paris.,OGP,2008-06-24,2004.561 2008.045,0,"D_Reunion_1947"
-6627,Reseau Geodesique de la Reunion 1992,geodetic,ITRF91 at epoch 1993.0,1992,7019,8901,1196,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Piton des Neiges (code 6626).",IGN Paris.,OGP,2006-08-18,2006.770,0,"D_RGR_1992"
-6628,Tahiti 52,geodetic,"Fundamental point: Tahiti North Base. Latitude: 17°38'10.0""S, longitude: 149°36'57.8""W (of Greenwich).",1952,7022,8901,2811,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by Tahiti 79 (datum code 6690) in Tahiti and Moorea 87 (code 6691) in Moorea.","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2005.380 2008.045,0,"D_Tahiti_1952"
-6629,Tahaa 54,geodetic,"Fundamental point: Tahaa East Base. Latitude: 16°33'20.97""S, longitude: 151°29'06.25""W (of Greenwich).",1954,7022,8901,2812,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2005.380 2008.045,0,"D_Tahaa_1954"
-6630,IGN72 Nuku Hiva,geodetic,"Fundamental point: Taiohae. Latitude: 8°55'03.97""S, longitude: 140°05'36.24""W (of Greenwich).",1972,7022,8901,3129,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2005.380 2008.045,0,"D_IGN72_Nuku_Hiva"
-6631,K0 1949,geodetic,,1949,7022,8901,2816,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2002-11-29,,1,"D_K0_1949"
-6632,Combani 1950,geodetic,,1950,7022,8901,3340,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2002-11-29,,0,"D_Combani_1950"
-6633,IGN56 Lifou,geodetic,South end of the Goume base.,1956,7022,8901,2814,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,2006.620,0,"D_IGN56_Lifou"
-6634,IGN72 Grande Terre,geodetic,North end of Gomen base.,1972,7022,8901,2822,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,2006.620,0,"D_IGN72_Grande_Terre"
-6635,ST87 Ouvea,geodetic,,1987,7022,8901,2813,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Service Topographique de la Nouvelle Caledonie.,OGP,2002-11-29,,1,"D_ST87_Ouvea"
-6636,Petrels 1972,geodetic,"Fundamental point: Astro station DZ on Ile de Petrels. Latitude: 66°40'00""S, longitude: 140°00'46""E (of Greenwich).",1972,7022,8901,2817,"Geodetic survey,  topographic mapping.",,IGN Paris.,OGP,2008-06-24,2008.045,0,"D_Petrels_1972"
-6637,Pointe Geologie Perroud 1950,geodetic,"Fundamental point: Astro station G.0 on Pointe Geologie. Latitude: 66°39'30""S, longitude: 140°01'00""E (of Greenwich).",1950,7022,8901,2818,"Geodetic survey,  topographic mapping.",,IGN Paris.,OGP,2008-06-24,2008.045,0,"D_Pointe_Geologie_Perroud_1950"
-6638,Saint Pierre et Miquelon 1950,geodetic,,1950,7008,8901,1220,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2006-02-03,2006.060,0,"D_Saint_Pierre_et_Miquelon_1950"
-6639,MOP78,geodetic,,1978,7022,8901,2815,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2002-11-29,,0,"D_MOP78"
-6640,Reseau de Reference des Antilles Francaises 1991,geodetic,WGS 84 coordinates of a single station determined during the 1988 Tango mission.,1991,7030,8901,2824,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Fort Marigot and Sainte Anne (datum codes 6621-22) in Guadeloupe and Fort Desaix (datum code 6625) in Martinique.",IGN Paris.,OGP,2004-03-26,2004.200,0,"D_RRAF_1991"
-6641,IGN53 Mare,geodetic,South-east end of the La Roche base.,1953,7022,8901,2819,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,2006.620,0,"D_IGN53_Mare"
-6642,ST84 Ile des Pins,geodetic,"Fundamental point: Pic Nga.",1984,7022,8901,2820,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,2006.620,0,"D_ST84_Ile_des_Pins"
-6643,ST71 Belep,geodetic,,1971,7022,8901,2821,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Service Topographique de la Nouvelle Caledonie.,OGP,2002-11-29,,0,"D_ST71_Belep"
-6644,NEA74 Noumea,geodetic,Noumea old signal station.,1974,7022,8901,2823,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,2006.620,0,"D_NEA74_Noumea"
-6645,Reseau Geodesique Nouvelle Caledonie 1991,geodetic,ITRF90 at epoch 1989.0,1989,7022,8901,1174,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Service Topographique de la Nouvelle Caledonie.,OGP,2002-11-29,,1,"D_RGNC_1991"
-6646,Grand Comoros,geodetic,"Fundamental point: M'Tsaoueni.  Latitude: 11°28'32.200""S, longitude: 43°15'42.315""E (of Greenwich).",,7022,8901,2807,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2008-06-24,2008.045,0,"D_Grand_Comoros"
-6647,International Terrestrial Reference Frame 1988,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1988,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1988.0. Replaced by ITRF89 (code 6648).","International Earth Rotation Service (IERS) Annual Report for 1988. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6648,International Terrestrial Reference Frame 1989,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1989,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1989.0. Replaces ITRF88 (code 6647). Replaced by ITRF90 (code 6649).","International Earth Rotation Service (IERS) Technical Note No. 6. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6649,International Terrestrial Reference Frame 1990,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1990,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1990.0. Replaces ITRF89 (code 6648). Replaced by ITRF91 (code 6650).","International Earth Rotation Service (IERS) Technical Note No. 9. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6650,International Terrestrial Reference Frame 1991,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1991,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1991.0. Replaces ITRF90 (code 6649). Replaced by ITRF92 (code 6651).","International Earth Rotation Service (IERS) Technical Note No. 12. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6651,International Terrestrial Reference Frame 1992,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1992,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1992.0. Replaces ITRF91 (code 6650). Replaced by ITRF93 (code 6652).","International Earth Rotation Service (IERS) Technical Note No. 15. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6652,International Terrestrial Reference Frame 1993,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1993,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1993.0. Replaces ITRF92 (code 6651). Replaced by ITRF94 (code 6653).","International Earth Rotation Service (IERS) Technical Note No. 18. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6653,International Terrestrial Reference Frame 1994,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1994,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1994.0. Replaces ITRF93 (code 6652). Replaced by ITRF96 (code 6654).","International Earth Rotation Service (IERS) Technical Note No. 20. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6654,International Terrestrial Reference Frame 1996,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1996,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1996.0. Replaces ITRF94 (code 6653). Replaced by ITRF97 (code 6655).","International Earth Rotation Service (IERS) Technical Note No. 24. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6655,International Terrestrial Reference Frame 1997,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1997,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1997.0. Replaces ITRF96 (code 6654). Replaced by ITRF2000 (code 6656).","International Earth Rotation Service (IERS) Technical Note No. 27. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6656,International Terrestrial Reference Frame 2000,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",2000,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 2000.0. Replaces ITRF97 (code 6655). Replaced by ITRF2005 (code 6758).","IGN Paris http://lareg.ensg.ign.fr/ITRF",OGP,2006-10-13,2006.770 2006.892,0,
-6657,Reykjavik 1900,geodetic,"Fundamental point:  Latitude: 64°08'31.88""N, longitude: 21°55'51.15""W (of Greenwich).",1900,7051,8901,3262,Medium scale topographic mapping.,,"Landmaelingar Islands (National Survey of Iceland).",OGP,2008-06-24,2008.045,0,"D_Reykjavik_1900"
-6658,Hjorsey 1955,geodetic,"Fundamental point:  Latitude: 64°31'29.26""N, longitude: 22°22'05.84""W (of Greenwich).",1955,7022,8901,3262,"1/50,000 scale topographic mapping.",,"Landmaelingar Islands (National Survey of Iceland).",OGP,2008-06-24,2008.045,0,"D_Hjorsey_1955"
-6659,Islands Network 1993,geodetic,ITRF93 at epoch 1993.6.,1996,7019,8901,1120,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Landmaelingar Islands (National Survey of Iceland).",OGP,2006-08-18,2006.770,0,"D_Islands_Network_1993"
-6660,Helle 1954,geodetic,,1954,7022,8901,2869,"Geodetic survey, topographic mapping..",,Statens kartverk.,OGP,2003-06-27,,0,"D_Helle_1954"
-6661,Latvia 1992,geodetic,Constrained to 4 ETRS89 points in Latvia from the EUREF Baltic 1992 campaign.,1992,7019,8901,1139,"Topographic mapping, geodetic survey.",Densification of ETRS89 during the 1992 Baltic campaign.,"Latvijas Republikas Valsts zemes dienests (State Land Service of the Republic of Latvia) via EuroGeographics. http://crs.bkg.bund.de/crs-eu/",OGP,2003-06-27,,0,"D_Latvia_1992"
-6663,Porto Santo 1995,geodetic,SE Base on Porto Santo island. Origin and orientation constrained to those of the 1936 adjustment.,1995,7022,8901,1314,Topographic mapping.,"Classical and GPS observations. Replaces 1936 adjustment (datum code 6615). ¶For Selvagens see Selvagem Grande (datum code 6616).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",OGP,2005-09-06,2005.460,0,"D_Porto_Santo_1995"
-6664,Azores Oriental Islands 1995,geodetic,"Fundamental point: Forte de São Bras. Origin and orientation constrained to those of the 1940 adjustment.",1940,7022,8901,1345,Topographic mapping.,"Classical and GPS observations. Replaces 1940 adjustment (datum code 6184).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",OGP,2005-09-06,2005.460,0,"D_Azores_Oriental_Islands_1995"
-6665,Azores Central Islands 1995,geodetic,"Fundamental point: Graciosa south west base. Origin and orientation constrained to those of the 1948 adjustment.",1948,7022,8901,1301,Topographic mapping.,"Classical and GPS observations. Replaces 1948 adjustment (datum code 6183).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",OGP,2005-09-06,2005.460,0,"D_Azores_Central_Islands_1995"
-6666,Lisbon 1890,geodetic,"Fundamental point: Castelo Sao Jorge, Lisbon. Latitude: 38°42'43.631""N, longitude: 9°07'54.862""W of Greenwich.",1937,7004,8901,1294,Topographic mapping.,"Replaced by Lisbon 1937 adjustment (which uses International 1924 ellipsoid).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",OGP,2008-06-24,2003.361 2008.045,0,"D_Lisbon_1890"
-6667,Iraq-Kuwait Boundary Datum 1992,geodetic,Four stations established between September and December 1991 determined by GPS and Doppler observations.,1992,7030,8901,2876,International boundary demarcation,,"United Nations Iraq-Kuwait Boundary Demarcation Commission, Final Report, May 1993.",OGP,2003-09-01,,0,"D_Iraq_Kuwait_Boundary_1992"
-6668,European Datum 1979,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52°22'51.4456""N, longitude: 13°03'58.9283""E (of Greenwich).",1979,7022,8901,1297,Scientific network.,Replaced by 1987 adjustment.,,OGP,2008-06-24,2008.045,0,"D_European_1979"
-6670,Istituto Geografico Militaire 1995,geodetic,Network of 1296 points observed 1992-1995 and adjusted in 1996 constrained to 9 ETRS89 points. Densification of ETRS89 in Italy.,1995,7030,8901,1127,Geodetic survey and scientific study.,,ENI,OGP,2004-01-07,,0,"D_IGM_1995"
-6671,Voirol 1879,geodetic,"Fundamental point: Voirol. Latitude: 36°45'08.199""N, longitude: 3°02'49.435""E (of Greenwich). Uses RGS (and old IGN) value of 2°20'13.95""for Greenwich-Paris meridian difference.",1879,7011,8901,1365,Topographic mapping.,"Replaces Voirol 1875 (code 6304).",IGN Paris,OGP,2008-06-24,2008.045,0,"D_Voirol_1879"
-6672,Chatham Islands Datum 1971,geodetic,,1971,7022,8901,2889,"Geodetic survey, topographic mapping, engineering survey.","Replaced by Chatham Islands Datum 1979 (code 6673).","Office of Surveyor General (OSG) Technical Report 14, June 2001.",OGP,2004-02-17,,0,"D_Chatham_Island_1971"
-6673,Chatham Islands Datum 1979,geodetic,"Fundamental point: station Astro. Latitude: 43°57'23.60""S, longitude: 176°34'28.65""W (of Greenwich).",1979,7022,8901,2889,"Geodetic survey, topographic mapping, engineering survey.","Replaces Chatham Islands Datum 1971 (code 6672). Replaced by New Zealand Geodetic Datum 2000 (code 6167) from March 2000.","Office of Surveyor General (OSG) Technical Report 14, June 2001.",OGP,2008-06-24,2008.045,0,"D_Chatham_Islands_1979"
-6674,Sistema de Referencia Geocentrico para America del Sur 2000,geodetic,ITRF2000 at epoch 2000.40.,2000,7019,8901,3418,Geodetic survey.,"Realised by a frame of 184 stations observed in 2000 and adjusted in the ITRF2000. Includes ties to tide gauges. Replaces SIRGAS 1995 system for South America; expands SIRGAS to Mexico and Central America.","IBGE Brazil,  http://www1.ibge.gov.br/",OGP,2006-08-18,2005.460 2005.830 2006.465 2006.770,0,"D_SIRGAS_2000"
-6675,Guam 1963,geodetic,"Fundamental point: Tagcha. Latitude: 13°22'38.49""N, longitude: 144°45'51.56""E (of Greenwich).",1963,7008,8901,3255,Topographic mapping.,"Replaced by NAD83(HARN)","US National Geospatial Intelligence Agency (NGA). http://earth-info.nga.mil/",OGP,2008-06-24,2005.460 2008.045,0,"D_Guam_1963"
-6676,Vientiane 1982,geodetic,"Fundamental point: Vientiane (Nongteng) Astro Pillar. Latitude: 18°01'31.6301""N, longitude: 102°30'56.6999""E (of Greenwich).",1982,7024,8901,1138,Topographic mapping.,Replaced by Lao 1993.,National Geographic Department,OGP,2008-06-24,2008.045,0,"D_Vientiane_1982"
-6677,Lao 1993,geodetic,"Fundamental point: Lao 1982 coordinates of Pakxa pillar. Latitude: 18°23'57.0056""N, longitude: 103°38'41.8020""E (of Greenwich). Orientation parallel with WGS 84.",1993,7024,8901,1138,Topographic mapping.,Replaces Vientiane 1982. Replaced by Lao 1997,National Geographic Department,OGP,2008-06-24,2008.045,0,"D_Lao_1993"
-6678,Lao National Datum 1997,geodetic,"Fundamental point: Vientiane (Nongteng) Astro Pillar. Latitude: 18°01'31.3480""N, longitude: 102°30'57.1376""E (of Greenwich).",1997,7024,8901,1138,"Cadastre, topographic mapping, engineering survey.",Replaces Lao 1993.,National Geographic Department,OGP,2008-06-24,2008.045,0,"D_Lao_National_Datum_1997"
-6679,Jouik 1961,geodetic,,1961,7012,8901,2967,Hydrographic charting.,"Replaced by Mauritania 1999 (datum code 6702).",Woodside,OGP,2006-06-12,2006.440,0,"D_Jouik_1961"
-6680,Nouakchott 1965,geodetic,Nouakchott astronomical point.,1965,7012,8901,2968,Topographic survey.,"Triangulation limited to environs of Nouakchott. Extended in 1982 by satellite translocation from a single station ""Ruines"" to support Syledis chain for offshore operations. Replaced by Mauritania 1999 (datum code 6602).",IGN Paris and various industry sources.,OGP,2006-06-12,2006.440,0,"D_Nouakchott_1965"
-6681,Mauritania 1999,geodetic,,1999,7012,8901,1157,"Minerals management, topographic mapping.","A network of 36 GPS stations tied to ITRF96, 8 of which are IGN astronomic points.",Woodside,OGP,2004-10-14,,1,"D_Mauritania_1999"
-6682,Gulshan 303,geodetic,"Gulshan garden, Dhaka.",1995,7015,8901,1041,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Network of more than 140 control points observed and adjusted in 1995 by Japan International Cooperation Agency (JICA).",Survey of Bangladesh via IGN Paris and Tullow Oil.,OGP,2006-06-22,2006.470,0,"D_Gulshan_303"
-6683,Philippine Reference System 1992,geodetic,"Fundamental point: Balacan. Latitude: 13°33'41.000""N, longitude: 121°52'03.000""E (of Greenwich), geoid-ellipsoid separation 0.34m.",1992,7008,8901,1190,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Luzon 1911 datum (code 6253).","National Mapping and Resource Information Authority, Coast and Geodetic Survey Department.",OGP,2008-06-24,2008.045,0,"D_Phillipine_Reference_System_1992"
-6684,Gan 1970,geodetic,,1970,7022,8901,3274,Topographic mapping.,"In some references incorrectly named ""Gandajika 1970"". See datum code 6685.",Various industry sources.,OGP,2005-04-14,,0,"D_Gan_1970"
-6685,Gandajika,geodetic,Gandajika base.,1953,7022,8901,1259,Topographic mapping.,In some references incorrectly attributed to the Maldives. See datum code 6684.,Various industry sources.,OGP,2005-04-14,,1,
-6686,Marco Geocentrico Nacional de Referencia,geodetic,"ITRF94 at epoch 1995.4.  Bogota observatory coordinates: Latitude: 4°35'46.3215""N, longitude: 74°04'39.0285""W (of Greenwich).",2004,7019,8901,3229,Geodetic survey.,"Densification of SIRGAS 1995 within Colombia. Replaces Bogota 1975 (datum code 6218).","Instituto Geografico Agustin Codazzi (IGAC) publication ""Aspectos prácticos de la adopción del Marco Geocéntrico Nacional de Referencia MAGNA-SIRGAS como datum oficial de Colombia"". http://www.igac.gov.co/MAGNAWEB/DocumentosMAGNA.htm",OGP,2008-06-24,2006.770 2007.060 2008.045,0,"D_MAGNA"
-6687,Reseau Geodesique de la Polynesie Francaise,geodetic,"ITRF92 at epoch 1993.0. Densification by GPS of the Reference Network of French Polynesia, a coordinate set of 13 stations determined through DORIS observations.",1993,7019,8901,1098,Geodetic survey.,"Replaces Tahaa 54 (datum code 6629), IGN 63 Hiva Oa (6689), IGN 72 Nuku Hiva (6630), Maupiti 83 (6692), MHEFO 55 (6688), Moorea 87 (6691) and Tahiti 79 (6690).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie. Also www.shom.fr, technical report 002/199.",OGP,2006-08-18,2006.770,0,"D_Reseau_Geodesique_de_la_Polynesie_Francaise"
-6688,Fatu Iva 72,geodetic,"Fundamental point: Latitude: 9°25'58.00""S, longitude: 138°55'06.25""W (of Greenwich).",1972,7022,8901,3133,Hydrographic and topographic survey.,"Recomputed by IGN in 1972 using origin and observations of 1953-1955 Mission Hydrographique des Establissements Francais d'Oceanie (MHEFO 55). Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2008.045,0,"D_Fatu_Iva_1972"
-6689,IGN63 Hiva Oa,geodetic,"Fundamental point: Atuona. Latitude: 9°48'27.20""S, longitude: 139°02'15.45""W (of Greenwich).",1963,7022,8901,3130,Hydrographic and topographic survey.,"Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2008.045,0,"D_IGN63_Hiva_Oa"
-6690,Tahiti 79,geodetic,"Fundamental point: Tahiti North Base. Latitude: 17°38'10.0""S, longitude: 149°36'57.8""W (of Greenwich).",1979,7022,8901,3124,Hydrographic and topographic survey.,"Replaces Tahiti 52 (datum code 6628) in Tahiti. Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2008.045,0,"D_Tahiti_1979"
-6691,Moorea 87,geodetic,Two stations on Tahiti whose coordinates from the Tahiti 1979 adjustment were held fixed.,1987,7022,8901,3125,Hydrographic and topographic survey.,"Replaces Tahiti 52 (datum code 6628) in Moorea. Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2005-08-12,,0,"D_Moorea_1987"
-6692,Maupiti 83,geodetic,"Fundamental point: Pitiahe South Base. Latitude: 16°28'28.942""S, longitude: 152°14'55.059""W (of Greenwich).",1983,7022,8901,3126,Hydrographic and topographic survey.,"Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service  de l'Urbanisme, Section topographie.",OGP,2008-06-24,2008.045,0,"D_Maupiti_1983"
-6693,Nakhl-e Ghanem,geodetic,"Coordinates of two stations determined with respect to ITRF 2000 at epoch 2005.2: BMT1 latitude 27°42'09.8417""N, longitude 52°12'11.0362""E (of Greenwich); Total1 latitude 27°31'03.8896""N, longitude 52°36'13.1312""E (of Greenwich).",2005,7030,8901,2362,Engineering survey for onshore facilities for South Pars phase 11 and Pars LNG.,,Total,OGP,2008-06-24,2006.770 2008.045,0,"D_Nakhl-e_Ghanem"
-6694,Posiciones Geodesicas Argentinas 1994,geodetic,"A geodetic network of 127 high accuracy surveyed points based on WGS 84 that define the National Geodetic System (Sistema Geodésico Nacional).",1994,7030,8901,1033,"Topographic mapping, geodetic survey.","Una red geodésica de 127 puntos materializados¶en el terreno que definen el Sistema Geodésico Nacional. ¶Technically, but at this record revision date not legally, replaced by POSGAR 98 (code 6190).","Instituto Geográfico Militar de la República Argentina, http://www.igm.gov.ar",OGP,2008-06-23,2008.052,0,"D_POSGAR_1994"
-6695,Katanga 1955,geodetic,"Fundamental point: Tshinsenda A. Latitude: 12°30'31.568""S, longitude: 28°01'02.971""E (of Greenwich).",1955,7008,8901,3147,"Cadastre, topographic mapping, engineering survey.",Replaces earlier adjustments.,"Clifford J. Mugnier, in Photogrammetric Engineering and Remote Sensing, June 2005.",OGP,2009-05-21,2008.045 2009.011,0,"D_Katanga_1955"
-6696,Kasai 1953,geodetic,"Two stations of the Katanga triangulation with ellipsoid change applied: Kabila, latitude 6°58'34.023""S, longitude 23°50'24.028""E (of Greenwich); and Gandajika NW base, latitude 6°45'01.057""S, longitude 23°57'03.038""E (of Greenwich).",1955,7012,8901,3148,"Cadastre, topographic mapping, engineering survey.",Replaced by IGC 1962 Arc of the 6th Parallel South.,Institute Geographique du Congo,OGP,2008-06-24,2008.045,0,"D_Kasai_1955"
-6697,IGC 1962 Arc of the 6th Parallel South,geodetic,"Coordinates of 3 stations determined with respect to Arc 1950: Mulungu 4°47'39.2325""S, 29°59'37.5864""E; Nyakawembe 4°14'57.3618""S, 29°42'52.8032""E; Kavula 4°35'15.8634""S, 29°41'14.2693""E (all longitude w.r.t. Greenwich).",1962,7012,8901,3149,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Institute Geographique du Congo,OGP,2008-06-24,2006.721 2008.045,0,"D_IGC_1962_Arc_of_the_6th_Parallel_South"
-6698,IGN 1962 Kerguelen,geodetic,K0 1949.,1949,7022,8901,2816,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2005-11-23,,0,"D_Kerguelen_Island_1949"
-6699,Le Pouce 1934,geodetic,"Fundamental point: Le Pouce. Latitude: 20°11'42.25""S, longitude: 57°31'18.58""E (of Greenwich).",1934,7012,8901,3209,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Cartography Section, Ministry of Housing and Land.",OGP,2008-06-24,2008.045,0,"D_Le_Pouce_1934"
-6700,IGN Astro 1960,geodetic,Realised through a set of independent astronomically-positioned points.,1960,7012,8901,1157,Small scale topographic mapping.,"Observed during 1959-1960. Independent points not connected through a network. Relative accuracy estimated at 50-100m. Replaced by Mauritania 1999 (datum code 6702).","Ministry of Works and Transport, Topography and Cartography Directive.",OGP,2006-06-12,2006.440,0,"D_IGN_Astro_1960"
-6701,Institut Geographique du Congo Belge 1955,geodetic,"Fundamental point: Yella east base. Latitude: 6°00'53.139""S, longitude: 12°58'29.287""E (of Greenwich).",1955,7012,8901,3171,"Cadastre, topographic mapping, engineering survey.","Replaced by IGC 1962 Arc of the 6th Parallel South, except for oil industry activities.",Institut Geographique du Congo Belge.,OGP,2008-06-24,2008.045,0,"D_Institut_Geographique_du_Congo_Belge_1955"
-6702,Mauritania 1999,geodetic,ITRF96 at epoch 1997.0,1999,7019,8901,1157,Geodesy.,"A network of 36 GPS stations tied to ITRF96, 8 of which are IGN 1962 astronomic points.","Ministry of Works and Transport, Topography and Cartography Directive.",OGP,2006-08-18,2006.770,0,"D_Mauritania_1999"
-6703,Missao Hidrografico Angola y Sao Tome 1951,geodetic,Extension of Camacupa datum into Cabinda.,1951,7012,8901,1318,Coastal hydrography.,"A variation of this datum has been adopted by the oil industry but incorrectly using the International 1924 ellipsoid and not tied to the official Portuguese triangulation - see Mhast (onshore) and Mhast (offshore) (codes 6704 and 6705).",Various industry sources.,OGP,2006-01-03,,0,"D_Mhast_1951"
-6704,"Mhast (onshore)",geodetic,Probably adopted a Mhast 1951 coordinate set but associated an incorrect ellipsoid with it.,,7022,8901,3179,"Oil industry exploration and production. From 1979, offshore use superseded by Mhast (offshore) (code 6705).","Adopted by oil industry with intention of being Mhast 1951 (code 6703) but incorrectly (for Mhast 1951) used the International 1924 ellipsoid. This datum differs by about 400 metres from the Portuguese Mhast 1951 and Camacupa datums.",ChevronTexaco.,OGP,2006-01-03,,0,"D_Mhast_Onshore"
-6705,"Mhast (offshore)",geodetic,"Fundamental point: Station Y at Malongo base camp. Latitude: 5°23'30.810""S, longitude: 12°12'01.590""E (of Greenwich).",1979,7022,8901,3180,Oil industry offshore exploration and production between 1979 and 1987.,"Origin coordinates determined by Transit single point position using 32 passes and transformed from WGS72BE using transformation code 15790. Differs from Mhast (onshore) by approximately 10m. Replaced in 1987 by Malongo 1987 (code 6259).",ChevronTexaco.,OGP,2008-06-24,2008.045,0,"D_Mhast_Offshore"
-6706,Egypt Gulf of Suez S-650 TL,geodetic,"Fundamental point: Station S-650 DMX. Adopted coordinates: latitude: 28°19'02.1907""N, longitude: 33°06'36.6344""E (of Greenwich). The proper Egypt 1907 coordinates for S-650 differ from these by about 20m.",1980,7020,8901,2341,Oil industry offshore exploration and production in Gulf of Suez after 1980.,"A coherent set of stations bordering the Gulf of Suez coordinated by Transit translocation (""TL"") between 1980 and 1984. Based on incorrect Egypt 1907 values for origin station S-650. Differs from true Egypt 1907 by approximately 20m.",Various industry sources.,OGP,2008-06-24,2008.045,0,"D_Egypt_Gulf_of_Suez_S-650_TL"
-6707,Tern Island 1961,geodetic,"Fundamental point: station FRIG on tern island, station B4 on Sorol Atoll.",1961,7022,8901,3181,Military and topographic mapping,"Two independent astronomic determinations considered to be consistent through adoption of common transformation to WGS 84 (see tfm code 15795).","DMA / NIMA / NGA TR8350.2 (original 1987 first edition and 3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Tern_Island_1961"
-6708,Cocos Islands 1965,geodetic,"Fundamental point: Anna 1.",1965,7003,8901,1069,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6709,Iwo Jima 1945,geodetic,"Fundamental point: Beacon ""E"".",1945,7022,8901,3200,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6710,St. Helena 1971,geodetic,"Fundamental point: DOS 71/4.",1971,7022,8901,3183,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6711,Marcus Island 1952,geodetic,Marcus Island Astronomic Station.,1952,7022,8901,3203,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6712,Ascension Island 1958,geodetic,,1958,7022,8901,3182,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Ascension_Island_1958"
-6713,Ayabelle Lighthouse,geodetic,"Fundamental point: Ayabelle Lighthouse.",,7012,8901,1081,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Ayabelle"
-6714,Bellevue,geodetic,,1960,7022,8901,3193,Military and topographic mapping,"Datum covers all the major islands of Vanuatu in two different adjustment blocks, but practical usage is as given in the area of use.","DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-07-29,2006.510,0,"D_Bellevue_IGN"
-6715,Camp Area Astro,geodetic,,,7022,8901,3205,Geodetic and topographic survey,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Camp_Area"
-6716,Phoenix Islands 1966,geodetic,,1966,7022,8901,3196,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6717,Cape Canaveral,geodetic,"Fundamental point: Central 1950.  Latitude: 28°29'32.36555""N, longitude 80°34'38.77362""W (of Greenwich)",1963,7008,8901,3206,US space and military operations.,,"US NGS and DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2008-06-24,2006.870 2008.045,0,"D_Cape_Canaveral"
-6718,Solomon 1968,geodetic,"Fundamental point: GUX 1.",1968,7022,8901,1213,"Military and topographic mapping, +/- 25 meters in each component",,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Solomon_1968"
-6719,Easter Island 1967,geodetic,,1967,7022,8901,3188,"Military and topographic mapping, +/- 25 meters in each component",,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Easter_Island_1967"
-6720,Fiji Geodetic Datum 1986,geodetic,NWL 9D coordinates of 6 stations on Vitu Levu and Vanua Levu.,1986,7043,8901,1094,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Viti Levu 1912, Vanua Levu 1915 and Fiji 1956.","Survey Review 30,231 (January 1989).",OGP,2006-07-19,2006.500,0,"D_Fiji_1986"
-6721,Fiji 1956,geodetic,"Latitude origin was obtained astronomically at station Rasusuva = 17°49'03.13""S,  longitude origin was obtained astronomically at station Suva = 178°25'35.835""E (of Greenwich).",1956,7022,8901,3398,Military and topographic mapping,For topographic mapping replaces Viti Levu 1912 and Vanua Levu 1915. Replaced by Fiji Geodetic Datum 1986.,"SOPAC, www.sopac.org, and Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2008-06-24,2006.500 2008.045,0,"D_Fiji_1956"
-6722,South Georgia 1968,geodetic,"Fundamental point: ISTS 061.",1968,7022,8901,3187,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6723,Grand Cayman 1959,geodetic,"Fundamental point: GC1. Latitude: 19°17'54.43""N, longitude: 81°22'37.17""W (of Greenwich).",1959,7008,8901,3185,Topographic mapping,,"Clifford J. Mugnier; in Photogrammetric Engineering & Remote Sensing November 1998. http://www.asprs.org/",OGP,2008-06-24,2008.045,0,"D_Grand_Cayman_1959"
-6724,Diego Garcia 1969,geodetic,"Fundamental point: ISTS 073.",1969,7022,8901,3189,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6725,Johnston Island 1961,geodetic,,1961,7022,8901,3201,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Johnston_Island_1961"
-6726,Little Cayman 1961,geodetic,"Fundamental point: LC5. Latitude: 19°39'46.324""N, longitude: 81°03'47.910""W (of Greenwich).",1961,7008,8901,3186,Military and topographic mapping.,,"Clifford J. Mugnier; in Photogrammetric Engineering & Remote Sensing November 1998. http://www.asprs.org/",OGP,2008-06-24,2008.045,0,"D_Little_Cayman_1961"
-6727,Midway 1961,geodetic,,1961,7022,8901,3202,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Midway_1961"
-6728,Pico de las Nieves 1984,geodetic,,,7022,8901,3199,Military and topographic mapping,"Replaces Pico de las Nieves 1968 (PN68). Replaced by REGCAN95.","DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2009-05-21,2009.033,0,"D_Pico_de_Las_Nieves"
-6729,Pitcairn 1967,geodetic,"Fundamental point: Pitcairn Astro. Latitude: 25°04'06.87""S, longitude: 130°06'47.83""W (of Greenwich).",1967,7022,8901,3208,Military and topographic mapping,Replaced by Pitcairn 2006.,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2008-06-24,2008.004 2008.045,0,"D_Pitcairn_1967"
-6730,Santo 1965,geodetic,,1965,7022,8901,3194,Military and topographic mapping,"Datum covers all the major islands of Vanuatu in two different adjustment blocks, but practical usage is as given in the area of use.","DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-07-29,2006.510,0,"D_Santo_DOS_1965"
-6731,Viti Levu 1916,geodetic,,1916,7012,8901,3195,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,1,"D_Viti_Levu_1916"
-6732,Marshall Islands 1960,geodetic,,1960,7053,8901,3191,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
-6733,Wake Island 1952,geodetic,,1952,7022,8901,3190,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Wake_Island_1952"
-6734,Tristan 1968,geodetic,,1968,7022,8901,3184,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Tristan_1968"
-6735,Kusaie 1951,geodetic,,1951,7022,8901,3192,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Kusaie_1951"
-6736,Deception Island,geodetic,,,7012,8901,3204,Military and scientific mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Deception_Island"
-6737,Geocentric datum of Korea,geodetic,ITRF2000 at epoch 2002.0.,2002,7019,8901,1135,Geodetic survey.,,"Permanent Committee for GIS Infrastructure for Asia and the Pacific (PCGIAP), http://www.gsi.go.jp/PCGIAP",OGP,2006-08-18,2006.770,0,"D_Korea_2000"
-6738,Hong Kong 1963,geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22°18'12.82""N, longitude 114°10'18.75""E (of Greenwich).",1963,7007,8901,1118,Topographic mapping and hydrographic charting.,"Replaced by Hong Kong 1963(67) for military purposes only in 1967.  Replaced by Hong Kong 1980.","Survey and Mapping Office, Lands Department. http://www.info.gov.hk/landsd/",OGP,2008-06-24,2008.045,0,"D_Hong_Kong_1963"
-6739,"Hong Kong 1963(67)",geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22°18'12.82""N, longitude 114°10'18.75""E (of Greenwich).",1967,7022,8901,1118,Military mapping and charting.,Replaces Hong Kong 1963 for military purposes only in 1967.  Replaced by Hong Kong 1980.,UK Hydrographic Office.,OGP,2008-06-24,2008.045,0,"D_Hong_Kong_1963_67"
-6740,Parametrop Zemp 1990,geodetic,Geocentre.,1990,7054,8901,1262,Geodetic survey.,Derived through satellite tracking techniques.,"Geodeziya i Katografiya, 1993.",OGP,2006-02-03,,0,"D_Parametrop_Zemp_1990"
-6741,Faroe Datum 1954,geodetic,Astronomical observations at 3 points.,1954,7022,8901,3248,"Geodetic survey, topographic mapping, engineering and cadastral survey.","Replaced by ED50 in late 1970's for all purposes other than cadastre. Replaced by fk89 for cadastre.","Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-04,2005.472,0,"D_Faroe_Datum_1954"
-6742,Geodetic Datum of Malaysia 2000,geodetic,"ITRF2000, epoch 2000.0.",2000,7019,8901,1151,"Geodetic survey, topographic mapping, engineering and cadastrral survey.",Replaces all older Malaysian datums.,"GDM2000 Technical Manual; Department of Survey and Mapping Malaysia. www.jupem.gov.my",OGP,2006-03-16,,0,"D_GDM_2000"
-6743,Karbala 1979,geodetic,"Fundamental point: Karbala. Latitude: 32°34'14.4941""N, longitude: 44°00'49.6379""E.",1979,7012,8901,1124,Geodetic survey.,National geodetic network established by Polservice consortium.,Various industry sources.,OGP,2009-05-21,2009.003,0,"D_Karbala_1979_Polservice"
-6744,Nahrwan 1934,geodetic,"Fundamental point: Nahrwan south base.  Latitude: 33°19'10.87""N, longitude: 44°43'25.54""E (of Greenwich).",1934,7012,8901,3390,Oil exploration and production.,"This adjustment later discovered to have a significant orientation error. In Iran replaced by FD58. In Iraq, replaced by Nahrwan 1967.",Various industry sources.,OGP,2008-06-24,2008.045,0,"D_Nahrwan_1934"
-6745,"Rauenberg Datum/83",geodetic,"Fundamental point: Rauenberg. Latitude: 52°27'12.021""N, longitude: 13°22'04.928""E (of Greenwich). This station was destroyed in 1910 and the station at Potsdam substituted as the fundamental point.",1990,7004,8901,2545,"Geodetic survey, cadastre, topographic mapping, engineering survey.","RD/83 is the realisation of DHDN in Saxony. It is the resultant of applying a transformation derived at 106 points throughout former East Germany to Pulkovo 1942/83 points in Saxony.","BKG via EuroGeographics. http://crs.bkg.bund.de",OGP,2008-06-24,2008.045,0,
-6746,"Potsdam Datum/83",geodetic,"Fundamental point: Rauenberg. Latitude: 52°27'12.021""N, longitude: 13°22'04.928""E (of Greenwich). This station was destroyed in 1910 and the station at Potsdam substituted as the fundamental point.",1990,7004,8901,2544,"Geodetic survey, cadastre, topographic mapping, engineering survey.","PD/83 is the realisation of DHDN in Thuringen. It is the resultant of applying a transformation derived at 13 points on the border between East and West Germany to Pulkovo 1942/83 points in Thuringen.","BKG via EuroGeographics. http://crs.bkg.bund.de",OGP,2008-06-24,2008.045,0,
-6747,Greenland 1996,geodetic,ITRF94 at epoch 1996.62,1996,7019,8901,1107,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Ammassalik 1958, Qornoq 1927 and Scoresbysund 1952.","Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-18,2006.770,0,"D_Greenland_1996"
-6748,Vanua Levu 1915,geodetic,"Latitude origin was obtained astronomically at station Numuiloa = 16°23'38.36""S, longitude origin was obtained astronomically at station Suva = 178°25'35.835""E.",1915,7055,8901,3401,"Geodetic survey, cadastre, topographic mapping, engineering survey.","For topographic mapping, replaced by Fiji 1956. For other purposes, replaced by Fiji 1986.","Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2008-06-24,2008.045,0,"D_Vanua_Levu_1915"
-6749,Reseau Geodesique de Nouvelle Caledonie 91-93,geodetic,ITRF90 at epoch 1989.0.,1989,7019,8901,1174,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-08-18,2006.770,0,
-6750,ST87 Ouvea,geodetic,Ouloup.,1987,7030,8901,2813,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,,0,
-6751,"Kertau (RSO)",geodetic,,1969,7056,8901,1309,Metrication of RSO grid.,Adopts metric conversion of 0.914398 metres per yard exactly. This is a truncation of the Sears 1922 ratio.,Defence Geographic Centre.,OGP,2006-07-24,,0,
-6752,Viti Levu 1912,geodetic,"Latitude origin was obtained astronomically at station Monavatu = 17°53'28.285""S, longitude origin was obtained astronomically at station Suva = 178°25'35.835""E.",1912,7055,8901,3195,"Geodetic survey, cadastre, topographic mapping, engineering survey.","For topographic mapping, replaced by Fiji 1956. For other purposes, replaced by Fiji 1986.","Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2008-06-24,2008.045,0,
-6753,fk89,geodetic,,1989,7022,8901,3248,Cadastre,Replaces FD54 for cadastre.,"Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-04,,0,"D_fk89"
-6754,Libyan Geodetic Datum 2006,geodetic,5 stations tied to ITRF2000 through 8 days of continuous observations in May 2006.,2006,7022,8901,1143,"Geodetic survey, topographic mapping, engineering survey.",Replaces ELD79.,Survey Department of Libya.,OGP,2006-08-25,,0,"D_Libyan_Geodetic_Datum_2006"
-6755,Datum Geodesi Nasional 1995,geodetic,ITRF91at epoch 1992.0.,1995,7030,8901,1122,"Geodetic survey, topographic mapping, engineering survey.",Replaces ID74 and all older datums.,Bakosurtanal.,OGP,2006-08-25,,0,"D_Datum_Geodesi_Nasional_1995"
-6756,Vietnam 2000,geodetic,"Point N00, located in the premises of the Land Administration Research Institute, Hoang Quoc Viet Street, Hanoi.",2000,7030,8901,1252,"Geodetic survey, topographic mapping, engineering survey.",Replaces Hanoi 1972.,General Director of Land Administration.,OGP,2006-09-13,,0,"D_Vietnam_2000"
-6757,SVY21,geodetic,"Fundamental point: Base 7 at Pierce Resevoir. Latitude: 1°22'02.9154""N, longitude: 103°49'31.9752""E (of Greenwich).",2004,7030,8901,1210,Cadastre.,Replaces Kertau 1968 for cadastral purposes from August 2004.,Singapore Land Authority,OGP,2008-06-24,2008.045,0,"D_SVY21"
-6758,Jamaica 2001,geodetic,Aligned to WGS 84.,2001,7030,8901,1128,"Geodetic survey, cadastre, topographic mapping, hydrographic charting, engineering survey.",,National Land Agency.,OGP,2007-01-19,,0,"D_Jamaica_2001"
-6759,"NAD83 (National Spatial Reference System 2007)",geodetic,"Coordinates of 486 national continually operating reference system (CORS) and 195 collaborative GPS (CGPS) sites constrained to their CORS96 values, ITRF2000 at epoch 2002.0.",2007,7019,8901,1511,Geodetic survey.,,"U.S. National Geodetic Survey, http://www.ngs.noaa.gov/",OGP,2007-03-13,,0,
-6760,World Geodetic System 1966,geodetic,Developed from a worldwide distribution of terrestrial and geodetic satellite observations and defined through a set of station coordinates.,1966,7025,8901,1262,Geodesy.,"A worldwide 5° × 5° mean free air gravity anomaly field provided the basic data for producing the WGS 66 gravimetric geoid. Replaced by WGS 72.","US DMA/NIMA/NGA",OGP,2007-03-25,,0,
-6761,Croatian Terrestrial Reference System,geodetic,Densification of ETRS89 in Croatia at epoch 1995.55.,1996,7019,8901,1076,Geodesy.,Based on 78 control points with coordinates determined in ETRS89.,State Geodetic Administration of the Republic of Croatia.,OGP,2007-09-25,,0,
-6762,Bermuda 2000,geodetic,ITRF96 at epoch 2000.0.,2000,7030,8901,1047,"Topographic mapping, cadastral and engineering survey.",,Department of Lands Buildings and Surveys,OGP,2007-12-12,,0,
-6763,Pitcairn 2006,geodetic,"Fundamental point: Pitcairn Astro. Latitude: 25°04'06.7894""S, longitude: 130°06'46.6816""W (of Greenwich), derived by single point GPS oberservations.",2006,7030,8901,3208,"Cadastre, topographic mapping and engineering survey",Replaces Pitcairn 1967.,Pitcairn Island Government.,OGP,2008-06-24,2008.045,0,
-6764,Ross Sea Region Geodetic Datum 2000,geodetic,Based on ITRF96 at epoch 2000.0,2000,7019,8901,3558,"Geodetic survey, topographic mapping.",,"Land Information New Zealand: LINZS25001 Standard for Ross Sea Region Geodetic Datum 2000; 16 November 2007.",OGP,2008-04-04,,0,
-6765,Slovenia Geodetic Datum 1996,geodetic,"Densification of ETRS89, based on ITRS89 at epoch 1995.55.",1996,7019,8901,1212,"Geodetic survey, topographic mapping.",,Surveying and Mapping Authority of Slovenia,OGP,2008-04-04,,0,
-6801,"CH1903 (Bern)",geodetic,"Fundamental point: Old Bern observatory. Latitude: 46°57'08.660""N, longitude: 0°E (of Bern).",1903,7004,8907,1286,Topographic mapping.,,"Bundesamt für Landestopographie",OGP,2008-06-24,2003.361 2008.045,0,"D_Bern_1898"
-6802,"Bogota 1975 (Bogota)",geodetic,"Fundamental point: Bogota observatory. Latitude: 4°35'56.570""N, longitude: 0°E (of Bogota).",1975,7022,8904,3229,Topographic mapping.,,,OGP,2008-06-24,2000.200 2003.361 2008.045,0,"D_Bogota"
-6803,"Lisbon 1937 (Lisbon)",geodetic,"Fundamental point: Castelo Sao Jorge, Lisbon. Latitude: 38°42'43.631""N, longitude: 0°E (of Lisbon).",1937,7022,8902,1294,Topographic mapping.,"Replaces Lisbon 1890 adjustment (which used Bessel 1841 ellipsoid).","Instituto Geografico e Cadastral; Lisbon",OGP,2008-06-24,2001.551 2008.045,0,"D_Lisbon"
-6804,"Makassar (Jakarta)",geodetic,"Fundamental point: station P1, Moncongloe. Latitude 5°08'41.42""S, longitude 12°35'47.15""E (of Jakarta).",,7004,8908,1316,Topographic mapping.,,OGP,OGP,2008-06-24,2003.361 2008.045,0,"D_Makassar"
-6805,"Militar-Geographische Institut (Ferro)",geodetic,"Fundamental point: Hermannskogel. Latitude: 48°16'15.29""N, longitude: 33°57'41.06""E (of Ferro).",1901,7004,8909,1321,Geodetic survey.,Replaced by MGI in Austria and MGI 1901 in former Yugoslavia.,"Bundesamt fur Eich- und Vermessungswesen; Wien",OGP,2009-05-21,2008.045 2009.015,0,"D_MGI"
-6806,"Monte Mario (Rome)",geodetic,"Fundamental point: Monte Mario. Latitude: 41°55'25.51""N, longitude: 0°00' 00.00""E (of Rome).",,7022,8906,3343,Topographic mapping.,"Replaced Genova datum, Bessel 1841 ellipsoid, from 1940.",,OGP,2008-06-24,2003.360 2008.045,0,"D_Monte_Mario"
-6807,"Nouvelle Triangulation Francaise (Paris)",geodetic,"Fundamental point: Pantheon. Latitude: 54.273618g N, longitude: 0.0106921g E (of Paris).",1895,7011,8903,1326,Topographic mapping.,,,OGP,2004-01-07,2003.361,0,"D_NTF"
-6808,"Padang 1884 (Jakarta)",geodetic,"Fundamental point: Padang",1884,7004,8908,1355,Topographic mapping.,,,OGP,1995-06-02,,0,"D_Padang_1884"
-6809,"Reseau National Belge 1950 (Brussels)",geodetic,"Fundamental point: Lommel (tower). Latitude: 51°13'47.334""N, longitude: 0°56'44.773""E (of Brussels).",1950,7022,8910,1347,Topographic mapping.,,,OGP,2008-06-24,2008.045,0,"D_Belge_1950"
-6810,"Tananarive 1925 (Paris)",geodetic,"Fundamental point: Tananarive observatory. Latitude: 21.0191667g S, longitude: 50.23849537g E (of Paris)",1925,7022,8903,3273,Topographic mapping.,,IGN Paris,OGP,2003-12-31,2003.361,0,"D_Tananarive_1925"
-6811,"Voirol 1875 (Paris)",geodetic,"Fundamental point: Voirol. Latitude: 40.83578 grads N, longitude: 0.78873 grads E (of Paris).",1875,7011,8903,1365,Topographic mapping.,,IGN Paris,OGP,2004-01-07,2003.361,0,"D_Voirol_1875"
-6813,"Batavia (Jakarta)",geodetic,"Fundamental point: Longitude at Batavia astronomical station. Latitude: 6°07'39.522""S, longitude: 0°00'00.0""E (of Jakarta). Latitude and azimuth at Genuk.",,7004,8908,1285,Topographic mapping.,,,OGP,2008-06-24,2003.361 2008.045,0,"D_Batavia"
-6814,"Stockholm 1938 (Stockholm)",geodetic,"Fundamental point: Stockholm observatory",1938,7004,8911,3313,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RT90 adjustment (datum code 6124)",,OGP,1996-04-12,,0,"D_Stockholm_1938"
-6815,"Greek (Athens)",geodetic,"Fundamental point: Athens Observatory. Latitude 37°58'20.132""N, longitude 0°E (of Athens).",,7004,8912,1106,Topographic mapping.,See geodetic datum alias 6404.  Used as basis of topographic mapping based on Hatt projection.,"Topography Department; National Technical University of Athens",OGP,2008-06-24,2008.045,0,"D_Greek"
-6816,"Carthage (Paris)",geodetic,"Fundamental point: Carthage. Latitude: 40.9464506g N, longitude: 8.8724368g E (of Paris).",1925,7011,8903,1618,Topographic mapping.,Fundamental point astronomic coordinates determined in 1878.,,OGP,2004-01-15,2003.362 2003.050,0,"D_Carthage"
-6817,"NGO 1948 (Oslo)",geodetic,"Fundamental point: Oslo observatory. Latitude: 59°54'43.7""N, longitude: 0°00'00.0""E (of Oslo).",1948,7005,8913,1352,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,,OGP,2008-06-24,2003.362 2008.045,0,"D_NGO_1948"
-6818,"S-JTSK (Ferro)",geodetic,"Modification of Austrian MGI (Ferro) datum.",1920,7004,8909,1306,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Research Institute for Geodesy Topography and Cartography (VUGTK); Prague.",OGP,2001-08-28,2001.260,0,"D_S_JTSK"
-6819,"Nord Sahara 1959 (Paris)",geodetic,"Coordinates of primary network readjusted on ED50 datum and then transformed conformally to Clarke 1880 (RGS) ellipsoid.",1959,7012,8903,1366,Topographic mapping.,,"""Le System Geodesique Nord-Sahara""; IGN Paris",OGP,2000-06-23,,1,"D_Nord_Sahara_1959"
-6820,"Gunung Segara (Jakarta)",geodetic,"Station P5 (Gunung Segara) 0°32'12.83""S, 117°08'48.47""E (of Greenwich). Longitude 8°20'20.68""E (of Jakarta).",,7004,8908,1360,Topographic mapping.,,,OGP,2008-06-24,2008.045,0,"D_Gunung_Segara"
-6821,"Voirol 1879 (Paris)",geodetic,"Fundamental point: Voirol. Latitude: 40.835864 grads N, longitude: 0.788735 grads E (of Paris).",1879,7011,8903,1365,Topographic mapping.,"Replaces Voirol 1875 (Paris) (code 6811).",IGN Paris,OGP,2004-01-07,,0,"D_Voirol_1879"
-6896,International Terrestrial Reference Frame 2005,geodetic,"Origin at geocentre, originally orientated to the BIH Terrestrial System at epoch 1984.0 then adjusted to ensure zero net rotation to earth's overall tectonic motion. Defined by time series of Cartesian station coordinates and Earth Rotation parameters.",2005,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 2005.0. Replaces ITRF2000 (code 6656).","IGN Paris http://itrf.ensg.ign.fr/itrs_itrf.php",OGP,2007-01-19,,0,
-6901,"Ancienne Triangulation Francaise (Paris)",geodetic,,,7027,8914,1326,Topographic mapping.,"Uses the RGS value for the Paris meridian.  In Alsace, data suspected to be transformation of German network into ATF. Replaced by Nouvelle Triangulation Francaise (Paris) (code 6807) which uses the 1936 IGN value for the Paris meridian.",,OGP,2007-11-01,2007.083,0,"D_ATF"
-6902,"Nord de Guerre (Paris)",geodetic,,,7027,8903,1369,Topographic mapping.,,,OGP,1995-06-02,,1,"D_Nord_de_Guerre"
-6903,"Madrid 1870 (Madrid)",geodetic,"Fundamental point: Madrid observatory.",1870,7028,8905,2366,Topographic mapping.,,"Institut de Geomatica; Barcelona",OGP,1998-11-11,,0,"D_Madrid_1870"
-6904,"Lisbon 1890 (Lisbon)",geodetic,"Fundamental point: Castelo Sao Jorge, Lisbon. Latitude: 38°42'43.631""N, longitude: 0°E (of Lisbon).",1937,7004,8902,1294,Topographic mapping.,"Replaced by Lisbon 1937 adjustment (which uses International 1924 ellipsoid).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",OGP,2008-06-24,2003.232 2008.045,0,"D_Lisbon_1890"
-9300,Astra Minas,engineering,"Origin at 45°59'54.79""S, 67°34'38.94""W (of Greenwich).",,,,1265,Oil industry mapping.,,,OGP,2008-06-24,2008.045,0,
-9301,Barcelona,engineering,"Centre of the gateway of San Cristobal chuch; Plaza Boyaca; Barcelona.",,,,1266,Oil industry mapping.,"Coordinates variously given as 10°08'06""N  64°41'17""W and 10°08'06""N  64°41'07.5""W.  It is not clear whether there should be two local datums.","Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9302,Maturin,engineering,"Concrete post PR-1 in Plaza Bolivar; Maturin.  9°44'55""N, 63°10'40""W (of Greenwich).",,,,1320,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9303,Maracaibo Cross,engineering,"Cruz Canada Morillo in Maracaibo; 10°38'32.328""N, 71°37'12.12""W  Loma Quintana datum.",,,,1319,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9304,La Rosa,engineering,"Monument in La Rosa; 10°22'40.417""N, 71°26'59.488""W  Loma Quintana datum.",,,,1311,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9305,Mene Grande,engineering,"Monument in Santa Barbara; Mene Grande.  9°52'25.488""N, 70°54'35.310""W (of Greenwich).",,,,1270,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9306,El Cubo,engineering,"8°44'17.258""N, 72°30'09.01""W (of Greenwich).",,,,1269,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9307,Dabajuro,engineering,"Church tower at Dabajuro; 11°01'19""N, 70°40'40""W (of Greenwich).",,,,1268,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9308,Tucupita,engineering,"Centre of Plaza Bolivar; Tucupita; 9°03'32""N, 62°03'07.6""W (of Greenwich).",,,,1370,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9309,El Mene,engineering,"10°04'49.1""N, 71°02'10""W (of Greenwich).",,,,1270,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9310,Santa Maria de Ipire,engineering,"Concrete post PR-1 in Plaza Bolivar; Santa Maria de Ipire; 8°40'06""N, 65°19'09""W (of Greenwich).",,,,1371,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2008-06-24,2008.045,0,
-9311,Barinas west base,engineering,Concrete pillar.,,,,1267,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",OGP,2000-06-10,,0,
-9312,EPSG example  X,engineering,"Bin grid I=J=1 at WGS 84 / UTM zone 31N 456781E 5836723N.",,,,1263,Example only.,"Example only!","Bin grid orientation = 20 degrees grid.  Bin width I=25m, J=12.5m.  Bin increment I=1, J=1.  Scale factor at origin 0.99984.¶¶Example only!",OGP,2000-06-23,,1,
-9313,EPSG example Platform Y,engineering,Conductor slot A1.,,,,1263,Example only.,Example only,OGP,OGP,2000-06-23,,0,
-9314,Tombak LNG plant,engineering,"Plant grid coordinates of x=20000m, y=10000m at Nakhl-e Ghanem / UTM zone 39 coordinates 618336.784E, 3067774.21N. Plant grid x orientated at UTM grid bearing of 45 deg., plant grid y orientated at UTM grid bearing of 315 deg.",,,,2362,Engineering survey.,,Total,OGP,2005-08-18,,0,
-9315,UKOOA P6 seismic bin grid example,engineering,"Centre of bin grid I=J=1.",,,,1263,Example only.,,"UKOOA Data Exchange Format P6/98 ""Definition of 3D Seismic Binning Grids"".",OGP,2005-09-08,,0,
Deleted: grass/trunk/lib/proj/gt_datum.csv
--- grass/trunk/lib/proj/gt_datum.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/gt_datum.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,229 +0,0 @@
-CODE,NAME,ELLIPSOID,DELTAX,SIGMAX,DELTAY,SIGMAY,DELTAZ,SIGMAZ,NORTH,SOUTH,WEST,EAST,ROTX,ROTY,ROTZ,SCALE
-ADI-M,"ADINDAN, Mean",CD,-166,5,-15,5,204,3,-5,31,15,55
-ADI-A,"ADINDAN, Ethiopia",CD,-165,3,-11,3,206,3,-3,25,26,50
-ADI-B,"ADINDAN, Sudan",CD,-161,3,-14,5,205,3,-3,31,15,45
-ADI-C,"ADINDAN, Mali",CD,-123,25,-20,25,220,25,3,31,-20,11
-ADI-D,"ADINDAN, Senegal",CD,-128,25,-18,25,224,25,5,23,-24,-5
-ADI-E,"ADINDAN, Burkina Faso",CD,-118,25,-14,25,218,25,4,22,-12,8
-ADI-F,"ADINDAN, Cameroon",CD,-134,25,-2,25,210,25,-4,19,3,23
-AFG,"AFGOOYE, Somalia",KA,-43,25,-163,25,45,25,-8,19,35,60
-AIA,"ANTIGUA ISLAND ASTRO 1943",CD,-270,25,13,25,62,25,16,20,-65,-61
-AIN-A,"AIN EL ABD 1970, Bahrain",IN,-150,25,-250,25,-1,25,24,28,49,53
-AIN-B,"AIN EL ABD 1970, Saudi Arabia",IN,-143,10,-236,10,7,10,8,38,28,62
-AMA,"AMERICAN SAMOA 1962",CC,-115,25,118,25,426,25,-19,-9,-174,-165
-ANO,"ANNA 1 ASTRO 1965, Cocos Is.",AN,-491,25,-22,25,435,25,-14,-10,94,99
-ARF-M,"ARC 1950, Mean",CD,-143,20,-90,33,-294,20,-36,10,4,42
-ARF-A,"ARC 1950, Botswana",CD,-138,3,-105,5,-289,3,-33,-13,13,36
-ARF-B,"ARC 1950, Lesotho",CD,-125,3,-108,3,-295,8,-36,-23,21,35
-ARF-C,"ARC 1950, Malawi",CD,-161,9,-73,24,-317,8,-21,-3,26,42
-ARF-D,"ARC 1950, Swaziland",CD,-134,15,-105,15,-295,15,-33,-20,25,40
-ARF-E,"ARC 1950, Zaire",CD,-169,25,-19,25,-278,25,-21,10,4,38
-ARF-F,"ARC 1950, Zambia",CD,-147,21,-74,21,-283,27,-24,-1,15,40
-ARF-G,"ARC 1950, Zimbabwe",CD,-142,5,-96,8,-293,11,-29,-9,19,39
-ARF-H,"ARC 1950, Burundi",CD,-153,20,-5,20,-292,20,-11,4,21,37
-ARS-M,"ARC 1960, Kenya & Tanzania",CD,-160,20,-6,20,-302,20,-18,8,23,47
-ARS-A,"ARC 1960, Kenya",CD,-157,4,-2,3,-299,3,-11,8,28,47
-ARS-B,"ARC 1960, Tanzania",CD,-175,6,-23,9,-303,10,-18,5,23,47
-ASC,"ASCENSION ISLAND 1958",IN,-205,25,107,25,53,25,-9,-6,-16,-13
-ASM,"MONTSERRAT ISLAND ASTRO 1958",CD,174,25,359,25,365,25,15,18,-64,-61
-ASQ,"ASTRO STATION 1952, Marcus Is.",IN,124,25,-234,25,-25,25,22,26,152,156
-ATF,"ASTRO BEACON E 1945, Iwo Jima",IN,145,25,75,25,-272,25,22,26,140,144
-AUA,"AUSTRALIAN GEODETIC 1966",AN,-133,3,-48,3,148,3,-46,-4,109,161
-AUG,"AUSTRALIAN GEODETIC 1984",AN,-134,2,-48,2,149,2,-46,-4,109,161
-BAT,"DJAKARTA, INDONESIA",BR,-377,3,681,3,-50,3,-16,11,89,146
-BID,"BISSAU, Guinea-Bissau",IN,-173,25,253,25,27,25,5,19,-23,-7
-BER,"BERMUDA 1957, Bermuda Islands",CC,-73,20,213,20,296,20,31,34,-66,-63
-BOO,"BOGOTA OBSERVATORY, Colombia",IN,307,6,304,5,-318,6,-10,16,-85,-61
-BUR,"BUKIT RIMPAH, Banka & Belitung",BR,-384,-1,664,-1,-48,-1,-6,0,103,110
-CAC,"CAPE CANAVERAL, Fla & Bahamas",CC,-2,3,151,3,181,3,15,38,-94,-58
-CAI,"CAMPO INCHAUSPE 1969, Arg.",IN,-148,5,136,5,90,5,-62,-20,-76,-47
-CAO,"CANTON ASTRO 1966, Phoenix Is.",IN,298,15,-304,15,-375,15,-13,3,-180,-165
-CAP,"CAPE, South Africa",CD,-136,3,-108,6,-292,6,-43,-15,10,40
-CAZ,"CAMP AREA ASTRO, Camp McMurdo",IN,-104,-1,-129,-1,239,-1,-85,-70,135,180
-CCD,"S-JTSK, Czech Republic",BR,589,4,76,2,480,3,43,56,6,28
-CGE,"CARTHAGE, Tunisia",CD,-263,6,6,9,431,8,24,43,2,18
-CHI,"CHATHAM ISLAND ASTRO 1971, NZ",IN,175,15,-38,15,113,15,-46,-42,-180,-174
-CHU,"CHUA ASTRO, Paraguay",IN,-134,6,229,9,-29,5,-33,-14,-69,-49
-COA,"CORREGO ALEGRE, Brazil",IN,-206,5,172,3,-6,5,-39,9,-80,-29
-DAL,"DABOLA, Guinea",CD,-83,15,37,15,124,15,1,19,-18,-4
-DID,"DECEPTION ISLAND",CD,260,20,12,20,-147,20,-65,-62,-62,-58
-DOB,"GUX 1 ASTRO, Guadalcanal Is.",IN,252,25,-209,25,-751,25,-12,-8,158,163
-EAS,"EASTER ISLAND 1967",IN,211,25,147,25,111,25,-29,-26,-111,-108
-ENW,"WAKE-ENIWETOK 1960",HO,102,3,52,3,-38,3,1,16,159,175
-EST,"ESTONIA, 1937",BR,374,2,150,3,588,3,52,65,16,34
-EUR-M,"EUROPEAN 1950, Mean (3 Param)",IN,-87,3,-98,8,-121,5,30,80,5,33
-EUR-A,"EUROPEAN 1950, Western Europe",IN,-87,3,-96,3,-120,3,30,78,-15,25
-EUR-B,"EUROPEAN 1950, Greece",IN,-84,25,-95,25,-130,25,30,48,14,34
-EUR-C,"EUROPEAN 1950, Norway & Finland",IN,-87,3,-95,5,-120,3,52,80,-2,38
-EUR-D,"EUROPEAN 1950, Portugal & Spain",IN,-84,5,-107,6,-120,3,30,49,-15,10
-EUR-E,"EUROPEAN 1950, Cyprus",IN,-104,15,-101,15,-140,15,33,37,31,36
-EUR-F,"EUROPEAN 1950, Egypt",IN,-130,6,-117,8,-151,8,16,38,19,42
-EUR-G,"EUROPEAN 1950, England, Channel",IN,-86,3,-96,3,-120,3,48,62,-10,3
-EUR-H,"EUROPEAN 1950, Iran",IN,-117,9,-132,12,-164,11,19,47,37,69
-EUR-I,"EUROPEAN 1950, Sardinia(Italy)",IN,-97,25,-103,25,-120,25,37,43,6,12
-EUR-J,"EUROPEAN 1950, Sicily(Italy)",IN,-97,20,-88,20,-135,20,35,40,10,17
-EUR-K,"EUROPEAN 1950, England, Ireland",IN,-86,3,-96,3,-120,3,48,62,-12,3
-EUR-L,"EUROPEAN 1950, Malta",IN,-107,25,-88,25,-149,25,34,38,12,16
-EUR-S,"EUROPEAN 1950, Iraq, Israel",IN,-103,-1,-106,-1,-141,-1,20,48,24,60
-EUR-T,"EUROPEAN 1950, Tunisia",IN,-112,25,-77,25,-145,25,24,43,2,18
-EUS,"EUROPEAN 1979",IN,-86,3,-98,3,-119,3,30,80,-15,24
-FAH,"OMAN",CD,-346,3,-1,3,224,9,10,32,46,65
-FLO,"OBSERVATORIO MET. 1939, Flores",IN,-425,20,-169,20,81,20,38,41,-33,-30
-FOT,"FORT THOMAS 1955, Leeward Is.",CD,-7,25,215,25,225,25,16,19,-64,-61
-GAA,"GAN 1970, Rep. of Maldives",IN,-133,25,-321,25,50,25,-2,9,71,75
-GEO,"GEODETIC DATUM 1949, NZ",IN,84,5,-22,3,209,5,-48,-33,165,180
-GIZ,"DOS 1968, Gizo Island",IN,230,25,-199,25,-752,25,-10,-7,155,158
-GRA,"GRACIOSA BASE SW 1948, Azores",IN,-104,3,167,3,-38,3,37,41,-30,-26
-GUA,"GUAM 1963",CC,-100,3,-248,3,259,3,12,15,143,146
-GSE,"GUNUNG SEGARA, Indonesia",BR,-403,-1,684,-1,41,-1,-6,9,106,121
-HEN,"HERAT NORTH, Afghanistan",IN,-333,-1,-222,-1,114,-1,23,44,55,81
-HER,"HERMANNSKOGEL, old Yugoslavia",BR,682,-1,-203,-1,480,-1,35,52,7,29
-HIT,"PROVISIONAL SOUTH CHILEAN 1963",IN,16,25,196,25,93,25,-64,-25,-83,-60
-HJO,"HJORSEY 1955, Iceland",IN,-73,3,46,3,-86,6,61,69,-27,-11
-HKD,"HONG KONG 1963",IN,-156,25,-271,25,-189,25,21,24,112,116
-HTN,"HU-TZU-SHAN, Taiwan",IN,-637,15,-549,15,-203,15,20,28,117,124
-IBE,"BELLEVUE (IGN), Efate Is.",IN,-127,20,-769,20,472,20,-20,-16,167,171
-IDN,"INDONESIAN 1974",ID,-24,25,-15,25,5,25,-16,11,89,146
-IND-B,"INDIAN, Bangladesh",EA,282,10,726,8,254,12,15,33,80,100
-IND-I,"INDIAN, India & Nepal",EC,295,12,736,10,257,15,2,44,62,105
-IND-P,"INDIAN, Pakistan",EF,283,-1,682,-1,231,-1,17,44,55,81
-INF-A,"INDIAN 1954, Thailand",EA,217,15,823,6,299,12,0,27,91,111
-ING-A,"INDIAN 1960, Vietnam 16N",EA,198,25,881,25,317,25,2,30,101,115
-ING-B,"INDIAN 1960, Con Son Island",EA,182,25,915,25,344,25,6,11,104,109
-INH-A,"INDIAN 1975, Thailand",EA,209,12,818,10,290,12,0,27,91,111
-INH-A1,"INDIAN 1975, Thailand",EA,210,3,814,2,289,3,0,27,91,111
-IRL,"IRELAND 1965",AM,506,3,-122,3,611,3,50,57,-12,-4
-ISG,"ISTS 061 ASTRO 1968, S Georgia",IN,-794,25,119,25,-298,25,-56,-52,-38,-34
-IST,"ISTS 073 ASTRO 1969, Diego Garc",IN,208,25,-435,25,-229,25,-10,-4,69,75
-JOH,"JOHNSTON ISLAND 1961",IN,189,25,-79,25,-202,25,15,19,-171,-168
-KAN,"KANDAWALA, Sri Lanka",EA,-97,20,787,20,86,20,4,12,77,85
-KEG,"KERGUELEN ISLAND 1949",IN,145,25,-187,25,103,25,-52,-47,65,74
-KEA,"KERTAU 1948, W Malaysia & Sing.",EE,-11,10,851,8,5,6,-5,12,94,112
-KUS,"KUSAIE ASTRO 1951, Caroline Is.",IN,647,25,1777,25,-1124,25,-1,12,134,167
-LCF,"L.C. 5 ASTRO 1961, Cayman Brac",CC,42,25,124,25,147,25,18,21,-83,-78
-LEH,"LEIGON, Ghana",CD,-130,2,29,3,364,2,-1,17,-9,7
-LIB,"LIBERIA 1964",CD,-90,15,40,15,88,15,-1,14,-17,-1
-LUZ-A,"LUZON, Philippines",CC,-133,8,-77,11,-51,9,3,23,115,128
-LUZ-B,"LUZON, Mindanao Island",CC,-133,25,-79,25,-72,25,4,12,120,128
-MAS,"MASSAWA, Ethiopia",BR,639,25,405,25,60,25,7,25,37,53
-MER,"MERCHICH, Morocco",CD,31,5,146,3,47,3,22,42,-19,5
-MID,"MIDWAY ASTRO 1961, Midway Is.",IN,403,25,-81,25,277,25,25,30,-180,-169
-MIK,"MAHE 1971, Mahe Is.",CD,41,25,-220,25,-134,25,-6,-3,54,57
-MIN-A,"MINNA, Cameroon",CD,-81,25,-84,25,115,25,-4,19,3,23
-MIN-B,"MINNA, Nigeria",CD,-92,3,-93,6,122,5,-1,21,-4,20
-MOD,"ROME 1940, Sardinia",IN,-225,25,-65,25,9,25,37,43,6,12
-MPO,"M'PORALOKO, Gabon",CD,-74,25,-130,25,42,25,-10,8,3,20
-MVS,"VITI LEVU 1916, Viti Levu Is.",CD,51,25,391,25,-36,25,-20,-16,176,180
-NAH-A,"NAHRWAN, Masirah Island (Oman)",CD,-247,25,-148,25,369,25,19,22,57,60
-NAH-B,"NAHRWAN, United Arab Emirates",CD,-249,25,-156,25,381,25,17,32,45,62
-NAH-C,"NAHRWAN, Saudi Arabia",CD,-243,20,-192,20,477,20,8,38,28,62
-NAP,"NAPARIMA, Trinidad & Tobago",IN,-10,15,375,15,165,15,8,13,-64,-59
-NAR-A,"NORTH AMERICAN 1983, Alaska",RF,0,2,0,2,0,2,48,78,-175,-135
-NAR-B,"NORTH AMERICAN 1983, Canada",RF,0,2,0,2,0,2,36,90,-150,-50
-NAR-C,"NORTH AMERICAN 1983, CONUS",RF,0,2,0,2,0,2,15,60,-135,-60
-NAR-D,"NORTH AMERICAN 1983, Mexico",RF,0,2,0,2,0,2,11,35,-122,-72
-NAR-E,"NORTH AMERICAN 1983, Aleutian",RF,-2,5,0,2,4,5,51,74,-180,180
-NAR-H,"NORTH AMERICAN 1983, Hawaii",RF,1,2,1,2,-1,2,17,24,-164,-153
-NAS-A,"NORTH AMERICAN 1927, Eastern US",CC,-9,5,161,5,179,8,18,55,-102,-60
-NAS-B,"NORTH AMERICAN 1927, Western US",CC,-8,5,159,3,175,3,19,55,-132,-87
-NAS-C,"NORTH AMERICAN 1927, CONUS",CC,-8,5,160,5,176,6,15,60,-135,-60
-NAS-D,"NORTH AMERICAN 1927, Alaska",CC,-5,5,135,9,172,5,47,78,-175,-130
-NAS-E,"NORTH AMERICAN 1927, Canada",CC,-10,15,158,11,187,6,36,90,-150,-50
-NAS-F,"NORTH AMERICAN 1927, Alberta/BC",CC,-7,8,162,8,188,6,43,65,-145,-105
-NAS-G,"NORTH AMERICAN 1927, E. Canada",CC,-22,6,160,6,190,3,38,68,-85,-45
-NAS-H,"NORTH AMERICAN 1927, Man/Ont",CC,-9,9,157,5,184,5,36,63,-108,-69
-NAS-I,"NORTH AMERICAN 1927, NW Terr.",CC,4,5,159,5,188,3,43,90,-144,-55
-NAS-J,"NORTH AMERICAN 1927, Yukon",CC,-7,5,139,8,181,3,53,75,-147,-117
-NAS-L,"NORTH AMERICAN 1927, Mexico",CC,-12,8,130,6,190,6,10,38,-122,-80
-NAS-N,"NORTH AMERICAN 1927, C. America",CC,0,8,125,3,194,5,3,25,-98,-77
-NAS-O,"NORTH AMERICAN 1927, Canal Zone",CC,0,20,125,20,201,20,3,15,-86,-74
-NAS-P,"NORTH AMERICAN 1927, Caribbean",CC,-3,3,142,9,183,12,8,29,-87,-58
-NAS-Q,"NORTH AMERICAN 1927, Bahamas",CC,-4,5,154,3,178,5,19,29,-83,-71
-NAS-R,"NORTH AMERICAN 1927, San Salv.",CC,1,25,140,25,165,25,23,26,-75,-74
-NAS-T,"NORTH AMERICAN 1927, Cuba",CC,-9,25,152,25,178,25,18,25,-87,-72
-NAS-U,"NORTH AMERICAN 1927, Greenland",CC,11,25,114,25,195,25,74,81,-74,-56
-NAS-V,"NORTH AMERICAN 1927, Aleutian E",CC,-2,6,152,8,149,10,50,58,-180,-161
-NAS-W,"NORTH AMERICAN 1927, Aleutian W",CC,2,10,204,10,105,10,50,58,169,180
-NSD,"NORTH SAHARA 1959, Algeria",CD,-186,25,-93,25,310,25,13,43,-15,18
-OEG,"OLD EGYPTIAN 1907",HE,-130,3,110,6,-13,8,16,38,19,42
-OGB-M,"ORDNANCE GB 1936, Mean (3 Para)",AA,375,10,-111,10,431,15,44,66,-14,7
-OGB-A,"ORDNANCE GB 1936, England",AA,371,5,-112,5,434,6,44,61,-12,7
-OGB-B,"ORDNANCE GB 1936, Eng., Wales",AA,371,10,-111,10,434,15,44,61,-12,7
-OGB-C,"ORDNANCE GB 1936, Scotland",AA,384,10,-111,10,425,10,49,66,-14,4
-OGB-D,"ORDNANCE GB 1936, Wales",AA,370,20,-108,20,434,20,46,59,-11,3
-OHA-M,"OLD HAWAIIAN (CC), Mean",CC,61,25,-285,20,-181,20,17,24,-164,-153
-OHA-A,"OLD HAWAIIAN (CC), Hawaii",CC,89,25,-279,25,-183,25,17,22,-158,-153
-OHA-B,"OLD HAWAIIAN (CC), Kauai",CC,45,20,-290,20,-172,20,20,24,-161,-158
-OHA-C,"OLD HAWAIIAN (CC), Maui",CC,65,25,-290,25,-190,25,19,23,-158,-154
-OHA-D,"OLD HAWAIIAN (CC), Oahu",CC,58,10,-283,6,-182,6,20,23,-160,-156
-OHI-M,"OLD HAWAIIAN (IN), Mean",IN,201,25,-228,20,-346,20,17,24,-164,-153
-OHI-A,"OLD HAWAIIAN (IN), Hawaii",IN,229,25,-222,25,-348,25,17,22,-158,-153
-OHI-B,"OLD HAWAIIAN (IN), Kauai",IN,185,20,-233,20,-337,20,20,24,-161,-158
-OHI-C,"OLD HAWAIIAN (IN), Maui",IN,205,25,-233,25,-355,25,19,23,-158,-154
-OHI-D,"OLD HAWAIIAN (IN), Oahu",IN,198,10,-226,6,-347,6,20,23,-160,-156
-PHA,"AYABELLE LIGHTHOUSE, Djibouti",CD,-79,25,-129,25,145,25,5,20,36,49
-PIT,"PITCAIRN ASTRO 1967",IN,185,25,165,25,42,25,-27,-21,-134,-119
-PLN,"PICO DE LAS NIEVES, Canary Is.",IN,-307,25,-92,25,127,25,26,31,-20,-12
-POS,"PORTO SANTO 1936, Madeira Is.",IN,-499,25,-249,25,314,25,31,35,-18,-15
-PRP-A,"PROV. S AMERICAN 1956, Bolivia",IN,-270,5,188,11,-388,14,-28,-4,-75,-51
-PRP-B,"PROV. S AMERICAN 1956, N Chile",IN,-270,25,183,25,-390,25,-45,-12,-83,-60
-PRP-C,"PROV. S AMERICAN 1956, S Chile",IN,-305,20,243,20,-442,20,-64,-20,-83,-60
-PRP-D,"PROV. S AMERICAN 1956, Colombia",IN,-282,15,169,15,-371,15,-10,16,-85,-61
-PRP-E,"PROV. S AMERICAN 1956, Ecuador",IN,-278,3,171,5,-367,3,-11,7,-85,-70
-PRP-F,"PROV. S AMERICAN 1956, Guyana",IN,-298,6,159,14,-369,5,-4,14,-67,-51
-PRP-G,"PROV. S AMERICAN 1956, Peru",IN,-279,6,175,8,-379,12,-24,5,-87,-63
-PRP-H,"PROV. S AMERICAN 1956, Venez",IN,-295,9,173,14,-371,15,-5,18,-79,-54
-PRP-M,"PROV. S AMERICAN 1956, Mean",IN,-288,17,175,27,-376,27,-64,18,-87,-51
-PTB,"POINT 58, Burkina Faso & Niger",CD,-106,25,-129,25,165,25,0,10,-15,25
-PTN,"POINT NOIRE 1948, Congo",CD,-148,25,51,25,-291,25,-11,10,5,25
-PUK,"PULKOVO 1942, Russia",KA,28,-1,-130,-1,-95,-1,36,89,-180,180
-PUR,"PUERTO RICO & Virgin Is.",CC,11,3,72,3,-101,3,16,20,-69,-63
-QAT,"QATAR NATIONAL",IN,-128,20,-283,20,22,20,19,32,45,57
-QUO,"QORNOQ, South Greenland",IN,164,25,138,25,-189,32,57,85,-77,-7
-REU,"REUNION, Mascarene Is.",IN,94,25,-948,25,-1262,25,-27,-12,47,65
-SAE,"SANTO (DOS) 1965",IN,170,25,42,25,84,25,-20,-11,163,172
-SAO,"SAO BRAZ, Santa Maria Is.",IN,-203,25,141,25,53,25,35,39,-27,-23
-SAP,"SAPPER HILL 1943, E Falkland Is",IN,-355,1,21,1,72,1,-54,-50,-61,-56
-SAN-M,"SOUTH AMERICAN 1969, Mean",SA,-57,15,1,6,-41,9,-65,-50,-90,-25
-SAN-A,"SOUTH AMERICAN 1969, Argentina",SA,-62,5,-1,5,-37,5,-62,-20,-76,-47
-SAN-B,"SOUTH AMERICAN 1969, Bolivia",SA,-61,15,2,15,-48,15,-28,-4,-75,-51
-SAN-C,"SOUTH AMERICAN 1969, Brazil",SA,-60,3,-2,5,-41,5,-39,9,-80,-29
-SAN-D,"SOUTH AMERICAN 1969, Chile",SA,-75,15,-1,8,-44,11,-64,-12,-83,-60
-SAN-E,"SOUTH AMERICAN 1969, Colombia",SA,-44,6,6,6,-36,5,-10,16,-85,-61
-SAN-F,"SOUTH AMERICAN 1969, Ecuador",SA,-48,3,3,3,-44,3,-11,7,-85,-70
-SAN-G,"SOUTH AMERICAN 1969, Guyana",SA,-53,9,3,5,-47,5,-4,14,-67,-51
-SAN-H,"SOUTH AMERICAN 1969, Paraguay",SA,-61,15,2,15,-33,15,-33,-14,-69,-49
-SAN-I,"SOUTH AMERICAN 1969, Peru",SA,-58,5,0,5,-44,5,-24,5,-87,-63
-SAN-J,"SOUTH AMERICAN 1969, Baltra",SA,-47,25,26,25,-42,25,-2,1,-92,-89
-SAN-K,"SOUTH AMERICAN 1969, Trinidad",SA,-45,25,12,25,-33,25,4,17,-68,-55
-SAN-L,"SOUTH AMERICAN 1969, Venezuela",SA,-45,3,8,6,-33,3,-5,18,-79,-54
-SCK,"SCHWARZECK, Namibia",BN,616,20,97,20,-251,20,-35,-11,5,31
-SGM,"SELVAGEM GRANDE 1938, Salvage Is,"I,N -28,9   2,5 -12,4   25,6,0   2,28,32,-18,-14
-SHB,"ASTRO DOS 71/4, St. Helena Is.",IN,-320,25,550,25,-494,25,-18,-14,-7,-4
-SOA,"SOUTH ASIA, Singapore",FA,7,25,-10,25,-26,25,0,3,102,106
-SPK-A,"S-42 (PULKOVO 1942), Hungary",KA,28,2,-121,2,-77,2,40,54,11,29
-SPK-B,"S-42 (PULKOVO 1942), Poland",KA,23,4,-124,2,-82,4,43,60,8,30
-SPK-C,"S-42 (PK42) Former Czechoslov.",KA,26,3,-121,3,-78,2,42,57,6,28
-SPK-D,"S-42 (PULKOVO 1942), Latvia",KA,24,2,-124,2,-82,2,50,64,15,34
-SPK-E,"S-42 (PK 1942), Kazakhstan",KA,15,25,-130,25,-84,25,35,62,41,93
-SPK-F,"S-42 (PULKOVO 1942), Albania",KA,24,3,-130,3,-92,3,34,48,14,26
-SPK-G,"S-42 (PULKOVO 1942), Romania",KA,28,3,-121,5,-77,3,38,54,15,35
-SRL,"SIERRA LEONE 1960",CD,-88,15,4,15,101,15,1,16,-19,-4
-TAN,"TANANARIVE OBSERVATORY 1925",IN,-189,-1,-242,-1,-91,-1,-34,-8,40,53
-TDC,"TRISTAN ASTRO 1968",IN,-632,25,438,25,-609,25,-39,-36,-14,-11
-TIL,"TIMBALAI 1948, Brunei & E Malay",EB,-679,10,669,10,-48,12,-5,15,101,125
-TOY-A,"TOKYO, Japan",BR,-148,8,507,5,685,8,19,51,119,156
-TOY-B,"TOKYO, South Korea",BR,-146,8,507,5,687,8,27,45,120,139
-TOY-B1,"TOKYO, South Korea",BR,-147,2,506,2,687,2,27,45,120,139
-TOY-C,"TOKYO, Okinawa",BR,-158,20,507,5,676,20,19,31,119,134
-TOY-M,"TOKYO, Mean",BR,-148,20,507,5,685,20,23,53,120,155
-TRN,"ASTRO TERN ISLAND (FRIG) 1961",IN,114,25,-116,25,-333,25,22,26,-168,-164
-VOI,"VOIROL 1874, Algeria",CD,-73,-1,-247,-1,227,-1,13,43,-15,18
-VOR,"VOIROL 1960, Algeria",CD,-123,25,-206,25,219,25,13,43,-15,18
-WAK,"WAKE ISLAND ASTRO 1952",IN,276,25,-57,25,149,25,17,21,164,168
-YAC,"YACARE, Uruguay",IN,-155,-1,171,-1,37,-1,-40,-25,-65,-47
-ZAN,"ZANDERIJ, Suriname",IN,-265,5,120,5,-358,8,-10,20,-76,-47
-KGS,"KOREAN GEO DATUM 1995, S Korea",WE,0,1,0,1,0,1,27,45,120,139
-SIR,"SIRGAS, South America",RF,0,1,0,1,0,1,-65,-50,-90,-25
-EUR-7,"EUROPEAN 1950, Mean (7 Param)",IN,-102,,-102,,-129,,,,,0.413,-0.184,0.385,0.0000024664
-OGB-7,"ORDNANCE GB 1936, Mean (7 Para)",AA,446,,-99,,544,,,,,,-0.945,-0.261,-0.435,-0.0000208927
Deleted: grass/trunk/lib/proj/gt_ellips.csv
--- grass/trunk/lib/proj/gt_ellips.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/gt_ellips.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,24 +0,0 @@
-NAME,CODE,A,B,RF
-Airy 1830                     ,AA,6377563.396,6356256.9090,299.324964600
-Modified Airy                 ,AM,6377340.189,6356034.4480,299.324964600
-Australian National           ,AN,6378160.000,6356774.7190,298.250000000
-Bessel 1841(Namibia)          ,BN,6377483.865,6356165.3830,299.152812800
-Bessel 1841                   ,BR,6377397.155,6356078.9630,299.152812800
-Clarke 1866                   ,CC,6378206.400,6356583.8000,294.978698200
-Clarke 1880                   ,CD,6378249.145,6356514.8700,293.465000000
-Everest (India 1830)          ,EA,6377276.345,6356075.4130,300.801700000
-Everest (E. Malasia, Brunei)  ,EB,6377298.556,6356097.5500,300.801700000
-Everest 1956 (India)          ,EC,6377301.243,6356100.2280,300.801700000
-Everest 1969 (West Malasia)   ,ED,6377295.664,6356094.6680,300.801700000
-Everest 1948(W.Mals. & Sing.) ,EE,6377304.063,6356103.0390,300.801700000
-Everest (Pakistan)            ,EF,6377309.613,6356109.5710,300.801700000
-Mod. Fischer 1960(South Asia) ,FA,6378155.000,6356773.3200,298.300000000
-Helmert 1906                  ,HE,6378200.000,6356818.1700,298.300000000
-Hough 1960                    ,HO,6378270.000,6356794.3430,297.000000000
-Indonesian 1974               ,ID,6378160.000,6356774.5040,298.247000000
-International 1924            ,IN,6378388.000,6356911.9460,297.000000000
-Krassovsky 1940               ,KA,6378245.000,6356863.0190,298.300000000
-GRS 80                        ,RF,6378137.000,6356752.3141,298.257222101
-South American 1969           ,SA,6378160.000,6356774.7190,298.250000000
-WGS 72                        ,WD,6378135.000,6356750.5200,298.260000000
-WGS 84                        ,WE,6378137.000,6356752.3142,298.257223563
Deleted: grass/trunk/lib/proj/iau2000.csv
--- grass/trunk/lib/proj/iau2000.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/iau2000.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,6864 +0,0 @@
-# GEOGCS Mercury Areocentric
-<19900> 	+proj=longlat +a=2439700 +b=2439700 +no_defs
-# GEOGCS Mercury Areographic
-<19901> 	+proj=longlat +a=2439700 +b=2439700 +no_defs
-# Equirectangular Mercury Areocentric, clon=0
-<19910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equirectangular Mercury Areographic, clon=0
-<19911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equirectangular Mercury Areocentric, clon=180
-<19912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equirectangular Mercury Areographic, clon=180
-<19913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areocentric, clon=0
-<19914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areographic, clon=0
-<19915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areocentric, clon=180
-<19916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areographic, clon=180
-<19917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# North Polar Mercury Areocentric, clon=0
-<19918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# North Polar Mercury Areographic, clon=0
-<19919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# South Polar Mercury Areocentric, clon=0
-<19920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# South Polar Mercury Areographic, clon=0
-<19921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areocentric, clon=0
-<19922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areographic, clon=0
-<19923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areocentric, clon=180
-<19924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areographic, clon=180
-<19925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areocentric, clon=0
-<19926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areographic, clon=0
-<19927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areocentric, clon=180
-<19928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areographic, clon=180
-<19929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal AUTO Mercury Areocentric
-<19960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal AUTO Mercury Areographic
-<19961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Stereographic AUTO Mercury Areocentric, clon=0
-<19962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Stereographic AUTO Mercury Areographic, clon=0
-<19963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Transverse Mercator AUTO Mercury Areocentric
-<19964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Transverse Mercator AUTO Mercury Areographic
-<19965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Orthographic AUTO Mercury Areocentric
-<19966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Orthographic AUTO Mercury Areographic
-<19967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mercury Areocentric
-<19968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mercury Areographic
-<19969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mercury Areocentric
-<19970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mercury Areographic
-<19971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mercury Areocentric
-<19972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mercury Areographic
-<19973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mercator AUTO Mercury Areocentric
-<19974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mercator AUTO Mercury Areographic
-<19975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Albers AUTO Mercury Areocentric
-<19976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Albers AUTO Mercury Areographic
-<19977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide AUTO Mercury Areocentric
-<19980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide AUTO Mercury Areographic
-<19981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson AUTO Mercury Areocentric
-<19982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson AUTO Mercury Areographic
-<19983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# GEOGCS Venus Areocentric
-<29900> 	+proj=longlat +a=6051800 +b=6051800 +no_defs
-# GEOGCS Venus Areographic
-<29901> 	+proj=longlat +a=6051800 +b=6051800 +no_defs
-# Equirectangular Venus Areocentric, clon=0
-<29910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equirectangular Venus Areographic, clon=0
-<29911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equirectangular Venus Areocentric, clon=180
-<29912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equirectangular Venus Areographic, clon=180
-<29913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areocentric, clon=0
-<29914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areographic, clon=0
-<29915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areocentric, clon=180
-<29916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areographic, clon=180
-<29917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# North Polar Venus Areocentric, clon=0
-<29918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# North Polar Venus Areographic, clon=0
-<29919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# South Polar Venus Areocentric, clon=0
-<29920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# South Polar Venus Areographic, clon=0
-<29921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areocentric, clon=0
-<29922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areographic, clon=0
-<29923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areocentric, clon=180
-<29924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areographic, clon=180
-<29925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areocentric, clon=0
-<29926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areographic, clon=0
-<29927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areocentric, clon=180
-<29928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areographic, clon=180
-<29929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal AUTO Venus Areocentric
-<29960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal AUTO Venus Areographic
-<29961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Stereographic AUTO Venus Areocentric, clon=0
-<29962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Stereographic AUTO Venus Areographic, clon=0
-<29963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Transverse Mercator AUTO Venus Areocentric
-<29964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Transverse Mercator AUTO Venus Areographic
-<29965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Orthographic AUTO Venus Areocentric
-<29966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Orthographic AUTO Venus Areographic
-<29967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Venus Areocentric
-<29968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Venus Areographic
-<29969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Venus Areocentric
-<29970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Venus Areographic
-<29971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Venus Areocentric
-<29972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Venus Areographic
-<29973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mercator AUTO Venus Areocentric
-<29974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mercator AUTO Venus Areographic
-<29975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Albers AUTO Venus Areocentric
-<29976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Albers AUTO Venus Areographic
-<29977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide AUTO Venus Areocentric
-<29980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide AUTO Venus Areographic
-<29981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson AUTO Venus Areocentric
-<29982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson AUTO Venus Areographic
-<29983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# GEOGCS Earth Areocentric
-<39900> 	+proj=longlat +a=6378140 +b=-1895273619.09362 +no_defs
-# GEOGCS Earth Areographic
-<39901> 	+proj=longlat +a=6378140 +b=-1895273619.09362 +no_defs
-# Equirectangular Earth Areocentric, clon=0
-<39910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Equirectangular Earth Areographic, clon=0
-<39911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Equirectangular Earth Areocentric, clon=180
-<39912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Equirectangular Earth Areographic, clon=180
-<39913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Sinusoidal Earth Areocentric, clon=0
-<39914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Sinusoidal Earth Areographic, clon=0
-<39915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Sinusoidal Earth Areocentric, clon=180
-<39916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Sinusoidal Earth Areographic, clon=180
-<39917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# North Polar Earth Areocentric, clon=0
-<39918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# North Polar Earth Areographic, clon=0
-<39919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# South Polar Earth Areocentric, clon=0
-<39920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# South Polar Earth Areographic, clon=0
-<39921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mollweide Earth Areocentric, clon=0
-<39922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mollweide Earth Areographic, clon=0
-<39923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mollweide Earth Areocentric, clon=180
-<39924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mollweide Earth Areographic, clon=180
-<39925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Robinson Earth Areocentric, clon=0
-<39926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Robinson Earth Areographic, clon=0
-<39927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Robinson Earth Areocentric, clon=180
-<39928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Robinson Earth Areographic, clon=180
-<39929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Sinusoidal AUTO Earth Areocentric
-<39960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Sinusoidal AUTO Earth Areographic
-<39961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Stereographic AUTO Earth Areocentric, clon=0
-<39962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Stereographic AUTO Earth Areographic, clon=0
-<39963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Transverse Mercator AUTO Earth Areocentric
-<39964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Transverse Mercator AUTO Earth Areographic
-<39965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Orthographic AUTO Earth Areocentric
-<39966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Orthographic AUTO Earth Areographic
-<39967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Equidistant Cylindrical AUTO Earth Areocentric
-<39968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Equidistant Cylindrical AUTO Earth Areographic
-<39969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Lambert Conformal Conic AUTO Earth Areocentric
-<39970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Lambert Conformal Conic AUTO Earth Areographic
-<39971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Earth Areocentric
-<39972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Earth Areographic
-<39973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mercator AUTO Earth Areocentric
-<39974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mercator AUTO Earth Areographic
-<39975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Albers AUTO Earth Areocentric
-<39976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Albers AUTO Earth Areographic
-<39977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mollweide AUTO Earth Areocentric
-<39980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Mollweide AUTO Earth Areographic
-<39981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Robinson AUTO Earth Areocentric
-<39982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# Robinson AUTO Earth Areographic
-<39983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378140 +b=-1895273619.09362 +units=m +no_defs
-# GEOGCS Moon Areocentric
-<30100> 	+proj=longlat +a=1737400 +b=1737400 +no_defs
-# GEOGCS Moon Areographic
-<30101> 	+proj=longlat +a=1737400 +b=1737400 +no_defs
-# Equirectangular Moon Areocentric, clon=0
-<30110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equirectangular Moon Areographic, clon=0
-<30111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equirectangular Moon Areocentric, clon=180
-<30112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equirectangular Moon Areographic, clon=180
-<30113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areocentric, clon=0
-<30114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areographic, clon=0
-<30115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areocentric, clon=180
-<30116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areographic, clon=180
-<30117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# North Polar Moon Areocentric, clon=0
-<30118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# North Polar Moon Areographic, clon=0
-<30119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# South Polar Moon Areocentric, clon=0
-<30120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# South Polar Moon Areographic, clon=0
-<30121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areocentric, clon=0
-<30122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areographic, clon=0
-<30123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areocentric, clon=180
-<30124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areographic, clon=180
-<30125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areocentric, clon=0
-<30126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areographic, clon=0
-<30127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areocentric, clon=180
-<30128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areographic, clon=180
-<30129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal AUTO Moon Areocentric
-<30160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal AUTO Moon Areographic
-<30161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Stereographic AUTO Moon Areocentric, clon=0
-<30162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Stereographic AUTO Moon Areographic, clon=0
-<30163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Transverse Mercator AUTO Moon Areocentric
-<30164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Transverse Mercator AUTO Moon Areographic
-<30165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Orthographic AUTO Moon Areocentric
-<30166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Orthographic AUTO Moon Areographic
-<30167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Moon Areocentric
-<30168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Moon Areographic
-<30169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Moon Areocentric
-<30170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Moon Areographic
-<30171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Moon Areocentric
-<30172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Moon Areographic
-<30173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mercator AUTO Moon Areocentric
-<30174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mercator AUTO Moon Areographic
-<30175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Albers AUTO Moon Areocentric
-<30176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Albers AUTO Moon Areographic
-<30177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide AUTO Moon Areocentric
-<30180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide AUTO Moon Areographic
-<30181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson AUTO Moon Areocentric
-<30182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson AUTO Moon Areographic
-<30183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# GEOGCS Mars Areocentric
-<49900> 	+proj=longlat +a=3396190 +b=-573598373.3707101 +no_defs
-# GEOGCS Mars Areographic
-<49901> 	+proj=longlat +a=3396190 +b=-573598373.3707101 +no_defs
-# Equirectangular Mars Areocentric, clon=0
-<49910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equirectangular Mars Areographic, clon=0
-<49911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equirectangular Mars Areocentric, clon=180
-<49912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equirectangular Mars Areographic, clon=180
-<49913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areocentric, clon=0
-<49914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areographic, clon=0
-<49915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areocentric, clon=180
-<49916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areographic, clon=180
-<49917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# North Polar Mars Areocentric, clon=0
-<49918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# North Polar Mars Areographic, clon=0
-<49919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# South Polar Mars Areocentric, clon=0
-<49920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# South Polar Mars Areographic, clon=0
-<49921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areocentric, clon=0
-<49922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areographic, clon=0
-<49923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areocentric, clon=180
-<49924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areographic, clon=180
-<49925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areocentric, clon=0
-<49926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areographic, clon=0
-<49927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areocentric, clon=180
-<49928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areographic, clon=180
-<49929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal AUTO Mars Areocentric
-<49960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal AUTO Mars Areographic
-<49961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Stereographic AUTO Mars Areocentric, clon=0
-<49962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Stereographic AUTO Mars Areographic, clon=0
-<49963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Transverse Mercator AUTO Mars Areocentric
-<49964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Transverse Mercator AUTO Mars Areographic
-<49965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Orthographic AUTO Mars Areocentric
-<49966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Orthographic AUTO Mars Areographic
-<49967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mars Areocentric
-<49968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mars Areographic
-<49969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mars Areocentric
-<49970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mars Areographic
-<49971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mars Areocentric
-<49972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mars Areographic
-<49973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mercator AUTO Mars Areocentric
-<49974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mercator AUTO Mars Areographic
-<49975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Albers AUTO Mars Areocentric
-<49976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Albers AUTO Mars Areographic
-<49977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide AUTO Mars Areocentric
-<49980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide AUTO Mars Areographic
-<49981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson AUTO Mars Areocentric
-<49982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson AUTO Mars Areographic
-<49983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# GEOGCS Phobos Areocentric
-<40100> 	+proj=longlat +a=11100 +b=11100 +no_defs
-# GEOGCS Phobos Areographic
-<40101> 	+proj=longlat +a=11100 +b=11100 +no_defs
-# Equirectangular Phobos Areocentric, clon=0
-<40110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Equirectangular Phobos Areographic, clon=0
-<40111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Equirectangular Phobos Areocentric, clon=180
-<40112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Equirectangular Phobos Areographic, clon=180
-<40113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Sinusoidal Phobos Areocentric, clon=0
-<40114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Sinusoidal Phobos Areographic, clon=0
-<40115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Sinusoidal Phobos Areocentric, clon=180
-<40116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Sinusoidal Phobos Areographic, clon=180
-<40117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# North Polar Phobos Areocentric, clon=0
-<40118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# North Polar Phobos Areographic, clon=0
-<40119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# South Polar Phobos Areocentric, clon=0
-<40120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# South Polar Phobos Areographic, clon=0
-<40121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mollweide Phobos Areocentric, clon=0
-<40122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mollweide Phobos Areographic, clon=0
-<40123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mollweide Phobos Areocentric, clon=180
-<40124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mollweide Phobos Areographic, clon=180
-<40125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Robinson Phobos Areocentric, clon=0
-<40126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Robinson Phobos Areographic, clon=0
-<40127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Robinson Phobos Areocentric, clon=180
-<40128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Robinson Phobos Areographic, clon=180
-<40129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Sinusoidal AUTO Phobos Areocentric
-<40160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Sinusoidal AUTO Phobos Areographic
-<40161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Stereographic AUTO Phobos Areocentric, clon=0
-<40162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Stereographic AUTO Phobos Areographic, clon=0
-<40163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Transverse Mercator AUTO Phobos Areocentric
-<40164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Transverse Mercator AUTO Phobos Areographic
-<40165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Orthographic AUTO Phobos Areocentric
-<40166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Orthographic AUTO Phobos Areographic
-<40167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phobos Areocentric
-<40168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phobos Areographic
-<40169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phobos Areocentric
-<40170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phobos Areographic
-<40171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phobos Areocentric
-<40172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phobos Areographic
-<40173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mercator AUTO Phobos Areocentric
-<40174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mercator AUTO Phobos Areographic
-<40175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Albers AUTO Phobos Areocentric
-<40176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Albers AUTO Phobos Areographic
-<40177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mollweide AUTO Phobos Areocentric
-<40180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Mollweide AUTO Phobos Areographic
-<40181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Robinson AUTO Phobos Areocentric
-<40182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# Robinson AUTO Phobos Areographic
-<40183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11100 +b=11100 +units=m +no_defs
-# GEOGCS Deimos Areocentric
-<40200> 	+proj=longlat +a=6200 +b=6200 +no_defs
-# GEOGCS Deimos Areographic
-<40201> 	+proj=longlat +a=6200 +b=6200 +no_defs
-# Equirectangular Deimos Areocentric, clon=0
-<40210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equirectangular Deimos Areographic, clon=0
-<40211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equirectangular Deimos Areocentric, clon=180
-<40212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equirectangular Deimos Areographic, clon=180
-<40213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areocentric, clon=0
-<40214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areographic, clon=0
-<40215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areocentric, clon=180
-<40216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areographic, clon=180
-<40217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# North Polar Deimos Areocentric, clon=0
-<40218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# North Polar Deimos Areographic, clon=0
-<40219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# South Polar Deimos Areocentric, clon=0
-<40220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# South Polar Deimos Areographic, clon=0
-<40221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areocentric, clon=0
-<40222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areographic, clon=0
-<40223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areocentric, clon=180
-<40224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areographic, clon=180
-<40225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areocentric, clon=0
-<40226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areographic, clon=0
-<40227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areocentric, clon=180
-<40228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areographic, clon=180
-<40229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal AUTO Deimos Areocentric
-<40260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal AUTO Deimos Areographic
-<40261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Stereographic AUTO Deimos Areocentric, clon=0
-<40262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Stereographic AUTO Deimos Areographic, clon=0
-<40263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Transverse Mercator AUTO Deimos Areocentric
-<40264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Transverse Mercator AUTO Deimos Areographic
-<40265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Orthographic AUTO Deimos Areocentric
-<40266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Orthographic AUTO Deimos Areographic
-<40267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Deimos Areocentric
-<40268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Deimos Areographic
-<40269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Deimos Areocentric
-<40270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Deimos Areographic
-<40271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Deimos Areocentric
-<40272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Deimos Areographic
-<40273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mercator AUTO Deimos Areocentric
-<40274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mercator AUTO Deimos Areographic
-<40275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Albers AUTO Deimos Areocentric
-<40276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Albers AUTO Deimos Areographic
-<40277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide AUTO Deimos Areocentric
-<40280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide AUTO Deimos Areographic
-<40281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson AUTO Deimos Areocentric
-<40282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson AUTO Deimos Areographic
-<40283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# GEOGCS Jupiter Areocentric
-<59900> 	+proj=longlat +a=71492000 +b=-1030521133.150415 +no_defs
-# GEOGCS Jupiter Areographic
-<59901> 	+proj=longlat +a=71492000 +b=-1030521133.150415 +no_defs
-# Equirectangular Jupiter Areocentric, clon=0
-<59910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equirectangular Jupiter Areographic, clon=0
-<59911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equirectangular Jupiter Areocentric, clon=180
-<59912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equirectangular Jupiter Areographic, clon=180
-<59913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areocentric, clon=0
-<59914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areographic, clon=0
-<59915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areocentric, clon=180
-<59916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areographic, clon=180
-<59917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# North Polar Jupiter Areocentric, clon=0
-<59918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# North Polar Jupiter Areographic, clon=0
-<59919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# South Polar Jupiter Areocentric, clon=0
-<59920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# South Polar Jupiter Areographic, clon=0
-<59921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areocentric, clon=0
-<59922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areographic, clon=0
-<59923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areocentric, clon=180
-<59924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areographic, clon=180
-<59925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areocentric, clon=0
-<59926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areographic, clon=0
-<59927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areocentric, clon=180
-<59928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areographic, clon=180
-<59929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal AUTO Jupiter Areocentric
-<59960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal AUTO Jupiter Areographic
-<59961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Stereographic AUTO Jupiter Areocentric, clon=0
-<59962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Stereographic AUTO Jupiter Areographic, clon=0
-<59963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Transverse Mercator AUTO Jupiter Areocentric
-<59964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Transverse Mercator AUTO Jupiter Areographic
-<59965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Orthographic AUTO Jupiter Areocentric
-<59966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Orthographic AUTO Jupiter Areographic
-<59967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equidistant Cylindrical AUTO Jupiter Areocentric
-<59968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equidistant Cylindrical AUTO Jupiter Areographic
-<59969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Conformal Conic AUTO Jupiter Areocentric
-<59970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Conformal Conic AUTO Jupiter Areographic
-<59971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Jupiter Areocentric
-<59972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Jupiter Areographic
-<59973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mercator AUTO Jupiter Areocentric
-<59974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mercator AUTO Jupiter Areographic
-<59975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Albers AUTO Jupiter Areocentric
-<59976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Albers AUTO Jupiter Areographic
-<59977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide AUTO Jupiter Areocentric
-<59980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide AUTO Jupiter Areographic
-<59981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson AUTO Jupiter Areocentric
-<59982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson AUTO Jupiter Areographic
-<59983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# GEOGCS Io Areocentric
-<50100> 	+proj=longlat +a=1821460 +b=1821460 +no_defs
-# GEOGCS Io Areographic
-<50101> 	+proj=longlat +a=1821460 +b=1821460 +no_defs
-# Equirectangular Io Areocentric, clon=0
-<50110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Equirectangular Io Areographic, clon=0
-<50111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Equirectangular Io Areocentric, clon=180
-<50112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Equirectangular Io Areographic, clon=180
-<50113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Sinusoidal Io Areocentric, clon=0
-<50114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Sinusoidal Io Areographic, clon=0
-<50115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Sinusoidal Io Areocentric, clon=180
-<50116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Sinusoidal Io Areographic, clon=180
-<50117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# North Polar Io Areocentric, clon=0
-<50118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# North Polar Io Areographic, clon=0
-<50119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# South Polar Io Areocentric, clon=0
-<50120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# South Polar Io Areographic, clon=0
-<50121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mollweide Io Areocentric, clon=0
-<50122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mollweide Io Areographic, clon=0
-<50123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mollweide Io Areocentric, clon=180
-<50124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mollweide Io Areographic, clon=180
-<50125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Robinson Io Areocentric, clon=0
-<50126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Robinson Io Areographic, clon=0
-<50127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Robinson Io Areocentric, clon=180
-<50128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Robinson Io Areographic, clon=180
-<50129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Sinusoidal AUTO Io Areocentric
-<50160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Sinusoidal AUTO Io Areographic
-<50161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Stereographic AUTO Io Areocentric, clon=0
-<50162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Stereographic AUTO Io Areographic, clon=0
-<50163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Transverse Mercator AUTO Io Areocentric
-<50164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Transverse Mercator AUTO Io Areographic
-<50165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Orthographic AUTO Io Areocentric
-<50166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Orthographic AUTO Io Areographic
-<50167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Equidistant Cylindrical AUTO Io Areocentric
-<50168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Equidistant Cylindrical AUTO Io Areographic
-<50169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Lambert Conformal Conic AUTO Io Areocentric
-<50170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Lambert Conformal Conic AUTO Io Areographic
-<50171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Io Areocentric
-<50172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Io Areographic
-<50173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mercator AUTO Io Areocentric
-<50174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mercator AUTO Io Areographic
-<50175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Albers AUTO Io Areocentric
-<50176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Albers AUTO Io Areographic
-<50177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mollweide AUTO Io Areocentric
-<50180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Mollweide AUTO Io Areographic
-<50181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Robinson AUTO Io Areocentric
-<50182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# Robinson AUTO Io Areographic
-<50183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821460 +b=1821460 +units=m +no_defs
-# GEOGCS Europa Areocentric
-<50200> 	+proj=longlat +a=1562090 +b=1562090 +no_defs
-# GEOGCS Europa Areographic
-<50201> 	+proj=longlat +a=1562090 +b=1562090 +no_defs
-# Equirectangular Europa Areocentric, clon=0
-<50210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Equirectangular Europa Areographic, clon=0
-<50211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Equirectangular Europa Areocentric, clon=180
-<50212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Equirectangular Europa Areographic, clon=180
-<50213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Sinusoidal Europa Areocentric, clon=0
-<50214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Sinusoidal Europa Areographic, clon=0
-<50215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Sinusoidal Europa Areocentric, clon=180
-<50216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Sinusoidal Europa Areographic, clon=180
-<50217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# North Polar Europa Areocentric, clon=0
-<50218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# North Polar Europa Areographic, clon=0
-<50219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# South Polar Europa Areocentric, clon=0
-<50220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# South Polar Europa Areographic, clon=0
-<50221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mollweide Europa Areocentric, clon=0
-<50222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mollweide Europa Areographic, clon=0
-<50223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mollweide Europa Areocentric, clon=180
-<50224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mollweide Europa Areographic, clon=180
-<50225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Robinson Europa Areocentric, clon=0
-<50226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Robinson Europa Areographic, clon=0
-<50227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Robinson Europa Areocentric, clon=180
-<50228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Robinson Europa Areographic, clon=180
-<50229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Sinusoidal AUTO Europa Areocentric
-<50260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Sinusoidal AUTO Europa Areographic
-<50261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Stereographic AUTO Europa Areocentric, clon=0
-<50262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Stereographic AUTO Europa Areographic, clon=0
-<50263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Transverse Mercator AUTO Europa Areocentric
-<50264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Transverse Mercator AUTO Europa Areographic
-<50265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Orthographic AUTO Europa Areocentric
-<50266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Orthographic AUTO Europa Areographic
-<50267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Equidistant Cylindrical AUTO Europa Areocentric
-<50268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Equidistant Cylindrical AUTO Europa Areographic
-<50269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Lambert Conformal Conic AUTO Europa Areocentric
-<50270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Lambert Conformal Conic AUTO Europa Areographic
-<50271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Europa Areocentric
-<50272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Europa Areographic
-<50273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mercator AUTO Europa Areocentric
-<50274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mercator AUTO Europa Areographic
-<50275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Albers AUTO Europa Areocentric
-<50276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Albers AUTO Europa Areographic
-<50277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mollweide AUTO Europa Areocentric
-<50280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Mollweide AUTO Europa Areographic
-<50281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Robinson AUTO Europa Areocentric
-<50282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# Robinson AUTO Europa Areographic
-<50283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1562090 +b=1562090 +units=m +no_defs
-# GEOGCS Ganymede Areocentric
-<50300> 	+proj=longlat +a=2632345 +b=2632345 +no_defs
-# GEOGCS Ganymede Areographic
-<50301> 	+proj=longlat +a=2632345 +b=2632345 +no_defs
-# Equirectangular Ganymede Areocentric, clon=0
-<50310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Equirectangular Ganymede Areographic, clon=0
-<50311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Equirectangular Ganymede Areocentric, clon=180
-<50312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Equirectangular Ganymede Areographic, clon=180
-<50313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Sinusoidal Ganymede Areocentric, clon=0
-<50314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Sinusoidal Ganymede Areographic, clon=0
-<50315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Sinusoidal Ganymede Areocentric, clon=180
-<50316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Sinusoidal Ganymede Areographic, clon=180
-<50317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# North Polar Ganymede Areocentric, clon=0
-<50318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# North Polar Ganymede Areographic, clon=0
-<50319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# South Polar Ganymede Areocentric, clon=0
-<50320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# South Polar Ganymede Areographic, clon=0
-<50321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mollweide Ganymede Areocentric, clon=0
-<50322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mollweide Ganymede Areographic, clon=0
-<50323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mollweide Ganymede Areocentric, clon=180
-<50324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mollweide Ganymede Areographic, clon=180
-<50325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Robinson Ganymede Areocentric, clon=0
-<50326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Robinson Ganymede Areographic, clon=0
-<50327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Robinson Ganymede Areocentric, clon=180
-<50328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Robinson Ganymede Areographic, clon=180
-<50329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Sinusoidal AUTO Ganymede Areocentric
-<50360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Sinusoidal AUTO Ganymede Areographic
-<50361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Stereographic AUTO Ganymede Areocentric, clon=0
-<50362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Stereographic AUTO Ganymede Areographic, clon=0
-<50363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Transverse Mercator AUTO Ganymede Areocentric
-<50364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Transverse Mercator AUTO Ganymede Areographic
-<50365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Orthographic AUTO Ganymede Areocentric
-<50366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Orthographic AUTO Ganymede Areographic
-<50367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ganymede Areocentric
-<50368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ganymede Areographic
-<50369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ganymede Areocentric
-<50370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ganymede Areographic
-<50371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ganymede Areocentric
-<50372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ganymede Areographic
-<50373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mercator AUTO Ganymede Areocentric
-<50374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mercator AUTO Ganymede Areographic
-<50375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Albers AUTO Ganymede Areocentric
-<50376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Albers AUTO Ganymede Areographic
-<50377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mollweide AUTO Ganymede Areocentric
-<50380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Mollweide AUTO Ganymede Areographic
-<50381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Robinson AUTO Ganymede Areocentric
-<50382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# Robinson AUTO Ganymede Areographic
-<50383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2632345 +b=2632345 +units=m +no_defs
-# GEOGCS Callisto Areocentric
-<50400> 	+proj=longlat +a=2409300 +b=2409300 +no_defs
-# GEOGCS Callisto Areographic
-<50401> 	+proj=longlat +a=2409300 +b=2409300 +no_defs
-# Equirectangular Callisto Areocentric, clon=0
-<50410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Equirectangular Callisto Areographic, clon=0
-<50411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Equirectangular Callisto Areocentric, clon=180
-<50412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Equirectangular Callisto Areographic, clon=180
-<50413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Sinusoidal Callisto Areocentric, clon=0
-<50414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Sinusoidal Callisto Areographic, clon=0
-<50415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Sinusoidal Callisto Areocentric, clon=180
-<50416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Sinusoidal Callisto Areographic, clon=180
-<50417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# North Polar Callisto Areocentric, clon=0
-<50418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# North Polar Callisto Areographic, clon=0
-<50419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# South Polar Callisto Areocentric, clon=0
-<50420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# South Polar Callisto Areographic, clon=0
-<50421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mollweide Callisto Areocentric, clon=0
-<50422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mollweide Callisto Areographic, clon=0
-<50423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mollweide Callisto Areocentric, clon=180
-<50424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mollweide Callisto Areographic, clon=180
-<50425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Robinson Callisto Areocentric, clon=0
-<50426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Robinson Callisto Areographic, clon=0
-<50427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Robinson Callisto Areocentric, clon=180
-<50428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Robinson Callisto Areographic, clon=180
-<50429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Sinusoidal AUTO Callisto Areocentric
-<50460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Sinusoidal AUTO Callisto Areographic
-<50461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Stereographic AUTO Callisto Areocentric, clon=0
-<50462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Stereographic AUTO Callisto Areographic, clon=0
-<50463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Transverse Mercator AUTO Callisto Areocentric
-<50464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Transverse Mercator AUTO Callisto Areographic
-<50465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Orthographic AUTO Callisto Areocentric
-<50466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Orthographic AUTO Callisto Areographic
-<50467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Callisto Areocentric
-<50468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Callisto Areographic
-<50469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Callisto Areocentric
-<50470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Callisto Areographic
-<50471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Callisto Areocentric
-<50472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Callisto Areographic
-<50473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mercator AUTO Callisto Areocentric
-<50474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mercator AUTO Callisto Areographic
-<50475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Albers AUTO Callisto Areocentric
-<50476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Albers AUTO Callisto Areographic
-<50477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mollweide AUTO Callisto Areocentric
-<50480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Mollweide AUTO Callisto Areographic
-<50481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Robinson AUTO Callisto Areocentric
-<50482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# Robinson AUTO Callisto Areographic
-<50483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2409300 +b=2409300 +units=m +no_defs
-# GEOGCS Amalthea Areocentric
-<50500> 	+proj=longlat +a=83500 +b=83500 +no_defs
-# GEOGCS Amalthea Areographic
-<50501> 	+proj=longlat +a=83500 +b=83500 +no_defs
-# Equirectangular Amalthea Areocentric, clon=0
-<50510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equirectangular Amalthea Areographic, clon=0
-<50511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equirectangular Amalthea Areocentric, clon=180
-<50512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equirectangular Amalthea Areographic, clon=180
-<50513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areocentric, clon=0
-<50514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areographic, clon=0
-<50515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areocentric, clon=180
-<50516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areographic, clon=180
-<50517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# North Polar Amalthea Areocentric, clon=0
-<50518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# North Polar Amalthea Areographic, clon=0
-<50519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# South Polar Amalthea Areocentric, clon=0
-<50520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# South Polar Amalthea Areographic, clon=0
-<50521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areocentric, clon=0
-<50522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areographic, clon=0
-<50523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areocentric, clon=180
-<50524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areographic, clon=180
-<50525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areocentric, clon=0
-<50526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areographic, clon=0
-<50527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areocentric, clon=180
-<50528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areographic, clon=180
-<50529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal AUTO Amalthea Areocentric
-<50560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal AUTO Amalthea Areographic
-<50561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Stereographic AUTO Amalthea Areocentric, clon=0
-<50562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Stereographic AUTO Amalthea Areographic, clon=0
-<50563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Transverse Mercator AUTO Amalthea Areocentric
-<50564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Transverse Mercator AUTO Amalthea Areographic
-<50565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Orthographic AUTO Amalthea Areocentric
-<50566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Orthographic AUTO Amalthea Areographic
-<50567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Amalthea Areocentric
-<50568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Amalthea Areographic
-<50569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Amalthea Areocentric
-<50570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Amalthea Areographic
-<50571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Amalthea Areocentric
-<50572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Amalthea Areographic
-<50573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mercator AUTO Amalthea Areocentric
-<50574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mercator AUTO Amalthea Areographic
-<50575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Albers AUTO Amalthea Areocentric
-<50576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Albers AUTO Amalthea Areographic
-<50577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide AUTO Amalthea Areocentric
-<50580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide AUTO Amalthea Areographic
-<50581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson AUTO Amalthea Areocentric
-<50582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson AUTO Amalthea Areographic
-<50583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# GEOGCS Himalia Areocentric
-<50600> 	+proj=longlat +a=85000 +b=85000 +no_defs
-# GEOGCS Himalia Areographic
-<50601> 	+proj=longlat +a=85000 +b=85000 +no_defs
-# Equirectangular Himalia Areocentric, clon=0
-<50610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equirectangular Himalia Areographic, clon=0
-<50611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equirectangular Himalia Areocentric, clon=180
-<50612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equirectangular Himalia Areographic, clon=180
-<50613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areocentric, clon=0
-<50614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areographic, clon=0
-<50615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areocentric, clon=180
-<50616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areographic, clon=180
-<50617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# North Polar Himalia Areocentric, clon=0
-<50618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# North Polar Himalia Areographic, clon=0
-<50619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# South Polar Himalia Areocentric, clon=0
-<50620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# South Polar Himalia Areographic, clon=0
-<50621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areocentric, clon=0
-<50622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areographic, clon=0
-<50623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areocentric, clon=180
-<50624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areographic, clon=180
-<50625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areocentric, clon=0
-<50626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areographic, clon=0
-<50627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areocentric, clon=180
-<50628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areographic, clon=180
-<50629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal AUTO Himalia Areocentric
-<50660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal AUTO Himalia Areographic
-<50661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Stereographic AUTO Himalia Areocentric, clon=0
-<50662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Stereographic AUTO Himalia Areographic, clon=0
-<50663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Transverse Mercator AUTO Himalia Areocentric
-<50664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Transverse Mercator AUTO Himalia Areographic
-<50665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Orthographic AUTO Himalia Areocentric
-<50666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Orthographic AUTO Himalia Areographic
-<50667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Himalia Areocentric
-<50668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Himalia Areographic
-<50669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Himalia Areocentric
-<50670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Himalia Areographic
-<50671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Himalia Areocentric
-<50672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Himalia Areographic
-<50673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mercator AUTO Himalia Areocentric
-<50674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mercator AUTO Himalia Areographic
-<50675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Albers AUTO Himalia Areocentric
-<50676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Albers AUTO Himalia Areographic
-<50677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide AUTO Himalia Areocentric
-<50680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide AUTO Himalia Areographic
-<50681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson AUTO Himalia Areocentric
-<50682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson AUTO Himalia Areographic
-<50683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# GEOGCS Elara Areocentric
-<50700> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# GEOGCS Elara Areographic
-<50701> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# Equirectangular Elara Areocentric, clon=0
-<50710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Elara Areographic, clon=0
-<50711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Elara Areocentric, clon=180
-<50712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Elara Areographic, clon=180
-<50713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areocentric, clon=0
-<50714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areographic, clon=0
-<50715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areocentric, clon=180
-<50716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areographic, clon=180
-<50717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Elara Areocentric, clon=0
-<50718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Elara Areographic, clon=0
-<50719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Elara Areocentric, clon=0
-<50720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Elara Areographic, clon=0
-<50721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areocentric, clon=0
-<50722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areographic, clon=0
-<50723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areocentric, clon=180
-<50724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areographic, clon=180
-<50725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areocentric, clon=0
-<50726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areographic, clon=0
-<50727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areocentric, clon=180
-<50728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areographic, clon=180
-<50729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Elara Areocentric
-<50760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Elara Areographic
-<50761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Elara Areocentric, clon=0
-<50762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Elara Areographic, clon=0
-<50763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Elara Areocentric
-<50764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Elara Areographic
-<50765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Elara Areocentric
-<50766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Elara Areographic
-<50767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Elara Areocentric
-<50768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Elara Areographic
-<50769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Elara Areocentric
-<50770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Elara Areographic
-<50771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Elara Areocentric
-<50772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Elara Areographic
-<50773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Elara Areocentric
-<50774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Elara Areographic
-<50775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Elara Areocentric
-<50776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Elara Areographic
-<50777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Elara Areocentric
-<50780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Elara Areographic
-<50781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Elara Areocentric
-<50782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Elara Areographic
-<50783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# GEOGCS Pasiphae Areocentric
-<50800> 	+proj=longlat +a=18000 +b=18000 +no_defs
-# GEOGCS Pasiphae Areographic
-<50801> 	+proj=longlat +a=18000 +b=18000 +no_defs
-# Equirectangular Pasiphae Areocentric, clon=0
-<50810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equirectangular Pasiphae Areographic, clon=0
-<50811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equirectangular Pasiphae Areocentric, clon=180
-<50812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equirectangular Pasiphae Areographic, clon=180
-<50813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areocentric, clon=0
-<50814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areographic, clon=0
-<50815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areocentric, clon=180
-<50816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areographic, clon=180
-<50817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# North Polar Pasiphae Areocentric, clon=0
-<50818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# North Polar Pasiphae Areographic, clon=0
-<50819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# South Polar Pasiphae Areocentric, clon=0
-<50820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# South Polar Pasiphae Areographic, clon=0
-<50821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areocentric, clon=0
-<50822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areographic, clon=0
-<50823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areocentric, clon=180
-<50824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areographic, clon=180
-<50825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areocentric, clon=0
-<50826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areographic, clon=0
-<50827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areocentric, clon=180
-<50828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areographic, clon=180
-<50829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal AUTO Pasiphae Areocentric
-<50860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal AUTO Pasiphae Areographic
-<50861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Stereographic AUTO Pasiphae Areocentric, clon=0
-<50862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Stereographic AUTO Pasiphae Areographic, clon=0
-<50863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Transverse Mercator AUTO Pasiphae Areocentric
-<50864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Transverse Mercator AUTO Pasiphae Areographic
-<50865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Orthographic AUTO Pasiphae Areocentric
-<50866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Orthographic AUTO Pasiphae Areographic
-<50867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pasiphae Areocentric
-<50868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pasiphae Areographic
-<50869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pasiphae Areocentric
-<50870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pasiphae Areographic
-<50871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pasiphae Areocentric
-<50872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pasiphae Areographic
-<50873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mercator AUTO Pasiphae Areocentric
-<50874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mercator AUTO Pasiphae Areographic
-<50875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Albers AUTO Pasiphae Areocentric
-<50876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Albers AUTO Pasiphae Areographic
-<50877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide AUTO Pasiphae Areocentric
-<50880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide AUTO Pasiphae Areographic
-<50881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson AUTO Pasiphae Areocentric
-<50882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson AUTO Pasiphae Areographic
-<50883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# GEOGCS Sinope Areocentric
-<50900> 	+proj=longlat +a=14000 +b=14000 +no_defs
-# GEOGCS Sinope Areographic
-<50901> 	+proj=longlat +a=14000 +b=14000 +no_defs
-# Equirectangular Sinope Areocentric, clon=0
-<50910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equirectangular Sinope Areographic, clon=0
-<50911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equirectangular Sinope Areocentric, clon=180
-<50912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equirectangular Sinope Areographic, clon=180
-<50913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areocentric, clon=0
-<50914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areographic, clon=0
-<50915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areocentric, clon=180
-<50916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areographic, clon=180
-<50917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# North Polar Sinope Areocentric, clon=0
-<50918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# North Polar Sinope Areographic, clon=0
-<50919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# South Polar Sinope Areocentric, clon=0
-<50920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# South Polar Sinope Areographic, clon=0
-<50921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areocentric, clon=0
-<50922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areographic, clon=0
-<50923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areocentric, clon=180
-<50924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areographic, clon=180
-<50925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areocentric, clon=0
-<50926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areographic, clon=0
-<50927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areocentric, clon=180
-<50928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areographic, clon=180
-<50929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal AUTO Sinope Areocentric
-<50960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal AUTO Sinope Areographic
-<50961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Stereographic AUTO Sinope Areocentric, clon=0
-<50962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Stereographic AUTO Sinope Areographic, clon=0
-<50963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Transverse Mercator AUTO Sinope Areocentric
-<50964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Transverse Mercator AUTO Sinope Areographic
-<50965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Orthographic AUTO Sinope Areocentric
-<50966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Orthographic AUTO Sinope Areographic
-<50967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Sinope Areocentric
-<50968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Sinope Areographic
-<50969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Sinope Areocentric
-<50970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Sinope Areographic
-<50971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Sinope Areocentric
-<50972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Sinope Areographic
-<50973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mercator AUTO Sinope Areocentric
-<50974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mercator AUTO Sinope Areographic
-<50975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Albers AUTO Sinope Areocentric
-<50976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Albers AUTO Sinope Areographic
-<50977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide AUTO Sinope Areocentric
-<50980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide AUTO Sinope Areographic
-<50981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson AUTO Sinope Areocentric
-<50982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson AUTO Sinope Areographic
-<50983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# GEOGCS Lysithea Areocentric
-<51000> 	+proj=longlat +a=12000 +b=12000 +no_defs
-# GEOGCS Lysithea Areographic
-<51001> 	+proj=longlat +a=12000 +b=12000 +no_defs
-# Equirectangular Lysithea Areocentric, clon=0
-<51010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equirectangular Lysithea Areographic, clon=0
-<51011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equirectangular Lysithea Areocentric, clon=180
-<51012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equirectangular Lysithea Areographic, clon=180
-<51013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areocentric, clon=0
-<51014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areographic, clon=0
-<51015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areocentric, clon=180
-<51016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areographic, clon=180
-<51017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# North Polar Lysithea Areocentric, clon=0
-<51018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# North Polar Lysithea Areographic, clon=0
-<51019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# South Polar Lysithea Areocentric, clon=0
-<51020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# South Polar Lysithea Areographic, clon=0
-<51021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areocentric, clon=0
-<51022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areographic, clon=0
-<51023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areocentric, clon=180
-<51024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areographic, clon=180
-<51025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areocentric, clon=0
-<51026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areographic, clon=0
-<51027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areocentric, clon=180
-<51028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areographic, clon=180
-<51029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal AUTO Lysithea Areocentric
-<51060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal AUTO Lysithea Areographic
-<51061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Stereographic AUTO Lysithea Areocentric, clon=0
-<51062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Stereographic AUTO Lysithea Areographic, clon=0
-<51063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Transverse Mercator AUTO Lysithea Areocentric
-<51064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Transverse Mercator AUTO Lysithea Areographic
-<51065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Orthographic AUTO Lysithea Areocentric
-<51066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Orthographic AUTO Lysithea Areographic
-<51067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lysithea Areocentric
-<51068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lysithea Areographic
-<51069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lysithea Areocentric
-<51070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lysithea Areographic
-<51071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lysithea Areocentric
-<51072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lysithea Areographic
-<51073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mercator AUTO Lysithea Areocentric
-<51074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mercator AUTO Lysithea Areographic
-<51075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Albers AUTO Lysithea Areocentric
-<51076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Albers AUTO Lysithea Areographic
-<51077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide AUTO Lysithea Areocentric
-<51080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide AUTO Lysithea Areographic
-<51081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson AUTO Lysithea Areocentric
-<51082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson AUTO Lysithea Areographic
-<51083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# GEOGCS Carme Areocentric
-<51100> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# GEOGCS Carme Areographic
-<51101> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# Equirectangular Carme Areocentric, clon=0
-<51110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Carme Areographic, clon=0
-<51111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Carme Areocentric, clon=180
-<51112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Carme Areographic, clon=180
-<51113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areocentric, clon=0
-<51114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areographic, clon=0
-<51115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areocentric, clon=180
-<51116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areographic, clon=180
-<51117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Carme Areocentric, clon=0
-<51118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Carme Areographic, clon=0
-<51119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Carme Areocentric, clon=0
-<51120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Carme Areographic, clon=0
-<51121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areocentric, clon=0
-<51122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areographic, clon=0
-<51123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areocentric, clon=180
-<51124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areographic, clon=180
-<51125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areocentric, clon=0
-<51126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areographic, clon=0
-<51127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areocentric, clon=180
-<51128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areographic, clon=180
-<51129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Carme Areocentric
-<51160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Carme Areographic
-<51161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Carme Areocentric, clon=0
-<51162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Carme Areographic, clon=0
-<51163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Carme Areocentric
-<51164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Carme Areographic
-<51165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Carme Areocentric
-<51166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Carme Areographic
-<51167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Carme Areocentric
-<51168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Carme Areographic
-<51169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Carme Areocentric
-<51170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Carme Areographic
-<51171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Carme Areocentric
-<51172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Carme Areographic
-<51173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Carme Areocentric
-<51174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Carme Areographic
-<51175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Carme Areocentric
-<51176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Carme Areographic
-<51177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Carme Areocentric
-<51180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Carme Areographic
-<51181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Carme Areocentric
-<51182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Carme Areographic
-<51183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# GEOGCS Ananke Areocentric
-<51200> 	+proj=longlat +a=10000 +b=10000 +no_defs
-# GEOGCS Ananke Areographic
-<51201> 	+proj=longlat +a=10000 +b=10000 +no_defs
-# Equirectangular Ananke Areocentric, clon=0
-<51210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Ananke Areographic, clon=0
-<51211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Ananke Areocentric, clon=180
-<51212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Ananke Areographic, clon=180
-<51213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areocentric, clon=0
-<51214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areographic, clon=0
-<51215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areocentric, clon=180
-<51216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areographic, clon=180
-<51217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# North Polar Ananke Areocentric, clon=0
-<51218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# North Polar Ananke Areographic, clon=0
-<51219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# South Polar Ananke Areocentric, clon=0
-<51220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# South Polar Ananke Areographic, clon=0
-<51221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areocentric, clon=0
-<51222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areographic, clon=0
-<51223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areocentric, clon=180
-<51224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areographic, clon=180
-<51225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areocentric, clon=0
-<51226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areographic, clon=0
-<51227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areocentric, clon=180
-<51228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areographic, clon=180
-<51229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal AUTO Ananke Areocentric
-<51260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal AUTO Ananke Areographic
-<51261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Stereographic AUTO Ananke Areocentric, clon=0
-<51262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Stereographic AUTO Ananke Areographic, clon=0
-<51263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Transverse Mercator AUTO Ananke Areocentric
-<51264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Transverse Mercator AUTO Ananke Areographic
-<51265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Orthographic AUTO Ananke Areocentric
-<51266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Orthographic AUTO Ananke Areographic
-<51267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ananke Areocentric
-<51268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ananke Areographic
-<51269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ananke Areocentric
-<51270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ananke Areographic
-<51271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ananke Areocentric
-<51272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ananke Areographic
-<51273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mercator AUTO Ananke Areocentric
-<51274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mercator AUTO Ananke Areographic
-<51275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Albers AUTO Ananke Areocentric
-<51276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Albers AUTO Ananke Areographic
-<51277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide AUTO Ananke Areocentric
-<51280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide AUTO Ananke Areographic
-<51281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson AUTO Ananke Areocentric
-<51282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson AUTO Ananke Areographic
-<51283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# GEOGCS Leda Areocentric
-<51300> 	+proj=longlat +a=5000 +b=5000 +no_defs
-# GEOGCS Leda Areographic
-<51301> 	+proj=longlat +a=5000 +b=5000 +no_defs
-# Equirectangular Leda Areocentric, clon=0
-<51310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equirectangular Leda Areographic, clon=0
-<51311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equirectangular Leda Areocentric, clon=180
-<51312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equirectangular Leda Areographic, clon=180
-<51313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areocentric, clon=0
-<51314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areographic, clon=0
-<51315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areocentric, clon=180
-<51316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areographic, clon=180
-<51317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# North Polar Leda Areocentric, clon=0
-<51318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# North Polar Leda Areographic, clon=0
-<51319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# South Polar Leda Areocentric, clon=0
-<51320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# South Polar Leda Areographic, clon=0
-<51321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areocentric, clon=0
-<51322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areographic, clon=0
-<51323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areocentric, clon=180
-<51324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areographic, clon=180
-<51325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areocentric, clon=0
-<51326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areographic, clon=0
-<51327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areocentric, clon=180
-<51328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areographic, clon=180
-<51329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal AUTO Leda Areocentric
-<51360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal AUTO Leda Areographic
-<51361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Stereographic AUTO Leda Areocentric, clon=0
-<51362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Stereographic AUTO Leda Areographic, clon=0
-<51363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Transverse Mercator AUTO Leda Areocentric
-<51364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Transverse Mercator AUTO Leda Areographic
-<51365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Orthographic AUTO Leda Areocentric
-<51366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Orthographic AUTO Leda Areographic
-<51367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Leda Areocentric
-<51368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Leda Areographic
-<51369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Leda Areocentric
-<51370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Leda Areographic
-<51371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Leda Areocentric
-<51372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Leda Areographic
-<51373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mercator AUTO Leda Areocentric
-<51374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mercator AUTO Leda Areographic
-<51375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Albers AUTO Leda Areocentric
-<51376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Albers AUTO Leda Areographic
-<51377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide AUTO Leda Areocentric
-<51380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide AUTO Leda Areographic
-<51381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson AUTO Leda Areocentric
-<51382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson AUTO Leda Areographic
-<51383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# GEOGCS Thebe Areocentric
-<51400> 	+proj=longlat +a=49300 +b=49300 +no_defs
-# GEOGCS Thebe Areographic
-<51401> 	+proj=longlat +a=49300 +b=49300 +no_defs
-# Equirectangular Thebe Areocentric, clon=0
-<51410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equirectangular Thebe Areographic, clon=0
-<51411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equirectangular Thebe Areocentric, clon=180
-<51412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equirectangular Thebe Areographic, clon=180
-<51413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areocentric, clon=0
-<51414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areographic, clon=0
-<51415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areocentric, clon=180
-<51416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areographic, clon=180
-<51417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# North Polar Thebe Areocentric, clon=0
-<51418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# North Polar Thebe Areographic, clon=0
-<51419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# South Polar Thebe Areocentric, clon=0
-<51420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# South Polar Thebe Areographic, clon=0
-<51421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areocentric, clon=0
-<51422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areographic, clon=0
-<51423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areocentric, clon=180
-<51424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areographic, clon=180
-<51425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areocentric, clon=0
-<51426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areographic, clon=0
-<51427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areocentric, clon=180
-<51428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areographic, clon=180
-<51429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal AUTO Thebe Areocentric
-<51460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal AUTO Thebe Areographic
-<51461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Stereographic AUTO Thebe Areocentric, clon=0
-<51462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Stereographic AUTO Thebe Areographic, clon=0
-<51463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Transverse Mercator AUTO Thebe Areocentric
-<51464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Transverse Mercator AUTO Thebe Areographic
-<51465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Orthographic AUTO Thebe Areocentric
-<51466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Orthographic AUTO Thebe Areographic
-<51467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thebe Areocentric
-<51468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thebe Areographic
-<51469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thebe Areocentric
-<51470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thebe Areographic
-<51471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thebe Areocentric
-<51472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thebe Areographic
-<51473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mercator AUTO Thebe Areocentric
-<51474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mercator AUTO Thebe Areographic
-<51475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Albers AUTO Thebe Areocentric
-<51476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Albers AUTO Thebe Areographic
-<51477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide AUTO Thebe Areocentric
-<51480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide AUTO Thebe Areographic
-<51481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson AUTO Thebe Areocentric
-<51482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson AUTO Thebe Areographic
-<51483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# GEOGCS Adrastea Areocentric
-<51500> 	+proj=longlat +a=8200 +b=8200 +no_defs
-# GEOGCS Adrastea Areographic
-<51501> 	+proj=longlat +a=8200 +b=8200 +no_defs
-# Equirectangular Adrastea Areocentric, clon=0
-<51510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equirectangular Adrastea Areographic, clon=0
-<51511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equirectangular Adrastea Areocentric, clon=180
-<51512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equirectangular Adrastea Areographic, clon=180
-<51513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areocentric, clon=0
-<51514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areographic, clon=0
-<51515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areocentric, clon=180
-<51516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areographic, clon=180
-<51517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# North Polar Adrastea Areocentric, clon=0
-<51518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# North Polar Adrastea Areographic, clon=0
-<51519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# South Polar Adrastea Areocentric, clon=0
-<51520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# South Polar Adrastea Areographic, clon=0
-<51521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areocentric, clon=0
-<51522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areographic, clon=0
-<51523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areocentric, clon=180
-<51524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areographic, clon=180
-<51525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areocentric, clon=0
-<51526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areographic, clon=0
-<51527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areocentric, clon=180
-<51528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areographic, clon=180
-<51529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal AUTO Adrastea Areocentric
-<51560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal AUTO Adrastea Areographic
-<51561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Stereographic AUTO Adrastea Areocentric, clon=0
-<51562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Stereographic AUTO Adrastea Areographic, clon=0
-<51563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Transverse Mercator AUTO Adrastea Areocentric
-<51564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Transverse Mercator AUTO Adrastea Areographic
-<51565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Orthographic AUTO Adrastea Areocentric
-<51566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Orthographic AUTO Adrastea Areographic
-<51567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Adrastea Areocentric
-<51568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Adrastea Areographic
-<51569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Adrastea Areocentric
-<51570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Adrastea Areographic
-<51571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Adrastea Areocentric
-<51572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Adrastea Areographic
-<51573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mercator AUTO Adrastea Areocentric
-<51574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mercator AUTO Adrastea Areographic
-<51575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Albers AUTO Adrastea Areocentric
-<51576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Albers AUTO Adrastea Areographic
-<51577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide AUTO Adrastea Areocentric
-<51580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide AUTO Adrastea Areographic
-<51581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson AUTO Adrastea Areocentric
-<51582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson AUTO Adrastea Areographic
-<51583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# GEOGCS Metis Areocentric
-<51600> 	+proj=longlat +a=21500 +b=21500 +no_defs
-# GEOGCS Metis Areographic
-<51601> 	+proj=longlat +a=21500 +b=21500 +no_defs
-# Equirectangular Metis Areocentric, clon=0
-<51610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equirectangular Metis Areographic, clon=0
-<51611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equirectangular Metis Areocentric, clon=180
-<51612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equirectangular Metis Areographic, clon=180
-<51613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areocentric, clon=0
-<51614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areographic, clon=0
-<51615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areocentric, clon=180
-<51616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areographic, clon=180
-<51617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# North Polar Metis Areocentric, clon=0
-<51618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# North Polar Metis Areographic, clon=0
-<51619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# South Polar Metis Areocentric, clon=0
-<51620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# South Polar Metis Areographic, clon=0
-<51621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areocentric, clon=0
-<51622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areographic, clon=0
-<51623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areocentric, clon=180
-<51624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areographic, clon=180
-<51625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areocentric, clon=0
-<51626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areographic, clon=0
-<51627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areocentric, clon=180
-<51628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areographic, clon=180
-<51629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal AUTO Metis Areocentric
-<51660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal AUTO Metis Areographic
-<51661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Stereographic AUTO Metis Areocentric, clon=0
-<51662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Stereographic AUTO Metis Areographic, clon=0
-<51663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Transverse Mercator AUTO Metis Areocentric
-<51664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Transverse Mercator AUTO Metis Areographic
-<51665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Orthographic AUTO Metis Areocentric
-<51666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Orthographic AUTO Metis Areographic
-<51667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Metis Areocentric
-<51668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Metis Areographic
-<51669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Metis Areocentric
-<51670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Metis Areographic
-<51671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Metis Areocentric
-<51672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Metis Areographic
-<51673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mercator AUTO Metis Areocentric
-<51674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mercator AUTO Metis Areographic
-<51675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Albers AUTO Metis Areocentric
-<51676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Albers AUTO Metis Areographic
-<51677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide AUTO Metis Areocentric
-<51680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide AUTO Metis Areographic
-<51681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson AUTO Metis Areocentric
-<51682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson AUTO Metis Areographic
-<51683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# GEOGCS Saturn Areocentric
-<69900> 	+proj=longlat +a=60268000 +b=-554950145.8116413 +no_defs
-# GEOGCS Saturn Areographic
-<69901> 	+proj=longlat +a=60268000 +b=-554950145.8116413 +no_defs
-# Equirectangular Saturn Areocentric, clon=0
-<69910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equirectangular Saturn Areographic, clon=0
-<69911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equirectangular Saturn Areocentric, clon=180
-<69912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equirectangular Saturn Areographic, clon=180
-<69913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areocentric, clon=0
-<69914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areographic, clon=0
-<69915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areocentric, clon=180
-<69916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areographic, clon=180
-<69917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# North Polar Saturn Areocentric, clon=0
-<69918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# North Polar Saturn Areographic, clon=0
-<69919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# South Polar Saturn Areocentric, clon=0
-<69920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# South Polar Saturn Areographic, clon=0
-<69921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areocentric, clon=0
-<69922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areographic, clon=0
-<69923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areocentric, clon=180
-<69924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areographic, clon=180
-<69925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areocentric, clon=0
-<69926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areographic, clon=0
-<69927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areocentric, clon=180
-<69928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areographic, clon=180
-<69929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal AUTO Saturn Areocentric
-<69960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal AUTO Saturn Areographic
-<69961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Stereographic AUTO Saturn Areocentric, clon=0
-<69962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Stereographic AUTO Saturn Areographic, clon=0
-<69963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Transverse Mercator AUTO Saturn Areocentric
-<69964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Transverse Mercator AUTO Saturn Areographic
-<69965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Orthographic AUTO Saturn Areocentric
-<69966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Orthographic AUTO Saturn Areographic
-<69967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equidistant Cylindrical AUTO Saturn Areocentric
-<69968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equidistant Cylindrical AUTO Saturn Areographic
-<69969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Conformal Conic AUTO Saturn Areocentric
-<69970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Conformal Conic AUTO Saturn Areographic
-<69971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Saturn Areocentric
-<69972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Saturn Areographic
-<69973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mercator AUTO Saturn Areocentric
-<69974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mercator AUTO Saturn Areographic
-<69975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Albers AUTO Saturn Areocentric
-<69976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Albers AUTO Saturn Areographic
-<69977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide AUTO Saturn Areocentric
-<69980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide AUTO Saturn Areographic
-<69981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson AUTO Saturn Areocentric
-<69982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson AUTO Saturn Areographic
-<69983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# GEOGCS Mimas Areocentric
-<60100> 	+proj=longlat +a=198600 +b=198600 +no_defs
-# GEOGCS Mimas Areographic
-<60101> 	+proj=longlat +a=198600 +b=198600 +no_defs
-# Equirectangular Mimas Areocentric, clon=0
-<60110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Equirectangular Mimas Areographic, clon=0
-<60111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Equirectangular Mimas Areocentric, clon=180
-<60112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Equirectangular Mimas Areographic, clon=180
-<60113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Sinusoidal Mimas Areocentric, clon=0
-<60114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Sinusoidal Mimas Areographic, clon=0
-<60115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Sinusoidal Mimas Areocentric, clon=180
-<60116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Sinusoidal Mimas Areographic, clon=180
-<60117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# North Polar Mimas Areocentric, clon=0
-<60118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# North Polar Mimas Areographic, clon=0
-<60119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# South Polar Mimas Areocentric, clon=0
-<60120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# South Polar Mimas Areographic, clon=0
-<60121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mollweide Mimas Areocentric, clon=0
-<60122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mollweide Mimas Areographic, clon=0
-<60123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mollweide Mimas Areocentric, clon=180
-<60124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mollweide Mimas Areographic, clon=180
-<60125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Robinson Mimas Areocentric, clon=0
-<60126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Robinson Mimas Areographic, clon=0
-<60127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Robinson Mimas Areocentric, clon=180
-<60128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Robinson Mimas Areographic, clon=180
-<60129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Sinusoidal AUTO Mimas Areocentric
-<60160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Sinusoidal AUTO Mimas Areographic
-<60161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Stereographic AUTO Mimas Areocentric, clon=0
-<60162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Stereographic AUTO Mimas Areographic, clon=0
-<60163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Transverse Mercator AUTO Mimas Areocentric
-<60164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Transverse Mercator AUTO Mimas Areographic
-<60165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Orthographic AUTO Mimas Areocentric
-<60166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Orthographic AUTO Mimas Areographic
-<60167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mimas Areocentric
-<60168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mimas Areographic
-<60169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mimas Areocentric
-<60170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mimas Areographic
-<60171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mimas Areocentric
-<60172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mimas Areographic
-<60173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mercator AUTO Mimas Areocentric
-<60174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mercator AUTO Mimas Areographic
-<60175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Albers AUTO Mimas Areocentric
-<60176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Albers AUTO Mimas Areographic
-<60177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mollweide AUTO Mimas Areocentric
-<60180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Mollweide AUTO Mimas Areographic
-<60181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Robinson AUTO Mimas Areocentric
-<60182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# Robinson AUTO Mimas Areographic
-<60183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198600 +b=198600 +units=m +no_defs
-# GEOGCS Enceladus Areocentric
-<60200> 	+proj=longlat +a=249400 +b=249400 +no_defs
-# GEOGCS Enceladus Areographic
-<60201> 	+proj=longlat +a=249400 +b=249400 +no_defs
-# Equirectangular Enceladus Areocentric, clon=0
-<60210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Equirectangular Enceladus Areographic, clon=0
-<60211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Equirectangular Enceladus Areocentric, clon=180
-<60212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Equirectangular Enceladus Areographic, clon=180
-<60213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Sinusoidal Enceladus Areocentric, clon=0
-<60214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Sinusoidal Enceladus Areographic, clon=0
-<60215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Sinusoidal Enceladus Areocentric, clon=180
-<60216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Sinusoidal Enceladus Areographic, clon=180
-<60217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# North Polar Enceladus Areocentric, clon=0
-<60218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# North Polar Enceladus Areographic, clon=0
