[GRASS-SVN] r69253 - grass/trunk/lib/btree2
Thu Aug 25 09:26:22 PDT 2016
Author: mmetz
Date: 2016-08-25 09:26:22 -0700 (Thu, 25 Aug 2016)
New Revision: 69253
   grass/trunk/lib/btree2/kdtree.c
btree2lib: improve kdtree balancing
Modified: grass/trunk/lib/btree2/kdtree.c
--- grass/trunk/lib/btree2/kdtree.c	2016-08-24 16:26:30 UTC (rev 69252)
+++ grass/trunk/lib/btree2/kdtree.c	2016-08-25 16:26:22 UTC (rev 69253)
@@ -31,10 +31,13 @@
 #undef KD_DEBUG
 #endif
+static int rcalls = 0;
+static int rcallsmax = 0;
 static struct kdnode *kdtree_insert2(struct kdtree *, struct kdnode *,
-                                 struct kdnode *, int, int);
-static int kdtree_replace(struct kdtree *, struct kdnode *);
-static int kdtree_balance(struct kdtree *, struct kdnode *);
+                                     struct kdnode *, int, int);
+static int kdtree_replace(struct kdtree *, struct kdnode *, int);
+static int kdtree_balance(struct kdtree *, struct kdnode *, int);
 static int kdtree_first(struct kdtrav *, double *, int *);
 static int kdtree_next(struct kdtrav *, double *, int *);
@@ -97,6 +100,7 @@
 	if (t->btol < 2)
 	    t->btol = 2;
+    t->btol = 7;
     t->nextdim = G_malloc(ndims * sizeof(char));
     for (i = 0; i < ndims - 1; i++)
@@ -161,6 +165,13 @@
     t->root = kdtree_insert2(t, t->root, nnew, 1, dc);
+    /* print depth of recursion
+     * recursively called fns are insert2, balance, and replace */
+    if (rcallsmax > 1)
+	fprintf(stdout, "%d\n", rcallsmax);
     return count < t->count;
@@ -210,6 +221,9 @@
 	    n = s[top].n;
 	    dir = s[top].dir;
 	    n->child[dir] = NULL;
+	    /* update node depth */
+	    n->depth = (!n->child[!dir] ? 0 : n->child[!dir]->depth + 1);
 	else {
 	    t->root = NULL;
@@ -218,23 +232,19 @@
     else
-	kdtree_replace(t, s[top].n);
+	kdtree_replace(t, s[top].n, 1);
     if (top) {
-	int old_depth;
 	top--;
 	dir = s[top].dir;
 	n = s[top].n;
-	kdtree_balance(t, n->child[dir]);
+	while (kdtree_balance(t, n->child[dir], 0));
-	old_depth = n->depth;
 	ld = (!n->child[0] ? -1 : n->child[0]->depth);
 	rd = (!n->child[1] ? -1 : n->child[1]->depth);
 	n->depth = MAX(ld, rd) + 1;
-	if (old_depth == n->depth)
-	    top = 0;
     while (top) {
 	top--;
@@ -246,7 +256,7 @@
-    while (kdtree_balance(t, t->root));
+    while (kdtree_balance(t, t->root, 0));
     return 1;
@@ -256,7 +266,7 @@
  * level 0 = a bit, 1 = more, 2 = a lot */
 void kdtree_optimize(struct kdtree *t, int level)
-    struct kdnode *n;
+    struct kdnode *n, *n2;
     struct kdstack {
 	struct kdnode *n;
 	int dir;
@@ -265,108 +275,109 @@
     int dir;
     int top;
     int ld, rd;
-    int count = 0;
-    int bal = 0;
+    int diffl, diffr;
+    int nbal;
     if (!t->root)
 	return;
-    if (level < 0)
-	level = 0;
+    G_debug(1, "k-d tree optimization for %zd items, tree depth %d",
+            t->count, t->root->depth);
+    nbal = 0;
     top = 0;
     s[top].n = t->root;
-    s[top].dir = 0;
-    s[top].v = 0;
-    top++;
+    while (s[top].n) {
+	n = s[top].n;
-    G_debug(1, "k-d tree optimization for %zd items:", t->count);
