[GRASS-SVN] r69129 - grass/branches/releasebranch_7_2/raster/r.out.gdal
Thu Aug 11 12:07:38 PDT 2016
Author: mmetz
Date: 2016-08-11 12:07:38 -0700 (Thu, 11 Aug 2016)
New Revision: 69129
   grass/branches/releasebranch_7_2/raster/r.out.gdal/export_band.c
   grass/branches/releasebranch_7_2/raster/r.out.gdal/local_proto.h
   grass/branches/releasebranch_7_2/raster/r.out.gdal/main.c
r.out.gdal: enhance compatibility WRT metadata (backport trunk r69128)
Modified: grass/branches/releasebranch_7_2/raster/r.out.gdal/export_band.c
--- grass/branches/releasebranch_7_2/raster/r.out.gdal/export_band.c	2016-08-11 19:06:32 UTC (rev 69128)
+++ grass/branches/releasebranch_7_2/raster/r.out.gdal/export_band.c	2016-08-11 19:07:38 UTC (rev 69129)
@@ -202,7 +202,8 @@
 int export_band(GDALDatasetH hMEMDS, int band,
 		const char *name, const char *mapset,
 		struct Cell_head *cellhead, RASTER_MAP_TYPE maptype,
-		double nodataval, int suppress_main_colortable)
+		double nodataval, int suppress_main_colortable,
+		int no_metadata, int writenodata)
     struct Colors sGrassColors;
     GDALColorTableH hCT;
@@ -237,9 +238,6 @@
 	Rast_get_fp_range_min_max(&sRange, &dfCellMin, &dfCellMax);
-    sprintf(value, "GRASS GIS %s", GRASS_VERSION_NUMBER);
-    GDALSetMetadataItem(hBand, "Generated_with", value, NULL);
     /* use default color rules if no color rules are given */
     if (Rast_read_colors(name, mapset, &sGrassColors) >= 0) {
 	int maxcolor, i;
@@ -312,28 +310,30 @@
 	    GDALSetRasterColorTable(hBand, hCT);
-	if (rcount > 0) {
-	    /* Create metadata entries for color table rules */
-	    sprintf(value, "%d", rcount);
-	    GDALSetMetadataItem(hBand, "COLOR_TABLE_RULES_COUNT", value,
-				NULL);
+	if (!no_metadata) {
+	    if (rcount > 0) {
+		/* Create metadata entries for color table rules */
+		sprintf(value, "%d", rcount);
+		GDALSetMetadataItem(hBand, "COLOR_TABLE_RULES_COUNT", value,
+				    NULL);
-	/* Add the rules in reverse order */
-	/* This can cause a GDAL warning with many rules, something like
-	 * Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag. */
-	for (i = rcount - 1; i >= 0; i--) {
-	    DCELL val1, val2;
-	    unsigned char r1, g1, b1, r2, g2, b2;
+	    /* Add the rules in reverse order */
+	    /* This can cause a GDAL warning with many rules, something like
+	     * Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag. */
+	    for (i = rcount - 1; i >= 0; i--) {
+		DCELL val1, val2;
+		unsigned char r1, g1, b1, r2, g2, b2;
-	    Rast_get_fp_color_rule(&val1, &r1, &g1, &b1, &val2, &r2, &g2, &b2,
-			       &sGrassColors, i);
+		Rast_get_fp_color_rule(&val1, &r1, &g1, &b1, &val2, &r2, &g2, &b2,
+				   &sGrassColors, i);
-	    sprintf(key, "COLOR_TABLE_RULE_RGB_%d", rcount - i - 1);
-	    sprintf(value, "%e %e %d %d %d %d %d %d", val1, val2, r1, g1, b1,
-		    r2, g2, b2);
-	    GDALSetMetadataItem(hBand, key, value, NULL);
+		sprintf(key, "COLOR_TABLE_RULE_RGB_%d", rcount - i - 1);
+		sprintf(value, "%e %e %d %d %d %d %d %d", val1, val2, r1, g1, b1,
+			r2, g2, b2);
+		GDALSetMetadataItem(hBand, key, value, NULL);
@@ -442,6 +442,8 @@
 	    G_percent(row + 1, rows, 2);
+    if (writenodata && n_nulls == 0)
+	GDALSetRasterNoDataValue(hBand, nodataval);
     Rast_close(fd);
Modified: grass/branches/releasebranch_7_2/raster/r.out.gdal/local_proto.h
