[GRASS-SVN] r69082 - grass-addons/grass7/display/d.legend.vect
svn_grass at osgeo.org
Thu Aug 4 08:02:48 PDT 2016
Author: lazaa
Date: 2016-08-04 08:02:48 -0700 (Thu, 04 Aug 2016)
New Revision: 69082
grass-addons/grass7/display/d.legend.vect/draw.c
grass-addons/grass7/display/d.legend.vect/main.c
Layer order, symbol sizing, bg border
Modified: grass-addons/grass7/display/d.legend.vect/draw.c
--- grass-addons/grass7/display/d.legend.vect/draw.c 2016-08-04 14:56:51 UTC (rev 69081)
+++ grass-addons/grass7/display/d.legend.vect/draw.c 2016-08-04 15:02:48 UTC (rev 69082)
@@ -16,8 +16,8 @@
#include "local_proto.h"
void draw(char *file_name, double LL, double LT, char *title, int cols, int bgcolor,
- int bcolor, int do_bg, char* tit_font, int tit_size, char *sub_font, int sub_size,
- char *font, int fontsize, int fontcolor, int symb_size)
+ int bcolor, int bg_width, int do_bg, char* tit_font, int tit_size, char *sub_font,
+ int sub_size, char *font, int fontsize, int fontcolor, int symb_size)
double db, dt, dl, dr;
double bb, bt, bl, br;
@@ -35,7 +35,7 @@
int ret, R, G, B;
char *part, *sub_delim;
double maxlblw, sym_lbl_space;
- double symb_h, symb_w, max_symb_w;
+ double symb_h, symb_w, def_symb_h, def_symb_w;
int item_count, item;
double it_per_col;
double margin, bg_h, bg_w;
@@ -54,7 +54,7 @@
D_text_size(tit_size, tit_size);
D_get_text_box(title, &bb, &bt, &bl, &br);
margin = 10;
- title_h = bb - bt;
+ title_h = bb - bt + margin;
title_w = br - bl;
if (! do_bg) {
x = x0;
@@ -72,14 +72,19 @@
/* Get number of legend row(item) and the biggest symbol*/
item_count = 0;
- max_symb_w = 0;
+ def_symb_w = symb_size;
got_new = G_getl2(buf, sizeof(buf), file_in);
G_strip(buf);
while (got_new) {
/* Get the maximum symbol size */
- label = G_malloc(strlen(buf) + 1);
symb_name = G_malloc(strlen(buf) + 1);
+ type_str = G_malloc(strlen(buf) + 1);
+ line_color_str = G_malloc(strlen(buf) + 1);
+ fill_color_str = G_malloc(strlen(buf) + 1);
+ label = G_malloc(strlen(buf)+1);
+ line_color = G_malloc(sizeof(RGBA_Color));
+ fill_color = G_malloc(sizeof(RGBA_Color));
part = strtok(buf, sep);
sscanf(part, "%s", label);
@@ -87,20 +92,32 @@
sscanf(part, "%s", symb_name);
part = strtok(NULL, sep);
sscanf(part, "%lf", &size);
+ part = strtok(NULL, sep);
+ sscanf(part, "%s", line_color_str);
+ sscanf(part, "%s", fill_color_str);
+ sscanf(part, "%lf", &line_width);
+ sscanf(part, "%s", type_str);
+ sscanf(part, "%d", &type_count);
/* Symbol */
- if ((strcmp(symb_name,"legend/area")==0) || (strcmp(symb_name,"legend/line")==0))
+ if (strcmp(type_str,"point")!=0) {
size = symb_size;
+ D_line_width(line_width);
Symb = S_read(symb_name);
if (Symb == NULL)
G_warning(_("Cannot read symbol"));
else
S_stroke(Symb, size, 0, 0);
- symb_w = Symb->xscale * size * 2;
+// symb_w = Symb->xscale * size * 2;
+ symb_w = size;
- if (symb_w > max_symb_w)
- max_symb_w = symb_w;
+ if (symb_w > def_symb_w)
+ def_symb_w = symb_w;
item_count++;
@@ -112,7 +129,8 @@
bg_h = 0;
maxlblw = 0;
offs_y = title_h;
- sym_lbl_space = 15;
+ sym_lbl_space = 10;
+ def_symb_h = symb_size;
item = 0;
offs_x = 0;
margin = 10;
@@ -129,7 +147,7 @@
else {
if (bg_h < offs_y)
- bg_h = offs_y + symb_h/2.;
+ bg_h = offs_y + def_symb_h/2.;
offs_x += maxlblw + margin;
offs_y = title_h + row_ind;
maxlblw = 0;
@@ -149,7 +167,7 @@
row_w = br - bl;
offs_y += text_h + row_ind;
if (bg_h < offs_y)
if (row_w > maxlblw)
maxlblw = row_w;
@@ -189,8 +207,9 @@
