[GRASS-SVN] r69182 - grass/branches/releasebranch_7_2/lib/proj
Sun Aug 21 09:29:01 PDT 2016
Author: martinl
Date: 2016-08-21 09:29:01 -0700 (Sun, 21 Aug 2016)
New Revision: 69182
   grass/branches/releasebranch_7_2/lib/proj/ellipse.c
projlib: improve doxygen documentation ellipse.c (merge r69181)
Modified: grass/branches/releasebranch_7_2/lib/proj/ellipse.c
--- grass/branches/releasebranch_7_2/lib/proj/ellipse.c	2016-08-21 16:27:01 UTC (rev 69181)
+++ grass/branches/releasebranch_7_2/lib/proj/ellipse.c	2016-08-21 16:29:01 UTC (rev 69182)
@@ -1,7 +1,6 @@
+   \file lib/proj/ellipse.c
-   \file ellipse.c
    \brief GProj library - Functions for reading datum parameters from the location database
    \author Paul Kelly <paul-grass stjohnspoint.co.uk>
@@ -11,7 +10,7 @@
    This program is free software under the GNU General Public
    License (>=v2). Read the file COPYING that comes with GRASS
    for details.
 #include <unistd.h>
 #include <ctype.h>
@@ -25,15 +24,22 @@
 static int get_a_e2_rf(const char *, const char *, double *, double *,
 		       double *);
- * This routine returns the ellipsoid parameters from the database.
+ * \brief Get the ellipsoid parameters from the database.
  * If the PROJECTION_FILE exists in the PERMANENT mapset, read info from
  * that file, otherwise return WGS 84 values.
- * \return 1 ok, 0 default values used.
- *         Dies with diagnostic if there is an error
+ * Dies with diagnostic if there is an error.
+ * \param[out] a semi-major axis
+ * \param[out] e2 first eccentricity squared
+ * \param[out] rf reciprocal of the ellipsoid flattening term
+ * \return 1 on success
+ * \return 0 default values used.
 int GPJ_get_ellipsoid_params(double *a, double *e2, double *rf)
     int ret;
@@ -48,9 +54,24 @@
     return ret;
-int
-GPJ__get_ellipsoid_params(const struct Key_Value *proj_keys,
-			  double *a, double *e2, double *rf)
+ * \brief Get the ellipsoid parameters from proj keys structure.
+ * If the PROJECTION_FILE exists in the PERMANENT mapset, read info from
+ * that file, otherwise return WGS 84 values.
+ * \param proj_keys proj definition
+int GPJ__get_ellipsoid_params(const struct Key_Value *proj_keys,
+                              double *a, double *e2, double *rf)
     struct gpj_ellps estruct;
     struct gpj_datum dstruct;
@@ -125,12 +146,15 @@
- * \brief looks up ellipsoid in ellipsoid table and returns the
- * a, e2 parameters for the ellipsoid
+ * \brief Looks up ellipsoid in ellipsoid table and returns the a, e2
+ * parameters for the ellipsoid.
- * \return 1 if ok,
- *         -1 if not found in table
+ * \param name ellipsoid name
+ * \param[out] estruct ellipsoid
+ * \return -1 if not found in table
 int GPJ_get_ellipsoid_by_name(const char *name, struct gpj_ellps *estruct)
@@ -155,9 +179,8 @@
     return -1;
-static int
-get_a_e2_rf(const char *s1, const char *s2, double *a, double *e2,
-	    double *recipf)
+int get_a_e2_rf(const char *s1, const char *s2, double *a, double *e2,
+                double *recipf)
     double b, f;
@@ -278,6 +301,11 @@
     return outputlist;
+  \brief Free ellipsoid data structure.
+  \param estruct data structure to be freed
 void GPJ_free_ellps(struct gpj_ellps *estruct)
     G_free(estruct->name);