-<60219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# South Polar Enceladus Areocentric, clon=0
-<60220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# South Polar Enceladus Areographic, clon=0
-<60221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mollweide Enceladus Areocentric, clon=0
-<60222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mollweide Enceladus Areographic, clon=0
-<60223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mollweide Enceladus Areocentric, clon=180
-<60224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mollweide Enceladus Areographic, clon=180
-<60225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Robinson Enceladus Areocentric, clon=0
-<60226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Robinson Enceladus Areographic, clon=0
-<60227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Robinson Enceladus Areocentric, clon=180
-<60228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Robinson Enceladus Areographic, clon=180
-<60229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Sinusoidal AUTO Enceladus Areocentric
-<60260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Sinusoidal AUTO Enceladus Areographic
-<60261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Stereographic AUTO Enceladus Areocentric, clon=0
-<60262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Stereographic AUTO Enceladus Areographic, clon=0
-<60263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Transverse Mercator AUTO Enceladus Areocentric
-<60264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Transverse Mercator AUTO Enceladus Areographic
-<60265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Orthographic AUTO Enceladus Areocentric
-<60266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Orthographic AUTO Enceladus Areographic
-<60267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Enceladus Areocentric
-<60268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Enceladus Areographic
-<60269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Enceladus Areocentric
-<60270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Enceladus Areographic
-<60271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Enceladus Areocentric
-<60272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Enceladus Areographic
-<60273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mercator AUTO Enceladus Areocentric
-<60274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mercator AUTO Enceladus Areographic
-<60275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Albers AUTO Enceladus Areocentric
-<60276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Albers AUTO Enceladus Areographic
-<60277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mollweide AUTO Enceladus Areocentric
-<60280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Mollweide AUTO Enceladus Areographic
-<60281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Robinson AUTO Enceladus Areocentric
-<60282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# Robinson AUTO Enceladus Areographic
-<60283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=249400 +b=249400 +units=m +no_defs
-# GEOGCS Tethys Areocentric
-<60300> 	+proj=longlat +a=529800 +b=529800 +no_defs
-# GEOGCS Tethys Areographic
-<60301> 	+proj=longlat +a=529800 +b=529800 +no_defs
-# Equirectangular Tethys Areocentric, clon=0
-<60310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Equirectangular Tethys Areographic, clon=0
-<60311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Equirectangular Tethys Areocentric, clon=180
-<60312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Equirectangular Tethys Areographic, clon=180
-<60313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Sinusoidal Tethys Areocentric, clon=0
-<60314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Sinusoidal Tethys Areographic, clon=0
-<60315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Sinusoidal Tethys Areocentric, clon=180
-<60316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Sinusoidal Tethys Areographic, clon=180
-<60317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# North Polar Tethys Areocentric, clon=0
-<60318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# North Polar Tethys Areographic, clon=0
-<60319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# South Polar Tethys Areocentric, clon=0
-<60320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# South Polar Tethys Areographic, clon=0
-<60321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mollweide Tethys Areocentric, clon=0
-<60322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mollweide Tethys Areographic, clon=0
-<60323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mollweide Tethys Areocentric, clon=180
-<60324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mollweide Tethys Areographic, clon=180
-<60325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Robinson Tethys Areocentric, clon=0
-<60326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Robinson Tethys Areographic, clon=0
-<60327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Robinson Tethys Areocentric, clon=180
-<60328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Robinson Tethys Areographic, clon=180
-<60329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Sinusoidal AUTO Tethys Areocentric
-<60360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Sinusoidal AUTO Tethys Areographic
-<60361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Stereographic AUTO Tethys Areocentric, clon=0
-<60362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Stereographic AUTO Tethys Areographic, clon=0
-<60363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Transverse Mercator AUTO Tethys Areocentric
-<60364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Transverse Mercator AUTO Tethys Areographic
-<60365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Orthographic AUTO Tethys Areocentric
-<60366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Orthographic AUTO Tethys Areographic
-<60367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Tethys Areocentric
-<60368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Tethys Areographic
-<60369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Tethys Areocentric
-<60370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Tethys Areographic
-<60371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Tethys Areocentric
-<60372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Tethys Areographic
-<60373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mercator AUTO Tethys Areocentric
-<60374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mercator AUTO Tethys Areographic
-<60375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Albers AUTO Tethys Areocentric
-<60376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Albers AUTO Tethys Areographic
-<60377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mollweide AUTO Tethys Areocentric
-<60380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Mollweide AUTO Tethys Areographic
-<60381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Robinson AUTO Tethys Areocentric
-<60382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# Robinson AUTO Tethys Areographic
-<60383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=529800 +b=529800 +units=m +no_defs
-# GEOGCS Dione Areocentric
-<60400> 	+proj=longlat +a=560000 +b=560000 +no_defs
-# GEOGCS Dione Areographic
-<60401> 	+proj=longlat +a=560000 +b=560000 +no_defs
-# Equirectangular Dione Areocentric, clon=0
-<60410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Equirectangular Dione Areographic, clon=0
-<60411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Equirectangular Dione Areocentric, clon=180
-<60412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Equirectangular Dione Areographic, clon=180
-<60413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Sinusoidal Dione Areocentric, clon=0
-<60414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Sinusoidal Dione Areographic, clon=0
-<60415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Sinusoidal Dione Areocentric, clon=180
-<60416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Sinusoidal Dione Areographic, clon=180
-<60417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# North Polar Dione Areocentric, clon=0
-<60418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# North Polar Dione Areographic, clon=0
-<60419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# South Polar Dione Areocentric, clon=0
-<60420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# South Polar Dione Areographic, clon=0
-<60421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mollweide Dione Areocentric, clon=0
-<60422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mollweide Dione Areographic, clon=0
-<60423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mollweide Dione Areocentric, clon=180
-<60424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mollweide Dione Areographic, clon=180
-<60425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Robinson Dione Areocentric, clon=0
-<60426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Robinson Dione Areographic, clon=0
-<60427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Robinson Dione Areocentric, clon=180
-<60428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Robinson Dione Areographic, clon=180
-<60429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Sinusoidal AUTO Dione Areocentric
-<60460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Sinusoidal AUTO Dione Areographic
-<60461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Stereographic AUTO Dione Areocentric, clon=0
-<60462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Stereographic AUTO Dione Areographic, clon=0
-<60463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Transverse Mercator AUTO Dione Areocentric
-<60464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Transverse Mercator AUTO Dione Areographic
-<60465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Orthographic AUTO Dione Areocentric
-<60466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Orthographic AUTO Dione Areographic
-<60467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Dione Areocentric
-<60468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Dione Areographic
-<60469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Dione Areocentric
-<60470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Dione Areographic
-<60471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Dione Areocentric
-<60472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Dione Areographic
-<60473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mercator AUTO Dione Areocentric
-<60474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mercator AUTO Dione Areographic
-<60475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Albers AUTO Dione Areocentric
-<60476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Albers AUTO Dione Areographic
-<60477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mollweide AUTO Dione Areocentric
-<60480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Mollweide AUTO Dione Areographic
-<60481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Robinson AUTO Dione Areocentric
-<60482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# Robinson AUTO Dione Areographic
-<60483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=560000 +b=560000 +units=m +no_defs
-# GEOGCS Rhea Areocentric
-<60500> 	+proj=longlat +a=764000 +b=764000 +no_defs
-# GEOGCS Rhea Areographic
-<60501> 	+proj=longlat +a=764000 +b=764000 +no_defs
-# Equirectangular Rhea Areocentric, clon=0
-<60510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Equirectangular Rhea Areographic, clon=0
-<60511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Equirectangular Rhea Areocentric, clon=180
-<60512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Equirectangular Rhea Areographic, clon=180
-<60513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Sinusoidal Rhea Areocentric, clon=0
-<60514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Sinusoidal Rhea Areographic, clon=0
-<60515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Sinusoidal Rhea Areocentric, clon=180
-<60516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Sinusoidal Rhea Areographic, clon=180
-<60517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# North Polar Rhea Areocentric, clon=0
-<60518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# North Polar Rhea Areographic, clon=0
-<60519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# South Polar Rhea Areocentric, clon=0
-<60520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# South Polar Rhea Areographic, clon=0
-<60521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mollweide Rhea Areocentric, clon=0
-<60522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mollweide Rhea Areographic, clon=0
-<60523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mollweide Rhea Areocentric, clon=180
-<60524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mollweide Rhea Areographic, clon=180
-<60525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Robinson Rhea Areocentric, clon=0
-<60526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Robinson Rhea Areographic, clon=0
-<60527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Robinson Rhea Areocentric, clon=180
-<60528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Robinson Rhea Areographic, clon=180
-<60529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Sinusoidal AUTO Rhea Areocentric
-<60560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Sinusoidal AUTO Rhea Areographic
-<60561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Stereographic AUTO Rhea Areocentric, clon=0
-<60562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Stereographic AUTO Rhea Areographic, clon=0
-<60563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Transverse Mercator AUTO Rhea Areocentric
-<60564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Transverse Mercator AUTO Rhea Areographic
-<60565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Orthographic AUTO Rhea Areocentric
-<60566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Orthographic AUTO Rhea Areographic
-<60567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rhea Areocentric
-<60568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rhea Areographic
-<60569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rhea Areocentric
-<60570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rhea Areographic
-<60571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rhea Areocentric
-<60572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rhea Areographic
-<60573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mercator AUTO Rhea Areocentric
-<60574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mercator AUTO Rhea Areographic
-<60575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Albers AUTO Rhea Areocentric
-<60576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Albers AUTO Rhea Areographic
-<60577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mollweide AUTO Rhea Areocentric
-<60580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Mollweide AUTO Rhea Areographic
-<60581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Robinson AUTO Rhea Areocentric
-<60582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# Robinson AUTO Rhea Areographic
-<60583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=764000 +b=764000 +units=m +no_defs
-# GEOGCS Titan Areocentric
-<60600> 	+proj=longlat +a=2575000 +b=2575000 +no_defs
-# GEOGCS Titan Areographic
-<60601> 	+proj=longlat +a=2575000 +b=2575000 +no_defs
-# Equirectangular Titan Areocentric, clon=0
-<60610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Equirectangular Titan Areographic, clon=0
-<60611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Equirectangular Titan Areocentric, clon=180
-<60612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Equirectangular Titan Areographic, clon=180
-<60613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Sinusoidal Titan Areocentric, clon=0
-<60614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Sinusoidal Titan Areographic, clon=0
-<60615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Sinusoidal Titan Areocentric, clon=180
-<60616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Sinusoidal Titan Areographic, clon=180
-<60617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# North Polar Titan Areocentric, clon=0
-<60618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# North Polar Titan Areographic, clon=0
-<60619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# South Polar Titan Areocentric, clon=0
-<60620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# South Polar Titan Areographic, clon=0
-<60621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mollweide Titan Areocentric, clon=0
-<60622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mollweide Titan Areographic, clon=0
-<60623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mollweide Titan Areocentric, clon=180
-<60624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mollweide Titan Areographic, clon=180
-<60625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Robinson Titan Areocentric, clon=0
-<60626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Robinson Titan Areographic, clon=0
-<60627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Robinson Titan Areocentric, clon=180
-<60628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Robinson Titan Areographic, clon=180
-<60629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Sinusoidal AUTO Titan Areocentric
-<60660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Sinusoidal AUTO Titan Areographic
-<60661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Stereographic AUTO Titan Areocentric, clon=0
-<60662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Stereographic AUTO Titan Areographic, clon=0
-<60663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Transverse Mercator AUTO Titan Areocentric
-<60664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Transverse Mercator AUTO Titan Areographic
-<60665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Orthographic AUTO Titan Areocentric
-<60666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Orthographic AUTO Titan Areographic
-<60667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titan Areocentric
-<60668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titan Areographic
-<60669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titan Areocentric
-<60670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titan Areographic
-<60671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titan Areocentric
-<60672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titan Areographic
-<60673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mercator AUTO Titan Areocentric
-<60674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mercator AUTO Titan Areographic
-<60675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Albers AUTO Titan Areocentric
-<60676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Albers AUTO Titan Areographic
-<60677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mollweide AUTO Titan Areocentric
-<60680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Mollweide AUTO Titan Areographic
-<60681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Robinson AUTO Titan Areocentric
-<60682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# Robinson AUTO Titan Areographic
-<60683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2575000 +b=2575000 +units=m +no_defs
-# GEOGCS Hyperion Areocentric
-<60700> 	+proj=longlat +a=133000 +b=133000 +no_defs
-# GEOGCS Hyperion Areographic
-<60701> 	+proj=longlat +a=133000 +b=133000 +no_defs
-# Equirectangular Hyperion Areocentric, clon=0
-<60710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Equirectangular Hyperion Areographic, clon=0
-<60711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Equirectangular Hyperion Areocentric, clon=180
-<60712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Equirectangular Hyperion Areographic, clon=180
-<60713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Sinusoidal Hyperion Areocentric, clon=0
-<60714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Sinusoidal Hyperion Areographic, clon=0
-<60715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Sinusoidal Hyperion Areocentric, clon=180
-<60716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Sinusoidal Hyperion Areographic, clon=180
-<60717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# North Polar Hyperion Areocentric, clon=0
-<60718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# North Polar Hyperion Areographic, clon=0
-<60719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# South Polar Hyperion Areocentric, clon=0
-<60720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# South Polar Hyperion Areographic, clon=0
-<60721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mollweide Hyperion Areocentric, clon=0
-<60722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mollweide Hyperion Areographic, clon=0
-<60723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mollweide Hyperion Areocentric, clon=180
-<60724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mollweide Hyperion Areographic, clon=180
-<60725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Robinson Hyperion Areocentric, clon=0
-<60726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Robinson Hyperion Areographic, clon=0
-<60727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Robinson Hyperion Areocentric, clon=180
-<60728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Robinson Hyperion Areographic, clon=180
-<60729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Sinusoidal AUTO Hyperion Areocentric
-<60760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Sinusoidal AUTO Hyperion Areographic
-<60761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Stereographic AUTO Hyperion Areocentric, clon=0
-<60762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Stereographic AUTO Hyperion Areographic, clon=0
-<60763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Transverse Mercator AUTO Hyperion Areocentric
-<60764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Transverse Mercator AUTO Hyperion Areographic
-<60765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Orthographic AUTO Hyperion Areocentric
-<60766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Orthographic AUTO Hyperion Areographic
-<60767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Hyperion Areocentric
-<60768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Hyperion Areographic
-<60769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Hyperion Areocentric
-<60770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Hyperion Areographic
-<60771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Hyperion Areocentric
-<60772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Hyperion Areographic
-<60773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mercator AUTO Hyperion Areocentric
-<60774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mercator AUTO Hyperion Areographic
-<60775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Albers AUTO Hyperion Areocentric
-<60776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Albers AUTO Hyperion Areographic
-<60777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mollweide AUTO Hyperion Areocentric
-<60780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Mollweide AUTO Hyperion Areographic
-<60781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Robinson AUTO Hyperion Areocentric
-<60782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# Robinson AUTO Hyperion Areographic
-<60783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=133000 +b=133000 +units=m +no_defs
-# GEOGCS Iapetus Areocentric
-<60800> 	+proj=longlat +a=718000 +b=718000 +no_defs
-# GEOGCS Iapetus Areographic
-<60801> 	+proj=longlat +a=718000 +b=718000 +no_defs
-# Equirectangular Iapetus Areocentric, clon=0
-<60810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Equirectangular Iapetus Areographic, clon=0
-<60811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Equirectangular Iapetus Areocentric, clon=180
-<60812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Equirectangular Iapetus Areographic, clon=180
-<60813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Sinusoidal Iapetus Areocentric, clon=0
-<60814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Sinusoidal Iapetus Areographic, clon=0
-<60815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Sinusoidal Iapetus Areocentric, clon=180
-<60816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Sinusoidal Iapetus Areographic, clon=180
-<60817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# North Polar Iapetus Areocentric, clon=0
-<60818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# North Polar Iapetus Areographic, clon=0
-<60819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# South Polar Iapetus Areocentric, clon=0
-<60820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# South Polar Iapetus Areographic, clon=0
-<60821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mollweide Iapetus Areocentric, clon=0
-<60822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mollweide Iapetus Areographic, clon=0
-<60823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mollweide Iapetus Areocentric, clon=180
-<60824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mollweide Iapetus Areographic, clon=180
-<60825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Robinson Iapetus Areocentric, clon=0
-<60826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Robinson Iapetus Areographic, clon=0
-<60827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Robinson Iapetus Areocentric, clon=180
-<60828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Robinson Iapetus Areographic, clon=180
-<60829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Sinusoidal AUTO Iapetus Areocentric
-<60860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Sinusoidal AUTO Iapetus Areographic
-<60861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Stereographic AUTO Iapetus Areocentric, clon=0
-<60862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Stereographic AUTO Iapetus Areographic, clon=0
-<60863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Transverse Mercator AUTO Iapetus Areocentric
-<60864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Transverse Mercator AUTO Iapetus Areographic
-<60865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Orthographic AUTO Iapetus Areocentric
-<60866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Orthographic AUTO Iapetus Areographic
-<60867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Iapetus Areocentric
-<60868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Iapetus Areographic
-<60869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Iapetus Areocentric
-<60870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Iapetus Areographic
-<60871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Iapetus Areocentric
-<60872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Iapetus Areographic
-<60873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mercator AUTO Iapetus Areocentric
-<60874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mercator AUTO Iapetus Areographic
-<60875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Albers AUTO Iapetus Areocentric
-<60876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Albers AUTO Iapetus Areographic
-<60877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mollweide AUTO Iapetus Areocentric
-<60880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Mollweide AUTO Iapetus Areographic
-<60881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Robinson AUTO Iapetus Areocentric
-<60882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# Robinson AUTO Iapetus Areographic
-<60883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=718000 +b=718000 +units=m +no_defs
-# GEOGCS Phoebe Areocentric
-<60900> 	+proj=longlat +a=110000 +b=110000 +no_defs
-# GEOGCS Phoebe Areographic
-<60901> 	+proj=longlat +a=110000 +b=110000 +no_defs
-# Equirectangular Phoebe Areocentric, clon=0
-<60910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Equirectangular Phoebe Areographic, clon=0
-<60911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Equirectangular Phoebe Areocentric, clon=180
-<60912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Equirectangular Phoebe Areographic, clon=180
-<60913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Sinusoidal Phoebe Areocentric, clon=0
-<60914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Sinusoidal Phoebe Areographic, clon=0
-<60915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Sinusoidal Phoebe Areocentric, clon=180
-<60916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Sinusoidal Phoebe Areographic, clon=180
-<60917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# North Polar Phoebe Areocentric, clon=0
-<60918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# North Polar Phoebe Areographic, clon=0
-<60919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# South Polar Phoebe Areocentric, clon=0
-<60920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# South Polar Phoebe Areographic, clon=0
-<60921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mollweide Phoebe Areocentric, clon=0
-<60922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mollweide Phoebe Areographic, clon=0
-<60923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mollweide Phoebe Areocentric, clon=180
-<60924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mollweide Phoebe Areographic, clon=180
-<60925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Robinson Phoebe Areocentric, clon=0
-<60926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Robinson Phoebe Areographic, clon=0
-<60927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Robinson Phoebe Areocentric, clon=180
-<60928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Robinson Phoebe Areographic, clon=180
-<60929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Sinusoidal AUTO Phoebe Areocentric
-<60960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Sinusoidal AUTO Phoebe Areographic
-<60961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Stereographic AUTO Phoebe Areocentric, clon=0
-<60962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Stereographic AUTO Phoebe Areographic, clon=0
-<60963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Transverse Mercator AUTO Phoebe Areocentric
-<60964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Transverse Mercator AUTO Phoebe Areographic
-<60965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Orthographic AUTO Phoebe Areocentric
-<60966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Orthographic AUTO Phoebe Areographic
-<60967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phoebe Areocentric
-<60968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phoebe Areographic
-<60969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phoebe Areocentric
-<60970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phoebe Areographic
-<60971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phoebe Areocentric
-<60972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phoebe Areographic
-<60973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mercator AUTO Phoebe Areocentric
-<60974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mercator AUTO Phoebe Areographic
-<60975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Albers AUTO Phoebe Areocentric
-<60976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Albers AUTO Phoebe Areographic
-<60977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mollweide AUTO Phoebe Areocentric
-<60980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Mollweide AUTO Phoebe Areographic
-<60981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Robinson AUTO Phoebe Areocentric
-<60982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# Robinson AUTO Phoebe Areographic
-<60983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=110000 +b=110000 +units=m +no_defs
-# GEOGCS Janus Areocentric
-<61000> 	+proj=longlat +a=88800 +b=88800 +no_defs
-# GEOGCS Janus Areographic
-<61001> 	+proj=longlat +a=88800 +b=88800 +no_defs
-# Equirectangular Janus Areocentric, clon=0
-<61010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Equirectangular Janus Areographic, clon=0
-<61011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Equirectangular Janus Areocentric, clon=180
-<61012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Equirectangular Janus Areographic, clon=180
-<61013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Sinusoidal Janus Areocentric, clon=0
-<61014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Sinusoidal Janus Areographic, clon=0
-<61015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Sinusoidal Janus Areocentric, clon=180
-<61016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Sinusoidal Janus Areographic, clon=180
-<61017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# North Polar Janus Areocentric, clon=0
-<61018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# North Polar Janus Areographic, clon=0
-<61019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# South Polar Janus Areocentric, clon=0
-<61020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# South Polar Janus Areographic, clon=0
-<61021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mollweide Janus Areocentric, clon=0
-<61022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mollweide Janus Areographic, clon=0
-<61023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mollweide Janus Areocentric, clon=180
-<61024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mollweide Janus Areographic, clon=180
-<61025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Robinson Janus Areocentric, clon=0
-<61026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Robinson Janus Areographic, clon=0
-<61027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Robinson Janus Areocentric, clon=180
-<61028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Robinson Janus Areographic, clon=180
-<61029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Sinusoidal AUTO Janus Areocentric
-<61060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Sinusoidal AUTO Janus Areographic
-<61061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Stereographic AUTO Janus Areocentric, clon=0
-<61062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Stereographic AUTO Janus Areographic, clon=0
-<61063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Transverse Mercator AUTO Janus Areocentric
-<61064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Transverse Mercator AUTO Janus Areographic
-<61065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Orthographic AUTO Janus Areocentric
-<61066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Orthographic AUTO Janus Areographic
-<61067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Janus Areocentric
-<61068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Janus Areographic
-<61069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Janus Areocentric
-<61070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Janus Areographic
-<61071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Janus Areocentric
-<61072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Janus Areographic
-<61073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mercator AUTO Janus Areocentric
-<61074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mercator AUTO Janus Areographic
-<61075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Albers AUTO Janus Areocentric
-<61076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Albers AUTO Janus Areographic
-<61077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mollweide AUTO Janus Areocentric
-<61080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Mollweide AUTO Janus Areographic
-<61081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Robinson AUTO Janus Areocentric
-<61082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# Robinson AUTO Janus Areographic
-<61083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=88800 +b=88800 +units=m +no_defs
-# GEOGCS Epimetheus Areocentric
-<61100> 	+proj=longlat +a=59500 +b=59500 +no_defs
-# GEOGCS Epimetheus Areographic
-<61101> 	+proj=longlat +a=59500 +b=59500 +no_defs
-# Equirectangular Epimetheus Areocentric, clon=0
-<61110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Equirectangular Epimetheus Areographic, clon=0
-<61111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Equirectangular Epimetheus Areocentric, clon=180
-<61112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Equirectangular Epimetheus Areographic, clon=180
-<61113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Sinusoidal Epimetheus Areocentric, clon=0
-<61114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Sinusoidal Epimetheus Areographic, clon=0
-<61115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Sinusoidal Epimetheus Areocentric, clon=180
-<61116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Sinusoidal Epimetheus Areographic, clon=180
-<61117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# North Polar Epimetheus Areocentric, clon=0
-<61118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# North Polar Epimetheus Areographic, clon=0
-<61119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# South Polar Epimetheus Areocentric, clon=0
-<61120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# South Polar Epimetheus Areographic, clon=0
-<61121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mollweide Epimetheus Areocentric, clon=0
-<61122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mollweide Epimetheus Areographic, clon=0
-<61123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mollweide Epimetheus Areocentric, clon=180
-<61124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mollweide Epimetheus Areographic, clon=180
-<61125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Robinson Epimetheus Areocentric, clon=0
-<61126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Robinson Epimetheus Areographic, clon=0
-<61127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Robinson Epimetheus Areocentric, clon=180
-<61128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Robinson Epimetheus Areographic, clon=180
-<61129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Sinusoidal AUTO Epimetheus Areocentric
-<61160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Sinusoidal AUTO Epimetheus Areographic
-<61161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Stereographic AUTO Epimetheus Areocentric, clon=0
-<61162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Stereographic AUTO Epimetheus Areographic, clon=0
-<61163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Transverse Mercator AUTO Epimetheus Areocentric
-<61164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Transverse Mercator AUTO Epimetheus Areographic
-<61165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Orthographic AUTO Epimetheus Areocentric
-<61166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Orthographic AUTO Epimetheus Areographic
-<61167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Epimetheus Areocentric
-<61168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Epimetheus Areographic
-<61169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Epimetheus Areocentric
-<61170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Epimetheus Areographic
-<61171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Epimetheus Areocentric
-<61172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Epimetheus Areographic
-<61173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mercator AUTO Epimetheus Areocentric
-<61174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mercator AUTO Epimetheus Areographic
-<61175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Albers AUTO Epimetheus Areocentric
-<61176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Albers AUTO Epimetheus Areographic
-<61177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mollweide AUTO Epimetheus Areocentric
-<61180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Mollweide AUTO Epimetheus Areographic
-<61181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Robinson AUTO Epimetheus Areocentric
-<61182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# Robinson AUTO Epimetheus Areographic
-<61183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=59500 +b=59500 +units=m +no_defs
-# GEOGCS Helene Areocentric
-<61200> 	+proj=longlat +a=16000 +b=16000 +no_defs
-# GEOGCS Helene Areographic
-<61201> 	+proj=longlat +a=16000 +b=16000 +no_defs
-# Equirectangular Helene Areocentric, clon=0
-<61210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equirectangular Helene Areographic, clon=0
-<61211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equirectangular Helene Areocentric, clon=180
-<61212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equirectangular Helene Areographic, clon=180
-<61213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Helene Areocentric, clon=0
-<61214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Helene Areographic, clon=0
-<61215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Helene Areocentric, clon=180
-<61216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Helene Areographic, clon=180
-<61217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# North Polar Helene Areocentric, clon=0
-<61218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# North Polar Helene Areographic, clon=0
-<61219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# South Polar Helene Areocentric, clon=0
-<61220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# South Polar Helene Areographic, clon=0
-<61221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Helene Areocentric, clon=0
-<61222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Helene Areographic, clon=0
-<61223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Helene Areocentric, clon=180
-<61224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Helene Areographic, clon=180
-<61225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Helene Areocentric, clon=0
-<61226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Helene Areographic, clon=0
-<61227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Helene Areocentric, clon=180
-<61228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Helene Areographic, clon=180
-<61229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal AUTO Helene Areocentric
-<61260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal AUTO Helene Areographic
-<61261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Stereographic AUTO Helene Areocentric, clon=0
-<61262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Stereographic AUTO Helene Areographic, clon=0
-<61263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Transverse Mercator AUTO Helene Areocentric
-<61264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Transverse Mercator AUTO Helene Areographic
-<61265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Orthographic AUTO Helene Areocentric
-<61266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Orthographic AUTO Helene Areographic
-<61267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Helene Areocentric
-<61268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Helene Areographic
-<61269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Helene Areocentric
-<61270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Helene Areographic
-<61271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Helene Areocentric
-<61272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Helene Areographic
-<61273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mercator AUTO Helene Areocentric
-<61274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mercator AUTO Helene Areographic
-<61275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Albers AUTO Helene Areocentric
-<61276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Albers AUTO Helene Areographic
-<61277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide AUTO Helene Areocentric
-<61280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide AUTO Helene Areographic
-<61281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson AUTO Helene Areocentric
-<61282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson AUTO Helene Areographic
-<61283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# GEOGCS Telesto Areocentric
-<61300> 	+proj=longlat +a=11000 +b=11000 +no_defs
-# GEOGCS Telesto Areographic
-<61301> 	+proj=longlat +a=11000 +b=11000 +no_defs
-# Equirectangular Telesto Areocentric, clon=0
-<61310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Equirectangular Telesto Areographic, clon=0
-<61311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Equirectangular Telesto Areocentric, clon=180
-<61312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Equirectangular Telesto Areographic, clon=180
-<61313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Sinusoidal Telesto Areocentric, clon=0
-<61314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Sinusoidal Telesto Areographic, clon=0
-<61315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Sinusoidal Telesto Areocentric, clon=180
-<61316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Sinusoidal Telesto Areographic, clon=180
-<61317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# North Polar Telesto Areocentric, clon=0
-<61318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# North Polar Telesto Areographic, clon=0
-<61319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# South Polar Telesto Areocentric, clon=0
-<61320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# South Polar Telesto Areographic, clon=0
-<61321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mollweide Telesto Areocentric, clon=0
-<61322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mollweide Telesto Areographic, clon=0
-<61323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mollweide Telesto Areocentric, clon=180
-<61324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mollweide Telesto Areographic, clon=180
-<61325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Robinson Telesto Areocentric, clon=0
-<61326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Robinson Telesto Areographic, clon=0
-<61327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Robinson Telesto Areocentric, clon=180
-<61328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Robinson Telesto Areographic, clon=180
-<61329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Sinusoidal AUTO Telesto Areocentric
-<61360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Sinusoidal AUTO Telesto Areographic
-<61361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Stereographic AUTO Telesto Areocentric, clon=0
-<61362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Stereographic AUTO Telesto Areographic, clon=0
-<61363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Transverse Mercator AUTO Telesto Areocentric
-<61364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Transverse Mercator AUTO Telesto Areographic
-<61365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Orthographic AUTO Telesto Areocentric
-<61366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Orthographic AUTO Telesto Areographic
-<61367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Telesto Areocentric
-<61368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Telesto Areographic
-<61369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Telesto Areocentric
-<61370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Telesto Areographic
-<61371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Telesto Areocentric
-<61372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Telesto Areographic
-<61373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mercator AUTO Telesto Areocentric
-<61374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mercator AUTO Telesto Areographic
-<61375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Albers AUTO Telesto Areocentric
-<61376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Albers AUTO Telesto Areographic
-<61377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mollweide AUTO Telesto Areocentric
-<61380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Mollweide AUTO Telesto Areographic
-<61381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Robinson AUTO Telesto Areocentric
-<61382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# Robinson AUTO Telesto Areographic
-<61383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11000 +b=11000 +units=m +no_defs
-# GEOGCS Calypso Areocentric
-<61400> 	+proj=longlat +a=9500 +b=9500 +no_defs
-# GEOGCS Calypso Areographic
-<61401> 	+proj=longlat +a=9500 +b=9500 +no_defs
-# Equirectangular Calypso Areocentric, clon=0
-<61410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Equirectangular Calypso Areographic, clon=0
-<61411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Equirectangular Calypso Areocentric, clon=180
-<61412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Equirectangular Calypso Areographic, clon=180
-<61413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Sinusoidal Calypso Areocentric, clon=0
-<61414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Sinusoidal Calypso Areographic, clon=0
-<61415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Sinusoidal Calypso Areocentric, clon=180
-<61416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Sinusoidal Calypso Areographic, clon=180
-<61417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# North Polar Calypso Areocentric, clon=0
-<61418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# North Polar Calypso Areographic, clon=0
-<61419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# South Polar Calypso Areocentric, clon=0
-<61420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# South Polar Calypso Areographic, clon=0
-<61421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mollweide Calypso Areocentric, clon=0
-<61422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mollweide Calypso Areographic, clon=0
-<61423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mollweide Calypso Areocentric, clon=180
-<61424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mollweide Calypso Areographic, clon=180
-<61425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Robinson Calypso Areocentric, clon=0
-<61426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Robinson Calypso Areographic, clon=0
-<61427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Robinson Calypso Areocentric, clon=180
-<61428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Robinson Calypso Areographic, clon=180
-<61429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Sinusoidal AUTO Calypso Areocentric
-<61460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Sinusoidal AUTO Calypso Areographic
-<61461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Stereographic AUTO Calypso Areocentric, clon=0
-<61462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Stereographic AUTO Calypso Areographic, clon=0
-<61463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Transverse Mercator AUTO Calypso Areocentric
-<61464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Transverse Mercator AUTO Calypso Areographic
-<61465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Orthographic AUTO Calypso Areocentric
-<61466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Orthographic AUTO Calypso Areographic
-<61467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Calypso Areocentric
-<61468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Calypso Areographic
-<61469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Calypso Areocentric
-<61470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Calypso Areographic
-<61471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Calypso Areocentric
-<61472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Calypso Areographic
-<61473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mercator AUTO Calypso Areocentric
-<61474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mercator AUTO Calypso Areographic
-<61475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Albers AUTO Calypso Areocentric
-<61476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Albers AUTO Calypso Areographic
-<61477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mollweide AUTO Calypso Areocentric
-<61480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Mollweide AUTO Calypso Areographic
-<61481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Robinson AUTO Calypso Areocentric
-<61482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# Robinson AUTO Calypso Areographic
-<61483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=9500 +b=9500 +units=m +no_defs
-# GEOGCS Atlas Areocentric
-<61500> 	+proj=longlat +a=16000 +b=16000 +no_defs
-# GEOGCS Atlas Areographic
-<61501> 	+proj=longlat +a=16000 +b=16000 +no_defs
-# Equirectangular Atlas Areocentric, clon=0
-<61510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equirectangular Atlas Areographic, clon=0
-<61511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equirectangular Atlas Areocentric, clon=180
-<61512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equirectangular Atlas Areographic, clon=180
-<61513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Atlas Areocentric, clon=0
-<61514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Atlas Areographic, clon=0
-<61515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Atlas Areocentric, clon=180
-<61516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal Atlas Areographic, clon=180
-<61517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# North Polar Atlas Areocentric, clon=0
-<61518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# North Polar Atlas Areographic, clon=0
-<61519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# South Polar Atlas Areocentric, clon=0
-<61520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# South Polar Atlas Areographic, clon=0
-<61521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Atlas Areocentric, clon=0
-<61522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Atlas Areographic, clon=0
-<61523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Atlas Areocentric, clon=180
-<61524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide Atlas Areographic, clon=180
-<61525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Atlas Areocentric, clon=0
-<61526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Atlas Areographic, clon=0
-<61527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Atlas Areocentric, clon=180
-<61528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson Atlas Areographic, clon=180
-<61529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal AUTO Atlas Areocentric
-<61560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Sinusoidal AUTO Atlas Areographic
-<61561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Stereographic AUTO Atlas Areocentric, clon=0
-<61562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Stereographic AUTO Atlas Areographic, clon=0
-<61563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Transverse Mercator AUTO Atlas Areocentric
-<61564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Transverse Mercator AUTO Atlas Areographic
-<61565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Orthographic AUTO Atlas Areocentric
-<61566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Orthographic AUTO Atlas Areographic
-<61567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Atlas Areocentric
-<61568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Atlas Areographic
-<61569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Atlas Areocentric
-<61570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Atlas Areographic
-<61571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Atlas Areocentric
-<61572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Atlas Areographic
-<61573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mercator AUTO Atlas Areocentric
-<61574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mercator AUTO Atlas Areographic
-<61575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Albers AUTO Atlas Areocentric
-<61576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Albers AUTO Atlas Areographic
-<61577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide AUTO Atlas Areocentric
-<61580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Mollweide AUTO Atlas Areographic
-<61581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson AUTO Atlas Areocentric
-<61582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# Robinson AUTO Atlas Areographic
-<61583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=16000 +b=16000 +units=m +no_defs
-# GEOGCS Prometheus Areocentric
-<61600> 	+proj=longlat +a=50100 +b=50100 +no_defs
-# GEOGCS Prometheus Areographic
-<61601> 	+proj=longlat +a=50100 +b=50100 +no_defs
-# Equirectangular Prometheus Areocentric, clon=0
-<61610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Equirectangular Prometheus Areographic, clon=0
-<61611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Equirectangular Prometheus Areocentric, clon=180
-<61612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Equirectangular Prometheus Areographic, clon=180
-<61613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Sinusoidal Prometheus Areocentric, clon=0
-<61614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Sinusoidal Prometheus Areographic, clon=0
-<61615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Sinusoidal Prometheus Areocentric, clon=180
-<61616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Sinusoidal Prometheus Areographic, clon=180
-<61617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# North Polar Prometheus Areocentric, clon=0
-<61618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# North Polar Prometheus Areographic, clon=0
-<61619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# South Polar Prometheus Areocentric, clon=0
-<61620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# South Polar Prometheus Areographic, clon=0
-<61621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mollweide Prometheus Areocentric, clon=0
-<61622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mollweide Prometheus Areographic, clon=0
-<61623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mollweide Prometheus Areocentric, clon=180
-<61624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mollweide Prometheus Areographic, clon=180
-<61625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Robinson Prometheus Areocentric, clon=0
-<61626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Robinson Prometheus Areographic, clon=0
-<61627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Robinson Prometheus Areocentric, clon=180
-<61628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Robinson Prometheus Areographic, clon=180
-<61629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Sinusoidal AUTO Prometheus Areocentric
-<61660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Sinusoidal AUTO Prometheus Areographic
-<61661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Stereographic AUTO Prometheus Areocentric, clon=0
-<61662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Stereographic AUTO Prometheus Areographic, clon=0
-<61663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Transverse Mercator AUTO Prometheus Areocentric
-<61664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Transverse Mercator AUTO Prometheus Areographic
-<61665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Orthographic AUTO Prometheus Areocentric
-<61666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Orthographic AUTO Prometheus Areographic
-<61667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Prometheus Areocentric
-<61668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Prometheus Areographic
-<61669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Prometheus Areocentric
-<61670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Prometheus Areographic
-<61671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Prometheus Areocentric
-<61672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Prometheus Areographic
-<61673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mercator AUTO Prometheus Areocentric
-<61674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mercator AUTO Prometheus Areographic
-<61675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Albers AUTO Prometheus Areocentric
-<61676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Albers AUTO Prometheus Areographic
-<61677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mollweide AUTO Prometheus Areocentric
-<61680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Mollweide AUTO Prometheus Areographic
-<61681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Robinson AUTO Prometheus Areocentric
-<61682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# Robinson AUTO Prometheus Areographic
-<61683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=50100 +b=50100 +units=m +no_defs
-# GEOGCS Pandora Areocentric
-<61700> 	+proj=longlat +a=41900 +b=41900 +no_defs
-# GEOGCS Pandora Areographic
-<61701> 	+proj=longlat +a=41900 +b=41900 +no_defs
-# Equirectangular Pandora Areocentric, clon=0
-<61710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Equirectangular Pandora Areographic, clon=0
-<61711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Equirectangular Pandora Areocentric, clon=180
-<61712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Equirectangular Pandora Areographic, clon=180
-<61713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Sinusoidal Pandora Areocentric, clon=0
-<61714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Sinusoidal Pandora Areographic, clon=0
-<61715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Sinusoidal Pandora Areocentric, clon=180
-<61716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Sinusoidal Pandora Areographic, clon=180
-<61717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# North Polar Pandora Areocentric, clon=0
-<61718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# North Polar Pandora Areographic, clon=0
-<61719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# South Polar Pandora Areocentric, clon=0
-<61720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# South Polar Pandora Areographic, clon=0
-<61721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mollweide Pandora Areocentric, clon=0
-<61722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mollweide Pandora Areographic, clon=0
-<61723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mollweide Pandora Areocentric, clon=180
-<61724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mollweide Pandora Areographic, clon=180
-<61725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Robinson Pandora Areocentric, clon=0
-<61726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Robinson Pandora Areographic, clon=0
-<61727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Robinson Pandora Areocentric, clon=180
-<61728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Robinson Pandora Areographic, clon=180
-<61729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Sinusoidal AUTO Pandora Areocentric
-<61760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Sinusoidal AUTO Pandora Areographic
-<61761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Stereographic AUTO Pandora Areocentric, clon=0
-<61762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Stereographic AUTO Pandora Areographic, clon=0
-<61763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Transverse Mercator AUTO Pandora Areocentric
-<61764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Transverse Mercator AUTO Pandora Areographic
-<61765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Orthographic AUTO Pandora Areocentric
-<61766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Orthographic AUTO Pandora Areographic
-<61767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pandora Areocentric
-<61768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pandora Areographic
-<61769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pandora Areocentric
-<61770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pandora Areographic
-<61771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pandora Areocentric
-<61772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pandora Areographic
-<61773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mercator AUTO Pandora Areocentric
-<61774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mercator AUTO Pandora Areographic
-<61775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Albers AUTO Pandora Areocentric
-<61776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Albers AUTO Pandora Areographic
-<61777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mollweide AUTO Pandora Areocentric
-<61780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Mollweide AUTO Pandora Areographic
-<61781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Robinson AUTO Pandora Areocentric
-<61782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# Robinson AUTO Pandora Areographic
-<61783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=41900 +b=41900 +units=m +no_defs
-# GEOGCS Pan Areocentric
-<61800> 	+proj=longlat +a=10000 +b=10000 +no_defs
-# GEOGCS Pan Areographic
-<61801> 	+proj=longlat +a=10000 +b=10000 +no_defs
-# Equirectangular Pan Areocentric, clon=0
-<61810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Pan Areographic, clon=0
-<61811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Pan Areocentric, clon=180
-<61812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Pan Areographic, clon=180
-<61813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Pan Areocentric, clon=0
-<61814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Pan Areographic, clon=0
-<61815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Pan Areocentric, clon=180
-<61816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Pan Areographic, clon=180
-<61817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# North Polar Pan Areocentric, clon=0
-<61818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# North Polar Pan Areographic, clon=0
-<61819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# South Polar Pan Areocentric, clon=0
-<61820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# South Polar Pan Areographic, clon=0
-<61821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Pan Areocentric, clon=0
-<61822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Pan Areographic, clon=0
-<61823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Pan Areocentric, clon=180
-<61824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Pan Areographic, clon=180
-<61825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Pan Areocentric, clon=0
-<61826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Pan Areographic, clon=0
-<61827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Pan Areocentric, clon=180
-<61828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Pan Areographic, clon=180
-<61829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal AUTO Pan Areocentric
-<61860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal AUTO Pan Areographic
-<61861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Stereographic AUTO Pan Areocentric, clon=0
-<61862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Stereographic AUTO Pan Areographic, clon=0
-<61863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Transverse Mercator AUTO Pan Areocentric
-<61864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Transverse Mercator AUTO Pan Areographic
-<61865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Orthographic AUTO Pan Areocentric
-<61866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Orthographic AUTO Pan Areographic
-<61867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pan Areocentric
-<61868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pan Areographic
-<61869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pan Areocentric
-<61870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pan Areographic
-<61871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pan Areocentric
-<61872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pan Areographic
-<61873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mercator AUTO Pan Areocentric
-<61874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mercator AUTO Pan Areographic
-<61875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Albers AUTO Pan Areocentric
-<61876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Albers AUTO Pan Areographic
-<61877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide AUTO Pan Areocentric
-<61880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide AUTO Pan Areographic
-<61881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson AUTO Pan Areocentric
-<61882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson AUTO Pan Areographic
-<61883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# GEOGCS Methone Areocentric
-<63200> 	+proj=longlat +a=1600 +b=1600 +no_defs
-# GEOGCS Methone Areographic
-<63201> 	+proj=longlat +a=1600 +b=1600 +no_defs
-# Equirectangular Methone Areocentric, clon=0
-<63210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equirectangular Methone Areographic, clon=0
-<63211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equirectangular Methone Areocentric, clon=180
-<63212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equirectangular Methone Areographic, clon=180
-<63213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areocentric, clon=0
-<63214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areographic, clon=0
-<63215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areocentric, clon=180
-<63216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areographic, clon=180
-<63217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# North Polar Methone Areocentric, clon=0
-<63218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# North Polar Methone Areographic, clon=0
-<63219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# South Polar Methone Areocentric, clon=0
-<63220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# South Polar Methone Areographic, clon=0
-<63221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areocentric, clon=0
-<63222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areographic, clon=0
-<63223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areocentric, clon=180
-<63224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areographic, clon=180
-<63225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areocentric, clon=0
-<63226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areographic, clon=0
-<63227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areocentric, clon=180
-<63228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areographic, clon=180
-<63229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal AUTO Methone Areocentric
-<63260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal AUTO Methone Areographic
-<63261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Stereographic AUTO Methone Areocentric, clon=0
-<63262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Stereographic AUTO Methone Areographic, clon=0
-<63263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Transverse Mercator AUTO Methone Areocentric
-<63264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Transverse Mercator AUTO Methone Areographic
-<63265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Orthographic AUTO Methone Areocentric
-<63266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Orthographic AUTO Methone Areographic
-<63267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Methone Areocentric
-<63268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Methone Areographic
-<63269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Methone Areocentric
-<63270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Methone Areographic
-<63271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Methone Areocentric
-<63272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Methone Areographic
-<63273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mercator AUTO Methone Areocentric
-<63274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mercator AUTO Methone Areographic
-<63275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Albers AUTO Methone Areocentric
-<63276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Albers AUTO Methone Areographic
-<63277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide AUTO Methone Areocentric
-<63280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide AUTO Methone Areographic
-<63281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson AUTO Methone Areocentric
-<63282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson AUTO Methone Areographic
-<63283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# GEOGCS Pallene Areocentric
-<63300> 	+proj=longlat +a=2500 +b=2500 +no_defs
-# GEOGCS Pallene Areographic
-<63301> 	+proj=longlat +a=2500 +b=2500 +no_defs
-# Equirectangular Pallene Areocentric, clon=0
-<63310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equirectangular Pallene Areographic, clon=0
-<63311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equirectangular Pallene Areocentric, clon=180
-<63312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equirectangular Pallene Areographic, clon=180
-<63313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areocentric, clon=0
-<63314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areographic, clon=0
-<63315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areocentric, clon=180
-<63316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areographic, clon=180
-<63317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# North Polar Pallene Areocentric, clon=0
-<63318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# North Polar Pallene Areographic, clon=0
-<63319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# South Polar Pallene Areocentric, clon=0
-<63320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# South Polar Pallene Areographic, clon=0
-<63321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areocentric, clon=0
-<63322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areographic, clon=0
-<63323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areocentric, clon=180
-<63324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areographic, clon=180
-<63325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areocentric, clon=0
-<63326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areographic, clon=0
-<63327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areocentric, clon=180
-<63328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areographic, clon=180
-<63329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal AUTO Pallene Areocentric
-<63360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal AUTO Pallene Areographic
-<63361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Stereographic AUTO Pallene Areocentric, clon=0
-<63362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Stereographic AUTO Pallene Areographic, clon=0
-<63363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Transverse Mercator AUTO Pallene Areocentric
-<63364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Transverse Mercator AUTO Pallene Areographic
-<63365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Orthographic AUTO Pallene Areocentric
-<63366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Orthographic AUTO Pallene Areographic
-<63367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pallene Areocentric
-<63368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pallene Areographic
-<63369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pallene Areocentric
-<63370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pallene Areographic
-<63371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pallene Areocentric
-<63372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pallene Areographic
-<63373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mercator AUTO Pallene Areocentric
-<63374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mercator AUTO Pallene Areographic
-<63375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Albers AUTO Pallene Areocentric
-<63376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Albers AUTO Pallene Areographic
-<63377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide AUTO Pallene Areocentric
-<63380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide AUTO Pallene Areographic
-<63381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson AUTO Pallene Areocentric
-<63382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson AUTO Pallene Areographic
-<63383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# GEOGCS Polydeuces Areocentric
-<63400> 	+proj=longlat +a=1300 +b=1300 +no_defs
-# GEOGCS Polydeuces Areographic
-<63401> 	+proj=longlat +a=1300 +b=1300 +no_defs
-# Equirectangular Polydeuces Areocentric, clon=0
-<63410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equirectangular Polydeuces Areographic, clon=0
-<63411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equirectangular Polydeuces Areocentric, clon=180
-<63412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equirectangular Polydeuces Areographic, clon=180
-<63413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areocentric, clon=0
-<63414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areographic, clon=0
-<63415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areocentric, clon=180
-<63416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areographic, clon=180
-<63417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# North Polar Polydeuces Areocentric, clon=0
-<63418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# North Polar Polydeuces Areographic, clon=0
-<63419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# South Polar Polydeuces Areocentric, clon=0
-<63420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# South Polar Polydeuces Areographic, clon=0
-<63421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areocentric, clon=0
-<63422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areographic, clon=0
-<63423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areocentric, clon=180
-<63424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areographic, clon=180
-<63425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areocentric, clon=0
-<63426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areographic, clon=0
-<63427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areocentric, clon=180
-<63428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areographic, clon=180
-<63429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal AUTO Polydeuces Areocentric
-<63460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal AUTO Polydeuces Areographic
-<63461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Stereographic AUTO Polydeuces Areocentric, clon=0
-<63462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Stereographic AUTO Polydeuces Areographic, clon=0
-<63463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Transverse Mercator AUTO Polydeuces Areocentric
-<63464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Transverse Mercator AUTO Polydeuces Areographic
-<63465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Orthographic AUTO Polydeuces Areocentric
-<63466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Orthographic AUTO Polydeuces Areographic
-<63467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Polydeuces Areocentric
-<63468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Polydeuces Areographic
-<63469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Polydeuces Areocentric
-<63470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Polydeuces Areographic
-<63471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Polydeuces Areocentric
-<63472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Polydeuces Areographic
-<63473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mercator AUTO Polydeuces Areocentric
-<63474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mercator AUTO Polydeuces Areographic
-<63475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Albers AUTO Polydeuces Areocentric
-<63476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Albers AUTO Polydeuces Areographic
-<63477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide AUTO Polydeuces Areocentric
-<63480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide AUTO Polydeuces Areographic
-<63481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson AUTO Polydeuces Areocentric
-<63482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson AUTO Polydeuces Areographic
-<63483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# GEOGCS Uranus Areocentric
-<79900> 	+proj=longlat +a=25559000 +b=-1089240145.112749 +no_defs
-# GEOGCS Uranus Areographic
-<79901> 	+proj=longlat +a=25559000 +b=-1089240145.112749 +no_defs
-# Equirectangular Uranus Areocentric, clon=0
-<79910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equirectangular Uranus Areographic, clon=0
-<79911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equirectangular Uranus Areocentric, clon=180
-<79912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equirectangular Uranus Areographic, clon=180
-<79913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areocentric, clon=0
-<79914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areographic, clon=0
-<79915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areocentric, clon=180
-<79916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areographic, clon=180
-<79917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# North Polar Uranus Areocentric, clon=0
-<79918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# North Polar Uranus Areographic, clon=0
-<79919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# South Polar Uranus Areocentric, clon=0
-<79920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# South Polar Uranus Areographic, clon=0
-<79921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areocentric, clon=0
-<79922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areographic, clon=0
-<79923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areocentric, clon=180
-<79924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areographic, clon=180
-<79925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areocentric, clon=0
-<79926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areographic, clon=0
-<79927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areocentric, clon=180
-<79928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areographic, clon=180
-<79929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal AUTO Uranus Areocentric
-<79960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal AUTO Uranus Areographic
-<79961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Stereographic AUTO Uranus Areocentric, clon=0
-<79962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Stereographic AUTO Uranus Areographic, clon=0
-<79963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Transverse Mercator AUTO Uranus Areocentric
-<79964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Transverse Mercator AUTO Uranus Areographic
-<79965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Orthographic AUTO Uranus Areocentric
-<79966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Orthographic AUTO Uranus Areographic
-<79967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equidistant Cylindrical AUTO Uranus Areocentric
-<79968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equidistant Cylindrical AUTO Uranus Areographic
-<79969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Conformal Conic AUTO Uranus Areocentric
-<79970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Conformal Conic AUTO Uranus Areographic
-<79971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Uranus Areocentric
-<79972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Uranus Areographic
-<79973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mercator AUTO Uranus Areocentric
-<79974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mercator AUTO Uranus Areographic
-<79975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Albers AUTO Uranus Areocentric
-<79976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Albers AUTO Uranus Areographic
-<79977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide AUTO Uranus Areocentric
-<79980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide AUTO Uranus Areographic
-<79981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson AUTO Uranus Areocentric
-<79982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson AUTO Uranus Areographic
-<79983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# GEOGCS Ariel Areocentric
-<70100> 	+proj=longlat +a=578900 +b=578900 +no_defs
-# GEOGCS Ariel Areographic
-<70101> 	+proj=longlat +a=578900 +b=578900 +no_defs
-# Equirectangular Ariel Areocentric, clon=0
-<70110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equirectangular Ariel Areographic, clon=0
-<70111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equirectangular Ariel Areocentric, clon=180
-<70112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equirectangular Ariel Areographic, clon=180
-<70113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areocentric, clon=0
-<70114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areographic, clon=0
-<70115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areocentric, clon=180
-<70116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areographic, clon=180
-<70117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# North Polar Ariel Areocentric, clon=0
-<70118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# North Polar Ariel Areographic, clon=0
-<70119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# South Polar Ariel Areocentric, clon=0
-<70120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# South Polar Ariel Areographic, clon=0
-<70121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areocentric, clon=0
-<70122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areographic, clon=0
-<70123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areocentric, clon=180
-<70124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areographic, clon=180
-<70125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areocentric, clon=0
-<70126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areographic, clon=0
-<70127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areocentric, clon=180
-<70128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areographic, clon=180
-<70129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal AUTO Ariel Areocentric
-<70160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal AUTO Ariel Areographic
-<70161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Stereographic AUTO Ariel Areocentric, clon=0
-<70162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Stereographic AUTO Ariel Areographic, clon=0
-<70163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Transverse Mercator AUTO Ariel Areocentric
-<70164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Transverse Mercator AUTO Ariel Areographic
-<70165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Orthographic AUTO Ariel Areocentric
-<70166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Orthographic AUTO Ariel Areographic
-<70167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ariel Areocentric
-<70168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ariel Areographic
-<70169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ariel Areocentric
-<70170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ariel Areographic
-<70171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ariel Areocentric
-<70172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ariel Areographic
-<70173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mercator AUTO Ariel Areocentric
-<70174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mercator AUTO Ariel Areographic
-<70175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Albers AUTO Ariel Areocentric
-<70176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Albers AUTO Ariel Areographic
-<70177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide AUTO Ariel Areocentric
-<70180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide AUTO Ariel Areographic
-<70181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson AUTO Ariel Areocentric
-<70182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson AUTO Ariel Areographic
-<70183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# GEOGCS Umbriel Areocentric
-<70200> 	+proj=longlat +a=584700 +b=584700 +no_defs
-# GEOGCS Umbriel Areographic
-<70201> 	+proj=longlat +a=584700 +b=584700 +no_defs
-# Equirectangular Umbriel Areocentric, clon=0
-<70210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equirectangular Umbriel Areographic, clon=0
-<70211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equirectangular Umbriel Areocentric, clon=180
-<70212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equirectangular Umbriel Areographic, clon=180
-<70213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areocentric, clon=0
-<70214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areographic, clon=0
-<70215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areocentric, clon=180
-<70216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areographic, clon=180
-<70217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# North Polar Umbriel Areocentric, clon=0
-<70218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# North Polar Umbriel Areographic, clon=0
-<70219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# South Polar Umbriel Areocentric, clon=0
-<70220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# South Polar Umbriel Areographic, clon=0
-<70221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areocentric, clon=0
-<70222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areographic, clon=0
-<70223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areocentric, clon=180
-<70224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areographic, clon=180
-<70225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areocentric, clon=0
-<70226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areographic, clon=0
-<70227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areocentric, clon=180
-<70228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areographic, clon=180
-<70229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal AUTO Umbriel Areocentric
-<70260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal AUTO Umbriel Areographic
-<70261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Stereographic AUTO Umbriel Areocentric, clon=0
-<70262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Stereographic AUTO Umbriel Areographic, clon=0
-<70263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Transverse Mercator AUTO Umbriel Areocentric
-<70264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Transverse Mercator AUTO Umbriel Areographic
-<70265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Orthographic AUTO Umbriel Areocentric
-<70266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Orthographic AUTO Umbriel Areographic
-<70267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Umbriel Areocentric
-<70268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Umbriel Areographic
-<70269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Umbriel Areocentric
-<70270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Umbriel Areographic
-<70271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Umbriel Areocentric
-<70272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Umbriel Areographic
-<70273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mercator AUTO Umbriel Areocentric
-<70274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mercator AUTO Umbriel Areographic
-<70275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Albers AUTO Umbriel Areocentric
-<70276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Albers AUTO Umbriel Areographic
-<70277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide AUTO Umbriel Areocentric
-<70280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide AUTO Umbriel Areographic
-<70281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson AUTO Umbriel Areocentric
-<70282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson AUTO Umbriel Areographic
-<70283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# GEOGCS Titania Areocentric
-<70300> 	+proj=longlat +a=788900 +b=788900 +no_defs
-# GEOGCS Titania Areographic
-<70301> 	+proj=longlat +a=788900 +b=788900 +no_defs
-# Equirectangular Titania Areocentric, clon=0
-<70310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equirectangular Titania Areographic, clon=0
-<70311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equirectangular Titania Areocentric, clon=180
-<70312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equirectangular Titania Areographic, clon=180
-<70313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areocentric, clon=0
-<70314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areographic, clon=0
-<70315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areocentric, clon=180
-<70316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areographic, clon=180
-<70317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# North Polar Titania Areocentric, clon=0
-<70318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# North Polar Titania Areographic, clon=0
-<70319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# South Polar Titania Areocentric, clon=0
-<70320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# South Polar Titania Areographic, clon=0
-<70321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areocentric, clon=0
-<70322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areographic, clon=0
-<70323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areocentric, clon=180
-<70324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areographic, clon=180
-<70325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areocentric, clon=0
-<70326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areographic, clon=0
-<70327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areocentric, clon=180
-<70328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areographic, clon=180
-<70329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal AUTO Titania Areocentric
-<70360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal AUTO Titania Areographic
-<70361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Stereographic AUTO Titania Areocentric, clon=0
-<70362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Stereographic AUTO Titania Areographic, clon=0
-<70363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Transverse Mercator AUTO Titania Areocentric
-<70364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Transverse Mercator AUTO Titania Areographic
-<70365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Orthographic AUTO Titania Areocentric
-<70366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Orthographic AUTO Titania Areographic
-<70367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titania Areocentric
-<70368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titania Areographic
-<70369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titania Areocentric
-<70370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titania Areographic
-<70371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titania Areocentric
-<70372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titania Areographic
-<70373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mercator AUTO Titania Areocentric
-<70374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mercator AUTO Titania Areographic
-<70375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Albers AUTO Titania Areocentric
-<70376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Albers AUTO Titania Areographic
-<70377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide AUTO Titania Areocentric
-<70380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide AUTO Titania Areographic
-<70381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson AUTO Titania Areocentric
-<70382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson AUTO Titania Areographic
-<70383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# GEOGCS Oberon Areocentric
-<70400> 	+proj=longlat +a=761400 +b=761400 +no_defs
-# GEOGCS Oberon Areographic
-<70401> 	+proj=longlat +a=761400 +b=761400 +no_defs
-# Equirectangular Oberon Areocentric, clon=0
-<70410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equirectangular Oberon Areographic, clon=0
-<70411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equirectangular Oberon Areocentric, clon=180
-<70412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equirectangular Oberon Areographic, clon=180
-<70413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areocentric, clon=0
-<70414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areographic, clon=0
-<70415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areocentric, clon=180
-<70416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areographic, clon=180
-<70417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# North Polar Oberon Areocentric, clon=0
-<70418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# North Polar Oberon Areographic, clon=0
-<70419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# South Polar Oberon Areocentric, clon=0
-<70420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# South Polar Oberon Areographic, clon=0
-<70421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areocentric, clon=0
-<70422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areographic, clon=0
-<70423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areocentric, clon=180
-<70424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areographic, clon=180
-<70425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areocentric, clon=0
-<70426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areographic, clon=0
-<70427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areocentric, clon=180
-<70428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areographic, clon=180
-<70429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal AUTO Oberon Areocentric
-<70460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal AUTO Oberon Areographic
-<70461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Stereographic AUTO Oberon Areocentric, clon=0
-<70462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Stereographic AUTO Oberon Areographic, clon=0
-<70463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Transverse Mercator AUTO Oberon Areocentric
-<70464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Transverse Mercator AUTO Oberon Areographic
-<70465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Orthographic AUTO Oberon Areocentric
-<70466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Orthographic AUTO Oberon Areographic
-<70467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Oberon Areocentric
-<70468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Oberon Areographic
-<70469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Oberon Areocentric
-<70470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Oberon Areographic
-<70471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Oberon Areocentric
-<70472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Oberon Areographic
-<70473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mercator AUTO Oberon Areocentric
-<70474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mercator AUTO Oberon Areographic
-<70475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Albers AUTO Oberon Areocentric
-<70476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Albers AUTO Oberon Areographic
-<70477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide AUTO Oberon Areocentric
-<70480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide AUTO Oberon Areographic
-<70481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson AUTO Oberon Areocentric
-<70482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson AUTO Oberon Areographic
-<70483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# GEOGCS Miranda Areocentric
-<70500> 	+proj=longlat +a=235800 +b=235800 +no_defs
-# GEOGCS Miranda Areographic
-<70501> 	+proj=longlat +a=235800 +b=235800 +no_defs
-# Equirectangular Miranda Areocentric, clon=0
-<70510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equirectangular Miranda Areographic, clon=0
-<70511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equirectangular Miranda Areocentric, clon=180
-<70512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equirectangular Miranda Areographic, clon=180
-<70513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areocentric, clon=0
-<70514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areographic, clon=0
-<70515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areocentric, clon=180
-<70516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areographic, clon=180
-<70517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# North Polar Miranda Areocentric, clon=0
-<70518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# North Polar Miranda Areographic, clon=0
-<70519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# South Polar Miranda Areocentric, clon=0
-<70520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# South Polar Miranda Areographic, clon=0
-<70521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areocentric, clon=0
-<70522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areographic, clon=0
-<70523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areocentric, clon=180
-<70524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areographic, clon=180
-<70525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areocentric, clon=0
-<70526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areographic, clon=0
-<70527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areocentric, clon=180
-<70528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areographic, clon=180
-<70529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal AUTO Miranda Areocentric
-<70560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal AUTO Miranda Areographic
-<70561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Stereographic AUTO Miranda Areocentric, clon=0
-<70562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Stereographic AUTO Miranda Areographic, clon=0
-<70563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Transverse Mercator AUTO Miranda Areocentric
-<70564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Transverse Mercator AUTO Miranda Areographic
-<70565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Orthographic AUTO Miranda Areocentric
-<70566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Orthographic AUTO Miranda Areographic
-<70567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Miranda Areocentric
-<70568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Miranda Areographic
-<70569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Miranda Areocentric
-<70570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Miranda Areographic
-<70571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Miranda Areocentric
-<70572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Miranda Areographic
-<70573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mercator AUTO Miranda Areocentric
-<70574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mercator AUTO Miranda Areographic
-<70575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Albers AUTO Miranda Areocentric
-<70576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Albers AUTO Miranda Areographic
-<70577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide AUTO Miranda Areocentric
-<70580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide AUTO Miranda Areographic
-<70581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson AUTO Miranda Areocentric
-<70582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson AUTO Miranda Areographic
-<70583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# GEOGCS Cordelia Areocentric
-<70600> 	+proj=longlat +a=13000 +b=13000 +no_defs
-# GEOGCS Cordelia Areographic
-<70601> 	+proj=longlat +a=13000 +b=13000 +no_defs
-# Equirectangular Cordelia Areocentric, clon=0
-<70610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equirectangular Cordelia Areographic, clon=0
-<70611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equirectangular Cordelia Areocentric, clon=180
-<70612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equirectangular Cordelia Areographic, clon=180
-<70613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areocentric, clon=0
-<70614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areographic, clon=0
-<70615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areocentric, clon=180
-<70616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areographic, clon=180
-<70617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# North Polar Cordelia Areocentric, clon=0
-<70618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# North Polar Cordelia Areographic, clon=0
-<70619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# South Polar Cordelia Areocentric, clon=0
-<70620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# South Polar Cordelia Areographic, clon=0
-<70621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areocentric, clon=0
-<70622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areographic, clon=0
-<70623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areocentric, clon=180
-<70624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areographic, clon=180
-<70625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areocentric, clon=0
-<70626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areographic, clon=0
-<70627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areocentric, clon=180
-<70628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areographic, clon=180
-<70629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal AUTO Cordelia Areocentric
-<70660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal AUTO Cordelia Areographic
-<70661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Stereographic AUTO Cordelia Areocentric, clon=0
-<70662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Stereographic AUTO Cordelia Areographic, clon=0
-<70663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Transverse Mercator AUTO Cordelia Areocentric
-<70664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Transverse Mercator AUTO Cordelia Areographic
-<70665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Orthographic AUTO Cordelia Areocentric
-<70666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Orthographic AUTO Cordelia Areographic
-<70667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cordelia Areocentric
-<70668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cordelia Areographic
-<70669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cordelia Areocentric
-<70670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cordelia Areographic
-<70671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cordelia Areocentric
-<70672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cordelia Areographic
-<70673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mercator AUTO Cordelia Areocentric
-<70674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mercator AUTO Cordelia Areographic
-<70675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Albers AUTO Cordelia Areocentric
-<70676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Albers AUTO Cordelia Areographic
-<70677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide AUTO Cordelia Areocentric
-<70680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide AUTO Cordelia Areographic
-<70681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson AUTO Cordelia Areocentric
-<70682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson AUTO Cordelia Areographic
-<70683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# GEOGCS Ophelia Areocentric
-<70700> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# GEOGCS Ophelia Areographic
-<70701> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# Equirectangular Ophelia Areocentric, clon=0
-<70710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Ophelia Areographic, clon=0
-<70711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Ophelia Areocentric, clon=180
-<70712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Ophelia Areographic, clon=180
-<70713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areocentric, clon=0
-<70714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areographic, clon=0
-<70715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areocentric, clon=180
-<70716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areographic, clon=180
-<70717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Ophelia Areocentric, clon=0
-<70718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Ophelia Areographic, clon=0
-<70719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Ophelia Areocentric, clon=0
-<70720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Ophelia Areographic, clon=0
-<70721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areocentric, clon=0
-<70722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areographic, clon=0
-<70723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areocentric, clon=180
-<70724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areographic, clon=180
-<70725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areocentric, clon=0
-<70726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areographic, clon=0
-<70727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areocentric, clon=180
-<70728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areographic, clon=180
-<70729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Ophelia Areocentric
-<70760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Ophelia Areographic
-<70761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Ophelia Areocentric, clon=0
-<70762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Ophelia Areographic, clon=0
-<70763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Ophelia Areocentric
-<70764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Ophelia Areographic
-<70765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Ophelia Areocentric
-<70766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Ophelia Areographic
-<70767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ophelia Areocentric
-<70768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ophelia Areographic
-<70769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ophelia Areocentric
-<70770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ophelia Areographic
-<70771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ophelia Areocentric
-<70772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ophelia Areographic
-<70773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Ophelia Areocentric
-<70774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Ophelia Areographic
-<70775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Ophelia Areocentric
-<70776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Ophelia Areographic
-<70777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Ophelia Areocentric
-<70780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Ophelia Areographic
-<70781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Ophelia Areocentric
-<70782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Ophelia Areographic
-<70783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# GEOGCS Bianca Areocentric
-<70800> 	+proj=longlat +a=21000 +b=21000 +no_defs
-# GEOGCS Bianca Areographic
-<70801> 	+proj=longlat +a=21000 +b=21000 +no_defs
-# Equirectangular Bianca Areocentric, clon=0
-<70810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equirectangular Bianca Areographic, clon=0
-<70811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equirectangular Bianca Areocentric, clon=180
-<70812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equirectangular Bianca Areographic, clon=180
-<70813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areocentric, clon=0
-<70814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areographic, clon=0
-<70815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areocentric, clon=180
-<70816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areographic, clon=180
-<70817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# North Polar Bianca Areocentric, clon=0
-<70818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# North Polar Bianca Areographic, clon=0
-<70819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# South Polar Bianca Areocentric, clon=0
-<70820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# South Polar Bianca Areographic, clon=0
-<70821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areocentric, clon=0
-<70822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areographic, clon=0
-<70823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areocentric, clon=180
-<70824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areographic, clon=180
-<70825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areocentric, clon=0
-<70826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areographic, clon=0
-<70827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areocentric, clon=180
-<70828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areographic, clon=180
-<70829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal AUTO Bianca Areocentric
-<70860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal AUTO Bianca Areographic
-<70861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Stereographic AUTO Bianca Areocentric, clon=0
-<70862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Stereographic AUTO Bianca Areographic, clon=0
-<70863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Transverse Mercator AUTO Bianca Areocentric
-<70864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Transverse Mercator AUTO Bianca Areographic
-<70865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Orthographic AUTO Bianca Areocentric
-<70866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Orthographic AUTO Bianca Areographic
-<70867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Bianca Areocentric
-<70868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Bianca Areographic
-<70869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Bianca Areocentric
-<70870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Bianca Areographic
-<70871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Bianca Areocentric
-<70872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Bianca Areographic
-<70873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mercator AUTO Bianca Areocentric
-<70874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mercator AUTO Bianca Areographic
-<70875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Albers AUTO Bianca Areocentric
-<70876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Albers AUTO Bianca Areographic
-<70877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide AUTO Bianca Areocentric
-<70880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide AUTO Bianca Areographic
-<70881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson AUTO Bianca Areocentric
-<70882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson AUTO Bianca Areographic
-<70883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# GEOGCS Cressida Areocentric
-<70900> 	+proj=longlat +a=31000 +b=31000 +no_defs
-# GEOGCS Cressida Areographic
-<70901> 	+proj=longlat +a=31000 +b=31000 +no_defs
-# Equirectangular Cressida Areocentric, clon=0
-<70910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equirectangular Cressida Areographic, clon=0
-<70911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equirectangular Cressida Areocentric, clon=180
-<70912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equirectangular Cressida Areographic, clon=180
-<70913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areocentric, clon=0
-<70914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areographic, clon=0
-<70915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areocentric, clon=180
-<70916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areographic, clon=180
-<70917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# North Polar Cressida Areocentric, clon=0
-<70918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# North Polar Cressida Areographic, clon=0
-<70919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# South Polar Cressida Areocentric, clon=0
-<70920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# South Polar Cressida Areographic, clon=0
-<70921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areocentric, clon=0
-<70922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areographic, clon=0
-<70923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areocentric, clon=180
-<70924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areographic, clon=180
-<70925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areocentric, clon=0
-<70926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areographic, clon=0
-<70927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areocentric, clon=180
-<70928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areographic, clon=180
-<70929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal AUTO Cressida Areocentric
-<70960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal AUTO Cressida Areographic
-<70961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Stereographic AUTO Cressida Areocentric, clon=0
-<70962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Stereographic AUTO Cressida Areographic, clon=0
-<70963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Transverse Mercator AUTO Cressida Areocentric
-<70964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Transverse Mercator AUTO Cressida Areographic
-<70965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Orthographic AUTO Cressida Areocentric
-<70966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Orthographic AUTO Cressida Areographic
-<70967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cressida Areocentric
-<70968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cressida Areographic
-<70969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cressida Areocentric
-<70970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cressida Areographic
-<70971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cressida Areocentric
-<70972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cressida Areographic
-<70973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mercator AUTO Cressida Areocentric
-<70974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mercator AUTO Cressida Areographic
-<70975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Albers AUTO Cressida Areocentric
-<70976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Albers AUTO Cressida Areographic
-<70977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide AUTO Cressida Areocentric
-<70980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide AUTO Cressida Areographic
-<70981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson AUTO Cressida Areocentric
-<70982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson AUTO Cressida Areographic
-<70983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# GEOGCS Desdemona Areocentric
-<71000> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# GEOGCS Desdemona Areographic
-<71001> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# Equirectangular Desdemona Areocentric, clon=0
-<71010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Desdemona Areographic, clon=0
-<71011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Desdemona Areocentric, clon=180
-<71012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Desdemona Areographic, clon=180
-<71013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areocentric, clon=0
-<71014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areographic, clon=0
-<71015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areocentric, clon=180
-<71016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areographic, clon=180
-<71017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Desdemona Areocentric, clon=0
-<71018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Desdemona Areographic, clon=0
-<71019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Desdemona Areocentric, clon=0
-<71020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Desdemona Areographic, clon=0
-<71021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areocentric, clon=0
-<71022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areographic, clon=0
-<71023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areocentric, clon=180
-<71024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areographic, clon=180
-<71025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areocentric, clon=0
-<71026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areographic, clon=0
-<71027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areocentric, clon=180
-<71028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areographic, clon=180
-<71029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Desdemona Areocentric
-<71060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Desdemona Areographic
-<71061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Desdemona Areocentric, clon=0
-<71062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Desdemona Areographic, clon=0
-<71063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Desdemona Areocentric
-<71064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Desdemona Areographic
-<71065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Desdemona Areocentric
-<71066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Desdemona Areographic
-<71067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Desdemona Areocentric
-<71068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Desdemona Areographic
-<71069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Desdemona Areocentric
-<71070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Desdemona Areographic
-<71071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Desdemona Areocentric
-<71072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Desdemona Areographic
-<71073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Desdemona Areocentric
-<71074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Desdemona Areographic
-<71075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Desdemona Areocentric
-<71076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Desdemona Areographic
-<71077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Desdemona Areocentric
-<71080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Desdemona Areographic
-<71081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Desdemona Areocentric
-<71082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Desdemona Areographic
-<71083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# GEOGCS Juliet Areocentric
-<71100> 	+proj=longlat +a=42000 +b=42000 +no_defs
-# GEOGCS Juliet Areographic
-<71101> 	+proj=longlat +a=42000 +b=42000 +no_defs
-# Equirectangular Juliet Areocentric, clon=0
-<71110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equirectangular Juliet Areographic, clon=0
-<71111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equirectangular Juliet Areocentric, clon=180
-<71112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equirectangular Juliet Areographic, clon=180
-<71113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areocentric, clon=0
-<71114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areographic, clon=0
-<71115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areocentric, clon=180
-<71116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areographic, clon=180
-<71117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# North Polar Juliet Areocentric, clon=0
-<71118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# North Polar Juliet Areographic, clon=0
-<71119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# South Polar Juliet Areocentric, clon=0
-<71120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# South Polar Juliet Areographic, clon=0
-<71121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areocentric, clon=0
-<71122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areographic, clon=0
-<71123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areocentric, clon=180
-<71124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areographic, clon=180
-<71125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areocentric, clon=0
-<71126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areographic, clon=0
-<71127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areocentric, clon=180
-<71128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areographic, clon=180
-<71129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal AUTO Juliet Areocentric
-<71160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal AUTO Juliet Areographic
-<71161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Stereographic AUTO Juliet Areocentric, clon=0
-<71162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Stereographic AUTO Juliet Areographic, clon=0
-<71163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Transverse Mercator AUTO Juliet Areocentric
-<71164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Transverse Mercator AUTO Juliet Areographic
-<71165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Orthographic AUTO Juliet Areocentric
-<71166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Orthographic AUTO Juliet Areographic
-<71167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Juliet Areocentric
-<71168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Juliet Areographic
-<71169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Juliet Areocentric
-<71170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Juliet Areographic
-<71171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Juliet Areocentric
-<71172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Juliet Areographic
-<71173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mercator AUTO Juliet Areocentric
-<71174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mercator AUTO Juliet Areographic
-<71175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Albers AUTO Juliet Areocentric
-<71176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Albers AUTO Juliet Areographic
-<71177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide AUTO Juliet Areocentric
-<71180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide AUTO Juliet Areographic
-<71181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson AUTO Juliet Areocentric
-<71182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson AUTO Juliet Areographic
-<71183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# GEOGCS Portia Areocentric
-<71200> 	+proj=longlat +a=54000 +b=54000 +no_defs
-# GEOGCS Portia Areographic
-<71201> 	+proj=longlat +a=54000 +b=54000 +no_defs
-# Equirectangular Portia Areocentric, clon=0
-<71210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equirectangular Portia Areographic, clon=0
-<71211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equirectangular Portia Areocentric, clon=180
-<71212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equirectangular Portia Areographic, clon=180
-<71213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areocentric, clon=0
-<71214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areographic, clon=0
-<71215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areocentric, clon=180
-<71216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areographic, clon=180
-<71217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# North Polar Portia Areocentric, clon=0
-<71218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# North Polar Portia Areographic, clon=0
-<71219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# South Polar Portia Areocentric, clon=0
-<71220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# South Polar Portia Areographic, clon=0
-<71221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areocentric, clon=0
-<71222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areographic, clon=0
-<71223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areocentric, clon=180
-<71224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areographic, clon=180
-<71225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areocentric, clon=0
-<71226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areographic, clon=0
-<71227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areocentric, clon=180
-<71228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areographic, clon=180
-<71229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal AUTO Portia Areocentric
-<71260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal AUTO Portia Areographic
-<71261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Stereographic AUTO Portia Areocentric, clon=0
-<71262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Stereographic AUTO Portia Areographic, clon=0
-<71263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Transverse Mercator AUTO Portia Areocentric
-<71264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Transverse Mercator AUTO Portia Areographic
-<71265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Orthographic AUTO Portia Areocentric
-<71266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Orthographic AUTO Portia Areographic
-<71267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Portia Areocentric
-<71268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Portia Areographic
-<71269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Portia Areocentric
-<71270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Portia Areographic
-<71271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Portia Areocentric
-<71272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Portia Areographic
-<71273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mercator AUTO Portia Areocentric
-<71274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mercator AUTO Portia Areographic
-<71275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Albers AUTO Portia Areocentric
-<71276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Albers AUTO Portia Areographic
-<71277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide AUTO Portia Areocentric
-<71280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide AUTO Portia Areographic
-<71281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson AUTO Portia Areocentric
-<71282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson AUTO Portia Areographic
-<71283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# GEOGCS Rosalind Areocentric
-<71300> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# GEOGCS Rosalind Areographic
-<71301> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# Equirectangular Rosalind Areocentric, clon=0
-<71310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Rosalind Areographic, clon=0
-<71311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Rosalind Areocentric, clon=180
-<71312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Rosalind Areographic, clon=180
-<71313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areocentric, clon=0
-<71314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areographic, clon=0
-<71315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areocentric, clon=180
-<71316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areographic, clon=180
-<71317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Rosalind Areocentric, clon=0
-<71318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Rosalind Areographic, clon=0
-<71319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Rosalind Areocentric, clon=0
-<71320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Rosalind Areographic, clon=0
-<71321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areocentric, clon=0
-<71322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areographic, clon=0
-<71323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areocentric, clon=180
-<71324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areographic, clon=180
-<71325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areocentric, clon=0
-<71326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areographic, clon=0
-<71327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areocentric, clon=180
-<71328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areographic, clon=180
-<71329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Rosalind Areocentric
-<71360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Rosalind Areographic
-<71361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Rosalind Areocentric, clon=0
-<71362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Rosalind Areographic, clon=0
-<71363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Rosalind Areocentric
-<71364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Rosalind Areographic
-<71365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Rosalind Areocentric
-<71366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Rosalind Areographic
-<71367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rosalind Areocentric
-<71368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rosalind Areographic
-<71369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rosalind Areocentric
-<71370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rosalind Areographic
-<71371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rosalind Areocentric
-<71372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rosalind Areographic
-<71373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Rosalind Areocentric
-<71374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Rosalind Areographic
-<71375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Rosalind Areocentric
-<71376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Rosalind Areographic
-<71377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Rosalind Areocentric
-<71380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Rosalind Areographic
-<71381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Rosalind Areocentric
-<71382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Rosalind Areographic
-<71383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# GEOGCS Belinda Areocentric
-<71400> 	+proj=longlat +a=33000 +b=33000 +no_defs
-# GEOGCS Belinda Areographic
-<71401> 	+proj=longlat +a=33000 +b=33000 +no_defs
-# Equirectangular Belinda Areocentric, clon=0
-<71410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equirectangular Belinda Areographic, clon=0
-<71411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equirectangular Belinda Areocentric, clon=180
-<71412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equirectangular Belinda Areographic, clon=180
-<71413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areocentric, clon=0
-<71414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areographic, clon=0
-<71415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areocentric, clon=180
-<71416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areographic, clon=180
-<71417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# North Polar Belinda Areocentric, clon=0
-<71418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# North Polar Belinda Areographic, clon=0
-<71419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# South Polar Belinda Areocentric, clon=0
-<71420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# South Polar Belinda Areographic, clon=0
-<71421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areocentric, clon=0
-<71422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areographic, clon=0
-<71423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areocentric, clon=180
-<71424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areographic, clon=180
-<71425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areocentric, clon=0
-<71426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areographic, clon=0
-<71427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areocentric, clon=180
-<71428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areographic, clon=180
-<71429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal AUTO Belinda Areocentric
-<71460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal AUTO Belinda Areographic
-<71461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Stereographic AUTO Belinda Areocentric, clon=0
-<71462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Stereographic AUTO Belinda Areographic, clon=0
-<71463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Transverse Mercator AUTO Belinda Areocentric
-<71464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Transverse Mercator AUTO Belinda Areographic
-<71465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Orthographic AUTO Belinda Areocentric
-<71466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Orthographic AUTO Belinda Areographic
-<71467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Belinda Areocentric
-<71468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Belinda Areographic
-<71469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Belinda Areocentric
-<71470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Belinda Areographic
-<71471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Belinda Areocentric
-<71472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Belinda Areographic
-<71473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mercator AUTO Belinda Areocentric
-<71474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mercator AUTO Belinda Areographic
-<71475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Albers AUTO Belinda Areocentric
-<71476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Albers AUTO Belinda Areographic
-<71477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide AUTO Belinda Areocentric
-<71480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide AUTO Belinda Areographic
-<71481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson AUTO Belinda Areocentric
-<71482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson AUTO Belinda Areographic
-<71483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# GEOGCS Puck Areocentric
-<71500> 	+proj=longlat +a=77000 +b=77000 +no_defs
-# GEOGCS Puck Areographic
-<71501> 	+proj=longlat +a=77000 +b=77000 +no_defs
-# Equirectangular Puck Areocentric, clon=0
-<71510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equirectangular Puck Areographic, clon=0
-<71511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equirectangular Puck Areocentric, clon=180
-<71512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equirectangular Puck Areographic, clon=180
-<71513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areocentric, clon=0
-<71514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areographic, clon=0
-<71515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areocentric, clon=180
-<71516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areographic, clon=180
-<71517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# North Polar Puck Areocentric, clon=0
-<71518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# North Polar Puck Areographic, clon=0
-<71519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# South Polar Puck Areocentric, clon=0
-<71520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# South Polar Puck Areographic, clon=0
-<71521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areocentric, clon=0
-<71522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areographic, clon=0
-<71523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areocentric, clon=180
-<71524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areographic, clon=180
-<71525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areocentric, clon=0
-<71526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areographic, clon=0
-<71527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areocentric, clon=180
-<71528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areographic, clon=180
-<71529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal AUTO Puck Areocentric
-<71560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal AUTO Puck Areographic
-<71561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Stereographic AUTO Puck Areocentric, clon=0
-<71562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Stereographic AUTO Puck Areographic, clon=0
-<71563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Transverse Mercator AUTO Puck Areocentric
-<71564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Transverse Mercator AUTO Puck Areographic
-<71565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Orthographic AUTO Puck Areocentric
-<71566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Orthographic AUTO Puck Areographic
-<71567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Puck Areocentric
-<71568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Puck Areographic
-<71569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Puck Areocentric
-<71570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Puck Areographic
-<71571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Puck Areocentric
-<71572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Puck Areographic
-<71573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mercator AUTO Puck Areocentric
-<71574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mercator AUTO Puck Areographic
-<71575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Albers AUTO Puck Areocentric
-<71576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Albers AUTO Puck Areographic
-<71577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide AUTO Puck Areocentric
-<71580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide AUTO Puck Areographic
-<71581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson AUTO Puck Areocentric
-<71582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson AUTO Puck Areographic
-<71583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# GEOGCS Neptune Areocentric
-<89900> 	+proj=longlat +a=24764000 +b=-1425034021.193139 +no_defs
-# GEOGCS Neptune Areographic
-<89901> 	+proj=longlat +a=24764000 +b=-1425034021.193139 +no_defs
-# Equirectangular Neptune Areocentric, clon=0
-<89910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equirectangular Neptune Areographic, clon=0
-<89911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equirectangular Neptune Areocentric, clon=180
-<89912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equirectangular Neptune Areographic, clon=180
-<89913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areocentric, clon=0
-<89914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areographic, clon=0
-<89915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areocentric, clon=180
-<89916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areographic, clon=180
-<89917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# North Polar Neptune Areocentric, clon=0
-<89918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# North Polar Neptune Areographic, clon=0
-<89919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# South Polar Neptune Areocentric, clon=0
-<89920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# South Polar Neptune Areographic, clon=0
-<89921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areocentric, clon=0
-<89922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areographic, clon=0
-<89923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areocentric, clon=180
-<89924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areographic, clon=180
-<89925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areocentric, clon=0
-<89926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areographic, clon=0
-<89927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areocentric, clon=180
-<89928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areographic, clon=180
-<89929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal AUTO Neptune Areocentric
-<89960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal AUTO Neptune Areographic
-<89961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Stereographic AUTO Neptune Areocentric, clon=0
-<89962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Stereographic AUTO Neptune Areographic, clon=0
-<89963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Transverse Mercator AUTO Neptune Areocentric
-<89964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Transverse Mercator AUTO Neptune Areographic
-<89965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Orthographic AUTO Neptune Areocentric
-<89966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Orthographic AUTO Neptune Areographic
-<89967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equidistant Cylindrical AUTO Neptune Areocentric
-<89968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equidistant Cylindrical AUTO Neptune Areographic
-<89969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Conformal Conic AUTO Neptune Areocentric
-<89970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Conformal Conic AUTO Neptune Areographic
-<89971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Neptune Areocentric
-<89972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Neptune Areographic
-<89973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mercator AUTO Neptune Areocentric
-<89974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mercator AUTO Neptune Areographic
-<89975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Albers AUTO Neptune Areocentric
-<89976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Albers AUTO Neptune Areographic
-<89977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide AUTO Neptune Areocentric
-<89980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide AUTO Neptune Areographic
-<89981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson AUTO Neptune Areocentric
-<89982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson AUTO Neptune Areographic
-<89983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# GEOGCS Triton Areocentric
-<80100> 	+proj=longlat +a=1352600 +b=1352600 +no_defs
-# GEOGCS Triton Areographic
-<80101> 	+proj=longlat +a=1352600 +b=1352600 +no_defs
-# Equirectangular Triton Areocentric, clon=0
-<80110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equirectangular Triton Areographic, clon=0
-<80111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equirectangular Triton Areocentric, clon=180
-<80112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equirectangular Triton Areographic, clon=180
-<80113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areocentric, clon=0
-<80114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areographic, clon=0
-<80115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areocentric, clon=180
-<80116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areographic, clon=180
-<80117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# North Polar Triton Areocentric, clon=0
-<80118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# North Polar Triton Areographic, clon=0
-<80119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# South Polar Triton Areocentric, clon=0
-<80120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# South Polar Triton Areographic, clon=0
-<80121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areocentric, clon=0
-<80122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areographic, clon=0
-<80123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areocentric, clon=180
-<80124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areographic, clon=180
-<80125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areocentric, clon=0
-<80126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areographic, clon=0
-<80127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areocentric, clon=180
-<80128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areographic, clon=180
-<80129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal AUTO Triton Areocentric
-<80160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal AUTO Triton Areographic
-<80161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Stereographic AUTO Triton Areocentric, clon=0
-<80162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Stereographic AUTO Triton Areographic, clon=0
-<80163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Transverse Mercator AUTO Triton Areocentric
-<80164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Transverse Mercator AUTO Triton Areographic
-<80165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Orthographic AUTO Triton Areocentric
-<80166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Orthographic AUTO Triton Areographic
-<80167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Triton Areocentric
-<80168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Triton Areographic
-<80169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Triton Areocentric
-<80170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Triton Areographic
-<80171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Triton Areocentric
-<80172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Triton Areographic
-<80173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mercator AUTO Triton Areocentric
-<80174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mercator AUTO Triton Areographic
-<80175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Albers AUTO Triton Areocentric
-<80176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Albers AUTO Triton Areographic
-<80177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide AUTO Triton Areocentric
-<80180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide AUTO Triton Areographic
-<80181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson AUTO Triton Areocentric
-<80182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson AUTO Triton Areographic
-<80183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# GEOGCS Nereid Areocentric
-<80200> 	+proj=longlat +a=170000 +b=170000 +no_defs
-# GEOGCS Nereid Areographic
-<80201> 	+proj=longlat +a=170000 +b=170000 +no_defs
-# Equirectangular Nereid Areocentric, clon=0
-<80210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equirectangular Nereid Areographic, clon=0
-<80211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equirectangular Nereid Areocentric, clon=180
-<80212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equirectangular Nereid Areographic, clon=180
-<80213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areocentric, clon=0
-<80214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areographic, clon=0
-<80215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areocentric, clon=180
-<80216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areographic, clon=180
-<80217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# North Polar Nereid Areocentric, clon=0
-<80218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# North Polar Nereid Areographic, clon=0
-<80219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# South Polar Nereid Areocentric, clon=0
-<80220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# South Polar Nereid Areographic, clon=0
-<80221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areocentric, clon=0
-<80222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areographic, clon=0
-<80223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areocentric, clon=180
-<80224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areographic, clon=180
-<80225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areocentric, clon=0
-<80226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areographic, clon=0
-<80227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areocentric, clon=180
-<80228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areographic, clon=180
-<80229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal AUTO Nereid Areocentric
-<80260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal AUTO Nereid Areographic
-<80261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Stereographic AUTO Nereid Areocentric, clon=0
-<80262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Stereographic AUTO Nereid Areographic, clon=0
-<80263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Transverse Mercator AUTO Nereid Areocentric
-<80264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Transverse Mercator AUTO Nereid Areographic
-<80265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Orthographic AUTO Nereid Areocentric
-<80266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Orthographic AUTO Nereid Areographic
-<80267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Nereid Areocentric
-<80268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Nereid Areographic
-<80269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Nereid Areocentric
-<80270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Nereid Areographic
-<80271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Nereid Areocentric
-<80272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Nereid Areographic
-<80273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mercator AUTO Nereid Areocentric
-<80274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mercator AUTO Nereid Areographic
-<80275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Albers AUTO Nereid Areocentric
-<80276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Albers AUTO Nereid Areographic
-<80277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide AUTO Nereid Areocentric
-<80280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide AUTO Nereid Areographic
-<80281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson AUTO Nereid Areocentric
-<80282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson AUTO Nereid Areographic
-<80283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# GEOGCS Naiad Areocentric
-<80300> 	+proj=longlat +a=29000 +b=29000 +no_defs
-# GEOGCS Naiad Areographic
-<80301> 	+proj=longlat +a=29000 +b=29000 +no_defs
-# Equirectangular Naiad Areocentric, clon=0
-<80310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equirectangular Naiad Areographic, clon=0
-<80311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equirectangular Naiad Areocentric, clon=180
-<80312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equirectangular Naiad Areographic, clon=180
-<80313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areocentric, clon=0
-<80314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areographic, clon=0
-<80315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areocentric, clon=180
-<80316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areographic, clon=180
-<80317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# North Polar Naiad Areocentric, clon=0
-<80318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# North Polar Naiad Areographic, clon=0
-<80319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# South Polar Naiad Areocentric, clon=0
-<80320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# South Polar Naiad Areographic, clon=0
-<80321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areocentric, clon=0
-<80322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areographic, clon=0
-<80323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areocentric, clon=180
-<80324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areographic, clon=180
-<80325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areocentric, clon=0
-<80326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areographic, clon=0
-<80327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areocentric, clon=180
-<80328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areographic, clon=180
-<80329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal AUTO Naiad Areocentric
-<80360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal AUTO Naiad Areographic
-<80361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Stereographic AUTO Naiad Areocentric, clon=0
-<80362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Stereographic AUTO Naiad Areographic, clon=0
-<80363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Transverse Mercator AUTO Naiad Areocentric
-<80364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Transverse Mercator AUTO Naiad Areographic
-<80365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Orthographic AUTO Naiad Areocentric
-<80366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Orthographic AUTO Naiad Areographic
-<80367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Naiad Areocentric
-<80368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Naiad Areographic
-<80369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Naiad Areocentric
-<80370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Naiad Areographic
-<80371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Naiad Areocentric
-<80372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Naiad Areographic
-<80373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mercator AUTO Naiad Areocentric
-<80374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mercator AUTO Naiad Areographic
-<80375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Albers AUTO Naiad Areocentric
-<80376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Albers AUTO Naiad Areographic
-<80377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide AUTO Naiad Areocentric
-<80380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide AUTO Naiad Areographic
-<80381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson AUTO Naiad Areocentric
-<80382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson AUTO Naiad Areographic
-<80383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# GEOGCS Thalassa Areocentric
-<80400> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# GEOGCS Thalassa Areographic
-<80401> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# Equirectangular Thalassa Areocentric, clon=0
-<80410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Thalassa Areographic, clon=0
-<80411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Thalassa Areocentric, clon=180
-<80412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Thalassa Areographic, clon=180
-<80413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areocentric, clon=0
-<80414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areographic, clon=0
-<80415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areocentric, clon=180
-<80416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areographic, clon=180
-<80417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Thalassa Areocentric, clon=0
-<80418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Thalassa Areographic, clon=0
-<80419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Thalassa Areocentric, clon=0
-<80420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Thalassa Areographic, clon=0
-<80421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areocentric, clon=0
-<80422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areographic, clon=0
-<80423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areocentric, clon=180
-<80424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areographic, clon=180
-<80425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areocentric, clon=0
-<80426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areographic, clon=0
-<80427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areocentric, clon=180
-<80428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areographic, clon=180
-<80429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Thalassa Areocentric
-<80460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Thalassa Areographic
-<80461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Thalassa Areocentric, clon=0
-<80462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Thalassa Areographic, clon=0
-<80463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Thalassa Areocentric
-<80464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Thalassa Areographic
-<80465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Thalassa Areocentric
-<80466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Thalassa Areographic
-<80467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thalassa Areocentric
-<80468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thalassa Areographic
-<80469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thalassa Areocentric
-<80470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thalassa Areographic
-<80471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thalassa Areocentric
-<80472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thalassa Areographic
-<80473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Thalassa Areocentric
-<80474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Thalassa Areographic
-<80475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Thalassa Areocentric
-<80476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Thalassa Areographic
-<80477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Thalassa Areocentric
-<80480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Thalassa Areographic
-<80481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Thalassa Areocentric
-<80482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Thalassa Areographic
-<80483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# GEOGCS Despina Areocentric
-<80500> 	+proj=longlat +a=74000 +b=74000 +no_defs
-# GEOGCS Despina Areographic
-<80501> 	+proj=longlat +a=74000 +b=74000 +no_defs
-# Equirectangular Despina Areocentric, clon=0
-<80510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equirectangular Despina Areographic, clon=0
-<80511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equirectangular Despina Areocentric, clon=180
-<80512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equirectangular Despina Areographic, clon=180
-<80513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areocentric, clon=0
-<80514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areographic, clon=0
-<80515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areocentric, clon=180
-<80516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areographic, clon=180
-<80517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# North Polar Despina Areocentric, clon=0
-<80518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# North Polar Despina Areographic, clon=0
-<80519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# South Polar Despina Areocentric, clon=0
-<80520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# South Polar Despina Areographic, clon=0
-<80521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areocentric, clon=0
-<80522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areographic, clon=0
-<80523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areocentric, clon=180
-<80524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areographic, clon=180
-<80525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areocentric, clon=0
-<80526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areographic, clon=0
-<80527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areocentric, clon=180
-<80528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areographic, clon=180
-<80529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal AUTO Despina Areocentric
-<80560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal AUTO Despina Areographic
-<80561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Stereographic AUTO Despina Areocentric, clon=0
-<80562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Stereographic AUTO Despina Areographic, clon=0
-<80563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Transverse Mercator AUTO Despina Areocentric
-<80564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Transverse Mercator AUTO Despina Areographic
-<80565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Orthographic AUTO Despina Areocentric
-<80566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Orthographic AUTO Despina Areographic
-<80567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Despina Areocentric
-<80568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Despina Areographic
-<80569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Despina Areocentric
-<80570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Despina Areographic
-<80571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Despina Areocentric
-<80572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Despina Areographic
-<80573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mercator AUTO Despina Areocentric
-<80574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mercator AUTO Despina Areographic
-<80575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Albers AUTO Despina Areocentric
-<80576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Albers AUTO Despina Areographic
-<80577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide AUTO Despina Areocentric
-<80580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide AUTO Despina Areographic
-<80581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson AUTO Despina Areocentric
-<80582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson AUTO Despina Areographic
-<80583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# GEOGCS Galatea Areocentric
-<80600> 	+proj=longlat +a=79000 +b=79000 +no_defs
-# GEOGCS Galatea Areographic
-<80601> 	+proj=longlat +a=79000 +b=79000 +no_defs
-# Equirectangular Galatea Areocentric, clon=0
-<80610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equirectangular Galatea Areographic, clon=0
-<80611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equirectangular Galatea Areocentric, clon=180
-<80612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equirectangular Galatea Areographic, clon=180
-<80613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areocentric, clon=0
-<80614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areographic, clon=0
-<80615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areocentric, clon=180
-<80616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areographic, clon=180
-<80617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# North Polar Galatea Areocentric, clon=0
-<80618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# North Polar Galatea Areographic, clon=0
-<80619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# South Polar Galatea Areocentric, clon=0
-<80620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# South Polar Galatea Areographic, clon=0
-<80621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areocentric, clon=0
-<80622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areographic, clon=0
-<80623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areocentric, clon=180
-<80624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areographic, clon=180
-<80625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areocentric, clon=0
-<80626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areographic, clon=0
-<80627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areocentric, clon=180
-<80628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areographic, clon=180
-<80629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal AUTO Galatea Areocentric
-<80660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal AUTO Galatea Areographic
-<80661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Stereographic AUTO Galatea Areocentric, clon=0
-<80662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Stereographic AUTO Galatea Areographic, clon=0
-<80663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Transverse Mercator AUTO Galatea Areocentric
-<80664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Transverse Mercator AUTO Galatea Areographic
-<80665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Orthographic AUTO Galatea Areocentric
-<80666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Orthographic AUTO Galatea Areographic
-<80667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Galatea Areocentric
-<80668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Galatea Areographic
-<80669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Galatea Areocentric
-<80670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Galatea Areographic
-<80671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Galatea Areocentric
-<80672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Galatea Areographic
-<80673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mercator AUTO Galatea Areocentric
-<80674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mercator AUTO Galatea Areographic
-<80675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Albers AUTO Galatea Areocentric
-<80676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Albers AUTO Galatea Areographic
-<80677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide AUTO Galatea Areocentric
-<80680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide AUTO Galatea Areographic
-<80681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson AUTO Galatea Areocentric
-<80682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson AUTO Galatea Areographic
-<80683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# GEOGCS Larissa Areocentric
-<80700> 	+proj=longlat +a=96000 +b=-1220565.409986697 +no_defs
-# GEOGCS Larissa Areographic
-<80701> 	+proj=longlat +a=96000 +b=-1220565.409986697 +no_defs
-# Equirectangular Larissa Areocentric, clon=0
-<80710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equirectangular Larissa Areographic, clon=0
-<80711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equirectangular Larissa Areocentric, clon=180
-<80712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equirectangular Larissa Areographic, clon=180
-<80713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areocentric, clon=0
-<80714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areographic, clon=0
-<80715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areocentric, clon=180
-<80716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areographic, clon=180
-<80717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# North Polar Larissa Areocentric, clon=0
-<80718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# North Polar Larissa Areographic, clon=0
-<80719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# South Polar Larissa Areocentric, clon=0
-<80720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# South Polar Larissa Areographic, clon=0
-<80721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areocentric, clon=0
-<80722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areographic, clon=0
-<80723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areocentric, clon=180
-<80724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areographic, clon=180
-<80725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areocentric, clon=0
-<80726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areographic, clon=0