/* Symbol */
+ if (strcmp(type_str,"point") != 0){
size = symb_size;
if (Symb == NULL)
@@ -226,9 +245,13 @@
D_font(font);
D_get_text_box(label, &bb, &bt, &bl, &br);
- symb_h = Symb->yscale * size * 2;
+// symb_h = Symb->yscale * size * 2;
+ symb_h = size;
+ if (symb_h < def_symb_h)
+ symb_h = def_symb_h;
text_h = bb - bt;
- row_w = max_symb_w + sym_lbl_space + br - bl;
+ row_w = def_symb_w + sym_lbl_space + br - bl;
if (symb_h >= text_h)
offs_y += symb_h + row_ind;
else
@@ -241,11 +264,12 @@
if (! do_bg) {
- x = x0 + offs_x + max_symb_w/2.;
+ x = x0 + offs_x + def_symb_w/2.;
y = y0 + offs_y - symb_h/2;
D_symbol(Symb, x, y, line_color, fill_color);
- x = x0 + offs_x + max_symb_w + sym_lbl_space;
+ x = x0 + offs_x + def_symb_w + sym_lbl_space;
y = y0 + offs_y - symb_h/2. + text_h/2.;
D_pos_abs(x, y);
D_use_color(fontcolor);
@@ -268,9 +292,9 @@
bg_w = offs_x + maxlblw;
x0bg = x0 - margin;
- y0bg = y0 - margin;
+ y0bg = y0;
x1bg = x0 + bg_w + margin;
- y1bg = y0 + bg_h + margin;
+ y1bg = y0 + bg_h;
if (bgcolor) {
D_use_color(bgcolor);
@@ -278,6 +302,7 @@
D_use_color(bcolor);
+ D_line_width(bg_width);
D_begin();
D_move_abs(x0bg, y0bg);
D_cont_abs(x0bg, y1bg);
Modified: grass-addons/grass7/display/d.legend.vect/main.c
--- grass-addons/grass7/display/d.legend.vect/main.c 2016-08-04 14:56:51 UTC (rev 69081)
+++ grass-addons/grass7/display/d.legend.vect/main.c 2016-08-04 15:02:48 UTC (rev 69082)
@@ -24,15 +24,16 @@
// struct Option *opt_input, *opt_sep;
struct Option *opt_at, *opt_cols, *opt_font, *opt_fontsize,
*opt_fontcolor, *opt_title, *opt_tit_font, *opt_tit_fontsize, *opt_sub_font,
- *opt_sub_fontsize, *opt_bcolor, *opt_bgcolor, *opt_symb_size;
+ *opt_sub_fontsize, *opt_bcolor, *opt_bgcolor, *opt_symb_size, *opt_line_width,
+ *opt_bg_width;
struct Flag *fl_bg;
double LL, LT;
- char *title, *file_name, *leg_dir;
+ char *title, *file_name;
int bcolor, bgcolor, do_bg;
int fontsize, fontcolor, tit_size, sub_size;
char *font, *tit_font, *sub_font;
- int cols, symb_size;
+ int cols, symb_size, bg_width;
/* Initialize the GIS calls */
@@ -94,6 +95,13 @@
opt_bgcolor->label = _("Background color");
opt_bgcolor->guisection = _("Background");
+ opt_bg_width = G_define_option();
+ opt_bg_width->type = TYPE_INTEGER;
+ opt_bg_width->key = "border_width";
+ opt_bg_width->answer = "2";
+ opt_bg_width->label = _("Background border width");
+ opt_bg_width->guisection = _("Background");
opt_tit_font = G_define_option();
opt_tit_font->key = "title_font";
opt_tit_font->type = TYPE_STRING;
@@ -164,7 +172,6 @@
/* parse and check options and flags */
file_name = getenv("GRASS_LEGEND_FILE");
-// file_name = opt_input->answer;
if (!file_name)
G_fatal_error("No legend file defined.");
@@ -184,6 +191,7 @@
cols = 1;
sscanf(opt_symb_size->answer, "%d", &symb_size);
+ sscanf(opt_bg_width->answer, "%d", &bg_width);
/* Background */
do_bg = fl_bg->answer;
@@ -222,10 +230,10 @@
/* Pre-calculate the layout */
if (do_bg)
- draw(file_name, LL, LT, title, cols, bgcolor, bcolor, 1, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
+ draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 1, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
/* Draw legend */
- draw(file_name, LL, LT, title, cols, bgcolor, bcolor, 0, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
+ draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 0, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
D_close_driver();
