[GRASS-SVN] r69077 - in grass/branches/releasebranch_7_0/gui/wxpython: gui_core iclass wxplot
svn_grass at osgeo.org
Thu Aug 4 04:19:40 PDT 2016
Author: annakrat
Date: 2016-08-04 04:19:40 -0700 (Thu, 04 Aug 2016)
New Revision: 69077
Added:
grass/branches/releasebranch_7_0/gui/wxpython/gui_core/wxlibplot.py
grass/branches/releasebranch_7_0/gui/wxpython/iclass/plots.py
grass/branches/releasebranch_7_0/gui/wxpython/wxplot/base.py
grass/branches/releasebranch_7_0/gui/wxpython/wxplot/histogram.py
grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py
grass/branches/releasebranch_7_0/gui/wxpython/wxplot/scatter.py
wxGUI: solve #2558 and #3112 by distributing wx.lib.plot.py with GRASS (merge from trunk, r69075)
Copied: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/wxlibplot.py (from rev 69075, grass/trunk/gui/wxpython/gui_core/wxlibplot.py)
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/wxlibplot.py (rev 0)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/wxlibplot.py 2016-08-04 11:19:40 UTC (rev 69077)
@@ -0,0 +1,2556 @@
+# Name: wx.lib.plot.py
+# Purpose: Line, Bar and Scatter Graphs
+# Author: Gordon Williams
+# Created: 2003/11/03
+# RCS-ID: $Id$
+# Copyright: (c) 2002
+# Licence: Use as you wish.
+# Included in GRASS GIS instead of importing it from wxPython
+# to overcome bug present in wxPython 3.0.2.
+# See #2558 and #3112
+# 12/15/2003 - Jeff Grimmett (grimmtooth at softhome.net)
+# o 2.5 compatability update.
+# o Renamed to plot.py in the wx.lib directory.
+# o Reworked test frame to work with wx demo framework. This saves a bit
+# of tedious cut and paste, and the test app is excellent.
+# 12/18/2003 - Jeff Grimmett (grimmtooth at softhome.net)
+# o wxScrolledMessageDialog -> ScrolledMessageDialog
+# Oct 6, 2004 Gordon Williams (g_will at cyberus.ca)
+# - Added bar graph demo
+# - Modified line end shape from round to square.
+# - Removed FloatDCWrapper for conversion to ints and ints in arguments
+# Oct 15, 2004 Gordon Williams (g_will at cyberus.ca)
+# - Imported modules given leading underscore to name.
+# - Added Cursor Line Tracking and User Point Labels.
+# - Demo for Cursor Line Tracking and Point Labels.
+# - Size of plot preview frame adjusted to show page better.
+# - Added helper functions PositionUserToScreen and PositionScreenToUser in PlotCanvas.
+# - Added functions GetClosestPoints (all curves) and GetClosestPoint (only closest curve)
+# can be in either user coords or screen coords.
+# Jun 22, 2009 Florian Hoech (florian.hoech at gmx.de)
+# - Fixed exception when drawing empty plots on Mac OS X
+# - Fixed exception when trying to draw point labels on Mac OS X (Mac OS X
+# point label drawing code is still slow and only supports wx.COPY)
+# - Moved label positions away from axis lines a bit
+# - Added PolySpline class and modified demo 1 and 2 to use it
+# - Added center and diagonal lines option (Set/GetEnableCenterLines,
+# Set/GetEnableDiagonals)
+# - Added anti-aliasing option with optional high-resolution mode
+# (Set/GetEnableAntiAliasing, Set/GetEnableHiRes) and demo
+# - Added option to specify exact number of tick marks to use for each axis
+# (SetXSpec(<number>, SetYSpec(<number>) -- work like 'min', but with
+# <number> tick marks)
+# - Added support for background and foreground colours (enabled via
+# SetBackgroundColour/SetForegroundColour on a PlotCanvas instance)
+# - Changed PlotCanvas printing initialization from occuring in __init__ to
+# occur on access. This will postpone any IPP and / or CUPS warnings
+# which appear on stderr on some Linux systems until printing functionality
+# is actually used.
+This is a simple light weight plotting module that can be used with
+Boa or easily integrated into your own wxPython application. The
+emphasis is on small size and fast plotting for large data sets. It
+has a reasonable number of features to do line and scatter graphs
+easily as well as simple bar graphs. It is not as sophisticated or
+as powerful as SciPy Plt or Chaco. Both of these are great packages
+but consume huge amounts of computer resources for simple plots.
+They can be found at http://scipy.com
+This file contains two parts; first the re-usable library stuff, then,
+after a "if __name__=='__main__'" test, a simple frame and a few default
+plots for examples and testing.
+Based on wxPlotCanvas
+Written by K.Hinsen, R. Srinivasan;
+Ported to wxPython Harm van der Heijden, feb 1999
+Major Additions Gordon Williams Feb. 2003 (g_will at cyberus.ca)
+ -More style options
+ -Zooming using mouse "rubber band"
+ -Scroll left, right
+ -Grid(graticule)
+ -Printing, preview, and page set up (margins)
+ -Axis and title labels
+ -Cursor xy axis values
+ -Doc strings and lots of comments
+ -Optimizations for large number of points
+ -Legends
+Did a lot of work here to speed markers up. Only a factor of 4
+improvement though. Lines are much faster than markers, especially
+filled markers. Stay away from circles and triangles unless you
+only have a few thousand points.
+Times for 25,000 points
+Line - 0.078 sec
+Markers
+Square - 0.22 sec
+dot - 0.10
+circle - 0.87
+cross,plus - 0.28
+triangle, triangle_down - 0.90
+Thanks to Chris Barker for getting this version working on Linux.
+Zooming controls with mouse (when enabled):
+ Left mouse drag - Zoom box.
+ Left mouse double click - reset zoom.
+ Right mouse click - zoom out centred on click location.
+import string as _string
+import time as _time
+import sys
+import wx
+# Needs NumPy
+try:
+ import numpy as np
+except:
+ msg = """
+ This module requires the NumPy module, which could not be
+ imported. It probably is not installed (it's not part of the
+ standard Python distribution). See the Numeric Python site
+ (http://numpy.scipy.org) for information on downloading source or
+ binaries."""
+ raise ImportError("NumPy not found.\n" + msg)
+# Plotting classes...
+class PolyPoints:
+ """Base Class for lines and markers
+ - All methods are private.
+ def __init__(self, points, attr):
+ self._points = np.array(points).astype(np.float64)
+ self._logscale = (False, False)
+ self._pointSize = (1.0, 1.0)
+ self.currentScale = (1, 1)
+ self.currentShift = (0, 0)
+ self.scaled = self.points
+ self.attributes = {}
+ self.attributes.update(self._attributes)
+ for name, value in attr.items():
+ if name not in self._attributes.keys():
+ raise KeyError(
+ "Style attribute incorrect. Should be one of %s" % self._attributes.keys())
+ self.attributes[name] = value
+ def setLogScale(self, logscale):
+ self._logscale = logscale
+ def __getattr__(self, name):
+ if name == 'points':
+ if len(self._points) > 0:
+ data = np.array(self._points, copy=True)
+ if self._logscale[0]:
+ data = self.log10(data, 0)
+ if self._logscale[1]:
+ data = self.log10(data, 1)
+ return data
+ else:
+ return self._points
+ else:
+ raise AttributeError(name)
+ def log10(self, data, ind):
+ data = np.compress(data[:, ind] > 0, data, 0)
+ data[:, ind] = np.log10(data[:, ind])
+ return data
+ def boundingBox(self):
+ if len(self.points) == 0:
+ # no curves to draw
+ # defaults to (-1,-1) and (1,1) but axis can be set in Draw
+ minXY = np.array([-1.0, -1.0])
+ maxXY = np.array([1.0, 1.0])
+ else:
+ minXY = np.minimum.reduce(self.points)
+ maxXY = np.maximum.reduce(self.points)
+ return minXY, maxXY
+ def scaleAndShift(self, scale=(1, 1), shift=(0, 0)):
+ return
+ if (scale is not self.currentScale) or (shift is not self.currentShift):
+ # update point scaling
+ self.scaled = scale * self.points + shift
+ self.currentScale = scale
+ self.currentShift = shift
+ # else unchanged use the current scaling
+ def getLegend(self):
+ return self.attributes['legend']
+ def getClosestPoint(self, pntXY, pointScaled=True):
+ """Returns the index of closest point on the curve, pointXY, scaledXY, distance
+ x, y in user coords
+ if pointScaled == True based on screen coords
+ if pointScaled == False based on user coords
+ if pointScaled == True:
+ # Using screen coords
+ p = self.scaled
+ pxy = self.currentScale * np.array(pntXY) + self.currentShift
+ else:
+ # Using user coords
+ p = self.points
+ pxy = np.array(pntXY)
+ # determine distance for each point
+ d = np.sqrt(np.add.reduce((p - pxy) ** 2, 1)) # sqrt(dx^2+dy^2)
+ pntIndex = np.argmin(d)
+ dist = d[pntIndex]
+ return [pntIndex, self.points[pntIndex], self.scaled[pntIndex] / self._pointSize, dist]
+class PolyLine(PolyPoints):
+ """Class to define line type and style
+ - All methods except __init__ are private.