-<80727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areocentric, clon=180
-<80728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areographic, clon=180
-<80729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal AUTO Larissa Areocentric
-<80760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal AUTO Larissa Areographic
-<80761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Stereographic AUTO Larissa Areocentric, clon=0
-<80762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Stereographic AUTO Larissa Areographic, clon=0
-<80763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Transverse Mercator AUTO Larissa Areocentric
-<80764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Transverse Mercator AUTO Larissa Areographic
-<80765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Orthographic AUTO Larissa Areocentric
-<80766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Orthographic AUTO Larissa Areographic
-<80767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equidistant Cylindrical AUTO Larissa Areocentric
-<80768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equidistant Cylindrical AUTO Larissa Areographic
-<80769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Conformal Conic AUTO Larissa Areocentric
-<80770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Conformal Conic AUTO Larissa Areographic
-<80771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Larissa Areocentric
-<80772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Larissa Areographic
-<80773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mercator AUTO Larissa Areocentric
-<80774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mercator AUTO Larissa Areographic
-<80775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Albers AUTO Larissa Areocentric
-<80776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Albers AUTO Larissa Areographic
-<80777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide AUTO Larissa Areocentric
-<80780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide AUTO Larissa Areographic
-<80781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson AUTO Larissa Areocentric
-<80782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson AUTO Larissa Areographic
-<80783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# GEOGCS Proteus Areocentric
-<80800> 	+proj=longlat +a=208000 +b=208000 +no_defs
-# GEOGCS Proteus Areographic
-<80801> 	+proj=longlat +a=208000 +b=208000 +no_defs
-# Equirectangular Proteus Areocentric, clon=0
-<80810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equirectangular Proteus Areographic, clon=0
-<80811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equirectangular Proteus Areocentric, clon=180
-<80812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equirectangular Proteus Areographic, clon=180
-<80813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areocentric, clon=0
-<80814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areographic, clon=0
-<80815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areocentric, clon=180
-<80816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areographic, clon=180
-<80817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# North Polar Proteus Areocentric, clon=0
-<80818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# North Polar Proteus Areographic, clon=0
-<80819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# South Polar Proteus Areocentric, clon=0
-<80820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# South Polar Proteus Areographic, clon=0
-<80821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areocentric, clon=0
-<80822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areographic, clon=0
-<80823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areocentric, clon=180
-<80824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areographic, clon=180
-<80825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areocentric, clon=0
-<80826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areographic, clon=0
-<80827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areocentric, clon=180
-<80828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areographic, clon=180
-<80829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal AUTO Proteus Areocentric
-<80860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal AUTO Proteus Areographic
-<80861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Stereographic AUTO Proteus Areocentric, clon=0
-<80862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Stereographic AUTO Proteus Areographic, clon=0
-<80863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Transverse Mercator AUTO Proteus Areocentric
-<80864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Transverse Mercator AUTO Proteus Areographic
-<80865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Orthographic AUTO Proteus Areocentric
-<80866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Orthographic AUTO Proteus Areographic
-<80867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Proteus Areocentric
-<80868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Proteus Areographic
-<80869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Proteus Areocentric
-<80870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Proteus Areographic
-<80871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Proteus Areocentric
-<80872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Proteus Areographic
-<80873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mercator AUTO Proteus Areocentric
-<80874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mercator AUTO Proteus Areographic
-<80875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Albers AUTO Proteus Areocentric
-<80876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Albers AUTO Proteus Areographic
-<80877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide AUTO Proteus Areocentric
-<80880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide AUTO Proteus Areographic
-<80881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson AUTO Proteus Areocentric
-<80882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson AUTO Proteus Areographic
-<80883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# GEOGCS Pluto Areocentric
-<99900> 	+proj=longlat +a=1195000 +b=1195000 +no_defs
-# GEOGCS Pluto Areographic
-<99901> 	+proj=longlat +a=1195000 +b=1195000 +no_defs
-# Equirectangular Pluto Areocentric, clon=0
-<99910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equirectangular Pluto Areographic, clon=0
-<99911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equirectangular Pluto Areocentric, clon=180
-<99912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equirectangular Pluto Areographic, clon=180
-<99913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areocentric, clon=0
-<99914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areographic, clon=0
-<99915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areocentric, clon=180
-<99916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areographic, clon=180
-<99917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# North Polar Pluto Areocentric, clon=0
-<99918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# North Polar Pluto Areographic, clon=0
-<99919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# South Polar Pluto Areocentric, clon=0
-<99920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# South Polar Pluto Areographic, clon=0
-<99921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areocentric, clon=0
-<99922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areographic, clon=0
-<99923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areocentric, clon=180
-<99924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areographic, clon=180
-<99925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areocentric, clon=0
-<99926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areographic, clon=0
-<99927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areocentric, clon=180
-<99928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areographic, clon=180
-<99929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal AUTO Pluto Areocentric
-<99960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal AUTO Pluto Areographic
-<99961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Stereographic AUTO Pluto Areocentric, clon=0
-<99962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Stereographic AUTO Pluto Areographic, clon=0
-<99963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Transverse Mercator AUTO Pluto Areocentric
-<99964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Transverse Mercator AUTO Pluto Areographic
-<99965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Orthographic AUTO Pluto Areocentric
-<99966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Orthographic AUTO Pluto Areographic
-<99967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pluto Areocentric
-<99968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pluto Areographic
-<99969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pluto Areocentric
-<99970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pluto Areographic
-<99971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pluto Areocentric
-<99972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pluto Areographic
-<99973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mercator AUTO Pluto Areocentric
-<99974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mercator AUTO Pluto Areographic
-<99975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Albers AUTO Pluto Areocentric
-<99976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Albers AUTO Pluto Areographic
-<99977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide AUTO Pluto Areocentric
-<99980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide AUTO Pluto Areographic
-<99981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson AUTO Pluto Areocentric
-<99982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson AUTO Pluto Areographic
-<99983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# GEOGCS Charon Areocentric
-<90100> 	+proj=longlat +a=593000 +b=593000 +no_defs
-# GEOGCS Charon Areographic
-<90101> 	+proj=longlat +a=593000 +b=593000 +no_defs
-# Equirectangular Charon Areocentric, clon=0
-<90110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Equirectangular Charon Areographic, clon=0
-<90111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Equirectangular Charon Areocentric, clon=180
-<90112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Equirectangular Charon Areographic, clon=180
-<90113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Sinusoidal Charon Areocentric, clon=0
-<90114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Sinusoidal Charon Areographic, clon=0
-<90115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Sinusoidal Charon Areocentric, clon=180
-<90116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Sinusoidal Charon Areographic, clon=180
-<90117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# North Polar Charon Areocentric, clon=0
-<90118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# North Polar Charon Areographic, clon=0
-<90119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# South Polar Charon Areocentric, clon=0
-<90120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# South Polar Charon Areographic, clon=0
-<90121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mollweide Charon Areocentric, clon=0
-<90122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mollweide Charon Areographic, clon=0
-<90123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mollweide Charon Areocentric, clon=180
-<90124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mollweide Charon Areographic, clon=180
-<90125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Robinson Charon Areocentric, clon=0
-<90126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Robinson Charon Areographic, clon=0
-<90127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Robinson Charon Areocentric, clon=180
-<90128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Robinson Charon Areographic, clon=180
-<90129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Sinusoidal AUTO Charon Areocentric
-<90160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Sinusoidal AUTO Charon Areographic
-<90161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Stereographic AUTO Charon Areocentric, clon=0
-<90162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Stereographic AUTO Charon Areographic, clon=0
-<90163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Transverse Mercator AUTO Charon Areocentric
-<90164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Transverse Mercator AUTO Charon Areographic
-<90165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Orthographic AUTO Charon Areocentric
-<90166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Orthographic AUTO Charon Areographic
-<90167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Charon Areocentric
-<90168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Charon Areographic
-<90169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Charon Areocentric
-<90170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Charon Areographic
-<90171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Charon Areocentric
-<90172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Charon Areographic
-<90173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mercator AUTO Charon Areocentric
-<90174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mercator AUTO Charon Areographic
-<90175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Albers AUTO Charon Areocentric
-<90176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Albers AUTO Charon Areographic
-<90177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mollweide AUTO Charon Areocentric
-<90180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Mollweide AUTO Charon Areographic
-<90181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Robinson AUTO Charon Areocentric
-<90182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# Robinson AUTO Charon Areographic
-<90183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=593000 +b=593000 +units=m +no_defs
-# GEOGCS Gaspra Areocentric
-<951101000> 	+proj=longlat +a=6100 +b=6100 +no_defs
-# GEOGCS Gaspra Areographic
-<951101001> 	+proj=longlat +a=6100 +b=6100 +no_defs
-# Equirectangular Gaspra Areocentric, clon=0
-<951101010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equirectangular Gaspra Areographic, clon=0
-<951101011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equirectangular Gaspra Areocentric, clon=180
-<951101012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equirectangular Gaspra Areographic, clon=180
-<951101013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areocentric, clon=0
-<951101014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areographic, clon=0
-<951101015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areocentric, clon=180
-<951101016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areographic, clon=180
-<951101017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# North Polar Gaspra Areocentric, clon=0
-<951101018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# North Polar Gaspra Areographic, clon=0
-<951101019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# South Polar Gaspra Areocentric, clon=0
-<951101020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# South Polar Gaspra Areographic, clon=0
-<951101021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areocentric, clon=0
-<951101022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areographic, clon=0
-<951101023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areocentric, clon=180
-<951101024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areographic, clon=180
-<951101025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areocentric, clon=0
-<951101026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areographic, clon=0
-<951101027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areocentric, clon=180
-<951101028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areographic, clon=180
-<951101029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal AUTO Gaspra Areocentric
-<951101060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal AUTO Gaspra Areographic
-<951101061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Stereographic AUTO Gaspra Areocentric, clon=0
-<951101062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Stereographic AUTO Gaspra Areographic, clon=0
-<951101063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Transverse Mercator AUTO Gaspra Areocentric
-<951101064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Transverse Mercator AUTO Gaspra Areographic
-<951101065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Orthographic AUTO Gaspra Areocentric
-<951101066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Orthographic AUTO Gaspra Areographic
-<951101067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Gaspra Areocentric
-<951101068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Gaspra Areographic
-<951101069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Gaspra Areocentric
-<951101070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Gaspra Areographic
-<951101071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Gaspra Areocentric
-<951101072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Gaspra Areographic
-<951101073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mercator AUTO Gaspra Areocentric
-<951101074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mercator AUTO Gaspra Areographic
-<951101075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Albers AUTO Gaspra Areocentric
-<951101076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Albers AUTO Gaspra Areographic
-<951101077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide AUTO Gaspra Areocentric
-<951101080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide AUTO Gaspra Areographic
-<951101081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson AUTO Gaspra Areocentric
-<951101082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson AUTO Gaspra Areographic
-<951101083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# GEOGCS Ida Areocentric
-<243101000> 	+proj=longlat +a=15650 +b=15650 +no_defs
-# GEOGCS Ida Areographic
-<243101001> 	+proj=longlat +a=15650 +b=15650 +no_defs
-# Equirectangular Ida Areocentric, clon=0
-<243101010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equirectangular Ida Areographic, clon=0
-<243101011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equirectangular Ida Areocentric, clon=180
-<243101012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equirectangular Ida Areographic, clon=180
-<243101013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areocentric, clon=0
-<243101014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areographic, clon=0
-<243101015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areocentric, clon=180
-<243101016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areographic, clon=180
-<243101017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# North Polar Ida Areocentric, clon=0
-<243101018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# North Polar Ida Areographic, clon=0
-<243101019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# South Polar Ida Areocentric, clon=0
-<243101020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# South Polar Ida Areographic, clon=0
-<243101021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areocentric, clon=0
-<243101022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areographic, clon=0
-<243101023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areocentric, clon=180
-<243101024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areographic, clon=180
-<243101025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areocentric, clon=0
-<243101026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areographic, clon=0
-<243101027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areocentric, clon=180
-<243101028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areographic, clon=180
-<243101029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal AUTO Ida Areocentric
-<243101060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal AUTO Ida Areographic
-<243101061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Stereographic AUTO Ida Areocentric, clon=0
-<243101062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Stereographic AUTO Ida Areographic, clon=0
-<243101063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Transverse Mercator AUTO Ida Areocentric
-<243101064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Transverse Mercator AUTO Ida Areographic
-<243101065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Orthographic AUTO Ida Areocentric
-<243101066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Orthographic AUTO Ida Areographic
-<243101067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ida Areocentric
-<243101068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ida Areographic
-<243101069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ida Areocentric
-<243101070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ida Areographic
-<243101071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ida Areocentric
-<243101072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ida Areographic
-<243101073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mercator AUTO Ida Areocentric
-<243101074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mercator AUTO Ida Areographic
-<243101075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Albers AUTO Ida Areocentric
-<243101076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Albers AUTO Ida Areographic
-<243101077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide AUTO Ida Areocentric
-<243101080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide AUTO Ida Areographic
-<243101081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson AUTO Ida Areocentric
-<243101082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson AUTO Ida Areographic
-<243101083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# GEOGCS Ceres Areocentric
-<200000100> 	+proj=longlat +a=487300 +b=-6796814.859713897 +no_defs
-# GEOGCS Ceres Areographic
-<200000101> 	+proj=longlat +a=487300 +b=-6796814.859713897 +no_defs
-# Equirectangular Ceres Areocentric, clon=0
-<200000110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equirectangular Ceres Areographic, clon=0
-<200000111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equirectangular Ceres Areocentric, clon=180
-<200000112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equirectangular Ceres Areographic, clon=180
-<200000113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areocentric, clon=0
-<200000114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areographic, clon=0
-<200000115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areocentric, clon=180
-<200000116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areographic, clon=180
-<200000117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# North Polar Ceres Areocentric, clon=0
-<200000118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# North Polar Ceres Areographic, clon=0
-<200000119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# South Polar Ceres Areocentric, clon=0
-<200000120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# South Polar Ceres Areographic, clon=0
-<200000121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areocentric, clon=0
-<200000122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areographic, clon=0
-<200000123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areocentric, clon=180
-<200000124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areographic, clon=180
-<200000125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areocentric, clon=0
-<200000126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areographic, clon=0
-<200000127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areocentric, clon=180
-<200000128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areographic, clon=180
-<200000129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal AUTO Ceres Areocentric
-<200000160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal AUTO Ceres Areographic
-<200000161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Stereographic AUTO Ceres Areocentric, clon=0
-<200000162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Stereographic AUTO Ceres Areographic, clon=0
-<200000163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Transverse Mercator AUTO Ceres Areocentric
-<200000164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Transverse Mercator AUTO Ceres Areographic
-<200000165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Orthographic AUTO Ceres Areocentric
-<200000166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Orthographic AUTO Ceres Areographic
-<200000167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ceres Areocentric
-<200000168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ceres Areographic
-<200000169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ceres Areocentric
-<200000170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ceres Areographic
-<200000171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ceres Areocentric
-<200000172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ceres Areographic
-<200000173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mercator AUTO Ceres Areocentric
-<200000174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mercator AUTO Ceres Areographic
-<200000175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Albers AUTO Ceres Areocentric
-<200000176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Albers AUTO Ceres Areographic
-<200000177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide AUTO Ceres Areocentric
-<200000180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide AUTO Ceres Areographic
-<200000181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson AUTO Ceres Areocentric
-<200000182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson AUTO Ceres Areographic
-<200000183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# GEOGCS Lutetia Areocentric
-<200002100> 	+proj=longlat +a=52500 +b=52500 +no_defs
-# GEOGCS Lutetia Areographic
-<200002101> 	+proj=longlat +a=52500 +b=52500 +no_defs
-# Equirectangular Lutetia Areocentric, clon=0
-<200002110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equirectangular Lutetia Areographic, clon=0
-<200002111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equirectangular Lutetia Areocentric, clon=180
-<200002112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equirectangular Lutetia Areographic, clon=180
-<200002113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areocentric, clon=0
-<200002114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areographic, clon=0
-<200002115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areocentric, clon=180
-<200002116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areographic, clon=180
-<200002117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# North Polar Lutetia Areocentric, clon=0
-<200002118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# North Polar Lutetia Areographic, clon=0
-<200002119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# South Polar Lutetia Areocentric, clon=0
-<200002120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# South Polar Lutetia Areographic, clon=0
-<200002121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areocentric, clon=0
-<200002122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areographic, clon=0
-<200002123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areocentric, clon=180
-<200002124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areographic, clon=180
-<200002125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areocentric, clon=0
-<200002126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areographic, clon=0
-<200002127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areocentric, clon=180
-<200002128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areographic, clon=180
-<200002129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal AUTO Lutetia Areocentric
-<200002160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal AUTO Lutetia Areographic
-<200002161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Stereographic AUTO Lutetia Areocentric, clon=0
-<200002162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Stereographic AUTO Lutetia Areographic, clon=0
-<200002163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Transverse Mercator AUTO Lutetia Areocentric
-<200002164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Transverse Mercator AUTO Lutetia Areographic
-<200002165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Orthographic AUTO Lutetia Areocentric
-<200002166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Orthographic AUTO Lutetia Areographic
-<200002167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lutetia Areocentric
-<200002168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lutetia Areographic
-<200002169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lutetia Areocentric
-<200002170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lutetia Areographic
-<200002171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lutetia Areocentric
-<200002172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lutetia Areographic
-<200002173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mercator AUTO Lutetia Areocentric
-<200002174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mercator AUTO Lutetia Areographic
-<200002175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Albers AUTO Lutetia Areocentric
-<200002176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Albers AUTO Lutetia Areographic
-<200002177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide AUTO Lutetia Areocentric
-<200002180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide AUTO Lutetia Areographic
-<200002181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson AUTO Lutetia Areocentric
-<200002182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson AUTO Lutetia Areographic
-<200002183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# GEOGCS Eros Areocentric
-<200043300> 	+proj=longlat +a=7311 +b=7311 +no_defs
-# GEOGCS Eros Areographic
-<200043301> 	+proj=longlat +a=7311 +b=7311 +no_defs
-# Equirectangular Eros Areocentric, clon=0
-<200043310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Equirectangular Eros Areographic, clon=0
-<200043311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Equirectangular Eros Areocentric, clon=180
-<200043312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Equirectangular Eros Areographic, clon=180
-<200043313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Sinusoidal Eros Areocentric, clon=0
-<200043314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Sinusoidal Eros Areographic, clon=0
-<200043315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Sinusoidal Eros Areocentric, clon=180
-<200043316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Sinusoidal Eros Areographic, clon=180
-<200043317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# North Polar Eros Areocentric, clon=0
-<200043318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# North Polar Eros Areographic, clon=0
-<200043319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# South Polar Eros Areocentric, clon=0
-<200043320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# South Polar Eros Areographic, clon=0
-<200043321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mollweide Eros Areocentric, clon=0
-<200043322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mollweide Eros Areographic, clon=0
-<200043323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mollweide Eros Areocentric, clon=180
-<200043324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mollweide Eros Areographic, clon=180
-<200043325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Robinson Eros Areocentric, clon=0
-<200043326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Robinson Eros Areographic, clon=0
-<200043327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Robinson Eros Areocentric, clon=180
-<200043328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Robinson Eros Areographic, clon=180
-<200043329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Sinusoidal AUTO Eros Areocentric
-<200043360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Sinusoidal AUTO Eros Areographic
-<200043361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Stereographic AUTO Eros Areocentric, clon=0
-<200043362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Stereographic AUTO Eros Areographic, clon=0
-<200043363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Transverse Mercator AUTO Eros Areocentric
-<200043364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Transverse Mercator AUTO Eros Areographic
-<200043365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Orthographic AUTO Eros Areocentric
-<200043366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Orthographic AUTO Eros Areographic
-<200043367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Equidistant Cylindrical AUTO Eros Areocentric
-<200043368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Equidistant Cylindrical AUTO Eros Areographic
-<200043369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Lambert Conformal Conic AUTO Eros Areocentric
-<200043370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Lambert Conformal Conic AUTO Eros Areographic
-<200043371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Eros Areocentric
-<200043372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Eros Areographic
-<200043373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mercator AUTO Eros Areocentric
-<200043374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mercator AUTO Eros Areographic
-<200043375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Albers AUTO Eros Areocentric
-<200043376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Albers AUTO Eros Areographic
-<200043377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mollweide AUTO Eros Areocentric
-<200043380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Mollweide AUTO Eros Areographic
-<200043381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Robinson AUTO Eros Areocentric
-<200043382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
-# Robinson AUTO Eros Areographic
-<200043383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=7311 +b=7311 +units=m +no_defs
Deleted: grass/trunk/lib/proj/iau2009.csv
--- grass/trunk/lib/proj/iau2009.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/iau2009.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,7656 +0,0 @@
-# GEOGCS Mercury Areocentric
-<19900> 	+proj=longlat +a=2439700 +b=2439700 +no_defs
-# GEOGCS Mercury Areographic
-<19901> 	+proj=longlat +a=2439700 +b=2439700 +no_defs
-# Equirectangular Mercury Areocentric, clon=0
-<19910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equirectangular Mercury Areographic, clon=0
-<19911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equirectangular Mercury Areocentric, clon=180
-<19912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equirectangular Mercury Areographic, clon=180
-<19913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areocentric, clon=0
-<19914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areographic, clon=0
-<19915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areocentric, clon=180
-<19916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal Mercury Areographic, clon=180
-<19917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# North Polar Mercury Areocentric, clon=0
-<19918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# North Polar Mercury Areographic, clon=0
-<19919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# South Polar Mercury Areocentric, clon=0
-<19920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# South Polar Mercury Areographic, clon=0
-<19921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areocentric, clon=0
-<19922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areographic, clon=0
-<19923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areocentric, clon=180
-<19924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide Mercury Areographic, clon=180
-<19925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areocentric, clon=0
-<19926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areographic, clon=0
-<19927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areocentric, clon=180
-<19928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson Mercury Areographic, clon=180
-<19929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal AUTO Mercury Areocentric
-<19960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Sinusoidal AUTO Mercury Areographic
-<19961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Stereographic AUTO Mercury Areocentric, clon=0
-<19962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Stereographic AUTO Mercury Areographic, clon=0
-<19963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Transverse Mercator AUTO Mercury Areocentric
-<19964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Transverse Mercator AUTO Mercury Areographic
-<19965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Orthographic AUTO Mercury Areocentric
-<19966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Orthographic AUTO Mercury Areographic
-<19967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mercury Areocentric
-<19968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mercury Areographic
-<19969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mercury Areocentric
-<19970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mercury Areographic
-<19971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mercury Areocentric
-<19972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mercury Areographic
-<19973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mercator AUTO Mercury Areocentric
-<19974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mercator AUTO Mercury Areographic
-<19975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Albers AUTO Mercury Areocentric
-<19976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Albers AUTO Mercury Areographic
-<19977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide AUTO Mercury Areocentric
-<19980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Mollweide AUTO Mercury Areographic
-<19981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson AUTO Mercury Areocentric
-<19982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# Robinson AUTO Mercury Areographic
-<19983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2439700 +b=2439700 +units=m +no_defs
-# GEOGCS Venus Areocentric
-<29900> 	+proj=longlat +a=6051800 +b=6051800 +no_defs
-# GEOGCS Venus Areographic
-<29901> 	+proj=longlat +a=6051800 +b=6051800 +no_defs
-# Equirectangular Venus Areocentric, clon=0
-<29910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equirectangular Venus Areographic, clon=0
-<29911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equirectangular Venus Areocentric, clon=180
-<29912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equirectangular Venus Areographic, clon=180
-<29913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areocentric, clon=0
-<29914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areographic, clon=0
-<29915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areocentric, clon=180
-<29916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal Venus Areographic, clon=180
-<29917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# North Polar Venus Areocentric, clon=0
-<29918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# North Polar Venus Areographic, clon=0
-<29919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# South Polar Venus Areocentric, clon=0
-<29920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# South Polar Venus Areographic, clon=0
-<29921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areocentric, clon=0
-<29922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areographic, clon=0
-<29923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areocentric, clon=180
-<29924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide Venus Areographic, clon=180
-<29925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areocentric, clon=0
-<29926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areographic, clon=0
-<29927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areocentric, clon=180
-<29928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson Venus Areographic, clon=180
-<29929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal AUTO Venus Areocentric
-<29960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Sinusoidal AUTO Venus Areographic
-<29961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Stereographic AUTO Venus Areocentric, clon=0
-<29962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Stereographic AUTO Venus Areographic, clon=0
-<29963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Transverse Mercator AUTO Venus Areocentric
-<29964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Transverse Mercator AUTO Venus Areographic
-<29965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Orthographic AUTO Venus Areocentric
-<29966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Orthographic AUTO Venus Areographic
-<29967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Venus Areocentric
-<29968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Venus Areographic
-<29969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Venus Areocentric
-<29970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Venus Areographic
-<29971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Venus Areocentric
-<29972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Venus Areographic
-<29973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mercator AUTO Venus Areocentric
-<29974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mercator AUTO Venus Areographic
-<29975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Albers AUTO Venus Areocentric
-<29976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Albers AUTO Venus Areographic
-<29977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide AUTO Venus Areocentric
-<29980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Mollweide AUTO Venus Areographic
-<29981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson AUTO Venus Areocentric
-<29982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# Robinson AUTO Venus Areographic
-<29983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6051800 +b=6051800 +units=m +no_defs
-# GEOGCS Earth Areocentric
-<39900> 	+proj=longlat +a=6378136.5 +b=-1895839728.098866 +no_defs
-# GEOGCS Earth Areographic
-<39901> 	+proj=longlat +a=6378136.5 +b=-1895839728.098866 +no_defs
-# Equirectangular Earth Areocentric, clon=0
-<39910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Equirectangular Earth Areographic, clon=0
-<39911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Equirectangular Earth Areocentric, clon=180
-<39912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Equirectangular Earth Areographic, clon=180
-<39913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Sinusoidal Earth Areocentric, clon=0
-<39914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Sinusoidal Earth Areographic, clon=0
-<39915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Sinusoidal Earth Areocentric, clon=180
-<39916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Sinusoidal Earth Areographic, clon=180
-<39917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# North Polar Earth Areocentric, clon=0
-<39918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# North Polar Earth Areographic, clon=0
-<39919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# South Polar Earth Areocentric, clon=0
-<39920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# South Polar Earth Areographic, clon=0
-<39921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mollweide Earth Areocentric, clon=0
-<39922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mollweide Earth Areographic, clon=0
-<39923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mollweide Earth Areocentric, clon=180
-<39924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mollweide Earth Areographic, clon=180
-<39925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Robinson Earth Areocentric, clon=0
-<39926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Robinson Earth Areographic, clon=0
-<39927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Robinson Earth Areocentric, clon=180
-<39928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Robinson Earth Areographic, clon=180
-<39929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Sinusoidal AUTO Earth Areocentric
-<39960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Sinusoidal AUTO Earth Areographic
-<39961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Stereographic AUTO Earth Areocentric, clon=0
-<39962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Stereographic AUTO Earth Areographic, clon=0
-<39963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Transverse Mercator AUTO Earth Areocentric
-<39964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Transverse Mercator AUTO Earth Areographic
-<39965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Orthographic AUTO Earth Areocentric
-<39966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Orthographic AUTO Earth Areographic
-<39967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Equidistant Cylindrical AUTO Earth Areocentric
-<39968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Equidistant Cylindrical AUTO Earth Areographic
-<39969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Lambert Conformal Conic AUTO Earth Areocentric
-<39970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Lambert Conformal Conic AUTO Earth Areographic
-<39971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Earth Areocentric
-<39972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Earth Areographic
-<39973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mercator AUTO Earth Areocentric
-<39974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mercator AUTO Earth Areographic
-<39975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Albers AUTO Earth Areocentric
-<39976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Albers AUTO Earth Areographic
-<39977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mollweide AUTO Earth Areocentric
-<39980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Mollweide AUTO Earth Areographic
-<39981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Robinson AUTO Earth Areocentric
-<39982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# Robinson AUTO Earth Areographic
-<39983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6378136.5 +b=-1895839728.098866 +units=m +no_defs
-# GEOGCS Moon Areocentric
-<30100> 	+proj=longlat +a=1737400 +b=1737400 +no_defs
-# GEOGCS Moon Areographic
-<30101> 	+proj=longlat +a=1737400 +b=1737400 +no_defs
-# Equirectangular Moon Areocentric, clon=0
-<30110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equirectangular Moon Areographic, clon=0
-<30111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equirectangular Moon Areocentric, clon=180
-<30112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equirectangular Moon Areographic, clon=180
-<30113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areocentric, clon=0
-<30114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areographic, clon=0
-<30115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areocentric, clon=180
-<30116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal Moon Areographic, clon=180
-<30117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# North Polar Moon Areocentric, clon=0
-<30118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# North Polar Moon Areographic, clon=0
-<30119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# South Polar Moon Areocentric, clon=0
-<30120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# South Polar Moon Areographic, clon=0
-<30121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areocentric, clon=0
-<30122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areographic, clon=0
-<30123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areocentric, clon=180
-<30124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide Moon Areographic, clon=180
-<30125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areocentric, clon=0
-<30126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areographic, clon=0
-<30127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areocentric, clon=180
-<30128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson Moon Areographic, clon=180
-<30129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal AUTO Moon Areocentric
-<30160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Sinusoidal AUTO Moon Areographic
-<30161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Stereographic AUTO Moon Areocentric, clon=0
-<30162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Stereographic AUTO Moon Areographic, clon=0
-<30163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Transverse Mercator AUTO Moon Areocentric
-<30164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Transverse Mercator AUTO Moon Areographic
-<30165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Orthographic AUTO Moon Areocentric
-<30166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Orthographic AUTO Moon Areographic
-<30167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Moon Areocentric
-<30168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Moon Areographic
-<30169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Moon Areocentric
-<30170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Moon Areographic
-<30171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Moon Areocentric
-<30172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Moon Areographic
-<30173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mercator AUTO Moon Areocentric
-<30174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mercator AUTO Moon Areographic
-<30175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Albers AUTO Moon Areocentric
-<30176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Albers AUTO Moon Areographic
-<30177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide AUTO Moon Areocentric
-<30180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Mollweide AUTO Moon Areographic
-<30181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson AUTO Moon Areocentric
-<30182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# Robinson AUTO Moon Areographic
-<30183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1737400 +b=1737400 +units=m +no_defs
-# GEOGCS Mars Areocentric
-<49900> 	+proj=longlat +a=3396190 +b=-573598373.3707101 +no_defs
-# GEOGCS Mars Areographic
-<49901> 	+proj=longlat +a=3396190 +b=-573598373.3707101 +no_defs
-# Equirectangular Mars Areocentric, clon=0
-<49910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equirectangular Mars Areographic, clon=0
-<49911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equirectangular Mars Areocentric, clon=180
-<49912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equirectangular Mars Areographic, clon=180
-<49913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areocentric, clon=0
-<49914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areographic, clon=0
-<49915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areocentric, clon=180
-<49916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal Mars Areographic, clon=180
-<49917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# North Polar Mars Areocentric, clon=0
-<49918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# North Polar Mars Areographic, clon=0
-<49919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# South Polar Mars Areocentric, clon=0
-<49920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# South Polar Mars Areographic, clon=0
-<49921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areocentric, clon=0
-<49922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areographic, clon=0
-<49923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areocentric, clon=180
-<49924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide Mars Areographic, clon=180
-<49925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areocentric, clon=0
-<49926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areographic, clon=0
-<49927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areocentric, clon=180
-<49928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson Mars Areographic, clon=180
-<49929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal AUTO Mars Areocentric
-<49960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Sinusoidal AUTO Mars Areographic
-<49961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Stereographic AUTO Mars Areocentric, clon=0
-<49962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Stereographic AUTO Mars Areographic, clon=0
-<49963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Transverse Mercator AUTO Mars Areocentric
-<49964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Transverse Mercator AUTO Mars Areographic
-<49965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Orthographic AUTO Mars Areocentric
-<49966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Orthographic AUTO Mars Areographic
-<49967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mars Areocentric
-<49968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mars Areographic
-<49969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mars Areocentric
-<49970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mars Areographic
-<49971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mars Areocentric
-<49972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mars Areographic
-<49973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mercator AUTO Mars Areocentric
-<49974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mercator AUTO Mars Areographic
-<49975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Albers AUTO Mars Areocentric
-<49976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Albers AUTO Mars Areographic
-<49977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide AUTO Mars Areocentric
-<49980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Mollweide AUTO Mars Areographic
-<49981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson AUTO Mars Areocentric
-<49982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# Robinson AUTO Mars Areographic
-<49983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3396190 +b=-573598373.3707101 +units=m +no_defs
-# GEOGCS Phobos Areocentric
-<40100> 	+proj=longlat +a=11080 +b=11080 +no_defs
-# GEOGCS Phobos Areographic
-<40101> 	+proj=longlat +a=11080 +b=11080 +no_defs
-# Equirectangular Phobos Areocentric, clon=0
-<40110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Equirectangular Phobos Areographic, clon=0
-<40111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Equirectangular Phobos Areocentric, clon=180
-<40112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Equirectangular Phobos Areographic, clon=180
-<40113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Sinusoidal Phobos Areocentric, clon=0
-<40114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Sinusoidal Phobos Areographic, clon=0
-<40115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Sinusoidal Phobos Areocentric, clon=180
-<40116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Sinusoidal Phobos Areographic, clon=180
-<40117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# North Polar Phobos Areocentric, clon=0
-<40118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# North Polar Phobos Areographic, clon=0
-<40119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# South Polar Phobos Areocentric, clon=0
-<40120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# South Polar Phobos Areographic, clon=0
-<40121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mollweide Phobos Areocentric, clon=0
-<40122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mollweide Phobos Areographic, clon=0
-<40123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mollweide Phobos Areocentric, clon=180
-<40124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mollweide Phobos Areographic, clon=180
-<40125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Robinson Phobos Areocentric, clon=0
-<40126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Robinson Phobos Areographic, clon=0
-<40127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Robinson Phobos Areocentric, clon=180
-<40128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Robinson Phobos Areographic, clon=180
-<40129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Sinusoidal AUTO Phobos Areocentric
-<40160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Sinusoidal AUTO Phobos Areographic
-<40161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Stereographic AUTO Phobos Areocentric, clon=0
-<40162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Stereographic AUTO Phobos Areographic, clon=0
-<40163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Transverse Mercator AUTO Phobos Areocentric
-<40164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Transverse Mercator AUTO Phobos Areographic
-<40165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Orthographic AUTO Phobos Areocentric
-<40166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Orthographic AUTO Phobos Areographic
-<40167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phobos Areocentric
-<40168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phobos Areographic
-<40169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phobos Areocentric
-<40170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phobos Areographic
-<40171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phobos Areocentric
-<40172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phobos Areographic
-<40173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mercator AUTO Phobos Areocentric
-<40174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mercator AUTO Phobos Areographic
-<40175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Albers AUTO Phobos Areocentric
-<40176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Albers AUTO Phobos Areographic
-<40177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mollweide AUTO Phobos Areocentric
-<40180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Mollweide AUTO Phobos Areographic
-<40181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Robinson AUTO Phobos Areocentric
-<40182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# Robinson AUTO Phobos Areographic
-<40183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=11080 +b=11080 +units=m +no_defs
-# GEOGCS Deimos Areocentric
-<40200> 	+proj=longlat +a=6200 +b=6200 +no_defs
-# GEOGCS Deimos Areographic
-<40201> 	+proj=longlat +a=6200 +b=6200 +no_defs
-# Equirectangular Deimos Areocentric, clon=0
-<40210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equirectangular Deimos Areographic, clon=0
-<40211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equirectangular Deimos Areocentric, clon=180
-<40212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equirectangular Deimos Areographic, clon=180
-<40213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areocentric, clon=0
-<40214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areographic, clon=0
-<40215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areocentric, clon=180
-<40216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal Deimos Areographic, clon=180
-<40217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# North Polar Deimos Areocentric, clon=0
-<40218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# North Polar Deimos Areographic, clon=0
-<40219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# South Polar Deimos Areocentric, clon=0
-<40220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# South Polar Deimos Areographic, clon=0
-<40221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areocentric, clon=0
-<40222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areographic, clon=0
-<40223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areocentric, clon=180
-<40224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide Deimos Areographic, clon=180
-<40225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areocentric, clon=0
-<40226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areographic, clon=0
-<40227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areocentric, clon=180
-<40228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson Deimos Areographic, clon=180
-<40229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal AUTO Deimos Areocentric
-<40260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Sinusoidal AUTO Deimos Areographic
-<40261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Stereographic AUTO Deimos Areocentric, clon=0
-<40262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Stereographic AUTO Deimos Areographic, clon=0
-<40263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Transverse Mercator AUTO Deimos Areocentric
-<40264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Transverse Mercator AUTO Deimos Areographic
-<40265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Orthographic AUTO Deimos Areocentric
-<40266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Orthographic AUTO Deimos Areographic
-<40267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Deimos Areocentric
-<40268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Deimos Areographic
-<40269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Deimos Areocentric
-<40270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Deimos Areographic
-<40271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Deimos Areocentric
-<40272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Deimos Areographic
-<40273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mercator AUTO Deimos Areocentric
-<40274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mercator AUTO Deimos Areographic
-<40275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Albers AUTO Deimos Areocentric
-<40276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Albers AUTO Deimos Areographic
-<40277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide AUTO Deimos Areocentric
-<40280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Mollweide AUTO Deimos Areographic
-<40281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson AUTO Deimos Areocentric
-<40282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# Robinson AUTO Deimos Areographic
-<40283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6200 +b=6200 +units=m +no_defs
-# GEOGCS Jupiter Areocentric
-<59900> 	+proj=longlat +a=71492000 +b=-1030521133.150415 +no_defs
-# GEOGCS Jupiter Areographic
-<59901> 	+proj=longlat +a=71492000 +b=-1030521133.150415 +no_defs
-# Equirectangular Jupiter Areocentric, clon=0
-<59910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equirectangular Jupiter Areographic, clon=0
-<59911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equirectangular Jupiter Areocentric, clon=180
-<59912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equirectangular Jupiter Areographic, clon=180
-<59913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areocentric, clon=0
-<59914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areographic, clon=0
-<59915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areocentric, clon=180
-<59916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal Jupiter Areographic, clon=180
-<59917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# North Polar Jupiter Areocentric, clon=0
-<59918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# North Polar Jupiter Areographic, clon=0
-<59919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# South Polar Jupiter Areocentric, clon=0
-<59920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# South Polar Jupiter Areographic, clon=0
-<59921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areocentric, clon=0
-<59922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areographic, clon=0
-<59923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areocentric, clon=180
-<59924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide Jupiter Areographic, clon=180
-<59925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areocentric, clon=0
-<59926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areographic, clon=0
-<59927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areocentric, clon=180
-<59928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson Jupiter Areographic, clon=180
-<59929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal AUTO Jupiter Areocentric
-<59960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Sinusoidal AUTO Jupiter Areographic
-<59961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Stereographic AUTO Jupiter Areocentric, clon=0
-<59962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Stereographic AUTO Jupiter Areographic, clon=0
-<59963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Transverse Mercator AUTO Jupiter Areocentric
-<59964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Transverse Mercator AUTO Jupiter Areographic
-<59965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Orthographic AUTO Jupiter Areocentric
-<59966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Orthographic AUTO Jupiter Areographic
-<59967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equidistant Cylindrical AUTO Jupiter Areocentric
-<59968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Equidistant Cylindrical AUTO Jupiter Areographic
-<59969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Conformal Conic AUTO Jupiter Areocentric
-<59970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Conformal Conic AUTO Jupiter Areographic
-<59971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Jupiter Areocentric
-<59972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Jupiter Areographic
-<59973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mercator AUTO Jupiter Areocentric
-<59974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mercator AUTO Jupiter Areographic
-<59975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Albers AUTO Jupiter Areocentric
-<59976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Albers AUTO Jupiter Areographic
-<59977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide AUTO Jupiter Areocentric
-<59980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Mollweide AUTO Jupiter Areographic
-<59981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson AUTO Jupiter Areocentric
-<59982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# Robinson AUTO Jupiter Areographic
-<59983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=71492000 +b=-1030521133.150415 +units=m +no_defs
-# GEOGCS Io Areocentric
-<50100> 	+proj=longlat +a=1821490 +b=1821490 +no_defs
-# GEOGCS Io Areographic
-<50101> 	+proj=longlat +a=1821490 +b=1821490 +no_defs
-# Equirectangular Io Areocentric, clon=0
-<50110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Equirectangular Io Areographic, clon=0
-<50111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Equirectangular Io Areocentric, clon=180
-<50112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Equirectangular Io Areographic, clon=180
-<50113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Sinusoidal Io Areocentric, clon=0
-<50114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Sinusoidal Io Areographic, clon=0
-<50115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Sinusoidal Io Areocentric, clon=180
-<50116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Sinusoidal Io Areographic, clon=180
-<50117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# North Polar Io Areocentric, clon=0
-<50118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# North Polar Io Areographic, clon=0
-<50119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# South Polar Io Areocentric, clon=0
-<50120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# South Polar Io Areographic, clon=0
-<50121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mollweide Io Areocentric, clon=0
-<50122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mollweide Io Areographic, clon=0
-<50123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mollweide Io Areocentric, clon=180
-<50124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mollweide Io Areographic, clon=180
-<50125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Robinson Io Areocentric, clon=0
-<50126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Robinson Io Areographic, clon=0
-<50127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Robinson Io Areocentric, clon=180
-<50128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Robinson Io Areographic, clon=180
-<50129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Sinusoidal AUTO Io Areocentric
-<50160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Sinusoidal AUTO Io Areographic
-<50161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Stereographic AUTO Io Areocentric, clon=0
-<50162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Stereographic AUTO Io Areographic, clon=0
-<50163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Transverse Mercator AUTO Io Areocentric
-<50164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Transverse Mercator AUTO Io Areographic
-<50165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Orthographic AUTO Io Areocentric
-<50166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Orthographic AUTO Io Areographic
-<50167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Equidistant Cylindrical AUTO Io Areocentric
-<50168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Equidistant Cylindrical AUTO Io Areographic
-<50169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Lambert Conformal Conic AUTO Io Areocentric
-<50170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Lambert Conformal Conic AUTO Io Areographic
-<50171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Io Areocentric
-<50172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Io Areographic
-<50173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mercator AUTO Io Areocentric
-<50174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mercator AUTO Io Areographic
-<50175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Albers AUTO Io Areocentric
-<50176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Albers AUTO Io Areographic
-<50177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mollweide AUTO Io Areocentric
-<50180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Mollweide AUTO Io Areographic
-<50181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Robinson AUTO Io Areocentric
-<50182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# Robinson AUTO Io Areographic
-<50183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1821490 +b=1821490 +units=m +no_defs
-# GEOGCS Europa Areocentric
-<50200> 	+proj=longlat +a=1560800 +b=1560800 +no_defs
-# GEOGCS Europa Areographic
-<50201> 	+proj=longlat +a=1560800 +b=1560800 +no_defs
-# Equirectangular Europa Areocentric, clon=0
-<50210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Equirectangular Europa Areographic, clon=0
-<50211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Equirectangular Europa Areocentric, clon=180
-<50212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Equirectangular Europa Areographic, clon=180
-<50213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Sinusoidal Europa Areocentric, clon=0
-<50214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Sinusoidal Europa Areographic, clon=0
-<50215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Sinusoidal Europa Areocentric, clon=180
-<50216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Sinusoidal Europa Areographic, clon=180
-<50217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# North Polar Europa Areocentric, clon=0
-<50218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# North Polar Europa Areographic, clon=0
-<50219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# South Polar Europa Areocentric, clon=0
-<50220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# South Polar Europa Areographic, clon=0
-<50221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mollweide Europa Areocentric, clon=0
-<50222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mollweide Europa Areographic, clon=0
-<50223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mollweide Europa Areocentric, clon=180
-<50224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mollweide Europa Areographic, clon=180
-<50225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Robinson Europa Areocentric, clon=0
-<50226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Robinson Europa Areographic, clon=0
-<50227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Robinson Europa Areocentric, clon=180
-<50228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Robinson Europa Areographic, clon=180
-<50229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Sinusoidal AUTO Europa Areocentric
-<50260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Sinusoidal AUTO Europa Areographic
-<50261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Stereographic AUTO Europa Areocentric, clon=0
-<50262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Stereographic AUTO Europa Areographic, clon=0
-<50263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Transverse Mercator AUTO Europa Areocentric
-<50264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Transverse Mercator AUTO Europa Areographic
-<50265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Orthographic AUTO Europa Areocentric
-<50266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Orthographic AUTO Europa Areographic
-<50267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Europa Areocentric
-<50268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Europa Areographic
-<50269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Europa Areocentric
-<50270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Europa Areographic
-<50271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Europa Areocentric
-<50272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Europa Areographic
-<50273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mercator AUTO Europa Areocentric
-<50274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mercator AUTO Europa Areographic
-<50275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Albers AUTO Europa Areocentric
-<50276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Albers AUTO Europa Areographic
-<50277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mollweide AUTO Europa Areocentric
-<50280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Mollweide AUTO Europa Areographic
-<50281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Robinson AUTO Europa Areocentric
-<50282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# Robinson AUTO Europa Areographic
-<50283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1560800 +b=1560800 +units=m +no_defs
-# GEOGCS Ganymede Areocentric
-<50300> 	+proj=longlat +a=2631200 +b=2631200 +no_defs
-# GEOGCS Ganymede Areographic
-<50301> 	+proj=longlat +a=2631200 +b=2631200 +no_defs
-# Equirectangular Ganymede Areocentric, clon=0
-<50310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Equirectangular Ganymede Areographic, clon=0
-<50311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Equirectangular Ganymede Areocentric, clon=180
-<50312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Equirectangular Ganymede Areographic, clon=180
-<50313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Sinusoidal Ganymede Areocentric, clon=0
-<50314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Sinusoidal Ganymede Areographic, clon=0
-<50315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Sinusoidal Ganymede Areocentric, clon=180
-<50316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Sinusoidal Ganymede Areographic, clon=180
-<50317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# North Polar Ganymede Areocentric, clon=0
-<50318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# North Polar Ganymede Areographic, clon=0
-<50319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# South Polar Ganymede Areocentric, clon=0
-<50320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# South Polar Ganymede Areographic, clon=0
-<50321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mollweide Ganymede Areocentric, clon=0
-<50322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mollweide Ganymede Areographic, clon=0
-<50323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mollweide Ganymede Areocentric, clon=180
-<50324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mollweide Ganymede Areographic, clon=180
-<50325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Robinson Ganymede Areocentric, clon=0
-<50326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Robinson Ganymede Areographic, clon=0
-<50327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Robinson Ganymede Areocentric, clon=180
-<50328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Robinson Ganymede Areographic, clon=180
-<50329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Sinusoidal AUTO Ganymede Areocentric
-<50360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Sinusoidal AUTO Ganymede Areographic
-<50361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Stereographic AUTO Ganymede Areocentric, clon=0
-<50362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Stereographic AUTO Ganymede Areographic, clon=0
-<50363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Transverse Mercator AUTO Ganymede Areocentric
-<50364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Transverse Mercator AUTO Ganymede Areographic
-<50365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Orthographic AUTO Ganymede Areocentric
-<50366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Orthographic AUTO Ganymede Areographic
-<50367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ganymede Areocentric
-<50368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ganymede Areographic
-<50369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ganymede Areocentric
-<50370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ganymede Areographic
-<50371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ganymede Areocentric
-<50372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ganymede Areographic
-<50373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mercator AUTO Ganymede Areocentric
-<50374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mercator AUTO Ganymede Areographic
-<50375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Albers AUTO Ganymede Areocentric
-<50376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Albers AUTO Ganymede Areographic
-<50377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mollweide AUTO Ganymede Areocentric
-<50380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Mollweide AUTO Ganymede Areographic
-<50381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Robinson AUTO Ganymede Areocentric
-<50382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# Robinson AUTO Ganymede Areographic
-<50383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2631200 +b=2631200 +units=m +no_defs
-# GEOGCS Callisto Areocentric
-<50400> 	+proj=longlat +a=2410300 +b=2410300 +no_defs
-# GEOGCS Callisto Areographic
-<50401> 	+proj=longlat +a=2410300 +b=2410300 +no_defs
-# Equirectangular Callisto Areocentric, clon=0
-<50410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Equirectangular Callisto Areographic, clon=0
-<50411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Equirectangular Callisto Areocentric, clon=180
-<50412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Equirectangular Callisto Areographic, clon=180
-<50413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Sinusoidal Callisto Areocentric, clon=0
-<50414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Sinusoidal Callisto Areographic, clon=0
-<50415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Sinusoidal Callisto Areocentric, clon=180
-<50416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Sinusoidal Callisto Areographic, clon=180
-<50417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# North Polar Callisto Areocentric, clon=0
-<50418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# North Polar Callisto Areographic, clon=0
-<50419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# South Polar Callisto Areocentric, clon=0
-<50420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# South Polar Callisto Areographic, clon=0
-<50421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mollweide Callisto Areocentric, clon=0
-<50422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mollweide Callisto Areographic, clon=0
-<50423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mollweide Callisto Areocentric, clon=180
-<50424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mollweide Callisto Areographic, clon=180
-<50425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Robinson Callisto Areocentric, clon=0
-<50426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Robinson Callisto Areographic, clon=0
-<50427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Robinson Callisto Areocentric, clon=180
-<50428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Robinson Callisto Areographic, clon=180
-<50429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Sinusoidal AUTO Callisto Areocentric
-<50460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Sinusoidal AUTO Callisto Areographic
-<50461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Stereographic AUTO Callisto Areocentric, clon=0
-<50462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Stereographic AUTO Callisto Areographic, clon=0
-<50463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Transverse Mercator AUTO Callisto Areocentric
-<50464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Transverse Mercator AUTO Callisto Areographic
-<50465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Orthographic AUTO Callisto Areocentric
-<50466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Orthographic AUTO Callisto Areographic
-<50467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Callisto Areocentric
-<50468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Callisto Areographic
-<50469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Callisto Areocentric
-<50470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Callisto Areographic
-<50471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Callisto Areocentric
-<50472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Callisto Areographic
-<50473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mercator AUTO Callisto Areocentric
-<50474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mercator AUTO Callisto Areographic
-<50475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Albers AUTO Callisto Areocentric
-<50476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Albers AUTO Callisto Areographic
-<50477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mollweide AUTO Callisto Areocentric
-<50480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Mollweide AUTO Callisto Areographic
-<50481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Robinson AUTO Callisto Areocentric
-<50482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# Robinson AUTO Callisto Areographic
-<50483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2410300 +b=2410300 +units=m +no_defs
-# GEOGCS Amalthea Areocentric
-<50500> 	+proj=longlat +a=83500 +b=83500 +no_defs
-# GEOGCS Amalthea Areographic
-<50501> 	+proj=longlat +a=83500 +b=83500 +no_defs
-# Equirectangular Amalthea Areocentric, clon=0
-<50510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equirectangular Amalthea Areographic, clon=0
-<50511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equirectangular Amalthea Areocentric, clon=180
-<50512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equirectangular Amalthea Areographic, clon=180
-<50513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areocentric, clon=0
-<50514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areographic, clon=0
-<50515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areocentric, clon=180
-<50516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal Amalthea Areographic, clon=180
-<50517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# North Polar Amalthea Areocentric, clon=0
-<50518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# North Polar Amalthea Areographic, clon=0
-<50519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# South Polar Amalthea Areocentric, clon=0
-<50520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# South Polar Amalthea Areographic, clon=0
-<50521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areocentric, clon=0
-<50522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areographic, clon=0
-<50523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areocentric, clon=180
-<50524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide Amalthea Areographic, clon=180
-<50525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areocentric, clon=0
-<50526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areographic, clon=0
-<50527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areocentric, clon=180
-<50528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson Amalthea Areographic, clon=180
-<50529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal AUTO Amalthea Areocentric
-<50560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Sinusoidal AUTO Amalthea Areographic
-<50561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Stereographic AUTO Amalthea Areocentric, clon=0
-<50562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Stereographic AUTO Amalthea Areographic, clon=0
-<50563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Transverse Mercator AUTO Amalthea Areocentric
-<50564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Transverse Mercator AUTO Amalthea Areographic
-<50565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Orthographic AUTO Amalthea Areocentric
-<50566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Orthographic AUTO Amalthea Areographic
-<50567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Amalthea Areocentric
-<50568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Amalthea Areographic
-<50569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Amalthea Areocentric
-<50570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Amalthea Areographic
-<50571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Amalthea Areocentric
-<50572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Amalthea Areographic
-<50573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mercator AUTO Amalthea Areocentric
-<50574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mercator AUTO Amalthea Areographic
-<50575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Albers AUTO Amalthea Areocentric
-<50576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Albers AUTO Amalthea Areographic
-<50577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide AUTO Amalthea Areocentric
-<50580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Mollweide AUTO Amalthea Areographic
-<50581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson AUTO Amalthea Areocentric
-<50582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# Robinson AUTO Amalthea Areographic
-<50583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=83500 +b=83500 +units=m +no_defs
-# GEOGCS Himalia Areocentric
-<50600> 	+proj=longlat +a=85000 +b=85000 +no_defs
-# GEOGCS Himalia Areographic
-<50601> 	+proj=longlat +a=85000 +b=85000 +no_defs
-# Equirectangular Himalia Areocentric, clon=0
-<50610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equirectangular Himalia Areographic, clon=0
-<50611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equirectangular Himalia Areocentric, clon=180
-<50612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equirectangular Himalia Areographic, clon=180
-<50613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areocentric, clon=0
-<50614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areographic, clon=0
-<50615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areocentric, clon=180
-<50616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal Himalia Areographic, clon=180
-<50617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# North Polar Himalia Areocentric, clon=0
-<50618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# North Polar Himalia Areographic, clon=0
-<50619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# South Polar Himalia Areocentric, clon=0
-<50620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# South Polar Himalia Areographic, clon=0
-<50621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areocentric, clon=0
-<50622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areographic, clon=0
-<50623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areocentric, clon=180
-<50624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide Himalia Areographic, clon=180
-<50625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areocentric, clon=0
-<50626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areographic, clon=0
-<50627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areocentric, clon=180
-<50628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson Himalia Areographic, clon=180
-<50629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal AUTO Himalia Areocentric
-<50660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Sinusoidal AUTO Himalia Areographic
-<50661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Stereographic AUTO Himalia Areocentric, clon=0
-<50662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Stereographic AUTO Himalia Areographic, clon=0
-<50663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Transverse Mercator AUTO Himalia Areocentric
-<50664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Transverse Mercator AUTO Himalia Areographic
-<50665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Orthographic AUTO Himalia Areocentric
-<50666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Orthographic AUTO Himalia Areographic
-<50667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Himalia Areocentric
-<50668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Himalia Areographic
-<50669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Himalia Areocentric
-<50670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Himalia Areographic
-<50671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Himalia Areocentric
-<50672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Himalia Areographic
-<50673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mercator AUTO Himalia Areocentric
-<50674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mercator AUTO Himalia Areographic
-<50675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Albers AUTO Himalia Areocentric
-<50676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Albers AUTO Himalia Areographic
-<50677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide AUTO Himalia Areocentric
-<50680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Mollweide AUTO Himalia Areographic
-<50681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson AUTO Himalia Areocentric
-<50682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# Robinson AUTO Himalia Areographic
-<50683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=85000 +b=85000 +units=m +no_defs
-# GEOGCS Elara Areocentric
-<50700> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# GEOGCS Elara Areographic
-<50701> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# Equirectangular Elara Areocentric, clon=0
-<50710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Elara Areographic, clon=0
-<50711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Elara Areocentric, clon=180
-<50712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Elara Areographic, clon=180
-<50713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areocentric, clon=0
-<50714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areographic, clon=0
-<50715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areocentric, clon=180
-<50716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Elara Areographic, clon=180
-<50717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Elara Areocentric, clon=0
-<50718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Elara Areographic, clon=0
-<50719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Elara Areocentric, clon=0
-<50720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Elara Areographic, clon=0
-<50721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areocentric, clon=0
-<50722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areographic, clon=0
-<50723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areocentric, clon=180
-<50724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Elara Areographic, clon=180
-<50725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areocentric, clon=0
-<50726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areographic, clon=0
-<50727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areocentric, clon=180
-<50728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Elara Areographic, clon=180
-<50729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Elara Areocentric
-<50760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Elara Areographic
-<50761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Elara Areocentric, clon=0
-<50762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Elara Areographic, clon=0
-<50763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Elara Areocentric
-<50764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Elara Areographic
-<50765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Elara Areocentric
-<50766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Elara Areographic
-<50767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Elara Areocentric
-<50768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Elara Areographic
-<50769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Elara Areocentric
-<50770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Elara Areographic
-<50771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Elara Areocentric
-<50772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Elara Areographic
-<50773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Elara Areocentric
-<50774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Elara Areographic
-<50775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Elara Areocentric
-<50776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Elara Areographic
-<50777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Elara Areocentric
-<50780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Elara Areographic
-<50781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Elara Areocentric
-<50782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Elara Areographic
-<50783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# GEOGCS Pasiphae Areocentric
-<50800> 	+proj=longlat +a=18000 +b=18000 +no_defs
-# GEOGCS Pasiphae Areographic
-<50801> 	+proj=longlat +a=18000 +b=18000 +no_defs
-# Equirectangular Pasiphae Areocentric, clon=0
-<50810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equirectangular Pasiphae Areographic, clon=0
-<50811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equirectangular Pasiphae Areocentric, clon=180
-<50812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equirectangular Pasiphae Areographic, clon=180
-<50813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areocentric, clon=0
-<50814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areographic, clon=0
-<50815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areocentric, clon=180
-<50816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal Pasiphae Areographic, clon=180
-<50817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# North Polar Pasiphae Areocentric, clon=0
-<50818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# North Polar Pasiphae Areographic, clon=0
-<50819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# South Polar Pasiphae Areocentric, clon=0
-<50820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# South Polar Pasiphae Areographic, clon=0
-<50821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areocentric, clon=0
-<50822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areographic, clon=0
-<50823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areocentric, clon=180
-<50824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide Pasiphae Areographic, clon=180
-<50825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areocentric, clon=0
-<50826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areographic, clon=0
-<50827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areocentric, clon=180
-<50828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson Pasiphae Areographic, clon=180
-<50829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal AUTO Pasiphae Areocentric
-<50860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Sinusoidal AUTO Pasiphae Areographic
-<50861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Stereographic AUTO Pasiphae Areocentric, clon=0
-<50862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Stereographic AUTO Pasiphae Areographic, clon=0
-<50863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Transverse Mercator AUTO Pasiphae Areocentric
-<50864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Transverse Mercator AUTO Pasiphae Areographic
-<50865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Orthographic AUTO Pasiphae Areocentric
-<50866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Orthographic AUTO Pasiphae Areographic
-<50867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pasiphae Areocentric
-<50868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pasiphae Areographic
-<50869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pasiphae Areocentric
-<50870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pasiphae Areographic
-<50871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pasiphae Areocentric
-<50872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pasiphae Areographic
-<50873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mercator AUTO Pasiphae Areocentric
-<50874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mercator AUTO Pasiphae Areographic
-<50875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Albers AUTO Pasiphae Areocentric
-<50876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Albers AUTO Pasiphae Areographic
-<50877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide AUTO Pasiphae Areocentric
-<50880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Mollweide AUTO Pasiphae Areographic
-<50881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson AUTO Pasiphae Areocentric
-<50882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# Robinson AUTO Pasiphae Areographic
-<50883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=18000 +b=18000 +units=m +no_defs
-# GEOGCS Sinope Areocentric
-<50900> 	+proj=longlat +a=14000 +b=14000 +no_defs
-# GEOGCS Sinope Areographic
-<50901> 	+proj=longlat +a=14000 +b=14000 +no_defs
-# Equirectangular Sinope Areocentric, clon=0
-<50910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equirectangular Sinope Areographic, clon=0
-<50911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equirectangular Sinope Areocentric, clon=180
-<50912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equirectangular Sinope Areographic, clon=180
-<50913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areocentric, clon=0
-<50914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areographic, clon=0
-<50915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areocentric, clon=180
-<50916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal Sinope Areographic, clon=180
-<50917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# North Polar Sinope Areocentric, clon=0
-<50918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# North Polar Sinope Areographic, clon=0
-<50919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# South Polar Sinope Areocentric, clon=0
-<50920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# South Polar Sinope Areographic, clon=0
-<50921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areocentric, clon=0
-<50922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areographic, clon=0
-<50923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areocentric, clon=180
-<50924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide Sinope Areographic, clon=180
-<50925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areocentric, clon=0
-<50926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areographic, clon=0
-<50927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areocentric, clon=180
-<50928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson Sinope Areographic, clon=180
-<50929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal AUTO Sinope Areocentric
-<50960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Sinusoidal AUTO Sinope Areographic
-<50961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Stereographic AUTO Sinope Areocentric, clon=0
-<50962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Stereographic AUTO Sinope Areographic, clon=0
-<50963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Transverse Mercator AUTO Sinope Areocentric
-<50964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Transverse Mercator AUTO Sinope Areographic
-<50965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Orthographic AUTO Sinope Areocentric
-<50966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Orthographic AUTO Sinope Areographic
-<50967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Sinope Areocentric
-<50968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Sinope Areographic
-<50969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Sinope Areocentric
-<50970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Sinope Areographic
-<50971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Sinope Areocentric
-<50972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Sinope Areographic
-<50973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mercator AUTO Sinope Areocentric
-<50974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mercator AUTO Sinope Areographic
-<50975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Albers AUTO Sinope Areocentric
-<50976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Albers AUTO Sinope Areographic
-<50977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide AUTO Sinope Areocentric
-<50980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Mollweide AUTO Sinope Areographic
-<50981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson AUTO Sinope Areocentric
-<50982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# Robinson AUTO Sinope Areographic
-<50983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14000 +b=14000 +units=m +no_defs
-# GEOGCS Lysithea Areocentric
-<51000> 	+proj=longlat +a=12000 +b=12000 +no_defs
-# GEOGCS Lysithea Areographic
-<51001> 	+proj=longlat +a=12000 +b=12000 +no_defs
-# Equirectangular Lysithea Areocentric, clon=0
-<51010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equirectangular Lysithea Areographic, clon=0
-<51011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equirectangular Lysithea Areocentric, clon=180
-<51012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equirectangular Lysithea Areographic, clon=180
-<51013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areocentric, clon=0
-<51014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areographic, clon=0
-<51015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areocentric, clon=180
-<51016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal Lysithea Areographic, clon=180
-<51017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# North Polar Lysithea Areocentric, clon=0
-<51018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# North Polar Lysithea Areographic, clon=0
-<51019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# South Polar Lysithea Areocentric, clon=0
-<51020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# South Polar Lysithea Areographic, clon=0
-<51021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areocentric, clon=0
-<51022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areographic, clon=0
-<51023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areocentric, clon=180
-<51024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide Lysithea Areographic, clon=180
-<51025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areocentric, clon=0
-<51026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areographic, clon=0
-<51027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areocentric, clon=180
-<51028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson Lysithea Areographic, clon=180
-<51029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal AUTO Lysithea Areocentric
-<51060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Sinusoidal AUTO Lysithea Areographic
-<51061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Stereographic AUTO Lysithea Areocentric, clon=0
-<51062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Stereographic AUTO Lysithea Areographic, clon=0
-<51063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Transverse Mercator AUTO Lysithea Areocentric
-<51064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Transverse Mercator AUTO Lysithea Areographic
-<51065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Orthographic AUTO Lysithea Areocentric
-<51066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Orthographic AUTO Lysithea Areographic
-<51067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lysithea Areocentric
-<51068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lysithea Areographic
-<51069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lysithea Areocentric
-<51070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lysithea Areographic
-<51071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lysithea Areocentric
-<51072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lysithea Areographic
-<51073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mercator AUTO Lysithea Areocentric
-<51074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mercator AUTO Lysithea Areographic
-<51075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Albers AUTO Lysithea Areocentric
-<51076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Albers AUTO Lysithea Areographic
-<51077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide AUTO Lysithea Areocentric
-<51080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Mollweide AUTO Lysithea Areographic
-<51081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson AUTO Lysithea Areocentric
-<51082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# Robinson AUTO Lysithea Areographic
-<51083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12000 +b=12000 +units=m +no_defs
-# GEOGCS Carme Areocentric
-<51100> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# GEOGCS Carme Areographic
-<51101> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# Equirectangular Carme Areocentric, clon=0
-<51110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Carme Areographic, clon=0
-<51111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Carme Areocentric, clon=180
-<51112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Carme Areographic, clon=180
-<51113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areocentric, clon=0
-<51114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areographic, clon=0
-<51115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areocentric, clon=180
-<51116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Carme Areographic, clon=180
-<51117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Carme Areocentric, clon=0
-<51118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Carme Areographic, clon=0
-<51119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Carme Areocentric, clon=0
-<51120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Carme Areographic, clon=0
-<51121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areocentric, clon=0
-<51122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areographic, clon=0
-<51123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areocentric, clon=180
-<51124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Carme Areographic, clon=180
-<51125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areocentric, clon=0
-<51126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areographic, clon=0
-<51127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areocentric, clon=180
-<51128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Carme Areographic, clon=180
-<51129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Carme Areocentric
-<51160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Carme Areographic
-<51161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Carme Areocentric, clon=0
-<51162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Carme Areographic, clon=0
-<51163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Carme Areocentric
-<51164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Carme Areographic
-<51165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Carme Areocentric
-<51166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Carme Areographic
-<51167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Carme Areocentric
-<51168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Carme Areographic
-<51169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Carme Areocentric
-<51170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Carme Areographic
-<51171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Carme Areocentric
-<51172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Carme Areographic
-<51173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Carme Areocentric
-<51174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Carme Areographic
-<51175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Carme Areocentric
-<51176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Carme Areographic
-<51177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Carme Areocentric
-<51180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Carme Areographic
-<51181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Carme Areocentric
-<51182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Carme Areographic
-<51183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# GEOGCS Ananke Areocentric
-<51200> 	+proj=longlat +a=10000 +b=10000 +no_defs
-# GEOGCS Ananke Areographic
-<51201> 	+proj=longlat +a=10000 +b=10000 +no_defs
-# Equirectangular Ananke Areocentric, clon=0
-<51210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Ananke Areographic, clon=0
-<51211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Ananke Areocentric, clon=180
-<51212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equirectangular Ananke Areographic, clon=180
-<51213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areocentric, clon=0
-<51214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areographic, clon=0
-<51215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areocentric, clon=180
-<51216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal Ananke Areographic, clon=180
-<51217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# North Polar Ananke Areocentric, clon=0
-<51218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# North Polar Ananke Areographic, clon=0
-<51219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# South Polar Ananke Areocentric, clon=0
-<51220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# South Polar Ananke Areographic, clon=0
-<51221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areocentric, clon=0
-<51222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areographic, clon=0
-<51223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areocentric, clon=180
-<51224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide Ananke Areographic, clon=180
-<51225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areocentric, clon=0
-<51226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areographic, clon=0
-<51227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areocentric, clon=180
-<51228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson Ananke Areographic, clon=180
-<51229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal AUTO Ananke Areocentric
-<51260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Sinusoidal AUTO Ananke Areographic
-<51261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Stereographic AUTO Ananke Areocentric, clon=0
-<51262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Stereographic AUTO Ananke Areographic, clon=0
-<51263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Transverse Mercator AUTO Ananke Areocentric
-<51264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Transverse Mercator AUTO Ananke Areographic
-<51265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Orthographic AUTO Ananke Areocentric
-<51266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Orthographic AUTO Ananke Areographic
-<51267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ananke Areocentric
-<51268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ananke Areographic
-<51269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ananke Areocentric
-<51270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ananke Areographic
-<51271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ananke Areocentric
-<51272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ananke Areographic
-<51273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mercator AUTO Ananke Areocentric
-<51274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mercator AUTO Ananke Areographic
-<51275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Albers AUTO Ananke Areocentric
-<51276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Albers AUTO Ananke Areographic
-<51277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide AUTO Ananke Areocentric
-<51280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Mollweide AUTO Ananke Areographic
-<51281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson AUTO Ananke Areocentric
-<51282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# Robinson AUTO Ananke Areographic
-<51283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10000 +b=10000 +units=m +no_defs
-# GEOGCS Leda Areocentric
-<51300> 	+proj=longlat +a=5000 +b=5000 +no_defs
-# GEOGCS Leda Areographic
-<51301> 	+proj=longlat +a=5000 +b=5000 +no_defs
-# Equirectangular Leda Areocentric, clon=0
-<51310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equirectangular Leda Areographic, clon=0
-<51311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equirectangular Leda Areocentric, clon=180
-<51312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equirectangular Leda Areographic, clon=180
-<51313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areocentric, clon=0
-<51314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areographic, clon=0
-<51315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areocentric, clon=180
-<51316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal Leda Areographic, clon=180
-<51317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# North Polar Leda Areocentric, clon=0
-<51318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# North Polar Leda Areographic, clon=0
-<51319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# South Polar Leda Areocentric, clon=0
-<51320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# South Polar Leda Areographic, clon=0
-<51321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areocentric, clon=0
-<51322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areographic, clon=0
-<51323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areocentric, clon=180
-<51324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide Leda Areographic, clon=180
-<51325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areocentric, clon=0
-<51326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areographic, clon=0
-<51327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areocentric, clon=180
-<51328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson Leda Areographic, clon=180
-<51329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal AUTO Leda Areocentric
-<51360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Sinusoidal AUTO Leda Areographic
-<51361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Stereographic AUTO Leda Areocentric, clon=0
-<51362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Stereographic AUTO Leda Areographic, clon=0
-<51363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Transverse Mercator AUTO Leda Areocentric
-<51364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Transverse Mercator AUTO Leda Areographic
-<51365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Orthographic AUTO Leda Areocentric
-<51366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Orthographic AUTO Leda Areographic
-<51367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Leda Areocentric
-<51368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Leda Areographic
-<51369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Leda Areocentric
-<51370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Leda Areographic
-<51371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Leda Areocentric
-<51372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Leda Areographic
-<51373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mercator AUTO Leda Areocentric
-<51374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mercator AUTO Leda Areographic
-<51375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Albers AUTO Leda Areocentric
-<51376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Albers AUTO Leda Areographic
-<51377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide AUTO Leda Areocentric
-<51380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Mollweide AUTO Leda Areographic
-<51381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson AUTO Leda Areocentric
-<51382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# Robinson AUTO Leda Areographic
-<51383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=5000 +b=5000 +units=m +no_defs
-# GEOGCS Thebe Areocentric
-<51400> 	+proj=longlat +a=49300 +b=49300 +no_defs
-# GEOGCS Thebe Areographic
-<51401> 	+proj=longlat +a=49300 +b=49300 +no_defs
-# Equirectangular Thebe Areocentric, clon=0
-<51410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equirectangular Thebe Areographic, clon=0
-<51411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equirectangular Thebe Areocentric, clon=180
-<51412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equirectangular Thebe Areographic, clon=180
-<51413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areocentric, clon=0
-<51414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areographic, clon=0
-<51415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areocentric, clon=180
-<51416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal Thebe Areographic, clon=180
-<51417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# North Polar Thebe Areocentric, clon=0
-<51418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# North Polar Thebe Areographic, clon=0
-<51419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# South Polar Thebe Areocentric, clon=0
-<51420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# South Polar Thebe Areographic, clon=0
-<51421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areocentric, clon=0
-<51422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areographic, clon=0
-<51423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areocentric, clon=180
-<51424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide Thebe Areographic, clon=180
-<51425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areocentric, clon=0
-<51426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areographic, clon=0
-<51427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areocentric, clon=180
-<51428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson Thebe Areographic, clon=180
-<51429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal AUTO Thebe Areocentric
-<51460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Sinusoidal AUTO Thebe Areographic
-<51461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Stereographic AUTO Thebe Areocentric, clon=0
-<51462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Stereographic AUTO Thebe Areographic, clon=0
-<51463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Transverse Mercator AUTO Thebe Areocentric
-<51464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Transverse Mercator AUTO Thebe Areographic
-<51465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Orthographic AUTO Thebe Areocentric
-<51466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Orthographic AUTO Thebe Areographic
-<51467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thebe Areocentric
-<51468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thebe Areographic
-<51469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thebe Areocentric
-<51470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thebe Areographic
-<51471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thebe Areocentric
-<51472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thebe Areographic
-<51473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mercator AUTO Thebe Areocentric
-<51474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mercator AUTO Thebe Areographic
-<51475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Albers AUTO Thebe Areocentric
-<51476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Albers AUTO Thebe Areographic
-<51477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide AUTO Thebe Areocentric
-<51480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Mollweide AUTO Thebe Areographic
-<51481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson AUTO Thebe Areocentric
-<51482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# Robinson AUTO Thebe Areographic
-<51483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=49300 +b=49300 +units=m +no_defs
-# GEOGCS Adrastea Areocentric
-<51500> 	+proj=longlat +a=8200 +b=8200 +no_defs
-# GEOGCS Adrastea Areographic
-<51501> 	+proj=longlat +a=8200 +b=8200 +no_defs
-# Equirectangular Adrastea Areocentric, clon=0
-<51510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equirectangular Adrastea Areographic, clon=0
-<51511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equirectangular Adrastea Areocentric, clon=180
-<51512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equirectangular Adrastea Areographic, clon=180
-<51513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areocentric, clon=0
-<51514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areographic, clon=0
-<51515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areocentric, clon=180
-<51516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal Adrastea Areographic, clon=180
-<51517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# North Polar Adrastea Areocentric, clon=0
-<51518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# North Polar Adrastea Areographic, clon=0
-<51519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# South Polar Adrastea Areocentric, clon=0
-<51520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# South Polar Adrastea Areographic, clon=0
-<51521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areocentric, clon=0
-<51522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areographic, clon=0
-<51523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areocentric, clon=180
-<51524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide Adrastea Areographic, clon=180
-<51525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areocentric, clon=0
-<51526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areographic, clon=0
-<51527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areocentric, clon=180
-<51528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson Adrastea Areographic, clon=180
-<51529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal AUTO Adrastea Areocentric
-<51560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Sinusoidal AUTO Adrastea Areographic
-<51561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Stereographic AUTO Adrastea Areocentric, clon=0
-<51562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Stereographic AUTO Adrastea Areographic, clon=0
-<51563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Transverse Mercator AUTO Adrastea Areocentric
-<51564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Transverse Mercator AUTO Adrastea Areographic
-<51565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Orthographic AUTO Adrastea Areocentric
-<51566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Orthographic AUTO Adrastea Areographic
-<51567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Adrastea Areocentric
-<51568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Adrastea Areographic
-<51569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Adrastea Areocentric
-<51570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Adrastea Areographic
-<51571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Adrastea Areocentric
-<51572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Adrastea Areographic
-<51573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mercator AUTO Adrastea Areocentric
-<51574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mercator AUTO Adrastea Areographic
-<51575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Albers AUTO Adrastea Areocentric
-<51576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Albers AUTO Adrastea Areographic
-<51577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide AUTO Adrastea Areocentric
-<51580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Mollweide AUTO Adrastea Areographic
-<51581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson AUTO Adrastea Areocentric
-<51582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# Robinson AUTO Adrastea Areographic
-<51583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8200 +b=8200 +units=m +no_defs
-# GEOGCS Metis Areocentric
-<51600> 	+proj=longlat +a=21500 +b=21500 +no_defs
-# GEOGCS Metis Areographic
-<51601> 	+proj=longlat +a=21500 +b=21500 +no_defs
-# Equirectangular Metis Areocentric, clon=0
-<51610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equirectangular Metis Areographic, clon=0
-<51611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equirectangular Metis Areocentric, clon=180
-<51612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equirectangular Metis Areographic, clon=180
-<51613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areocentric, clon=0
-<51614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areographic, clon=0
-<51615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areocentric, clon=180
-<51616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal Metis Areographic, clon=180
-<51617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# North Polar Metis Areocentric, clon=0
-<51618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# North Polar Metis Areographic, clon=0
-<51619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# South Polar Metis Areocentric, clon=0
-<51620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# South Polar Metis Areographic, clon=0
-<51621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areocentric, clon=0
-<51622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areographic, clon=0
-<51623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areocentric, clon=180
-<51624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide Metis Areographic, clon=180
-<51625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areocentric, clon=0
-<51626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areographic, clon=0
-<51627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areocentric, clon=180
-<51628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson Metis Areographic, clon=180
-<51629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal AUTO Metis Areocentric
-<51660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Sinusoidal AUTO Metis Areographic
-<51661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Stereographic AUTO Metis Areocentric, clon=0
-<51662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Stereographic AUTO Metis Areographic, clon=0
-<51663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Transverse Mercator AUTO Metis Areocentric
-<51664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Transverse Mercator AUTO Metis Areographic
-<51665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Orthographic AUTO Metis Areocentric
-<51666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Orthographic AUTO Metis Areographic
-<51667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Metis Areocentric
-<51668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Metis Areographic
-<51669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Metis Areocentric
-<51670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Metis Areographic
-<51671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Metis Areocentric
-<51672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Metis Areographic
-<51673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mercator AUTO Metis Areocentric
-<51674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mercator AUTO Metis Areographic
-<51675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Albers AUTO Metis Areocentric
-<51676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Albers AUTO Metis Areographic
-<51677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide AUTO Metis Areocentric
-<51680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Mollweide AUTO Metis Areographic
-<51681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson AUTO Metis Areocentric
-<51682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# Robinson AUTO Metis Areographic
-<51683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21500 +b=21500 +units=m +no_defs
-# GEOGCS Saturn Areocentric
-<69900> 	+proj=longlat +a=60268000 +b=-554950145.8116413 +no_defs
-# GEOGCS Saturn Areographic
-<69901> 	+proj=longlat +a=60268000 +b=-554950145.8116413 +no_defs
-# Equirectangular Saturn Areocentric, clon=0
-<69910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equirectangular Saturn Areographic, clon=0
-<69911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equirectangular Saturn Areocentric, clon=180
-<69912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equirectangular Saturn Areographic, clon=180
-<69913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areocentric, clon=0
-<69914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areographic, clon=0
-<69915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areocentric, clon=180
-<69916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal Saturn Areographic, clon=180
-<69917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# North Polar Saturn Areocentric, clon=0
-<69918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# North Polar Saturn Areographic, clon=0
-<69919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# South Polar Saturn Areocentric, clon=0
-<69920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# South Polar Saturn Areographic, clon=0
-<69921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areocentric, clon=0
-<69922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areographic, clon=0
-<69923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areocentric, clon=180
-<69924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide Saturn Areographic, clon=180
-<69925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areocentric, clon=0
-<69926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areographic, clon=0
-<69927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areocentric, clon=180
-<69928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson Saturn Areographic, clon=180
-<69929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal AUTO Saturn Areocentric
-<69960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Sinusoidal AUTO Saturn Areographic
-<69961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Stereographic AUTO Saturn Areocentric, clon=0
-<69962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Stereographic AUTO Saturn Areographic, clon=0
-<69963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Transverse Mercator AUTO Saturn Areocentric
-<69964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Transverse Mercator AUTO Saturn Areographic
-<69965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Orthographic AUTO Saturn Areocentric
-<69966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Orthographic AUTO Saturn Areographic
-<69967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equidistant Cylindrical AUTO Saturn Areocentric
-<69968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Equidistant Cylindrical AUTO Saturn Areographic
-<69969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Conformal Conic AUTO Saturn Areocentric
-<69970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Conformal Conic AUTO Saturn Areographic
-<69971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Saturn Areocentric
-<69972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Saturn Areographic
-<69973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mercator AUTO Saturn Areocentric
-<69974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mercator AUTO Saturn Areographic
-<69975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Albers AUTO Saturn Areocentric
-<69976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Albers AUTO Saturn Areographic
-<69977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide AUTO Saturn Areocentric
-<69980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Mollweide AUTO Saturn Areographic
-<69981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson AUTO Saturn Areocentric
-<69982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# Robinson AUTO Saturn Areographic
-<69983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=60268000 +b=-554950145.8116413 +units=m +no_defs
-# GEOGCS Mimas Areocentric
-<60100> 	+proj=longlat +a=198200 +b=198200 +no_defs
-# GEOGCS Mimas Areographic
-<60101> 	+proj=longlat +a=198200 +b=198200 +no_defs
-# Equirectangular Mimas Areocentric, clon=0
-<60110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Equirectangular Mimas Areographic, clon=0
-<60111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Equirectangular Mimas Areocentric, clon=180
-<60112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Equirectangular Mimas Areographic, clon=180
-<60113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Sinusoidal Mimas Areocentric, clon=0
-<60114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Sinusoidal Mimas Areographic, clon=0
-<60115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Sinusoidal Mimas Areocentric, clon=180
-<60116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Sinusoidal Mimas Areographic, clon=180
-<60117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# North Polar Mimas Areocentric, clon=0
-<60118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# North Polar Mimas Areographic, clon=0
-<60119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# South Polar Mimas Areocentric, clon=0
-<60120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# South Polar Mimas Areographic, clon=0
-<60121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mollweide Mimas Areocentric, clon=0
-<60122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mollweide Mimas Areographic, clon=0
-<60123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mollweide Mimas Areocentric, clon=180
-<60124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mollweide Mimas Areographic, clon=180
-<60125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Robinson Mimas Areocentric, clon=0
-<60126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Robinson Mimas Areographic, clon=0
-<60127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Robinson Mimas Areocentric, clon=180
-<60128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Robinson Mimas Areographic, clon=180
-<60129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Sinusoidal AUTO Mimas Areocentric
-<60160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Sinusoidal AUTO Mimas Areographic
-<60161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Stereographic AUTO Mimas Areocentric, clon=0
-<60162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Stereographic AUTO Mimas Areographic, clon=0
-<60163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Transverse Mercator AUTO Mimas Areocentric
-<60164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Transverse Mercator AUTO Mimas Areographic
-<60165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Orthographic AUTO Mimas Areocentric
-<60166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Orthographic AUTO Mimas Areographic
-<60167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mimas Areocentric
-<60168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mimas Areographic
-<60169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mimas Areocentric
-<60170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mimas Areographic
-<60171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mimas Areocentric
-<60172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mimas Areographic
-<60173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mercator AUTO Mimas Areocentric
-<60174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mercator AUTO Mimas Areographic
-<60175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Albers AUTO Mimas Areocentric
-<60176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Albers AUTO Mimas Areographic
-<60177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mollweide AUTO Mimas Areocentric
-<60180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Mollweide AUTO Mimas Areographic
-<60181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Robinson AUTO Mimas Areocentric
-<60182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# Robinson AUTO Mimas Areographic
-<60183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=198200 +b=198200 +units=m +no_defs
-# GEOGCS Enceladus Areocentric
-<60200> 	+proj=longlat +a=252100 +b=252100 +no_defs
-# GEOGCS Enceladus Areographic
-<60201> 	+proj=longlat +a=252100 +b=252100 +no_defs
-# Equirectangular Enceladus Areocentric, clon=0
-<60210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Equirectangular Enceladus Areographic, clon=0
-<60211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Equirectangular Enceladus Areocentric, clon=180
-<60212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Equirectangular Enceladus Areographic, clon=180
-<60213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Sinusoidal Enceladus Areocentric, clon=0
-<60214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Sinusoidal Enceladus Areographic, clon=0
-<60215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Sinusoidal Enceladus Areocentric, clon=180
-<60216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Sinusoidal Enceladus Areographic, clon=180
-<60217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# North Polar Enceladus Areocentric, clon=0
-<60218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# North Polar Enceladus Areographic, clon=0
-<60219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# South Polar Enceladus Areocentric, clon=0
-<60220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# South Polar Enceladus Areographic, clon=0
-<60221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mollweide Enceladus Areocentric, clon=0
-<60222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mollweide Enceladus Areographic, clon=0
-<60223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mollweide Enceladus Areocentric, clon=180
-<60224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mollweide Enceladus Areographic, clon=180
-<60225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Robinson Enceladus Areocentric, clon=0
-<60226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Robinson Enceladus Areographic, clon=0
-<60227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Robinson Enceladus Areocentric, clon=180
-<60228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Robinson Enceladus Areographic, clon=180
-<60229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Sinusoidal AUTO Enceladus Areocentric
-<60260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Sinusoidal AUTO Enceladus Areographic
-<60261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Stereographic AUTO Enceladus Areocentric, clon=0
-<60262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Stereographic AUTO Enceladus Areographic, clon=0
-<60263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Transverse Mercator AUTO Enceladus Areocentric
-<60264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Transverse Mercator AUTO Enceladus Areographic
-<60265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Orthographic AUTO Enceladus Areocentric
-<60266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Orthographic AUTO Enceladus Areographic
-<60267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Enceladus Areocentric
-<60268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Enceladus Areographic
-<60269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Enceladus Areocentric
-<60270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Enceladus Areographic
-<60271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Enceladus Areocentric
-<60272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Enceladus Areographic
-<60273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mercator AUTO Enceladus Areocentric
-<60274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mercator AUTO Enceladus Areographic
-<60275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Albers AUTO Enceladus Areocentric
-<60276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Albers AUTO Enceladus Areographic
-<60277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mollweide AUTO Enceladus Areocentric
-<60280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Mollweide AUTO Enceladus Areographic
-<60281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Robinson AUTO Enceladus Areocentric
-<60282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# Robinson AUTO Enceladus Areographic
-<60283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=252100 +b=252100 +units=m +no_defs
-# GEOGCS Tethys Areocentric
-<60300> 	+proj=longlat +a=531000 +b=531000 +no_defs
-# GEOGCS Tethys Areographic
-<60301> 	+proj=longlat +a=531000 +b=531000 +no_defs
-# Equirectangular Tethys Areocentric, clon=0
-<60310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Equirectangular Tethys Areographic, clon=0
-<60311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Equirectangular Tethys Areocentric, clon=180
-<60312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Equirectangular Tethys Areographic, clon=180
-<60313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Sinusoidal Tethys Areocentric, clon=0
-<60314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Sinusoidal Tethys Areographic, clon=0
-<60315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Sinusoidal Tethys Areocentric, clon=180
-<60316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Sinusoidal Tethys Areographic, clon=180
-<60317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# North Polar Tethys Areocentric, clon=0
-<60318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# North Polar Tethys Areographic, clon=0
-<60319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# South Polar Tethys Areocentric, clon=0
-<60320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# South Polar Tethys Areographic, clon=0
-<60321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mollweide Tethys Areocentric, clon=0
-<60322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mollweide Tethys Areographic, clon=0
-<60323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mollweide Tethys Areocentric, clon=180
-<60324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mollweide Tethys Areographic, clon=180
-<60325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Robinson Tethys Areocentric, clon=0
-<60326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Robinson Tethys Areographic, clon=0
-<60327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Robinson Tethys Areocentric, clon=180
-<60328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Robinson Tethys Areographic, clon=180
-<60329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Sinusoidal AUTO Tethys Areocentric
-<60360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Sinusoidal AUTO Tethys Areographic
-<60361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Stereographic AUTO Tethys Areocentric, clon=0
-<60362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Stereographic AUTO Tethys Areographic, clon=0
-<60363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Transverse Mercator AUTO Tethys Areocentric
-<60364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Transverse Mercator AUTO Tethys Areographic
-<60365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Orthographic AUTO Tethys Areocentric
-<60366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Orthographic AUTO Tethys Areographic
-<60367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Tethys Areocentric
-<60368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Tethys Areographic
-<60369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Tethys Areocentric
-<60370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Tethys Areographic
-<60371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Tethys Areocentric
-<60372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Tethys Areographic
-<60373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mercator AUTO Tethys Areocentric
-<60374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mercator AUTO Tethys Areographic
-<60375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Albers AUTO Tethys Areocentric
-<60376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Albers AUTO Tethys Areographic
-<60377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mollweide AUTO Tethys Areocentric
-<60380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Mollweide AUTO Tethys Areographic
-<60381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Robinson AUTO Tethys Areocentric
-<60382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# Robinson AUTO Tethys Areographic
-<60383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=531000 +b=531000 +units=m +no_defs
-# GEOGCS Dione Areocentric
-<60400> 	+proj=longlat +a=561400 +b=561400 +no_defs
-# GEOGCS Dione Areographic
-<60401> 	+proj=longlat +a=561400 +b=561400 +no_defs
-# Equirectangular Dione Areocentric, clon=0
-<60410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Equirectangular Dione Areographic, clon=0
-<60411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Equirectangular Dione Areocentric, clon=180
-<60412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Equirectangular Dione Areographic, clon=180
-<60413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Sinusoidal Dione Areocentric, clon=0
-<60414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Sinusoidal Dione Areographic, clon=0
-<60415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Sinusoidal Dione Areocentric, clon=180
-<60416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Sinusoidal Dione Areographic, clon=180
-<60417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# North Polar Dione Areocentric, clon=0
-<60418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# North Polar Dione Areographic, clon=0
-<60419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# South Polar Dione Areocentric, clon=0
-<60420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# South Polar Dione Areographic, clon=0
-<60421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mollweide Dione Areocentric, clon=0
-<60422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mollweide Dione Areographic, clon=0
-<60423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mollweide Dione Areocentric, clon=180
-<60424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mollweide Dione Areographic, clon=180
-<60425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Robinson Dione Areocentric, clon=0
-<60426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Robinson Dione Areographic, clon=0
-<60427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Robinson Dione Areocentric, clon=180
-<60428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Robinson Dione Areographic, clon=180
-<60429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Sinusoidal AUTO Dione Areocentric
-<60460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Sinusoidal AUTO Dione Areographic
-<60461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Stereographic AUTO Dione Areocentric, clon=0
-<60462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Stereographic AUTO Dione Areographic, clon=0
-<60463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Transverse Mercator AUTO Dione Areocentric
-<60464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Transverse Mercator AUTO Dione Areographic
-<60465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Orthographic AUTO Dione Areocentric
-<60466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Orthographic AUTO Dione Areographic
-<60467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Dione Areocentric
-<60468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Dione Areographic
-<60469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Dione Areocentric
-<60470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Dione Areographic
-<60471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Dione Areocentric
-<60472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Dione Areographic
-<60473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mercator AUTO Dione Areocentric
-<60474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mercator AUTO Dione Areographic
-<60475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Albers AUTO Dione Areocentric
-<60476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Albers AUTO Dione Areographic
-<60477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mollweide AUTO Dione Areocentric
-<60480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Mollweide AUTO Dione Areographic
-<60481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Robinson AUTO Dione Areocentric
-<60482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# Robinson AUTO Dione Areographic
-<60483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=561400 +b=561400 +units=m +no_defs
-# GEOGCS Rhea Areocentric
-<60500> 	+proj=longlat +a=763500 +b=763500 +no_defs
-# GEOGCS Rhea Areographic
-<60501> 	+proj=longlat +a=763500 +b=763500 +no_defs
-# Equirectangular Rhea Areocentric, clon=0
-<60510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Equirectangular Rhea Areographic, clon=0
-<60511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Equirectangular Rhea Areocentric, clon=180
-<60512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Equirectangular Rhea Areographic, clon=180
-<60513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Sinusoidal Rhea Areocentric, clon=0
-<60514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Sinusoidal Rhea Areographic, clon=0
-<60515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Sinusoidal Rhea Areocentric, clon=180
-<60516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Sinusoidal Rhea Areographic, clon=180
-<60517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# North Polar Rhea Areocentric, clon=0
-<60518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# North Polar Rhea Areographic, clon=0
-<60519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# South Polar Rhea Areocentric, clon=0
-<60520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# South Polar Rhea Areographic, clon=0
-<60521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mollweide Rhea Areocentric, clon=0
-<60522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mollweide Rhea Areographic, clon=0
-<60523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mollweide Rhea Areocentric, clon=180
-<60524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mollweide Rhea Areographic, clon=180
-<60525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Robinson Rhea Areocentric, clon=0
-<60526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Robinson Rhea Areographic, clon=0
-<60527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Robinson Rhea Areocentric, clon=180
-<60528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Robinson Rhea Areographic, clon=180
-<60529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Sinusoidal AUTO Rhea Areocentric
-<60560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Sinusoidal AUTO Rhea Areographic
-<60561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Stereographic AUTO Rhea Areocentric, clon=0
-<60562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Stereographic AUTO Rhea Areographic, clon=0
-<60563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Transverse Mercator AUTO Rhea Areocentric
-<60564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Transverse Mercator AUTO Rhea Areographic
-<60565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Orthographic AUTO Rhea Areocentric
-<60566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Orthographic AUTO Rhea Areographic
-<60567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rhea Areocentric
-<60568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rhea Areographic
-<60569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rhea Areocentric
-<60570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rhea Areographic
-<60571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rhea Areocentric
-<60572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rhea Areographic
-<60573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mercator AUTO Rhea Areocentric
-<60574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mercator AUTO Rhea Areographic
-<60575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Albers AUTO Rhea Areocentric
-<60576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Albers AUTO Rhea Areographic
-<60577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mollweide AUTO Rhea Areocentric
-<60580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Mollweide AUTO Rhea Areographic
-<60581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Robinson AUTO Rhea Areocentric
-<60582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# Robinson AUTO Rhea Areographic
-<60583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=763500 +b=763500 +units=m +no_defs
-# GEOGCS Titan Areocentric
-<60600> 	+proj=longlat +a=2574730 +b=2574730 +no_defs
-# GEOGCS Titan Areographic
-<60601> 	+proj=longlat +a=2574730 +b=2574730 +no_defs
-# Equirectangular Titan Areocentric, clon=0
-<60610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Equirectangular Titan Areographic, clon=0
-<60611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Equirectangular Titan Areocentric, clon=180
-<60612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Equirectangular Titan Areographic, clon=180
-<60613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Sinusoidal Titan Areocentric, clon=0
-<60614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Sinusoidal Titan Areographic, clon=0
-<60615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Sinusoidal Titan Areocentric, clon=180
-<60616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Sinusoidal Titan Areographic, clon=180
-<60617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# North Polar Titan Areocentric, clon=0
-<60618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# North Polar Titan Areographic, clon=0
-<60619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# South Polar Titan Areocentric, clon=0
-<60620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# South Polar Titan Areographic, clon=0
-<60621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mollweide Titan Areocentric, clon=0
-<60622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mollweide Titan Areographic, clon=0
-<60623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mollweide Titan Areocentric, clon=180
-<60624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mollweide Titan Areographic, clon=180
-<60625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Robinson Titan Areocentric, clon=0
-<60626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Robinson Titan Areographic, clon=0
-<60627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Robinson Titan Areocentric, clon=180
-<60628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Robinson Titan Areographic, clon=180
-<60629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Sinusoidal AUTO Titan Areocentric
-<60660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Sinusoidal AUTO Titan Areographic
-<60661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Stereographic AUTO Titan Areocentric, clon=0
-<60662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Stereographic AUTO Titan Areographic, clon=0
-<60663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Transverse Mercator AUTO Titan Areocentric
-<60664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Transverse Mercator AUTO Titan Areographic
-<60665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Orthographic AUTO Titan Areocentric
-<60666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Orthographic AUTO Titan Areographic
-<60667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titan Areocentric
-<60668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titan Areographic
-<60669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titan Areocentric
-<60670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titan Areographic
-<60671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titan Areocentric
-<60672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titan Areographic
-<60673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mercator AUTO Titan Areocentric
-<60674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mercator AUTO Titan Areographic
-<60675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Albers AUTO Titan Areocentric
-<60676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Albers AUTO Titan Areographic
-<60677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mollweide AUTO Titan Areocentric
-<60680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Mollweide AUTO Titan Areographic
-<60681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Robinson AUTO Titan Areocentric
-<60682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# Robinson AUTO Titan Areographic
-<60683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2574730 +b=2574730 +units=m +no_defs
-# GEOGCS Hyperion Areocentric
-<60700> 	+proj=longlat +a=135000 +b=135000 +no_defs
-# GEOGCS Hyperion Areographic
-<60701> 	+proj=longlat +a=135000 +b=135000 +no_defs
-# Equirectangular Hyperion Areocentric, clon=0
-<60710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Equirectangular Hyperion Areographic, clon=0
-<60711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Equirectangular Hyperion Areocentric, clon=180
-<60712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Equirectangular Hyperion Areographic, clon=180
-<60713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Sinusoidal Hyperion Areocentric, clon=0
-<60714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Sinusoidal Hyperion Areographic, clon=0
-<60715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Sinusoidal Hyperion Areocentric, clon=180
-<60716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Sinusoidal Hyperion Areographic, clon=180
-<60717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# North Polar Hyperion Areocentric, clon=0
-<60718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# North Polar Hyperion Areographic, clon=0
-<60719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# South Polar Hyperion Areocentric, clon=0
-<60720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# South Polar Hyperion Areographic, clon=0
-<60721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mollweide Hyperion Areocentric, clon=0
-<60722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mollweide Hyperion Areographic, clon=0
-<60723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mollweide Hyperion Areocentric, clon=180
-<60724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mollweide Hyperion Areographic, clon=180
-<60725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Robinson Hyperion Areocentric, clon=0
-<60726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Robinson Hyperion Areographic, clon=0
-<60727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Robinson Hyperion Areocentric, clon=180
-<60728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Robinson Hyperion Areographic, clon=180
-<60729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Sinusoidal AUTO Hyperion Areocentric
-<60760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Sinusoidal AUTO Hyperion Areographic
-<60761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Stereographic AUTO Hyperion Areocentric, clon=0
-<60762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Stereographic AUTO Hyperion Areographic, clon=0
-<60763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Transverse Mercator AUTO Hyperion Areocentric
-<60764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Transverse Mercator AUTO Hyperion Areographic
-<60765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Orthographic AUTO Hyperion Areocentric
-<60766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Orthographic AUTO Hyperion Areographic
-<60767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Hyperion Areocentric
-<60768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Hyperion Areographic
-<60769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Hyperion Areocentric
-<60770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Hyperion Areographic
-<60771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Hyperion Areocentric
-<60772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Hyperion Areographic
-<60773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mercator AUTO Hyperion Areocentric
-<60774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mercator AUTO Hyperion Areographic
-<60775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Albers AUTO Hyperion Areocentric
-<60776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Albers AUTO Hyperion Areographic
-<60777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mollweide AUTO Hyperion Areocentric
-<60780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Mollweide AUTO Hyperion Areographic
-<60781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Robinson AUTO Hyperion Areocentric
-<60782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# Robinson AUTO Hyperion Areographic
-<60783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=135000 +b=135000 +units=m +no_defs
-# GEOGCS Iapetus Areocentric
-<60800> 	+proj=longlat +a=745700 +b=-15804080.28319055 +no_defs
-# GEOGCS Iapetus Areographic
-<60801> 	+proj=longlat +a=745700 +b=-15804080.28319055 +no_defs
-# Equirectangular Iapetus Areocentric, clon=0
-<60810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Equirectangular Iapetus Areographic, clon=0
-<60811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Equirectangular Iapetus Areocentric, clon=180
-<60812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Equirectangular Iapetus Areographic, clon=180
-<60813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Sinusoidal Iapetus Areocentric, clon=0
-<60814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Sinusoidal Iapetus Areographic, clon=0
-<60815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Sinusoidal Iapetus Areocentric, clon=180
-<60816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Sinusoidal Iapetus Areographic, clon=180
-<60817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# North Polar Iapetus Areocentric, clon=0
-<60818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# North Polar Iapetus Areographic, clon=0
-<60819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# South Polar Iapetus Areocentric, clon=0
-<60820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# South Polar Iapetus Areographic, clon=0
-<60821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mollweide Iapetus Areocentric, clon=0
-<60822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mollweide Iapetus Areographic, clon=0
-<60823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mollweide Iapetus Areocentric, clon=180
-<60824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mollweide Iapetus Areographic, clon=180
-<60825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Robinson Iapetus Areocentric, clon=0
-<60826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Robinson Iapetus Areographic, clon=0
-<60827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Robinson Iapetus Areocentric, clon=180
-<60828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Robinson Iapetus Areographic, clon=180
-<60829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Sinusoidal AUTO Iapetus Areocentric
-<60860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Sinusoidal AUTO Iapetus Areographic
-<60861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Stereographic AUTO Iapetus Areocentric, clon=0
-<60862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Stereographic AUTO Iapetus Areographic, clon=0
-<60863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Transverse Mercator AUTO Iapetus Areocentric
-<60864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Transverse Mercator AUTO Iapetus Areographic
-<60865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Orthographic AUTO Iapetus Areocentric
-<60866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Orthographic AUTO Iapetus Areographic
-<60867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Equidistant Cylindrical AUTO Iapetus Areocentric
-<60868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Equidistant Cylindrical AUTO Iapetus Areographic
-<60869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Lambert Conformal Conic AUTO Iapetus Areocentric
-<60870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Lambert Conformal Conic AUTO Iapetus Areographic
-<60871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Iapetus Areocentric
-<60872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Iapetus Areographic
-<60873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mercator AUTO Iapetus Areocentric
-<60874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mercator AUTO Iapetus Areographic
-<60875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Albers AUTO Iapetus Areocentric
-<60876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Albers AUTO Iapetus Areographic
-<60877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mollweide AUTO Iapetus Areocentric
-<60880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Mollweide AUTO Iapetus Areographic
-<60881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Robinson AUTO Iapetus Areocentric
-<60882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# Robinson AUTO Iapetus Areographic
-<60883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=745700 +b=-15804080.28319055 +units=m +no_defs
-# GEOGCS Phoebe Areocentric
-<60900> 	+proj=longlat +a=106500 +b=106500 +no_defs
-# GEOGCS Phoebe Areographic
-<60901> 	+proj=longlat +a=106500 +b=106500 +no_defs
-# Equirectangular Phoebe Areocentric, clon=0
-<60910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Equirectangular Phoebe Areographic, clon=0
-<60911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Equirectangular Phoebe Areocentric, clon=180
-<60912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Equirectangular Phoebe Areographic, clon=180
-<60913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Sinusoidal Phoebe Areocentric, clon=0
-<60914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Sinusoidal Phoebe Areographic, clon=0
-<60915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Sinusoidal Phoebe Areocentric, clon=180
-<60916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Sinusoidal Phoebe Areographic, clon=180
-<60917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# North Polar Phoebe Areocentric, clon=0
-<60918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# North Polar Phoebe Areographic, clon=0
-<60919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# South Polar Phoebe Areocentric, clon=0
-<60920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# South Polar Phoebe Areographic, clon=0
-<60921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mollweide Phoebe Areocentric, clon=0
-<60922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mollweide Phoebe Areographic, clon=0
-<60923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mollweide Phoebe Areocentric, clon=180
-<60924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mollweide Phoebe Areographic, clon=180
-<60925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Robinson Phoebe Areocentric, clon=0
-<60926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Robinson Phoebe Areographic, clon=0
-<60927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Robinson Phoebe Areocentric, clon=180
-<60928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Robinson Phoebe Areographic, clon=180
-<60929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Sinusoidal AUTO Phoebe Areocentric
-<60960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Sinusoidal AUTO Phoebe Areographic
-<60961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Stereographic AUTO Phoebe Areocentric, clon=0
-<60962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Stereographic AUTO Phoebe Areographic, clon=0
-<60963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Transverse Mercator AUTO Phoebe Areocentric
-<60964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Transverse Mercator AUTO Phoebe Areographic
-<60965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Orthographic AUTO Phoebe Areocentric
-<60966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Orthographic AUTO Phoebe Areographic
-<60967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phoebe Areocentric
-<60968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Phoebe Areographic
-<60969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phoebe Areocentric
