[GRASS-SVN] r69115 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Tue Aug 9 13:16:41 PDT 2016
Author: annakrat
Date: 2016-08-09 13:16:41 -0700 (Tue, 09 Aug 2016)
New Revision: 69115
grass/trunk/display/d.vect/main.c
d.vect: add flag to not put the layer in legend, see #3122
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2016-08-09 20:07:29 UTC (rev 69114)
+++ grass/trunk/display/d.vect/main.c 2016-08-09 20:16:41 UTC (rev 69115)
@@ -55,7 +55,7 @@
struct Option *width_opt, *wcolumn_opt, *wscale_opt;
struct Option *leglab_opt;
struct Option *icon_line_opt, *icon_area_opt;
- struct Flag *id_flag, *cats_acolors_flag, *sqrt_flag;
+ struct Flag *id_flag, *cats_acolors_flag, *sqrt_flag, *legend_flag;
char *desc;
struct cat_list *Clist;
@@ -324,6 +324,11 @@
"instead of circle radius");
sqrt_flag->guisection = _("Symbols");
+ legend_flag = G_define_flag();
+ legend_flag->key = 'l';
+ legend_flag->label = _("Do not add this layer to vector legend");
+ legend_flag->guisection = _("Legend");
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -453,10 +458,13 @@
stat += display_dir(&Map, type, Clist, chcat, size);
- write_into_legfile(&Map, type, leglab_opt->answer, map_name,
- icon_opt->answer, size_opt->answer, color_opt->answer,
- fcolor_opt->answer, width_opt->answer, icon_area_opt->answer,
+ if (!legend_flag->answer) {
+ write_into_legfile(&Map, type, leglab_opt->answer, map_name,
+ icon_opt->answer, size_opt->answer,
+ color_opt->answer, fcolor_opt->answer,
+ width_opt->answer, icon_area_opt->answer,
icon_line_opt->answer);
/* reset line width: Do we need to get line width from display
* driver (not implemented)? It will help restore previous line