+	/* balance node */
+	while (kdtree_balance(t, n, level)) {
+	    while (kdtree_balance(t, n->child[0], level));
+	    while (kdtree_balance(t, n->child[1], level));
-    /* top-down balancing */
-    while (top) {
-	top--;
-	n = s[top].n;
-	if (!s[top].v) {
-	    s[top].v = 1;
-	    while (kdtree_balance(t, n))
-		bal++;
-	else {
-	    /* update node depth */
-	    if (level) {
-		    bal++;
+	    nbal++;
-	if (s[top].dir < 2) {
-	    dir = s[top].dir;
-	    s[top].dir++;
-	    if (!s[top].n->child[dir] && s[top].dir < 2) {
-		dir = s[top].dir;
-		s[top].dir++;
+	ld = (!n->child[0] ? -1 : n->child[0]->depth);
+	rd = (!n->child[1] ? -1 : n->child[1]->depth);
-	    if (s[top].n->child[dir]) {
-		n = s[top].n;
-		top++;
-		s[top].n = n->child[dir];
-		s[top].dir = 0;
-		s[top].v = 0;
-		top++;
-	count++;
-    if (level < 2) {
-	G_debug(1, "%d steps, %d times balanced", count, bal);
-	return;
+	dir = (rd > ld);
-    /* bottom-up balancing */
-    /* go down */
-    top = 0;
-    s[top].n = t->root;
-    while (s[top].n) {
-	n = s[top].n;
-	s[top].dir = 0;
-	s[top].v = 0;
 	top++;
-	s[top].n = n->child[0];
+	s[top].n = n->child[dir];
-    /* traverse */
     while (top) {
 	top--;
-	if (s[top].dir == 0) {
-	    s[top].dir = 1;
+	n = s[top].n;
-	    /* go down the other side */
+	n->depth = MAX(ld, rd) + 1;
+    if (level) {
+	top = 0;
+	s[top].n = t->root;
+	    n = s[top].n;
+		nbal++;
+	    diffl = diffr = -1;
+	    if (n->child[0]) {
+		n2 = n->child[0];
+		ld = (!n2->child[0] ? -1 : n2->child[0]->depth);
+		rd = (!n2->child[1] ? -1 : n2->child[1]->depth);
+		diffl = ld - rd;
+		if (diffl < 0)
+		    diffl = -diffl;
+	    if (n->child[1]) {
+		n2 = n->child[1];
+		diffr = ld - rd;
+		if (diffr < 0)
+		    diffr = -diffr;
+	    dir = (diffr > diffl);
 	    top++;
-	    s[top].n = n->child[1];
-		n = s[top].n;
-		s[top].dir = 0;
-		s[top].v = 0;
-		top++;
-	else {
+	while (top) {
+	    top--;
 	    n = s[top].n;
-		bal++;
-	count++;
+    G_debug(1, "k-d tree optimization: %d times balanced, new depth %d",
+            nbal, t->root->depth);
+    return;
 /* find k nearest neighbors
@@ -747,7 +758,7 @@
 /*            internal functions              */
-static int kdtree_replace(struct kdtree *t, struct kdnode *r)
+static int kdtree_replace(struct kdtree *t, struct kdnode *r, int bmode)
     double mindist;
     int rdir, ordir, dir;
@@ -762,6 +773,14 @@
     int is_leaf;
     int nr;
+    if (!r)
+	return 0;
+    if (!r->child[0] && !r->child[1])
+	return 0;
+    /* do not call kdtree_balance in this fn, this can cause
+     * stack overflow due to too many recursive calls */
     /* find replacement for r
      * overwrite r, delete replacement */
     nr = 0;
@@ -938,26 +957,33 @@
 	G_fatal_error("No replacement at all");
     /* delete last replacement */
+    if (s[top2].n != rn) {
+	G_fatal_error("Wrong top2 for last replacement");
     top = top2 - 1;
     n = s[top].n;
-    dir = 0;
+    dir = s[top].dir;
     if (n->child[dir] != rn) {
-	dir = !dir;
-    if (n->child[dir] != rn) {
 	G_fatal_error("Last replacement disappeared");
+    kdtree_free_node(rn);
-    kdtree_free_node(rn);
     t->count--;
-    n->depth = (!n->child[!dir] ? 0 : n->child[!dir]->depth + 1);
+    if (bmode > 1)
+	while (kdtree_balance(t, n, bmode));
     if (n->depth == old_depth)
 	top = 0;
 #ifdef KD_DEBUG
-    top = top2;
+    top = top2 - 1;
 #endif
     /* go back up */
@@ -986,34 +1012,50 @@
     return nr;
-static int kdtree_balance(struct kdtree *t, struct kdnode *r)
+static int kdtree_balance(struct kdtree *t, struct kdnode *r, int bmode)
     struct kdnode *or;
     int dir;
     int rd, ld;
+    int old_depth;
+    int btol;
-    if (!r)
+    if (!r) {
 	return 0;
+    ld = (!r->child[0] ? -1 : r->child[0]->depth);
+    rd = (!r->child[1] ? -1 : r->child[1]->depth);
+    old_depth = MAX(ld, rd) + 1;
+    if (old_depth != r->depth) {
+	G_warning("balancing: depth is wrong: %d != %d", r->depth, old_depth);
+	r->depth = old_depth;
     /* subtree difference */
+    btol = t->btol;
+    if (!r->child[0] || !r->child[1])
+	btol = 2;
     dir = -1;
-    if (ld > rd + t->btol) {
+    if (ld > rd + btol) {
 	dir = 0;
-    else if (rd > ld + t->btol) {
+    else if (rd > ld + btol) {
 	dir = 1;
-    else
+    else {
 	return 0;
     or = kdtree_newnode(t);
     memcpy(or->c, r->c, t->csize);
     or->uid = r->uid;
     or->dim = t->nextdim[r->dim];
-    if (!kdtree_replace(t, r))
+    if (!kdtree_replace(t, r, bmode))
 	G_fatal_error("kdtree_balance: nothing replaced");
 #ifdef KD_DEBUG
@@ -1025,20 +1067,29 @@
 #endif
-    r->child[!dir] = kdtree_insert2(t, r->child[!dir], or, 0, 1);
+    r->child[!dir] = kdtree_insert2(t, r->child[!dir], or, bmode, 1);
-    ld = r->child[0]->depth;
-    rd = r->child[1]->depth;
     r->depth = MAX(ld, rd) + 1;
+    if (r->depth == old_depth) {
+	G_debug(4, "balancing had no effect");
+	return 1;
+    if (r->depth > old_depth)
+	G_fatal_error("balancing failed");
     return 1;
 static struct kdnode *kdtree_insert2(struct kdtree *t, struct kdnode *r,
-                                 struct kdnode *nnew, int balance, int dc)
+                                     struct kdnode *nnew,
+				     int balance, int dc)
-    struct kdnode *n, *nr;
     struct kdstack {
 	struct kdnode *n;
 	int dir;
@@ -1048,6 +1099,7 @@
     int ld, rd;
     int old_depth;
     int go_back;
+    int bmode;
     if (!r) {
 	r = nnew;
@@ -1056,9 +1108,69 @@
 	return r;
-    if (balance) {
-	/* balance root */
-	while (kdtree_balance(t, r));
+    /* level of recursion */
+    rcalls++;
+    if (rcallsmax < rcalls)
+	rcallsmax = rcalls;
+    /* most optimal tree: bmode = 2, only bottom-up balancing
+     * fastest tree building: bmode = 0 with a priori, top-down and
+     * bottom-up balancing */
+    bmode = 0;
+    if (balance && bmode == 0) {
+	int diffl, diffr;
+	top = 0;
+	s[top].n = r;
+	    n = s[top].n;
+	    while (kdtree_balance(t, n, bmode)) {
+		while (kdtree_balance(t, n->child[0], bmode));
+		while (kdtree_balance(t, n->child[1], bmode));
+		n2 = n->child[0];
+		diffl = ld - rd;
+		if (diffl < 0)
+		    diffl = -diffl;
+		n2 = n->child[1];
