[GRASS-SVN] r69137 - grass/branches/releasebranch_7_2/raster/r.reclass
svn_grass at osgeo.org
Mon Aug 15 14:04:30 PDT 2016
Author: neteler
Date: 2016-08-15 14:04:30 -0700 (Mon, 15 Aug 2016)
New Revision: 69137
grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html
r.reclass manual: example added
Modified: grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html
--- grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html 2016-08-15 21:03:18 UTC (rev 69136)
+++ grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html 2016-08-15 21:04:30 UTC (rev 69137)
@@ -114,6 +114,8 @@
<h2>EXAMPLES</h2>
+<h3>Reclass rules examples</h3>
The following examples may help clarify the reclass rules.
<p><dl>
<dt>
@@ -186,7 +188,46 @@
the last label which was specified becomes the label for that category.
In this case the labels are assigned exactly as in the two previous examples.
+<h3>Usage example</h3>
+In this example, the 21 classes of the landuse map (North Carolina sample
+dataset) are simplified to 7 classes:
+<div class="code"><pre>
+r.category landuse96_28m
+0 not classified
+1 High Intensity Developed
+2 Low Intensity Developed
+3 Cultivated
+20 Water Bodies
+21 Unconsolidated Sediment
+# use this command or save rules with editor in textfile "landuserecl.txt"
+echo "0 = NULL
+1 2 = 1 developed
+3 = 2 agriculture
+4 6 = 3 herbaceous
+7 8 9 = 4 shrubland
+10 thru 18 = 5 forest
+20 = 6 water
+21 = 7 sediment" > landuserecl.txt
+r.reclass input=landuse96_28m output=landclass96_recl \
+ rules=landuserecl.txt \
+ title="Simplified landuse classes 1996"
+# verify result
+r.category landuse96_recl
+1 developed
+2 agriculture
+3 herbaceous
+4 shrubland
+5 forest
+6 water
+7 sediment
+</pre></div>
<h2>SEE ALSO</h2>
<em>
