[GRASS-SVN] r69113 - grass-addons/grass7/misc/m.printws
svn_grass at osgeo.org
Tue Aug 9 05:55:29 PDT 2016
Author: kuszinger
Date: 2016-08-09 05:55:29 -0700 (Tue, 09 Aug 2016)
New Revision: 69113
grass-addons/grass7/misc/m.printws/m.printws.py
Eliminating cairo driver auto created map.png file
in current directory
Modified: grass-addons/grass7/misc/m.printws/m.printws.py
--- grass-addons/grass7/misc/m.printws/m.printws.py 2016-08-09 11:59:10 UTC (rev 69112)
+++ grass-addons/grass7/misc/m.printws/m.printws.py 2016-08-09 12:55:29 UTC (rev 69113)
@@ -640,8 +640,13 @@
1], e=extents[2], n=extents[3])
regionmode = 'window'
- #setting GRASS rendering environment
+ # setting GRASS rendering environment
+ # dummy file name is defined since the following lines
+ # when switching on the cairo driver would create
+ # an empty map.png in the current directory
+ os.environ['GRASS_RENDER_FILE'] = os.path.join(TMPDIR, str(os.getpid(
+ )) + '_DIS_' + str(00) + '_GEN_' + str(00) + '.png')
os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
os.environ['GRASS_RENDER_TRANSPARENT'] = 'TRUE'
