[GRASS-SVN] r69231 - grass/branches/releasebranch_7_2/misc/m.nviz.script
svn_grass at osgeo.org
Tue Aug 23 05:47:27 PDT 2016
Author: martinl
Date: 2016-08-23 05:47:27 -0700 (Tue, 23 Aug 2016)
New Revision: 69231
grass/branches/releasebranch_7_2/misc/m.nviz.script/m.nviz.script.html
<m.nviz.script> - old manuals? (see #3040) (merge r69230 from trunk)
Modified: grass/branches/releasebranch_7_2/misc/m.nviz.script/m.nviz.script.html
--- grass/branches/releasebranch_7_2/misc/m.nviz.script/m.nviz.script.html 2016-08-23 12:46:27 UTC (rev 69230)
+++ grass/branches/releasebranch_7_2/misc/m.nviz.script/m.nviz.script.html 2016-08-23 12:47:27 UTC (rev 69231)
@@ -3,8 +3,7 @@
The <em>m.nviz.script</em> program allows the user to easily create a script
that can be run in NVIZ to fly through a terrain.
-The NVIZ flight path can be chosen interactively from the GRASS
-monitor (<em>-i</em>) or supplied on the command line as comma
+The NVIZ flight path can be supplied on the command line as comma
separated coordinates. The program optionally allows a KeyFrame
file to created (after running the script). This KeyFrame file can
be loaded into the <em>Keyframe Animation</em> panel for fine
@@ -18,11 +17,6 @@
<h3>Flags:</h3>
<dl>
-<dt><b>-i</b>
-<dd>Intercative mode
-<dd>The user selects the camera path from the GRASS monitor by
- clicking the left mouse button along the route. Click the
- right mouse button to finish.
<dt><b>-f</b>
<dd>Full render
<dd>The script will draw all loaded NVIZ data and save scene to PPM image.
@@ -75,7 +69,6 @@
<dt><b>route</b>
<dd>The comma separated geographic coordinates for keyframe locations.
-<dd>The interactive flag (<em>-i</em>) overrides this option.
</dl>
@@ -87,7 +80,7 @@
<div class="code"><pre>
g.region raster=elevation.dem
d.rast elevation.dem
-m.nviz.script -ik input=elevation.dem output=nviz.script dist=2400 ht=1220 frames=1000
+m.nviz.script -k input=elevation.dem output=nviz.script dist=2400 ht=1220 frames=1000
</pre></div>
In the above the example the user is prompted to select the route from the GRASS monitor.
The output script, 'nviz.script.nvscr', can then be run in NVIZ:
