[GRASS-SVN] r69315 - in grass/trunk: lib/python/temporal lib/python/temporal/testsuite temporal/t.rast.algebra temporal/t.rast.algebra/testsuite temporal/t.select
svn_grass at osgeo.org
Tue Aug 30 23:59:10 PDT 2016
Author: huhabla
Date: 2016-08-30 23:59:10 -0700 (Tue, 30 Aug 2016)
New Revision: 69315
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_operator.py
grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
grass/trunk/lib/python/temporal/temporal_vector_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
grass/trunk/temporal/t.select/t.select.py
temporal framework: Better error handling for temporal operators, Code cleanup, better readability, better dry-run implementation, dry-run tests (merge from relbr72)
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -582,7 +582,7 @@
t_QUOTE = r'[\"\']'
# These are the things that should be ignored.
- t_ignore = ' \t'
+ t_ignore = ' \t\n'
# Read time string and convert it into a date object
def t_DATETIME(self, t):
@@ -650,12 +650,13 @@
# Handle errors.
def t_error(self, t):
- raise SyntaxError("syntax error on line %d near '%s'" %
- (t.lineno, t.value))
+ raise SyntaxError("syntax error on line %d position %i near '%s'" %
+ (t.lineno, t.lexpos, t.value))
# Build the lexer
def build(self,**kwargs):
- self.lexer = lex.lex(module=self, optimize=False, debug=False, **kwargs)
+ self.lexer = lex.lex(module=self, optimize=False,
+ nowarn=True, debug=0, **kwargs)
# Just for testing
def test(self,data):
@@ -794,7 +795,8 @@
# Check if spatio-temporal operators are present in the expression
if "{" in expression or "}" in expression:
- self.msgr.error(_("Spatio temporal operators are not supported in granularity algebra mode"))
+ self.msgr.error(_("Spatio-temporal topological operators are not"
+ " supported in granularity algebra mode"))
return False
# detect all STDS
@@ -879,8 +881,7 @@
self.expression = expression
self.parser.parse(expression)
- if self.dry_run is True:
- return self.process_chain_dict
+ return self.process_chain_dict
def generate_map_name(self):
"""Generate an unique map name and register it in the objects map list
@@ -897,8 +898,10 @@
self.names[name] = name
return name
- def generate_new_map(self, base_map, bool_op='and',
- copy=True, rename=True,
+ def generate_new_map(self, base_map,
+ bool_op='and',
+ copy=True,
+ rename=True,
remove=False):
"""Generate a new map using the spatio-temporal extent of the base map
@@ -919,7 +922,7 @@
# Create new map based on the related map list.
map_new = base_map.get_new_instance(mapname)
# Set initial map extend of new vector map.
- self.overlay_map_extent(map_new, base_map, bool_op = bool_op, copy = copy)
+ self.overlay_map_extent(map_new, base_map, bool_op=bool_op, copy=copy)
if not rename:
name = base_map.get_id()
map_new.set_id(name)
@@ -929,8 +932,12 @@
map_new.uid = name
return map_new
- def overlay_map_extent(self, mapA, mapB, bool_op = None, temp_op = 'l',
- copy = False):
+ def overlay_map_extent(self,
+ mapA,
+ mapB,
+ bool_op=None,
+ temp_op='l',
+ copy=False):
"""Compute the spatio-temporal extent of two topological related maps
:param mapA: The first map
@@ -1003,7 +1010,10 @@
returncode = 0
return(returncode)
- def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ):
+ def set_temporal_extent_list(self,
+ maplist,
+ topolist=["EQUAL"],
+ temporal='l' ):
""" Change temporal extent of map list based on temporal relations to
other map list and given temporal operator.
@@ -1083,7 +1093,9 @@
self.msgr.message(_("Removing un-needed or empty %s maps"%(key)))
self._remove_maps(map_names[key], key)
- def _remove_maps(self, namelist, map_type):
+ def _remove_maps(self,
+ namelist,
+ map_type):
"""Remove maps of specific type
:param namelist: List of map names to be removed
@@ -1105,17 +1117,20 @@
if self.dry_run is False:
m.run()
- def check_stds(self, input, clear=False, stds_type=None, check_type=True):
+ def check_stds(self,
+ input,
+ clear=False,
+ stds_type=None,
+ check_type=True):
""" Check if input space time dataset exist in database and return its map list.
- :param input: Name of space time data set as string or list of maps.
- :param clear: Reset the stored conditional values to empty list.
- :param check_type: Check the type of the space time dataset to match the global stds type
- :param stds_type: The type of the space time dataset to be opened, if not provided
- then self.stdstype will be used
+ :param input: Name of space time data set as string or list of maps.
+ :param clear: Reset the stored conditional values to empty list.
+ :param check_type: Check the type of the space time dataset to match the global stds type
+ :param stds_type: The type of the space time dataset to be opened, if not provided
+ then self.stdstype will be used
- :return: List of maps.
+ :return: List of maps.
if isinstance(input, str):
# Check for mapset in given stds input.
@@ -1129,7 +1144,7 @@
else:
stds = dataset_factory(self.stdstype, id_input)
# Check for occurrence of space time dataset.
- if stds.is_in_db(dbif=self.dbif) == False:
+ if stds.is_in_db(dbif=self.dbif) is False:
raise FatalError(_("Space time %s dataset <%s> not found") %
(stds.get_new_map_instance(None).get_type(), id_input))
else:
@@ -1153,9 +1168,9 @@
if "condition_value" not in dir(map_i):
map_i.condition_value = []
# Set and check global temporal type variable and map.
- if map_i.is_time_absolute() and self.temporaltype == None:
+ if map_i.is_time_absolute() and self.temporaltype is None:
self.temporaltype = 'absolute'
- elif map_i.is_time_relative() and self.temporaltype == None:
+ elif map_i.is_time_relative() and self.temporaltype is None:
self.temporaltype = 'relative'
elif map_i.is_time_absolute() and self.temporaltype == 'relative':
self.msgr.fatal(_("Wrong temporal type of space time dataset <%s> \
@@ -1165,11 +1180,11 @@
<%s> time is required") %
(id_input, self.temporaltype))
- elif isinstance(input, self.mapclass):
+ elif isinstance(input, self.mapclass):
# Check if the input is a single map and return it as list with one entry.
maplist = [input]
- elif isinstance(input, list):
+ elif isinstance(input, list):
maplist = input
# Create map_value as empty list item.
for map_i in maplist:
@@ -1194,9 +1209,15 @@
return(maplist)
- def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
- assign_val = False, count_map = False, compare_bool = False,
- compop = None, aggregate = None):
+ def get_temporal_topo_list(self,
+ maplistA,
+ maplistB=None,
+ assign_val=False,
+ count_map=False,
+ compare_bool=False,
+ compop=None,
+ aggregate=None):
"""Build temporal topology for two space time data sets, copy map objects
for given relation into map list.