-<60970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Phoebe Areographic
-<60971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phoebe Areocentric
-<60972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Phoebe Areographic
-<60973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mercator AUTO Phoebe Areocentric
-<60974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mercator AUTO Phoebe Areographic
-<60975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Albers AUTO Phoebe Areocentric
-<60976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Albers AUTO Phoebe Areographic
-<60977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mollweide AUTO Phoebe Areocentric
-<60980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Mollweide AUTO Phoebe Areographic
-<60981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Robinson AUTO Phoebe Areocentric
-<60982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# Robinson AUTO Phoebe Areographic
-<60983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=106500 +b=106500 +units=m +no_defs
-# GEOGCS Janus Areocentric
-<61000> 	+proj=longlat +a=89500 +b=89500 +no_defs
-# GEOGCS Janus Areographic
-<61001> 	+proj=longlat +a=89500 +b=89500 +no_defs
-# Equirectangular Janus Areocentric, clon=0
-<61010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Equirectangular Janus Areographic, clon=0
-<61011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Equirectangular Janus Areocentric, clon=180
-<61012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Equirectangular Janus Areographic, clon=180
-<61013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Sinusoidal Janus Areocentric, clon=0
-<61014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Sinusoidal Janus Areographic, clon=0
-<61015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Sinusoidal Janus Areocentric, clon=180
-<61016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Sinusoidal Janus Areographic, clon=180
-<61017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# North Polar Janus Areocentric, clon=0
-<61018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# North Polar Janus Areographic, clon=0
-<61019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# South Polar Janus Areocentric, clon=0
-<61020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# South Polar Janus Areographic, clon=0
-<61021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mollweide Janus Areocentric, clon=0
-<61022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mollweide Janus Areographic, clon=0
-<61023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mollweide Janus Areocentric, clon=180
-<61024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mollweide Janus Areographic, clon=180
-<61025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Robinson Janus Areocentric, clon=0
-<61026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Robinson Janus Areographic, clon=0
-<61027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Robinson Janus Areocentric, clon=180
-<61028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Robinson Janus Areographic, clon=180
-<61029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Sinusoidal AUTO Janus Areocentric
-<61060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Sinusoidal AUTO Janus Areographic
-<61061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Stereographic AUTO Janus Areocentric, clon=0
-<61062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Stereographic AUTO Janus Areographic, clon=0
-<61063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Transverse Mercator AUTO Janus Areocentric
-<61064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Transverse Mercator AUTO Janus Areographic
-<61065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Orthographic AUTO Janus Areocentric
-<61066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Orthographic AUTO Janus Areographic
-<61067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Janus Areocentric
-<61068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Janus Areographic
-<61069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Janus Areocentric
-<61070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Janus Areographic
-<61071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Janus Areocentric
-<61072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Janus Areographic
-<61073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mercator AUTO Janus Areocentric
-<61074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mercator AUTO Janus Areographic
-<61075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Albers AUTO Janus Areocentric
-<61076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Albers AUTO Janus Areographic
-<61077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mollweide AUTO Janus Areocentric
-<61080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Mollweide AUTO Janus Areographic
-<61081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Robinson AUTO Janus Areocentric
-<61082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# Robinson AUTO Janus Areographic
-<61083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=89500 +b=89500 +units=m +no_defs
-# GEOGCS Epimetheus Areocentric
-<61100> 	+proj=longlat +a=58100 +b=58100 +no_defs
-# GEOGCS Epimetheus Areographic
-<61101> 	+proj=longlat +a=58100 +b=58100 +no_defs
-# Equirectangular Epimetheus Areocentric, clon=0
-<61110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Equirectangular Epimetheus Areographic, clon=0
-<61111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Equirectangular Epimetheus Areocentric, clon=180
-<61112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Equirectangular Epimetheus Areographic, clon=180
-<61113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Sinusoidal Epimetheus Areocentric, clon=0
-<61114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Sinusoidal Epimetheus Areographic, clon=0
-<61115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Sinusoidal Epimetheus Areocentric, clon=180
-<61116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Sinusoidal Epimetheus Areographic, clon=180
-<61117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# North Polar Epimetheus Areocentric, clon=0
-<61118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# North Polar Epimetheus Areographic, clon=0
-<61119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# South Polar Epimetheus Areocentric, clon=0
-<61120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# South Polar Epimetheus Areographic, clon=0
-<61121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mollweide Epimetheus Areocentric, clon=0
-<61122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mollweide Epimetheus Areographic, clon=0
-<61123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mollweide Epimetheus Areocentric, clon=180
-<61124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mollweide Epimetheus Areographic, clon=180
-<61125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Robinson Epimetheus Areocentric, clon=0
-<61126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Robinson Epimetheus Areographic, clon=0
-<61127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Robinson Epimetheus Areocentric, clon=180
-<61128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Robinson Epimetheus Areographic, clon=180
-<61129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Sinusoidal AUTO Epimetheus Areocentric
-<61160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Sinusoidal AUTO Epimetheus Areographic
-<61161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Stereographic AUTO Epimetheus Areocentric, clon=0
-<61162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Stereographic AUTO Epimetheus Areographic, clon=0
-<61163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Transverse Mercator AUTO Epimetheus Areocentric
-<61164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Transverse Mercator AUTO Epimetheus Areographic
-<61165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Orthographic AUTO Epimetheus Areocentric
-<61166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Orthographic AUTO Epimetheus Areographic
-<61167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Epimetheus Areocentric
-<61168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Epimetheus Areographic
-<61169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Epimetheus Areocentric
-<61170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Epimetheus Areographic
-<61171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Epimetheus Areocentric
-<61172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Epimetheus Areographic
-<61173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mercator AUTO Epimetheus Areocentric
-<61174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mercator AUTO Epimetheus Areographic
-<61175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Albers AUTO Epimetheus Areocentric
-<61176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Albers AUTO Epimetheus Areographic
-<61177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mollweide AUTO Epimetheus Areocentric
-<61180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Mollweide AUTO Epimetheus Areographic
-<61181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Robinson AUTO Epimetheus Areocentric
-<61182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# Robinson AUTO Epimetheus Areographic
-<61183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=58100 +b=58100 +units=m +no_defs
-# GEOGCS Helene Areocentric
-<61200> 	+proj=longlat +a=17600 +b=17600 +no_defs
-# GEOGCS Helene Areographic
-<61201> 	+proj=longlat +a=17600 +b=17600 +no_defs
-# Equirectangular Helene Areocentric, clon=0
-<61210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Equirectangular Helene Areographic, clon=0
-<61211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Equirectangular Helene Areocentric, clon=180
-<61212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Equirectangular Helene Areographic, clon=180
-<61213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Sinusoidal Helene Areocentric, clon=0
-<61214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Sinusoidal Helene Areographic, clon=0
-<61215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Sinusoidal Helene Areocentric, clon=180
-<61216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Sinusoidal Helene Areographic, clon=180
-<61217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# North Polar Helene Areocentric, clon=0
-<61218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# North Polar Helene Areographic, clon=0
-<61219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# South Polar Helene Areocentric, clon=0
-<61220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# South Polar Helene Areographic, clon=0
-<61221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mollweide Helene Areocentric, clon=0
-<61222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mollweide Helene Areographic, clon=0
-<61223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mollweide Helene Areocentric, clon=180
-<61224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mollweide Helene Areographic, clon=180
-<61225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Robinson Helene Areocentric, clon=0
-<61226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Robinson Helene Areographic, clon=0
-<61227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Robinson Helene Areocentric, clon=180
-<61228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Robinson Helene Areographic, clon=180
-<61229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Sinusoidal AUTO Helene Areocentric
-<61260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Sinusoidal AUTO Helene Areographic
-<61261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Stereographic AUTO Helene Areocentric, clon=0
-<61262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Stereographic AUTO Helene Areographic, clon=0
-<61263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Transverse Mercator AUTO Helene Areocentric
-<61264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Transverse Mercator AUTO Helene Areographic
-<61265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Orthographic AUTO Helene Areocentric
-<61266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Orthographic AUTO Helene Areographic
-<61267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Helene Areocentric
-<61268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Helene Areographic
-<61269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Helene Areocentric
-<61270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Helene Areographic
-<61271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Helene Areocentric
-<61272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Helene Areographic
-<61273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mercator AUTO Helene Areocentric
-<61274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mercator AUTO Helene Areographic
-<61275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Albers AUTO Helene Areocentric
-<61276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Albers AUTO Helene Areographic
-<61277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mollweide AUTO Helene Areocentric
-<61280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Mollweide AUTO Helene Areographic
-<61281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Robinson AUTO Helene Areocentric
-<61282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# Robinson AUTO Helene Areographic
-<61283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=17600 +b=17600 +units=m +no_defs
-# GEOGCS Telesto Areocentric
-<61300> 	+proj=longlat +a=12400 +b=12400 +no_defs
-# GEOGCS Telesto Areographic
-<61301> 	+proj=longlat +a=12400 +b=12400 +no_defs
-# Equirectangular Telesto Areocentric, clon=0
-<61310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Equirectangular Telesto Areographic, clon=0
-<61311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Equirectangular Telesto Areocentric, clon=180
-<61312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Equirectangular Telesto Areographic, clon=180
-<61313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Sinusoidal Telesto Areocentric, clon=0
-<61314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Sinusoidal Telesto Areographic, clon=0
-<61315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Sinusoidal Telesto Areocentric, clon=180
-<61316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Sinusoidal Telesto Areographic, clon=180
-<61317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# North Polar Telesto Areocentric, clon=0
-<61318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# North Polar Telesto Areographic, clon=0
-<61319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# South Polar Telesto Areocentric, clon=0
-<61320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# South Polar Telesto Areographic, clon=0
-<61321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mollweide Telesto Areocentric, clon=0
-<61322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mollweide Telesto Areographic, clon=0
-<61323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mollweide Telesto Areocentric, clon=180
-<61324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mollweide Telesto Areographic, clon=180
-<61325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Robinson Telesto Areocentric, clon=0
-<61326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Robinson Telesto Areographic, clon=0
-<61327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Robinson Telesto Areocentric, clon=180
-<61328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Robinson Telesto Areographic, clon=180
-<61329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Sinusoidal AUTO Telesto Areocentric
-<61360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Sinusoidal AUTO Telesto Areographic
-<61361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Stereographic AUTO Telesto Areocentric, clon=0
-<61362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Stereographic AUTO Telesto Areographic, clon=0
-<61363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Transverse Mercator AUTO Telesto Areocentric
-<61364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Transverse Mercator AUTO Telesto Areographic
-<61365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Orthographic AUTO Telesto Areocentric
-<61366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Orthographic AUTO Telesto Areographic
-<61367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Telesto Areocentric
-<61368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Telesto Areographic
-<61369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Telesto Areocentric
-<61370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Telesto Areographic
-<61371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Telesto Areocentric
-<61372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Telesto Areographic
-<61373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mercator AUTO Telesto Areocentric
-<61374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mercator AUTO Telesto Areographic
-<61375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Albers AUTO Telesto Areocentric
-<61376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Albers AUTO Telesto Areographic
-<61377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mollweide AUTO Telesto Areocentric
-<61380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Mollweide AUTO Telesto Areographic
-<61381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Robinson AUTO Telesto Areocentric
-<61382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# Robinson AUTO Telesto Areographic
-<61383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=12400 +b=12400 +units=m +no_defs
-# GEOGCS Calypso Areocentric
-<61400> 	+proj=longlat +a=10700 +b=10700 +no_defs
-# GEOGCS Calypso Areographic
-<61401> 	+proj=longlat +a=10700 +b=10700 +no_defs
-# Equirectangular Calypso Areocentric, clon=0
-<61410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Equirectangular Calypso Areographic, clon=0
-<61411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Equirectangular Calypso Areocentric, clon=180
-<61412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Equirectangular Calypso Areographic, clon=180
-<61413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Sinusoidal Calypso Areocentric, clon=0
-<61414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Sinusoidal Calypso Areographic, clon=0
-<61415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Sinusoidal Calypso Areocentric, clon=180
-<61416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Sinusoidal Calypso Areographic, clon=180
-<61417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# North Polar Calypso Areocentric, clon=0
-<61418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# North Polar Calypso Areographic, clon=0
-<61419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# South Polar Calypso Areocentric, clon=0
-<61420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# South Polar Calypso Areographic, clon=0
-<61421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mollweide Calypso Areocentric, clon=0
-<61422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mollweide Calypso Areographic, clon=0
-<61423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mollweide Calypso Areocentric, clon=180
-<61424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mollweide Calypso Areographic, clon=180
-<61425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Robinson Calypso Areocentric, clon=0
-<61426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Robinson Calypso Areographic, clon=0
-<61427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Robinson Calypso Areocentric, clon=180
-<61428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Robinson Calypso Areographic, clon=180
-<61429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Sinusoidal AUTO Calypso Areocentric
-<61460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Sinusoidal AUTO Calypso Areographic
-<61461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Stereographic AUTO Calypso Areocentric, clon=0
-<61462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Stereographic AUTO Calypso Areographic, clon=0
-<61463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Transverse Mercator AUTO Calypso Areocentric
-<61464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Transverse Mercator AUTO Calypso Areographic
-<61465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Orthographic AUTO Calypso Areocentric
-<61466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Orthographic AUTO Calypso Areographic
-<61467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Calypso Areocentric
-<61468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Calypso Areographic
-<61469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Calypso Areocentric
-<61470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Calypso Areographic
-<61471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Calypso Areocentric
-<61472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Calypso Areographic
-<61473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mercator AUTO Calypso Areocentric
-<61474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mercator AUTO Calypso Areographic
-<61475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Albers AUTO Calypso Areocentric
-<61476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Albers AUTO Calypso Areographic
-<61477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mollweide AUTO Calypso Areocentric
-<61480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Mollweide AUTO Calypso Areographic
-<61481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Robinson AUTO Calypso Areocentric
-<61482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# Robinson AUTO Calypso Areographic
-<61483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=10700 +b=10700 +units=m +no_defs
-# GEOGCS Atlas Areocentric
-<61500> 	+proj=longlat +a=15100 +b=15100 +no_defs
-# GEOGCS Atlas Areographic
-<61501> 	+proj=longlat +a=15100 +b=15100 +no_defs
-# Equirectangular Atlas Areocentric, clon=0
-<61510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Equirectangular Atlas Areographic, clon=0
-<61511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Equirectangular Atlas Areocentric, clon=180
-<61512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Equirectangular Atlas Areographic, clon=180
-<61513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Sinusoidal Atlas Areocentric, clon=0
-<61514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Sinusoidal Atlas Areographic, clon=0
-<61515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Sinusoidal Atlas Areocentric, clon=180
-<61516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Sinusoidal Atlas Areographic, clon=180
-<61517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# North Polar Atlas Areocentric, clon=0
-<61518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# North Polar Atlas Areographic, clon=0
-<61519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# South Polar Atlas Areocentric, clon=0
-<61520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# South Polar Atlas Areographic, clon=0
-<61521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mollweide Atlas Areocentric, clon=0
-<61522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mollweide Atlas Areographic, clon=0
-<61523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mollweide Atlas Areocentric, clon=180
-<61524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mollweide Atlas Areographic, clon=180
-<61525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Robinson Atlas Areocentric, clon=0
-<61526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Robinson Atlas Areographic, clon=0
-<61527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Robinson Atlas Areocentric, clon=180
-<61528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Robinson Atlas Areographic, clon=180
-<61529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Sinusoidal AUTO Atlas Areocentric
-<61560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Sinusoidal AUTO Atlas Areographic
-<61561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Stereographic AUTO Atlas Areocentric, clon=0
-<61562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Stereographic AUTO Atlas Areographic, clon=0
-<61563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Transverse Mercator AUTO Atlas Areocentric
-<61564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Transverse Mercator AUTO Atlas Areographic
-<61565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Orthographic AUTO Atlas Areocentric
-<61566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Orthographic AUTO Atlas Areographic
-<61567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Atlas Areocentric
-<61568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Atlas Areographic
-<61569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Atlas Areocentric
-<61570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Atlas Areographic
-<61571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Atlas Areocentric
-<61572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Atlas Areographic
-<61573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mercator AUTO Atlas Areocentric
-<61574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mercator AUTO Atlas Areographic
-<61575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Albers AUTO Atlas Areocentric
-<61576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Albers AUTO Atlas Areographic
-<61577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mollweide AUTO Atlas Areocentric
-<61580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Mollweide AUTO Atlas Areographic
-<61581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Robinson AUTO Atlas Areocentric
-<61582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# Robinson AUTO Atlas Areographic
-<61583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15100 +b=15100 +units=m +no_defs
-# GEOGCS Prometheus Areocentric
-<61600> 	+proj=longlat +a=43100 +b=43100 +no_defs
-# GEOGCS Prometheus Areographic
-<61601> 	+proj=longlat +a=43100 +b=43100 +no_defs
-# Equirectangular Prometheus Areocentric, clon=0
-<61610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Equirectangular Prometheus Areographic, clon=0
-<61611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Equirectangular Prometheus Areocentric, clon=180
-<61612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Equirectangular Prometheus Areographic, clon=180
-<61613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Sinusoidal Prometheus Areocentric, clon=0
-<61614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Sinusoidal Prometheus Areographic, clon=0
-<61615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Sinusoidal Prometheus Areocentric, clon=180
-<61616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Sinusoidal Prometheus Areographic, clon=180
-<61617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# North Polar Prometheus Areocentric, clon=0
-<61618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# North Polar Prometheus Areographic, clon=0
-<61619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# South Polar Prometheus Areocentric, clon=0
-<61620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# South Polar Prometheus Areographic, clon=0
-<61621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mollweide Prometheus Areocentric, clon=0
-<61622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mollweide Prometheus Areographic, clon=0
-<61623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mollweide Prometheus Areocentric, clon=180
-<61624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mollweide Prometheus Areographic, clon=180
-<61625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Robinson Prometheus Areocentric, clon=0
-<61626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Robinson Prometheus Areographic, clon=0
-<61627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Robinson Prometheus Areocentric, clon=180
-<61628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Robinson Prometheus Areographic, clon=180
-<61629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Sinusoidal AUTO Prometheus Areocentric
-<61660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Sinusoidal AUTO Prometheus Areographic
-<61661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Stereographic AUTO Prometheus Areocentric, clon=0
-<61662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Stereographic AUTO Prometheus Areographic, clon=0
-<61663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Transverse Mercator AUTO Prometheus Areocentric
-<61664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Transverse Mercator AUTO Prometheus Areographic
-<61665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Orthographic AUTO Prometheus Areocentric
-<61666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Orthographic AUTO Prometheus Areographic
-<61667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Prometheus Areocentric
-<61668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Prometheus Areographic
-<61669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Prometheus Areocentric
-<61670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Prometheus Areographic
-<61671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Prometheus Areocentric
-<61672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Prometheus Areographic
-<61673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mercator AUTO Prometheus Areocentric
-<61674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mercator AUTO Prometheus Areographic
-<61675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Albers AUTO Prometheus Areocentric
-<61676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Albers AUTO Prometheus Areographic
-<61677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mollweide AUTO Prometheus Areocentric
-<61680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Mollweide AUTO Prometheus Areographic
-<61681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Robinson AUTO Prometheus Areocentric
-<61682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# Robinson AUTO Prometheus Areographic
-<61683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=43100 +b=43100 +units=m +no_defs
-# GEOGCS Pandora Areocentric
-<61700> 	+proj=longlat +a=40700 +b=40700 +no_defs
-# GEOGCS Pandora Areographic
-<61701> 	+proj=longlat +a=40700 +b=40700 +no_defs
-# Equirectangular Pandora Areocentric, clon=0
-<61710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Equirectangular Pandora Areographic, clon=0
-<61711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Equirectangular Pandora Areocentric, clon=180
-<61712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Equirectangular Pandora Areographic, clon=180
-<61713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Sinusoidal Pandora Areocentric, clon=0
-<61714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Sinusoidal Pandora Areographic, clon=0
-<61715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Sinusoidal Pandora Areocentric, clon=180
-<61716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Sinusoidal Pandora Areographic, clon=180
-<61717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# North Polar Pandora Areocentric, clon=0
-<61718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# North Polar Pandora Areographic, clon=0
-<61719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# South Polar Pandora Areocentric, clon=0
-<61720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# South Polar Pandora Areographic, clon=0
-<61721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mollweide Pandora Areocentric, clon=0
-<61722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mollweide Pandora Areographic, clon=0
-<61723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mollweide Pandora Areocentric, clon=180
-<61724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mollweide Pandora Areographic, clon=180
-<61725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Robinson Pandora Areocentric, clon=0
-<61726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Robinson Pandora Areographic, clon=0
-<61727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Robinson Pandora Areocentric, clon=180
-<61728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Robinson Pandora Areographic, clon=180
-<61729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Sinusoidal AUTO Pandora Areocentric
-<61760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Sinusoidal AUTO Pandora Areographic
-<61761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Stereographic AUTO Pandora Areocentric, clon=0
-<61762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Stereographic AUTO Pandora Areographic, clon=0
-<61763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Transverse Mercator AUTO Pandora Areocentric
-<61764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Transverse Mercator AUTO Pandora Areographic
-<61765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Orthographic AUTO Pandora Areocentric
-<61766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Orthographic AUTO Pandora Areographic
-<61767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pandora Areocentric
-<61768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pandora Areographic
-<61769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pandora Areocentric
-<61770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pandora Areographic
-<61771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pandora Areocentric
-<61772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pandora Areographic
-<61773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mercator AUTO Pandora Areocentric
-<61774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mercator AUTO Pandora Areographic
-<61775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Albers AUTO Pandora Areocentric
-<61776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Albers AUTO Pandora Areographic
-<61777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mollweide AUTO Pandora Areocentric
-<61780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Mollweide AUTO Pandora Areographic
-<61781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Robinson AUTO Pandora Areocentric
-<61782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# Robinson AUTO Pandora Areographic
-<61783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40700 +b=40700 +units=m +no_defs
-# GEOGCS Pan Areocentric
-<61800> 	+proj=longlat +a=14100 +b=14100 +no_defs
-# GEOGCS Pan Areographic
-<61801> 	+proj=longlat +a=14100 +b=14100 +no_defs
-# Equirectangular Pan Areocentric, clon=0
-<61810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Equirectangular Pan Areographic, clon=0
-<61811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Equirectangular Pan Areocentric, clon=180
-<61812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Equirectangular Pan Areographic, clon=180
-<61813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Sinusoidal Pan Areocentric, clon=0
-<61814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Sinusoidal Pan Areographic, clon=0
-<61815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Sinusoidal Pan Areocentric, clon=180
-<61816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Sinusoidal Pan Areographic, clon=180
-<61817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# North Polar Pan Areocentric, clon=0
-<61818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# North Polar Pan Areographic, clon=0
-<61819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# South Polar Pan Areocentric, clon=0
-<61820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# South Polar Pan Areographic, clon=0
-<61821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mollweide Pan Areocentric, clon=0
-<61822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mollweide Pan Areographic, clon=0
-<61823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mollweide Pan Areocentric, clon=180
-<61824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mollweide Pan Areographic, clon=180
-<61825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Robinson Pan Areocentric, clon=0
-<61826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Robinson Pan Areographic, clon=0
-<61827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Robinson Pan Areocentric, clon=180
-<61828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Robinson Pan Areographic, clon=180
-<61829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Sinusoidal AUTO Pan Areocentric
-<61860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Sinusoidal AUTO Pan Areographic
-<61861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Stereographic AUTO Pan Areocentric, clon=0
-<61862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Stereographic AUTO Pan Areographic, clon=0
-<61863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Transverse Mercator AUTO Pan Areocentric
-<61864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Transverse Mercator AUTO Pan Areographic
-<61865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Orthographic AUTO Pan Areocentric
-<61866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Orthographic AUTO Pan Areographic
-<61867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pan Areocentric
-<61868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pan Areographic
-<61869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pan Areocentric
-<61870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pan Areographic
-<61871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pan Areocentric
-<61872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pan Areographic
-<61873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mercator AUTO Pan Areocentric
-<61874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mercator AUTO Pan Areographic
-<61875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Albers AUTO Pan Areocentric
-<61876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Albers AUTO Pan Areographic
-<61877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mollweide AUTO Pan Areocentric
-<61880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Mollweide AUTO Pan Areographic
-<61881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Robinson AUTO Pan Areocentric
-<61882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# Robinson AUTO Pan Areographic
-<61883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=14100 +b=14100 +units=m +no_defs
-# GEOGCS Methone Areocentric
-<63200> 	+proj=longlat +a=1600 +b=1600 +no_defs
-# GEOGCS Methone Areographic
-<63201> 	+proj=longlat +a=1600 +b=1600 +no_defs
-# Equirectangular Methone Areocentric, clon=0
-<63210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equirectangular Methone Areographic, clon=0
-<63211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equirectangular Methone Areocentric, clon=180
-<63212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equirectangular Methone Areographic, clon=180
-<63213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areocentric, clon=0
-<63214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areographic, clon=0
-<63215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areocentric, clon=180
-<63216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal Methone Areographic, clon=180
-<63217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# North Polar Methone Areocentric, clon=0
-<63218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# North Polar Methone Areographic, clon=0
-<63219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# South Polar Methone Areocentric, clon=0
-<63220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# South Polar Methone Areographic, clon=0
-<63221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areocentric, clon=0
-<63222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areographic, clon=0
-<63223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areocentric, clon=180
-<63224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide Methone Areographic, clon=180
-<63225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areocentric, clon=0
-<63226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areographic, clon=0
-<63227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areocentric, clon=180
-<63228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson Methone Areographic, clon=180
-<63229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal AUTO Methone Areocentric
-<63260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Sinusoidal AUTO Methone Areographic
-<63261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Stereographic AUTO Methone Areocentric, clon=0
-<63262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Stereographic AUTO Methone Areographic, clon=0
-<63263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Transverse Mercator AUTO Methone Areocentric
-<63264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Transverse Mercator AUTO Methone Areographic
-<63265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Orthographic AUTO Methone Areocentric
-<63266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Orthographic AUTO Methone Areographic
-<63267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Methone Areocentric
-<63268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Methone Areographic
-<63269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Methone Areocentric
-<63270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Methone Areographic
-<63271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Methone Areocentric
-<63272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Methone Areographic
-<63273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mercator AUTO Methone Areocentric
-<63274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mercator AUTO Methone Areographic
-<63275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Albers AUTO Methone Areocentric
-<63276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Albers AUTO Methone Areographic
-<63277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide AUTO Methone Areocentric
-<63280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Mollweide AUTO Methone Areographic
-<63281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson AUTO Methone Areocentric
-<63282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# Robinson AUTO Methone Areographic
-<63283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1600 +b=1600 +units=m +no_defs
-# GEOGCS Pallene Areocentric
-<63300> 	+proj=longlat +a=2500 +b=2500 +no_defs
-# GEOGCS Pallene Areographic
-<63301> 	+proj=longlat +a=2500 +b=2500 +no_defs
-# Equirectangular Pallene Areocentric, clon=0
-<63310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equirectangular Pallene Areographic, clon=0
-<63311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equirectangular Pallene Areocentric, clon=180
-<63312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equirectangular Pallene Areographic, clon=180
-<63313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areocentric, clon=0
-<63314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areographic, clon=0
-<63315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areocentric, clon=180
-<63316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal Pallene Areographic, clon=180
-<63317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# North Polar Pallene Areocentric, clon=0
-<63318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# North Polar Pallene Areographic, clon=0
-<63319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# South Polar Pallene Areocentric, clon=0
-<63320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# South Polar Pallene Areographic, clon=0
-<63321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areocentric, clon=0
-<63322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areographic, clon=0
-<63323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areocentric, clon=180
-<63324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide Pallene Areographic, clon=180
-<63325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areocentric, clon=0
-<63326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areographic, clon=0
-<63327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areocentric, clon=180
-<63328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson Pallene Areographic, clon=180
-<63329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal AUTO Pallene Areocentric
-<63360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Sinusoidal AUTO Pallene Areographic
-<63361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Stereographic AUTO Pallene Areocentric, clon=0
-<63362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Stereographic AUTO Pallene Areographic, clon=0
-<63363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Transverse Mercator AUTO Pallene Areocentric
-<63364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Transverse Mercator AUTO Pallene Areographic
-<63365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Orthographic AUTO Pallene Areocentric
-<63366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Orthographic AUTO Pallene Areographic
-<63367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pallene Areocentric
-<63368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pallene Areographic
-<63369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pallene Areocentric
-<63370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pallene Areographic
-<63371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pallene Areocentric
-<63372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pallene Areographic
-<63373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mercator AUTO Pallene Areocentric
-<63374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mercator AUTO Pallene Areographic
-<63375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Albers AUTO Pallene Areocentric
-<63376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Albers AUTO Pallene Areographic
-<63377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide AUTO Pallene Areocentric
-<63380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Mollweide AUTO Pallene Areographic
-<63381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson AUTO Pallene Areocentric
-<63382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# Robinson AUTO Pallene Areographic
-<63383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2500 +b=2500 +units=m +no_defs
-# GEOGCS Polydeuces Areocentric
-<63400> 	+proj=longlat +a=1300 +b=1300 +no_defs
-# GEOGCS Polydeuces Areographic
-<63401> 	+proj=longlat +a=1300 +b=1300 +no_defs
-# Equirectangular Polydeuces Areocentric, clon=0
-<63410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equirectangular Polydeuces Areographic, clon=0
-<63411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equirectangular Polydeuces Areocentric, clon=180
-<63412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equirectangular Polydeuces Areographic, clon=180
-<63413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areocentric, clon=0
-<63414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areographic, clon=0
-<63415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areocentric, clon=180
-<63416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal Polydeuces Areographic, clon=180
-<63417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# North Polar Polydeuces Areocentric, clon=0
-<63418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# North Polar Polydeuces Areographic, clon=0
-<63419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# South Polar Polydeuces Areocentric, clon=0
-<63420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# South Polar Polydeuces Areographic, clon=0
-<63421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areocentric, clon=0
-<63422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areographic, clon=0
-<63423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areocentric, clon=180
-<63424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide Polydeuces Areographic, clon=180
-<63425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areocentric, clon=0
-<63426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areographic, clon=0
-<63427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areocentric, clon=180
-<63428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson Polydeuces Areographic, clon=180
-<63429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal AUTO Polydeuces Areocentric
-<63460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Sinusoidal AUTO Polydeuces Areographic
-<63461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Stereographic AUTO Polydeuces Areocentric, clon=0
-<63462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Stereographic AUTO Polydeuces Areographic, clon=0
-<63463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Transverse Mercator AUTO Polydeuces Areocentric
-<63464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Transverse Mercator AUTO Polydeuces Areographic
-<63465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Orthographic AUTO Polydeuces Areocentric
-<63466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Orthographic AUTO Polydeuces Areographic
-<63467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Polydeuces Areocentric
-<63468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Equidistant Cylindrical AUTO Polydeuces Areographic
-<63469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Polydeuces Areocentric
-<63470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Conformal Conic AUTO Polydeuces Areographic
-<63471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Polydeuces Areocentric
-<63472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Polydeuces Areographic
-<63473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mercator AUTO Polydeuces Areocentric
-<63474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mercator AUTO Polydeuces Areographic
-<63475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Albers AUTO Polydeuces Areocentric
-<63476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Albers AUTO Polydeuces Areographic
-<63477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide AUTO Polydeuces Areocentric
-<63480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Mollweide AUTO Polydeuces Areographic
-<63481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson AUTO Polydeuces Areocentric
-<63482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# Robinson AUTO Polydeuces Areographic
-<63483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1300 +b=1300 +units=m +no_defs
-# GEOGCS Daphnis Areocentric
-<63500> 	+proj=longlat +a=3800 +b=3800 +no_defs
-# GEOGCS Daphnis Areographic
-<63501> 	+proj=longlat +a=3800 +b=3800 +no_defs
-# Equirectangular Daphnis Areocentric, clon=0
-<63510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Equirectangular Daphnis Areographic, clon=0
-<63511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Equirectangular Daphnis Areocentric, clon=180
-<63512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Equirectangular Daphnis Areographic, clon=180
-<63513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Sinusoidal Daphnis Areocentric, clon=0
-<63514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Sinusoidal Daphnis Areographic, clon=0
-<63515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Sinusoidal Daphnis Areocentric, clon=180
-<63516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Sinusoidal Daphnis Areographic, clon=180
-<63517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# North Polar Daphnis Areocentric, clon=0
-<63518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# North Polar Daphnis Areographic, clon=0
-<63519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# South Polar Daphnis Areocentric, clon=0
-<63520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# South Polar Daphnis Areographic, clon=0
-<63521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mollweide Daphnis Areocentric, clon=0
-<63522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mollweide Daphnis Areographic, clon=0
-<63523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mollweide Daphnis Areocentric, clon=180
-<63524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mollweide Daphnis Areographic, clon=180
-<63525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Robinson Daphnis Areocentric, clon=0
-<63526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Robinson Daphnis Areographic, clon=0
-<63527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Robinson Daphnis Areocentric, clon=180
-<63528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Robinson Daphnis Areographic, clon=180
-<63529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Sinusoidal AUTO Daphnis Areocentric
-<63560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Sinusoidal AUTO Daphnis Areographic
-<63561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Stereographic AUTO Daphnis Areocentric, clon=0
-<63562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Stereographic AUTO Daphnis Areographic, clon=0
-<63563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Transverse Mercator AUTO Daphnis Areocentric
-<63564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Transverse Mercator AUTO Daphnis Areographic
-<63565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Orthographic AUTO Daphnis Areocentric
-<63566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Orthographic AUTO Daphnis Areographic
-<63567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Daphnis Areocentric
-<63568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Daphnis Areographic
-<63569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Daphnis Areocentric
-<63570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Daphnis Areographic
-<63571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Daphnis Areocentric
-<63572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Daphnis Areographic
-<63573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mercator AUTO Daphnis Areocentric
-<63574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mercator AUTO Daphnis Areographic
-<63575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Albers AUTO Daphnis Areocentric
-<63576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Albers AUTO Daphnis Areographic
-<63577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mollweide AUTO Daphnis Areocentric
-<63580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Mollweide AUTO Daphnis Areographic
-<63581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Robinson AUTO Daphnis Areocentric
-<63582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# Robinson AUTO Daphnis Areographic
-<63583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3800 +b=3800 +units=m +no_defs
-# GEOGCS Anthe Areocentric
-<64900> 	+proj=longlat +a=1000 +b=1000 +no_defs
-# GEOGCS Anthe Areographic
-<64901> 	+proj=longlat +a=1000 +b=1000 +no_defs
-# Equirectangular Anthe Areocentric, clon=0
-<64910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Equirectangular Anthe Areographic, clon=0
-<64911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Equirectangular Anthe Areocentric, clon=180
-<64912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Equirectangular Anthe Areographic, clon=180
-<64913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Sinusoidal Anthe Areocentric, clon=0
-<64914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Sinusoidal Anthe Areographic, clon=0
-<64915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Sinusoidal Anthe Areocentric, clon=180
-<64916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Sinusoidal Anthe Areographic, clon=180
-<64917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# North Polar Anthe Areocentric, clon=0
-<64918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# North Polar Anthe Areographic, clon=0
-<64919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# South Polar Anthe Areocentric, clon=0
-<64920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# South Polar Anthe Areographic, clon=0
-<64921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mollweide Anthe Areocentric, clon=0
-<64922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mollweide Anthe Areographic, clon=0
-<64923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mollweide Anthe Areocentric, clon=180
-<64924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mollweide Anthe Areographic, clon=180
-<64925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Robinson Anthe Areocentric, clon=0
-<64926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Robinson Anthe Areographic, clon=0
-<64927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Robinson Anthe Areocentric, clon=180
-<64928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Robinson Anthe Areographic, clon=180
-<64929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Sinusoidal AUTO Anthe Areocentric
-<64960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Sinusoidal AUTO Anthe Areographic
-<64961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Stereographic AUTO Anthe Areocentric, clon=0
-<64962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Stereographic AUTO Anthe Areographic, clon=0
-<64963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Transverse Mercator AUTO Anthe Areocentric
-<64964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Transverse Mercator AUTO Anthe Areographic
-<64965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Orthographic AUTO Anthe Areocentric
-<64966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Orthographic AUTO Anthe Areographic
-<64967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Anthe Areocentric
-<64968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Anthe Areographic
-<64969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Anthe Areocentric
-<64970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Anthe Areographic
-<64971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Anthe Areocentric
-<64972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Anthe Areographic
-<64973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mercator AUTO Anthe Areocentric
-<64974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mercator AUTO Anthe Areographic
-<64975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Albers AUTO Anthe Areocentric
-<64976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Albers AUTO Anthe Areographic
-<64977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mollweide AUTO Anthe Areocentric
-<64980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Mollweide AUTO Anthe Areographic
-<64981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Robinson AUTO Anthe Areocentric
-<64982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# Robinson AUTO Anthe Areographic
-<64983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1000 +b=1000 +units=m +no_defs
-# GEOGCS Uranus Areocentric
-<79900> 	+proj=longlat +a=25559000 +b=-1089240145.112749 +no_defs
-# GEOGCS Uranus Areographic
-<79901> 	+proj=longlat +a=25559000 +b=-1089240145.112749 +no_defs
-# Equirectangular Uranus Areocentric, clon=0
-<79910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equirectangular Uranus Areographic, clon=0
-<79911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equirectangular Uranus Areocentric, clon=180
-<79912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equirectangular Uranus Areographic, clon=180
-<79913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areocentric, clon=0
-<79914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areographic, clon=0
-<79915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areocentric, clon=180
-<79916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal Uranus Areographic, clon=180
-<79917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# North Polar Uranus Areocentric, clon=0
-<79918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# North Polar Uranus Areographic, clon=0
-<79919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# South Polar Uranus Areocentric, clon=0
-<79920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# South Polar Uranus Areographic, clon=0
-<79921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areocentric, clon=0
-<79922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areographic, clon=0
-<79923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areocentric, clon=180
-<79924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide Uranus Areographic, clon=180
-<79925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areocentric, clon=0
-<79926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areographic, clon=0
-<79927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areocentric, clon=180
-<79928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson Uranus Areographic, clon=180
-<79929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal AUTO Uranus Areocentric
-<79960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Sinusoidal AUTO Uranus Areographic
-<79961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Stereographic AUTO Uranus Areocentric, clon=0
-<79962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Stereographic AUTO Uranus Areographic, clon=0
-<79963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Transverse Mercator AUTO Uranus Areocentric
-<79964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Transverse Mercator AUTO Uranus Areographic
-<79965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Orthographic AUTO Uranus Areocentric
-<79966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Orthographic AUTO Uranus Areographic
-<79967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equidistant Cylindrical AUTO Uranus Areocentric
-<79968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Equidistant Cylindrical AUTO Uranus Areographic
-<79969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Conformal Conic AUTO Uranus Areocentric
-<79970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Conformal Conic AUTO Uranus Areographic
-<79971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Uranus Areocentric
-<79972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Uranus Areographic
-<79973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mercator AUTO Uranus Areocentric
-<79974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mercator AUTO Uranus Areographic
-<79975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Albers AUTO Uranus Areocentric
-<79976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Albers AUTO Uranus Areographic
-<79977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide AUTO Uranus Areocentric
-<79980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Mollweide AUTO Uranus Areographic
-<79981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson AUTO Uranus Areocentric
-<79982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# Robinson AUTO Uranus Areographic
-<79983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=25559000 +b=-1089240145.112749 +units=m +no_defs
-# GEOGCS Ariel Areocentric
-<70100> 	+proj=longlat +a=578900 +b=578900 +no_defs
-# GEOGCS Ariel Areographic
-<70101> 	+proj=longlat +a=578900 +b=578900 +no_defs
-# Equirectangular Ariel Areocentric, clon=0
-<70110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equirectangular Ariel Areographic, clon=0
-<70111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equirectangular Ariel Areocentric, clon=180
-<70112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equirectangular Ariel Areographic, clon=180
-<70113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areocentric, clon=0
-<70114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areographic, clon=0
-<70115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areocentric, clon=180
-<70116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal Ariel Areographic, clon=180
-<70117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# North Polar Ariel Areocentric, clon=0
-<70118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# North Polar Ariel Areographic, clon=0
-<70119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# South Polar Ariel Areocentric, clon=0
-<70120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# South Polar Ariel Areographic, clon=0
-<70121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areocentric, clon=0
-<70122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areographic, clon=0
-<70123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areocentric, clon=180
-<70124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide Ariel Areographic, clon=180
-<70125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areocentric, clon=0
-<70126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areographic, clon=0
-<70127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areocentric, clon=180
-<70128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson Ariel Areographic, clon=180
-<70129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal AUTO Ariel Areocentric
-<70160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Sinusoidal AUTO Ariel Areographic
-<70161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Stereographic AUTO Ariel Areocentric, clon=0
-<70162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Stereographic AUTO Ariel Areographic, clon=0
-<70163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Transverse Mercator AUTO Ariel Areocentric
-<70164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Transverse Mercator AUTO Ariel Areographic
-<70165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Orthographic AUTO Ariel Areocentric
-<70166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Orthographic AUTO Ariel Areographic
-<70167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ariel Areocentric
-<70168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ariel Areographic
-<70169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ariel Areocentric
-<70170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ariel Areographic
-<70171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ariel Areocentric
-<70172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ariel Areographic
-<70173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mercator AUTO Ariel Areocentric
-<70174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mercator AUTO Ariel Areographic
-<70175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Albers AUTO Ariel Areocentric
-<70176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Albers AUTO Ariel Areographic
-<70177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide AUTO Ariel Areocentric
-<70180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Mollweide AUTO Ariel Areographic
-<70181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson AUTO Ariel Areocentric
-<70182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# Robinson AUTO Ariel Areographic
-<70183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=578900 +b=578900 +units=m +no_defs
-# GEOGCS Umbriel Areocentric
-<70200> 	+proj=longlat +a=584700 +b=584700 +no_defs
-# GEOGCS Umbriel Areographic
-<70201> 	+proj=longlat +a=584700 +b=584700 +no_defs
-# Equirectangular Umbriel Areocentric, clon=0
-<70210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equirectangular Umbriel Areographic, clon=0
-<70211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equirectangular Umbriel Areocentric, clon=180
-<70212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equirectangular Umbriel Areographic, clon=180
-<70213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areocentric, clon=0
-<70214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areographic, clon=0
-<70215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areocentric, clon=180
-<70216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal Umbriel Areographic, clon=180
-<70217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# North Polar Umbriel Areocentric, clon=0
-<70218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# North Polar Umbriel Areographic, clon=0
-<70219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# South Polar Umbriel Areocentric, clon=0
-<70220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# South Polar Umbriel Areographic, clon=0
-<70221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areocentric, clon=0
-<70222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areographic, clon=0
-<70223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areocentric, clon=180
-<70224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide Umbriel Areographic, clon=180
-<70225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areocentric, clon=0
-<70226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areographic, clon=0
-<70227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areocentric, clon=180
-<70228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson Umbriel Areographic, clon=180
-<70229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal AUTO Umbriel Areocentric
-<70260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Sinusoidal AUTO Umbriel Areographic
-<70261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Stereographic AUTO Umbriel Areocentric, clon=0
-<70262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Stereographic AUTO Umbriel Areographic, clon=0
-<70263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Transverse Mercator AUTO Umbriel Areocentric
-<70264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Transverse Mercator AUTO Umbriel Areographic
-<70265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Orthographic AUTO Umbriel Areocentric
-<70266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Orthographic AUTO Umbriel Areographic
-<70267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Umbriel Areocentric
-<70268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Umbriel Areographic
-<70269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Umbriel Areocentric
-<70270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Umbriel Areographic
-<70271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Umbriel Areocentric
-<70272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Umbriel Areographic
-<70273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mercator AUTO Umbriel Areocentric
-<70274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mercator AUTO Umbriel Areographic
-<70275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Albers AUTO Umbriel Areocentric
-<70276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Albers AUTO Umbriel Areographic
-<70277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide AUTO Umbriel Areocentric
-<70280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Mollweide AUTO Umbriel Areographic
-<70281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson AUTO Umbriel Areocentric
-<70282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# Robinson AUTO Umbriel Areographic
-<70283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=584700 +b=584700 +units=m +no_defs
-# GEOGCS Titania Areocentric
-<70300> 	+proj=longlat +a=788900 +b=788900 +no_defs
-# GEOGCS Titania Areographic
-<70301> 	+proj=longlat +a=788900 +b=788900 +no_defs
-# Equirectangular Titania Areocentric, clon=0
-<70310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equirectangular Titania Areographic, clon=0
-<70311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equirectangular Titania Areocentric, clon=180
-<70312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equirectangular Titania Areographic, clon=180
-<70313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areocentric, clon=0
-<70314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areographic, clon=0
-<70315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areocentric, clon=180
-<70316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal Titania Areographic, clon=180
-<70317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# North Polar Titania Areocentric, clon=0
-<70318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# North Polar Titania Areographic, clon=0
-<70319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# South Polar Titania Areocentric, clon=0
-<70320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# South Polar Titania Areographic, clon=0
-<70321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areocentric, clon=0
-<70322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areographic, clon=0
-<70323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areocentric, clon=180
-<70324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide Titania Areographic, clon=180
-<70325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areocentric, clon=0
-<70326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areographic, clon=0
-<70327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areocentric, clon=180
-<70328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson Titania Areographic, clon=180
-<70329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal AUTO Titania Areocentric
-<70360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Sinusoidal AUTO Titania Areographic
-<70361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Stereographic AUTO Titania Areocentric, clon=0
-<70362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Stereographic AUTO Titania Areographic, clon=0
-<70363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Transverse Mercator AUTO Titania Areocentric
-<70364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Transverse Mercator AUTO Titania Areographic
-<70365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Orthographic AUTO Titania Areocentric
-<70366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Orthographic AUTO Titania Areographic
-<70367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titania Areocentric
-<70368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Equidistant Cylindrical AUTO Titania Areographic
-<70369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titania Areocentric
-<70370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Conformal Conic AUTO Titania Areographic
-<70371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titania Areocentric
-<70372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Titania Areographic
-<70373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mercator AUTO Titania Areocentric
-<70374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mercator AUTO Titania Areographic
-<70375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Albers AUTO Titania Areocentric
-<70376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Albers AUTO Titania Areographic
-<70377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide AUTO Titania Areocentric
-<70380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Mollweide AUTO Titania Areographic
-<70381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson AUTO Titania Areocentric
-<70382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# Robinson AUTO Titania Areographic
-<70383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=788900 +b=788900 +units=m +no_defs
-# GEOGCS Oberon Areocentric
-<70400> 	+proj=longlat +a=761400 +b=761400 +no_defs
-# GEOGCS Oberon Areographic
-<70401> 	+proj=longlat +a=761400 +b=761400 +no_defs
-# Equirectangular Oberon Areocentric, clon=0
-<70410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equirectangular Oberon Areographic, clon=0
-<70411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equirectangular Oberon Areocentric, clon=180
-<70412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equirectangular Oberon Areographic, clon=180
-<70413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areocentric, clon=0
-<70414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areographic, clon=0
-<70415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areocentric, clon=180
-<70416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal Oberon Areographic, clon=180
-<70417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# North Polar Oberon Areocentric, clon=0
-<70418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# North Polar Oberon Areographic, clon=0
-<70419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# South Polar Oberon Areocentric, clon=0
-<70420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# South Polar Oberon Areographic, clon=0
-<70421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areocentric, clon=0
-<70422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areographic, clon=0
-<70423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areocentric, clon=180
-<70424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide Oberon Areographic, clon=180
-<70425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areocentric, clon=0
-<70426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areographic, clon=0
-<70427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areocentric, clon=180
-<70428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson Oberon Areographic, clon=180
-<70429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal AUTO Oberon Areocentric
-<70460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Sinusoidal AUTO Oberon Areographic
-<70461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Stereographic AUTO Oberon Areocentric, clon=0
-<70462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Stereographic AUTO Oberon Areographic, clon=0
-<70463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Transverse Mercator AUTO Oberon Areocentric
-<70464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Transverse Mercator AUTO Oberon Areographic
-<70465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Orthographic AUTO Oberon Areocentric
-<70466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Orthographic AUTO Oberon Areographic
-<70467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Oberon Areocentric
-<70468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Equidistant Cylindrical AUTO Oberon Areographic
-<70469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Oberon Areocentric
-<70470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Conformal Conic AUTO Oberon Areographic
-<70471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Oberon Areocentric
-<70472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Oberon Areographic
-<70473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mercator AUTO Oberon Areocentric
-<70474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mercator AUTO Oberon Areographic
-<70475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Albers AUTO Oberon Areocentric
-<70476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Albers AUTO Oberon Areographic
-<70477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide AUTO Oberon Areocentric
-<70480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Mollweide AUTO Oberon Areographic
-<70481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson AUTO Oberon Areocentric
-<70482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# Robinson AUTO Oberon Areographic
-<70483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=761400 +b=761400 +units=m +no_defs
-# GEOGCS Miranda Areocentric
-<70500> 	+proj=longlat +a=235800 +b=235800 +no_defs
-# GEOGCS Miranda Areographic
-<70501> 	+proj=longlat +a=235800 +b=235800 +no_defs
-# Equirectangular Miranda Areocentric, clon=0
-<70510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equirectangular Miranda Areographic, clon=0
-<70511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equirectangular Miranda Areocentric, clon=180
-<70512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equirectangular Miranda Areographic, clon=180
-<70513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areocentric, clon=0
-<70514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areographic, clon=0
-<70515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areocentric, clon=180
-<70516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal Miranda Areographic, clon=180
-<70517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# North Polar Miranda Areocentric, clon=0
-<70518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# North Polar Miranda Areographic, clon=0
-<70519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# South Polar Miranda Areocentric, clon=0
-<70520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# South Polar Miranda Areographic, clon=0
-<70521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areocentric, clon=0
-<70522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areographic, clon=0
-<70523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areocentric, clon=180
-<70524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide Miranda Areographic, clon=180
-<70525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areocentric, clon=0
-<70526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areographic, clon=0
-<70527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areocentric, clon=180
-<70528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson Miranda Areographic, clon=180
-<70529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal AUTO Miranda Areocentric
-<70560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Sinusoidal AUTO Miranda Areographic
-<70561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Stereographic AUTO Miranda Areocentric, clon=0
-<70562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Stereographic AUTO Miranda Areographic, clon=0
-<70563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Transverse Mercator AUTO Miranda Areocentric
-<70564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Transverse Mercator AUTO Miranda Areographic
-<70565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Orthographic AUTO Miranda Areocentric
-<70566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Orthographic AUTO Miranda Areographic
-<70567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Miranda Areocentric
-<70568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Equidistant Cylindrical AUTO Miranda Areographic
-<70569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Miranda Areocentric
-<70570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Conformal Conic AUTO Miranda Areographic
-<70571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Miranda Areocentric
-<70572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Miranda Areographic
-<70573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mercator AUTO Miranda Areocentric
-<70574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mercator AUTO Miranda Areographic
-<70575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Albers AUTO Miranda Areocentric
-<70576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Albers AUTO Miranda Areographic
-<70577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide AUTO Miranda Areocentric
-<70580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Mollweide AUTO Miranda Areographic
-<70581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson AUTO Miranda Areocentric
-<70582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# Robinson AUTO Miranda Areographic
-<70583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=235800 +b=235800 +units=m +no_defs
-# GEOGCS Cordelia Areocentric
-<70600> 	+proj=longlat +a=13000 +b=13000 +no_defs
-# GEOGCS Cordelia Areographic
-<70601> 	+proj=longlat +a=13000 +b=13000 +no_defs
-# Equirectangular Cordelia Areocentric, clon=0
-<70610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equirectangular Cordelia Areographic, clon=0
-<70611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equirectangular Cordelia Areocentric, clon=180
-<70612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equirectangular Cordelia Areographic, clon=180
-<70613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areocentric, clon=0
-<70614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areographic, clon=0
-<70615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areocentric, clon=180
-<70616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal Cordelia Areographic, clon=180
-<70617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# North Polar Cordelia Areocentric, clon=0
-<70618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# North Polar Cordelia Areographic, clon=0
-<70619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# South Polar Cordelia Areocentric, clon=0
-<70620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# South Polar Cordelia Areographic, clon=0
-<70621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areocentric, clon=0
-<70622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areographic, clon=0
-<70623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areocentric, clon=180
-<70624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide Cordelia Areographic, clon=180
-<70625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areocentric, clon=0
-<70626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areographic, clon=0
-<70627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areocentric, clon=180
-<70628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson Cordelia Areographic, clon=180
-<70629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal AUTO Cordelia Areocentric
-<70660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Sinusoidal AUTO Cordelia Areographic
-<70661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Stereographic AUTO Cordelia Areocentric, clon=0
-<70662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Stereographic AUTO Cordelia Areographic, clon=0
-<70663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Transverse Mercator AUTO Cordelia Areocentric
-<70664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Transverse Mercator AUTO Cordelia Areographic
-<70665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Orthographic AUTO Cordelia Areocentric
-<70666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Orthographic AUTO Cordelia Areographic
-<70667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cordelia Areocentric
-<70668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cordelia Areographic
-<70669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cordelia Areocentric
-<70670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cordelia Areographic
-<70671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cordelia Areocentric
-<70672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cordelia Areographic
-<70673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mercator AUTO Cordelia Areocentric
-<70674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mercator AUTO Cordelia Areographic
-<70675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Albers AUTO Cordelia Areocentric
-<70676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Albers AUTO Cordelia Areographic
-<70677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide AUTO Cordelia Areocentric
-<70680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Mollweide AUTO Cordelia Areographic
-<70681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson AUTO Cordelia Areocentric
-<70682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# Robinson AUTO Cordelia Areographic
-<70683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=13000 +b=13000 +units=m +no_defs
-# GEOGCS Ophelia Areocentric
-<70700> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# GEOGCS Ophelia Areographic
-<70701> 	+proj=longlat +a=15000 +b=15000 +no_defs
-# Equirectangular Ophelia Areocentric, clon=0
-<70710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Ophelia Areographic, clon=0
-<70711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Ophelia Areocentric, clon=180
-<70712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equirectangular Ophelia Areographic, clon=180
-<70713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areocentric, clon=0
-<70714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areographic, clon=0
-<70715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areocentric, clon=180
-<70716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal Ophelia Areographic, clon=180
-<70717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Ophelia Areocentric, clon=0
-<70718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# North Polar Ophelia Areographic, clon=0
-<70719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Ophelia Areocentric, clon=0
-<70720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# South Polar Ophelia Areographic, clon=0
-<70721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areocentric, clon=0
-<70722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areographic, clon=0
-<70723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areocentric, clon=180
-<70724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide Ophelia Areographic, clon=180
-<70725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areocentric, clon=0
-<70726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areographic, clon=0
-<70727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areocentric, clon=180
-<70728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson Ophelia Areographic, clon=180
-<70729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Ophelia Areocentric
-<70760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Sinusoidal AUTO Ophelia Areographic
-<70761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Ophelia Areocentric, clon=0
-<70762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Stereographic AUTO Ophelia Areographic, clon=0
-<70763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Ophelia Areocentric
-<70764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Transverse Mercator AUTO Ophelia Areographic
-<70765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Ophelia Areocentric
-<70766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Orthographic AUTO Ophelia Areographic
-<70767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ophelia Areocentric
-<70768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ophelia Areographic
-<70769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ophelia Areocentric
-<70770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ophelia Areographic
-<70771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ophelia Areocentric
-<70772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ophelia Areographic
-<70773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Ophelia Areocentric
-<70774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mercator AUTO Ophelia Areographic
-<70775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Ophelia Areocentric
-<70776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Albers AUTO Ophelia Areographic
-<70777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Ophelia Areocentric
-<70780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Mollweide AUTO Ophelia Areographic
-<70781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Ophelia Areocentric
-<70782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# Robinson AUTO Ophelia Areographic
-<70783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15000 +b=15000 +units=m +no_defs
-# GEOGCS Bianca Areocentric
-<70800> 	+proj=longlat +a=21000 +b=21000 +no_defs
-# GEOGCS Bianca Areographic
-<70801> 	+proj=longlat +a=21000 +b=21000 +no_defs
-# Equirectangular Bianca Areocentric, clon=0
-<70810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equirectangular Bianca Areographic, clon=0
-<70811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equirectangular Bianca Areocentric, clon=180
-<70812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equirectangular Bianca Areographic, clon=180
-<70813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areocentric, clon=0
-<70814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areographic, clon=0
-<70815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areocentric, clon=180
-<70816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal Bianca Areographic, clon=180
-<70817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# North Polar Bianca Areocentric, clon=0
-<70818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# North Polar Bianca Areographic, clon=0
-<70819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# South Polar Bianca Areocentric, clon=0
-<70820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# South Polar Bianca Areographic, clon=0
-<70821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areocentric, clon=0
-<70822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areographic, clon=0
-<70823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areocentric, clon=180
-<70824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide Bianca Areographic, clon=180
-<70825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areocentric, clon=0
-<70826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areographic, clon=0
-<70827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areocentric, clon=180
-<70828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson Bianca Areographic, clon=180
-<70829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal AUTO Bianca Areocentric
-<70860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Sinusoidal AUTO Bianca Areographic
-<70861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Stereographic AUTO Bianca Areocentric, clon=0
-<70862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Stereographic AUTO Bianca Areographic, clon=0
-<70863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Transverse Mercator AUTO Bianca Areocentric
-<70864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Transverse Mercator AUTO Bianca Areographic
-<70865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Orthographic AUTO Bianca Areocentric
-<70866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Orthographic AUTO Bianca Areographic
-<70867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Bianca Areocentric
-<70868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Bianca Areographic
-<70869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Bianca Areocentric
-<70870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Bianca Areographic
-<70871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Bianca Areocentric
-<70872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Bianca Areographic
-<70873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mercator AUTO Bianca Areocentric
-<70874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mercator AUTO Bianca Areographic
-<70875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Albers AUTO Bianca Areocentric
-<70876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Albers AUTO Bianca Areographic
-<70877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide AUTO Bianca Areocentric
-<70880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Mollweide AUTO Bianca Areographic
-<70881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson AUTO Bianca Areocentric
-<70882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# Robinson AUTO Bianca Areographic
-<70883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=21000 +b=21000 +units=m +no_defs
-# GEOGCS Cressida Areocentric
-<70900> 	+proj=longlat +a=31000 +b=31000 +no_defs
-# GEOGCS Cressida Areographic
-<70901> 	+proj=longlat +a=31000 +b=31000 +no_defs
-# Equirectangular Cressida Areocentric, clon=0
-<70910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equirectangular Cressida Areographic, clon=0
-<70911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equirectangular Cressida Areocentric, clon=180
-<70912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equirectangular Cressida Areographic, clon=180
-<70913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areocentric, clon=0
-<70914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areographic, clon=0
-<70915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areocentric, clon=180
-<70916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal Cressida Areographic, clon=180
-<70917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# North Polar Cressida Areocentric, clon=0
-<70918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# North Polar Cressida Areographic, clon=0
-<70919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# South Polar Cressida Areocentric, clon=0
-<70920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# South Polar Cressida Areographic, clon=0
-<70921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areocentric, clon=0
-<70922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areographic, clon=0
-<70923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areocentric, clon=180
-<70924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide Cressida Areographic, clon=180
-<70925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areocentric, clon=0
-<70926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areographic, clon=0
-<70927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areocentric, clon=180
-<70928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson Cressida Areographic, clon=180
-<70929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal AUTO Cressida Areocentric
-<70960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Sinusoidal AUTO Cressida Areographic
-<70961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Stereographic AUTO Cressida Areocentric, clon=0
-<70962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Stereographic AUTO Cressida Areographic, clon=0
-<70963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Transverse Mercator AUTO Cressida Areocentric
-<70964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Transverse Mercator AUTO Cressida Areographic
-<70965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Orthographic AUTO Cressida Areocentric
-<70966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Orthographic AUTO Cressida Areographic
-<70967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cressida Areocentric
-<70968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Cressida Areographic
-<70969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cressida Areocentric
-<70970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Cressida Areographic
-<70971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cressida Areocentric
-<70972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Cressida Areographic
-<70973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mercator AUTO Cressida Areocentric
-<70974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mercator AUTO Cressida Areographic
-<70975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Albers AUTO Cressida Areocentric
-<70976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Albers AUTO Cressida Areographic
-<70977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide AUTO Cressida Areocentric
-<70980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Mollweide AUTO Cressida Areographic
-<70981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson AUTO Cressida Areocentric
-<70982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# Robinson AUTO Cressida Areographic
-<70983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=31000 +b=31000 +units=m +no_defs
-# GEOGCS Desdemona Areocentric
-<71000> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# GEOGCS Desdemona Areographic
-<71001> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# Equirectangular Desdemona Areocentric, clon=0
-<71010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Desdemona Areographic, clon=0
-<71011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Desdemona Areocentric, clon=180
-<71012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Desdemona Areographic, clon=180
-<71013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areocentric, clon=0
-<71014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areographic, clon=0
-<71015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areocentric, clon=180
-<71016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Desdemona Areographic, clon=180
-<71017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Desdemona Areocentric, clon=0
-<71018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Desdemona Areographic, clon=0
-<71019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Desdemona Areocentric, clon=0
-<71020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Desdemona Areographic, clon=0
-<71021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areocentric, clon=0
-<71022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areographic, clon=0
-<71023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areocentric, clon=180
-<71024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Desdemona Areographic, clon=180
-<71025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areocentric, clon=0
-<71026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areographic, clon=0
-<71027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areocentric, clon=180
-<71028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Desdemona Areographic, clon=180
-<71029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Desdemona Areocentric
-<71060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Desdemona Areographic
-<71061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Desdemona Areocentric, clon=0
-<71062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Desdemona Areographic, clon=0
-<71063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Desdemona Areocentric
-<71064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Desdemona Areographic
-<71065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Desdemona Areocentric
-<71066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Desdemona Areographic
-<71067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Desdemona Areocentric
-<71068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Desdemona Areographic
-<71069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Desdemona Areocentric
-<71070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Desdemona Areographic
-<71071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Desdemona Areocentric
-<71072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Desdemona Areographic
-<71073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Desdemona Areocentric
-<71074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Desdemona Areographic
-<71075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Desdemona Areocentric
-<71076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Desdemona Areographic
-<71077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Desdemona Areocentric
-<71080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Desdemona Areographic
-<71081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Desdemona Areocentric
-<71082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Desdemona Areographic
-<71083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# GEOGCS Juliet Areocentric
-<71100> 	+proj=longlat +a=42000 +b=42000 +no_defs
-# GEOGCS Juliet Areographic
-<71101> 	+proj=longlat +a=42000 +b=42000 +no_defs
-# Equirectangular Juliet Areocentric, clon=0
-<71110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equirectangular Juliet Areographic, clon=0
-<71111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equirectangular Juliet Areocentric, clon=180
-<71112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equirectangular Juliet Areographic, clon=180
-<71113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areocentric, clon=0
-<71114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areographic, clon=0
-<71115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areocentric, clon=180
-<71116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal Juliet Areographic, clon=180
-<71117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# North Polar Juliet Areocentric, clon=0
-<71118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# North Polar Juliet Areographic, clon=0
-<71119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# South Polar Juliet Areocentric, clon=0
-<71120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# South Polar Juliet Areographic, clon=0
-<71121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areocentric, clon=0
-<71122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areographic, clon=0
-<71123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areocentric, clon=180
-<71124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide Juliet Areographic, clon=180
-<71125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areocentric, clon=0
-<71126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areographic, clon=0
-<71127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areocentric, clon=180
-<71128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson Juliet Areographic, clon=180
-<71129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal AUTO Juliet Areocentric
-<71160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Sinusoidal AUTO Juliet Areographic
-<71161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Stereographic AUTO Juliet Areocentric, clon=0
-<71162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Stereographic AUTO Juliet Areographic, clon=0
-<71163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Transverse Mercator AUTO Juliet Areocentric
-<71164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Transverse Mercator AUTO Juliet Areographic
-<71165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Orthographic AUTO Juliet Areocentric
-<71166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Orthographic AUTO Juliet Areographic
-<71167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Juliet Areocentric
-<71168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Juliet Areographic
-<71169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Juliet Areocentric
-<71170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Juliet Areographic
-<71171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Juliet Areocentric
-<71172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Juliet Areographic
-<71173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mercator AUTO Juliet Areocentric
-<71174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mercator AUTO Juliet Areographic
-<71175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Albers AUTO Juliet Areocentric
-<71176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Albers AUTO Juliet Areographic
-<71177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide AUTO Juliet Areocentric
-<71180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Mollweide AUTO Juliet Areographic
-<71181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson AUTO Juliet Areocentric
-<71182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# Robinson AUTO Juliet Areographic
-<71183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=42000 +b=42000 +units=m +no_defs
-# GEOGCS Portia Areocentric
-<71200> 	+proj=longlat +a=54000 +b=54000 +no_defs
-# GEOGCS Portia Areographic
-<71201> 	+proj=longlat +a=54000 +b=54000 +no_defs
-# Equirectangular Portia Areocentric, clon=0
-<71210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equirectangular Portia Areographic, clon=0
-<71211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equirectangular Portia Areocentric, clon=180
-<71212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equirectangular Portia Areographic, clon=180
-<71213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areocentric, clon=0
-<71214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areographic, clon=0
-<71215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areocentric, clon=180
-<71216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal Portia Areographic, clon=180
-<71217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# North Polar Portia Areocentric, clon=0
-<71218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# North Polar Portia Areographic, clon=0
-<71219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# South Polar Portia Areocentric, clon=0
-<71220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# South Polar Portia Areographic, clon=0
-<71221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areocentric, clon=0
-<71222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areographic, clon=0
-<71223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areocentric, clon=180
-<71224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide Portia Areographic, clon=180
-<71225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areocentric, clon=0
-<71226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areographic, clon=0
-<71227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areocentric, clon=180
-<71228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson Portia Areographic, clon=180
-<71229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal AUTO Portia Areocentric
-<71260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Sinusoidal AUTO Portia Areographic
-<71261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Stereographic AUTO Portia Areocentric, clon=0
-<71262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Stereographic AUTO Portia Areographic, clon=0
-<71263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Transverse Mercator AUTO Portia Areocentric
-<71264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Transverse Mercator AUTO Portia Areographic
-<71265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Orthographic AUTO Portia Areocentric
-<71266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Orthographic AUTO Portia Areographic
-<71267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Portia Areocentric
-<71268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Portia Areographic
-<71269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Portia Areocentric
-<71270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Portia Areographic
-<71271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Portia Areocentric
-<71272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Portia Areographic
-<71273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mercator AUTO Portia Areocentric
-<71274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mercator AUTO Portia Areographic
-<71275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Albers AUTO Portia Areocentric
-<71276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Albers AUTO Portia Areographic
-<71277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide AUTO Portia Areocentric
-<71280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Mollweide AUTO Portia Areographic
-<71281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson AUTO Portia Areocentric
-<71282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# Robinson AUTO Portia Areographic
-<71283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=54000 +b=54000 +units=m +no_defs
-# GEOGCS Rosalind Areocentric
-<71300> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# GEOGCS Rosalind Areographic
-<71301> 	+proj=longlat +a=27000 +b=27000 +no_defs
-# Equirectangular Rosalind Areocentric, clon=0
-<71310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Rosalind Areographic, clon=0
-<71311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Rosalind Areocentric, clon=180
-<71312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equirectangular Rosalind Areographic, clon=180
-<71313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areocentric, clon=0
-<71314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areographic, clon=0
-<71315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areocentric, clon=180
-<71316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal Rosalind Areographic, clon=180
-<71317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Rosalind Areocentric, clon=0
-<71318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# North Polar Rosalind Areographic, clon=0
-<71319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Rosalind Areocentric, clon=0
-<71320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# South Polar Rosalind Areographic, clon=0
-<71321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areocentric, clon=0
-<71322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areographic, clon=0
-<71323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areocentric, clon=180
-<71324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide Rosalind Areographic, clon=180
-<71325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areocentric, clon=0
-<71326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areographic, clon=0
-<71327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areocentric, clon=180
-<71328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson Rosalind Areographic, clon=180
-<71329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Rosalind Areocentric
-<71360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Sinusoidal AUTO Rosalind Areographic
-<71361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Rosalind Areocentric, clon=0
-<71362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Stereographic AUTO Rosalind Areographic, clon=0
-<71363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Rosalind Areocentric
-<71364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Transverse Mercator AUTO Rosalind Areographic
-<71365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Rosalind Areocentric
-<71366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Orthographic AUTO Rosalind Areographic
-<71367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rosalind Areocentric
-<71368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Rosalind Areographic
-<71369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rosalind Areocentric
-<71370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Rosalind Areographic
-<71371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rosalind Areocentric
-<71372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Rosalind Areographic
-<71373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Rosalind Areocentric
-<71374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mercator AUTO Rosalind Areographic
-<71375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Rosalind Areocentric
-<71376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Albers AUTO Rosalind Areographic
-<71377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Rosalind Areocentric
-<71380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Mollweide AUTO Rosalind Areographic
-<71381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Rosalind Areocentric
-<71382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# Robinson AUTO Rosalind Areographic
-<71383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=27000 +b=27000 +units=m +no_defs
-# GEOGCS Belinda Areocentric
-<71400> 	+proj=longlat +a=33000 +b=33000 +no_defs
-# GEOGCS Belinda Areographic
-<71401> 	+proj=longlat +a=33000 +b=33000 +no_defs
-# Equirectangular Belinda Areocentric, clon=0
-<71410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equirectangular Belinda Areographic, clon=0
-<71411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equirectangular Belinda Areocentric, clon=180
-<71412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equirectangular Belinda Areographic, clon=180
-<71413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areocentric, clon=0
-<71414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areographic, clon=0
-<71415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areocentric, clon=180
-<71416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal Belinda Areographic, clon=180
-<71417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# North Polar Belinda Areocentric, clon=0
-<71418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# North Polar Belinda Areographic, clon=0
-<71419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# South Polar Belinda Areocentric, clon=0
-<71420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# South Polar Belinda Areographic, clon=0
-<71421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areocentric, clon=0
-<71422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areographic, clon=0
-<71423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areocentric, clon=180
-<71424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide Belinda Areographic, clon=180
-<71425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areocentric, clon=0
-<71426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areographic, clon=0
-<71427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areocentric, clon=180
-<71428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson Belinda Areographic, clon=180
-<71429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal AUTO Belinda Areocentric
-<71460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Sinusoidal AUTO Belinda Areographic
-<71461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Stereographic AUTO Belinda Areocentric, clon=0
-<71462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Stereographic AUTO Belinda Areographic, clon=0
-<71463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Transverse Mercator AUTO Belinda Areocentric
-<71464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Transverse Mercator AUTO Belinda Areographic
-<71465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Orthographic AUTO Belinda Areocentric
-<71466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Orthographic AUTO Belinda Areographic
-<71467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Belinda Areocentric
-<71468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Belinda Areographic
-<71469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Belinda Areocentric
-<71470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Belinda Areographic
-<71471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Belinda Areocentric
-<71472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Belinda Areographic
-<71473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mercator AUTO Belinda Areocentric
-<71474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mercator AUTO Belinda Areographic
-<71475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Albers AUTO Belinda Areocentric
-<71476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Albers AUTO Belinda Areographic
-<71477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide AUTO Belinda Areocentric
-<71480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Mollweide AUTO Belinda Areographic
-<71481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson AUTO Belinda Areocentric
-<71482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# Robinson AUTO Belinda Areographic
-<71483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=33000 +b=33000 +units=m +no_defs
-# GEOGCS Puck Areocentric
-<71500> 	+proj=longlat +a=77000 +b=77000 +no_defs
-# GEOGCS Puck Areographic
-<71501> 	+proj=longlat +a=77000 +b=77000 +no_defs
-# Equirectangular Puck Areocentric, clon=0
-<71510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equirectangular Puck Areographic, clon=0
-<71511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equirectangular Puck Areocentric, clon=180
-<71512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equirectangular Puck Areographic, clon=180
-<71513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areocentric, clon=0
-<71514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areographic, clon=0
-<71515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areocentric, clon=180
-<71516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal Puck Areographic, clon=180
-<71517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# North Polar Puck Areocentric, clon=0
-<71518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# North Polar Puck Areographic, clon=0
-<71519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# South Polar Puck Areocentric, clon=0
-<71520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# South Polar Puck Areographic, clon=0
-<71521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areocentric, clon=0
-<71522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areographic, clon=0
-<71523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areocentric, clon=180
-<71524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide Puck Areographic, clon=180
-<71525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areocentric, clon=0
-<71526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areographic, clon=0
-<71527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areocentric, clon=180
-<71528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson Puck Areographic, clon=180
-<71529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal AUTO Puck Areocentric
-<71560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Sinusoidal AUTO Puck Areographic
-<71561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Stereographic AUTO Puck Areocentric, clon=0
-<71562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Stereographic AUTO Puck Areographic, clon=0
-<71563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Transverse Mercator AUTO Puck Areocentric
-<71564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Transverse Mercator AUTO Puck Areographic
-<71565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Orthographic AUTO Puck Areocentric
-<71566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Orthographic AUTO Puck Areographic
-<71567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Puck Areocentric
-<71568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Puck Areographic
-<71569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Puck Areocentric
-<71570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Puck Areographic
-<71571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Puck Areocentric
-<71572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Puck Areographic
-<71573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mercator AUTO Puck Areocentric
-<71574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mercator AUTO Puck Areographic
-<71575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Albers AUTO Puck Areocentric
-<71576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Albers AUTO Puck Areographic
-<71577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide AUTO Puck Areocentric
-<71580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Mollweide AUTO Puck Areographic
-<71581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson AUTO Puck Areocentric
-<71582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# Robinson AUTO Puck Areographic
-<71583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=77000 +b=77000 +units=m +no_defs
-# GEOGCS Neptune Areocentric
-<89900> 	+proj=longlat +a=24764000 +b=-1425034021.193139 +no_defs
-# GEOGCS Neptune Areographic
-<89901> 	+proj=longlat +a=24764000 +b=-1425034021.193139 +no_defs
-# Equirectangular Neptune Areocentric, clon=0
-<89910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equirectangular Neptune Areographic, clon=0
-<89911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equirectangular Neptune Areocentric, clon=180
-<89912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equirectangular Neptune Areographic, clon=180
-<89913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areocentric, clon=0
-<89914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areographic, clon=0
-<89915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areocentric, clon=180
-<89916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal Neptune Areographic, clon=180
-<89917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# North Polar Neptune Areocentric, clon=0
-<89918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# North Polar Neptune Areographic, clon=0
-<89919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# South Polar Neptune Areocentric, clon=0
-<89920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# South Polar Neptune Areographic, clon=0
-<89921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areocentric, clon=0
-<89922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areographic, clon=0
-<89923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areocentric, clon=180
-<89924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide Neptune Areographic, clon=180
-<89925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areocentric, clon=0
-<89926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areographic, clon=0
-<89927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areocentric, clon=180
-<89928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson Neptune Areographic, clon=180
-<89929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal AUTO Neptune Areocentric
-<89960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Sinusoidal AUTO Neptune Areographic
-<89961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Stereographic AUTO Neptune Areocentric, clon=0
-<89962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Stereographic AUTO Neptune Areographic, clon=0
-<89963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Transverse Mercator AUTO Neptune Areocentric
-<89964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Transverse Mercator AUTO Neptune Areographic
-<89965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Orthographic AUTO Neptune Areocentric
-<89966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Orthographic AUTO Neptune Areographic
-<89967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equidistant Cylindrical AUTO Neptune Areocentric
-<89968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Equidistant Cylindrical AUTO Neptune Areographic
-<89969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Conformal Conic AUTO Neptune Areocentric
-<89970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Conformal Conic AUTO Neptune Areographic
-<89971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Neptune Areocentric
-<89972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Neptune Areographic
-<89973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mercator AUTO Neptune Areocentric
-<89974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mercator AUTO Neptune Areographic
-<89975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Albers AUTO Neptune Areocentric
-<89976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Albers AUTO Neptune Areographic
-<89977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide AUTO Neptune Areocentric
-<89980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Mollweide AUTO Neptune Areographic
-<89981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson AUTO Neptune Areocentric
-<89982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# Robinson AUTO Neptune Areographic
-<89983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=-1425034021.193139 +units=m +no_defs
-# GEOGCS Triton Areocentric
-<80100> 	+proj=longlat +a=1352600 +b=1352600 +no_defs
-# GEOGCS Triton Areographic
-<80101> 	+proj=longlat +a=1352600 +b=1352600 +no_defs
-# Equirectangular Triton Areocentric, clon=0
-<80110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equirectangular Triton Areographic, clon=0
-<80111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equirectangular Triton Areocentric, clon=180
-<80112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equirectangular Triton Areographic, clon=180
-<80113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areocentric, clon=0
-<80114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areographic, clon=0
-<80115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areocentric, clon=180
-<80116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal Triton Areographic, clon=180
-<80117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# North Polar Triton Areocentric, clon=0
-<80118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# North Polar Triton Areographic, clon=0
-<80119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# South Polar Triton Areocentric, clon=0
-<80120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# South Polar Triton Areographic, clon=0
-<80121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areocentric, clon=0
-<80122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areographic, clon=0
-<80123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areocentric, clon=180
-<80124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide Triton Areographic, clon=180
-<80125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areocentric, clon=0
-<80126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areographic, clon=0
-<80127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areocentric, clon=180
-<80128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson Triton Areographic, clon=180
-<80129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal AUTO Triton Areocentric
-<80160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Sinusoidal AUTO Triton Areographic
-<80161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Stereographic AUTO Triton Areocentric, clon=0
-<80162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Stereographic AUTO Triton Areographic, clon=0
-<80163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Transverse Mercator AUTO Triton Areocentric
-<80164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Transverse Mercator AUTO Triton Areographic
-<80165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Orthographic AUTO Triton Areocentric
-<80166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Orthographic AUTO Triton Areographic
-<80167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Triton Areocentric
-<80168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Equidistant Cylindrical AUTO Triton Areographic
-<80169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Triton Areocentric
-<80170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Conformal Conic AUTO Triton Areographic
-<80171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Triton Areocentric
-<80172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Triton Areographic
-<80173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mercator AUTO Triton Areocentric
-<80174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mercator AUTO Triton Areographic
-<80175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Albers AUTO Triton Areocentric
-<80176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Albers AUTO Triton Areographic
-<80177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide AUTO Triton Areocentric
-<80180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Mollweide AUTO Triton Areographic
-<80181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson AUTO Triton Areocentric
-<80182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# Robinson AUTO Triton Areographic
-<80183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1352600 +b=1352600 +units=m +no_defs
-# GEOGCS Nereid Areocentric
-<80200> 	+proj=longlat +a=170000 +b=170000 +no_defs
-# GEOGCS Nereid Areographic
-<80201> 	+proj=longlat +a=170000 +b=170000 +no_defs
-# Equirectangular Nereid Areocentric, clon=0
-<80210> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equirectangular Nereid Areographic, clon=0
-<80211> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equirectangular Nereid Areocentric, clon=180
-<80212> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equirectangular Nereid Areographic, clon=180
-<80213> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areocentric, clon=0
-<80214> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areographic, clon=0
-<80215> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areocentric, clon=180
-<80216> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal Nereid Areographic, clon=180
-<80217> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# North Polar Nereid Areocentric, clon=0
-<80218> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# North Polar Nereid Areographic, clon=0
-<80219> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# South Polar Nereid Areocentric, clon=0
-<80220> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# South Polar Nereid Areographic, clon=0
-<80221> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areocentric, clon=0
-<80222> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areographic, clon=0
-<80223> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areocentric, clon=180
-<80224> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide Nereid Areographic, clon=180
-<80225> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areocentric, clon=0
-<80226> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areographic, clon=0
-<80227> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areocentric, clon=180
-<80228> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson Nereid Areographic, clon=180
-<80229> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal AUTO Nereid Areocentric
-<80260> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Sinusoidal AUTO Nereid Areographic
-<80261> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Stereographic AUTO Nereid Areocentric, clon=0
-<80262> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Stereographic AUTO Nereid Areographic, clon=0
-<80263> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Transverse Mercator AUTO Nereid Areocentric
-<80264> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Transverse Mercator AUTO Nereid Areographic
-<80265> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Orthographic AUTO Nereid Areocentric
-<80266> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Orthographic AUTO Nereid Areographic
-<80267> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Nereid Areocentric
-<80268> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Nereid Areographic
-<80269> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Nereid Areocentric
-<80270> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Nereid Areographic
-<80271> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Nereid Areocentric
-<80272> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Nereid Areographic
-<80273> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mercator AUTO Nereid Areocentric
-<80274> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mercator AUTO Nereid Areographic
-<80275> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Albers AUTO Nereid Areocentric
-<80276> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Albers AUTO Nereid Areographic
-<80277> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide AUTO Nereid Areocentric
-<80280> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Mollweide AUTO Nereid Areographic
-<80281> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson AUTO Nereid Areocentric
-<80282> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# Robinson AUTO Nereid Areographic
-<80283> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=170000 +b=170000 +units=m +no_defs
-# GEOGCS Naiad Areocentric
-<80300> 	+proj=longlat +a=29000 +b=29000 +no_defs
-# GEOGCS Naiad Areographic
-<80301> 	+proj=longlat +a=29000 +b=29000 +no_defs
-# Equirectangular Naiad Areocentric, clon=0
-<80310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equirectangular Naiad Areographic, clon=0
-<80311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equirectangular Naiad Areocentric, clon=180
-<80312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equirectangular Naiad Areographic, clon=180
-<80313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areocentric, clon=0
-<80314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areographic, clon=0
-<80315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areocentric, clon=180
-<80316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal Naiad Areographic, clon=180
-<80317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# North Polar Naiad Areocentric, clon=0
-<80318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# North Polar Naiad Areographic, clon=0
-<80319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# South Polar Naiad Areocentric, clon=0
-<80320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# South Polar Naiad Areographic, clon=0
-<80321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areocentric, clon=0
-<80322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areographic, clon=0
-<80323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areocentric, clon=180
-<80324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide Naiad Areographic, clon=180
-<80325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areocentric, clon=0
-<80326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areographic, clon=0
-<80327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areocentric, clon=180
-<80328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson Naiad Areographic, clon=180
-<80329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal AUTO Naiad Areocentric
-<80360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Sinusoidal AUTO Naiad Areographic
-<80361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Stereographic AUTO Naiad Areocentric, clon=0
-<80362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Stereographic AUTO Naiad Areographic, clon=0
-<80363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Transverse Mercator AUTO Naiad Areocentric
-<80364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Transverse Mercator AUTO Naiad Areographic
-<80365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Orthographic AUTO Naiad Areocentric
-<80366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Orthographic AUTO Naiad Areographic
-<80367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Naiad Areocentric
-<80368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Naiad Areographic
-<80369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Naiad Areocentric
-<80370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Naiad Areographic
-<80371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Naiad Areocentric
-<80372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Naiad Areographic
-<80373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mercator AUTO Naiad Areocentric
-<80374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mercator AUTO Naiad Areographic
-<80375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Albers AUTO Naiad Areocentric
-<80376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Albers AUTO Naiad Areographic
-<80377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide AUTO Naiad Areocentric
-<80380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Mollweide AUTO Naiad Areographic
-<80381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson AUTO Naiad Areocentric
-<80382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# Robinson AUTO Naiad Areographic
-<80383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=29000 +b=29000 +units=m +no_defs
-# GEOGCS Thalassa Areocentric
-<80400> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# GEOGCS Thalassa Areographic
-<80401> 	+proj=longlat +a=40000 +b=40000 +no_defs
-# Equirectangular Thalassa Areocentric, clon=0
-<80410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Thalassa Areographic, clon=0
-<80411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Thalassa Areocentric, clon=180
-<80412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equirectangular Thalassa Areographic, clon=180
-<80413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areocentric, clon=0
-<80414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areographic, clon=0
-<80415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areocentric, clon=180
-<80416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal Thalassa Areographic, clon=180
-<80417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Thalassa Areocentric, clon=0
-<80418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# North Polar Thalassa Areographic, clon=0
-<80419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Thalassa Areocentric, clon=0
-<80420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# South Polar Thalassa Areographic, clon=0
-<80421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areocentric, clon=0
-<80422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areographic, clon=0
-<80423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areocentric, clon=180
-<80424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide Thalassa Areographic, clon=180
-<80425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areocentric, clon=0
-<80426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areographic, clon=0
-<80427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areocentric, clon=180
-<80428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson Thalassa Areographic, clon=180
-<80429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Thalassa Areocentric
-<80460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Sinusoidal AUTO Thalassa Areographic
-<80461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Thalassa Areocentric, clon=0
-<80462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Stereographic AUTO Thalassa Areographic, clon=0
-<80463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Thalassa Areocentric
-<80464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Transverse Mercator AUTO Thalassa Areographic
-<80465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Thalassa Areocentric
-<80466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Orthographic AUTO Thalassa Areographic
-<80467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thalassa Areocentric
-<80468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Thalassa Areographic
-<80469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thalassa Areocentric
-<80470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Thalassa Areographic
-<80471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thalassa Areocentric
-<80472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Thalassa Areographic
-<80473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Thalassa Areocentric
-<80474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mercator AUTO Thalassa Areographic
-<80475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Thalassa Areocentric
-<80476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Albers AUTO Thalassa Areographic
-<80477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Thalassa Areocentric
-<80480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Mollweide AUTO Thalassa Areographic
-<80481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Thalassa Areocentric
-<80482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# Robinson AUTO Thalassa Areographic
-<80483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=40000 +b=40000 +units=m +no_defs
-# GEOGCS Despina Areocentric
-<80500> 	+proj=longlat +a=74000 +b=74000 +no_defs
-# GEOGCS Despina Areographic
-<80501> 	+proj=longlat +a=74000 +b=74000 +no_defs
-# Equirectangular Despina Areocentric, clon=0
-<80510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equirectangular Despina Areographic, clon=0
-<80511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equirectangular Despina Areocentric, clon=180
-<80512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equirectangular Despina Areographic, clon=180
-<80513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areocentric, clon=0
-<80514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areographic, clon=0
-<80515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areocentric, clon=180
-<80516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal Despina Areographic, clon=180
-<80517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# North Polar Despina Areocentric, clon=0
-<80518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# North Polar Despina Areographic, clon=0
-<80519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# South Polar Despina Areocentric, clon=0
-<80520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# South Polar Despina Areographic, clon=0
-<80521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areocentric, clon=0
-<80522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areographic, clon=0
-<80523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areocentric, clon=180
-<80524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide Despina Areographic, clon=180
-<80525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areocentric, clon=0
-<80526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areographic, clon=0
-<80527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areocentric, clon=180
-<80528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson Despina Areographic, clon=180
-<80529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal AUTO Despina Areocentric
-<80560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Sinusoidal AUTO Despina Areographic
-<80561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Stereographic AUTO Despina Areocentric, clon=0
-<80562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Stereographic AUTO Despina Areographic, clon=0
-<80563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Transverse Mercator AUTO Despina Areocentric
-<80564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Transverse Mercator AUTO Despina Areographic
-<80565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Orthographic AUTO Despina Areocentric
-<80566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Orthographic AUTO Despina Areographic
-<80567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Despina Areocentric
-<80568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Despina Areographic
-<80569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Despina Areocentric
-<80570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Despina Areographic
-<80571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Despina Areocentric
-<80572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Despina Areographic
-<80573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mercator AUTO Despina Areocentric
-<80574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mercator AUTO Despina Areographic
-<80575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Albers AUTO Despina Areocentric
-<80576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Albers AUTO Despina Areographic
-<80577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide AUTO Despina Areocentric
-<80580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Mollweide AUTO Despina Areographic
-<80581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson AUTO Despina Areocentric
-<80582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# Robinson AUTO Despina Areographic
-<80583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=74000 +b=74000 +units=m +no_defs
-# GEOGCS Galatea Areocentric
-<80600> 	+proj=longlat +a=79000 +b=79000 +no_defs
-# GEOGCS Galatea Areographic
-<80601> 	+proj=longlat +a=79000 +b=79000 +no_defs
-# Equirectangular Galatea Areocentric, clon=0
-<80610> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equirectangular Galatea Areographic, clon=0
-<80611> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equirectangular Galatea Areocentric, clon=180
-<80612> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equirectangular Galatea Areographic, clon=180
-<80613> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areocentric, clon=0
-<80614> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areographic, clon=0
-<80615> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areocentric, clon=180
-<80616> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal Galatea Areographic, clon=180
-<80617> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# North Polar Galatea Areocentric, clon=0
-<80618> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# North Polar Galatea Areographic, clon=0
-<80619> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# South Polar Galatea Areocentric, clon=0
-<80620> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# South Polar Galatea Areographic, clon=0
-<80621> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areocentric, clon=0
-<80622> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areographic, clon=0
-<80623> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areocentric, clon=180
-<80624> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide Galatea Areographic, clon=180
-<80625> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areocentric, clon=0
-<80626> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areographic, clon=0
-<80627> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areocentric, clon=180
-<80628> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson Galatea Areographic, clon=180
-<80629> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal AUTO Galatea Areocentric
-<80660> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Sinusoidal AUTO Galatea Areographic
-<80661> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Stereographic AUTO Galatea Areocentric, clon=0
-<80662> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Stereographic AUTO Galatea Areographic, clon=0
-<80663> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Transverse Mercator AUTO Galatea Areocentric
-<80664> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Transverse Mercator AUTO Galatea Areographic
-<80665> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Orthographic AUTO Galatea Areocentric
-<80666> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Orthographic AUTO Galatea Areographic
-<80667> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Galatea Areocentric
-<80668> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Galatea Areographic
-<80669> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Galatea Areocentric
-<80670> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Galatea Areographic
-<80671> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Galatea Areocentric
-<80672> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Galatea Areographic
-<80673> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mercator AUTO Galatea Areocentric
-<80674> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mercator AUTO Galatea Areographic
-<80675> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Albers AUTO Galatea Areocentric
-<80676> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Albers AUTO Galatea Areographic
-<80677> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide AUTO Galatea Areocentric
-<80680> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Mollweide AUTO Galatea Areographic
-<80681> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson AUTO Galatea Areocentric
-<80682> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# Robinson AUTO Galatea Areographic
-<80683> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=79000 +b=79000 +units=m +no_defs
-# GEOGCS Larissa Areocentric
-<80700> 	+proj=longlat +a=96000 +b=-1220565.409986697 +no_defs
-# GEOGCS Larissa Areographic
-<80701> 	+proj=longlat +a=96000 +b=-1220565.409986697 +no_defs
-# Equirectangular Larissa Areocentric, clon=0
-<80710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equirectangular Larissa Areographic, clon=0
-<80711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equirectangular Larissa Areocentric, clon=180
-<80712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equirectangular Larissa Areographic, clon=180
-<80713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areocentric, clon=0
-<80714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areographic, clon=0
-<80715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areocentric, clon=180
-<80716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal Larissa Areographic, clon=180
-<80717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# North Polar Larissa Areocentric, clon=0
-<80718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# North Polar Larissa Areographic, clon=0
-<80719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# South Polar Larissa Areocentric, clon=0
-<80720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# South Polar Larissa Areographic, clon=0
-<80721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areocentric, clon=0
-<80722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areographic, clon=0
-<80723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areocentric, clon=180
-<80724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide Larissa Areographic, clon=180
-<80725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areocentric, clon=0
-<80726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areographic, clon=0
-<80727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areocentric, clon=180
-<80728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson Larissa Areographic, clon=180
-<80729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal AUTO Larissa Areocentric
-<80760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Sinusoidal AUTO Larissa Areographic
-<80761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Stereographic AUTO Larissa Areocentric, clon=0
-<80762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Stereographic AUTO Larissa Areographic, clon=0
-<80763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Transverse Mercator AUTO Larissa Areocentric
-<80764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Transverse Mercator AUTO Larissa Areographic
-<80765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Orthographic AUTO Larissa Areocentric
-<80766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Orthographic AUTO Larissa Areographic
-<80767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equidistant Cylindrical AUTO Larissa Areocentric
-<80768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Equidistant Cylindrical AUTO Larissa Areographic
-<80769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Conformal Conic AUTO Larissa Areocentric
-<80770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Conformal Conic AUTO Larissa Areographic
-<80771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Larissa Areocentric
-<80772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Larissa Areographic
-<80773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mercator AUTO Larissa Areocentric
-<80774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mercator AUTO Larissa Areographic
-<80775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Albers AUTO Larissa Areocentric
-<80776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Albers AUTO Larissa Areographic
-<80777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide AUTO Larissa Areocentric
-<80780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Mollweide AUTO Larissa Areographic
-<80781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson AUTO Larissa Areocentric
-<80782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# Robinson AUTO Larissa Areographic
-<80783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=96000 +b=-1220565.409986697 +units=m +no_defs
-# GEOGCS Proteus Areocentric
-<80800> 	+proj=longlat +a=208000 +b=208000 +no_defs
-# GEOGCS Proteus Areographic
-<80801> 	+proj=longlat +a=208000 +b=208000 +no_defs
-# Equirectangular Proteus Areocentric, clon=0
-<80810> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equirectangular Proteus Areographic, clon=0
-<80811> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equirectangular Proteus Areocentric, clon=180
-<80812> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equirectangular Proteus Areographic, clon=180
-<80813> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areocentric, clon=0
-<80814> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areographic, clon=0
-<80815> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areocentric, clon=180
-<80816> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal Proteus Areographic, clon=180
-<80817> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# North Polar Proteus Areocentric, clon=0
-<80818> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# North Polar Proteus Areographic, clon=0
-<80819> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# South Polar Proteus Areocentric, clon=0
-<80820> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# South Polar Proteus Areographic, clon=0
-<80821> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areocentric, clon=0
-<80822> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areographic, clon=0
-<80823> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areocentric, clon=180
-<80824> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide Proteus Areographic, clon=180
-<80825> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areocentric, clon=0
-<80826> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areographic, clon=0
-<80827> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areocentric, clon=180
-<80828> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson Proteus Areographic, clon=180
-<80829> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal AUTO Proteus Areocentric
-<80860> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Sinusoidal AUTO Proteus Areographic
-<80861> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Stereographic AUTO Proteus Areocentric, clon=0
-<80862> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Stereographic AUTO Proteus Areographic, clon=0
-<80863> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Transverse Mercator AUTO Proteus Areocentric
-<80864> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Transverse Mercator AUTO Proteus Areographic
-<80865> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Orthographic AUTO Proteus Areocentric
-<80866> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Orthographic AUTO Proteus Areographic
-<80867> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Proteus Areocentric
-<80868> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Proteus Areographic
-<80869> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Proteus Areocentric
-<80870> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Proteus Areographic
-<80871> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Proteus Areocentric
-<80872> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Proteus Areographic
-<80873> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mercator AUTO Proteus Areocentric
-<80874> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mercator AUTO Proteus Areographic
-<80875> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Albers AUTO Proteus Areocentric
-<80876> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Albers AUTO Proteus Areographic
-<80877> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide AUTO Proteus Areocentric
-<80880> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Mollweide AUTO Proteus Areographic
-<80881> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson AUTO Proteus Areocentric
-<80882> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# Robinson AUTO Proteus Areographic
-<80883> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=208000 +b=208000 +units=m +no_defs
-# GEOGCS Pluto Areocentric
-<99900> 	+proj=longlat +a=1195000 +b=1195000 +no_defs
-# GEOGCS Pluto Areographic
-<99901> 	+proj=longlat +a=1195000 +b=1195000 +no_defs
-# Equirectangular Pluto Areocentric, clon=0
-<99910> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equirectangular Pluto Areographic, clon=0
-<99911> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equirectangular Pluto Areocentric, clon=180
-<99912> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equirectangular Pluto Areographic, clon=180
-<99913> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areocentric, clon=0
-<99914> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areographic, clon=0
-<99915> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areocentric, clon=180
-<99916> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal Pluto Areographic, clon=180
-<99917> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# North Polar Pluto Areocentric, clon=0
-<99918> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# North Polar Pluto Areographic, clon=0
-<99919> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# South Polar Pluto Areocentric, clon=0
-<99920> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# South Polar Pluto Areographic, clon=0
-<99921> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areocentric, clon=0
-<99922> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areographic, clon=0
-<99923> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areocentric, clon=180
-<99924> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide Pluto Areographic, clon=180
-<99925> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areocentric, clon=0
-<99926> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areographic, clon=0
-<99927> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areocentric, clon=180
-<99928> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson Pluto Areographic, clon=180
-<99929> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal AUTO Pluto Areocentric
-<99960> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Sinusoidal AUTO Pluto Areographic
-<99961> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Stereographic AUTO Pluto Areocentric, clon=0
-<99962> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Stereographic AUTO Pluto Areographic, clon=0
-<99963> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Transverse Mercator AUTO Pluto Areocentric
-<99964> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Transverse Mercator AUTO Pluto Areographic
-<99965> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Orthographic AUTO Pluto Areocentric
-<99966> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Orthographic AUTO Pluto Areographic
-<99967> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pluto Areocentric
-<99968> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Pluto Areographic
-<99969> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pluto Areocentric
-<99970> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Pluto Areographic
-<99971> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pluto Areocentric
-<99972> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Pluto Areographic
-<99973> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mercator AUTO Pluto Areocentric
-<99974> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mercator AUTO Pluto Areographic
-<99975> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Albers AUTO Pluto Areocentric
-<99976> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Albers AUTO Pluto Areographic
-<99977> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide AUTO Pluto Areocentric
-<99980> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Mollweide AUTO Pluto Areographic
-<99981> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson AUTO Pluto Areocentric
-<99982> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# Robinson AUTO Pluto Areographic
-<99983> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1195000 +b=1195000 +units=m +no_defs
-# GEOGCS Charon Areocentric
-<90100> 	+proj=longlat +a=605000 +b=605000 +no_defs
-# GEOGCS Charon Areographic
-<90101> 	+proj=longlat +a=605000 +b=605000 +no_defs
-# Equirectangular Charon Areocentric, clon=0
-<90110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Equirectangular Charon Areographic, clon=0
-<90111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Equirectangular Charon Areocentric, clon=180
-<90112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Equirectangular Charon Areographic, clon=180
-<90113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Sinusoidal Charon Areocentric, clon=0
-<90114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Sinusoidal Charon Areographic, clon=0
-<90115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Sinusoidal Charon Areocentric, clon=180
-<90116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Sinusoidal Charon Areographic, clon=180
-<90117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# North Polar Charon Areocentric, clon=0
-<90118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# North Polar Charon Areographic, clon=0
-<90119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# South Polar Charon Areocentric, clon=0
-<90120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# South Polar Charon Areographic, clon=0
-<90121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mollweide Charon Areocentric, clon=0
-<90122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mollweide Charon Areographic, clon=0
-<90123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mollweide Charon Areocentric, clon=180
-<90124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mollweide Charon Areographic, clon=180
-<90125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Robinson Charon Areocentric, clon=0
-<90126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Robinson Charon Areographic, clon=0
-<90127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Robinson Charon Areocentric, clon=180
-<90128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Robinson Charon Areographic, clon=180
-<90129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Sinusoidal AUTO Charon Areocentric
-<90160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Sinusoidal AUTO Charon Areographic
-<90161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Stereographic AUTO Charon Areocentric, clon=0
-<90162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Stereographic AUTO Charon Areographic, clon=0
-<90163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Transverse Mercator AUTO Charon Areocentric
-<90164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Transverse Mercator AUTO Charon Areographic
-<90165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Orthographic AUTO Charon Areocentric
-<90166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Orthographic AUTO Charon Areographic
-<90167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Charon Areocentric
-<90168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Charon Areographic
-<90169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Charon Areocentric
-<90170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Charon Areographic
-<90171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Charon Areocentric
-<90172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Charon Areographic
-<90173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mercator AUTO Charon Areocentric
-<90174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mercator AUTO Charon Areographic
-<90175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Albers AUTO Charon Areocentric
-<90176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Albers AUTO Charon Areographic
-<90177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mollweide AUTO Charon Areocentric
-<90180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Mollweide AUTO Charon Areographic
-<90181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Robinson AUTO Charon Areocentric
-<90182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# Robinson AUTO Charon Areographic
-<90183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=605000 +b=605000 +units=m +no_defs
-# GEOGCS Borrelly Areocentric
-<100000500> 	+proj=longlat +a=4220 +b=4220 +no_defs
-# GEOGCS Borrelly Areographic
-<100000501> 	+proj=longlat +a=4220 +b=4220 +no_defs
-# Equirectangular Borrelly Areocentric, clon=0
-<100000510> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Equirectangular Borrelly Areographic, clon=0
-<100000511> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Equirectangular Borrelly Areocentric, clon=180
-<100000512> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Equirectangular Borrelly Areographic, clon=180
-<100000513> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Sinusoidal Borrelly Areocentric, clon=0
-<100000514> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Sinusoidal Borrelly Areographic, clon=0
-<100000515> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Sinusoidal Borrelly Areocentric, clon=180
-<100000516> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Sinusoidal Borrelly Areographic, clon=180
-<100000517> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# North Polar Borrelly Areocentric, clon=0
-<100000518> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# North Polar Borrelly Areographic, clon=0
-<100000519> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# South Polar Borrelly Areocentric, clon=0
-<100000520> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# South Polar Borrelly Areographic, clon=0
-<100000521> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mollweide Borrelly Areocentric, clon=0
-<100000522> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mollweide Borrelly Areographic, clon=0
-<100000523> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mollweide Borrelly Areocentric, clon=180
-<100000524> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mollweide Borrelly Areographic, clon=180
-<100000525> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Robinson Borrelly Areocentric, clon=0
-<100000526> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Robinson Borrelly Areographic, clon=0
-<100000527> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Robinson Borrelly Areocentric, clon=180
-<100000528> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Robinson Borrelly Areographic, clon=180
-<100000529> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Sinusoidal AUTO Borrelly Areocentric
-<100000560> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Sinusoidal AUTO Borrelly Areographic
-<100000561> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Stereographic AUTO Borrelly Areocentric, clon=0
-<100000562> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Stereographic AUTO Borrelly Areographic, clon=0
-<100000563> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Transverse Mercator AUTO Borrelly Areocentric
-<100000564> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Transverse Mercator AUTO Borrelly Areographic
-<100000565> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Orthographic AUTO Borrelly Areocentric
-<100000566> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Orthographic AUTO Borrelly Areographic
-<100000567> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Equidistant Cylindrical AUTO Borrelly Areocentric
-<100000568> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Equidistant Cylindrical AUTO Borrelly Areographic
-<100000569> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Lambert Conformal Conic AUTO Borrelly Areocentric
-<100000570> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Lambert Conformal Conic AUTO Borrelly Areographic
-<100000571> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Borrelly Areocentric
-<100000572> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Borrelly Areographic
-<100000573> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mercator AUTO Borrelly Areocentric
-<100000574> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mercator AUTO Borrelly Areographic
-<100000575> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Albers AUTO Borrelly Areocentric
-<100000576> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Albers AUTO Borrelly Areographic
-<100000577> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mollweide AUTO Borrelly Areocentric
-<100000580> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Mollweide AUTO Borrelly Areographic
-<100000581> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Robinson AUTO Borrelly Areocentric
-<100000582> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# Robinson AUTO Borrelly Areographic
-<100000583> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=4220 +b=4220 +units=m +no_defs
-# GEOGCS Tempel 1 Areocentric
-<100009300> 	+proj=longlat +a=3000 +b=3000 +no_defs
-# GEOGCS Tempel 1 Areographic
-<100009301> 	+proj=longlat +a=3000 +b=3000 +no_defs
