[GRASS-SVN] r69200 - in grass/trunk: raster/r.in.lidar raster3d/r3.in.lidar scripts/v.what.vect vector/v.in.lidar vector/v.in.pdal
Sun Aug 21 19:16:33 PDT 2016
Author: wenzeslaus
Date: 2016-08-21 19:16:33 -0700 (Sun, 21 Aug 2016)
New Revision: 69200
   grass/trunk/raster/r.in.lidar/r.in.lidar.html
   grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
   grass/trunk/scripts/v.what.vect/v.what.vect.html
   grass/trunk/vector/v.in.lidar/v.in.lidar.html
   grass/trunk/vector/v.in.pdal/v.in.pdal.html
more see also links, references and authors for lidar related modules
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html	2016-08-21 22:54:25 UTC (rev 69199)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html	2016-08-22 02:16:33 UTC (rev 69200)
@@ -573,7 +573,9 @@
 <a href="r.in.xyz.html">r.in.xyz</a>,
 <a href="r.mapcalc.html">r.mapcalc</a>,
 <a href="r.univar.html">r.univar</a>,
-<a href="v.in.lidar.html">v.in.lidar</a>
+<a href="v.in.lidar.html">v.in.lidar</a>,
+<a href="r3.in.lidar.html">r3.in.lidar</a>,
+<a href="v.vect.stats.html">v.vect.stats</a>
 <br>
 <a href="v.lidar.correction.html">v.lidar.correction</a>,
 <a href="v.lidar.edgedetection.html">v.lidar.edgedetection</a>,
@@ -611,6 +613,6 @@
 <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
 (base_raster option, documentation)
 <br>
-based on r.in.xyz by Hamish Bowman and Volker Wichmann<br>
+based on <em>r.in.xyz</em> by Hamish Bowman and Volker Wichmann<br>
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
--- grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html	2016-08-21 22:54:25 UTC (rev 69199)
+++ grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html	2016-08-22 02:16:33 UTC (rev 69200)
@@ -92,7 +92,26 @@
 <a href="g.region.html">g.region</a>
 </em>
+<h2>REFERENCES</h2>
+<ul>
+<li>
+V. Petras, A. Petrasova, J. Jeziorska, H. Mitasova (2016):
+<em>Processing UAV and lidar point clouds in GRASS GIS</em>.
+XXIII ISPRS Congress 2016
+[<a href="http://www.int-arch-photogramm-remote-sens-spatial-inf-sci.net/XLI-B7/945/2016/">ISPRS Archives</a>,
+<a href="https://www.researchgate.net/publication/304340172_Processing_UAV_and_lidar_point_clouds_in_GRASS_GIS">ResearchGate</a>]
+<li>
+<a href="http://www.asprs.org/Committee-General/LASer-LAS-File-Format-Exchange-Activities.html">
+ASPRS LAS format</a>
+<li>
+<a href="http://www.liblas.org/">LAS library</a>
+<li>
+<a href="http://test.liblas.org/doxygen/liblas_8h.htm">LAS library C API</a> documentation
+</ul>
 <h2>AUTHOR</h2>
-Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.html
--- grass/trunk/scripts/v.what.vect/v.what.vect.html	2016-08-21 22:54:25 UTC (rev 69199)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.html	2016-08-22 02:16:33 UTC (rev 69200)
@@ -62,7 +62,8 @@
 <a href="v.distance.html">v.distance</a>,
 <a href="v.rast.stats.html">v.rast.stats</a>,
 <a href="v.what.rast.html">v.what.rast</a>,
-<a href="v.what.rast3.html">v.what.rast3</a>
+<a href="v.what.rast3.html">v.what.rast3</a>,
 </em>
Modified: grass/trunk/vector/v.in.lidar/v.in.lidar.html
--- grass/trunk/vector/v.in.lidar/v.in.lidar.html	2016-08-21 22:54:25 UTC (rev 69199)
+++ grass/trunk/vector/v.in.lidar/v.in.lidar.html	2016-08-22 02:16:33 UTC (rev 69200)
@@ -122,7 +122,16 @@
   v.in.lidar -tb input="Serpent Mound Model LAS Data.las" output=Serpent_Mound_Model_pts
 </pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.in.lidar.html">r.in.lidar</a>,
+<a href="g.region.html">g.region</a>,
+<a href="v.in.ogr.html">v.in.ogr</a>,
+</em>
 <h2>REFERENCES</h2>
@@ -130,11 +139,14 @@
 <a href="http://www.liblas.org/">LAS library</a> <br>
 <h2>AUTHOR</h2>
 Markus Metz
 <br>
-based on v.in.ogr
+Vaclav Petras,
+<a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+(decimation, cats, areas, zrange)
+<br>
+based on <em>v.in.ogr</em> by various authors
Modified: grass/trunk/vector/v.in.pdal/v.in.pdal.html
--- grass/trunk/vector/v.in.pdal/v.in.pdal.html	2016-08-21 22:54:25 UTC (rev 69199)
+++ grass/trunk/vector/v.in.pdal/v.in.pdal.html	2016-08-22 02:16:33 UTC (rev 69200)
@@ -27,13 +27,33 @@
 v.in.pdal input=points.las output=points -c -r -w
 </pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
 <h2>REFERENCES</h2>
 <ul>
+<li>
+    V. Petras, A. Petrasova, J. Jeziorska, H. Mitasova (2016):
+    <em>Processing UAV and lidar point clouds in GRASS GIS</em>.
+    XXIII ISPRS Congress 2016
+    [<a href="http://www.int-arch-photogramm-remote-sens-spatial-inf-sci.net/XLI-B7/945/2016/">ISPRS Archives</a>,
+    <a href="https://www.researchgate.net/publication/304340172_Processing_UAV_and_lidar_point_clouds_in_GRASS_GIS">ResearchGate</a>]
 <li>Zhang, Keqi, et al.
     <em>A progressive morphological filter for removing nonground
     measurements from airborne LIDAR data.</em>
     Geoscience and Remote Sensing,
     IEEE Transactions on 41.4 (2003): 872-882.
 </ul>
+<h2>AUTHOR</h2>
+Vaclav Petras,