@@ -1397,9 +1418,12 @@
return(resultlist)
- def assign_bool_value(self, map_i, tbrelations, topolist = ["EQUAL"]):
+ def assign_bool_value(self,
+ map_i,
+ tbrelations,
+ topolist=["EQUAL"]):
""" Function to assign boolean map value based on the map_values from the
- compared map list by topological relationships.
+ compared map list by topological relationships.
:param map_i: Map object with temporal extent.
:param tbrelations: List of temporal relation to map_i.
@@ -1428,7 +1452,12 @@
return(resultbool)
- def compare_bool_value(self, map_i, tbrelations, compop, aggregate, topolist = ["EQUAL"]):
+ def compare_bool_value(self,
+ map_i,
+ tbrelations,
+ compop,
+ aggregate,
""" Function to evaluate two map lists with boolean values by boolean
comparison operator.
@@ -1498,8 +1527,12 @@
return(p.relations, p.temporal, p.function, p.aggregate)
- def perform_temporal_selection(self, maplistA, maplistB, topolist = ["EQUAL"],
- inverse = False, assign_val = False):
+ def perform_temporal_selection(self,
+ maplistA,
+ maplistB,
+ inverse=False,
+ assign_val=False):
"""This function performs temporal selection operation.
:param maplistA: List of maps representing the left side of a temporal
@@ -1579,7 +1612,11 @@
resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
return(resultlist)
- def set_granularity(self, maplistA, maplistB, toperator = 'l', topolist = ["EQUAL"]):
+ def set_granularity(self,
+ maplistA,
+ maplistB,
+ toperator='l',
"""This function sets the temporal extends of a list of maps based on
another map list.
@@ -1848,7 +1885,7 @@
map_i.condition_value = boolname
return(maplist)
- def eval_map_list(self, maplist ,thenlist, topolist = ["EQUAL"]):
+ def eval_map_list(self, maplist ,thenlist, topolist=["EQUAL"]):
""" This function transfers boolean values from temporal expression
from one map list to another by their topology. These boolean
values are added to the maps as condition_value.
@@ -1874,7 +1911,7 @@
return(resultlist)
- def build_condition_list(self, tvarexpr, thenlist, topolist = ["EQUAL"]):
+ def build_condition_list(self, tvarexpr, thenlist, topolist=["EQUAL"]):
""" This function evaluates temporal variable expressions of a conditional
expression in two steps.
At first it combines stepwise the single conditions by their relations with LALR.
@@ -1957,7 +1994,7 @@
A recursive function is used to evaluate comparison statements
from left to right in the given conditional list.
- For example:
+ For example::
- [True, '||', False, '&&', True] -> True
- [True, '||', False, '&&', False] -> False
@@ -2089,11 +2126,11 @@
m.flags["overwrite"].value = self.overwrite
if map_i.get_type() == 'raster':
- m.inputs["raster"].value = map_i.get_id(), newident
+ m.inputs["raster"].value = map_i.get_id(), newident
elif map_i.get_type() == 'raster3d':
- m.inputs["raster_3d"].value = map_i.get_id(), newident
+ m.inputs["raster_3d"].value = map_i.get_id(), newident
elif map_i.get_type() == 'vector':
- m.inputs["vector"].value = map_i.get_id(), newident
+ m.inputs["vector"].value = map_i.get_id(), newident
# Add the process description to the dict
self.process_chain_dict["processes"].append(m.get_dict())
@@ -2206,7 +2243,7 @@
expr : STRDS LPAREN stds RPAREN
if self.run:
- t[0] = self.check_stds(t[3], stds_type = "strds", check_type=False)
+ t[0] = self.check_stds(t[3], stds_type = "strds", check_type=False)
else:
t[0] = t[3]
if self.debug:
@@ -2219,7 +2256,7 @@
expr : STR3DS LPAREN stds RPAREN
if self.run:
- t[0] = self.check_stds(t[3], stds_type = "str3ds", check_type=False)
+ t[0] = self.check_stds(t[3], stds_type = "str3ds", check_type=False)
else:
t[0] = t[3]
if self.debug:
@@ -2233,7 +2270,7 @@
if self.run:
print(t[3])
- t[0] = self.check_stds(t[3], stds_type = "stvds", check_type=False)
+ t[0] = self.check_stds(t[3], stds_type = "stvds", check_type=False)
else:
t[0] = t[3]
if self.debug:
@@ -2332,8 +2369,9 @@
if self.run:
maplistA = self.check_stds(t[1])
maplistB = self.check_stds(t[3])
- resultlist = self.get_temporal_topo_list(maplistA, maplistB,
- count_map = True)
+ resultlist = self.get_temporal_topo_list(maplistA,
+ maplistB,
+ count_map=True)
t[0] = resultlist
def p_t_hash2(self,t):
@@ -2348,8 +2386,10 @@
topolist = self.eval_toperator(t[2], optype='hash')[0]
- resultlist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
- count_map = True)
+ maplistB,
+ topolist,
+ count_map=True)
t[0] = resultlist
def p_t_hash_paren(self, t):
@@ -2431,7 +2471,7 @@
# A # B == 2
# td(A) < 31
- t_var_expr : t_td_var comp_op number
+ t_var_expr : t_td_var comp_op number
| t_hash_var comp_op number
if self.run:
@@ -2493,18 +2533,18 @@
# TODO: Implement statement in backward direction:
# TIME comp_op START_TIME LPAREN stds RPAREN
- t_var_expr : START_TIME LPAREN stds RPAREN comp_op TIME
- | START_DATE LPAREN stds RPAREN comp_op DATE
+ t_var_expr : START_TIME LPAREN stds RPAREN comp_op TIME
+ | START_DATE LPAREN stds RPAREN comp_op DATE
| START_DATETIME LPAREN stds RPAREN comp_op DATETIME
- | END_TIME LPAREN stds RPAREN comp_op TIME
- | END_DATE LPAREN stds RPAREN comp_op DATE
- | END_DATETIME LPAREN stds RPAREN comp_op DATETIME
- | START_TIME LPAREN expr RPAREN comp_op TIME
- | START_DATE LPAREN expr RPAREN comp_op DATE
+ | END_TIME LPAREN stds RPAREN comp_op TIME
+ | END_DATE LPAREN stds RPAREN comp_op DATE
+ | END_DATETIME LPAREN stds RPAREN comp_op DATETIME
+ | START_TIME LPAREN expr RPAREN comp_op TIME
+ | START_DATE LPAREN expr RPAREN comp_op DATE
| START_DATETIME LPAREN expr RPAREN comp_op DATETIME
- | END_TIME LPAREN expr RPAREN comp_op TIME
- | END_DATE LPAREN expr RPAREN comp_op DATE
- | END_DATETIME LPAREN expr RPAREN comp_op DATETIME
+ | END_TIME LPAREN expr RPAREN comp_op TIME
+ | END_DATE LPAREN expr RPAREN comp_op DATE
+ | END_DATETIME LPAREN expr RPAREN comp_op DATETIME
if self.run:
# Check input maplist.
@@ -2627,7 +2667,7 @@
# The temporal topology relation equals is implicit
# Examples:
# A {!:} B # Select the part of A that is temporally unequal to B
- # A {:} B # Select the part of A that is temporally equal B
+ # A { :} B # Select the part of A that is temporally equal B
# A {!:, equals} B # Select the part of A that is temporally unequal to B
# A {!:, during} B # Select the part of A that is temporally not during B
# A {:, overlaps} B # Select the part of A that temporally overlaps B
@@ -2734,8 +2774,8 @@
elseresult = self.eval_condition_list(elsecond, inverse = True)
# Combine and sort else and then statement to result map list.
- combilist = thenresult + elseresult
- resultlist = sorted(combilist, key = AbstractDatasetComparisonKeyStartTime)
+ combilist = thenresult + elseresult
+ resultlist = sorted(combilist, key = AbstractDatasetComparisonKeyStartTime)
# Clear the map and conditional values of the map list.
resultlist = self.check_stds(resultlist, clear = True)
# Return resulting map list.
@@ -2763,7 +2803,7 @@
elselist = self.check_stds(t[9])
# Get temporal conditional statement.
tvarexpr = t[5]
- topolist = self.eval_toperator(t[3], optype = 'relation')[0]
+ topolist = self.eval_toperator(t[3], optype='relation')[0]
thencond = self.build_condition_list(tvarexpr, thenlist, topolist)
thenresult = self.eval_condition_list(thencond)
elsecond = self.build_condition_list(tvarexpr, elselist, topolist)
@@ -2793,8 +2833,8 @@
# buff_t(A : B, "10 minutes") # Select the part of A that is temporally
# equal to B and create a buffer of 10 minutes around
- expr : BUFF_T LPAREN stds COMMA QUOTE number NAME QUOTE RPAREN
- | BUFF_T LPAREN expr COMMA QUOTE number NAME QUOTE RPAREN
+ expr : BUFF_T LPAREN stds COMMA QUOTE number NAME QUOTE RPAREN
+ | BUFF_T LPAREN expr COMMA QUOTE number NAME QUOTE RPAREN
| BUFF_T LPAREN stds COMMA number RPAREN
| BUFF_T LPAREN expr COMMA number RPAREN
@@ -2815,7 +2855,7 @@
if self.debug:
if len(t) == 10:
- print(str(t[3]) + "* = buff_t(", str(t[3]), "," , '"', str(t[6]), str(t[7]), '"', ")")
+ print(str(t[3]) + "* = buff_t(", str(t[3]), ",", '"', str(t[6]), str(t[7]), '"', ")")
elif len(t) == 7:
print(str(t[3]) + "* = buff_t(", str(t[3]), ",", str(t[5]), ")")
@@ -2843,8 +2883,8 @@
# tshift(A : B, "10 minutes") # Shift the selection from A temporally
# by 10 minutes.
- expr : TSHIFT LPAREN stds COMMA QUOTE number NAME QUOTE RPAREN
- | TSHIFT LPAREN expr COMMA QUOTE number NAME QUOTE RPAREN
+ expr : TSHIFT LPAREN stds COMMA QUOTE number NAME QUOTE RPAREN
+ | TSHIFT LPAREN expr COMMA QUOTE number NAME QUOTE RPAREN
| TSHIFT LPAREN stds COMMA number RPAREN
| TSHIFT LPAREN expr COMMA number RPAREN
@@ -2857,7 +2897,8 @@
elif len(t) == 7:
increment = str(t[5])
# Perform shifting.
- shiftlist = AbstractSpaceTimeDataset.shift_map_list(maplist, increment)
+ shiftlist = AbstractSpaceTimeDataset.shift_map_list(maplist,
+ increment)
t[0] = shiftlist
else:
t[0] = t[3] + "*"
@@ -2871,8 +2912,8 @@
# Handle errors.
def p_error(self, t):
if t:
- raise SyntaxError("syntax error on line %d, token %s near '%s' expression '%s'" %
- (t.lineno, t.type, t.value, self.expression))
+ raise SyntaxError("syntax error on line %d, position %i token %s near '%s' expression '%s'" %
+ (t.lineno, t.lexpos, t.type, t.value, self.expression))
else:
raise SyntaxError("Unexpected syntax error")
Modified: grass/trunk/lib/python/temporal/temporal_operator.py
--- grass/trunk/lib/python/temporal/temporal_operator.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/temporal_operator.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -24,32 +24,32 @@
>>> p = TemporalOperatorParser()
>>> expression = "{&&, during}"
>>> p.parse(expression, optype = 'boolean')
- >>> print((p.relations, p.temporal, p.function,p.aggregate))
+ >>> print((p.relations, p.temporal, p.function, p.aggregate))
(['during'], 'l', '&&', '&')
>>> expression = "{||, equal | during}"
(['equal', 'during'], 'l', '||', '|')
>>> expression = "{||, equal | during, &}"
(['equal', 'during'], 'l', '||', '&')
>>> expression = "{&&, during, |}"
(['during'], 'l', '&&', '|')
>>> expression = "{&&, during, |, r}"
(['during'], 'r', '&&', '|')
>>> expression = "{&&, during, u}"
(['during'], 'u', '&&', '&')
>>> expression = "{:, during, r}"
@@ -101,6 +101,36 @@
>>> p.parse(expression, optype = 'overlay')
>>> print((p.relations, p.temporal, p.function))
(['overlaps', 'overlapped'], 'r', '^')
+ >>> p = TemporalOperatorParser()
+ >>> expression = "{&&, equal | during | contains | starts, &}"
+ >>> p.parse(expression, optype = 'boolean')
+ (['equal', 'during', 'contains', 'starts'], 'l', '&&', '&')
+ >>> expression = "{&&, equal | during | contains | starts, &&&&&}"
+ Traceback (most recent call last):
+ SyntaxError: Unexpected syntax error in expression "{&&, equal | during | contains | starts, &&&&&}" at position 42 near &
+ >>> expression = "{+, starting}"
+ >>> p.parse(expression)
+ SyntaxError: syntax error on line 1 position 4 near 'starting'
+ >>> expression = "{nope, start, |, l}"
+ SyntaxError: syntax error on line 1 position 1 near 'nope'
+ >>> expression = "{++, start, |, l}"
+ SyntaxError: Unexpected syntax error in expression "{++, start, |, l}" at position 2 near +
+ >>> expression = "{^, over, right}"
+ >>> p.parse(expression, optype='rter')
+ SyntaxError: Unknown optype rter, must be one of ['select', 'boolean', 'raster', 'hash', 'relation', 'overlay']
from __future__ import print_function
@@ -163,7 +193,7 @@
t_T_NOT_SELECT = r'!:'
t_COMMA = r','
t_LEFTREF = '^[l|left]'
- t_RIGHTREF ='^[r|right]'
+ t_RIGHTREF = '^[r|right]'
t_UNION = '^[u|union]'
t_DISJOINT = '^[d|disjoint]'
t_INTERSECT = '^[i|intersect]'
@@ -182,7 +212,7 @@
t_CRPAREN = r'\}'
- t_ignore = ' \t'