+ _attributes = {'colour': 'black',
+ 'width': 1,
+ 'style': wx.PENSTYLE_SOLID,
+ 'legend': ''}
+ def __init__(self, points, **attr):
+ Creates PolyLine object
+ :param `points`: sequence (array, tuple or list) of (x,y) points making up line
+ :keyword `attr`: keyword attributes, default to:
+ 'colour'= 'black' wx.Pen Colour any wx.Colour
+ 'width'= 1 Pen width
+ 'style'= wx.PENSTYLE_SOLID wx.Pen style
+ 'legend'= '' Line Legend to display
+ PolyPoints.__init__(self, points, attr)
+ def draw(self, dc, printerScale, coord=None):
+ colour = self.attributes['colour']
+ width = self.attributes['width'] * printerScale * self._pointSize[0]
+ style = self.attributes['style']
+ if not isinstance(colour, wx.Colour):
+ colour = wx.NamedColour(colour)
+ pen = wx.Pen(colour, width, style)
+ pen.SetCap(wx.CAP_BUTT)
+ dc.SetPen(pen)
+ if coord is None:
+ if len(self.scaled): # bugfix for Mac OS X
+ dc.DrawLines(self.scaled)
+ else:
+ dc.DrawLines(coord) # draw legend line
+ def getSymExtent(self, printerScale):
+ """Width and Height of Marker"""
+ h = self.attributes['width'] * printerScale * self._pointSize[0]
+ w = 5 * h
+ return (w, h)
+class PolySpline(PolyLine):
+ 'width': 1,
+ 'legend': ''}
+ :param `points`: sequence (array, tuple or list) of (x,y) points making up spline
+ PolyLine.__init__(self, points, **attr)
+ pen.SetCap(wx.CAP_ROUND)
+ dc.SetPen(pen)
+ if coord is None:
+ dc.DrawSpline(self.scaled)
+ else:
+class PolyMarker(PolyPoints):
+ """Class to define marker type and style
+ 'width': 1,
+ 'size': 2,
+ 'fillcolour': None,
+ 'fillstyle': wx.BRUSHSTYLE_SOLID,
+ 'marker': 'circle',
+ 'legend': ''}
+ Creates PolyMarker object
+ 'size'= 2 Marker size
+ 'fillcolour'= same as colour wx.Brush Colour any wx.Colour
+ 'fillstyle'= wx.BRUSHSTYLE_SOLID wx.Brush fill style (use wx.BRUSHSTYLE_TRANSPARENT for no fill)
+ 'style'= wx.FONTFAMILY_SOLID wx.Pen style
+ 'marker'= 'circle' Marker shape
+ Marker Shapes:
+ - 'circle'
+ - 'dot'
+ - 'square'
+ - 'triangle'
+ - 'triangle_down'
+ - 'cross'
+ - 'plus'
+ size = self.attributes['size'] * printerScale * self._pointSize[0]
+ fillcolour = self.attributes['fillcolour']
+ fillstyle = self.attributes['fillstyle']
+ marker = self.attributes['marker']
+ if colour and not isinstance(colour, wx.Colour):
+ if fillcolour and not isinstance(fillcolour, wx.Colour):
+ fillcolour = wx.NamedColour(fillcolour)
+ dc.SetPen(wx.Pen(colour, width))
+ if fillcolour:
+ dc.SetBrush(wx.Brush(fillcolour, fillstyle))
+ else:
+ dc.SetBrush(wx.Brush(colour, fillstyle))
+ if coord is None:
+ self._drawmarkers(dc, self.scaled, marker, size)
+ else:
+ self._drawmarkers(dc, coord, marker, size) # draw legend marker
+ s = 5 * self.attributes['size'] * printerScale * self._pointSize[0]
+ return (s, s)
+ def _drawmarkers(self, dc, coords, marker, size=1):
+ f = eval('self._' + marker)
+ f(dc, coords, size)
+ def _circle(self, dc, coords, size=1):
+ fact = 2.5 * size
+ wh = 5.0 * size
+ rect = np.zeros((len(coords), 4), np.float) + [0.0, 0.0, wh, wh]
+ rect[:, 0:2] = coords - [fact, fact]
+ dc.DrawEllipseList(rect.astype(np.int32))
+ def _dot(self, dc, coords, size=1):
+ dc.DrawPointList(coords)
+ def _square(self, dc, coords, size=1):
+ fact = 2.5 * size
+ wh = 5.0 * size
+ dc.DrawRectangleList(rect.astype(np.int32))
+ def _triangle(self, dc, coords, size=1):
+ shape = [(-2.5 * size, 1.44 * size),
+ (2.5 * size, 1.44 * size), (0.0, -2.88 * size)]
+ poly = np.repeat(coords, 3, 0)
+ poly.shape = (len(coords), 3, 2)
+ poly += shape
+ dc.DrawPolygonList(poly.astype(np.int32))
+ def _triangle_down(self, dc, coords, size=1):
+ shape = [(-2.5 * size, -1.44 * size),
+ (2.5 * size, -1.44 * size), (0.0, 2.88 * size)]
+ poly += shape
+ def _cross(self, dc, coords, size=1):
+ fact = 2.5 * size
+ for f in [[-fact, -fact, fact, fact], [-fact, fact, fact, -fact]]:
+ lines = np.concatenate((coords, coords), axis=1) + f
+ dc.DrawLineList(lines.astype(np.int32))
+ def _plus(self, dc, coords, size=1):
+ fact = 2.5 * size
+ for f in [[-fact, 0, fact, 0], [0, -fact, 0, fact]]:
+class PlotGraphics:
+ """Container to hold PolyXXX objects and graph labels
+ def __init__(self, objects, title='', xLabel='', yLabel=''):
+ """Creates PlotGraphics object
+ objects - list of PolyXXX objects to make graph
+ title - title shown at top of graph
+ xLabel - label shown on x-axis
+ yLabel - label shown on y-axis
+ if type(objects) not in [list, tuple]:
+ raise TypeError("objects argument should be list or tuple")
+ self.objects = objects
+ self.title = title
+ self.xLabel = xLabel
+ self.yLabel = yLabel
+ if type(logscale) != tuple:
+ raise TypeError(
+ 'logscale must be a tuple of bools, e.g. (False, False)')
+ if len(self.objects) == 0:
+ return
+ for o in self.objects:
+ o.setLogScale(logscale)
+ p1, p2 = self.objects[0].boundingBox()
+ for o in self.objects[1:]:
+ p1o, p2o = o.boundingBox()
+ p1 = np.minimum(p1, p1o)
+ p2 = np.maximum(p2, p2o)
+ return p1, p2
+ o.scaleAndShift(scale, shift)
+ def setPrinterScale(self, scale):
+ """Thickens up lines and markers only for printing"""
+ self.printerScale = scale
+ def setXLabel(self, xLabel=''):
+ """Set the X axis label on the graph"""
+ def setYLabel(self, yLabel=''):
+ """Set the Y axis label on the graph"""
+ def setTitle(self, title=''):
+ """Set the title at the top of graph"""
+ def getXLabel(self):
+ """Get x axis label string"""
+ return self.xLabel
+ def getYLabel(self):
+ """Get y axis label string"""
+ return self.yLabel
+ def getTitle(self, title=''):
+ """Get the title at the top of graph"""
+ return self.title
+ def draw(self, dc):
+ # t=_time.clock() # profile info
+ o._pointSize = self._pointSize
+ o.draw(dc, self.printerScale)
+ #dt= _time.clock()-t
+ #print(o, "time=", dt)
+ """Get max width and height of lines and markers symbols for legend"""
+ self.objects[0]._pointSize = self._pointSize
+ symExt = self.objects[0].getSymExtent(printerScale)
+ oSymExt = o.getSymExtent(printerScale)
+ symExt = np.maximum(symExt, oSymExt)
+ return symExt
+ def getLegendNames(self):
+ """Returns list of legend names"""
+ lst = [None] * len(self)
+ for i in range(len(self)):
+ lst[i] = self.objects[i].getLegend()
+ return lst
+ def __len__(self):
+ return len(self.objects)
+ def __getitem__(self, item):
+ return self.objects[item]
+# Main window that you will want to import into your application.
+class PlotCanvas(wx.Panel):
+ Subclass of a wx.Panel which holds two scrollbars and the actual
+ plotting canvas (self.canvas). It allows for simple general plotting
+ of data with zoom, labels, and automatic axis scaling."""
+ def __init__(self, parent, id=wx.ID_ANY, pos=wx.DefaultPosition,
+ size=wx.DefaultSize, style=0, name="plotCanvas"):
+ """Constructs a panel, which can be a child of a frame or
+ any other non-control window"""
+ wx.Panel.__init__(self, parent, id, pos, size, style, name)
+ self._isWindowCreated = False
+ sizer = wx.FlexGridSizer(2, 2, 0, 0)
+ self.canvas = wx.Window(self, -1)
+ self.sb_vert = wx.ScrollBar(self, -1, style=wx.SB_VERTICAL)
+ self.sb_vert.SetScrollbar(0, 1000, 1000, 1000)
+ self.sb_hor = wx.ScrollBar(self, -1, style=wx.SB_HORIZONTAL)
+ self.sb_hor.SetScrollbar(0, 1000, 1000, 1000)
+ sizer.Add(self.canvas, 1, wx.EXPAND)
+ sizer.Add(self.sb_vert, 0, wx.EXPAND)
+ sizer.Add(self.sb_hor, 0, wx.EXPAND)
+ sizer.Add((0, 0))
+ sizer.AddGrowableRow(0, 1)
+ sizer.AddGrowableCol(0, 1)
+ self.sb_vert.Show(False)
+ self.sb_hor.Show(False)
+ self.SetSizer(sizer)
+ self.Fit()
+ self.border = (1, 1)
+ self.SetBackgroundColour("white")
+ # Create some mouse events for zooming
+ self.canvas.Bind(wx.EVT_LEFT_DOWN, self.OnMouseLeftDown)
+ self.canvas.Bind(wx.EVT_LEFT_UP, self.OnMouseLeftUp)
+ self.canvas.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.canvas.Bind(wx.EVT_LEFT_DCLICK, self.OnMouseDoubleClick)
+ self.canvas.Bind(wx.EVT_RIGHT_DOWN, self.OnMouseRightDown)
+ # scrollbar events
+ self.Bind(wx.EVT_SCROLL_THUMBTRACK, self.OnScroll)
+ self.Bind(wx.EVT_SCROLL_PAGEUP, self.OnScroll)
+ self.Bind(wx.EVT_SCROLL_PAGEDOWN, self.OnScroll)
+ self.Bind(wx.EVT_SCROLL_LINEUP, self.OnScroll)
+ self.Bind(wx.EVT_SCROLL_LINEDOWN, self.OnScroll)
+ # set curser as cross-hairs
+ self.canvas.SetCursor(wx.CROSS_CURSOR)
+## self.HandCursor = wx.Cursor(Hand.GetImage())
+ self.HandCursor = wx.CursorFromImage(Hand.GetImage())
+ self.GrabHandCursor = wx.CursorFromImage(GrabHand.GetImage())
+## self.GrabHandCursor = wx.Cursor(GrabHand.GetImage())
+## self.MagCursor = wx.Cursor(MagPlus.GetImage())
+ self.MagCursor = wx.CursorFromImage(MagPlus.GetImage())
+ # Things for printing
+ self._print_data = None
+ self._pageSetupData = None
+ self.printerScale = 1
+ self.parent = parent
+ # scrollbar variables
+ self._sb_ignore = False
+ self._adjustingSB = False
+ self._sb_xfullrange = 0
+ self._sb_yfullrange = 0
+ self._sb_xunit = 0
+ self._sb_yunit = 0
+ self._dragEnabled = False
+ self._screenCoordinates = np.array([0.0, 0.0])
+ # Zooming variables
+ self._zoomInFactor = 0.5
+ self._zoomOutFactor = 2
+ self._zoomCorner1 = np.array([0.0, 0.0]) # left mouse down corner
+ self._zoomCorner2 = np.array([0.0, 0.0]) # left mouse up corner
+ self._zoomEnabled = False
+ self._hasDragged = False
+ # Drawing Variables
+ self.last_draw = None
+ self._pointScale = 1
+ self._pointShift = 0
+ self._xSpec = 'auto'
+ self._ySpec = 'auto'
+ self._gridEnabled = False
+ self._legendEnabled = False
+ self._titleEnabled = True
+ self._centerLinesEnabled = False
+ self._diagonalsEnabled = False
+ # Fonts
+ self._fontCache = {}
+ self._fontSizeAxis = 10
+ self._fontSizeTitle = 15
+ self._fontSizeLegend = 7
+ # pointLabels
+ self._pointLabelEnabled = False
+ self.last_PointLabel = None
+ self._pointLabelFunc = None
+ self.canvas.Bind(wx.EVT_LEAVE_WINDOW, self.OnLeave)
+ if sys.platform != "darwin":
+ self._logicalFunction = wx.EQUIV # (NOT src) XOR dst
+ else:
+ # wx.EQUIV not supported on Mac OS X
+ self._logicalFunction = wx.COPY
+ self._useScientificNotation = False
+ self._antiAliasingEnabled = False
+ self._hiResEnabled = False
+ self._fontScale = 1.0
+ self.canvas.Bind(wx.EVT_PAINT, self.OnPaint)
+ self.canvas.Bind(wx.EVT_SIZE, self.OnSize)
+ # OnSize called to make sure the buffer is initialized.
+ # This might result in OnSize getting called twice on some
+ # platforms at initialization, but little harm done.
+ self.OnSize(None) # sets the initial size based on client size
+ self._gridColour = wx.BLACK
+ if '__WXGTK__' in wx.PlatformInfo:
+ self.Bind(wx.EVT_WINDOW_CREATE, self.doSetWindowCreated)
+ else:
+ self.doSetWindowCreated(None)
+ def doSetWindowCreated(self, evt):
+ self._isWindowCreated = True
+ self.OnSize(None)
+ def SetCursor(self, cursor):
+ self.canvas.SetCursor(cursor)
+ def GetGridColour(self):
+ return self._gridColour
+ def SetGridColour(self, colour):
+ if isinstance(colour, wx.Colour):
+ self._gridColour = colour
+ else:
+ self._gridColour = wx.Colour(colour)
+ # SaveFile
+ def SaveFile(self, fileName=''):
+ """Saves the file to the type specified in the extension. If no file
+ name is specified a dialog box is provided. Returns True if sucessful,
+ otherwise False.
