[GRASS-SVN] r69111 - in grass-addons/grass7/misc: . m.printws
Tue Aug 9 04:44:13 PDT 2016
Author: kuszinger
Date: 2016-08-09 04:44:13 -0700 (Tue, 09 Aug 2016)
New Revision: 69111
Added:
   grass-addons/grass7/misc/m.printws/
   grass-addons/grass7/misc/m.printws/LICENSE
   grass-addons/grass7/misc/m.printws/Makefile
   grass-addons/grass7/misc/m.printws/README.md
   grass-addons/grass7/misc/m.printws/m.printws.html
   grass-addons/grass7/misc/m.printws/m.printws.py
   grass-addons/grass7/misc/m.printws/m.printws_sample_print.png
   grass-addons/grass7/misc/m.printws/m.printws_screen.png
   grass-addons/grass7/misc/Makefile
Modified: grass-addons/grass7/misc/Makefile
--- grass-addons/grass7/misc/Makefile	2016-08-09 08:23:55 UTC (rev 69110)
+++ grass-addons/grass7/misc/Makefile	2016-08-09 11:44:13 UTC (rev 69111)
@@ -2,7 +2,8 @@
 SUBDIRS = \
 	m.eigensystem \
-	m.gcp.filter
+	m.gcp.filter \
+	m.printws
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass7/misc/m.printws/LICENSE
--- grass-addons/grass7/misc/m.printws/LICENSE	                        (rev 0)
+++ grass-addons/grass7/misc/m.printws/LICENSE	2016-08-09 11:44:13 UTC (rev 69111)
@@ -0,0 +1,674 @@
+                    GNU GENERAL PUBLIC LICENSE
+                       Version 3, 29 June 2007
+ Copyright (C) 2007 Free Software Foundation, Inc. <http://fsf.org/>
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+                            Preamble
+  The GNU General Public License is a free, copyleft license for
+software and other kinds of works.
+  The licenses for most software and other practical works are designed
+to take away your freedom to share and change the works.  By contrast,
+the GNU General Public License is intended to guarantee your freedom to
+share and change all versions of a program--to make sure it remains free
+software for all its users.  We, the Free Software Foundation, use the
+GNU General Public License for most of our software; it applies also to
+any other work released this way by its authors.  You can apply it to
+your programs, too.
+  When we speak of free software, we are referring to freedom, not
+price.  Our General Public Licenses are designed to make sure that you
+have the freedom to distribute copies of free software (and charge for
+them if you wish), that you receive source code or can get it if you
+want it, that you can change the software or use pieces of it in new
+free programs, and that you know you can do these things.
+  To protect your rights, we need to prevent others from denying you
+these rights or asking you to surrender the rights.  Therefore, you have
+certain responsibilities if you distribute copies of the software, or if
+you modify it: responsibilities to respect the freedom of others.
+  For example, if you distribute copies of such a program, whether
+gratis or for a fee, you must pass on to the recipients the same
+freedoms that you received.  You must make sure that they, too, receive
+or can get the source code.  And you must show them these terms so they
+know their rights.
+  Developers that use the GNU GPL protect your rights with two steps:
+(1) assert copyright on the software, and (2) offer you this License
+giving you legal permission to copy, distribute and/or modify it.
+  For the developers' and authors' protection, the GPL clearly explains
+that there is no warranty for this free software.  For both users' and
+authors' sake, the GPL requires that modified versions be marked as
+changed, so that their problems will not be attributed erroneously to
+authors of previous versions.
+  Some devices are designed to deny users access to install or run
+modified versions of the software inside them, although the manufacturer
+can do so.  This is fundamentally incompatible with the aim of
+protecting users' freedom to change the software.  The systematic
+pattern of such abuse occurs in the area of products for individuals to
+use, which is precisely where it is most unacceptable.  Therefore, we
+have designed this version of the GPL to prohibit the practice for those
+products.  If such problems arise substantially in other domains, we
+stand ready to extend this provision to those domains in future versions
+of the GPL, as needed to protect the freedom of users.
+  Finally, every program is threatened constantly by software patents.
+States should not allow patents to restrict development and use of
+software on general-purpose computers, but in those that do, we wish to
+avoid the special danger that patents applied to a free program could
+make it effectively proprietary.  To prevent this, the GPL assures that
+patents cannot be used to render the program non-free.
+  The precise terms and conditions for copying, distribution and
+modification follow.
+                       TERMS AND CONDITIONS
+  0. Definitions.
+  "This License" refers to version 3 of the GNU General Public License.
+  "Copyright" also means copyright-like laws that apply to other kinds of
+works, such as semiconductor masks.
+  "The Program" refers to any copyrightable work licensed under this
+License.  Each licensee is addressed as "you".  "Licensees" and
+"recipients" may be individuals or organizations.
+  To "modify" a work means to copy from or adapt all or part of the work
+in a fashion requiring copyright permission, other than the making of an
+exact copy.  The resulting work is called a "modified version" of the
+earlier work or a work "based on" the earlier work.
+  A "covered work" means either the unmodified Program or a work based
+on the Program.
+  To "propagate" a work means to do anything with it that, without
+permission, would make you directly or secondarily liable for
+infringement under applicable copyright law, except executing it on a
+computer or modifying a private copy.  Propagation includes copying,
+distribution (with or without modification), making available to the
+public, and in some countries other activities as well.
+  To "convey" a work means any kind of propagation that enables other
+parties to make or receive copies.  Mere interaction with a user through
+a computer network, with no transfer of a copy, is not conveying.
+  An interactive user interface displays "Appropriate Legal Notices"
+to the extent that it includes a convenient and prominently visible
+feature that (1) displays an appropriate copyright notice, and (2)
+tells the user that there is no warranty for the work (except to the
+extent that warranties are provided), that licensees may convey the
+work under this License, and how to view a copy of this License.  If
+the interface presents a list of user commands or options, such as a
+menu, a prominent item in the list meets this criterion.
+  1. Source Code.
+  The "source code" for a work means the preferred form of the work
+for making modifications to it.  "Object code" means any non-source
+form of a work.
+  A "Standard Interface" means an interface that either is an official
+standard defined by a recognized standards body, or, in the case of
+interfaces specified for a particular programming language, one that
+is widely used among developers working in that language.
+  The "System Libraries" of an executable work include anything, other
+than the work as a whole, that (a) is included in the normal form of
+packaging a Major Component, but which is not part of that Major
+Component, and (b) serves only to enable use of the work with that
+Major Component, or to implement a Standard Interface for which an
+implementation is available to the public in source code form.  A
+"Major Component", in this context, means a major essential component
+(kernel, window system, and so on) of the specific operating system
+(if any) on which the executable work runs, or a compiler used to
+produce the work, or an object code interpreter used to run it.
+  The "Corresponding Source" for a work in object code form means all
+the source code needed to generate, install, and (for an executable
+work) run the object code and to modify the work, including scripts to
+control those activities.  However, it does not include the work's
+System Libraries, or general-purpose tools or generally available free
+programs which are used unmodified in performing those activities but
+which are not part of the work.  For example, Corresponding Source
+includes interface definition files associated with source files for
+the work, and the source code for shared libraries and dynamically
+linked subprograms that the work is specifically designed to require,
+such as by intimate data communication or control flow between those
+subprograms and other parts of the work.
+  The Corresponding Source need not include anything that users
+can regenerate automatically from other parts of the Corresponding
+Source.
+  The Corresponding Source for a work in source code form is that
+same work.
+  2. Basic Permissions.
+  All rights granted under this License are granted for the term of
+copyright on the Program, and are irrevocable provided the stated
+conditions are met.  This License explicitly affirms your unlimited
+permission to run the unmodified Program.  The output from running a
+covered work is covered by this License only if the output, given its
+content, constitutes a covered work.  This License acknowledges your
+rights of fair use or other equivalent, as provided by copyright law.
+  You may make, run and propagate covered works that you do not
+convey, without conditions so long as your license otherwise remains
+in force.  You may convey covered works to others for the sole purpose
+of having them make modifications exclusively for you, or provide you
+with facilities for running those works, provided that you comply with
+the terms of this License in conveying all material for which you do
+not control copyright.  Those thus making or running the covered works
+for you must do so exclusively on your behalf, under your direction
+and control, on terms that prohibit them from making any copies of
+your copyrighted material outside their relationship with you.
+  Conveying under any other circumstances is permitted solely under
+the conditions stated below.  Sublicensing is not allowed; section 10
+makes it unnecessary.
+  3. Protecting Users' Legal Rights From Anti-Circumvention Law.
+  No covered work shall be deemed part of an effective technological
+measure under any applicable law fulfilling obligations under article
+11 of the WIPO copyright treaty adopted on 20 December 1996, or
+similar laws prohibiting or restricting circumvention of such
+measures.