# Track line numbers.
def t_newline(self, t):
@@ -191,8 +221,7 @@
def t_NAME(self, t):
r'[a-zA-Z_][a-zA-Z_0-9]*'
- self.temporal_symbol(t)
- return t
+ return self.temporal_symbol(t)
# Parse symbols
def temporal_symbol(self, t):
@@ -214,18 +243,19 @@
elif t.value == 'i' or t.value == 'intersect':
t.value = 'i'
t.type = 'INTERSECT'
- #else:
- # t.type = 'NAME'
+ else:
+ self.t_error(t)
return(t)
# Handle errors.
# Build the lexer
- self.lexer = lex.lex(module=self, **kwargs)
# Just for testing
@@ -245,13 +275,15 @@
def __init__(self):
self.lexer = TemporalOperatorLexer()
self.lexer.build()
- self.parser = yacc.yacc(module=self)
- self.relations = None # Temporal relations equals, contain, during, ...
- self.temporal = None # Temporal operation like intersect, left, right, ...
- self.function = None # Actual operation
- self.aggregate = None # Aggregation function
+ self.parser = yacc.yacc(module=self, debug=0)
+ self.relations = None # Temporal relations (equals, contain, during, ...)
+ self.temporal = None # Temporal operation (intersect, left, right, ...)
+ self.function = None # Actual operation (+, -, /, *, ... )
+ self.aggregate = None # Aggregation function (|, &)
- def parse(self, expression, optype='relation'):
+ self.optype_list = ["select", "boolean", "raster", "hash", "relation", "overlay"]
+ def parse(self, expression, optype='relation'):
"""Parse the expression and fill the object variables
:param expression:
@@ -259,30 +291,38 @@
- select { :, during, r}
- boolean {&&, contains, |}
- raster { *, equal, |}
- - vector { |, starts, &}
+ - overlay { |, starts, &}
- hash { #, during, l}
- relation {during}
:return:
self.optype = optype
+ if optype not in self.optype_list:
+ raise SyntaxError("Unknown optype %s, must be one of %s"%(self.optype, str(self.optype_list)))
+ self.expression = expression
# Error rule for syntax errors.
- raise SyntaxError("Unexpected syntax error")
+ raise SyntaxError("Unexpected syntax error in expression"
+ " \"%s\" at position %i near %s"%(self.expression,
+ t.lexpos,
+ t.value))
# Get the tokens from the lexer class
tokens = TemporalOperatorLexer.tokens
def p_relation_operator(self, t):
+ # {during}
+ # {during | equal | starts}
operator : CLPAREN relation CRPAREN
| CLPAREN relationlist CRPAREN
# Check for correct type.
if not self.optype == 'relation':
- raise SyntaxError("invalid syntax")
+ raise SyntaxError("Wrong optype \"%s\" must be \"relation\""%self.optype)
else:
# Set three operator components.
if isinstance(t[2], list):
@@ -295,6 +335,8 @@
t[0] = t[2]
def p_relation_bool_operator(self, t):
+ # {||, during}
+ # {&&, during | equal | starts}
operator : CLPAREN OR OR COMMA relation CRPAREN
| CLPAREN AND AND COMMA relation CRPAREN
@@ -302,7 +344,7 @@
| CLPAREN AND AND COMMA relationlist CRPAREN
if not self.optype == 'boolean':
+ raise SyntaxError("Wrong optype \"%s\" must be \"boolean\""%self.optype)
else:
if isinstance(t[5], list):
@@ -316,6 +358,8 @@
t[0] = t[2]
def p_relation_bool_combi_operator(self, t):
+ # {||, during, &}
+ # {&&, during | equal | starts, |}
operator : CLPAREN OR OR COMMA relation COMMA OR CRPAREN
| CLPAREN OR OR COMMA relation COMMA AND CRPAREN
@@ -327,7 +371,7 @@
| CLPAREN AND AND COMMA relationlist COMMA AND CRPAREN
else:
@@ -341,6 +385,8 @@
t[0] = t[2]
def p_relation_bool_combi_operator2(self, t):
+ # {||, during, left}
+ # {&&, during | equal | starts, union}
operator : CLPAREN OR OR COMMA relation COMMA temporal CRPAREN
| CLPAREN AND AND COMMA relation COMMA temporal CRPAREN
@@ -348,7 +394,7 @@
| CLPAREN AND AND COMMA relationlist COMMA temporal CRPAREN
else:
@@ -362,6 +408,8 @@
t[0] = t[2]
def p_relation_bool_combi_operator3(self, t):
+ # {||, during, |, left}
+ # {&&, during | equal | starts, &, union}
operator : CLPAREN OR OR COMMA relation COMMA OR COMMA temporal CRPAREN
| CLPAREN OR OR COMMA relation COMMA AND COMMA temporal CRPAREN
@@ -373,7 +421,7 @@
| CLPAREN AND AND COMMA relationlist COMMA AND COMMA temporal CRPAREN
else:
@@ -387,6 +435,10 @@
t[0] = t[2]
def p_select_relation_operator(self, t):
+ # { :, during}
+ # {!:, during | equal | starts}
+ # { :, during | equal | starts, l}
operator : CLPAREN select CRPAREN
| CLPAREN select COMMA relation CRPAREN
@@ -395,7 +447,7 @@
| CLPAREN select COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'select':
+ raise SyntaxError("Wrong optype \"%s\" must be \"select\""%self.optype)
else:
if len(t) == 4:
@@ -419,6 +471,10 @@
t[0] = t[2]
def p_hash_relation_operator(self, t):
+ # {#, during}
+ # {#, during | equal | starts}
+ # {#, during | equal | starts, l}
operator : CLPAREN HASH CRPAREN
| CLPAREN HASH COMMA relation CRPAREN
@@ -427,7 +483,7 @@
| CLPAREN HASH COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'hash':
+ raise SyntaxError("Wrong optype \"%s\" must be \"hash\""%self.optype)
else:
if len(t) == 4:
@@ -451,7 +507,10 @@
t[0] = t[2]
def p_raster_relation_operator(self, t):
- # The expression should always return a list of maps.