+ .bmp Save a Windows bitmap file.
+ .xbm Save an X bitmap file.
+ .xpm Save an XPM bitmap file.
+ .png Save a Portable Network Graphics file.
+ .jpg Save a Joint Photographic Experts Group file.
+ extensions = {
+ "bmp": wx.BITMAP_TYPE_BMP, # Save a Windows bitmap file.
+ "xbm": wx.BITMAP_TYPE_XBM, # Save an X bitmap file.
+ "xpm": wx.BITMAP_TYPE_XPM, # Save an XPM bitmap file.
+ "jpg": wx.BITMAP_TYPE_JPEG, # Save a JPG file.
+ "png": wx.BITMAP_TYPE_PNG, # Save a PNG file.
+ fType = _string.lower(fileName[-3:])
+ dlg1 = None
+ while fType not in extensions:
+ if dlg1: # FileDialog exists: Check for extension
+ dlg2 = wx.MessageDialog(self, 'File name extension\n'
+ 'must be one of\nbmp, xbm, xpm, png, or jpg',
+ 'File Name Error', wx.OK | wx.ICON_ERROR)
+ try:
+ dlg2.ShowModal()
+ finally:
+ dlg2.Destroy()
+ # FileDialog doesn't exist: just check one
+ else:
+ dlg1 = wx.FileDialog(
+ self,
+ "Choose a file with extension bmp, gif, xbm, xpm, png, or jpg", ".", "",
+ "BMP files (*.bmp)|*.bmp|XBM files (*.xbm)|*.xbm|XPM file (*.xpm)|*.xpm|PNG files (*.png)|*.png|JPG files (*.jpg)|*.jpg",
+ wx.SAVE | wx.OVERWRITE_PROMPT
+ if dlg1.ShowModal() == wx.ID_OK:
+ fileName = dlg1.GetPath()
+ else: # exit without saving
+ dlg1.Destroy()
+ return False
+ if dlg1:
+ dlg1.Destroy()
+ # Save Bitmap
+ res = self._Buffer.SaveFile(fileName, extensions[fType])
+ return res
+ @property
+ def print_data(self):
+ if not self._print_data:
+ self._print_data = wx.PrintData()
+ self._print_data.SetPaperId(wx.PAPER_LETTER)
+ self._print_data.SetOrientation(wx.LANDSCAPE)
+ return self._print_data
+ @property
+ def pageSetupData(self):
+ if not self._pageSetupData:
+ self._pageSetupData = wx.PageSetupDialogData()
+ self._pageSetupData.SetMarginBottomRight((25, 25))
+ self._pageSetupData.SetMarginTopLeft((25, 25))
+ self._pageSetupData.SetPrintData(self.print_data)
+ return self._pageSetupData
+ def PageSetup(self):
+ """Brings up the page setup dialog"""
+ data = self.pageSetupData
+ data.SetPrintData(self.print_data)
+ dlg = wx.PageSetupDialog(self.parent, data)
+ try:
+ if dlg.ShowModal() == wx.ID_OK:
+ data = dlg.GetPageSetupData() # returns wx.PageSetupDialogData
+ # updates page parameters from dialog
+ self.pageSetupData.SetMarginBottomRight(
+ data.GetMarginBottomRight())
+ self.pageSetupData.SetMarginTopLeft(data.GetMarginTopLeft())
+ self.pageSetupData.SetPrintData(data.GetPrintData())
+ data.GetPrintData()) # updates print_data
+ finally:
+ dlg.Destroy()
+ def Printout(self, paper=None):
+ """Print current plot."""
+ if paper != None:
+ self.print_data.SetPaperId(paper)
+ pdd = wx.PrintDialogData(self.print_data)
+ printer = wx.Printer(pdd)
+ out = PlotPrintout(self)
+ print_ok = printer.Print(self.parent, out)
+ if print_ok:
+ printer.GetPrintDialogData().GetPrintData())
+ out.Destroy()
+ def PrintPreview(self):
+ """Print-preview current plot."""
+ printout = PlotPrintout(self)
+ printout2 = PlotPrintout(self)
+ self.preview = wx.PrintPreview(printout, printout2, self.print_data)
+ if not self.preview.IsOk():
+ wx.MessageDialog(self, "Print Preview failed.\n"
+ "Check that default printer is configured\n",
+ "Print error", wx.OK | wx.CENTRE).ShowModal()
+ self.preview.SetZoom(40)
+ # search up tree to find frame instance
+ frameInst = self
+ while not isinstance(frameInst, wx.Frame):
+ frameInst = frameInst.GetParent()
+ frame = wx.PreviewFrame(self.preview, frameInst, "Preview")
+ frame.Initialize()
+ frame.SetPosition(self.GetPosition())
+ frame.SetSize((600, 550))
+ frame.Centre(wx.BOTH)
+ frame.Show(True)
+ raise TypeError(
+ if self.last_draw is not None:
+ graphics, xAxis, yAxis = self.last_draw
+ graphics.setLogScale(logscale)
+ self.last_draw = (graphics, None, None)
+ self.SetXSpec('min')
+ self.SetYSpec('min')
+ def getLogScale(self):
+ return self._logscale
+ def SetFontSizeAxis(self, point=10):
+ """Set the tick and axis label font size (default is 10 point)"""
+ self._fontSizeAxis = point
+ def GetFontSizeAxis(self):
+ """Get current tick and axis label font size in points"""
+ return self._fontSizeAxis
+ def SetFontSizeTitle(self, point=15):
+ """Set Title font size (default is 15 point)"""
+ self._fontSizeTitle = point
+ def GetFontSizeTitle(self):
+ """Get current Title font size in points"""
+ return self._fontSizeTitle
+ def SetFontSizeLegend(self, point=7):
+ """Set Legend font size (default is 7 point)"""
+ self._fontSizeLegend = point
+ def GetFontSizeLegend(self):
+ """Get current Legend font size in points"""
+ return self._fontSizeLegend
+ def SetShowScrollbars(self, value):
+ """Set True to show scrollbars"""
+ if value not in [True, False]:
+ raise TypeError("Value should be True or False")
+ if value == self.GetShowScrollbars():
+ return
+ self.sb_vert.Show(value)
+ self.sb_hor.Show(value)
+ wx.CallAfter(self.Layout)
+ def GetShowScrollbars(self):
+ return self.sb_vert.IsShown()
+ def SetUseScientificNotation(self, useScientificNotation):
+ self._useScientificNotation = useScientificNotation
+ def GetUseScientificNotation(self):
+ return self._useScientificNotation
+ def SetEnableAntiAliasing(self, enableAntiAliasing):
+ """Set True to enable anti-aliasing."""
+ self._antiAliasingEnabled = enableAntiAliasing
+ self.Redraw()
+ def GetEnableAntiAliasing(self):
+ return self._antiAliasingEnabled
+ def SetEnableHiRes(self, enableHiRes):
+ """Set True to enable high-resolution mode when using anti-aliasing."""
+ self._hiResEnabled = enableHiRes
+ self.Redraw()
+ def GetEnableHiRes(self):
+ return self._hiResEnabled
+ def SetEnableDrag(self, value):
+ """Set True to enable drag."""
+ if value:
+ if self.GetEnableZoom():
+ self.SetEnableZoom(False)
+ self.SetCursor(self.HandCursor)
+ else:
+ self.SetCursor(wx.CROSS_CURSOR)
+ self._dragEnabled = value
+ def GetEnableDrag(self):
+ return self._dragEnabled
+ def SetEnableZoom(self, value):
+ """Set True to enable zooming."""
+ if value:
+ if self.GetEnableDrag():
+ self.SetEnableDrag(False)
+ self.SetCursor(self.MagCursor)
+ else:
+ self._zoomEnabled = value
+ def GetEnableZoom(self):
+ """True if zooming enabled."""
+ return self._zoomEnabled
+ def SetEnableGrid(self, value):
+ """Set True, 'Horizontal' or 'Vertical' to enable grid."""
+ if value not in [True, False, 'Horizontal', 'Vertical']:
+ raise TypeError(
+ "Value should be True, False, Horizontal or Vertical")
+ self._gridEnabled = value
+ self.Redraw()
+ def GetEnableGrid(self):
+ """True if grid enabled."""
+ return self._gridEnabled
+ def SetEnableCenterLines(self, value):
+ """Set True, 'Horizontal' or 'Vertical' to enable center line(s)."""
+ raise TypeError(
+ self._centerLinesEnabled = value
+ self.Redraw()
+ def GetEnableCenterLines(self):
+ return self._centerLinesEnabled
+ def SetEnableDiagonals(self, value):
+ """Set True, 'Bottomleft-Topright' or 'Bottomright-Topleft' to enable
+ center line(s)."""
+ if value not in [True, False, 'Bottomleft-Topright', 'Bottomright-Topleft']:
+ raise TypeError(
+ "Value should be True, False, Bottomleft-Topright or Bottomright-Topleft")
+ self._diagonalsEnabled = value
+ self.Redraw()
+ def GetEnableDiagonals(self):
+ return self._diagonalsEnabled
+ def SetEnableLegend(self, value):
+ """Set True to enable legend."""
+ self._legendEnabled = value
+ self.Redraw()
+ def GetEnableLegend(self):
+ """True if Legend enabled."""
+ return self._legendEnabled
+ def SetEnableTitle(self, value):
+ """Set True to enable title."""
+ self._titleEnabled = value
+ self.Redraw()
+ def GetEnableTitle(self):
+ """True if title enabled."""
+ return self._titleEnabled
+ def SetEnablePointLabel(self, value):
+ """Set True to enable pointLabel."""
+ self._pointLabelEnabled = value
+ self.Redraw() # will erase existing pointLabel if present
+ def GetEnablePointLabel(self):
+ """True if pointLabel enabled."""
+ return self._pointLabelEnabled
+ def SetPointLabelFunc(self, func):
+ """Sets the function with custom code for pointLabel drawing
+ ******** more info needed ***************
+ self._pointLabelFunc = func
+ def GetPointLabelFunc(self):
+ """Returns pointLabel Drawing Function"""
+ return self._pointLabelFunc
+ def Reset(self):
+ """Unzoom the plot."""
+ self.last_PointLabel = None # reset pointLabel
+ self._Draw(self.last_draw[0])
+ def ScrollRight(self, units):
+ """Move view right number of axis units."""
+ xAxis = (xAxis[0] + units, xAxis[1] + units)
+ self._Draw(graphics, xAxis, yAxis)
+ def ScrollUp(self, units):
+ """Move view up number of axis units."""
+ yAxis = (yAxis[0] + units, yAxis[1] + units)
+ def GetXY(self, event):
+ """Wrapper around _getXY, which handles log scales"""
+ x, y = self._getXY(event)
+ if self.getLogScale()[0]:
+ x = np.power(10, x)
+ if self.getLogScale()[1]:
+ y = np.power(10, y)
+ return x, y
+ def _getXY(self, event):
+ """Takes a mouse event and returns the XY user axis values."""