+  When you convey a covered work, you waive any legal power to forbid
+circumvention of technological measures to the extent such circumvention
+is effected by exercising rights under this License with respect to
+the covered work, and you disclaim any intention to limit operation or
+modification of the work as a means of enforcing, against the work's
+users, your or third parties' legal rights to forbid circumvention of
+technological measures.
+  4. Conveying Verbatim Copies.
+  You may convey verbatim copies of the Program's source code as you
+receive it, in any medium, provided that you conspicuously and
+appropriately publish on each copy an appropriate copyright notice;
+keep intact all notices stating that this License and any
+non-permissive terms added in accord with section 7 apply to the code;
+keep intact all notices of the absence of any warranty; and give all
+recipients a copy of this License along with the Program.
+  You may charge any price or no price for each copy that you convey,
+and you may offer support or warranty protection for a fee.
+  5. Conveying Modified Source Versions.
+  You may convey a work based on the Program, or the modifications to
+produce it from the Program, in the form of source code under the
+terms of section 4, provided that you also meet all of these conditions:
+    a) The work must carry prominent notices stating that you modified
+    it, and giving a relevant date.
+    b) The work must carry prominent notices stating that it is
+    released under this License and any conditions added under section
+    7.  This requirement modifies the requirement in section 4 to
+    "keep intact all notices".
+    c) You must license the entire work, as a whole, under this
+    License to anyone who comes into possession of a copy.  This
+    License will therefore apply, along with any applicable section 7
+    additional terms, to the whole of the work, and all its parts,
+    regardless of how they are packaged.  This License gives no
+    permission to license the work in any other way, but it does not
+    invalidate such permission if you have separately received it.
+    d) If the work has interactive user interfaces, each must display
+    Appropriate Legal Notices; however, if the Program has interactive
+    interfaces that do not display Appropriate Legal Notices, your
+    work need not make them do so.
+  A compilation of a covered work with other separate and independent
+works, which are not by their nature extensions of the covered work,
+and which are not combined with it such as to form a larger program,
+in or on a volume of a storage or distribution medium, is called an
+"aggregate" if the compilation and its resulting copyright are not
+used to limit the access or legal rights of the compilation's users
+beyond what the individual works permit.  Inclusion of a covered work
+in an aggregate does not cause this License to apply to the other
+parts of the aggregate.
+  6. Conveying Non-Source Forms.
+  You may convey a covered work in object code form under the terms
+of sections 4 and 5, provided that you also convey the
+machine-readable Corresponding Source under the terms of this License,
+in one of these ways:
+    a) Convey the object code in, or embodied in, a physical product
+    (including a physical distribution medium), accompanied by the
+    Corresponding Source fixed on a durable physical medium
+    customarily used for software interchange.
+    b) Convey the object code in, or embodied in, a physical product
+    (including a physical distribution medium), accompanied by a
+    written offer, valid for at least three years and valid for as
+    long as you offer spare parts or customer support for that product
+    model, to give anyone who possesses the object code either (1) a
+    copy of the Corresponding Source for all the software in the
+    product that is covered by this License, on a durable physical
+    medium customarily used for software interchange, for a price no
+    more than your reasonable cost of physically performing this
+    conveying of source, or (2) access to copy the
+    Corresponding Source from a network server at no charge.
+    c) Convey individual copies of the object code with a copy of the
+    written offer to provide the Corresponding Source.  This
+    alternative is allowed only occasionally and noncommercially, and
+    only if you received the object code with such an offer, in accord
+    with subsection 6b.
+    d) Convey the object code by offering access from a designated
+    place (gratis or for a charge), and offer equivalent access to the
+    Corresponding Source in the same way through the same place at no
+    further charge.  You need not require recipients to copy the
+    Corresponding Source along with the object code.  If the place to
+    copy the object code is a network server, the Corresponding Source
+    may be on a different server (operated by you or a third party)
+    that supports equivalent copying facilities, provided you maintain
+    clear directions next to the object code saying where to find the
+    Corresponding Source.  Regardless of what server hosts the
+    Corresponding Source, you remain obligated to ensure that it is
+    available for as long as needed to satisfy these requirements.
+    e) Convey the object code using peer-to-peer transmission, provided
+    you inform other peers where the object code and Corresponding
+    Source of the work are being offered to the general public at no
+    charge under subsection 6d.
+  A separable portion of the object code, whose source code is excluded
+from the Corresponding Source as a System Library, need not be
+included in conveying the object code work.
+  A "User Product" is either (1) a "consumer product", which means any
+tangible personal property which is normally used for personal, family,
+or household purposes, or (2) anything designed or sold for incorporation
+into a dwelling.  In determining whether a product is a consumer product,
+doubtful cases shall be resolved in favor of coverage.  For a particular
+product received by a particular user, "normally used" refers to a
+typical or common use of that class of product, regardless of the status
+of the particular user or of the way in which the particular user
+actually uses, or expects or is expected to use, the product.  A product
+is a consumer product regardless of whether the product has substantial
+commercial, industrial or non-consumer uses, unless such uses represent
+the only significant mode of use of the product.
+  "Installation Information" for a User Product means any methods,
+procedures, authorization keys, or other information required to install
+and execute modified versions of a covered work in that User Product from
+a modified version of its Corresponding Source.  The information must
+suffice to ensure that the continued functioning of the modified object
+code is in no case prevented or interfered with solely because
+modification has been made.
+  If you convey an object code work under this section in, or with, or
+specifically for use in, a User Product, and the conveying occurs as
+part of a transaction in which the right of possession and use of the
+User Product is transferred to the recipient in perpetuity or for a
+fixed term (regardless of how the transaction is characterized), the
+Corresponding Source conveyed under this section must be accompanied
+by the Installation Information.  But this requirement does not apply
+if neither you nor any third party retains the ability to install
+modified object code on the User Product (for example, the work has
+been installed in ROM).
+  The requirement to provide Installation Information does not include a
+requirement to continue to provide support service, warranty, or updates
+for a work that has been modified or installed by the recipient, or for
+the User Product in which it has been modified or installed.  Access to a
+network may be denied when the modification itself materially and
+adversely affects the operation of the network or violates the rules and
+protocols for communication across the network.
+  Corresponding Source conveyed, and Installation Information provided,
+in accord with this section must be in a format that is publicly
+documented (and with an implementation available to the public in
+source code form), and must require no special password or key for
+unpacking, reading or copying.
+  7. Additional Terms.
+  "Additional permissions" are terms that supplement the terms of this
+License by making exceptions from one or more of its conditions.
+Additional permissions that are applicable to the entire Program shall
+be treated as though they were included in this License, to the extent
+that they are valid under applicable law.  If additional permissions
+apply only to part of the Program, that part may be used separately
+under those permissions, but the entire Program remains governed by
+this License without regard to the additional permissions.
+  When you convey a copy of a covered work, you may at your option
+remove any additional permissions from that copy, or from any part of
+it.  (Additional permissions may be written to require their own
+removal in certain cases when you modify the work.)  You may place
+additional permissions on material, added by you to a covered work,
+for which you have or can give appropriate copyright permission.
+  Notwithstanding any other provision of this License, for material you
+add to a covered work, you may (if authorized by the copyright holders of
+that material) supplement the terms of this License with terms:
+    a) Disclaiming warranty or limiting liability differently from the
+    terms of sections 15 and 16 of this License; or
+    b) Requiring preservation of specified reasonable legal notices or
+    author attributions in that material or in the Appropriate Legal
+    Notices displayed by works containing it; or
+    c) Prohibiting misrepresentation of the origin of that material, or
+    requiring that modified versions of such material be marked in
+    reasonable ways as different from the original version; or
+    d) Limiting the use for publicity purposes of names of licensors or
+    authors of the material; or
+    e) Declining to grant rights under trademark law for use of some
+    trade names, trademarks, or service marks; or
+    f) Requiring indemnification of licensors and authors of that
+    material by anyone who conveys the material (or modified versions of
+    it) with contractual assumptions of liability to the recipient, for
+    any liability that these contractual assumptions directly impose on
+    those licensors and authors.
+  All other non-permissive additional terms are considered "further
+restrictions" within the meaning of section 10.  If the Program as you
+received it, or any part of it, contains a notice stating that it is
+governed by this License along with a term that is a further
+restriction, you may remove that term.  If a license document contains
+a further restriction but permits relicensing or conveying under this
+License, you may add to a covered work material governed by the terms
+of that license document, provided that the further restriction does
+not survive such relicensing or conveying.