--- grass/branches/releasebranch_7_2/raster/r.out.gdal/local_proto.h	2016-08-11 19:06:32 UTC (rev 69128)
+++ grass/branches/releasebranch_7_2/raster/r.out.gdal/local_proto.h	2016-08-11 19:07:38 UTC (rev 69129)
@@ -56,7 +56,7 @@
 /* export_band.c */
 int export_band(GDALDatasetH, int, const char *,
 		const char *, struct Cell_head *, RASTER_MAP_TYPE,
-		double, int);
+		double, int, int, int);
 int exact_checks(GDALDataType, const char *, const char *,
                  struct Cell_head *, RASTER_MAP_TYPE, double,
 		 const char *, int);
Modified: grass/branches/releasebranch_7_2/raster/r.out.gdal/main.c
--- grass/branches/releasebranch_7_2/raster/r.out.gdal/main.c	2016-08-11 19:06:32 UTC (rev 69128)
+++ grass/branches/releasebranch_7_2/raster/r.out.gdal/main.c	2016-08-11 19:07:38 UTC (rev 69129)
@@ -114,7 +114,7 @@
     struct GModule *module;
-    struct Flag *flag_l, *flag_c, *flag_f, *flag_t;
+    struct Flag *flag_l, *flag_c, *flag_m, *flag_f, *flag_t;
     struct Option *input, *format, *type, *output, *createopt, *metaopt,
 	*nodataopt;
@@ -148,6 +148,12 @@
     flag_c->description = _("Only applicable to Byte or UInt16 data types");
     flag_c->guisection = _("Creation");
+    flag_m = G_define_flag();
+    flag_m->key = 'm';
+    flag_m->label = _("Do not write non-standard metadata");
+    flag_m->description = _("Enhances compatibility with other GIS software");
+    flag_m->guisection = _("Creation");
     flag_t = G_define_flag();
     flag_t->key = 't';
     flag_t->label = _("Write raster attribute table");
@@ -220,8 +226,12 @@
     nodataopt = G_define_option();
     nodataopt->key = "nodata";
     nodataopt->type = TYPE_DOUBLE;
+    nodataopt->label =
+	_("Assign a specified nodata value to output bands");
     nodataopt->description =
-	_("Assign a specified nodata value to output bands");
+	_("If given, the nodata value is always written to metadata "
+	  "even if there are no NULL cells in the input band "
+	  "(enhances output compatibility).");
     nodataopt->multiple = NO;
     nodataopt->required = NO;
     nodataopt->guisection = _("Creation");
@@ -581,7 +591,29 @@
     /* Add metadata */
     AttachMetadata(hCurrDS, metaopt->answers);
+    if (strcmp(format->answer, "GTiff") == 0) {
+	char *pszKey;
+	char *pszValue;
+	pszKey = "TIFFTAG_SOFTWARE";
+	G_asprintf(&pszValue, "GRASS GIS %s with GDAL %d.%d.%d",
+	           GRASS_VERSION_NUMBER,
+		   GDAL_VERSION_MAJOR, GDAL_VERSION_MINOR, GDAL_VERSION_REV);
+	GDALSetMetadataItem(hCurrDS, pszKey, pszValue, NULL);
+	G_free(pszValue);
+    else if (!flag_m->answer) {
+	char *pszKey;
+	char *pszValue;
+	pszKey = "SOFTWARE";
+	G_free(pszValue);
     /* Export to GDAL raster */
     G_message(_("Exporting raster data to %s format..."), format->answer);
     for (band = 0; band < ref.nfiles; band++) {
@@ -595,7 +627,7 @@
 	retval = export_band
 	    (hCurrDS, band + 1, ref.file[band].name,
 	     ref.file[band].mapset, &cellhead, maptype, nodataval,
-	     flag_c->answer);
+	     flag_c->answer, flag_m->answer, (nodataopt->answer != NULL));
 	/* read/write error */
 	if (retval == -1) {
@@ -604,8 +636,7 @@
 	else if (flag_t->answer) {
 	    retval = export_attr(hCurrDS, band + 1, ref.file[band].name,
-	     ref.file[band].mapset, maptype);
+	                         ref.file[band].mapset, maptype);