+ x, y = self.PositionScreenToUser(event.GetPosition())
+ return x, y
+ def PositionUserToScreen(self, pntXY):
+ """Converts User position to Screen Coordinates"""
+ userPos = np.array(pntXY)
+ x, y = userPos * self._pointScale + self._pointShift
+ return x, y
+ def PositionScreenToUser(self, pntXY):
+ """Converts Screen position to User Coordinates"""
+ screenPos = np.array(pntXY)
+ x, y = (screenPos - self._pointShift) / self._pointScale
+ return x, y
+ def SetXSpec(self, type='auto'):
+ """xSpec- defines x axis type. Can be 'none', 'min' or 'auto'
+ where:
+ * 'none' - shows no axis or tick mark values
+ * 'min' - shows min bounding box values
+ * 'auto' - rounds axis range to sensible values
+ * <number> - like 'min', but with <number> tick marks
+ self._xSpec = type
+ def SetYSpec(self, type='auto'):
+ """ySpec- defines x axis type. Can be 'none', 'min' or 'auto'
+ where:
+ self._ySpec = type
+ def GetXSpec(self):
+ """Returns current XSpec for axis"""
+ return self._xSpec
+ def GetYSpec(self):
+ """Returns current YSpec for axis"""
+ return self._ySpec
+ def GetXMaxRange(self):
+ xAxis = self._getXMaxRange()
+ xAxis = np.power(10, xAxis)
+ return xAxis
+ def _getXMaxRange(self):
+ """Returns (minX, maxX) x-axis range for displayed graph"""
+ graphics = self.last_draw[0]
+ p1, p2 = graphics.boundingBox() # min, max points of graphics
+ xAxis = self._axisInterval(self._xSpec, p1[0], p2[0]) # in user units
+ return xAxis
+ def GetYMaxRange(self):
+ yAxis = self._getYMaxRange()
+ yAxis = np.power(10, yAxis)
+ return yAxis
+ def _getYMaxRange(self):
+ """Returns (minY, maxY) y-axis range for displayed graph"""
+ yAxis = self._axisInterval(self._ySpec, p1[1], p2[1])
+ return yAxis
+ def GetXCurrentRange(self):
+ xAxis = self._getXCurrentRange()
+ return xAxis
+ def _getXCurrentRange(self):
+ """Returns (minX, maxX) x-axis for currently displayed portion of graph"""
+ return self.last_draw[1]
+ def GetYCurrentRange(self):
+ yAxis = self._getYCurrentRange()
+ return yAxis
+ def _getYCurrentRange(self):
+ """Returns (minY, maxY) y-axis for currently displayed portion of graph"""
+ return self.last_draw[2]
+ def Draw(self, graphics, xAxis=None, yAxis=None, dc=None):
+ """Wrapper around _Draw, which handles log axes"""
+ graphics.setLogScale(self.getLogScale())
+ # check Axis is either tuple or none
+ if type(xAxis) not in [type(None), tuple]:
+ raise TypeError(
+ "xAxis should be None or (minX,maxX)" + str(type(xAxis)))
+ if type(yAxis) not in [type(None), tuple]:
+ raise TypeError(
+ "yAxis should be None or (minY,maxY)" + str(type(xAxis)))
+ # check case for axis = (a,b) where a==b caused by improper zooms
+ if xAxis != None:
+ if xAxis[0] == xAxis[1]:
+ return
+ xAxis = np.log10(xAxis)
+ if yAxis != None:
+ if yAxis[0] == yAxis[1]:
+ return
+ yAxis = np.log10(yAxis)
+ self._Draw(graphics, xAxis, yAxis, dc)
+ def _Draw(self, graphics, xAxis=None, yAxis=None, dc=None):
+ Draw objects in graphics with specified x and y axis.
+ graphics- instance of PlotGraphics with list of PolyXXX objects
+ xAxis - tuple with (min, max) axis range to view
+ yAxis - same as xAxis
+ dc - drawing context - doesn't have to be specified.
+ If it's not, the offscreen buffer is used
+ if dc is None:
+ # sets new dc and clears it
+ dc = wx.BufferedDC(wx.ClientDC(self.canvas), self._Buffer)
+ bbr = wx.Brush(self.GetBackgroundColour(), wx.BRUSHSTYLE_SOLID)
+ dc.SetBackground(bbr)
+ dc.SetBackgroundMode(wx.SOLID)
+ dc.Clear()
+ if self._antiAliasingEnabled:
+ if not isinstance(dc, wx.GCDC):
+ try:
+ dc = wx.GCDC(dc)
+ except Exception:
+ pass
+ else:
+ if self._hiResEnabled:
+ # high precision - each logical unit is 1/20 of a point
+ dc.SetMapMode(wx.MM_TWIPS)
+ self._pointSize = tuple(
+ 1.0 / lscale for lscale in dc.GetLogicalScale())
+ self._setSize()
+ elif self._pointSize != (1.0, 1.0):
+ self._setSize()
+ if (sys.platform in ("darwin", "win32") or not isinstance(dc, wx.GCDC) or wx.VERSION >= (2, 9)):
+ self._fontScale = sum(self._pointSize) / 2.0
+ else:
+ # on Linux, we need to correct the font size by a certain factor if wx.GCDC is used,
+ # to make text the same size as if wx.GCDC weren't used
+ screenppi = map(float, wx.ScreenDC().GetPPI())
+ ppi = dc.GetPPI()
+ self._fontScale = (screenppi[
+ 0] / ppi[0] * self._pointSize[0] + screenppi[1] / ppi[1] * self._pointSize[1]) / 2.0
+ graphics._pointSize = self._pointSize
+ dc.SetTextForeground(self.GetForegroundColour())
+ dc.SetTextBackground(self.GetBackgroundColour())
+ # dc.Clear()
+ # set font size for every thing but title and legend
+ dc.SetFont(self._getFont(self._fontSizeAxis))
+ # sizes axis to axis type, create lower left and upper right corners of
+ # plot
+ if xAxis is None or yAxis is None:
+ # One or both axis not specified in Draw
+ if xAxis is None:
+ self._xSpec, p1[0], p2[0]) # in user units
+ if yAxis is None:
+ # Adjust bounding box for axis spec
+ # lower left corner user scale (xmin,ymin)
+ p1[0], p1[1] = xAxis[0], yAxis[0]
+ # upper right corner user scale (xmax,ymax)
+ p2[0], p2[1] = xAxis[1], yAxis[1]
+ else:
+ # Both axis specified in Draw
+ p1 = np.array([xAxis[0], yAxis[0]])
+ p2 = np.array([xAxis[1], yAxis[1]])
+ # saves most recient values
+ self.last_draw = (graphics, np.array(xAxis), np.array(yAxis))
+ # Get ticks and textExtents for axis if required
+ if self._xSpec is not 'none':
+ xticks = self._xticks(xAxis[0], xAxis[1])
+ else:
+ xticks = None
+ if xticks:
+ # w h of x axis text last number on axis
+ xTextExtent = dc.GetTextExtent(xticks[-1][1])
+ else:
+ xTextExtent = (0, 0) # No text for ticks
+ if self._ySpec is not 'none':
+ yticks = self._yticks(yAxis[0], yAxis[1])
+ else:
+ yticks = None
+ if yticks:
+ yTextExtent = dc.GetTextExtent('-2e-2')
+ else:
+ yTextExtentBottom = dc.GetTextExtent(yticks[0][1])
+ yTextExtentTop = dc.GetTextExtent(yticks[-1][1])
+ yTextExtent = (max(yTextExtentBottom[0], yTextExtentTop[0]),
+ max(yTextExtentBottom[1], yTextExtentTop[1]))
+ else:
+ yticks = None
+ yTextExtent = (0, 0) # No text for ticks
+ # TextExtents for Title and Axis Labels
+ titleWH, xLabelWH, yLabelWH = self._titleLablesWH(dc, graphics)
+ # TextExtents for Legend
+ legendBoxWH, legendSymExt, legendTextExt = self._legendWH(dc, graphics)
+ # room around graph area
+ # use larger of number width or legend width
+ rhsW = max(xTextExtent[0], legendBoxWH[0]) + 5 * self._pointSize[0]
+ lhsW = yTextExtent[0] + yLabelWH[1] + 3 * self._pointSize[0]
+ bottomH = max(
+ xTextExtent[1], yTextExtent[1] / 2.) + xLabelWH[1] + 2 * self._pointSize[1]
+ topH = yTextExtent[1] / 2. + titleWH[1]
+ # make plot area smaller by text size
+ textSize_scale = np.array([rhsW + lhsW, bottomH + topH])
+ # shift plot area by this amount
+ textSize_shift = np.array([lhsW, bottomH])
+ # draw title if requested
+ if self._titleEnabled:
+ dc.SetFont(self._getFont(self._fontSizeTitle))
+ titlePos = (self.plotbox_origin[0] + lhsW + (self.plotbox_size[0] - lhsW - rhsW) / 2. - titleWH[0] / 2.,
+ self.plotbox_origin[1] - self.plotbox_size[1])
+ dc.DrawText(graphics.getTitle(), titlePos[0], titlePos[1])
+ # draw label text
+ xLabelPos = (self.plotbox_origin[0] + lhsW + (self.plotbox_size[0] - lhsW - rhsW) / 2. - xLabelWH[0] / 2.,
+ self.plotbox_origin[1] - xLabelWH[1])
+ dc.DrawText(graphics.getXLabel(), xLabelPos[0], xLabelPos[1])
+ yLabelPos = (self.plotbox_origin[0] - 3 * self._pointSize[0],
+ self.plotbox_origin[1] - bottomH - (self.plotbox_size[1] - bottomH - topH) / 2. + yLabelWH[0] / 2.)
+ if graphics.getYLabel(): # bug fix for Linux
+ dc.DrawRotatedText(
+ graphics.getYLabel(), yLabelPos[0], yLabelPos[1], 90)
+ # drawing legend makers and text
+ if self._legendEnabled:
+ self._drawLegend(
+ dc, graphics, rhsW, topH, legendBoxWH, legendSymExt, legendTextExt)
+ # allow for scaling and shifting plotted points
+ scale = (self.plotbox_size - textSize_scale) / \
+ (p2 - p1) * np.array((1, -1))
+ shift = -p1 * scale + self.plotbox_origin + \
+ textSize_shift * np.array((1, -1))
+ # make available for mouse events
+ self._pointScale = scale / self._pointSize
+ self._pointShift = shift / self._pointSize
+ self._drawAxes(dc, p1, p2, scale, shift, xticks, yticks)
+ graphics.scaleAndShift(scale, shift)
+ # thicken up lines and markers if printing
+ graphics.setPrinterScale(self.printerScale)
+ # set clipping area so drawing does not occur outside axis box
+ ptx, pty, rectWidth, rectHeight = self._point2ClientCoord(p1, p2)
+ # allow graph to overlap axis lines by adding units to width and height
+ dc.SetClippingRegion(ptx * self._pointSize[0], pty * self._pointSize[
+ 1], rectWidth * self._pointSize[0] + 2, rectHeight * self._pointSize[1] + 1)
+ # Draw the lines and markers
+ #start = _time.clock()
+ graphics.draw(dc)
+ # print("entire graphics drawing took: %f second"%(_time.clock() - start))
+ # remove the clipping region
+ dc.DestroyClippingRegion()
+ self._adjustScrollbars()
+ def Redraw(self, dc=None):
+ """Redraw the existing plot."""
+ def Clear(self):
+ """Erase the window."""
+ bbr = wx.Brush(self.GetBackgroundColour(), wx.SOLID)
+ dc.Clear()
+ try:
+ dc = wx.GCDC(dc)
+ except Exception:
+ pass
+ def Zoom(self, Center, Ratio):
+ """ Zoom on the plot
+ Centers on the X,Y coords given in Center
+ Zooms by the Ratio = (Xratio, Yratio) given
+ self.last_PointLabel = None # reset maker
+ x, y = Center
+ if self.last_draw != None:
+ (graphics, xAxis, yAxis) = self.last_draw
+ w = (xAxis[1] - xAxis[0]) * Ratio[0]
+ h = (yAxis[1] - yAxis[0]) * Ratio[1]
+ xAxis = (x - w / 2, x + w / 2)
+ yAxis = (y - h / 2, y + h / 2)
+ def GetClosestPoints(self, pntXY, pointScaled=True):
+ """Returns list with
+ [curveNumber, legend, index of closest point, pointXY, scaledXY, distance]
+ list for each curve.
+ Returns [] if no curves are being plotted.
+ if self.last_draw is None:
+ # no graph available
+ return []
+ l = []
+ for curveNum, obj in enumerate(graphics):
+ # check there are points in the curve
+ if len(obj.points) == 0:
+ continue # go to next obj
+ #[curveNumber, legend, index of closest point, pointXY, scaledXY, distance]
+ cn = [curveNum] + \
+ [obj.getLegend()] + obj.getClosestPoint(pntXY, pointScaled)
+ l.append(cn)
+ return l
+ def GetClosestPoint(self, pntXY, pointScaled=True):
+ list for only the closest curve.