-# Equirectangular Tempel 1 Areocentric, clon=0
-<100009310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Equirectangular Tempel 1 Areographic, clon=0
-<100009311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Equirectangular Tempel 1 Areocentric, clon=180
-<100009312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Equirectangular Tempel 1 Areographic, clon=180
-<100009313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Sinusoidal Tempel 1 Areocentric, clon=0
-<100009314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Sinusoidal Tempel 1 Areographic, clon=0
-<100009315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Sinusoidal Tempel 1 Areocentric, clon=180
-<100009316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Sinusoidal Tempel 1 Areographic, clon=180
-<100009317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# North Polar Tempel 1 Areocentric, clon=0
-<100009318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# North Polar Tempel 1 Areographic, clon=0
-<100009319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# South Polar Tempel 1 Areocentric, clon=0
-<100009320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# South Polar Tempel 1 Areographic, clon=0
-<100009321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mollweide Tempel 1 Areocentric, clon=0
-<100009322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mollweide Tempel 1 Areographic, clon=0
-<100009323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mollweide Tempel 1 Areocentric, clon=180
-<100009324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mollweide Tempel 1 Areographic, clon=180
-<100009325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Robinson Tempel 1 Areocentric, clon=0
-<100009326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Robinson Tempel 1 Areographic, clon=0
-<100009327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Robinson Tempel 1 Areocentric, clon=180
-<100009328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Robinson Tempel 1 Areographic, clon=180
-<100009329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Sinusoidal AUTO Tempel 1 Areocentric
-<100009360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Sinusoidal AUTO Tempel 1 Areographic
-<100009361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Stereographic AUTO Tempel 1 Areocentric, clon=0
-<100009362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Stereographic AUTO Tempel 1 Areographic, clon=0
-<100009363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Transverse Mercator AUTO Tempel 1 Areocentric
-<100009364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Transverse Mercator AUTO Tempel 1 Areographic
-<100009365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Orthographic AUTO Tempel 1 Areocentric
-<100009366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Orthographic AUTO Tempel 1 Areographic
-<100009367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Tempel 1 Areocentric
-<100009368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Tempel 1 Areographic
-<100009369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Tempel 1 Areocentric
-<100009370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Tempel 1 Areographic
-<100009371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Tempel 1 Areocentric
-<100009372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Tempel 1 Areographic
-<100009373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mercator AUTO Tempel 1 Areocentric
-<100009374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mercator AUTO Tempel 1 Areographic
-<100009375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Albers AUTO Tempel 1 Areocentric
-<100009376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Albers AUTO Tempel 1 Areographic
-<100009377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mollweide AUTO Tempel 1 Areocentric
-<100009380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Mollweide AUTO Tempel 1 Areographic
-<100009381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Robinson AUTO Tempel 1 Areocentric
-<100009382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# Robinson AUTO Tempel 1 Areographic
-<100009383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=3000 +b=3000 +units=m +no_defs
-# GEOGCS Wild 2 Areocentric
-<100010700> 	+proj=longlat +a=1975 +b=1975 +no_defs
-# GEOGCS Wild 2 Areographic
-<100010701> 	+proj=longlat +a=1975 +b=1975 +no_defs
-# Equirectangular Wild 2 Areocentric, clon=0
-<100010710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Equirectangular Wild 2 Areographic, clon=0
-<100010711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Equirectangular Wild 2 Areocentric, clon=180
-<100010712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Equirectangular Wild 2 Areographic, clon=180
-<100010713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Sinusoidal Wild 2 Areocentric, clon=0
-<100010714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Sinusoidal Wild 2 Areographic, clon=0
-<100010715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Sinusoidal Wild 2 Areocentric, clon=180
-<100010716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Sinusoidal Wild 2 Areographic, clon=180
-<100010717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# North Polar Wild 2 Areocentric, clon=0
-<100010718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# North Polar Wild 2 Areographic, clon=0
-<100010719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# South Polar Wild 2 Areocentric, clon=0
-<100010720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# South Polar Wild 2 Areographic, clon=0
-<100010721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mollweide Wild 2 Areocentric, clon=0
-<100010722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mollweide Wild 2 Areographic, clon=0
-<100010723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mollweide Wild 2 Areocentric, clon=180
-<100010724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mollweide Wild 2 Areographic, clon=180
-<100010725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Robinson Wild 2 Areocentric, clon=0
-<100010726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Robinson Wild 2 Areographic, clon=0
-<100010727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Robinson Wild 2 Areocentric, clon=180
-<100010728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Robinson Wild 2 Areographic, clon=180
-<100010729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Sinusoidal AUTO Wild 2 Areocentric
-<100010760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Sinusoidal AUTO Wild 2 Areographic
-<100010761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Stereographic AUTO Wild 2 Areocentric, clon=0
-<100010762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Stereographic AUTO Wild 2 Areographic, clon=0
-<100010763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Transverse Mercator AUTO Wild 2 Areocentric
-<100010764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Transverse Mercator AUTO Wild 2 Areographic
-<100010765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Orthographic AUTO Wild 2 Areocentric
-<100010766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Orthographic AUTO Wild 2 Areographic
-<100010767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Equidistant Cylindrical AUTO Wild 2 Areocentric
-<100010768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Equidistant Cylindrical AUTO Wild 2 Areographic
-<100010769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Lambert Conformal Conic AUTO Wild 2 Areocentric
-<100010770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Lambert Conformal Conic AUTO Wild 2 Areographic
-<100010771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Wild 2 Areocentric
-<100010772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Wild 2 Areographic
-<100010773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mercator AUTO Wild 2 Areocentric
-<100010774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mercator AUTO Wild 2 Areographic
-<100010775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Albers AUTO Wild 2 Areocentric
-<100010776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Albers AUTO Wild 2 Areographic
-<100010777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mollweide AUTO Wild 2 Areocentric
-<100010780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Mollweide AUTO Wild 2 Areographic
-<100010781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Robinson AUTO Wild 2 Areocentric
-<100010782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# Robinson AUTO Wild 2 Areographic
-<100010783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=1975 +b=1975 +units=m +no_defs
-# GEOGCS Gaspra Areocentric
-<951101000> 	+proj=longlat +a=6100 +b=6100 +no_defs
-# GEOGCS Gaspra Areographic
-<951101001> 	+proj=longlat +a=6100 +b=6100 +no_defs
-# Equirectangular Gaspra Areocentric, clon=0
-<951101010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equirectangular Gaspra Areographic, clon=0
-<951101011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equirectangular Gaspra Areocentric, clon=180
-<951101012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equirectangular Gaspra Areographic, clon=180
-<951101013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areocentric, clon=0
-<951101014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areographic, clon=0
-<951101015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areocentric, clon=180
-<951101016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal Gaspra Areographic, clon=180
-<951101017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# North Polar Gaspra Areocentric, clon=0
-<951101018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# North Polar Gaspra Areographic, clon=0
-<951101019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# South Polar Gaspra Areocentric, clon=0
-<951101020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# South Polar Gaspra Areographic, clon=0
-<951101021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areocentric, clon=0
-<951101022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areographic, clon=0
-<951101023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areocentric, clon=180
-<951101024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide Gaspra Areographic, clon=180
-<951101025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areocentric, clon=0
-<951101026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areographic, clon=0
-<951101027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areocentric, clon=180
-<951101028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson Gaspra Areographic, clon=180
-<951101029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal AUTO Gaspra Areocentric
-<951101060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Sinusoidal AUTO Gaspra Areographic
-<951101061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Stereographic AUTO Gaspra Areocentric, clon=0
-<951101062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Stereographic AUTO Gaspra Areographic, clon=0
-<951101063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Transverse Mercator AUTO Gaspra Areocentric
-<951101064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Transverse Mercator AUTO Gaspra Areographic
-<951101065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Orthographic AUTO Gaspra Areocentric
-<951101066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Orthographic AUTO Gaspra Areographic
-<951101067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Gaspra Areocentric
-<951101068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Equidistant Cylindrical AUTO Gaspra Areographic
-<951101069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Gaspra Areocentric
-<951101070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Conformal Conic AUTO Gaspra Areographic
-<951101071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Gaspra Areocentric
-<951101072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Gaspra Areographic
-<951101073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mercator AUTO Gaspra Areocentric
-<951101074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mercator AUTO Gaspra Areographic
-<951101075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Albers AUTO Gaspra Areocentric
-<951101076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Albers AUTO Gaspra Areographic
-<951101077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide AUTO Gaspra Areocentric
-<951101080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Mollweide AUTO Gaspra Areographic
-<951101081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson AUTO Gaspra Areocentric
-<951101082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# Robinson AUTO Gaspra Areographic
-<951101083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=6100 +b=6100 +units=m +no_defs
-# GEOGCS Ida Areocentric
-<243101000> 	+proj=longlat +a=15650 +b=15650 +no_defs
-# GEOGCS Ida Areographic
-<243101001> 	+proj=longlat +a=15650 +b=15650 +no_defs
-# Equirectangular Ida Areocentric, clon=0
-<243101010> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equirectangular Ida Areographic, clon=0
-<243101011> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equirectangular Ida Areocentric, clon=180
-<243101012> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equirectangular Ida Areographic, clon=180
-<243101013> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areocentric, clon=0
-<243101014> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areographic, clon=0
-<243101015> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areocentric, clon=180
-<243101016> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal Ida Areographic, clon=180
-<243101017> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# North Polar Ida Areocentric, clon=0
-<243101018> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# North Polar Ida Areographic, clon=0
-<243101019> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# South Polar Ida Areocentric, clon=0
-<243101020> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# South Polar Ida Areographic, clon=0
-<243101021> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areocentric, clon=0
-<243101022> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areographic, clon=0
-<243101023> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areocentric, clon=180
-<243101024> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide Ida Areographic, clon=180
-<243101025> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areocentric, clon=0
-<243101026> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areographic, clon=0
-<243101027> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areocentric, clon=180
-<243101028> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson Ida Areographic, clon=180
-<243101029> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal AUTO Ida Areocentric
-<243101060> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Sinusoidal AUTO Ida Areographic
-<243101061> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Stereographic AUTO Ida Areocentric, clon=0
-<243101062> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Stereographic AUTO Ida Areographic, clon=0
-<243101063> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Transverse Mercator AUTO Ida Areocentric
-<243101064> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Transverse Mercator AUTO Ida Areographic
-<243101065> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Orthographic AUTO Ida Areocentric
-<243101066> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Orthographic AUTO Ida Areographic
-<243101067> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ida Areocentric
-<243101068> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ida Areographic
-<243101069> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ida Areocentric
-<243101070> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ida Areographic
-<243101071> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ida Areocentric
-<243101072> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ida Areographic
-<243101073> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mercator AUTO Ida Areocentric
-<243101074> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mercator AUTO Ida Areographic
-<243101075> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Albers AUTO Ida Areocentric
-<243101076> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Albers AUTO Ida Areographic
-<243101077> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide AUTO Ida Areocentric
-<243101080> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Mollweide AUTO Ida Areographic
-<243101081> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson AUTO Ida Areocentric
-<243101082> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# Robinson AUTO Ida Areographic
-<243101083> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=15650 +b=15650 +units=m +no_defs
-# GEOGCS Ceres Areocentric
-<200000100> 	+proj=longlat +a=487300 +b=-6796814.859713897 +no_defs
-# GEOGCS Ceres Areographic
-<200000101> 	+proj=longlat +a=487300 +b=-6796814.859713897 +no_defs
-# Equirectangular Ceres Areocentric, clon=0
-<200000110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equirectangular Ceres Areographic, clon=0
-<200000111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equirectangular Ceres Areocentric, clon=180
-<200000112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equirectangular Ceres Areographic, clon=180
-<200000113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areocentric, clon=0
-<200000114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areographic, clon=0
-<200000115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areocentric, clon=180
-<200000116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal Ceres Areographic, clon=180
-<200000117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# North Polar Ceres Areocentric, clon=0
-<200000118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# North Polar Ceres Areographic, clon=0
-<200000119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# South Polar Ceres Areocentric, clon=0
-<200000120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# South Polar Ceres Areographic, clon=0
-<200000121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areocentric, clon=0
-<200000122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areographic, clon=0
-<200000123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areocentric, clon=180
-<200000124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide Ceres Areographic, clon=180
-<200000125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areocentric, clon=0
-<200000126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areographic, clon=0
-<200000127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areocentric, clon=180
-<200000128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson Ceres Areographic, clon=180
-<200000129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal AUTO Ceres Areocentric
-<200000160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Sinusoidal AUTO Ceres Areographic
-<200000161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Stereographic AUTO Ceres Areocentric, clon=0
-<200000162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Stereographic AUTO Ceres Areographic, clon=0
-<200000163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Transverse Mercator AUTO Ceres Areocentric
-<200000164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Transverse Mercator AUTO Ceres Areographic
-<200000165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Orthographic AUTO Ceres Areocentric
-<200000166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Orthographic AUTO Ceres Areographic
-<200000167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ceres Areocentric
-<200000168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Equidistant Cylindrical AUTO Ceres Areographic
-<200000169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ceres Areocentric
-<200000170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Conformal Conic AUTO Ceres Areographic
-<200000171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ceres Areocentric
-<200000172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Ceres Areographic
-<200000173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mercator AUTO Ceres Areocentric
-<200000174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mercator AUTO Ceres Areographic
-<200000175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Albers AUTO Ceres Areocentric
-<200000176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Albers AUTO Ceres Areographic
-<200000177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide AUTO Ceres Areocentric
-<200000180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Mollweide AUTO Ceres Areographic
-<200000181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson AUTO Ceres Areocentric
-<200000182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# Robinson AUTO Ceres Areographic
-<200000183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=487300 +b=-6796814.859713897 +units=m +no_defs
-# GEOGCS Vesta Areocentric
-<200000400> 	+proj=longlat +a=255000 +b=255000 +no_defs
-# GEOGCS Vesta Areographic
-<200000401> 	+proj=longlat +a=255000 +b=255000 +no_defs
-# Equirectangular Vesta Areocentric, clon=0
-<200000410> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Equirectangular Vesta Areographic, clon=0
-<200000411> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Equirectangular Vesta Areocentric, clon=180
-<200000412> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Equirectangular Vesta Areographic, clon=180
-<200000413> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Sinusoidal Vesta Areocentric, clon=0
-<200000414> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Sinusoidal Vesta Areographic, clon=0
-<200000415> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Sinusoidal Vesta Areocentric, clon=180
-<200000416> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Sinusoidal Vesta Areographic, clon=180
-<200000417> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# North Polar Vesta Areocentric, clon=0
-<200000418> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# North Polar Vesta Areographic, clon=0
-<200000419> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# South Polar Vesta Areocentric, clon=0
-<200000420> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# South Polar Vesta Areographic, clon=0
-<200000421> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mollweide Vesta Areocentric, clon=0
-<200000422> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mollweide Vesta Areographic, clon=0
-<200000423> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mollweide Vesta Areocentric, clon=180
-<200000424> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mollweide Vesta Areographic, clon=180
-<200000425> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Robinson Vesta Areocentric, clon=0
-<200000426> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Robinson Vesta Areographic, clon=0
-<200000427> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Robinson Vesta Areocentric, clon=180
-<200000428> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Robinson Vesta Areographic, clon=180
-<200000429> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Sinusoidal AUTO Vesta Areocentric
-<200000460> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Sinusoidal AUTO Vesta Areographic
-<200000461> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Stereographic AUTO Vesta Areocentric, clon=0
-<200000462> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Stereographic AUTO Vesta Areographic, clon=0
-<200000463> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Transverse Mercator AUTO Vesta Areocentric
-<200000464> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Transverse Mercator AUTO Vesta Areographic
-<200000465> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Orthographic AUTO Vesta Areocentric
-<200000466> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Orthographic AUTO Vesta Areographic
-<200000467> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Vesta Areocentric
-<200000468> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Vesta Areographic
-<200000469> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Vesta Areocentric
-<200000470> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Vesta Areographic
-<200000471> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Vesta Areocentric
-<200000472> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Vesta Areographic
-<200000473> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mercator AUTO Vesta Areocentric
-<200000474> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mercator AUTO Vesta Areographic
-<200000475> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Albers AUTO Vesta Areocentric
-<200000476> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Albers AUTO Vesta Areographic
-<200000477> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mollweide AUTO Vesta Areocentric
-<200000480> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Mollweide AUTO Vesta Areographic
-<200000481> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Robinson AUTO Vesta Areocentric
-<200000482> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# Robinson AUTO Vesta Areographic
-<200000483> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=255000 +b=255000 +units=m +no_defs
-# GEOGCS Lutetia Areocentric
-<200002100> 	+proj=longlat +a=52500 +b=52500 +no_defs
-# GEOGCS Lutetia Areographic
-<200002101> 	+proj=longlat +a=52500 +b=52500 +no_defs
-# Equirectangular Lutetia Areocentric, clon=0
-<200002110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equirectangular Lutetia Areographic, clon=0
-<200002111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equirectangular Lutetia Areocentric, clon=180
-<200002112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equirectangular Lutetia Areographic, clon=180
-<200002113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areocentric, clon=0
-<200002114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areographic, clon=0
-<200002115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areocentric, clon=180
-<200002116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal Lutetia Areographic, clon=180
-<200002117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# North Polar Lutetia Areocentric, clon=0
-<200002118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# North Polar Lutetia Areographic, clon=0
-<200002119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# South Polar Lutetia Areocentric, clon=0
-<200002120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# South Polar Lutetia Areographic, clon=0
-<200002121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areocentric, clon=0
-<200002122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areographic, clon=0
-<200002123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areocentric, clon=180
-<200002124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide Lutetia Areographic, clon=180
-<200002125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areocentric, clon=0
-<200002126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areographic, clon=0
-<200002127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areocentric, clon=180
-<200002128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson Lutetia Areographic, clon=180
-<200002129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal AUTO Lutetia Areocentric
-<200002160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Sinusoidal AUTO Lutetia Areographic
-<200002161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Stereographic AUTO Lutetia Areocentric, clon=0
-<200002162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Stereographic AUTO Lutetia Areographic, clon=0
-<200002163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Transverse Mercator AUTO Lutetia Areocentric
-<200002164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Transverse Mercator AUTO Lutetia Areographic
-<200002165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Orthographic AUTO Lutetia Areocentric
-<200002166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Orthographic AUTO Lutetia Areographic
-<200002167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lutetia Areocentric
-<200002168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Lutetia Areographic
-<200002169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lutetia Areocentric
-<200002170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Lutetia Areographic
-<200002171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lutetia Areocentric
-<200002172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Lutetia Areographic
-<200002173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mercator AUTO Lutetia Areocentric
-<200002174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mercator AUTO Lutetia Areographic
-<200002175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Albers AUTO Lutetia Areocentric
-<200002176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Albers AUTO Lutetia Areographic
-<200002177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide AUTO Lutetia Areocentric
-<200002180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Mollweide AUTO Lutetia Areographic
-<200002181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson AUTO Lutetia Areocentric
-<200002182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# Robinson AUTO Lutetia Areographic
-<200002183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=52500 +b=52500 +units=m +no_defs
-# GEOGCS Eros Areocentric
-<200043300> 	+proj=longlat +a=8450 +b=8450 +no_defs
-# GEOGCS Eros Areographic
-<200043301> 	+proj=longlat +a=8450 +b=8450 +no_defs
-# Equirectangular Eros Areocentric, clon=0
-<200043310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Equirectangular Eros Areographic, clon=0
-<200043311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Equirectangular Eros Areocentric, clon=180
-<200043312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Equirectangular Eros Areographic, clon=180
-<200043313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Sinusoidal Eros Areocentric, clon=0
-<200043314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Sinusoidal Eros Areographic, clon=0
-<200043315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Sinusoidal Eros Areocentric, clon=180
-<200043316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Sinusoidal Eros Areographic, clon=180
-<200043317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# North Polar Eros Areocentric, clon=0
-<200043318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# North Polar Eros Areographic, clon=0
-<200043319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# South Polar Eros Areocentric, clon=0
-<200043320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# South Polar Eros Areographic, clon=0
-<200043321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mollweide Eros Areocentric, clon=0
-<200043322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mollweide Eros Areographic, clon=0
-<200043323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mollweide Eros Areocentric, clon=180
-<200043324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mollweide Eros Areographic, clon=180
-<200043325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Robinson Eros Areocentric, clon=0
-<200043326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Robinson Eros Areographic, clon=0
-<200043327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Robinson Eros Areocentric, clon=180
-<200043328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Robinson Eros Areographic, clon=180
-<200043329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Sinusoidal AUTO Eros Areocentric
-<200043360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Sinusoidal AUTO Eros Areographic
-<200043361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Stereographic AUTO Eros Areocentric, clon=0
-<200043362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Stereographic AUTO Eros Areographic, clon=0
-<200043363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Transverse Mercator AUTO Eros Areocentric
-<200043364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Transverse Mercator AUTO Eros Areographic
-<200043365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Orthographic AUTO Eros Areocentric
-<200043366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Orthographic AUTO Eros Areographic
-<200043367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Equidistant Cylindrical AUTO Eros Areocentric
-<200043368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Equidistant Cylindrical AUTO Eros Areographic
-<200043369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Lambert Conformal Conic AUTO Eros Areocentric
-<200043370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Lambert Conformal Conic AUTO Eros Areographic
-<200043371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Eros Areocentric
-<200043372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Eros Areographic
-<200043373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mercator AUTO Eros Areocentric
-<200043374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mercator AUTO Eros Areographic
-<200043375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Albers AUTO Eros Areocentric
-<200043376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Albers AUTO Eros Areographic
-<200043377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mollweide AUTO Eros Areocentric
-<200043380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Mollweide AUTO Eros Areographic
-<200043381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Robinson AUTO Eros Areocentric
-<200043382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# Robinson AUTO Eros Areographic
-<200043383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=8450 +b=8450 +units=m +no_defs
-# GEOGCS Davida Areocentric
-<200051100> 	+proj=longlat +a=150000 +b=150000 +no_defs
-# GEOGCS Davida Areographic
-<200051101> 	+proj=longlat +a=150000 +b=150000 +no_defs
-# Equirectangular Davida Areocentric, clon=0
-<200051110> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Equirectangular Davida Areographic, clon=0
-<200051111> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Equirectangular Davida Areocentric, clon=180
-<200051112> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Equirectangular Davida Areographic, clon=180
-<200051113> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Sinusoidal Davida Areocentric, clon=0
-<200051114> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Sinusoidal Davida Areographic, clon=0
-<200051115> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Sinusoidal Davida Areocentric, clon=180
-<200051116> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Sinusoidal Davida Areographic, clon=180
-<200051117> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# North Polar Davida Areocentric, clon=0
-<200051118> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# North Polar Davida Areographic, clon=0
-<200051119> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# South Polar Davida Areocentric, clon=0
-<200051120> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# South Polar Davida Areographic, clon=0
-<200051121> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mollweide Davida Areocentric, clon=0
-<200051122> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mollweide Davida Areographic, clon=0
-<200051123> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mollweide Davida Areocentric, clon=180
-<200051124> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mollweide Davida Areographic, clon=180
-<200051125> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Robinson Davida Areocentric, clon=0
-<200051126> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Robinson Davida Areographic, clon=0
-<200051127> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Robinson Davida Areocentric, clon=180
-<200051128> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Robinson Davida Areographic, clon=180
-<200051129> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Sinusoidal AUTO Davida Areocentric
-<200051160> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Sinusoidal AUTO Davida Areographic
-<200051161> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Stereographic AUTO Davida Areocentric, clon=0
-<200051162> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Stereographic AUTO Davida Areographic, clon=0
-<200051163> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Transverse Mercator AUTO Davida Areocentric
-<200051164> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Transverse Mercator AUTO Davida Areographic
-<200051165> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Orthographic AUTO Davida Areocentric
-<200051166> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Orthographic AUTO Davida Areographic
-<200051167> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Davida Areocentric
-<200051168> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Equidistant Cylindrical AUTO Davida Areographic
-<200051169> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Davida Areocentric
-<200051170> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Lambert Conformal Conic AUTO Davida Areographic
-<200051171> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Davida Areocentric
-<200051172> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Davida Areographic
-<200051173> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mercator AUTO Davida Areocentric
-<200051174> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mercator AUTO Davida Areographic
-<200051175> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Albers AUTO Davida Areocentric
-<200051176> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Albers AUTO Davida Areographic
-<200051177> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mollweide AUTO Davida Areocentric
-<200051180> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Mollweide AUTO Davida Areographic
-<200051181> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Robinson AUTO Davida Areocentric
-<200051182> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# Robinson AUTO Davida Areographic
-<200051183> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=150000 +b=150000 +units=m +no_defs
-# GEOGCS Mathilde Areocentric
-<200025300> 	+proj=longlat +a=26500 +b=26500 +no_defs
-# GEOGCS Mathilde Areographic
-<200025301> 	+proj=longlat +a=26500 +b=26500 +no_defs
-# Equirectangular Mathilde Areocentric, clon=0
-<200025310> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Equirectangular Mathilde Areographic, clon=0
-<200025311> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Equirectangular Mathilde Areocentric, clon=180
-<200025312> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Equirectangular Mathilde Areographic, clon=180
-<200025313> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Sinusoidal Mathilde Areocentric, clon=0
-<200025314> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Sinusoidal Mathilde Areographic, clon=0
-<200025315> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Sinusoidal Mathilde Areocentric, clon=180
-<200025316> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Sinusoidal Mathilde Areographic, clon=180
-<200025317> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# North Polar Mathilde Areocentric, clon=0
-<200025318> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# North Polar Mathilde Areographic, clon=0
-<200025319> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# South Polar Mathilde Areocentric, clon=0
-<200025320> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# South Polar Mathilde Areographic, clon=0
-<200025321> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mollweide Mathilde Areocentric, clon=0
-<200025322> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mollweide Mathilde Areographic, clon=0
-<200025323> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mollweide Mathilde Areocentric, clon=180
-<200025324> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mollweide Mathilde Areographic, clon=180
-<200025325> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Robinson Mathilde Areocentric, clon=0
-<200025326> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Robinson Mathilde Areographic, clon=0
-<200025327> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Robinson Mathilde Areocentric, clon=180
-<200025328> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Robinson Mathilde Areographic, clon=180
-<200025329> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Sinusoidal AUTO Mathilde Areocentric
-<200025360> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Sinusoidal AUTO Mathilde Areographic
-<200025361> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Stereographic AUTO Mathilde Areocentric, clon=0
-<200025362> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Stereographic AUTO Mathilde Areographic, clon=0
-<200025363> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Transverse Mercator AUTO Mathilde Areocentric
-<200025364> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Transverse Mercator AUTO Mathilde Areographic
-<200025365> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Orthographic AUTO Mathilde Areocentric
-<200025366> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Orthographic AUTO Mathilde Areographic
-<200025367> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mathilde Areocentric
-<200025368> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Equidistant Cylindrical AUTO Mathilde Areographic
-<200025369> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mathilde Areocentric
-<200025370> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Lambert Conformal Conic AUTO Mathilde Areographic
-<200025371> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mathilde Areocentric
-<200025372> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Mathilde Areographic
-<200025373> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mercator AUTO Mathilde Areocentric
-<200025374> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mercator AUTO Mathilde Areographic
-<200025375> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Albers AUTO Mathilde Areocentric
-<200025376> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Albers AUTO Mathilde Areographic
-<200025377> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mollweide AUTO Mathilde Areocentric
-<200025380> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Mollweide AUTO Mathilde Areographic
-<200025381> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Robinson AUTO Mathilde Areocentric
-<200025382> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# Robinson AUTO Mathilde Areographic
-<200025383> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=26500 +b=26500 +units=m +no_defs
-# GEOGCS Steins Areocentric
-<200286700> 	+proj=longlat +a=2700 +b=2700 +no_defs
-# GEOGCS Steins Areographic
-<200286701> 	+proj=longlat +a=2700 +b=2700 +no_defs
-# Equirectangular Steins Areocentric, clon=0
-<200286710> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Equirectangular Steins Areographic, clon=0
-<200286711> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Equirectangular Steins Areocentric, clon=180
-<200286712> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Equirectangular Steins Areographic, clon=180
-<200286713> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=180 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Sinusoidal Steins Areocentric, clon=0
-<200286714> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Sinusoidal Steins Areographic, clon=0
-<200286715> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Sinusoidal Steins Areocentric, clon=180
-<200286716> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Sinusoidal Steins Areographic, clon=180
-<200286717> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# North Polar Steins Areocentric, clon=0
-<200286718> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# North Polar Steins Areographic, clon=0
-<200286719> 	+proj=stere +lat_0=90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# South Polar Steins Areocentric, clon=0
-<200286720> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# South Polar Steins Areographic, clon=0
-<200286721> 	+proj=stere +lat_0=-90 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mollweide Steins Areocentric, clon=0
-<200286722> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mollweide Steins Areographic, clon=0
-<200286723> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mollweide Steins Areocentric, clon=180
-<200286724> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mollweide Steins Areographic, clon=180
-<200286725> 	+proj=moll +lon_0=180 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Robinson Steins Areocentric, clon=0
-<200286726> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Robinson Steins Areographic, clon=0
-<200286727> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Robinson Steins Areocentric, clon=180
-<200286728> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Robinson Steins Areographic, clon=180
-<200286729> 	+proj=robin +lon_0=180 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Sinusoidal AUTO Steins Areocentric
-<200286760> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Sinusoidal AUTO Steins Areographic
-<200286761> 	+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Stereographic AUTO Steins Areocentric, clon=0
-<200286762> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Stereographic AUTO Steins Areographic, clon=0
-<200286763> 	+proj=stere +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Transverse Mercator AUTO Steins Areocentric
-<200286764> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Transverse Mercator AUTO Steins Areographic
-<200286765> 	+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Orthographic AUTO Steins Areocentric
-<200286766> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Orthographic AUTO Steins Areographic
-<200286767> 	+proj=ortho +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Steins Areocentric
-<200286768> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Equidistant Cylindrical AUTO Steins Areographic
-<200286769> 	+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Steins Areocentric
-<200286770> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Lambert Conformal Conic AUTO Steins Areographic
-<200286771> 	+proj=lcc +lat_1=-20 +lat_2=20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Steins Areocentric
-<200286772> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Lambert Azimuthal Equal Area AUTO Steins Areographic
-<200286773> 	+proj=laea +lat_0=90 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mercator AUTO Steins Areocentric
-<200286774> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mercator AUTO Steins Areographic
-<200286775> 	+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Albers AUTO Steins Areocentric
-<200286776> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Albers AUTO Steins Areographic
-<200286777> 	+proj=aea +lat_1=20 +lat_2=-20 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mollweide AUTO Steins Areocentric
-<200286780> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Mollweide AUTO Steins Areographic
-<200286781> 	+proj=moll +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Robinson AUTO Steins Areocentric
-<200286782> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
-# Robinson AUTO Steins Areographic
-<200286783> 	+proj=robin +lon_0=0 +x_0=0 +y_0=0 +a=2700 +b=2700 +units=m +no_defs
Deleted: grass/trunk/lib/proj/pcs.csv
--- grass/trunk/lib/proj/pcs.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/pcs.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,3356 +0,0 @@
-"COORD_REF_SYS_CODE","COORD_REF_SYS_NAME","UOM_CODE","SOURCE_GEOGCRS_CODE","COORD_OP_CODE","COORD_OP_METHOD_CODE","SHOW_CRS","DEPRECATED","COORD_SYS_CODE","PARAMETER_CODE_1","PARAMETER_VALUE_1","PARAMETER_UOM_1","PARAMETER_CODE_2","PARAMETER_VALUE_2","PARAMETER_UOM_2","PARAMETER_CODE_3","PARAMETER_VALUE_3","PARAMETER_UOM_3","PARAMETER_CODE_4","PARAMETER_VALUE_4","PARAMETER_UOM_4","PARAMETER_CODE_5","PARAMETER_VALUE_5","PARAMETER_UOM_5","PARAMETER_CODE_6","PARAMETER_VALUE_6","PARAMETER_UOM_6","PARAMETER_CODE_7","PARAMETER_VALUE_7","PARAMETER_UOM_7"
-2000,"Anguilla 1957 / British West Indies Grid",9001,4600,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2001,"Antigua 1943 / British West Indies Grid",9001,4601,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2002,"Dominica 1945 / British West Indies Grid",9001,4602,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2003,"Grenada 1953 / British West Indies Grid",9001,4603,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2004,"Montserrat 1958 / British West Indies Grid",9001,4604,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2005,"St. Kitts 1955 / British West Indies Grid",9001,4605,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2006,"St. Lucia 1955 / British West Indies Grid",9001,4606,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2007,"St. Vincent 45 / British West Indies Grid",9001,4607,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2008,"NAD27(CGQ77) / SCoPQ zone 2",9001,4609,17700,9807,1,0,4499,8801,0,9110,8802,-55.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2009,"NAD27(CGQ77) / SCoPQ zone 3",9001,4609,17703,9807,1,0,4499,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2010,"NAD27(CGQ77) / SCoPQ zone 4",9001,4609,17704,9807,1,0,4499,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2011,"NAD27(CGQ77) / SCoPQ zone 5",9001,4609,17705,9807,1,0,4499,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2012,"NAD27(CGQ77) / SCoPQ zone 6",9001,4609,17706,9807,1,0,4499,8801,0,9110,8802,-67.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2013,"NAD27(CGQ77) / SCoPQ zone 7",9001,4609,17707,9807,1,0,4499,8801,0,9110,8802,-70.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2014,"NAD27(CGQ77) / SCoPQ zone 8",9001,4609,17708,9807,1,0,4499,8801,0,9110,8802,-73.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2015,"NAD27(CGQ77) / SCoPQ zone 9",9001,4609,17709,9807,1,0,4499,8801,0,9110,8802,-76.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2016,"NAD27(CGQ77) / SCoPQ zone 10",9001,4609,17710,9807,1,0,4499,8801,0,9110,8802,-79.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2017,"NAD27(76) / MTM zone 8",9001,4608,17708,9807,1,0,4499,8801,0,9110,8802,-73.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2018,"NAD27(76) / MTM zone 9",9001,4608,17709,9807,1,0,4499,8801,0,9110,8802,-76.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2019,"NAD27(76) / MTM zone 10",9001,4608,17710,9807,1,0,4499,8801,0,9110,8802,-79.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2020,"NAD27(76) / MTM zone 11",9001,4608,17711,9807,1,0,4400,8801,0,9110,8802,-82.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2021,"NAD27(76) / MTM zone 12",9001,4608,17712,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2022,"NAD27(76) / MTM zone 13",9001,4608,17713,9807,1,0,4400,8801,0,9102,8802,-84,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2023,"NAD27(76) / MTM zone 14",9001,4608,17714,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2024,"NAD27(76) / MTM zone 15",9001,4608,17715,9807,1,0,4400,8801,0,9102,8802,-90,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2025,"NAD27(76) / MTM zone 16",9001,4608,17716,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2026,"NAD27(76) / MTM zone 17",9001,4608,17717,9807,1,0,4400,8801,0,9102,8802,-96,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2027,"NAD27(76) / UTM zone 15N",9001,4608,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2028,"NAD27(76) / UTM zone 16N",9001,4608,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2029,"NAD27(76) / UTM zone 17N",9001,4608,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2030,"NAD27(76) / UTM zone 18N",9001,4608,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2031,"NAD27(CGQ77) / UTM zone 17N",9001,4609,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2032,"NAD27(CGQ77) / UTM zone 18N",9001,4609,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2033,"NAD27(CGQ77) / UTM zone 19N",9001,4609,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2034,"NAD27(CGQ77) / UTM zone 20N",9001,4609,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2035,"NAD27(CGQ77) / UTM zone 21N",9001,4609,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2036,"NAD83(CSRS98) / New Brunswick Stereo",9001,4140,19946,9809,1,1,4500,8801,46.3,9110,8802,-66.3,9110,8805,0.999912,9201,8806,2500000,9001,8807,7500000,9001,,,,,,
-2037,"NAD83(CSRS98) / UTM zone 19N",9001,4140,16019,9807,1,1,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2038,"NAD83(CSRS98) / UTM zone 20N",9001,4140,16020,9807,1,1,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2039,"Israel / Israeli TM Grid",9001,4141,18204,9807,1,0,4400,8801,31.4403817,9110,8802,35.1216261,9110,8805,1.0000067,9201,8806,219529.584,9001,8807,626907.39,9001,,,,,,
-2040,"Locodjo 1965 / UTM zone 30N",9001,4142,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2041,"Abidjan 1987 / UTM zone 30N",9001,4143,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2042,"Locodjo 1965 / UTM zone 29N",9001,4142,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2043,"Abidjan 1987 / UTM zone 29N",9001,4143,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2044,"Hanoi 1972 / Gauss-Kruger zone 18",9001,4147,16218,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-2045,"Hanoi 1972 / Gauss-Kruger zone 19",9001,4147,16219,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-2046,"Hartebeesthoek94 / Lo15",9001,4148,17515,9808,1,0,6503,8801,0,9102,8802,15,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2047,"Hartebeesthoek94 / Lo17",9001,4148,17517,9808,1,0,6503,8801,0,9102,8802,17,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2048,"Hartebeesthoek94 / Lo19",9001,4148,17519,9808,1,0,6503,8801,0,9102,8802,19,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2049,"Hartebeesthoek94 / Lo21",9001,4148,17521,9808,1,0,6503,8801,0,9102,8802,21,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2050,"Hartebeesthoek94 / Lo23",9001,4148,17523,9808,1,0,6503,8801,0,9102,8802,23,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2051,"Hartebeesthoek94 / Lo25",9001,4148,17525,9808,1,0,6503,8801,0,9102,8802,25,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2052,"Hartebeesthoek94 / Lo27",9001,4148,17527,9808,1,0,6503,8801,0,9102,8802,27,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2053,"Hartebeesthoek94 / Lo29",9001,4148,17529,9808,1,0,6503,8801,0,9102,8802,29,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2054,"Hartebeesthoek94 / Lo31",9001,4148,17531,9808,1,0,6503,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2055,"Hartebeesthoek94 / Lo33",9001,4148,17533,9808,1,0,6503,8801,0,9102,8802,33,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2056,"CH1903+ / LV95",9001,4150,19950,9815,1,0,4498,8811,46.570866,9110,8812,7.26225,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,2600000,9001,8817,1200000,9001
-2057,"Rassadiran / Nakhl e Taqi",9001,4153,19951,9815,1,0,4400,8811,27.31077837,9110,8812,52.3612741,9110,8813,0.34179803,9110,8814,0.34179803,9110,8815,0.999895934,9201,8816,658377.437,9001,8817,3044969.194,9001
-2058,"ED50(ED77) / UTM zone 38N",9001,4154,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2059,"ED50(ED77) / UTM zone 39N",9001,4154,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2060,"ED50(ED77) / UTM zone 40N",9001,4154,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2061,"ED50(ED77) / UTM zone 41N",9001,4154,16041,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2062,"Madrid 1870 (Madrid) / Spain",9001,4903,19921,9801,1,0,4499,8801,40,9102,8802,0,9102,8805,0.9988085293,9201,8806,600000,9001,8807,600000,9001,,,,,,
-2063,"Dabola 1981 / UTM zone 28N",9001,4315,16028,9807,1,1,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2064,"Dabola 1981 / UTM zone 29N",9001,4315,16029,9807,1,1,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2065,"S-JTSK (Ferro) / Krovak",9001,4818,19952,9819,1,0,6501,8806,0,9001,8807,0,9001,8811,49.3,9110,8813,30.1717303,9110,8818,78.3,9110,8819,0.9999,9201,8833,42.3,9110
-2066,"Mount Dillon / Tobago Grid",9039,4157,19924,9806,1,0,4407,8801,11.1507843,9110,8802,-60.4109632,9110,8806,187500,9039,8807,180000,9039,,,,,,,,,
-2067,"Naparima 1955 / UTM zone 20N",9001,4158,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2068,"ELD79 / Libya zone 5",9001,4159,18240,9807,1,0,4499,8801,0,9102,8802,9,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2069,"ELD79 / Libya zone 6",9001,4159,18241,9807,1,0,4499,8801,0,9102,8802,11,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2070,"ELD79 / Libya zone 7",9001,4159,18242,9807,1,0,4499,8801,0,9102,8802,13,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2071,"ELD79 / Libya zone 8",9001,4159,18243,9807,1,0,4499,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2072,"ELD79 / Libya zone 9",9001,4159,18244,9807,1,0,4499,8801,0,9102,8802,17,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2073,"ELD79 / Libya zone 10",9001,4159,18245,9807,1,0,4499,8801,0,9102,8802,19,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2074,"ELD79 / Libya zone 11",9001,4159,18246,9807,1,0,4499,8801,0,9102,8802,21,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2075,"ELD79 / Libya zone 12",9001,4159,18247,9807,1,0,4499,8801,0,9102,8802,23,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2076,"ELD79 / Libya zone 13",9001,4159,18248,9807,1,0,4499,8801,0,9102,8802,25,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2077,"ELD79 / UTM zone 32N",9001,4159,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2078,"ELD79 / UTM zone 33N",9001,4159,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2079,"ELD79 / UTM zone 34N",9001,4159,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2080,"ELD79 / UTM zone 35N",9001,4159,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2081,"Chos Malal 1914 / Argentina zone 2",9001,4160,18032,9807,1,0,4530,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-2082,"Pampa del Castillo / Argentina zone 2",9001,4161,18032,9807,1,0,4530,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-2083,"Hito XVIII 1963 / Argentina zone 2",9001,4254,18032,9807,1,0,4530,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-2084,"Hito XVIII 1963 / UTM zone 19S",9001,4254,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2085,"NAD27 / Cuba Norte",9001,4267,18061,9801,1,1,4532,8801,22.21,9110,8802,-81,9110,8805,0.99993602,9201,8806,500000,9001,8807,280296.016,9001,,,,,,
-2086,"NAD27 / Cuba Sur",9001,4267,18062,9801,1,1,4532,8801,20.43,9110,8802,-76.5,9110,8805,0.99994848,9201,8806,500000,9001,8807,229126.939,9001,,,,,,
-2087,"ELD79 / TM 12 NE",9001,4159,16412,9807,1,0,4400,8801,0,9102,8802,12,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2088,"Carthage / TM 11 NE",9001,4223,16411,9807,1,0,4400,8801,0,9102,8802,11,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2089,"Yemen NGN96 / UTM zone 38N",9001,4163,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2090,"Yemen NGN96 / UTM zone 39N",9001,4163,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2091,"South Yemen / Gauss Kruger zone 8",9001,4164,16208,9807,1,1,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-2092,"South Yemen / Gauss Kruger zone 9",9001,4164,16209,9807,1,1,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-2093,"Hanoi 1972 / GK 106 NE",9001,4147,16586,9807,1,0,4530,8801,0,9102,8802,106,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2094,"WGS 72BE / TM 106 NE",9001,4324,16506,9807,1,0,4400,8801,0,9102,8802,106,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2095,"Bissau / UTM zone 28N",9001,4165,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2096,"Korean 1985 / Korea East Belt",9001,4162,18251,9807,1,0,4530,8801,38,9102,8802,129,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-2097,"Korean 1985 / Korea Central Belt",9001,4162,18252,9807,1,0,4530,8801,38,9102,8802,127,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-2098,"Korean 1985 / Korea West Belt",9001,4162,18253,9807,1,0,4530,8801,38,9102,8802,125,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-2099,"Qatar 1948 / Qatar Grid",9001,4286,19953,9806,1,0,4400,8801,25.22565,9110,8802,50.4541,9110,8806,100000,9001,8807,100000,9001,,,,,,,,,
-2100,"GGRS87 / Greek Grid",9001,4121,19930,9807,1,0,4400,8801,0,9102,8802,24,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2101,"Lake / Maracaibo Grid M1",9001,4249,18260,9801,1,0,4499,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,0,9001,8807,-52684.972,9001,,,,,,
-2102,"Lake / Maracaibo Grid",9001,4249,18261,9801,1,0,4499,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,200000,9001,8807,147315.028,9001,,,,,,
-2103,"Lake / Maracaibo Grid M3",9001,4249,18262,9801,1,0,4499,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,500000,9001,8807,447315.028,9001,,,,,,
-2104,"Lake / Maracaibo La Rosa Grid",9001,4249,18263,9801,1,0,4499,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,-17044,9001,8807,-23139.97,9001,,,,,,
-2105,"NZGD2000 / Mount Eden 2000",9001,4167,17931,9807,1,0,4500,8801,-36.5247,9110,8802,174.4551,9110,8805,0.9999,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2106,"NZGD2000 / Bay of Plenty 2000",9001,4167,17932,9807,1,0,4500,8801,-37.454,9110,8802,176.2758,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2107,"NZGD2000 / Poverty Bay 2000",9001,4167,17933,9807,1,0,4500,8801,-38.3728,9110,8802,177.5308,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2108,"NZGD2000 / Hawkes Bay 2000",9001,4167,17934,9807,1,0,4500,8801,-39.3903,9110,8802,176.4025,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2109,"NZGD2000 / Taranaki 2000",9001,4167,17935,9807,1,0,4500,8801,-39.0808,9110,8802,174.134,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2110,"NZGD2000 / Tuhirangi 2000",9001,4167,17936,9807,1,0,4500,8801,-39.3044,9110,8802,175.3824,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2111,"NZGD2000 / Wanganui 2000",9001,4167,17937,9807,1,0,4500,8801,-40.1431,9110,8802,175.2917,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2112,"NZGD2000 / Wairarapa 2000",9001,4167,17938,9807,1,0,4500,8801,-40.5531,9110,8802,175.385,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2113,"NZGD2000 / Wellington 2000",9001,4167,17939,9807,1,0,4500,8801,-41.1804,9110,8802,174.4635,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2114,"NZGD2000 / Collingwood 2000",9001,4167,17940,9807,1,0,4500,8801,-40.4253,9110,8802,172.4019,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2115,"NZGD2000 / Nelson 2000",9001,4167,17941,9807,1,0,4500,8801,-41.1628,9110,8802,173.1757,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2116,"NZGD2000 / Karamea 2000",9001,4167,17942,9807,1,0,4500,8801,-41.1723,9110,8802,172.0632,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2117,"NZGD2000 / Buller 2000",9001,4167,17943,9807,1,0,4500,8801,-41.4838,9110,8802,171.3452,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2118,"NZGD2000 / Grey 2000",9001,4167,17944,9807,1,0,4500,8801,-42.2001,9110,8802,171.3259,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2119,"NZGD2000 / Amuri 2000",9001,4167,17945,9807,1,0,4500,8801,-42.412,9110,8802,173.0036,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2120,"NZGD2000 / Marlborough 2000",9001,4167,17946,9807,1,0,4500,8801,-41.324,9110,8802,173.4807,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2121,"NZGD2000 / Hokitika 2000",9001,4167,17947,9807,1,0,4500,8801,-42.531,9110,8802,170.5847,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2122,"NZGD2000 / Okarito 2000",9001,4167,17948,9807,1,0,4500,8801,-43.0636,9110,8802,170.1539,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2123,"NZGD2000 / Jacksons Bay 2000",9001,4167,17949,9807,1,0,4500,8801,-43.584,9110,8802,168.3622,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2124,"NZGD2000 / Mount Pleasant 2000",9001,4167,17950,9807,1,0,4500,8801,-43.3526,9110,8802,172.4337,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2125,"NZGD2000 / Gawler 2000",9001,4167,17951,9807,1,0,4500,8801,-43.4455,9110,8802,171.2138,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2126,"NZGD2000 / Timaru 2000",9001,4167,17952,9807,1,0,4500,8801,-44.2407,9110,8802,171.0326,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2127,"NZGD2000 / Lindis Peak 2000",9001,4167,17953,9807,1,0,4500,8801,-44.4406,9110,8802,169.2803,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2128,"NZGD2000 / Mount Nicholas 2000",9001,4167,17954,9807,1,0,4500,8801,-45.0758,9110,8802,168.2355,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2129,"NZGD2000 / Mount York 2000",9001,4167,17955,9807,1,0,4500,8801,-45.3349,9110,8802,167.4419,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2130,"NZGD2000 / Observation Point 2000",9001,4167,17956,9807,1,0,4500,8801,-45.4858,9110,8802,170.3742,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2131,"NZGD2000 / North Taieri 2000",9001,4167,17957,9807,1,0,4500,8801,-45.5141,9110,8802,170.1657,9110,8805,0.99996,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2132,"NZGD2000 / Bluff 2000",9001,4167,17958,9807,1,0,4500,8801,-46.36,9110,8802,168.2034,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2133,"NZGD2000 / UTM zone 58S",9001,4167,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2134,"NZGD2000 / UTM zone 59S",9001,4167,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2135,"NZGD2000 / UTM zone 60S",9001,4167,16160,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2136,"Accra / Ghana National Grid",9094,4168,19959,9807,1,0,4404,8801,4.4,9110,8802,-1,9110,8805,0.99975,9201,8806,900000,9094,8807,0,9094,,,,,,
-2137,"Accra / TM 1 NW",9001,4168,17001,9807,1,0,4400,8801,0,9102,8802,-1,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2138,"NAD27(CGQ77) / Quebec Lambert",9001,4609,19944,9802,1,0,4499,8821,44,9110,8822,-68.3,9110,8823,60,9110,8824,46,9110,8826,0,9001,8827,0,9001,,,
-2139,"NAD83(CSRS98) / SCoPQ zone 2",9001,4140,17700,9807,1,1,4499,8801,0,9110,8802,-55.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2140,"NAD83(CSRS98) / MTM zone 3",9001,4140,17703,9807,1,1,4496,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2141,"NAD83(CSRS98) / MTM zone 4",9001,4140,17704,9807,1,1,4496,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2142,"NAD83(CSRS98) / MTM zone 5",9001,4140,17705,9807,1,1,4496,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2143,"NAD83(CSRS98) / MTM zone 6",9001,4140,17706,9807,1,1,4496,8801,0,9110,8802,-67.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2144,"NAD83(CSRS98) / MTM zone 7",9001,4140,17707,9807,1,1,4496,8801,0,9110,8802,-70.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2145,"NAD83(CSRS98) / MTM zone 8",9001,4140,17708,9807,1,1,4496,8801,0,9110,8802,-73.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2146,"NAD83(CSRS98) / MTM zone 9",9001,4140,17709,9807,1,1,4496,8801,0,9110,8802,-76.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2147,"NAD83(CSRS98) / MTM zone 10",9001,4140,17710,9807,1,1,4496,8801,0,9110,8802,-79.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2148,"NAD83(CSRS98) / UTM zone 21N",9001,4140,16021,9807,1,1,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2149,"NAD83(CSRS98) / UTM zone 18N",9001,4140,16018,9807,1,1,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2150,"NAD83(CSRS98) / UTM zone 17N",9001,4140,16017,9807,1,1,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2151,"NAD83(CSRS98) / UTM zone 13N",9001,4140,16013,9807,1,1,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2152,"NAD83(CSRS98) / UTM zone 12N",9001,4140,16012,9807,1,1,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2153,"NAD83(CSRS98) / UTM zone 11N",9001,4140,16011,9807,1,1,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2154,"RGF93 / Lambert-93",9001,4171,18085,9802,1,0,4499,8821,46.3,9110,8822,3,9110,8823,49,9110,8824,44,9110,8826,700000,9001,8827,6600000,9001,,,
-2155,"American Samoa 1962 / American Samoa Lambert",9003,4169,15300,9801,1,1,4497,8801,-14.16,9110,8802,170,9110,8805,1,9201,8806,500000,9003,8807,0,9003,,,,,,
-2156,"NAD83(HARN) / UTM zone 59S",9001,4152,16159,9807,1,1,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2157,"IRENET95 / Irish Transverse Mercator",9001,4173,19962,9807,1,0,4400,8801,53.3,9110,8802,-8,9110,8805,0.99982,9201,8806,600000,9001,8807,750000,9001,,,,,,
-2158,"IRENET95 / UTM zone 29N",9001,4173,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2159,"Sierra Leone 1924 / New Colony Grid",9094,4174,19963,9807,1,0,4404,8801,6.4,9110,8802,-12,9110,8805,1,9201,8806,500000,9094,8807,0,9094,,,,,,
-2160,"Sierra Leone 1924 / New War Office Grid",9094,4174,19964,9807,1,0,4404,8801,6.4,9110,8802,-12,9110,8805,1,9201,8806,800000,9094,8807,600000,9094,,,,,,
-2161,"Sierra Leone 1968 / UTM zone 28N",9001,4175,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2162,"Sierra Leone 1968 / UTM zone 29N",9001,4175,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2163,US National Atlas Equal Area,9001,4052,3899,1027,1,0,4499,8801,45,9102,8802,-100,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-2164,"Locodjo 1965 / TM 5 NW",9001,4142,17005,9807,1,0,4400,8801,0,9102,8802,-5,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2165,"Abidjan 1987 / TM 5 NW",9001,4143,17005,9807,1,0,4400,8801,0,9102,8802,-5,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2166,"Pulkovo 1942(83) / Gauss Kruger zone 3",9001,4178,16263,9807,1,1,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-2167,"Pulkovo 1942(83) / Gauss Kruger zone 4",9001,4178,16264,9807,1,1,4530,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-2168,"Pulkovo 1942(83) / Gauss Kruger zone 5",9001,4178,16265,9807,1,1,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-2169,"Luxembourg 1930 / Gauss",9001,4181,19966,9807,1,0,4530,8801,49.5,9110,8802,6.1,9110,8805,1,9201,8806,80000,9001,8807,100000,9001,,,,,,
-2170,"MGI / Slovenia Grid",9001,4312,19967,9807,1,1,4530,8801,0,9110,8802,15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-2171,"Pulkovo 1942(58) / Poland zone I",9001,4179,18281,9809,1,1,4530,8801,50.373,9110,8802,21.05,9110,8805,0.9998,9201,8806,4637000,9001,8807,5647000,9001,,,,,,
-2172,"Pulkovo 1942(58) / Poland zone II",9001,4179,18282,9809,1,0,4530,8801,53.0007,9110,8802,21.301,9110,8805,0.9998,9201,8806,4603000,9001,8807,5806000,9001,,,,,,
-2173,"Pulkovo 1942(58) / Poland zone III",9001,4179,18283,9809,1,0,4530,8801,53.35,9110,8802,17.003,9110,8805,0.9998,9201,8806,3501000,9001,8807,5999000,9001,,,,,,
-2174,"Pulkovo 1942(58) / Poland zone IV",9001,4179,18284,9809,1,0,4530,8801,51.4015,9110,8802,16.402,9110,8805,0.9998,9201,8806,3703000,9001,8807,5627000,9001,,,,,,
-2175,"Pulkovo 1942(58) / Poland zone V",9001,4179,18285,9807,1,0,4530,8801,0,9110,8802,18.573,9110,8805,0.999983,9201,8806,237000,9001,8807,-4700000,9001,,,,,,
-2176,"ETRS89 / Poland CS2000 zone 5",9001,4258,18305,9807,1,0,4531,8801,0,9102,8802,15,9102,8805,0.999923,9201,8806,5500000,9001,8807,0,9001,,,,,,
-2177,"ETRS89 / Poland CS2000 zone 6",9001,4258,18306,9807,1,0,4531,8801,0,9102,8802,18,9102,8805,0.999923,9201,8806,6500000,9001,8807,0,9001,,,,,,
-2178,"ETRS89 / Poland CS2000 zone 7",9001,4258,18307,9807,1,0,4531,8801,0,9102,8802,21,9102,8805,0.999923,9201,8806,7500000,9001,8807,0,9001,,,,,,
-2179,"ETRS89 / Poland CS2000 zone 8",9001,4258,18308,9807,1,0,4531,8801,0,9102,8802,24,9102,8805,0.999923,9201,8806,8500000,9001,8807,0,9001,,,,,,
-2180,"ETRS89 / Poland CS92",9001,4258,18300,9807,1,0,4531,8801,0,9102,8802,19,9102,8805,0.9993,9201,8806,500000,9001,8807,-5300000,9001,,,,,,
-2188,"Azores Occidental 1939 / UTM zone 25N",9001,4182,16025,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2189,"Azores Central 1948 / UTM zone 26N",9001,4183,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2190,"Azores Oriental 1940 / UTM zone 26N",9001,4184,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2191,"Madeira 1936 / UTM zone 28N",9001,4185,16028,9807,1,1,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2192,"ED50 / France EuroLambert",9001,4230,18086,9801,1,0,4499,8801,46.48,9110,8802,2.2014025,9110,8805,0.99987742,9201,8806,600000,9001,8807,2200000,9001,,,,,,
-2193,"NZGD2000 / New Zealand Transverse Mercator 2000",9001,4167,19971,9807,1,0,4500,8801,0,9102,8802,173,9102,8805,0.9996,9201,8806,1600000,9001,8807,10000000,9001,,,,,,
-2194,"American Samoa 1962 / American Samoa Lambert",9003,4169,15301,9801,1,1,4497,8801,-14.16,9110,8802,-170,9110,8805,1,9201,8806,500000,9003,8807,0,9003,,,,,,
-2195,"NAD83(HARN) / UTM zone 2S",9001,4152,16102,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2196,"ETRS89 / Kp2000 Jutland",9001,4258,18401,9807,1,0,4400,8801,0,9110,8802,9.3,9110,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-2197,"ETRS89 / Kp2000 Zealand",9001,4258,18402,9807,1,0,4400,8801,0,9102,8802,12,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-2198,"ETRS89 / Kp2000 Bornholm",9001,4258,18403,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,1,9201,8806,900000,9001,8807,0,9001,,,,,,
-2199,"Albanian 1987 / Gauss Kruger zone 4",9001,4191,16204,9807,1,1,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-2200,"ATS77 / New Brunswick Stereographic (ATS77)",9001,4122,19945,9809,1,0,4500,8801,46.3,9110,8802,-66.3,9110,8805,0.999912,9201,8806,300000,9001,8807,800000,9001,,,,,,
-2201,"REGVEN / UTM zone 18N",9001,4189,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2202,"REGVEN / UTM zone 19N",9001,4189,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2203,"REGVEN / UTM zone 20N",9001,4189,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2204,"NAD27 / Tennessee",9003,4267,15302,9802,1,0,4497,8821,34.4,9110,8822,-86,9110,8823,35.15,9110,8824,36.25,9110,8826,2000000,9003,8827,100000,9003,,,
-2205,"NAD83 / Kentucky North",9001,4269,15303,9802,1,0,4499,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,500000,9001,8827,0,9001,,,
-2206,"ED50 / 3-degree Gauss-Kruger zone 9",9001,4230,16269,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-2207,"ED50 / 3-degree Gauss-Kruger zone 10",9001,4230,16270,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-2208,"ED50 / 3-degree Gauss-Kruger zone 11",9001,4230,16271,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-2209,"ED50 / 3-degree Gauss-Kruger zone 12",9001,4230,16272,9807,1,0,4530,8801,0,9102,8802,36,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-2210,"ED50 / 3-degree Gauss-Kruger zone 13",9001,4230,16273,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-2211,"ED50 / 3-degree Gauss-Kruger zone 14",9001,4230,16274,9807,1,0,4530,8801,0,9102,8802,42,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-2212,"ED50 / 3-degree Gauss-Kruger zone 15",9001,4230,16275,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-2213,"ETRS89 / TM 30 NE",9001,4258,16430,9807,1,0,4400,8801,0,9102,8802,30,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2214,"Douala 1948 / AOF west",9001,4192,18415,9807,1,1,4400,8801,0,9110,8802,10.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-2215,"Manoca 1962 / UTM zone 32N",9001,4193,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2216,"Qornoq 1927 / UTM zone 22N",9001,4194,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2217,"Qornoq 1927 / UTM zone 23N",9001,4194,16023,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2218,"Scoresbysund 1952 / Greenland zone 5 east",9001,4195,18425,9826,1,0,4501,8801,70.3,9110,8802,-24,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2219,"ATS77 / UTM zone 19N",9001,4122,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2220,"ATS77 / UTM zone 20N",9001,4122,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2221,"Scoresbysund 1952 / Greenland zone 6 east",9001,4195,18426,9826,1,0,4501,8801,67.3,9110,8802,-32,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2222,"NAD83 / Arizona East (ft)",9002,4269,15304,9807,1,0,4495,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-2223,"NAD83 / Arizona Central (ft)",9002,4269,15305,9807,1,0,4495,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-2224,"NAD83 / Arizona West (ft)",9002,4269,15306,9807,1,0,4495,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,700000,9002,8807,0,9002,,,,,,
-2225,"NAD83 / California zone 1 (ftUS)",9003,4269,15307,9802,1,0,4497,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2226,"NAD83 / California zone 2 (ftUS)",9003,4269,15308,9802,1,0,4497,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2227,"NAD83 / California zone 3 (ftUS)",9003,4269,15309,9802,1,0,4497,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2228,"NAD83 / California zone 4 (ftUS)",9003,4269,15310,9802,1,0,4497,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2229,"NAD83 / California zone 5 (ftUS)",9003,4269,15311,9802,1,0,4497,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2230,"NAD83 / California zone 6 (ftUS)",9003,4269,15312,9802,1,0,4497,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2231,"NAD83 / Colorado North (ftUS)",9003,4269,15313,9802,1,0,4497,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,3000000,9003,8827,1000000,9003,,,
-2232,"NAD83 / Colorado Central (ftUS)",9003,4269,15314,9802,1,0,4497,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,3000000,9003,8827,1000000,9003,,,
-2233,"NAD83 / Colorado South (ftUS)",9003,4269,15315,9802,1,0,4497,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,3000000,9003,8827,1000000,9003,,,
-2234,"NAD83 / Connecticut (ftUS)",9003,4269,15316,9802,1,0,4497,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,1000000,9003,8827,500000,9003,,,
-2235,"NAD83 / Delaware (ftUS)",9003,4269,15317,9807,1,0,4497,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2236,"NAD83 / Florida East (ftUS)",9003,4269,15318,9807,1,0,4497,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2237,"NAD83 / Florida West (ftUS)",9003,4269,15319,9807,1,0,4497,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2238,"NAD83 / Florida North (ftUS)",9003,4269,15320,9802,1,0,4497,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,1968500,9003,8827,0,9003,,,
-2239,"NAD83 / Georgia East (ftUS)",9003,4269,15321,9807,1,0,4497,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2240,"NAD83 / Georgia West (ftUS)",9003,4269,15322,9807,1,0,4497,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-2241,"NAD83 / Idaho East (ftUS)",9003,4269,15323,9807,1,0,4497,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2242,"NAD83 / Idaho Central (ftUS)",9003,4269,15324,9807,1,0,4497,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-2243,"NAD83 / Idaho West (ftUS)",9003,4269,15325,9807,1,0,4497,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,2624666.667,9003,8807,0,9003,,,,,,
-2244,"NAD83 / Indiana East (ftUS)",9003,4269,15326,9807,1,1,4497,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,818125,9003,,,,,,
-2245,"NAD83 / Indiana West (ftUS)",9003,4269,15327,9807,1,1,4497,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,818125,9003,,,,,,
-2246,"NAD83 / Kentucky North (ftUS)",9003,4269,15328,9802,1,0,4497,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,1640416.667,9003,8827,0,9003,,,
-2247,"NAD83 / Kentucky South (ftUS)",9003,4269,15329,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,1640416.667,9003,8827,1640416.667,9003,,,
-2248,"NAD83 / Maryland (ftUS)",9003,4269,15330,9802,1,0,4497,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,1312333.333,9003,8827,0,9003,,,
-2249,"NAD83 / Massachusetts Mainland (ftUS)",9003,4269,15331,9802,1,0,4497,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,656166.667,9003,8827,2460625,9003,,,
-2250,"NAD83 / Massachusetts Island (ftUS)",9003,4269,15332,9802,1,0,4497,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,1640416.667,9003,8827,0,9003,,,
-2251,"NAD83 / Michigan North (ft)",9002,4269,15333,9802,1,0,4495,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,26246719.16,9002,8827,0,9002,,,
-2252,"NAD83 / Michigan Central (ft)",9002,4269,15334,9802,1,0,4495,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,19685039.37,9002,8827,0,9002,,,
-2253,"NAD83 / Michigan South (ft)",9002,4269,15335,9802,1,0,4495,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,13123359.58,9002,8827,0,9002,,,
-2254,"NAD83 / Mississippi East (ftUS)",9003,4269,15336,9807,1,0,4497,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,984250,9003,8807,0,9003,,,,,,
-2255,"NAD83 / Mississippi West (ftUS)",9003,4269,15337,9807,1,0,4497,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-2256,"NAD83 / Montana (ft)",9002,4269,15338,9802,1,0,4495,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,1968503.937,9002,8827,0,9002,,,
-2257,"NAD83 / New Mexico East (ftUS)",9003,4269,15339,9807,1,0,4497,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,541337.5,9003,8807,0,9003,,,,,,
-2258,"NAD83 / New Mexico Central (ftUS)",9003,4269,15340,9807,1,0,4497,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-2259,"NAD83 / New Mexico West (ftUS)",9003,4269,15341,9807,1,0,4497,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,2723091.667,9003,8807,0,9003,,,,,,
-2260,"NAD83 / New York East (ftUS)",9003,4269,15342,9807,1,0,4497,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-2261,"NAD83 / New York Central (ftUS)",9003,4269,15343,9807,1,0,4497,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,820208.333,9003,8807,0,9003,,,,,,
-2262,"NAD83 / New York West (ftUS)",9003,4269,15344,9807,1,0,4497,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,1148291.667,9003,8807,0,9003,,,,,,
-2263,"NAD83 / New York Long Island (ftUS)",9003,4269,15345,9802,1,0,4497,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,984250,9003,8827,0,9003,,,
-2264,"NAD83 / North Carolina (ftUS)",9003,4269,15346,9802,1,0,4497,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,2000000,9003,8827,0,9003,,,
-2265,"NAD83 / North Dakota North (ft)",9002,4269,15347,9802,1,0,4495,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,1968503.937,9002,8827,0,9002,,,
-2266,"NAD83 / North Dakota South (ft)",9002,4269,15348,9802,1,0,4495,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,1968503.937,9002,8827,0,9002,,,
-2267,"NAD83 / Oklahoma North (ftUS)",9003,4269,15349,9802,1,0,4497,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,1968500,9003,8827,0,9003,,,
-2268,"NAD83 / Oklahoma South (ftUS)",9003,4269,15350,9802,1,0,4497,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,1968500,9003,8827,0,9003,,,
-2269,"NAD83 / Oregon North (ft)",9002,4269,15351,9802,1,0,4495,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,8202099.738,9002,8827,0,9002,,,
-2270,"NAD83 / Oregon South (ft)",9002,4269,15352,9802,1,0,4495,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,4921259.843,9002,8827,0,9002,,,
-2271,"NAD83 / Pennsylvania North (ftUS)",9003,4269,15353,9802,1,0,4497,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,1968500,9003,8827,0,9003,,,
-2272,"NAD83 / Pennsylvania South (ftUS)",9003,4269,15354,9802,1,0,4497,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,1968500,9003,8827,0,9003,,,
-2273,"NAD83 / South Carolina (ft)",9002,4269,15355,9802,1,0,4495,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,2000000,9002,8827,0,9002,,,
-2274,"NAD83 / Tennessee (ftUS)",9003,4269,15356,9802,1,0,4497,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,1968500,9003,8827,0,9003,,,
-2275,"NAD83 / Texas North (ftUS)",9003,4269,15357,9802,1,0,4497,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,656166.667,9003,8827,3280833.333,9003,,,
-2276,"NAD83 / Texas North Central (ftUS)",9003,4269,15358,9802,1,0,4497,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,1968500,9003,8827,6561666.667,9003,,,
-2277,"NAD83 / Texas Central (ftUS)",9003,4269,15359,9802,1,0,4497,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,2296583.333,9003,8827,9842500,9003,,,
-2278,"NAD83 / Texas South Central (ftUS)",9003,4269,15360,9802,1,0,4497,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,1968500,9003,8827,13123333.333,9003,,,
-2279,"NAD83 / Texas South (ftUS)",9003,4269,15361,9802,1,0,4497,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,984250,9003,8827,16404166.667,9003,,,
-2280,"NAD83 / Utah North (ft)",9002,4269,15362,9802,0,0,4495,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640419.948,9002,8827,3280839.895,9002,,,
-2281,"NAD83 / Utah Central (ft)",9002,4269,15363,9802,0,0,4495,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640419.948,9002,8827,6561679.79,9002,,,
-2282,"NAD83 / Utah South (ft)",9002,4269,15364,9802,0,0,4495,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640419.948,9002,8827,9842519.685,9002,,,
-2283,"NAD83 / Virginia North (ftUS)",9003,4269,15365,9802,1,0,4497,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,11482916.667,9003,8827,6561666.667,9003,,,
-2284,"NAD83 / Virginia South (ftUS)",9003,4269,15366,9802,1,0,4497,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,11482916.667,9003,8827,3280833.333,9003,,,
-2285,"NAD83 / Washington North (ftUS)",9003,4269,15367,9802,1,0,4497,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,1640416.667,9003,8827,0,9003,,,
-2286,"NAD83 / Washington South (ftUS)",9003,4269,15368,9802,1,0,4497,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,1640416.667,9003,8827,0,9003,,,
-2287,"NAD83 / Wisconsin North (ftUS)",9003,4269,15369,9802,1,0,4497,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,1968500,9003,8827,0,9003,,,
-2288,"NAD83 / Wisconsin Central (ftUS)",9003,4269,15370,9802,1,0,4497,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,1968500,9003,8827,0,9003,,,
-2289,"NAD83 / Wisconsin South (ftUS)",9003,4269,15371,9802,1,0,4497,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,1968500,9003,8827,0,9003,,,
-2290,"ATS77 / Prince Edward Isl. Stereographic (ATS77)",9001,4122,19933,9809,1,0,4496,8801,47.15,9110,8802,-63,9110,8805,0.999912,9201,8806,700000,9001,8807,400000,9001,,,,,,
-2291,"NAD83(CSRS98) / Prince Edward Isl. Stereographic (NAD83)",9001,4122,19960,9809,1,1,4496,8801,47.15,9110,8802,-63,9110,8805,0.999912,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2292,"NAD83(CSRS98) / Prince Edward Isl. Stereographic (NAD83)",9001,4140,19960,9809,1,1,4496,8801,47.15,9110,8802,-63,9110,8805,0.999912,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2294,"ATS77 / MTM Nova Scotia zone 4",9001,4122,17794,9807,1,0,4400,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,4500000,9001,8807,0,9001,,,,,,
-2295,"ATS77 / MTM Nova Scotia zone 5",9001,4122,17795,9807,1,0,4400,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,5500000,9001,8807,0,9001,,,,,,
-2296,"Ammassalik 1958 / Greenland zone 7 east",9001,4196,18427,9826,1,0,4501,8801,64.3,9110,8802,-40,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2297,"Qornoq 1927 / Greenland zone 1 east",9001,4194,18421,9826,1,1,4501,8801,82.3,9110,8802,-40,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2298,"Qornoq 1927 / Greenland zone 2 east",9001,4194,18422,9826,1,1,4501,8801,79.3,9110,8802,-24,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2299,"Qornoq 1927 / Greenland zone 2 west",9001,4194,18432,9826,1,0,4501,8801,79.3,9110,8802,-64,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2300,"Qornoq 1927 / Greenland zone 3 east",9001,4194,18423,9826,1,1,4501,8801,76.3,9110,8802,-20,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2301,"Qornoq 1927 / Greenland zone 3 west",9001,4194,18433,9826,1,0,4501,8801,76.3,9110,8802,-64,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2302,"Qornoq 1927 / Greenland zone 4 east",9001,4194,18424,9826,1,1,4501,8801,73.3,9110,8802,-24,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2303,"Qornoq 1927 / Greenland zone 4 west",9001,4194,18434,9826,1,0,4501,8801,73.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2304,"Qornoq 1927 / Greenland zone 5 west",9001,4194,18435,9826,1,0,4501,8801,70.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2305,"Qornoq 1927 / Greenland zone 6 west",9001,4194,18436,9826,1,0,4501,8801,67.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2306,"Qornoq 1927 / Greenland zone 7 west",9001,4194,18437,9826,1,0,4501,8801,64.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2307,"Qornoq 1927 / Greenland zone 8 east",9001,4194,18428,9826,1,0,4501,8801,61.3,9110,8802,-48,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-2308,"Batavia / TM 109 SE",9001,4211,16709,9807,1,0,4400,8801,0,9102,8802,109,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2309,"WGS 84 / TM 116 SE",9001,4326,16716,9807,1,0,4400,8801,0,9102,8802,116,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2310,"WGS 84 / TM 132 SE",9001,4326,16732,9807,1,0,4400,8801,0,9102,8802,132,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2311,"WGS 84 / TM 6 NE",9001,4326,16406,9807,1,0,4400,8801,0,9102,8802,6,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2312,"Garoua / UTM zone 33N",9001,4197,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2313,"Kousseri / UTM zone 33N",9001,4198,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2314,"Trinidad 1903 / Trinidad Grid (ftCla)",9005,4302,19975,9806,1,0,4403,8801,10.263,9110,8802,-61.2,9110,8806,283800,9005,8807,214500,9005,,,,,,,,,
-2315,"Campo Inchauspe / UTM zone 19S",9001,4221,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2316,"Campo Inchauspe / UTM zone 20S",9001,4221,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2317,"PSAD56 / ICN Regional",9001,4248,19976,9802,1,0,4499,8821,6,9102,8822,-66,9102,8823,9,9102,8824,3,9102,8826,1000000,9001,8827,1000000,9001,,,
-2318,"Ain el Abd / Aramco Lambert",9001,4204,19977,9802,1,0,4400,8821,25.0522236,9110,8822,48,9102,8823,17,9102,8824,33,9102,8826,0,9001,8827,0,9001,,,
-2319,"ED50 / TM27",9001,4230,16305,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2320,"ED50 / TM30",9001,4230,16370,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2321,"ED50 / TM33",9001,4230,16306,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2322,"ED50 / TM36",9001,4230,16372,9807,1,0,4530,8801,0,9102,8802,36,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2323,"ED50 / TM39",9001,4230,16307,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2324,"ED50 / TM42",9001,4230,16374,9807,1,0,4530,8801,0,9102,8802,42,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2325,"ED50 / TM45",9001,4230,16308,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2326,Hong Kong 1980 Grid System,9001,4611,19978,9807,1,0,4500,8801,22.184368,9110,8802,114.10428,9110,8805,1,9201,8806,836694.05,9001,8807,819069.8,9001,,,,,,
-2327,"Xian 1980 / Gauss-Kruger zone 13",9001,4610,16213,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-2328,"Xian 1980 / Gauss-Kruger zone 14",9001,4610,16214,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-2329,"Xian 1980 / Gauss-Kruger zone 15",9001,4610,16215,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-2330,"Xian 1980 / Gauss-Kruger zone 16",9001,4610,16216,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-2331,"Xian 1980 / Gauss-Kruger zone 17",9001,4610,16217,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-2332,"Xian 1980 / Gauss-Kruger zone 18",9001,4610,16218,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-2333,"Xian 1980 / Gauss-Kruger zone 19",9001,4610,16219,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-2334,"Xian 1980 / Gauss-Kruger zone 20",9001,4610,16220,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-2335,"Xian 1980 / Gauss-Kruger zone 21",9001,4610,16221,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-2336,"Xian 1980 / Gauss-Kruger zone 22",9001,4610,16222,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-2337,"Xian 1980 / Gauss-Kruger zone 23",9001,4610,16223,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-2338,"Xian 1980 / Gauss-Kruger CM 75E",9001,4610,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2339,"Xian 1980 / Gauss-Kruger CM 81E",9001,4610,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2340,"Xian 1980 / Gauss-Kruger CM 87E",9001,4610,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2341,"Xian 1980 / Gauss-Kruger CM 93E",9001,4610,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2342,"Xian 1980 / Gauss-Kruger CM 99E",9001,4610,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2343,"Xian 1980 / Gauss-Kruger CM 105E",9001,4610,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2344,"Xian 1980 / Gauss-Kruger CM 111E",9001,4610,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2345,"Xian 1980 / Gauss-Kruger CM 117E",9001,4610,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2346,"Xian 1980 / Gauss-Kruger CM 123E",9001,4610,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2347,"Xian 1980 / Gauss-Kruger CM 129E",9001,4610,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2348,"Xian 1980 / Gauss-Kruger CM 135E",9001,4610,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2349,"Xian 1980 / 3-degree Gauss-Kruger zone 25",9001,4610,16285,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-2350,"Xian 1980 / 3-degree Gauss-Kruger zone 26",9001,4610,16286,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-2351,"Xian 1980 / 3-degree Gauss-Kruger zone 27",9001,4610,16287,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-2352,"Xian 1980 / 3-degree Gauss-Kruger zone 28",9001,4610,16288,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-2353,"Xian 1980 / 3-degree Gauss-Kruger zone 29",9001,4610,16289,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-2354,"Xian 1980 / 3-degree Gauss-Kruger zone 30",9001,4610,16290,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-2355,"Xian 1980 / 3-degree Gauss-Kruger zone 31",9001,4610,16291,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-2356,"Xian 1980 / 3-degree Gauss-Kruger zone 32",9001,4610,16292,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-2357,"Xian 1980 / 3-degree Gauss-Kruger zone 33",9001,4610,16293,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,33500000,9001,8807,0,9001,,,,,,
-2358,"Xian 1980 / 3-degree Gauss-Kruger zone 34",9001,4610,16294,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,34500000,9001,8807,0,9001,,,,,,
-2359,"Xian 1980 / 3-degree Gauss-Kruger zone 35",9001,4610,16295,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,35500000,9001,8807,0,9001,,,,,,
-2360,"Xian 1980 / 3-degree Gauss-Kruger zone 36",9001,4610,16296,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,36500000,9001,8807,0,9001,,,,,,
-2361,"Xian 1980 / 3-degree Gauss-Kruger zone 37",9001,4610,16297,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,37500000,9001,8807,0,9001,,,,,,
-2362,"Xian 1980 / 3-degree Gauss-Kruger zone 38",9001,4610,16298,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,38500000,9001,8807,0,9001,,,,,,
-2363,"Xian 1980 / 3-degree Gauss-Kruger zone 39",9001,4610,16299,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,39500000,9001,8807,0,9001,,,,,,
-2364,"Xian 1980 / 3-degree Gauss-Kruger zone 40",9001,4610,16070,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,40500000,9001,8807,0,9001,,,,,,
-2365,"Xian 1980 / 3-degree Gauss-Kruger zone 41",9001,4610,16071,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,41500000,9001,8807,0,9001,,,,,,
-2366,"Xian 1980 / 3-degree Gauss-Kruger zone 42",9001,4610,16072,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,42500000,9001,8807,0,9001,,,,,,
-2367,"Xian 1980 / 3-degree Gauss-Kruger zone 43",9001,4610,16073,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,43500000,9001,8807,0,9001,,,,,,
-2368,"Xian 1980 / 3-degree Gauss-Kruger zone 44",9001,4610,16074,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,44500000,9001,8807,0,9001,,,,,,
-2369,"Xian 1980 / 3-degree Gauss-Kruger zone 45",9001,4610,16075,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,45500000,9001,8807,0,9001,,,,,,
-2370,"Xian 1980 / 3-degree Gauss-Kruger CM 75E",9001,4610,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2371,"Xian 1980 / 3-degree Gauss-Kruger CM 78E",9001,4610,16386,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2372,"Xian 1980 / 3-degree Gauss-Kruger CM 81E",9001,4610,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2373,"Xian 1980 / 3-degree Gauss-Kruger CM 84E",9001,4610,16388,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2374,"Xian 1980 / 3-degree Gauss-Kruger CM 87E",9001,4610,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2375,"Xian 1980 / 3-degree Gauss-Kruger CM 90E",9001,4610,16390,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2376,"Xian 1980 / 3-degree Gauss-Kruger CM 93E",9001,4610,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2377,"Xian 1980 / 3-degree Gauss-Kruger CM 96E",9001,4610,16392,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2378,"Xian 1980 / 3-degree Gauss-Kruger CM 99E",9001,4610,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2379,"Xian 1980 / 3-degree Gauss-Kruger CM 102E",9001,4610,16394,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2380,"Xian 1980 / 3-degree Gauss-Kruger CM 105E",9001,4610,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2381,"Xian 1980 / 3-degree Gauss-Kruger CM 108E",9001,4610,16396,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2382,"Xian 1980 / 3-degree Gauss-Kruger CM 111E",9001,4610,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2383,"Xian 1980 / 3-degree Gauss-Kruger CM 114E",9001,4610,16398,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2384,"Xian 1980 / 3-degree Gauss-Kruger CM 117E",9001,4610,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2385,"Xian 1980 / 3-degree Gauss-Kruger CM 120E",9001,4610,16170,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2386,"Xian 1980 / 3-degree Gauss-Kruger CM 123E",9001,4610,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2387,"Xian 1980 / 3-degree Gauss-Kruger CM 126E",9001,4610,16172,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2388,"Xian 1980 / 3-degree Gauss-Kruger CM 129E",9001,4610,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2389,"Xian 1980 / 3-degree Gauss-Kruger CM 132E",9001,4610,16174,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2390,"Xian 1980 / 3-degree Gauss-Kruger CM 135E",9001,4610,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2391,"KKJ / Finland zone 1",9001,4123,18191,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-2392,"KKJ / Finland zone 2",9001,4123,18192,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-2393,"KKJ / Finland Uniform Coordinate System",9001,4123,18193,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-2394,"KKJ / Finland zone 4",9001,4123,18194,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-2395,"South Yemen / Gauss-Kruger zone 8",9001,4164,16208,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-2396,"South Yemen / Gauss-Kruger zone 9",9001,4164,16209,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-2397,"Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 3",9001,4178,16263,9807,1,0,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-2398,"Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 4",9001,4178,16264,9807,1,0,4530,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-2399,"Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 5",9001,4178,16265,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-2400,RT90 2.5 gon W,9001,4124,19929,9807,1,1,4530,8801,0,9110,8802,15.48298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-2401,"Beijing 1954 / 3-degree Gauss-Kruger zone 25",9001,4214,16285,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-2402,"Beijing 1954 / 3-degree Gauss-Kruger zone 26",9001,4214,16286,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-2403,"Beijing 1954 / 3-degree Gauss-Kruger zone 27",9001,4214,16287,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-2404,"Beijing 1954 / 3-degree Gauss-Kruger zone 28",9001,4214,16288,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-2405,"Beijing 1954 / 3-degree Gauss-Kruger zone 29",9001,4214,16289,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-2406,"Beijing 1954 / 3-degree Gauss-Kruger zone 30",9001,4214,16290,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-2407,"Beijing 1954 / 3-degree Gauss-Kruger zone 31",9001,4214,16291,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-2408,"Beijing 1954 / 3-degree Gauss-Kruger zone 32",9001,4214,16292,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-2409,"Beijing 1954 / 3-degree Gauss-Kruger zone 33",9001,4214,16293,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,33500000,9001,8807,0,9001,,,,,,
-2410,"Beijing 1954 / 3-degree Gauss-Kruger zone 34",9001,4214,16294,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,34500000,9001,8807,0,9001,,,,,,
-2411,"Beijing 1954 / 3-degree Gauss-Kruger zone 35",9001,4214,16295,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,35500000,9001,8807,0,9001,,,,,,
-2412,"Beijing 1954 / 3-degree Gauss-Kruger zone 36",9001,4214,16296,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,36500000,9001,8807,0,9001,,,,,,
-2413,"Beijing 1954 / 3-degree Gauss-Kruger zone 37",9001,4214,16297,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,37500000,9001,8807,0,9001,,,,,,
-2414,"Beijing 1954 / 3-degree Gauss-Kruger zone 38",9001,4214,16298,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,38500000,9001,8807,0,9001,,,,,,
-2415,"Beijing 1954 / 3-degree Gauss-Kruger zone 39",9001,4214,16299,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,39500000,9001,8807,0,9001,,,,,,
-2416,"Beijing 1954 / 3-degree Gauss-Kruger zone 40",9001,4214,16070,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,40500000,9001,8807,0,9001,,,,,,
-2417,"Beijing 1954 / 3-degree Gauss-Kruger zone 41",9001,4214,16071,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,41500000,9001,8807,0,9001,,,,,,
-2418,"Beijing 1954 / 3-degree Gauss-Kruger zone 42",9001,4214,16072,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,42500000,9001,8807,0,9001,,,,,,
-2419,"Beijing 1954 / 3-degree Gauss-Kruger zone 43",9001,4214,16073,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,43500000,9001,8807,0,9001,,,,,,
-2420,"Beijing 1954 / 3-degree Gauss-Kruger zone 44",9001,4214,16074,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,44500000,9001,8807,0,9001,,,,,,
-2421,"Beijing 1954 / 3-degree Gauss-Kruger zone 45",9001,4214,16075,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,45500000,9001,8807,0,9001,,,,,,
-2422,"Beijing 1954 / 3-degree Gauss-Kruger CM 75E",9001,4214,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2423,"Beijing 1954 / 3-degree Gauss-Kruger CM 78E",9001,4214,16386,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2424,"Beijing 1954 / 3-degree Gauss-Kruger CM 81E",9001,4214,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2425,"Beijing 1954 / 3-degree Gauss-Kruger CM 84E",9001,4214,16388,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2426,"Beijing 1954 / 3-degree Gauss-Kruger CM 87E",9001,4214,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2427,"Beijing 1954 / 3-degree Gauss-Kruger CM 90E",9001,4214,16390,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2428,"Beijing 1954 / 3-degree Gauss-Kruger CM 93E",9001,4214,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2429,"Beijing 1954 / 3-degree Gauss-Kruger CM 96E",9001,4214,16392,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2430,"Beijing 1954 / 3-degree Gauss-Kruger CM 99E",9001,4214,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2431,"Beijing 1954 / 3-degree Gauss-Kruger CM 102E",9001,4214,16394,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2432,"Beijing 1954 / 3-degree Gauss-Kruger CM 105E",9001,4214,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2433,"Beijing 1954 / 3-degree Gauss-Kruger CM 108E",9001,4214,16396,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2434,"Beijing 1954 / 3-degree Gauss-Kruger CM 111E",9001,4214,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2435,"Beijing 1954 / 3-degree Gauss-Kruger CM 114E",9001,4214,16398,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2436,"Beijing 1954 / 3-degree Gauss-Kruger CM 117E",9001,4214,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2437,"Beijing 1954 / 3-degree Gauss-Kruger CM 120E",9001,4214,16170,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2438,"Beijing 1954 / 3-degree Gauss-Kruger CM 123E",9001,4214,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2439,"Beijing 1954 / 3-degree Gauss-Kruger CM 126E",9001,4214,16172,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2440,"Beijing 1954 / 3-degree Gauss-Kruger CM 129E",9001,4214,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2441,"Beijing 1954 / 3-degree Gauss-Kruger CM 132E",9001,4214,16174,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2442,"Beijing 1954 / 3-degree Gauss-Kruger CM 135E",9001,4214,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2443,"JGD2000 / Japan Plane Rectangular CS I",9001,4612,17801,9807,1,0,4530,8801,33,9110,8802,129.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2444,"JGD2000 / Japan Plane Rectangular CS II",9001,4612,17802,9807,1,0,4530,8801,33,9110,8802,131,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2445,"JGD2000 / Japan Plane Rectangular CS III",9001,4612,17803,9807,1,0,4530,8801,36,9110,8802,132.1,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2446,"JGD2000 / Japan Plane Rectangular CS IV",9001,4612,17804,9807,1,0,4530,8801,33,9110,8802,133.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2447,"JGD2000 / Japan Plane Rectangular CS V",9001,4612,17805,9807,1,0,4530,8801,36,9110,8802,134.2,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2448,"JGD2000 / Japan Plane Rectangular CS VI",9001,4612,17806,9807,1,0,4530,8801,36,9110,8802,136,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2449,"JGD2000 / Japan Plane Rectangular CS VII",9001,4612,17807,9807,1,0,4530,8801,36,9110,8802,137.1,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2450,"JGD2000 / Japan Plane Rectangular CS VIII",9001,4612,17808,9807,1,0,4530,8801,36,9110,8802,138.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2451,"JGD2000 / Japan Plane Rectangular CS IX",9001,4612,17809,9807,1,0,4530,8801,36,9110,8802,139.5,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2452,"JGD2000 / Japan Plane Rectangular CS X",9001,4612,17810,9807,1,0,4530,8801,40,9110,8802,140.5,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2453,"JGD2000 / Japan Plane Rectangular CS XI",9001,4612,17811,9807,1,0,4530,8801,44,9110,8802,140.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2454,"JGD2000 / Japan Plane Rectangular CS XII",9001,4612,17812,9807,1,0,4530,8801,44,9110,8802,142.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2455,"JGD2000 / Japan Plane Rectangular CS XIII",9001,4612,17813,9807,1,0,4530,8801,44,9110,8802,144.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2456,"JGD2000 / Japan Plane Rectangular CS XIV",9001,4612,17814,9807,1,0,4530,8801,26,9110,8802,142,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2457,"JGD2000 / Japan Plane Rectangular CS XV",9001,4612,17815,9807,1,0,4530,8801,26,9110,8802,127.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2458,"JGD2000 / Japan Plane Rectangular CS XVI",9001,4612,17816,9807,1,0,4530,8801,26,9110,8802,124,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2459,"JGD2000 / Japan Plane Rectangular CS XVII",9001,4612,17817,9807,1,0,4530,8801,26,9110,8802,131,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2460,"JGD2000 / Japan Plane Rectangular CS XVIII",9001,4612,17818,9807,1,0,4530,8801,20,9110,8802,136,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2461,"JGD2000 / Japan Plane Rectangular CS XIX",9001,4612,17819,9807,1,0,4530,8801,26,9110,8802,154,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-2462,"Albanian 1987 / Gauss-Kruger zone 4",9001,4191,16204,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-2463,"Pulkovo 1995 / Gauss-Kruger CM 21E",9001,4200,16304,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2464,"Pulkovo 1995 / Gauss-Kruger CM 27E",9001,4200,16305,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2465,"Pulkovo 1995 / Gauss-Kruger CM 33E",9001,4200,16306,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2466,"Pulkovo 1995 / Gauss-Kruger CM 39E",9001,4200,16307,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2467,"Pulkovo 1995 / Gauss-Kruger CM 45E",9001,4200,16308,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2468,"Pulkovo 1995 / Gauss-Kruger CM 51E",9001,4200,16309,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2469,"Pulkovo 1995 / Gauss-Kruger CM 57E",9001,4200,16310,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2470,"Pulkovo 1995 / Gauss-Kruger CM 63E",9001,4200,16311,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2471,"Pulkovo 1995 / Gauss-Kruger CM 69E",9001,4200,16312,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2472,"Pulkovo 1995 / Gauss-Kruger CM 75E",9001,4200,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2473,"Pulkovo 1995 / Gauss-Kruger CM 81E",9001,4200,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2474,"Pulkovo 1995 / Gauss-Kruger CM 87E",9001,4200,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2475,"Pulkovo 1995 / Gauss-Kruger CM 93E",9001,4200,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2476,"Pulkovo 1995 / Gauss-Kruger CM 99E",9001,4200,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2477,"Pulkovo 1995 / Gauss-Kruger CM 105E",9001,4200,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2478,"Pulkovo 1995 / Gauss-Kruger CM 111E",9001,4200,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2479,"Pulkovo 1995 / Gauss-Kruger CM 117E",9001,4200,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2480,"Pulkovo 1995 / Gauss-Kruger CM 123E",9001,4200,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2481,"Pulkovo 1995 / Gauss-Kruger CM 129E",9001,4200,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2482,"Pulkovo 1995 / Gauss-Kruger CM 135E",9001,4200,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2483,"Pulkovo 1995 / Gauss-Kruger CM 141E",9001,4200,16324,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2484,"Pulkovo 1995 / Gauss-Kruger CM 147E",9001,4200,16325,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2485,"Pulkovo 1995 / Gauss-Kruger CM 153E",9001,4200,16326,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2486,"Pulkovo 1995 / Gauss-Kruger CM 159E",9001,4200,16327,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2487,"Pulkovo 1995 / Gauss-Kruger CM 165E",9001,4200,16328,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2488,"Pulkovo 1995 / Gauss-Kruger CM 171E",9001,4200,16329,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2489,"Pulkovo 1995 / Gauss-Kruger CM 177E",9001,4200,16330,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2490,"Pulkovo 1995 / Gauss-Kruger CM 177W",9001,4200,16331,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2491,"Pulkovo 1995 / Gauss-Kruger CM 171W",9001,4200,16332,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2492,"Pulkovo 1942 / Gauss-Kruger CM 9E",9001,4284,16302,9807,1,1,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2493,"Pulkovo 1942 / Gauss-Kruger CM 15E",9001,4284,16303,9807,1,1,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2494,"Pulkovo 1942 / Gauss-Kruger CM 21E",9001,4284,16304,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2495,"Pulkovo 1942 / Gauss-Kruger CM 27E",9001,4284,16305,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2496,"Pulkovo 1942 / Gauss-Kruger CM 33E",9001,4284,16306,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2497,"Pulkovo 1942 / Gauss-Kruger CM 39E",9001,4284,16307,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2498,"Pulkovo 1942 / Gauss-Kruger CM 45E",9001,4284,16308,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2499,"Pulkovo 1942 / Gauss-Kruger CM 51E",9001,4284,16309,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2500,"Pulkovo 1942 / Gauss-Kruger CM 57E",9001,4284,16310,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2501,"Pulkovo 1942 / Gauss-Kruger CM 63E",9001,4284,16311,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2502,"Pulkovo 1942 / Gauss-Kruger CM 69E",9001,4284,16312,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2503,"Pulkovo 1942 / Gauss-Kruger CM 75E",9001,4284,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2504,"Pulkovo 1942 / Gauss-Kruger CM 81E",9001,4284,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2505,"Pulkovo 1942 / Gauss-Kruger CM 87E",9001,4284,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2506,"Pulkovo 1942 / Gauss-Kruger CM 93E",9001,4284,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2507,"Pulkovo 1942 / Gauss-Kruger CM 99E",9001,4284,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2508,"Pulkovo 1942 / Gauss-Kruger CM 105E",9001,4284,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2509,"Pulkovo 1942 / Gauss-Kruger CM 111E",9001,4284,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2510,"Pulkovo 1942 / Gauss-Kruger CM 117E",9001,4284,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2511,"Pulkovo 1942 / Gauss-Kruger CM 123E",9001,4284,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2512,"Pulkovo 1942 / Gauss-Kruger CM 129E",9001,4284,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2513,"Pulkovo 1942 / Gauss-Kruger CM 135E",9001,4284,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2514,"Pulkovo 1942 / Gauss-Kruger CM 141E",9001,4284,16324,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2515,"Pulkovo 1942 / Gauss-Kruger CM 147E",9001,4284,16325,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2516,"Pulkovo 1942 / Gauss-Kruger CM 153E",9001,4284,16326,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2517,"Pulkovo 1942 / Gauss-Kruger CM 159E",9001,4284,16327,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2518,"Pulkovo 1942 / Gauss-Kruger CM 165E",9001,4284,16328,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2519,"Pulkovo 1942 / Gauss-Kruger CM 171E",9001,4284,16329,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2520,"Pulkovo 1942 / Gauss-Kruger CM 177E",9001,4284,16330,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2521,"Pulkovo 1942 / Gauss-Kruger CM 177W",9001,4284,16331,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2522,"Pulkovo 1942 / Gauss-Kruger CM 171W",9001,4284,16332,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2523,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 7",9001,4284,16267,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-2524,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 8",9001,4284,16268,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-2525,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 9",9001,4284,16269,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-2526,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 10",9001,4284,16270,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-2527,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 11",9001,4284,16271,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-2528,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 12",9001,4284,16272,9807,1,0,4530,8801,0,9102,8802,36,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-2529,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 13",9001,4284,16273,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-2530,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 14",9001,4284,16274,9807,1,0,4530,8801,0,9102,8802,42,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-2531,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 15",9001,4284,16275,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-2532,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 16",9001,4284,16276,9807,1,0,4530,8801,0,9102,8802,48,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-2533,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 17",9001,4284,16277,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-2534,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 18",9001,4284,16278,9807,1,0,4530,8801,0,9102,8802,54,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-2535,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 19",9001,4284,16279,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-2536,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 20",9001,4284,16280,9807,1,0,4530,8801,0,9102,8802,60,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-2537,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 21",9001,4284,16281,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-2538,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 22",9001,4284,16282,9807,1,0,4530,8801,0,9102,8802,66,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-2539,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 23",9001,4284,16283,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-2540,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 24",9001,4284,16284,9807,1,0,4530,8801,0,9102,8802,72,9102,8805,1,9201,8806,24500000,9001,8807,0,9001,,,,,,
-2541,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 25",9001,4284,16285,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-2542,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 26",9001,4284,16286,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-2543,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 27",9001,4284,16287,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-2544,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 28",9001,4284,16288,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-2545,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 29",9001,4284,16289,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-2546,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 30",9001,4284,16290,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-2547,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 31",9001,4284,16291,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-2548,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 32",9001,4284,16292,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-2549,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 33",9001,4284,16293,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,33500000,9001,8807,0,9001,,,,,,
-2550,"Samboja / UTM zone 50S",9001,4125,16150,9807,1,1,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2551,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 34",9001,4284,16294,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,34500000,9001,8807,0,9001,,,,,,
-2552,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 35",9001,4284,16295,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,35500000,9001,8807,0,9001,,,,,,
-2553,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 36",9001,4284,16296,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,36500000,9001,8807,0,9001,,,,,,
-2554,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 37",9001,4284,16297,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,37500000,9001,8807,0,9001,,,,,,
-2555,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 38",9001,4284,16298,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,38500000,9001,8807,0,9001,,,,,,
-2556,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 39",9001,4284,16299,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,39500000,9001,8807,0,9001,,,,,,
-2557,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 40",9001,4284,16070,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,40500000,9001,8807,0,9001,,,,,,
-2558,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 41",9001,4284,16071,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,41500000,9001,8807,0,9001,,,,,,
-2559,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 42",9001,4284,16072,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,42500000,9001,8807,0,9001,,,,,,
-2560,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 43",9001,4284,16073,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,43500000,9001,8807,0,9001,,,,,,
-2561,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 44",9001,4284,16074,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,44500000,9001,8807,0,9001,,,,,,
-2562,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 45",9001,4284,16075,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,45500000,9001,8807,0,9001,,,,,,
-2563,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 46",9001,4284,16076,9807,1,0,4530,8801,0,9102,8802,138,9102,8805,1,9201,8806,46500000,9001,8807,0,9001,,,,,,
-2564,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 47",9001,4284,16077,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,47500000,9001,8807,0,9001,,,,,,
-2565,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 48",9001,4284,16078,9807,1,0,4530,8801,0,9102,8802,144,9102,8805,1,9201,8806,48500000,9001,8807,0,9001,,,,,,
-2566,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 49",9001,4284,16079,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,49500000,9001,8807,0,9001,,,,,,
-2567,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 50",9001,4284,16080,9807,1,0,4530,8801,0,9102,8802,150,9102,8805,1,9201,8806,50500000,9001,8807,0,9001,,,,,,
-2568,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 51",9001,4284,16081,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,51500000,9001,8807,0,9001,,,,,,
-2569,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 52",9001,4284,16082,9807,1,0,4530,8801,0,9102,8802,156,9102,8805,1,9201,8806,52500000,9001,8807,0,9001,,,,,,
-2570,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 53",9001,4284,16083,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,53500000,9001,8807,0,9001,,,,,,
-2571,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 54",9001,4284,16084,9807,1,0,4530,8801,0,9102,8802,162,9102,8805,1,9201,8806,54500000,9001,8807,0,9001,,,,,,
-2572,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 55",9001,4284,16085,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,55500000,9001,8807,0,9001,,,,,,
-2573,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 56",9001,4284,16086,9807,1,0,4530,8801,0,9102,8802,168,9102,8805,1,9201,8806,56500000,9001,8807,0,9001,,,,,,
-2574,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 57",9001,4284,16087,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,57500000,9001,8807,0,9001,,,,,,
-2575,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 58",9001,4284,16088,9807,1,0,4530,8801,0,9102,8802,174,9102,8805,1,9201,8806,58500000,9001,8807,0,9001,,,,,,
-2576,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 59",9001,4284,16089,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,59500000,9001,8807,0,9001,,,,,,
-2577,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 60",9001,4284,16090,9807,1,1,4530,8801,0,9102,8802,180,9102,8805,1,9201,8806,60000000,9001,8807,0,9001,,,,,,
-2578,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 61",9001,4284,16091,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,61500000,9001,8807,0,9001,,,,,,
-2579,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 62",9001,4284,16092,9807,1,0,4530,8801,0,9102,8802,-174,9102,8805,1,9201,8806,62500000,9001,8807,0,9001,,,,,,
-2580,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 63",9001,4284,16093,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,63500000,9001,8807,0,9001,,,,,,
-2581,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 64",9001,4284,16094,9807,1,0,4530,8801,0,9102,8802,-168,9102,8805,1,9201,8806,64500000,9001,8807,0,9001,,,,,,
-2582,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 21E",9001,4284,16304,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2583,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 24E",9001,4284,16368,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2584,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 27E",9001,4284,16305,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2585,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 30E",9001,4284,16370,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2586,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 33E",9001,4284,16306,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2587,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 36E",9001,4284,16372,9807,1,0,4530,8801,0,9102,8802,36,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2588,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 39E",9001,4284,16307,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2589,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 42E",9001,4284,16374,9807,1,0,4530,8801,0,9102,8802,42,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2590,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 45E",9001,4284,16308,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2591,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 48E",9001,4284,16376,9807,1,0,4530,8801,0,9102,8802,48,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2592,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 51E",9001,4284,16309,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2593,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 54E",9001,4284,16378,9807,1,0,4530,8801,0,9102,8802,54,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2594,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 57E",9001,4284,16310,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2595,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 60E",9001,4284,16380,9807,1,0,4530,8801,0,9102,8802,60,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2596,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 63E",9001,4284,16311,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2597,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 66E",9001,4284,16382,9807,1,0,4530,8801,0,9102,8802,66,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2598,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 69E",9001,4284,16312,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2599,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 72E",9001,4284,16384,9807,1,0,4530,8801,0,9102,8802,72,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2600,Lietuvos Koordinoei Sistema 1994,9001,4669,19934,9807,1,1,4530,8801,0,9102,8802,24,9102,8805,0.9998,9201,8806,500000,9001,8807,0,9001,,,,,,
-2601,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 75E",9001,4284,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2602,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 78E",9001,4284,16386,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2603,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 81E",9001,4284,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2604,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 84E",9001,4284,16388,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2605,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 87E",9001,4284,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2606,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 90E",9001,4284,16390,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2607,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 93E",9001,4284,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2608,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 96E",9001,4284,16392,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2609,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 99E",9001,4284,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2610,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 102E",9001,4284,16394,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2611,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 105E",9001,4284,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2612,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 108E",9001,4284,16396,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2613,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 111E",9001,4284,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2614,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 114E",9001,4284,16398,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2615,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 117E",9001,4284,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2616,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 120E",9001,4284,16170,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2617,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 123E",9001,4284,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2618,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 126E",9001,4284,16172,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2619,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 129E",9001,4284,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2620,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 132E",9001,4284,16174,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2621,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 135E",9001,4284,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2622,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 138E",9001,4284,16176,9807,1,0,4530,8801,0,9102,8802,138,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2623,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 141E",9001,4284,16324,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2624,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 144E",9001,4284,16178,9807,1,0,4530,8801,0,9102,8802,144,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2625,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 147E",9001,4284,16325,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2626,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 150E",9001,4284,16180,9807,1,0,4530,8801,0,9102,8802,150,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2627,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 153E",9001,4284,16326,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2628,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 156E",9001,4284,16182,9807,1,0,4530,8801,0,9102,8802,156,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2629,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 159E",9001,4284,16327,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2630,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 162E",9001,4284,16184,9807,1,0,4530,8801,0,9102,8802,162,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2631,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 165E",9001,4284,16328,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2632,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 168E",9001,4284,16186,9807,1,0,4530,8801,0,9102,8802,168,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2633,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 171E",9001,4284,16329,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2634,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 174E",9001,4284,16188,9807,1,0,4530,8801,0,9102,8802,174,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2635,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 177E",9001,4284,16330,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2636,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 180E",9001,4284,16190,9807,1,0,4530,8801,0,9102,8802,180,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2637,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 177W",9001,4284,16331,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2638,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 174W",9001,4284,16192,9807,1,0,4530,8801,0,9102,8802,-174,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2639,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 171W",9001,4284,16332,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2640,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 168W",9001,4284,16194,9807,1,0,4530,8801,0,9102,8802,-168,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2641,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 7",9001,4200,16267,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-2642,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 8",9001,4200,16268,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-2643,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 9",9001,4200,16269,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-2644,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 10",9001,4200,16270,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-2645,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 11",9001,4200,16271,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-2646,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 12",9001,4200,16272,9807,1,0,4530,8801,0,9102,8802,36,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-2647,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 13",9001,4200,16273,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-2648,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 14",9001,4200,16274,9807,1,0,4530,8801,0,9102,8802,42,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-2649,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 15",9001,4200,16275,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-2650,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 16",9001,4200,16276,9807,1,0,4530,8801,0,9102,8802,48,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-2651,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 17",9001,4200,16277,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-2652,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 18",9001,4200,16278,9807,1,0,4530,8801,0,9102,8802,54,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-2653,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 19",9001,4200,16279,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-2654,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 20",9001,4200,16280,9807,1,0,4530,8801,0,9102,8802,60,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-2655,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 21",9001,4200,16281,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-2656,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 22",9001,4200,16282,9807,1,0,4530,8801,0,9102,8802,66,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-2657,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 23",9001,4200,16283,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-2658,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 24",9001,4200,16284,9807,1,0,4530,8801,0,9102,8802,72,9102,8805,1,9201,8806,24500000,9001,8807,0,9001,,,,,,
-2659,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 25",9001,4200,16285,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-2660,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 26",9001,4200,16286,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-2661,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 27",9001,4200,16287,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-2662,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 28",9001,4200,16288,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-2663,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 29",9001,4200,16289,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-2664,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 30",9001,4200,16290,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-2665,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 31",9001,4200,16291,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-2666,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 32",9001,4200,16292,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-2667,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 33",9001,4200,16293,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,33500000,9001,8807,0,9001,,,,,,
-2668,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 34",9001,4200,16294,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,34500000,9001,8807,0,9001,,,,,,
-2669,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 35",9001,4200,16295,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,35500000,9001,8807,0,9001,,,,,,
-2670,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 36",9001,4200,16296,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,36500000,9001,8807,0,9001,,,,,,
-2671,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 37",9001,4200,16297,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,37500000,9001,8807,0,9001,,,,,,
-2672,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 38",9001,4200,16298,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,38500000,9001,8807,0,9001,,,,,,
-2673,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 39",9001,4200,16299,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,39500000,9001,8807,0,9001,,,,,,
-2674,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 40",9001,4200,16070,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,40500000,9001,8807,0,9001,,,,,,
-2675,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 41",9001,4200,16071,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,41500000,9001,8807,0,9001,,,,,,
-2676,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 42",9001,4200,16072,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,42500000,9001,8807,0,9001,,,,,,
-2677,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 43",9001,4200,16073,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,43500000,9001,8807,0,9001,,,,,,
-2678,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 44",9001,4200,16074,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,44500000,9001,8807,0,9001,,,,,,
-2679,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 45",9001,4200,16075,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,45500000,9001,8807,0,9001,,,,,,
-2680,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 46",9001,4200,16076,9807,1,0,4530,8801,0,9102,8802,138,9102,8805,1,9201,8806,46500000,9001,8807,0,9001,,,,,,
-2681,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 47",9001,4200,16077,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,47500000,9001,8807,0,9001,,,,,,
-2682,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 48",9001,4200,16078,9807,1,0,4530,8801,0,9102,8802,144,9102,8805,1,9201,8806,48500000,9001,8807,0,9001,,,,,,
-2683,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 49",9001,4200,16079,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,49500000,9001,8807,0,9001,,,,,,
-2684,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 50",9001,4200,16080,9807,1,0,4530,8801,0,9102,8802,150,9102,8805,1,9201,8806,50500000,9001,8807,0,9001,,,,,,
-2685,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 51",9001,4200,16081,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,51500000,9001,8807,0,9001,,,,,,
-2686,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 52",9001,4200,16082,9807,1,0,4530,8801,0,9102,8802,156,9102,8805,1,9201,8806,52500000,9001,8807,0,9001,,,,,,
-2687,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 53",9001,4200,16083,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,53500000,9001,8807,0,9001,,,,,,
-2688,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 54",9001,4200,16084,9807,1,0,4530,8801,0,9102,8802,162,9102,8805,1,9201,8806,54500000,9001,8807,0,9001,,,,,,
-2689,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 55",9001,4200,16085,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,55500000,9001,8807,0,9001,,,,,,
-2690,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 56",9001,4200,16086,9807,1,0,4530,8801,0,9102,8802,168,9102,8805,1,9201,8806,56500000,9001,8807,0,9001,,,,,,
-2691,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 57",9001,4200,16087,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,57500000,9001,8807,0,9001,,,,,,
-2692,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 58",9001,4200,16088,9807,1,0,4530,8801,0,9102,8802,174,9102,8805,1,9201,8806,58500000,9001,8807,0,9001,,,,,,
-2693,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 59",9001,4200,16089,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,59500000,9001,8807,0,9001,,,,,,
-2694,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 60",9001,4200,16090,9807,1,1,4530,8801,0,9102,8802,180,9102,8805,1,9201,8806,60000000,9001,8807,0,9001,,,,,,
-2695,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 61",9001,4200,16091,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,61500000,9001,8807,0,9001,,,,,,
-2696,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 62",9001,4200,16092,9807,1,0,4530,8801,0,9102,8802,-174,9102,8805,1,9201,8806,62500000,9001,8807,0,9001,,,,,,
-2697,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 63",9001,4200,16093,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,63500000,9001,8807,0,9001,,,,,,
-2698,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 64",9001,4200,16094,9807,1,0,4530,8801,0,9102,8802,-168,9102,8805,1,9201,8806,64500000,9001,8807,0,9001,,,,,,
-2699,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 21E",9001,4200,16304,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2700,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 24E",9001,4200,16368,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2701,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 27E",9001,4200,16305,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2702,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 30E",9001,4200,16370,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2703,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 33E",9001,4200,16306,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2704,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 36E",9001,4200,16372,9807,1,0,4530,8801,0,9102,8802,36,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2705,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 39E",9001,4200,16307,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2706,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 42E",9001,4200,16374,9807,1,0,4530,8801,0,9102,8802,42,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2707,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 45E",9001,4200,16308,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2708,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 48E",9001,4200,16376,9807,1,0,4530,8801,0,9102,8802,48,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2709,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 51E",9001,4200,16309,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2710,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 54E",9001,4200,16378,9807,1,0,4530,8801,0,9102,8802,54,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2711,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 57E",9001,4200,16310,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2712,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 60E",9001,4200,16380,9807,1,0,4530,8801,0,9102,8802,60,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2713,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 63E",9001,4200,16311,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2714,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 66E",9001,4200,16382,9807,1,0,4530,8801,0,9102,8802,66,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2715,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 69E",9001,4200,16312,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2716,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 72E",9001,4200,16384,9807,1,0,4530,8801,0,9102,8802,72,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2717,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 75E",9001,4200,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2718,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 78E",9001,4200,16386,9807,1,0,4530,8801,0,9102,8802,78,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2719,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 81E",9001,4200,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2720,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 84E",9001,4200,16388,9807,1,0,4530,8801,0,9102,8802,84,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2721,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 87E",9001,4200,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2722,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 90E",9001,4200,16390,9807,1,0,4530,8801,0,9102,8802,90,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2723,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 93E",9001,4200,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2724,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 96E",9001,4200,16392,9807,1,0,4530,8801,0,9102,8802,96,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2725,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 99E",9001,4200,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2726,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 102E",9001,4200,16394,9807,1,0,4530,8801,0,9102,8802,102,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2727,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 105E",9001,4200,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2728,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 108E",9001,4200,16396,9807,1,0,4530,8801,0,9102,8802,108,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2729,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 111E",9001,4200,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2730,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 114E",9001,4200,16398,9807,1,0,4530,8801,0,9102,8802,114,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2731,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 117E",9001,4200,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2732,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 120E",9001,4200,16170,9807,1,0,4530,8801,0,9102,8802,120,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2733,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 123E",9001,4200,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2734,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 126E",9001,4200,16172,9807,1,0,4530,8801,0,9102,8802,126,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2735,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 129E",9001,4200,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2736,"Tete / UTM zone 36S",9001,4127,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2737,"Tete / UTM zone 37S",9001,4127,16137,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2738,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 132E",9001,4200,16174,9807,1,0,4530,8801,0,9102,8802,132,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2739,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 135E",9001,4200,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2740,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 138E",9001,4200,16176,9807,1,0,4530,8801,0,9102,8802,138,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2741,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 141E",9001,4200,16324,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2742,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 144E",9001,4200,16178,9807,1,0,4530,8801,0,9102,8802,144,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2743,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 147E",9001,4200,16325,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2744,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 150E",9001,4200,16180,9807,1,0,4530,8801,0,9102,8802,150,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2745,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 153E",9001,4200,16326,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2746,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 156E",9001,4200,16182,9807,1,0,4530,8801,0,9102,8802,156,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2747,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 159E",9001,4200,16327,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2748,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 162E",9001,4200,16184,9807,1,0,4530,8801,0,9102,8802,162,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2749,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 165E",9001,4200,16328,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2750,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 168E",9001,4200,16186,9807,1,0,4530,8801,0,9102,8802,168,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2751,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 171E",9001,4200,16329,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2752,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 174E",9001,4200,16188,9807,1,0,4530,8801,0,9102,8802,174,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2753,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 177E",9001,4200,16330,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2754,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 180E",9001,4200,16190,9807,1,0,4530,8801,0,9102,8802,180,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2755,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 177W",9001,4200,16331,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2756,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 174W",9001,4200,16192,9807,1,0,4530,8801,0,9102,8802,-174,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2757,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 171W",9001,4200,16332,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2758,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 168W",9001,4200,16194,9807,1,0,4530,8801,0,9102,8802,-168,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2759,"NAD83(HARN) / Alabama East",9001,4152,10131,9807,1,0,4499,8801,30.3,9110,8802,-85.5,9110,8805,0.99996,9201,8806,200000,9001,8807,0,9001,,,,,,
-2760,"NAD83(HARN) / Alabama West",9001,4152,10132,9807,1,0,4499,8801,30,9110,8802,-87.3,9110,8805,0.999933333,9201,8806,600000,9001,8807,0,9001,,,,,,
-2761,"NAD83(HARN) / Arizona East",9001,4152,10231,9807,1,0,4499,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-2762,"NAD83(HARN) / Arizona Central",9001,4152,10232,9807,1,0,4499,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-2763,"NAD83(HARN) / Arizona West",9001,4152,10233,9807,1,0,4499,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,213360,9001,8807,0,9001,,,,,,
-2764,"NAD83(HARN) / Arkansas North",9001,4152,10331,9802,1,0,4499,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,400000,9001,8827,0,9001,,,
-2765,"NAD83(HARN) / Arkansas South",9001,4152,10332,9802,1,0,4499,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,400000,9001,8827,400000,9001,,,
-2766,"NAD83(HARN) / California zone 1",9001,4152,10431,9802,1,0,4499,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,2000000,9001,8827,500000,9001,,,
-2767,"NAD83(HARN) / California zone 2",9001,4152,10432,9802,1,0,4499,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,2000000,9001,8827,500000,9001,,,
-2768,"NAD83(HARN) / California zone 3",9001,4152,10433,9802,1,0,4499,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,2000000,9001,8827,500000,9001,,,
-2769,"NAD83(HARN) / California zone 4",9001,4152,10434,9802,1,0,4499,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,2000000,9001,8827,500000,9001,,,
-2770,"NAD83(HARN) / California zone 5",9001,4152,10435,9802,1,0,4499,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,2000000,9001,8827,500000,9001,,,
-2771,"NAD83(HARN) / California zone 6",9001,4152,10436,9802,1,0,4499,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,2000000,9001,8827,500000,9001,,,
-2772,"NAD83(HARN) / Colorado North",9001,4152,10531,9802,1,0,4499,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-2773,"NAD83(HARN) / Colorado Central",9001,4152,10532,9802,1,0,4499,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-2774,"NAD83(HARN) / Colorado South",9001,4152,10533,9802,1,0,4499,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-2775,"NAD83(HARN) / Connecticut",9001,4152,10630,9802,1,0,4499,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,304800.6096,9001,8827,152400.3048,9001,,,
-2776,"NAD83(HARN) / Delaware",9001,4152,10730,9807,1,0,4499,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,200000,9001,8807,0,9001,,,,,,
-2777,"NAD83(HARN) / Florida East",9001,4152,10931,9807,1,0,4499,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-2778,"NAD83(HARN) / Florida West",9001,4152,10932,9807,1,0,4499,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-2779,"NAD83(HARN) / Florida North",9001,4152,10933,9802,1,0,4499,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,600000,9001,8827,0,9001,,,
-2780,"NAD83(HARN) / Georgia East",9001,4152,11031,9807,1,0,4499,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-2781,"NAD83(HARN) / Georgia West",9001,4152,11032,9807,1,0,4499,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,700000,9001,8807,0,9001,,,,,,
-2782,"NAD83(HARN) / Hawaii zone 1",9001,4152,15131,9807,1,0,4499,8801,18.5,9110,8802,-155.3,9110,8805,0.999966667,9201,8806,500000,9001,8807,0,9001,,,,,,
-2783,"NAD83(HARN) / Hawaii zone 2",9001,4152,15132,9807,1,0,4499,8801,20.2,9110,8802,-156.4,9110,8805,0.999966667,9201,8806,500000,9001,8807,0,9001,,,,,,
-2784,"NAD83(HARN) / Hawaii zone 3",9001,4152,15133,9807,1,0,4499,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,500000,9001,8807,0,9001,,,,,,
-2785,"NAD83(HARN) / Hawaii zone 4",9001,4152,15134,9807,1,0,4499,8801,21.5,9110,8802,-159.3,9110,8805,0.99999,9201,8806,500000,9001,8807,0,9001,,,,,,
-2786,"NAD83(HARN) / Hawaii zone 5",9001,4152,15135,9807,1,0,4499,8801,21.4,9110,8802,-160.1,9110,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-2787,"NAD83(HARN) / Idaho East",9001,4152,11131,9807,1,0,4499,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,200000,9001,8807,0,9001,,,,,,
-2788,"NAD83(HARN) / Idaho Central",9001,4152,11132,9807,1,0,4499,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,500000,9001,8807,0,9001,,,,,,
-2789,"NAD83(HARN) / Idaho West",9001,4152,11133,9807,1,0,4499,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,800000,9001,8807,0,9001,,,,,,
-2790,"NAD83(HARN) / Illinois East",9001,4152,11231,9807,1,0,4499,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,300000,9001,8807,0,9001,,,,,,
-2791,"NAD83(HARN) / Illinois West",9001,4152,11232,9807,1,0,4499,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,700000,9001,8807,0,9001,,,,,,
-2792,"NAD83(HARN) / Indiana East",9001,4152,11331,9807,1,0,4499,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,100000,9001,8807,250000,9001,,,,,,
-2793,"NAD83(HARN) / Indiana West",9001,4152,11332,9807,1,0,4499,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,900000,9001,8807,250000,9001,,,,,,
-2794,"NAD83(HARN) / Iowa North",9001,4152,11431,9802,1,0,4499,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,1500000,9001,8827,1000000,9001,,,
-2795,"NAD83(HARN) / Iowa South",9001,4152,11432,9802,1,0,4499,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,500000,9001,8827,0,9001,,,
-2796,"NAD83(HARN) / Kansas North",9001,4152,11531,9802,1,0,4499,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,400000,9001,8827,0,9001,,,
-2797,"NAD83(HARN) / Kansas South",9001,4152,11532,9802,1,0,4499,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,400000,9001,8827,400000,9001,,,
-2798,"NAD83(HARN) / Kentucky North",9001,4152,15303,9802,1,0,4499,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,500000,9001,8827,0,9001,,,
-2799,"NAD83(HARN) / Kentucky South",9001,4152,11632,9802,1,0,4499,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,500000,9001,8827,500000,9001,,,
-2800,"NAD83(HARN) / Louisiana North",9001,4152,11731,9802,1,0,4499,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,1000000,9001,8827,0,9001,,,
-2801,"NAD83(HARN) / Louisiana South",9001,4152,11732,9802,1,0,4499,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,1000000,9001,8827,0,9001,,,
-2802,"NAD83(HARN) / Maine East",9001,4152,11831,9807,1,0,4499,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,300000,9001,8807,0,9001,,,,,,
-2803,"NAD83(HARN) / Maine West",9001,4152,11832,9807,1,0,4499,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,900000,9001,8807,0,9001,,,,,,
-2804,"NAD83(HARN) / Maryland",9001,4152,11930,9802,1,0,4499,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,400000,9001,8827,0,9001,,,
-2805,"NAD83(HARN) / Massachusetts Mainland",9001,4152,12031,9802,1,0,4499,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,200000,9001,8827,750000,9001,,,
-2806,"NAD83(HARN) / Massachusetts Island",9001,4152,12032,9802,1,0,4499,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,500000,9001,8827,0,9001,,,
-2807,"NAD83(HARN) / Michigan North",9001,4152,12141,9802,1,0,4499,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,8000000,9001,8827,0,9001,,,
-2808,"NAD83(HARN) / Michigan Central",9001,4152,12142,9802,1,0,4499,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,6000000,9001,8827,0,9001,,,
-2809,"NAD83(HARN) / Michigan South",9001,4152,12143,9802,1,0,4499,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,4000000,9001,8827,0,9001,,,
-2810,"NAD83(HARN) / Minnesota North",9001,4152,12231,9802,1,0,4499,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,800000,9001,8827,100000,9001,,,
-2811,"NAD83(HARN) / Minnesota Central",9001,4152,12232,9802,1,0,4499,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,800000,9001,8827,100000,9001,,,
-2812,"NAD83(HARN) / Minnesota South",9001,4152,12233,9802,1,0,4499,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,800000,9001,8827,100000,9001,,,
-2813,"NAD83(HARN) / Mississippi East",9001,4152,12331,9807,1,0,4499,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,300000,9001,8807,0,9001,,,,,,
-2814,"NAD83(HARN) / Mississippi West",9001,4152,12332,9807,1,0,4499,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,700000,9001,8807,0,9001,,,,,,
-2815,"NAD83(HARN) / Missouri East",9001,4152,12431,9807,1,0,4499,8801,35.5,9110,8802,-90.3,9110,8805,0.999933333,9201,8806,250000,9001,8807,0,9001,,,,,,
-2816,"NAD83(HARN) / Missouri Central",9001,4152,12432,9807,1,0,4499,8801,35.5,9110,8802,-92.3,9110,8805,0.999933333,9201,8806,500000,9001,8807,0,9001,,,,,,
-2817,"NAD83(HARN) / Missouri West",9001,4152,12433,9807,1,0,4499,8801,36.1,9110,8802,-94.3,9110,8805,0.999941177,9201,8806,850000,9001,8807,0,9001,,,,,,
-2818,"NAD83(HARN) / Montana",9001,4152,12530,9802,1,0,4499,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,600000,9001,8827,0,9001,,,
-2819,"NAD83(HARN) / Nebraska",9001,4152,12630,9802,1,0,4499,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,500000,9001,8827,0,9001,,,
-2820,"NAD83(HARN) / Nevada East",9001,4152,12731,9807,1,0,4499,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,200000,9001,8807,8000000,9001,,,,,,
-2821,"NAD83(HARN) / Nevada Central",9001,4152,12732,9807,1,0,4499,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,500000,9001,8807,6000000,9001,,,,,,
-2822,"NAD83(HARN) / Nevada West",9001,4152,12733,9807,1,0,4499,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,800000,9001,8807,4000000,9001,,,,,,
-2823,"NAD83(HARN) / New Hampshire",9001,4152,12830,9807,1,0,4499,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,300000,9001,8807,0,9001,,,,,,
-2824,"NAD83(HARN) / New Jersey",9001,4152,12930,9807,1,0,4499,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-2825,"NAD83(HARN) / New Mexico East",9001,4152,13031,9807,1,0,4499,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,165000,9001,8807,0,9001,,,,,,
-2826,"NAD83(HARN) / New Mexico Central",9001,4152,13032,9807,1,0,4499,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-2827,"NAD83(HARN) / New Mexico West",9001,4152,13033,9807,1,0,4499,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,830000,9001,8807,0,9001,,,,,,
-2828,"NAD83(HARN) / New York East",9001,4152,13131,9807,1,0,4499,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-2829,"NAD83(HARN) / New York Central",9001,4152,13132,9807,1,0,4499,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,250000,9001,8807,0,9001,,,,,,
-2830,"NAD83(HARN) / New York West",9001,4152,13133,9807,1,0,4499,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,350000,9001,8807,0,9001,,,,,,
-2831,"NAD83(HARN) / New York Long Island",9001,4152,13134,9802,1,0,4499,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,300000,9001,8827,0,9001,,,
-2832,"NAD83(HARN) / North Dakota North",9001,4152,13331,9802,1,0,4499,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,600000,9001,8827,0,9001,,,
-2833,"NAD83(HARN) / North Dakota South",9001,4152,13332,9802,1,0,4499,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,600000,9001,8827,0,9001,,,
-2834,"NAD83(HARN) / Ohio North",9001,4152,13431,9802,1,0,4499,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,600000,9001,8827,0,9001,,,
-2835,"NAD83(HARN) / Ohio South",9001,4152,13432,9802,1,0,4499,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,600000,9001,8827,0,9001,,,
-2836,"NAD83(HARN) / Oklahoma North",9001,4152,13531,9802,1,0,4499,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,600000,9001,8827,0,9001,,,
-2837,"NAD83(HARN) / Oklahoma South",9001,4152,13532,9802,1,0,4499,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,600000,9001,8827,0,9001,,,
-2838,"NAD83(HARN) / Oregon North",9001,4152,13631,9802,1,0,4499,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,2500000,9001,8827,0,9001,,,
-2839,"NAD83(HARN) / Oregon South",9001,4152,13632,9802,1,0,4499,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,1500000,9001,8827,0,9001,,,
-2840,"NAD83(HARN) / Rhode Island",9001,4152,13830,9807,1,0,4499,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,100000,9001,8807,0,9001,,,,,,
-2841,"NAD83(HARN) / South Dakota North",9001,4152,14031,9802,1,0,4499,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,600000,9001,8827,0,9001,,,
-2842,"NAD83(HARN) / South Dakota South",9001,4152,14032,9802,1,0,4499,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,600000,9001,8827,0,9001,,,
-2843,"NAD83(HARN) / Tennessee",9001,4152,14130,9802,1,0,4499,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,600000,9001,8827,0,9001,,,
-2844,"NAD83(HARN) / Texas North",9001,4152,14231,9802,1,0,4499,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,200000,9001,8827,1000000,9001,,,
-2845,"NAD83(HARN) / Texas North Central",9001,4152,14232,9802,1,0,4499,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,600000,9001,8827,2000000,9001,,,
-2846,"NAD83(HARN) / Texas Central",9001,4152,14233,9802,1,0,4499,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,700000,9001,8827,3000000,9001,,,
-2847,"NAD83(HARN) / Texas South Central",9001,4152,14234,9802,1,0,4499,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,600000,9001,8827,4000000,9001,,,
-2848,"NAD83(HARN) / Texas South",9001,4152,14235,9802,1,0,4499,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,300000,9001,8827,5000000,9001,,,
-2849,"NAD83(HARN) / Utah North",9001,4152,14331,9802,1,0,4499,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,500000,9001,8827,1000000,9001,,,
-2850,"NAD83(HARN) / Utah Central",9001,4152,14332,9802,1,0,4499,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,500000,9001,8827,2000000,9001,,,
-2851,"NAD83(HARN) / Utah South",9001,4152,14333,9802,1,0,4499,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,500000,9001,8827,3000000,9001,,,
-2852,"NAD83(HARN) / Vermont",9001,4152,14430,9807,1,0,4499,8801,42.3,9110,8802,-72.3,9110,8805,0.999964286,9201,8806,500000,9001,8807,0,9001,,,,,,
-2853,"NAD83(HARN) / Virginia North",9001,4152,14531,9802,1,0,4499,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,3500000,9001,8827,2000000,9001,,,
-2854,"NAD83(HARN) / Virginia South",9001,4152,14532,9802,1,0,4499,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,3500000,9001,8827,1000000,9001,,,
-2855,"NAD83(HARN) / Washington North",9001,4152,14631,9802,1,0,4499,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,500000,9001,8827,0,9001,,,
-2856,"NAD83(HARN) / Washington South",9001,4152,14632,9802,1,0,4499,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,500000,9001,8827,0,9001,,,
-2857,"NAD83(HARN) / West Virginia North",9001,4152,14731,9802,1,0,4499,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,600000,9001,8827,0,9001,,,
-2858,"NAD83(HARN) / West Virginia South",9001,4152,14732,9802,1,0,4499,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,600000,9001,8827,0,9001,,,
-2859,"NAD83(HARN) / Wisconsin North",9001,4152,14831,9802,1,0,4499,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,600000,9001,8827,0,9001,,,
-2860,"NAD83(HARN) / Wisconsin Central",9001,4152,14832,9802,1,0,4499,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,600000,9001,8827,0,9001,,,
-2861,"NAD83(HARN) / Wisconsin South",9001,4152,14833,9802,1,0,4499,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,600000,9001,8827,0,9001,,,
-2862,"NAD83(HARN) / Wyoming East",9001,4152,14931,9807,1,0,4499,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,200000,9001,8807,0,9001,,,,,,
-2863,"NAD83(HARN) / Wyoming East Central",9001,4152,14932,9807,1,0,4499,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,400000,9001,8807,100000,9001,,,,,,
-2864,"NAD83(HARN) / Wyoming West Central",9001,4152,14933,9807,1,0,4499,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,600000,9001,8807,0,9001,,,,,,
-2865,"NAD83(HARN) / Wyoming West",9001,4152,14934,9807,1,0,4499,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,800000,9001,8807,100000,9001,,,,,,
-2866,"NAD83(HARN) / Puerto Rico and Virgin Is.",9001,4152,15230,9802,1,0,4499,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,200000,9001,8827,200000,9001,,,
-2867,"NAD83(HARN) / Arizona East (ft)",9002,4152,15304,9807,1,0,4495,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-2868,"NAD83(HARN) / Arizona Central (ft)",9002,4152,15305,9807,1,0,4495,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-2869,"NAD83(HARN) / Arizona West (ft)",9002,4152,15306,9807,1,0,4495,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,700000,9002,8807,0,9002,,,,,,
-2870,"NAD83(HARN) / California zone 1 (ftUS)",9003,4152,15307,9802,1,0,4497,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2871,"NAD83(HARN) / California zone 2 (ftUS)",9003,4152,15308,9802,1,0,4497,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2872,"NAD83(HARN) / California zone 3 (ftUS)",9003,4152,15309,9802,1,0,4497,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2873,"NAD83(HARN) / California zone 4 (ftUS)",9003,4152,15310,9802,1,0,4497,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2874,"NAD83(HARN) / California zone 5 (ftUS)",9003,4152,15311,9802,1,0,4497,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2875,"NAD83(HARN) / California zone 6 (ftUS)",9003,4152,15312,9802,1,0,4497,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-2876,"NAD83(HARN) / Colorado North (ftUS)",9003,4152,15313,9802,1,0,4497,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,3000000,9003,8827,1000000,9003,,,
-2877,"NAD83(HARN) / Colorado Central (ftUS)",9003,4152,15314,9802,1,0,4497,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,3000000,9003,8827,1000000,9003,,,
-2878,"NAD83(HARN) / Colorado South (ftUS)",9003,4152,15315,9802,1,0,4497,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,3000000,9003,8827,1000000,9003,,,
-2879,"NAD83(HARN) / Connecticut (ftUS)",9003,4152,15316,9802,1,0,4497,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,1000000,9003,8827,500000,9003,,,
-2880,"NAD83(HARN) / Delaware (ftUS)",9003,4152,15317,9807,1,0,4497,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2881,"NAD83(HARN) / Florida East (ftUS)",9003,4152,15318,9807,1,0,4497,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2882,"NAD83(HARN) / Florida West (ftUS)",9003,4152,15319,9807,1,0,4497,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2883,"NAD83(HARN) / Florida North (ftUS)",9003,4152,15320,9802,1,0,4497,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,1968500,9003,8827,0,9003,,,
-2884,"NAD83(HARN) / Georgia East (ftUS)",9003,4152,15321,9807,1,0,4497,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2885,"NAD83(HARN) / Georgia West (ftUS)",9003,4152,15322,9807,1,0,4497,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-2886,"NAD83(HARN) / Idaho East (ftUS)",9003,4152,15323,9807,1,0,4497,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-2887,"NAD83(HARN) / Idaho Central (ftUS)",9003,4152,15324,9807,1,0,4497,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-2888,"NAD83(HARN) / Idaho West (ftUS)",9003,4152,15325,9807,1,0,4497,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,2624666.667,9003,8807,0,9003,,,,,,
-2889,"NAD83(HARN) / Indiana East (ftUS)",9003,4152,15326,9807,1,1,4497,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,818125,9003,,,,,,
-2890,"NAD83(HARN) / Indiana West (ftUS)",9003,4152,15327,9807,1,1,4497,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,818125,9003,,,,,,
-2891,"NAD83(HARN) / Kentucky North (ftUS)",9003,4152,15328,9802,1,0,4497,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,1640416.667,9003,8827,0,9003,,,
-2892,"NAD83(HARN) / Kentucky South (ftUS)",9003,4152,15329,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,1640416.667,9003,8827,1640416.667,9003,,,
-2893,"NAD83(HARN) / Maryland (ftUS)",9003,4152,15330,9802,1,0,4497,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,1312333.333,9003,8827,0,9003,,,
-2894,"NAD83(HARN) / Massachusetts Mainland (ftUS)",9003,4152,15331,9802,1,0,4497,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,656166.667,9003,8827,2460625,9003,,,
-2895,"NAD83(HARN) / Massachusetts Island (ftUS)",9003,4152,15332,9802,1,0,4497,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,1640416.667,9003,8827,0,9003,,,
-2896,"NAD83(HARN) / Michigan North (ft)",9002,4152,15333,9802,1,0,4495,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,26246719.16,9002,8827,0,9002,,,
-2897,"NAD83(HARN) / Michigan Central (ft)",9002,4152,15334,9802,1,0,4495,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,19685039.37,9002,8827,0,9002,,,
-2898,"NAD83(HARN) / Michigan South (ft)",9002,4152,15335,9802,1,0,4495,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,13123359.58,9002,8827,0,9002,,,
-2899,"NAD83(HARN) / Mississippi East (ftUS)",9003,4152,15336,9807,1,0,4497,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,984250,9003,8807,0,9003,,,,,,
-2900,"NAD83(HARN) / Mississippi West (ftUS)",9003,4152,15337,9807,1,0,4497,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-2901,"NAD83(HARN) / Montana (ft)",9002,4152,15338,9802,1,0,4495,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,1968503.937,9002,8827,0,9002,,,
-2902,"NAD83(HARN) / New Mexico East (ftUS)",9003,4152,15339,9807,1,0,4497,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,541337.5,9003,8807,0,9003,,,,,,
-2903,"NAD83(HARN) / New Mexico Central (ftUS)",9003,4152,15340,9807,1,0,4497,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-2904,"NAD83(HARN) / New Mexico West (ftUS)",9003,4152,15341,9807,1,0,4497,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,2723091.667,9003,8807,0,9003,,,,,,
-2905,"NAD83(HARN) / New York East (ftUS)",9003,4152,15342,9807,1,0,4497,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-2906,"NAD83(HARN) / New York Central (ftUS)",9003,4152,15343,9807,1,0,4497,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,820208.333,9003,8807,0,9003,,,,,,
-2907,"NAD83(HARN) / New York West (ftUS)",9003,4152,15344,9807,1,0,4497,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,1148291.667,9003,8807,0,9003,,,,,,
-2908,"NAD83(HARN) / New York Long Island (ftUS)",9003,4152,15345,9802,1,0,4497,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,984250,9003,8827,0,9003,,,
-2909,"NAD83(HARN) / North Dakota North (ft)",9002,4152,15347,9802,1,0,4495,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,1968503.937,9002,8827,0,9002,,,
-2910,"NAD83(HARN) / North Dakota South (ft)",9002,4152,15348,9802,1,0,4495,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,1968503.937,9002,8827,0,9002,,,
-2911,"NAD83(HARN) / Oklahoma North (ftUS)",9003,4152,15349,9802,1,0,4497,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,1968500,9003,8827,0,9003,,,
-2912,"NAD83(HARN) / Oklahoma South (ftUS)",9003,4152,15350,9802,1,0,4497,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,1968500,9003,8827,0,9003,,,
-2913,"NAD83(HARN) / Oregon North (ft)",9002,4152,15351,9802,1,0,4495,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,8202099.738,9002,8827,0,9002,,,
-2914,"NAD83(HARN) / Oregon South (ft)",9002,4152,15352,9802,1,0,4495,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,4921259.843,9002,8827,0,9002,,,
-2915,"NAD83(HARN) / Tennessee (ftUS)",9003,4152,15356,9802,1,0,4497,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,1968500,9003,8827,0,9003,,,
-2916,"NAD83(HARN) / Texas North (ftUS)",9003,4152,15357,9802,1,0,4497,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,656166.667,9003,8827,3280833.333,9003,,,
