[GRASS-SVN] r69133 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sun Aug 14 19:04:02 PDT 2016
Author: annakrat
Date: 2016-08-14 19:04:01 -0700 (Sun, 14 Aug 2016)
New Revision: 69133
grass/trunk/display/d.vect/legend.c
grass/trunk/display/d.vect/local_proto.h
grass/trunk/display/d.vect/main.c
d.vect: if size_column is used, write -1 to legend; symbol_size will be then used for point legend, see #3125
Modified: grass/trunk/display/d.vect/legend.c
--- grass/trunk/display/d.vect/legend.c 2016-08-13 13:48:18 UTC (rev 69132)
+++ grass/trunk/display/d.vect/legend.c 2016-08-15 02:04:01 UTC (rev 69133)
@@ -4,7 +4,7 @@
void write_into_legfile(struct Map_info *Map, int type, const char *leglab, const char *name_map, const char *icon,
const char *size, const char *color, const char *fcolor, const char *width, const char *icon_area,
- const char *icon_line)
+ const char *icon_line, const char *size_column)
int nfeatures;
FILE *fd;
@@ -14,6 +14,9 @@
strcpy(map, name_map);
strtok_r(map, "@", &ptr);
+ if (size_column)
+ size = "-1";
/* Write into legend file */
leg_file = getenv("GRASS_LEGEND_FILE");
if (leg_file) {
Modified: grass/trunk/display/d.vect/local_proto.h
--- grass/trunk/display/d.vect/local_proto.h 2016-08-13 13:48:18 UTC (rev 69132)
+++ grass/trunk/display/d.vect/local_proto.h 2016-08-15 02:04:01 UTC (rev 69133)
@@ -69,4 +69,4 @@
/* legend.c */
void write_into_legfile(struct Map_info *, int, const char *, const char *,
const char *, const char *, const char *, const char *,
- const char *, const char *, const char *);
+ const char *, const char *, const char *, const char *);
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2016-08-13 13:48:18 UTC (rev 69132)
+++ grass/trunk/display/d.vect/main.c 2016-08-15 02:04:01 UTC (rev 69133)
@@ -463,7 +463,7 @@
icon_opt->answer, size_opt->answer,
color_opt->answer, fcolor_opt->answer,
width_opt->answer, icon_area_opt->answer,
- icon_line_opt->answer);
+ icon_line_opt->answer, sizecolumn_opt->answer);
/* reset line width: Do we need to get line width from display