+  If you add terms to a covered work in accord with this section, you
+must place, in the relevant source files, a statement of the
+additional terms that apply to those files, or a notice indicating
+where to find the applicable terms.
+  Additional terms, permissive or non-permissive, may be stated in the
+form of a separately written license, or stated as exceptions;
+the above requirements apply either way.
+  8. Termination.
+  You may not propagate or modify a covered work except as expressly
+provided under this License.  Any attempt otherwise to propagate or
+modify it is void, and will automatically terminate your rights under
+this License (including any patent licenses granted under the third
+paragraph of section 11).
+  However, if you cease all violation of this License, then your
+license from a particular copyright holder is reinstated (a)
+provisionally, unless and until the copyright holder explicitly and
+finally terminates your license, and (b) permanently, if the copyright
+holder fails to notify you of the violation by some reasonable means
+prior to 60 days after the cessation.
+  Moreover, your license from a particular copyright holder is
+reinstated permanently if the copyright holder notifies you of the
+violation by some reasonable means, this is the first time you have
+received notice of violation of this License (for any work) from that
+copyright holder, and you cure the violation prior to 30 days after
+your receipt of the notice.
+  Termination of your rights under this section does not terminate the
+licenses of parties who have received copies or rights from you under
+this License.  If your rights have been terminated and not permanently
+reinstated, you do not qualify to receive new licenses for the same
+material under section 10.
+  9. Acceptance Not Required for Having Copies.
+  You are not required to accept this License in order to receive or
+run a copy of the Program.  Ancillary propagation of a covered work
+occurring solely as a consequence of using peer-to-peer transmission
+to receive a copy likewise does not require acceptance.  However,
+nothing other than this License grants you permission to propagate or
+modify any covered work.  These actions infringe copyright if you do
+not accept this License.  Therefore, by modifying or propagating a
+covered work, you indicate your acceptance of this License to do so.
+  10. Automatic Licensing of Downstream Recipients.
+  Each time you convey a covered work, the recipient automatically
+receives a license from the original licensors, to run, modify and
+propagate that work, subject to this License.  You are not responsible
+for enforcing compliance by third parties with this License.
+  An "entity transaction" is a transaction transferring control of an
+organization, or substantially all assets of one, or subdividing an
+organization, or merging organizations.  If propagation of a covered
+work results from an entity transaction, each party to that
+transaction who receives a copy of the work also receives whatever
+licenses to the work the party's predecessor in interest had or could
+give under the previous paragraph, plus a right to possession of the
+Corresponding Source of the work from the predecessor in interest, if
+the predecessor has it or can get it with reasonable efforts.
+  You may not impose any further restrictions on the exercise of the
+rights granted or affirmed under this License.  For example, you may
+not impose a license fee, royalty, or other charge for exercise of
+rights granted under this License, and you may not initiate litigation
+(including a cross-claim or counterclaim in a lawsuit) alleging that
+any patent claim is infringed by making, using, selling, offering for
+sale, or importing the Program or any portion of it.
+  11. Patents.
+  A "contributor" is a copyright holder who authorizes use under this
+License of the Program or a work on which the Program is based.  The
+work thus licensed is called the contributor's "contributor version".
+  A contributor's "essential patent claims" are all patent claims
+owned or controlled by the contributor, whether already acquired or
+hereafter acquired, that would be infringed by some manner, permitted
+by this License, of making, using, or selling its contributor version,
+but do not include claims that would be infringed only as a
+consequence of further modification of the contributor version.  For
+purposes of this definition, "control" includes the right to grant
+patent sublicenses in a manner consistent with the requirements of
+this License.
+  Each contributor grants you a non-exclusive, worldwide, royalty-free
+patent license under the contributor's essential patent claims, to
+make, use, sell, offer for sale, import and otherwise run, modify and
+propagate the contents of its contributor version.
+  In the following three paragraphs, a "patent license" is any express
+agreement or commitment, however denominated, not to enforce a patent
+(such as an express permission to practice a patent or covenant not to
+sue for patent infringement).  To "grant" such a patent license to a
+party means to make such an agreement or commitment not to enforce a
+patent against the party.
+  If you convey a covered work, knowingly relying on a patent license,
+and the Corresponding Source of the work is not available for anyone
+to copy, free of charge and under the terms of this License, through a
+publicly available network server or other readily accessible means,
+then you must either (1) cause the Corresponding Source to be so
+available, or (2) arrange to deprive yourself of the benefit of the
+patent license for this particular work, or (3) arrange, in a manner
+consistent with the requirements of this License, to extend the patent
+license to downstream recipients.  "Knowingly relying" means you have
+actual knowledge that, but for the patent license, your conveying the
+covered work in a country, or your recipient's use of the covered work
+in a country, would infringe one or more identifiable patents in that
+country that you have reason to believe are valid.
+  If, pursuant to or in connection with a single transaction or
+arrangement, you convey, or propagate by procuring conveyance of, a
+covered work, and grant a patent license to some of the parties
+receiving the covered work authorizing them to use, propagate, modify
+or convey a specific copy of the covered work, then the patent license
+you grant is automatically extended to all recipients of the covered
+work and works based on it.
+  A patent license is "discriminatory" if it does not include within
+the scope of its coverage, prohibits the exercise of, or is
+conditioned on the non-exercise of one or more of the rights that are
+specifically granted under this License.  You may not convey a covered
+work if you are a party to an arrangement with a third party that is
+in the business of distributing software, under which you make payment
+to the third party based on the extent of your activity of conveying
+the work, and under which the third party grants, to any of the
+parties who would receive the covered work from you, a discriminatory
+patent license (a) in connection with copies of the covered work
+conveyed by you (or copies made from those copies), or (b) primarily
+for and in connection with specific products or compilations that
+contain the covered work, unless you entered into that arrangement,
+or that patent license was granted, prior to 28 March 2007.
+  Nothing in this License shall be construed as excluding or limiting
+any implied license or other defenses to infringement that may
+otherwise be available to you under applicable patent law.
+  12. No Surrender of Others' Freedom.
+  If conditions are imposed on you (whether by court order, agreement or
+otherwise) that contradict the conditions of this License, they do not
+excuse you from the conditions of this License.  If you cannot convey a
+covered work so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you may
+not convey it at all.  For example, if you agree to terms that obligate you
+to collect a royalty for further conveying from those to whom you convey
+the Program, the only way you could satisfy both those terms and this
+License would be to refrain entirely from conveying the Program.
+  13. Use with the GNU Affero General Public License.
+  Notwithstanding any other provision of this License, you have
+permission to link or combine any covered work with a work licensed
+under version 3 of the GNU Affero General Public License into a single
+combined work, and to convey the resulting work.  The terms of this
+License will continue to apply to the part which is the covered work,
+but the special requirements of the GNU Affero General Public License,
+section 13, concerning interaction through a network will apply to the
+combination as such.
+  14. Revised Versions of this License.
+  The Free Software Foundation may publish revised and/or new versions of
+the GNU General Public License from time to time.  Such new versions will
+be similar in spirit to the present version, but may differ in detail to
+address new problems or concerns.
+  Each version is given a distinguishing version number.  If the
+Program specifies that a certain numbered version of the GNU General
+Public License "or any later version" applies to it, you have the
+option of following the terms and conditions either of that numbered
+version or of any later version published by the Free Software
+Foundation.  If the Program does not specify a version number of the
+GNU General Public License, you may choose any version ever published
+by the Free Software Foundation.
+  If the Program specifies that a proxy can decide which future
+versions of the GNU General Public License can be used, that proxy's
+public statement of acceptance of a version permanently authorizes you
+to choose that version for the Program.
+  Later license versions may give you additional or different
+permissions.  However, no additional obligations are imposed on any
+author or copyright holder as a result of your choosing to follow a
+later version.
+  15. Disclaimer of Warranty.
+  THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY
+APPLICABLE LAW.  EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT
+HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY
+OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO,
+THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+PURPOSE.  THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM
+IS WITH YOU.  SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF
+ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
+  16. Limitation of Liability.
+  IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
+WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MODIFIES AND/OR CONVEYS
+THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY
+GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE
+USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF
+DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD
+PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS),
+EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF
+SUCH DAMAGES.
+  17. Interpretation of Sections 15 and 16.
+  If the disclaimer of warranty and limitation of liability provided
+above cannot be given local legal effect according to their terms,
+reviewing courts shall apply local law that most closely approximates
+an absolute waiver of all civil liability in connection with the
+Program, unless a warranty or assumption of liability accompanies a
+copy of the Program in return for a fee.
+                     END OF TERMS AND CONDITIONS
+            How to Apply These Terms to Your New Programs
+  If you develop a new program, and you want it to be of the greatest
+possible use to the public, the best way to achieve this is to make it
+free software which everyone can redistribute and change under these terms.