-2917,"NAD83(HARN) / Texas North Central (ftUS)",9003,4152,15358,9802,1,0,4497,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,1968500,9003,8827,6561666.667,9003,,,
-2918,"NAD83(HARN) / Texas Central (ftUS)",9003,4152,15359,9802,1,0,4497,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,2296583.333,9003,8827,9842500,9003,,,
-2919,"NAD83(HARN) / Texas South Central (ftUS)",9003,4152,15360,9802,1,0,4497,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,1968500,9003,8827,13123333.333,9003,,,
-2920,"NAD83(HARN) / Texas South (ftUS)",9003,4152,15361,9802,1,0,4497,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,984250,9003,8827,16404166.667,9003,,,
-2921,"NAD83(HARN) / Utah North (ft)",9002,4152,15362,9802,0,0,4495,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640419.948,9002,8827,3280839.895,9002,,,
-2922,"NAD83(HARN) / Utah Central (ft)",9002,4152,15363,9802,0,0,4495,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640419.948,9002,8827,6561679.79,9002,,,
-2923,"NAD83(HARN) / Utah South (ft)",9002,4152,15364,9802,0,0,4495,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640419.948,9002,8827,9842519.685,9002,,,
-2924,"NAD83(HARN) / Virginia North (ftUS)",9003,4152,15365,9802,1,0,4497,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,11482916.667,9003,8827,6561666.667,9003,,,
-2925,"NAD83(HARN) / Virginia South (ftUS)",9003,4152,15366,9802,1,0,4497,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,11482916.667,9003,8827,3280833.333,9003,,,
-2926,"NAD83(HARN) / Washington North (ftUS)",9003,4152,15367,9802,1,0,4497,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,1640416.667,9003,8827,0,9003,,,
-2927,"NAD83(HARN) / Washington South (ftUS)",9003,4152,15368,9802,1,0,4497,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,1640416.667,9003,8827,0,9003,,,
-2928,"NAD83(HARN) / Wisconsin North (ftUS)",9003,4152,15369,9802,1,0,4497,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,1968500,9003,8827,0,9003,,,
-2929,"NAD83(HARN) / Wisconsin Central (ftUS)",9003,4152,15370,9802,1,0,4497,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,1968500,9003,8827,0,9003,,,
-2930,"NAD83(HARN) / Wisconsin South (ftUS)",9003,4152,15371,9802,1,0,4497,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,1968500,9003,8827,0,9003,,,
-2931,"Beduaram / TM 13 NE",9001,4213,16413,9807,1,0,4499,8801,0,9102,8802,13,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2932,"QND95 / Qatar National Grid",9001,4614,19919,9807,1,0,4400,8801,24.27,9110,8802,51.13,9110,8805,0.99999,9201,8806,200000,9001,8807,300000,9001,,,,,,
-2933,"Segara / UTM zone 50S",9001,4613,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2934,"Segara (Jakarta) / NEIEZ",9001,4820,19905,9804,1,1,4499,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-2935,"Pulkovo 1942 / CS63 zone A1",9001,4284,18441,9807,1,0,4530,8801,0.07,9110,8802,41.32,9110,8805,1,9201,8806,1300000,9001,8807,0,9001,,,,,,
-2936,"Pulkovo 1942 / CS63 zone A2",9001,4284,18442,9807,1,0,4530,8801,0.07,9110,8802,44.32,9110,8805,1,9201,8806,2300000,9001,8807,0,9001,,,,,,
-2937,"Pulkovo 1942 / CS63 zone A3",9001,4284,18443,9807,1,0,4530,8801,0.07,9110,8802,47.32,9110,8805,1,9201,8806,3300000,9001,8807,0,9001,,,,,,
-2938,"Pulkovo 1942 / CS63 zone A4",9001,4284,18444,9807,1,0,4530,8801,0.07,9110,8802,50.32,9110,8805,1,9201,8806,4300000,9001,8807,0,9001,,,,,,
-2939,"Pulkovo 1942 / CS63 zone K2",9001,4284,18446,9807,1,0,4530,8801,0.08,9110,8802,50.46,9110,8805,1,9201,8806,2300000,9001,8807,0,9001,,,,,,
-2940,"Pulkovo 1942 / CS63 zone K3",9001,4284,18447,9807,1,0,4530,8801,0.08,9110,8802,53.46,9110,8805,1,9201,8806,3300000,9001,8807,0,9001,,,,,,
-2941,"Pulkovo 1942 / CS63 zone K4",9001,4284,18448,9807,1,0,4530,8801,0.08,9110,8802,56.46,9110,8805,1,9201,8806,4300000,9001,8807,0,9001,,,,,,
-2942,"Porto Santo / UTM zone 28N",9001,4615,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2943,"Selvagem Grande / UTM zone 28N",9001,4616,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2944,"NAD83(CSRS) / SCoPQ zone 2",9001,4617,17700,9807,1,0,4499,8801,0,9110,8802,-55.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2945,"NAD83(CSRS) / MTM zone 3",9001,4617,17703,9807,1,0,4496,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2946,"NAD83(CSRS) / MTM zone 4",9001,4617,17704,9807,1,0,4496,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2947,"NAD83(CSRS) / MTM zone 5",9001,4617,17705,9807,1,0,4496,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2948,"NAD83(CSRS) / MTM zone 6",9001,4617,17706,9807,1,0,4496,8801,0,9110,8802,-67.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2949,"NAD83(CSRS) / MTM zone 7",9001,4617,17707,9807,1,0,4496,8801,0,9110,8802,-70.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2950,"NAD83(CSRS) / MTM zone 8",9001,4617,17708,9807,1,0,4496,8801,0,9110,8802,-73.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2951,"NAD83(CSRS) / MTM zone 9",9001,4617,17709,9807,1,0,4496,8801,0,9110,8802,-76.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2952,"NAD83(CSRS) / MTM zone 10",9001,4617,17710,9807,1,0,4496,8801,0,9110,8802,-79.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2953,"NAD83(CSRS) / New Brunswick Stereographic",9001,4617,19946,9809,1,0,4500,8801,46.3,9110,8802,-66.3,9110,8805,0.999912,9201,8806,2500000,9001,8807,7500000,9001,,,,,,
-2954,"NAD83(CSRS) / Prince Edward Isl. Stereographic (NAD83)",9001,4617,19960,9809,1,0,4496,8801,47.15,9110,8802,-63,9110,8805,0.999912,9201,8806,400000,9001,8807,800000,9001,,,,,,
-2955,"NAD83(CSRS) / UTM zone 11N",9001,4617,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2956,"NAD83(CSRS) / UTM zone 12N",9001,4617,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2957,"NAD83(CSRS) / UTM zone 13N",9001,4617,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2958,"NAD83(CSRS) / UTM zone 17N",9001,4617,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2959,"NAD83(CSRS) / UTM zone 18N",9001,4617,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2960,"NAD83(CSRS) / UTM zone 19N",9001,4617,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2961,"NAD83(CSRS) / UTM zone 20N",9001,4617,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2962,"NAD83(CSRS) / UTM zone 21N",9001,4617,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2963,"Lisbon 1890 (Lisbon) / Portugal Bonne",9001,4904,19979,9828,1,0,6509,8801,39.4,9110,8802,1,9110,8806,0,9001,8807,0,9001,,,,,,,,,
-2964,"NAD27 / Alaska Albers",9003,4267,15020,9822,1,0,4497,8821,50,9102,8822,-154,9102,8823,55,9102,8824,65,9102,8826,0,9003,8827,0,9003,,,
-2965,"NAD83 / Indiana East (ftUS)",9003,4269,15372,9807,1,0,4497,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,820208.333,9003,,,,,,
-2966,"NAD83 / Indiana West (ftUS)",9003,4269,15373,9807,1,0,4497,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,820208.333,9003,,,,,,
-2967,"NAD83(HARN) / Indiana East (ftUS)",9003,4152,15372,9807,1,0,4497,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,820208.333,9003,,,,,,
-2968,"NAD83(HARN) / Indiana West (ftUS)",9003,4152,15373,9807,1,0,4497,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,820208.333,9003,,,,,,
-2969,"Fort Marigot / UTM zone 20N",9001,4621,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2970,"Guadeloupe 1948 / UTM zone 20N",9001,4622,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2971,"CSG67 / UTM zone 22N",9001,4623,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2972,"RGFG95 / UTM zone 22N",9001,4624,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2973,"Martinique 1938 / UTM zone 20N",9001,4625,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2975,"RGR92 / UTM zone 40S",9001,4627,16140,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2976,"Tahiti 52 / UTM zone 6S",9001,4628,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2977,"Tahaa 54 / UTM zone 5S",9001,4629,16105,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2978,"IGN72 Nuku Hiva / UTM zone 7S",9001,4630,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2979,"K0 1949 / UTM zone 42S",9001,4631,16142,9807,1,1,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2980,"Combani 1950 / UTM zone 38S",9001,4632,16138,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2981,"IGN56 Lifou / UTM zone 58S",9001,4633,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2982,"IGN72 Grand Terre / UTM zone 58S",9001,4634,16158,9807,1,1,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2983,"ST87 Ouvea / UTM zone 58S",9001,4635,16158,9807,1,1,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2984,"RGNC 1991 / Lambert New Caledonia",9001,4645,19981,9802,1,1,4499,8821,-21.3,9110,8822,166,9110,8823,-20.4,9110,8824,-22.2,9110,8826,400000,9001,8827,300000,9001,,,
-2985,"Petrels 1972 / Terre Adelie Polar Stereographic",9001,4636,19983,9830,1,0,4492,8826,300000,9001,8827,200000,9001,8832,-67,9102,8833,140,9102,,,,,,,,,
-2986,"Perroud 1950 / Terre Adelie Polar Stereographic",9001,4637,19983,9830,1,0,4492,8826,300000,9001,8827,200000,9001,8832,-67,9102,8833,140,9102,,,,,,,,,
-2987,"Saint Pierre et Miquelon 1950 / UTM zone 21N",9001,4638,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2988,"MOP78 / UTM zone 1S",9001,4639,16101,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2989,"RRAF 1991 / UTM zone 20N",9001,4640,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-2990,"Reunion 1947 / TM Reunion",9001,4626,19982,9807,1,1,4499,8801,-21.07,9110,8802,55.32,9110,8805,1,9201,8806,50000,9001,8807,160000,9001,,,,,,
-2991,"NAD83 / Oregon Lambert",9001,4269,13633,9802,1,0,4499,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,400000,9001,8827,0,9001,,,
-2992,"NAD83 / Oregon Lambert (ft)",9002,4269,15374,9802,1,0,4495,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,1312335.958,9002,8827,0,9002,,,
-2993,"NAD83(HARN) / Oregon Lambert",9001,4152,13633,9802,1,0,4499,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,400000,9001,8827,0,9001,,,
-2994,"NAD83(HARN) / Oregon Lambert (ft)",9002,4152,15374,9802,1,0,4495,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,1312335.958,9002,8827,0,9002,,,
-2995,"IGN53 Mare / UTM zone 58S",9001,4641,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2996,"ST84 Ile des Pins / UTM zone 58S",9001,4642,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2997,"ST71 Belep / UTM zone 58S",9001,4643,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2998,"NEA74 Noumea / UTM zone 58S",9001,4644,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-2999,"Grand Comoros / UTM zone 38S",9001,4646,16138,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3000,"Segara / NEIEZ",9001,4613,19905,9804,1,0,4499,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-3001,"Batavia / NEIEZ",9001,4211,19905,9804,1,0,4499,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-3002,"Makassar / NEIEZ",9001,4257,19905,9804,1,0,4499,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-3003,"Monte Mario / Italy zone 1",9001,4265,18121,9807,1,0,4499,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3004,"Monte Mario / Italy zone 2",9001,4265,18122,9807,1,0,4499,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,2520000,9001,8807,0,9001,,,,,,
-3005,"NAD83 / BC Albers",9001,4269,19984,9822,1,0,4400,8821,45,9102,8822,-126,9102,8823,50,9110,8824,58.3,9110,8826,1000000,9001,8827,0,9001,,,
-3006,SWEREF99 TM,9001,4619,17333,9807,1,0,4531,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3007,SWEREF99 12 00,9001,4619,17321,9807,1,0,4531,8801,0,9102,8802,12,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3008,SWEREF99 13 30,9001,4619,17322,9807,1,0,4531,8801,0,9110,8802,13.3,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3009,SWEREF99 15 00,9001,4619,17323,9807,1,0,4531,8801,0,9102,8802,15,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3010,SWEREF99 16 30,9001,4619,17324,9807,1,0,4531,8801,0,9110,8802,16.3,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3011,SWEREF99 18 00,9001,4619,17325,9807,1,0,4531,8801,0,9102,8802,18,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3012,SWEREF99 14 15,9001,4619,17326,9807,1,0,4531,8801,0,9110,8802,14.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3013,SWEREF99 15 45,9001,4619,17327,9807,1,0,4531,8801,0,9110,8802,15.45,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3014,SWEREF99 17 15,9001,4619,17328,9807,1,0,4531,8801,0,9110,8802,17.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3015,SWEREF99 18 45,9001,4619,17329,9807,1,0,4531,8801,0,9110,8802,18.45,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3016,SWEREF99 20 15,9001,4619,17330,9807,1,0,4531,8801,0,9110,8802,20.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3017,SWEREF99 21 45,9001,4619,17331,9807,1,0,4531,8801,0,9110,8802,21.45,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3018,SWEREF99 23 15,9001,4619,17332,9807,1,0,4531,8801,0,9110,8802,23.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-3019,RT90 7.5 gon V,9001,4124,17334,9807,1,0,4530,8801,0,9110,8802,11.18298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3020,RT90 5 gon V,9001,4124,17335,9807,1,0,4530,8801,0,9110,8802,13.33298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3021,RT90 2.5 gon V,9001,4124,19929,9807,1,0,4530,8801,0,9110,8802,15.48298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3022,RT90 0 gon,9001,4124,17336,9807,1,0,4530,8801,0,9110,8802,18.03298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3023,RT90 2.5 gon O,9001,4124,17337,9807,1,0,4530,8801,0,9110,8802,20.18298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3024,RT90 5 gon O,9001,4124,17338,9807,1,0,4530,8801,0,9110,8802,22.33298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3025,RT38 7.5 gon V,9001,4308,17334,9807,1,0,4530,8801,0,9110,8802,11.18298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3026,RT38 5 gon V,9001,4308,17335,9807,1,0,4530,8801,0,9110,8802,13.33298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3027,RT38 2.5 gon V,9001,4308,19929,9807,1,0,4530,8801,0,9110,8802,15.48298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3028,RT38 0 gon,9001,4308,17336,9807,1,0,4530,8801,0,9110,8802,18.03298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3029,RT38 2.5 gon O,9001,4308,17337,9807,1,0,4530,8801,0,9110,8802,20.18298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3030,RT38 5 gon O,9001,4308,17338,9807,1,0,4530,8801,0,9110,8802,22.33298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-3031,"WGS 84 / Antarctic Polar Stereographic",9001,4326,19992,9829,1,0,4490,8806,0,9001,8807,0,9001,8832,-71,9102,8833,0,9102,,,,,,,,,
-3032,"WGS 84 / Australian Antarctic Polar Stereographic",9001,4326,19993,9829,1,0,4489,8806,6000000,9001,8807,6000000,9001,8832,-71,9102,8833,70,9102,,,,,,,,,
-3033,"WGS 84 / Australian Antarctic Lambert",9001,4326,19994,9802,1,0,4400,8821,-50,9110,8822,70,9110,8823,-68.3,9110,8824,-74.3,9110,8826,6000000,9001,8827,6000000,9001,,,
-3034,"ETRS89 / ETRS-LCC",9001,4258,19985,9802,1,0,4500,8821,52,9102,8822,10,9102,8823,35,9102,8824,65,9102,8826,4000000,9001,8827,2800000,9001,,,
-3035,"ETRS89 / ETRS-LAEA",9001,4258,19986,9820,1,0,4532,8801,52,9102,8802,10,9102,8806,4321000,9001,8807,3210000,9001,,,,,,,,,
-3036,"Moznet / UTM zone 36S",9001,4130,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3037,"Moznet / UTM zone 37S",9001,4130,16137,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3038,"ETRS89 / ETRS-TM26",9001,4258,16026,9807,1,0,4500,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3039,"ETRS89 / ETRS-TM27",9001,4258,16027,9807,1,0,4500,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3040,"ETRS89 / ETRS-TM28",9001,4258,16028,9807,1,0,4500,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3041,"ETRS89 / ETRS-TM29",9001,4258,16029,9807,1,0,4500,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3042,"ETRS89 / ETRS-TM30",9001,4258,16030,9807,1,0,4500,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3043,"ETRS89 / ETRS-TM31",9001,4258,16031,9807,1,0,4500,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3044,"ETRS89 / ETRS-TM32",9001,4258,16032,9807,1,0,4500,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3045,"ETRS89 / ETRS-TM33",9001,4258,16033,9807,1,0,4500,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3046,"ETRS89 / ETRS-TM34",9001,4258,16034,9807,1,0,4500,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3047,"ETRS89 / ETRS-TM35",9001,4258,16035,9807,1,0,4500,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3048,"ETRS89 / ETRS-TM36",9001,4258,16036,9807,1,0,4500,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3049,"ETRS89 / ETRS-TM37",9001,4258,16037,9807,1,0,4500,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3050,"ETRS89 / ETRS-TM38",9001,4258,16038,9807,1,0,4500,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3051,"ETRS89 / ETRS-TM39",9001,4258,16039,9807,1,0,4500,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3052,"Reykjavik 1900 / Lambert 1900",9001,4657,19987,9826,1,0,4491,8801,65,9110,8802,-19.011965,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3053,"Hjorsey 1955 / Lambert 1955",9001,4658,19988,9826,1,0,4491,8801,65,9102,8802,-18,9102,8805,1,9201,8806,500000,9001,8807,500000,9001,,,,,,
-3054,"Hjorsey 1955 / UTM zone 26N",9001,4658,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3055,"Hjorsey 1955 / UTM zone 27N",9001,4658,16027,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3056,"Hjorsey 1955 / UTM zone 28N",9001,4658,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3057,"ISN93 / Lambert 1993",9001,4659,19989,9802,1,0,4499,8821,65,9110,8822,-19,9110,8823,64.15,9110,8824,65.45,9110,8826,500000,9001,8827,500000,9001,,,
-3058,"Helle 1954 / Jan Mayen Grid",9001,4660,19991,9807,1,0,4531,8801,0,9110,8802,-8.3,9110,8805,1,9201,8806,50000,9001,8807,-7800000,9001,,,,,,
-3059,"LKS92 / Latvia TM",9001,4661,19990,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,0.9996,9201,8806,500000,9001,8807,-6000000,9001,,,,,,
-3060,"IGN72 Grande Terre / UTM zone 58S",9001,4662,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3061,"Porto Santo 1995 / UTM zone 28N",9001,4663,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3062,"Azores Oriental 1995 / UTM zone 26N",9001,4664,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3063,"Azores Central 1995 / UTM zone 26N",9001,4665,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3064,"IGM95 / UTM zone 32N",9001,4670,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3065,"IGM95 / UTM zone 33N",9001,4670,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3066,"ED50 / Jordan TM",9001,4230,19995,9807,1,0,4400,8801,0,9102,8802,37,9102,8805,0.9998,9201,8806,500000,9001,8807,-3000000,9001,,,,,,
-3067,"ETRS89 / ETRS-TM35FIN",9001,4258,16065,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3068,"DHDN / Soldner Berlin",9001,4314,19996,9806,1,0,4531,8801,52.25071338,9110,8802,13.37379332,9110,8806,40000,9001,8807,10000,9001,,,,,,,,,
-3069,"NAD27 / Wisconsin Transverse Mercator",9001,4267,14811,9807,1,0,4499,8801,0,9102,8802,-90,9102,8805,0.9996,9201,8806,500000,9001,8807,-4500000,9001,,,,,,
-3070,"NAD83 / Wisconsin Transverse Mercator",9001,4269,14841,9807,1,0,4499,8801,0,9102,8802,-90,9102,8805,0.9996,9201,8806,520000,9001,8807,-4480000,9001,,,,,,
-3071,"NAD83(HARN) / Wisconsin Transverse Mercator",9001,4152,14841,9807,1,0,4499,8801,0,9102,8802,-90,9102,8805,0.9996,9201,8806,520000,9001,8807,-4480000,9001,,,,,,
-3072,"NAD83 / Maine CS2000 East",9001,4269,11851,9807,1,0,4499,8801,43.5,9110,8802,-67.523,9110,8805,0.99998,9201,8806,700000,9001,8807,0,9001,,,,,,
-3073,"NAD83 / Maine CS2000 Central",9001,4269,11852,9807,1,1,4499,8801,43,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-3074,"NAD83 / Maine CS2000 West",9001,4269,11853,9807,1,0,4499,8801,42.5,9110,8802,-70.223,9110,8805,0.99998,9201,8806,300000,9001,8807,0,9001,,,,,,
-3075,"NAD83(HARN) / Maine CS2000 East",9001,4152,11851,9807,1,0,4499,8801,43.5,9110,8802,-67.523,9110,8805,0.99998,9201,8806,700000,9001,8807,0,9001,,,,,,
-3076,"NAD83(HARN) / Maine CS2000 Central",9001,4152,11852,9807,1,1,4499,8801,43,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-3077,"NAD83(HARN) / Maine CS2000 West",9001,4152,11853,9807,1,0,4499,8801,42.5,9110,8802,-70.223,9110,8805,0.99998,9201,8806,300000,9001,8807,0,9001,,,,,,
-3078,"NAD83 / Michigan Oblique Mercator",9001,4269,12150,9812,1,0,4499,8806,2546731.496,9001,8807,-4354009.816,9001,8811,45.1833,9110,8812,-86,9110,8813,337.25556,9102,8814,337.25556,9102,8815,0.9996,9201
-3079,"NAD83(HARN) / Michigan Oblique Mercator",9001,4152,12150,9812,1,0,4499,8806,2546731.496,9001,8807,-4354009.816,9001,8811,45.1833,9110,8812,-86,9110,8813,337.25556,9102,8814,337.25556,9102,8815,0.9996,9201
-3080,"NAD27 / Shackleford",9002,4267,14252,9802,1,0,4495,8821,31.1,9110,8822,-100,9110,8823,27.25,9110,8824,34.55,9110,8826,3000000,9002,8827,3000000,9002,,,
-3081,"NAD83 / Texas State Mapping System",9001,4269,14251,9802,1,0,4499,8821,31.1,9110,8822,-100,9110,8823,27.25,9110,8824,34.55,9110,8826,1000000,9001,8827,1000000,9001,,,
-3082,"NAD83 / Texas Centric Lambert Conformal",9001,4269,14253,9802,1,0,4499,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,5000000,9001,,,
-3083,"NAD83 / Texas Centric Albers Equal Area",9001,4269,14254,9822,1,0,4499,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,6000000,9001,,,
-3084,"NAD83(HARN) / Texas Centric Lambert Conformal",9001,4152,14253,9802,1,0,4499,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,5000000,9001,,,
-3085,"NAD83(HARN) / Texas Centric Albers Equal Area",9001,4152,14254,9822,1,0,4499,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,6000000,9001,,,
-3086,"NAD83 / Florida GDL Albers",9001,4269,10934,9822,1,0,4499,8821,24,9110,8822,-84,9110,8823,24,9110,8824,31.3,9110,8826,400000,9001,8827,0,9001,,,
-3087,"NAD83(HARN) / Florida GDL Albers",9001,4152,10934,9822,1,0,4499,8821,24,9110,8822,-84,9110,8823,24,9110,8824,31.3,9110,8826,400000,9001,8827,0,9001,,,
-3088,"NAD83 / Kentucky Single Zone",9001,4269,11630,9802,1,0,4499,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,1500000,9001,8827,1000000,9001,,,
-3089,"NAD83 / Kentucky Single Zone (ftUS)",9003,4269,15375,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,4921250,9003,8827,3280833.333,9003,,,
-3090,"NAD83(HARN) / Kentucky Single Zone",9001,4152,11630,9802,1,0,4499,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,1500000,9001,8827,1000000,9001,,,
-3091,"NAD83(HARN) / Kentucky Single Zone (ftUS)",9003,4152,15375,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,4921250,9003,8827,3280833.333,9003,,,
-3092,"Tokyo / UTM zone 51N",9001,4301,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3093,"Tokyo / UTM zone 52N",9001,4301,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3094,"Tokyo / UTM zone 53N",9001,4301,16053,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3095,"Tokyo / UTM zone 54N",9001,4301,16054,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3096,"Tokyo / UTM zone 55N",9001,4301,16055,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3097,"JGD2000 / UTM zone 51N",9001,4612,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3098,"JGD2000 / UTM zone 52N",9001,4612,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3099,"JGD2000 / UTM zone 53N",9001,4612,16053,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3100,"JGD2000 / UTM zone 54N",9001,4612,16054,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3101,"JGD2000 / UTM zone 55N",9001,4612,16055,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3102,"American Samoa 1962 / American Samoa Lambert",9003,4169,15376,9801,1,0,4497,8801,-14.16,9110,8802,-170,9110,8805,1,9201,8806,500000,9003,8807,312234.65,9003,,,,,,
-3103,"Mauritania 1999 / UTM zone 28N",9001,4681,16028,9807,1,1,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3104,"Mauritania 1999 / UTM zone 29N",9001,4681,16029,9807,1,1,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3105,"Mauritania 1999 / UTM zone 30N",9001,4681,16030,9807,1,1,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3106,"Gulshan 303 / Bangladesh Transverse Mercator",9001,4682,16490,9807,1,0,4400,8801,0,9102,8802,90,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3107,"GDA94 / SA Lambert",9001,4283,17359,9802,1,0,4400,8821,-32,9102,8822,135,9102,8823,-28,9102,8824,-36,9102,8826,1000000,9001,8827,2000000,9001,,,
-3108,"ETRS89 / Guernsey Grid",9001,4258,19998,9807,1,0,4400,8801,49.3,9110,8802,-2.25,9110,8805,0.999997,9201,8806,47000,9001,8807,50000,9001,,,,,,
-3109,"ETRS89 / Jersey Transverse Mercator",9001,4258,19999,9807,1,0,4400,8801,49.225,9102,8802,-2.135,9102,8805,0.9999999,9201,8806,40000,9001,8807,70000,9001,,,,,,
-3110,"AGD66 / Vicgrid66",9001,4202,17360,9802,1,0,4400,8821,-37,9102,8822,145,9102,8823,-36,9102,8824,-38,9102,8826,2500000,9001,8827,4500000,9001,,,
-3111,"GDA94 / Vicgrid94",9001,4283,17361,9802,1,0,4400,8821,-37,9102,8822,145,9102,8823,-36,9102,8824,-38,9102,8826,2500000,9001,8827,2500000,9001,,,
-3112,"GDA94 / Geoscience Australia Lambert",9001,4283,17362,9802,1,0,4400,8821,0,9102,8822,134,9102,8823,-18,9102,8824,-36,9102,8826,0,9001,8827,0,9001,,,
-3113,"GDA94 / BCSG02",9001,4283,17363,9807,1,0,4400,8801,-28,9102,8802,153,9102,8805,0.99999,9201,8806,50000,9001,8807,100000,9001,,,,,,
-3114,"MAGNA-SIRGAS / Colombia Far West zone",9001,4686,18055,9807,1,0,4500,8801,4.35463215,9110,8802,-80.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3115,"MAGNA-SIRGAS / Colombia West zone",9001,4686,18056,9807,1,0,4500,8801,4.35463215,9110,8802,-77.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3116,"MAGNA-SIRGAS / Colombia Bogota zone",9001,4686,18057,9807,1,0,4500,8801,4.35463215,9110,8802,-74.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3117,"MAGNA-SIRGAS / Colombia East Central zone",9001,4686,18058,9807,1,0,4500,8801,4.35463215,9110,8802,-71.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3118,"MAGNA-SIRGAS / Colombia East zone",9001,4686,18059,9807,1,0,4500,8801,4.35463215,9110,8802,-68.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3119,"Douala 1948 / AEF west",9001,4192,18415,9807,1,0,4400,8801,0,9110,8802,10.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3120,"Pulkovo 1942(58) / Poland zone I",9001,4179,18280,9809,1,0,4530,8801,50.373,9110,8802,21.05,9110,8805,0.9998,9201,8806,4637000,9001,8807,5467000,9001,,,,,,
-3121,"PRS92 / Philippines zone 1",9001,4683,18171,9807,1,0,4499,8801,0,9102,8802,117,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-3122,"PRS92 / Philippines zone 2",9001,4683,18172,9807,1,0,4499,8801,0,9102,8802,119,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-3123,"PRS92 / Philippines zone 3",9001,4683,18173,9807,1,0,4499,8801,0,9102,8802,121,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-3124,"PRS92 / Philippines zone 4",9001,4683,18174,9807,1,0,4499,8801,0,9102,8802,123,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-3125,"PRS92 / Philippines zone 5",9001,4683,18175,9807,1,0,4499,8801,0,9102,8802,125,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-3126,"ETRS89 / ETRS-GK19FIN",9001,4258,18183,9807,1,0,4500,8801,0,9102,8802,19,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3127,"ETRS89 / ETRS-GK20FIN",9001,4258,18184,9807,1,0,4500,8801,0,9102,8802,20,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3128,"ETRS89 / ETRS-GK21FIN",9001,4258,18185,9807,1,0,4500,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3129,"ETRS89 / ETRS-GK22FIN",9001,4258,18186,9807,1,0,4500,8801,0,9102,8802,22,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3130,"ETRS89 / ETRS-GK23FIN",9001,4258,18187,9807,1,0,4500,8801,0,9102,8802,23,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3131,"ETRS89 / ETRS-GK24FIN",9001,4258,18188,9807,1,0,4500,8801,0,9102,8802,24,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3132,"ETRS89 / ETRS-GK25FIN",9001,4258,18189,9807,1,0,4500,8801,0,9102,8802,25,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3133,"ETRS89 / ETRS-GK26FIN",9001,4258,18190,9807,1,0,4500,8801,0,9102,8802,26,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3134,"ETRS89 / ETRS-GK27FIN",9001,4258,18195,9807,1,0,4500,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3135,"ETRS89 / ETRS-GK28FIN",9001,4258,18196,9807,1,0,4500,8801,0,9102,8802,28,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3136,"ETRS89 / ETRS-GK29FIN",9001,4258,18197,9807,1,0,4500,8801,0,9102,8802,29,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3137,"ETRS89 / ETRS-GK30FIN",9001,4258,18198,9807,1,0,4500,8801,0,9102,8802,30,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3138,"ETRS89 / ETRS-GK31FIN",9001,4258,18199,9807,1,0,4500,8801,0,9102,8802,31,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3139,"Vanua Levu 1915 / Vanua Levu Grid",9098,4748,19878,9833,1,0,4533,8801,-16.15,9110,8802,179.2,9110,8806,1251331.8,9098,8807,1662888.5,9098,,,,,,,,,
-3140,"Viti Levu 1912 / Viti Levu Grid",9098,4752,19879,9806,1,0,4533,8801,-18,9102,8802,178,9102,8806,544000,9098,8807,704000,9098,,,,,,,,,
-3141,"Fiji 1956 / UTM zone 60S",9001,4721,16160,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3142,"Fiji 1956 / UTM zone 1S",9001,4721,16101,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3143,"Fiji 1986 / Fiji Map Grid",9001,4720,19880,9807,1,1,4400,8801,-17,9110,8802,178.45,9110,8805,0.99985,9001,8806,2000000,9001,8807,4000000,9001,,,,,,
-3144,"FD54 / Faroe Lambert",9001,4741,19870,9826,1,0,4501,8801,62,9102,8802,-9,9102,8805,1,9201,8806,500000,9001,8807,500000,9001,,,,,,
-3145,"ETRS89 / Faroe Lambert",9001,4258,19870,9826,1,0,4501,8801,62,9102,8802,-9,9102,8805,1,9201,8806,500000,9001,8807,500000,9001,,,,,,
-3146,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 6",9001,4284,16266,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3147,"Pulkovo 1942 / 3-degree Gauss-Kruger CM 18E",9001,4284,16366,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3148,"Indian 1960 / UTM zone 48N",9001,4131,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3149,"Indian 1960 / UTM zone 49N",9001,4131,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3150,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 6",9001,4200,16266,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3151,"Pulkovo 1995 / 3-degree Gauss-Kruger CM 18E",9001,4200,16366,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3152,ST74,9001,4619,19876,9807,1,0,4531,8801,0,9110,8802,18.0328044,9110,8805,0.99999425,9201,8806,100178.1808,9001,8807,-6500614.7836,9001,,,,,,
-3153,"NAD83(CSRS) / BC Albers",9001,4617,19984,9822,1,0,4400,8821,45,9102,8822,-126,9102,8823,50,9110,8824,58.3,9110,8826,1000000,9001,8827,0,9001,,,
-3154,"NAD83(CSRS) / UTM zone 7N",9001,4617,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3155,"NAD83(CSRS) / UTM zone 8N",9001,4617,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3156,"NAD83(CSRS) / UTM zone 9N",9001,4617,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3157,"NAD83(CSRS) / UTM zone 10N",9001,4617,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3158,"NAD83(CSRS) / UTM zone 14N",9001,4617,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3159,"NAD83(CSRS) / UTM zone 15N",9001,4617,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3160,"NAD83(CSRS) / UTM zone 16N",9001,4617,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3161,"NAD83 / Ontario MNR Lambert",9001,4269,19875,9802,1,0,4400,8821,0,9102,8822,-85,9102,8823,44.5,9102,8824,53.5,9102,8826,930000,9001,8827,6430000,9001,,,
-3162,"NAD83(CSRS) / Ontario MNR Lambert",9001,4617,19875,9802,1,0,4400,8821,0,9102,8822,-85,9102,8823,44.5,9102,8824,53.5,9102,8826,930000,9001,8827,6430000,9001,,,
-3163,"RGNC91-93 / Lambert New Caledonia",9001,4749,19981,9802,1,0,4499,8821,-21.3,9110,8822,166,9110,8823,-20.4,9110,8824,-22.2,9110,8826,400000,9001,8827,300000,9001,,,
-3164,"ST87 Ouvea / UTM zone 58S",9001,4750,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3165,"NEA74 Noumea / Noumea Lambert",9001,4644,19873,9802,1,0,4499,8821,-22.16108903,9110,8822,166.26327327,9110,8823,-22.14408903,9110,8824,-22.17408903,9110,8826,0.66,9001,8827,1.02,9001,,,
-3166,"NEA74 Noumea / Noumea Lambert 2",9001,4644,19874,9802,1,0,4499,8821,-22.1611,9110,8822,166.2633,9110,8823,-22.1441,9110,8824,-22.1741,9110,8826,8.313,9001,8827,-2.354,9001,,,
-3167,"Kertau (RSO) / RSO Malaya (ch)",9301,4751,19871,9812,1,0,4410,8806,40000,9301,8807,0,9301,8811,4,9110,8812,102.15,9110,8813,323.01328458,9110,8814,323.07483685,9110,8815,0.99984,9201
-3168,"Kertau (RSO) / RSO Malaya (m)",9001,4751,19872,9812,1,0,4400,8806,804670.24,9001,8807,0,9001,8811,4,9110,8812,102.15,9110,8813,323.01328458,9110,8814,323.07483685,9110,8815,0.99984,9201
-3169,"RGNC91-93 / UTM zone 57S",9001,4749,16157,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3170,"RGNC91-93 / UTM zone 58S",9001,4749,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3171,"RGNC91-93 / UTM zone 59S",9001,4749,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3172,"IGN53 Mare / UTM zone 59S",9001,4641,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3173,"fk89 / Faroe Lambert FK89",9001,4753,19877,9826,1,0,4501,8801,62,9102,8802,-9,9102,8805,1,9201,8806,700000,9001,8807,700000,9001,,,,,,
-3174,"NAD83 / Great Lakes Albers",9001,4269,15397,9822,1,0,4499,8821,45.568977,9102,8822,-84.455955,9102,8823,42.122774,9102,8824,49.01518,9102,8826,1000000,9001,8827,1000000,9001,,,
-3175,"NAD83 / Great Lakes and St Lawrence Albers",9001,4269,15398,9822,1,0,4499,8821,45.568977,9102,8822,-83.248627,9102,8823,42.122774,9102,8824,49.01518,9102,8826,1000000,9001,8827,1000000,9001,,,
-3176,"Indian 1960 / TM 106 NE",9001,4131,16506,9807,1,0,4400,8801,0,9102,8802,106,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3177,"LGD2006 / Libya TM",9001,4754,18319,9807,1,0,4499,8801,0,9102,8802,17,9102,8805,0.9965,9201,8806,1000000,9001,8807,0,9001,,,,,,
-3178,"GR96 / UTM zone 18N",9001,4747,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3179,"GR96 / UTM zone 19N",9001,4747,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3180,"GR96 / UTM zone 20N",9001,4747,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3181,"GR96 / UTM zone 21N",9001,4747,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3182,"GR96 / UTM zone 22N",9001,4747,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3183,"GR96 / UTM zone 23N",9001,4747,16023,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3184,"GR96 / UTM zone 24N",9001,4747,16024,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3185,"GR96 / UTM zone 25N",9001,4747,16025,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3186,"GR96 / UTM zone 26N",9001,4747,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3187,"GR96 / UTM zone 27N",9001,4747,16027,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3188,"GR96 / UTM zone 28N",9001,4747,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3189,"GR96 / UTM zone 29N",9001,4747,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3190,"LGD2006 / Libya TM zone 5",9001,4754,18310,9807,1,0,4499,8801,0,9102,8802,9,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3191,"LGD2006 / Libya TM zone 6",9001,4754,18311,9807,1,0,4499,8801,0,9102,8802,11,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3192,"LGD2006 / Libya TM zone 7",9001,4754,18312,9807,1,0,4499,8801,0,9102,8802,13,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3193,"LGD2006 / Libya TM zone 8",9001,4754,18313,9807,1,0,4499,8801,0,9102,8802,15,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3194,"LGD2006 / Libya TM zone 9",9001,4754,18314,9807,1,0,4499,8801,0,9102,8802,17,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3195,"LGD2006 / Libya TM zone 10",9001,4754,18315,9807,1,0,4499,8801,0,9102,8802,19,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3196,"LGD2006 / Libya TM zone 11",9001,4754,18316,9807,1,0,4499,8801,0,9102,8802,21,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3197,"LGD2006 / Libya TM zone 12",9001,4754,18317,9807,1,0,4499,8801,0,9102,8802,23,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3198,"LGD2006 / Libya TM zone 13",9001,4754,18318,9807,1,0,4499,8801,0,9102,8802,25,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3199,"LGD2006 / UTM zone 32N",9001,4754,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3200,"FD58 / Iraq zone",9001,4132,19906,9801,1,0,4400,8801,32.3,9110,8802,45,9110,8805,0.9987864078,9201,8806,1500000,9001,8807,1166200,9001,,,,,,
-3201,"LGD2006 / UTM zone 33N",9001,4754,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3202,"LGD2006 / UTM zone 34N",9001,4754,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3203,"LGD2006 / UTM zone 35N",9001,4754,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3204,"WGS 84 / SCAR IMW SP19-20",9001,4326,17204,9802,1,0,4400,8821,-90,9102,8822,-66,9102,8823,-60.4,9110,8824,-63.2,9110,8826,0,9001,8827,0,9001,,,
-3205,"WGS 84 / SCAR IMW SP21-22",9001,4326,17205,9802,1,0,4400,8821,-90,9102,8822,-54,9102,8823,-60.4,9110,8824,-63.2,9110,8826,0,9001,8827,0,9001,,,
-3206,"WGS 84 / SCAR IMW SP23-24",9001,4326,17206,9802,1,0,4400,8821,-90,9102,8822,-42,9102,8823,-60.4,9110,8824,-63.2,9110,8826,0,9001,8827,0,9001,,,
-3207,"WGS 84 / SCAR IMW SQ01-02",9001,4326,17207,9802,1,0,4400,8821,-90,9102,8822,-174,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3208,"WGS 84 / SCAR IMW SQ19-20",9001,4326,17208,9802,1,0,4400,8821,-90,9102,8822,-66,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3209,"WGS 84 / SCAR IMW SQ21-22",9001,4326,17209,9802,1,0,4400,8821,-90,9102,8822,-54,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3210,"WGS 84 / SCAR IMW SQ37-38",9001,4326,17210,9802,1,0,4400,8821,-90,9102,8822,42,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3211,"WGS 84 / SCAR IMW SQ39-40",9001,4326,17211,9802,1,0,4400,8821,-90,9102,8822,54,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3212,"WGS 84 / SCAR IMW SQ41-42",9001,4326,17212,9802,1,0,4400,8821,-90,9102,8822,66,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3213,"WGS 84 / SCAR IMW SQ43-44",9001,4326,17213,9802,1,0,4400,8821,-90,9102,8822,78,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3214,"WGS 84 / SCAR IMW SQ45-46",9001,4326,17214,9802,1,0,4400,8821,-90,9102,8822,90,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3215,"WGS 84 / SCAR IMW SQ47-48",9001,4326,17215,9802,1,0,4400,8821,-90,9102,8822,102,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3216,"WGS 84 / SCAR IMW SQ49-50",9001,4326,17216,9802,1,0,4400,8821,-90,9102,8822,114,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3217,"WGS 84 / SCAR IMW SQ51-52",9001,4326,17217,9802,1,0,4400,8821,-90,9102,8822,126,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3218,"WGS 84 / SCAR IMW SQ53-54",9001,4326,17218,9802,1,0,4400,8821,-90,9102,8822,138,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3219,"WGS 84 / SCAR IMW SQ55-56",9001,4326,17219,9802,1,0,4400,8821,-90,9102,8822,150,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3220,"WGS 84 / SCAR IMW SQ57-58",9001,4326,17220,9802,1,0,4400,8821,-90,9102,8822,162,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-3221,"WGS 84 / SCAR IMW SR13-14",9001,4326,17221,9802,1,0,4400,8821,-90,9102,8822,-102,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3222,"WGS 84 / SCAR IMW SR15-16",9001,4326,17222,9802,1,0,4400,8821,-90,9102,8822,-90,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3223,"WGS 84 / SCAR IMW SR17-18",9001,4326,17223,9802,1,0,4400,8821,-90,9102,8822,-78,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3224,"WGS 84 / SCAR IMW SR19-20",9001,4326,17224,9802,1,0,4400,8821,-90,9102,8822,-66,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3225,"WGS 84 / SCAR IMW SR27-28",9001,4326,17225,9802,1,0,4400,8821,-90,9102,8822,-18,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3226,"WGS 84 / SCAR IMW SR29-30",9001,4326,17226,9802,1,0,4400,8821,-90,9102,8822,-6,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3227,"WGS 84 / SCAR IMW SR31-32",9001,4326,17227,9802,1,0,4400,8821,-90,9102,8822,6,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3228,"WGS 84 / SCAR IMW SR33-34",9001,4326,17228,9802,1,0,4400,8821,-90,9102,8822,18,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3229,"WGS 84 / SCAR IMW SR35-36",9001,4326,17229,9802,1,0,4400,8821,-90,9102,8822,30,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3230,"WGS 84 / SCAR IMW SR37-38",9001,4326,17230,9802,1,0,4400,8821,-90,9102,8822,42,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3231,"WGS 84 / SCAR IMW SR39-40",9001,4326,17231,9802,1,0,4400,8821,-90,9102,8822,54,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3232,"WGS 84 / SCAR IMW SR41-42",9001,4326,17232,9802,1,0,4400,8821,-90,9102,8822,66,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3233,"WGS 84 / SCAR IMW SR43-44",9001,4326,17233,9802,1,0,4400,8821,-90,9102,8822,78,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3234,"WGS 84 / SCAR IMW SR45-46",9001,4326,17234,9802,1,0,4400,8821,-90,9102,8822,90,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3235,"WGS 84 / SCAR IMW SR47-48",9001,4326,17235,9802,1,0,4400,8821,-90,9102,8822,102,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3236,"WGS 84 / SCAR IMW SR49-50",9001,4326,17236,9802,1,0,4400,8821,-90,9102,8822,114,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3237,"WGS 84 / SCAR IMW SR51-52",9001,4326,17237,9802,1,0,4400,8821,-90,9102,8822,126,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3238,"WGS 84 / SCAR IMW SR53-54",9001,4326,17238,9802,1,0,4400,8821,-90,9102,8822,138,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3239,"WGS 84 / SCAR IMW SR55-56",9001,4326,17239,9802,1,0,4400,8821,-90,9102,8822,150,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3240,"WGS 84 / SCAR IMW SR57-58",9001,4326,17240,9802,1,0,4400,8821,-90,9102,8822,162,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3241,"WGS 84 / SCAR IMW SR59-60",9001,4326,17241,9802,1,0,4400,8821,-90,9102,8822,174,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-3242,"WGS 84 / SCAR IMW SS04-06",9001,4326,17242,9802,1,0,4400,8821,-90,9102,8822,-153,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3243,"WGS 84 / SCAR IMW SS07-09",9001,4326,17243,9802,1,0,4400,8821,-90,9102,8822,-135,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3244,"WGS 84 / SCAR IMW SS10-12",9001,4326,17244,9802,1,0,4400,8821,-90,9102,8822,-117,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3245,"WGS 84 / SCAR IMW SS13-15",9001,4326,17245,9802,1,0,4400,8821,-90,9102,8822,-99,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3246,"WGS 84 / SCAR IMW SS16-18",9001,4326,17246,9802,1,0,4400,8821,-90,9102,8822,-81,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3247,"WGS 84 / SCAR IMW SS19-21",9001,4326,17247,9802,1,0,4400,8821,-90,9102,8822,-63,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3248,"WGS 84 / SCAR IMW SS25-27",9001,4326,17248,9802,1,0,4400,8821,-90,9102,8822,-27,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3249,"WGS 84 / SCAR IMW SS28-30",9001,4326,17249,9802,1,0,4400,8821,-90,9102,8822,-9,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3250,"WGS 84 / SCAR IMW SS31-33",9001,4326,17250,9802,1,0,4400,8821,-90,9102,8822,9,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3251,"WGS 84 / SCAR IMW SS34-36",9001,4326,17251,9802,1,0,4400,8821,-90,9102,8822,27,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3252,"WGS 84 / SCAR IMW SS37-39",9001,4326,17252,9802,1,0,4400,8821,-90,9102,8822,45,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3253,"WGS 84 / SCAR IMW SS40-42",9001,4326,17253,9802,1,0,4400,8821,-90,9102,8822,63,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3254,"WGS 84 / SCAR IMW SS43-45",9001,4326,17254,9802,1,0,4400,8821,-90,9102,8822,81,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3255,"WGS 84 / SCAR IMW SS46-48",9001,4326,17255,9802,1,0,4400,8821,-90,9102,8822,99,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3256,"WGS 84 / SCAR IMW SS49-51",9001,4326,17256,9802,1,0,4400,8821,-90,9102,8822,117,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3257,"WGS 84 / SCAR IMW SS52-54",9001,4326,17257,9802,1,0,4400,8821,-90,9102,8822,135,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3258,"WGS 84 / SCAR IMW SS55-57",9001,4326,17258,9802,1,0,4400,8821,-90,9102,8822,153,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3259,"WGS 84 / SCAR IMW SS58-60",9001,4326,17259,9802,1,0,4400,8821,-90,9102,8822,171,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-3260,"WGS 84 / SCAR IMW ST01-04",9001,4326,17260,9802,1,0,4400,8821,-90,9102,8822,-168,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3261,"WGS 84 / SCAR IMW ST05-08",9001,4326,17261,9802,1,0,4400,8821,-90,9102,8822,-144,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3262,"WGS 84 / SCAR IMW ST09-12",9001,4326,17262,9802,1,0,4400,8821,-90,9102,8822,-120,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3263,"WGS 84 / SCAR IMW ST13-16",9001,4326,17263,9802,1,0,4400,8821,-90,9102,8822,-96,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3264,"WGS 84 / SCAR IMW ST17-20",9001,4326,17264,9802,1,0,4400,8821,-90,9102,8822,-72,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3265,"WGS 84 / SCAR IMW ST21-24",9001,4326,17265,9802,1,0,4400,8821,-90,9102,8822,-48,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3266,"WGS 84 / SCAR IMW ST25-28",9001,4326,17266,9802,1,0,4400,8821,-90,9102,8822,-24,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3267,"WGS 84 / SCAR IMW ST29-32",9001,4326,17267,9802,1,0,4400,8821,-90,9102,8822,0,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3268,"WGS 84 / SCAR IMW ST33-36",9001,4326,17268,9802,1,0,4400,8821,-90,9102,8822,24,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3269,"WGS 84 / SCAR IMW ST37-40",9001,4326,17269,9802,1,0,4400,8821,-90,9102,8822,48,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3270,"WGS 84 / SCAR IMW ST41-44",9001,4326,17270,9802,1,0,4400,8821,-90,9102,8822,72,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3271,"WGS 84 / SCAR IMW ST45-48",9001,4326,17271,9802,1,0,4400,8821,-90,9102,8822,96,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3272,"WGS 84 / SCAR IMW ST49-52",9001,4326,17272,9802,1,0,4400,8821,-90,9102,8822,120,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3273,"WGS 84 / SCAR IMW ST53-56",9001,4326,17273,9802,1,0,4400,8821,-90,9102,8822,144,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3274,"WGS 84 / SCAR IMW ST57-60",9001,4326,17274,9802,1,0,4400,8821,-90,9102,8822,168,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3275,"WGS 84 / SCAR IMW SU01-05",9001,4326,17275,9829,1,0,4471,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-165,9102,,,,,,,,,
-3276,"WGS 84 / SCAR IMW SU06-10",9001,4326,17276,9829,1,0,4473,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-135,9102,,,,,,,,,
-3277,"WGS 84 / SCAR IMW SU11-15",9001,4326,17277,9829,1,0,4474,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-105,9102,,,,,,,,,
-3278,"WGS 84 / SCAR IMW SU16-20",9001,4326,17278,9829,1,0,4476,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-75,9102,,,,,,,,,
-3279,"WGS 84 / SCAR IMW SU21-25",9001,4326,17279,9829,1,0,4477,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-45,9102,,,,,,,,,
-3280,"WGS 84 / SCAR IMW SU26-30",9001,4326,17280,9829,1,0,4479,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-15,9102,,,,,,,,,
-3281,"WGS 84 / SCAR IMW SU31-35",9001,4326,17281,9829,1,0,4480,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,15,9102,,,,,,,,,
-3282,"WGS 84 / SCAR IMW SU36-40",9001,4326,17282,9829,1,0,4482,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,45,9102,,,,,,,,,
-3283,"WGS 84 / SCAR IMW SU41-45",9001,4326,17283,9829,1,0,4483,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,75,9102,,,,,,,,,
-3284,"WGS 84 / SCAR IMW SU46-50",9001,4326,17284,9829,1,0,4485,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,105,9102,,,,,,,,,
-3285,"WGS 84 / SCAR IMW SU51-55",9001,4326,17285,9829,1,0,4486,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,135,9102,,,,,,,,,
-3286,"WGS 84 / SCAR IMW SU56-60",9001,4326,17286,9829,1,0,4488,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,165,9102,,,,,,,,,
-3287,"WGS 84 / SCAR IMW SV01-10",9001,4326,17287,9829,1,0,4472,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-150,9102,,,,,,,,,
-3288,"WGS 84 / SCAR IMW SV11-20",9001,4326,17288,9829,1,0,4475,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-90,9102,,,,,,,,,
-3289,"WGS 84 / SCAR IMW SV21-30",9001,4326,17289,9829,1,0,4478,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-30,9102,,,,,,,,,
-3290,"WGS 84 / SCAR IMW SV31-40",9001,4326,17290,9829,1,0,4481,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,30,9102,,,,,,,,,
-3291,"WGS 84 / SCAR IMW SV41-50",9001,4326,17291,9829,1,0,4484,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,90,9102,,,,,,,,,
-3292,"WGS 84 / SCAR IMW SV51-60",9001,4326,17292,9829,1,0,4487,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,150,9102,,,,,,,,,
-3293,"WGS 84 / SCAR IMW SW01-60",9001,4326,17293,9829,1,0,4490,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,0,9102,,,,,,,,,
-3294,"WGS 84 / USGS Transantarctic Mountains",9001,4326,17294,9802,1,0,4400,8821,-78,9102,8822,162,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-3295,"Guam 1963 / Yap Islands",9001,4675,15399,9832,1,0,4499,8801,9.324815,9110,8802,138.100748,9110,8806,40000,9001,8807,60000,9001,,,,,,,,,
-3296,"RGPF / UTM zone 5S",9001,4687,16105,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3297,"RGPF / UTM zone 6S",9001,4687,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3298,"RGPF / UTM zone 7S",9001,4687,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3299,"RGPF / UTM zone 8S",9001,4687,16108,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3300,Estonian Coordinate System of 1992,9001,4133,19938,9802,1,0,4530,8821,57.310319415,9110,8822,24,9110,8823,59.2,9110,8824,58,9110,8826,500000,9001,8827,6375000,9001,,,
-3301,Estonian Coordinate System of 1997,9001,4180,19938,9802,1,0,4530,8821,57.310319415,9110,8822,24,9110,8823,59.2,9110,8824,58,9110,8826,500000,9001,8827,6375000,9001,,,
-3302,"IGN63 Hiva Oa / UTM zone 7S",9001,4689,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3303,"Fatu Iva 72 / UTM zone 7S",9001,4688,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3304,"Tahiti 79 / UTM zone 6S",9001,4690,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3305,"Moorea 87 / UTM zone 6S",9001,4691,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3306,"Maupiti 83 / UTM zone 5S",9001,4692,16105,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3307,"Nakhl-e Ghanem / UTM zone 39N",9001,4693,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3308,"GDA94 / NSW Lambert",9001,4283,17364,9802,1,0,4400,8821,-33.25,9102,8822,147,9102,8823,-30.75,9102,8824,-35.75,9102,8826,9300000,9001,8827,4500000,9001,,,
-3309,"NAD27 / California Albers",9001,4267,10420,9822,1,0,4499,8821,0,9102,8822,-120,9102,8823,34,9102,8824,40.5,9102,8826,0,9001,8827,-4000000,9001,,,
-3310,"NAD83 / California Albers",9001,4269,10420,9822,1,0,4499,8821,0,9102,8822,-120,9102,8823,34,9102,8824,40.5,9102,8826,0,9001,8827,-4000000,9001,,,
-3311,"NAD83(HARN) / California Albers",9001,4152,10420,9822,1,0,4499,8821,0,9102,8822,-120,9102,8823,34,9102,8824,40.5,9102,8826,0,9001,8827,-4000000,9001,,,
-3312,"CSG67 / UTM zone 21N",9001,4623,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3313,"RGFG95 / UTM zone 21N",9001,4624,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3314,"Katanga 1955 / Katanga Lambert",9001,4695,17401,9802,1,1,4400,8821,0,9102,8822,26,9102,8823,-6.5,9102,8824,-11.5,9102,8826,0,9001,8827,0,9001,,,
-3315,"Katanga 1955 / Katanga TM",9001,4695,17402,9807,1,1,4400,8801,-9,9102,8802,26,9102,8805,0.9998,9201,8806,0,9001,8807,0,9001,,,,,,
-3316,"Kasai 1953 / Congo TM zone 22",9001,4696,17422,9807,1,0,4400,8801,0,9102,8802,22,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3317,"Kasai 1953 / Congo TM zone 24",9001,4696,17424,9807,1,0,4400,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3318,"IGC 1962 / Congo TM zone 12",9001,4697,17412,9807,1,0,4400,8801,0,9102,8802,12,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3319,"IGC 1962 / Congo TM zone 14",9001,4697,17414,9807,1,0,4400,8801,0,9102,8802,14,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3320,"IGC 1962 / Congo TM zone 16",9001,4697,17416,9807,1,0,4400,8801,0,9102,8802,16,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3321,"IGC 1962 / Congo TM zone 18",9001,4697,17418,9807,1,0,4400,8801,0,9102,8802,18,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3322,"IGC 1962 / Congo TM zone 20",9001,4697,17420,9807,1,0,4400,8801,0,9102,8802,20,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3323,"IGC 1962 / Congo TM zone 22",9001,4697,17422,9807,1,0,4400,8801,0,9102,8802,22,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3324,"IGC 1962 / Congo TM zone 24",9001,4697,17424,9807,1,0,4400,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3325,"IGC 1962 / Congo TM zone 26",9001,4697,17426,9807,1,0,4400,8801,0,9102,8802,26,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3326,"IGC 1962 / Congo TM zone 28",9001,4697,17428,9807,1,0,4400,8801,0,9102,8802,28,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3327,"IGC 1962 / Congo TM zone 30",9001,4697,17430,9807,1,0,4400,8801,0,9102,8802,30,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3328,"Pulkovo 1942(58) / GUGiK-80",9001,4179,18286,9809,1,0,4530,8801,52.1,9110,8802,19.1,9110,8805,0.999714,9201,8806,500000,9001,8807,500000,9001,,,,,,
-3329,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 5",9001,4179,16265,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-3330,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 6",9001,4179,16266,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3331,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 7",9001,4179,16267,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-3332,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 8",9001,4179,16268,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-3333,"Pulkovo 1942(58) / Gauss-Kruger zone 3",9001,4179,16203,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-3334,"Pulkovo 1942(58) / Gauss-Kruger zone 4",9001,4179,16204,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-3335,"Pulkovo 1942(58) / Gauss-Kruger zone 5",9001,4179,16205,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-3336,"IGN 1962 Kerguelen / UTM zone 42S",9001,4698,16142,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3337,"Le Pouce 1934 / Mauritius Grid",9001,4699,19899,9801,1,0,4400,8801,-20.114225,9110,8802,57.311858,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-3338,"NAD83 / Alaska Albers",9001,4269,15021,9822,1,0,4499,8821,50,9102,8822,-154,9102,8823,55,9102,8824,65,9102,8826,0,9001,8827,0,9001,,,
-3339,"IGCB 1955 / Congo TM zone 12",9001,4701,17412,9807,1,0,4400,8801,0,9102,8802,12,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3340,"IGCB 1955 / Congo TM zone 14",9001,4701,17414,9807,1,0,4400,8801,0,9102,8802,14,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3341,"IGCB 1955 / Congo TM zone 16",9001,4701,17416,9807,1,0,4400,8801,0,9102,8802,16,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3342,"IGCB 1955 / UTM zone 33S",9001,4701,16133,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3343,"Mauritania 1999 / UTM zone 28N",9001,4702,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3344,"Mauritania 1999 / UTM zone 29N",9001,4702,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3345,"Mauritania 1999 / UTM zone 30N",9001,4702,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3346,"LKS94 / Lithuania TM",9001,4669,19934,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,0.9998,9201,8806,500000,9001,8807,0,9001,,,,,,
-3347,"NAD83 / Statistics Canada Lambert",9001,4269,19897,9802,1,0,4400,8821,63.390675,9102,8822,-91.52,9110,8823,49,9102,8824,77,9102,8826,6200000,9001,8827,3000000,9001,,,
-3348,"NAD83(CSRS) / Statistics Canada Lambert",9001,4617,19897,9802,1,0,4400,8821,63.390675,9102,8822,-91.52,9110,8823,49,9102,8824,77,9102,8826,6200000,9001,8827,3000000,9001,,,
-3349,"WGS 84 / PDC Mercator",9001,4326,19898,9804,1,1,4400,8801,0,9102,8802,-150,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3350,"Pulkovo 1942 / CS63 zone C0",9001,4284,18450,9807,1,0,4530,8801,0.06,9110,8802,21.57,9110,8805,1,9201,8806,250000,9001,8807,0,9001,,,,,,
-3351,"Pulkovo 1942 / CS63 zone C1",9001,4284,18451,9807,1,0,4530,8801,0.06,9110,8802,24.57,9110,8805,1,9201,8806,1250000,9001,8807,0,9001,,,,,,
-3352,"Pulkovo 1942 / CS63 zone C2",9001,4284,18452,9807,1,0,4530,8801,0.06,9110,8802,27.57,9110,8805,1,9201,8806,2250000,9001,8807,0,9001,,,,,,
-3353,"Mhast (onshore) / UTM zone 32S",9001,4704,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3354,"Mhast (offshore) / UTM zone 32S",9001,4705,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3355,"Egypt Gulf of Suez S-650 TL / Red Belt",9001,4706,18072,9807,1,0,4400,8801,30,9102,8802,31,9102,8805,1,9201,8806,615000,9001,8807,810000,9001,,,,,,
-3356,"Grand Cayman 1959 / UTM zone 17N",9001,4723,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3357,"Little Cayman 1961 / UTM zone 17N",9001,4726,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3358,"NAD83(HARN) / North Carolina",9001,4152,13230,9802,1,0,4499,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,609601.22,9001,8827,0,9001,,,
-3359,"NAD83(HARN) / North Carolina (ftUS)",9002,4152,15346,9802,1,1,4495,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,2000000,9003,8827,0,9003,,,
-3360,"NAD83(HARN) / South Carolina",9001,4152,13930,9802,1,0,4499,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,609600,9001,8827,0,9001,,,
-3361,"NAD83(HARN) / South Carolina (ft)",9002,4152,15355,9802,1,0,4495,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,2000000,9002,8827,0,9002,,,
-3362,"NAD83(HARN) / Pennsylvania North",9001,4152,13731,9802,1,0,4499,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,600000,9001,8827,0,9001,,,
-3363,"NAD83(HARN) / Pennsylvania North (ftUS)",9003,4152,15353,9802,1,0,4497,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,1968500,9003,8827,0,9003,,,
-3364,"NAD83(HARN) / Pennsylvania South",9001,4152,13732,9802,1,0,4499,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,600000,9001,8827,0,9001,,,
-3365,"NAD83(HARN) / Pennsylvania South (ftUS)",9003,4152,15354,9802,1,0,4497,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,1968500,9003,8827,0,9003,,,
-3366,Hong Kong 1963 Grid System,9001,4738,19896,9806,1,1,4500,8801,22.184368,9110,8802,114.10428,9110,8806,132033.92,9005,8807,62565.96,9005,,,,,,,,,
-3367,"IGN Astro 1960 / UTM zone 28N",9001,4700,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3368,"IGN Astro 1960 / UTM zone 29N",9001,4700,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3369,"IGN Astro 1960 / UTM zone 30N",9001,4700,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3370,"NAD27 / UTM zone 59N",9001,4267,16059,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3371,"NAD27 / UTM zone 60N",9001,4267,16060,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3372,"NAD83 / UTM zone 59N",9001,4269,16059,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3373,"NAD83 / UTM zone 60N",9001,4269,16060,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3374,"FD54 / UTM zone 29N",9001,4741,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3375,"GDM2000 / Peninsula RSO",9001,4742,19895,9812,1,0,4400,8806,804671,9001,8807,0,9001,8811,4,9110,8812,102.15,9110,8813,323.013286728,9110,8814,323.07483685,9110,8815,0.99984,9201
-3376,"GDM2000 / East Malaysia BRSO",9001,4742,19894,9812,1,0,4400,8806,0,9001,8807,0,9001,8811,4,9110,8812,115,9110,8813,53.185691582,9110,8814,53.07483685,9110,8815,0.99984,9201
-3377,"GDM2000 / Johor Grid",9001,4742,19893,9806,1,0,4400,8801,2.071804708,9110,8802,103.254057045,9110,8806,-14810.562,9001,8807,8758.32,9001,,,,,,,,,
-3378,"GDM2000 / Sembilan and Melaka Grid",9001,4742,19892,9806,1,0,4400,8801,2.405645149,9110,8802,101.582965815,9110,8806,3673.785,9001,8807,-4240.573,9001,,,,,,,,,
-3379,"GDM2000 / PahangGrid",9001,4742,19891,9806,1,0,4400,8801,3.460979712,9110,8802,102.220587634,9110,8806,-7368.228,9001,8807,6485.858,9001,,,,,,,,,
-3380,"GDM2000 / Selangor Grid",9001,4742,19890,9806,1,0,4400,8801,3.410473658,9110,8802,101.232078849,9110,8806,-34836.161,9001,8807,56464.049,9001,,,,,,,,,
-3381,"GDM2000 / Terengganu Grid",9001,4742,19889,9806,1,0,4400,8801,4.583462672,9110,8802,103.041299225,9110,8806,19594.245,9001,8807,3371.895,9001,,,,,,,,,
-3382,"GDM2000 / Pinang Grid",9001,4742,19888,9806,1,0,4400,8801,5.251746315,9110,8802,100.203975707,9110,8806,-23.414,9001,8807,62.283,9001,,,,,,,,,
-3383,"GDM2000 / Kedah and Perlis Grid",9001,4742,19887,9806,1,0,4400,8801,5.575282177,9110,8802,100.3810936,9110,8806,0,9001,8807,0,9001,,,,,,,,,
-3384,"GDM2000 / Perak Grid",9001,4742,19886,9806,1,0,4400,8801,4.513262688,9110,8802,100.485547811,9110,8806,-1.769,9001,8807,133454.779,9001,,,,,,,,,
-3385,"GDM2000 / Kelantan Grid",9001,4742,19885,9806,1,0,4400,8801,5.582115717,9110,8802,102.174287001,9110,8806,13227.851,9001,8807,8739.894,9001,,,,,,,,,
-3386,"KKJ / Finland zone 0",9001,4123,18180,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-3387,"KKJ / Finland zone 5",9001,4123,18205,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-3388,"Pulkovo 1942 / Caspian Sea Mercator",9001,4284,19884,9805,1,0,4534,8802,51,9102,8806,0,9001,8807,0,9001,8823,42,9102,,,,,,,,,
-3389,"Pulkovo 1942 / 3-degree Gauss-Kruger zone 60",9001,4284,16099,9807,1,0,4530,8801,0,9102,8802,180,9102,8805,1,9201,8806,60500000,9001,8807,0,9001,,,,,,
-3390,"Pulkovo 1995 / 3-degree Gauss-Kruger zone 60",9001,4200,16099,9807,1,0,4530,8801,0,9102,8802,180,9102,8805,1,9201,8806,60500000,9001,8807,0,9001,,,,,,
-3391,"Karbala 1979 / UTM zone 37N",9001,4743,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3392,"Karbala 1979 / UTM zone 38N",9001,4743,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3393,"Karbala 1979 / UTM zone 39N",9001,4743,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3394,"Nahrwan 1934 / Iraq zone",9001,4744,19906,9801,1,0,4400,8801,32.3,9110,8802,45,9110,8805,0.9987864078,9201,8806,1500000,9001,8807,1166200,9001,,,,,,
-3395,"WGS 84 / World Mercator",9001,4326,19883,9804,1,0,4400,8801,0,9102,8802,0,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3396,"PD/83 / 3-degree Gauss-Kruger zone 3",9001,4746,16263,9807,1,0,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-3397,"PD/83 / 3-degree Gauss-Kruger zone 4",9001,4746,16264,9807,1,0,4530,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-3398,"RD/83 / 3-degree Gauss-Kruger zone 4",9001,4745,16264,9807,1,0,4530,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-3399,"RD/83 / 3-degree Gauss-Kruger zone 5",9001,4745,16265,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-3400,"NAD83 / Alberta 10-TM (Forest)",9001,4269,19881,9807,1,0,4400,8801,0,9102,8802,-115,9102,8805,0.9992,9201,8806,500000,9001,8807,0,9001,,,,,,
-3401,"NAD83 / Alberta 10-TM (Resource)",9001,4269,19882,9807,1,0,4400,8801,0,9102,8802,-115,9102,8805,0.9992,9201,8806,0,9001,8807,0,9001,,,,,,
-3402,"NAD83(CSRS) / Alberta 10-TM (Forest)",9001,4617,19881,9807,1,0,4400,8801,0,9102,8802,-115,9102,8805,0.9992,9201,8806,500000,9001,8807,0,9001,,,,,,
-3403,"NAD83(CSRS) / Alberta 10-TM (Resource)",9001,4617,19882,9807,1,0,4400,8801,0,9102,8802,-115,9102,8805,0.9992,9201,8806,0,9001,8807,0,9001,,,,,,
-3404,"NAD83(HARN) / North Carolina (ftUS)",9003,4152,15346,9802,1,0,4497,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,2000000,9003,8827,0,9003,,,
-3405,"VN-2000 / UTM zone 48N",9001,4756,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3406,"VN-2000 / UTM zone 49N",9001,4756,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3407,Hong Kong 1963 Grid System,9005,4738,19896,9806,1,0,4502,8801,22.184368,9110,8802,114.10428,9110,8806,132033.92,9005,8807,62565.96,9005,,,,,,,,,
-3408,NSIDC EASE-Grid North,9001,4053,3897,1027,1,0,4469,8801,90,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3409,NSIDC EASE-Grid South,9001,4053,3898,1027,1,0,4470,8801,-90,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3410,NSIDC EASE-Grid Global,9001,4053,19869,9834,1,0,4499,8802,0,9102,8806,0,9001,8807,0,9001,8823,30,9102,,,,,,,,,
-3411,NSIDC Sea Ice Polar Stereographic North,9001,4054,19865,9829,1,0,4468,8806,0,9001,8807,0,9001,8832,70,9102,8833,-45,9102,,,,,,,,,
-3412,NSIDC Sea Ice Polar Stereographic South,9001,4054,19866,9829,1,0,4470,8806,0,9001,8807,0,9001,8832,-70,9102,8833,0,9102,,,,,,,,,
-3413,"WGS 84 / NSIDC Sea Ice Polar Stereographic North",9001,4326,19865,9829,1,0,4468,8806,0,9001,8807,0,9001,8832,70,9102,8833,-45,9102,,,,,,,,,
-3414,"SVY21 / Singapore TM",9001,4757,19864,9807,1,0,4500,8801,1.22,9110,8802,103.5,9110,8805,1,9201,8806,28001.642,9001,8807,38744.572,9001,,,,,,
-3415,"WGS 72BE / South China Sea Lambert",9001,4324,19863,9802,1,0,4400,8821,21,9102,8822,114,9102,8823,18,9102,8824,24,9102,8826,500000,9001,8827,500000,9001,,,
-3416,"ETRS89 / Austria Lambert",9001,4258,19947,9802,1,0,4530,8821,47.3,9110,8822,13.2,9110,8823,49,9110,8824,46,9110,8826,400000,9001,8827,400000,9001,,,
-3417,"NAD83 / Iowa North (ft US)",9003,4269,15377,9802,1,0,4497,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,4921250,9003,8827,3280833.3333,9003,,,
-3418,"NAD83 / Iowa South (ft US)",9003,4269,15378,9802,1,0,4497,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,1640416.6667,9003,8827,0,9003,,,
-3419,"NAD83 / Kansas North (ft US)",9003,4269,15379,9802,1,0,4497,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,1312333.3333,9003,8827,0,9003,,,
-3420,"NAD83 / Kansas South (ft US)",9003,4269,15380,9802,1,0,4497,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-3421,"NAD83 / Nevada East (ft US)",9003,4269,15381,9807,1,0,4497,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,656166.6667,9003,8807,26246666.6667,9003,,,,,,
-3422,"NAD83 / Nevada Central (ft US)",9003,4269,15382,9807,1,0,4497,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,1640416.6667,9003,8807,19685000,9003,,,,,,
-3423,"NAD83 / Nevada West (ft US)",9003,4269,15383,9807,1,0,4497,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,2624666.6667,9003,8807,13123333.3333,9003,,,,,,
-3424,"NAD83 / New Jersey (ft US)",9003,4269,15384,9807,1,0,4497,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-3425,"NAD83(HARN) / Iowa North (ft US)",9003,4152,15377,9802,1,0,4497,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,4921250,9003,8827,3280833.3333,9003,,,
-3426,"NAD83(HARN) / Iowa South (ft US)",9003,4152,15378,9802,1,0,4497,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,1640416.6667,9003,8827,0,9003,,,
-3427,"NAD83(HARN) / Kansas North (ft US)",9003,4152,15379,9802,1,0,4497,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,1312333.3333,9003,8827,0,9003,,,
-3428,"NAD83(HARN) / Kansas South (ft US)",9003,4152,15380,9802,1,0,4497,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-3429,"NAD83(HARN) / Nevada East (ft US)",9003,4152,15381,9807,1,0,4497,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,656166.6667,9003,8807,26246666.6667,9003,,,,,,
-3430,"NAD83(HARN) / Nevada Central (ft US)",9003,4152,15382,9807,1,0,4497,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,1640416.6667,9003,8807,19685000,9003,,,,,,
-3431,"NAD83(HARN) / Nevada West (ft US)",9003,4152,15383,9807,1,0,4497,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,2624666.6667,9003,8807,13123333.3333,9003,,,,,,
-3432,"NAD83(HARN) / New Jersey (ft US)",9003,4152,15384,9807,1,0,4497,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-3433,"NAD83 / Arkansas North (ftUS)",9003,4269,15385,9802,1,0,4497,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,1312333.3333,9003,8827,0,9003,,,
-3434,"NAD83 / Arkansas South (ftUS)",9003,4269,15386,9802,1,0,4497,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-3435,"NAD83 / Illinois East (ftUS)",9003,4269,15387,9807,1,0,4497,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,984250,9003,8807,0,9003,,,,,,
-3436,"NAD83 / Illinois West (ftUS)",9003,4269,15388,9807,1,0,4497,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,2296583.3333,9003,8807,0,9003,,,,,,
-3437,"NAD83 / New Hampshire (ftUS)",9003,4269,15389,9807,1,0,4497,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,984250,9003,8807,0,9003,,,,,,
-3438,"NAD83 / Rhode Island (ftUS)",9003,4269,15390,9807,1,0,4497,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,328083.3333,9003,8807,0,9003,,,,,,
-3439,"PSD93 / UTM zone 39N",9001,4134,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3440,"PSD93 / UTM zone 40N",9001,4134,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3441,"NAD83(HARN) / Arkansas North (ftUS)",9003,4152,15385,9802,1,0,4497,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,1312333.3333,9003,8827,0,9003,,,
-3442,"NAD83(HARN) / Arkansas South (ftUS)",9003,4152,15386,9802,1,0,4497,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-3443,"NAD83(HARN) / Illinois East (ftUS)",9003,4152,15387,9807,1,0,4497,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,984250,9003,8807,0,9003,,,,,,
-3444,"NAD83(HARN) / Illinois West (ftUS)",9003,4152,15388,9807,1,0,4497,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,2296583.3333,9003,8807,0,9003,,,,,,
-3445,"NAD83(HARN) / New Hampshire (ftUS)",9003,4152,15389,9807,1,0,4497,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,984250,9003,8807,0,9003,,,,,,
-3446,"NAD83(HARN) / Rhode Island (ftUS)",9003,4152,15390,9807,1,0,4497,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,328083.3333,9003,8807,0,9003,,,,,,
-3447,"ETRS89 / Belgian Lambert 2005",9001,4258,19862,9802,1,0,4499,8821,50.4752134,9110,8822,4.2133177,9110,8823,49.5,9110,8824,51.1,9110,8826,150328,9001,8827,166262,9001,,,
-3448,"JAD2001 / Jamaica Metric Grid",9001,4758,19860,9801,1,0,4400,8801,18,9102,8802,-77,9102,8805,1,9201,8806,750000,9001,8807,650000,9001,,,,,,
-3449,"JAD2001 / UTM zone 17N",9001,4758,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3450,"JAD2001 / UTM zone 18N",9001,4758,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3451,"NAD83 / Louisiana North (ftUS)",9003,4269,15391,9802,1,0,4497,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3452,"NAD83 / Louisiana South (ftUS)",9003,4269,15392,9802,1,0,4497,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3453,"NAD83 / Louisiana Offshore (ftUS)",9003,4269,15393,9802,1,0,4497,8821,25.3,9110,8822,-91.2,9110,8823,27.5,9110,8824,26.1,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3454,"NAD83 / South Dakota North (ftUS)",9003,4269,15395,9802,1,0,4497,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,1968500,9003,8827,0,9003,,,
-3455,"NAD83 / South Dakota South (ftUS)",9003,4269,15395,9802,1,0,4497,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,1968500,9003,8827,0,9003,,,
-3456,"NAD83(HARN) / Louisiana North (ftUS)",9003,4152,15391,9802,1,0,4497,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3457,"NAD83(HARN) / Louisiana South (ftUS)",9003,4152,15392,9802,1,0,4497,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3458,"NAD83(HARN) / South Dakota North (ftUS)",9003,4152,15394,9802,1,0,4497,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,1968500,9003,8827,0,9003,,,
-3459,"NAD83(HARN) / South Dakota South (ftUS)",9003,4152,15395,9802,1,0,4497,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,1968500,9003,8827,0,9003,,,
-3460,"Fiji 1986 / Fiji Map Grid",9001,4720,19859,9807,1,0,4400,8801,-17,9110,8802,178.45,9110,8805,0.99985,9201,8806,2000000,9001,8807,4000000,9001,,,,,,
-3461,"Dabola 1981 / UTM zone 28N",9001,4155,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3462,"Dabola 1981 / UTM zone 29N",9001,4155,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3463,"NAD83 / Maine CS2000 Central",9001,4269,11854,9807,1,0,4499,8801,43.3,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-3464,"NAD83(HARN) / Maine CS2000 Central",9001,4152,11854,9807,1,0,4499,8801,43.3,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-3465,"NAD83(NSRS2007) / Alabama East",9001,4759,10131,9807,1,0,4499,8801,30.3,9110,8802,-85.5,9110,8805,0.99996,9201,8806,200000,9001,8807,0,9001,,,,,,
-3466,"NAD83(NSRS2007) / Alabama West",9001,4759,10132,9807,1,0,4499,8801,30,9110,8802,-87.3,9110,8805,0.999933333,9201,8806,600000,9001,8807,0,9001,,,,,,
-3467,"NAD83(NSRS2007) / Alaska Albers",9001,4759,15021,9822,1,0,4499,8821,50,9102,8822,-154,9102,8823,55,9102,8824,65,9102,8826,0,9001,8827,0,9001,,,
-3468,"NAD83(NSRS2007) / Alaska zone 1",9001,4759,15031,9812,1,0,4499,8806,5000000,9001,8807,-5000000,9001,8811,57,9110,8812,-133.4,9110,8813,323.07483685,9110,8814,323.07483685,9110,8815,0.9999,9201
-3469,"NAD83(NSRS2007) / Alaska zone 2",9001,4759,15032,9807,1,0,4499,8801,54,9102,8802,-142,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3470,"NAD83(NSRS2007) / Alaska zone 3",9001,4759,15033,9807,1,0,4499,8801,54,9102,8802,-146,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3471,"NAD83(NSRS2007) / Alaska zone 4",9001,4759,15034,9807,1,0,4499,8801,54,9102,8802,-150,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3472,"NAD83(NSRS2007) / Alaska zone 5",9001,4759,15035,9807,1,0,4499,8801,54,9102,8802,-154,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3473,"NAD83(NSRS2007) / Alaska zone 6",9001,4759,15036,9807,1,0,4499,8801,54,9102,8802,-158,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3474,"NAD83(NSRS2007) / Alaska zone 7",9001,4759,15037,9807,1,0,4499,8801,54,9102,8802,-162,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3475,"NAD83(NSRS2007) / Alaska zone 8",9001,4759,15038,9807,1,0,4499,8801,54,9102,8802,-166,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3476,"NAD83(NSRS2007) / Alaska zone 9",9001,4759,15039,9807,1,0,4499,8801,54,9102,8802,-170,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3477,"NAD83(NSRS2007) / Alaska zone 10",9001,4759,15040,9802,1,0,4499,8821,51,9110,8822,-176,9110,8823,53.5,9110,8824,51.5,9110,8826,1000000,9001,8827,0,9001,,,
-3478,"NAD83(NSRS2007) / Arizona Central",9001,4759,10232,9807,1,0,4499,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-3479,"NAD83(NSRS2007) / Arizona Central (ft)",9002,4759,15305,9807,1,0,4495,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-3480,"NAD83(NSRS2007) / Arizona East",9001,4759,10231,9807,1,0,4499,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-3481,"NAD83(NSRS2007) / Arizona East (ft)",9002,4759,15304,9807,1,0,4495,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-3482,"NAD83(NSRS2007) / Arizona West",9001,4759,10233,9807,1,0,4499,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,213360,9001,8807,0,9001,,,,,,
-3483,"NAD83(NSRS2007) / Arizona West (ft)",9002,4759,15306,9807,1,0,4495,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,700000,9002,8807,0,9002,,,,,,
-3484,"NAD83(NSRS2007) / Arkansas North",9001,4759,10331,9802,1,0,4499,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,400000,9001,8827,0,9001,,,
-3485,"NAD83(NSRS2007) / Arkansas North (ftUS)",9003,4759,15385,9802,1,0,4497,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,1312333.3333,9003,8827,0,9003,,,
-3486,"NAD83(NSRS2007) / Arkansas South",9001,4759,10332,9802,1,0,4499,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,400000,9001,8827,400000,9001,,,
-3487,"NAD83(NSRS2007) / Arkansas South (ftUS)",9003,4759,15386,9802,1,0,4497,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-3488,"NAD83(NSRS2007) / California Albers",9001,4759,10420,9822,1,0,4499,8821,0,9102,8822,-120,9102,8823,34,9102,8824,40.5,9102,8826,0,9001,8827,-4000000,9001,,,
-3489,"NAD83(NSRS2007) / California zone 1",9001,4759,10431,9802,1,0,4499,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,2000000,9001,8827,500000,9001,,,
-3490,"NAD83(NSRS2007) / California zone 1 (ftUS)",9003,4759,15307,9802,1,0,4497,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-3491,"NAD83(NSRS2007) / California zone 2",9001,4759,10432,9802,1,0,4499,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,2000000,9001,8827,500000,9001,,,
-3492,"NAD83(NSRS2007) / California zone 2 (ftUS)",9003,4759,15308,9802,1,0,4497,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-3493,"NAD83(NSRS2007) / California zone 3",9001,4759,10433,9802,1,0,4499,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,2000000,9001,8827,500000,9001,,,
-3494,"NAD83(NSRS2007) / California zone 3 (ftUS)",9003,4759,15309,9802,1,0,4497,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-3495,"NAD83(NSRS2007) / California zone 4",9001,4759,10434,9802,1,0,4499,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,2000000,9001,8827,500000,9001,,,
-3496,"NAD83(NSRS2007) / California zone 4 (ftUS)",9003,4759,15310,9802,1,0,4497,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-3497,"NAD83(NSRS2007) / California zone 5",9001,4759,10435,9802,1,0,4499,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,2000000,9001,8827,500000,9001,,,
-3498,"NAD83(NSRS2007) / California zone 5 (ftUS)",9003,4759,15311,9802,1,0,4497,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-3499,"NAD83(NSRS2007) / California zone 6",9001,4759,10436,9802,1,0,4499,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,2000000,9001,8827,500000,9001,,,
-3500,"NAD83(NSRS2007) / California zone 6 (ftUS)",9003,4759,15312,9802,1,0,4497,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-3501,"NAD83(NSRS2007) / Colorado Central",9001,4759,10532,9802,1,0,4499,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-3502,"NAD83(NSRS2007) / Colorado Central (ftUS)",9003,4759,15314,9802,1,0,4497,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,3000000,9003,8827,1000000,9003,,,
-3503,"NAD83(NSRS2007) / Colorado North",9001,4759,10531,9802,1,0,4499,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-3504,"NAD83(NSRS2007) / Colorado North (ftUS)",9003,4759,15313,9802,1,0,4497,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,3000000,9003,8827,1000000,9003,,,
-3505,"NAD83(NSRS2007) / Colorado South",9001,4759,10533,9802,1,0,4499,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-3506,"NAD83(NSRS2007) / Colorado South (ftUS)",9003,4759,15315,9802,1,0,4497,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,3000000,9003,8827,1000000,9003,,,
-3507,"NAD83(NSRS2007) / Connecticut",9001,4759,10630,9802,1,0,4499,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,304800.6096,9001,8827,152400.3048,9001,,,
-3508,"NAD83(NSRS2007) / Connecticut (ftUS)",9003,4759,15316,9802,1,0,4497,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,1000000,9003,8827,500000,9003,,,
-3509,"NAD83(NSRS2007) / Delaware",9001,4759,10730,9807,1,0,4499,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,200000,9001,8807,0,9001,,,,,,
-3510,"NAD83(NSRS2007) / Delaware (ftUS)",9003,4759,15317,9807,1,0,4497,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-3511,"NAD83(NSRS2007) / Florida East",9001,4759,10931,9807,1,0,4499,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-3512,"NAD83(NSRS2007) / Florida East (ftUS)",9003,4759,15318,9807,1,0,4497,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-3513,"NAD83(NSRS2007) / Florida GDL Albers",9001,4759,10934,9822,1,0,4499,8821,24,9110,8822,-84,9110,8823,24,9110,8824,31.3,9110,8826,400000,9001,8827,0,9001,,,
-3514,"NAD83(NSRS2007) / Florida North",9001,4759,10933,9802,1,0,4499,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,600000,9001,8827,0,9001,,,
-3515,"NAD83(NSRS2007) / Florida North (ftUS)",9003,4759,15320,9802,1,0,4497,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,1968500,9003,8827,0,9003,,,
-3516,"NAD83(NSRS2007) / Florida West",9001,4759,10932,9807,1,0,4499,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-3517,"NAD83(NSRS2007) / Florida West (ftUS)",9003,4759,15319,9807,1,0,4497,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-3518,"NAD83(NSRS2007) / Georgia East",9001,4759,11031,9807,1,0,4499,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-3519,"NAD83(NSRS2007) / Georgia East (ftUS)",9003,4759,15321,9807,1,0,4497,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-3520,"NAD83(NSRS2007) / Georgia West",9001,4759,11032,9807,1,0,4499,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,700000,9001,8807,0,9001,,,,,,
-3521,"NAD83(NSRS2007) / Georgia West (ftUS)",9003,4759,15322,9807,1,0,4497,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-3522,"NAD83(NSRS2007) / Idaho Central",9001,4759,11132,9807,1,0,4499,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,500000,9001,8807,0,9001,,,,,,
-3523,"NAD83(NSRS2007) / Idaho Central (ftUS)",9003,4759,15324,9807,1,0,4497,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-3524,"NAD83(NSRS2007) / Idaho East",9001,4759,11131,9807,1,0,4499,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,200000,9001,8807,0,9001,,,,,,
-3525,"NAD83(NSRS2007) / Idaho East (ftUS)",9003,4759,15323,9807,1,0,4497,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-3526,"NAD83(NSRS2007) / Idaho West",9001,4759,11133,9807,1,0,4499,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,800000,9001,8807,0,9001,,,,,,
-3527,"NAD83(NSRS2007) / Idaho West (ftUS)",9003,4759,15325,9807,1,0,4497,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,2624666.667,9003,8807,0,9003,,,,,,
-3528,"NAD83(NSRS2007) / Illinois East",9001,4759,11231,9807,1,0,4499,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,300000,9001,8807,0,9001,,,,,,
-3529,"NAD83(NSRS2007) / Illinois East (ftUS)",9003,4759,15387,9807,1,0,4497,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,984250,9003,8807,0,9003,,,,,,
-3530,"NAD83(NSRS2007) / Illinois West",9001,4759,11232,9807,1,0,4499,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,700000,9001,8807,0,9001,,,,,,
-3531,"NAD83(NSRS2007) / Illinois West (ftUS)",9003,4759,15388,9807,1,0,4497,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,2296583.3333,9003,8807,0,9003,,,,,,
-3532,"NAD83(NSRS2007) / Indiana East",9001,4759,11331,9807,1,0,4499,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,100000,9001,8807,250000,9001,,,,,,
-3533,"NAD83(NSRS2007) / Indiana East (ftUS)",9003,4759,15372,9807,1,0,4497,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,820208.333,9003,,,,,,
-3534,"NAD83(NSRS2007) / Indiana West",9001,4759,11332,9807,1,0,4499,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,900000,9001,8807,250000,9001,,,,,,
-3535,"NAD83(NSRS2007) / Indiana West (ftUS)",9003,4759,15373,9807,1,0,4497,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,820208.333,9003,,,,,,
-3536,"NAD83(NSRS2007) / Iowa North",9001,4759,11431,9802,1,0,4499,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,1500000,9001,8827,1000000,9001,,,
-3537,"NAD83(NSRS2007) / Iowa North (ft US)",9003,4759,15377,9802,1,0,4497,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,4921250,9003,8827,3280833.3333,9003,,,
-3538,"NAD83(NSRS2007) / Iowa South",9001,4759,11432,9802,1,0,4499,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,500000,9001,8827,0,9001,,,
-3539,"NAD83(NSRS2007) / Iowa South (ft US)",9003,4759,15378,9802,1,0,4497,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,1640416.6667,9003,8827,0,9003,,,
-3540,"NAD83(NSRS2007) / Kansas North",9001,4759,11531,9802,1,0,4499,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,400000,9001,8827,0,9001,,,
-3541,"NAD83(NSRS2007) / Kansas North (ft US)",9003,4759,15379,9802,1,0,4497,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,1312333.3333,9003,8827,0,9003,,,
-3542,"NAD83(NSRS2007) / Kansas South",9001,4759,11532,9802,1,0,4499,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,400000,9001,8827,400000,9001,,,
-3543,"NAD83(NSRS2007) / Kansas South (ft US)",9003,4759,15380,9802,1,0,4497,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-3544,"NAD83(NSRS2007) / Kentucky North",9001,4759,15303,9802,1,0,4499,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,500000,9001,8827,0,9001,,,
-3545,"NAD83(NSRS2007) / Kentucky North (ftUS)",9003,4759,15328,9802,1,0,4497,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,1640416.667,9003,8827,0,9003,,,
-3546,"NAD83(NSRS2007) / Kentucky Single Zone",9001,4759,11630,9802,1,0,4499,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,1500000,9001,8827,1000000,9001,,,
-3547,"NAD83(NSRS2007) / Kentucky Single Zone (ftUS)",9003,4759,15375,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,4921250,9003,8827,3280833.333,9003,,,
-3548,"NAD83(NSRS2007) / Kentucky South",9001,4759,11632,9802,1,0,4499,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,500000,9001,8827,500000,9001,,,
-3549,"NAD83(NSRS2007) / Kentucky South (ftUS)",9003,4759,15329,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,1640416.667,9003,8827,1640416.667,9003,,,
-3550,"NAD83(NSRS2007) / Louisiana North",9001,4759,11731,9802,1,0,4499,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,1000000,9001,8827,0,9001,,,
-3551,"NAD83(NSRS2007) / Louisiana North (ftUS)",9003,4759,15391,9802,1,0,4497,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3552,"NAD83(NSRS2007) / Louisiana South",9001,4759,11732,9802,1,0,4499,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,1000000,9001,8827,0,9001,,,
-3553,"NAD83(NSRS2007) / Louisiana South (ftUS)",9003,4759,15392,9802,1,0,4497,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,3280833.3333,9003,8827,0,9003,,,
-3554,"NAD83(NSRS2007) / Maine CS2000 Central",9001,4759,11854,9807,1,0,4499,8801,43.3,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-3555,"NAD83(NSRS2007) / Maine CS2000 East",9001,4759,11851,9807,1,0,4499,8801,43.5,9110,8802,-67.523,9110,8805,0.99998,9201,8806,700000,9001,8807,0,9001,,,,,,
-3556,"NAD83(NSRS2007) / Maine CS2000 West",9001,4759,11853,9807,1,0,4499,8801,42.5,9110,8802,-70.223,9110,8805,0.99998,9201,8806,300000,9001,8807,0,9001,,,,,,
-3557,"NAD83(NSRS2007) / Maine East",9001,4759,11831,9807,1,0,4499,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,300000,9001,8807,0,9001,,,,,,
-3558,"NAD83(NSRS2007) / Maine West",9001,4759,11832,9807,1,0,4499,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,900000,9001,8807,0,9001,,,,,,
-3559,"NAD83(NSRS2007) / Maryland",9001,4759,11930,9802,1,0,4499,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,400000,9001,8827,0,9001,,,
-3560,"NAD83 / Utah North (ftUS)",9003,4269,15297,9802,0,0,4497,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640416.6667,9003,8827,3280833.3333,9003,,,
-3561,"Old Hawaiian / Hawaii zone 1",9003,4135,15101,9807,1,0,4497,8801,18.5,9110,8802,-155.3,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-3562,"Old Hawaiian / Hawaii zone 2",9003,4135,15102,9807,1,0,4497,8801,20.2,9110,8802,-156.4,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-3563,"Old Hawaiian / Hawaii zone 3",9003,4135,15103,9807,1,0,4497,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,500000,9003,8807,0,9003,,,,,,
-3564,"Old Hawaiian / Hawaii zone 4",9003,4135,15104,9807,1,0,4497,8801,21.5,9110,8802,-159.3,9110,8805,0.99999,9201,8806,500000,9003,8807,0,9003,,,,,,
-3565,"Old Hawaiian / Hawaii zone 5",9003,4135,15105,9807,1,0,4497,8801,21.4,9110,8802,-160.1,9110,8805,1,9201,8806,500000,9003,8807,0,9003,,,,,,
-3566,"NAD83 / Utah Central (ftUS)",9003,4269,15298,9802,0,0,4497,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640416.6667,9003,8827,6561666.6667,9003,,,
-3567,"NAD83 / Utah South (ftUS)",9003,4269,15299,9802,0,0,4497,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640416.6667,9003,8827,9842500,9003,,,
-3568,"NAD83(HARN) / Utah North (ftUS)",9003,4152,15297,9802,0,0,4497,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640416.6667,9003,8827,3280833.3333,9003,,,
-3569,"NAD83(HARN) / Utah Central (ftUS)",9003,4152,15298,9802,0,0,4497,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640416.6667,9003,8827,6561666.6667,9003,,,
-3570,"NAD83(HARN) / Utah South (ftUS)",9003,4152,15299,9802,0,0,4497,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640416.6667,9003,8827,9842500,9003,,,
-3571,"WGS 84 / North Pole LAEA Bering Sea",9001,4326,17295,9820,1,0,4464,8801,90,9102,8802,180,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3572,"WGS 84 / North Pole LAEA Alaska",9001,4326,17296,9820,1,0,4467,8801,90,9102,8802,-150,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3573,"WGS 84 / North Pole LAEA Canada",9001,4326,17297,9820,1,0,4466,8801,90,9102,8802,-100,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3574,"WGS 84 / North Pole LAEA Atlantic",9001,4326,17298,9820,1,0,4465,8801,90,9102,8802,-40,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3575,"WGS 84 / North Pole LAEA Europe",9001,4326,17299,9820,1,0,4463,8801,90,9102,8802,10,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3576,"WGS 84 / North Pole LAEA Russia",9001,4326,17300,9820,1,0,4462,8801,90,9102,8802,90,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3577,"GDA94 / Australian Albers",9001,4283,17365,9822,1,0,4400,8821,0,9102,8822,132,9102,8823,-18,9102,8824,-36,9102,8826,0,9001,8827,0,9001,,,
-3578,"NAD83 / Yukon Albers",9001,4269,19858,9822,1,0,4400,8821,59,9110,8822,-132.3,9110,8823,61.4,9110,8824,68,9110,8826,500000,9001,8827,500000,9001,,,
-3579,"NAD83(CSRS) / Yukon Albers",9001,4617,19858,9822,1,0,4400,8821,59,9110,8822,-132.3,9110,8823,61.4,9110,8824,68,9110,8826,500000,9001,8827,500000,9001,,,
-3580,"NAD83 / NWT Lambert",9001,4269,19857,9802,1,0,4400,8821,0,9102,8822,-112,9102,8823,62,9102,8824,70,9102,8826,0,9001,8827,0,9001,,,
-3581,"NAD83(CSRS) / NWT Lambert",9001,4617,19857,9802,1,0,4400,8821,0,9102,8822,-112,9102,8823,62,9102,8824,70,9102,8826,0,9001,8827,0,9001,,,
-3582,"NAD83(NSRS2007) / Maryland (ftUS)",9003,4759,15330,9802,1,0,4497,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,1312333.333,9003,8827,0,9003,,,
-3583,"NAD83(NSRS2007) / Massachusetts Island",9001,4759,12032,9802,1,0,4499,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,500000,9001,8827,0,9001,,,
-3584,"NAD83(NSRS2007) / Massachusetts Island (ftUS)",9003,4759,15332,9802,1,0,4497,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,1640416.667,9003,8827,0,9003,,,
-3585,"NAD83(NSRS2007) / Massachusetts Mainland",9001,4759,12031,9802,1,0,4499,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,200000,9001,8827,750000,9001,,,
-3586,"NAD83(NSRS2007) / Massachusetts Mainland (ftUS)",9003,4759,15331,9802,1,0,4497,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,656166.667,9003,8827,2460625,9003,,,
-3587,"NAD83(NSRS2007) / Michigan Central",9001,4759,12142,9802,1,0,4499,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,6000000,9001,8827,0,9001,,,
-3588,"NAD83(NSRS2007) / Michigan Central (ft)",9002,4759,15334,9802,1,0,4495,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,19685039.37,9002,8827,0,9002,,,
-3589,"NAD83(NSRS2007) / Michigan North",9001,4759,12141,9802,1,0,4499,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,8000000,9001,8827,0,9001,,,
-3590,"NAD83(NSRS2007) / Michigan North (ft)",9002,4759,15333,9802,1,0,4495,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,26246719.16,9002,8827,0,9002,,,
-3591,"NAD83(NSRS2007) / Michigan Oblique Mercator",9001,4759,12150,9812,1,0,4499,8806,2546731.496,9001,8807,-4354009.816,9001,8811,45.1833,9110,8812,-86,9110,8813,337.25556,9102,8814,337.25556,9102,8815,0.9996,9201
-3592,"NAD83(NSRS2007) / Michigan South",9001,4759,12143,9802,1,0,4499,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,4000000,9001,8827,0,9001,,,
-3593,"NAD83(NSRS2007) / Michigan South (ft)",9002,4759,15335,9802,1,0,4495,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,13123359.58,9002,8827,0,9002,,,
-3594,"NAD83(NSRS2007) / Minnesota Central",9001,4759,12232,9802,1,0,4499,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,800000,9001,8827,100000,9001,,,
-3595,"NAD83(NSRS2007) / Minnesota North",9001,4759,12231,9802,1,0,4499,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,800000,9001,8827,100000,9001,,,
-3596,"NAD83(NSRS2007) / Minnesota South",9001,4759,12233,9802,1,0,4499,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,800000,9001,8827,100000,9001,,,
-3597,"NAD83(NSRS2007) / Mississippi East",9001,4759,12331,9807,1,0,4499,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,300000,9001,8807,0,9001,,,,,,
-3598,"NAD83(NSRS2007) / Mississippi East (ftUS)",9003,4759,15336,9807,1,0,4497,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,984250,9003,8807,0,9003,,,,,,
-3599,"NAD83(NSRS2007) / Mississippi West",9001,4759,12332,9807,1,0,4499,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,700000,9001,8807,0,9001,,,,,,
-3600,"NAD83(NSRS2007) / Mississippi West (ftUS)",9003,4759,15337,9807,1,0,4497,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-3601,"NAD83(NSRS2007) / Missouri Central",9001,4759,12432,9807,1,0,4499,8801,35.5,9110,8802,-92.3,9110,8805,0.999933333,9201,8806,500000,9001,8807,0,9001,,,,,,
-3602,"NAD83(NSRS2007) / Missouri East",9001,4759,12431,9807,1,0,4499,8801,35.5,9110,8802,-90.3,9110,8805,0.999933333,9201,8806,250000,9001,8807,0,9001,,,,,,
-3603,"NAD83(NSRS2007) / Missouri West",9001,4759,12433,9807,1,0,4499,8801,36.1,9110,8802,-94.3,9110,8805,0.999941177,9201,8806,850000,9001,8807,0,9001,,,,,,
-3604,"NAD83(NSRS2007) / Montana",9001,4759,12530,9802,1,0,4499,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,600000,9001,8827,0,9001,,,
-3605,"NAD83(NSRS2007) / Montana (ft)",9002,4759,15338,9802,1,0,4495,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,1968503.937,9002,8827,0,9002,,,
-3606,"NAD83(NSRS2007) / Nebraska",9001,4759,12630,9802,1,0,4499,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,500000,9001,8827,0,9001,,,
-3607,"NAD83(NSRS2007) / Nevada Central",9001,4759,12732,9807,1,0,4499,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,500000,9001,8807,6000000,9001,,,,,,
-3608,"NAD83(NSRS2007) / Nevada Central (ft US)",9003,4759,15382,9807,1,0,4497,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,1640416.6667,9003,8807,19685000,9003,,,,,,
-3609,"NAD83(NSRS2007) / Nevada East",9001,4759,12731,9807,1,0,4499,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,200000,9001,8807,8000000,9001,,,,,,
-3610,"NAD83(NSRS2007) / Nevada East (ft US)",9003,4759,15381,9807,1,0,4497,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,656166.6667,9003,8807,26246666.6667,9003,,,,,,
-3611,"NAD83(NSRS2007) / Nevada West",9001,4759,12733,9807,1,0,4499,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,800000,9001,8807,4000000,9001,,,,,,
-3612,"NAD83(NSRS2007) / Nevada West (ft US)",9003,4759,15383,9807,1,0,4497,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,2624666.6667,9003,8807,13123333.3333,9003,,,,,,
-3613,"NAD83(NSRS2007) / New Hampshire",9001,4759,12830,9807,1,0,4499,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,300000,9001,8807,0,9001,,,,,,
-3614,"NAD83(NSRS2007) / New Hampshire (ftUS)",9003,4759,15389,9807,1,0,4497,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,984250,9003,8807,0,9003,,,,,,
-3615,"NAD83(NSRS2007) / New Jersey",9001,4759,12930,9807,1,0,4499,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-3616,"NAD83(NSRS2007) / New Jersey (ft US)",9003,4759,15384,9807,1,0,4497,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-3617,"NAD83(NSRS2007) / New Mexico Central",9001,4759,13032,9807,1,0,4499,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3618,"NAD83(NSRS2007) / New Mexico Central (ftUS)",9003,4759,15340,9807,1,0,4497,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-3619,"NAD83(NSRS2007) / New Mexico East",9001,4759,13031,9807,1,0,4499,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,165000,9001,8807,0,9001,,,,,,
-3620,"NAD83(NSRS2007) / New Mexico East (ftUS)",9003,4759,15339,9807,1,0,4497,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,541337.5,9003,8807,0,9003,,,,,,
-3621,"NAD83(NSRS2007) / New Mexico West",9001,4759,13033,9807,1,0,4499,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,830000,9001,8807,0,9001,,,,,,
-3622,"NAD83(NSRS2007) / New Mexico West (ftUS)",9003,4759,15341,9807,1,0,4497,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,2723091.667,9003,8807,0,9003,,,,,,
-3623,"NAD83(NSRS2007) / New York Central",9001,4759,13132,9807,1,0,4499,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,250000,9001,8807,0,9001,,,,,,
-3624,"NAD83(NSRS2007) / New York Central (ftUS)",9003,4759,15343,9807,1,0,4497,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,820208.333,9003,8807,0,9003,,,,,,
-3625,"NAD83(NSRS2007) / New York East",9001,4759,13131,9807,1,0,4499,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-3626,"NAD83(NSRS2007) / New York East (ftUS)",9003,4759,15342,9807,1,0,4497,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-3627,"NAD83(NSRS2007) / New York Long Island",9001,4759,13134,9802,1,0,4499,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,300000,9001,8827,0,9001,,,
-3628,"NAD83(NSRS2007) / New York Long Island (ftUS)",9003,4759,15345,9802,1,0,4497,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,984250,9003,8827,0,9003,,,
-3629,"NAD83(NSRS2007) / New York West",9001,4759,13133,9807,1,0,4499,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,350000,9001,8807,0,9001,,,,,,
-3630,"NAD83(NSRS2007) / New York West (ftUS)",9003,4759,15344,9807,1,0,4497,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,1148291.667,9003,8807,0,9003,,,,,,
-3631,"NAD83(NSRS2007) / North Carolina",9001,4759,13230,9802,1,0,4499,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,609601.22,9001,8827,0,9001,,,
-3632,"NAD83(NSRS2007) / North Carolina (ftUS)",9003,4759,15346,9802,1,0,4497,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,2000000,9003,8827,0,9003,,,
-3633,"NAD83(NSRS2007) / North Dakota North",9001,4759,13331,9802,1,0,4499,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,600000,9001,8827,0,9001,,,
-3634,"NAD83(NSRS2007) / North Dakota North (ft)",9002,4759,15347,9802,1,0,4495,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,1968503.937,9002,8827,0,9002,,,
-3635,"NAD83(NSRS2007) / North Dakota South",9001,4759,13332,9802,1,0,4499,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,600000,9001,8827,0,9001,,,
-3636,"NAD83(NSRS2007) / North Dakota South (ft)",9002,4759,15348,9802,1,0,4495,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,1968503.937,9002,8827,0,9002,,,
-3637,"NAD83(NSRS2007) / Ohio North",9001,4759,13431,9802,1,0,4499,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,600000,9001,8827,0,9001,,,
-3638,"NAD83(NSRS2007) / Ohio South",9001,4759,13432,9802,1,0,4499,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,600000,9001,8827,0,9001,,,
-3639,"NAD83(NSRS2007) / Oklahoma North",9001,4759,13531,9802,1,0,4499,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,600000,9001,8827,0,9001,,,
-3640,"NAD83(NSRS2007) / Oklahoma North (ftUS)",9003,4759,15349,9802,1,0,4497,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,1968500,9003,8827,0,9003,,,
-3641,"NAD83(NSRS2007) / Oklahoma South",9001,4759,13532,9802,1,0,4499,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,600000,9001,8827,0,9001,,,
-3642,"NAD83(NSRS2007) / Oklahoma South (ftUS)",9003,4759,15350,9802,1,0,4497,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,1968500,9003,8827,0,9003,,,
-3643,"NAD83(NSRS2007) / Oregon Lambert",9001,4759,13633,9802,1,0,4499,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,400000,9001,8827,0,9001,,,
-3644,"NAD83(NSRS2007) / Oregon Lambert (ft)",9002,4759,15374,9802,1,0,4495,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,1312335.958,9002,8827,0,9002,,,
-3645,"NAD83(NSRS2007) / Oregon North",9001,4759,13631,9802,1,0,4499,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,2500000,9001,8827,0,9001,,,
-3646,"NAD83(NSRS2007) / Oregon North (ft)",9002,4759,15351,9802,1,0,4495,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,8202099.738,9002,8827,0,9002,,,
-3647,"NAD83(NSRS2007) / Oregon South",9001,4759,13632,9802,1,0,4499,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,1500000,9001,8827,0,9001,,,
-3648,"NAD83(NSRS2007) / Oregon South (ft)",9002,4759,15352,9802,1,0,4495,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,4921259.843,9002,8827,0,9002,,,
-3649,"NAD83(NSRS2007) / Pennsylvania North",9001,4759,13731,9802,1,0,4499,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,600000,9001,8827,0,9001,,,
-3650,"NAD83(NSRS2007) / Pennsylvania North (ftUS)",9003,4759,15353,9802,1,0,4497,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,1968500,9003,8827,0,9003,,,
-3651,"NAD83(NSRS2007) / Pennsylvania South",9001,4759,13732,9802,1,0,4499,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,600000,9001,8827,0,9001,,,
-3652,"NAD83(NSRS2007) / Pennsylvania South (ftUS)",9003,4759,15354,9802,1,0,4497,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,1968500,9003,8827,0,9003,,,
-3653,"NAD83(NSRS2007) / Rhode Island",9001,4759,13830,9807,1,0,4499,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,100000,9001,8807,0,9001,,,,,,
-3654,"NAD83(NSRS2007) / Rhode Island (ftUS)",9003,4759,15390,9807,1,0,4497,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,328083.3333,9003,8807,0,9003,,,,,,
-3655,"NAD83(NSRS2007) / South Carolina",9001,4759,13930,9802,1,0,4499,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,609600,9001,8827,0,9001,,,
-3656,"NAD83(NSRS2007) / South Carolina (ft)",9002,4759,15355,9802,1,0,4495,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,2000000,9002,8827,0,9002,,,
-3657,"NAD83(NSRS2007) / South Dakota North",9001,4759,14031,9802,1,0,4499,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,600000,9001,8827,0,9001,,,
-3658,"NAD83(NSRS2007) / South Dakota North (ftUS)",9003,4759,15394,9802,1,0,4497,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,1968500,9003,8827,0,9003,,,
-3659,"NAD83(NSRS2007) / South Dakota South",9001,4759,14032,9802,1,0,4499,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,600000,9001,8827,0,9001,,,
-3660,"NAD83(NSRS2007) / South Dakota South (ftUS)",9003,4759,15395,9802,1,0,4497,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,1968500,9003,8827,0,9003,,,
-3661,"NAD83(NSRS2007) / Tennessee",9001,4759,14130,9802,1,0,4499,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,600000,9001,8827,0,9001,,,
-3662,"NAD83(NSRS2007) / Tennessee (ftUS)",9003,4759,15356,9802,1,0,4497,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,1968500,9003,8827,0,9003,,,
-3663,"NAD83(NSRS2007) / Texas Central",9001,4759,14233,9802,1,0,4499,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,700000,9001,8827,3000000,9001,,,
-3664,"NAD83(NSRS2007) / Texas Central (ftUS)",9003,4759,15359,9802,1,0,4497,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,2296583.333,9003,8827,9842500,9003,,,
-3665,"NAD83(NSRS2007) / Texas Centric Albers Equal Area",9001,4759,14254,9822,1,0,4499,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,6000000,9001,,,
-3666,"NAD83(NSRS2007) / Texas Centric Lambert Conformal",9001,4759,14253,9802,1,0,4499,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,5000000,9001,,,
-3667,"NAD83(NSRS2007) / Texas North",9001,4759,14231,9802,1,0,4499,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,200000,9001,8827,1000000,9001,,,
-3668,"NAD83(NSRS2007) / Texas North (ftUS)",9003,4759,15357,9802,1,0,4497,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,656166.667,9003,8827,3280833.333,9003,,,
-3669,"NAD83(NSRS2007) / Texas North Central",9001,4759,14232,9802,1,0,4499,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,600000,9001,8827,2000000,9001,,,
-3670,"NAD83(NSRS2007) / Texas North Central (ftUS)",9003,4759,15358,9802,1,0,4497,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,1968500,9003,8827,6561666.667,9003,,,
-3671,"NAD83(NSRS2007) / Texas South",9001,4759,14235,9802,1,0,4499,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,300000,9001,8827,5000000,9001,,,
-3672,"NAD83(NSRS2007) / Texas South (ftUS)",9003,4759,15361,9802,1,0,4497,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,984250,9003,8827,16404166.667,9003,,,
-3673,"NAD83(NSRS2007) / Texas South Central",9001,4759,14234,9802,1,0,4499,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,600000,9001,8827,4000000,9001,,,
-3674,"NAD83(NSRS2007) / Texas South Central (ftUS)",9003,4759,15360,9802,1,0,4497,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,1968500,9003,8827,13123333.333,9003,,,
-3675,"NAD83(NSRS2007) / Utah Central",9001,4759,14332,9802,1,0,4499,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,500000,9001,8827,2000000,9001,,,
-3676,"NAD83(NSRS2007) / Utah Central (ft)",9002,4759,15363,9802,0,0,4495,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640419.948,9002,8827,6561679.79,9002,,,
-3677,"NAD83(NSRS2007) / Utah Central (ftUS)",9003,4759,15298,9802,0,0,4497,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640416.6667,9003,8827,6561666.6667,9003,,,
-3678,"NAD83(NSRS2007) / Utah North",9001,4759,14331,9802,1,0,4499,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,500000,9001,8827,1000000,9001,,,
-3679,"NAD83(NSRS2007) / Utah North (ft)",9002,4759,15362,9802,0,0,4495,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640419.948,9002,8827,3280839.895,9002,,,
-3680,"NAD83(NSRS2007) / Utah North (ftUS)",9003,4759,15297,9802,0,0,4497,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640416.6667,9003,8827,3280833.3333,9003,,,
-3681,"NAD83(NSRS2007) / Utah South",9001,4759,14333,9802,1,0,4499,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,500000,9001,8827,3000000,9001,,,
-3682,"NAD83(NSRS2007) / Utah South (ft)",9002,4759,15364,9802,0,0,4495,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640419.948,9002,8827,9842519.685,9002,,,
-3683,"NAD83(NSRS2007) / Utah South (ftUS)",9003,4759,15299,9802,0,0,4497,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640416.6667,9003,8827,9842500,9003,,,
-3684,"NAD83(NSRS2007) / Vermont",9001,4759,14430,9807,1,0,4499,8801,42.3,9110,8802,-72.3,9110,8805,0.999964286,9201,8806,500000,9001,8807,0,9001,,,,,,
-3685,"NAD83(NSRS2007) / Virginia North",9001,4759,14531,9802,1,0,4499,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,3500000,9001,8827,2000000,9001,,,
-3686,"NAD83(NSRS2007) / Virginia North (ftUS)",9003,4759,15365,9802,1,0,4497,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,11482916.667,9003,8827,6561666.667,9003,,,
-3687,"NAD83(NSRS2007) / Virginia South",9001,4759,14532,9802,1,0,4499,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,3500000,9001,8827,1000000,9001,,,
-3688,"NAD83(NSRS2007) / Virginia South (ftUS)",9003,4759,15366,9802,1,0,4497,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,11482916.667,9003,8827,3280833.333,9003,,,
-3689,"NAD83(NSRS2007) / Washington North",9001,4759,14631,9802,1,0,4499,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,500000,9001,8827,0,9001,,,
-3690,"NAD83(NSRS2007) / Washington North (ftUS)",9003,4759,15367,9802,1,0,4497,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,1640416.667,9003,8827,0,9003,,,
-3691,"NAD83(NSRS2007) / Washington South",9001,4759,14632,9802,1,0,4499,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,500000,9001,8827,0,9001,,,
-3692,"NAD83(NSRS2007) / Washington South (ftUS)",9003,4759,15368,9802,1,0,4497,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,1640416.667,9003,8827,0,9003,,,
-3693,"NAD83(NSRS2007) / West Virginia North",9001,4759,14731,9802,1,0,4499,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,600000,9001,8827,0,9001,,,
-3694,"NAD83(NSRS2007) / West Virginia South",9001,4759,14732,9802,1,0,4499,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,600000,9001,8827,0,9001,,,
-3695,"NAD83(NSRS2007) / Wisconsin Central",9001,4759,14832,9802,1,0,4499,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,600000,9001,8827,0,9001,,,
-3696,"NAD83(NSRS2007) / Wisconsin Central (ftUS)",9003,4759,15370,9802,1,0,4497,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,1968500,9003,8827,0,9003,,,
-3697,"NAD83(NSRS2007) / Wisconsin North",9001,4759,14831,9802,1,0,4499,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,600000,9001,8827,0,9001,,,
-3698,"NAD83(NSRS2007) / Wisconsin North (ftUS)",9003,4759,15369,9802,1,0,4497,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,1968500,9003,8827,0,9003,,,
-3699,"NAD83(NSRS2007) / Wisconsin South",9001,4759,14833,9802,1,0,4499,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,600000,9001,8827,0,9001,,,
-3700,"NAD83(NSRS2007) / Wisconsin South (ftUS)",9003,4759,15371,9802,1,0,4497,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,1968500,9003,8827,0,9003,,,
-3701,"NAD83(NSRS2007) / Wisconsin Transverse Mercator",9001,4759,14841,9807,1,0,4499,8801,0,9102,8802,-90,9102,8805,0.9996,9201,8806,520000,9001,8807,-4480000,9001,,,,,,
-3702,"NAD83(NSRS2007) / Wyoming East",9001,4759,14931,9807,1,0,4499,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,200000,9001,8807,0,9001,,,,,,
-3703,"NAD83(NSRS2007) / Wyoming East Central",9001,4759,14932,9807,1,0,4499,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,400000,9001,8807,100000,9001,,,,,,
-3704,"NAD83(NSRS2007) / Wyoming West Central",9001,4759,14933,9807,1,0,4499,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,600000,9001,8807,0,9001,,,,,,
-3705,"NAD83(NSRS2007) / Wyoming West",9001,4759,14934,9807,1,0,4499,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,800000,9001,8807,100000,9001,,,,,,
-3706,"NAD83(NSRS2007) / UTM zone 59N",9001,4759,16059,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3707,"NAD83(NSRS2007) / UTM zone 60N",9001,4759,16060,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3708,"NAD83(NSRS2007) / UTM zone 1N",9001,4759,16001,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3709,"NAD83(NSRS2007) / UTM zone 2N",9001,4759,16002,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3710,"NAD83(NSRS2007) / UTM zone 3N",9001,4759,16003,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3711,"NAD83(NSRS2007) / UTM zone 4N",9001,4759,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3712,"NAD83(NSRS2007) / UTM zone 5N",9001,4759,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3713,"NAD83(NSRS2007) / UTM zone 6N",9001,4759,16006,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3714,"NAD83(NSRS2007) / UTM zone 7N",9001,4759,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3715,"NAD83(NSRS2007) / UTM zone 8N",9001,4759,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3716,"NAD83(NSRS2007) / UTM zone 9N",9001,4759,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3717,"NAD83(NSRS2007) / UTM zone 10N",9001,4759,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3718,"NAD83(NSRS2007) / UTM zone 11N",9001,4759,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3719,"NAD83(NSRS2007) / UTM zone 12N",9001,4759,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3720,"NAD83(NSRS2007) / UTM zone 13N",9001,4759,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3721,"NAD83(NSRS2007) / UTM zone 14N",9001,4759,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3722,"NAD83(NSRS2007) / UTM zone 15N",9001,4759,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3723,"NAD83(NSRS2007) / UTM zone 16N",9001,4759,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3724,"NAD83(NSRS2007) / UTM zone 17N",9001,4759,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3725,"NAD83(NSRS2007) / UTM zone 18N",9001,4759,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3726,"NAD83(NSRS2007) / UTM zone 19N",9001,4759,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3727,"Reunion 1947 / TM Reunion",9001,4626,19856,9807,1,0,4499,8801,-21.07,9110,8802,55.32,9110,8805,1,9201,8806,160000,9001,8807,50000,9001,,,,,,
-3728,"NAD83(NSRS2007) / Ohio North (ftUS)",9003,4759,13433,9802,1,0,4497,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,1968500,9003,8827,0,9003,,,
-3729,"NAD83(NSRS2007) / Ohio South (ftUS)",9003,4759,13434,9802,1,0,4497,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,1968500,9003,8827,0,9003,,,
-3730,"NAD83(NSRS2007) / Wyoming East (ftUS)",9003,4759,14935,9807,1,0,4497,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,656166.6667,9003,8807,0,9003,,,,,,
-3731,"NAD83(NSRS2007) / Wyoming East Central (ftUS)",9003,4759,14936,9807,1,0,4497,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,1312333.3333,9003,8807,328083.3333,9003,,,,,,
-3732,"NAD83(NSRS2007) / Wyoming West Central (ftUS)",9003,4759,14937,9807,1,0,4497,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,1968500,9003,8807,0,9003,,,,,,
-3733,"NAD83(NSRS2007) / Wyoming West (ftUS)",9003,4759,14938,9807,1,0,4497,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,2624666.6667,9003,8807,328083.3333,9003,,,,,,
-3734,"NAD83 / Ohio North (ftUS)",9003,4269,13433,9802,1,0,4497,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,1968500,9003,8827,0,9003,,,
-3735,"NAD83 / Ohio South (ftUS)",9003,4269,13434,9802,1,0,4497,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,1968500,9003,8827,0,9003,,,
-3736,"NAD83 / Wyoming East (ftUS)",9003,4269,14935,9807,1,0,4497,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,656166.6667,9003,8807,0,9003,,,,,,
-3737,"NAD83 / Wyoming East Central (ftUS)",9003,4269,14936,9807,1,0,4497,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,1312333.3333,9003,8807,328083.3333,9003,,,,,,
-3738,"NAD83 / Wyoming West Central (ftUS)",9003,4269,14937,9807,1,0,4497,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,1968500,9003,8807,0,9003,,,,,,
-3739,"NAD83 / Wyoming West (ftUS)",9003,4269,14938,9807,1,0,4497,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,2624666.6667,9003,8807,328083.3333,9003,,,,,,
-3740,"NAD83(HARN) / UTM zone 10N",9001,4152,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3741,"NAD83(HARN) / UTM zone 11N",9001,4152,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3742,"NAD83(HARN) / UTM zone 12N",9001,4152,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3743,"NAD83(HARN) / UTM zone 13N",9001,4152,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3744,"NAD83(HARN) / UTM zone 14N",9001,4152,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3745,"NAD83(HARN) / UTM zone 15N",9001,4152,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3746,"NAD83(HARN) / UTM zone 16N",9001,4152,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3747,"NAD83(HARN) / UTM zone 17N",9001,4152,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3748,"NAD83(HARN) / UTM zone 18N",9001,4152,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3749,"NAD83(HARN) / UTM zone 19N",9001,4152,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3750,"NAD83(HARN) / UTM zone 4N",9001,4152,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3751,"NAD83(HARN) / UTM zone 5N",9001,4152,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3752,"WGS 84 / Mercator 41",9001,4326,19855,9804,1,1,4499,8801,-41,9102,8802,100,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3753,"NAD83(HARN) / Ohio North (ftUS)",9003,4152,13433,9802,1,0,4497,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,1968500,9003,8827,0,9003,,,
-3754,"NAD83(HARN) / Ohio South (ftUS)",9003,4152,13434,9802,1,0,4497,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,1968500,9003,8827,0,9003,,,
-3755,"NAD83(HARN) / Wyoming East (ftUS)",9003,4152,14935,9807,1,0,4497,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,656166.6667,9003,8807,0,9003,,,,,,
-3756,"NAD83(HARN) / Wyoming East Central (ftUS)",9003,4152,14936,9807,1,0,4497,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,1312333.3333,9003,8807,328083.3333,9003,,,,,,
-3757,"NAD83(HARN) / Wyoming West Central (ftUS)",9003,4152,14937,9807,1,0,4497,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,1968500,9003,8807,0,9003,,,,,,
-3758,"NAD83(HARN) / Wyoming West (ftUS)",9003,4152,14938,9807,1,0,4497,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,2624666.6667,9003,8807,328083.3333,9003,,,,,,
-3759,"NAD83 / Hawaii zone 3 (ftUS)",9003,4269,15138,9807,1,0,4497,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,1640416.6667,9003,8807,0,9003,,,,,,
-3760,"NAD83(HARN) / Hawaii zone 3 (ftUS)",9003,4152,15138,9807,1,0,4497,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,1640416.6667,9003,8807,0,9003,,,,,,
-3761,"NAD83(CSRS) / UTM zone 22N",9001,4617,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3762,"WGS 84 / South Georgia Lambert",9001,4326,19854,9802,1,0,4400,8821,-55,9102,8822,-37,9102,8823,-54,9110,8824,-54.45,9110,8826,0,9001,8827,0,9001,,,
-3763,"ETRS89 / Portugal TM06",9001,4258,19853,9807,1,0,4499,8801,39.400573,9110,8802,-8.075919,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3764,"NZGD2000 / Chatham Island Circuit 2000",9001,4167,17959,9807,1,0,4500,8801,-44,9110,8802,-176.3,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-3765,"HTRS96 / Croatia TM",9001,4761,19851,9807,1,0,4400,8801,0,9102,8802,16.5,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3766,"HTRS96 / Croatia LCC",9001,4761,19852,9802,1,0,4400,8821,0,9102,8822,16.3,9110,8823,45.55,9110,8824,43.05,9110,8826,0,9001,8827,0,9001,,,
-3767,"HTRS96 / UTM zone 33N",9001,4761,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3768,"HTRS96 / UTM zone 34N",9001,4761,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3769,"Bermuda 1957 / UTM zone 20N",9001,4216,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3770,"BDA2000 / Bermuda 2000 National Grid",9001,4762,19849,9807,1,0,4400,8801,32,9110,8802,-64.45,9110,8805,1,9201,8806,550000,9001,8807,100000,9001,,,,,,
-3771,"NAD27 / Alberta 3TM ref merid 111 W",9001,4267,17722,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3772,"NAD27 / Alberta 3TM ref merid 114 W",9001,4267,17723,9807,1,0,4400,8801,0,9102,8802,-114,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3773,"NAD27 / Alberta 3TM ref merid 117 W",9001,4267,17724,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3774,"NAD27 / Alberta 3TM ref merid 120 W",9001,4267,17725,9807,1,1,4400,8801,0,9102,8802,-120,9102,8805,0.9999,9001,8806,0,9001,8807,0,9001,,,,,,
-3775,"NAD83 / Alberta 3TM ref merid 111 W",9001,4269,17722,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3776,"NAD83 / Alberta 3TM ref merid 114 W",9001,4269,17723,9807,1,0,4400,8801,0,9102,8802,-114,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3777,"NAD83 / Alberta 3TM ref merid 117 W",9001,4269,17724,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3778,"NAD83 / Alberta 3TM ref merid 120 W",9001,4269,17725,9807,1,1,4400,8801,0,9102,8802,-120,9102,8805,0.9999,9001,8806,0,9001,8807,0,9001,,,,,,
-3779,"NAD83(CSRS) / Alberta 3TM ref merid 111 W",9001,4617,17722,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3780,"NAD83(CSRS) / Alberta 3TM ref merid 114 W",9001,4617,17723,9807,1,0,4400,8801,0,9102,8802,-114,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3781,"NAD83(CSRS) / Alberta 3TM ref merid 117 W",9001,4617,17724,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3782,"NAD83(CSRS) / Alberta 3TM ref merid 120 W",9001,4617,17725,9807,1,1,4400,8801,0,9102,8802,-120,9102,8805,0.9999,9001,8806,0,9001,8807,0,9001,,,,,,
-3783,"Pitcairn 2006 / Pitcairn TM 2006",9001,4763,19848,9807,1,0,4400,8801,-25.04067894,9110,8802,-130.06466816,9110,8805,1,9201,8806,14200,9001,8807,15500,9001,,,,,,
-3784,"Pitcairn 1967 / UTM zone 9S",9001,4729,16109,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-3785,"Popular Visualisation CRS / Mercator",9001,4055,19847,9841,1,1,4499,8801,0,9102,8802,0,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3786,"World Equidistant Cylindrical (Sphere)",9001,4047,19968,9823,1,1,4499,8801,0,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3787,"MGI / Slovene National Grid",9001,4312,19845,9807,1,1,4498,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,500000,9001,8807,-5000000,9001,,,,,,
-3788,"NZGD2000 / Auckland Islands TM 2000",9001,4167,17960,9807,1,0,4500,8801,0,9102,8802,166,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-3789,"NZGD2000 / Campbell Island TM 2000",9001,4167,17961,9807,1,0,4500,8801,0,9102,8802,169,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-3790,"NZGD2000 / Antipodes Islands TM 2000",9001,4167,17962,9807,1,0,4500,8801,0,9102,8802,179,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-3791,"NZGD2000 / Raoul Island TM 2000",9001,4167,17963,9807,1,0,4500,8801,0,9102,8802,-178,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-3793,"NZGD2000 / Chatham Islands TM 2000",9001,4167,17965,9807,1,0,4500,8801,0,9110,8802,-176.3,9110,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-3794,"Slovenia 1996 / Slovene National Grid",9001,4765,19845,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,500000,9001,8807,-5000000,9001,,,,,,
-3795,"NAD27 / Cuba Norte",9001,4267,18063,9802,1,0,4532,8821,22.21,9110,8822,-81,9110,8823,23,9110,8824,21.42,9110,8826,500000,9001,8827,280296.016,9001,,,
-3796,"NAD27 / Cuba Sur",9001,4267,18064,9802,1,0,4532,8821,20.43,9110,8822,-76.5,9110,8823,21.18,9110,8824,20.08,9110,8826,500000,9001,8827,229126.939,9001,,,
-3797,"NAD27 / MTQ Lambert",9001,4267,19844,9802,1,0,4499,8821,44,9102,8822,-70,9102,8823,50,9102,8824,46,9102,8826,800000,9001,8827,0,9001,,,
-3798,"NAD83 / MTQ Lambert",9001,4269,19844,9802,1,0,4499,8821,44,9102,8822,-70,9102,8823,50,9102,8824,46,9102,8826,800000,9001,8827,0,9001,,,
-3799,"NAD83(CSRS) / MTQ Lambert",9001,4617,19844,9802,1,0,4499,8821,44,9102,8822,-70,9102,8823,50,9102,8824,46,9102,8826,800000,9001,8827,0,9001,,,
-3800,"NAD27 / Alberta 3TM ref merid 120 W",9001,4267,17726,9807,1,0,4400,8801,0,9102,8802,-120,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3801,"NAD83 / Alberta 3TM ref merid 120 W",9001,4269,17726,9807,1,0,4400,8801,0,9102,8802,-120,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3802,"NAD83(CSRS) / Alberta 3TM ref merid 120 W",9001,4617,17726,9807,1,0,4400,8801,0,9102,8802,-120,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-3812,"ETRS89 / Belgian Lambert 2008",9001,4258,3811,9802,1,0,4499,8821,50.4752134,9110,8822,4.2133177,9110,8823,49.5,9110,8824,51.1,9110,8826,649328,9001,8827,665262,9001,,,
-3814,"NAD83 / Mississippi TM",9001,4269,3813,9807,1,0,4499,8801,32.3,9110,8802,-89.45,9110,8805,0.9998335,9201,8806,500000,9001,8807,1300000,9001,,,,,,
-3815,"NAD83(HARN) / Mississippi TM",9001,4152,3813,9807,1,0,4499,8801,32.3,9110,8802,-89.45,9110,8805,0.9998335,9201,8806,500000,9001,8807,1300000,9001,,,,,,
-3816,"NAD83(NSRS2007) / Mississippi TM",9001,4759,3813,9807,1,0,4499,8801,32.3,9110,8802,-89.45,9110,8805,0.9998335,9201,8806,500000,9001,8807,1300000,9001,,,,,,
-3825,"TWD97 / TM2 zone 119",9001,3824,3818,9807,1,0,4499,8801,0,9102,8802,119,9102,8805,0.9999,9201,8806,250000,9001,8807,0,9001,,,,,,
-3826,"TWD97 / TM2 zone 121",9001,3824,3820,9807,1,0,4499,8801,0,9102,8802,121,9102,8805,0.9999,9201,8806,250000,9001,8807,0,9001,,,,,,
-3827,"TWD67 / TM2 zone 119",9001,3821,3818,9807,1,0,4499,8801,0,9102,8802,119,9102,8805,0.9999,9201,8806,250000,9001,8807,0,9001,,,,,,
-3828,"TWD67 / TM2 zone 121",9001,3821,3820,9807,1,0,4499,8801,0,9102,8802,121,9102,8805,0.9999,9201,8806,250000,9001,8807,0,9001,,,,,,
-3829,"Hu Tzu Shan / UTM zone 51N",9001,4236,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3832,"WGS 84 / PDC Mercator",9001,4326,3831,9804,1,0,4400,8801,0,9102,8802,150,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3833,"Pulkovo 1942(58) / Gauss-Kruger zone 2",9001,4179,16202,9807,1,0,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-3834,"Pulkovo 1942(83) / Gauss-Kruger zone 2",9001,4178,16202,9807,1,0,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-3835,"Pulkovo 1942(83) / Gauss-Kruger zone 3",9001,4178,16203,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-3836,"Pulkovo 1942(83) / Gauss-Kruger zone 4",9001,4178,16204,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-3837,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 3",9001,4179,16263,9807,1,0,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-3838,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 4",9001,4179,16264,9807,1,0,4530,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-3839,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 9",9001,4179,16269,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-3840,"Pulkovo 1942(58) / 3-degree Gauss-Kruger zone 10",9001,4179,16270,9807,1,0,4530,8801,0,9102,8802,30,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-3841,"Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 6",9001,4178,16266,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3842,"Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 7",9001,4178,16266,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3843,"Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 8",9001,4178,16266,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3844,"Pulkovo 1942(58) / Stereo70",9001,4179,19926,9809,1,0,4530,8801,46,9102,8802,25,9102,8805,0.99975,9201,8806,500000,9001,8807,500000,9001,,,,,,
-3845,"SWEREF99 / RT90 7.5 gon V emulation",9001,4619,17339,9807,1,0,4530,8801,0,9110,8802,11.18225,9110,8805,1.000006,9201,8806,1500025.141,9001,8807,-667.282,9001,,,,,,
-3846,"SWEREF99 / RT90 5 gon V emulation",9001,4619,17340,9807,1,0,4530,8801,0,9110,8802,13.332256,9110,8805,1.0000058,9201,8806,1500044.695,9001,8807,-667.13,9001,,,,,,
-3847,"SWEREF99 / RT90 2.5 gon V emulation",9001,4619,17341,9807,1,0,4530,8801,0,9110,8802,15.4822624306,9110,8805,1.00000561024,9201,8806,1500064.274,9001,8807,-667.711,9001,,,,,,
-3848,"SWEREF99 / RT90 0 gon emulation",9001,4619,17342,9807,1,0,4530,8801,0,9110,8802,18.032268,9110,8805,1.0000054,9201,8806,1500083.521,9001,8807,-668.844,9001,,,,,,
-3849,"SWEREF99 / RT90 2.5 gon O emulation",9001,4619,17343,9807,1,0,4530,8801,0,9110,8802,20.182274,9110,8805,1.0000052,9201,8806,1500102.765,9001,8807,-670.706,9001,,,,,,
-3850,"SWEREF99 / RT90 5 gon O emulation",9001,4619,17344,9807,1,0,4530,8801,0,9110,8802,22.33228,9110,8805,1.0000049,9201,8806,1500121.846,9001,8807,-672.557,9001,,,,,,
-3851,"NZGD2000 / NZCS2000",9001,4167,17964,9802,1,0,4500,8821,-41,9110,8822,173,9110,8823,-37.3,9110,8824,-44.3,9110,8826,3000000,9001,8827,7000000,9001,,,
-3852,"RSRGD2000 / DGLC2000",9001,4764,17966,9802,1,0,4500,8821,-90,9110,8822,157,9110,8823,-76.4,9110,8824,-79.2,9110,8826,500000,9001,8827,0,9001,,,
-3854,County ST74,9001,4619,3853,9807,1,0,4531,8801,0,9110,8802,18.0328332,9110,8805,0.99999506,9201,8806,100182.7406,9001,8807,-6500620.1207,9001,,,,,,
-3857,"WGS 84 / Pseudo-Mercator",9001,4326,3856,1024,1,0,4499,8801,0,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3890,"IGRS / UTM zone 37N",9001,3889,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3891,"IGRS / UTM zone 38N",9001,3889,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3892,"IGRS / UTM zone 39N",9001,3889,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3893,"ED50 / Iraq National Grid",9001,4230,19907,9807,1,0,4400,8801,29.0134566,9110,8802,46.3,9110,8805,0.9994,9201,8806,800000,9001,8807,0,9001,,,,,,
-3907,"MGI 1901 / Balkans zone 5",9001,3906,18275,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,5500000,9001,8807,0,9001,,,,,,
-3908,"MGI 1901 / Balkans zone 6",9001,3906,18276,9807,1,0,4530,8801,0,9102,8802,18,9102,8805,0.9999,9201,8806,6500000,9001,8807,0,9001,,,,,,
-3909,"MGI 1901 / Balkans zone 7",9001,3906,18277,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,0.9999,9201,8806,7500000,9001,8807,0,9001,,,,,,
-3910,"MGI 1901 / Balkans zone 8",9001,3906,18278,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,8500000,9001,8807,0,9001,,,,,,
-3911,"MGI 1901 / Slovenia Grid",9001,3906,19967,9807,1,0,4530,8801,0,9110,8802,15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-3912,"MGI 1901 / Slovene National Grid",9001,3906,19845,9807,1,0,4498,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,500000,9001,8807,-5000000,9001,,,,,,
-3920,"Puerto Rico / UTM zone 20N",9001,4139,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-3942,"RGF93 / CC42",9001,4171,18101,9802,1,0,4499,8821,42,9102,8822,3,9102,8823,41.25,9102,8824,42.75,9102,8826,1700000,9001,8827,1200000,9001,,,
-3943,"RGF93 / CC43",9001,4171,18102,9802,1,0,4499,8821,43,9102,8822,3,9102,8823,42.25,9102,8824,43.75,9102,8826,1700000,9001,8827,2200000,9001,,,
-3944,"RGF93 / CC44",9001,4171,18103,9802,1,0,4499,8821,44,9102,8822,3,9102,8823,43.25,9102,8824,44.75,9102,8826,1700000,9001,8827,3200000,9001,,,
-3945,"RGF93 / CC45",9001,4171,18104,9802,1,0,4499,8821,45,9102,8822,3,9102,8823,44.25,9102,8824,45.75,9102,8826,1700000,9001,8827,4200000,9001,,,
-3946,"RGF93 / CC46",9001,4171,18105,9802,1,0,4499,8821,46,9102,8822,3,9102,8823,45.25,9102,8824,46.75,9102,8826,1700000,9001,8827,5200000,9001,,,
-3947,"RGF93 / CC47",9001,4171,18106,9802,1,0,4499,8821,47,9102,8822,3,9102,8823,46.25,9102,8824,47.75,9102,8826,1700000,9001,8827,6200000,9001,,,
-3948,"RGF93 / CC48",9001,4171,18107,9802,1,0,4499,8821,48,9102,8822,3,9102,8823,47.25,9102,8824,48.75,9102,8826,1700000,9001,8827,7200000,9001,,,
-3949,"RGF93 / CC49",9001,4171,18108,9802,1,0,4499,8821,49,9102,8822,3,9102,8823,48.25,9102,8824,49.75,9102,8826,1700000,9001,8827,8200000,9001,,,
-3950,"RGF93 / CC50",9001,4171,18109,9802,1,0,4499,8821,50,9102,8822,3,9102,8823,49.25,9102,8824,50.75,9102,8826,1700000,9001,8827,9200000,9001,,,
-3968,"NAD83 / Virginia Lambert",9001,4269,3967,9802,1,0,4499,8821,36,9102,8822,-79.5,9102,8823,37,9102,8824,39.5,9102,8826,0,9001,8827,0,9001,,,
-3969,"NAD83(HARN) / Virginia Lambert",9001,4152,3967,9802,1,0,4499,8821,36,9102,8822,-79.5,9102,8823,37,9102,8824,39.5,9102,8826,0,9001,8827,0,9001,,,
-3970,"NAD83(NSRS2007) / Virginia Lambert",9001,4759,3967,9802,1,0,4499,8821,36,9102,8822,-79.5,9102,8823,37,9102,8824,39.5,9102,8826,0,9001,8827,0,9001,,,
-3973,"WGS 84 / NSIDC EASE-Grid North",9001,4326,3897,1027,1,0,4469,8801,90,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3974,"WGS 84 / NSIDC EASE-Grid South",9001,4326,3898,1027,1,0,4470,8801,-90,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3975,"WGS 84 / NSIDC EASE-Grid Global",9001,4326,19869,9834,1,0,4499,8802,0,9102,8806,0,9001,8807,0,9001,8823,30,9102,,,,,,,,,
-3976,"WGS 84 / NSIDC Sea Ice Polar Stereographic South",9001,4326,19866,9829,1,0,4470,8806,0,9001,8807,0,9001,8832,-70,9102,8833,0,9102,,,,,,,,,
-3978,"NAD83 / Canada Atlas Lambert",9001,4269,3977,9802,1,0,4400,8821,49,9102,8822,-95,9102,8823,49,9102,8824,77,9102,8826,0,9001,8827,0,9001,,,
-3979,"NAD83(CSRS) / Canada Atlas Lambert",9001,4617,3977,9802,1,0,4400,8821,49,9102,8822,-95,9102,8823,49,9102,8824,77,9102,8826,0,9001,8827,0,9001,,,
-3985,"Katanga 1955 / Katanga Lambert",9001,4695,3980,9802,1,0,4499,8821,9,9102,8822,26,9102,8823,-6.5,9102,8824,-11.5,9102,8826,500000,9001,8827,500000,9001,,,
-3986,"Katanga 1955 / Katanga Gauss zone A",9001,4695,3981,9807,1,0,4499,8801,-9,9102,8802,30,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3987,"Katanga 1955 / Katanga Gauss zone B",9001,4695,3982,9807,1,0,4499,8801,-9,9102,8802,28,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3988,"Katanga 1955 / Katanga Gauss zone C",9001,4695,3983,9807,1,0,4499,8801,-9,9102,8802,26,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3989,"Katanga 1955 / Katanga Gauss zone D",9001,4695,3984,9807,1,0,4499,8801,-9,9102,8802,24,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3991,Puerto Rico State Plane CS of 1927,9003,4139,15201,9802,1,0,4497,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,500000,9003,8827,0,9003,,,
-3992,"Puerto Rico / St. Croix",9003,4139,15202,9802,1,0,4497,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,500000,9003,8827,100000,9003,,,
-3993,"Guam 1963 / Guam SPCS",9001,4675,15400,9831,1,0,4499,8801,13.282087887,9110,8802,144.445550254,9110,8806,50000,9001,8807,50000,9001,,,,,,,,,
-3994,"WGS 84 / Mercator 41",9001,4326,19843,9805,1,0,4499,8802,100,9102,8806,0,9001,8807,0,9001,8823,-41,9102,,,,,,,,,
-3995,"WGS 84 / Arctic Polar Stereographic",9001,4326,19842,9829,1,0,4469,8806,0,9001,8807,0,9001,8832,71,9102,8833,0,9102,,,,,,,,,
-3996,"WGS 84 / IBCAO Polar Stereographic",9001,4326,19840,9829,1,0,4469,8806,0,9001,8807,0,9001,8832,75,9102,8833,0,9102,,,,,,,,,
-3997,"WGS 84 / Dubai Local TM",9001,4326,19839,9807,1,0,4400,8801,0,9110,8802,55.2,9110,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-4026,"MOLDREF99 / Moldova TM",9001,4023,3999,9807,1,0,4530,8801,0,9110,8802,28.24,9110,8805,0.99994,9201,8806,200000,9001,8807,-5000000,9001,,,,,,
-4037,"WGS 84 / TMzn35N",9001,4326,16035,9807,1,0,4500,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-4038,"WGS 84 / TMzn36N",9001,4326,16036,9807,1,0,4500,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-4048,"RGRDC 2005 / Congo TM zone 12",9001,4046,17412,9807,1,0,4499,8801,0,9102,8802,12,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4049,"RGRDC 2005 / Congo TM zone 14",9001,4046,17414,9807,1,0,4499,8801,0,9102,8802,14,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4050,"RGRDC 2005 / Congo TM zone 16",9001,4046,17416,9807,1,0,4499,8801,0,9102,8802,16,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4051,"RGRDC 2005 / Congo TM zone 18",9001,4046,17418,9807,1,0,4499,8801,0,9102,8802,18,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4056,"RGRDC 2005 / Congo TM zone 20",9001,4046,17420,9807,1,0,4499,8801,0,9102,8802,20,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4057,"RGRDC 2005 / Congo TM zone 22",9001,4046,17422,9807,1,0,4499,8801,0,9102,8802,22,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4058,"RGRDC 2005 / Congo TM zone 24",9001,4046,17424,9807,1,0,4499,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4059,"RGRDC 2005 / Congo TM zone 26",9001,4046,17426,9807,1,0,4499,8801,0,9102,8802,26,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4060,"RGRDC 2005 / Congo TM zone 28",9001,4046,17428,9807,1,0,4499,8801,0,9102,8802,28,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4061,"RGRDC 2005 / UTM zone 33S",9001,4046,16133,9807,1,0,4499,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4062,"RGRDC 2005 / UTM zone 34S",9001,4046,16134,9807,1,0,4499,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4063,"RGRDC 2005 / UTM zone 35S",9001,4046,16135,9807,1,0,4499,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4071,"Chua / UTM zone 23S",9001,4224,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-4082,"REGCAN95 / UTM zone 27N",9001,4081,16027,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-4083,"REGCAN95 / UTM zone 28N",9001,4081,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-4087,"WGS 84 / World Equidistant Cylindrical",9001,4326,4085,1028,1,0,4499,8802,0,9102,8806,0,9001,8807,0,9001,8823,0,9102,,,,,,,,,
-4088,"World Equidistant Cylindrical (Sphere)",9001,4047,4086,1029,1,0,4499,8802,0,9102,8806,0,9001,8807,0,9001,8823,0,9102,,,,,,,,,
-5514,"S-JTSK / Krovak East North",9001,4818,19952,9819,1,0,6501,8806,0,9001,8807,0,9001,8811,49.3,9110,8813,30.1717303,9110,8818,78.3,9110,8819,0.9999,9201,8833,42.3,9110
-5819,EPSG topocentric example A,9001,4979,15594,9837,1,0,4461,8834,55,9102,8835,5,9102,8836,0,9001,,,,,,,,,,,,
-5820,EPSG topocentric example B,9001,4978,15595,9836,1,0,4461,8837,3771793.97,9001,8838,140253.34,9001,8839,5124304.35,9001,,,,,,,,,,,,
-5821,EPSG vertical perspective example,9001,5819,19850,9838,1,0,4461,8834,55,9102,8835,5,9102,8836,200,9001,8840,5900,9036,,,,,,,,,
-20004,"Pulkovo 1995 / Gauss-Kruger zone 4",9001,4200,16204,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-20005,"Pulkovo 1995 / Gauss-Kruger zone 5",9001,4200,16205,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-20006,"Pulkovo 1995 / Gauss-Kruger zone 6",9001,4200,16206,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-20007,"Pulkovo 1995 / Gauss-Kruger zone 7",9001,4200,16207,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-20008,"Pulkovo 1995 / Gauss-Kruger zone 8",9001,4200,16208,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-20009,"Pulkovo 1995 / Gauss-Kruger zone 9",9001,4200,16209,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-20010,"Pulkovo 1995 / Gauss-Kruger zone 10",9001,4200,16210,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-20011,"Pulkovo 1995 / Gauss-Kruger zone 11",9001,4200,16211,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-20012,"Pulkovo 1995 / Gauss-Kruger zone 12",9001,4200,16212,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-20013,"Pulkovo 1995 / Gauss-Kruger zone 13",9001,4200,16213,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-20014,"Pulkovo 1995 / Gauss-Kruger zone 14",9001,4200,16214,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-20015,"Pulkovo 1995 / Gauss-Kruger zone 15",9001,4200,16215,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-20016,"Pulkovo 1995 / Gauss-Kruger zone 16",9001,4200,16216,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-20017,"Pulkovo 1995 / Gauss-Kruger zone 17",9001,4200,16217,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-20018,"Pulkovo 1995 / Gauss-Kruger zone 18",9001,4200,16218,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-20019,"Pulkovo 1995 / Gauss-Kruger zone 19",9001,4200,16219,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-20020,"Pulkovo 1995 / Gauss-Kruger zone 20",9001,4200,16220,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-20021,"Pulkovo 1995 / Gauss-Kruger zone 21",9001,4200,16221,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-20022,"Pulkovo 1995 / Gauss-Kruger zone 22",9001,4200,16222,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-20023,"Pulkovo 1995 / Gauss-Kruger zone 23",9001,4200,16223,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-20024,"Pulkovo 1995 / Gauss-Kruger zone 24",9001,4200,16224,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,24500000,9001,8807,0,9001,,,,,,
-20025,"Pulkovo 1995 / Gauss-Kruger zone 25",9001,4200,16225,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-20026,"Pulkovo 1995 / Gauss-Kruger zone 26",9001,4200,16226,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-20027,"Pulkovo 1995 / Gauss-Kruger zone 27",9001,4200,16227,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-20028,"Pulkovo 1995 / Gauss-Kruger zone 28",9001,4200,16228,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-20029,"Pulkovo 1995 / Gauss-Kruger zone 29",9001,4200,16229,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-20030,"Pulkovo 1995 / Gauss-Kruger zone 30",9001,4200,16230,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-20031,"Pulkovo 1995 / Gauss-Kruger zone 31",9001,4200,16231,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-20032,"Pulkovo 1995 / Gauss-Kruger zone 32",9001,4200,16232,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-20064,"Pulkovo 1995 / Gauss-Kruger 4N",9001,4200,16304,9807,1,1,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20065,"Pulkovo 1995 / Gauss-Kruger 5N",9001,4200,16305,9807,1,1,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20066,"Pulkovo 1995 / Gauss-Kruger 6N",9001,4200,16306,9807,1,1,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20067,"Pulkovo 1995 / Gauss-Kruger 7N",9001,4200,16307,9807,1,1,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20068,"Pulkovo 1995 / Gauss-Kruger 8N",9001,4200,16308,9807,1,1,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20069,"Pulkovo 1995 / Gauss-Kruger 9N",9001,4200,16309,9807,1,1,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20070,"Pulkovo 1995 / Gauss-Kruger 10N",9001,4200,16310,9807,1,1,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20071,"Pulkovo 1995 / Gauss-Kruger 11N",9001,4200,16311,9807,1,1,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20072,"Pulkovo 1995 / Gauss-Kruger 12N",9001,4200,16312,9807,1,1,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20073,"Pulkovo 1995 / Gauss-Kruger 13N",9001,4200,16313,9807,1,1,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20074,"Pulkovo 1995 / Gauss-Kruger 14N",9001,4200,16314,9807,1,1,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20075,"Pulkovo 1995 / Gauss-Kruger 15N",9001,4200,16315,9807,1,1,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20076,"Pulkovo 1995 / Gauss-Kruger 16N",9001,4200,16316,9807,1,1,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20077,"Pulkovo 1995 / Gauss-Kruger 17N",9001,4200,16317,9807,1,1,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20078,"Pulkovo 1995 / Gauss-Kruger 18N",9001,4200,16318,9807,1,1,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20079,"Pulkovo 1995 / Gauss-Kruger 19N",9001,4200,16319,9807,1,1,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20080,"Pulkovo 1995 / Gauss-Kruger 20N",9001,4200,16320,9807,1,1,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20081,"Pulkovo 1995 / Gauss-Kruger 21N",9001,4200,16321,9807,1,1,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20082,"Pulkovo 1995 / Gauss-Kruger 22N",9001,4200,16322,9807,1,1,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20083,"Pulkovo 1995 / Gauss-Kruger 23N",9001,4200,16323,9807,1,1,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20084,"Pulkovo 1995 / Gauss-Kruger 24N",9001,4200,16324,9807,1,1,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20085,"Pulkovo 1995 / Gauss-Kruger 25N",9001,4200,16325,9807,1,1,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20086,"Pulkovo 1995 / Gauss-Kruger 26N",9001,4200,16326,9807,1,1,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20087,"Pulkovo 1995 / Gauss-Kruger 27N",9001,4200,16327,9807,1,1,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20088,"Pulkovo 1995 / Gauss-Kruger 28N",9001,4200,16328,9807,1,1,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20089,"Pulkovo 1995 / Gauss-Kruger 29N",9001,4200,16329,9807,1,1,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20090,"Pulkovo 1995 / Gauss-Kruger 30N",9001,4200,16330,9807,1,1,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20091,"Pulkovo 1995 / Gauss-Kruger 31N",9001,4200,16331,9807,1,1,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20092,"Pulkovo 1995 / Gauss-Kruger 32N",9001,4200,16332,9807,1,1,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-20135,"Adindan / UTM zone 35N",9001,4201,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20136,"Adindan / UTM zone 36N",9001,4201,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20137,"Adindan / UTM zone 37N",9001,4201,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20138,"Adindan / UTM zone 38N",9001,4201,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20248,"AGD66 / AMG zone 48",9001,4202,17448,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20249,"AGD66 / AMG zone 49",9001,4202,17449,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20250,"AGD66 / AMG zone 50",9001,4202,17450,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20251,"AGD66 / AMG zone 51",9001,4202,17451,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20252,"AGD66 / AMG zone 52",9001,4202,17452,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20253,"AGD66 / AMG zone 53",9001,4202,17453,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20254,"AGD66 / AMG zone 54",9001,4202,17454,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20255,"AGD66 / AMG zone 55",9001,4202,17455,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20256,"AGD66 / AMG zone 56",9001,4202,17456,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20257,"AGD66 / AMG zone 57",9001,4202,17457,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20258,"AGD66 / AMG zone 58",9001,4202,17458,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20348,"AGD84 / AMG zone 48",9001,4203,17448,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20349,"AGD84 / AMG zone 49",9001,4203,17449,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20350,"AGD84 / AMG zone 50",9001,4203,17450,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20351,"AGD84 / AMG zone 51",9001,4203,17451,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20352,"AGD84 / AMG zone 52",9001,4203,17452,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20353,"AGD84 / AMG zone 53",9001,4203,17453,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20354,"AGD84 / AMG zone 54",9001,4203,17454,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20355,"AGD84 / AMG zone 55",9001,4203,17455,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20356,"AGD84 / AMG zone 56",9001,4203,17456,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20357,"AGD84 / AMG zone 57",9001,4203,17457,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20358,"AGD84 / AMG zone 58",9001,4203,17458,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20436,"Ain el Abd / UTM zone 36N",9001,4204,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20437,"Ain el Abd / UTM zone 37N",9001,4204,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20438,"Ain el Abd / UTM zone 38N",9001,4204,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20439,"Ain el Abd / UTM zone 39N",9001,4204,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20440,"Ain el Abd / UTM zone 40N",9001,4204,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20499,"Ain el Abd / Bahrain Grid",9001,4204,19900,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20538,"Afgooye / UTM zone 38N",9001,4205,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20539,"Afgooye / UTM zone 39N",9001,4205,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-20790,"Lisbon (Lisbon) / Portuguese National Grid",9001,4803,19936,9807,1,0,4499,8801,39.4,9110,8802,1,9110,8805,1,9201,8806,200000,9001,8807,300000,9001,,,,,,
-20791,"Lisbon (Lisbon) / Portuguese Grid",9001,4803,19969,9807,1,0,4499,8801,39.4,9110,8802,1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-20822,"Aratu / UTM zone 22S",9001,4208,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20823,"Aratu / UTM zone 23S",9001,4208,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20824,"Aratu / UTM zone 24S",9001,4208,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20934,"Arc 1950 / UTM zone 34S",9001,4209,16134,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20935,"Arc 1950 / UTM zone 35S",9001,4209,16135,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-20936,"Arc 1950 / UTM zone 36S",9001,4209,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21035,"Arc 1960 / UTM zone 35S",9001,4210,16135,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21036,"Arc 1960 / UTM zone 36S",9001,4210,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21037,"Arc 1960 / UTM zone 37S",9001,4210,16137,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21095,"Arc 1960 / UTM zone 35N",9001,4210,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-21096,"Arc 1960 / UTM zone 36N",9001,4210,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-21097,"Arc 1960 / UTM zone 37N",9001,4210,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-21100,"Batavia (Jakarta) / NEIEZ",9001,4813,19905,9804,1,1,4499,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-21148,"Batavia / UTM zone 48S",9001,4211,16148,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21149,"Batavia / UTM zone 49S",9001,4211,16149,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21150,"Batavia / UTM zone 50S",9001,4211,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-21291,"Barbados 1938 / British West Indies Grid",9001,4212,19942,9807,1,0,4400,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-21292,"Barbados 1938 / Barbados National Grid",9001,4212,19943,9807,1,0,4400,8801,13.1035,9110,8802,-59.3335,9110,8805,0.9999986,9201,8806,30000,9001,8807,75000,9001,,,,,,
-21413,"Beijing 1954 / Gauss-Kruger zone 13",9001,4214,16213,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-21414,"Beijing 1954 / Gauss-Kruger zone 14",9001,4214,16214,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-21415,"Beijing 1954 / Gauss-Kruger zone 15",9001,4214,16215,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-21416,"Beijing 1954 / Gauss-Kruger zone 16",9001,4214,16216,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-21417,"Beijing 1954 / Gauss-Kruger zone 17",9001,4214,16217,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-21418,"Beijing 1954 / Gauss-Kruger zone 18",9001,4214,16218,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-21419,"Beijing 1954 / Gauss-Kruger zone 19",9001,4214,16219,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-21420,"Beijing 1954 / Gauss-Kruger zone 20",9001,4214,16220,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-21421,"Beijing 1954 / Gauss-Kruger zone 21",9001,4214,16221,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-21422,"Beijing 1954 / Gauss-Kruger zone 22",9001,4214,16222,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-21423,"Beijing 1954 / Gauss-Kruger zone 23",9001,4214,16223,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-21453,"Beijing 1954 / Gauss-Kruger CM 75E",9001,4214,16313,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21454,"Beijing 1954 / Gauss-Kruger CM 81E",9001,4214,16314,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21455,"Beijing 1954 / Gauss-Kruger CM 87E",9001,4214,16315,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21456,"Beijing 1954 / Gauss-Kruger CM 93E",9001,4214,16316,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21457,"Beijing 1954 / Gauss-Kruger CM 99E",9001,4214,16317,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21458,"Beijing 1954 / Gauss-Kruger CM 105E",9001,4214,16318,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21459,"Beijing 1954 / Gauss-Kruger CM 111E",9001,4214,16319,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21460,"Beijing 1954 / Gauss-Kruger CM 117E",9001,4214,16320,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21461,"Beijing 1954 / Gauss-Kruger CM 123E",9001,4214,16321,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21462,"Beijing 1954 / Gauss-Kruger CM 129E",9001,4214,16322,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21463,"Beijing 1954 / Gauss-Kruger CM 135E",9001,4214,16323,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21473,"Beijing 1954 / Gauss-Kruger 13N",9001,4214,16313,9807,1,1,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21474,"Beijing 1954 / Gauss-Kruger 14N",9001,4214,16314,9807,1,1,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21475,"Beijing 1954 / Gauss-Kruger 15N",9001,4214,16315,9807,1,1,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21476,"Beijing 1954 / Gauss-Kruger 16N",9001,4214,16316,9807,1,1,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21477,"Beijing 1954 / Gauss-Kruger 17N",9001,4214,16317,9807,1,1,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21478,"Beijing 1954 / Gauss-Kruger 18N",9001,4214,16318,9807,1,1,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21479,"Beijing 1954 / Gauss-Kruger 19N",9001,4214,16319,9807,1,1,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21480,"Beijing 1954 / Gauss-Kruger 20N",9001,4214,16320,9807,1,1,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21481,"Beijing 1954 / Gauss-Kruger 21N",9001,4214,16321,9807,1,1,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21482,"Beijing 1954 / Gauss-Kruger 22N",9001,4214,16322,9807,1,1,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21483,"Beijing 1954 / Gauss-Kruger 23N",9001,4214,16323,9807,1,1,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-21500,"Belge 1950 (Brussels) / Belge Lambert 50",9001,4809,19901,9802,1,0,4499,8821,90,9110,8822,0,9110,8823,49.5,9110,8824,51.1,9110,8826,150000,9001,8827,5400000,9001,,,
-21780,"Bern 1898 (Bern) / LV03C",9001,4801,19923,9815,1,0,4498,8811,46.570866,9110,8812,0,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,0,9001,8817,0,9001
-21781,"CH1903 / LV03",9001,4149,19922,9815,1,0,4498,8811,46.570866,9110,8812,7.26225,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,600000,9001,8817,200000,9001
-21782,"CH1903 / LV03C-G",9001,4149,19841,9815,1,0,4498,8811,46.570866,9110,8812,7.26225,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,0,9001,8817,0,9001
-21817,"Bogota 1975 / UTM zone 17N",9001,4218,16017,9807,1,1,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-21818,"Bogota 1975 / UTM zone 18N",9001,4218,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-21891,"Bogota 1975 / Colombia West zone",9001,4218,18051,9807,1,1,4499,8801,4.355657,9110,8802,-77.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21892,"Bogota 1975 / Colombia Bogota zone",9001,4218,18052,9807,1,1,4499,8801,4.355657,9110,8802,-74.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21893,"Bogota 1975 / Colombia East Central zone",9001,4218,18053,9807,1,1,4499,8801,4.355657,9110,8802,-71.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21894,"Bogota 1975 / Colombia East",9001,4218,18054,9807,1,1,4499,8801,4.355657,9110,8802,-68.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21896,"Bogota 1975 / Colombia West zone",9001,4218,18051,9807,1,0,4530,8801,4.355657,9110,8802,-77.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21897,"Bogota 1975 / Colombia Bogota zone",9001,4218,18052,9807,1,0,4530,8801,4.355657,9110,8802,-74.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21898,"Bogota 1975 / Colombia East Central zone",9001,4218,18053,9807,1,0,4530,8801,4.355657,9110,8802,-71.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-21899,"Bogota 1975 / Colombia East",9001,4218,18054,9807,1,0,4530,8801,4.355657,9110,8802,-68.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-22032,"Camacupa / UTM zone 32S",9001,4220,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22033,"Camacupa / UTM zone 33S",9001,4220,16133,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22091,"Camacupa / TM 11.30 SE",9001,4220,16611,9807,1,0,4400,8801,0,9110,8802,11.3,9110,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22092,"Camacupa / TM 12 SE",9001,4220,16612,9807,1,0,4400,8801,0,9102,8802,12,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22171,"POSGAR 98 / Argentina 1",9001,4190,18031,9807,1,0,4530,8801,-90,9102,8802,-72,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-22172,"POSGAR 98 / Argentina 2",9001,4190,18032,9807,1,0,4530,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-22173,"POSGAR 98 / Argentina 3",9001,4190,18033,9807,1,0,4530,8801,-90,9102,8802,-66,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-22174,"POSGAR 98 / Argentina 4",9001,4190,18034,9807,1,0,4530,8801,-90,9102,8802,-63,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-22175,"POSGAR 98 / Argentina 5",9001,4190,18035,9807,1,0,4530,8801,-90,9102,8802,-60,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-22176,"POSGAR 98 / Argentina 6",9001,4190,18036,9807,1,0,4530,8801,-90,9102,8802,-57,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-22177,"POSGAR 98 / Argentina 7",9001,4190,18037,9807,1,0,4530,8801,-90,9102,8802,-54,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-22181,"POSGAR 94 / Argentina 1",9001,4694,18031,9807,1,0,4530,8801,-90,9102,8802,-72,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-22182,"POSGAR 94 / Argentina 2",9001,4694,18032,9807,1,0,4530,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-22183,"POSGAR 94 / Argentina 3",9001,4694,18033,9807,1,0,4530,8801,-90,9102,8802,-66,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-22184,"POSGAR 94 / Argentina 4",9001,4694,18034,9807,1,0,4530,8801,-90,9102,8802,-63,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-22185,"POSGAR 94 / Argentina 5",9001,4694,18035,9807,1,0,4530,8801,-90,9102,8802,-60,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-22186,"POSGAR 94 / Argentina 6",9001,4694,18036,9807,1,0,4530,8801,-90,9102,8802,-57,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-22187,"POSGAR 94 / Argentina 7",9001,4694,18037,9807,1,0,4530,8801,-90,9102,8802,-54,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-22191,"Campo Inchauspe / Argentina 1",9001,4221,18031,9807,1,0,4530,8801,-90,9102,8802,-72,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-22192,"Campo Inchauspe / Argentina 2",9001,4221,18032,9807,1,0,4530,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-22193,"Campo Inchauspe / Argentina 3",9001,4221,18033,9807,1,0,4530,8801,-90,9102,8802,-66,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-22194,"Campo Inchauspe / Argentina 4",9001,4221,18034,9807,1,0,4530,8801,-90,9102,8802,-63,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-22195,"Campo Inchauspe / Argentina 5",9001,4221,18035,9807,1,0,4530,8801,-90,9102,8802,-60,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-22196,"Campo Inchauspe / Argentina 6",9001,4221,18036,9807,1,0,4530,8801,-90,9102,8802,-57,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-22197,"Campo Inchauspe / Argentina 7",9001,4221,18037,9807,1,0,4530,8801,-90,9102,8802,-54,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-22234,"Cape / UTM zone 34S",9001,4222,16134,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22235,"Cape / UTM zone 35S",9001,4222,16135,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22236,"Cape / UTM zone 36S",9001,4222,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22275,"Cape / Lo15",9001,4222,17515,9808,1,0,6503,8801,0,9102,8802,15,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22277,"Cape / Lo17",9001,4222,17517,9808,1,0,6503,8801,0,9102,8802,17,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22279,"Cape / Lo19",9001,4222,17519,9808,1,0,6503,8801,0,9102,8802,19,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22281,"Cape / Lo21",9001,4222,17521,9808,1,0,6503,8801,0,9102,8802,21,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22283,"Cape / Lo23",9001,4222,17523,9808,1,0,6503,8801,0,9102,8802,23,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22285,"Cape / Lo25",9001,4222,17525,9808,1,0,6503,8801,0,9102,8802,25,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22287,"Cape / Lo27",9001,4222,17527,9808,1,0,6503,8801,0,9102,8802,27,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22289,"Cape / Lo29",9001,4222,17529,9808,1,0,6503,8801,0,9102,8802,29,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22291,"Cape / Lo31",9001,4222,17531,9808,1,0,6503,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22293,"Cape / Lo33",9001,4222,17533,9808,1,0,6503,8801,0,9102,8802,33,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-22300,"Carthage (Paris) / Tunisia Mining Grid",9036,4816,19937,9816,1,0,4406,8821,38.81973,9105,8822,7.83445,9105,8826,270,9036,8827,582,9036,,,,,,,,,
-22332,"Carthage / UTM zone 32N",9001,4223,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-22391,"Carthage / Nord Tunisie",9001,4223,18181,9801,1,0,4499,8801,40,9105,8802,11,9105,8805,0.999625544,9201,8806,500000,9001,8807,300000,9001,,,,,,
-22392,"Carthage / Sud Tunisie",9001,4223,18182,9801,1,0,4499,8801,37,9105,8802,11,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-22521,"Corrego Alegre / UTM zone 21S",9001,4225,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22522,"Corrego Alegre / UTM zone 22S",9001,4225,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22523,"Corrego Alegre / UTM zone 23S",9001,4225,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22524,"Corrego Alegre / UTM zone 24S",9001,4225,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22525,"Corrego Alegre / UTM zone 25S",9001,4225,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-22700,"Deir ez Zor / Levant Zone",9001,4227,19940,9817,1,0,4499,8801,34.39,9110,8802,37.21,9110,8805,0.9996256,9201,8806,300000,9001,8807,300000,9001,,,,,,
-22770,"Deir ez Zor / Syria Lambert",9001,4227,19948,9801,1,0,4499,8801,34.39,9110,8802,37.21,9110,8805,0.9996256,9201,8806,300000,9001,8807,300000,9001,,,,,,
-22780,"Deir ez Zor / Levant Stereographic",9001,4227,19949,9809,1,0,4499,8801,38,9105,8802,43.5,9105,8805,0.9995341,9201,8806,0,9001,8807,0,9001,,,,,,
-22832,"Douala / UTM zone 32N",9001,4228,16032,9807,1,1,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-22991,"Egypt 1907 / Blue Belt",9001,4229,18071,9807,1,0,4400,8801,30,9102,8802,35,9102,8805,1,9201,8806,300000,9001,8807,1100000,9001,,,,,,
-22992,"Egypt 1907 / Red Belt",9001,4229,18072,9807,1,0,4400,8801,30,9102,8802,31,9102,8805,1,9201,8806,615000,9001,8807,810000,9001,,,,,,
-22993,"Egypt 1907 / Purple Belt",9001,4229,18073,9807,1,0,4400,8801,30,9102,8802,27,9102,8805,1,9201,8806,700000,9001,8807,200000,9001,,,,,,
-22994,"Egypt 1907 / Extended Purple Belt",9001,4229,18074,9807,1,0,4400,8801,30,9102,8802,27,9102,8805,1,9201,8806,700000,9001,8807,1200000,9001,,,,,,
-23028,"ED50 / UTM zone 28N",9001,4230,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23029,"ED50 / UTM zone 29N",9001,4230,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23030,"ED50 / UTM zone 30N",9001,4230,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23031,"ED50 / UTM zone 31N",9001,4230,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23032,"ED50 / UTM zone 32N",9001,4230,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23033,"ED50 / UTM zone 33N",9001,4230,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23034,"ED50 / UTM zone 34N",9001,4230,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23035,"ED50 / UTM zone 35N",9001,4230,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23036,"ED50 / UTM zone 36N",9001,4230,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23037,"ED50 / UTM zone 37N",9001,4230,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23038,"ED50 / UTM zone 38N",9001,4230,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23090,"ED50 / TM 0 N",9001,4230,16400,9807,1,0,4400,8801,0,9102,8802,0,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23095,"ED50 / TM 5 NE",9001,4230,16405,9807,1,0,4400,8801,0,9102,8802,5,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23239,"Fahud / UTM zone 39N",9001,4232,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23240,"Fahud / UTM zone 40N",9001,4232,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23433,"Garoua / UTM zone 33N",9001,4234,16033,9807,1,1,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23700,"HD72 / EOV",9001,4237,19931,9815,1,0,4498,8811,47.08398174,9110,8812,19.02548584,9110,8813,90,9110,8814,90,9110,8815,0.99993,9201,8816,650000,9001,8817,200000,9001
-23830,"DGN95 / Indonesia TM-3 zone 46.2",9001,4755,17432,9807,1,0,4499,8801,0,9102,8802,94.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23831,"DGN95 / Indonesia TM-3 zone 47.1",9001,4755,17433,9807,1,0,4499,8801,0,9102,8802,97.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23832,"DGN95 / Indonesia TM-3 zone 47.2",9001,4755,17434,9807,1,0,4499,8801,0,9102,8802,100.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23833,"DGN95 / Indonesia TM-3 zone 48.1",9001,4755,17435,9807,1,0,4499,8801,0,9102,8802,103.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23834,"DGN95 / Indonesia TM-3 zone 48.2",9001,4755,17436,9807,1,0,4499,8801,0,9102,8802,106.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23835,"DGN95 / Indonesia TM-3 zone 49.1",9001,4755,17437,9807,1,0,4499,8801,0,9102,8802,109.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23836,"DGN95 / Indonesia TM-3 zone 49.2",9001,4755,17438,9807,1,0,4499,8801,0,9102,8802,112.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23837,"DGN95 / Indonesia TM-3 zone 50.1",9001,4755,17439,9807,1,0,4499,8801,0,9102,8802,115.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23838,"DGN95 / Indonesia TM-3 zone 50.2",9001,4755,17440,9807,1,0,4499,8801,0,9102,8802,118.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23839,"DGN95 / Indonesia TM-3 zone 51.1",9001,4755,17441,9807,1,0,4499,8801,0,9102,8802,121.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23840,"DGN95 / Indonesia TM-3 zone 51.2",9001,4755,17442,9807,1,0,4499,8801,0,9102,8802,124.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23841,"DGN95 / Indonesia TM-3 zone 52.1",9001,4755,17443,9807,1,0,4499,8801,0,9102,8802,127.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23842,"DGN95 / Indonesia TM-3 zone 52.2",9001,4755,17444,9807,1,0,4499,8801,0,9102,8802,130.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23843,"DGN95 / Indonesia TM-3 zone 53.1",9001,4755,17445,9807,1,0,4499,8801,0,9102,8802,133.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23844,"DGN95 / Indonesia TM-3 zone 53.2",9001,4755,17446,9807,1,0,4499,8801,0,9102,8802,136.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23845,"DGN95 / Indonesia TM-3 zone 54.1",9001,4755,17447,9807,1,0,4499,8801,0,9102,8802,139.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-23846,"ID74 / UTM zone 46N",9001,4238,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23847,"ID74 / UTM zone 47N",9001,4238,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23848,"ID74 / UTM zone 48N",9001,4238,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23849,"ID74 / UTM zone 49N",9001,4238,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23850,"ID74 / UTM zone 50N",9001,4238,16050,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23851,"ID74 / UTM zone 51N",9001,4238,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23852,"ID74 / UTM zone 52N",9001,4238,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23853,"ID74 / UTM zone 53N",9001,4238,16053,9807,1,1,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23866,"DGN95 / UTM zone 46N",9001,4755,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23867,"DGN95 / UTM zone 47N",9001,4755,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23868,"DGN95 / UTM zone 48N",9001,4755,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23869,"DGN95 / UTM zone 49N",9001,4755,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23870,"DGN95 / UTM zone 50N",9001,4755,16050,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23871,"DGN95 / UTM zone 51N",9001,4755,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23872,"DGN95 / UTM zone 52N",9001,4755,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23877,"DGN95 / UTM zone 47S",9001,4755,16147,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23878,"DGN95 / UTM zone 48S",9001,4755,16148,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23879,"DGN95 / UTM zone 49S",9001,4755,16149,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23880,"DGN95 / UTM zone 50S",9001,4755,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23881,"DGN95 / UTM zone 51S",9001,4755,16151,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23882,"DGN95 / UTM zone 52S",9001,4755,16152,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23883,"DGN95 / UTM zone 53S",9001,4755,16153,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23884,"DGN95 / UTM zone 54S",9001,4755,16154,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23886,"ID74 / UTM zone 46S",9001,4238,16146,9807,1,1,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23887,"ID74 / UTM zone 47S",9001,4238,16147,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23888,"ID74 / UTM zone 48S",9001,4238,16148,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23889,"ID74 / UTM zone 49S",9001,4238,16149,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23890,"ID74 / UTM zone 50S",9001,4238,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23891,"ID74 / UTM zone 51S",9001,4238,16151,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23892,"ID74 / UTM zone 52S",9001,4238,16152,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23893,"ID74 / UTM zone 53S",9001,4238,16153,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23894,"ID74 / UTM zone 54S",9001,4238,16154,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-23946,"Indian 1954 / UTM zone 46N",9001,4239,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23947,"Indian 1954 / UTM zone 47N",9001,4239,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-23948,"Indian 1954 / UTM zone 48N",9001,4239,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24047,"Indian 1975 / UTM zone 47N",9001,4240,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24048,"Indian 1975 / UTM zone 48N",9001,4240,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24100,"Jamaica 1875 / Jamaica (Old Grid)",9005,4241,19909,9801,1,0,4403,8801,18,9102,8802,-77,9102,8805,1,9201,8806,550000,9005,8807,400000,9005,,,,,,
-24200,"JAD69 / Jamaica National Grid",9001,4242,19910,9801,1,0,4400,8801,18,9102,8802,-77,9102,8805,1,9201,8806,250000,9001,8807,150000,9001,,,,,,
-24305,"Kalianpur 1937 / UTM zone 45N",9001,4144,16045,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24306,"Kalianpur 1937 / UTM zone 46N",9001,4144,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24311,"Kalianpur 1962 / UTM zone 41N",9001,4145,16041,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24312,"Kalianpur 1962 / UTM zone 42N",9001,4145,16042,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24313,"Kalianpur 1962 / UTM zone 43N",9001,4145,16043,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24342,"Kalianpur 1975 / UTM zone 42N",9001,4146,16042,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24343,"Kalianpur 1975 / UTM zone 43N",9001,4146,16043,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24344,"Kalianpur 1975 / UTM zone 44N",9001,4146,16044,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24345,"Kalianpur 1975 / UTM zone 45N",9001,4146,16045,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24346,"Kalianpur 1975 / UTM zone 46N",9001,4146,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24347,"Kalianpur 1975 / UTM zone 47N",9001,4146,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24370,"Kalianpur 1880 / India zone 0",9084,4243,18110,9801,1,0,4408,8801,39.3,9110,8802,68,9110,8805,0.99846154,9201,8806,2355500,9084,8807,2590000,9084,,,,,,
-24371,"Kalianpur 1880 / India zone I",9084,4243,18111,9801,1,0,4408,8801,32.3,9110,8802,68,9110,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-24372,"Kalianpur 1880 / India zone IIa",9084,4243,18112,9801,1,0,4408,8801,26,9102,8802,74,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-24373,"Kalianpur 1880 / India zone III",9084,4243,18114,9801,1,0,4408,8801,19,9102,8802,80,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-24374,"Kalianpur 1880 / India zone IV",9084,4243,18116,9801,1,0,4408,8801,12,9102,8802,80,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-24375,"Kalianpur 1937 / India zone IIb",9001,4144,18238,9801,1,0,4400,8801,26,9102,8802,90,9102,8805,0.99878641,9201,8806,2743185.69,9001,8807,914395.23,9001,,,,,,
-24376,"Kalianpur 1962 / India zone I",9001,4145,18236,9801,1,0,4400,8801,32.3,9110,8802,68,9110,8805,0.99878641,9201,8806,2743196.4,9001,8807,914398.8,9001,,,,,,
-24377,"Kalianpur 1962 / India zone IIa",9001,4145,18237,9801,1,0,4400,8801,26,9102,8802,74,9102,8805,0.99878641,9201,8806,2743196.4,9001,8807,914398.8,9001,,,,,,
-24378,"Kalianpur 1975 / India zone I",9001,4146,18231,9801,1,0,4400,8801,32.3,9110,8802,68,9110,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-24379,"Kalianpur 1975 / India zone IIa",9001,4146,18232,9801,1,0,4400,8801,26,9102,8802,74,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-24380,"Kalianpur 1975 / India zone IIb",9001,4146,18235,9801,1,0,4400,8801,26,9102,8802,90,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-24381,"Kalianpur 1975 / India zone III",9001,4146,18233,9801,1,0,4400,8801,19,9102,8802,80,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-24382,"Kalianpur 1880 / India zone IIb",9084,4243,18113,9801,1,0,4408,8801,26,9102,8802,90,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-24383,"Kalianpur 1975 / India zone IV",9001,4146,18234,9801,1,0,4400,8801,12,9102,8802,80,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-24500,"Kertau 1968 / Singapore Grid",9001,4245,19920,9806,1,0,4400,8801,1.1715528,9110,8802,103.5110808,9110,8806,30000,9001,8807,30000,9001,,,,,,,,,
-24547,"Kertau 1968 / UTM zone 47N",9001,4245,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24548,"Kertau 1968 / UTM zone 48N",9001,4245,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24571,"Kertau / R.S.O. Malaya (ch)",9062,4245,19935,9812,1,1,4401,8806,40000,9062,8807,0,9062,8811,4,9110,8812,102.15,9110,8813,323.01328458,9110,8814,323.07483685,9110,8815,0.99984,9201
-24600,KOC Lambert,9001,4246,19906,9801,1,0,4400,8801,32.3,9110,8802,45,9110,8805,0.9987864078,9201,8806,1500000,9001,8807,1166200,9001,,,,,,
-24718,"La Canoa / UTM zone 18N",9001,4247,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24719,"La Canoa / UTM zone 19N",9001,4247,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24720,"La Canoa / UTM zone 20N",9001,4247,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24817,"PSAD56 / UTM zone 17N",9001,4248,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24818,"PSAD56 / UTM zone 18N",9001,4248,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24819,"PSAD56 / UTM zone 19N",9001,4248,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24820,"PSAD56 / UTM zone 20N",9001,4248,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24821,"PSAD56 / UTM zone 21N",9001,4248,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-24877,"PSAD56 / UTM zone 17S",9001,4248,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-24878,"PSAD56 / UTM zone 18S",9001,4248,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-24879,"PSAD56 / UTM zone 19S",9001,4248,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-24880,"PSAD56 / UTM zone 20S",9001,4248,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-24881,"PSAD56 / UTM zone 21S",9001,4248,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-24882,"PSAD56 / UTM zone 22S",9001,4248,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-24891,"PSAD56 / Peru west zone",9001,4248,18161,9807,1,0,4499,8801,-6,9110,8802,-80.3,9110,8805,0.99983008,9201,8806,222000,9001,8807,1426834.743,9001,,,,,,
-24892,"PSAD56 / Peru central zone",9001,4248,18162,9807,1,0,4499,8801,-9.3,9110,8802,-76,9110,8805,0.99932994,9201,8806,720000,9001,8807,1039979.159,9001,,,,,,
-24893,"PSAD56 / Peru east zone",9001,4248,18163,9807,1,0,4499,8801,-9.3,9110,8802,-70.3,9110,8805,0.99952992,9201,8806,1324000,9001,8807,1040084.558,9001,,,,,,
