[GRASS-SVN] r69233 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Tue Aug 23 05:56:54 PDT 2016
Author: martinl
Date: 2016-08-23 05:56:54 -0700 (Tue, 23 Aug 2016)
New Revision: 69233
grass/trunk/raster/r.to.vect/main.c
r.to.vect: delete output on error
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2016-08-23 12:48:11 UTC (rev 69232)
+++ grass/trunk/raster/r.to.vect/main.c 2016-08-23 12:56:54 UTC (rev 69233)
@@ -153,7 +153,8 @@
if (Vect_open_new(&Map, out_opt->answer, z_flg->answer) < 0)
G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
+ Vect_set_error_handler_io(NULL, &Map);
Vect_hist_command(&Map);
Cats = Vect_new_cats_struct();
