[GRASS-SVN] r69206 - in grass/trunk: raster/r.timestamp raster3d/r3.timestamp vector/v.timestamp
svn_grass at osgeo.org
Mon Aug 22 06:22:28 PDT 2016
Author: martinl
Date: 2016-08-22 06:22:27 -0700 (Mon, 22 Aug 2016)
New Revision: 69206
grass/trunk/raster/r.timestamp/r.timestamp.html
grass/trunk/raster3d/r3.timestamp/main.c
grass/trunk/raster3d/r3.timestamp/r3.timestamp.html
grass/trunk/vector/v.timestamp/v.timestamp.html
clean up manual pages of timestamp modules
Modified: grass/trunk/raster/r.timestamp/r.timestamp.html
--- grass/trunk/raster/r.timestamp/r.timestamp.html 2016-08-22 12:30:12 UTC (rev 69205)
+++ grass/trunk/raster/r.timestamp/r.timestamp.html 2016-08-22 13:22:27 UTC (rev 69206)
@@ -96,29 +96,37 @@
dates).
<div class="code"><pre>
- r.timestamp map=soils
+r.timestamp map=soils
</pre></div>
Sets the timestamp for "soils" to the single date "15 sep 1987".
- r.timestamp map=soils date='15 sep 1987'
+r.timestamp map=soils date='15 sep 1987'
</pre></div>
Sets the timestamp for "soils" to have the start date "15 sep 1987"
and the end date "20 feb 1988".
- r.timestamp map=soils date='15 sep 1987/20 feb 1988'
+r.timestamp map=soils date='15 sep 1987/20 feb 1988'
</pre></div>
+Sets the timestamp for "soils" to have the start date "18 feb 2005
+10:30:00" and the end date "20 jul 2007 20:30:00".
+<div class="code"><pre>
+r.timestamp map=soils date='18 feb 2005 10:30:00/20 jul 2007 20:30:00'
+</pre></div>
Removes the timestamp for the "soils" raster map.
- r.timestamp map=soils date=none
+r.timestamp map=soils date=none
</pre></div>
<h2>KNOWN ISSUES</h2>
Spaces in the timestamp value are required.
<h2>SEE ALSO</h2>
Modified: grass/trunk/raster3d/r3.timestamp/main.c
--- grass/trunk/raster3d/r3.timestamp/main.c 2016-08-22 12:30:12 UTC (rev 69205)
+++ grass/trunk/raster3d/r3.timestamp/main.c 2016-08-22 13:22:27 UTC (rev 69206)
@@ -41,11 +41,12 @@
module = G_define_module();
G_add_keyword(_("raster3d"));
+ G_add_keyword(_("metadata"));
G_add_keyword(_("timestamp"));
G_add_keyword(_("time"));
G_add_keyword(_("voxel"));
- module->description =
- _("Print/add/remove a timestamp for a 3D raster map");
+ module->label = _("Modifies a timestamp for a 3D raster map.");
+ module->description = _("Print/add/remove a timestamp for a 3D raster map.");
map = G_define_standard_option(G_OPT_R3_MAP);
Modified: grass/trunk/raster3d/r3.timestamp/r3.timestamp.html
--- grass/trunk/raster3d/r3.timestamp/r3.timestamp.html 2016-08-22 12:30:12 UTC (rev 69205)
+++ grass/trunk/raster3d/r3.timestamp/r3.timestamp.html 2016-08-22 13:22:27 UTC (rev 69206)
@@ -1,88 +1,59 @@
<h2>DESCRIPTION</h2>
-This command has 2 modes of operation. If no date argument
-is supplied, then the current timestamp for the 3D raster map
-is printed. If a date argument is specified, then the
-timestamp for the 3D raster map is set to the specified
-date(s). See EXAMPLES below.
+This command has 2 modes of operation. If no <b>date</b> argument is
+supplied, then the current timestamp for the 3D raster map is
+printed. If a date argument is specified, then the timestamp for the
+3D raster map is set to the specified date(s). See examples below.
+<p>
+See <a href="r.timestamp.html#timestamp-format">TIMESTAMP FORMAT</a>
+description for details.
+<h2>NOTES</h2>
+Strings containing spaces should be quoted. For specifying a range of
+time, the two timestamps should be separated by a forward slash. To
+remove the timestamp from a 3D raster map, use <b>date=none</b>.
<h2>EXAMPLES</h2>
-<b>r3.timestamp map=soils</b><br>
- Prints the timestamp for the "soils" 3D raster map. If
- there is no timestamp for soils, nothing is printed. If
- there is a timestamp, one or two lines are printed,
- depending on if the timestamp for the map consists of a
- single date or two dates (ie start and end dates).
-<p><b>r3.timestamp map=soils date='15 sep 1987'</b><br>
- Sets the timestamp for "soils" to the single date<br>
- "15 sep 1987"
-<p><b>r3.timestamp map=soils date='15 sep 1987/20 feb 1988'</b><br>
- Sets the timestamp for "soils" to have the start date<br>
- "15 sep 1987" and the end date "20 feb 1988"
-<p><b>r3.timestamp map=soils date='18 feb 2005 10:30:00/20 jul 2007 20:30:00'</b><br>
- "18 aug 2005 10:30:00" and the end date "20 jul 2007 20:30:00"
-<p>
-<b>r3.timestamp map=soils date=none</b><br>
- Removes the timestamp for the "soils" 3D raster map
+Prints the timestamp for the "soils" 3D raster map. If there is no
+timestamp for soils, nothing is printed. If there is a timestamp, one
+or two lines are printed, depending on if the timestamp for the map
+consists of a single date or two dates (ie start and end dates).