-25000,"Leigon / Ghana Metre Grid",9001,4250,19904,9807,1,0,4400,8801,4.4,9110,8802,-1,9110,8805,0.99975,9201,8806,274319.51,9001,8807,0,9001,,,,,,
-25231,"Lome / UTM zone 31N",9001,4252,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25391,"Luzon 1911 / Philippines zone I",9001,4253,18171,9807,1,0,4499,8801,0,9102,8802,117,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-25392,"Luzon 1911 / Philippines zone II",9001,4253,18172,9807,1,0,4499,8801,0,9102,8802,119,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-25393,"Luzon 1911 / Philippines zone III",9001,4253,18173,9807,1,0,4499,8801,0,9102,8802,121,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-25394,"Luzon 1911 / Philippines zone IV",9001,4253,18174,9807,1,0,4499,8801,0,9102,8802,123,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-25395,"Luzon 1911 / Philippines zone V",9001,4253,18175,9807,1,0,4499,8801,0,9102,8802,125,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-25700,"Makassar (Jakarta) / NEIEZ",9001,4804,19905,9804,1,1,4499,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-25828,"ETRS89 / UTM zone 28N",9001,4258,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25829,"ETRS89 / UTM zone 29N",9001,4258,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25830,"ETRS89 / UTM zone 30N",9001,4258,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25831,"ETRS89 / UTM zone 31N",9001,4258,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25832,"ETRS89 / UTM zone 32N",9001,4258,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25833,"ETRS89 / UTM zone 33N",9001,4258,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25834,"ETRS89 / UTM zone 34N",9001,4258,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25835,"ETRS89 / UTM zone 35N",9001,4258,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25836,"ETRS89 / UTM zone 36N",9001,4258,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25837,"ETRS89 / UTM zone 37N",9001,4258,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25838,"ETRS89 / UTM zone 38N",9001,4258,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25884,"ETRS89 / TM Baltic93",9001,4258,19939,9807,1,0,4530,8801,0,9102,8802,24,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-25932,"Malongo 1987 / UTM zone 32S",9001,4259,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-26191,"Merchich / Nord Maroc",9001,4261,18131,9801,1,0,4499,8801,37,9105,8802,-6,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-26192,"Merchich / Sud Maroc",9001,4261,18132,9801,1,0,4499,8801,33,9105,8802,-6,9105,8805,0.999615596,9201,8806,500000,9001,8807,300000,9001,,,,,,
-26193,"Merchich / Sahara",9001,4261,18133,9801,1,1,4499,8801,29,9105,8802,-6,9105,8805,0.9996,9201,8806,1200000,9001,8807,400000,9001,,,,,,
-26194,"Merchich / Sahara Nord",9001,4261,18134,9801,1,0,4499,8801,29,9105,8802,-6,9105,8805,0.999616304,9201,8806,1200000,9001,8807,400000,9001,,,,,,
-26195,"Merchich / Sahara Sud",9001,4261,18135,9801,1,0,4499,8801,25,9105,8802,-6,9105,8805,0.999616437,9201,8806,1500000,9001,8807,400000,9001,,,,,,
-26237,"Massawa / UTM zone 37N",9001,4262,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26331,"Minna / UTM zone 31N",9001,4263,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26332,"Minna / UTM zone 32N",9001,4263,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26391,"Minna / Nigeria West Belt",9001,4263,18151,9807,1,0,4400,8801,4,9110,8802,4.3,9110,8805,0.99975,9201,8806,230738.26,9001,8807,0,9001,,,,,,
-26392,"Minna / Nigeria Mid Belt",9001,4263,18152,9807,1,0,4400,8801,4,9110,8802,8.3,9110,8805,0.99975,9201,8806,670553.98,9001,8807,0,9001,,,,,,
-26393,"Minna / Nigeria East Belt",9001,4263,18153,9807,1,0,4400,8801,4,9110,8802,12.3,9110,8805,0.99975,9201,8806,1110369.7,9001,8807,0,9001,,,,,,
-26432,"Mhast / UTM zone 32S",9001,4264,16132,9807,1,1,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-26591,"Monte Mario (Rome) / Italy zone 1",9001,4806,18121,9807,1,1,4499,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,1500000,9001,8807,0,9001,,,,,,
-26592,"Monte Mario (Rome) / Italy zone 2",9001,4806,18122,9807,1,1,4499,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,2520000,9001,8807,0,9001,,,,,,
-26632,"M'poraloko / UTM zone 32N",9001,4266,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26692,"M'poraloko / UTM zone 32S",9001,4266,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-26701,"NAD27 / UTM zone 1N",9001,4267,16001,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26702,"NAD27 / UTM zone 2N",9001,4267,16002,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26703,"NAD27 / UTM zone 3N",9001,4267,16003,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26704,"NAD27 / UTM zone 4N",9001,4267,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26705,"NAD27 / UTM zone 5N",9001,4267,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26706,"NAD27 / UTM zone 6N",9001,4267,16006,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26707,"NAD27 / UTM zone 7N",9001,4267,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26708,"NAD27 / UTM zone 8N",9001,4267,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26709,"NAD27 / UTM zone 9N",9001,4267,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26710,"NAD27 / UTM zone 10N",9001,4267,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26711,"NAD27 / UTM zone 11N",9001,4267,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26712,"NAD27 / UTM zone 12N",9001,4267,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26713,"NAD27 / UTM zone 13N",9001,4267,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26714,"NAD27 / UTM zone 14N",9001,4267,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26715,"NAD27 / UTM zone 15N",9001,4267,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26716,"NAD27 / UTM zone 16N",9001,4267,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26717,"NAD27 / UTM zone 17N",9001,4267,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26718,"NAD27 / UTM zone 18N",9001,4267,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26719,"NAD27 / UTM zone 19N",9001,4267,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26720,"NAD27 / UTM zone 20N",9001,4267,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26721,"NAD27 / UTM zone 21N",9001,4267,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26722,"NAD27 / UTM zone 22N",9001,4267,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26729,"NAD27 / Alabama East",9003,4267,10101,9807,1,0,4497,8801,30.3,9110,8802,-85.5,9110,8805,0.99996,9201,8806,500000,9003,8807,0,9003,,,,,,
-26730,"NAD27 / Alabama West",9003,4267,10102,9807,1,0,4497,8801,30,9110,8802,-87.3,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-26731,"NAD27 / Alaska zone 1",9003,4267,15001,9812,1,0,4497,8806,16404166.67,9003,8807,-16404166.67,9003,8811,57,9110,8812,-133.4,9110,8813,323.07483685,9110,8814,323.07483685,9110,8815,0.9999,9201
-26732,"NAD27 / Alaska zone 2",9003,4267,15002,9807,1,0,4497,8801,54,9102,8802,-142,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26733,"NAD27 / Alaska zone 3",9003,4267,15003,9807,1,0,4497,8801,54,9102,8802,-146,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26734,"NAD27 / Alaska zone 4",9003,4267,15004,9807,1,0,4497,8801,54,9102,8802,-150,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26735,"NAD27 / Alaska zone 5",9003,4267,15005,9807,1,0,4497,8801,54,9102,8802,-154,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26736,"NAD27 / Alaska zone 6",9003,4267,15006,9807,1,0,4497,8801,54,9102,8802,-158,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26737,"NAD27 / Alaska zone 7",9003,4267,15007,9807,1,0,4497,8801,54,9102,8802,-162,9102,8805,0.9999,9201,8806,700000,9003,8807,0,9003,,,,,,
-26738,"NAD27 / Alaska zone 8",9003,4267,15008,9807,1,0,4497,8801,54,9102,8802,-166,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26739,"NAD27 / Alaska zone 9",9003,4267,15009,9807,1,0,4497,8801,54,9102,8802,-170,9102,8805,0.9999,9201,8806,600000,9003,8807,0,9003,,,,,,
-26740,"NAD27 / Alaska zone 10",9003,4267,15010,9802,1,0,4497,8821,51,9110,8822,-176,9110,8823,53.5,9110,8824,51.5,9110,8826,3000000,9003,8827,0,9003,,,
-26741,"NAD27 / California zone I",9003,4267,10401,9802,1,0,4497,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,2000000,9003,8827,0,9003,,,
-26742,"NAD27 / California zone II",9003,4267,10402,9802,1,0,4497,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,2000000,9003,8827,0,9003,,,
-26743,"NAD27 / California zone III",9003,4267,10403,9802,1,0,4497,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,2000000,9003,8827,0,9003,,,
-26744,"NAD27 / California zone IV",9003,4267,10404,9802,1,0,4497,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,2000000,9003,8827,0,9003,,,
-26745,"NAD27 / California zone V",9003,4267,10405,9802,1,0,4497,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,2000000,9003,8827,0,9003,,,
-26746,"NAD27 / California zone VI",9003,4267,10406,9802,1,0,4497,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,2000000,9003,8827,0,9003,,,
-26747,"NAD27 / California zone VII",9003,4267,10407,9802,1,1,4497,8821,34.08,9110,8822,-118.2,9110,8823,34.25,9110,8824,33.52,9110,8826,4186692.58,9003,8827,416926.74,9003,,,
-26748,"NAD27 / Arizona East",9003,4267,10201,9807,1,0,4497,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26749,"NAD27 / Arizona Central",9003,4267,10202,9807,1,0,4497,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26750,"NAD27 / Arizona West",9003,4267,10203,9807,1,0,4497,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-26751,"NAD27 / Arkansas North",9003,4267,10301,9802,1,0,4497,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,2000000,9003,8827,0,9003,,,
-26752,"NAD27 / Arkansas South",9003,4267,10302,9802,1,0,4497,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,2000000,9003,8827,0,9003,,,
-26753,"NAD27 / Colorado North",9003,4267,10501,9802,1,0,4497,8821,39.2,9110,8822,-105.3,9110,8823,39.43,9110,8824,40.47,9110,8826,2000000,9003,8827,0,9003,,,
-26754,"NAD27 / Colorado Central",9003,4267,10502,9802,1,0,4497,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,2000000,9003,8827,0,9003,,,
-26755,"NAD27 / Colorado South",9003,4267,10503,9802,1,0,4497,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,2000000,9003,8827,0,9003,,,
-26756,"NAD27 / Connecticut",9003,4267,10600,9802,1,0,4497,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,600000,9003,8827,0,9003,,,
-26757,"NAD27 / Delaware",9003,4267,10700,9807,1,0,4497,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,500000,9003,8807,0,9003,,,,,,
-26758,"NAD27 / Florida East",9003,4267,10901,9807,1,0,4497,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-26759,"NAD27 / Florida West",9003,4267,10902,9807,1,0,4497,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-26760,"NAD27 / Florida North",9003,4267,10903,9802,1,0,4497,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,2000000,9003,8827,0,9003,,,
-26766,"NAD27 / Georgia East",9003,4267,11001,9807,1,0,4497,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26767,"NAD27 / Georgia West",9003,4267,11002,9807,1,0,4497,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26768,"NAD27 / Idaho East",9003,4267,11101,9807,1,0,4497,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,500000,9003,8807,0,9003,,,,,,
-26769,"NAD27 / Idaho Central",9003,4267,11102,9807,1,0,4497,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,500000,9003,8807,0,9003,,,,,,
-26770,"NAD27 / Idaho West",9003,4267,11103,9807,1,0,4497,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-26771,"NAD27 / Illinois East",9003,4267,11201,9807,1,0,4497,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,500000,9003,8807,0,9003,,,,,,
-26772,"NAD27 / Illinois West",9003,4267,11202,9807,1,0,4497,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-26773,"NAD27 / Indiana East",9003,4267,11301,9807,1,0,4497,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-26774,"NAD27 / Indiana West",9003,4267,11302,9807,1,0,4497,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-26775,"NAD27 / Iowa North",9003,4267,11401,9802,1,0,4497,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,2000000,9003,8827,0,9003,,,
-26776,"NAD27 / Iowa South",9003,4267,11402,9802,1,0,4497,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,2000000,9003,8827,0,9003,,,
-26777,"NAD27 / Kansas North",9003,4267,11501,9802,1,0,4497,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,2000000,9003,8827,0,9003,,,
-26778,"NAD27 / Kansas South",9003,4267,11502,9802,1,0,4497,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,2000000,9003,8827,0,9003,,,
-26779,"NAD27 / Kentucky North",9003,4267,11601,9802,1,0,4497,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,2000000,9003,8827,0,9003,,,
-26780,"NAD27 / Kentucky South",9003,4267,11602,9802,1,0,4497,8821,36.2,9110,8822,-85.45,9110,8823,36.44,9110,8824,37.56,9110,8826,2000000,9003,8827,0,9003,,,
-26781,"NAD27 / Louisiana North",9003,4267,11701,9802,1,0,4497,8821,30.4,9110,8822,-92.3,9110,8823,31.1,9110,8824,32.4,9110,8826,2000000,9003,8827,0,9003,,,
-26782,"NAD27 / Louisiana South",9003,4267,11702,9802,1,0,4497,8821,28.4,9110,8822,-91.2,9110,8823,29.18,9110,8824,30.42,9110,8826,2000000,9003,8827,0,9003,,,
-26783,"NAD27 / Maine East",9003,4267,11801,9807,1,0,4497,8801,43.5,9110,8802,-68.3,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-26784,"NAD27 / Maine West",9003,4267,11802,9807,1,0,4497,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-26785,"NAD27 / Maryland",9003,4267,11900,9802,1,0,4497,8821,37.5,9110,8822,-77,9110,8823,38.18,9110,8824,39.27,9110,8826,800000,9003,8827,0,9003,,,
-26786,"NAD27 / Massachusetts Mainland",9003,4267,12001,9802,1,0,4497,8821,41,9110,8822,-71.3,9110,8823,41.43,9110,8824,42.41,9110,8826,600000,9003,8827,0,9003,,,
-26787,"NAD27 / Massachusetts Island",9003,4267,12002,9802,1,0,4497,8821,41,9110,8822,-70.3,9110,8823,41.17,9110,8824,41.29,9110,8826,200000,9003,8827,0,9003,,,
-26791,"NAD27 / Minnesota North",9003,4267,12201,9802,1,0,4497,8821,46.3,9110,8822,-93.06,9110,8823,47.02,9110,8824,48.38,9110,8826,2000000,9003,8827,0,9003,,,
-26792,"NAD27 / Minnesota Central",9003,4267,12202,9802,1,0,4497,8821,45,9110,8822,-94.15,9110,8823,45.37,9110,8824,47.03,9110,8826,2000000,9003,8827,0,9003,,,
-26793,"NAD27 / Minnesota South",9003,4267,12203,9802,1,0,4497,8821,43,9110,8822,-94,9110,8823,43.47,9110,8824,45.13,9110,8826,2000000,9003,8827,0,9003,,,
-26794,"NAD27 / Mississippi East",9003,4267,12301,9807,1,0,4497,8801,29.4,9110,8802,-88.5,9110,8805,0.99996,9201,8806,500000,9003,8807,0,9003,,,,,,
-26795,"NAD27 / Mississippi West",9003,4267,12302,9807,1,0,4497,8801,30.3,9110,8802,-90.2,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-26796,"NAD27 / Missouri East",9003,4267,12401,9807,1,0,4497,8801,35.5,9110,8802,-90.3,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-26797,"NAD27 / Missouri Central",9003,4267,12402,9807,1,0,4497,8801,35.5,9110,8802,-92.3,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-26798,"NAD27 / Missouri West",9003,4267,12403,9807,1,0,4497,8801,36.1,9110,8802,-94.3,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-26799,"NAD27 / California zone VII",9003,4267,10408,9802,1,0,4497,8821,34.08,9110,8822,-118.2,9110,8823,34.25,9110,8824,33.52,9110,8826,4186692.58,9003,8827,4160926.74,9003,,,
-26801,"NAD Michigan / Michigan East",9003,4268,12101,9807,1,0,4497,8801,41.3,9110,8802,-83.4,9110,8805,0.999942857,9201,8806,500000,9003,8807,0,9003,,,,,,
-26802,"NAD Michigan / Michigan Old Central",9003,4268,12102,9807,1,0,4497,8801,41.3,9110,8802,-85.45,9110,8805,0.999909091,9201,8806,500000,9003,8807,0,9003,,,,,,
-26803,"NAD Michigan / Michigan West",9003,4268,12103,9807,1,0,4497,8801,41.3,9110,8802,-88.45,9110,8805,0.999909091,9201,8806,500000,9003,8807,0,9003,,,,,,
-26811,"NAD Michigan / Michigan North",9003,4268,12111,9802,1,0,4497,8821,44.47,9110,8822,-87,9110,8823,45.29,9110,8824,47.05,9110,8826,2000000,9003,8827,0,9003,,,
-26812,"NAD Michigan / Michigan Central",9003,4268,12112,9802,1,0,4497,8821,43.19,9110,8822,-84.2,9110,8823,44.11,9110,8824,45.42,9110,8826,2000000,9003,8827,0,9003,,,
-26813,"NAD Michigan / Michigan South",9003,4268,12113,9802,1,0,4497,8821,41.3,9110,8822,-84.2,9110,8823,42.06,9110,8824,43.4,9110,8826,2000000,9003,8827,0,9003,,,
-26814,"NAD83 / Maine East (ftUS)",9001,4269,11833,9807,1,1,4499,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-26815,"NAD83 / Maine West (ftUS)",9001,4269,11834,9807,1,1,4499,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-26819,"NAD83 / Minnesota North (ftUS)",9001,4269,12234,9802,1,1,4499,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26820,"NAD83 / Minnesota Central (ftUS)",9001,4269,12235,9802,1,1,4499,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26821,"NAD83 / Minnesota South (ftUS)",9001,4269,12236,9802,1,1,4499,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26822,"NAD83 / Nebraska (ftUS)",9001,4269,15396,9802,1,1,4499,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-26823,"NAD83 / West Virginia North (ftUS)",9001,4269,14733,9802,1,1,4499,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9001,8827,0,9001,,,
-26824,"NAD83 / West Virginia South (ftUS)",9001,4269,14734,9802,1,1,4499,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9001,8827,0,9001,,,
-26825,"NAD83(HARN) / Maine East (ftUS)",9001,4152,11833,9807,1,1,4499,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-26826,"NAD83(HARN) / Maine West (ftUS)",9001,4152,11834,9807,1,1,4499,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-26830,"NAD83(HARN) / Minnesota North (ftUS)",9001,4152,12234,9802,1,1,4499,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26831,"NAD83(HARN) / Minnesota Central (ftUS)",9001,4152,12235,9802,1,1,4499,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26832,"NAD83(HARN) / Minnesota South (ftUS)",9001,4152,12236,9802,1,1,4499,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26833,"NAD83(HARN) / Nebraska (ftUS)",9001,4152,15396,9802,1,1,4499,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-26834,"NAD83(HARN) / West Virginia North (ftUS)",9001,4152,14733,9802,1,1,4499,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9001,8827,0,9001,,,
-26835,"NAD83(HARN) / West Virginia South (ftUS)",9001,4152,14734,9802,1,1,4499,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9001,8827,0,9001,,,
-26836,"NAD83(NSRS2007) / Maine East (ftUS)",9001,4759,11833,9807,1,1,4499,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-26837,"NAD83(NSRS2007) / Maine West (ftUS)",9001,4759,11834,9807,1,1,4499,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-26841,"NAD83(NSRS2007) / Minnesota North (ftUS)",9001,4759,12234,9802,1,1,4499,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26842,"NAD83(NSRS2007) / Minnesota Central (ftUS)",9001,4759,12235,9802,1,1,4499,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26843,"NAD83(NSRS2007) / Minnesota South (ftUS)",9001,4759,12236,9802,1,1,4499,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26844,"NAD83(NSRS2007) / Nebraska (ftUS)",9001,4759,15396,9802,1,1,4499,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-26845,"NAD83(NSRS2007) / West Virginia North (ftUS)",9001,4759,14733,9802,1,1,4499,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9001,8827,0,9001,,,
-26846,"NAD83(NSRS2007) / West Virginia South (ftUS)",9001,4759,14734,9802,1,1,4499,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9001,8827,0,9001,,,
-26847,"NAD83 / Maine East (ftUS)",9003,4269,11833,9807,1,0,4497,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-26848,"NAD83 / Maine West (ftUS)",9003,4269,11834,9807,1,0,4497,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-26849,"NAD83 / Minnesota North (ftUS)",9003,4269,12234,9802,1,0,4497,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26850,"NAD83 / Minnesota Central (ftUS)",9003,4269,12235,9802,1,0,4497,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26851,"NAD83 / Minnesota South (ftUS)",9003,4269,12236,9802,1,0,4497,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26852,"NAD83 / Nebraska (ftUS)",9003,4269,15396,9802,1,0,4497,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-26853,"NAD83 / West Virginia North (ftUS)",9003,4269,14735,9802,1,0,4497,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9003,8827,0,9003,,,
-26854,"NAD83 / West Virginia South (ftUS)",9003,4269,14736,9802,1,0,4497,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9003,8827,0,9003,,,
-26855,"NAD83(HARN) / Maine East (ftUS)",9003,4152,11833,9807,1,0,4497,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-26856,"NAD83(HARN) / Maine West (ftUS)",9003,4152,11834,9807,1,0,4497,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-26857,"NAD83(HARN) / Minnesota North (ftUS)",9003,4152,12234,9802,1,0,4497,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26858,"NAD83(HARN) / Minnesota Central (ftUS)",9003,4152,12235,9802,1,0,4497,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26859,"NAD83(HARN) / Minnesota South (ftUS)",9003,4152,12236,9802,1,0,4497,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26860,"NAD83(HARN) / Nebraska (ftUS)",9003,4152,15396,9802,1,0,4497,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-26861,"NAD83(HARN) / West Virginia North (ftUS)",9003,4152,14735,9802,1,0,4497,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9003,8827,0,9003,,,
-26862,"NAD83(HARN) / West Virginia South (ftUS)",9003,4152,14736,9802,1,0,4497,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9003,8827,0,9003,,,
-26863,"NAD83(NSRS2007) / Maine East (ftUS)",9003,4759,11833,9807,1,0,4497,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-26864,"NAD83(NSRS2007) / Maine West (ftUS)",9003,4759,11834,9807,1,0,4497,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-26865,"NAD83(NSRS2007) / Minnesota North (ftUS)",9003,4759,12234,9802,1,0,4497,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26866,"NAD83(NSRS2007) / Minnesota Central (ftUS)",9003,4759,12235,9802,1,0,4497,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26867,"NAD83(NSRS2007) / Minnesota South (ftUS)",9003,4759,12236,9802,1,0,4497,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-26868,"NAD83(NSRS2007) / Nebraska (ftUS)",9003,4759,15396,9802,1,0,4497,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-26869,"NAD83(NSRS2007) / West Virginia North (ftUS)",9003,4759,14735,9802,1,0,4497,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9003,8827,0,9003,,,
-26870,"NAD83(NSRS2007) / West Virginia South (ftUS)",9003,4759,14736,9802,1,0,4497,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9003,8827,0,9003,,,
-26891,"NAD83(CSRS) / MTM zone 11",9001,4617,17711,9807,1,0,4400,8801,0,9110,8802,-82.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26892,"NAD83(CSRS) / MTM zone 12",9001,4617,17712,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26893,"NAD83(CSRS) / MTM zone 13",9001,4617,17713,9807,1,0,4400,8801,0,9102,8802,-84,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26894,"NAD83(CSRS) / MTM zone 14",9001,4617,17714,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26895,"NAD83(CSRS) / MTM zone 15",9001,4617,17715,9807,1,0,4400,8801,0,9102,8802,-90,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26896,"NAD83(CSRS) / MTM zone 16",9001,4617,17716,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26897,"NAD83(CSRS) / MTM zone 17",9001,4617,17717,9807,1,0,4400,8801,0,9102,8802,-96,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26898,"NAD83(CSRS) / MTM zone 1",9001,4617,17701,9807,1,0,4496,8801,0,9102,8802,-53,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26899,"NAD83(CSRS) / MTM zone 2",9001,4617,17702,9807,1,0,4496,8801,0,9102,8802,-56,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-26901,"NAD83 / UTM zone 1N",9001,4269,16001,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26902,"NAD83 / UTM zone 2N",9001,4269,16002,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26903,"NAD83 / UTM zone 3N",9001,4269,16003,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26904,"NAD83 / UTM zone 4N",9001,4269,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26905,"NAD83 / UTM zone 5N",9001,4269,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26906,"NAD83 / UTM zone 6N",9001,4269,16006,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26907,"NAD83 / UTM zone 7N",9001,4269,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26908,"NAD83 / UTM zone 8N",9001,4269,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26909,"NAD83 / UTM zone 9N",9001,4269,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26910,"NAD83 / UTM zone 10N",9001,4269,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26911,"NAD83 / UTM zone 11N",9001,4269,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26912,"NAD83 / UTM zone 12N",9001,4269,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26913,"NAD83 / UTM zone 13N",9001,4269,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26914,"NAD83 / UTM zone 14N",9001,4269,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26915,"NAD83 / UTM zone 15N",9001,4269,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26916,"NAD83 / UTM zone 16N",9001,4269,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26917,"NAD83 / UTM zone 17N",9001,4269,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26918,"NAD83 / UTM zone 18N",9001,4269,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26919,"NAD83 / UTM zone 19N",9001,4269,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26920,"NAD83 / UTM zone 20N",9001,4269,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26921,"NAD83 / UTM zone 21N",9001,4269,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26922,"NAD83 / UTM zone 22N",9001,4269,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26923,"NAD83 / UTM zone 23N",9001,4269,16023,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-26929,"NAD83 / Alabama East",9001,4269,10131,9807,1,0,4499,8801,30.3,9110,8802,-85.5,9110,8805,0.99996,9201,8806,200000,9001,8807,0,9001,,,,,,
-26930,"NAD83 / Alabama West",9001,4269,10132,9807,1,0,4499,8801,30,9110,8802,-87.3,9110,8805,0.999933333,9201,8806,600000,9001,8807,0,9001,,,,,,
-26931,"NAD83 / Alaska zone 1",9001,4269,15031,9812,1,0,4499,8806,5000000,9001,8807,-5000000,9001,8811,57,9110,8812,-133.4,9110,8813,323.07483685,9110,8814,323.07483685,9110,8815,0.9999,9201
-26932,"NAD83 / Alaska zone 2",9001,4269,15032,9807,1,0,4499,8801,54,9102,8802,-142,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26933,"NAD83 / Alaska zone 3",9001,4269,15033,9807,1,0,4499,8801,54,9102,8802,-146,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26934,"NAD83 / Alaska zone 4",9001,4269,15034,9807,1,0,4499,8801,54,9102,8802,-150,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26935,"NAD83 / Alaska zone 5",9001,4269,15035,9807,1,0,4499,8801,54,9102,8802,-154,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26936,"NAD83 / Alaska zone 6",9001,4269,15036,9807,1,0,4499,8801,54,9102,8802,-158,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26937,"NAD83 / Alaska zone 7",9001,4269,15037,9807,1,0,4499,8801,54,9102,8802,-162,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26938,"NAD83 / Alaska zone 8",9001,4269,15038,9807,1,0,4499,8801,54,9102,8802,-166,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26939,"NAD83 / Alaska zone 9",9001,4269,15039,9807,1,0,4499,8801,54,9102,8802,-170,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26940,"NAD83 / Alaska zone 10",9001,4269,15040,9802,1,0,4499,8821,51,9110,8822,-176,9110,8823,53.5,9110,8824,51.5,9110,8826,1000000,9001,8827,0,9001,,,
-26941,"NAD83 / California zone 1",9001,4269,10431,9802,1,0,4499,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,2000000,9001,8827,500000,9001,,,
-26942,"NAD83 / California zone 2",9001,4269,10432,9802,1,0,4499,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,2000000,9001,8827,500000,9001,,,
-26943,"NAD83 / California zone 3",9001,4269,10433,9802,1,0,4499,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,2000000,9001,8827,500000,9001,,,
-26944,"NAD83 / California zone 4",9001,4269,10434,9802,1,0,4499,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,2000000,9001,8827,500000,9001,,,
-26945,"NAD83 / California zone 5",9001,4269,10435,9802,1,0,4499,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,2000000,9001,8827,500000,9001,,,
-26946,"NAD83 / California zone 6",9001,4269,10436,9802,1,0,4499,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,2000000,9001,8827,500000,9001,,,
-26948,"NAD83 / Arizona East",9001,4269,10231,9807,1,0,4499,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-26949,"NAD83 / Arizona Central",9001,4269,10232,9807,1,0,4499,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-26950,"NAD83 / Arizona West",9001,4269,10233,9807,1,0,4499,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,213360,9001,8807,0,9001,,,,,,
-26951,"NAD83 / Arkansas North",9001,4269,10331,9802,1,0,4499,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,400000,9001,8827,0,9001,,,
-26952,"NAD83 / Arkansas South",9001,4269,10332,9802,1,0,4499,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,400000,9001,8827,400000,9001,,,
-26953,"NAD83 / Colorado North",9001,4269,10531,9802,1,0,4499,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-26954,"NAD83 / Colorado Central",9001,4269,10532,9802,1,0,4499,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-26955,"NAD83 / Colorado South",9001,4269,10533,9802,1,0,4499,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-26956,"NAD83 / Connecticut",9001,4269,10630,9802,1,0,4499,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,304800.6096,9001,8827,152400.3048,9001,,,
-26957,"NAD83 / Delaware",9001,4269,10730,9807,1,0,4499,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,200000,9001,8807,0,9001,,,,,,
-26958,"NAD83 / Florida East",9001,4269,10931,9807,1,0,4499,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-26959,"NAD83 / Florida West",9001,4269,10932,9807,1,0,4499,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-26960,"NAD83 / Florida North",9001,4269,10933,9802,1,0,4499,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,600000,9001,8827,0,9001,,,
-26961,"NAD83 / Hawaii zone 1",9001,4269,15131,9807,1,0,4499,8801,18.5,9110,8802,-155.3,9110,8805,0.999966667,9201,8806,500000,9001,8807,0,9001,,,,,,
-26962,"NAD83 / Hawaii zone 2",9001,4269,15132,9807,1,0,4499,8801,20.2,9110,8802,-156.4,9110,8805,0.999966667,9201,8806,500000,9001,8807,0,9001,,,,,,
-26963,"NAD83 / Hawaii zone 3",9001,4269,15133,9807,1,0,4499,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26964,"NAD83 / Hawaii zone 4",9001,4269,15134,9807,1,0,4499,8801,21.5,9110,8802,-159.3,9110,8805,0.99999,9201,8806,500000,9001,8807,0,9001,,,,,,
-26965,"NAD83 / Hawaii zone 5",9001,4269,15135,9807,1,0,4499,8801,21.4,9110,8802,-160.1,9110,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-26966,"NAD83 / Georgia East",9001,4269,11031,9807,1,0,4499,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-26967,"NAD83 / Georgia West",9001,4269,11032,9807,1,0,4499,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,700000,9001,8807,0,9001,,,,,,
-26968,"NAD83 / Idaho East",9001,4269,11131,9807,1,0,4499,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,200000,9001,8807,0,9001,,,,,,
-26969,"NAD83 / Idaho Central",9001,4269,11132,9807,1,0,4499,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,500000,9001,8807,0,9001,,,,,,
-26970,"NAD83 / Idaho West",9001,4269,11133,9807,1,0,4499,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,800000,9001,8807,0,9001,,,,,,
-26971,"NAD83 / Illinois East",9001,4269,11231,9807,1,0,4499,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,300000,9001,8807,0,9001,,,,,,
-26972,"NAD83 / Illinois West",9001,4269,11232,9807,1,0,4499,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,700000,9001,8807,0,9001,,,,,,
-26973,"NAD83 / Indiana East",9001,4269,11331,9807,1,0,4499,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,100000,9001,8807,250000,9001,,,,,,
-26974,"NAD83 / Indiana West",9001,4269,11332,9807,1,0,4499,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,900000,9001,8807,250000,9001,,,,,,
-26975,"NAD83 / Iowa North",9001,4269,11431,9802,1,0,4499,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,1500000,9001,8827,1000000,9001,,,
-26976,"NAD83 / Iowa South",9001,4269,11432,9802,1,0,4499,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,500000,9001,8827,0,9001,,,
-26977,"NAD83 / Kansas North",9001,4269,11531,9802,1,0,4499,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,400000,9001,8827,0,9001,,,
-26978,"NAD83 / Kansas South",9001,4269,11532,9802,1,0,4499,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,400000,9001,8827,400000,9001,,,
-26979,"NAD83 / Kentucky North",9001,4269,11631,9802,1,1,4499,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,37.58,9110,8826,500000,9001,8827,0,9001,,,
-26980,"NAD83 / Kentucky South",9001,4269,11632,9802,1,0,4499,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,500000,9001,8827,500000,9001,,,
-26981,"NAD83 / Louisiana North",9001,4269,11731,9802,1,0,4499,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,1000000,9001,8827,0,9001,,,
-26982,"NAD83 / Louisiana South",9001,4269,11732,9802,1,0,4499,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,1000000,9001,8827,0,9001,,,
-26983,"NAD83 / Maine East",9001,4269,11831,9807,1,0,4499,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,300000,9001,8807,0,9001,,,,,,
-26984,"NAD83 / Maine West",9001,4269,11832,9807,1,0,4499,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,900000,9001,8807,0,9001,,,,,,
-26985,"NAD83 / Maryland",9001,4269,11930,9802,1,0,4499,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,400000,9001,8827,0,9001,,,
-26986,"NAD83 / Massachusetts Mainland",9001,4269,12031,9802,1,0,4499,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,200000,9001,8827,750000,9001,,,
-26987,"NAD83 / Massachusetts Island",9001,4269,12032,9802,1,0,4499,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,500000,9001,8827,0,9001,,,
-26988,"NAD83 / Michigan North",9001,4269,12141,9802,1,0,4499,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,8000000,9001,8827,0,9001,,,
-26989,"NAD83 / Michigan Central",9001,4269,12142,9802,1,0,4499,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,6000000,9001,8827,0,9001,,,
-26990,"NAD83 / Michigan South",9001,4269,12143,9802,1,0,4499,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,4000000,9001,8827,0,9001,,,
-26991,"NAD83 / Minnesota North",9001,4269,12231,9802,1,0,4499,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,800000,9001,8827,100000,9001,,,
-26992,"NAD83 / Minnesota Central",9001,4269,12232,9802,1,0,4499,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,800000,9001,8827,100000,9001,,,
-26993,"NAD83 / Minnesota South",9001,4269,12233,9802,1,0,4499,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,800000,9001,8827,100000,9001,,,
-26994,"NAD83 / Mississippi East",9001,4269,12331,9807,1,0,4499,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,300000,9001,8807,0,9001,,,,,,
-26995,"NAD83 / Mississippi West",9001,4269,12332,9807,1,0,4499,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,700000,9001,8807,0,9001,,,,,,
-26996,"NAD83 / Missouri East",9001,4269,12431,9807,1,0,4499,8801,35.5,9110,8802,-90.3,9110,8805,0.999933333,9201,8806,250000,9001,8807,0,9001,,,,,,
-26997,"NAD83 / Missouri Central",9001,4269,12432,9807,1,0,4499,8801,35.5,9110,8802,-92.3,9110,8805,0.999933333,9201,8806,500000,9001,8807,0,9001,,,,,,
-26998,"NAD83 / Missouri West",9001,4269,12433,9807,1,0,4499,8801,36.1,9110,8802,-94.3,9110,8805,0.999941177,9201,8806,850000,9001,8807,0,9001,,,,,,
-27037,"Nahrwan 1967 / UTM zone 37N",9001,4270,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-27038,"Nahrwan 1967 / UTM zone 38N",9001,4270,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-27039,"Nahrwan 1967 / UTM zone 39N",9001,4270,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-27040,"Nahrwan 1967 / UTM zone 40N",9001,4270,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-27120,"Naparima 1972 / UTM zone 20N",9001,4271,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-27200,"NZGD49 / New Zealand Map Grid",9001,4272,19917,9811,1,0,4400,8801,-41,9102,8802,173,9102,8806,2510000,9001,8807,6023150,9001,,,,,,,,,
-27205,"NZGD49 / Mount Eden Circuit",9001,4272,17901,9807,1,0,4500,8801,-36.5247515,9110,8802,174.45516217,9110,8805,0.9999,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27206,"NZGD49 / Bay of Plenty Circuit",9001,4272,17902,9807,1,0,4500,8801,-37.45404993,9110,8802,176.27583101,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27207,"NZGD49 / Poverty Bay Circuit",9001,4272,17903,9807,1,0,4500,8801,-38.372893,9110,8802,177.53082906,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27208,"NZGD49 / Hawkes Bay Circuit",9001,4272,17904,9807,1,0,4500,8801,-39.39033455,9110,8802,176.40252499,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27209,"NZGD49 / Taranaki Circuit",9001,4272,17905,9807,1,0,4500,8801,-39.08087299,9110,8802,174.13408423,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27210,"NZGD49 / Tuhirangi Circuit",9001,4272,17906,9807,1,0,4500,8801,-39.30448934,9110,8802,175.38241325,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27211,"NZGD49 / Wanganui Circuit",9001,4272,17907,9807,1,0,4500,8801,-40.14310097,9110,8802,175.29171586,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27212,"NZGD49 / Wairarapa Circuit",9001,4272,17908,9807,1,0,4500,8801,-40.55319175,9110,8802,175.38504588,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27213,"NZGD49 / Wellington Circuit",9001,4272,17909,9807,1,0,4500,8801,-41.18047507,9110,8802,174.46358432,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27214,"NZGD49 / Collingwood Circuit",9001,4272,17910,9807,1,0,4500,8801,-40.42531326,9110,8802,172.40193674,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27215,"NZGD49 / Nelson Circuit",9001,4272,17911,9807,1,0,4500,8801,-41.1628361,9110,8802,173.17575405,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27216,"NZGD49 / Karamea Circuit",9001,4272,17912,9807,1,0,4500,8801,-41.17236815,9110,8802,172.06325015,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27217,"NZGD49 / Buller Circuit",9001,4272,17913,9807,1,0,4500,8801,-41.48388903,9110,8802,171.34525362,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27218,"NZGD49 / Grey Circuit",9001,4272,17914,9807,1,0,4500,8801,-42.20012994,9110,8802,171.32591767,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27219,"NZGD49 / Amuri Circuit",9001,4272,17915,9807,1,0,4500,8801,-42.41208197,9110,8802,173.00364802,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27220,"NZGD49 / Marlborough Circuit",9001,4272,17916,9807,1,0,4500,8801,-41.3240152,9110,8802,173.48074668,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27221,"NZGD49 / Hokitika Circuit",9001,4272,17917,9807,1,0,4500,8801,-42.53107605,9110,8802,170.58479766,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27222,"NZGD49 / Okarito Circuit",9001,4272,17918,9807,1,0,4500,8801,-43.06364613,9110,8802,170.1539333,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27223,"NZGD49 / Jacksons Bay Circuit",9001,4272,17919,9807,1,0,4500,8801,-43.58400904,9110,8802,168.36225612,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27224,"NZGD49 / Mount Pleasant Circuit",9001,4272,17920,9807,1,0,4500,8801,-43.35262953,9110,8802,172.43378969,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27225,"NZGD49 / Gawler Circuit",9001,4272,17921,9807,1,0,4500,8801,-43.44553616,9110,8802,171.21386945,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27226,"NZGD49 / Timaru Circuit",9001,4272,17922,9807,1,0,4500,8801,-44.24079933,9110,8802,171.0326103,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27227,"NZGD49 / Lindis Peak Circuit",9001,4272,17923,9807,1,0,4500,8801,-44.44069647,9110,8802,169.28039183,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27228,"NZGD49 / Mount Nicholas Circuit",9001,4272,17924,9807,1,0,4500,8801,-45.07584493,9110,8802,168.23551083,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27229,"NZGD49 / Mount York Circuit",9001,4272,17925,9807,1,0,4500,8801,-45.33494142,9110,8802,167.44199024,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27230,"NZGD49 / Observation Point Circuit",9001,4272,17926,9807,1,0,4500,8801,-45.48583078,9110,8802,170.37429426,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27231,"NZGD49 / North Taieri Circuit",9001,4272,17927,9807,1,0,4500,8801,-45.51414481,9110,8802,170.16573208,9110,8805,0.99996,9201,8806,300000,9001,8807,700000,9001,,,,,,
-27232,"NZGD49 / Bluff Circuit",9001,4272,17928,9807,1,0,4500,8801,-46.36000346,9110,8802,168.20343392,9110,8805,1,9201,8806,300002.66,9001,8807,699999.58,9001,,,,,,
-27258,"NZGD49 / UTM zone 58S",9001,4272,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-27259,"NZGD49 / UTM zone 59S",9001,4272,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-27260,"NZGD49 / UTM zone 60S",9001,4272,16160,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-27291,"NZGD49 / North Island Grid",9040,4272,18141,9807,1,0,4409,8801,-39,9110,8802,175.3,9110,8805,1,9201,8806,300000,9040,8807,400000,9040,,,,,,
-27292,"NZGD49 / South Island Grid",9040,4272,18142,9807,1,0,4409,8801,-44,9110,8802,171.3,9110,8805,1,9201,8806,500000,9040,8807,500000,9040,,,,,,
-27391,"NGO 1948 (Oslo) / NGO zone I",9001,4817,18221,9807,1,0,4531,8801,58,9110,8802,-4.4,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27392,"NGO 1948 (Oslo) / NGO zone II",9001,4817,18222,9807,1,0,4531,8801,58,9110,8802,-2.2,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27393,"NGO 1948 (Oslo) / NGO zone III",9001,4817,18223,9807,1,0,4531,8801,58,9110,8802,0,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27394,"NGO 1948 (Oslo) / NGO zone IV",9001,4817,18224,9807,1,0,4531,8801,58,9110,8802,2.3,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27395,"NGO 1948 (Oslo) / NGO zone V",9001,4817,18225,9807,1,0,4531,8801,58,9110,8802,6.1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27396,"NGO 1948 (Oslo) / NGO zone VI",9001,4817,18226,9807,1,0,4531,8801,58,9110,8802,10.1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27397,"NGO 1948 (Oslo) / NGO zone VII",9001,4817,18227,9807,1,0,4531,8801,58,9110,8802,14.1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27398,"NGO 1948 (Oslo) / NGO zone VIII",9001,4817,18228,9807,1,0,4531,8801,58,9110,8802,18.2,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-27429,"Datum 73 / UTM zone 29N",9001,4274,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-27492,"Datum 73 / Modified Portuguese Grid",9001,4274,19974,9807,1,1,4530,8801,39.4,9110,8802,-8.0754862,9110,8805,1,9201,8806,180.598,9001,8807,-86.99,9001,,,,,,
-27493,"Datum 73 / Modified Portuguese Grid",9001,4274,19974,9807,1,0,4499,8801,39.4,9110,8802,-8.0754862,9110,8805,1,9201,8806,180.598,9001,8807,-86.99,9001,,,,,,
-27500,"ATF (Paris) / Nord de Guerre",9001,4901,19903,9801,1,0,4499,8801,55,9105,8802,6,9105,8805,0.99950908,9201,8806,500000,9001,8807,300000,9001,,,,,,
-27561,"NTF (Paris) / Lambert Nord France",9001,4807,18091,9801,1,0,4499,8801,55,9105,8802,0,9105,8805,0.999877341,9201,8806,600000,9001,8807,200000,9001,,,,,,
-27562,"NTF (Paris) / Lambert Centre France",9001,4807,18092,9801,1,0,4499,8801,52,9105,8802,0,9105,8805,0.99987742,9201,8806,600000,9001,8807,200000,9001,,,,,,
-27563,"NTF (Paris) / Lambert Sud France",9001,4807,18093,9801,1,0,4499,8801,49,9105,8802,0,9105,8805,0.999877499,9201,8806,600000,9001,8807,200000,9001,,,,,,
-27564,"NTF (Paris) / Lambert Corse",9001,4807,18094,9801,1,0,4499,8801,46.85,9105,8802,0,9105,8805,0.99994471,9201,8806,234.358,9001,8807,185861.369,9001,,,,,,
-27571,"NTF (Paris) / Lambert zone I",9001,4807,18081,9801,1,0,4499,8801,55,9105,8802,0,9105,8805,0.999877341,9201,8806,600000,9001,8807,1200000,9001,,,,,,
-27572,"NTF (Paris) / Lambert zone II",9001,4807,18082,9801,1,0,4499,8801,52,9105,8802,0,9105,8805,0.99987742,9201,8806,600000,9001,8807,2200000,9001,,,,,,
-27573,"NTF (Paris) / Lambert zone III",9001,4807,18083,9801,1,0,4499,8801,49,9105,8802,0,9105,8805,0.999877499,9201,8806,600000,9001,8807,3200000,9001,,,,,,
-27574,"NTF (Paris) / Lambert zone IV",9001,4807,18084,9801,1,0,4499,8801,46.85,9105,8802,0,9105,8805,0.99994471,9201,8806,234.358,9001,8807,4185861.369,9001,,,,,,
-27581,"NTF (Paris) / France I",9001,4807,18081,9801,1,1,4499,8801,55,9105,8802,0,9105,8805,0.999877341,9201,8806,600000,9001,8807,1200000,9001,,,,,,
-27582,"NTF (Paris) / France II",9001,4807,18082,9801,1,1,4499,8801,52,9105,8802,0,9105,8805,0.99987742,9201,8806,600000,9001,8807,2200000,9001,,,,,,
-27583,"NTF (Paris) / France III",9001,4807,18083,9801,1,1,4499,8801,49,9105,8802,0,9105,8805,0.999877499,9201,8806,600000,9001,8807,3200000,9001,,,,,,
-27584,"NTF (Paris) / France IV",9001,4807,18084,9801,1,1,4499,8801,46.85,9105,8802,0,9105,8805,0.99994471,9201,8806,234.358,9001,8807,4185861.369,9001,,,,,,
-27591,"NTF (Paris) / Nord France",9001,4807,18091,9801,1,1,4499,8801,55,9105,8802,0,9105,8805,0.999877341,9201,8806,600000,9001,8807,200000,9001,,,,,,
-27592,"NTF (Paris) / Centre France",9001,4807,18092,9801,1,1,4499,8801,52,9105,8802,0,9105,8805,0.99987742,9201,8806,600000,9001,8807,200000,9001,,,,,,
-27593,"NTF (Paris) / Sud France",9001,4807,18093,9801,1,1,4499,8801,49,9105,8802,0,9105,8805,0.999877499,9201,8806,600000,9001,8807,200000,9001,,,,,,
-27594,"NTF (Paris) / Corse",9001,4807,18094,9801,1,1,4499,8801,46.85,9105,8802,0,9105,8805,0.99994471,9201,8806,234.358,9001,8807,185861.369,9001,,,,,,
-27700,"OSGB 1936 / British National Grid",9001,4277,19916,9807,1,0,4400,8801,49,9102,8802,-2,9102,8805,0.9996012717,9201,8806,400000,9001,8807,-100000,9001,,,,,,
-28191,"Palestine 1923 / Palestine Grid",9001,4281,18201,9806,1,0,4400,8801,31.4402749,9110,8802,35.124349,9110,8806,170251.555,9001,8807,126867.909,9001,,,,,,,,,
-28192,"Palestine 1923 / Palestine Belt",9001,4281,18202,9807,1,0,4400,8801,31.4402749,9110,8802,35.124349,9110,8805,1,9201,8806,170251.555,9001,8807,1126867.909,9001,,,,,,
-28193,"Palestine 1923 / Israeli CS Grid",9001,4281,18203,9806,1,0,4400,8801,31.4402749,9110,8802,35.124349,9110,8806,170251.555,9001,8807,1126867.909,9001,,,,,,,,,
-28232,"Pointe Noire / UTM zone 32S",9001,4282,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28348,"GDA94 / MGA zone 48",9001,4283,17348,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28349,"GDA94 / MGA zone 49",9001,4283,17349,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28350,"GDA94 / MGA zone 50",9001,4283,17350,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28351,"GDA94 / MGA zone 51",9001,4283,17351,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28352,"GDA94 / MGA zone 52",9001,4283,17352,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28353,"GDA94 / MGA zone 53",9001,4283,17353,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28354,"GDA94 / MGA zone 54",9001,4283,17354,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28355,"GDA94 / MGA zone 55",9001,4283,17355,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28356,"GDA94 / MGA zone 56",9001,4283,17356,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28357,"GDA94 / MGA zone 57",9001,4283,17357,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28358,"GDA94 / MGA zone 58",9001,4283,17358,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-28402,"Pulkovo 1942 / Gauss-Kruger zone 2",9001,4284,16202,9807,1,1,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-28403,"Pulkovo 1942 / Gauss-Kruger zone 3",9001,4284,16203,9807,1,1,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-28404,"Pulkovo 1942 / Gauss-Kruger zone 4",9001,4284,16204,9807,1,0,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-28405,"Pulkovo 1942 / Gauss-Kruger zone 5",9001,4284,16205,9807,1,0,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-28406,"Pulkovo 1942 / Gauss-Kruger zone 6",9001,4284,16206,9807,1,0,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-28407,"Pulkovo 1942 / Gauss-Kruger zone 7",9001,4284,16207,9807,1,0,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-28408,"Pulkovo 1942 / Gauss-Kruger zone 8",9001,4284,16208,9807,1,0,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-28409,"Pulkovo 1942 / Gauss-Kruger zone 9",9001,4284,16209,9807,1,0,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-28410,"Pulkovo 1942 / Gauss-Kruger zone 10",9001,4284,16210,9807,1,0,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-28411,"Pulkovo 1942 / Gauss-Kruger zone 11",9001,4284,16211,9807,1,0,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-28412,"Pulkovo 1942 / Gauss-Kruger zone 12",9001,4284,16212,9807,1,0,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-28413,"Pulkovo 1942 / Gauss-Kruger zone 13",9001,4284,16213,9807,1,0,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-28414,"Pulkovo 1942 / Gauss-Kruger zone 14",9001,4284,16214,9807,1,0,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-28415,"Pulkovo 1942 / Gauss-Kruger zone 15",9001,4284,16215,9807,1,0,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-28416,"Pulkovo 1942 / Gauss-Kruger zone 16",9001,4284,16216,9807,1,0,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-28417,"Pulkovo 1942 / Gauss-Kruger zone 17",9001,4284,16217,9807,1,0,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-28418,"Pulkovo 1942 / Gauss-Kruger zone 18",9001,4284,16218,9807,1,0,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-28419,"Pulkovo 1942 / Gauss-Kruger zone 19",9001,4284,16219,9807,1,0,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-28420,"Pulkovo 1942 / Gauss-Kruger zone 20",9001,4284,16220,9807,1,0,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-28421,"Pulkovo 1942 / Gauss-Kruger zone 21",9001,4284,16221,9807,1,0,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-28422,"Pulkovo 1942 / Gauss-Kruger zone 22",9001,4284,16222,9807,1,0,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-28423,"Pulkovo 1942 / Gauss-Kruger zone 23",9001,4284,16223,9807,1,0,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-28424,"Pulkovo 1942 / Gauss-Kruger zone 24",9001,4284,16224,9807,1,0,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,24500000,9001,8807,0,9001,,,,,,
-28425,"Pulkovo 1942 / Gauss-Kruger zone 25",9001,4284,16225,9807,1,0,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-28426,"Pulkovo 1942 / Gauss-Kruger zone 26",9001,4284,16226,9807,1,0,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-28427,"Pulkovo 1942 / Gauss-Kruger zone 27",9001,4284,16227,9807,1,0,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-28428,"Pulkovo 1942 / Gauss-Kruger zone 28",9001,4284,16228,9807,1,0,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-28429,"Pulkovo 1942 / Gauss-Kruger zone 29",9001,4284,16229,9807,1,0,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-28430,"Pulkovo 1942 / Gauss-Kruger zone 30",9001,4284,16230,9807,1,0,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-28431,"Pulkovo 1942 / Gauss-Kruger zone 31",9001,4284,16231,9807,1,0,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-28432,"Pulkovo 1942 / Gauss-Kruger zone 32",9001,4284,16232,9807,1,0,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-28462,"Pulkovo 1942 / Gauss-Kruger 2N",9001,4284,16302,9807,1,1,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28463,"Pulkovo 1942 / Gauss-Kruger 3N",9001,4284,16303,9807,1,1,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28464,"Pulkovo 1942 / Gauss-Kruger 4N",9001,4284,16304,9807,1,1,4530,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28465,"Pulkovo 1942 / Gauss-Kruger 5N",9001,4284,16305,9807,1,1,4530,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28466,"Pulkovo 1942 / Gauss-Kruger 6N",9001,4284,16306,9807,1,1,4530,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28467,"Pulkovo 1942 / Gauss-Kruger 7N",9001,4284,16307,9807,1,1,4530,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28468,"Pulkovo 1942 / Gauss-Kruger 8N",9001,4284,16308,9807,1,1,4530,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28469,"Pulkovo 1942 / Gauss-Kruger 9N",9001,4284,16309,9807,1,1,4530,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28470,"Pulkovo 1942 / Gauss-Kruger 10N",9001,4284,16310,9807,1,1,4530,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28471,"Pulkovo 1942 / Gauss-Kruger 11N",9001,4284,16311,9807,1,1,4530,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28472,"Pulkovo 1942 / Gauss-Kruger 12N",9001,4284,16312,9807,1,1,4530,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28473,"Pulkovo 1942 / Gauss-Kruger 13N",9001,4284,16313,9807,1,1,4530,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28474,"Pulkovo 1942 / Gauss-Kruger 14N",9001,4284,16314,9807,1,1,4530,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28475,"Pulkovo 1942 / Gauss-Kruger 15N",9001,4284,16315,9807,1,1,4530,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28476,"Pulkovo 1942 / Gauss-Kruger 16N",9001,4284,16316,9807,1,1,4530,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28477,"Pulkovo 1942 / Gauss-Kruger 17N",9001,4284,16317,9807,1,1,4530,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28478,"Pulkovo 1942 / Gauss-Kruger 18N",9001,4284,16318,9807,1,1,4530,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28479,"Pulkovo 1942 / Gauss-Kruger 19N",9001,4284,16319,9807,1,1,4530,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28480,"Pulkovo 1942 / Gauss-Kruger 20N",9001,4284,16320,9807,1,1,4530,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28481,"Pulkovo 1942 / Gauss-Kruger 21N",9001,4284,16321,9807,1,1,4530,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28482,"Pulkovo 1942 / Gauss-Kruger 22N",9001,4284,16322,9807,1,1,4530,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28483,"Pulkovo 1942 / Gauss-Kruger 23N",9001,4284,16323,9807,1,1,4530,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28484,"Pulkovo 1942 / Gauss-Kruger 24N",9001,4284,16324,9807,1,1,4530,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28485,"Pulkovo 1942 / Gauss-Kruger 25N",9001,4284,16325,9807,1,1,4530,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28486,"Pulkovo 1942 / Gauss-Kruger 26N",9001,4284,16326,9807,1,1,4530,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28487,"Pulkovo 1942 / Gauss-Kruger 27N",9001,4284,16327,9807,1,1,4530,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28488,"Pulkovo 1942 / Gauss-Kruger 28N",9001,4284,16328,9807,1,1,4530,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28489,"Pulkovo 1942 / Gauss-Kruger 29N",9001,4284,16329,9807,1,1,4530,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28490,"Pulkovo 1942 / Gauss-Kruger 30N",9001,4284,16330,9807,1,1,4530,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28491,"Pulkovo 1942 / Gauss-Kruger 31N",9001,4284,16331,9807,1,1,4530,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28492,"Pulkovo 1942 / Gauss-Kruger 32N",9001,4284,16332,9807,1,1,4530,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-28600,"Qatar 1974 / Qatar National Grid",9001,4285,19919,9807,1,0,4400,8801,24.27,9110,8802,51.13,9110,8805,0.99999,9201,8806,200000,9001,8807,300000,9001,,,,,,
-28991,"Amersfoort / RD Old",9001,4289,19913,9809,1,0,4499,8801,52.0922178,9110,8802,5.23155,9110,8805,0.9999079,9201,8806,0,9001,8807,0,9001,,,,,,
-28992,"Amersfoort / RD New",9001,4289,19914,9809,1,0,4499,8801,52.0922178,9110,8802,5.23155,9110,8805,0.9999079,9201,8806,155000,9001,8807,463000,9001,,,,,,
-29100,"SAD69 / Brazil Polyconic",9001,4291,19941,9818,1,1,4499,8801,0,9102,8802,-54,9102,8806,5000000,9001,8807,10000000,9001,,,,,,,,,
-29101,"SAD69 / Brazil Polyconic",9001,4618,19941,9818,1,0,4499,8801,0,9102,8802,-54,9102,8806,5000000,9001,8807,10000000,9001,,,,,,,,,
-29118,"SAD69 / UTM zone 18N",9001,4291,16018,9807,1,1,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29119,"SAD69 / UTM zone 19N",9001,4291,16019,9807,1,1,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29120,"SAD69 / UTM zone 20N",9001,4291,16020,9807,1,1,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29121,"SAD69 / UTM zone 21N",9001,4291,16021,9807,1,1,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29122,"SAD69 / UTM zone 22N",9001,4291,16022,9807,1,1,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29168,"SAD69 / UTM zone 18N",9001,4618,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29169,"SAD69 / UTM zone 19N",9001,4618,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29170,"SAD69 / UTM zone 20N",9001,4618,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29171,"SAD69 / UTM zone 21N",9001,4618,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29172,"SAD69 / UTM zone 22N",9001,4618,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29177,"SAD69 / UTM zone 17S",9001,4291,16117,9807,1,1,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29178,"SAD69 / UTM zone 18S",9001,4291,16118,9807,1,1,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29179,"SAD69 / UTM zone 19S",9001,4291,16119,9807,1,1,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29180,"SAD69 / UTM zone 20S",9001,4291,16120,9807,1,1,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29181,"SAD69 / UTM zone 21S",9001,4291,16121,9807,1,1,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29182,"SAD69 / UTM zone 22S",9001,4291,16122,9807,1,1,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29183,"SAD69 / UTM zone 23S",9001,4291,16123,9807,1,1,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29184,"SAD69 / UTM zone 24S",9001,4291,16124,9807,1,1,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29185,"SAD69 / UTM zone 25S",9001,4291,16125,9807,1,1,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29187,"SAD69 / UTM zone 17S",9001,4618,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29188,"SAD69 / UTM zone 18S",9001,4618,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29189,"SAD69 / UTM zone 19S",9001,4618,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29190,"SAD69 / UTM zone 20S",9001,4618,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29191,"SAD69 / UTM zone 21S",9001,4618,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29192,"SAD69 / UTM zone 22S",9001,4618,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29193,"SAD69 / UTM zone 23S",9001,4618,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29194,"SAD69 / UTM zone 24S",9001,4618,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29195,"SAD69 / UTM zone 25S",9001,4618,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29220,"Sapper Hill 1943 / UTM zone 20S",9001,4292,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29221,"Sapper Hill 1943 / UTM zone 21S",9001,4292,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29333,"Schwarzeck / UTM zone 33S",9001,4293,16133,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29371,"Schwarzeck / Lo22/11",9031,4293,17611,9808,1,0,6502,8801,-22,9102,8802,11,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29373,"Schwarzeck / Lo22/13",9031,4293,17613,9808,1,0,6502,8801,-22,9102,8802,13,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29375,"Schwarzeck / Lo22/15",9031,4293,17615,9808,1,0,6502,8801,-22,9102,8802,15,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29377,"Schwarzeck / Lo22/17",9031,4293,17617,9808,1,0,6502,8801,-22,9102,8802,17,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29379,"Schwarzeck / Lo22/19",9031,4293,17619,9808,1,0,6502,8801,-22,9102,8802,19,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29381,"Schwarzeck / Lo22/21",9031,4293,17621,9808,1,0,6502,8801,-22,9102,8802,21,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29383,"Schwarzeck / Lo22/23",9031,4293,17623,9808,1,0,6502,8801,-22,9102,8802,23,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29385,"Schwarzeck / Lo22/25",9031,4293,17625,9808,1,0,6502,8801,-22,9102,8802,25,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-29635,"Sudan / UTM zone 35N",9001,4296,16035,9807,1,1,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29636,"Sudan / UTM zone 36N",9001,4296,16036,9807,1,1,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29700,"Tananarive (Paris) / Laborde Grid",9001,4810,19911,9815,1,1,4499,8811,-21,9105,8812,49,9105,8813,21,9105,8814,21,9105,8815,0.9995,9201,8816,400000,9001,8817,800000,9001
-29701,"Tananarive (Paris) / Laborde Grid",9001,4810,19861,9813,1,0,4530,8806,400000,9001,8807,800000,9001,8811,-21,9105,8812,49,9105,8813,21,9105,8815,0.9995,9201,,,
-29702,"Tananarive (Paris) / Laborde Grid approximation",9001,4810,19911,9815,1,0,4530,8811,-21,9105,8812,49,9105,8813,21,9105,8814,21,9105,8815,0.9995,9201,8816,400000,9001,8817,800000,9001
-29738,"Tananarive / UTM zone 38S",9001,4297,16138,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29739,"Tananarive / UTM zone 39S",9001,4297,16139,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-29849,"Timbalai 1948 / UTM zone 49N",9001,4298,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29850,"Timbalai 1948 / UTM zone 50N",9001,4298,16050,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-29871,"Timbalai 1948 / RSO Borneo (ch)",9042,4298,19956,9815,1,0,4402,8811,4,9110,8812,115,9110,8813,53.18569537,9110,8814,53.07483685,9110,8815,0.99984,9201,8816,29352.4763,9042,8817,22014.3572,9042
-29872,"Timbalai 1948 / RSO Borneo (ft)",9041,4298,19957,9815,1,0,4405,8811,4,9110,8812,115,9110,8813,53.18569537,9110,8814,53.07483685,9110,8815,0.99984,9201,8816,1937263.44,9041,8817,1452947.58,9041
-29873,"Timbalai 1948 / RSO Borneo (m)",9001,4298,19958,9815,1,0,4400,8811,4,9110,8812,115,9110,8813,53.18569537,9110,8814,53.07483685,9110,8815,0.99984,9201,8816,590476.87,9001,8817,442857.65,9001
-29900,"TM65 / Irish National Grid",9001,4299,19908,9807,1,1,4400,8801,53.3,9110,8802,-8,9110,8805,1.000035,9201,8806,200000,9001,8807,250000,9001,,,,,,
-29901,"OSNI 1952 / Irish National Grid",9001,4188,19973,9807,1,0,4400,8801,53.3,9110,8802,-8,9110,8805,1,9201,8806,200000,9001,8807,250000,9001,,,,,,
-29902,"TM65 / Irish Grid",9001,4299,19972,9807,1,0,4400,8801,53.3,9110,8802,-8,9110,8805,1.000035,9201,8806,200000,9001,8807,250000,9001,,,,,,
-29903,"TM75 / Irish Grid",9001,4300,19972,9807,1,0,4400,8801,53.3,9110,8802,-8,9110,8805,1.000035,9201,8806,200000,9001,8807,250000,9001,,,,,,
-30161,"Tokyo / Japan Plane Rectangular CS I",9001,4301,17801,9807,1,0,4530,8801,33,9110,8802,129.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30162,"Tokyo / Japan Plane Rectangular CS II",9001,4301,17802,9807,1,0,4530,8801,33,9110,8802,131,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30163,"Tokyo / Japan Plane Rectangular CS III",9001,4301,17803,9807,1,0,4530,8801,36,9110,8802,132.1,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30164,"Tokyo / Japan Plane Rectangular CS IV",9001,4301,17804,9807,1,0,4530,8801,33,9110,8802,133.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30165,"Tokyo / Japan Plane Rectangular CS V",9001,4301,17805,9807,1,0,4530,8801,36,9110,8802,134.2,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30166,"Tokyo / Japan Plane Rectangular CS VI",9001,4301,17806,9807,1,0,4530,8801,36,9110,8802,136,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30167,"Tokyo / Japan Plane Rectangular CS VII",9001,4301,17807,9807,1,0,4530,8801,36,9110,8802,137.1,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30168,"Tokyo / Japan Plane Rectangular CS VIII",9001,4301,17808,9807,1,0,4530,8801,36,9110,8802,138.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30169,"Tokyo / Japan Plane Rectangular CS IX",9001,4301,17809,9807,1,0,4530,8801,36,9110,8802,139.5,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30170,"Tokyo / Japan Plane Rectangular CS X",9001,4301,17810,9807,1,0,4530,8801,40,9110,8802,140.5,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30171,"Tokyo / Japan Plane Rectangular CS XI",9001,4301,17811,9807,1,0,4530,8801,44,9110,8802,140.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30172,"Tokyo / Japan Plane Rectangular CS XII",9001,4301,17812,9807,1,0,4530,8801,44,9110,8802,142.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30173,"Tokyo / Japan Plane Rectangular CS XIII",9001,4301,17813,9807,1,0,4530,8801,44,9110,8802,144.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30174,"Tokyo / Japan Plane Rectangular CS XIV",9001,4301,17814,9807,1,0,4530,8801,26,9110,8802,142,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30175,"Tokyo / Japan Plane Rectangular CS XV",9001,4301,17815,9807,1,0,4530,8801,26,9110,8802,127.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30176,"Tokyo / Japan Plane Rectangular CS XVI",9001,4301,17816,9807,1,0,4530,8801,26,9110,8802,124,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30177,"Tokyo / Japan Plane Rectangular CS XVII",9001,4301,17817,9807,1,0,4530,8801,26,9110,8802,131,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30178,"Tokyo / Japan Plane Rectangular CS XVIII",9001,4301,17818,9807,1,0,4530,8801,20,9110,8802,136,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30179,"Tokyo / Japan Plane Rectangular CS XIX",9001,4301,17819,9807,1,0,4530,8801,26,9110,8802,154,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-30200,"Trinidad 1903 / Trinidad Grid",9039,4302,19925,9806,1,0,4407,8801,10.263,9110,8802,-61.2,9110,8806,430000,9039,8807,325000,9039,,,,,,,,,
-30339,"TC(1948) / UTM zone 39N",9001,4303,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-30340,"TC(1948) / UTM zone 40N",9001,4303,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-30491,"Voirol 1875 / Nord Algerie (ancienne)",9001,4304,18011,9801,1,0,4499,8801,40,9105,8802,3,9105,8805,0.999625544,9201,8806,500000,9001,8807,300000,9001,,,,,,
-30492,"Voirol 1875 / Sud Algerie (ancienne)",9001,4304,18012,9801,1,0,4499,8801,37,9105,8802,3,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-30493,"Voirol 1879 / Nord Algerie (ancienne)",9001,4671,18011,9801,1,0,4499,8801,40,9105,8802,3,9105,8805,0.999625544,9201,8806,500000,9001,8807,300000,9001,,,,,,
-30494,"Voirol 1879 / Sud Algerie (ancienne)",9001,4671,18012,9801,1,0,4499,8801,37,9105,8802,3,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-30729,"Nord Sahara 1959 / UTM zone 29N",9001,4307,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-30730,"Nord Sahara 1959 / UTM zone 30N",9001,4307,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-30731,"Nord Sahara 1959 / UTM zone 31N",9001,4307,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-30732,"Nord Sahara 1959 / UTM zone 32N",9001,4307,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-30791,"Nord Sahara 1959 / Voirol Unifie Nord",9001,4307,18021,9801,1,0,4499,8801,40,9105,8802,3,9105,8805,0.999625544,9201,8806,500135,9001,8807,300090,9001,,,,,,
-30792,"Nord Sahara 1959 / Voirol Unifie Sud",9001,4307,18022,9801,1,0,4499,8801,37,9105,8802,3,9105,8805,0.999625769,9201,8806,500135,9001,8807,300090,9001,,,,,,
-30800,RT38 2.5 gon W,9001,4308,19929,9807,1,1,4530,8801,0,9110,8802,15.48298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-31028,"Yoff / UTM zone 28N",9001,4310,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31121,"Zanderij / UTM zone 21N",9001,4311,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31154,"Zanderij / TM 54 NW",9001,4311,17054,9807,1,0,4400,8801,0,9102,8802,-54,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31170,"Zanderij / Suriname Old TM",9001,4311,19954,9807,1,0,4400,8801,0,9110,8802,-55.41,9110,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31171,"Zanderij / Suriname TM",9001,4311,19955,9807,1,0,4400,8801,0,9110,8802,-55.41,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-31251,"MGI (Ferro) / Austria GK West Zone",9001,4805,18001,9807,1,0,4530,8801,0,9102,8802,28,9102,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-31252,"MGI (Ferro) / Austria GK Central Zone",9001,4805,18002,9807,1,0,4530,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-31253,"MGI (Ferro) / Austria GK East Zone",9001,4805,18003,9807,1,0,4530,8801,0,9102,8802,34,9102,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-31254,"MGI / Austria GK West",9001,4312,18004,9807,1,0,4530,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-31255,"MGI / Austria GK Central",9001,4312,18005,9807,1,0,4530,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-31256,"MGI / Austria GK East",9001,4312,18006,9807,1,0,4530,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-31257,"MGI / Austria GK M28",9001,4312,18007,9807,1,0,4530,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,150000,9001,8807,-5000000,9001,,,,,,
-31258,"MGI / Austria GK M31",9001,4312,18008,9807,1,0,4530,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,450000,9001,8807,-5000000,9001,,,,,,
-31259,"MGI / Austria GK M34",9001,4312,18009,9807,1,0,4530,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,750000,9001,8807,-5000000,9001,,,,,,
-31265,"MGI / 3-degree Gauss zone 5",9001,4312,16265,9807,1,1,4499,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-31266,"MGI / 3-degree Gauss zone 6",9001,4312,16266,9807,1,1,4499,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-31267,"MGI / 3-degree Gauss zone 7",9001,4312,16267,9807,1,1,4499,8801,0,9102,8802,21,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-31268,"MGI / 3-degree Gauss zone 8",9001,4312,16268,9807,1,1,4499,8801,0,9102,8802,24,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-31275,"MGI / Balkans zone 5",9001,4312,18275,9807,1,1,4530,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,5500000,9001,8807,0,9001,,,,,,
-31276,"MGI / Balkans zone 6",9001,4312,18276,9807,1,1,4530,8801,0,9102,8802,18,9102,8805,0.9999,9201,8806,6500000,9001,8807,0,9001,,,,,,
-31277,"MGI / Balkans zone 7",9001,4312,18277,9807,1,1,4530,8801,0,9102,8802,21,9102,8805,0.9999,9201,8806,7500000,9001,8807,0,9001,,,,,,
-31278,"MGI / Balkans zone 8",9001,4312,18277,9807,1,1,4530,8801,0,9102,8802,21,9102,8805,0.9999,9201,8806,7500000,9001,8807,0,9001,,,,,,
-31279,"MGI / Balkans zone 8",9001,4312,18278,9807,1,1,4530,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,8500000,9001,8807,0,9001,,,,,,
-31281,"MGI (Ferro) / Austria West Zone",9001,4805,18041,9807,1,0,4530,8801,0,9102,8802,28,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-31282,"MGI (Ferro) / Austria Central Zone",9001,4805,18042,9807,1,0,4530,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-31283,"MGI (Ferro) / Austria East Zone",9001,4805,18043,9807,1,0,4530,8801,0,9102,8802,34,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-31284,"MGI / Austria M28",9001,4312,18044,9807,1,0,4530,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-31285,"MGI / Austria M31",9001,4312,18045,9807,1,0,4530,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,450000,9001,8807,0,9001,,,,,,
-31286,"MGI / Austria M34",9001,4312,18046,9807,1,0,4530,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,750000,9001,8807,0,9001,,,,,,
-31287,"MGI / Austria Lambert",9001,4312,19947,9802,1,0,4530,8821,47.3,9110,8822,13.2,9110,8823,49,9110,8824,46,9110,8826,400000,9001,8827,400000,9001,,,
-31288,"MGI (Ferro) / M28",9001,4805,18047,9807,1,0,4530,8801,0,9102,8802,28,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-31289,"MGI (Ferro) / M31",9001,4805,18048,9807,1,0,4530,8801,0,9102,8802,31,9102,8805,1,9201,8806,450000,9001,8807,0,9001,,,,,,
-31290,"MGI (Ferro) / M34",9001,4805,18049,9807,1,0,4530,8801,0,9102,8802,34,9102,8805,1,9201,8806,750000,9001,8807,0,9001,,,,,,
-31291,"MGI (Ferro) / Austria West Zone",9001,4805,18041,9807,1,1,4499,8801,0,9102,8802,28,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-31292,"MGI (Ferro) / Austria Central Zone",9001,4805,18042,9807,1,1,4499,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-31293,"MGI (Ferro) / Austria East Zone",9001,4805,18043,9807,1,1,4499,8801,0,9102,8802,34,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-31294,"MGI / M28",9001,4312,18044,9807,1,1,4499,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-31295,"MGI / M31",9001,4312,18045,9807,1,1,4499,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,450000,9001,8807,0,9001,,,,,,
-31296,"MGI / M34",9001,4312,18046,9807,1,1,4499,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,750000,9001,8807,0,9001,,,,,,
-31297,"MGI / Austria Lambert",9001,4312,19947,9802,1,1,4499,8821,47.3,9110,8822,13.2,9110,8823,49,9110,8824,46,9110,8826,400000,9001,8827,400000,9001,,,
-31300,"Belge 1972 / Belge Lambert 72",9001,4313,19902,9803,1,0,4499,8821,90,9110,8822,4.2124983,9110,8823,49.5,9110,8824,51.1,9110,8826,150000.01256,9001,8827,5400088.4378,9001,,,
-31370,"Belge 1972 / Belgian Lambert 72",9001,4313,19961,9802,1,0,4499,8821,90,9110,8822,4.2202952,9110,8823,51.100000204,9110,8824,49.500000204,9110,8826,150000.013,9001,8827,5400088.438,9001,,,
-31461,"DHDN / 3-degree Gauss zone 1",9001,4314,16261,9807,1,1,4499,8801,0,9102,8802,3,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-31462,"DHDN / 3-degree Gauss zone 2",9001,4314,16262,9807,1,1,4499,8801,0,9102,8802,6,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-31463,"DHDN / 3-degree Gauss zone 3",9001,4314,16263,9807,1,1,4499,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-31464,"DHDN / 3-degree Gauss zone 4",9001,4314,16264,9807,1,1,4499,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-31465,"DHDN / 3-degree Gauss zone 5",9001,4314,16265,9807,1,1,4499,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-31466,"DHDN / 3-degree Gauss-Kruger zone 2",9001,4314,16262,9807,1,0,4530,8801,0,9102,8802,6,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-31467,"DHDN / 3-degree Gauss-Kruger zone 3",9001,4314,16263,9807,1,0,4530,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-31468,"DHDN / 3-degree Gauss-Kruger zone 4",9001,4314,16264,9807,1,0,4530,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-31469,"DHDN / 3-degree Gauss-Kruger zone 5",9001,4314,16265,9807,1,0,4530,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-31528,"Conakry 1905 / UTM zone 28N",9001,4315,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31529,"Conakry 1905 / UTM zone 29N",9001,4315,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31600,"Dealul Piscului 1930 / Stereo 33",9001,4316,19927,9809,1,0,4499,8801,45.54,9110,8802,25.23328772,9110,8805,0.9996667,9201,8806,500000,9001,8807,500000,9001,,,,,,
-31700,"Dealul Piscului 1970/ Stereo 70",9001,4317,19926,9809,1,1,4530,8801,46,9102,8802,25,9102,8805,0.99975,9201,8806,500000,9001,8807,500000,9001,,,,,,
-31838,"NGN / UTM zone 38N",9001,4318,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31839,"NGN / UTM zone 39N",9001,4318,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31900,"KUDAMS / KTM",9001,4319,19928,9807,1,1,4400,8801,0,9102,8802,48,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31901,"KUDAMS / KTM",9001,4319,19997,9807,1,0,4400,8801,0,9102,8802,48,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-31965,"SIRGAS 2000 / UTM zone 11N",9001,4674,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31966,"SIRGAS 2000 / UTM zone 12N",9001,4674,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31967,"SIRGAS 2000 / UTM zone 13N",9001,4674,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31968,"SIRGAS 2000 / UTM zone 14N",9001,4674,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31969,"SIRGAS 2000 / UTM zone 15N",9001,4674,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31970,"SIRGAS 2000 / UTM zone 16N",9001,4674,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31971,"SIRGAS 2000 / UTM zone 17N",9001,4674,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31972,"SIRGAS 2000 / UTM zone 18N",9001,4674,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31973,"SIRGAS 2000 / UTM zone 19N",9001,4674,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31974,"SIRGAS 2000 / UTM zone 20N",9001,4674,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31975,"SIRGAS 2000 / UTM zone 21N",9001,4674,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31976,"SIRGAS 2000 / UTM zone 22N",9001,4674,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31977,"SIRGAS 2000 / UTM zone 17S",9001,4674,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31978,"SIRGAS 2000 / UTM zone 18S",9001,4674,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31979,"SIRGAS 2000 / UTM zone 19S",9001,4674,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31980,"SIRGAS 2000 / UTM zone 20S",9001,4674,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31981,"SIRGAS 2000 / UTM zone 21S",9001,4674,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31982,"SIRGAS 2000 / UTM zone 22S",9001,4674,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31983,"SIRGAS 2000 / UTM zone 23S",9001,4674,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31984,"SIRGAS 2000 / UTM zone 24S",9001,4674,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31985,"SIRGAS 2000 / UTM zone 25S",9001,4674,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31986,"SIRGAS 1995 / UTM zone 17N",9001,4170,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31987,"SIRGAS 1995 / UTM zone 18N",9001,4170,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31988,"SIRGAS 1995 / UTM zone 19N",9001,4170,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31989,"SIRGAS 1995 / UTM zone 20N",9001,4170,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31990,"SIRGAS 1995 / UTM zone 21N",9001,4170,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31991,"SIRGAS 1995 / UTM zone 22N",9001,4170,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-31992,"SIRGAS 1995 / UTM zone 17S",9001,4170,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31993,"SIRGAS 1995 / UTM zone 18S",9001,4170,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31994,"SIRGAS 1995 / UTM zone 19S",9001,4170,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31995,"SIRGAS 1995 / UTM zone 20S",9001,4170,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31996,"SIRGAS 1995 / UTM zone 21S",9001,4170,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31997,"SIRGAS 1995 / UTM zone 22S",9001,4170,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31998,"SIRGAS 1995 / UTM zone 23S",9001,4170,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-31999,"SIRGAS 1995 / UTM zone 24S",9001,4170,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32000,"SIRGAS 1995 / UTM zone 25S",9001,4170,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32001,"NAD27 / Montana North",9003,4267,12501,9802,1,0,4497,8821,47,9110,8822,-109.3,9110,8823,48.43,9110,8824,47.51,9110,8826,2000000,9003,8827,0,9003,,,
-32002,"NAD27 / Montana Central",9003,4267,12502,9802,1,0,4497,8821,45.5,9110,8822,-109.3,9110,8823,47.53,9110,8824,46.27,9110,8826,2000000,9003,8827,0,9003,,,
-32003,"NAD27 / Montana South",9003,4267,12503,9802,1,0,4497,8821,44,9110,8822,-109.3,9110,8823,46.24,9110,8824,44.52,9110,8826,2000000,9003,8827,0,9003,,,
-32005,"NAD27 / Nebraska North",9003,4267,12601,9802,1,0,4497,8821,41.2,9110,8822,-100,9110,8823,41.51,9110,8824,42.49,9110,8826,2000000,9003,8827,0,9003,,,
-32006,"NAD27 / Nebraska South",9003,4267,12602,9802,1,0,4497,8821,39.4,9110,8822,-99.3,9110,8823,40.17,9110,8824,41.43,9110,8826,2000000,9003,8827,0,9003,,,
-32007,"NAD27 / Nevada East",9003,4267,12701,9807,1,0,4497,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-32008,"NAD27 / Nevada Central",9003,4267,12702,9807,1,0,4497,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-32009,"NAD27 / Nevada West",9003,4267,12703,9807,1,0,4497,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-32010,"NAD27 / New Hampshire",9003,4267,12800,9807,1,0,4497,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-32011,"NAD27 / New Jersey",9003,4267,12900,9807,1,0,4497,8801,38.5,9110,8802,-74.4,9110,8805,0.999975,9201,8806,2000000,9003,8807,0,9003,,,,,,
-32012,"NAD27 / New Mexico East",9003,4267,13001,9807,1,0,4497,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,500000,9003,8807,0,9003,,,,,,
-32013,"NAD27 / New Mexico Central",9003,4267,13002,9807,1,0,4497,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-32014,"NAD27 / New Mexico West",9003,4267,13003,9807,1,0,4497,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,500000,9003,8807,0,9003,,,,,,
-32015,"NAD27 / New York East",9003,4267,13101,9807,1,0,4497,8801,40,9110,8802,-74.2,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-32016,"NAD27 / New York Central",9003,4267,13102,9807,1,0,4497,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,500000,9003,8807,0,9003,,,,,,
-32017,"NAD27 / New York West",9003,4267,13103,9807,1,0,4497,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,500000,9003,8807,0,9003,,,,,,
-32018,"NAD27 / New York Long Island",9003,4267,13104,9802,1,0,4497,8821,40.3,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,1000000,9003,8827,0,9003,,,
-32019,"NAD27 / North Carolina",9003,4267,13200,9802,1,0,4497,8821,33.45,9110,8822,-79,9110,8823,34.2,9110,8824,36.1,9110,8826,2000000,9003,8827,0,9003,,,
-32020,"NAD27 / North Dakota North",9003,4267,13301,9802,1,0,4497,8821,47,9110,8822,-100.3,9110,8823,47.26,9110,8824,48.44,9110,8826,2000000,9003,8827,0,9003,,,
-32021,"NAD27 / North Dakota South",9003,4267,13302,9802,1,0,4497,8821,45.4,9110,8822,-100.3,9110,8823,46.11,9110,8824,47.29,9110,8826,2000000,9003,8827,0,9003,,,
-32022,"NAD27 / Ohio North",9003,4267,13401,9802,1,0,4497,8821,39.4,9110,8822,-82.3,9110,8823,40.26,9110,8824,41.42,9110,8826,2000000,9003,8827,0,9003,,,
-32023,"NAD27 / Ohio South",9003,4267,13402,9802,1,0,4497,8821,38,9110,8822,-82.3,9110,8823,38.44,9110,8824,40.02,9110,8826,2000000,9003,8827,0,9003,,,
-32024,"NAD27 / Oklahoma North",9003,4267,13501,9802,1,0,4497,8821,35,9110,8822,-98,9110,8823,35.34,9110,8824,36.46,9110,8826,2000000,9003,8827,0,9003,,,
-32025,"NAD27 / Oklahoma South",9003,4267,13502,9802,1,0,4497,8821,33.2,9110,8822,-98,9110,8823,33.56,9110,8824,35.14,9110,8826,2000000,9003,8827,0,9003,,,
-32026,"NAD27 / Oregon North",9003,4267,13601,9802,1,0,4497,8821,43.4,9110,8822,-120.3,9110,8823,44.2,9110,8824,46,9110,8826,2000000,9003,8827,0,9003,,,
-32027,"NAD27 / Oregon South",9003,4267,13602,9802,1,0,4497,8821,41.4,9110,8822,-120.3,9110,8823,42.2,9110,8824,44,9110,8826,2000000,9003,8827,0,9003,,,
-32028,"NAD27 / Pennsylvania North",9003,4267,13701,9802,1,0,4497,8821,40.1,9110,8822,-77.45,9110,8823,40.53,9110,8824,41.57,9110,8826,2000000,9003,8827,0,9003,,,
-32029,"NAD27 / Pennsylvania South",9003,4267,13702,9802,1,0,4497,8821,39.2,9110,8822,-77.45,9110,8823,39.56,9110,8824,40.48,9110,8826,2000000,9003,8827,0,9003,,,
-32030,"NAD27 / Rhode Island",9003,4267,13800,9807,1,0,4497,8801,41.05,9110,8802,-71.3,9110,8805,0.9999938,9201,8806,500000,9003,8807,0,9003,,,,,,
-32031,"NAD27 / South Carolina North",9003,4267,13901,9802,1,0,4497,8821,33,9110,8822,-81,9110,8823,33.46,9110,8824,34.58,9110,8826,2000000,9003,8827,0,9003,,,
-32033,"NAD27 / South Carolina South",9003,4267,13902,9802,1,0,4497,8821,31.5,9110,8822,-81,9110,8823,32.2,9110,8824,33.4,9110,8826,2000000,9003,8827,0,9003,,,
-32034,"NAD27 / South Dakota North",9003,4267,14001,9802,1,0,4497,8821,43.5,9110,8822,-100,9110,8823,44.25,9110,8824,45.41,9110,8826,2000000,9003,8827,0,9003,,,
-32035,"NAD27 / South Dakota South",9003,4267,14002,9802,1,0,4497,8821,42.2,9110,8822,-100.2,9110,8823,42.5,9110,8824,44.24,9110,8826,2000000,9003,8827,0,9003,,,
-32036,"NAD27 / Tennessee",9003,4267,14100,9802,1,1,4497,8821,34.4,9110,8822,-86,9110,8823,35.15,9110,8824,36.25,9110,8826,100000,9003,8827,0,9003,,,
-32037,"NAD27 / Texas North",9003,4267,14201,9802,1,0,4497,8821,34,9110,8822,-101.3,9110,8823,34.39,9110,8824,36.11,9110,8826,2000000,9003,8827,0,9003,,,
-32038,"NAD27 / Texas North Central",9003,4267,14202,9802,1,0,4497,8821,31.4,9110,8822,-97.3,9110,8823,32.08,9110,8824,33.58,9110,8826,2000000,9003,8827,0,9003,,,
-32039,"NAD27 / Texas Central",9003,4267,14203,9802,1,0,4497,8821,29.4,9110,8822,-100.2,9110,8823,30.07,9110,8824,31.53,9110,8826,2000000,9003,8827,0,9003,,,
-32040,"NAD27 / Texas South Central",9003,4267,14204,9802,1,0,4497,8821,27.5,9110,8822,-99,9110,8823,28.23,9110,8824,30.17,9110,8826,2000000,9003,8827,0,9003,,,
-32041,"NAD27 / Texas South",9003,4267,14205,9802,1,0,4497,8821,25.4,9110,8822,-98.3,9110,8823,26.1,9110,8824,27.5,9110,8826,2000000,9003,8827,0,9003,,,
-32042,"NAD27 / Utah North",9003,4267,14301,9802,1,0,4497,8821,40.2,9110,8822,-111.3,9110,8823,40.43,9110,8824,41.47,9110,8826,2000000,9003,8827,0,9003,,,
-32043,"NAD27 / Utah Central",9003,4267,14302,9802,1,0,4497,8821,38.2,9110,8822,-111.3,9110,8823,39.01,9110,8824,40.39,9110,8826,2000000,9003,8827,0,9003,,,
-32044,"NAD27 / Utah South",9003,4267,14303,9802,1,0,4497,8821,36.4,9110,8822,-111.3,9110,8823,37.13,9110,8824,38.21,9110,8826,2000000,9003,8827,0,9003,,,
-32045,"NAD27 / Vermont",9003,4267,14400,9807,1,0,4497,8801,42.3,9110,8802,-72.3,9110,8805,0.999964286,9201,8806,500000,9003,8807,0,9003,,,,,,
-32046,"NAD27 / Virginia North",9003,4267,14501,9802,1,0,4497,8821,37.4,9110,8822,-78.3,9110,8823,38.02,9110,8824,39.12,9110,8826,2000000,9003,8827,0,9003,,,
-32047,"NAD27 / Virginia South",9003,4267,14502,9802,1,0,4497,8821,36.2,9110,8822,-78.3,9110,8823,36.46,9110,8824,37.58,9110,8826,2000000,9003,8827,0,9003,,,
-32048,"NAD27 / Washington North",9003,4267,14601,9802,1,0,4497,8821,47,9110,8822,-120.5,9110,8823,47.3,9110,8824,48.44,9110,8826,2000000,9003,8827,0,9003,,,
-32049,"NAD27 / Washington South",9003,4267,14602,9802,1,0,4497,8821,45.2,9110,8822,-120.3,9110,8823,45.5,9110,8824,47.2,9110,8826,2000000,9003,8827,0,9003,,,
-32050,"NAD27 / West Virginia North",9003,4267,14701,9802,1,0,4497,8821,38.3,9110,8822,-79.3,9110,8823,39,9110,8824,40.15,9110,8826,2000000,9003,8827,0,9003,,,
-32051,"NAD27 / West Virginia South",9003,4267,14702,9802,1,0,4497,8821,37,9110,8822,-81,9110,8823,37.29,9110,8824,38.53,9110,8826,2000000,9003,8827,0,9003,,,
-32052,"NAD27 / Wisconsin North",9003,4267,14801,9802,1,0,4497,8821,45.1,9110,8822,-90,9110,8823,45.34,9110,8824,46.46,9110,8826,2000000,9003,8827,0,9003,,,
-32053,"NAD27 / Wisconsin Central",9003,4267,14802,9802,1,0,4497,8821,43.5,9110,8822,-90,9110,8823,44.15,9110,8824,45.3,9110,8826,2000000,9003,8827,0,9003,,,
-32054,"NAD27 / Wisconsin South",9003,4267,14803,9802,1,0,4497,8821,42,9110,8822,-90,9110,8823,42.44,9110,8824,44.04,9110,8826,2000000,9003,8827,0,9003,,,
-32055,"NAD27 / Wyoming East",9003,4267,14901,9807,1,0,4497,8801,40.4,9110,8802,-105.1,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-32056,"NAD27 / Wyoming East Central",9003,4267,14902,9807,1,0,4497,8801,40.4,9110,8802,-107.2,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-32057,"NAD27 / Wyoming West Central",9003,4267,14903,9807,1,0,4497,8801,40.4,9110,8802,-108.45,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-32058,"NAD27 / Wyoming West",9003,4267,14904,9807,1,0,4497,8801,40.4,9110,8802,-110.05,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-32061,"NAD27 / Guatemala Norte",9001,4267,18211,9801,1,0,4499,8801,16.49,9110,8802,-90.2,9110,8805,0.99992226,9201,8806,500000,9001,8807,292209.579,9001,,,,,,
-32062,"NAD27 / Guatemala Sur",9001,4267,18212,9801,1,0,4499,8801,14.54,9110,8802,-90.2,9110,8805,0.99989906,9201,8806,500000,9001,8807,325992.681,9001,,,,,,
-32064,"NAD27 / BLM 14N (ftUS)",9003,4267,15914,9807,1,0,4497,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32065,"NAD27 / BLM 15N (ftUS)",9003,4267,15915,9807,1,0,4497,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32066,"NAD27 / BLM 16N (ftUS)",9003,4267,15916,9807,1,0,4497,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32067,"NAD27 / BLM 17N (ftUS)",9003,4267,15917,9807,1,0,4497,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32074,"NAD27 / BLM 14N (feet)",9003,4267,15914,9807,1,1,4497,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32075,"NAD27 / BLM 15N (feet)",9003,4267,15915,9807,1,1,4497,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32076,"NAD27 / BLM 16N (feet)",9003,4267,15916,9807,1,1,4497,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32077,"NAD27 / BLM 17N (feet)",9003,4267,15917,9807,1,1,4497,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32081,"NAD27 / MTM zone 1",9001,4267,17701,9807,1,0,4400,8801,0,9102,8802,-53,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32082,"NAD27 / MTM zone 2",9001,4267,17702,9807,1,0,4400,8801,0,9102,8802,-56,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32083,"NAD27 / MTM zone 3",9001,4267,17703,9807,1,0,4400,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32084,"NAD27 / MTM zone 4",9001,4267,17704,9807,1,0,4400,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32085,"NAD27 / MTM zone 5",9001,4267,17705,9807,1,0,4400,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32086,"NAD27 / MTM zone 6",9001,4267,17706,9807,1,0,4400,8801,0,9110,8802,-67.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32098,"NAD27 / Quebec Lambert",9001,4267,19944,9802,1,0,4499,8821,44,9110,8822,-68.3,9110,8823,60,9110,8824,46,9110,8826,0,9001,8827,0,9001,,,
-32099,"NAD27 / Louisiana Offshore",9003,4267,11703,9802,1,0,4497,8821,25.4,9110,8822,-91.2,9110,8823,27.5,9110,8824,26.1,9110,8826,2000000,9003,8827,0,9003,,,
-32100,"NAD83 / Montana",9001,4269,12530,9802,1,0,4499,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,600000,9001,8827,0,9001,,,
-32104,"NAD83 / Nebraska",9001,4269,12630,9802,1,0,4499,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,500000,9001,8827,0,9001,,,
-32107,"NAD83 / Nevada East",9001,4269,12731,9807,1,0,4499,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,200000,9001,8807,8000000,9001,,,,,,
-32108,"NAD83 / Nevada Central",9001,4269,12732,9807,1,0,4499,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,500000,9001,8807,6000000,9001,,,,,,
-32109,"NAD83 / Nevada West",9001,4269,12733,9807,1,0,4499,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,800000,9001,8807,4000000,9001,,,,,,
-32110,"NAD83 / New Hampshire",9001,4269,12830,9807,1,0,4499,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,300000,9001,8807,0,9001,,,,,,
-32111,"NAD83 / New Jersey",9001,4269,12930,9807,1,0,4499,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-32112,"NAD83 / New Mexico East",9001,4269,13031,9807,1,0,4499,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,165000,9001,8807,0,9001,,,,,,
-32113,"NAD83 / New Mexico Central",9001,4269,13032,9807,1,0,4499,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-32114,"NAD83 / New Mexico West",9001,4269,13033,9807,1,0,4499,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,830000,9001,8807,0,9001,,,,,,
-32115,"NAD83 / New York East",9001,4269,13131,9807,1,0,4499,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-32116,"NAD83 / New York Central",9001,4269,13132,9807,1,0,4499,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,250000,9001,8807,0,9001,,,,,,
-32117,"NAD83 / New York West",9001,4269,13133,9807,1,0,4499,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,350000,9001,8807,0,9001,,,,,,
-32118,"NAD83 / New York Long Island",9001,4269,13134,9802,1,0,4499,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,300000,9001,8827,0,9001,,,
-32119,"NAD83 / North Carolina",9001,4269,13230,9802,1,0,4499,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,609601.22,9001,8827,0,9001,,,
-32120,"NAD83 / North Dakota North",9001,4269,13331,9802,1,0,4499,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,600000,9001,8827,0,9001,,,
-32121,"NAD83 / North Dakota South",9001,4269,13332,9802,1,0,4499,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,600000,9001,8827,0,9001,,,
-32122,"NAD83 / Ohio North",9001,4269,13431,9802,1,0,4499,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,600000,9001,8827,0,9001,,,
-32123,"NAD83 / Ohio South",9001,4269,13432,9802,1,0,4499,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,600000,9001,8827,0,9001,,,
-32124,"NAD83 / Oklahoma North",9001,4269,13531,9802,1,0,4499,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,600000,9001,8827,0,9001,,,
-32125,"NAD83 / Oklahoma South",9001,4269,13532,9802,1,0,4499,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,600000,9001,8827,0,9001,,,
-32126,"NAD83 / Oregon North",9001,4269,13631,9802,1,0,4499,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,2500000,9001,8827,0,9001,,,
-32127,"NAD83 / Oregon South",9001,4269,13632,9802,1,0,4499,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,1500000,9001,8827,0,9001,,,
-32128,"NAD83 / Pennsylvania North",9001,4269,13731,9802,1,0,4499,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,600000,9001,8827,0,9001,,,
-32129,"NAD83 / Pennsylvania South",9001,4269,13732,9802,1,0,4499,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,600000,9001,8827,0,9001,,,
-32130,"NAD83 / Rhode Island",9001,4269,13830,9807,1,0,4499,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,100000,9001,8807,0,9001,,,,,,
-32133,"NAD83 / South Carolina",9001,4269,13930,9802,1,0,4499,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,609600,9001,8827,0,9001,,,
-32134,"NAD83 / South Dakota North",9001,4269,14031,9802,1,0,4499,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,600000,9001,8827,0,9001,,,
-32135,"NAD83 / South Dakota South",9001,4269,14032,9802,1,0,4499,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,600000,9001,8827,0,9001,,,
-32136,"NAD83 / Tennessee",9001,4269,14130,9802,1,0,4499,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,600000,9001,8827,0,9001,,,
-32137,"NAD83 / Texas North",9001,4269,14231,9802,1,0,4499,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,200000,9001,8827,1000000,9001,,,
-32138,"NAD83 / Texas North Central",9001,4269,14232,9802,1,0,4499,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,600000,9001,8827,2000000,9001,,,
-32139,"NAD83 / Texas Central",9001,4269,14233,9802,1,0,4499,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,700000,9001,8827,3000000,9001,,,
-32140,"NAD83 / Texas South Central",9001,4269,14234,9802,1,0,4499,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,600000,9001,8827,4000000,9001,,,
-32141,"NAD83 / Texas South",9001,4269,14235,9802,1,0,4499,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,300000,9001,8827,5000000,9001,,,
-32142,"NAD83 / Utah North",9001,4269,14331,9802,1,0,4499,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,500000,9001,8827,1000000,9001,,,
-32143,"NAD83 / Utah Central",9001,4269,14332,9802,1,0,4499,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,500000,9001,8827,2000000,9001,,,
-32144,"NAD83 / Utah South",9001,4269,14333,9802,1,0,4499,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,500000,9001,8827,3000000,9001,,,
-32145,"NAD83 / Vermont",9001,4269,14430,9807,1,0,4499,8801,42.3,9110,8802,-72.3,9110,8805,0.999964286,9201,8806,500000,9001,8807,0,9001,,,,,,
-32146,"NAD83 / Virginia North",9001,4269,14531,9802,1,0,4499,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,3500000,9001,8827,2000000,9001,,,
-32147,"NAD83 / Virginia South",9001,4269,14532,9802,1,0,4499,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,3500000,9001,8827,1000000,9001,,,
-32148,"NAD83 / Washington North",9001,4269,14631,9802,1,0,4499,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,500000,9001,8827,0,9001,,,
-32149,"NAD83 / Washington South",9001,4269,14632,9802,1,0,4499,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,500000,9001,8827,0,9001,,,
-32150,"NAD83 / West Virginia North",9001,4269,14731,9802,1,0,4499,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,600000,9001,8827,0,9001,,,
-32151,"NAD83 / West Virginia South",9001,4269,14732,9802,1,0,4499,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,600000,9001,8827,0,9001,,,
-32152,"NAD83 / Wisconsin North",9001,4269,14831,9802,1,0,4499,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,600000,9001,8827,0,9001,,,
-32153,"NAD83 / Wisconsin Central",9001,4269,14832,9802,1,0,4499,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,600000,9001,8827,0,9001,,,
-32154,"NAD83 / Wisconsin South",9001,4269,14833,9802,1,0,4499,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,600000,9001,8827,0,9001,,,
-32155,"NAD83 / Wyoming East",9001,4269,14931,9807,1,0,4499,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,200000,9001,8807,0,9001,,,,,,
-32156,"NAD83 / Wyoming East Central",9001,4269,14932,9807,1,0,4499,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,400000,9001,8807,100000,9001,,,,,,
-32157,"NAD83 / Wyoming West Central",9001,4269,14933,9807,1,0,4499,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,600000,9001,8807,0,9001,,,,,,
-32158,"NAD83 / Wyoming West",9001,4269,14934,9807,1,0,4499,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,800000,9001,8807,100000,9001,,,,,,
-32161,"NAD83 / Puerto Rico & Virgin Is.",9001,4269,15230,9802,1,0,4499,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,200000,9001,8827,200000,9001,,,
-32164,"NAD83 / BLM 14N (ftUS)",9003,4269,15914,9807,1,0,4497,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32165,"NAD83 / BLM 15N (ftUS)",9003,4269,15915,9807,1,0,4497,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32166,"NAD83 / BLM 16N (ftUS)",9003,4269,15916,9807,1,0,4497,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32167,"NAD83 / BLM 17N (ftUS)",9003,4269,15917,9807,1,0,4497,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32180,"NAD83 / SCoPQ zone 2",9001,4269,17700,9807,1,0,4499,8801,0,9110,8802,-55.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32181,"NAD83 / MTM zone 1",9001,4269,17701,9807,1,0,4496,8801,0,9102,8802,-53,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32182,"NAD83 / MTM zone 2",9001,4269,17702,9807,1,0,4496,8801,0,9102,8802,-56,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32183,"NAD83 / MTM zone 3",9001,4269,17703,9807,1,0,4496,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32184,"NAD83 / MTM zone 4",9001,4269,17704,9807,1,0,4496,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32185,"NAD83 / MTM zone 5",9001,4269,17705,9807,1,0,4496,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32186,"NAD83 / MTM zone 6",9001,4269,17706,9807,1,0,4496,8801,0,9110,8802,-67.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32187,"NAD83 / MTM zone 7",9001,4269,17707,9807,1,0,4496,8801,0,9110,8802,-70.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32188,"NAD83 / MTM zone 8",9001,4269,17708,9807,1,0,4496,8801,0,9110,8802,-73.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32189,"NAD83 / MTM zone 9",9001,4269,17709,9807,1,0,4496,8801,0,9110,8802,-76.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32190,"NAD83 / MTM zone 10",9001,4269,17710,9807,1,0,4496,8801,0,9110,8802,-79.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32191,"NAD83 / MTM zone 11",9001,4269,17711,9807,1,0,4400,8801,0,9110,8802,-82.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32192,"NAD83 / MTM zone 12",9001,4269,17712,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32193,"NAD83 / MTM zone 13",9001,4269,17713,9807,1,0,4400,8801,0,9102,8802,-84,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32194,"NAD83 / MTM zone 14",9001,4269,17714,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32195,"NAD83 / MTM zone 15",9001,4269,17715,9807,1,0,4400,8801,0,9102,8802,-90,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32196,"NAD83 / MTM zone 16",9001,4269,17716,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32197,"NAD83 / MTM zone 17",9001,4269,17717,9807,1,0,4400,8801,0,9102,8802,-96,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-32198,"NAD83 / Quebec Lambert",9001,4269,19944,9802,1,0,4499,8821,44,9110,8822,-68.3,9110,8823,60,9110,8824,46,9110,8826,0,9001,8827,0,9001,,,
-32199,"NAD83 / Louisiana Offshore",9001,4269,11733,9802,1,0,4499,8821,25.3,9110,8822,-91.2,9110,8823,27.5,9110,8824,26.1,9110,8826,1000000,9001,8827,0,9001,,,
-32201,"WGS 72 / UTM zone 1N",9001,4322,16001,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32202,"WGS 72 / UTM zone 2N",9001,4322,16002,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32203,"WGS 72 / UTM zone 3N",9001,4322,16003,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32204,"WGS 72 / UTM zone 4N",9001,4322,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32205,"WGS 72 / UTM zone 5N",9001,4322,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32206,"WGS 72 / UTM zone 6N",9001,4322,16006,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32207,"WGS 72 / UTM zone 7N",9001,4322,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32208,"WGS 72 / UTM zone 8N",9001,4322,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32209,"WGS 72 / UTM zone 9N",9001,4322,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32210,"WGS 72 / UTM zone 10N",9001,4322,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32211,"WGS 72 / UTM zone 11N",9001,4322,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32212,"WGS 72 / UTM zone 12N",9001,4322,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32213,"WGS 72 / UTM zone 13N",9001,4322,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32214,"WGS 72 / UTM zone 14N",9001,4322,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32215,"WGS 72 / UTM zone 15N",9001,4322,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32216,"WGS 72 / UTM zone 16N",9001,4322,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32217,"WGS 72 / UTM zone 17N",9001,4322,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32218,"WGS 72 / UTM zone 18N",9001,4322,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32219,"WGS 72 / UTM zone 19N",9001,4322,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32220,"WGS 72 / UTM zone 20N",9001,4322,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32221,"WGS 72 / UTM zone 21N",9001,4322,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32222,"WGS 72 / UTM zone 22N",9001,4322,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32223,"WGS 72 / UTM zone 23N",9001,4322,16023,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32224,"WGS 72 / UTM zone 24N",9001,4322,16024,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32225,"WGS 72 / UTM zone 25N",9001,4322,16025,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32226,"WGS 72 / UTM zone 26N",9001,4322,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32227,"WGS 72 / UTM zone 27N",9001,4322,16027,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32228,"WGS 72 / UTM zone 28N",9001,4322,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32229,"WGS 72 / UTM zone 29N",9001,4322,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32230,"WGS 72 / UTM zone 30N",9001,4322,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32231,"WGS 72 / UTM zone 31N",9001,4322,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32232,"WGS 72 / UTM zone 32N",9001,4322,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32233,"WGS 72 / UTM zone 33N",9001,4322,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32234,"WGS 72 / UTM zone 34N",9001,4322,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32235,"WGS 72 / UTM zone 35N",9001,4322,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32236,"WGS 72 / UTM zone 36N",9001,4322,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32237,"WGS 72 / UTM zone 37N",9001,4322,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32238,"WGS 72 / UTM zone 38N",9001,4322,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32239,"WGS 72 / UTM zone 39N",9001,4322,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32240,"WGS 72 / UTM zone 40N",9001,4322,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32241,"WGS 72 / UTM zone 41N",9001,4322,16041,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32242,"WGS 72 / UTM zone 42N",9001,4322,16042,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32243,"WGS 72 / UTM zone 43N",9001,4322,16043,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32244,"WGS 72 / UTM zone 44N",9001,4322,16044,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32245,"WGS 72 / UTM zone 45N",9001,4322,16045,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32246,"WGS 72 / UTM zone 46N",9001,4322,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32247,"WGS 72 / UTM zone 47N",9001,4322,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32248,"WGS 72 / UTM zone 48N",9001,4322,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32249,"WGS 72 / UTM zone 49N",9001,4322,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32250,"WGS 72 / UTM zone 50N",9001,4322,16050,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32251,"WGS 72 / UTM zone 51N",9001,4322,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32252,"WGS 72 / UTM zone 52N",9001,4322,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32253,"WGS 72 / UTM zone 53N",9001,4322,16053,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32254,"WGS 72 / UTM zone 54N",9001,4322,16054,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32255,"WGS 72 / UTM zone 55N",9001,4322,16055,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32256,"WGS 72 / UTM zone 56N",9001,4322,16056,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32257,"WGS 72 / UTM zone 57N",9001,4322,16057,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32258,"WGS 72 / UTM zone 58N",9001,4322,16058,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32259,"WGS 72 / UTM zone 59N",9001,4322,16059,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32260,"WGS 72 / UTM zone 60N",9001,4322,16060,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32301,"WGS 72 / UTM zone 1S",9001,4322,16101,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32302,"WGS 72 / UTM zone 2S",9001,4322,16102,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32303,"WGS 72 / UTM zone 3S",9001,4322,16103,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32304,"WGS 72 / UTM zone 4S",9001,4322,16104,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32305,"WGS 72 / UTM zone 5S",9001,4322,16105,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32306,"WGS 72 / UTM zone 6S",9001,4322,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32307,"WGS 72 / UTM zone 7S",9001,4322,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32308,"WGS 72 / UTM zone 8S",9001,4322,16108,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32309,"WGS 72 / UTM zone 9S",9001,4322,16109,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32310,"WGS 72 / UTM zone 10S",9001,4322,16110,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32311,"WGS 72 / UTM zone 11S",9001,4322,16111,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32312,"WGS 72 / UTM zone 12S",9001,4322,16112,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32313,"WGS 72 / UTM zone 13S",9001,4322,16113,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32314,"WGS 72 / UTM zone 14S",9001,4322,16114,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32315,"WGS 72 / UTM zone 15S",9001,4322,16115,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32316,"WGS 72 / UTM zone 16S",9001,4322,16116,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32317,"WGS 72 / UTM zone 17S",9001,4322,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32318,"WGS 72 / UTM zone 18S",9001,4322,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32319,"WGS 72 / UTM zone 19S",9001,4322,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32320,"WGS 72 / UTM zone 20S",9001,4322,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32321,"WGS 72 / UTM zone 21S",9001,4322,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32322,"WGS 72 / UTM zone 22S",9001,4322,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32323,"WGS 72 / UTM zone 23S",9001,4322,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32324,"WGS 72 / UTM zone 24S",9001,4322,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32325,"WGS 72 / UTM zone 25S",9001,4322,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32326,"WGS 72 / UTM zone 26S",9001,4322,16126,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32327,"WGS 72 / UTM zone 27S",9001,4322,16127,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32328,"WGS 72 / UTM zone 28S",9001,4322,16128,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32329,"WGS 72 / UTM zone 29S",9001,4322,16129,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32330,"WGS 72 / UTM zone 30S",9001,4322,16130,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32331,"WGS 72 / UTM zone 31S",9001,4322,16131,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32332,"WGS 72 / UTM zone 32S",9001,4322,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32333,"WGS 72 / UTM zone 33S",9001,4322,16133,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32334,"WGS 72 / UTM zone 34S",9001,4322,16134,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32335,"WGS 72 / UTM zone 35S",9001,4322,16135,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32336,"WGS 72 / UTM zone 36S",9001,4322,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32337,"WGS 72 / UTM zone 37S",9001,4322,16137,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32338,"WGS 72 / UTM zone 38S",9001,4322,16138,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32339,"WGS 72 / UTM zone 39S",9001,4322,16139,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32340,"WGS 72 / UTM zone 40S",9001,4322,16140,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32341,"WGS 72 / UTM zone 41S",9001,4322,16141,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32342,"WGS 72 / UTM zone 42S",9001,4322,16142,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32343,"WGS 72 / UTM zone 43S",9001,4322,16143,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32344,"WGS 72 / UTM zone 44S",9001,4322,16144,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32345,"WGS 72 / UTM zone 45S",9001,4322,16145,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32346,"WGS 72 / UTM zone 46S",9001,4322,16146,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32347,"WGS 72 / UTM zone 47S",9001,4322,16147,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32348,"WGS 72 / UTM zone 48S",9001,4322,16148,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32349,"WGS 72 / UTM zone 49S",9001,4322,16149,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32350,"WGS 72 / UTM zone 50S",9001,4322,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32351,"WGS 72 / UTM zone 51S",9001,4322,16151,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32352,"WGS 72 / UTM zone 52S",9001,4322,16152,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32353,"WGS 72 / UTM zone 53S",9001,4322,16153,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32354,"WGS 72 / UTM zone 54S",9001,4322,16154,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32355,"WGS 72 / UTM zone 55S",9001,4322,16155,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32356,"WGS 72 / UTM zone 56S",9001,4322,16156,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32357,"WGS 72 / UTM zone 57S",9001,4322,16157,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32358,"WGS 72 / UTM zone 58S",9001,4322,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32359,"WGS 72 / UTM zone 59S",9001,4322,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32360,"WGS 72 / UTM zone 60S",9001,4322,16160,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32401,"WGS 72BE / UTM zone 1N",9001,4324,16001,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32402,"WGS 72BE / UTM zone 2N",9001,4324,16002,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32403,"WGS 72BE / UTM zone 3N",9001,4324,16003,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32404,"WGS 72BE / UTM zone 4N",9001,4324,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32405,"WGS 72BE / UTM zone 5N",9001,4324,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32406,"WGS 72BE / UTM zone 6N",9001,4324,16006,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32407,"WGS 72BE / UTM zone 7N",9001,4324,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32408,"WGS 72BE / UTM zone 8N",9001,4324,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32409,"WGS 72BE / UTM zone 9N",9001,4324,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32410,"WGS 72BE / UTM zone 10N",9001,4324,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32411,"WGS 72BE / UTM zone 11N",9001,4324,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32412,"WGS 72BE / UTM zone 12N",9001,4324,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32413,"WGS 72BE / UTM zone 13N",9001,4324,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32414,"WGS 72BE / UTM zone 14N",9001,4324,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32415,"WGS 72BE / UTM zone 15N",9001,4324,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32416,"WGS 72BE / UTM zone 16N",9001,4324,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32417,"WGS 72BE / UTM zone 17N",9001,4324,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32418,"WGS 72BE / UTM zone 18N",9001,4324,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32419,"WGS 72BE / UTM zone 19N",9001,4324,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32420,"WGS 72BE / UTM zone 20N",9001,4324,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32421,"WGS 72BE / UTM zone 21N",9001,4324,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32422,"WGS 72BE / UTM zone 22N",9001,4324,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32423,"WGS 72BE / UTM zone 23N",9001,4324,16023,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32424,"WGS 72BE / UTM zone 24N",9001,4324,16024,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32425,"WGS 72BE / UTM zone 25N",9001,4324,16025,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32426,"WGS 72BE / UTM zone 26N",9001,4324,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32427,"WGS 72BE / UTM zone 27N",9001,4324,16027,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32428,"WGS 72BE / UTM zone 28N",9001,4324,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32429,"WGS 72BE / UTM zone 29N",9001,4324,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32430,"WGS 72BE / UTM zone 30N",9001,4324,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32431,"WGS 72BE / UTM zone 31N",9001,4324,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32432,"WGS 72BE / UTM zone 32N",9001,4324,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32433,"WGS 72BE / UTM zone 33N",9001,4324,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32434,"WGS 72BE / UTM zone 34N",9001,4324,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32435,"WGS 72BE / UTM zone 35N",9001,4324,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32436,"WGS 72BE / UTM zone 36N",9001,4324,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32437,"WGS 72BE / UTM zone 37N",9001,4324,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32438,"WGS 72BE / UTM zone 38N",9001,4324,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32439,"WGS 72BE / UTM zone 39N",9001,4324,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32440,"WGS 72BE / UTM zone 40N",9001,4324,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32441,"WGS 72BE / UTM zone 41N",9001,4324,16041,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32442,"WGS 72BE / UTM zone 42N",9001,4324,16042,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32443,"WGS 72BE / UTM zone 43N",9001,4324,16043,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32444,"WGS 72BE / UTM zone 44N",9001,4324,16044,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32445,"WGS 72BE / UTM zone 45N",9001,4324,16045,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32446,"WGS 72BE / UTM zone 46N",9001,4324,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32447,"WGS 72BE / UTM zone 47N",9001,4324,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32448,"WGS 72BE / UTM zone 48N",9001,4324,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32449,"WGS 72BE / UTM zone 49N",9001,4324,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32450,"WGS 72BE / UTM zone 50N",9001,4324,16050,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32451,"WGS 72BE / UTM zone 51N",9001,4324,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32452,"WGS 72BE / UTM zone 52N",9001,4324,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32453,"WGS 72BE / UTM zone 53N",9001,4324,16053,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32454,"WGS 72BE / UTM zone 54N",9001,4324,16054,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32455,"WGS 72BE / UTM zone 55N",9001,4324,16055,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32456,"WGS 72BE / UTM zone 56N",9001,4324,16056,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32457,"WGS 72BE / UTM zone 57N",9001,4324,16057,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32458,"WGS 72BE / UTM zone 58N",9001,4324,16058,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32459,"WGS 72BE / UTM zone 59N",9001,4324,16059,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32460,"WGS 72BE / UTM zone 60N",9001,4324,16060,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32501,"WGS 72BE / UTM zone 1S",9001,4324,16101,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32502,"WGS 72BE / UTM zone 2S",9001,4324,16102,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32503,"WGS 72BE / UTM zone 3S",9001,4324,16103,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32504,"WGS 72BE / UTM zone 4S",9001,4324,16104,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32505,"WGS 72BE / UTM zone 5S",9001,4324,16105,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32506,"WGS 72BE / UTM zone 6S",9001,4324,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32507,"WGS 72BE / UTM zone 7S",9001,4324,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32508,"WGS 72BE / UTM zone 8S",9001,4324,16108,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32509,"WGS 72BE / UTM zone 9S",9001,4324,16109,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32510,"WGS 72BE / UTM zone 10S",9001,4324,16110,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32511,"WGS 72BE / UTM zone 11S",9001,4324,16111,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32512,"WGS 72BE / UTM zone 12S",9001,4324,16112,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32513,"WGS 72BE / UTM zone 13S",9001,4324,16113,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32514,"WGS 72BE / UTM zone 14S",9001,4324,16114,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32515,"WGS 72BE / UTM zone 15S",9001,4324,16115,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32516,"WGS 72BE / UTM zone 16S",9001,4324,16116,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32517,"WGS 72BE / UTM zone 17S",9001,4324,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32518,"WGS 72BE / UTM zone 18S",9001,4324,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32519,"WGS 72BE / UTM zone 19S",9001,4324,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32520,"WGS 72BE / UTM zone 20S",9001,4324,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32521,"WGS 72BE / UTM zone 21S",9001,4324,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32522,"WGS 72BE / UTM zone 22S",9001,4324,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32523,"WGS 72BE / UTM zone 23S",9001,4324,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32524,"WGS 72BE / UTM zone 24S",9001,4324,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32525,"WGS 72BE / UTM zone 25S",9001,4324,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32526,"WGS 72BE / UTM zone 26S",9001,4324,16126,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32527,"WGS 72BE / UTM zone 27S",9001,4324,16127,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32528,"WGS 72BE / UTM zone 28S",9001,4324,16128,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32529,"WGS 72BE / UTM zone 29S",9001,4324,16129,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32530,"WGS 72BE / UTM zone 30S",9001,4324,16130,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32531,"WGS 72BE / UTM zone 31S",9001,4324,16131,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32532,"WGS 72BE / UTM zone 32S",9001,4324,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32533,"WGS 72BE / UTM zone 33S",9001,4324,16133,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32534,"WGS 72BE / UTM zone 34S",9001,4324,16134,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32535,"WGS 72BE / UTM zone 35S",9001,4324,16135,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32536,"WGS 72BE / UTM zone 36S",9001,4324,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32537,"WGS 72BE / UTM zone 37S",9001,4324,16137,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32538,"WGS 72BE / UTM zone 38S",9001,4324,16138,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32539,"WGS 72BE / UTM zone 39S",9001,4324,16139,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32540,"WGS 72BE / UTM zone 40S",9001,4324,16140,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32541,"WGS 72BE / UTM zone 41S",9001,4324,16141,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32542,"WGS 72BE / UTM zone 42S",9001,4324,16142,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32543,"WGS 72BE / UTM zone 43S",9001,4324,16143,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32544,"WGS 72BE / UTM zone 44S",9001,4324,16144,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32545,"WGS 72BE / UTM zone 45S",9001,4324,16145,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32546,"WGS 72BE / UTM zone 46S",9001,4324,16146,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32547,"WGS 72BE / UTM zone 47S",9001,4324,16147,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32548,"WGS 72BE / UTM zone 48S",9001,4324,16148,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32549,"WGS 72BE / UTM zone 49S",9001,4324,16149,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32550,"WGS 72BE / UTM zone 50S",9001,4324,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32551,"WGS 72BE / UTM zone 51S",9001,4324,16151,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32552,"WGS 72BE / UTM zone 52S",9001,4324,16152,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32553,"WGS 72BE / UTM zone 53S",9001,4324,16153,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32554,"WGS 72BE / UTM zone 54S",9001,4324,16154,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32555,"WGS 72BE / UTM zone 55S",9001,4324,16155,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32556,"WGS 72BE / UTM zone 56S",9001,4324,16156,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32557,"WGS 72BE / UTM zone 57S",9001,4324,16157,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32558,"WGS 72BE / UTM zone 58S",9001,4324,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32559,"WGS 72BE / UTM zone 59S",9001,4324,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32560,"WGS 72BE / UTM zone 60S",9001,4324,16160,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32600,"WGS 84 / UTM grid system (northern hemisphere)",9001,4326,16000,9824,1,0,4400,8801,0,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,8830,-180,9102,8831,6,9102,,,
-32601,"WGS 84 / UTM zone 1N",9001,4326,16001,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32602,"WGS 84 / UTM zone 2N",9001,4326,16002,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32603,"WGS 84 / UTM zone 3N",9001,4326,16003,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32604,"WGS 84 / UTM zone 4N",9001,4326,16004,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32605,"WGS 84 / UTM zone 5N",9001,4326,16005,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32606,"WGS 84 / UTM zone 6N",9001,4326,16006,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32607,"WGS 84 / UTM zone 7N",9001,4326,16007,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32608,"WGS 84 / UTM zone 8N",9001,4326,16008,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32609,"WGS 84 / UTM zone 9N",9001,4326,16009,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32610,"WGS 84 / UTM zone 10N",9001,4326,16010,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32611,"WGS 84 / UTM zone 11N",9001,4326,16011,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32612,"WGS 84 / UTM zone 12N",9001,4326,16012,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32613,"WGS 84 / UTM zone 13N",9001,4326,16013,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32614,"WGS 84 / UTM zone 14N",9001,4326,16014,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32615,"WGS 84 / UTM zone 15N",9001,4326,16015,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32616,"WGS 84 / UTM zone 16N",9001,4326,16016,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32617,"WGS 84 / UTM zone 17N",9001,4326,16017,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32618,"WGS 84 / UTM zone 18N",9001,4326,16018,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32619,"WGS 84 / UTM zone 19N",9001,4326,16019,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32620,"WGS 84 / UTM zone 20N",9001,4326,16020,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32621,"WGS 84 / UTM zone 21N",9001,4326,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32622,"WGS 84 / UTM zone 22N",9001,4326,16022,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32623,"WGS 84 / UTM zone 23N",9001,4326,16023,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32624,"WGS 84 / UTM zone 24N",9001,4326,16024,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32625,"WGS 84 / UTM zone 25N",9001,4326,16025,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32626,"WGS 84 / UTM zone 26N",9001,4326,16026,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32627,"WGS 84 / UTM zone 27N",9001,4326,16027,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32628,"WGS 84 / UTM zone 28N",9001,4326,16028,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32629,"WGS 84 / UTM zone 29N",9001,4326,16029,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32630,"WGS 84 / UTM zone 30N",9001,4326,16030,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32631,"WGS 84 / UTM zone 31N",9001,4326,16031,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32632,"WGS 84 / UTM zone 32N",9001,4326,16032,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32633,"WGS 84 / UTM zone 33N",9001,4326,16033,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32634,"WGS 84 / UTM zone 34N",9001,4326,16034,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32635,"WGS 84 / UTM zone 35N",9001,4326,16035,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32636,"WGS 84 / UTM zone 36N",9001,4326,16036,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32637,"WGS 84 / UTM zone 37N",9001,4326,16037,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32638,"WGS 84 / UTM zone 38N",9001,4326,16038,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32639,"WGS 84 / UTM zone 39N",9001,4326,16039,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32640,"WGS 84 / UTM zone 40N",9001,4326,16040,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32641,"WGS 84 / UTM zone 41N",9001,4326,16041,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32642,"WGS 84 / UTM zone 42N",9001,4326,16042,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32643,"WGS 84 / UTM zone 43N",9001,4326,16043,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32644,"WGS 84 / UTM zone 44N",9001,4326,16044,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32645,"WGS 84 / UTM zone 45N",9001,4326,16045,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32646,"WGS 84 / UTM zone 46N",9001,4326,16046,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32647,"WGS 84 / UTM zone 47N",9001,4326,16047,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32648,"WGS 84 / UTM zone 48N",9001,4326,16048,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32649,"WGS 84 / UTM zone 49N",9001,4326,16049,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32650,"WGS 84 / UTM zone 50N",9001,4326,16050,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32651,"WGS 84 / UTM zone 51N",9001,4326,16051,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32652,"WGS 84 / UTM zone 52N",9001,4326,16052,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32653,"WGS 84 / UTM zone 53N",9001,4326,16053,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32654,"WGS 84 / UTM zone 54N",9001,4326,16054,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32655,"WGS 84 / UTM zone 55N",9001,4326,16055,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32656,"WGS 84 / UTM zone 56N",9001,4326,16056,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32657,"WGS 84 / UTM zone 57N",9001,4326,16057,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32658,"WGS 84 / UTM zone 58N",9001,4326,16058,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32659,"WGS 84 / UTM zone 59N",9001,4326,16059,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32660,"WGS 84 / UTM zone 60N",9001,4326,16060,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-32661,"WGS 84 / UPS North",9001,4326,16061,9810,1,0,4493,8801,90,9102,8802,0,9102,8805,0.994,9201,8806,2000000,9001,8807,2000000,9001,,,,,,
-32662,"WGS 84 / Plate Carree",9001,4326,19968,9823,1,1,4499,8801,0,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-32663,"WGS 84 / World Equidistant Cylindrical",9001,4326,19846,9842,1,1,4499,8801,0,9102,8806,0,9001,8807,0,9001,8822,0,9102,,,,,,,,,
-32664,"WGS 84 / BLM 14N (ftUS)",9003,4326,15914,9807,1,0,4497,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32665,"WGS 84 / BLM 15N (ftUS)",9003,4326,15915,9807,1,0,4497,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32666,"WGS 84 / BLM 16N (ftUS)",9003,4326,15916,9807,1,0,4497,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32667,"WGS 84 / BLM 17N (ftUS)",9003,4326,15917,9807,1,0,4497,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-32700,"WGS 84 / UTM grid system (southern hemisphere)",9001,4326,16100,9824,1,0,4400,8801,0,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,8830,-180,9102,8831,6,9102,,,
-32701,"WGS 84 / UTM zone 1S",9001,4326,16101,9807,1,0,4400,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32702,"WGS 84 / UTM zone 2S",9001,4326,16102,9807,1,0,4400,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32703,"WGS 84 / UTM zone 3S",9001,4326,16103,9807,1,0,4400,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32704,"WGS 84 / UTM zone 4S",9001,4326,16104,9807,1,0,4400,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32705,"WGS 84 / UTM zone 5S",9001,4326,16105,9807,1,0,4400,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32706,"WGS 84 / UTM zone 6S",9001,4326,16106,9807,1,0,4400,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32707,"WGS 84 / UTM zone 7S",9001,4326,16107,9807,1,0,4400,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32708,"WGS 84 / UTM zone 8S",9001,4326,16108,9807,1,0,4400,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32709,"WGS 84 / UTM zone 9S",9001,4326,16109,9807,1,0,4400,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32710,"WGS 84 / UTM zone 10S",9001,4326,16110,9807,1,0,4400,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32711,"WGS 84 / UTM zone 11S",9001,4326,16111,9807,1,0,4400,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32712,"WGS 84 / UTM zone 12S",9001,4326,16112,9807,1,0,4400,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32713,"WGS 84 / UTM zone 13S",9001,4326,16113,9807,1,0,4400,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32714,"WGS 84 / UTM zone 14S",9001,4326,16114,9807,1,0,4400,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32715,"WGS 84 / UTM zone 15S",9001,4326,16115,9807,1,0,4400,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32716,"WGS 84 / UTM zone 16S",9001,4326,16116,9807,1,0,4400,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32717,"WGS 84 / UTM zone 17S",9001,4326,16117,9807,1,0,4400,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32718,"WGS 84 / UTM zone 18S",9001,4326,16118,9807,1,0,4400,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32719,"WGS 84 / UTM zone 19S",9001,4326,16119,9807,1,0,4400,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32720,"WGS 84 / UTM zone 20S",9001,4326,16120,9807,1,0,4400,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32721,"WGS 84 / UTM zone 21S",9001,4326,16121,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32722,"WGS 84 / UTM zone 22S",9001,4326,16122,9807,1,0,4400,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32723,"WGS 84 / UTM zone 23S",9001,4326,16123,9807,1,0,4400,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32724,"WGS 84 / UTM zone 24S",9001,4326,16124,9807,1,0,4400,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32725,"WGS 84 / UTM zone 25S",9001,4326,16125,9807,1,0,4400,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32726,"WGS 84 / UTM zone 26S",9001,4326,16126,9807,1,0,4400,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32727,"WGS 84 / UTM zone 27S",9001,4326,16127,9807,1,0,4400,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32728,"WGS 84 / UTM zone 28S",9001,4326,16128,9807,1,0,4400,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32729,"WGS 84 / UTM zone 29S",9001,4326,16129,9807,1,0,4400,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32730,"WGS 84 / UTM zone 30S",9001,4326,16130,9807,1,0,4400,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32731,"WGS 84 / UTM zone 31S",9001,4326,16131,9807,1,0,4400,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32732,"WGS 84 / UTM zone 32S",9001,4326,16132,9807,1,0,4400,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32733,"WGS 84 / UTM zone 33S",9001,4326,16133,9807,1,0,4400,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32734,"WGS 84 / UTM zone 34S",9001,4326,16134,9807,1,0,4400,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32735,"WGS 84 / UTM zone 35S",9001,4326,16135,9807,1,0,4400,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32736,"WGS 84 / UTM zone 36S",9001,4326,16136,9807,1,0,4400,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32737,"WGS 84 / UTM zone 37S",9001,4326,16137,9807,1,0,4400,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32738,"WGS 84 / UTM zone 38S",9001,4326,16138,9807,1,0,4400,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32739,"WGS 84 / UTM zone 39S",9001,4326,16139,9807,1,0,4400,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32740,"WGS 84 / UTM zone 40S",9001,4326,16140,9807,1,0,4400,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32741,"WGS 84 / UTM zone 41S",9001,4326,16141,9807,1,0,4400,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32742,"WGS 84 / UTM zone 42S",9001,4326,16142,9807,1,0,4400,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32743,"WGS 84 / UTM zone 43S",9001,4326,16143,9807,1,0,4400,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32744,"WGS 84 / UTM zone 44S",9001,4326,16144,9807,1,0,4400,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32745,"WGS 84 / UTM zone 45S",9001,4326,16145,9807,1,0,4400,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32746,"WGS 84 / UTM zone 46S",9001,4326,16146,9807,1,0,4400,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32747,"WGS 84 / UTM zone 47S",9001,4326,16147,9807,1,0,4400,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32748,"WGS 84 / UTM zone 48S",9001,4326,16148,9807,1,0,4400,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32749,"WGS 84 / UTM zone 49S",9001,4326,16149,9807,1,0,4400,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32750,"WGS 84 / UTM zone 50S",9001,4326,16150,9807,1,0,4400,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32751,"WGS 84 / UTM zone 51S",9001,4326,16151,9807,1,0,4400,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32752,"WGS 84 / UTM zone 52S",9001,4326,16152,9807,1,0,4400,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32753,"WGS 84 / UTM zone 53S",9001,4326,16153,9807,1,0,4400,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32754,"WGS 84 / UTM zone 54S",9001,4326,16154,9807,1,0,4400,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32755,"WGS 84 / UTM zone 55S",9001,4326,16155,9807,1,0,4400,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32756,"WGS 84 / UTM zone 56S",9001,4326,16156,9807,1,0,4400,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32757,"WGS 84 / UTM zone 57S",9001,4326,16157,9807,1,0,4400,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32758,"WGS 84 / UTM zone 58S",9001,4326,16158,9807,1,0,4400,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32759,"WGS 84 / UTM zone 59S",9001,4326,16159,9807,1,0,4400,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32760,"WGS 84 / UTM zone 60S",9001,4326,16160,9807,1,0,4400,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-32761,"WGS 84 / UPS South",9001,4326,16161,9810,1,0,4494,8801,-90,9102,8802,0,9102,8805,0.994,9201,8806,2000000,9001,8807,2000000,9001,,,,,,
-32766,"WGS 84 / TM 36 SE",9001,4326,16636,9807,1,0,4400,8801,0,9102,8802,36,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
Deleted: grass/trunk/lib/proj/pcs.override.csv
--- grass/trunk/lib/proj/pcs.override.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/pcs.override.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,14 +0,0 @@
-"COORD_REF_SYS_CODE","COORD_REF_SYS_NAME","UOM_CODE","SOURCE_GEOGCRS_CODE","COORD_OP_CODE","COORD_OP_METHOD_CODE","SHOW_CRS","DEPRECATED","PARAMETER_CODE_1","PARAMETER_VALUE_1","PARAMETER_UOM_1","PARAMETER_CODE_2","PARAMETER_VALUE_2","PARAMETER_UOM_2","PARAMETER_CODE_3","PARAMETER_VALUE_3","PARAMETER_UOM_3","PARAMETER_CODE_4","PARAMETER_VALUE_4","PARAMETER_UOM_4","PARAMETER_CODE_5","PARAMETER_VALUE_5","PARAMETER_UOM_5","PARAMETER_CODE_6","PARAMETER_VALUE_6","PARAMETER_UOM_6","PARAMETER_CODE_7","PARAMETER_VALUE_7","PARAMETER_UOM_7"
-# NOTICE: The master version of this file is in the libgeotiff subversion at:
-# https://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/pcs.override.csv
-# Do *not* change other copies without upstreaming the results to libgeotiff.
-# Adjust central meridian to be relative to prime meridian.
-26591,"Monte Mario (Rome) / Italy zone 1",9001,4806,18121,9807,1,0,8801,0,9102,8802,-3.45233333333333,9102,8805,0.9996,9201,8806,1500000,9001,8807,0,9001,,,,,,
-26592,"Monte Mario (Rome) / Italy zone 2",9001,4806,18122,9807,1,0,8801,0,9102,8802,2.54766666666666,9102,8805,0.9996,9201,8806,2520000,9001,8807,0,9001,,,,,,
Deleted: grass/trunk/lib/proj/prime_meridian.csv
--- grass/trunk/lib/proj/prime_meridian.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/prime_meridian.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,14 +0,0 @@
-"PRIME_MERIDIAN_CODE","PRIME_MERIDIAN_NAME","GREENWICH_LONGITUDE","UOM_CODE","REMARKS","INFORMATION_SOURCE","DATA_SOURCE","REVISION_DATE","CHANGE_ID","DEPRECATED"
-8901,Greenwich,0.0,9110,,,EPSG,1995-06-02 00:00:00,96.29,0
-8902,Lisbon,-9.0754862,9110,,Instituto Geografico e Cadastral; Lisbon,EPSG,1995-06-02 00:00:00,96.29,0
-8903,Paris,2.5969213,9105,Value adopted by IGN (Paris) in 1936. Equivalent to 2 deg 20min 14.025sec. Preferred by EPSG to earlier value of 2deg 20min 13.95sec (2.596898 grads) used by RGS London.,Institut Geographique National (IGN); Paris,EPSG,1995-06-02 00:00:00,,0
-8904,Bogota,-74.04513,9110,,"Instituto Geografico ""Augustin Cadazzi"" (IGAC); Bogota",EPSG,1995-06-02 00:00:00,96.29,0
-8905,Madrid,-3.411658,9110,,,EPSG,1995-06-02 00:00:00,96.29,0
-8906,Rome,12.27084,9110,,,EPSG,1995-06-02 00:00:00,96.29,0
-8907,Bern,7.26225,9110,1895 value.  Newer value of 7 deg 26 min 22.335 sec E determined in 1938.,Bundesamt für Landestopographie,EPSG,1995-06-02 00:00:00,96.29,0
-8908,Jakarta,106.482779,9110,,,EPSG,1995-06-02 00:00:00,96.29,0
-8909,Ferro,-17.4,9110,Used in Austria and former Czechoslovakia.,,EPSG,1995-06-02 00:00:00,96.29,0
-8910,Brussels,4.220471,9110,,,EPSG,1995-06-02 00:00:00,96.29,0
-8911,Stockholm,18.03298,9110,,,EPSG,1995-06-02 00:00:00,96.29,0
-8912,Athens,23.4258815,9110,Used in Greece for older mapping based on Hatt projection.,Topography Department; National Technical University of Athens.,EPSG,1997-06-16 00:00:00,,0
-8913,Oslo,10.43225,9110,Formerly known as Kristiania or Christiania.,Statens Kartverk - Geodesidivisjonen,EPSG,1999-10-20 00:00:00,,0
Deleted: grass/trunk/lib/proj/projop_wparm.csv
--- grass/trunk/lib/proj/projop_wparm.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/projop_wparm.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,1589 +0,0 @@
-"COORD_OP_CODE","COORD_OP_NAME","COORD_OP_METHOD_CODE","PARAMETER_CODE_1","PARAMETER_VALUE_1","PARAMETER_UOM_1","PARAMETER_CODE_2","PARAMETER_VALUE_2","PARAMETER_UOM_2","PARAMETER_CODE_3","PARAMETER_VALUE_3","PARAMETER_UOM_3","PARAMETER_CODE_4","PARAMETER_VALUE_4","PARAMETER_UOM_4","PARAMETER_CODE_5","PARAMETER_VALUE_5","PARAMETER_UOM_5","PARAMETER_CODE_6","PARAMETER_VALUE_6","PARAMETER_UOM_6","PARAMETER_CODE_7","PARAMETER_VALUE_7","PARAMETER_UOM_7"
-101,deg to DMSH,9637,,,,,,,,,,,,,,,,,,,,,
-102,degH to DMSH,9638,,,,,,,,,,,,,,,,,,,,,
-103,Hdeg to DMSH,9639,,,,,,,,,,,,,,,,,,,,,
-104,DM to DMSH,9640,,,,,,,,,,,,,,,,,,,,,
-105,DMH to DMSH,9641,,,,,,,,,,,,,,,,,,,,,
-106,HDM to DMSH,9642,,,,,,,,,,,,,,,,,,,,,
-107,DMS to DMSH,9643,,,,,,,,,,,,,,,,,,,,,
-108,HDMS to DMSH,9644,,,,,,,,,,,,,,,,,,,,,
-3811,Belgian Lambert 2008,9802,8821,50.4752134,9110,8822,4.2133177,9110,8823,49.5,9110,8824,51.1,9110,8826,649328,9001,8827,665262,9001,,,
-3813,Mississippi Transverse Mercator,9807,8801,32.3,9110,8802,-89.45,9110,8805,0.9998335,9201,8806,500000,9001,8807,1300000,9001,,,,,,
-3818,Taiwan 2-degree TM zone 119,9807,8801,0,9102,8802,119,9102,8805,0.9999,9201,8806,250000,9001,8807,0,9001,,,,,,
-3820,Taiwan 2-degree TM zone 121,9807,8801,0,9102,8802,121,9102,8805,0.9999,9201,8806,250000,9001,8807,0,9001,,,,,,
-3831,Pacific Disaster Center Mercator,9804,8801,0,9102,8802,150,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-3853,County ST74,9807,8801,0,9110,8802,18.0328332,9110,8805,0.99999506,9201,8806,100182.7406,9001,8807,-6500620.1207,9001,,,,,,
-3856,Popular Visualisation Pseudo-Mercator,1024,8801,0,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3897,US NSIDC Equal Area north projection,1027,8801,90,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3898,US NSIDC Equal Area south projection,1027,8801,-90,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3899,US National Atlas Equal Area,1027,8801,45,9102,8802,-100,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-3967,Virginia Lambert Conic Conformal,9802,8821,36,9102,8822,-79.5,9102,8823,37,9102,8824,39.5,9102,8826,0,9001,8827,0,9001,,,
-3977,Canada Atlas Lambert,9802,8821,49,9102,8822,-95,9102,8823,49,9102,8824,77,9102,8826,0,9001,8827,0,9001,,,
-3980,Katanga Lambert,9802,8821,9,9102,8822,26,9102,8823,-6.5,9102,8824,-11.5,9102,8826,500000,9001,8827,500000,9001,,,
-3981,Katanga Gauss zone A,9807,8801,-9,9102,8802,30,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3982,Katanga Gauss zone B,9807,8801,-9,9102,8802,28,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3983,Katanga Gauss zone C,9807,8801,-9,9102,8802,26,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3984,Katanga Gauss zone D,9807,8801,-9,9102,8802,24,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-3999,Moldova Transverse Mercator,9807,8801,0,9110,8802,28.24,9110,8805,0.99994,9201,8806,200000,9001,8807,-5000000,9001,,,,,,
-4085,World Equidistant Cylindrical,1028,8802,0,9102,8806,0,9001,8807,0,9001,8823,0,9102,,,,,,,,,
-4086,"World Equidistant Cylindrical (Sphere)",1029,8802,0,9102,8806,0,9001,8807,0,9001,8823,0,9102,,,,,,,,,
-10101,Alabama CS27 East zone,9807,8801,30.3,9110,8802,-85.5,9110,8805,0.99996,9201,8806,500000,9003,8807,0,9003,,,,,,
-10102,Alabama CS27 West zone,9807,8801,30,9110,8802,-87.3,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-10131,"SPCS83 Alabama East zone (meters)",9807,8801,30.3,9110,8802,-85.5,9110,8805,0.99996,9201,8806,200000,9001,8807,0,9001,,,,,,
-10132,"SPCS83 Alabama West zone (meters)",9807,8801,30,9110,8802,-87.3,9110,8805,0.999933333,9201,8806,600000,9001,8807,0,9001,,,,,,
-10201,Arizona Coordinate System East zone,9807,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-10202,Arizona Coordinate System Central zone,9807,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-10203,Arizona Coordinate System West zone,9807,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-10231,"SPCS83 Arizona East zone (meters)",9807,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-10232,"SPCS83 Arizona Central zone (meters)",9807,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,213360,9001,8807,0,9001,,,,,,
-10233,"SPCS83 Arizona West zone (meters)",9807,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,213360,9001,8807,0,9001,,,,,,
-10301,Arkansas CS27 North,9802,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,2000000,9003,8827,0,9003,,,
-10302,Arkansas CS27 South,9802,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,2000000,9003,8827,0,9003,,,
-10331,"SPCS83 Arkansas North zone (meters)",9802,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,400000,9001,8827,0,9001,,,
-10332,"SPCS83 Arkansas South zone (meters)",9802,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,400000,9001,8827,400000,9001,,,
-10401,California CS27 zone I,9802,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,2000000,9003,8827,0,9003,,,
-10402,California CS27 zone II,9802,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,2000000,9003,8827,0,9003,,,
-10403,California CS27 zone III,9802,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,2000000,9003,8827,0,9003,,,
-10404,California CS27 zone IV,9802,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,2000000,9003,8827,0,9003,,,
-10405,California CS27 zone V,9802,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,2000000,9003,8827,0,9003,,,
-10406,California CS27 zone VI,9802,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,2000000,9003,8827,0,9003,,,
-10407,California CS27 zone VII,9802,8821,34.08,9110,8822,-118.2,9110,8823,34.25,9110,8824,33.52,9110,8826,4186692.58,9003,8827,416926.74,9003,,,
-10408,California CS27 zone VII,9802,8821,34.08,9110,8822,-118.2,9110,8823,34.25,9110,8824,33.52,9110,8826,4186692.58,9003,8827,4160926.74,9003,,,
-10420,California Albers,9822,8821,0,9102,8822,-120,9102,8823,34,9102,8824,40.5,9102,8826,0,9001,8827,-4000000,9001,,,
-10431,"SPCS83 California zone 1 (meters)",9802,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,2000000,9001,8827,500000,9001,,,
-10432,"SPCS83 California zone 2 (meters)",9802,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,2000000,9001,8827,500000,9001,,,
-10433,"SPCS83 California zone 3 (meters)",9802,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,2000000,9001,8827,500000,9001,,,
-10434,"SPCS83 California zone 4 (meters)",9802,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,2000000,9001,8827,500000,9001,,,
-10435,"SPCS83 California zone 5 (meters)",9802,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,2000000,9001,8827,500000,9001,,,
-10436,"SPCS83 California zone 6 (meters)",9802,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,2000000,9001,8827,500000,9001,,,
-10501,Colorado CS27 North zone,9802,8821,39.2,9110,8822,-105.3,9110,8823,39.43,9110,8824,40.47,9110,8826,2000000,9003,8827,0,9003,,,
-10502,Colorado CS27 Central zone,9802,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,2000000,9003,8827,0,9003,,,
-10503,Colorado CS27 South zone,9802,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,2000000,9003,8827,0,9003,,,
-10531,"SPCS83 Colorado North zone (meters)",9802,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-10532,"SPCS83 Colorado Central zone (meters)",9802,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-10533,"SPCS83 Colorado South zone (meters)",9802,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,914401.8289,9001,8827,304800.6096,9001,,,
-10600,Connecticut CS27,9802,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,600000,9003,8827,0,9003,,,
-10630,"SPCS83 Connecticut zone (meters)",9802,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,304800.6096,9001,8827,152400.3048,9001,,,
-10700,Delaware CS27,9807,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,500000,9003,8807,0,9003,,,,,,
-10730,"SPCS83 Delaware zone (meters)",9807,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,200000,9001,8807,0,9001,,,,,,
-10901,Florida CS27 East zone,9807,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-10902,Florida CS27 West zone,9807,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-10903,Florida CS27 North zone,9802,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,2000000,9003,8827,0,9003,,,
-10931,"SPCS83 Florida East zone (meters)",9807,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-10932,"SPCS83 Florida West zone (meters)",9807,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,200000,9001,8807,0,9001,,,,,,
-10933,"SPCS83 Florida North zone (meters)",9802,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,600000,9001,8827,0,9001,,,
-10934,"Florida GDL Albers (meters)",9822,8821,24,9110,8822,-84,9110,8823,24,9110,8824,31.3,9110,8826,400000,9001,8827,0,9001,,,
-11001,Georgia CS27 East zone,9807,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-11002,Georgia CS27 West zone,9807,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-11031,"SPCS83 Georgia East zone (meters)",9807,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-11032,"SPCS83 Georgia West zone (meters)",9807,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,700000,9001,8807,0,9001,,,,,,
-11101,Idaho CS27 East zone,9807,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,500000,9003,8807,0,9003,,,,,,
-11102,Idaho CS27 Central zone,9807,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,500000,9003,8807,0,9003,,,,,,
-11103,Idaho CS27 West zone,9807,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-11131,"SPCS83 Idaho East zone (meters)",9807,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,200000,9001,8807,0,9001,,,,,,
-11132,"SPCS83 Idaho Central zone (meters)",9807,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,500000,9001,8807,0,9001,,,,,,
-11133,"SPCS83 Idaho West zone (meters)",9807,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,800000,9001,8807,0,9001,,,,,,
-11201,Illinois CS27 East zone,9807,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,500000,9003,8807,0,9003,,,,,,
-11202,Illinois CS27 West zone,9807,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-11231,"SPCS83 Illinois East zone (meters)",9807,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,300000,9001,8807,0,9001,,,,,,
-11232,"SPCS83 Illinois West zone (meters)",9807,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,700000,9001,8807,0,9001,,,,,,
-11301,Indiana CS27 East zone,9807,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-11302,Indiana CS27 West zone,9807,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-11331,"SPCS83 Indiana East zone (meters)",9807,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,100000,9001,8807,250000,9001,,,,,,
-11332,"SPCS83 Indiana West zone (meters)",9807,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,900000,9001,8807,250000,9001,,,,,,
-11401,Iowa CS27 North zone,9802,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,2000000,9003,8827,0,9003,,,
-11402,Iowa CS27 South zone,9802,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,2000000,9003,8827,0,9003,,,
-11431,"SPCS83 Iowa North zone (meters)",9802,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,1500000,9001,8827,1000000,9001,,,
-11432,"SPCS83 Iowa South zone (meters)",9802,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,500000,9001,8827,0,9001,,,
-11501,Kansas CS27 North zone,9802,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,2000000,9003,8827,0,9003,,,
-11502,Kansas CS27 South zone,9802,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,2000000,9003,8827,0,9003,,,
-11531,"SPCS83 Kansas North zone (meters)",9802,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,400000,9001,8827,0,9001,,,
-11532,"SPCS83 Kansas South zone (meters)",9802,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,400000,9001,8827,400000,9001,,,
-11601,Kentucky CS27 North zone,9802,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,2000000,9003,8827,0,9003,,,
-11602,Kentucky CS27 South zone,9802,8821,36.2,9110,8822,-85.45,9110,8823,36.44,9110,8824,37.56,9110,8826,2000000,9003,8827,0,9003,,,
-11630,"SPCS83 Kentucky Single Zone (meters)",9802,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,1500000,9001,8827,1000000,9001,,,
-11631,Kentucky CS83 North zone,9802,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,37.58,9110,8826,500000,9001,8827,0,9001,,,
-11632,"SPCS83 Kentucky South zone (meters)",9802,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,500000,9001,8827,500000,9001,,,
-11701,Louisiana CS27 North zone,9802,8821,30.4,9110,8822,-92.3,9110,8823,31.1,9110,8824,32.4,9110,8826,2000000,9003,8827,0,9003,,,
-11702,Louisiana CS27 South zone,9802,8821,28.4,9110,8822,-91.2,9110,8823,29.18,9110,8824,30.42,9110,8826,2000000,9003,8827,0,9003,,,
-11703,Louisiana CS27 Offshore zone,9802,8821,25.4,9110,8822,-91.2,9110,8823,27.5,9110,8824,26.1,9110,8826,2000000,9003,8827,0,9003,,,
-11731,"SPCS83 Louisiana North zone (meters)",9802,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,1000000,9001,8827,0,9001,,,
-11732,"SPCS83 Louisiana South zone (meters)",9802,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,1000000,9001,8827,0,9001,,,
-11733,"SPCS83 Louisiana Offshore zone (meters)",9802,8821,25.3,9110,8822,-91.2,9110,8823,27.5,9110,8824,26.1,9110,8826,1000000,9001,8827,0,9001,,,
-11801,Maine CS27 East zone,9807,8801,43.5,9110,8802,-68.3,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-11802,Maine CS27 West zone,9807,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-11831,"SPCS83 Maine East zone (meters)",9807,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,300000,9001,8807,0,9001,,,,,,
-11832,"SPCS83 Maine West zone (meters)",9807,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,900000,9001,8807,0,9001,,,,,,
-11833,"SPCS83 Maine East zone (US Survey feet)",9807,8801,43.4,9110,8802,-68.3,9110,8805,0.9999,9201,8806,984250,9003,8807,0,9003,,,,,,
-11834,"SPCS83 Maine West zone (US Survey feet)",9807,8801,42.5,9110,8802,-70.1,9110,8805,0.999966667,9201,8806,2952750,9003,8807,0,9003,,,,,,
-11851,"Maine CS2000 East zone (meters)",9807,8801,43.5,9110,8802,-67.523,9110,8805,0.99998,9201,8806,700000,9001,8807,0,9001,,,,,,
-11852,Maine CS2000 Central zone,9807,8801,43,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-11853,"Maine CS2000 West zone (meters)",9807,8801,42.5,9110,8802,-70.223,9110,8805,0.99998,9201,8806,300000,9001,8807,0,9001,,,,,,
-11854,"Maine CS2000 Central zone (meters)",9807,8801,43.3,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
-11900,Maryland CS27,9802,8821,37.5,9110,8822,-77,9110,8823,38.18,9110,8824,39.27,9110,8826,800000,9003,8827,0,9003,,,
-11930,"SPCS83 Maryland zone (meters)",9802,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,400000,9001,8827,0,9001,,,
-12001,Massachusetts CS27 Mainland zone,9802,8821,41,9110,8822,-71.3,9110,8823,41.43,9110,8824,42.41,9110,8826,600000,9003,8827,0,9003,,,
-12002,Massachusetts CS27 Island zone,9802,8821,41,9110,8822,-70.3,9110,8823,41.17,9110,8824,41.29,9110,8826,200000,9003,8827,0,9003,,,
-12031,"SPCS83 Massachusetts Mainland zone (meters)",9802,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,200000,9001,8827,750000,9001,,,
-12032,"SPCS83 Massachusetts Island zone (meters)",9802,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,500000,9001,8827,0,9001,,,
-12101,Michigan State Plane East zone,9807,8801,41.3,9110,8802,-83.4,9110,8805,0.999942857,9201,8806,500000,9003,8807,0,9003,,,,,,
-12102,Michigan State Plane Old Central zone,9807,8801,41.3,9110,8802,-85.45,9110,8805,0.999909091,9201,8806,500000,9003,8807,0,9003,,,,,,
-12103,Michigan State Plane West zone,9807,8801,41.3,9110,8802,-88.45,9110,8805,0.999909091,9201,8806,500000,9003,8807,0,9003,,,,,,
-12111,Michigan CS27 North zone,9802,8821,44.47,9110,8822,-87,9110,8823,45.29,9110,8824,47.05,9110,8826,2000000,9003,8827,0,9003,,,
-12112,Michigan CS27 Central zone,9802,8821,43.19,9110,8822,-84.2,9110,8823,44.11,9110,8824,45.42,9110,8826,2000000,9003,8827,0,9003,,,
-12113,Michigan CS27 South zone,9802,8821,41.3,9110,8822,-84.2,9110,8823,42.06,9110,8824,43.4,9110,8826,2000000,9003,8827,0,9003,,,
-12141,"SPCS83 Michigan North zone (meters)",9802,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,8000000,9001,8827,0,9001,,,
-12142,"SPCS83 Michigan Central zone (meters)",9802,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,6000000,9001,8827,0,9001,,,
-12143,"SPCS83 Michigan South zone (meters)",9802,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,4000000,9001,8827,0,9001,,,
-12150,"Michigan Oblique Mercator (meters)",9812,8806,2546731.496,9001,8807,-4354009.816,9001,8811,45.1833,9110,8812,-86,9110,8813,337.25556,9102,8814,337.25556,9102,8815,0.9996,9201
-12201,Minnesota CS27 North zone,9802,8821,46.3,9110,8822,-93.06,9110,8823,47.02,9110,8824,48.38,9110,8826,2000000,9003,8827,0,9003,,,
-12202,Minnesota CS27 Central zone,9802,8821,45,9110,8822,-94.15,9110,8823,45.37,9110,8824,47.03,9110,8826,2000000,9003,8827,0,9003,,,
-12203,Minnesota CS27 South zone,9802,8821,43,9110,8822,-94,9110,8823,43.47,9110,8824,45.13,9110,8826,2000000,9003,8827,0,9003,,,
-12231,"SPCS83 Minnesota North zone (meters)",9802,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,800000,9001,8827,100000,9001,,,
-12232,"SPCS83 Minnesota Central zone (meters)",9802,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,800000,9001,8827,100000,9001,,,
-12233,"SPCS83 Minnesota South zone (meters)",9802,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,800000,9001,8827,100000,9001,,,
-12234,"SPCS83 Minnesota North zone (US Survey feet)",9802,8821,46.3,9110,8822,-93.06,9110,8823,48.38,9110,8824,47.02,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-12235,"SPCS83 Minnesota Central zone (US Survey feet)",9802,8821,45,9110,8822,-94.15,9110,8823,47.03,9110,8824,45.37,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-12236,"SPCS83 Minnesota South zone (US Survey feet)",9802,8821,43,9110,8822,-94,9110,8823,45.13,9110,8824,43.47,9110,8826,2624666.6667,9003,8827,328083.3333,9003,,,
-12301,Mississippi CS27 East zone,9807,8801,29.4,9110,8802,-88.5,9110,8805,0.99996,9201,8806,500000,9003,8807,0,9003,,,,,,
-12302,Mississippi CS27 West zone,9807,8801,30.3,9110,8802,-90.2,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-12331,"SPCS83 Mississippi East zone (meters)",9807,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,300000,9001,8807,0,9001,,,,,,
-12332,"SPCS83 Mississippi West zone (meters)",9807,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,700000,9001,8807,0,9001,,,,,,
-12401,Missouri CS27 East zone,9807,8801,35.5,9110,8802,-90.3,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-12402,Missouri CS27 Central zone,9807,8801,35.5,9110,8802,-92.3,9110,8805,0.999933333,9201,8806,500000,9003,8807,0,9003,,,,,,
-12403,Missouri CS27 West zone,9807,8801,36.1,9110,8802,-94.3,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-12431,"SPCS83 Missouri East zone (meters)",9807,8801,35.5,9110,8802,-90.3,9110,8805,0.999933333,9201,8806,250000,9001,8807,0,9001,,,,,,
-12432,"SPCS83 Missouri Central zone (meters)",9807,8801,35.5,9110,8802,-92.3,9110,8805,0.999933333,9201,8806,500000,9001,8807,0,9001,,,,,,
-12433,"SPCS83 Missouri West zone (meters)",9807,8801,36.1,9110,8802,-94.3,9110,8805,0.999941177,9201,8806,850000,9001,8807,0,9001,,,,,,
-12501,Montana CS27 North zone,9802,8821,47,9110,8822,-109.3,9110,8823,48.43,9110,8824,47.51,9110,8826,2000000,9003,8827,0,9003,,,
-12502,Montana CS27 Central zone,9802,8821,45.5,9110,8822,-109.3,9110,8823,47.53,9110,8824,46.27,9110,8826,2000000,9003,8827,0,9003,,,
-12503,Montana CS27 South zone,9802,8821,44,9110,8822,-109.3,9110,8823,46.24,9110,8824,44.52,9110,8826,2000000,9003,8827,0,9003,,,
-12530,"SPCS83 Montana zone (meters)",9802,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,600000,9001,8827,0,9001,,,
-12601,Nebraska CS27 North zone,9802,8821,41.2,9110,8822,-100,9110,8823,41.51,9110,8824,42.49,9110,8826,2000000,9003,8827,0,9003,,,
-12602,Nebraska CS27 South zone,9802,8821,39.4,9110,8822,-99.3,9110,8823,40.17,9110,8824,41.43,9110,8826,2000000,9003,8827,0,9003,,,
-12630,"SPCS83 Nebraska zone (meters)",9802,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,500000,9001,8827,0,9001,,,
-12701,Nevada CS27 East zone,9807,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-12702,Nevada CS27 Central zone,9807,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-12703,Nevada CS27 West zone,9807,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-12731,"SPCS83 Nevada East zone (meters)",9807,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,200000,9001,8807,8000000,9001,,,,,,
-12732,"SPCS83 Nevada Central zone (meters)",9807,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,500000,9001,8807,6000000,9001,,,,,,
-12733,"SPCS83 Nevada West zone (meters)",9807,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,800000,9001,8807,4000000,9001,,,,,,
-12800,New Hampshire CS27,9807,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-12830,"SPCS83 New Hampshire zone (meters)",9807,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,300000,9001,8807,0,9001,,,,,,
-12900,New Jersey CS27,9807,8801,38.5,9110,8802,-74.4,9110,8805,0.999975,9201,8806,2000000,9003,8807,0,9003,,,,,,
-12930,"SPCS83 New Jersey zone (meters)",9807,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-13001,New Mexico CS27 East zone,9807,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,500000,9003,8807,0,9003,,,,,,
-13002,New Mexico CS27 Central zone,9807,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-13003,New Mexico CS27 West zone,9807,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,500000,9003,8807,0,9003,,,,,,
-13031,"SPCS83 New Mexico East zone (meters)",9807,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,165000,9001,8807,0,9001,,,,,,
-13032,"SPCS83 New Mexico Central zone (meters)",9807,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-13033,"SPCS83 New Mexico West zone (meters)",9807,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,830000,9001,8807,0,9001,,,,,,
-13101,New York CS27 East zone,9807,8801,40,9110,8802,-74.2,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-13102,New York CS27 Central zone,9807,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,500000,9003,8807,0,9003,,,,,,
-13103,New York CS27 West zone,9807,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,500000,9003,8807,0,9003,,,,,,
-13104,New York CS27 Long Island zone,9802,8821,40.3,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,1000000,9003,8827,0,9003,,,
-13131,"SPCS83 New York East zone (meters)",9807,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,150000,9001,8807,0,9001,,,,,,
-13132,"SPCS83 New York Central zone (meters)",9807,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,250000,9001,8807,0,9001,,,,,,
-13133,"SPCS83 New York West zone (meters)",9807,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,350000,9001,8807,0,9001,,,,,,
-13134,"SPCS83 New York Long Island zone (meters)",9802,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,300000,9001,8827,0,9001,,,
-13200,North Carolina CS27,9802,8821,33.45,9110,8822,-79,9110,8823,34.2,9110,8824,36.1,9110,8826,2000000,9003,8827,0,9003,,,
-13230,"SPCS83 North Carolina zone (meters)",9802,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,609601.22,9001,8827,0,9001,,,
-13301,North Dakota CS27 North zone,9802,8821,47,9110,8822,-100.3,9110,8823,47.26,9110,8824,48.44,9110,8826,2000000,9003,8827,0,9003,,,
-13302,North Dakota CS27 South zone,9802,8821,45.4,9110,8822,-100.3,9110,8823,46.11,9110,8824,47.29,9110,8826,2000000,9003,8827,0,9003,,,
-13331,"SPCS83 North Dakota North zone (meters)",9802,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,600000,9001,8827,0,9001,,,
-13332,"SPCS83 North Dakota South zone (meters)",9802,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,600000,9001,8827,0,9001,,,
-13401,Ohio CS27 North zone,9802,8821,39.4,9110,8822,-82.3,9110,8823,40.26,9110,8824,41.42,9110,8826,2000000,9003,8827,0,9003,,,
-13402,Ohio CS27 South zone,9802,8821,38,9110,8822,-82.3,9110,8823,38.44,9110,8824,40.02,9110,8826,2000000,9003,8827,0,9003,,,
-13431,"SPCS83 Ohio North zone (meters)",9802,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,600000,9001,8827,0,9001,,,
-13432,"SPCS83 Ohio South zone (meters)",9802,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,600000,9001,8827,0,9001,,,
-13433,"SPCS83 Ohio North zone (US Survey feet)",9802,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,1968500,9003,8827,0,9003,,,
-13434,"SPCS83 Ohio South zone (US Survey feet)",9802,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,1968500,9003,8827,0,9003,,,
-13501,Oklahoma CS27 North zone,9802,8821,35,9110,8822,-98,9110,8823,35.34,9110,8824,36.46,9110,8826,2000000,9003,8827,0,9003,,,
-13502,Oklahoma CS27 South zone,9802,8821,33.2,9110,8822,-98,9110,8823,33.56,9110,8824,35.14,9110,8826,2000000,9003,8827,0,9003,,,
-13531,"SPCS83 Oklahoma North zone (meters)",9802,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,600000,9001,8827,0,9001,,,
-13532,"SPCS83 Oklahoma South zone (meters)",9802,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,600000,9001,8827,0,9001,,,
-13601,Oregon CS27 North zone,9802,8821,43.4,9110,8822,-120.3,9110,8823,44.2,9110,8824,46,9110,8826,2000000,9003,8827,0,9003,,,
-13602,Oregon CS27 South zone,9802,8821,41.4,9110,8822,-120.3,9110,8823,42.2,9110,8824,44,9110,8826,2000000,9003,8827,0,9003,,,
-13631,"SPCS83 Oregon North zone (meters)",9802,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,2500000,9001,8827,0,9001,,,
-13632,"SPCS83 Oregon South zone (meters)",9802,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,1500000,9001,8827,0,9001,,,
-13633,"Oregon GIC Lambert (meters)",9802,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,400000,9001,8827,0,9001,,,
-13701,Pennsylvania CS27 North zone,9802,8821,40.1,9110,8822,-77.45,9110,8823,40.53,9110,8824,41.57,9110,8826,2000000,9003,8827,0,9003,,,
-13702,Pennsylvania CS27 South zone,9802,8821,39.2,9110,8822,-77.45,9110,8823,39.56,9110,8824,40.48,9110,8826,2000000,9003,8827,0,9003,,,
-13731,"SPCS83 Pennsylvania North zone (meters)",9802,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,600000,9001,8827,0,9001,,,
-13732,"SPCS83 Pennsylvania South zone (meters)",9802,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,600000,9001,8827,0,9001,,,
-13800,Rhode Island CS27,9807,8801,41.05,9110,8802,-71.3,9110,8805,0.9999938,9201,8806,500000,9003,8807,0,9003,,,,,,
-13830,"SPCS83 Rhode Island zone (meters)",9807,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,100000,9001,8807,0,9001,,,,,,
-13901,South Carolina CS27 North zone,9802,8821,33,9110,8822,-81,9110,8823,33.46,9110,8824,34.58,9110,8826,2000000,9003,8827,0,9003,,,
-13902,South Carolina CS27 South zone,9802,8821,31.5,9110,8822,-81,9110,8823,32.2,9110,8824,33.4,9110,8826,2000000,9003,8827,0,9003,,,
-13930,"SPCS83 South Carolina zone (meters)",9802,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,609600,9001,8827,0,9001,,,
-14001,South Dakota CS27 North zone,9802,8821,43.5,9110,8822,-100,9110,8823,44.25,9110,8824,45.41,9110,8826,2000000,9003,8827,0,9003,,,
-14002,South Dakota CS27 South zone,9802,8821,42.2,9110,8822,-100.2,9110,8823,42.5,9110,8824,44.24,9110,8826,2000000,9003,8827,0,9003,,,
-14031,"SPCS83 South Dakota North zone (meters)",9802,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,600000,9001,8827,0,9001,,,
-14032,"SPCS83 South Dakota South zone (meters)",9802,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,600000,9001,8827,0,9001,,,
-14100,Tennessee CS27,9802,8821,34.4,9110,8822,-86,9110,8823,35.15,9110,8824,36.25,9110,8826,100000,9003,8827,0,9003,,,
-14130,"SPCS83 Tennessee zone (meters)",9802,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,600000,9001,8827,0,9001,,,
-14201,Texas CS27 North zone,9802,8821,34,9110,8822,-101.3,9110,8823,34.39,9110,8824,36.11,9110,8826,2000000,9003,8827,0,9003,,,
-14202,Texas CS27 North Central zone,9802,8821,31.4,9110,8822,-97.3,9110,8823,32.08,9110,8824,33.58,9110,8826,2000000,9003,8827,0,9003,,,
-14203,Texas CS27 Central zone,9802,8821,29.4,9110,8822,-100.2,9110,8823,30.07,9110,8824,31.53,9110,8826,2000000,9003,8827,0,9003,,,
-14204,Texas CS27 South Central zone,9802,8821,27.5,9110,8822,-99,9110,8823,28.23,9110,8824,30.17,9110,8826,2000000,9003,8827,0,9003,,,
-14205,Texas CS27 South zone,9802,8821,25.4,9110,8822,-98.3,9110,8823,26.1,9110,8824,27.5,9110,8826,2000000,9003,8827,0,9003,,,
-14231,"SPCS83 Texas North zone (meters)",9802,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,200000,9001,8827,1000000,9001,,,
-14232,"SPCS83 Texas North Central zone (meters)",9802,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,600000,9001,8827,2000000,9001,,,
-14233,"SPCS83 Texas Central zone (meters)",9802,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,700000,9001,8827,3000000,9001,,,
-14234,"SPCS83 Texas South Central zone (meters)",9802,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,600000,9001,8827,4000000,9001,,,
-14235,"SPCS83 Texas South zone (meters)",9802,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,300000,9001,8827,5000000,9001,,,
-14251,"Texas State Mapping System (meters)",9802,8821,31.1,9110,8822,-100,9110,8823,27.25,9110,8824,34.55,9110,8826,1000000,9001,8827,1000000,9001,,,
-14252,Shackleford,9802,8821,31.1,9110,8822,-100,9110,8823,27.25,9110,8824,34.55,9110,8826,3000000,9002,8827,3000000,9002,,,
-14253,Texas Centric Lambert Conformal,9802,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,5000000,9001,,,
-14254,Texas Centric Albers Equal Area,9822,8821,18,9110,8822,-100,9110,8823,27.3,9110,8824,35,9110,8826,1500000,9001,8827,6000000,9001,,,
-14301,Utah CS27 North zone,9802,8821,40.2,9110,8822,-111.3,9110,8823,40.43,9110,8824,41.47,9110,8826,2000000,9003,8827,0,9003,,,
-14302,Utah CS27 Central zone,9802,8821,38.2,9110,8822,-111.3,9110,8823,39.01,9110,8824,40.39,9110,8826,2000000,9003,8827,0,9003,,,
-14303,Utah CS27 South zone,9802,8821,36.4,9110,8822,-111.3,9110,8823,37.13,9110,8824,38.21,9110,8826,2000000,9003,8827,0,9003,,,
-14331,"SPCS83 Utah North zone (meters)",9802,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,500000,9001,8827,1000000,9001,,,
-14332,"SPCS83 Utah Central zone (meters)",9802,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,500000,9001,8827,2000000,9001,,,
-14333,"SPCS83 Utah South zone (meters)",9802,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,500000,9001,8827,3000000,9001,,,
-14400,Vermont CS27,9807,8801,42.3,9110,8802,-72.3,9110,8805,0.999964286,9201,8806,500000,9003,8807,0,9003,,,,,,
-14430,"SPCS83 Vermont zone (meters)",9807,8801,42.3,9110,8802,-72.3,9110,8805,0.999964286,9201,8806,500000,9001,8807,0,9001,,,,,,
-14501,Virginia CS27 North zone,9802,8821,37.4,9110,8822,-78.3,9110,8823,38.02,9110,8824,39.12,9110,8826,2000000,9003,8827,0,9003,,,
-14502,Virginia CS27 South zone,9802,8821,36.2,9110,8822,-78.3,9110,8823,36.46,9110,8824,37.58,9110,8826,2000000,9003,8827,0,9003,,,
-14531,"SPCS83 Virginia North zone (meters)",9802,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,3500000,9001,8827,2000000,9001,,,
-14532,"SPCS83 Virginia South zone (meters)",9802,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,3500000,9001,8827,1000000,9001,,,
-14601,Washington CS27 North zone,9802,8821,47,9110,8822,-120.5,9110,8823,47.3,9110,8824,48.44,9110,8826,2000000,9003,8827,0,9003,,,
-14602,Washington CS27 South zone,9802,8821,45.2,9110,8822,-120.3,9110,8823,45.5,9110,8824,47.2,9110,8826,2000000,9003,8827,0,9003,,,
-14631,"SPCS83 Washington North zone (meters)",9802,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,500000,9001,8827,0,9001,,,
-14632,"SPCS83 Washington South zone (meters)",9802,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,500000,9001,8827,0,9001,,,
-14701,West Virginia CS27 North zone,9802,8821,38.3,9110,8822,-79.3,9110,8823,39,9110,8824,40.15,9110,8826,2000000,9003,8827,0,9003,,,
-14702,West Virginia CS27 South zone,9802,8821,37,9110,8822,-81,9110,8823,37.29,9110,8824,38.53,9110,8826,2000000,9003,8827,0,9003,,,
-14731,"SPCS83 West Virginia North zone (meters)",9802,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,600000,9001,8827,0,9001,,,
-14732,"SPCS83 West Virginia South zone (meters)",9802,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,600000,9001,8827,0,9001,,,
-14733,"SPCS83 West Virginia North zone (US Survey feet)",9802,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9001,8827,0,9001,,,
-14734,"SPCS83 West Virginia South zone (US Survey feet)",9802,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9001,8827,0,9001,,,
-14735,"SPCS83 West Virginia North zone (US Survey feet)",9802,8821,38.3,9110,8822,-79.3,9110,8823,40.15,9110,8824,39,9110,8826,1968500,9003,8827,0,9003,,,
-14736,"SPCS83 West Virginia South zone (US Survey feet)",9802,8821,37,9110,8822,-81,9110,8823,38.53,9110,8824,37.29,9110,8826,1968500,9003,8827,0,9003,,,
-14801,Wisconsin CS27 North zone,9802,8821,45.1,9110,8822,-90,9110,8823,45.34,9110,8824,46.46,9110,8826,2000000,9003,8827,0,9003,,,
-14802,Wisconsin CS27 Central zone,9802,8821,43.5,9110,8822,-90,9110,8823,44.15,9110,8824,45.3,9110,8826,2000000,9003,8827,0,9003,,,
-14803,Wisconsin CS27 South zone,9802,8821,42,9110,8822,-90,9110,8823,42.44,9110,8824,44.04,9110,8826,2000000,9003,8827,0,9003,,,
-14811,Wisconsin Transverse Mercator 27,9807,8801,0,9102,8802,-90,9102,8805,0.9996,9201,8806,500000,9001,8807,-4500000,9001,,,,,,