+		diffr = ld - rd;
+		if (diffr < 0)
+		    diffr = -diffr;
+	    top++;
+	while (top) {
+	    top--;
+	    n = s[top].n;
     /* find node with free child */
@@ -1068,69 +1180,38 @@
     while (s[top].n) {
 	n = s[top].n;
-	if (!cmpc(nnew, n, t) && (!dc || nnew->uid == n->uid)) {
-	    G_debug(1, "KD node exists already, nothing to do");
-	    kdtree_free_node(nnew);
+	if (balance && bmode < 2) {
+	    old_depth = n->depth;
-	    return r;
-	dir = cmp(nnew, n, n->dim) > 0;
-	s[top].dir = dir;
-	if (balance) {
-	    /* balance left subtree */
-	    while (kdtree_balance(t, n->child[0]));
-	    /* balance right subtree */
-	    while (kdtree_balance(t, n->child[1]));
-	    ld = (!n->child[0] ? -1 : n->child[0]->depth);
-	    rd = (!n->child[1] ? -1 : n->child[1]->depth);
-	    n->depth = MAX(ld, rd) + 1;
 	    if (old_depth != n->depth)
 		go_back = top;
-	if (dc && n->depth == 1 && !n->child[!dir] && n->child[dir]) {
-	    if ((cmp(nnew, n->child[dir], n->dim) > 0) != dir) {
-		/* n -> nnew -> n->child[dir] */
-		nnew->child[dir] = n->child[dir];
-		n->child[dir] = NULL;
-		nnew->child[!dir] = n;
-		nnew->depth = n->depth;
-		n->depth = 0;
-		nnew->dim = n->dim;
-		n->dim = t->nextdim[nnew->dim];
-		nr = nnew;
+	if (!cmpc(nnew, n, t) && (!dc || nnew->uid == n->uid)) {
+	    G_debug(1, "KD node exists already, nothing to do");
+	    kdtree_free_node(nnew);
+	    if (!balance) {
+		rcalls--;
+		return r;
-	    else {
-		/* n -> n->child[dir] -> nnew */
-		nnew->child[dir] = n->child[dir]->child[dir];
-		nnew->child[!dir] = n->child[dir]->child[!dir];
-		nnew->depth = n->child[dir]->depth;
-		nnew->dim = n->child[dir]->dim;
-		nr = n->child[dir];
-		nr->dim = n->dim;
-		nr->depth = n->depth;
-		nr->child[dir] = nnew;
-		nr->child[!dir] = n;
-		n->child[!dir] = NULL;
-		n->depth = 0;
-		n->dim = nnew->dim;
-	    if (top) {
-		s[top - 1].n->child[s[top - 1].dir] = nr;
-	    else {
-		r = nr;
-	    t->count++;
-	    return r;
+	    break;
+	dir = cmp(nnew, n, n->dim) > 0;
+	s[top].dir = dir;
 	top++;
 	if (top > 255)
@@ -1138,26 +1219,35 @@
-    /* insert to child pointer of parent */
-    top--;
-    n = s[top].n;
-    dir = s[top].dir;
-    n->child[dir] = nnew;
-    nnew->dim = t->nextdim[n->dim];
+    if (!s[top].n) {
+	/* insert to child pointer of parent */
+	top--;
+	n = s[top].n;
+	dir = s[top].dir;
+	n->child[dir] = nnew;
+	nnew->dim = t->nextdim[n->dim];
-    t->count++;
+	t->count++;
-    n->depth = (!n->child[!dir] ? 1 : n->child[!dir]->depth + 1);
+	n->depth = (!n->child[!dir] ? 1 : n->child[!dir]->depth + 1);
-    if (balance) {
-	/* balance parent */
-	while (kdtree_balance(t, n));
+	if (balance) {
+	    /* balance parent */
+	if (old_depth != n->depth)
+	    go_back = top;
-    if (old_depth != n->depth)
-	go_back = top;
     /* go back up */
 #ifdef KD_DEBUG
     go_back = top;
@@ -1168,6 +1258,23 @@
 	top--;
 	n = s[top].n;
+	if (balance) {
 #ifdef KD_DEBUG
 	/* debug directions */
 	if (n->child[0]) {
@@ -1179,13 +1286,10 @@
 		G_warning("Insert2: Right child is not larger");
 #endif
+    rcalls--;
     return r;