+  To do so, attach the following notices to the program.  It is safest
+to attach them to the start of each source file to most effectively
+state the exclusion of warranty; and each file should have at least
+the "copyright" line and a pointer to where the full notice is found.
+    {one line to give the program's name and a brief idea of what it does.}
+    Copyright (C) {year}  {name of author}
+    This program is free software: you can redistribute it and/or modify
+    it under the terms of the GNU General Public License as published by
+    the Free Software Foundation, either version 3 of the License, or
+    (at your option) any later version.
+    This program is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+    GNU General Public License for more details.
+    You should have received a copy of the GNU General Public License
+    along with this program.  If not, see <http://www.gnu.org/licenses/>.
+Also add information on how to contact you by electronic and paper mail.
+  If the program does terminal interaction, make it output a short
+notice like this when it starts in an interactive mode:
+    {project}  Copyright (C) {year}  {fullname}
+    This program comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
+    This is free software, and you are welcome to redistribute it
+    under certain conditions; type `show c' for details.
+The hypothetical commands `show w' and `show c' should show the appropriate
+parts of the General Public License.  Of course, your program's commands
+might be different; for a GUI interface, you would use an "about box".
+  You should also get your employer (if you work as a programmer) or school,
+if any, to sign a "copyright disclaimer" for the program, if necessary.
+For more information on this, and how to apply and follow the GNU GPL, see
+<http://www.gnu.org/licenses/>.
+  The GNU General Public License does not permit incorporating your program
+into proprietary programs.  If your program is a subroutine library, you
+may consider it more useful to permit linking proprietary applications with
+the library.  If this is what you want to do, use the GNU Lesser General
+Public License instead of this License.  But first, please read
+<http://www.gnu.org/philosophy/why-not-lgpl.html>.
Added: grass-addons/grass7/misc/m.printws/Makefile
--- grass-addons/grass7/misc/m.printws/Makefile	                        (rev 0)
+++ grass-addons/grass7/misc/m.printws/Makefile	2016-08-09 11:44:13 UTC (rev 69111)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = m.printws
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/misc/m.printws/README.md
--- grass-addons/grass7/misc/m.printws/README.md	                        (rev 0)
+++ grass-addons/grass7/misc/m.printws/README.md	2016-08-09 11:44:13 UTC (rev 69111)
@@ -0,0 +1 @@
+# m.printws
Added: grass-addons/grass7/misc/m.printws/m.printws.html
--- grass-addons/grass7/misc/m.printws/m.printws.html	                        (rev 0)
+++ grass-addons/grass7/misc/m.printws/m.printws.html	2016-08-09 11:44:13 UTC (rev 69111)
@@ -0,0 +1,168 @@
+<h2>DESCRIPTION</h2>
+<em>m.printws</em> adds a quick '<b>print w</b>ork<b>s</b>pace'
+function to GRASS GIS. Its purpose is to read a saved workspace file
+and render its content into a bitmap or PDF file similar to what the
+user configured in the workspace file for screen display, originally.
+As an opposite to other methods, the user is not required to create a separate map definition.
+<p>
+The module creates bitmap files so it is <b>not suitable to produce professional cartographic quality</b>.
+However, the following usage scenarios are recommended:
+<p>
+<ul>
+<li>Get a high resolution bitmap or PDF copy of a workspace composition to send in e-mail or include in office documents.
+</li>
+<li>Produce a quick printable page of the current screen composition.
+</li>
+<li>Use the main GRASS GIS window as a mapset composer. Supporting multiple displays whole mapset compositions
+could be saved as normal workspaces and printed in one run. Being a regular GRASS script it could be called from other
+scripts and command line as well. Even no GUI is necessary for it to run since it processes saved workspace files.
+</li>
+</ul>
+<h2>NOTES</h2>
+The module is set up to run with a full set of default values. To get quick result
+it is enough to specify the workspace file as input and the name of the output file without its exentsion
+since it is added autmatically depending on the selected output format. It creates a PDF format A4 landscape
+page at 150 dpi as default. Margins are 25mm, map area is 1000mm. Map frame is centered between the margins.
+<p>
+When selecting font, font names visible to GRASS GIS are not self evident. To ease font selection an "*" can be used to ask
+the script to look for a matching font. For example: <em>titlefont="Open*"</em> should find OpenSans or similar variations.
+<p>
+While running, the module modifies the map area edges ratio according to the region edges ratio.
+It also reduces the map area to fit between margins.
+It means that even faulty settings are corrected automatically.
+<b>This is why initial settings of 1000mm map size and -1,-1 placement results an optimally filled and fitted page.</b>
+<p>
+When reducing the target dpi resolution the content gerenation is very fast.
+It is recommended to run tests around 100dpi or lower and once we are satisfied with the layout
+it is time to set the final target dpi.
+<p>
+The module tries to render everything what are checked on the layer list and also adds overlays like barscale,
+legend and north arrow<b>*</b> <p>
+<small><i><b>*=as of July 2016 overlay modules positioning is buggy when rendering to file...</b></i></small>
+<p>
+<br>
+<br>
+Some <b>drawbacks</b> of the module which should be taken into consideration:
+<ul>
+<li>Depending on the number of layers with opacity lower than 100% the number of
+temporarily generated files may increase. An A4 300 dpi page consumes ~33MB
+disk space and when joining the layers all these are read into memory or swapped
+to disk by ImageMagick. Using many transparent layers, higher page size or higher
+resolution may slows down processing. Please check you system monitor while the module
+runs to follow memory and disk consumption. <b>The default 150 dpi</b> is good for testing compositions
+meanwhile also saves disk space and processing time. 300 dpi or more is recommended for production printouts only.
+</li>
+<li>Font size of <b>label files</b> is not fitted yet to the dpi set by the user. Label
+files should be regenerated to lower or higher font size according to dpi size.
+Please consider that modern screens are around 100dpi or higher. If you render
+300 dpi your labels should be drawn using 3 times bigger font size measured in dots.
+</li>
+</ul>
+The module saves current region and sets it back when finished.
+<h3>Multiple display support</h3>
+When your workspace contains more than one display definitions m.printws would create multiple maps printing all displays on a
+separate page in a separate file.
+File naming is automatic and works like demonstrated blow if having to displays named 'Downtown' and 'OVERVIEW OF CITY':
+<ul>
+<li>File name entered for output: /path/to/file/outname.pdf</li>
+<li>Generated map 1: /path/to/file/outname_DISPLAY_1_Downtown.pdf
+</li>
+<li>Generated map 2: /path/to/file/outname_DISPLAY_2_OVERVIEW OF CITY.pdf
+</li>
+</ul>
+When regenerating the map the files are overwritten. Selecting a full name as output (outname_DISPLAY_2_Downtown.pdf)
+the module will recognize its own additinons _DISPLAY_2_.... and .pdf and won't duplicate them in the newly generated filenames.
+<h3>Tips and tricks</h3>
+There is a macro possibility for titles.
+<ul>
+  <li>%DISPLAY% - as it is in the <b>title</b> field by default - in any of the text fields the name
+of the corresponting display will be used for text.</li>
+  <li>%USERNAME% - for user login name</li>
+  <li>%TIME24% - 15:25:33</li>
+  <li>%DATEYMD% - like 2016.08.02</li>
+  <li>%DATEMDY% - like 08/02/2016</li>
+  <li>%GXW% - name of the workspace file printed (full path)</li>
+</ul>
+<h3>Windows specific settings for ImageMagick</h3>
+ImageMagick (IM) is essential for merging createt map layers and convert to the desired format. On Windows,
+IM should be installed by the user and be sure to add IM program directory to the PATH. It is done by the
+IM installation program on windows. However, for GRASS GIS, the OSGeo4W environment should be changed.
+Find the <em>o4w_env.bat</em> file in the OSGeo4W installation path. This is usually
+under C:\OSGeo4W\bin.
+Look at this part:
+<div class="code"><pre>
+REM start with clean path
+set Path=%OSGEO4W_ROOT%\bin;%WINDIR%\system32;%WINDIR%;%WINDIR%\WBem
+</pre></div>
+and put back Windows path or if there is a collision in your system, add only
+IM path at the beginning (add %Path%; before the first occurence of %WINDIR%).
+set Path=%OSGEO4W_ROOT%\bin;%Path%;%WINDIR%\system32;%WINDIR%;%WINDIR%\WBem
+</pre></div>
+Save the .bat file. Restart GRASS GIS after this change. To check whether IM is accessible, in the GRASS GIS
+Layer Manager window click on <em>the Command console</em> tab and enter:
+magick convert
+</pre></div>
+If everything went fine, you will see the IM convert command help.
+<p>
+<h2>EXAMPLE</h2>
+# create a landscape 150dpi PDF copy of a workspace
+m.printws input=/home/kuszi/grassdata/Duna/maps/VP/nice_vectors_workspace.gxw \
+output=/home/kuszi/grassdata/Duna/maps/VP/sample_generated_printws maintitle=MAIN \
+subtitle=sub psunderleft=left psunderright=right psundercentral=center \
+region=cartosim_2 at PERMANENT pagemargin=10
+</pre></div>
+<center>
+  <img src="m.printws_screen.png" alt="Screen view of workspace" width="400px"><br>
+  <em>Figure: Screen view of workspace</em>
+</center><br>
+<center>
+  <img src="m.printws_sample_print.png" alt="m.printws run example" width="400px"><br>
+  <em>Figure: m.printws run example created from the same workspace</em>
+</center>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="g.gui.html">d.erase</a>,
+  <a href="ps.map.html">ps.map</a>,
+  <a href="d.label.html">d.label</a>,
+  <a href="http://www.imagemagick.org">ImageMagick</a>
+</em>
+<p>
+  <a href="variables.html#list-of-selected-grass-environment-variables-for-rendering">GRASS environment variables for
+  rendering</a> (GRASS_RENDER_FRAME)
+<h2>AUTHOR</h2>
+Robert Kuszinger, Giscom Kkt Hungary
+<p>
+Based on <em>d.*</em> commands and their functions in GRASS 7 by many authors.<br>
+Depends on <em>ImageMagick</em> multi-platform image manipulation tools.<br>
+<p>
+<i>Last changed: $Date: 2017-07-03 15:17:49 +0000 $</i>
Added: grass-addons/grass7/misc/m.printws/m.printws.py
--- grass-addons/grass7/misc/m.printws/m.printws.py	                        (rev 0)
+++ grass-addons/grass7/misc/m.printws/m.printws.py	2016-08-09 11:44:13 UTC (rev 69111)
@@ -0,0 +1,957 @@
+#!/usr/bin/env python
+# MODULE:       m.printws
+# AUTHOR(S):    Robert Kuszinger
+# PURPOSE:      Creates carographic-like map sheet page from
+#               a workspace composition
+# COPYRIGHT:    (C) 2016 by GRASS development team
+#               This program is free software under the GNU General
+#               Public License (>=v2). Read the file COPYING that
+#               comes with GRASS for details.
+#%module
+#% description: Opens a workspace file and creates a map sheet according to its visible contents.
+#% keyword: map
+#% keyword: print
+#% keyword: layout
+#% keyword: workspace
+#%end
+#%option G_OPT_F_BIN_INPUT
+#% key: input
+#% description: Name of workspace file to process
+#% required: YES
+#% gisprompt: old,bin,file
+#% guisection: Input
+#%end
+#%option
+#% key: dpi
+#% type: integer
+#% answer: 150
+#% multiple: no
+#% description: DPI for the generated page
+#% guisection: Output
+#%end
+#%option G_OPT_F_OUTPUT
+#% description: Name of output file without extension
+#% key: output
+#% gisprompt: new,file,file
+#%end
+#%option
+#% key: page
+#% type: string
+#% options: A4landscape,A4portrait,LETTERlandscape,LETTERportrait,A3landscape,A3portrait
+#% answer: A4landscape
+#% description: Output map page size
+#%end
+#%option
+#% key: format
+#% type: string
+#% options: jpg,png,bmp,pdf,ppm
+#% answer: pdf
+#% description: Output file format
+#%end
+#%option
+#% key: maintitle
+#% type: string
+#% answer: %DISPLAY%
+#% description: Main title of map sheet
+#% guisection: Titles
+#%end
+#%option
+#% key: titlefont
+#% type: string
+#% description: Font for title and postscript under the map
+#%end
+#%option G_OPT_C
+#% key: titlecolor
+#% type: string
+#% description: Title text color
+#%end
+#%option
+#% key: maintitlesize
+#% type: integer
+#% description: Main title font size in layout units
+#%end
+#%option
+#% key: subtitle
+#% type: string
+#% description: Subtitle text above the map sheet in the middle
+#%end
+#%option
+#% key: subtitlesize
+#% type: integer
+#%end
+#%option
+#% key: psunderleft
+#% type: string
+#% description: Postscript text under the map sheet on the left
+#%end
+#%option
+#% key: psunderright
+#% type: string
+#% description: Postscript text under the map sheet on the right
+#%end
+#%option
+#% key: psundercentral
+#% type: string
+#% description: Postscript text under the map sheet, centered
+#%end
+#%option
+#% key: pssize
+#% type: integer
+#% description: Postscript text font size in layout units
+#%end
+#%option G_OPT_M_REGION
+#% key:region
+#% description: Name of region to use - uses workspace displayed area if empty
+#% required: NO
+#% gisprompt: old,windows,region
+#%end
+#%flag
+#% key: d
+#% description: Debug - Leave temp files as is for alternative usage or checkup
+#% guisection: Optional
+#% suppress_required: yes
+#%end
+#%option
+#% key: layunits
+#% type: string
+#% options: cm,mm,inch
+#% answer: mm
+#% description: Unit used for layout specification
+#% guisection: Layout
+#%end
+#%option
+#% key: pagemargin
+#% type: string
+#% description: Margins in layout units left,right,top,bottom
+#%end
+#%option
+#% key: mapupperleft
+#% type: string
+#% answer: -1,-1
+#% description: Map frame upper left coordinates - negative means centering
+#%end
+#%option
+#% key: mapsize
+#% type: string
+#% answer: 1000
+#% description: Map frame size in layout units as width,height
+#%end
+#%option
+#% key: screendpi
+#% type: integer
+#% answer: 100
+#% description: The DPI of your monitor
+#%end
+import sys
+import os
+import pwd
+import atexit
+import re
+#from subprocess import call
+import tempfile
+import grass.script as grass
+from grass.exceptions import CalledModuleError
+from grass.script.utils import try_rmdir
+import copy
+import time
+# initialize global vars
+TMPFORMAT = 'BMP'
+TMPLOC = None
+SRCGISRC = None
+GISDBASE = None
+LAYERCOUNT = 10
+# temp dir
+REMOVE_TMPDIR = True
+PROXIES = {}
+# set upsize "constants"
+UPSD = {}
+ALLTASKDIC = {}
+ALLTASKDIC['width'] = 1.0  # 1 by 1 correction if any
+ALLTASKDIC['fontsize'] = 1.0  # 1 by 1 correction if any
+UPSD['*'] = ALLTASKDIC
+DVECTDIC = {}
+DVECTDIC['size'] = 1.0  # 1 by 1 correction if any
+UPSD['d.vect'] = DVECTDIC
+# PAGE dictionary
+PAGEDIC = {}
+PAGEDIC['A4portrait'] = (210.0, 297.0, '', 'A4')
+PAGEDIC['A4landscape'] = (297.0, 210.0, '', 'A4')
+PAGEDIC['A3portrait'] = (297.0, 420.0, '', 'A3')
+PAGEDIC['A3landscape'] = (420.0, 297.0, '', 'A3')
+PAGEDIC['LETTERportrait'] = (215.9, 297.4, '', 'Letter')
+PAGEDIC['LETTERlandscape'] = (297.4, 215.9, '', 'Letter')
+# HTML DECODE
+HTMLDIC = {}
+HTMLDIC['>'] = '>'
+HTMLDIC['<'] = '<'
+HTMLDIC['&'] = '&'
+HTMLDIC['"'] = '"'
+def cleanup():
+    # No cleanup is done here
+    # see end of main()
+    # kept for later
+    grass.verbose(_("Module cleanup"))
+def upsizeifnecessary(task, lastparam, value, upsize):
+    val = UPSD.get('*').get(lastparam, 0.0)
+    if val > 0:
+        return str(float(value) * val * upsize)
+    val = UPSD.get(task, {}).get(lastparam, 0.0)
+    if val > 0:
+    return value
+def htmldecode(str):
+    dic = HTMLDIC
+    answer = str
+    for key in dic:
+        answer = answer.replace(key, dic[key])
+    return answer
+def readworkspace(wspname, upsize):
+    # READS WORKSPACE FILE
+    # Anyone familiar with XML please replace to a well formed parser
+    # returns an array of two element arrays, where the two elements are:
+    # opacity as string, being '1' for opacity 1 and
+    # grass command reconstructed as a string from the worskpace definition
+    # the bottommost layer should be first on the list, meanwhile any overlays (barscale
+    # etc) should be last. The algorythm below does this exactly but using
+    # regex
+    searchmode = 'display'
+    extents = []
+    startnew = False
+    parameters = ''    # working method
+    flag = ''
+    displaydic = {}    # adding support for more displays
+    paramdic = {}      # migrating to grass.run calls / done 2016.07.30
+    flagdic = {}
+    task = ''
+    layers = []
+    grass.verbose(_("Layers: "))
+    f = open(wspname, 'r')
+    for line in f:
+        if searchmode == 'display':
+            # grass.message("  DISPLAY:"+line)    #was debug message
+            # NEED TO HANDLE more displays...!