+ # {-, during}
+ # {*, during | equal | starts}
+ # {/, during | equal | starts, l}
operator : CLPAREN arithmetic CRPAREN
| CLPAREN arithmetic COMMA relation CRPAREN
@@ -460,7 +519,7 @@
| CLPAREN arithmetic COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'raster':
+ raise SyntaxError("Wrong optype \"%s\" must be \"raster\""%self.optype)
else:
if len(t) == 4:
@@ -484,7 +543,10 @@
t[0] = t[2]
def p_overlay_relation_operator(self, t):
+ # {-, during}
+ # {~, during | equal | starts}
+ # {^, during | equal | starts, l}
operator : CLPAREN overlay CRPAREN
| CLPAREN overlay COMMA relation CRPAREN
@@ -493,7 +555,7 @@
| CLPAREN overlay COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'overlay':
+ raise SyntaxError("Wrong optype \"%s\" must be \"overlay\""%self.optype)
else:
if len(t) == 4:
@@ -534,7 +596,7 @@
t[0] = t[1]
def p_over(self, t):
- # The list of relations.
+ # The the over keyword
relation : OVER
Modified: grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -53,6 +53,8 @@
######################### Temporal functions ##############################
def p_statement_assign(self, t):
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -95,8 +95,7 @@
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -143,9 +143,14 @@
register_null=False,
dry_run=False, nprocs=1):
- TemporalAlgebraParser.__init__(self, pid=pid, run=run, debug=debug,
- spatial=spatial, register_null=register_null,
- dry_run=dry_run, nprocs=nprocs)
+ TemporalAlgebraParser.__init__(self,
+ pid=pid,
+ run=run,
+ debug=debug,
+ spatial=spatial,
+ register_null=register_null,
+ dry_run=dry_run,
+ nprocs=nprocs)
def check_null(self, t):
try:
@@ -160,30 +165,30 @@
compare_cmd=False, compop=None, aggregate=None,
new=False, convert=False, operator_cmd=False):
- for given relation into map list.
+ for given relation into map list.
- :param maplistA: List of maps.
- :param maplistB: List of maps.
- :param topolist: List of strings of temporal relations.
- :param assign_val: Boolean for assigning a boolean map value based on
- the map_values from the compared map list by
- topological relationships.
- :param count_map: Boolean if the number of topological related maps
- should be returned.
- :param compare_bool: Boolean for comparing boolean map values based on
- related map list and compariosn operator.
- :param compare_cmd: Boolean for comparing command list values based on
- :param compop: Comparison operator, && or ||.
- :param aggregate: Aggregation operator for relation map list, & or |.
- :param new: Boolean if new temporary maps should be created.
- :param convert: Boolean if conditional values should be converted to
- r.mapcalc command strings.
- :param operator_cmd: Boolean for aggregate arithmetic operators implicitly
- in command list values based on related map lists.
+ :param maplistA: List of maps.
+ :param maplistB: List of maps.
+ :param topolist: List of strings of temporal relations.
+ :param assign_val: Boolean for assigning a boolean map value based on
+ the map_values from the compared map list by
+ topological relationships.
+ :param count_map: Boolean if the number of topological related maps
+ should be returned.
+ :param compare_bool: Boolean for comparing boolean map values based on
+ related map list and compariosn operator.
+ :param compare_cmd: Boolean for comparing command list values based on
+ :param compop: Comparison operator, && or ||.
+ :param aggregate: Aggregation operator for relation map list, & or |.
+ :param new: Boolean if new temporary maps should be created.
+ :param convert: Boolean if conditional values should be converted to
+ r.mapcalc command strings.
+ :param operator_cmd: Boolean for aggregate arithmetic operators implicitly
+ in command list values based on related map lists.
- :return: List of maps from maplistA that fulfil the topological relationships
- to maplistB specified in topolist.
+ :return: List of maps from maplistA that fulfil the topological relationships
+ to maplistB specified in topolist.
topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED",
"DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED",
@@ -206,7 +211,7 @@
spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
# Build spatial temporal topology
if self.spatial:
- tb.build(maplistA, maplistB, spatial = spatialdict[self.stdstype])
+ tb.build(maplistA, maplistB, spatial=spatialdict[self.stdstype])
else:
tb.build(maplistA, maplistB)
# Iterate through maps in maplistA and search for relationships given
@@ -244,19 +249,19 @@
def build_command_string(self, map_i, relmap, operator = None, cmd_type = None):
"""This function build the r.mapcalc command string for conditionals,
- spatial variable combinations and boolean comparisons.
+ spatial variable combinations and boolean comparisons.
- For Example: 'if(a1 == 1, b1, c2)' or 'exist(a1) && sin(b1)'
+ For Example: 'if(a1 == 1, b1, c2)' or 'exist(a1) && sin(b1)'
- :param map_i: map object with temporal extent and built relations.
- :param relmap: map object with defined temporal relation to map_i.
- :param operator: String representing operator between two spatial variables
- :param cmd_type: map object with defined temporal relation to map_i:
- condition, conclusion or operator.
+ :param map_i: map object with temporal extent and built relations.
+ :param relmap: map object with defined temporal relation to map_i.
+ :param operator: String representing operator between two spatial variables
+ :param cmd_type: map object with defined temporal relation to map_i:
+ condition, conclusion or operator.
- :return: the resulting command string for conditionals or spatial variable
- combinations
+ :return: the resulting command string for conditionals or spatial variable
+ combinations
def sub_cmdstring(map_i):
"""This function search for command string in a map object and
@@ -289,25 +294,27 @@
if operator == None:
self.msgr.fatal("Error: Can't build command string for map %s, operator is missing"
%(map_i.get_map_id()))
- cmdstring = "(%s %s %s)" %(leftsub, operator, rightsub)
+ cmdstring = "(%s %s %s)" %(leftsub, operator, rightsub)
return(cmdstring)
def compare_cmd_value(self, map_i, tbrelations, compop, aggregate,
- topolist = ["EQUAL"], convert = False):
+ topolist = ["EQUAL"], convert = False):
- comparison operator. Extended temporal algebra version with command
- list builder for temporal raster algebra.