+ # closest points on screen based on screen scaling (pointScaled= True)
+ # list [curveNumber, index, pointXY, scaledXY, distance] for each curve
+ closestPts = self.GetClosestPoints(pntXY, pointScaled)
+ if closestPts == []:
+ return [] # no graph present
+ # find one with least distance
+ dists = [c[-1] for c in closestPts]
+ mdist = min(dists) # Min dist
+ i = dists.index(mdist) # index for min dist
+ return closestPts[i] # this is the closest point on closest curve
+ GetClosetPoint = GetClosestPoint
+ def UpdatePointLabel(self, mDataDict):
+ """Updates the pointLabel point on screen with data contained in
+ mDataDict.
+ mDataDict will be passed to your function set by
+ SetPointLabelFunc. It can contain anything you
+ want to display on the screen at the scaledXY point
+ you specify.
+ This function can be called from parent window with onClick,
+ onMotion events etc.
+ if self.last_PointLabel != None:
+ # compare pointXY
+ if np.sometrue(mDataDict["pointXY"] != self.last_PointLabel["pointXY"]):
+ # closest changed
+ self._drawPointLabel(self.last_PointLabel) # erase old
+ self._drawPointLabel(mDataDict) # plot new
+ else:
+ # just plot new with no erase
+ # save for next erase
+ self.last_PointLabel = mDataDict
+ # event handlers **********************************
+ def OnMotion(self, event):
+ if self._zoomEnabled and event.LeftIsDown():
+ if self._hasDragged:
+ self._drawRubberBand(
+ self._zoomCorner1, self._zoomCorner2) # remove old
+ else:
+ self._hasDragged = True
+ self._zoomCorner2[0], self._zoomCorner2[1] = self._getXY(event)
+ self._zoomCorner1, self._zoomCorner2) # add new
+ elif self._dragEnabled and event.LeftIsDown():
+ coordinates = event.GetPosition()
+ newpos, oldpos = map(np.array, map(
+ self.PositionScreenToUser, [coordinates, self._screenCoordinates]))
+ dist = newpos - oldpos
+ self._screenCoordinates = coordinates
+ yAxis -= dist[1]
+ xAxis -= dist[0]
+ def OnMouseLeftDown(self, event):
+ self._zoomCorner1[0], self._zoomCorner1[1] = self._getXY(event)
+ self._screenCoordinates = np.array(event.GetPosition())
+ if self._dragEnabled:
+ self.SetCursor(self.GrabHandCursor)
+ self.canvas.CaptureMouse()
+ def OnMouseLeftUp(self, event):
+ if self._zoomEnabled:
+ if self._hasDragged == True:
+ self._hasDragged = False # reset flag
+ minX, minY = np.minimum(self._zoomCorner1, self._zoomCorner2)
+ maxX, maxY = np.maximum(self._zoomCorner1, self._zoomCorner2)
+ self._Draw(
+ self.last_draw[0], xAxis=(minX, maxX), yAxis = (minY, maxY), dc = None)
+ # else: # A box has not been drawn, zoom in on a point
+ # this interfered with the double click, so I've disables it.
+ # X,Y = self._getXY(event)
+ # self.Zoom( (X,Y), (self._zoomInFactor,self._zoomInFactor) )
+ if self.canvas.HasCapture():
+ self.canvas.ReleaseMouse()
+ def OnMouseDoubleClick(self, event):
+ # Give a little time for the click to be totally finished
+ # before (possibly) removing the scrollbars and trigering
+ # size events, etc.
+ wx.CallLater(200, self.Reset)
+ def OnMouseRightDown(self, event):
+ X, Y = self._getXY(event)
+ self.Zoom((X, Y), (self._zoomOutFactor, self._zoomOutFactor))
+ def OnPaint(self, event):
+ # All that is needed here is to draw the buffer to screen
+ dc = wx.BufferedPaintDC(self.canvas, self._Buffer)
+ try:
+ dc = wx.GCDC(dc)
+ except Exception:
+ pass
+ def OnSize(self, event):
+ # The Buffer init is done here, to make sure the buffer is always
+ # the same size as the Window
+ Size = self.canvas.GetClientSize()
+ Size.width = max(1, Size.width)
+ Size.height = max(1, Size.height)
+ # Make new offscreen bitmap: this bitmap will always have the
+ # current drawing in it, so it can be used to save the image to
+ # a file, or whatever.
+ self._Buffer = wx.EmptyBitmap(Size.width, Size.height)
+ self._setSize()
+ if not self._isWindowCreated:
+ return
+ self.Clear()
+ else:
+ graphics, xSpec, ySpec = self.last_draw
+ self._Draw(graphics, xSpec, ySpec)
+ def OnLeave(self, event):
+ """Used to erase pointLabel when mouse outside window"""
+ def OnScroll(self, evt):
+ if not self._adjustingSB:
+ self._sb_ignore = True
+ sbpos = evt.GetPosition()
+ if evt.GetOrientation() == wx.VERTICAL:
+ fullrange, pagesize = self.sb_vert.GetRange(
+ ), self.sb_vert.GetPageSize()
+ sbpos = fullrange - pagesize - sbpos
+ dist = sbpos * self._sb_xunit - \
+ (self._getXCurrentRange()[0] - self._sb_xfullrange)
+ self.ScrollUp(dist)
+ if evt.GetOrientation() == wx.HORIZONTAL:
+ (self._getXCurrentRange()[0] - self._sb_xfullrange[0])
+ self.ScrollRight(dist)
+ # Private Methods **************************************************
+ def _setSize(self, width=None, height=None):
+ """DC width and height."""
+ if width is None:
+ (self.width, self.height) = self.canvas.GetClientSize()
+ else:
+ self.width, self.height = width, height
+ self.width *= self._pointSize[0] # high precision
+ self.height *= self._pointSize[1] # high precision
+ self.plotbox_size = 0.97 * np.array([self.width, self.height])
+ xo = 0.5 * (self.width - self.plotbox_size[0])
+ yo = self.height - 0.5 * (self.height - self.plotbox_size[1])
+ self.plotbox_origin = np.array([xo, yo])
+ def _setPrinterScale(self, scale):
+ """Used to thicken lines and increase marker size for print out."""
+ # line thickness on printer is very thin at 600 dot/in. Markers small
+ def _printDraw(self, printDC):
+ """Used for printing."""
+ self._Draw(graphics, xSpec, ySpec, printDC)
+ def _drawPointLabel(self, mDataDict):
+ """Draws and erases pointLabels"""
+ width = self._Buffer.GetWidth()
+ height = self._Buffer.GetHeight()
+ tmp_Buffer = wx.EmptyBitmap(width, height)
+ dcs = wx.MemoryDC()
+ dcs.SelectObject(tmp_Buffer)
+ dcs.Clear()
+ else:
+ tmp_Buffer = self._Buffer.GetSubBitmap((0, 0, width, height))
+ dcs = wx.MemoryDC(self._Buffer)
+ self._pointLabelFunc(dcs, mDataDict) # custom user pointLabel function
+ dc = wx.ClientDC(self.canvas)
+ dc = wx.BufferedDC(dc, self._Buffer)
+ # this will erase if called twice
+ dc.Blit(0, 0, width, height, dcs, 0, 0, self._logicalFunction)
+ if sys.platform == "darwin":
+ self._Buffer = tmp_Buffer
+ def _drawLegend(self, dc, graphics, rhsW, topH, legendBoxWH, legendSymExt, legendTextExt):
+ """Draws legend symbols and text"""
+ # top right hand corner of graph box is ref corner
+ trhc = self.plotbox_origin + \
+ (self.plotbox_size - [rhsW, topH]) * [1, -1]
+ # border space between legend sym and graph box
+ legendLHS = .091 * legendBoxWH[0]
+ # 1.1 used as space between lines
+ lineHeight = max(legendSymExt[1], legendTextExt[1]) * 1.1
+ dc.SetFont(self._getFont(self._fontSizeLegend))
+ for i in range(len(graphics)):
+ o = graphics[i]
+ s = i * lineHeight
+ if isinstance(o, PolyMarker):
+ # draw marker with legend
+ pnt = (trhc[0] + legendLHS + legendSymExt[0] / 2.,
+ trhc[1] + s + lineHeight / 2.)
+ o.draw(dc, self.printerScale, coord=np.array([pnt]))
+ elif isinstance(o, PolyLine):
+ # draw line with legend
+ pnt1 = (trhc[0] + legendLHS, trhc[1] + s + lineHeight / 2.)