+            m = re.search(
+                '(display name="([a-zA-Z\ 0-9]+)".+dim="([0-9\,]+)".+extent="([0-9\.\-\,]+)")', line)
+            if m:
+                display = m.group(2)
+                extentall = m.group(4)
+                extents = extentall.split(",")
+                dimall = m.group(3)
+                dims = dimall.split(",")
+                extents.extend(dims)
+                searchmode = 'layer'
+        if searchmode == 'layer':
+            m = re.search(
+                '(layer type="([a-zA-Z]+)".+checked="1"\ opacity="([0-9\.]+)"|overlay name="([a-zA-Z\.]+)")', line)
+            if m:
+                if m.group(2):
+                    layer = m.group(2)
+                    # if it is an overly, opacity is 100..... handle this
+                    opacity = m.group(3)
+                    startnew = True
+                    if m.group(3).startswith('1'):
+                        startnew = False
+                    searchmode = 'task'
+                elif m.group(4):
+                    opactiy = '1'
+                    task = m.group(4)
+                    paramdic['task'] = task
+                    startnew = False
+                    searchmode = 'parameters'
+            # in layer mode a /display could also come
+            m = re.search('</display>', line)
+            if m:
+                # storing layers under display in a dictionary
+                layers.insert(0, extents)
+                displaydic[display] = copy.deepcopy(layers)
+                layers = []
+        elif searchmode == 'task':
+            m = re.search('task name="(.+)"', line)
+            if m:
+                task = m.group(1)
+        elif searchmode == 'parameters':
+            m = re.search('(parameter) name="(.+)"|(flag) name="(.+)"', line)
+            if m:
+                if m.group(1) == 'parameter':
+                    parameters = parameters + ' ' + m.group(2) + '="'
+                    lastparam = m.group(2)
+                else:  # adding flags handling
+                    flag = flag + ' -' + m.group(4)
+                    flagdic[m.group(4)] = m.group(4)
+                    # grass.message("FLAG: "+m.group(4))    # was debug message
+            else:
+                m = re.search('<value>(.*)</value>', line)
+                if m:
+                    htmldecoded = htmldecode(m.group(1))
+                    upsized = upsizeifnecessary(
+                        task, lastparam, htmldecoded, upsize)
+                    parameters = parameters + '' + str(upsized) + '"'
+                    paramdic[lastparam] = str(upsized)
+                else:
+                    m = re.search('(</layer>)|(</overlay>)', line)
+                    if m:
+                        if startnew:
+                            if m.group(1):
+                                layers.insert(
+                                    0, (opacity, task + flag + parameters, paramdic, flagdic))
+                            else:
+                                layers.append(
+                                    (opacity, task + flag + parameters, paramdic, flagdic))
+                            grass.verbose(_(opacity + ' >> ' + str(display) + " >> " + task +
+                                            flag + parameters + " pd:" + str(paramdic) + " fd:" + str(flagdic)))
+                        else:
+                            if m.group(1):
+                                layers.insert(
+                                    0, ('1', task + flag + parameters, paramdic, flagdic))
+                            else:
+                                layers.append(
+                                    ('1', task + flag + parameters, paramdic, flagdic))
+                            grass.verbose(_('1 >> ' + str(display) + " >> " + task + flag +
+                        parameters = ''
+                        paramdic = {}
+                        flag = ''
+                        flagdic = {}
+    f.close()
+    return displaydic
+def converttommfrom(value, fromunit):
+    #converting some basic units to mm
+    d = {'mm': 1, 'cm': 10, 'inch': 25.4}
+    return (value * d[fromunit])
+def getpagemargins(option, unit):
+    # we live on mm so convert user input as specified by unit
+    d = {}
+    if len(option) < 1:
+        d['l'] = 25.0
+        d['r'] = 25.0
+        d['t'] = 25.0
+        d['b'] = 25.0
+        return d
+    temp = option.split(",")
+    d['l'] = converttommfrom(float(temp[0]), unit)
+    if len(temp) < 4:
+        d['r'] = d['l']
+        d['t'] = d['l']
+        d['b'] = d['l']
+        return d
+    d['r'] = converttommfrom(float(temp[1]), unit)
+    d['t'] = converttommfrom(float(temp[2]), unit)
+    d['b'] = converttommfrom(float(temp[3]), unit)
+    return d
+def getpagedata(page):
+    # returns page description data dictionary for the selected page
+    d = PAGEDIC
+    w = d[page][0]
+    h = d[page][1]
+    return {'width': w, 'w': w, 'height': h, 'h': h, 'page': d[page][3], 'parameters': d[page][2]}
+def getpagesizes(page):
+    # return page sizes only in dictionary
+    d = PAGEDIC
+    w = d[page][0]
+    h = d[page][1]
+    return {'width': w, 'w': w, 'height': h, 'h': h}
+def dictodots(dic, dpi):
+    # takes all values from a dictionary and returns another dic with
+    # incoming mm values converted to dots
+    d2 = {}
+    for key in dic:
+        d2[key] = int(round(dic[key] / 25.4 * dpi))
+    return d2
+def dictomm(dic, dpi):
+    # incoming dot values converted to mm
+    d2 = {}
+    for key in dic:
+        d2[key] = dic[key] * 25.4 / dpi
+    return d2
+def getmaxframeindots(marginsindots, pagesizesindots):
+    #returns available area on page in print dots (=pixels)
+    l = marginsindots['l']
+    r = pagesizesindots['w'] - marginsindots['r']
+    t = marginsindots['t']
+    b = pagesizesindots['h'] - marginsindots['b']
+    return {'t': t, 'b': b, 'l': l, 'r': r}
+def getmapUL(option, unit):
+    # processes user entered option for map area upper left corner
+    # r - right d - down from top left of page
+    d = {}
+        d['r'] = 0.0
+        d['d'] = 0.0
+        return d
+    d['r'] = converttommfrom(float(temp[0]), unit)
+    if len(temp) < 2:
+        d['d'] = d['r']
+        return d
+    d['d'] = converttommfrom(float(temp[1]), unit)
+    return d
+def getmapsizes(option, unit):
+    # processes user entered option for map size
+    # width and height
+    d = {}
+        d['w'] = 1000.0
+        d['h'] = 1000.0
+        return d
+    d['w'] = converttommfrom(float(temp[0]), unit)
+    if len(temp) < 2:
+        d['h'] = d['w']
+        return d
+    d['h'] = converttommfrom(float(temp[1]), unit)
+    return d
+def getmapframeindots(mapulindots, mapsizesindots, mxfd):
+    d = {}
+    # if map frame is bigger then area between margins it is
+    # shrinked to fit
+    mirrorwidth = abs(mxfd['r'] - mxfd['l']) + 1
+    mirrorheight = abs(mxfd['b'] - mxfd['t']) + 1
+    if mirrorwidth < mapsizesindots['w']:
+        wr = float(mirrorwidth) / mapsizesindots['w']
+        mapsizesindots['w'] = int(round(mapsizesindots['w'] * wr))
+        mapsizesindots['h'] = int(round(mapsizesindots['h'] * wr))
+    if mirrorheight < mapsizesindots['h']:
+        hr = float(mirrorheight) / mapsizesindots['h']
+        mapsizesindots['w'] = int(round(mapsizesindots['w'] * hr))
+        mapsizesindots['h'] = int(round(mapsizesindots['h'] * hr))
+    if mapulindots['r'] < 0:
+        realw = min(mirrorwidth, mapsizesindots['w'])
+        unusedhalf = int(round((mirrorwidth - realw) / 2))
+        d['l'] = mxfd['l'] + unusedhalf
+        d['r'] = mxfd['r'] - unusedhalf
+    else:
+        d['l'] = max(mxfd['l'], mapulindots['r'])
+        d['r'] = min(mxfd['r'], mapulindots['r'] + mapsizesindots['w'])
+    if mapulindots['d'] < 0:
+        realh = min(mirrorheight, mapsizesindots['h'])
+        unusedhalf = int(round((mirrorheight - realh) / 2))
+        d['t'] = mxfd['t'] + unusedhalf
+        d['b'] = mxfd['b'] - unusedhalf
+    else:
+        d['t'] = max(mxfd['t'], mapulindots['d'])
+        d['b'] = min(mxfd['b'], mapulindots['d'] + mapsizesindots['h'])
+    d['h'] = d['b'] - d['t'] + 1
+    d['w'] = d['r'] - d['l'] + 1
+    return d
+def render(astring, pdic, fdic):
+    grass.verbose(_("printws: Rendering into - BASE: " + LASTFILE))
+    grass.verbose(_("printws: Rendering command: " + astring))
+    pdic = copy.deepcopy(pdic)  # parameters
+    fdic = copy.deepcopy(fdic)  # flags
+    flags = ''
+    for key in fdic:
+        if key:
+            # grass.message(" KEY:"+str(key))  #was debug message
+            flags = flags + key
+    pdic['flags'] = flags
+    task = pdic['task']
+    del pdic['task']
+    # it should be replaced by grass.* API calls
+    # os.system(astring)
+    grass.run_command(task, **pdic)  # migration is going on
+def getfontbypattern(kindpattern):
+    # truetype and others which are likely utf8 start with capital font names
+    # also some fonts with _ in names seemed to be utf8 for sure
+    # fonts with space and : and without capital letter are excluded from
+    # randomization
+    s = grass.read_command("d.fontlist")
+    safe = 'romans'
+    split = s.splitlines()
+    for l in split:
+        # check if it has : or space.
