[GRASS-SVN] r69161 - grass/branches/releasebranch_7_0/gui/wxpython/gmodeler
svn_grass at osgeo.org
Fri Aug 19 03:47:59 PDT 2016
Author: martinl
Date: 2016-08-19 03:47:59 -0700 (Fri, 19 Aug 2016)
New Revision: 69161
grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py
grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py
g.gui.gmodeler - not possible to remove data from model (trac #2947)
wxGUI/gmodeler: avoid recursive deletion when undefining module parameters
(merge r68155 and r68201 from trunk)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py 2016-08-19 10:24:04 UTC (rev 69160)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py 2016-08-19 10:47:59 UTC (rev 69161)
@@ -789,9 +789,12 @@
x = width/2 - 200 + self._randomShift()
y = height/2 + self._randomShift()
for p in params['params']:
- if p.get('prompt', '') in ('raster', 'vector', 'raster_3d', 'dbtable') and \
- (p.get('value', None) or \
- (p.get('age', 'old') != 'old' and p.get('required', 'no') == 'yes')):
+ if p.get('prompt', '') not in ('raster', 'vector', 'raster_3d', 'dbtable'):
+ continue
+ # add new data item if defined or required
+ if p.get('value', None) or \
+ (p.get('age', 'old') != 'old' and p.get('required', 'no') == 'yes'):
data = layer.FindData(p.get('name', ''))
if data:
data.SetValue(p.get('value', ''))
@@ -830,7 +833,19 @@
data.AddRelation(rel)
self.AddLine(rel)
data.Update()
+ # remove dead data items
+ if not p.get('value', ''):
+ data = layer.FindData(p.get('name', ''))
+ if data:
+ remList, upList = self.model.RemoveItem(data, layer)
+ for item in remList:
+ self.canvas.diagram.RemoveShape(item)
+ item.__del__()
+ for item in upList:
+ item.Update()
# valid / parameterized ?
layer.SetValid(params)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py 2016-08-19 10:24:04 UTC (rev 69160)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py 2016-08-19 10:47:59 UTC (rev 69161)
@@ -192,16 +192,18 @@
"""Reset model"""
self.items = list()
- def RemoveItem(self, item):
+ def RemoveItem(self, item, reference=None):
"""Remove item from model
+ :item: item to be removed
+ :reference: reference item valid for deletion
:return: list of related items to remove/update
relList = list()
upList = list()
- self.items.remove(item)
+ doRemove = True
if isinstance(item, ModelAction):
for rel in item.GetRelations():
relList.append(rel)
@@ -213,17 +215,24 @@
elif isinstance(item, ModelData):
+ otherItem = rel.GetTo() if rel.GetFrom() == item else rel.GetFrom()
+ if reference and reference != otherItem:
+ doRemove = False
+ continue # avoid recursive deletion
relList.append(rel)
- if rel.GetFrom() == self:
- relList.append(rel.GetTo())
- else:
- relList.append(rel.GetFrom())
+ relList.append(otherItem)
+ if not doRemove:
+ upList.append(item)
elif isinstance(item, ModelLoop):
relList.append(rel)
for action in self.GetItems():
action.UnSetBlock(item)
+ if doRemove and item in self.items:
+ self.items.remove(item)
return relList, upList
