[GRASS-SVN] r69219 - in grass/trunk/vector: v.in.lidar v.in.pdal v.mkgrid v.vect.stats
svn_grass at osgeo.org
Mon Aug 22 19:00:21 PDT 2016
Author: wenzeslaus
Date: 2016-08-22 19:00:20 -0700 (Mon, 22 Aug 2016)
New Revision: 69219
grass/trunk/vector/v.in.lidar/v.in.lidar.html
grass/trunk/vector/v.in.pdal/v.in.pdal.html
grass/trunk/vector/v.mkgrid/v.mkgrid.html
grass/trunk/vector/v.vect.stats/v.vect.stats.html
more see also for lidar modules
Modified: grass/trunk/vector/v.in.lidar/v.in.lidar.html
--- grass/trunk/vector/v.in.lidar/v.in.lidar.html 2016-08-22 23:24:19 UTC (rev 69218)
+++ grass/trunk/vector/v.in.lidar/v.in.lidar.html 2016-08-23 02:00:20 UTC (rev 69219)
@@ -128,8 +128,8 @@
<a href="r.in.lidar.html">r.in.lidar</a>,
<a href="r3.in.lidar.html">r3.in.lidar</a>,
<a href="g.region.html">g.region</a>,
-<a href="v.vect.stats.html">v.vect.stats</a>
-<a href="v.in.ogr.html">v.in.ogr</a>,
+<a href="v.vect.stats.html">v.vect.stats</a>,
+<a href="v.in.ogr.html">v.in.ogr</a>
</em>
<h2>REFERENCES</h2>
Modified: grass/trunk/vector/v.in.pdal/v.in.pdal.html
--- grass/trunk/vector/v.in.pdal/v.in.pdal.html 2016-08-22 23:24:19 UTC (rev 69218)
+++ grass/trunk/vector/v.in.pdal/v.in.pdal.html 2016-08-23 02:00:20 UTC (rev 69219)
@@ -57,3 +57,5 @@
Vaclav Petras,
<a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/vector/v.mkgrid/v.mkgrid.html
--- grass/trunk/vector/v.mkgrid/v.mkgrid.html 2016-08-22 23:24:19 UTC (rev 69218)
+++ grass/trunk/vector/v.mkgrid/v.mkgrid.html 2016-08-23 02:00:20 UTC (rev 69219)
@@ -180,7 +180,8 @@
<em>
<a href="d.grid.html">d.grid</a>,
<a href="v.in.region.html">v.in.region</a>,
-<a href="v.patch.html">v.patch</a>
+<a href="v.patch.html">v.patch</a>,
</em>
<h2>AUTHORS</h2>
Modified: grass/trunk/vector/v.vect.stats/v.vect.stats.html
--- grass/trunk/vector/v.vect.stats/v.vect.stats.html 2016-08-22 23:24:19 UTC (rev 69218)
+++ grass/trunk/vector/v.vect.stats/v.vect.stats.html 2016-08-23 02:00:20 UTC (rev 69219)
@@ -155,14 +155,16 @@
g.region vector=points_of_interest res=2000 -pa
</pre></div>
-The hexagonal grid is created as a vector map based on the previously
+The hexagonal grid is created using
+the <em><a href="v.mkgrid.html">v.mkgrid</a></em> module
+as a vector map based on the previously
selected extent and size of the grid.
<div class="code"><pre>
v.mkgrid map=hexagons -h
</pre></div>
-The <em><a href="v.vect.stats.html">v.vect.stats</a></em> module
+The <em>v.vect.stats</em> module
counts the number of points and does one statistics on a selected
column (here: <em>elev_m</em>).
@@ -235,7 +237,8 @@
<a href="v.distance.html">v.distance</a>,
<a href="r.distance.html">r.distance</a>,
<a href="v.rast.stats.html">v.rast.stats</a>,
-<a href="v.what.vect.html">v.what.vect</a>
+<a href="v.what.vect.html">v.what.vect</a>,
+<a href="v.mkgrid.html">v.mkgrid</a>
</em>