+        m = re.search('[\:\ ]+', l, re.IGNORECASE)
+        if not m:
+            m = re.search('(.*' + kindpattern + '.*)', l, re.IGNORECASE)
+            if m:
+                if (safe == 'romans') or (len(safe) > len(l)):
+                    # change only to simpler variant
+                    # simpler variant names are usually shorter
+                    safe = l
+    if safe == 'romans':
+        for l in split:
+            if not m:
+                m = re.search('[A-Z].+[_].+', l, re.IGNORECASE)
+                if m:
+                    safe = l
+                    return safe     # returns first suitable font, won't run through all of them
+    return safe
+    # print "printws: Selected font: " + safe
+def decodetextmacros(text, dic):
+    result = text
+    for key in dic:
+        result = re.sub(key, dic[key], result)
+    return result
+#------------------- MAIN ---------------------------
+def main():
+    global GISDBASE, LAYERCOUNT, LASTFILE
+    textmacros = {}
+    textmacros['%TIME24%'] = time.strftime("%H:%M:%S")
+    textmacros['%DATEYMD%'] = time.strftime("%Y.%m.%d")
+    textmacros['%DATEMDY%'] = time.strftime("%m/%d/%Y")
+    textmacros['%USERNAME%'] = pwd.getpwuid(os.getuid())[0]
+    # saves region for restoring at end
+    savedregionname = "tmp.%s.%d" % (
+        os.path.basename(sys.argv[0]), os.getpid())
+    grass.run_command("g.region", save=savedregionname, overwrite=True)
+    # getting/setting screen/print dpi ratio
+    if len(options['dpi']) > 0:
+        dpioption = float(options['dpi'])
+    else:
+        dpioption = 150.0
+    if len(options['screendpi']) > 0:
+        screendpioption = float(options['screendpi'])
+    else:
+        screendpioption = 100.0
+    upsize = dpioption / screendpioption
+    if len(options['input']) > 0:
+        displays = readworkspace(options['input'], upsize)
+    else:
+        quit()
+    textmacros['%GXW%'] = options['input']
+    displaycounter = 0
+    # there could be multiple displays in a workspace so we loop them
+    # each display is a whole and independent file assembly
+    for key in displays:
+        textmacros['%DISPLAY%'] = key
+        grass.verbose(_('printws: rendering display: ' + key))
+        displaycounter = displaycounter + 1
+        layers = copy.deepcopy(displays[key])
+        # extracting extent information from layers dic and erase the item
+        # extents[0-5] w s e n minz maxz ;  extents [6-9] window x y w h
+        extents = layers[0]
+        grass.verbose("m.printws: EXTENTS from workspace:" +
+                      str(extents))  # was debug message
+        del layers[0]
+        regionmode = ''
+        if len(options['region']) > 0:
+            grass.run_command("g.region", region=options['region'])
+            regionmode = 'region'
+        else:
+            grass.run_command("g.region", "", w=extents[0], s=extents[
+                              1], e=extents[2], n=extents[3])
+            regionmode = 'window'
+        #setting GRASS rendering environment
+        os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+        os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
+        os.environ['GRASS_RENDER_TRANSPARENT'] = 'TRUE'
+        os.environ['GRASS_RENDER_FILE_COMPRESSION'] = '0'
+        os.environ['GRASS_RENDER_FILE_MAPPED'] = 'TRUE'
+        # reading further options and setting defaults
+        if len(options['page']) > 0:
+            pageoption = options['page']
+        else:
+            pageoption = 'A4landscape'
+        # parsing titles, etc.
+        if len(options['titlefont']) > 1:
+            isAsterisk = options['titlefont'].find('*')
+            if isAsterisk > 0:
+                titlefont = getfontbypattern(
+                    options['titlefont'].replace('*', ''))
+            else:
+                titlefont = options['titlefont']
+        else:
+            titlefont = getfontbypattern('Open')  # try to find something UTF-8
+        grass.verbose(_("printws: titlefont: " + titlefont))
+        if len(options['titlecolor']) > 1:
+            titlecolor = options['titlecolor']
+        else:
+            titlecolor = black
+        if len(options['maintitlesize']) > 1:
+            maintitlesize = converttommfrom(
+                float(options['maintitlesize']), options['layunits'])
+        else:
+            maintitlesize = 10.0
+        if len(options['subtitlesize']) > 1:
+            subtitlesize = converttommfrom(
+                float(options['subtitlesize']), options['layunits'])
+        else:
+            subtitlesize = 7.0
+        if len(options['pssize']) > 1:
+            pssize = converttommfrom(
+                float(options['pssize']), options['layunits'])
+        else:
+            pssize = 5.0
+        # Please fasten your seatbelts :) Calculations start here.
+        pagesizes = getpagesizes(pageoption)
+        pagesizesindots = dictodots(pagesizes, dpioption)
+        # Leave space for titles up and ps down
+        upperspace = 0
+        subtitletop = 0
+        if len(options['maintitle']) > 0:
+            upperspace = upperspace + maintitlesize * 1.2
+            subtitletop = maintitlesize * 1.2
+        if len(options['subtitle']) > 0:
+            upperspace = upperspace + subtitlesize * 1.2
+        lowerspace = 0
+        if (len(options['psundercentral']) > 0) or (len(options['psunderright']) > 0) or (len(options['psunderleft']) > 0):
+            lowerspace = lowerspace + pssize * 1.2
+        os.environ['GRASS_RENDER_WIDTH'] = str(pagesizesindots['w'])
+        os.environ['GRASS_RENDER_HEIGHT'] = str(pagesizesindots['h'])
+        pagemargins = getpagemargins(
+            options['pagemargin'], options['layunits'])
+        pagemarginsindots = dictodots(pagemargins, dpioption)
+        # Getting max drawing area in dots
+        mxfd = getmaxframeindots(pagemarginsindots, pagesizesindots)
+        maxframe = str(mxfd['t']) + ',' + str(mxfd['b']) + \
+            ',' + str(mxfd['l']) + ',' + str(mxfd['r'])
+        # convert font size to percentage for d.text
+        mxfmm = dictomm(mxfd, dpioption)
+        maintitlesize = maintitlesize / (mxfmm['b'] - mxfmm['t']) * 100.0
+        subtitlesize = subtitlesize / (mxfmm['b'] - mxfmm['t']) * 100.0
+        pssize = pssize / (mxfmm['r'] - mxfmm['l']) * 100.0
+        # subtitle location is another issue
+        subtitletoppercent = 100.0 - subtitletop / \
+            (mxfmm['b'] - mxfmm['t']) * 100.0
+        mapul = getmapUL(options['mapupperleft'], options['layunits'])
+        mapulindots = dictodots(mapul, dpioption)
+        mapsizes = getmapsizes(options['mapsize'], options['layunits'])
+        mapsizesindots = dictodots(mapsizes, dpioption)
+        # Correcting map area ratio to ratio of region edges
+        # OR screen window edges depeding on "regionmode"
+        # for later:     grass.use_temp_region()
+        s = grass.read_command("g.region", flags='p')
+        kv = grass.parse_key_val(s, sep=':')
+        regioncols = float(kv['cols'].strip())
+        regionrows = float(kv['rows'].strip())
+        ewres = float(kv['ewres'].strip())
+        nsres = float(kv['nsres'].strip())
+        sizex = regioncols * ewres
+        sizey = regionrows * nsres
+        if regionmode == 'region':
+            hregionratio = sizex / sizey
+            grass.verbose(_("printws: REGION MODE - region "))
+        else:  # surprisingly doing the SAME
+            # using screen window ratio for map area
+            # next line was a test for this but didn't help on gadgets positioning
+            #hregionratio = float(extents[8]) / float(extents[9])
+            grass.verbose(_("printws: REGION MODE - window"))
+        hmapratio = mapsizes['w'] / mapsizes['h']
+        grass.verbose(_("printws: raw mapsizes: " + str(mapsizesindots)))
+        grass.verbose(_("printws: hr: " + str(hregionratio)))
+        grass.verbose(_("printws: hm: " + str(hmapratio)))
+        if hregionratio > hmapratio:
+            grass.verbose(
+                _("printws: Map area height correction / " + str(hregionratio)))
+            mapsizes['h'] = mapsizes['w'] / hregionratio
+        elif hregionratio < hmapratio:
+            grass.verbose(
+                _("printws: Map area width correction * " + str(hregionratio)))
+            mapsizes['w'] = mapsizes['h'] * hregionratio
+        # changing region resolution to match print resolution
+        # to eliminate unnecessary CPU/data transfer (make it faster
+        # with invisible detail loss only). Does only downscale.