+ pnt2 = (trhc[0] + legendLHS + legendSymExt[0],
+ o.draw(dc, self.printerScale, coord=np.array([pnt1, pnt2]))
+ else:
+ raise TypeError(
+ "object is neither PolyMarker or PolyLine instance")
+ # draw legend txt
+ pnt = (trhc[0] + legendLHS + legendSymExt[0] + 5 * self._pointSize[0],
+ trhc[1] + s + lineHeight / 2. - legendTextExt[1] / 2)
+ dc.DrawText(o.getLegend(), pnt[0], pnt[1])
+ dc.SetFont(self._getFont(self._fontSizeAxis)) # reset
+ def _titleLablesWH(self, dc, graphics):
+ """Draws Title and labels and returns width and height for each"""
+ title = graphics.getTitle()
+ titleWH = dc.GetTextExtent(title)
+ else:
+ titleWH = (0, 0)
+ xLabel, yLabel = graphics.getXLabel(), graphics.getYLabel()
+ xLabelWH = dc.GetTextExtent(xLabel)
+ yLabelWH = dc.GetTextExtent(yLabel)
+ return titleWH, xLabelWH, yLabelWH
+ def _legendWH(self, dc, graphics):
+ """Returns the size in screen units for legend box"""
+ if self._legendEnabled != True:
+ legendBoxWH = symExt = txtExt = (0, 0)
+ else:
+ # find max symbol size
+ symExt = graphics.getSymExtent(self.printerScale)
+ # find max legend text extent
+ txtList = graphics.getLegendNames()
+ txtExt = dc.GetTextExtent(txtList[0])
+ for txt in graphics.getLegendNames()[1:]:
+ txtExt = np.maximum(txtExt, dc.GetTextExtent(txt))
+ maxW = symExt[0] + txtExt[0]
+ maxH = max(symExt[1], txtExt[1])
+ # padding .1 for lhs of legend box and space between lines
+ maxW = maxW * 1.1
+ maxH = maxH * 1.1 * len(txtList)
+ legendBoxWH = (maxW, maxH)
+ return (legendBoxWH, symExt, txtExt)
+ def _drawRubberBand(self, corner1, corner2):
+ """Draws/erases rect box from corner1 to corner2"""
+ corner1, corner2)
+ # draw rectangle
+ dc.SetPen(wx.Pen(wx.BLACK))
+ dc.SetBrush(wx.Brush(wx.WHITE, wx.BRUSHSTYLE_TRANSPARENT))
+ dc.SetLogicalFunction(wx.INVERT)
+ dc.DrawRectangle(ptx, pty, rectWidth, rectHeight)
+ dc.SetLogicalFunction(wx.COPY)
+ def _getFont(self, size):
+ """Take font size, adjusts if printing and returns wx.Font"""
+ s = size * self.printerScale * self._fontScale
+ of = self.GetFont()
+ # Linux speed up to get font from cache rather than X font server
+ key = (int(s), of.GetFamily(), of.GetStyle(), of.GetWeight())
+ font = self._fontCache.get(key, None)
+ if font:
+ return font # yeah! cache hit
+ else:
+ font = wx.Font(
+ int(s), of.GetFamily(), of.GetStyle(), of.GetWeight())
+ self._fontCache[key] = font
+ return font
+ def _point2ClientCoord(self, corner1, corner2):
+ """Converts user point coords to client screen int coords x,y,width,height"""
+ c1 = np.array(corner1)
+ c2 = np.array(corner2)
+ # convert to screen coords
+ pt1 = c1 * self._pointScale + self._pointShift
+ pt2 = c2 * self._pointScale + self._pointShift
+ # make height and width positive
+ pul = np.minimum(pt1, pt2) # Upper left corner
+ plr = np.maximum(pt1, pt2) # Lower right corner
+ rectWidth, rectHeight = plr - pul
+ ptx, pty = pul
+ return ptx, pty, rectWidth, rectHeight
+ def _axisInterval(self, spec, lower, upper):
+ """Returns sensible axis range for given spec"""
+ if spec == 'none' or spec == 'min' or isinstance(spec, (float, int)):
+ if lower == upper:
+ return lower - 0.5, upper + 0.5
+ else:
+ return lower, upper
+ elif spec == 'auto':
+ range = upper - lower
+ if range == 0.:
+ log = np.log10(range)
+ power = np.floor(log)
+ fraction = log - power
+ if fraction <= 0.05:
+ power = power - 1
+ grid = 10. ** power
+ lower = lower - lower % grid
+ mod = upper % grid
+ if mod != 0:
+ upper = upper - mod + grid
+ elif type(spec) == type(()):
+ lower, upper = spec
+ if lower <= upper:
+ else:
+ return upper, lower
+ else:
+ raise ValueError(str(spec) + ': illegal axis specification')
+ def _drawAxes(self, dc, p1, p2, scale, shift, xticks, yticks):
+ # increases thickness for printing only
+ penWidth = self.printerScale * self._pointSize[0]
+ dc.SetPen(wx.Pen(self._gridColour, penWidth))
+ # set length of tick marks--long ones make grid
+ if self._gridEnabled:
+ x, y, width, height = self._point2ClientCoord(p1, p2)
+ if self._gridEnabled == 'Horizontal':
+ yTickLength = (width / 2.0 + 1) * self._pointSize[1]
+ xTickLength = 3 * self.printerScale * self._pointSize[0]
+ elif self._gridEnabled == 'Vertical':
+ yTickLength = 3 * self.printerScale * self._pointSize[1]
+ xTickLength = (height / 2.0 + 1) * self._pointSize[0]
+ else:
+ else:
+ # lengthens lines for printing
+ lower, upper = p1[0], p2[0]
+ text = 1
+ # miny, maxy and tick lengths
+ for y, d in [(p1[1], -xTickLength), (p2[1], xTickLength)]:
+ for x, label in xticks:
+ pt = scale * np.array([x, y]) + shift
+ # draws tick mark d units
+ dc.DrawLine(pt[0], pt[1], pt[0], pt[1] + d)
+ if text:
+ dc.DrawText(
+ label, pt[0], pt[1] + 2 * self._pointSize[1])
+ a1 = scale * np.array([lower, y]) + shift
+ a2 = scale * np.array([upper, y]) + shift
+ # draws upper and lower axis line
+ dc.DrawLine(a1[0], a1[1], a2[0], a2[1])
+ text = 0 # axis values not drawn on top side
+ lower, upper = p1[1], p2[1]
+ text = 1
+ h = dc.GetCharHeight()
+ for x, d in [(p1[0], -yTickLength), (p2[0], yTickLength)]:
+ for y, label in yticks:
+ dc.DrawLine(pt[0], pt[1], pt[0] - d, pt[1])
+ if text:
+ dc.DrawText(label, pt[0] - dc.GetTextExtent(label)[0] - 3 * self._pointSize[0],
+ pt[1] - 0.75 * h)
+ a1 = scale * np.array([x, lower]) + shift
+ a2 = scale * np.array([x, upper]) + shift
+ text = 0 # axis values not drawn on right side
+ if self._centerLinesEnabled:
+ if self._centerLinesEnabled in ('Horizontal', True):
+ y1 = scale[1] * p1[1] + shift[1]
+ y2 = scale[1] * p2[1] + shift[1]
+ y = (y1 - y2) / 2.0 + y2
+ dc.DrawLine(
+ scale[0] * p1[0] + shift[0], y, scale[0] * p2[0] + shift[0], y)
+ if self._centerLinesEnabled in ('Vertical', True):
+ x1 = scale[0] * p1[0] + shift[0]
+ x2 = scale[0] * p2[0] + shift[0]
+ x = (x1 - x2) / 2.0 + x2
+ dc.DrawLine(
+ x, scale[1] * p1[1] + shift[1], x, scale[1] * p2[1] + shift[1])
+ if self._diagonalsEnabled:
+ if self._diagonalsEnabled in ('Bottomleft-Topright', True):
+ dc.DrawLine(scale[0] * p1[0] + shift[0], scale[1] * p1[1] +
+ shift[1], scale[0] * p2[0] + shift[0], scale[1] * p2[1] + shift[1])
+ if self._diagonalsEnabled in ('Bottomright-Topleft', True):
+ dc.DrawLine(scale[0] * p1[0] + shift[0], scale[1] * p2[1] +
+ shift[1], scale[0] * p2[0] + shift[0], scale[1] * p1[1] + shift[1])
+ def _xticks(self, *args):
+ return self._logticks(*args)
+ else:
+ attr = {'numticks': self._xSpec}
+ return self._ticks(*args, **attr)
+ def _yticks(self, *args):
+ else:
+ attr = {'numticks': self._ySpec}
+ def _logticks(self, lower, upper):
+ #lower,upper = map(np.log10,[lower,upper])
+ # print('logticks',lower,upper)
+ ticks = []
+ mag = np.power(10, np.floor(lower))
+ if upper - lower > 6:
+ t = np.power(10, np.ceil(lower))
+ base = np.power(10, np.floor((upper - lower) / 6))
+ def inc(t):
+ return t * base - t
+ else:
+ t = np.ceil(np.power(10, lower) / mag) * mag
+ def inc(t):
+ return 10 ** int(np.floor(np.log10(t) + 1e-16))
+ majortick = int(np.log10(mag))
+ while t <= pow(10, upper):
+ if majortick != int(np.floor(np.log10(t) + 1e-16)):
+ majortick = int(np.floor(np.log10(t) + 1e-16))
+ ticklabel = '1e%d' % majortick
+ else:
+ if upper - lower < 2:
+ minortick = int(t / pow(10, majortick) + .5)
+ ticklabel = '%de%d' % (minortick, majortick)
+ else:
+ ticklabel = ''
+ ticks.append((np.log10(t), ticklabel))
+ t += inc(t)
+ if len(ticks) == 0:
+ ticks = [(0, '')]
+ return ticks
+ def _ticks(self, lower, upper, numticks=None):
+ if isinstance(numticks, (float, int)):
+ ideal = (upper - lower) / float(numticks)
+ else:
+ ideal = (upper - lower) / 7.
+ log = np.log10(ideal)
+ grid = ideal
+ else:
+ factor = 1.
+ error = fraction
+ for f, lf in self._multiples:
+ e = np.fabs(fraction - lf)
+ if e < error:
+ error = e
+ factor = f
+ grid = factor * 10. ** power
+ if self._useScientificNotation and (power > 4 or power < -4):
+ format = '%+7.1e'
+ elif power >= 0:
+ digits = max(1, int(power))
+ format = '%' + repr(digits) + '.0f'
+ else:
+ digits = -int(power)
+ format = '%' + repr(digits + 2) + '.' + repr(digits) + 'f'
+ ticks = []
+ t = -grid * np.floor(-lower / grid)
+ while t <= upper:
+ if t == -0:
+ t = 0
+ ticks.append((t, format % (t,)))
+ t = t + grid
+ return ticks
+ _multiples = [(2., np.log10(2.)), (5., np.log10(5.))]
+ def _adjustScrollbars(self):
+ if self._sb_ignore:
+ return
+ if not self.GetShowScrollbars():
+ return
+ self._adjustingSB = True
+ needScrollbars = False
+ # horizontal scrollbar
+ r_current = self._getXCurrentRange()
+ r_max = list(self._getXMaxRange())
+ sbfullrange = float(self.sb_hor.GetRange())
+ r_max[0] = min(r_max[0], r_current[0])
+ r_max[1] = max(r_max[1], r_current[1])
+ self._sb_xfullrange = r_max
+ unit = (r_max[1] - r_max[0]) / float(self.sb_hor.GetRange())
+ pos = int((r_current[0] - r_max[0]) / unit)
+ if pos >= 0:
+ pagesize = int((r_current[1] - r_current[0]) / unit)
+ self.sb_hor.SetScrollbar(pos, pagesize, sbfullrange, pagesize)
+ self._sb_xunit = unit
+ needScrollbars = needScrollbars or (pagesize != sbfullrange)
+ else:
+ # vertical scrollbar
+ r_current = self._getYCurrentRange()
+ r_max = list(self._getYMaxRange())
+ sbfullrange = float(self.sb_vert.GetRange())
+ self._sb_yfullrange = r_max
+ unit = (r_max[1] - r_max[0]) / sbfullrange
+ if pos >= 0:
+ pos = (sbfullrange - 1 - pos - pagesize)
+ self.sb_vert.SetScrollbar(pos, pagesize, sbfullrange, pagesize)
+ self._sb_yunit = unit
+ else:
+ self.SetShowScrollbars(needScrollbars)
+# Used to layout the printer page
+class PlotPrintout(wx.Printout):
+ """Controls how the plot is made in printing and previewing"""
+ # Do not change method names in this class,
+ # we have to override wx.Printout methods here!
