[GRASS-SVN] r69154 - grass/trunk/display/d.vect.thematic
svn_grass at osgeo.org
Thu Aug 18 08:12:39 PDT 2016
Author: annakrat
Date: 2016-08-18 08:12:39 -0700 (Thu, 18 Aug 2016)
New Revision: 69154
grass/trunk/display/d.vect.thematic/display.c
grass/trunk/display/d.vect.thematic/local_proto.h
grass/trunk/display/d.vect.thematic/main.c
d.vect.thematic: use correctly colors for different symbols, author Adam Laza
Modified: grass/trunk/display/d.vect.thematic/display.c
--- grass/trunk/display/d.vect.thematic/display.c 2016-08-18 14:34:33 UTC (rev 69153)
+++ grass/trunk/display/d.vect.thematic/display.c 2016-08-18 15:12:39 UTC (rev 69154)
@@ -19,14 +19,15 @@
int display_lines(struct Map_info *Map, struct cat_list *Clist,
int chcat, const char *symbol_name, double size,
int default_width, dbCatValArray * cvarr, double *breaks,
- int nbreaks, const struct color_rgb *colors)
+ int nbreaks, const struct color_rgb *colors, const struct
+ color_rgb *bcolor)
int ltype, line, nlines;
struct line_pnts *Points;
struct line_cats *Cats;
int n_points, n_lines, n_centroids, n_boundaries, n_faces;
- RGBA_Color *primary_color, *sec_color;
+ RGBA_Color *primary_color, *secondary_color;
SYMBOL *Symb;
Symb = NULL;
@@ -38,6 +39,8 @@
primary_color = G_malloc(sizeof(RGBA_Color));
primary_color->a = RGBA_COLOR_OPAQUE;
+ secondary_color = G_malloc(sizeof(RGBA_Color));
+ secondary_color->a = RGBA_COLOR_OPAQUE;
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -97,9 +100,15 @@
primary_color->g = colors[i].g;
primary_color->b = colors[i].b;
+ if (bcolor !=NULL) {
+ secondary_color->r = bcolor->r;
+ secondary_color->g = bcolor->g;
+ secondary_color->b = bcolor->b;
draw_line(ltype, line, Points, Cats, chcat, size, default_width,
Clist, Symb, primary_color, &n_points, &n_lines,
- &n_centroids, &n_boundaries, &n_faces);
+ &n_centroids, &n_boundaries, &n_faces, secondary_color);
if (n_points > 0)
@@ -134,7 +143,7 @@
const struct cat_list *Clist, SYMBOL * Symb,
RGBA_Color * primary_color,
int *n_points, int *n_lines, int *n_centroids,
- int *n_boundaries, int *n_faces)
+ int *n_boundaries, int *n_faces, RGBA_Color *secondary_color)
double var_size, rotation;
int i;
@@ -194,7 +203,7 @@
return 0;
D_line_width(default_width);
- D_symbol(Symb, x0, y0, primary_color, primary_color);
+ D_symbol2(Symb, x0, y0, primary_color, secondary_color);
else {
/* Plot the lines */
Modified: grass/trunk/display/d.vect.thematic/local_proto.h
--- grass/trunk/display/d.vect.thematic/local_proto.h 2016-08-18 14:34:33 UTC (rev 69153)
+++ grass/trunk/display/d.vect.thematic/local_proto.h 2016-08-18 15:12:39 UTC (rev 69154)
@@ -21,10 +21,11 @@
int chcat, double size, int default_width,
const struct cat_list *Clist, SYMBOL *Symb,
RGBA_Color *primary_color, int *n_points, int *n_lines,
- int *n_centroids, int *n_boundaries, int *n_faces);
+ int *n_centroids, int *n_boundaries, int *n_faces,
+ RGBA_Color *secondary_color);
int display_lines(struct Map_info *, struct cat_list *, int,
const char *, double, int, dbCatValArray *, double *, int,
- const struct color_rgb *);
+ const struct color_rgb *, const struct color_rgb *);
Modified: grass/trunk/display/d.vect.thematic/main.c
--- grass/trunk/display/d.vect.thematic/main.c 2016-08-18 14:34:33 UTC (rev 69153)
+++ grass/trunk/display/d.vect.thematic/main.c 2016-08-18 15:12:39 UTC (rev 69154)
@@ -432,7 +432,8 @@
else if ((Vect_get_num_primitives(&Map, GV_POINT) > 0) ||
(Vect_get_num_primitives(&Map, GV_LINE) > 0)){
stat = display_lines(&Map, Clist, chcat, icon_opt->answer, size,
- default_width, &cvarr, breakpoints, nbreaks, colors);
+ default_width, &cvarr, breakpoints, nbreaks, colors,
+ has_color ? &bcolor : NULL);
