[GRASS-SVN] r69242 - in grass/branches/releasebranch_7_0: gui/wxpython/gui_core gui/wxpython/mapdisp gui/wxpython/mapswipe lib/python/script
svn_grass at osgeo.org
Tue Aug 23 07:49:21 PDT 2016
Author: lucadelu
Date: 2016-08-23 07:49:21 -0700 (Tue, 23 Aug 2016)
New Revision: 69242
grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py
grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py
grass/branches/releasebranch_7_0/lib/python/script/raster.py
python script: backported raster_what function to work with or without localized labels fixed #2912
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py 2016-08-23 14:43:28 UTC (rev 69241)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py 2016-08-23 14:49:21 UTC (rev 69242)
@@ -249,7 +249,8 @@
from grass.script import vector as gvect
from grass.script import raster as grast
testdata1 = grast.raster_what(map = ('elevation_shade at PERMANENT','landclass96'),
- coord = [(638509.051416,224742.348346)])
+ coord = [(638509.051416,224742.348346)],
+ localized=True)
testdata2 = gvect.vector_what(map=('firestations','bridges'),
coord=(633177.897487,221352.921257), distance=10)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py 2016-08-23 14:43:28 UTC (rev 69241)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py 2016-08-23 14:49:21 UTC (rev 69242)
@@ -867,7 +867,8 @@
rastQuery = []
vectQuery = []
if rast:
- rastQuery = grass.raster_what(map=rast, coord=(east, north))
+ rastQuery = grass.raster_what(map=rast, coord=(east, north),
+ localized=True)
if vect:
encoding = UserSettings.Get(group='atm', key='encoding', subkey='value')
try:
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py 2016-08-23 14:43:28 UTC (rev 69241)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py 2016-08-23 14:49:21 UTC (rev 69242)
@@ -645,11 +645,13 @@
result = []
if rasters[0]:
- result.extend(grass.raster_what(map=rasters[0], coord=(east, north)))
+ result.extend(grass.raster_what(map=rasters[0], coord=(east, north),
+ localized=True))
if vectors[0]:
result.extend(grass.vector_what(map=vectors[0], coord=(east, north), distance=qdist))
if rasters[1]:
- result.extend(grass.raster_what(map=rasters[1], coord=(east, north)))
+ result.extend(grass.raster_what(map=rasters[1], coord=(east, north),
+ localized=True))
if vectors[1]:
result.extend(grass.vector_what(map=vectors[1], coord=(east, north), distance=qdist))
Modified: grass/branches/releasebranch_7_0/lib/python/script/raster.py
--- grass/branches/releasebranch_7_0/lib/python/script/raster.py 2016-08-23 14:43:28 UTC (rev 69241)
+++ grass/branches/releasebranch_7_0/lib/python/script/raster.py 2016-08-23 14:49:21 UTC (rev 69242)
@@ -149,7 +149,7 @@
return p
-def raster_what(map, coord, env=None):
+def raster_what(map, coord, env=None, localized=False):
"""Interface to r.what
>>> raster_what('elevation', [[640000, 228000]])
@@ -187,7 +187,10 @@
if not ret:
return data
- labels = (_("value"), _("label"), _("color"))
+ if localized:
+ labels = (_("value"), _("label"), _("color"))
+ else:
+ labels = ('value', 'label', 'color')
for item in ret.splitlines():
line = item.split(sep)[3:]
for i, map_name in enumerate(map_list):