+ def __init__(self, graph):
+ """graph is instance of plotCanvas to be printed or previewed"""
+ wx.Printout.__init__(self)
+ self.graph = graph
+ def HasPage(self, page):
+ if page == 1:
+ return True
+ else:
+ return False
+ def GetPageInfo(self):
+ return (1, 1, 1, 1) # disable page numbers
+ def OnPrintPage(self, page):
+ dc = self.GetDC() # allows using floats for certain functions
+## print("PPI Printer",self.GetPPIPrinter())
+## print("PPI Screen", self.GetPPIScreen())
+## print("DC GetSize", dc.GetSize())
+## print("GetPageSizePixels", self.GetPageSizePixels())
+ # Note PPIScreen does not give the correct number
+ # Calulate everything for printer and then scale for preview
+ PPIPrinter = self.GetPPIPrinter() # printer dots/inch (w,h)
+ # PPIScreen= self.GetPPIScreen() # screen dots/inch (w,h)
+ dcSize = dc.GetSize() # DC size
+ if self.graph._antiAliasingEnabled and not isinstance(dc, wx.GCDC):
+ try:
+ dc = wx.GCDC(dc)
+ except Exception:
+ pass
+ else:
+ if self.graph._hiResEnabled:
+ pageSize = self.GetPageSizePixels() # page size in terms of pixcels
+ clientDcSize = self.graph.GetClientSize()
+ # find what the margins are (mm)
+ margLeftSize, margTopSize = self.graph.pageSetupData.GetMarginTopLeft()
+ margRightSize, margBottomSize = self.graph.pageSetupData.GetMarginBottomRight()
+ # calculate offset and scale for dc
+ pixLeft = margLeftSize * PPIPrinter[0] / 25.4 # mm*(dots/in)/(mm/in)
+ pixRight = margRightSize * PPIPrinter[0] / 25.4
+ pixTop = margTopSize * PPIPrinter[1] / 25.4
+ pixBottom = margBottomSize * PPIPrinter[1] / 25.4
+ plotAreaW = pageSize[0] - (pixLeft + pixRight)
+ plotAreaH = pageSize[1] - (pixTop + pixBottom)
+ # ratio offset and scale to screen size if preview
+ if self.IsPreview():
+ ratioW = float(dcSize[0]) / pageSize[0]
+ ratioH = float(dcSize[1]) / pageSize[1]
+ pixLeft *= ratioW
+ pixTop *= ratioH
+ plotAreaW *= ratioW
+ plotAreaH *= ratioH
+ # rescale plot to page or preview plot area
+ self.graph._setSize(plotAreaW, plotAreaH)
+ # Set offset and scale
+ dc.SetDeviceOrigin(pixLeft, pixTop)
+ # Thicken up pens and increase marker size for printing
+ ratioW = float(plotAreaW) / clientDcSize[0]
+ ratioH = float(plotAreaH) / clientDcSize[1]
+ aveScale = (ratioW + ratioH) / 2
+ if self.graph._antiAliasingEnabled and not self.IsPreview():
+ scale = dc.GetUserScale()
+ dc.SetUserScale(
+ scale[0] / self.graph._pointSize[0], scale[1] / self.graph._pointSize[1])
+ self.graph._setPrinterScale(aveScale) # tickens up pens for printing
+ self.graph._printDraw(dc)
+ # rescale back to original
+ self.graph._setSize()
+ self.graph._setPrinterScale(1)
+ self.graph.Redraw() # to get point label scale and shift correct
+ return True
+from wx.lib.embeddedimage import PyEmbeddedImage
+MagPlus = PyEmbeddedImage(
+ "iVBORw0KGgoAAAANSUhEUgAAABgAAAAYCAYAAADgdz34AAAABHNCSVQICAgIfAhkiAAAAOFJ"
+ "REFUeJy1VdEOxCAIo27//8XbuKfuPASGZ0Zisoi2FJABbZM3bY8c13lo5GvbjioBPAUEB0Yc"
+ "VZ0iGRRc56Ee8DcikEgrJD8EFpzRegQASiRtBtzuA0hrdRPYQxaEKyJPG6IHyiK3xnNZvUSS"
+ "NvUuzgYh0il4y14nCFPk5XgmNbRbQbVotGo9msj47G3UXJ7fuz8Q8FAGEu0/PbZh2D3NoshU"
+ "1VUydBGVZKMimlGeErdNGUmf/x7YpjMjcf8HVYvS2adr6aFVlCy/5Ijk9q8SeCR9isJR8SeJ"
+ "8pv7S0Wu2Acr0qdj3w7DRAAAAABJRU5ErkJggg==")
+GrabHand = PyEmbeddedImage(
+ "iVBORw0KGgoAAAANSUhEUgAAABgAAAAYCAYAAADgdz34AAAABHNCSVQICAgIfAhkiAAAARFJ"
+ "REFUeJy1VdESgzAIS2j//4s3s5fRQ6Rad5M7H0oxCZhWSpK1TjwUBCBJAIBItL1fijlfe1yJ"
+ "8noCGC9KgrXO7f0SyZEDAF/H2opsAHv9V/548nplT5Jo7YAFQKQ1RMWzmHUS96suqdBrHkuV"
+ "uxpdJjCS8CfGXWdJ2glzcquKSR5c46QOtCpgNyIHj6oieAXg3282QvMX45hy8a8H0VonJZUO"
+ "clesjOPg/dhBTq64o1Kacz4Ri2x5RKsf8+wcWQaJJL+A+xRcZHeQeBKjK+5EFiVJ4xy4x2Mn"
+ "1Vk4U5/DWmfPieiqbye7a3tV/cCsWKu76K76KUFFchVnhigJ/hmktelm/m3e3b8k+Ec8PqLH"
+ "CT4JRfyK9o1xYwAAAABJRU5ErkJggg==")
+Hand = PyEmbeddedImage(
+ "iVBORw0KGgoAAAANSUhEUgAAABgAAAAYCAYAAADgdz34AAAABHNCSVQICAgIfAhkiAAAARBJ"
+ "REFUeJytluECwiAIhDn1/Z942/UnjCGoq+6XNeWDC1xAqbKr6zyo61Ibds60J8GBT0yS3IEM"
+ "ABuIpJTa4IOLiAAQksuKyixLH1ShHgTgZl8KiALxOsODPoEMkgJ25Su6zoO3ZrjRnI96OLIq"
+ "k7dsqOCboDa4XV/nwQEQVeFtmMnvbSJja+oagKBUaLn9hzd7VipRa9ostIv0O1uhzzaqNJxk"
+ "hViwDVxqg51kksMg9r2rDDIFwHCap130FBhdMzeAfWg//6Ki5WWQrHSv6EIUeVs0g3wT3J7r"
+ "FmWQp/JJDXeRh2TXcJa91zAH2uN2mvXFsrIrsjS8rnftWmWfAiLIStuD9m9h9belvzgS/1fP"
+ "X7075IwDENteAAAAAElFTkSuQmCC")
+# if running standalone...
+# ...a sample implementation using the above
+def _draw1Objects():
+ # 100 points sin function, plotted as green circles
+ data1 = 2. * np.pi * np.arange(200) / 200.
+ data1.shape = (100, 2)
+ data1[:, 1] = np.sin(data1[:, 0])
+ markers1 = PolyMarker(
+ data1, legend='Green Markers', colour='green', marker='circle', size=1)
+ # 50 points cos function, plotted as red line
+ data1 = 2. * np.pi * np.arange(100) / 100.
+ data1.shape = (50, 2)
+ data1[:, 1] = np.cos(data1[:, 0])
+ lines = PolySpline(data1, legend='Red Line', colour='red')
+ # A few more points...
+ pi = np.pi
+ markers2 = PolyMarker([(0., 0.), (pi / 4., 1.), (pi / 2, 0.),
+ (3. * pi / 4., -1)], legend='Cross Legend', colour='blue',
+ marker='cross')
+ return PlotGraphics([markers1, lines, markers2], "Graph Title", "X Axis", "Y Axis")
+def _draw2Objects():
+ # 100 points sin function, plotted as green dots
+ line1 = PolySpline(
+ data1, legend='Green Line', colour='green', width=6, style=wx.PENSTYLE_DOT)
+ # 50 points cos function, plotted as red dot-dash
+ line2 = PolySpline(
+ data1, legend='Red Line', colour='red', width=3, style=wx.PENSTYLE_DOT_DASH)
+ pi = np.pi
+ markers1 = PolyMarker([(0., 0.), (pi / 4., 1.), (pi / 2, 0.),
+ (3. * pi / 4., -1)], legend='Cross Hatch Square', colour='blue', width=3, size=6,
+ fillcolour='red', fillstyle=wx.CROSSDIAG_HATCH,
+ marker='square')
+ return PlotGraphics([markers1, line1, line2], "Big Markers with Different Line Styles")
+def _draw3Objects():
+ markerList = ['circle', 'dot', 'square', 'triangle', 'triangle_down',
+ 'cross', 'plus', 'circle']
+ m = []
+ for i in range(len(markerList)):
+ m.append(PolyMarker([(2 * i + .5, i + .5)], legend=markerList[i], colour='blue',
+ marker=markerList[i]))
+ return PlotGraphics(m, "Selection of Markers", "Minimal Axis", "No Axis")
+def _draw4Objects():
+ # 25,000 point line
+ data1 = np.arange(5e5, 1e6, 10)
+ data1.shape = (25000, 2)
+ line1 = PolyLine(data1, legend='Wide Line', colour='green', width=5)
+ markers2 = PolyMarker(data1, legend='Square', colour='blue',
+ marker='square')
+ return PlotGraphics([line1, markers2], "25,000 Points", "Value X", "")
+def _draw5Objects():
+ # Empty graph with axis defined but no points/lines
+ points = []
+ line1 = PolyLine(points, legend='Wide Line', colour='green', width=5)
+ return PlotGraphics([line1], "Empty Plot With Just Axes", "Value X", "Value Y")
+def _draw6Objects():
+ # Bar graph
+ points1 = [(1, 0), (1, 10)]
+ line1 = PolyLine(points1, colour='green', legend='Feb.', width=10)
+ points1g = [(2, 0), (2, 4)]
+ line1g = PolyLine(points1g, colour='red', legend='Mar.', width=10)
+ points1b = [(3, 0), (3, 6)]
+ line1b = PolyLine(points1b, colour='blue', legend='Apr.', width=10)
+ points2 = [(4, 0), (4, 12)]
+ line2 = PolyLine(points2, colour='Yellow', legend='May', width=10)
+ points2g = [(5, 0), (5, 8)]
+ line2g = PolyLine(points2g, colour='orange', legend='June', width=10)
+ points2b = [(6, 0), (6, 4)]
+ line2b = PolyLine(points2b, colour='brown', legend='July', width=10)
+ return PlotGraphics([line1, line1g, line1b, line2, line2g, line2b],
+ "Bar Graph - (Turn on Grid, Legend)", "Months", "Number of Students")
+def _draw7Objects():
+ x = np.arange(1, 1000, 1)
+ y1 = 4.5 * x ** 2
+ y2 = 2.2 * x ** 3
+ points1 = np.transpose([x, y1])
+ points2 = np.transpose([x, y2])
+ line1 = PolyLine(points1, legend='quadratic', colour='blue', width=1)
+ line2 = PolyLine(points2, legend='cubic', colour='red', width=1)
+ return PlotGraphics([line1, line2], "double log plot", "Value X", "Value Y")
+class TestFrame(wx.Frame):
+ def __init__(self, parent, id, title):
+ wx.Frame.__init__(self, parent, id, title,
+ wx.DefaultPosition, (600, 400))
+ # Now Create the menu bar and items
+ self.mainmenu = wx.MenuBar()
+ menu = wx.Menu()
+ menu.Append(200, 'Page Setup...', 'Setup the printer page')
+ self.Bind(wx.EVT_MENU, self.OnFilePageSetup, id=200)
+ menu.Append(201, 'Print Preview...', 'Show the current plot on page')
+ self.Bind(wx.EVT_MENU, self.OnFilePrintPreview, id=201)
+ menu.Append(202, 'Print...', 'Print the current plot')
+ self.Bind(wx.EVT_MENU, self.OnFilePrint, id=202)
+ menu.Append(203, 'Save Plot...', 'Save current plot')
+ self.Bind(wx.EVT_MENU, self.OnSaveFile, id=203)
+ menu.Append(205, 'E&xit', 'Enough of this already!')