+        colsregiontomap = mapsizesindots['w'] / regioncols
+        rowsregiontomap = mapsizesindots['h'] / regionrows
+        newewres = ewres
+        newnsres = nsres
+        if colsregiontomap < 1:
+            newewres = ewres / colsregiontomap
+        if rowsregiontomap < 1:
+            newnsres = nsres / rowsregiontomap
+        grass.run_command("g.region", ewres=str(newewres), nsres=str(newnsres))
+        # Getting mapping area in dots
+        # Correcting mxfd to leave space for title and subscript
+        pagemarginstitles = copy.deepcopy(pagemargins)
+        pagemarginstitles['t'] = pagemarginstitles['t'] + upperspace
+        pagemarginstitles['b'] = pagemarginstitles['b'] + lowerspace
+        pagemarginsindotstitles = dictodots(pagemarginstitles, dpioption)
+        mxfdtitles = getmaxframeindots(
+            pagemarginsindotstitles, pagesizesindots)
+        mpfd = getmapframeindots(mapulindots, mapsizesindots, mxfdtitles)
+        mapframe = str(mpfd['t']) + ',' + str(mpfd['b']) + \
+            ',' + str(mpfd['l']) + ',' + str(mpfd['r'])
+        grass.verbose(_("printws: DOT VALUES ARE:"))
+        grass.verbose(_("printws: maxframe: " + str(mxfd)))
+        grass.verbose(_("printws: maxframe: " + maxframe))
+        grass.verbose(_("printws: mapframe: " + str(mpfd)))
+        grass.verbose(_("printws: mapframe: " + mapframe))
+        grass.verbose(_("printws: page: " + str(pagesizesindots)))
+        grass.verbose(_("printws: margins: " + str(pagemarginsindots)))
+        grass.verbose(_("printws: mapUL: " + str(mapulindots)))
+        grass.verbose(
+            _("printws: mapsizes (corrected): " + str(mapsizesindots)))
+        grass.verbose(_("printws: ewres (corrected): " + str(newewres)))
+        grass.verbose(_("printws: nsres (corrected): " + str(newnsres)))
+        # quit()
+        # ------------------- INMAP -------------------
+        imcommand = 'convert  -limit memory 720000000 -limit map 720000000 -units PixelsPerInch -density ' + \
+            str(int(dpioption)) + ' '
+        if os.name == 'nt':
+            imcommand = 'magick ' + imcommand
+        os.environ['GRASS_RENDER_FRAME'] = mapframe
+        grass.verbose(_("printws: Rendering: the following layers: "))
+        lastopacity = '-1'
+        for lay in layers:
+            grass.verbose(_(lay[1] + ' at: ' + lay[0] + ' opacity'))
+            if lay[0] == '1':
+                if lastopacity <> '1':
+                    LASTFILE = os.path.join(TMPDIR, str(os.getpid(
+                    )) + '_DIS_' + str(displaycounter) + '_GEN_' + str(LAYERCOUNT) + '.' + TMPFORMAT)
+                    os.environ['GRASS_RENDER_FILE'] = LASTFILE
+                    LAYERCOUNT = LAYERCOUNT + 2
+                    imcommand = imcommand + ' ' + LASTFILE
+                    lastopacity = '1'
+                render(lay[1], lay[2], lay[3])
+            else:
+                lastopacity = lay[0]
+                grass.verbose("LAY: " + str(lay))
+                imcommand = imcommand + \
+                    ' \( ' + LASTFILE + ' -channel a -evaluate multiply ' + \
+                    lay[0] + ' +channel \)'
+        # setting resolution back to pre-script state since map rendering is
+        # finished
+        # ------------------- OUTSIDE MAP texts, etc -------------------
+        os.environ['GRASS_RENDER_FRAME'] = maxframe
+        dict = {}
+        dict['task'] = "d.text"
+        dict['color'] = titlecolor
+        dict['font'] = titlefont
+        dict['charset'] = "UTF-8"
+        if len(options['maintitle']) > 1:
+            dict['text'] = decodetextmacros(options['maintitle'], textmacros)
+            dict['at'] = "50,99"
+            dict['align'] = "uc"
+            dict['size'] = str(maintitlesize)
+            render(str(dict), dict, {})
+        if len(options['subtitle']) > 1:
+            dict['text'] = decodetextmacros(options['subtitle'], textmacros)
+            dict['at'] = "50," + str(subtitletoppercent)
+            dict['size'] = str(subtitlesize)
+        dict['size'] = str(pssize)
+        if len(options['psundercentral']) > 1:
+                options['psundercentral'], textmacros)
+            dict['at'] = "50,1"
+            dict['align'] = "lc"
+        if len(options['psunderleft']) > 1:
+            dict['text'] = decodetextmacros(options['psunderleft'], textmacros)
+            dict['at'] = "0,1"
+            dict['align'] = "ll"
+        if len(options['psunderright']) > 1:
+                options['psunderright'], textmacros)
+            dict['at'] = "100,1"
+            dict['align'] = "lr"
+        # ------------------- GENERATING OUTPUT FILE -------------------
+        if len(options['output']) > 1:
+            output = options['output']
+        else:
+            output = 'map_' + str(os.getpid())
+        # remove extension AND display number and naming if any
+        output = os.path.splitext(output)[0]
+        output = re.sub('_DISPLAY_[0-9]+_.*', '', output)
+        if len(options['format']) > 1:
+            extension = options['format']
+        else:
+            extension = 'pdf'
+        displaypart = ''
+        if len(displays) > 1:
+            displaypart = '_DISPLAY_' + str(displaycounter) + '_' + key
+        pagedata = getpagedata(pageoption)
+        #params= ' -extent '+str(pagesizesindots['w'])+'x'+str(pagesizesindots['h'])+' -gravity center -compress jpeg -page '+pagedata['page']+' '+pagedata['parameters']+' -units PixelsPerInch -density '+str(dpioption)+'x'+str(dpioption)+' '
+        params = ' -compress jpeg -quality 92 ' + \
+            pagedata['parameters'] + ' -units PixelsPerInch -density ' + \
+        imcommand = imcommand + ' -layers flatten ' + params + \
+            '"' + output + displaypart + '.' + extension + '"'
+        grass.verbose(
+            _('printws: And the imagemagick command is... ' + imcommand))
+        os.system(imcommand)
+    if not flags['d']:
+        grass.verbose(_('printws: Doing graceful cleanup...'))
+        os.system('rm ' + os.path.join(TMPDIR, str(os.getpid()) + '*_GEN_*'))
+        if REMOVE_TMPDIR:
+            try_rmdir(TMPDIR)
+        else:
+            grass.message("\n%s\n" % _(
+                "printws: Temp dir remove failed. Do it yourself, please:"))
+            sys.stderr.write('%s\n' % TMPDIR % ' <---- this')
+    # restoring pre-script region
+    grass.run_command("g.region", region=savedregionname, overwrite=True)
+    grass.run_command('g.remove', flags="f", type="region",
+                      pattern=savedregionname)
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    global TMPDIR
+    TMPDIR = tempfile.mkdtemp()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/misc/m.printws/m.printws.py
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/misc/m.printws/m.printws_sample_print.png
(Binary files differ)
Property changes on: grass-addons/grass7/misc/m.printws/m.printws_sample_print.png
Added: svn:mime-type
   + image/png
Added: grass-addons/grass7/misc/m.printws/m.printws_screen.png
Property changes on: grass-addons/grass7/misc/m.printws/m.printws_screen.png
   + image/png