-14831,"SPCS83 Wisconsin North zone (meters)",9802,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,600000,9001,8827,0,9001,,,
-14832,"SPCS83 Wisconsin Central zone (meters)",9802,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,600000,9001,8827,0,9001,,,
-14833,"SPCS83 Wisconsin South zone (meters)",9802,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,600000,9001,8827,0,9001,,,
-14841,Wisconsin Transverse Mercator 83,9807,8801,0,9102,8802,-90,9102,8805,0.9996,9201,8806,520000,9001,8807,-4480000,9001,,,,,,
-14901,Wyoming CS27 East zone,9807,8801,40.4,9110,8802,-105.1,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-14902,Wyoming CS27 East Central zone,9807,8801,40.4,9110,8802,-107.2,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-14903,Wyoming CS27 West Central zone,9807,8801,40.4,9110,8802,-108.45,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-14904,Wyoming CS27 West zone,9807,8801,40.4,9110,8802,-110.05,9110,8805,0.999941177,9201,8806,500000,9003,8807,0,9003,,,,,,
-14931,"SPCS83 Wyoming East zone (meters)",9807,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,200000,9001,8807,0,9001,,,,,,
-14932,"SPCS83 Wyoming East Central zone (meters)",9807,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,400000,9001,8807,100000,9001,,,,,,
-14933,"SPCS83 Wyoming West Central zone (meters)",9807,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,600000,9001,8807,0,9001,,,,,,
-14934,"SPCS83 Wyoming West zone (meters)",9807,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,800000,9001,8807,100000,9001,,,,,,
-14935,"SPCS83 Wyoming East zone (US Survey feet)",9807,8801,40.3,9110,8802,-105.1,9110,8805,0.9999375,9201,8806,656166.6667,9003,8807,0,9003,,,,,,
-14936,"SPCS83 Wyoming East Central zone (US Survey feet)",9807,8801,40.3,9110,8802,-107.2,9110,8805,0.9999375,9201,8806,1312333.3333,9003,8807,328083.3333,9003,,,,,,
-14937,"SPCS83 Wyoming West Central zone (US Survey feet)",9807,8801,40.3,9110,8802,-108.45,9110,8805,0.9999375,9201,8806,1968500,9003,8807,0,9003,,,,,,
-14938,"SPCS83 Wyoming West zone (US Survey feet)",9807,8801,40.3,9110,8802,-110.05,9110,8805,0.9999375,9201,8806,2624666.6667,9003,8807,328083.3333,9003,,,,,,
-15001,Alaska CS27 zone 1,9812,8806,16404166.67,9003,8807,-16404166.67,9003,8811,57,9110,8812,-133.4,9110,8813,323.07483685,9110,8814,323.07483685,9110,8815,0.9999,9201
-15002,Alaska CS27 zone 2,9807,8801,54,9102,8802,-142,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15003,Alaska CS27 zone 3,9807,8801,54,9102,8802,-146,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15004,Alaska CS27 zone 4,9807,8801,54,9102,8802,-150,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15005,Alaska CS27 zone 5,9807,8801,54,9102,8802,-154,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15006,Alaska CS27 zone 6,9807,8801,54,9102,8802,-158,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15007,Alaska CS27 zone 7,9807,8801,54,9102,8802,-162,9102,8805,0.9999,9201,8806,700000,9003,8807,0,9003,,,,,,
-15008,Alaska CS27 zone 8,9807,8801,54,9102,8802,-166,9102,8805,0.9999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15009,Alaska CS27 zone 9,9807,8801,54,9102,8802,-170,9102,8805,0.9999,9201,8806,600000,9003,8807,0,9003,,,,,,
-15010,Alaska CS27 zone 10,9802,8821,51,9110,8822,-176,9110,8823,53.5,9110,8824,51.5,9110,8826,3000000,9003,8827,0,9003,,,
-15020,Alaska Albers,9822,8821,50,9102,8822,-154,9102,8823,55,9102,8824,65,9102,8826,0,9003,8827,0,9003,,,
-15021,"Alaska Albers (meters)",9822,8821,50,9102,8822,-154,9102,8823,55,9102,8824,65,9102,8826,0,9001,8827,0,9001,,,
-15031,"SPCS83 Alaska zone 1 (meters)",9812,8806,5000000,9001,8807,-5000000,9001,8811,57,9110,8812,-133.4,9110,8813,323.07483685,9110,8814,323.07483685,9110,8815,0.9999,9201
-15032,"SPCS83 Alaska zone 2 (meters)",9807,8801,54,9102,8802,-142,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15033,"SPCS83 Alaska zone 3 (meters)",9807,8801,54,9102,8802,-146,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15034,"SPCS83 Alaska zone 4 (meters)",9807,8801,54,9102,8802,-150,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15035,"SPCS83 Alaska zone 5 (meters)",9807,8801,54,9102,8802,-154,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15036,"SPCS83 Alaska zone 6 (meters)",9807,8801,54,9102,8802,-158,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15037,"SPCS83 Alaska zone 7 (meters)",9807,8801,54,9102,8802,-162,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15038,"SPCS83 Alaska zone 8 (meters)",9807,8801,54,9102,8802,-166,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15039,"SPCS83 Alaska zone 9 (meters)",9807,8801,54,9102,8802,-170,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15040,"SPCS83 Alaska zone 10 (meters)",9802,8821,51,9110,8822,-176,9110,8823,53.5,9110,8824,51.5,9110,8826,1000000,9001,8827,0,9001,,,
-15101,Hawaii CS27 zone 1,9807,8801,18.5,9110,8802,-155.3,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-15102,Hawaii CS27 zone 2,9807,8801,20.2,9110,8802,-156.4,9110,8805,0.999966667,9201,8806,500000,9003,8807,0,9003,,,,,,
-15103,Hawaii CS27 zone 3,9807,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15104,Hawaii CS27 zone 4,9807,8801,21.5,9110,8802,-159.3,9110,8805,0.99999,9201,8806,500000,9003,8807,0,9003,,,,,,
-15105,Hawaii CS27 zone 5,9807,8801,21.4,9110,8802,-160.1,9110,8805,1,9201,8806,500000,9003,8807,0,9003,,,,,,
-15131,"SPCS83 Hawaii zone 1 (meters)",9807,8801,18.5,9110,8802,-155.3,9110,8805,0.999966667,9201,8806,500000,9001,8807,0,9001,,,,,,
-15132,"SPCS83 Hawaii zone 2 (meters)",9807,8801,20.2,9110,8802,-156.4,9110,8805,0.999966667,9201,8806,500000,9001,8807,0,9001,,,,,,
-15133,"SPCS83 Hawaii zone 3 (meters)",9807,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15134,"SPCS83 Hawaii zone 4 (meters)",9807,8801,21.5,9110,8802,-159.3,9110,8805,0.99999,9201,8806,500000,9001,8807,0,9001,,,,,,
-15135,"SPCS83 Hawaii zone 5 (meters)",9807,8801,21.4,9110,8802,-160.1,9110,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-15138,"SPCS83 Hawaii zone 3 (US Survey feet)",9807,8801,21.1,9110,8802,-158,9110,8805,0.99999,9201,8806,1640416.6667,9003,8807,0,9003,,,,,,
-15201,Puerto Rico CS27,9802,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,500000,9003,8827,0,9003,,,
-15202,St. Croix CS27,9802,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,500000,9003,8827,100000,9003,,,
-15230,"SPCS83 Puerto Rico & Virgin Islands zone (meters)",9802,8821,17.5,9110,8822,-66.26,9110,8823,18.26,9110,8824,18.02,9110,8826,200000,9001,8827,200000,9001,,,
-15297,"SPCS83 Utah North zone (US Survey feet)",9802,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640416.6667,9003,8827,3280833.3333,9003,,,
-15298,"SPCS83 Utah Central zone (US Survey feet)",9802,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640416.6667,9003,8827,6561666.6667,9003,,,
-15299,"SPCS83 Utah South zone (US Survey feet)",9802,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640416.6667,9003,8827,9842500,9003,,,
-15300,American Samoa Lambert,9801,8801,-14.16,9110,8802,170,9110,8805,1,9201,8806,500000,9003,8807,0,9003,,,,,,
-15301,American Samoa Lambert,9801,8801,-14.16,9110,8802,-170,9110,8805,1,9201,8806,500000,9003,8807,0,9003,,,,,,
-15302,Tennessee CS27,9802,8821,34.4,9110,8822,-86,9110,8823,35.15,9110,8824,36.25,9110,8826,2000000,9003,8827,100000,9003,,,
-15303,"SPCS83 Kentucky North zone (meters)",9802,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,500000,9001,8827,0,9001,,,
-15304,"SPCS83 Arizona East zone (International feet)",9807,8801,31,9110,8802,-110.1,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-15305,"SPCS83 Arizona Central zone (International feet)",9807,8801,31,9110,8802,-111.55,9110,8805,0.9999,9201,8806,700000,9002,8807,0,9002,,,,,,
-15306,"SPCS83 Arizona West zone (International feet)",9807,8801,31,9110,8802,-113.45,9110,8805,0.999933333,9201,8806,700000,9002,8807,0,9002,,,,,,
-15307,"SPCS83 California zone 1 (US Survey feet)",9802,8821,39.2,9110,8822,-122,9110,8823,41.4,9110,8824,40,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-15308,"SPCS83 California zone 2 (US Survey feet)",9802,8821,37.4,9110,8822,-122,9110,8823,39.5,9110,8824,38.2,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-15309,"SPCS83 California zone 3 (US Survey feet)",9802,8821,36.3,9110,8822,-120.3,9110,8823,38.26,9110,8824,37.04,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-15310,"SPCS83 California zone 4 (US Survey feet)",9802,8821,35.2,9110,8822,-119,9110,8823,37.15,9110,8824,36,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-15311,"SPCS83 California zone 5 (US Survey feet)",9802,8821,33.3,9110,8822,-118,9110,8823,35.28,9110,8824,34.02,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-15312,"SPCS83 California zone 6 (US Survey feet)",9802,8821,32.1,9110,8822,-116.15,9110,8823,33.53,9110,8824,32.47,9110,8826,6561666.667,9003,8827,1640416.667,9003,,,
-15313,"SPCS83 Colorado North zone (US Survey feet)",9802,8821,39.2,9110,8822,-105.3,9110,8823,40.47,9110,8824,39.43,9110,8826,3000000,9003,8827,1000000,9003,,,
-15314,"SPCS83 Colorado Central zone (US Survey feet)",9802,8821,37.5,9110,8822,-105.3,9110,8823,39.45,9110,8824,38.27,9110,8826,3000000,9003,8827,1000000,9003,,,
-15315,"SPCS83 Colorado South zone (US Survey feet)",9802,8821,36.4,9110,8822,-105.3,9110,8823,38.26,9110,8824,37.14,9110,8826,3000000,9003,8827,1000000,9003,,,
-15316,"SPCS83 Connecticut zone (US Survey feet)",9802,8821,40.5,9110,8822,-72.45,9110,8823,41.52,9110,8824,41.12,9110,8826,1000000,9003,8827,500000,9003,,,
-15317,"SPCS83 Delaware zone (US Survey feet)",9807,8801,38,9110,8802,-75.25,9110,8805,0.999995,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-15318,"SPCS83 Florida East zone (US Survey feet)",9807,8801,24.2,9110,8802,-81,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-15319,"SPCS83 Florida West zone (US Survey feet)",9807,8801,24.2,9110,8802,-82,9110,8805,0.999941177,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-15320,"SPCS83 Florida North zone (US Survey feet)",9802,8821,29,9110,8822,-84.3,9110,8823,30.45,9110,8824,29.35,9110,8826,1968500,9003,8827,0,9003,,,
-15321,"SPCS83 Georgia East zone (US Survey feet)",9807,8801,30,9110,8802,-82.1,9110,8805,0.9999,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-15322,"SPCS83 Georgia West zone (US Survey feet)",9807,8801,30,9110,8802,-84.1,9110,8805,0.9999,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-15323,"SPCS83 Idaho East zone (US Survey feet)",9807,8801,41.4,9110,8802,-112.1,9110,8805,0.999947368,9201,8806,656166.667,9003,8807,0,9003,,,,,,
-15324,"SPCS83 Idaho Central zone (US Survey feet)",9807,8801,41.4,9110,8802,-114,9110,8805,0.999947368,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-15325,"SPCS83 Idaho West zone (US Survey feet)",9807,8801,41.4,9110,8802,-115.45,9110,8805,0.999933333,9201,8806,2624666.667,9003,8807,0,9003,,,,,,
-15326,"SPCS83 Indiana East zone (US Survey feet)",9807,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,818125,9003,,,,,,
-15327,"SPCS83 Indiana West zone (US Survey feet)",9807,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,818125,9003,,,,,,
-15328,"SPCS83 Kentucky North zone (US Survey feet)",9802,8821,37.3,9110,8822,-84.15,9110,8823,37.58,9110,8824,38.58,9110,8826,1640416.667,9003,8827,0,9003,,,
-15329,"SPCS83 Kentucky South zone (US Survey feet)",9802,8821,36.2,9110,8822,-85.45,9110,8823,37.56,9110,8824,36.44,9110,8826,1640416.667,9003,8827,1640416.667,9003,,,
-15330,"SPCS83 Maryland zone (US Survey feet)",9802,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,1312333.333,9003,8827,0,9003,,,
-15331,"SPCS83 Massachusetts Mainland zone (US Survey feet)",9802,8821,41,9110,8822,-71.3,9110,8823,42.41,9110,8824,41.43,9110,8826,656166.667,9003,8827,2460625,9003,,,
-15332,"SPCS83 Massachusetts Island zone (US Survey feet)",9802,8821,41,9110,8822,-70.3,9110,8823,41.29,9110,8824,41.17,9110,8826,1640416.667,9003,8827,0,9003,,,
-15333,"SPCS83 Michigan North zone (International feet)",9802,8821,44.47,9110,8822,-87,9110,8823,47.05,9110,8824,45.29,9110,8826,26246719.16,9002,8827,0,9002,,,
-15334,"SPCS83 Michigan Central zone (International feet)",9802,8821,43.19,9110,8822,-84.22,9110,8823,45.42,9110,8824,44.11,9110,8826,19685039.37,9002,8827,0,9002,,,
-15335,"SPCS83 Michigan South zone (International feet)",9802,8821,41.3,9110,8822,-84.22,9110,8823,43.4,9110,8824,42.06,9110,8826,13123359.58,9002,8827,0,9002,,,
-15336,"SPCS83 Mississippi East zone (US Survey feet)",9807,8801,29.3,9110,8802,-88.5,9110,8805,0.99995,9201,8806,984250,9003,8807,0,9003,,,,,,
-15337,"SPCS83 Mississippi West zone (US Survey feet)",9807,8801,29.3,9110,8802,-90.2,9110,8805,0.99995,9201,8806,2296583.333,9003,8807,0,9003,,,,,,
-15338,"SPCS83 Montana zone (International feet)",9802,8821,44.15,9110,8822,-109.3,9110,8823,49,9110,8824,45,9110,8826,1968503.937,9002,8827,0,9002,,,
-15339,"SPCS83 New Mexico East zone (US Survey feet)",9807,8801,31,9110,8802,-104.2,9110,8805,0.999909091,9201,8806,541337.5,9003,8807,0,9003,,,,,,
-15340,"SPCS83 New Mexico Central zone (US Survey feet)",9807,8801,31,9110,8802,-106.15,9110,8805,0.9999,9201,8806,1640416.667,9003,8807,0,9003,,,,,,
-15341,"SPCS83 New Mexico West zone (US Survey feet)",9807,8801,31,9110,8802,-107.5,9110,8805,0.999916667,9201,8806,2723091.667,9003,8807,0,9003,,,,,,
-15342,"SPCS83 New York East zone (US Survey feet)",9807,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-15343,"SPCS83 New York Central zone (US Survey feet)",9807,8801,40,9110,8802,-76.35,9110,8805,0.9999375,9201,8806,820208.333,9003,8807,0,9003,,,,,,
-15344,"SPCS83 New York West zone (US Survey feet)",9807,8801,40,9110,8802,-78.35,9110,8805,0.9999375,9201,8806,1148291.667,9003,8807,0,9003,,,,,,
-15345,"SPCS83 New York Long Island zone (US Survey feet)",9802,8821,40.1,9110,8822,-74,9110,8823,41.02,9110,8824,40.4,9110,8826,984250,9003,8827,0,9003,,,
-15346,"SPCS83 North Carolina zone (US Survey feet)",9802,8821,33.45,9110,8822,-79,9110,8823,36.1,9110,8824,34.2,9110,8826,2000000,9003,8827,0,9003,,,
-15347,"SPCS83 North Dakota North zone (International feet)",9802,8821,47,9110,8822,-100.3,9110,8823,48.44,9110,8824,47.26,9110,8826,1968503.937,9002,8827,0,9002,,,
-15348,"SPCS83 North Dakota South zone (International feet)",9802,8821,45.4,9110,8822,-100.3,9110,8823,47.29,9110,8824,46.11,9110,8826,1968503.937,9002,8827,0,9002,,,
-15349,"SPCS83 Oklahoma North zone (US Survey feet)",9802,8821,35,9110,8822,-98,9110,8823,36.46,9110,8824,35.34,9110,8826,1968500,9003,8827,0,9003,,,
-15350,"SPCS83 Oklahoma South zone (US Survey feet)",9802,8821,33.2,9110,8822,-98,9110,8823,35.14,9110,8824,33.56,9110,8826,1968500,9003,8827,0,9003,,,
-15351,"SPCS83 Oregon North zone (International feet)",9802,8821,43.4,9110,8822,-120.3,9110,8823,46,9110,8824,44.2,9110,8826,8202099.738,9002,8827,0,9002,,,
-15352,"SPCS83 Oregon South zone (International feet)",9802,8821,41.4,9110,8822,-120.3,9110,8823,44,9110,8824,42.2,9110,8826,4921259.843,9002,8827,0,9002,,,
-15353,"SPCS83 Pennsylvania North zone (US Survey feet)",9802,8821,40.1,9110,8822,-77.45,9110,8823,41.57,9110,8824,40.53,9110,8826,1968500,9003,8827,0,9003,,,
-15354,"SPCS83 Pennsylvania South zone (US Survey feet)",9802,8821,39.2,9110,8822,-77.45,9110,8823,40.58,9110,8824,39.56,9110,8826,1968500,9003,8827,0,9003,,,
-15355,"SPCS83 South Carolina zone (International feet)",9802,8821,31.5,9110,8822,-81,9110,8823,34.5,9110,8824,32.3,9110,8826,2000000,9002,8827,0,9002,,,
-15356,"SPCS83 Tennessee zone (US Survey feet)",9802,8821,34.2,9110,8822,-86,9110,8823,36.25,9110,8824,35.15,9110,8826,1968500,9003,8827,0,9003,,,
-15357,"SPCS83 Texas North zone (US Survey feet)",9802,8821,34,9110,8822,-101.3,9110,8823,36.11,9110,8824,34.39,9110,8826,656166.667,9003,8827,3280833.333,9003,,,
-15358,"SPCS83 Texas North Central zone (US Survey feet)",9802,8821,31.4,9110,8822,-98.3,9110,8823,33.58,9110,8824,32.08,9110,8826,1968500,9003,8827,6561666.667,9003,,,
-15359,"SPCS83 Texas Central zone (US Survey feet)",9802,8821,29.4,9110,8822,-100.2,9110,8823,31.53,9110,8824,30.07,9110,8826,2296583.333,9003,8827,9842500,9003,,,
-15360,"SPCS83 Texas South Central zone (US Survey feet)",9802,8821,27.5,9110,8822,-99,9110,8823,30.17,9110,8824,28.23,9110,8826,1968500,9003,8827,13123333.333,9003,,,
-15361,"SPCS83 Texas South zone (US Survey feet)",9802,8821,25.4,9110,8822,-98.3,9110,8823,27.5,9110,8824,26.1,9110,8826,984250,9003,8827,16404166.667,9003,,,
-15362,"SPCS83 Utah North zone (International feet)",9802,8821,40.2,9110,8822,-111.3,9110,8823,41.47,9110,8824,40.43,9110,8826,1640419.948,9002,8827,3280839.895,9002,,,
-15363,"SPCS83 Utah Central zone (International feet)",9802,8821,38.2,9110,8822,-111.3,9110,8823,40.39,9110,8824,39.01,9110,8826,1640419.948,9002,8827,6561679.79,9002,,,
-15364,"SPCS83 Utah South zone (International feet)",9802,8821,36.4,9110,8822,-111.3,9110,8823,38.21,9110,8824,37.13,9110,8826,1640419.948,9002,8827,9842519.685,9002,,,
-15365,"SPCS83 Virginia North zone (US Survey feet)",9802,8821,37.4,9110,8822,-78.3,9110,8823,39.12,9110,8824,38.02,9110,8826,11482916.667,9003,8827,6561666.667,9003,,,
-15366,"SPCS83 Virginia South zone (US Survey feet)",9802,8821,36.2,9110,8822,-78.3,9110,8823,37.58,9110,8824,36.46,9110,8826,11482916.667,9003,8827,3280833.333,9003,,,
-15367,"SPCS83 Washington North zone (US Survey feet)",9802,8821,47,9110,8822,-120.5,9110,8823,48.44,9110,8824,47.3,9110,8826,1640416.667,9003,8827,0,9003,,,
-15368,"SPCS83 Washington South zone (US Survey feet)",9802,8821,45.2,9110,8822,-120.3,9110,8823,47.2,9110,8824,45.5,9110,8826,1640416.667,9003,8827,0,9003,,,
-15369,"SPCS83 Wisconsin North zone (US Survey feet)",9802,8821,45.1,9110,8822,-90,9110,8823,46.46,9110,8824,45.34,9110,8826,1968500,9003,8827,0,9003,,,
-15370,"SPCS83 Wisconsin Central zone (US Survey feet)",9802,8821,43.5,9110,8822,-90,9110,8823,45.3,9110,8824,44.15,9110,8826,1968500,9003,8827,0,9003,,,
-15371,"SPCS83 Wisconsin South zone (US Survey feet)",9802,8821,42,9110,8822,-90,9110,8823,44.04,9110,8824,42.44,9110,8826,1968500,9003,8827,0,9003,,,
-15372,"SPCS83 Indiana East zone (US Survey feet)",9807,8801,37.3,9110,8802,-85.4,9110,8805,0.999966667,9201,8806,328083.333,9003,8807,820208.333,9003,,,,,,
-15373,"SPCS83 Indiana West zone (US Survey feet)",9807,8801,37.3,9110,8802,-87.05,9110,8805,0.999966667,9201,8806,2952750,9003,8807,820208.333,9003,,,,,,
-15374,"Oregon GIC Lambert (International feet)",9802,8821,41.45,9110,8822,-120.3,9110,8823,43,9110,8824,45.3,9110,8826,1312335.958,9002,8827,0,9002,,,
-15375,"SPCS83 Kentucky Single Zone (US Survey feet)",9802,8821,36.2,9110,8822,-85.45,9110,8823,37.05,9110,8824,38.4,9110,8826,4921250,9003,8827,3280833.333,9003,,,
-15376,American Samoa Lambert,9801,8801,-14.16,9110,8802,-170,9110,8805,1,9201,8806,500000,9003,8807,312234.65,9003,,,,,,
-15377,"SPCS83 Iowa North zone (US Survey feet)",9802,8821,41.3,9110,8822,-93.3,9110,8823,43.16,9110,8824,42.04,9110,8826,4921250,9003,8827,3280833.3333,9003,,,
-15378,"SPCS83 Iowa South zone (US Survey feet)",9802,8821,40,9110,8822,-93.3,9110,8823,41.47,9110,8824,40.37,9110,8826,1640416.6667,9003,8827,0,9003,,,
-15379,"SPCS83 Kansas North zone (US Survey feet)",9802,8821,38.2,9110,8822,-98,9110,8823,39.47,9110,8824,38.43,9110,8826,1312333.3333,9003,8827,0,9003,,,
-15380,"SPCS83 Kansas South zone (US Survey feet)",9802,8821,36.4,9110,8822,-98.3,9110,8823,38.34,9110,8824,37.16,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-15381,"SPCS83 Nevada East zone (US Survey feet)",9807,8801,34.45,9110,8802,-115.35,9110,8805,0.9999,9201,8806,656166.6667,9003,8807,26246666.6667,9003,,,,,,
-15382,"SPCS83 Nevada Central zone (US Survey feet)",9807,8801,34.45,9110,8802,-116.4,9110,8805,0.9999,9201,8806,1640416.6667,9003,8807,19685000,9003,,,,,,
-15383,"SPCS83 Nevada West zone (US Survey feet)",9807,8801,34.45,9110,8802,-118.35,9110,8805,0.9999,9201,8806,2624666.6667,9003,8807,13123333.3333,9003,,,,,,
-15384,"SPCS83 New Jersey zone (US Survey feet)",9807,8801,38.5,9110,8802,-74.3,9110,8805,0.9999,9201,8806,492125,9003,8807,0,9003,,,,,,
-15385,"SPCS83 Arkansas North zone (US Survey feet)",9802,8821,34.2,9110,8822,-92,9110,8823,36.14,9110,8824,34.56,9110,8826,1312333.3333,9003,8827,0,9003,,,
-15386,"SPCS83 Arkansas South zone (US Survey feet)",9802,8821,32.4,9110,8822,-92,9110,8823,34.46,9110,8824,33.18,9110,8826,1312333.3333,9003,8827,1312333.3333,9003,,,
-15387,"SPCS83 Illinois East zone (US Survey feet)",9807,8801,36.4,9110,8802,-88.2,9110,8805,0.999975,9201,8806,984250,9003,8807,0,9003,,,,,,
-15388,"SPCS83 Illinois West zone (US Survey feet)",9807,8801,36.4,9110,8802,-90.1,9110,8805,0.999941177,9201,8806,2296583.3333,9003,8807,0,9003,,,,,,
-15389,"SPCS83 New Hampshire zone (US Survey feet)",9807,8801,42.3,9110,8802,-71.4,9110,8805,0.999966667,9201,8806,984250,9003,8807,0,9003,,,,,,
-15390,"SPCS83 Rhode Island zone (US Survey feet)",9807,8801,41.05,9110,8802,-71.3,9110,8805,0.99999375,9201,8806,328083.3333,9003,8807,0,9003,,,,,,
-15391,"SPCS83 Louisiana North zone (US Survey feet)",9802,8821,30.3,9110,8822,-92.3,9110,8823,32.4,9110,8824,31.1,9110,8826,3280833.3333,9003,8827,0,9003,,,
-15392,"SPCS83 Louisiana South zone (US Survey feet)",9802,8821,28.3,9110,8822,-91.2,9110,8823,30.42,9110,8824,29.18,9110,8826,3280833.3333,9003,8827,0,9003,,,
-15393,"SPCS83 Louisiana Offshore zone (US Survey feet)",9802,8821,25.3,9110,8822,-91.2,9110,8823,27.5,9110,8824,26.1,9110,8826,3280833.3333,9003,8827,0,9003,,,
-15394,"SPCS83 South Dakota North zone (US Survey feet)",9802,8821,43.5,9110,8822,-100,9110,8823,45.41,9110,8824,44.25,9110,8826,1968500,9003,8827,0,9003,,,
-15395,"SPCS83 South Dakota South zone (US Survey feet)",9802,8821,42.2,9110,8822,-100.2,9110,8823,44.24,9110,8824,42.5,9110,8826,1968500,9003,8827,0,9003,,,
-15396,"SPCS83 Nebraska zone (US Survey feet)",9802,8821,39.5,9110,8822,-100,9110,8823,43,9110,8824,40,9110,8826,1640416.6667,9003,8827,0,9003,,,
-15397,Great Lakes Albers,9822,8821,45.568977,9102,8822,-84.455955,9102,8823,42.122774,9102,8824,49.01518,9102,8826,1000000,9001,8827,1000000,9001,,,
-15398,Great Lakes and St Lawrence Albers,9822,8821,45.568977,9102,8822,-83.248627,9102,8823,42.122774,9102,8824,49.01518,9102,8826,1000000,9001,8827,1000000,9001,,,
-15399,Yap Islands,9832,8801,9.324815,9110,8802,138.100748,9110,8806,40000,9001,8807,60000,9001,,,,,,,,,
-15400,Guam SPCS,9831,8801,13.282087887,9110,8802,144.445550254,9110,8806,50000,9001,8807,50000,9001,,,,,,,,,
-15498,Geographic 2D axis order reversal,9843,,,,,,,,,,,,,,,,,,,,,
-15499,Geographic 3D horizontal axis order reversal,9844,,,,,,,,,,,,,,,,,,,,,
-15500,Australian Antarctic geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15501,Australian Antarctic geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15502,CHTRF95 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15503,CHTRF95 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15504,EST97 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15505,EST97 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15506,ETRS89 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15507,ETRS89 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15508,GDA94 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15509,GDA94 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15510,Hartebeesthoek94 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15511,Hartebeesthoek94 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15512,IRENET95 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15513,IRENET95 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15514,ISN93 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15515,ISN93 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15516,JGD2000 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15517,JGD2000 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15518,LKS92 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15519,LKS92 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15520,LKS94 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15521,LKS94 geocentric to geog3D,9659,,,,,,,,,,,,,,,,,,,,,
-15522,Moznet geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15523,Moznet geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15524,"NAD83(CSRS) geocentric to geog3D",9602,,,,,,,,,,,,,,,,,,,,,
-15525,"NAD83(CSRS) geog3D to geog2D",9659,,,,,,,,,,,,,,,,,,,,,
-15526,"NAD83(HARN) geocentric to geog3D",9602,,,,,,,,,,,,,,,,,,,,,
-15527,"NAD83(HARN) geog3D to geog2D",9659,,,,,,,,,,,,,,,,,,,,,
-15528,NZGD2000 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15529,NZGD2000 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15530,POSGAR 98 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15531,POSGAR 98 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15532,REGVEN geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15533,REGVEN geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15534,RGF93 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15535,RGF93 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15536,RGFG95 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15537,RGFG95 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15538,RGNC91-93 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15539,RGNC91-93 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15540,RGR92 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15541,RGR92 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15542,RRAF 1991 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15543,RRAF 1991 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15544,SIRGAS geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15545,SIRGAS geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15546,SWEREF99 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15547,SWEREF99 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15548,WGS 84 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15549,WGS 84 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15550,Yemen NGN96 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15551,Yemen NGN96 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15552,IGM95 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15553,IGM95 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15554,WGS 72 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15555,WGS 72 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15556,WGS 72BE geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15557,WGS 72BE geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15558,SIRGAS 2000 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15559,SIRGAS 2000 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15560,Lao 1993 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15561,Lao 1993 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15562,Lao 1997 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15563,Lao 1997 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15564,PRS92 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15565,PRS92 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15566,MAGNA-SIRGAS geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15567,MAGNA-SIRGAS geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15568,RGPF geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15569,RGPF geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15570,POSGAR 94 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15571,POSGAR 94 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15572,Korean 2000 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15573,Korean 2000 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15574,Mauritania 1999 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15575,Mauritania 1999 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15576,PZ-90 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15577,PZ-90 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15578,GDM2000 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15579,GDM2000 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15580,GR96 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15581,GR96 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15582,LGD2006 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15583,LGD2006 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15584,DGN95 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15585,DGN95 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15586,JAD2001 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15587,JAD2001 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15588,"NAD83(NSRS2007) geocentric to geog3D",9602,,,,,,,,,,,,,,,,,,,,,
-15589,"NAD83(NSRS2007) geog3D to geog2D",9659,,,,,,,,,,,,,,,,,,,,,
-15590,WGS 66 geocentric to geog3D,9602,,,,,,,,,,,,,,,,,,,,,
-15591,WGS 66 geog3D to geog2D,9659,,,,,,,,,,,,,,,,,,,,,
-15592,geocentric to geographic3D,9602,,,,,,,,,,,,,,,,,,,,,
-15593,geographic3D to geographic2D,9659,,,,,,,,,,,,,,,,,,,,,
-15594,EPSG topocentric example A,9837,8834,55,9102,8835,5,9102,8836,0,9001,,,,,,,,,,,,
-15595,EPSG topocentric example B,9836,8837,3771793.97,9001,8838,140253.34,9001,8839,5124304.35,9001,,,,,,,,,,,,
-15914,"BLM zone 14N (US survey feet)",9807,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-15915,"BLM zone 15N (US survey feet)",9807,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-15916,"BLM zone 16N (US survey feet)",9807,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-15917,"BLM zone 17N (US survey feet)",9807,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,1640416.67,9003,8807,0,9003,,,,,,
-16000,"UTM grid system (northern hemisphere)",9824,8801,0,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,8830,-180,9102,8831,6,9102,,,
-16001,UTM zone 1N,9807,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16002,UTM zone 2N,9807,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16003,UTM zone 3N,9807,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16004,UTM zone 4N,9807,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16005,UTM zone 5N,9807,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16006,UTM zone 6N,9807,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16007,UTM zone 7N,9807,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16008,UTM zone 8N,9807,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16009,UTM zone 9N,9807,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16010,UTM zone 10N,9807,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16011,UTM zone 11N,9807,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16012,UTM zone 12N,9807,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16013,UTM zone 13N,9807,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16014,UTM zone 14N,9807,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16015,UTM zone 15N,9807,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16016,UTM zone 16N,9807,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16017,UTM zone 17N,9807,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16018,UTM zone 18N,9807,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16019,UTM zone 19N,9807,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16020,UTM zone 20N,9807,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16021,UTM zone 21N,9807,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16022,UTM zone 22N,9807,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16023,UTM zone 23N,9807,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16024,UTM zone 24N,9807,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16025,UTM zone 25N,9807,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16026,UTM zone 26N,9807,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16027,UTM zone 27N,9807,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16028,UTM zone 28N,9807,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16029,UTM zone 29N,9807,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16030,UTM zone 30N,9807,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16031,UTM zone 31N,9807,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16032,UTM zone 32N,9807,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16033,UTM zone 33N,9807,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16034,UTM zone 34N,9807,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16035,UTM zone 35N,9807,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16036,UTM zone 36N,9807,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16037,UTM zone 37N,9807,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16038,UTM zone 38N,9807,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16039,UTM zone 39N,9807,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16040,UTM zone 40N,9807,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16041,UTM zone 41N,9807,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16042,UTM zone 42N,9807,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16043,UTM zone 43N,9807,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16044,UTM zone 44N,9807,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16045,UTM zone 45N,9807,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16046,UTM zone 46N,9807,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16047,UTM zone 47N,9807,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16048,UTM zone 48N,9807,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16049,UTM zone 49N,9807,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16050,UTM zone 50N,9807,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16051,UTM zone 51N,9807,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16052,UTM zone 52N,9807,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16053,UTM zone 53N,9807,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16054,UTM zone 54N,9807,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16055,UTM zone 55N,9807,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16056,UTM zone 56N,9807,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16057,UTM zone 57N,9807,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16058,UTM zone 58N,9807,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16059,UTM zone 59N,9807,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16060,UTM zone 60N,9807,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16061,Universal Polar Stereographic North,9810,8801,90,9102,8802,0,9102,8805,0.994,9201,8806,2000000,9001,8807,2000000,9001,,,,,,
-16065,TM35FIN,9807,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16070,3-degree Gauss-Kruger zone 40,9807,8801,0,9102,8802,120,9102,8805,1,9201,8806,40500000,9001,8807,0,9001,,,,,,
-16071,3-degree Gauss-Kruger zone 41,9807,8801,0,9102,8802,123,9102,8805,1,9201,8806,41500000,9001,8807,0,9001,,,,,,
-16072,3-degree Gauss-Kruger zone 42,9807,8801,0,9102,8802,126,9102,8805,1,9201,8806,42500000,9001,8807,0,9001,,,,,,
-16073,3-degree Gauss-Kruger zone 43,9807,8801,0,9102,8802,129,9102,8805,1,9201,8806,43500000,9001,8807,0,9001,,,,,,
-16074,3-degree Gauss-Kruger zone 44,9807,8801,0,9102,8802,132,9102,8805,1,9201,8806,44500000,9001,8807,0,9001,,,,,,
-16075,3-degree Gauss-Kruger zone 45,9807,8801,0,9102,8802,135,9102,8805,1,9201,8806,45500000,9001,8807,0,9001,,,,,,
-16076,3-degree Gauss-Kruger zone 46,9807,8801,0,9102,8802,138,9102,8805,1,9201,8806,46500000,9001,8807,0,9001,,,,,,
-16077,3-degree Gauss-Kruger zone 47,9807,8801,0,9102,8802,141,9102,8805,1,9201,8806,47500000,9001,8807,0,9001,,,,,,
-16078,3-degree Gauss-Kruger zone 48,9807,8801,0,9102,8802,144,9102,8805,1,9201,8806,48500000,9001,8807,0,9001,,,,,,
-16079,3-degree Gauss-Kruger zone 49,9807,8801,0,9102,8802,147,9102,8805,1,9201,8806,49500000,9001,8807,0,9001,,,,,,
-16080,3-degree Gauss-Kruger zone 50,9807,8801,0,9102,8802,150,9102,8805,1,9201,8806,50500000,9001,8807,0,9001,,,,,,
-16081,3-degree Gauss-Kruger zone 51,9807,8801,0,9102,8802,153,9102,8805,1,9201,8806,51500000,9001,8807,0,9001,,,,,,
-16082,3-degree Gauss-Kruger zone 52,9807,8801,0,9102,8802,156,9102,8805,1,9201,8806,52500000,9001,8807,0,9001,,,,,,
-16083,3-degree Gauss-Kruger zone 53,9807,8801,0,9102,8802,159,9102,8805,1,9201,8806,53500000,9001,8807,0,9001,,,,,,
-16084,3-degree Gauss-Kruger zone 54,9807,8801,0,9102,8802,162,9102,8805,1,9201,8806,54500000,9001,8807,0,9001,,,,,,
-16085,3-degree Gauss-Kruger zone 55,9807,8801,0,9102,8802,165,9102,8805,1,9201,8806,55500000,9001,8807,0,9001,,,,,,
-16086,3-degree Gauss-Kruger zone 56,9807,8801,0,9102,8802,168,9102,8805,1,9201,8806,56500000,9001,8807,0,9001,,,,,,
-16087,3-degree Gauss-Kruger zone 57,9807,8801,0,9102,8802,171,9102,8805,1,9201,8806,57500000,9001,8807,0,9001,,,,,,
-16088,3-degree Gauss-Kruger zone 58,9807,8801,0,9102,8802,174,9102,8805,1,9201,8806,58500000,9001,8807,0,9001,,,,,,
-16089,3-degree Gauss-Kruger zone 59,9807,8801,0,9102,8802,177,9102,8805,1,9201,8806,59500000,9001,8807,0,9001,,,,,,
-16090,3-degree Gauss-Kruger zone 60,9807,8801,0,9102,8802,180,9102,8805,1,9201,8806,60000000,9001,8807,0,9001,,,,,,
-16091,3-degree Gauss-Kruger zone 61,9807,8801,0,9102,8802,-177,9102,8805,1,9201,8806,61500000,9001,8807,0,9001,,,,,,
-16092,3-degree Gauss-Kruger zone 62,9807,8801,0,9102,8802,-174,9102,8805,1,9201,8806,62500000,9001,8807,0,9001,,,,,,
-16093,3-degree Gauss-Kruger zone 63,9807,8801,0,9102,8802,-171,9102,8805,1,9201,8806,63500000,9001,8807,0,9001,,,,,,
-16094,3-degree Gauss-Kruger zone 64,9807,8801,0,9102,8802,-168,9102,8805,1,9201,8806,64500000,9001,8807,0,9001,,,,,,
-16099,3-degree Gauss-Kruger zone 60,9807,8801,0,9102,8802,180,9102,8805,1,9201,8806,60500000,9001,8807,0,9001,,,,,,
-16100,"UTM grid system (southern hemisphere)",9824,8801,0,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,8830,-180,9102,8831,6,9102,,,
-16101,UTM zone 1S,9807,8801,0,9102,8802,-177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16102,UTM zone 2S,9807,8801,0,9102,8802,-171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16103,UTM zone 3S,9807,8801,0,9102,8802,-165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16104,UTM zone 4S,9807,8801,0,9102,8802,-159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16105,UTM zone 5S,9807,8801,0,9102,8802,-153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16106,UTM zone 6S,9807,8801,0,9102,8802,-147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16107,UTM zone 7S,9807,8801,0,9102,8802,-141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16108,UTM zone 8S,9807,8801,0,9102,8802,-135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16109,UTM zone 9S,9807,8801,0,9102,8802,-129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16110,UTM zone 10S,9807,8801,0,9102,8802,-123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16111,UTM zone 11S,9807,8801,0,9102,8802,-117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16112,UTM zone 12S,9807,8801,0,9102,8802,-111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16113,UTM zone 13S,9807,8801,0,9102,8802,-105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16114,UTM zone 14S,9807,8801,0,9102,8802,-99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16115,UTM zone 15S,9807,8801,0,9102,8802,-93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16116,UTM zone 16S,9807,8801,0,9102,8802,-87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16117,UTM zone 17S,9807,8801,0,9102,8802,-81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16118,UTM zone 18S,9807,8801,0,9102,8802,-75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16119,UTM zone 19S,9807,8801,0,9102,8802,-69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16120,UTM zone 20S,9807,8801,0,9102,8802,-63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16121,UTM zone 21S,9807,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16122,UTM zone 22S,9807,8801,0,9102,8802,-51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16123,UTM zone 23S,9807,8801,0,9102,8802,-45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16124,UTM zone 24S,9807,8801,0,9102,8802,-39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16125,UTM zone 25S,9807,8801,0,9102,8802,-33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16126,UTM zone 26S,9807,8801,0,9102,8802,-27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16127,UTM zone 27S,9807,8801,0,9102,8802,-21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16128,UTM zone 28S,9807,8801,0,9102,8802,-15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16129,UTM zone 29S,9807,8801,0,9102,8802,-9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16130,UTM zone 30S,9807,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16131,UTM zone 31S,9807,8801,0,9102,8802,3,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16132,UTM zone 32S,9807,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16133,UTM zone 33S,9807,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16134,UTM zone 34S,9807,8801,0,9102,8802,21,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16135,UTM zone 35S,9807,8801,0,9102,8802,27,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16136,UTM zone 36S,9807,8801,0,9102,8802,33,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16137,UTM zone 37S,9807,8801,0,9102,8802,39,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16138,UTM zone 38S,9807,8801,0,9102,8802,45,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16139,UTM zone 39S,9807,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16140,UTM zone 40S,9807,8801,0,9102,8802,57,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16141,UTM zone 41S,9807,8801,0,9102,8802,63,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16142,UTM zone 42S,9807,8801,0,9102,8802,69,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16143,UTM zone 43S,9807,8801,0,9102,8802,75,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16144,UTM zone 44S,9807,8801,0,9102,8802,81,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16145,UTM zone 45S,9807,8801,0,9102,8802,87,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16146,UTM zone 46S,9807,8801,0,9102,8802,93,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16147,UTM zone 47S,9807,8801,0,9102,8802,99,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16148,UTM zone 48S,9807,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16149,UTM zone 49S,9807,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16150,UTM zone 50S,9807,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16151,UTM zone 51S,9807,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16152,UTM zone 52S,9807,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16153,UTM zone 53S,9807,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16154,UTM zone 54S,9807,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16155,UTM zone 55S,9807,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16156,UTM zone 56S,9807,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16157,UTM zone 57S,9807,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16158,UTM zone 58S,9807,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16159,UTM zone 59S,9807,8801,0,9102,8802,171,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16160,UTM zone 60S,9807,8801,0,9102,8802,177,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16161,Universal Polar Stereographic South,9810,8801,-90,9102,8802,0,9102,8805,0.994,9201,8806,2000000,9001,8807,2000000,9001,,,,,,
-16170,3-degree Gauss-Kruger CM 120E,9807,8801,0,9102,8802,120,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16171,3-degree Gauss-Kruger CM 123E,9807,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16172,3-degree Gauss-Kruger CM 126E,9807,8801,0,9102,8802,126,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16173,3-degree Gauss-Kruger CM 129E,9807,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16174,3-degree Gauss-Kruger CM 132E,9807,8801,0,9102,8802,132,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16175,3-degree Gauss-Kruger CM 135E,9807,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16176,3-degree Gauss-Kruger CM 138E,9807,8801,0,9102,8802,138,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16177,3-degree Gauss-Kruger CM 141E,9807,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16178,3-degree Gauss-Kruger CM 144E,9807,8801,0,9102,8802,144,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16179,3-degree Gauss-Kruger CM 147E,9807,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16180,3-degree Gauss-Kruger CM 150E,9807,8801,0,9102,8802,150,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16181,3-degree Gauss-Kruger CM 153E,9807,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16182,3-degree Gauss-Kruger CM 156E,9807,8801,0,9102,8802,156,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16183,3-degree Gauss-Kruger CM 159E,9807,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16184,3-degree Gauss-Kruger CM 162E,9807,8801,0,9102,8802,162,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16185,3-degree Gauss-Kruger CM 165E,9807,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16186,3-degree Gauss-Kruger CM 168E,9807,8801,0,9102,8802,168,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16187,3-degree Gauss-Kruger CM 171E,9807,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16188,3-degree Gauss-Kruger CM 174E,9807,8801,0,9102,8802,174,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16189,3-degree Gauss-Kruger CM 177E,9807,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16190,3-degree Gauss-Kruger CM 180,9807,8801,0,9102,8802,180,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16191,3-degree Gauss-Kruger CM 177W,9807,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16192,3-degree Gauss-Kruger CM 174W,9807,8801,0,9102,8802,-174,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16193,3-degree Gauss-Kruger CM 171W,9807,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16194,3-degree Gauss-Kruger CM 168W,9807,8801,0,9102,8802,-168,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16201,6-degree Gauss-Kruger zone 1,9807,8801,0,9102,8802,3,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-16202,6-degree Gauss-Kruger zone 2,9807,8801,0,9102,8802,9,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-16203,6-degree Gauss-Kruger zone 3,9807,8801,0,9102,8802,15,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-16204,6-degree Gauss-Kruger zone 4,9807,8801,0,9102,8802,21,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-16205,6-degree Gauss-Kruger zone 5,9807,8801,0,9102,8802,27,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-16206,6-degree Gauss-Kruger zone 6,9807,8801,0,9102,8802,33,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-16207,6-degree Gauss-Kruger zone 7,9807,8801,0,9102,8802,39,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-16208,6-degree Gauss-Kruger zone 8,9807,8801,0,9102,8802,45,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-16209,6-degree Gauss-Kruger zone 9,9807,8801,0,9102,8802,51,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-16210,6-degree Gauss-Kruger zone 10,9807,8801,0,9102,8802,57,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-16211,6-degree Gauss-Kruger zone 11,9807,8801,0,9102,8802,63,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-16212,6-degree Gauss-Kruger zone 12,9807,8801,0,9102,8802,69,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-16213,6-degree Gauss-Kruger zone 13,9807,8801,0,9102,8802,75,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-16214,6-degree Gauss-Kruger zone 14,9807,8801,0,9102,8802,81,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-16215,6-degree Gauss-Kruger zone 15,9807,8801,0,9102,8802,87,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-16216,6-degree Gauss-Kruger zone 16,9807,8801,0,9102,8802,93,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-16217,6-degree Gauss-Kruger zone 17,9807,8801,0,9102,8802,99,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-16218,6-degree Gauss-Kruger zone 18,9807,8801,0,9102,8802,105,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-16219,6-degree Gauss-Kruger zone 19,9807,8801,0,9102,8802,111,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-16220,6-degree Gauss-Kruger zone 20,9807,8801,0,9102,8802,117,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-16221,6-degree Gauss-Kruger zone 21,9807,8801,0,9102,8802,123,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-16222,6-degree Gauss-Kruger zone 22,9807,8801,0,9102,8802,129,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-16223,6-degree Gauss-Kruger zone 23,9807,8801,0,9102,8802,135,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-16224,6-degree Gauss-Kruger zone 24,9807,8801,0,9102,8802,141,9102,8805,1,9201,8806,24500000,9001,8807,0,9001,,,,,,
-16225,6-degree Gauss-Kruger zone 25,9807,8801,0,9102,8802,147,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-16226,6-degree Gauss-Kruger zone 26,9807,8801,0,9102,8802,153,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-16227,6-degree Gauss-Kruger zone 27,9807,8801,0,9102,8802,159,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-16228,6-degree Gauss-Kruger zone 28,9807,8801,0,9102,8802,165,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-16229,6-degree Gauss-Kruger zone 29,9807,8801,0,9102,8802,171,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-16230,6-degree Gauss-Kruger zone 30,9807,8801,0,9102,8802,177,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-16231,6-degree Gauss-Kruger zone 31,9807,8801,0,9102,8802,-177,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-16232,6-degree Gauss-Kruger zone 32,9807,8801,0,9102,8802,-171,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-16233,6-degree Gauss-Kruger zone 33,9807,8801,0,9102,8802,-165,9102,8805,1,9201,8806,33500000,9001,8807,0,9001,,,,,,
-16234,6-degree Gauss-Kruger zone 34,9807,8801,0,9102,8802,-159,9102,8805,1,9201,8806,34500000,9001,8807,0,9001,,,,,,
-16235,6-degree Gauss-Kruger zone 35,9807,8801,0,9102,8802,-153,9102,8805,1,9201,8806,35500000,9001,8807,0,9001,,,,,,
-16236,6-degree Gauss-Kruger zone 36,9807,8801,0,9102,8802,-147,9102,8805,1,9201,8806,36500000,9001,8807,0,9001,,,,,,
-16237,6-degree Gauss-Kruger zone 37,9807,8801,0,9102,8802,-141,9102,8805,1,9201,8806,37500000,9001,8807,0,9001,,,,,,
-16238,6-degree Gauss-Kruger zone 38,9807,8801,0,9102,8802,-135,9102,8805,1,9201,8806,38500000,9001,8807,0,9001,,,,,,
-16239,6-degree Gauss-Kruger zone 39,9807,8801,0,9102,8802,-129,9102,8805,1,9201,8806,39500000,9001,8807,0,9001,,,,,,
-16240,6-degree Gauss-Kruger zone 40,9807,8801,0,9102,8802,-123,9102,8805,1,9201,8806,40500000,9001,8807,0,9001,,,,,,
-16241,6-degree Gauss-Kruger zone 41,9807,8801,0,9102,8802,-117,9102,8805,1,9201,8806,41500000,9001,8807,0,9001,,,,,,
-16242,6-degree Gauss-Kruger zone 42,9807,8801,0,9102,8802,-111,9102,8805,1,9201,8806,42500000,9001,8807,0,9001,,,,,,
-16243,6-degree Gauss-Kruger zone 43,9807,8801,0,9102,8802,-105,9102,8805,1,9201,8806,43500000,9001,8807,0,9001,,,,,,
-16244,6-degree Gauss-Kruger zone 44,9807,8801,0,9102,8802,-99,9102,8805,1,9201,8806,44500000,9001,8807,0,9001,,,,,,
-16245,6-degree Gauss-Kruger zone 45,9807,8801,0,9102,8802,-93,9102,8805,1,9201,8806,45500000,9001,8807,0,9001,,,,,,
-16246,6-degree Gauss-Kruger zone 46,9807,8801,0,9102,8802,-87,9102,8805,1,9201,8806,46500000,9001,8807,0,9001,,,,,,
-16247,6-degree Gauss-Kruger zone 47,9807,8801,0,9102,8802,-81,9102,8805,1,9201,8806,47500000,9001,8807,0,9001,,,,,,
-16248,6-degree Gauss-Kruger zone 48,9807,8801,0,9102,8802,-75,9102,8805,1,9201,8806,48500000,9001,8807,0,9001,,,,,,
-16249,6-degree Gauss-Kruger zone 49,9807,8801,0,9102,8802,-69,9102,8805,1,9201,8806,49500000,9001,8807,0,9001,,,,,,
-16250,6-degree Gauss-Kruger zone 50,9807,8801,0,9102,8802,-63,9102,8805,1,9201,8806,50500000,9001,8807,0,9001,,,,,,
-16251,6-degree Gauss-Kruger zone 51,9807,8801,0,9102,8802,-57,9102,8805,1,9201,8806,51500000,9001,8807,0,9001,,,,,,
-16252,6-degree Gauss-Kruger zone 52,9807,8801,0,9102,8802,-51,9102,8805,1,9201,8806,52500000,9001,8807,0,9001,,,,,,
-16253,6-degree Gauss-Kruger zone 53,9807,8801,0,9102,8802,-45,9102,8805,1,9201,8806,53500000,9001,8807,0,9001,,,,,,
-16254,6-degree Gauss-Kruger zone 54,9807,8801,0,9102,8802,-39,9102,8805,1,9201,8806,54500000,9001,8807,0,9001,,,,,,
-16255,6-degree Gauss-Kruger zone 55,9807,8801,0,9102,8802,-33,9102,8805,1,9201,8806,55500000,9001,8807,0,9001,,,,,,
-16256,6-degree Gauss-Kruger zone 56,9807,8801,0,9102,8802,-27,9102,8805,1,9201,8806,56500000,9001,8807,0,9001,,,,,,
-16257,6-degree Gauss-Kruger zone 57,9807,8801,0,9102,8802,-21,9102,8805,1,9201,8806,57500000,9001,8807,0,9001,,,,,,
-16258,6-degree Gauss-Kruger zone 58,9807,8801,0,9102,8802,-15,9102,8805,1,9201,8806,58500000,9001,8807,0,9001,,,,,,
-16259,6-degree Gauss-Kruger zone 59,9807,8801,0,9102,8802,-9,9102,8805,1,9201,8806,59500000,9001,8807,0,9001,,,,,,
-16260,6-degree Gauss-Kruger zone 60,9807,8801,0,9102,8802,-3,9102,8805,1,9201,8806,60500000,9001,8807,0,9001,,,,,,
-16261,3-degree Gauss-Kruger zone 1,9807,8801,0,9102,8802,3,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-16262,3-degree Gauss-Kruger zone 2,9807,8801,0,9102,8802,6,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-16263,3-degree Gauss-Kruger zone 3,9807,8801,0,9102,8802,9,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-16264,3-degree Gauss-Kruger zone 4,9807,8801,0,9102,8802,12,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-16265,3-degree Gauss-Kruger zone 5,9807,8801,0,9102,8802,15,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-16266,3-degree Gauss-Kruger zone 6,9807,8801,0,9102,8802,18,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-16267,3-degree Gauss-Kruger zone 7,9807,8801,0,9102,8802,21,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-16268,3-degree Gauss-Kruger zone 8,9807,8801,0,9102,8802,24,9102,8805,1,9201,8806,8500000,9001,8807,0,9001,,,,,,
-16269,3-degree Gauss-Kruger zone 9,9807,8801,0,9102,8802,27,9102,8805,1,9201,8806,9500000,9001,8807,0,9001,,,,,,
-16270,3-degree Gauss-Kruger zone 10,9807,8801,0,9102,8802,30,9102,8805,1,9201,8806,10500000,9001,8807,0,9001,,,,,,
-16271,3-degree Gauss-Kruger zone 11,9807,8801,0,9102,8802,33,9102,8805,1,9201,8806,11500000,9001,8807,0,9001,,,,,,
-16272,3-degree Gauss-Kruger zone 12,9807,8801,0,9102,8802,36,9102,8805,1,9201,8806,12500000,9001,8807,0,9001,,,,,,
-16273,3-degree Gauss-Kruger zone 13,9807,8801,0,9102,8802,39,9102,8805,1,9201,8806,13500000,9001,8807,0,9001,,,,,,
-16274,3-degree Gauss-Kruger zone 14,9807,8801,0,9102,8802,42,9102,8805,1,9201,8806,14500000,9001,8807,0,9001,,,,,,
-16275,3-degree Gauss-Kruger zone 15,9807,8801,0,9102,8802,45,9102,8805,1,9201,8806,15500000,9001,8807,0,9001,,,,,,
-16276,3-degree Gauss-Kruger zone 16,9807,8801,0,9102,8802,48,9102,8805,1,9201,8806,16500000,9001,8807,0,9001,,,,,,
-16277,3-degree Gauss-Kruger zone 17,9807,8801,0,9102,8802,51,9102,8805,1,9201,8806,17500000,9001,8807,0,9001,,,,,,
-16278,3-degree Gauss-Kruger zone 18,9807,8801,0,9102,8802,54,9102,8805,1,9201,8806,18500000,9001,8807,0,9001,,,,,,
-16279,3-degree Gauss-Kruger zone 19,9807,8801,0,9102,8802,57,9102,8805,1,9201,8806,19500000,9001,8807,0,9001,,,,,,
-16280,3-degree Gauss-Kruger zone 20,9807,8801,0,9102,8802,60,9102,8805,1,9201,8806,20500000,9001,8807,0,9001,,,,,,
-16281,3-degree Gauss-Kruger zone 21,9807,8801,0,9102,8802,63,9102,8805,1,9201,8806,21500000,9001,8807,0,9001,,,,,,
-16282,3-degree Gauss-Kruger zone 22,9807,8801,0,9102,8802,66,9102,8805,1,9201,8806,22500000,9001,8807,0,9001,,,,,,
-16283,3-degree Gauss-Kruger zone 23,9807,8801,0,9102,8802,69,9102,8805,1,9201,8806,23500000,9001,8807,0,9001,,,,,,
-16284,3-degree Gauss-Kruger zone 24,9807,8801,0,9102,8802,72,9102,8805,1,9201,8806,24500000,9001,8807,0,9001,,,,,,
-16285,3-degree Gauss-Kruger zone 25,9807,8801,0,9102,8802,75,9102,8805,1,9201,8806,25500000,9001,8807,0,9001,,,,,,
-16286,3-degree Gauss-Kruger zone 26,9807,8801,0,9102,8802,78,9102,8805,1,9201,8806,26500000,9001,8807,0,9001,,,,,,
-16287,3-degree Gauss-Kruger zone 27,9807,8801,0,9102,8802,81,9102,8805,1,9201,8806,27500000,9001,8807,0,9001,,,,,,
-16288,3-degree Gauss-Kruger zone 28,9807,8801,0,9102,8802,84,9102,8805,1,9201,8806,28500000,9001,8807,0,9001,,,,,,
-16289,3-degree Gauss-Kruger zone 29,9807,8801,0,9102,8802,87,9102,8805,1,9201,8806,29500000,9001,8807,0,9001,,,,,,
-16290,3-degree Gauss-Kruger zone 30,9807,8801,0,9102,8802,90,9102,8805,1,9201,8806,30500000,9001,8807,0,9001,,,,,,
-16291,3-degree Gauss-Kruger zone 31,9807,8801,0,9102,8802,93,9102,8805,1,9201,8806,31500000,9001,8807,0,9001,,,,,,
-16292,3-degree Gauss-Kruger zone 32,9807,8801,0,9102,8802,96,9102,8805,1,9201,8806,32500000,9001,8807,0,9001,,,,,,
-16293,3-degree Gauss-Kruger zone 33,9807,8801,0,9102,8802,99,9102,8805,1,9201,8806,33500000,9001,8807,0,9001,,,,,,
-16294,3-degree Gauss-Kruger zone 34,9807,8801,0,9102,8802,102,9102,8805,1,9201,8806,34500000,9001,8807,0,9001,,,,,,
-16295,3-degree Gauss-Kruger zone 35,9807,8801,0,9102,8802,105,9102,8805,1,9201,8806,35500000,9001,8807,0,9001,,,,,,
-16296,3-degree Gauss-Kruger zone 36,9807,8801,0,9102,8802,108,9102,8805,1,9201,8806,36500000,9001,8807,0,9001,,,,,,
-16297,3-degree Gauss-Kruger zone 37,9807,8801,0,9102,8802,111,9102,8805,1,9201,8806,37500000,9001,8807,0,9001,,,,,,
-16298,3-degree Gauss-Kruger zone 38,9807,8801,0,9102,8802,114,9102,8805,1,9201,8806,38500000,9001,8807,0,9001,,,,,,
-16299,3-degree Gauss-Kruger zone 39,9807,8801,0,9102,8802,117,9102,8805,1,9201,8806,39500000,9001,8807,0,9001,,,,,,
-16301,Gauss-Kruger CM 3E,9807,8801,0,9102,8802,3,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16302,Gauss-Kruger CM 9E,9807,8801,0,9102,8802,9,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16303,Gauss-Kruger CM 15E,9807,8801,0,9102,8802,15,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16304,Gauss-Kruger CM 21E,9807,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16305,Gauss-Kruger CM 27E,9807,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16306,Gauss-Kruger CM 33E,9807,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16307,Gauss-Kruger CM 39E,9807,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16308,Gauss-Kruger CM 45E,9807,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16309,Gauss-Kruger CM 51E,9807,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16310,Gauss-Kruger CM 57E,9807,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16311,Gauss-Kruger CM 63E,9807,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16312,Gauss-Kruger CM 69E,9807,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16313,Gauss-Kruger CM 75E,9807,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16314,Gauss-Kruger CM 81E,9807,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16315,Gauss-Kruger CM 87E,9807,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16316,Gauss-Kruger CM 93E,9807,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16317,Gauss-Kruger CM 99E,9807,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16318,Gauss-Kruger CM 105E,9807,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16319,Gauss-Kruger CM 111E,9807,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16320,Gauss-Kruger CM 117E,9807,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16321,Gauss-Kruger CM 123E,9807,8801,0,9102,8802,123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16322,Gauss-Kruger CM 129E,9807,8801,0,9102,8802,129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16323,Gauss-Kruger CM 135E,9807,8801,0,9102,8802,135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16324,Gauss-Kruger CM 141E,9807,8801,0,9102,8802,141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16325,Gauss-Kruger CM 147E,9807,8801,0,9102,8802,147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16326,Gauss-Kruger CM 153E,9807,8801,0,9102,8802,153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16327,Gauss-Kruger CM 159E,9807,8801,0,9102,8802,159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16328,Gauss-Kruger CM 165E,9807,8801,0,9102,8802,165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16329,Gauss-Kruger CM 171E,9807,8801,0,9102,8802,171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16330,Gauss-Kruger CM 177E,9807,8801,0,9102,8802,177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16331,Gauss-Kruger CM 177W,9807,8801,0,9102,8802,-177,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16332,Gauss-Kruger CM 171W,9807,8801,0,9102,8802,-171,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16333,Gauss-Kruger CM 165W,9807,8801,0,9102,8802,-165,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16334,Gauss-Kruger CM 159W,9807,8801,0,9102,8802,-159,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16335,Gauss-Kruger CM 153W,9807,8801,0,9102,8802,-153,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16336,Gauss-Kruger CM 147W,9807,8801,0,9102,8802,-147,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16337,Gauss-Kruger CM 141W,9807,8801,0,9102,8802,-141,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16338,Gauss-Kruger CM 135W,9807,8801,0,9102,8802,-135,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16339,Gauss-Kruger CM 129W,9807,8801,0,9102,8802,-129,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16340,Gauss-Kruger CM 123W,9807,8801,0,9102,8802,-123,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16341,Gauss-Kruger CM 117W,9807,8801,0,9102,8802,-117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16342,Gauss-Kruger CM 111W,9807,8801,0,9102,8802,-111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16343,Gauss-Kruger CM 105W,9807,8801,0,9102,8802,-105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16344,Gauss-Kruger CM 99W,9807,8801,0,9102,8802,-99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16345,Gauss-Kruger CM 93W,9807,8801,0,9102,8802,-93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16346,Gauss-Kruger CM 87W,9807,8801,0,9102,8802,-87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16347,Gauss-Kruger CM 81W,9807,8801,0,9102,8802,-81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16348,Gauss-Kruger CM 75W,9807,8801,0,9102,8802,-75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16349,Gauss-Kruger CM 69W,9807,8801,0,9102,8802,-69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16350,Gauss-Kruger CM 63W,9807,8801,0,9102,8802,-63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16351,Gauss-Kruger CM 57W,9807,8801,0,9102,8802,-57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16352,Gauss-Kruger CM 51W,9807,8801,0,9102,8802,-51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16353,Gauss-Kruger CM 45W,9807,8801,0,9102,8802,-45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16354,Gauss-Kruger CM 39W,9807,8801,0,9102,8802,-39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16355,Gauss-Kruger CM 33W,9807,8801,0,9102,8802,-33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16356,Gauss-Kruger CM 27W,9807,8801,0,9102,8802,-27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16357,Gauss-Kruger CM 21W,9807,8801,0,9102,8802,-21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16358,Gauss-Kruger CM 15W,9807,8801,0,9102,8802,-15,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16359,Gauss-Kruger CM 9W,9807,8801,0,9102,8802,-9,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16360,Gauss-Kruger CM 3W,9807,8801,0,9102,8802,-3,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16361,3-degree Gauss-Kruger CM 3E,9807,8801,0,9102,8802,3,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16362,3-degree Gauss-Kruger CM 6E,9807,8801,0,9102,8802,6,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16363,3-degree Gauss-Kruger CM 9E,9807,8801,0,9102,8802,9,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16364,3-degree Gauss-Kruger CM 12E,9807,8801,0,9102,8802,12,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16365,3-degree Gauss-Kruger CM 15E,9807,8801,0,9102,8802,15,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16366,3-degree Gauss-Kruger CM 18E,9807,8801,0,9102,8802,18,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16367,3-degree Gauss-Kruger CM 21E,9807,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16368,3-degree Gauss-Kruger CM 24E,9807,8801,0,9102,8802,24,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16369,3-degree Gauss-Kruger CM 27E,9807,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16370,3-degree Gauss-Kruger CM 30E,9807,8801,0,9102,8802,30,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16371,3-degree Gauss-Kruger CM 33E,9807,8801,0,9102,8802,33,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16372,3-degree Gauss-Kruger CM 36E,9807,8801,0,9102,8802,36,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16373,3-degree Gauss-Kruger CM 39E,9807,8801,0,9102,8802,39,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16374,3-degree Gauss-Kruger CM 42E,9807,8801,0,9102,8802,42,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16375,3-degree Gauss-Kruger CM 45E,9807,8801,0,9102,8802,45,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16376,3-degree Gauss-Kruger CM 48E,9807,8801,0,9102,8802,48,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16377,3-degree Gauss-Kruger CM 51E,9807,8801,0,9102,8802,51,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16378,3-degree Gauss-Kruger CM 54E,9807,8801,0,9102,8802,54,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16379,3-degree Gauss-Kruger CM 57E,9807,8801,0,9102,8802,57,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16380,3-degree Gauss-Kruger CM 60E,9807,8801,0,9102,8802,60,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16381,3-degree Gauss-Kruger CM 63E,9807,8801,0,9102,8802,63,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16382,3-degree Gauss-Kruger CM 66E,9807,8801,0,9102,8802,66,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16383,3-degree Gauss-Kruger CM 69E,9807,8801,0,9102,8802,69,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16384,3-degree Gauss-Kruger CM 72E,9807,8801,0,9102,8802,72,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16385,3-degree Gauss-Kruger CM 75E,9807,8801,0,9102,8802,75,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16386,3-degree Gauss-Kruger CM 78E,9807,8801,0,9102,8802,78,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16387,3-degree Gauss-Kruger CM 81E,9807,8801,0,9102,8802,81,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16388,3-degree Gauss-Kruger CM 84E,9807,8801,0,9102,8802,84,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16389,3-degree Gauss-Kruger CM 87E,9807,8801,0,9102,8802,87,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16390,3-degree Gauss-Kruger CM 90E,9807,8801,0,9102,8802,90,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16391,3-degree Gauss-Kruger CM 93E,9807,8801,0,9102,8802,93,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16392,3-degree Gauss-Kruger CM 96E,9807,8801,0,9102,8802,96,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16393,3-degree Gauss-Kruger CM 99E,9807,8801,0,9102,8802,99,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16394,3-degree Gauss-Kruger CM 102E,9807,8801,0,9102,8802,102,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16395,3-degree Gauss-Kruger CM 105E,9807,8801,0,9102,8802,105,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16396,3-degree Gauss-Kruger CM 108E,9807,8801,0,9102,8802,108,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16397,3-degree Gauss-Kruger CM 111E,9807,8801,0,9102,8802,111,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16398,3-degree Gauss-Kruger CM 114E,9807,8801,0,9102,8802,114,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16399,3-degree Gauss-Kruger CM 117E,9807,8801,0,9102,8802,117,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16400,TM 0 N,9807,8801,0,9102,8802,0,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16405,TM 5 NE,9807,8801,0,9102,8802,5,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16406,TM 6 NE,9807,8801,0,9102,8802,6,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16411,TM 11 NE,9807,8801,0,9102,8802,11,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16412,TM 12 NE,9807,8801,0,9102,8802,12,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16413,TM 13 NE,9807,8801,0,9102,8802,13,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16430,TM 30 NE,9807,8801,0,9102,8802,30,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16490,Bangladesh Transverse Mercator,9807,8801,0,9102,8802,90,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16506,TM 106 NE,9807,8801,0,9102,8802,106,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-16586,GK 106 NE,9807,8801,0,9102,8802,106,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-16611,TM 11.30 SE,9807,8801,0,9110,8802,11.3,9110,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16612,TM 12 SE,9807,8801,0,9102,8802,12,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16636,TM 36 SE,9807,8801,0,9102,8802,36,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16709,TM 109 SE,9807,8801,0,9102,8802,109,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16716,TM 116 SE,9807,8801,0,9102,8802,116,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-16732,TM 132 SE,9807,8801,0,9102,8802,132,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17001,TM 1 NW,9807,8801,0,9102,8802,-1,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-17005,TM 5 NW,9807,8801,0,9102,8802,-5,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-17054,TM 54 NW,9807,8801,0,9102,8802,-54,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-17204,SCAR IMW SP19-20,9802,8821,-90,9102,8822,-66,9102,8823,-60.4,9110,8824,-63.2,9110,8826,0,9001,8827,0,9001,,,
-17205,SCAR IMW SP21-22,9802,8821,-90,9102,8822,-54,9102,8823,-60.4,9110,8824,-63.2,9110,8826,0,9001,8827,0,9001,,,
-17206,SCAR IMW SP23-24,9802,8821,-90,9102,8822,-42,9102,8823,-60.4,9110,8824,-63.2,9110,8826,0,9001,8827,0,9001,,,
-17207,SCAR IMW SQ01-02,9802,8821,-90,9102,8822,-174,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17208,SCAR IMW SQ19-20,9802,8821,-90,9102,8822,-66,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17209,SCAR IMW SQ21-22,9802,8821,-90,9102,8822,-54,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17210,SCAR IMW SQ37-38,9802,8821,-90,9102,8822,42,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17211,SCAR IMW SQ39-40,9802,8821,-90,9102,8822,54,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17212,SCAR IMW SQ41-42,9802,8821,-90,9102,8822,66,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17213,SCAR IMW SQ43-44,9802,8821,-90,9102,8822,78,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17214,SCAR IMW SQ45-46,9802,8821,-90,9102,8822,90,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17215,SCAR IMW SQ47-48,9802,8821,-90,9102,8822,102,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17216,SCAR IMW SQ49-50,9802,8821,-90,9102,8822,114,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17217,SCAR IMW SQ51-52,9802,8821,-90,9102,8822,126,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17218,SCAR IMW SQ53-54,9802,8821,-90,9102,8822,138,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17219,SCAR IMW SQ55-56,9802,8821,-90,9102,8822,150,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17220,SCAR IMW SQ57-58,9802,8821,-90,9102,8822,162,9102,8823,-64.4,9110,8824,-67.2,9110,8826,0,9001,8827,0,9001,,,
-17221,SCAR IMW SR13-14,9802,8821,-90,9102,8822,-102,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17222,SCAR IMW SR15-16,9802,8821,-90,9102,8822,-90,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17223,SCAR IMW SR17-18,9802,8821,-90,9102,8822,-78,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17224,SCAR IMW SR19-20,9802,8821,-90,9102,8822,-66,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17225,SCAR IMW SR27-28,9802,8821,-90,9102,8822,-18,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17226,SCAR IMW SR29-30,9802,8821,-90,9102,8822,-6,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17227,SCAR IMW SR31-32,9802,8821,-90,9102,8822,6,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17228,SCAR IMW SR33-34,9802,8821,-90,9102,8822,18,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17229,SCAR IMW SR35-36,9802,8821,-90,9102,8822,30,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17230,SCAR IMW SR37-38,9802,8821,-90,9102,8822,42,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17231,SCAR IMW SR39-40,9802,8821,-90,9102,8822,54,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17232,SCAR IMW SR41-42,9802,8821,-90,9102,8822,66,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17233,SCAR IMW SR43-44,9802,8821,-90,9102,8822,78,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17234,SCAR IMW SR45-46,9802,8821,-90,9102,8822,90,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17235,SCAR IMW SR47-48,9802,8821,-90,9102,8822,102,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17236,SCAR IMW SR49-50,9802,8821,-90,9102,8822,114,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17237,SCAR IMW SR51-52,9802,8821,-90,9102,8822,126,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17238,SCAR IMW SR53-54,9802,8821,-90,9102,8822,138,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17239,SCAR IMW SR55-56,9802,8821,-90,9102,8822,150,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17240,SCAR IMW SR57-58,9802,8821,-90,9102,8822,162,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17241,SCAR IMW SR59-60,9802,8821,-90,9102,8822,174,9102,8823,-68.4,9110,8824,-71.2,9110,8826,0,9001,8827,0,9001,,,
-17242,SCAR IMW SS04-06,9802,8821,-90,9102,8822,-153,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17243,SCAR IMW SS07-09,9802,8821,-90,9102,8822,-135,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17244,SCAR IMW SS10-12,9802,8821,-90,9102,8822,-117,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17245,SCAR IMW SS13-15,9802,8821,-90,9102,8822,-99,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17246,SCAR IMW SS16-18,9802,8821,-90,9102,8822,-81,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17247,SCAR IMW SS19-21,9802,8821,-90,9102,8822,-63,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17248,SCAR IMW SS25-27,9802,8821,-90,9102,8822,-27,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17249,SCAR IMW SS28-30,9802,8821,-90,9102,8822,-9,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17250,SCAR IMW SS31-33,9802,8821,-90,9102,8822,9,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17251,SCAR IMW SS34-36,9802,8821,-90,9102,8822,27,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17252,SCAR IMW SS37-39,9802,8821,-90,9102,8822,45,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17253,SCAR IMW SS40-42,9802,8821,-90,9102,8822,63,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17254,SCAR IMW SS43-45,9802,8821,-90,9102,8822,81,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17255,SCAR IMW SS46-48,9802,8821,-90,9102,8822,99,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17256,SCAR IMW SS49-51,9802,8821,-90,9102,8822,117,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17257,SCAR IMW SS52-54,9802,8821,-90,9102,8822,135,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17258,SCAR IMW SS55-57,9802,8821,-90,9102,8822,153,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17259,SCAR IMW SS58-60,9802,8821,-90,9102,8822,171,9102,8823,-72.4,9110,8824,-75.2,9110,8826,0,9001,8827,0,9001,,,
-17260,SCAR IMW ST01-04,9802,8821,-90,9102,8822,-168,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17261,SCAR IMW ST05-08,9802,8821,-90,9102,8822,-144,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17262,SCAR IMW ST09-12,9802,8821,-90,9102,8822,-120,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17263,SCAR IMW ST13-16,9802,8821,-90,9102,8822,-96,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17264,SCAR IMW ST17-20,9802,8821,-90,9102,8822,-72,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17265,SCAR IMW ST21-24,9802,8821,-90,9102,8822,-48,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17266,SCAR IMW ST25-28,9802,8821,-90,9102,8822,-24,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17267,SCAR IMW ST29-32,9802,8821,-90,9102,8822,0,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17268,SCAR IMW ST33-36,9802,8821,-90,9102,8822,24,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17269,SCAR IMW ST37-40,9802,8821,-90,9102,8822,48,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17270,SCAR IMW ST41-44,9802,8821,-90,9102,8822,72,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17271,SCAR IMW ST45-48,9802,8821,-90,9102,8822,96,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17272,SCAR IMW ST49-52,9802,8821,-90,9102,8822,120,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17273,SCAR IMW ST53-56,9802,8821,-90,9102,8822,144,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17274,SCAR IMW ST57-60,9802,8821,-90,9102,8822,168,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17275,SCAR IMW SU01-05,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-165,9102,,,,,,,,,
-17276,SCAR IMW SU06-10,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-135,9102,,,,,,,,,
-17277,SCAR IMW SU11-15,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-105,9102,,,,,,,,,
-17278,SCAR IMW SU16-20,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-75,9102,,,,,,,,,
-17279,SCAR IMW SU21-25,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-45,9102,,,,,,,,,
-17280,SCAR IMW SU26-30,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-15,9102,,,,,,,,,
-17281,SCAR IMW SU31-35,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,15,9102,,,,,,,,,
-17282,SCAR IMW SU36-40,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,45,9102,,,,,,,,,
-17283,SCAR IMW SU41-45,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,75,9102,,,,,,,,,
-17284,SCAR IMW SU46-50,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,105,9102,,,,,,,,,
-17285,SCAR IMW SU51-55,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,135,9102,,,,,,,,,
-17286,SCAR IMW SU56-60,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,165,9102,,,,,,,,,
-17287,SCAR IMW SV01-10,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-150,9102,,,,,,,,,
-17288,SCAR IMW SV11-20,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-90,9102,,,,,,,,,
-17289,SCAR IMW SV21-30,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,-30,9102,,,,,,,,,
-17290,SCAR IMW SV31-40,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,30,9102,,,,,,,,,
-17291,SCAR IMW SV41-50,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,90,9102,,,,,,,,,
-17292,SCAR IMW SV51-60,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,150,9102,,,,,,,,,
-17293,SCAR IMW SW01-60,9829,8806,0,9001,8807,0,9001,8832,-80.1419,9110,8833,0,9102,,,,,,,,,
-17294,USGS Transantarctic Mountains,9802,8821,-78,9102,8822,162,9102,8823,-76.4,9110,8824,-79.2,9110,8826,0,9001,8827,0,9001,,,
-17295,"North Pole Lambert Azimuthal Equal Area (Bering Sea)",9820,8801,90,9102,8802,180,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-17296,"North Pole Lambert Azimuthal Equal Area (Alaska)",9820,8801,90,9102,8802,-150,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-17297,"North Pole Lambert Azimuthal Equal Area (Canada)",9820,8801,90,9102,8802,-100,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-17298,"North Pole Lambert Azimuthal Equal Area (Atlantic)",9820,8801,90,9102,8802,-40,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-17299,"North Pole Lambert Azimuthal Equal Area (Europe)",9820,8801,90,9102,8802,10,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-17300,"North Pole Lambert Azimuthal Equal Area (Russia)",9820,8801,90,9102,8802,90,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-17321,SWEREF99 12 00,9807,8801,0,9102,8802,12,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17322,SWEREF99 13 30,9807,8801,0,9110,8802,13.3,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17323,SWEREF99 15 00,9807,8801,0,9102,8802,15,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17324,SWEREF99 16 30,9807,8801,0,9110,8802,16.3,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17325,SWEREF99 18 00,9807,8801,0,9102,8802,18,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17326,SWEREF99 14 15,9807,8801,0,9110,8802,14.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17327,SWEREF99 15 45,9807,8801,0,9110,8802,15.45,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17328,SWEREF99 17 15,9807,8801,0,9110,8802,17.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17329,SWEREF99 18 45,9807,8801,0,9110,8802,18.45,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17330,SWEREF99 20 15,9807,8801,0,9110,8802,20.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17331,SWEREF99 21 45,9807,8801,0,9110,8802,21.45,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17332,SWEREF99 23 15,9807,8801,0,9110,8802,23.15,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-17333,SWEREF99 TM,9807,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-17334,Sweden zone 7.5 gon V,9807,8801,0,9110,8802,11.18298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-17335,Sweden zone 5 gon V,9807,8801,0,9110,8802,13.33298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-17336,Sweden zone 0 gon,9807,8801,0,9110,8802,18.03298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-17337,Sweden zone 2.5 gon O,9807,8801,0,9110,8802,20.18298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-17338,Sweden zone 5 gon O,9807,8801,0,9110,8802,22.33298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-17339,RT90 zone 7.5 gon V emulation,9807,8801,0,9110,8802,11.18225,9110,8805,1.000006,9201,8806,1500025.141,9001,8807,-667.282,9001,,,,,,
-17340,RT90 zone 5 gon V emulation,9807,8801,0,9110,8802,13.332256,9110,8805,1.0000058,9201,8806,1500044.695,9001,8807,-667.13,9001,,,,,,
-17341,RT90 zone 2.5 gon V emulation,9807,8801,0,9110,8802,15.4822624306,9110,8805,1.00000561024,9201,8806,1500064.274,9001,8807,-667.711,9001,,,,,,
-17342,RT90 zone 0 gon emulation,9807,8801,0,9110,8802,18.032268,9110,8805,1.0000054,9201,8806,1500083.521,9001,8807,-668.844,9001,,,,,,
-17343,RT90 zone 2.5 gon O emulation,9807,8801,0,9110,8802,20.182274,9110,8805,1.0000052,9201,8806,1500102.765,9001,8807,-670.706,9001,,,,,,
-17344,RT90 zone 5 gon O emulation,9807,8801,0,9110,8802,22.33228,9110,8805,1.0000049,9201,8806,1500121.846,9001,8807,-672.557,9001,,,,,,
-17348,Map Grid of Australia zone 48,9807,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17349,Map Grid of Australia zone 49,9807,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17350,Map Grid of Australia zone 50,9807,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17351,Map Grid of Australia zone 51,9807,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17352,Map Grid of Australia zone 52,9807,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17353,Map Grid of Australia zone 53,9807,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17354,Map Grid of Australia zone 54,9807,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17355,Map Grid of Australia zone 55,9807,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17356,Map Grid of Australia zone 56,9807,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17357,Map Grid of Australia zone 57,9807,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17358,Map Grid of Australia zone 58,9807,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17359,SA Lambert,9802,8821,-32,9102,8822,135,9102,8823,-28,9102,8824,-36,9102,8826,1000000,9001,8827,2000000,9001,,,
-17360,Vicgrid66,9802,8821,-37,9102,8822,145,9102,8823,-36,9102,8824,-38,9102,8826,2500000,9001,8827,4500000,9001,,,
-17361,Vicgrid94,9802,8821,-37,9102,8822,145,9102,8823,-36,9102,8824,-38,9102,8826,2500000,9001,8827,2500000,9001,,,
-17362,Geoscience Australia Standard National Scale Lambert Projection,9802,8821,0,9102,8822,134,9102,8823,-18,9102,8824,-36,9102,8826,0,9001,8827,0,9001,,,
-17363,Brisbane City Survey Grid 02,9807,8801,-28,9102,8802,153,9102,8805,0.99999,9201,8806,50000,9001,8807,100000,9001,,,,,,
-17364,New South Wales Lambert,9802,8821,-33.25,9102,8822,147,9102,8823,-30.75,9102,8824,-35.75,9102,8826,9300000,9001,8827,4500000,9001,,,
-17365,Australian Albers,9822,8821,0,9102,8822,132,9102,8823,-18,9102,8824,-36,9102,8826,0,9001,8827,0,9001,,,
-17401,Katanga Lambert Conformal,9802,8821,0,9102,8822,26,9102,8823,-6.5,9102,8824,-11.5,9102,8826,0,9001,8827,0,9001,,,
-17402,Katanga Transverse Mercator,9807,8801,-9,9102,8802,26,9102,8805,0.9998,9201,8806,0,9001,8807,0,9001,,,,,,
-17412,Congo Transverse Mercator zone 12,9807,8801,0,9102,8802,12,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17414,Congo Transverse Mercator zone 14,9807,8801,0,9102,8802,14,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17416,Congo Transverse Mercator zone 16,9807,8801,0,9102,8802,16,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17418,Congo Transverse Mercator zone 18,9807,8801,0,9102,8802,18,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17420,Congo Transverse Mercator zone 20,9807,8801,0,9102,8802,20,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17422,Congo Transverse Mercator zone 22,9807,8801,0,9102,8802,22,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17424,Congo Transverse Mercator zone 24,9807,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17426,Congo Transverse Mercator zone 26,9807,8801,0,9102,8802,26,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17428,Congo Transverse Mercator zone 28,9807,8801,0,9102,8802,28,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17430,Congo Transverse Mercator zone 30,9807,8801,0,9102,8802,30,9102,8805,0.9999,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17432,Indonesia TM-3 zone 46.2,9807,8801,0,9102,8802,94.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17433,Indonesia TM-3 zone 47.1,9807,8801,0,9102,8802,97.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17434,Indonesia TM-3 zone 47.2,9807,8801,0,9102,8802,100.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17435,Indonesia TM-3 zone 48.1,9807,8801,0,9102,8802,103.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17436,Indonesia TM-3 zone 48.2,9807,8801,0,9102,8802,106.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17437,Indonesia TM-3 zone 49.1,9807,8801,0,9102,8802,109.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17438,Indonesia TM-3 zone 49.2,9807,8801,0,9102,8802,112.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17439,Indonesia TM-3 zone 50.1,9807,8801,0,9102,8802,115.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17440,Indonesia TM-3 zone 50.2,9807,8801,0,9102,8802,118.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17441,Indonesia TM-3 zone 51.1,9807,8801,0,9102,8802,121.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17442,Indonesia TM-3 zone 51.2,9807,8801,0,9102,8802,124.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17443,Indonesia TM-3 zone 52.1,9807,8801,0,9102,8802,127.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17444,Indonesia TM-3 zone 52.2,9807,8801,0,9102,8802,130.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17445,Indonesia TM-3 zone 53.1,9807,8801,0,9102,8802,133.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17446,Indonesia TM-3 zone 53.2,9807,8801,0,9102,8802,136.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17447,Indonesia TM-3 zone 54.1,9807,8801,0,9102,8802,139.5,9102,8805,0.9999,9201,8806,200000,9001,8807,1500000,9001,,,,,,
-17448,Australian Map Grid zone 48,9807,8801,0,9102,8802,105,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17449,Australian Map Grid zone 49,9807,8801,0,9102,8802,111,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17450,Australian Map Grid zone 50,9807,8801,0,9102,8802,117,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17451,Australian Map Grid zone 51,9807,8801,0,9102,8802,123,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17452,Australian Map Grid zone 52,9807,8801,0,9102,8802,129,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17453,Australian Map Grid zone 53,9807,8801,0,9102,8802,135,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17454,Australian Map Grid zone 54,9807,8801,0,9102,8802,141,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17455,Australian Map Grid zone 55,9807,8801,0,9102,8802,147,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17456,Australian Map Grid zone 56,9807,8801,0,9102,8802,153,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17457,Australian Map Grid zone 57,9807,8801,0,9102,8802,159,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17458,Australian Map Grid zone 58,9807,8801,0,9102,8802,165,9102,8805,0.9996,9201,8806,500000,9001,8807,10000000,9001,,,,,,
-17515,South African Survey Grid zone 15,9808,8801,0,9102,8802,15,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17517,South African Survey Grid zone 17,9808,8801,0,9102,8802,17,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17519,South African Survey Grid zone 19,9808,8801,0,9102,8802,19,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17521,South African Survey Grid zone 21,9808,8801,0,9102,8802,21,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17523,South African Survey Grid zone 23,9808,8801,0,9102,8802,23,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17525,South African Survey Grid zone 25,9808,8801,0,9102,8802,25,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17527,South African Survey Grid zone 27,9808,8801,0,9102,8802,27,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17529,South African Survey Grid zone 29,9808,8801,0,9102,8802,29,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17531,South African Survey Grid zone 31,9808,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17533,South African Survey Grid zone 33,9808,8801,0,9102,8802,33,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-17611,South West African Survey Grid zone 11,9808,8801,-22,9102,8802,11,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17613,South West African Survey Grid zone 13,9808,8801,-22,9102,8802,13,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17615,South West African Survey Grid zone 15,9808,8801,-22,9102,8802,15,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17617,South West African Survey Grid zone 17,9808,8801,-22,9102,8802,17,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17619,South West African Survey Grid zone 19,9808,8801,-22,9102,8802,19,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17621,South West African Survey Grid zone 21,9808,8801,-22,9102,8802,21,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17623,South West African Survey Grid zone 23,9808,8801,-22,9102,8802,23,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17625,South West African Survey Grid zone 25,9808,8801,-22,9102,8802,25,9102,8805,1,9201,8806,0,9031,8807,0,9031,,,,,,
-17700,MTM Quebec zone 2,9807,8801,0,9110,8802,-55.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17701,MTM zone 1,9807,8801,0,9102,8802,-53,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17702,MTM Newfoundland zone 2,9807,8801,0,9102,8802,-56,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17703,MTM zone 3,9807,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17704,MTM zone 4,9807,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17705,MTM zone 5,9807,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17706,MTM zone 6,9807,8801,0,9110,8802,-67.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17707,MTM zone 7,9807,8801,0,9110,8802,-70.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17708,MTM zone 8,9807,8801,0,9110,8802,-73.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17709,MTM zone 9,9807,8801,0,9110,8802,-76.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17710,MTM zone 10,9807,8801,0,9110,8802,-79.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17711,MTM zone 11,9807,8801,0,9110,8802,-82.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17712,MTM zone 12,9807,8801,0,9102,8802,-81,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17713,MTM zone 13,9807,8801,0,9102,8802,-84,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17714,MTM zone 14,9807,8801,0,9102,8802,-87,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17715,MTM zone 15,9807,8801,0,9102,8802,-90,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17716,MTM zone 16,9807,8801,0,9102,8802,-93,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17717,MTM zone 17,9807,8801,0,9102,8802,-96,9102,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-17722,Alberta 3-degree TM reference meridian 111 W,9807,8801,0,9102,8802,-111,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17723,Alberta 3-degree TM reference meridian 114 W,9807,8801,0,9102,8802,-114,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17724,Alberta 3-degree TM reference meridian 117 W,9807,8801,0,9102,8802,-117,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17725,Alberta 3-degree TM reference meridian 120 W,9807,8801,0,9102,8802,-120,9102,8805,0.9999,9001,8806,0,9001,8807,0,9001,,,,,,
-17726,Alberta 3-degree TM reference meridian 120 W,9807,8801,0,9102,8802,-120,9102,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17794,MTM Nova Scotia zone 4,9807,8801,0,9110,8802,-61.3,9110,8805,0.9999,9201,8806,4500000,9001,8807,0,9001,,,,,,
-17795,MTM Nova Scotia zone 5,9807,8801,0,9110,8802,-64.3,9110,8805,0.9999,9201,8806,5500000,9001,8807,0,9001,,,,,,
-17801,Japan Plane Rectangular CS zone I,9807,8801,33,9110,8802,129.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17802,Japan Plane Rectangular CS zone II,9807,8801,33,9110,8802,131,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17803,Japan Plane Rectangular CS zone III,9807,8801,36,9110,8802,132.1,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17804,Japan Plane Rectangular CS zone IV,9807,8801,33,9110,8802,133.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17805,Japan Plane Rectangular CS zone V,9807,8801,36,9110,8802,134.2,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17806,Japan Plane Rectangular CS zone VI,9807,8801,36,9110,8802,136,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17807,Japan Plane Rectangular CS zone VII,9807,8801,36,9110,8802,137.1,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17808,Japan Plane Rectangular CS zone VIII,9807,8801,36,9110,8802,138.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17809,Japan Plane Rectangular CS zone IX,9807,8801,36,9110,8802,139.5,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17810,Japan Plane Rectangular CS zone X,9807,8801,40,9110,8802,140.5,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17811,Japan Plane Rectangular CS zone XI,9807,8801,44,9110,8802,140.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17812,Japan Plane Rectangular CS zone XII,9807,8801,44,9110,8802,142.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17813,Japan Plane Rectangular CS zone XIII,9807,8801,44,9110,8802,144.15,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17814,Japan Plane Rectangular CS zone XIV,9807,8801,26,9110,8802,142,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17815,Japan Plane Rectangular CS zone XV,9807,8801,26,9110,8802,127.3,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17816,Japan Plane Rectangular CS zone XVI,9807,8801,26,9110,8802,124,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17817,Japan Plane Rectangular CS zone XVII,9807,8801,26,9110,8802,131,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17818,Japan Plane Rectangular CS zone XVIII,9807,8801,20,9110,8802,136,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17819,Japan Plane Rectangular CS zone XIX,9807,8801,26,9110,8802,154,9110,8805,0.9999,9201,8806,0,9001,8807,0,9001,,,,,,
-17901,Mount Eden Circuit,9807,8801,-36.5247515,9110,8802,174.45516217,9110,8805,0.9999,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17902,Bay of Plenty Circuit,9807,8801,-37.45404993,9110,8802,176.27583101,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17903,Poverty Bay Circuit,9807,8801,-38.372893,9110,8802,177.53082906,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17904,Hawkes Bay Circuit,9807,8801,-39.39033455,9110,8802,176.40252499,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17905,Taranaki Circuit,9807,8801,-39.08087299,9110,8802,174.13408423,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17906,Tuhirangi Circuit,9807,8801,-39.30448934,9110,8802,175.38241325,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17907,Wanganui Circuit,9807,8801,-40.14310097,9110,8802,175.29171586,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17908,Wairarapa Circuit,9807,8801,-40.55319175,9110,8802,175.38504588,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17909,Wellington Circuit,9807,8801,-41.18047507,9110,8802,174.46358432,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17910,Collingwood Circuit,9807,8801,-40.42531326,9110,8802,172.40193674,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17911,Nelson Circuit,9807,8801,-41.1628361,9110,8802,173.17575405,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17912,Karamea Circuit,9807,8801,-41.17236815,9110,8802,172.06325015,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17913,Buller Circuit,9807,8801,-41.48388903,9110,8802,171.34525362,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17914,Grey Circuit,9807,8801,-42.20012994,9110,8802,171.32591767,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17915,Amuri Circuit,9807,8801,-42.41208197,9110,8802,173.00364802,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17916,Marlborough Circuit,9807,8801,-41.3240152,9110,8802,173.48074668,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17917,Hokitika Circuit,9807,8801,-42.53107605,9110,8802,170.58479766,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17918,Okarito Circuit,9807,8801,-43.06364613,9110,8802,170.1539333,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17919,Jacksons Bay Circuit,9807,8801,-43.58400904,9110,8802,168.36225612,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17920,Mount Pleasant Circuit,9807,8801,-43.35262953,9110,8802,172.43378969,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17921,Gawler Circuit,9807,8801,-43.44553616,9110,8802,171.21386945,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17922,Timaru Circuit,9807,8801,-44.24079933,9110,8802,171.0326103,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17923,Lindis Peak Circuit,9807,8801,-44.44069647,9110,8802,169.28039183,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17924,Mount Nicholas Circuit,9807,8801,-45.07584493,9110,8802,168.23551083,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17925,Mount York Circuit,9807,8801,-45.33494142,9110,8802,167.44199024,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17926,Observation Point Circuit,9807,8801,-45.48583078,9110,8802,170.37429426,9110,8805,1,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17927,North Taieri Circuit,9807,8801,-45.51414481,9110,8802,170.16573208,9110,8805,0.99996,9201,8806,300000,9001,8807,700000,9001,,,,,,
-17928,Bluff Circuit,9807,8801,-46.36000346,9110,8802,168.20343392,9110,8805,1,9201,8806,300002.66,9001,8807,699999.58,9001,,,,,,
-17931,Mount Eden 2000,9807,8801,-36.5247,9110,8802,174.4551,9110,8805,0.9999,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17932,Bay of Plenty 2000,9807,8801,-37.454,9110,8802,176.2758,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17933,Poverty Bay 2000,9807,8801,-38.3728,9110,8802,177.5308,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17934,Hawkes Bay 2000,9807,8801,-39.3903,9110,8802,176.4025,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17935,Taranaki 2000,9807,8801,-39.0808,9110,8802,174.134,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17936,Tuhirangi 2000,9807,8801,-39.3044,9110,8802,175.3824,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17937,Wanganui 2000,9807,8801,-40.1431,9110,8802,175.2917,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17938,Wairarapa 2000,9807,8801,-40.5531,9110,8802,175.385,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17939,Wellington 2000,9807,8801,-41.1804,9110,8802,174.4635,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17940,Collingwood 2000,9807,8801,-40.4253,9110,8802,172.4019,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17941,Nelson 2000,9807,8801,-41.1628,9110,8802,173.1757,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17942,Karamea 2000,9807,8801,-41.1723,9110,8802,172.0632,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17943,Buller 2000,9807,8801,-41.4838,9110,8802,171.3452,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17944,Grey 2000,9807,8801,-42.2001,9110,8802,171.3259,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17945,Amuri 2000,9807,8801,-42.412,9110,8802,173.0036,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17946,Marlborough 2000,9807,8801,-41.324,9110,8802,173.4807,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17947,Hokitika 2000,9807,8801,-42.531,9110,8802,170.5847,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17948,Okarito 2000,9807,8801,-43.0636,9110,8802,170.1539,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17949,Jacksons Bay 2000,9807,8801,-43.584,9110,8802,168.3622,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17950,Mount Pleasant 2000,9807,8801,-43.3526,9110,8802,172.4337,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17951,Gawler 2000,9807,8801,-43.4455,9110,8802,171.2138,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17952,Timaru 2000,9807,8801,-44.2407,9110,8802,171.0326,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17953,Lindis Peak 2000,9807,8801,-44.4406,9110,8802,169.2803,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17954,Mount Nicholas 2000,9807,8801,-45.0758,9110,8802,168.2355,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17955,Mount York 2000,9807,8801,-45.3349,9110,8802,167.4419,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17956,Observation Point 2000,9807,8801,-45.4858,9110,8802,170.3742,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17957,North Taieri 2000,9807,8801,-45.5141,9110,8802,170.1657,9110,8805,0.99996,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17958,Bluff 2000,9807,8801,-46.36,9110,8802,168.2034,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17959,Chatham Island Circuit 2000,9807,8801,-44,9110,8802,-176.3,9110,8805,1,9201,8806,400000,9001,8807,800000,9001,,,,,,
-17960,Auckland Islands Transverse Mercator 2000,9807,8801,0,9102,8802,166,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-17961,Campbell Island Transverse Mercator 2000,9807,8801,0,9102,8802,169,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-17962,Antipodes Islands Transverse Mercator 2000,9807,8801,0,9102,8802,179,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-17963,Raoul Island Transverse Mercator 2000,9807,8801,0,9102,8802,-178,9102,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-17964,New Zealand Continental Shelf Lambert Conformal 2000,9802,8821,-41,9110,8822,173,9110,8823,-37.3,9110,8824,-44.3,9110,8826,3000000,9001,8827,7000000,9001,,,
-17965,Chatham Islands Transverse Mercator 2000,9807,8801,0,9110,8802,-176.3,9110,8805,1,9201,8806,3500000,9001,8807,10000000,9001,,,,,,
-17966,Darwin Glacier Lambert Conformal 2000,9802,8821,-90,9110,8822,157,9110,8823,-76.4,9110,8824,-79.2,9110,8826,500000,9001,8827,0,9001,,,
-18001,Austria Gauss-Kruger West Zone,9807,8801,0,9102,8802,28,9102,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-18002,Austria Gauss-Kruger Central Zone,9807,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-18003,Austria Gauss-Kruger East Zone,9807,8801,0,9102,8802,34,9102,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-18004,Austria Gauss-Kruger West,9807,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-18005,Austria Gauss-Kruger Central,9807,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-18006,Austria Gauss-Kruger East,9807,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
-18007,Austria Gauss-Kruger M28,9807,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,150000,9001,8807,-5000000,9001,,,,,,
-18008,Austria Gauss-Kruger M31,9807,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,450000,9001,8807,-5000000,9001,,,,,,
-18009,Austria Gauss-Kruger M34,9807,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,750000,9001,8807,-5000000,9001,,,,,,
-18011,"Nord Algerie (ancienne)",9801,8801,40,9105,8802,3,9105,8805,0.999625544,9201,8806,500000,9001,8807,300000,9001,,,,,,
-18012,"Sud Algerie (ancienne)",9801,8801,37,9105,8802,3,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-18021,Nord Algerie,9801,8801,40,9105,8802,3,9105,8805,0.999625544,9201,8806,500135,9001,8807,300090,9001,,,,,,
-18022,Sud Algerie,9801,8801,37,9105,8802,3,9105,8805,0.999625769,9201,8806,500135,9001,8807,300090,9001,,,,,,
-18031,Argentina zone 1,9807,8801,-90,9102,8802,-72,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-18032,Argentina zone 2,9807,8801,-90,9102,8802,-69,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-18033,Argentina zone 3,9807,8801,-90,9102,8802,-66,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-18034,Argentina zone 4,9807,8801,-90,9102,8802,-63,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-18035,Argentina zone 5,9807,8801,-90,9102,8802,-60,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-18036,Argentina zone 6,9807,8801,-90,9102,8802,-57,9102,8805,1,9201,8806,6500000,9001,8807,0,9001,,,,,,
-18037,Argentina zone 7,9807,8801,-90,9102,8802,-54,9102,8805,1,9201,8806,7500000,9001,8807,0,9001,,,,,,
-18041,Austria West Zone,9807,8801,0,9102,8802,28,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18042,Austria Central Zone,9807,8801,0,9102,8802,31,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18043,Austria East Zone,9807,8801,0,9102,8802,34,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18044,Austria M28,9807,8801,0,9110,8802,10.2,9110,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-18045,Austria M31,9807,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,450000,9001,8807,0,9001,,,,,,
-18046,Austria M34,9807,8801,0,9110,8802,16.2,9110,8805,1,9201,8806,750000,9001,8807,0,9001,,,,,,
-18047,Austria zone M28,9807,8801,0,9102,8802,28,9102,8805,1,9201,8806,150000,9001,8807,0,9001,,,,,,
-18048,Austria zone M31,9807,8801,0,9102,8802,31,9102,8805,1,9201,8806,450000,9001,8807,0,9001,,,,,,
-18049,Austria zone M34,9807,8801,0,9102,8802,34,9102,8805,1,9201,8806,750000,9001,8807,0,9001,,,,,,
-18051,Colombia West zone,9807,8801,4.355657,9110,8802,-77.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18052,Colombia Bogota zone,9807,8801,4.355657,9110,8802,-74.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18053,Colombia East Central zone,9807,8801,4.355657,9110,8802,-71.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18054,Colombia East zone,9807,8801,4.355657,9110,8802,-68.04513,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18055,Colombia MAGNA Far West zone,9807,8801,4.35463215,9110,8802,-80.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18056,Colombia MAGNA West zone,9807,8801,4.35463215,9110,8802,-77.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18057,Colombia MAGNA Bogota zone,9807,8801,4.35463215,9110,8802,-74.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18058,Colombia MAGNA East Central zone,9807,8801,4.35463215,9110,8802,-71.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18059,Colombia MAGNA East zone,9807,8801,4.35463215,9110,8802,-68.04390285,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18061,Cuba Norte,9801,8801,22.21,9110,8802,-81,9110,8805,0.99993602,9201,8806,500000,9001,8807,280296.016,9001,,,,,,
-18062,Cuba Sur,9801,8801,20.43,9110,8802,-76.5,9110,8805,0.99994848,9201,8806,500000,9001,8807,229126.939,9001,,,,,,
-18063,Cuba Norte,9802,8821,22.21,9110,8822,-81,9110,8823,23,9110,8824,21.42,9110,8826,500000,9001,8827,280296.016,9001,,,
-18064,Cuba Sur,9802,8821,20.43,9110,8822,-76.5,9110,8823,21.18,9110,8824,20.08,9110,8826,500000,9001,8827,229126.939,9001,,,
-18071,Egypt Blue Belt,9807,8801,30,9102,8802,35,9102,8805,1,9201,8806,300000,9001,8807,1100000,9001,,,,,,
-18072,Egypt Red Belt,9807,8801,30,9102,8802,31,9102,8805,1,9201,8806,615000,9001,8807,810000,9001,,,,,,
-18073,Egypt Purple Belt,9807,8801,30,9102,8802,27,9102,8805,1,9201,8806,700000,9001,8807,200000,9001,,,,,,
-18074,Egypt Extended Purple Belt,9807,8801,30,9102,8802,27,9102,8805,1,9201,8806,700000,9001,8807,1200000,9001,,,,,,
-18081,Lambert zone I,9801,8801,55,9105,8802,0,9105,8805,0.999877341,9201,8806,600000,9001,8807,1200000,9001,,,,,,
-18082,Lambert zone II,9801,8801,52,9105,8802,0,9105,8805,0.99987742,9201,8806,600000,9001,8807,2200000,9001,,,,,,
-18083,Lambert zone III,9801,8801,49,9105,8802,0,9105,8805,0.999877499,9201,8806,600000,9001,8807,3200000,9001,,,,,,
-18084,Lambert zone IV,9801,8801,46.85,9105,8802,0,9105,8805,0.99994471,9201,8806,234.358,9001,8807,4185861.369,9001,,,,,,
-18085,Lambert-93,9802,8821,46.3,9110,8822,3,9110,8823,49,9110,8824,44,9110,8826,700000,9001,8827,6600000,9001,,,
-18086,France EuroLambert,9801,8801,46.48,9110,8802,2.2014025,9110,8805,0.99987742,9201,8806,600000,9001,8807,2200000,9001,,,,,,
-18091,Lambert Nord France,9801,8801,55,9105,8802,0,9105,8805,0.999877341,9201,8806,600000,9001,8807,200000,9001,,,,,,
-18092,Lambert Centre France,9801,8801,52,9105,8802,0,9105,8805,0.99987742,9201,8806,600000,9001,8807,200000,9001,,,,,,
-18093,Lambert Sud France,9801,8801,49,9105,8802,0,9105,8805,0.999877499,9201,8806,600000,9001,8807,200000,9001,,,,,,
-18094,Lambert Corse,9801,8801,46.85,9105,8802,0,9105,8805,0.99994471,9201,8806,234.358,9001,8807,185861.369,9001,,,,,,
-18101,France Conic Conformal zone 1,9802,8821,42,9102,8822,3,9102,8823,41.25,9102,8824,42.75,9102,8826,1700000,9001,8827,1200000,9001,,,
-18102,France Conic Conformal zone 2,9802,8821,43,9102,8822,3,9102,8823,42.25,9102,8824,43.75,9102,8826,1700000,9001,8827,2200000,9001,,,
-18103,France Conic Conformal zone 3,9802,8821,44,9102,8822,3,9102,8823,43.25,9102,8824,44.75,9102,8826,1700000,9001,8827,3200000,9001,,,
-18104,France Conic Conformal zone 4,9802,8821,45,9102,8822,3,9102,8823,44.25,9102,8824,45.75,9102,8826,1700000,9001,8827,4200000,9001,,,
-18105,France Conic Conformal zone 5,9802,8821,46,9102,8822,3,9102,8823,45.25,9102,8824,46.75,9102,8826,1700000,9001,8827,5200000,9001,,,
-18106,France Conic Conformal zone 6,9802,8821,47,9102,8822,3,9102,8823,46.25,9102,8824,47.75,9102,8826,1700000,9001,8827,6200000,9001,,,
-18107,France Conic Conformal zone 7,9802,8821,48,9102,8822,3,9102,8823,47.25,9102,8824,48.75,9102,8826,1700000,9001,8827,7200000,9001,,,
-18108,France Conic Conformal zone 8,9802,8821,49,9102,8822,3,9102,8823,48.25,9102,8824,49.75,9102,8826,1700000,9001,8827,8200000,9001,,,
-18109,France Conic Conformal zone 9,9802,8821,50,9102,8822,3,9102,8823,49.25,9102,8824,50.75,9102,8826,1700000,9001,8827,9200000,9001,,,
-18110,India zone 0,9801,8801,39.3,9110,8802,68,9110,8805,0.99846154,9201,8806,2355500,9084,8807,2590000,9084,,,,,,
-18111,India zone I,9801,8801,32.3,9110,8802,68,9110,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18112,India zone IIa,9801,8801,26,9102,8802,74,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18113,India zone IIb,9801,8801,26,9102,8802,90,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18114,India zone IIIa,9801,8801,19,9102,8802,80,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18115,India zone IIIb,9801,8801,19,9102,8802,100,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18116,India zone IVa,9801,8801,12,9102,8802,80,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18117,India zone IVb,9801,8801,12,9102,8802,100,9102,8805,0.99878641,9201,8806,3000000,9084,8807,1000000,9084,,,,,,
-18121,Italy zone 1,9807,8801,0,9102,8802,9,9102,8805,0.9996,9201,8806,1500000,9001,8807,0,9001,,,,,,
-18122,Italy zone 2,9807,8801,0,9102,8802,15,9102,8805,0.9996,9201,8806,2520000,9001,8807,0,9001,,,,,,
-18131,Nord Maroc,9801,8801,37,9105,8802,-6,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-18132,Sud Maroc,9801,8801,33,9105,8802,-6,9105,8805,0.999615596,9201,8806,500000,9001,8807,300000,9001,,,,,,
-18133,Sahara,9801,8801,29,9105,8802,-6,9105,8805,0.9996,9201,8806,1200000,9001,8807,400000,9001,,,,,,
-18134,Sahara Nord,9801,8801,29,9105,8802,-6,9105,8805,0.999616304,9201,8806,1200000,9001,8807,400000,9001,,,,,,
-18135,Sahara Sud,9801,8801,25,9105,8802,-6,9105,8805,0.999616437,9201,8806,1500000,9001,8807,400000,9001,,,,,,
-18141,New Zealand North Island National Grid,9807,8801,-39,9110,8802,175.3,9110,8805,1,9201,8806,300000,9040,8807,400000,9040,,,,,,
-18142,New Zealand South Island National Grid,9807,8801,-44,9110,8802,171.3,9110,8805,1,9201,8806,500000,9040,8807,500000,9040,,,,,,
-18151,Nigeria West Belt,9807,8801,4,9110,8802,4.3,9110,8805,0.99975,9201,8806,230738.26,9001,8807,0,9001,,,,,,
-18152,Nigeria Mid Belt,9807,8801,4,9110,8802,8.3,9110,8805,0.99975,9201,8806,670553.98,9001,8807,0,9001,,,,,,
-18153,Nigeria East Belt,9807,8801,4,9110,8802,12.3,9110,8805,0.99975,9201,8806,1110369.7,9001,8807,0,9001,,,,,,
-18161,Peru west zone,9807,8801,-6,9110,8802,-80.3,9110,8805,0.99983008,9201,8806,222000,9001,8807,1426834.743,9001,,,,,,
-18162,Peru central zone,9807,8801,-9.3,9110,8802,-76,9110,8805,0.99932994,9201,8806,720000,9001,8807,1039979.159,9001,,,,,,
-18163,Peru east zone,9807,8801,-9.3,9110,8802,-70.3,9110,8805,0.99952992,9201,8806,1324000,9001,8807,1040084.558,9001,,,,,,
-18171,Philippines zone I,9807,8801,0,9102,8802,117,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-18172,Philippines zone II,9807,8801,0,9102,8802,119,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-18173,Philippines zone III,9807,8801,0,9102,8802,121,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-18174,Philippines zone IV,9807,8801,0,9102,8802,123,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-18175,Philippines zone V,9807,8801,0,9102,8802,125,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-18180,Finland zone 0,9807,8801,0,9102,8802,18,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18181,Nord Tunisie,9801,8801,40,9105,8802,11,9105,8805,0.999625544,9201,8806,500000,9001,8807,300000,9001,,,,,,
-18182,Sud Tunisie,9801,8801,37,9105,8802,11,9105,8805,0.999625769,9201,8806,500000,9001,8807,300000,9001,,,,,,
-18183,Finland ETRS-GK19,9807,8801,0,9102,8802,19,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18184,Finland ETRS-GK20,9807,8801,0,9102,8802,20,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18185,Finland ETRS-GK21,9807,8801,0,9102,8802,21,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18186,Finland ETRS-GK22,9807,8801,0,9102,8802,22,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18187,Finland ETRS-GK23,9807,8801,0,9102,8802,23,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18188,Finland ETRS-GK24,9807,8801,0,9102,8802,24,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18189,Finland ETRS-GK25,9807,8801,0,9102,8802,25,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18190,Finland ETRS-GK26,9807,8801,0,9102,8802,26,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18191,Finland zone 1,9807,8801,0,9102,8802,21,9102,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-18192,Finland zone 2,9807,8801,0,9102,8802,24,9102,8805,1,9201,8806,2500000,9001,8807,0,9001,,,,,,
-18193,Finland Uniform Coordinate System,9807,8801,0,9102,8802,27,9102,8805,1,9201,8806,3500000,9001,8807,0,9001,,,,,,
-18194,Finland zone 4,9807,8801,0,9102,8802,30,9102,8805,1,9201,8806,4500000,9001,8807,0,9001,,,,,,
-18195,Finland ETRS-GK27,9807,8801,0,9102,8802,27,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18196,Finland ETRS-GK28,9807,8801,0,9102,8802,28,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18197,Finland ETRS-GK29,9807,8801,0,9102,8802,29,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18198,Finland ETRS-GK30,9807,8801,0,9102,8802,30,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18199,Finland ETRS-GK31,9807,8801,0,9102,8802,31,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-18201,Palestine Grid,9806,8801,31.4402749,9110,8802,35.124349,9110,8806,170251.555,9001,8807,126867.909,9001,,,,,,,,,
-18202,Palestine Belt,9807,8801,31.4402749,9110,8802,35.124349,9110,8805,1,9201,8806,170251.555,9001,8807,1126867.909,9001,,,,,,
-18203,Israeli CS,9806,8801,31.4402749,9110,8802,35.124349,9110,8806,170251.555,9001,8807,1126867.909,9001,,,,,,,,,
-18204,Israeli TM,9807,8801,31.4403817,9110,8802,35.1216261,9110,8805,1.0000067,9201,8806,219529.584,9001,8807,626907.39,9001,,,,,,
-18205,Finland zone 5,9807,8801,0,9102,8802,33,9102,8805,1,9201,8806,5500000,9001,8807,0,9001,,,,,,
-18211,Guatemala Norte,9801,8801,16.49,9110,8802,-90.2,9110,8805,0.99992226,9201,8806,500000,9001,8807,292209.579,9001,,,,,,
-18212,Guatemala Sur,9801,8801,14.54,9110,8802,-90.2,9110,8805,0.99989906,9201,8806,500000,9001,8807,325992.681,9001,,,,,,
-18221,NGO zone I,9807,8801,58,9110,8802,-4.4,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18222,NGO zone II,9807,8801,58,9110,8802,-2.2,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18223,NGO zone III,9807,8801,58,9110,8802,0,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18224,NGO zone IV,9807,8801,58,9110,8802,2.3,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18225,NGO zone V,9807,8801,58,9110,8802,6.1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18226,NGO zone VI,9807,8801,58,9110,8802,10.1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18227,NGO zone VII,9807,8801,58,9110,8802,14.1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18228,NGO zone VIII,9807,8801,58,9110,8802,18.2,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18231,"India zone I (1975 metres)",9801,8801,32.3,9110,8802,68,9110,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-18232,"India zone IIa (1975 metres)",9801,8801,26,9102,8802,74,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-18233,"India zone IIIa (1975 metres)",9801,8801,19,9102,8802,80,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-18234,"India zone IVa (1975 metres)",9801,8801,12,9102,8802,80,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-18235,"India zone IIb (1975 metres)",9801,8801,26,9102,8802,90,9102,8805,0.99878641,9201,8806,2743195.5,9001,8807,914398.5,9001,,,,,,
-18236,"India zone I (1962 metres)",9801,8801,32.3,9110,8802,68,9110,8805,0.99878641,9201,8806,2743196.4,9001,8807,914398.8,9001,,,,,,
-18237,"India zone IIa (1962 metres)",9801,8801,26,9102,8802,74,9102,8805,0.99878641,9201,8806,2743196.4,9001,8807,914398.8,9001,,,,,,
-18238,"India zone IIb (1937 metres)",9801,8801,26,9102,8802,90,9102,8805,0.99878641,9201,8806,2743185.69,9001,8807,914395.23,9001,,,,,,
-18240,Libya zone 5,9807,8801,0,9102,8802,9,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18241,Libya zone 6,9807,8801,0,9102,8802,11,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18242,Libya zone 7,9807,8801,0,9102,8802,13,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18243,Libya zone 8,9807,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18244,Libya zone 9,9807,8801,0,9102,8802,17,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18245,Libya zone 10,9807,8801,0,9102,8802,19,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18246,Libya zone 11,9807,8801,0,9102,8802,21,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18247,Libya zone 12,9807,8801,0,9102,8802,23,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18248,Libya zone 13,9807,8801,0,9102,8802,25,9102,8805,0.9999,9201,8806,200000,9001,8807,0,9001,,,,,,
-18251,Korea East Belt,9807,8801,38,9102,8802,129,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-18252,Korea Central Belt,9807,8801,38,9102,8802,127,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-18253,Korea West Belt,9807,8801,38,9102,8802,125,9102,8805,1,9201,8806,200000,9001,8807,500000,9001,,,,,,
-18260,"Maracaibo Grid (M1)",9801,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,0,9001,8807,-52684.972,9001,,,,,,
-18261,Maracaibo Grid,9801,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,200000,9001,8807,147315.028,9001,,,,,,
-18262,"Maracaibo Grid (M3)",9801,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,500000,9001,8807,447315.028,9001,,,,,,
-18263,Maracaibo La Rosa Grid,9801,8801,10.1,9110,8802,-71.3620224,9110,8805,1,9201,8806,-17044,9001,8807,-23139.97,9001,,,,,,
-18275,Balkans zone 5,9807,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,5500000,9001,8807,0,9001,,,,,,
-18276,Balkans zone 6,9807,8801,0,9102,8802,18,9102,8805,0.9999,9201,8806,6500000,9001,8807,0,9001,,,,,,
-18277,Balkans zone 7,9807,8801,0,9102,8802,21,9102,8805,0.9999,9201,8806,7500000,9001,8807,0,9001,,,,,,
-18278,Balkans zone 8,9807,8801,0,9102,8802,24,9102,8805,0.9999,9201,8806,8500000,9001,8807,0,9001,,,,,,
-18280,Poland zone I,9809,8801,50.373,9110,8802,21.05,9110,8805,0.9998,9201,8806,4637000,9001,8807,5467000,9001,,,,,,
-18281,Poland zone I,9809,8801,50.373,9110,8802,21.05,9110,8805,0.9998,9201,8806,4637000,9001,8807,5647000,9001,,,,,,
-18282,Poland zone II,9809,8801,53.0007,9110,8802,21.301,9110,8805,0.9998,9201,8806,4603000,9001,8807,5806000,9001,,,,,,
-18283,Poland zone III,9809,8801,53.35,9110,8802,17.003,9110,8805,0.9998,9201,8806,3501000,9001,8807,5999000,9001,,,,,,
-18284,Poland zone IV,9809,8801,51.4015,9110,8802,16.402,9110,8805,0.9998,9201,8806,3703000,9001,8807,5627000,9001,,,,,,
-18285,Poland zone V,9807,8801,0,9110,8802,18.573,9110,8805,0.999983,9201,8806,237000,9001,8807,-4700000,9001,,,,,,
-18286,GUGiK-80,9809,8801,52.1,9110,8802,19.1,9110,8805,0.999714,9201,8806,500000,9001,8807,500000,9001,,,,,,
-18300,Poland CS92,9807,8801,0,9102,8802,19,9102,8805,0.9993,9201,8806,500000,9001,8807,-5300000,9001,,,,,,
-18305,Poland CS2000 zone 5,9807,8801,0,9102,8802,15,9102,8805,0.999923,9201,8806,5500000,9001,8807,0,9001,,,,,,
-18306,Poland CS2000 zone 6,9807,8801,0,9102,8802,18,9102,8805,0.999923,9201,8806,6500000,9001,8807,0,9001,,,,,,
-18307,Poland CS2000 zone 7,9807,8801,0,9102,8802,21,9102,8805,0.999923,9201,8806,7500000,9001,8807,0,9001,,,,,,
-18308,Poland CS2000 zone 8,9807,8801,0,9102,8802,24,9102,8805,0.999923,9201,8806,8500000,9001,8807,0,9001,,,,,,
-18310,Libya TM zone 5,9807,8801,0,9102,8802,9,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18311,Libya TM zone 6,9807,8801,0,9102,8802,11,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18312,Libya TM zone 7,9807,8801,0,9102,8802,13,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18313,Libya TM zone 8,9807,8801,0,9102,8802,15,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18314,Libya TM zone 9,9807,8801,0,9102,8802,17,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18315,Libya TM zone 10,9807,8801,0,9102,8802,19,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18316,Libya TM zone 11,9807,8801,0,9102,8802,21,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18317,Libya TM zone 12,9807,8801,0,9102,8802,23,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18318,Libya TM zone 13,9807,8801,0,9102,8802,25,9102,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18319,Libya TM,9807,8801,0,9102,8802,17,9102,8805,0.9965,9201,8806,1000000,9001,8807,0,9001,,,,,,
-18401,Kp2000 Jylland og Fyn,9807,8801,0,9110,8802,9.3,9110,8805,0.99995,9201,8806,200000,9001,8807,0,9001,,,,,,
-18402,Kp2000 Sjaelland,9807,8801,0,9102,8802,12,9102,8805,0.99995,9201,8806,500000,9001,8807,0,9001,,,,,,
-18403,Kp2000 Bornholm,9807,8801,0,9102,8802,15,9102,8805,1,9201,8806,900000,9001,8807,0,9001,,,,,,
-18411,French West Africa Senegal zone,9807,8801,0,9110,8802,-13.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18412,French West Africa Ivory Coast zone,9807,8801,0,9110,8802,-6.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18413,French West Africa Dahomey zone,9807,8801,0,9110,8802,0.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18414,French West Africa Niger zone,9807,8801,0,9110,8802,7.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18415,French Equatorial Africa west zone,9807,8801,0,9110,8802,10.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18416,French Equatorial Africa central zone,9807,8801,0,9110,8802,17.4,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18417,French Equatorial Africa east zone,9807,8801,0,9110,8802,24.3,9110,8805,0.999,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-18421,Greenland zone 1 east,9826,8801,82.3,9110,8802,-40,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18422,Greenland zone 2 east,9826,8801,79.3,9110,8802,-24,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18423,Greenland zone 3 east,9826,8801,76.3,9110,8802,-20,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18424,Greenland zone 4 east,9826,8801,73.3,9110,8802,-24,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18425,Greenland zone 5 east,9826,8801,70.3,9110,8802,-24,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18426,Greenland zone 6 east,9826,8801,67.3,9110,8802,-32,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18427,Greenland zone 7 east,9826,8801,64.3,9110,8802,-40,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18428,Greenland zone 8 east,9826,8801,61.3,9110,8802,-48,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18432,Greenland zone 2 west,9826,8801,79.3,9110,8802,-64,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18433,Greenland zone 3 west,9826,8801,76.3,9110,8802,-64,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18434,Greenland zone 4 west,9826,8801,73.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18435,Greenland zone 5 west,9826,8801,70.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18436,Greenland zone 6 west,9826,8801,67.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18437,Greenland zone 7 west,9826,8801,64.3,9110,8802,-52,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-18441,CS63 zone A1,9807,8801,0.07,9110,8802,41.32,9110,8805,1,9201,8806,1300000,9001,8807,0,9001,,,,,,
-18442,CS63 zone A2,9807,8801,0.07,9110,8802,44.32,9110,8805,1,9201,8806,2300000,9001,8807,0,9001,,,,,,
-18443,CS63 zone A3,9807,8801,0.07,9110,8802,47.32,9110,8805,1,9201,8806,3300000,9001,8807,0,9001,,,,,,
-18444,CS63 zone A4,9807,8801,0.07,9110,8802,50.32,9110,8805,1,9201,8806,4300000,9001,8807,0,9001,,,,,,
-18446,CS63 zone K2,9807,8801,0.08,9110,8802,50.46,9110,8805,1,9201,8806,2300000,9001,8807,0,9001,,,,,,
-18447,CS63 zone K3,9807,8801,0.08,9110,8802,53.46,9110,8805,1,9201,8806,3300000,9001,8807,0,9001,,,,,,
-18448,CS63 zone K4,9807,8801,0.08,9110,8802,56.46,9110,8805,1,9201,8806,4300000,9001,8807,0,9001,,,,,,
-18450,CS63 zone C0,9807,8801,0.06,9110,8802,21.57,9110,8805,1,9201,8806,250000,9001,8807,0,9001,,,,,,
-18451,CS63 zone C1,9807,8801,0.06,9110,8802,24.57,9110,8805,1,9201,8806,1250000,9001,8807,0,9001,,,,,,
-18452,CS63 zone C2,9807,8801,0.06,9110,8802,27.57,9110,8805,1,9201,8806,2250000,9001,8807,0,9001,,,,,,
-19839,Dubai Local Transverse Mercator,9807,8801,0,9110,8802,55.2,9110,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-19840,IBCAO Polar Stereographic,9829,8806,0,9001,8807,0,9001,8832,75,9102,8833,0,9102,,,,,,,,,
-19841,"Swiss Oblique Mercator 1903C (Greenwich)",9815,8811,46.570866,9110,8812,7.26225,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,0,9001,8817,0,9001
-19842,Arctic Polar Stereographic,9829,8806,0,9001,8807,0,9001,8832,71,9102,8833,0,9102,,,,,,,,,
-19843,Mercator 41,9805,8802,100,9102,8806,0,9001,8807,0,9001,8823,-41,9102,,,,,,,,,
-19844,Ministry of Transport of Quebec Lambert,9802,8821,44,9102,8822,-70,9102,8823,50,9102,8824,46,9102,8826,800000,9001,8827,0,9001,,,
-19845,Slovene National Grid,9807,8801,0,9102,8802,15,9102,8805,0.9999,9201,8806,500000,9001,8807,-5000000,9001,,,,,,
-19846,World Equidistant Cylindrical,9842,8801,0,9102,8806,0,9001,8807,0,9001,8822,0,9102,,,,,,,,,
-19847,Popular Visualisation Mercator,9841,8801,0,9102,8802,0,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19848,Pitcairn TM 2006,9807,8801,-25.04067894,9110,8802,-130.06466816,9110,8805,1,9201,8806,14200,9001,8807,15500,9001,,,,,,
-19849,Bermuda 2000 National Grid,9807,8801,32,9110,8802,-64.45,9110,8805,1,9201,8806,550000,9001,8807,100000,9001,,,,,,
-19850,EPSG vertical perspective example,9838,8834,55,9102,8835,5,9102,8836,200,9001,8840,5900,9036,,,,,,,,,
-19851,Croatia Transverse Mercator,9807,8801,0,9102,8802,16.5,9102,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-19852,Croatia Lambert Conformal Conic,9802,8821,0,9102,8822,16.3,9110,8823,45.55,9110,8824,43.05,9110,8826,0,9001,8827,0,9001,,,
-19853,Portugual TM06,9807,8801,39.400573,9110,8802,-8.075919,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19854,South Georgia Lambert,9802,8821,-55,9102,8822,-37,9102,8823,-54,9110,8824,-54.45,9110,8826,0,9001,8827,0,9001,,,
-19855,Mercator 41,9804,8801,-41,9102,8802,100,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19856,TM Reunion,9807,8801,-21.07,9110,8802,55.32,9110,8805,1,9201,8806,160000,9001,8807,50000,9001,,,,,,
-19857,Northwest Territories Lambert,9802,8821,0,9102,8822,-112,9102,8823,62,9102,8824,70,9102,8826,0,9001,8827,0,9001,,,
-19858,Yukon Albers,9822,8821,59,9110,8822,-132.3,9110,8823,61.4,9110,8824,68,9110,8826,500000,9001,8827,500000,9001,,,
-19859,Fiji Map Grid,9807,8801,-17,9110,8802,178.45,9110,8805,0.99985,9201,8806,2000000,9001,8807,4000000,9001,,,,,,
-19860,Jamaica Metric Grid 2001,9801,8801,18,9102,8802,-77,9102,8805,1,9201,8806,750000,9001,8807,650000,9001,,,,,,
-19861,Laborde Grid,9813,8806,400000,9001,8807,800000,9001,8811,-21,9105,8812,49,9105,8813,21,9105,8815,0.9995,9201,,,
-19862,Belgian Lambert 2005,9802,8821,50.4752134,9110,8822,4.2133177,9110,8823,49.5,9110,8824,51.1,9110,8826,150328,9001,8827,166262,9001,,,
-19863,South China Sea Lambert,9802,8821,21,9102,8822,114,9102,8823,18,9102,8824,24,9102,8826,500000,9001,8827,500000,9001,,,
-19864,Singapore Transverse Mercator,9807,8801,1.22,9110,8802,103.5,9110,8805,1,9201,8806,28001.642,9001,8807,38744.572,9001,,,,,,
-19865,US NSIDC Sea Ice polar stereographic north,9829,8806,0,9001,8807,0,9001,8832,70,9102,8833,-45,9102,,,,,,,,,
-19866,US NSIDC Sea Ice polar stereographic south,9829,8806,0,9001,8807,0,9001,8832,-70,9102,8833,0,9102,,,,,,,,,
-19867,US NSIDC Equal Area north projection,9821,8806,0,9001,8807,0,9001,8828,90,9102,8829,0,9102,,,,,,,,,
-19868,US NSIDC Equal Area south projection,9821,8806,0,9001,8807,0,9001,8828,-90,9102,8829,0,9102,,,,,,,,,
-19869,US NSIDC Equal Area global projection,9834,8802,0,9102,8806,0,9001,8807,0,9001,8823,30,9102,,,,,,,,,
-19870,Faroe Lambert,9826,8801,62,9102,8802,-9,9102,8805,1,9201,8806,500000,9001,8807,500000,9001,,,,,,
-19871,"Rectified Skew Orthomorphic Malaya Grid (chains)",9812,8806,40000,9301,8807,0,9301,8811,4,9110,8812,102.15,9110,8813,323.01328458,9110,8814,323.07483685,9110,8815,0.99984,9201
-19872,"Rectified Skew Orthomorphic Malaya Grid (metres)",9812,8806,804670.24,9001,8807,0,9001,8811,4,9110,8812,102.15,9110,8813,323.01328458,9110,8814,323.07483685,9110,8815,0.99984,9201
-19873,Noumea Lambert,9802,8821,-22.16108903,9110,8822,166.26327327,9110,8823,-22.14408903,9110,8824,-22.17408903,9110,8826,0.66,9001,8827,1.02,9001,,,
-19874,Noumea Lambert 2,9802,8821,-22.1611,9110,8822,166.2633,9110,8823,-22.1441,9110,8824,-22.1741,9110,8826,8.313,9001,8827,-2.354,9001,,,
-19875,Ontario MNR Lambert,9802,8821,0,9102,8822,-85,9102,8823,44.5,9102,8824,53.5,9102,8826,930000,9001,8827,6430000,9001,,,
-19876,ST74,9807,8801,0,9110,8802,18.0328044,9110,8805,0.99999425,9201,8806,100178.1808,9001,8807,-6500614.7836,9001,,,,,,
-19877,Faroe Lambert fk89,9826,8801,62,9102,8802,-9,9102,8805,1,9201,8806,700000,9001,8807,700000,9001,,,,,,
-19878,Vanua Levu Grid,9833,8801,-16.15,9110,8802,179.2,9110,8806,1251331.8,9098,8807,1662888.5,9098,,,,,,,,,
-19879,Viti Levu Grid,9806,8801,-18,9102,8802,178,9102,8806,544000,9098,8807,704000,9098,,,,,,,,,
-19880,Fiji Map Grid,9807,8801,-17,9110,8802,178.45,9110,8805,0.99985,9001,8806,2000000,9001,8807,4000000,9001,,,,,,
-19881,"Alberta 10-degree TM (Forest)",9807,8801,0,9102,8802,-115,9102,8805,0.9992,9201,8806,500000,9001,8807,0,9001,,,,,,
-19882,"Alberta 10-degree TM (Resource)",9807,8801,0,9102,8802,-115,9102,8805,0.9992,9201,8806,0,9001,8807,0,9001,,,,,,
-19883,World Mercator,9804,8801,0,9102,8802,0,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19884,Caspian Sea Mercator,9805,8802,51,9102,8806,0,9001,8807,0,9001,8823,42,9102,,,,,,,,,
-19885,Kelantan Grid,9806,8801,5.582115717,9110,8802,102.174287001,9110,8806,13227.851,9001,8807,8739.894,9001,,,,,,,,,
-19886,Perak Grid,9806,8801,4.513262688,9110,8802,100.485547811,9110,8806,-1.769,9001,8807,133454.779,9001,,,,,,,,,
-19887,Kedah and Perlis Grid,9806,8801,5.575282177,9110,8802,100.3810936,9110,8806,0,9001,8807,0,9001,,,,,,,,,
-19888,Pinang Grid,9806,8801,5.251746315,9110,8802,100.203975707,9110,8806,-23.414,9001,8807,62.283,9001,,,,,,,,,
-19889,Terengganu Grid,9806,8801,4.583462672,9110,8802,103.041299225,9110,8806,19594.245,9001,8807,3371.895,9001,,,,,,,,,
-19890,Selangor Grid,9806,8801,3.410473658,9110,8802,101.232078849,9110,8806,-34836.161,9001,8807,56464.049,9001,,,,,,,,,
-19891,Pahang Grid,9806,8801,3.460979712,9110,8802,102.220587634,9110,8806,-7368.228,9001,8807,6485.858,9001,,,,,,,,,
-19892,Sembilan and Melaka Grid,9806,8801,2.405645149,9110,8802,101.582965815,9110,8806,3673.785,9001,8807,-4240.573,9001,,,,,,,,,
-19893,Johor Grid,9806,8801,2.071804708,9110,8802,103.254057045,9110,8806,-14810.562,9001,8807,8758.32,9001,,,,,,,,,
-19894,East Malaysia BRSO,9812,8806,0,9001,8807,0,9001,8811,4,9110,8812,115,9110,8813,53.185691582,9110,8814,53.07483685,9110,8815,0.99984,9201
-19895,Peninsular RSO,9812,8806,804671,9001,8807,0,9001,8811,4,9110,8812,102.15,9110,8813,323.013286728,9110,8814,323.07483685,9110,8815,0.99984,9201
-19896,Hong Kong 1963 Grid,9806,8801,22.184368,9110,8802,114.10428,9110,8806,132033.92,9005,8807,62565.96,9005,,,,,,,,,
-19897,Statistics Canada Lambert,9802,8821,63.390675,9102,8822,-91.52,9110,8823,49,9102,8824,77,9102,8826,6200000,9001,8827,3000000,9001,,,
-19898,Pacific Disaster Center Mercator,9804,8801,0,9102,8802,-150,9102,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19899,Mauritius Grid,9801,8801,-20.114225,9110,8802,57.311858,9110,8805,1,9201,8806,1000000,9001,8807,1000000,9001,,,,,,
-19900,Bahrain State Grid,9807,8801,0,9102,8802,51,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-19901,Belge Lambert 50,9802,8821,90,9110,8822,0,9110,8823,49.5,9110,8824,51.1,9110,8826,150000,9001,8827,5400000,9001,,,
-19902,Belge Lambert 72,9803,8821,90,9110,8822,4.2124983,9110,8823,49.5,9110,8824,51.1,9110,8826,150000.01256,9001,8827,5400088.4378,9001,,,
-19903,Nord de Guerre,9801,8801,55,9105,8802,6,9105,8805,0.99950908,9201,8806,500000,9001,8807,300000,9001,,,,,,
-19904,Ghana Metre Grid,9807,8801,4.4,9110,8802,-1,9110,8805,0.99975,9201,8806,274319.51,9001,8807,0,9001,,,,,,
-19905,Netherlands East Indies Equatorial Zone,9804,8801,0,9102,8802,110,9102,8805,0.997,9201,8806,3900000,9001,8807,900000,9001,,,,,,
-19906,Iraq zone,9801,8801,32.3,9110,8802,45,9110,8805,0.9987864078,9201,8806,1500000,9001,8807,1166200,9001,,,,,,
-19907,Iraq National Grid,9807,8801,29.0134566,9110,8802,46.3,9110,8805,0.9994,9201,8806,800000,9001,8807,0,9001,,,,,,
-19908,Irish National Grid,9807,8801,53.3,9110,8802,-8,9110,8805,1.000035,9201,8806,200000,9001,8807,250000,9001,,,,,,
-19909,"Jamaica (Old Grid)",9801,8801,18,9102,8802,-77,9102,8805,1,9201,8806,550000,9005,8807,400000,9005,,,,,,
-19910,Jamaica National Grid,9801,8801,18,9102,8802,-77,9102,8805,1,9201,8806,250000,9001,8807,150000,9001,,,,,,
-19911,Laborde Grid approximation,9815,8811,-21,9105,8812,49,9105,8813,21,9105,8814,21,9105,8815,0.9995,9201,8816,400000,9001,8817,800000,9001
-19913,RD Old,9809,8801,52.0922178,9110,8802,5.23155,9110,8805,0.9999079,9201,8806,0,9001,8807,0,9001,,,,,,
-19914,RD New,9809,8801,52.0922178,9110,8802,5.23155,9110,8805,0.9999079,9201,8806,155000,9001,8807,463000,9001,,,,,,
-19915,Aden Zone,9801,8801,15,9102,8802,45,9102,8805,0.999365678,9201,8806,1500000,9001,8807,1000000,9001,,,,,,
-19916,British National Grid,9807,8801,49,9102,8802,-2,9102,8805,0.9996012717,9201,8806,400000,9001,8807,-100000,9001,,,,,,
-19917,New Zealand Map Grid,9811,8801,-41,9102,8802,173,9102,8806,2510000,9001,8807,6023150,9001,,,,,,,,,
-19919,Qatar National Grid,9807,8801,24.27,9110,8802,51.13,9110,8805,0.99999,9201,8806,200000,9001,8807,300000,9001,,,,,,
-19920,Singapore Grid,9806,8801,1.1715528,9110,8802,103.5110808,9110,8806,30000,9001,8807,30000,9001,,,,,,,,,
-19921,Spain,9801,8801,40,9102,8802,0,9102,8805,0.9988085293,9201,8806,600000,9001,8807,600000,9001,,,,,,
-19922,Swiss Oblique Mercator 1903M,9815,8811,46.570866,9110,8812,7.26225,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,600000,9001,8817,200000,9001
-19923,Swiss Oblique Mercator 1903C,9815,8811,46.570866,9110,8812,0,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,0,9001,8817,0,9001
-19924,Tobago Grid,9806,8801,11.1507843,9110,8802,-60.4109632,9110,8806,187500,9039,8807,180000,9039,,,,,,,,,
-19925,Trinidad Grid,9806,8801,10.263,9110,8802,-61.2,9110,8806,430000,9039,8807,325000,9039,,,,,,,,,
-19926,Stereo 70,9809,8801,46,9102,8802,25,9102,8805,0.99975,9201,8806,500000,9001,8807,500000,9001,,,,,,
-19927,Stereo 33,9809,8801,45.54,9110,8802,25.23328772,9110,8805,0.9996667,9201,8806,500000,9001,8807,500000,9001,,,,,,
-19928,Kuwait TM,9807,8801,0,9102,8802,48,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-19929,Sweden zone 2.5 gon V,9807,8801,0,9110,8802,15.48298,9110,8805,1,9201,8806,1500000,9001,8807,0,9001,,,,,,
-19930,Greek Grid,9807,8801,0,9102,8802,24,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-19931,Egyseges Orszagos Vetuleti,9815,8811,47.08398174,9110,8812,19.02548584,9110,8813,90,9110,8814,90,9110,8815,0.99993,9201,8816,650000,9001,8817,200000,9001
-19933,"Prince Edward Island Stereographic (ATS77)",9809,8801,47.15,9110,8802,-63,9110,8805,0.999912,9201,8806,700000,9001,8807,400000,9001,,,,,,
-19934,Lithuania 1994,9807,8801,0,9102,8802,24,9102,8805,0.9998,9201,8806,500000,9001,8807,0,9001,,,,,,
-19935,Rectified Skew Orthomorphic Malaya Grid,9812,8806,40000,9062,8807,0,9062,8811,4,9110,8812,102.15,9110,8813,323.01328458,9110,8814,323.07483685,9110,8815,0.99984,9201
-19936,Portuguese National Grid,9807,8801,39.4,9110,8802,1,9110,8805,1,9201,8806,200000,9001,8807,300000,9001,,,,,,
-19937,Tunisia Mining Grid,9816,8821,38.81973,9105,8822,7.83445,9105,8826,270,9036,8827,582,9036,,,,,,,,,
-19938,Estonian National Grid,9802,8821,57.310319415,9110,8822,24,9110,8823,59.2,9110,8824,58,9110,8826,500000,9001,8827,6375000,9001,,,
-19939,TM Baltic 93,9807,8801,0,9102,8802,24,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-19940,Levant Zone,9817,8801,34.39,9110,8802,37.21,9110,8805,0.9996256,9201,8806,300000,9001,8807,300000,9001,,,,,,
-19941,Brazil Polyconic,9818,8801,0,9102,8802,-54,9102,8806,5000000,9001,8807,10000000,9001,,,,,,,,,
-19942,British West Indies Grid,9807,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-19943,Barbados National Grid,9807,8801,13.1035,9110,8802,-59.3335,9110,8805,0.9999986,9201,8806,30000,9001,8807,75000,9001,,,,,,
-19944,Quebec Lambert Projection,9802,8821,44,9110,8822,-68.3,9110,8823,60,9110,8824,46,9110,8826,0,9001,8827,0,9001,,,
-19945,"New Brunswick Stereographic (ATS77)",9809,8801,46.3,9110,8802,-66.3,9110,8805,0.999912,9201,8806,300000,9001,8807,800000,9001,,,,,,
-19946,"New Brunswick Stereographic (NAD83)",9809,8801,46.3,9110,8802,-66.3,9110,8805,0.999912,9201,8806,2500000,9001,8807,7500000,9001,,,,,,
-19947,Austria Lambert,9802,8821,47.3,9110,8822,13.2,9110,8823,49,9110,8824,46,9110,8826,400000,9001,8827,400000,9001,,,
-19948,Syria Lambert,9801,8801,34.39,9110,8802,37.21,9110,8805,0.9996256,9201,8806,300000,9001,8807,300000,9001,,,,,,
-19949,Levant Stereographic,9809,8801,38,9105,8802,43.5,9105,8805,0.9995341,9201,8806,0,9001,8807,0,9001,,,,,,
-19950,Swiss Oblique Mercator 1995,9815,8811,46.570866,9110,8812,7.26225,9110,8813,90,9110,8814,90,9110,8815,1,9201,8816,2600000,9001,8817,1200000,9001
-19951,Nakhl e Taqi Oblique Mercator,9815,8811,27.31077837,9110,8812,52.3612741,9110,8813,0.34179803,9110,8814,0.34179803,9110,8815,0.999895934,9201,8816,658377.437,9001,8817,3044969.194,9001
-19952,Krovak,9819,8806,0,9001,8807,0,9001,8811,49.3,9110,8813,30.1717303,9110,8818,78.3,9110,8819,0.9999,9201,8833,42.3,9110
-19953,Qatar Grid,9806,8801,25.22565,9110,8802,50.4541,9110,8806,100000,9001,8807,100000,9001,,,,,,,,,
-19954,Suriname Old TM,9807,8801,0,9110,8802,-55.41,9110,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
-19955,Suriname TM,9807,8801,0,9110,8802,-55.41,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-19956,"Rectified Skew Orthomorphic Borneo Grid (chains)",9815,8811,4,9110,8812,115,9110,8813,53.18569537,9110,8814,53.07483685,9110,8815,0.99984,9201,8816,29352.4763,9042,8817,22014.3572,9042
-19957,"Rectified Skew Orthomorphic Borneo Grid (feet)",9815,8811,4,9110,8812,115,9110,8813,53.18569537,9110,8814,53.07483685,9110,8815,0.99984,9201,8816,1937263.44,9041,8817,1452947.58,9041
-19958,"Rectified Skew Orthomorphic Borneo Grid (metres)",9815,8811,4,9110,8812,115,9110,8813,53.18569537,9110,8814,53.07483685,9110,8815,0.99984,9201,8816,590476.87,9001,8817,442857.65,9001
-19959,Ghana National Grid,9807,8801,4.4,9110,8802,-1,9110,8805,0.99975,9201,8806,900000,9094,8807,0,9094,,,,,,
-19960,"Prince Edward Isl. Stereographic (NAD83)",9809,8801,47.15,9110,8802,-63,9110,8805,0.999912,9201,8806,400000,9001,8807,800000,9001,,,,,,
-19961,Belgian Lambert 72,9802,8821,90,9110,8822,4.2202952,9110,8823,51.100000204,9110,8824,49.500000204,9110,8826,150000.013,9001,8827,5400088.438,9001,,,
-19962,Irish Transverse Mercator,9807,8801,53.3,9110,8802,-8,9110,8805,0.99982,9201,8806,600000,9001,8807,750000,9001,,,,,,
-19963,Sierra Leone New Colony Grid,9807,8801,6.4,9110,8802,-12,9110,8805,1,9201,8806,500000,9094,8807,0,9094,,,,,,
-19964,New War Office Sierra Leone Grid,9807,8801,6.4,9110,8802,-12,9110,8805,1,9201,8806,800000,9094,8807,600000,9094,,,,,,
-19965,US National Atlas Equal Area,9821,8806,0,9001,8807,0,9001,8828,45,9102,8829,-100,9102,,,,,,,,,
-19966,Luxembourg Gauss,9807,8801,49.5,9110,8802,6.1,9110,8805,1,9201,8806,80000,9001,8807,100000,9001,,,,,,
-19967,Slovenia Grid,9807,8801,0,9110,8802,15,9110,8805,0.9999,9201,8806,500000,9001,8807,0,9001,,,,,,
-19968,"World Equidistant Cylindrical (Sphere)",9823,8801,0,9102,8802,0,9102,8806,0,9001,8807,0,9001,,,,,,,,,
-19969,Portuguese Grid,9807,8801,39.4,9110,8802,1,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19971,New Zealand Transverse Mercator 2000,9807,8801,0,9102,8802,173,9102,8805,0.9996,9201,8806,1600000,9001,8807,10000000,9001,,,,,,
-19972,Irish Grid,9807,8801,53.3,9110,8802,-8,9110,8805,1.000035,9201,8806,200000,9001,8807,250000,9001,,,,,,
-19973,Irish National Grid,9807,8801,53.3,9110,8802,-8,9110,8805,1,9201,8806,200000,9001,8807,250000,9001,,,,,,
-19974,Modified Portuguese Grid,9807,8801,39.4,9110,8802,-8.0754862,9110,8805,1,9201,8806,180.598,9001,8807,-86.99,9001,,,,,,
-19975,"Trinidad Grid (Clarke's feet)",9806,8801,10.263,9110,8802,-61.2,9110,8806,283800,9005,8807,214500,9005,,,,,,,,,
-19976,ICN Regional,9802,8821,6,9102,8822,-66,9102,8823,9,9102,8824,3,9102,8826,1000000,9001,8827,1000000,9001,,,
-19977,Aramco Lambert,9802,8821,25.0522236,9110,8822,48,9102,8823,17,9102,8824,33,9102,8826,0,9001,8827,0,9001,,,
-19978,Hong Kong 1980 Grid,9807,8801,22.184368,9110,8802,114.10428,9110,8805,1,9201,8806,836694.05,9001,8807,819069.8,9001,,,,,,
-19979,Portugal Bonne,9828,8801,39.4,9110,8802,1,9110,8806,0,9001,8807,0,9001,,,,,,,,,
-19981,Lambert New Caledonia,9802,8821,-21.3,9110,8822,166,9110,8823,-20.4,9110,8824,-22.2,9110,8826,400000,9001,8827,300000,9001,,,
-19982,TM Reunion,9807,8801,-21.07,9110,8802,55.32,9110,8805,1,9201,8806,50000,9001,8807,160000,9001,,,,,,
-19983,Terre Adelie Polar Stereographic,9830,8826,300000,9001,8827,200000,9001,8832,-67,9102,8833,140,9102,,,,,,,,,
-19984,British Columbia Albers,9822,8821,45,9102,8822,-126,9102,8823,50,9110,8824,58.3,9110,8826,1000000,9001,8827,0,9001,,,
-19985,Europe Conformal 2001,9802,8821,52,9102,8822,10,9102,8823,35,9102,8824,65,9102,8826,4000000,9001,8827,2800000,9001,,,
-19986,Europe Equal Area 2001,9820,8801,52,9102,8802,10,9102,8806,4321000,9001,8807,3210000,9001,,,,,,,,,
-19987,Iceland Lambert 1900,9826,8801,65,9110,8802,-19.011965,9110,8805,1,9201,8806,0,9001,8807,0,9001,,,,,,
-19988,Iceland Lambert 1955,9826,8801,65,9102,8802,-18,9102,8805,1,9201,8806,500000,9001,8807,500000,9001,,,,,,
-19989,Iceland Lambert 1993,9802,8821,65,9110,8822,-19,9110,8823,64.15,9110,8824,65.45,9110,8826,500000,9001,8827,500000,9001,,,
-19990,Latvian Transverse Mercator,9807,8801,0,9102,8802,24,9102,8805,0.9996,9201,8806,500000,9001,8807,-6000000,9001,,,,,,
-19991,Jan Mayen Grid,9807,8801,0,9110,8802,-8.3,9110,8805,1,9201,8806,50000,9001,8807,-7800000,9001,,,,,,
-19992,Antarctic Polar Stereographic,9829,8806,0,9001,8807,0,9001,8832,-71,9102,8833,0,9102,,,,,,,,,
-19993,Australian Antarctic Polar Stereographic,9829,8806,6000000,9001,8807,6000000,9001,8832,-71,9102,8833,70,9102,,,,,,,,,
-19994,Australian Antarctic Lambert,9802,8821,-50,9110,8822,70,9110,8823,-68.3,9110,8824,-74.3,9110,8826,6000000,9001,8827,6000000,9001,,,
-19995,Jordan Transverse Mercator,9807,8801,0,9102,8802,37,9102,8805,0.9998,9201,8806,500000,9001,8807,-3000000,9001,,,,,,
-19996,Soldner Berlin,9806,8801,52.25071338,9110,8802,13.37379332,9110,8806,40000,9001,8807,10000,9001,,,,,,,,,
-19997,Kuwait Transverse Mercator,9807,8801,0,9102,8802,48,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-19998,Guernsey Grid,9807,8801,49.3,9110,8802,-2.25,9110,8805,0.999997,9201,8806,47000,9001,8807,50000,9001,,,,,,
-19999,Jersey Transverse Mercator,9807,8801,49.225,9102,8802,-2.135,9102,8805,0.9999999,9201,8806,40000,9001,8807,70000,9001,,,,,,
Deleted: grass/trunk/lib/proj/stateplane.csv
--- grass/trunk/lib/proj/stateplane.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/stateplane.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,259 +0,0 @@
-"ID","STATE","ZONE","PROJ_METHOD","DATUM","USGS_CODE","EPSG_PCS_CODE"
-101,ALABAMA,EAST,1,NAD83,101,26929
-102,ALABAMA,WEST,1,NAD83,102,26930
-201,ARIZONA,EAST,1,NAD83,201,26948
-202,ARIZONA,CENTRAL,1,NAD83,202,26949
-203,ARIZONA,WEST,1,NAD83,203,26950
-301,ARKANSAS,NORTH,2,NAD83,301,26951
-302,ARKANSAS,SOUTH,2,NAD83,302,26952
-401,CALIFORNIA,I,2,NAD83,401,26941
-402,CALIFORNIA,II,2,NAD83,402,26942
-403,CALIFORNIA,III,2,NAD83,403,26943
-404,CALIFORNIA,IV,2,NAD83,404,26944
-405,CALIFORNIA,V,2,NAD83,405,26945
-406,CALIFORNIA,VI,2,NAD83,406,26946
-501,COLORADO,NORTH,2,NAD83,501,26953
-502,COLORADO,CENTRAL,2,NAD83,502,26954
-503,COLORADO,SOUTH,2,NAD83,503,26955
-600,CONNECTICUT,,2,NAD83,600,26956
-700,DELAWARE,,1,NAD83,700,26957
-901,FLORIDA,EAST,1,NAD83,901,26958
-902,FLORIDA,WEST,1,NAD83,902,26959
-903,FLORIDA,NORTH,2,NAD83,903,26960
-1001,GEORGIA,EAST,1,NAD83,1001,26966
-1002,GEORGIA,WEST,1,NAD83,1002,26967
-1101,IDAHO,EAST,1,NAD83,1101,26968
-1102,IDAHO,CENTRAL,1,NAD83,1102,26969
-1103,IDAHO,WEST,1,NAD83,1103,26970
-1201,ILLINOIS,EAST,1,NAD83,1201,26971
-1202,ILLINOIS,WEST,1,NAD83,1202,26972
-1301,INDIANA,EAST,1,NAD83,1301,26973
-1302,INDIANA,WEST,1,NAD83,1302,26974
-1401,IOWA,NORTH,2,NAD83,1401,26975
-1402,IOWA,SOUTH,2,NAD83,1402,26976
-1501,KANSAS,NORTH,2,NAD83,1501,26977
-1502,KANSAS,SOUTH,2,NAD83,1502,26978
-1600,KENTUCKY,SINGLE ZONE,2,NAD83,1600,3088
-1601,KENTUCKY,NORTH,2,NAD83,1601,2205
-1602,KENTUCKY,SOUTH,2,NAD83,1602,26980
-1701,LOUISIANA,NORTH,2,NAD83,1701,26981
-1702,LOUISIANA,SOUTH,2,NAD83,1702,26982
-1703,LOUISIANA,OFFSHORE,2,NAD83,1703,
-1801,MAINE,EAST,1,NAD83,1801,26983
-1802,MAINE,WEST,1,NAD83,1802,26984
-1900,MARYLAND,,2,NAD83,1900,26985
-2001,MASSACHUSETTS,MAINLAND,2,NAD83,2001,26986
-2002,MASSACHUSETTS,ISLAND,2,NAD83,2002,26987
-2111,MICHIGAN,NORTH,2,NAD83,2111,26988
-2112,MICHIGAN,CENTRAL,2,NAD83,2112,26989
-2113,MICHIGAN,SOUTH,2,NAD83,2113,26990
-2201,MINNESOTA,NORTH,2,NAD83,2201,26991
-2202,MINNESOTA,CENTRAL,2,NAD83,2202,26992
-2203,MINNESOTA,SOUTH,2,NAD83,2203,26993
-2301,MISSISSIPPI,EAST,1,NAD83,2301,26994
-2302,MISSISSIPPI,WEST,1,NAD83,2302,26995
-2401,MISSOURI,EAST,1,NAD83,2401,26996
-2402,MISSOURI,CENTRAL,1,NAD83,2402,26997
-2403,MISSOURI,WEST,1,NAD83,2403,26998
-2500,MONTANA,,2,NAD83,2500,32100
-2600,NEBRASKA,,2,NAD83,2600,32104
-2701,NEVADA,EAST,1,NAD83,2701,32107
-2702,NEVADA,CENTRAL,1,NAD83,2702,32108
-2703,NEVADA,WEST,1,NAD83,2703,32109
-2800,"NEW HAMPSHIRE",,1,NAD83,2800,32110
-2900,"NEW JERSEY",,1,NAD83,2900,32111
-3001,"NEW MEXICO",EAST,1,NAD83,3001,32112
-3002,"NEW MEXICO",CENTRAL,1,NAD83,3002,32113
-3003,"NEW MEXICO",WEST,1,NAD83,3003,32114
-3101,"NEW YORK",EAST,1,NAD83,3101,32115
-3102,"NEW YORK",CENTRAL,1,NAD83,3102,32116
-3103,"NEW YORK",WEST,1,NAD83,3103,32117
-3104,"NEW YORK","LONG ISLAND",2,NAD83,3104,32118
-3200,"NORTH CAROLINA",,2,NAD83,3200,32119
-3301,"NORTH DAKOTA",NORTH,2,NAD83,3301,32120
-3302,"NORTH DAKOTA",SOUTH,2,NAD83,3302,32121
-3401,OHIO,NORTH,2,NAD83,3401,32122
-3402,OHIO,SOUTH,2,NAD83,3402,32123
-3501,OKLAHOMA,NORTH,2,NAD83,3501,32124
-3502,OKLAHOMA,SOUTH,2,NAD83,3502,32125
-3601,OREGON,NORTH,2,NAD83,3601,32126
-3602,OREGON,SOUTH,2,NAD83,3602,32127
-3701,PENNSYLVANIA,NORTH,2,NAD83,3701,32128
-3702,PENNSYLVANIA,SOUTH,2,NAD83,3702,32129
-3800,"RHODE ISLAND",,1,NAD83,3800,32130
-3900,"SOUTH CAROLINA",,2,NAD83,3900,32133
-4001,"SOUTH DAKOTA",NORTH,2,NAD83,4001,32134
-4002,"SOUTH DAKOTA",SOUTH,2,NAD83,4002,32135
-4100,TENNESSEE,,2,NAD83,4100,32136
-4201,TEXAS,NORTH,2,NAD83,4201,32137
-4202,TEXAS,"NORTH CENTRAL",2,NAD83,4202,32138
-4203,TEXAS,CENTRAL,2,NAD83,4203,32139
-4204,TEXAS,"SOUTH CENTRAL",2,NAD83,4204,32140
-4205,TEXAS,SOUTH,2,NAD83,4205,32141
-4301,UTAH,NORTH,2,NAD83,4301,32142
-4302,UTAH,CENTRAL,2,NAD83,4302,32143
-4303,UTAH,SOUTH,2,NAD83,4303,32144
-4400,VERMONT,,1,NAD83,4400,32145
-4501,VIRGINIA,NORTH,2,NAD83,4501,32146
-4502,VIRGINIA,SOUTH,2,NAD83,4502,32147
-4601,WASHINGTON,NORTH,2,NAD83,4601,32148
-4602,WASHINGTON,SOUTH,2,NAD83,4602,32149
-4701,"WEST VIRGINIA",NORTH,2,NAD83,4701,32150
-4702,"WEST VIRGINIA",SOUTH,2,NAD83,4702,32151
-4801,WISCONSIN,NORTH,2,NAD83,4801,32152
-4802,WISCONSIN,CENTRAL,2,NAD83,4802,32153
-4803,WISCONSIN,SOUTH,2,NAD83,4803,32154
-4901,WYOMING,EAST,1,NAD83,4901,32155
-4902,WYOMING,"EAST CENTRAL",1,NAD83,4902,32156
-4903,WYOMING,"WEST CENTRAL",1,NAD83,4903,32157
-4904,WYOMING,WEST,1,NAD83,4904,32158
-5001,ALASKA,"ZONE NO. 1",4,NAD83,5001,26931
-5002,ALASKA,"ZONE NO. 2",1,NAD83,5002,26932
-5003,ALASKA,"ZONE NO. 3",1,NAD83,5003,26933
-5004,ALASKA,"ZONE NO. 4",1,NAD83,5004,26934
-5005,ALASKA,"ZONE NO. 5",1,NAD83,5005,26935
-5006,ALASKA,"ZONE NO. 6",1,NAD83,5006,26936
-5007,ALASKA,"ZONE NO. 7",1,NAD83,5007,26937
-5008,ALASKA,"ZONE NO. 8",1,NAD83,5008,26938
-5009,ALASKA,"ZONE NO. 9",1,NAD83,5009,26939
-5010,ALASKA,"ZONE NO. 10",2,NAD83,5010,26940
-5101,HAWAII,1,1,NAD83,5101,26961
-5102,HAWAII,2,1,NAD83,5102,26962
-5103,HAWAII,3,1,NAD83,5103,26963
-5104,HAWAII,4,1,NAD83,5104,26964
-5105,HAWAII,5,1,NAD83,5105,26965
-5200,"PUERTO RICO AND","VIRGIN ISLANDS",2,NAD83,5200,32161
-10101,ALABAMA,EAST,1,NAD27,101,26729
-10102,ALABAMA,WEST,1,NAD27,102,26730
-10201,ARIZONA,EAST,1,NAD27,201,26748
-10202,ARIZONA,CENTRAL,1,NAD27,202,26749
-10203,ARIZONA,WEST,1,NAD27,203,26750
-10301,ARKANSAS,NORTH,2,NAD27,301,26751
-10302,ARKANSAS,SOUTH,2,NAD27,302,26752
-10401,CALIFORNIA,I,2,NAD27,401,26741
-10402,CALIFORNIA,II,2,NAD27,402,26742
-10403,CALIFORNIA,III,2,NAD27,403,26743
-10404,CALIFORNIA,IV,2,NAD27,404,26744
-10405,CALIFORNIA,V,2,NAD27,405,26745
-10406,CALIFORNIA,VI,2,NAD27,406,26746
-10407,CALIFORNIA,VII,2,NAD27,407,26799
-10501,COLORADO,NORTH,2,NAD27,501,26753
-10502,COLORADO,CENTRAL,2,NAD27,502,26754
-10503,COLORADO,SOUTH,2,NAD27,503,26755
-10600,CONNECTICUT,,2,NAD27,600,26756
-10700,DELAWARE,,1,NAD27,700,26757
-10901,FLORIDA,EAST,1,NAD27,901,26758
-10902,FLORIDA,WEST,1,NAD27,902,26759
-10903,FLORIDA,NORTH,2,NAD27,903,26760
-11001,GEORGIA,EAST,1,NAD27,1001,26766
-11002,GEORGIA,WEST,1,NAD27,1002,26767
-11101,IDAHO,EAST,1,NAD27,1101,26768
-11102,IDAHO,CENTRAL,1,NAD27,1102,26769
-11103,IDAHO,WEST,1,NAD27,1103,26770
-11201,ILLINOIS,EAST,1,NAD27,1201,26771
-11202,ILLINOIS,WEST,1,NAD27,1202,26772
-11301,INDIANA,EAST,1,NAD27,1301,26773
-11302,INDIANA,WEST,1,NAD27,1302,26774
-11401,IOWA,NORTH,2,NAD27,1401,26775
-11402,IOWA,SOUTH,2,NAD27,1402,26776
-11501,KANSAS,NORTH,2,NAD27,1501,26777
-11502,KANSAS,SOUTH,2,NAD27,1502,26778
-11601,KENTUCKY,NORTH,2,NAD27,1601,26779
-11602,KENTUCKY,SOUTH,2,NAD27,1602,26780
-11701,LOUISIANA,NORTH,2,NAD27,1701,26781
-11702,LOUISIANA,SOUTH,2,NAD27,1702,26782
-11703,LOUISIANA,OFFSHORE,2,NAD27,1703,
-11801,MAINE,EAST,1,NAD27,1801,26783
-11802,MAINE,WEST,1,NAD27,1802,26784
-11900,MARYLAND,,2,NAD27,1900,26785
-12001,MASSACHUSETTS,MAINLAND,2,NAD27,2001,26786
-12002,MASSACHUSETTS,ISLAND,2,NAD27,2002,26787
-12101,MICHIGAN,EAST,1,NAD27,2101,26801
-12102,MICHIGAN,"CENTRAL/M",1,NAD27,2102,26802
-12103,MICHIGAN,WEST,1,NAD27,2103,26803
-12111,MICHIGAN,NORTH,2,NAD27,2111,26811
-12112,MICHIGAN,"CENTRAL/L",2,NAD27,2112,26812
-12113,MICHIGAN,SOUTH,2,NAD27,2113,26813
-12201,MINNESOTA,NORTH,2,NAD27,2201,26791
-12202,MINNESOTA,CENTRAL,2,NAD27,2202,26792
-12203,MINNESOTA,SOUTH,2,NAD27,2203,26793
-12301,MISSISSIPPI,EAST,1,NAD27,2301,26794
-12302,MISSISSIPPI,WEST,1,NAD27,2302,26795
-12401,MISSOURI,EAST,1,NAD27,2401,26796
-12402,MISSOURI,CENTRAL,1,NAD27,2402,26797
-12403,MISSOURI,WEST,1,NAD27,2403,26798
-12501,MONTANA,NORTH,2,NAD27,2501,32001
-12502,MONTANA,CENTRAL,2,NAD27,2502,32002
-12503,MONTANA,SOUTH,2,NAD27,2503,32003
-12601,NEBRASKA,NORTH,2,NAD27,2601,32005
-12602,NEBRASKA,SOUTH,2,NAD27,2602,32006
-12701,NEVADA,EAST,1,NAD27,2701,32007
-12702,NEVADA,CENTRAL,1,NAD27,2702,32008
-12703,NEVADA,WEST,1,NAD27,2703,32009
-12800,"NEW HAMPSHIRE",,1,NAD27,2800,32010
-12900,"NEW JERSEY",,1,NAD27,2900,32011
-13001,"NEW MEXICO",EAST,1,NAD27,3001,32012
-13002,"NEW MEXICO",CENTRAL,1,NAD27,3002,32013
-13003,"NEW MEXICO",WEST,1,NAD27,3003,32014
-13101,"NEW YORK",EAST,1,NAD27,3101,32015
-13102,"NEW YORK",CENTRAL,1,NAD27,3102,32016
-13103,"NEW YORK",WEST,1,NAD27,3103,32017
-13104,"NEW YORK","LONG ISLAND",2,NAD27,3104,32018
-13200,"NORTH CAROLINA",,2,NAD27,3200,32019
-13301,"NORTH DAKOTA",NORTH,2,NAD27,3301,32020
-13302,"NORTH DAKOTA",SOUTH,2,NAD27,3302,32021
-13401,OHIO,NORTH,2,NAD27,3401,32022
-13402,OHIO,SOUTH,2,NAD27,3402,32023
-13501,OKLAHOMA,NORTH,2,NAD27,3501,32024
-13502,OKLAHOMA,SOUTH,2,NAD27,3502,32025
-13601,OREGON,NORTH,2,NAD27,3601,32026
-13602,OREGON,SOUTH,2,NAD27,3602,32027
-13701,PENNSYLVANIA,NORTH,2,NAD27,3701,32028
-13702,PENNSYLVANIA,SOUTH,2,NAD27,3702,32029
-13800,"RHODE ISLAND",,1,NAD27,3800,32030
-13901,"SOUTH CAROLINA",NORTH,2,NAD27,3901,32031
-13902,"SOUTH CAROLINA",SOUTH,2,NAD27,3902,32033
-14001,"SOUTH DAKOTA",NORTH,2,NAD27,4001,32034
-14002,"SOUTH DAKOTA",SOUTH,2,NAD27,4002,32035
-14100,TENNESSEE,,2,NAD27,4100,2204
-14201,TEXAS,NORTH,2,NAD27,4201,32037
-14202,TEXAS,"NORTH CENTRAL",2,NAD27,4202,32038
-14203,TEXAS,CENTRAL,2,NAD27,4203,32039
-14204,TEXAS,"SOUTH CENTRAL",2,NAD27,4204,32040
-14205,TEXAS,SOUTH,2,NAD27,4205,32041
-14301,UTAH,NORTH,2,NAD27,4301,32042
-14302,UTAH,CENTRAL,2,NAD27,4302,32043
-14303,UTAH,SOUTH,2,NAD27,4303,32044
-14400,VERMONT,,1,NAD27,4400,32045
-14501,VIRGINIA,NORTH,2,NAD27,4501,32046
-14502,VIRGINIA,SOUTH,2,NAD27,4502,32047
-14601,WASHINGTON,NORTH,2,NAD27,4601,32048
-14602,WASHINGTON,SOUTH,2,NAD27,4602,32049
-14701,"WEST VIRGINIA",NORTH,2,NAD27,4701,32050
-14702,"WEST VIRGINIA",SOUTH,2,NAD27,4702,32051
-14801,WISCONSIN,NORTH,2,NAD27,4801,32052
-14802,WISCONSIN,CENTRAL,2,NAD27,4802,32053
-14803,WISCONSIN,SOUTH,2,NAD27,4803,32054
-14901,WYOMING,EAST,1,NAD27,4901,32055
-14902,WYOMING,"EAST CENTRAL",1,NAD27,4902,32056
-14903,WYOMING,"WEST CENTRAL",1,NAD27,4903,32057
-14904,WYOMING,WEST,1,NAD27,4904,32058
-15001,ALASKA,"ZONE NO. 1",4,NAD27,5001,26731
-15002,ALASKA,"ZONE NO. 2",1,NAD27,5002,26732
-15003,ALASKA,"ZONE NO. 3",1,NAD27,5003,26733
-15004,ALASKA,"ZONE NO. 4",1,NAD27,5004,26734
-15005,ALASKA,"ZONE NO. 5",1,NAD27,5005,26735
-15006,ALASKA,"ZONE NO. 6",1,NAD27,5006,26736
-15007,ALASKA,"ZONE NO. 7",1,NAD27,5007,26737
-15008,ALASKA,"ZONE NO. 8",1,NAD27,5008,26738
-15009,ALASKA,"ZONE NO. 9",1,NAD27,5009,26739
-15010,ALASKA,"ZONE NO. 10",2,NAD27,5010,26740
-15101,HAWAII,1,1,NAD27,5101,3561
-15102,HAWAII,2,1,NAD27,5102,3562
-15103,HAWAII,3,1,NAD27,5103,3563
-15104,HAWAII,4,1,NAD27,5104,3564
-15105,HAWAII,5,1,NAD27,5105,3565
-15201,"PUERTO RICO AND VIRGIN ISLANDS",,2,NAD27,5201,3991
-15202,"VIRGIN ISLANDS","ST. CROIX",2,NAD27,5202,3992
-15300,"AMERICAN SAMOA",,2,NAD27,5300,2155
-15400,"GUAM ISLAND",,3,NAD27,5400,
Deleted: grass/trunk/lib/proj/unit_of_measure.csv
--- grass/trunk/lib/proj/unit_of_measure.csv	2016-04-30 19:04:20 UTC (rev 68340)
+++ grass/trunk/lib/proj/unit_of_measure.csv	2016-04-30 21:08:30 UTC (rev 68341)
@@ -1,79 +0,0 @@
-uom_code,unit_of_meas_name,unit_of_meas_type,target_uom_code,factor_b,factor_c,remarks,information_source,data_source,revision_date,change_id,deprecated
-9001,metre,length,9001,1,1,Also known as International metre. SI standard unit.,ISO 1000.,OGP,1995-06-02,,0
-9002,foot,length,9001,0.3048,1,,ISO 1000; 1958,OGP,1995-06-02,,0
-9003,US survey foot,length,9001,12,39.37,Used in USA.,OGP,OGP,2000-05-07,1999.990,0
-9005,Clarke's foot,length,9001,0.3047972654,1,"Assumes Clarke's 1865 ratio of 1 British foot = 0.3047972654 French legal metres applies to the international metre.   Used in older Australian, southern African & British West Indian mapping.",Australian Land Information Group  www.auslig.gov.au,OGP,2005-09-06,1997.233 1999.990 2000.050 2005.370 2005.460,0
-9014,fathom,length,9001,1.8288,1,= 6 feet.,,OGP,1995-06-02,,0
-9030,nautical mile,length,9001,1852,1,,,OGP,1996-10-18,1996.240,0
-9031,German legal metre,length,9001,1.0000135965,1,Used in Namibia.,Chief Directorate Surveys and Land Information; Mowbray; South Africa,OGP,1997-06-16,,0
-9033,US survey chain,length,9001,792,39.37,Used in USA primarily for public lands cadastral work.,Bureau of Land Management technical bulletin 6 (1973) and Standard Field Tables 8th edition (1956).,OGP,2000-05-07,1999.990,0
-9034,US survey link,length,9001,7.92,39.37,Used in USA primarily for public lands cadastral work.,Bureau of Land Management technical bulletin 6 (1973) and Standard Field Tables 8th edition (1956).,OGP,2000-05-07,1999.990,0
-9035,US survey mile,length,9001,63360,39.37,Used in USA primarily for public lands cadastral work.,Bureau of Land Management technical bulletin 6 (1973) and Standard Field Tables 8th edition (1956).,OGP,2000-05-07,1999.990,0
-9036,kilometre,length,9001,1000,1,,ISO 1000.,OGP,1998-11-11,,0
-9037,Clarke's yard,length,9001,0.9143917962,1,"=3 Clarke's feet.  Assumes Clarke's 1865 ratio of 1 British foot = 0.3047972654 French legal metres applies to the international metre.   Used in older Australian, southern African & British West Indian mapping.",Australian Land Information Group  www.auslig.gov.au,OGP,2005-09-06,1997.233 1999.990 2005.370 2005.460,0
-9038,Clarke's chain,length,9001,20.1166195164,1,"=22 Clarke's yards.  Assumes Clarke's 1865 ratio of 1 British foot = 0.3047972654 French legal metres applies to the international metre.   Used in older Australian, southern African & British West Indian mapping.",Australian Land Information Group  www.auslig.gov.au,OGP,2005-09-06,1997.233 1999.990 2005.370 2005.460,0
-9039,Clarke's link,length,9001,0.201166195164,1,"=1/100 Clarke's chain. Assumes Clarke's 1865 ratio of 1 British foot = 0.3047972654 French legal metres applies to the international metre.   Used in older Australian, southern African & British West Indian mapping.",Australian Land Information Group  www.auslig.gov.au,OGP,2005-09-06,1997.233 1999.990 2005.370 2005.460,0
-9040,British yard (Sears 1922),length,9001,36,39.370147,Uses Sear's 1922 British yard-metre ratio as given by Bomford as 39.370147 inches per metre.  Used in East Malaysian and older New Zealand mapping.,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9041,British foot (Sears 1922),length,9001,12,39.370147,Uses Sear's 1922 British yard-metre ratio as given by Bomford as 39.370147 inches per metre.  Used in East Malaysian and older New Zealand mapping.,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9042,British chain (Sears 1922),length,9001,792,39.370147,Uses Sear's 1922 British yard-metre ratio as given by Bomford as 39.370147 inches per metre.  Used in East Malaysian and older New Zealand mapping.,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9043,British link (Sears 1922),length,9001,7.92,39.370147,Uses Sear's 1922 British yard-metre ratio as given by Bomford as 39.370147 inches per metre.  Used in East Malaysian and older New Zealand mapping.,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9050,British yard (Benoit 1895 A),length,9001,0.9143992,1,Uses Benoit's 1895 British yard-metre ratio as given by Clark as 0.9143992 metres per yard.  Used for deriving metric size of ellipsoid in Palestine.,"J.S.Clark; ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2006-03-21,1997.233 1999.990 2006.260,0
-9051,British foot (Benoit 1895 A),length,9001,0.9143992,3,Uses Benoit's 1895 British yard-metre ratio as given by Clark as 0.9143992 metres per yard.  Used for deriving metric size of ellipsoid in Palestine.,"J.S.Clark; ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2006-03-21,1997.233 1999.990 2006.260,0
-9052,British chain (Benoit 1895 A),length,9001,20.1167824,1,Uses Benoit's 1895 British yard-metre ratio as given by Clark as 0.9143992 metres per yard.  Used for deriving metric size of ellipsoid in Palestine.,"J.S.Clark; ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2006-03-21,1997.233 1999.990 2006.260,0
-9053,British link (Benoit 1895 A),length,9001,0.201167824,1,Uses Benoit's 1895 British yard-metre ratio as given by Clark as 0.9143992 metres per yard.  Used for deriving metric size of ellipsoid in Palestine.,"J.S.Clark; ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2006-03-21,1997.233 1999.990 2006.260,0
-9060,British yard (Benoit 1895 B),length,9001,36,39.370113,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.","G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9061,British foot (Benoit 1895 B),length,9001,12,39.370113,Uses Benoit's 1895 British yard-metre ratio as given by Bomford as 39.370113 inches per metre.  Used in West Malaysian mapping.,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9062,British chain (Benoit 1895 B),length,9001,792,39.370113,Uses Benoit's 1895 British yard-metre ratio as given by Bomford as 39.370113 inches per metre.  Used in West Malaysian mapping.,"G. Bomford ""Geodesy"" 2nd edition 1962; after J.S.Clark ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9063,British link (Benoit 1895 B),length,9001,7.92,39.370113,Uses Benoit's 1895 British yard-metre ratio as given by Bomford as 39.370113 inches per metre.  Used in West Malaysian mapping.,"G. Bomford; ""Geodesy""; 3rd edition 1975",OGP,2000-05-07,1997.233 1999.990,0
-9070,British foot (1865),length,9001,0.9144025,3,Uses Clark's estimate of 1853-1865 British foot-metre ratio of 0.9144025 metres per yard.  Used in 1962 and 1975 estimates of Indian foot.,"J.S.Clark; ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",OGP,2000-05-07,1997.233 1999.990,0
-9080,Indian foot,length,9001,12,39.370142,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British yard (= 3 British feet) taken to be J.S.Clark's 1865 value of 0.9144025 metres.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",OGP,2000-05-07,1997.231 1999.990,0
-9081,Indian foot (1937),length,9001,0.30479841,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British foot taken to be 1895 Benoit value of 12/39.370113m.  Rounded to 8 decimal places as 0.30479841. Used from Bangladesh to Vietnam.  Previously used in India and Pakistan but superseded.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",OGP,2000-05-07,1997.231 1999.990,0
-9082,Indian foot (1962),length,9001,0.3047996,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures with a small error as 1 Ind ft=0.3047996m.  Used in Pakistan since metrication.,"G. Bomford; ""Geodesy""; 2nd edition 1962",OGP,2007-01-25,1997.231 1999.990 2007.011,0
-9083,Indian foot (1975),length,9001,0.3047995,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures as 1 Ind ft=0.3047995m.  Used in India since metrication.,"G. Bomford; ""Geodesy""; 3rd edition 1975",OGP,2007-01-25,1997.231 1999.990 2007.011,0
-9084,Indian yard,length,9001,36,39.370142,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British yard (= 3 British feet) taken to be J.S.Clark's 1865 value of 0.9144025 metres.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",OGP,2000-05-07,1997.231 1999.990,0
-9085,Indian yard (1937),length,9001,0.91439523,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British foot taken to be 1895 Benoit value of 12/39.370113m.  Rounded to 8 decimal places as 0.30479841. Used from Bangladesh to Vietnam.  Previously used in India and Pakistan but superseded.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",OGP,2000-05-07,1997.231 1999.990,0
-9086,Indian yard (1962),length,9001,0.9143988,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures with a small error as 1 Ind ft=0.3047996m.  Used in Pakistan since metrication.,"G. Bomford; ""Geodesy""; 2nd edition 1962",OGP,2007-01-25,1997.231 1999.990 2007.011,0
-9087,Indian yard (1975),length,9001,0.9143985,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865).  British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures as 1 Ind ft=0.3047995m.  Used in India since metrication.,"G. Bomford; ""Geodesy""; 3rd edition 1975",OGP,2007-01-25,1997.231 1999.990 2007.011,0
-9093,Statute mile,length,9001,1609.344,1,=5280 feet,OGP,OGP,2000-03-07,,0
-9094,Gold Coast foot,length,9001,6378300,20926201,"Used in Ghana and some adjacent parts of British west Africa prior to metrication, except for the metrication of projection defining parameters when British foot (Sears 1922) used.",Ordnance Survey International,OGP,2001-01-21,2000.861,0
-9095,British foot (1936),length,9001,0.3048007491,1,For the 1936 retriangulation OSGB defines the relationship of 10 feet of 1796 to the International metre through the logarithmic relationship (10^0.48401603 exactly). 1 ft = 0.3048007491…m. Also used for metric conversions in Ireland.,"1. ""The Retriangulation of Great Britain"", Ordnance Survey of Great Britain.¶2. ""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",OGP,2006-11-27,2002.621 2006.932,0
-9096,yard,length,9001,0.9144,1,=3 international feet.,OGP,OGP,2006-07-14,,0
-9097,chain,length,9001,20.1168,1,=22 international yards or 66 international feet.,OGP,OGP,2006-07-14,,0
-9098,link,length,9001,20.1168,100,=1/100 international chain.,OGP,OGP,2006-07-14,,0
-9099,British yard (Sears 1922 truncated),length,9001,0.914398,1,Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures.,Defence Geographic Centre,OGP,2006-10-23,2006.901,0
-9101,radian,angle,9101,1,1,SI standard unit.,ISO 1000:1992,OGP,1995-06-02,,0
-9102,degree,angle,9101,3.14159265358979,180,= pi/180 radians,,OGP,2002-11-18,1996.220 2002.860,0
-9103,arc-minute,angle,9101,3.14159265358979,10800,1/60th degree = ((pi/180) / 60) radians,,OGP,2002-11-18,1996.220 2002.860,0
-9104,arc-second,angle,9101,3.14159265358979,648000,1/60th arc-minute = ((pi/180) / 3600) radians,,OGP,2002-11-18,1996.220 2002.860,0
-9105,grad,angle,9101,3.14159265358979,200,=pi/200 radians.,,OGP,2002-11-18,1996.220 1999.050 2002.860,0
-9106,gon,angle,9101,3.14159265358979,200,=pi/200 radians,,OGP,2002-11-18,1996.220 2002.860,0
-9107,degree minute second,angle,9102,,,"Degree representation. Format: signed degrees (integer) - arc-minutes (integer) - arc-seconds (real, any precision). Different symbol sets are in use as field separators, for example º ' "". Convert to degrees using algorithm.",OGP,OGP,2002-11-22,1996.190 2002.070 2002.780,0
-9108,degree minute second hemisphere,angle,9102,,,"Degree representation. Format: degrees (integer) - arc-minutes (integer) - arc-seconds (real) - hemisphere abbreviation (single character N S E or W). Different symbol sets are in use as field separators for example º ' "". Convert to deg using algorithm.",OGP,OGP,2002-11-22,1996.190 2002.070 2002.780,0
-9109,microradian,angle,9101,1,1000000,rad * 10E-6,ISO 1000.,OGP,1996-10-18,1999.050,0
-9110,sexagesimal DMS,angle,9102,,,Pseudo unit. Format: signed degrees - period - minutes (2 digits) - integer seconds (2 digits) - fraction of seconds (any precision). Must include leading zero in minutes and seconds and exclude decimal point for seconds. Convert to degree using formula.,OGP,OGP,2008-03-26,2002.270 2002.780 2008.020,0
-9111,sexagesimal DM,angle,9102,,,Pseudo unit. Format: sign - degrees - decimal point - integer minutes (two digits) - fraction of minutes (any precision).  Must include leading zero in integer minutes.  Must exclude decimal point for minutes.  Convert to deg using algorithm.,OGP,OGP,2002-11-22,2002.070 2002.780,0
-9112,centesimal minute,angle,9101,3.14159265358979,20000,1/100 of a grad and gon = ((pi/200) / 100) radians,http://www.geodesy.matav.hu/,OGP,2005-09-06,1998.480 1999.510 2002.860 2005.460,0
-9113,centesimal second,angle,9101,3.14159265358979,2000000,"1/100 of a centesimal minute or 1/10,000th of a grad and gon = ((pi/200) / 10000) radians",http://www.geodesy.matav.hu/,OGP,2005-09-06,1999.510 2002.860 2005.460,0
-9114,mil_6400,angle,9101,3.14159265358979,3200,Angle subtended by 1/6400 part of a circle.  Approximates to 1/1000th radian.  Note that other approximations (notably 1/6300 circle and 1/6000 circle) also exist.,http://www.geodesy.matav.hu/,OGP,2005-09-06,1999.510 2005.460,0
-9115,degree minute,angle,9102,,,"Degree representation. Format: signed degrees (integer)  - arc-minutes (real, any precision). Different symbol sets are in use as field separators, for example º '. Convert to degrees using algorithm.",OGP,OGP,2002-11-22,2002.780,0
-9116,degree hemisphere,angle,9102,,,"Degree representation. Format: degrees (real, any precision) - hemisphere abbreviation (single character N S E or W). Convert to degrees using algorithm.",OGP,OGP,2002-11-22,,0
-9117,hemisphere degree,angle,9102,,,"Degree representation. Format: hemisphere abbreviation (single character N S E or W) - degrees (real, any precision). Convert to degrees using algorithm.",OGP,OGP,2002-11-22,,0
-9118,degree minute hemisphere,angle,9102,,,"Degree representation. Format: degrees (integer) - arc-minutes (real, any precision) - hemisphere abbreviation (single character N S E or W). Different symbol sets are in use as field separators, for example º '. Convert to degrees using algorithm.",OGP,OGP,2002-11-22,,0
-9119,hemisphere degree minute,angle,9102,,,"Degree representation. Format:  hemisphere abbreviation (single character N S E or W) - degrees (integer) - arc-minutes (real, any precision). Different symbol sets are in use as field separators, for example º '. Convert to degrees using algorithm.",OGP,OGP,2002-11-22,,0
-9120,hemisphere degree minute second,angle,9102,,,"Degree representation. Format: hemisphere abbreviation (single character N S E or W) - degrees (integer) - arc-minutes (integer) - arc-seconds (real). Different symbol sets are in use as field separators for example º ' "". Convert to deg using algorithm.",OGP,OGP,2002-11-22,,0
-9121,sexagesimal DMS.s,angle,9102,,,"Pseudo unit. Format: signed degrees - minutes (two digits) - seconds (real, any precision). Must include leading zero in minutes and seconds where value is under 10 and include decimal separator for seconds. Convert to degree using algorithm.",ISO 6709:1983.,OGP,2002-11-22,,0
-9122,degree (supplier to define representation),angle,9101,3.14159265358979,180,"= pi/180 radians. The degree representation (e.g. decimal, DMSH, etc.) must be clarified by suppliers of data associated with this code.",OGP,OGP,2004-01-05,,0
-9201,unity,scale,9201,1,1,,,OGP,1996-09-12,,0
-9202,parts per million,scale,9201,1,1000000,,,OGP,1996-09-12,,0
-9203,coefficient,scale,9201,1,1,Used when parameters are coefficients.  They inherently take the units which depend upon the term to which the coefficient applies.,OGP,OGP,2004-09-14,2004.530,0
-9204,Bin width 330 US survey feet,length,9001,3960,39.37,,OGP,OGP,2000-10-19,2000.590,0
-9205,Bin width 165 US survey feet,length,9001,1980,39.37,,OGP,OGP,2000-10-19,2000.590,0
-9206,Bin width 82.5 US survey feet,length,9001,990,39.37,,OGP,OGP,2000-10-19,2000.590,0
-9207,Bin width 37.5 metres,length,9001,37.5,1,,OGP,OGP,2000-10-19,2000.590,0
-9208,Bin width 25 metres,length,9001,25,1,,OGP,OGP,2000-10-19,2000.590,0
-9209,Bin width 12.5 metres,length,9001,12.5,1,,OGP,OGP,2000-10-19,2000.590,0
-9210,Bin width 6.25 metres,length,9001,6.25,1,,OGP,OGP,2000-10-19,2000.590,0
-9211,Bin width 3.125 metres,length,9001,3.125,1,,OGP,OGP,2000-10-19,2000.590,0
-9300,British foot (Sears 1922 truncated),length,9001,0.914398,3,"Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures; this truncated ratio (0.914398, UoM code 9099) then converted to other imperial units. 3 ftSe(T) = 1 ydSe(T).",Defence Geographic Centre,OGP,2006-10-23,2006.901,0
-9301,British chain (Sears 1922 truncated),length,9001,20.116756,1,"Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures; this truncated ratio (0.914398, UoM code 9099) then converted to other imperial units. 1 chSe(T) = 22 ydSe(T). Used in metrication of Malaya RSO grid.",Defence Geographic Centre,OGP,2006-10-23,2006.901,0
-9302,British link (Sears 1922 truncated),length,9001,20.116756,100,"Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures; this truncated ratio (0.914398, UoM code 9099) then converted to other imperial units. 100 lkSe(T) = 1 chSe(T).",Defence Geographic Centre,OGP,2006-10-23,2006.901,0
