[GRASS-SVN] r69216 - in grass/branches/releasebranch_7_0: gui/wxpython/tools include/Make lib/db/dbmi_base lib/proj
svn_grass at osgeo.org
Mon Aug 22 14:38:00 PDT 2016
Author: martinl
Date: 2016-08-22 14:38:00 -0700 (Mon, 22 Aug 2016)
New Revision: 69216
grass/branches/releasebranch_7_0/gui/wxpython/tools/build_modules_xml.py
grass/branches/releasebranch_7_0/include/Make/Vars.make
grass/branches/releasebranch_7_0/lib/db/dbmi_base/dbmscap.c
grass/branches/releasebranch_7_0/lib/proj/Makefile
Patches to make the build reproducible (fileordering, randomness)
Patches applied: 01-sort-build-modules-list.patch, 02-sort-dbmscap.patch, 03-sort-obj-files.patch, 05-binary-nad-install.patch
To be solved: 04-srand48_auto-from-SOURCE_DATE_EPOCH.patch
(see #3042)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/tools/build_modules_xml.py
--- grass/branches/releasebranch_7_0/gui/wxpython/tools/build_modules_xml.py 2016-08-22 21:36:16 UTC (rev 69215)
+++ grass/branches/releasebranch_7_0/gui/wxpython/tools/build_modules_xml.py 2016-08-22 21:38:00 UTC (rev 69216)
@@ -51,7 +51,7 @@
# TODO: what about ms windows? does gtask handle this?
mlist = list(gcore.get_commands()[0])
indent = 4
- for m in mlist:
+ for m in sorted(mlist):
# TODO: get rid of g.mapsets_picker.py
if m == 'g.mapsets_picker.py' or m == 'g.parser':
continue
Modified: grass/branches/releasebranch_7_0/include/Make/Vars.make
--- grass/branches/releasebranch_7_0/include/Make/Vars.make 2016-08-22 21:36:16 UTC (rev 69215)
+++ grass/branches/releasebranch_7_0/include/Make/Vars.make 2016-08-22 21:38:00 UTC (rev 69216)
@@ -13,10 +13,10 @@
YACC_SOURCES := $(wildcard *.y)
AUTO_OBJS := \
- $(subst .c,.o,$(C_SOURCES)) \
- $(subst .cpp,.o,$(CPP_SOURCES)) \
- $(subst .l,.yy.o,$(LEX_SOURCES)) \
- $(subst .y,.tab.o,$(YACC_SOURCES))
+ $(sort $(subst .c,.o,$(C_SOURCES))) \
+ $(sort $(subst .cpp,.o,$(CPP_SOURCES))) \
+ $(sort $(subst .l,.yy.o,$(LEX_SOURCES))) \
+ $(sort $(subst .y,.tab.o,$(YACC_SOURCES)))
ifndef MOD_OBJS
MOD_OBJS = $(AUTO_OBJS)
Modified: grass/branches/releasebranch_7_0/lib/db/dbmi_base/dbmscap.c
--- grass/branches/releasebranch_7_0/lib/db/dbmi_base/dbmscap.c 2016-08-22 21:36:16 UTC (rev 69215)
+++ grass/branches/releasebranch_7_0/lib/db/dbmi_base/dbmscap.c 2016-08-22 21:38:00 UTC (rev 69216)
@@ -209,19 +209,22 @@
return list;
+static int cmp_entry(dbDbmscap *a, dbDbmscap *b) {
+ return( a->driverName && b->driverName ? strcmp(a->driverName,b->driverName) : 0 );
static void add_entry(dbDbmscap ** list, char *name, char *startup, char *comment)
+ /* add an entry to the list, so that the list remains ordered (by driverName) */
dbDbmscap *head, *cur, *tail;
- /* add this entry to the head of a linked list */
- tail = head = *list;
- while (tail && tail->next)
- tail = tail->next;
- *list = NULL;
cur = (dbDbmscap *) db_malloc(sizeof(dbDbmscap));
- if (cur == NULL)
- return; /* out of memory */
+ if (cur == NULL) {
+ *list = NULL;
+ return;
+ /* out of memory */
cur->next = NULL;
/* copy each item to the dbmscap structure */
@@ -229,11 +232,21 @@
strcpy(cur->startup, startup);
strcpy(cur->comment, comment);
+ /* find the last entry that is less than cur */
+ tail = head = *list;
+ while (tail && tail->next && cmp_entry(tail->next,cur)<0)
+ tail = tail->next;
/* handle the first call (head == NULL) */
- if (tail)
- tail->next = cur;
- else
- head = cur;
+ if (tail && cmp_entry(tail,cur)<0) {
+ /* insert right after tail */
+ cur->next = tail->next;
+ tail->next = cur;
+ } else {
+ /* insert at first position */
+ cur->next = head;
+ head = cur;
*list = head;
Modified: grass/branches/releasebranch_7_0/lib/proj/Makefile
--- grass/branches/releasebranch_7_0/lib/proj/Makefile 2016-08-22 21:36:16 UTC (rev 69215)
+++ grass/branches/releasebranch_7_0/lib/proj/Makefile 2016-08-22 21:38:00 UTC (rev 69216)
@@ -37,7 +37,7 @@
$(INSTALL) $< $@
endif
-$(NAD_DSTFILES): $(NAD_DIR)/%: $(NAD_BINFILES) | $(NAD_DIR)
+$(NAD_DSTFILES): $(NAD_DIR)/%: $(OBJDIR)/% | $(NAD_DIR)
$(INSTALL_DATA) $< $@
$(NAD_BINFILES): $(OBJDIR)/%: %.lla