-<h2>TIMESTAMP FORMAT</h2>
- The timestamp values must use the format as described in the
- GRASS datetime library. The source tree for this library
- should have a description of the format. For convience, the
- formats as of Feb, 1996 are reproduced here:
-<p> There are two types of datetime values: absolute and
- relative. Absolute values specify exact dates and/or times.
- Relative values specify a span of time. Some examples will
- help clarify:
-<p><b>Absolute</b><p> The general format for absolute values is
-<p><tt>
- day month year [bc] hour:minute:seconds timezone
-<br>
- day is 1-31<br>
- month is jan,feb,...,dec<br>
- year is 4 digit year<br>
- [bc] if present, indicates dates is BC<br>
- hour is 0-23 (24 hour clock)<br>
- minute is 0-59<br>
- second is 0-59.9999 (fractions of second allowed)<br>
- timezone is +hhmm or -hhmm (eg, -0600)<br>
-<br>
- parts can be missing
-<br>
- 1994 [bc]<br>
- Jan 1994 [bc]<br>
- 15 jan 1000 [bc]<br>
- 15 jan 1994 [bc] 10 [+0000]<br>
- 15 jan 1994 [bc] 10:00 [+0100]<br>
- 15 jan 1994 [bc] 10:00:23.34 [-0500]<br>
-<br>
-</tt>
- <b> Relative</b>
- There are two types of relative datetime values, year-
- month and day-second. The formats are:
-<p><tt>
- [-] # years # months<br>
- [-] # days # hours # minutes # seconds
-</tt><p> The words years, months, days, hours, minutes, seconds
- are literal words, and the # are the numeric values.<br>
- Examples:<p><tt>
- 2 years<br>
- 5 months<br>
- 2 years 5 months<br>
- 100 days<br>
- 15 hours 25 minutes 35.34 seconds<br>
- 100 days 25 minutes<br>
- 1000 hours 35.34 seconds
-</tt><p> The following are <i>illegal</i> because it mixes year-month
- and day-second (because the number of days in a month
- or in a year vary):<p><tt>
- 3 months 15 days<br>
- 3 years 10 days
-</tt>
+r3.timestamp map=soils
+</pre></div>
+Sets the timestamp for "soils" to the single date "15 sep 1987".
+r3.timestamp map=soils date='15 sep 1987'
+</pre></div>
+Sets the timestamp for "soils" to have the start date "15 sep 1987"
+and the end date "20 feb 1988".
+r3.timestamp map=soils date='15 sep 1987/20 feb 1988'
+</pre></div>
+r3.timestamp map=soils date='18 feb 2005 10:30:00/20 jul 2007 20:30:00'
+</pre></div>
+Removes the timestamp for the "soils" 3D raster map.
+r3.timestamp map=soils date=none
+</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/trunk/vector/v.timestamp/v.timestamp.html
--- grass/trunk/vector/v.timestamp/v.timestamp.html 2016-08-22 12:30:12 UTC (rev 69205)
+++ grass/trunk/vector/v.timestamp/v.timestamp.html 2016-08-22 13:22:27 UTC (rev 69206)
@@ -5,88 +5,16 @@
a date argument is specified, then the timestamp for the vector map is
+<p>
<h2>NOTES</h2>
remove the timestamp from a vector map, use <b>date=none</b>.
-The timestamp values must use the format as described in the <em>GRASS
-Datetime Library</em>. The source tree for this library should have a
-description of the format. For convience, the formats are reproduced
-here:
-<p>There are two types of datetime values:
-<ul>
- <li><em>absolute</em> and
- <li><em>relative</em>.
-</ul>
-Absolute values specify exact dates and/or times. Relative values
-specify a span of time.
-<h3>Absolute</h3>
-The general format for absolute values is:
-<div class="code"><pre>
- day is 1-31
- minute is 0-59
-</pre></div>
-Some parts can be missing, for example
- 1994 [bc]
- Jan 1994 [bc]
- 15 jan 1000 [bc]
-</pre></div>
-<h3>Relative</h3>
-There are two types of relative datetime values, year-month and
-day-second. The formats are:
-</pre></div>
-The words years, months, days, hours, minutes, seconds are literal
-words, and the # are the numeric values. Examples:
- 2 years
- 5 months
- 2 years 5 months
- 100 days
-</pre></div>
-The following are <i>illegal</i> because it mixes year-month and
-day-second (because the number of days in a month or in a year vary):
- 3 months 15 days
- 3 years 10 days
-</pre></div>
<h2>EXAMPLES</h2>
Prints the timestamp for the "lidar" vector map. If there is no
@@ -96,29 +24,30 @@
dates).
- v.timestamp map=lidar
+v.timestamp map=lidar
</pre></div>
Sets the timestamp for "lidar" to the single date "15 sep 1987".
- v.timestamp map=lidar date='15 sep 1987'
+v.timestamp map=lidar date='15 sep 1987'
</pre></div>
Sets the timestamp for "lidar" to have the start date "15 sep 1987"
- v.timestamp map=lidar date='15 sep 1987/20 feb 1988'
+v.timestamp map=lidar date='15 sep 1987/20 feb 1988'
</pre></div>
Removes the timestamp for the "lidar" vector map.
- v.timestamp map=lidar date=none
+v.timestamp map=lidar date=none
</pre></div>
<h2>SEE ALSO</h2>