+ comparison operator.
- :param map_i: Map object with temporal extent.
- :param tbrelations: List of temporal relation to map_i.
- :param topolist: List of strings for given temporal relations.
+ Extended temporal algebra version with command
+ list builder for temporal raster algebra.
- :return: Map object with conditional value that has been evaluated by
- comparison operators.
+ :param map_i: Map object with temporal extent.
+ :param tbrelations: List of temporal relation to map_i.
+ :param topolist: List of strings for given temporal relations.
+ :return: Map object with conditional value that has been evaluated by
+ comparison operators.
# Build comandlist list with elements from related maps and given relation operator.
if convert and "condition_value" in dir(map_i):
@@ -346,13 +353,13 @@
def operator_cmd_value(self, map_i, tbrelations, operator, topolist = ["EQUAL"]):
""" Function to evaluate two map lists by given arithmetic operator.
- :param operator: Arithmetic operator, +-*/%.
+ :param operator: Arithmetic operator, +-*/%.
- :return: Map object with command list with operators that has been
- evaluated by implicit aggregration.
+ :return: Map object with command list with operators that has been
+ evaluated by implicit aggregration.
leftcmd = map_i
@@ -375,20 +382,20 @@
def set_temporal_extent_list(self, maplist, topolist=["EQUAL"], temporal='l' ,
cmd_bool=False, cmd_type=None, operator=None):
- other map list and given temporal operator.
+ other map list and given temporal operator.
- :param maplist: List of map objects for which relations has been build
- correctely.
- :param temporal: The temporal operator specifying the temporal
- extent operation (intersection, union, disjoint
- union, right reference, left reference).
- :param cmd_bool: Boolean if command string should be merged for related maps.
- :param operator: String defining the type of operator.
+ :param maplist: List of map objects for which relations has been build
+ correctely.
+ :param temporal: The temporal operator specifying the temporal
+ extent operation (intersection, union, disjoint
+ union, right reference, left reference).
+ :param cmd_bool: Boolean if command string should be merged for related maps.
+ :param operator: String defining the type of operator.
- :return: Map list with specified temporal extent and optional command string.
+ :return: Map list with specified temporal extent and optional command string.
resultdict = {}
@@ -396,8 +403,10 @@
# Loop over temporal related maps and create overlay modules.
tbrelations = map_i.get_temporal_relations()
# Generate an intermediate map for the result map list.
- map_new = self.generate_new_map(base_map=map_i, bool_op='and',
- copy=True, rename=True)
+ map_new = self.generate_new_map(base_map=map_i,
+ bool_op='and',
+ copy=True,
+ rename=True)
# Combine temporal and spatial extents of intermediate map with related maps.
for topo in topolist:
@@ -405,10 +414,13 @@
for map_j in (tbrelations[topo]):
if temporal == 'r':
+ bool_op='and',
+ copy=True,
+ rename=True)
# Create overlayed map extent.
- returncode = self.overlay_map_extent(map_new, map_j, 'and',
+ returncode = self.overlay_map_extent(map_new, map_j,
+ 'and',
temp_op = temporal)
# Stop the loop if no temporal or spatial relationship exist.
@@ -444,33 +456,34 @@
conclusion_topolist=["EQUAL"],
temporal='l', null=False):
"""This function build the r.mapcalc command strings for spatial conditionals.
- :param iflist: Map list with temporal extents and command list.
- :param thenlist: Map list with temporal extents and command list or numeric string.
- :param elselist: Map list with temporal extents and command list or numeric string.
- :param condition_topolist: List of strings for given temporal relations between
- conditions and conclusions.
- :param conclusion_topolist: List of strings for given temporal relations between
- conditions (then and else).
- :param null: Boolean if null map support should be activated.
+ :param iflist: Map list with temporal extents and command list.
+ :param thenlist: Map list with temporal extents and command list or numeric string.
+ :param elselist: Map list with temporal extents and command list or numeric string.
+ :param condition_topolist: List of strings for given temporal relations between
+ conditions and conclusions.
+ :param conclusion_topolist: List of strings for given temporal relations between
+ conditions (then and else).
+ :param null: Boolean if null map support should be activated.
- :return: map list with resulting command string for given condition type.
+ :return: map list with resulting command string for given condition type.
resultlist = []
# First merge conclusion command maplists or strings.
# Check if alternative conclusion map list is given.
if all([isinstance(thenlist, list), isinstance(elselist, list)]):
# Build conclusion command map list.
- conclusiontopolist = self.get_temporal_topo_list(thenlist, elselist, conclusion_topolist)
+ conclusiontopolist = self.get_temporal_topo_list(thenlist, elselist,
+ conclusion_topolist)
conclusionlist = self.set_temporal_extent_list(conclusiontopolist,
- topolist = conclusion_topolist,
- temporal = temporal ,
- cmd_bool = True,
- cmd_type = "conclusion")
+ topolist=conclusion_topolist,
+ temporal=temporal ,
+ cmd_bool=True,
+ cmd_type="conclusion")
# Check if any conclusion is a numeric statements.
elif any([isinstance(thenlist, str), isinstance(elselist, str)]):
conclusionlist = []
@@ -482,7 +495,7 @@
# Create r.mapcalc expression string for the operation.
cmdstring = self.build_command_string(map_i,
numinput,
- cmd_type = 'conclusion')
+ cmd_type='conclusion')
# Conditional append of module command.
map_i.cmd_list = cmdstring
# Append map to result map list.
@@ -495,7 +508,7 @@
cmdstring = self.build_command_string(numinput,
map_i,
@@ -513,7 +526,7 @@
conclusionlist,
- cmd_type = 'condition')
+ cmd_type='condition')
@@ -521,7 +534,8 @@
return(resultlist)
elif isinstance(conclusionlist, list):
# Build result command map list between conditions and conclusions.
- conditiontopolist = self.get_temporal_topo_list(iflist, conclusionlist,
+ conditiontopolist = self.get_temporal_topo_list(iflist,
+ conclusionlist,
topolist=condition_topolist)
resultlist = self.set_temporal_extent_list(conditiontopolist,
topolist=condition_topolist,
@@ -554,7 +568,7 @@
new_map = RasterDataset(map_name)
else:
new_map = Raster3DDataset(map_name)
- if new_map.map_exists() and self.overwrite == False:
+ if new_map.map_exists() and self.overwrite is False:
self.msgr.fatal("Error maps with basename %s exist. "
"Use --o flag to overwrite existing file"%map_name)
map_test_list = []