+ self.Bind(wx.EVT_MENU, self.OnFileExit, id=205)
+ self.mainmenu.Append(menu, '&File')
+ menu = wx.Menu()
+ menu.Append(206, 'Draw1', 'Draw plots1')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw1, id=206)
+ menu.Append(207, 'Draw2', 'Draw plots2')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw2, id=207)
+ menu.Append(208, 'Draw3', 'Draw plots3')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw3, id=208)
+ menu.Append(209, 'Draw4', 'Draw plots4')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw4, id=209)
+ menu.Append(210, 'Draw5', 'Draw plots5')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw5, id=210)
+ menu.Append(260, 'Draw6', 'Draw plots6')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw6, id=260)
+ menu.Append(261, 'Draw7', 'Draw plots7')
+ self.Bind(wx.EVT_MENU, self.OnPlotDraw7, id=261)
+ menu.Append(211, '&Redraw', 'Redraw plots')
+ self.Bind(wx.EVT_MENU, self.OnPlotRedraw, id=211)
+ menu.Append(212, '&Clear', 'Clear canvas')
+ self.Bind(wx.EVT_MENU, self.OnPlotClear, id=212)
+ menu.Append(213, '&Scale', 'Scale canvas')
+ self.Bind(wx.EVT_MENU, self.OnPlotScale, id=213)
+ menu.Append(
+ 214, 'Enable &Zoom', 'Enable Mouse Zoom', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableZoom, id=214)
+ menu.Append(215, 'Enable &Grid', 'Turn on Grid', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableGrid, id=215)
+ menu.Append(
+ 217, 'Enable &Drag', 'Activates dragging mode', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableDrag, id=217)
+ menu.Append(
+ 220, 'Enable &Legend', 'Turn on Legend', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableLegend, id=220)
+ menu.Append(
+ 222, 'Enable &Point Label', 'Show Closest Point', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnablePointLabel, id=222)
+ menu.Append(
+ 223, 'Enable &Anti-Aliasing', 'Smooth output', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableAntiAliasing, id=223)
+ menu.Append(224, 'Enable &High-Resolution AA',
+ 'Draw in higher resolution', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableHiRes, id=224)
+ menu.Append(
+ 226, 'Enable Center Lines', 'Draw center lines', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableCenterLines, id=226)
+ menu.Append(
+ 227, 'Enable Diagonal Lines', 'Draw diagonal lines', kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnEnableDiagonals, id=227)
+ menu.Append(
+ 231, 'Set Gray Background', 'Change background colour to gray')
+ self.Bind(wx.EVT_MENU, self.OnBackgroundGray, id=231)
+ menu.Append(
+ 232, 'Set &White Background', 'Change background colour to white')
+ self.Bind(wx.EVT_MENU, self.OnBackgroundWhite, id=232)
+ menu.Append(
+ 233, 'Set Red Label Text', 'Change label text colour to red')
+ self.Bind(wx.EVT_MENU, self.OnForegroundRed, id=233)
+ menu.Append(
+ 234, 'Set &Black Label Text', 'Change label text colour to black')
+ self.Bind(wx.EVT_MENU, self.OnForegroundBlack, id=234)
+ menu.Append(225, 'Scroll Up 1', 'Move View Up 1 Unit')
+ self.Bind(wx.EVT_MENU, self.OnScrUp, id=225)
+ menu.Append(230, 'Scroll Rt 2', 'Move View Right 2 Units')
+ self.Bind(wx.EVT_MENU, self.OnScrRt, id=230)
+ menu.Append(235, '&Plot Reset', 'Reset to original plot')
+ self.Bind(wx.EVT_MENU, self.OnReset, id=235)
+ self.mainmenu.Append(menu, '&Plot')
+ menu = wx.Menu()
+ menu.Append(300, '&About', 'About this thing...')
+ self.Bind(wx.EVT_MENU, self.OnHelpAbout, id=300)
+ self.mainmenu.Append(menu, '&Help')
+ self.SetMenuBar(self.mainmenu)
+ # A status bar to tell people what's happening
+ self.CreateStatusBar(1)
+ self.client = PlotCanvas(self)
+ # define the function for drawing pointLabels
+ self.client.SetPointLabelFunc(self.DrawPointLabel)
+ # Create mouse event for showing cursor coords in status bar
+ self.client.canvas.Bind(wx.EVT_LEFT_DOWN, self.OnMouseLeftDown)
+ # Show closest point when enabled
+ self.client.canvas.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.Show(True)
+ def DrawPointLabel(self, dc, mDataDict):
+ """This is the fuction that defines how the pointLabels are plotted
+ dc - DC that will be passed
+ mDataDict - Dictionary of data that you want to use for the pointLabel
+ As an example I have decided I want a box at the curve point
+ with some text information about the curve plotted below.
+ Any wxDC method can be used.
+ dc.SetBrush(wx.Brush(wx.BLACK, wx.BRUSHSTYLE_SOLID))
+ sx, sy = mDataDict["scaledXY"] # scaled x,y of closest point
+ # 10by10 square centered on point
+ dc.DrawRectangle(sx - 5, sy - 5, 10, 10)
+ px, py = mDataDict["pointXY"]
+ cNum = mDataDict["curveNum"]
+ pntIn = mDataDict["pIndex"]
+ legend = mDataDict["legend"]
+ # make a string to display
+ s = "Crv# %i, '%s', Pt. (%.2f,%.2f), PtInd %i" % (
+ cNum, legend, px, py, pntIn)
+ dc.DrawText(s, sx, sy + 1)
+ s = "Left Mouse Down at Point: (%.4f, %.4f)" % self.client._getXY(
+ event)
+ self.SetStatusText(s)
+ event.Skip() # allows plotCanvas OnMouseLeftDown to be called
+ # show closest point (when enbled)
+ if self.client.GetEnablePointLabel() == True:
+ # make up dict with info for the pointLabel
+ # I've decided to mark the closest point on the closest curve
+ dlst = self.client.GetClosestPoint(
+ self.client._getXY(event), pointScaled=True)
+ if dlst != []: # returns [] if none
+ curveNum, legend, pIndex, pointXY, scaledXY, distance = dlst
+ # make up dictionary to pass to my user function (see
+ # DrawPointLabel)
+ mDataDict = {"curveNum": curveNum, "legend": legend, "pIndex": pIndex,
+ "pointXY": pointXY, "scaledXY": scaledXY}
+ # pass dict to update the pointLabel
+ self.client.UpdatePointLabel(mDataDict)
+ event.Skip() # go to next handler
+ def OnFilePageSetup(self, event):
+ self.client.PageSetup()
+ def OnFilePrintPreview(self, event):
+ self.client.PrintPreview()
+ def OnFilePrint(self, event):
+ self.client.Printout()
+ def OnSaveFile(self, event):
+ self.client.SaveFile()
+ def OnFileExit(self, event):
+ self.Close()
+ def OnPlotDraw1(self, event):
+ self.resetDefaults()
+ self.client.Draw(_draw1Objects())
+ def OnPlotDraw2(self, event):
+ self.client.Draw(_draw2Objects())
+ def OnPlotDraw3(self, event):
+ self.client.SetFont(
+ wx.Font(10, wx.FONTFAMILY_SCRIPT, wx.FONTSTYLE_NORMAL, wx.FONTWEIGHT_NORMAL))
+ self.client.SetFontSizeAxis(20)
+ self.client.SetFontSizeLegend(12)
+ self.client.SetXSpec('min')
+ self.client.SetYSpec('none')
+ self.client.Draw(_draw3Objects())
+ def OnPlotDraw4(self, event):
+ drawObj = _draw4Objects()
+ self.client.Draw(drawObj)
+# profile
+## start = _time.clock()
+# for x in range(10):
+# self.client.Draw(drawObj)
+## print("10 plots of Draw4 took: %f sec."%(_time.clock() - start))
+# profile end
+ def OnPlotDraw5(self, event):
+ # Empty plot with just axes
+ drawObj = _draw5Objects()
+ # make the axis X= (0,5), Y=(0,10)
+ # (default with None is X= (-1,1), Y= (-1,1))
+ self.client.Draw(drawObj, xAxis=(0, 5), yAxis= (0, 10))
+ def OnPlotDraw6(self, event):
+ # Bar Graph Example
+ # self.client.SetEnableLegend(True) #turn on Legend
+ # self.client.SetEnableGrid(True) #turn on Grid
+ self.client.SetXSpec('none') # turns off x-axis scale
+ self.client.SetYSpec('auto')
+ self.client.Draw(_draw6Objects(), xAxis=(0, 7))
+ def OnPlotDraw7(self, event):
+ # log scale example
+ self.client.setLogScale((True, True))
+ self.client.Draw(_draw7Objects())
+ def OnPlotRedraw(self, event):
+ self.client.Redraw()
+ def OnPlotClear(self, event):
+ self.client.Clear()
+ def OnPlotScale(self, event):
+ if self.client.last_draw != None:
+ graphics, xAxis, yAxis = self.client.last_draw
+ self.client.Draw(graphics, (1, 3.05), (0, 1))
+ def OnEnableZoom(self, event):
+ self.client.SetEnableZoom(event.IsChecked())
+ self.mainmenu.Check(217, not event.IsChecked())
+ def OnEnableGrid(self, event):
+ self.client.SetEnableGrid(event.IsChecked())
+ def OnEnableDrag(self, event):
+ self.client.SetEnableDrag(event.IsChecked())
+ self.mainmenu.Check(214, not event.IsChecked())
+ def OnEnableLegend(self, event):
+ self.client.SetEnableLegend(event.IsChecked())
+ def OnEnablePointLabel(self, event):
+ self.client.SetEnablePointLabel(event.IsChecked())
+ def OnEnableAntiAliasing(self, event):
+ self.client.SetEnableAntiAliasing(event.IsChecked())
+ def OnEnableHiRes(self, event):
+ self.client.SetEnableHiRes(event.IsChecked())
+ def OnEnableCenterLines(self, event):
+ self.client.SetEnableCenterLines(event.IsChecked())
+ def OnEnableDiagonals(self, event):
+ self.client.SetEnableDiagonals(event.IsChecked())
+ def OnBackgroundGray(self, event):
+ self.client.SetBackgroundColour("#CCCCCC")
+ def OnBackgroundWhite(self, event):
+ self.client.SetBackgroundColour("white")
+ def OnForegroundRed(self, event):
+ self.client.SetForegroundColour("red")
+ def OnForegroundBlack(self, event):
+ self.client.SetForegroundColour("black")
+ def OnScrUp(self, event):
+ self.client.ScrollUp(1)
+ def OnScrRt(self, event):
+ self.client.ScrollRight(2)
+ def OnReset(self, event):
+ self.client.Reset()
+ def OnHelpAbout(self, event):
+ from wx.lib.dialogs import ScrolledMessageDialog
+ about = ScrolledMessageDialog(self, __doc__, "About...")
+ about.ShowModal()
+ def resetDefaults(self):
+ """Just to reset the fonts back to the PlotCanvas defaults"""
+ wx.Font(10, wx.FONTFAMILY_SWISS, wx.FONTSTYLE_NORMAL, wx.FONTWEIGHT_NORMAL))
+ self.client.SetFontSizeAxis(10)
+ self.client.SetFontSizeLegend(7)
+ self.client.setLogScale((False, False))
+ self.client.SetXSpec('auto')
+def __test():
+ class MyApp(wx.App):
+ def OnInit(self):
+ wx.InitAllImageHandlers()
+ frame = TestFrame(None, -1, "PlotCanvas")
+ # frame.Show(True)
+ self.SetTopWindow(frame)
+ return True
+ app = MyApp(0)
+ app.MainLoop()
+if __name__ == '__main__':
+ __test()
Modified: grass/branches/releasebranch_7_0/gui/wxpython/iclass/plots.py
--- grass/branches/releasebranch_7_0/gui/wxpython/iclass/plots.py 2016-08-04 11:18:07 UTC (rev 69076)
+++ grass/branches/releasebranch_7_0/gui/wxpython/iclass/plots.py 2016-08-04 11:19:40 UTC (rev 69077)
@@ -16,7 +16,14 @@
import wx
-import wx.lib.plot as plot
+from core.globalvar import CheckWxVersion
+try:
+ if CheckWxVersion(version=[3, 0, 0]):
+ import gui_core.wxlibplot as plot
+ else:
+ import wx.lib.plot as plot
+except ImportError as e:
+ print >> sys.stderr, e
import wx.lib.scrolledpanel as scrolled
from core.utils import _
from core.gcmd import GError
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxplot/base.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxplot/base.py 2016-08-04 11:18:07 UTC (rev 69076)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxplot/base.py 2016-08-04 11:19:40 UTC (rev 69077)
@@ -19,8 +19,12 @@
import sys
import wx
try:
- import wx.lib.plot as plot
+ else:
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxplot/histogram.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxplot/histogram.py 2016-08-04 11:18:07 UTC (rev 69076)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxplot/histogram.py 2016-08-04 11:19:40 UTC (rev 69077)
@@ -18,8 +18,12 @@
import sys
import wx
try:
+ else:
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py 2016-08-04 11:18:07 UTC (rev 69076)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py 2016-08-04 11:19:40 UTC (rev 69077)
@@ -20,8 +20,12 @@
import math
import wx
try:
+ else:
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxplot/scatter.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxplot/scatter.py 2016-08-04 11:18:07 UTC (rev 69076)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxplot/scatter.py 2016-08-04 11:19:40 UTC (rev 69077)
@@ -18,8 +18,12 @@
import sys
import wx
try:
+ else:
