[GRASS-SVN] r69262 - grass/branches/releasebranch_7_0/vector/v.overlay
svn_grass at osgeo.org
Fri Aug 26 02:28:51 PDT 2016
Author: martinl
Date: 2016-08-26 02:28:51 -0700 (Fri, 26 Aug 2016)
New Revision: 69262
grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html
v.overlay: remove duplicated notes about olayer option from the manual, figure caption cosmetics (merge r69260 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html
--- grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html 2016-08-26 09:27:29 UTC (rev 69261)
+++ grass/branches/releasebranch_7_0/vector/v.overlay/v.overlay.html 2016-08-26 09:28:51 UTC (rev 69262)
@@ -30,6 +30,15 @@
<li><b>field 3</b>: category of <i>bfield</i> from <i>binput</i>
</ul>
+<h2>NOTES</h2>
+Currently only areas in <b>ainput</b> are supported for the operators
+<em>or</em> and <em>xor</em>! See also <em><a href="v.select.html">v.select</a></em>.
+The operator defines what kind of operation will be done. Features are
+written to output, if the result of an operation <b>ainput</b> operator <b>binput</b>
+is true.
<p>
If the <i>first</i> number of the <b>olayer</b> option is greater than 0, then the
resulting output map has a merged attribute table in the given layer
@@ -44,25 +53,7 @@
categories of <b>binput</b> in layer <em>blayer</em> are transferred to
the output layer with the third number.
-<h2>NOTES</h2>
-Currently only areas in <b>ainput</b> are supported for the operators
-<em>or</em> and <em>xor</em>! See also <em><a href="v.select.html">v.select</a></em>.
-The operator defines what kind of operation will be done. Features are
-written to output, if the result of an operation <b>ainput</b> operator <b>binput</b>
-is true.
<p>
-If the <i>first</i> number of the <b>olayer</b> option is greater than 0, then attributes
-of the tables from <b>ainput</b> and <b>binput</b> are joined into a new table linked
-to the output map with a new cat column.
-<p>
-If the <i>second</i> number of the <b>olayer</b> option is greater than 0, then the
-attribute table of <b>ainput</b> is copied to the output map.
-<p>
-If the <i>third</i> number of the <b>olayer</b> option is greater than 0, then the
-attribute table of <b>binput</b> is copied to the output map.
-<p>
If <b>atype</b>=auto is given than <em>v.overlay</em> determines
feature type for <b>ainput</b> from the first found feature.
@@ -107,7 +98,7 @@
<center>
<img src="v_overlay_op_and.png" alt="v.overlay with AND operator"><br>
-v.overlay with AND operator (selected polygons in grey color)
+<i>Figure: v.overlay with AND operator (selected polygons in grey color)</i>
</center>
@@ -124,7 +115,7 @@
<center>
<img src="v_overlay_op_or.png" alt="v.overlay with OR operator"><br>
-v.overlay with OR operator (selected polygons in grey color)
+<i>Figure: v.overlay with OR operator (selected polygons in grey color)</i>
</center>
@@ -141,7 +132,7 @@
<center>
<img src="v_overlay_op_xor.png" alt="v.overlay with XOR operator"><br>
-v.overlay with XOR operator (selected polygons in grey color)
+<i>Figure: v.overlay with XOR operator (selected polygons in grey color)</i>
</center>
@@ -158,7 +149,7 @@
<center>
<img src="v_overlay_op_not.png" alt="v.overlay with NOT operator"><br>
-v.overlay with NOT operator (selected polygon in grey color)
+<i>Figure: v.overlay with NOT operator (selected polygon in grey color)</i>
</center>
@@ -180,13 +171,13 @@
<center>
<img src="v_overlay_poly_1_2.png" alt="GRASS v.overlay: input polygons (1 and 2)" border=0>
<br>
-<i>v.overlay operations: original input polygons</i>
+<i>Figure: v.overlay operations: original input polygons</i>
</center>
<p>
<center>
<img src="v_overlay_poly_1_2_a_o_n_x.png" alt="GRASS v.overlay results: AND, OR, NOT, XOR operations" border=0>
<br>
-<i>v.overlay results of AND, OR, NOT, XOR operations</i>
+<i>Figure: v.overlay results of AND, OR, NOT, XOR operations</i>
</center>
@@ -238,7 +229,7 @@
<img src="v_overlay_census_wake2000.png" alt="GRASS v.overlay: polygon to polygon union (input 2)" border=1>
<img src="v_overlay_urban_census2000.png" alt="GRASS v.overlay: polygon to polygon union (result)" border=1>
<br>
-<i>v.overlay: Polygon union (right) of urban area (left) and Census 2000 (middle) areas (North Carolina dataset)</i>
+<i>Figure: v.overlay: Polygon union (right) of urban area (left) and Census 2000 (middle) areas (North Carolina dataset)</i>
</center>
<p>
@@ -264,7 +255,7 @@
<img src="v_overlay_area_lines.png" alt="GRASS v.overlay: Line to polygon clipping"><br>
<table border=0 width=590>
<tr><td><center>
-<i>v.overlay: Line to polygon clipping</i>
+<i>Figure: v.overlay: Line to polygon clipping</i>
</center></td></tr>
</table>
</center>