@@ -565,10 +579,10 @@
# Change map name to given basename.
# Create deepcopy of r.mapcalc module.
- map_test = map_i.get_new_instance(newident + "@" + self.mapset)
- map_test.set_temporal_extent(map_i.get_temporal_extent())
- map_test.set_spatial_extent(map_i.get_spatial_extent())
- map_test_list.append(map_test)
+ new_map = map_i.get_new_instance(newident + "@" + self.mapset)
+ new_map.set_temporal_extent(map_i.get_temporal_extent())
+ new_map.set_spatial_extent(map_i.get_spatial_extent())
+ map_test_list.append(new_map)
m = copy.deepcopy(self.m_mapcalc)
m_expression = newident + "=" + map_i.cmd_list
@@ -582,18 +596,16 @@
elif map_i.map_exists():
# Copy map if it exists b = a
m_expression = newident + "=" + map_i.get_map_id()
m.inputs["expression"].value = str(m_expression)
#print(m.get_bash())
@@ -622,7 +634,9 @@
# Put the map into the process dictionary
start, end = map_i.get_temporal_extent_as_tuple()
- self.process_chain_dict["register"].append((map_i.get_name(), str(start), str(end)))
+ self.process_chain_dict["register"].append((map_i.get_name(),
+ str(start),
+ str(end)))
# Get meta data from grass database.
@@ -650,6 +664,7 @@
# Register map in result space time dataset.
success = resultstds.register_map(map_i, dbif)
resultstds.update_from_registered_maps(dbif)
@@ -701,23 +716,29 @@
print("map(" + t[3] + ")")
def p_arith1_operation(self, t):
+ # A % B
+ # A / B
+ # A * B
+ # A % td(B)
+ # A * td(B)
+ # A / td(B)
- expr : stds MOD stds
- | expr MOD stds
- | stds MOD expr
- | expr MOD expr
- | stds DIV stds
- | expr DIV stds
- | stds DIV expr
- | expr DIV expr
+ expr : stds MOD stds
+ | expr MOD stds
+ | stds MOD expr
+ | expr MOD expr
+ | stds DIV stds
+ | expr DIV stds
+ | stds DIV expr
+ | expr DIV expr
| stds MULT stds
| expr MULT stds
| stds MULT expr
| expr MULT expr
- | stds MOD t_td_var
- | expr MOD t_td_var
- | stds DIV t_td_var
- | expr DIV t_td_var
+ | stds MOD t_td_var
+ | expr MOD t_td_var
+ | stds DIV t_td_var
+ | expr DIV t_td_var
| stds MULT t_td_var
| expr MULT t_td_var
@@ -731,13 +752,16 @@
resultlist = []
for map_i in topolist:
- map_new = self.generate_new_map(base_map=map_i, bool_op='and', copy=True)
+ bool_op='and',
+ copy=True)
count = 0
for map_j in (tbrelations['EQUAL']):
- returncode = self.overlay_map_extent(map_new, map_j, 'and', \
+ 'and',
temp_op='l')
if returncode == 0:
@@ -767,23 +791,29 @@
print(map.cmd_list)
def p_arith1_operation_numeric1(self, t):
+ # A % 1
+ # A / 4
+ # A * 5
+ # A % map(b1)
+ # A * map(b2)
+ # A / map(b3)
- expr : stds MOD number
- | expr MOD number
- | stds DIV number
- | expr DIV number
+ expr : stds MOD number
+ | expr MOD number
+ | stds DIV number
+ | expr DIV number
| stds MULT number
| expr MULT number
- | stds MOD numberstr
- | expr MOD numberstr
- | stds DIV numberstr
- | expr DIV numberstr
+ | stds MOD numberstr
+ | expr MOD numberstr
+ | stds DIV numberstr
+ | expr DIV numberstr
| stds MULT numberstr
| expr MULT numberstr
- | stds MOD mapexpr
- | expr MOD mapexpr
- | stds DIV mapexpr
- | expr DIV mapexpr
+ | stds MOD mapexpr
+ | expr MOD mapexpr
+ | stds DIV mapexpr
+ | expr DIV mapexpr
| stds MULT mapexpr
| expr MULT mapexpr
@@ -812,25 +842,31 @@
def p_arith1_operation_numeric2(self, t):
+ # 1 % A
+ # 4 / A
+ # 5 * A
+ # map(b1) % A
+ # map(b4) / A
+ # map(b5) * A
- expr : number MOD stds
- | number MOD expr
- | number DIV stds
- | number DIV expr
- | number MULT stds
- | number MULT expr
- | numberstr MOD stds
- | numberstr MOD expr
- | numberstr DIV stds
- | numberstr DIV expr
+ expr : number MOD stds
+ | number MOD expr
+ | number DIV stds
+ | number DIV expr
+ | number MULT stds
+ | number MULT expr
+ | numberstr MOD stds
+ | numberstr MOD expr
+ | numberstr DIV stds
+ | numberstr DIV expr
| numberstr MULT stds
| numberstr MULT expr
- | mapexpr MOD stds
- | mapexpr MOD expr
- | mapexpr DIV stds
- | mapexpr DIV expr
- | mapexpr MULT stds
- | mapexpr MULT expr
+ | mapexpr MOD stds
+ | mapexpr MOD expr
+ | mapexpr DIV stds
+ | mapexpr DIV expr
+ | mapexpr MULT stds
+ | mapexpr MULT expr
# Check input stds.
maplist = self.check_stds(t[3])
@@ -857,6 +893,10 @@
def p_arith2_operation(self, t):
+ # A + B
+ # A - B
+ # A + td(B)
+ # A - td(B)
expr : stds ADD stds
| expr ADD stds
@@ -881,14 +921,18 @@
resultlist = []
+ bool_op='and',
+ copy=True)
count = 0
+ map_j,
+ 'and',
temp_op='l')
if returncode == 0:
@@ -901,7 +945,8 @@
name = self.generate_map_name()
- cmdstring = self.build_command_string(map_i, map_j,
+ cmdstring = self.build_command_string(map_i,
+ map_j,
operator=t[2],
cmd_type="operator")
@@ -919,6 +964,10 @@
print(map.cmd_list)
def p_arith2_operation_numeric1(self, t):
+ # A + 2
+ # A - 3
+ # A + map(b4)
+ # A - map(b5)
expr : stds ADD number
| expr ADD number
@@ -957,19 +1006,23 @@
print(map.cmd_list)
def p_arith2_operation_numeric2(self, t):
