[GRASS-SVN] r69099 - grass-addons/grass7/display/d.legend.vect
svn_grass at osgeo.org
Sat Aug 6 13:10:58 PDT 2016
Author: annakrat
Date: 2016-08-06 13:10:58 -0700 (Sat, 06 Aug 2016)
New Revision: 69099
grass-addons/grass7/display/d.legend.vect/main.c
d.legend.vect: fix writing legend to stdout
Modified: grass-addons/grass7/display/d.legend.vect/main.c
--- grass-addons/grass7/display/d.legend.vect/main.c 2016-08-06 17:35:59 UTC (rev 69098)
+++ grass-addons/grass7/display/d.legend.vect/main.c 2016-08-06 20:10:58 UTC (rev 69099)
@@ -37,9 +37,10 @@
char *font, *tit_font, *sub_font;
int cols, symb_size, bg_width;
char *out_file;
- FILE *source, *target;
+ FILE *source;
char buf[BUFFSIZE];
char *sep;
+ size_t nread;
/* Initialize the GIS calls */
@@ -166,6 +167,12 @@
fl_bg->description = _("Display legend background");
fl_bg->guisection = _("Background");
+ opt_input = G_define_standard_option(G_OPT_F_INPUT);
+ opt_input->label = _("Input legend file");
+ opt_input->description = _("Path to legend file ");
+ opt_input->required = NO;
+ opt_input->guisection = _("In/Out");
opt_output = G_define_standard_option(G_OPT_F_OUTPUT);
opt_output->label = _("Output csv file");
opt_output->description = _("Path to output file or '-' "
@@ -173,14 +180,8 @@
opt_output->required = NO;
opt_output->guisection = _("In/Out");
- opt_input = G_define_standard_option(G_OPT_F_INPUT);
- opt_input->label = _("Input legend file");
- opt_input->description = _("Path to legend file ");
- opt_input->required = NO;
- opt_input->guisection = _("In/Out");
opt_sep = G_define_standard_option(G_OPT_F_SEP);
- opt_sep->guisection = _("Input");
+ opt_sep->guisection = _("In/Out");
/* Check command line */
if (G_parser(argc, argv)) {
@@ -264,25 +265,18 @@
if (opt_output->answer) {
- source = fopen(file_name, "r");
- if (!source)
- G_fatal_error(_("Unable to open input file <%s>"), file_name);
- if (strcmp(opt_output->answer,"-") == 0)
- while (fgets (buf, sizeof(GNAME_MAX), source) != NULL)
- puts (buf);
+ if (strcmp(opt_output->answer,"-") == 0) {
+ source = fopen(file_name, "r");
+ if (!source)
+ G_fatal_error(_("Unable to open input file <%s>"), file_name);
+ while ((nread = fread(buf, 1, sizeof(buf), source)))
+ fwrite(buf, 1, nread, stdout);
+ fclose(source);
else {
out_file = opt_output->answer;
- target = fopen(out_file, "w");
- if (!target) {
- fclose(source);
- G_fatal_error(_("Unable to create output file <%s>"), out_file);
- fputs (buf, target);
- fclose(target);
+ G_copy_file(file_name, out_file);
- fclose(source);
/* Pre-calculate the layout */
