[GRASS-SVN] r69309 - in grass/trunk/display: d.legend.vect d.vect
Tue Aug 30 20:25:43 PDT 2016
Author: annakrat
Date: 2016-08-30 20:25:43 -0700 (Tue, 30 Aug 2016)
New Revision: 69309
   grass/trunk/display/d.legend.vect/d.legend.vect.html
   grass/trunk/display/d.vect/main.c
d.vect/legend: change -l to -s to syncronize flags with d.vect.thematic
Modified: grass/trunk/display/d.legend.vect/d.legend.vect.html
--- grass/trunk/display/d.legend.vect/d.legend.vect.html	2016-08-31 03:11:15 UTC (rev 69308)
+++ grass/trunk/display/d.legend.vect/d.legend.vect.html	2016-08-31 03:25:43 UTC (rev 69309)
@@ -9,7 +9,8 @@
 border color and border width (<b>border_color</b> and <b>border_width</b>).
 Parameter <b>symbol_size</b> defines the size of line and area symbols.
 The size of point symbols is based on currently set symbology of vector maps using
-<em><a href="d.vect.html">d.vect</a></em>.
+<em><a href="d.vect.html">d.vect</a></em> or
+<em><a href="d.vect.thematic.html">d.vect.thematic</a></em>.
 <p>Module <em>d.vect.legend</em> supports subtitles (see section Notes).
 Their font and font size can be set using parameters <b>sub_font</b>
 and <b>sub_fontsize</b>.
@@ -17,15 +18,19 @@
 <h3>Changing legend symbols and labels</h3>
 Symbols for vector areas and lines, and labels for individual vector labels
 can be changed in the symbology setting of each vector map in
-<em><a href="d.vect.html">d.vect</a></em> module (in Legend tab). Use its parameters
+module (in Legend tab). Use its parameters
 <b>icon_area</b> and <b>icon_line</b> to pick from available symbols.
 By using parameter <b>legend_label</b> of <em>d.vect</em> module, users can change
 the default label, which is the map name.
 <h3>Modifying the order of legend entries and omitting certain vector maps
 from legend</h3>
-Module <em><a href="d.vect.html">d.vect</a></em> has a flag <b>-l</b>
-which when used removes the particular vector from vector legend.
+Modules <em><a href="d.vect.html">d.vect</a></em> and
+have a flag <b>-s</b>
+which removes the particular vector or thematic vector from vector legend.
 <p>The order of entries is defined by the order in Layer Manager (if used
 in GRASS GIS GUI). If that's not desired, one can export the legend file
 into a text file using parameter <b>output</b>, change the order of entries
@@ -82,6 +87,7 @@
 <em>
 <a href="d.vect.html">d.vect</a>,
+<a href="d.vect.thematic.html">d.vect.thematic</a>,
 <a href="d.legend.html">d.legend</a>
 </em>
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2016-08-31 03:11:15 UTC (rev 69308)
+++ grass/trunk/display/d.vect/main.c	2016-08-31 03:25:43 UTC (rev 69309)
@@ -325,8 +325,8 @@
     sqrt_flag->guisection = _("Symbols");
     legend_flag = G_define_flag();
-    legend_flag->key = 'l';
-    legend_flag->label = _("Do not add this layer to vector legend");
+    legend_flag->key = 's';
+    legend_flag->label = _("Do not show this layer in vector legend");
     legend_flag->guisection = _("Legend");
     /* Check command line */
