[GRASS-SVN] r69091 - grass-addons/grass7/display/d.legend.vect
svn_grass at osgeo.org
Fri Aug 5 05:51:10 PDT 2016
Author: lazaa
Date: 2016-08-05 05:51:10 -0700 (Fri, 05 Aug 2016)
New Revision: 69091
grass-addons/grass7/display/d.legend.vect/d.legend.vect.html
grass-addons/grass7/display/d.legend.vect/main.c
Input/Output file
Modified: grass-addons/grass7/display/d.legend.vect/d.legend.vect.html
--- grass-addons/grass7/display/d.legend.vect/d.legend.vect.html 2016-08-05 12:40:26 UTC (rev 69090)
+++ grass-addons/grass7/display/d.legend.vect/d.legend.vect.html 2016-08-05 12:51:10 UTC (rev 69091)
@@ -15,6 +15,8 @@
Flag <b>-b</b> shows the background and user can specify its properties with <b>border_color, bgcolor, border_width</b>
<p>
<b>symbol_size</b> defines the size of line and area symbols. The size of point symbols is defined in legend file via <em><a href="d.vect.html">d.vect</a></em> command.
+<p>
+<b>output</b> defines path to file where the internal legend file ['GRASS_LEGEND_FILE'] will be saved to. <b>input</b> defines the input file which the vector legend will be based on. This input file must have correct format.
<h2>EXAMPLES</h2>
Modified: grass-addons/grass7/display/d.legend.vect/main.c
--- grass-addons/grass7/display/d.legend.vect/main.c 2016-08-05 12:40:26 UTC (rev 69090)
+++ grass-addons/grass7/display/d.legend.vect/main.c 2016-08-05 12:51:10 UTC (rev 69091)
@@ -13,6 +13,8 @@
#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
#include <grass/display.h>
#include <grass/glocale.h>
#include "local_proto.h"
@@ -25,7 +27,7 @@
struct Option *opt_at, *opt_cols, *opt_font, *opt_fontsize,
*opt_fontcolor, *opt_title, *opt_tit_font, *opt_tit_fontsize, *opt_sub_font,
*opt_sub_fontsize, *opt_bcolor, *opt_bgcolor, *opt_symb_size,
- *opt_bg_width;
+ *opt_bg_width, *opt_output, *opt_input;
struct Flag *fl_bg;
double LL, LT;
@@ -34,6 +36,9 @@
int fontsize, fontcolor, tit_size, sub_size;
char *font, *tit_font, *sub_font;
int cols, symb_size, bg_width;
+ char *out_file;
+ FILE *source, *target;
+ char buf[512];
/* Initialize the GIS calls */
@@ -160,7 +165,19 @@
fl_bg->description = _("Display legend background");
fl_bg->guisection = _("Background");
+ opt_output = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt_output->label = _("Output csv file");
+ opt_output->description = _("Path to output file or '-' "
+ "for standard output");
+ opt_output->required = NO;
+ opt_output->guisection = _("In/Out");
+ opt_input = G_define_standard_option(G_OPT_F_INPUT);
+ opt_input->label = _("Input legend file");
+ opt_input->description = _("Path to legend file ");
+ opt_input->required = NO;
+ opt_input->guisection = _("In/Out");
/* Check command line */
if (G_parser(argc, argv)) {
exit(EXIT_FAILURE);
@@ -170,10 +187,6 @@
D_setup_unity(0);
/* parse and check options and flags */
- file_name = getenv("GRASS_LEGEND_FILE");
- if (!file_name)
- G_fatal_error("No legend file defined.");
if (opt_at->answer) {
sscanf(opt_at->answers[0], "%lf", &LL);
sscanf(opt_at->answers[1], "%lf", <);
@@ -231,6 +244,41 @@
fontcolor = D_parse_color(opt_fontcolor->answer, FALSE); /*default color: black */
+ /* I/O */
+ if (opt_input->answer) {
+ file_name = opt_input->answer;
+ if (!file_name)
+ G_fatal_error(_("Unable to open input file <%s>"), file_name);
+ else {
+ file_name = getenv("GRASS_LEGEND_FILE");
+ if (!file_name)
+ G_fatal_error("No legend file defined.");
+ if (opt_output->answer) {
+ source = fopen(file_name, "r");
+ if (!source)
+ if (strcmp(opt_output->answer,"-") == 0)
+ while (fgets (buf, sizeof(buf), source) != NULL)
+ puts (buf);
+ else {
+ out_file = opt_output->answer;
+ target = fopen(out_file, "w");
+ if (!target) {
+ fclose(source);
+ G_fatal_error(_("Unable to create output file <%s>"), out_file);
+ fputs (buf, target);
+ fclose(target);
+ fclose(source);
/* Pre-calculate the layout */
if (do_bg)
draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 1, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