+ # 2 + A
+ # 3 - A
+ # map(b2) + A
+ # map(b3) - A
- expr : number ADD stds
- | number ADD expr
- | number SUB stds
- | number SUB expr
+ expr : number ADD stds
+ | number ADD expr
+ | number SUB stds
+ | number SUB expr
| numberstr ADD stds
| numberstr ADD expr
| numberstr SUB stds
| numberstr SUB expr
- | mapexpr ADD stds
- | mapexpr ADD expr
- | mapexpr SUB stds
- | mapexpr SUB expr
+ | mapexpr ADD stds
+ | mapexpr ADD expr
+ | mapexpr SUB stds
+ | mapexpr SUB expr
# Check input stds.
@@ -995,6 +1048,10 @@
print(map.cmd_list)
def p_arith1_operation_relation(self, t):
+ # A {*, equal, l} B
+ # A {*, equal, l} td(B)
+ # A {*, equal, l} B {/, during, r} C
+ # A {*, equal, l} B {/, equal, l} C {/, during, r} D
expr : stds T_ARITH1_OPERATOR stds
| expr T_ARITH1_OPERATOR stds
@@ -1007,12 +1064,16 @@
# Check input stds.
- relations, temporal, function, aggregate = self.eval_toperator(t[2], optype='raster')
+ relations, temporal, function, aggregate = self.eval_toperator(t[2], optype='raster')
# Build conditional values based on topological relationships.
- complist = self.get_temporal_topo_list(maplistA, maplistB, topolist=relations,
- operator_cmd=True, compop=function)
+ complist = self.get_temporal_topo_list(maplistA,
+ maplistB,
+ topolist=relations,
+ operator_cmd=True,
+ compop=function)
# Set temporal extent based on topological relationships.
- resultlist = self.set_temporal_extent_list(complist, topolist=relations,
+ resultlist = self.set_temporal_extent_list(complist,
temporal=temporal)
t[0] = resultlist
@@ -1022,6 +1083,10 @@
print(map.cmd_list)
def p_arith2_operation_relation(self, t):
+ # A {+, equal, l} B
+ # A {+, equal, l} td(b)
+ # A {+, equal, l} B {-, during, r} C
+ # A {+, equal, l} B {+, equal, l} C {-, during, r} D
expr : stds T_ARITH2_OPERATOR stds
| expr T_ARITH2_OPERATOR stds
@@ -1034,12 +1099,16 @@
# Check input stds.
- relations, temporal, function, aggregate = self.eval_toperator(t[2], optype = 'raster')
+ maplistB,
+ compop=function)
temporal=temporal)
t[0] = resultlist
@@ -1049,6 +1118,11 @@
print(map.cmd_list)
def p_arith_operation_numeric_string(self, t):
+ # 1 + 1
+ # 1 - 1
+ # 1 * 1
+ # 1 / 1
+ # 1 % 1
numberstr : number ADD number
| number SUB number
@@ -1086,7 +1160,6 @@
def p_mapcalc_operation1(self, t):
- # Examples:
# sin(A)
# log(B)
@@ -1116,7 +1189,6 @@
print(map.cmd_list)
def p_mapexpr_operation(self, t):
- # Examples:
# sin(map(a))
mapexpr : mapcalc_arith LPAREN mapexpr RPAREN
@@ -1133,7 +1205,6 @@
print(mapstring)
def p_s_var_expr_1(self, t):
- # Examples:
# isnull(A)
s_var_expr : ISNULL LPAREN stds RPAREN
@@ -1162,7 +1233,6 @@
print(map.cmd_list)
def p_s_var_expr_2(self, t):
- # Examples:
# isntnull(A)
s_var_expr : ISNTNULL LPAREN stds RPAREN
@@ -1191,7 +1261,6 @@
print(map.cmd_list)
def p_s_var_expr_3(self, t):
- # Examples:
# A <= 2
s_var_expr : stds comp_op number
@@ -1220,7 +1289,6 @@
print(map.cmd_list)
def p_s_var_expr_4(self, t):
- # Examples:
# exist(B)
s_var_expr : EXIST LPAREN stds RPAREN
@@ -1249,12 +1317,11 @@
print(map.cmd_list)
def p_s_var_expr_comp(self, t):
- # Examples:
# A <= 2 || B == 10
# A < 3 && A > 1
s_var_expr : s_var_expr AND AND s_var_expr
- | s_var_expr OR OR s_var_expr
+ | s_var_expr OR OR s_var_expr
if self.run:
# Check input stds.
@@ -1265,12 +1332,16 @@
function = t[2] + t[3]
aggregate = t[2]
- complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB, topolist=relations,
- compare_cmd=True, compop=function,
+ complist = self.get_temporal_topo_list(s_var_exprA,
+ s_var_exprB,
+ compare_cmd=True,
+ compop=function,
aggregate=aggregate)
- resultlist = self.set_temporal_extent_list(complist, topolist = relations,
- temporal = temporal)
+ temporal=temporal)
t[0] = resultlist
@@ -1279,7 +1350,6 @@
print(map.cmd_list)
def p_s_var_expr_comp_op(self, t):
- # Examples:
# A <= 2 {||} B == 10
# A < 3 {&&, equal} A > 1
@@ -1290,13 +1360,17 @@
s_var_exprA = self.check_stds(t[1])
s_var_exprB = self.check_stds(t[3])
# Evaluate temporal comparison operator.
- relations, temporal, function, aggregate = self.eval_toperator(t[2], optype='boolean')
+ relations, temporal, function, aggregate = self.eval_toperator(t[2], optype='boolean')
+ s_var_exprB,
+ compare_cmd=True,
+ compop=function,
temporal=temporal)
t[0] = resultlist
@@ -1306,22 +1380,23 @@
print(map.cmd_list)
def p_s_expr_condition_if(self, t):
- # Examples:
# if(s_var_expr, B)
# if(A == 1, B)
- expr : IF LPAREN s_var_expr COMMA stds RPAREN
- | IF LPAREN s_var_expr COMMA expr RPAREN
+ expr : IF LPAREN s_var_expr COMMA stds RPAREN
+ | IF LPAREN s_var_expr COMMA expr RPAREN
| IF LPAREN ts_var_expr COMMA stds RPAREN
| IF LPAREN ts_var_expr COMMA expr RPAREN
ifmaplist = self.check_stds(t[3])
thenmaplist = self.check_stds(t[5])
- resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,
+ resultlist = self.build_condition_cmd_list(ifmaplist,
+ thenmaplist,
elselist=None,
condition_topolist=["EQUAL"],
- temporal='r', null=False)
+ temporal='r',
+ null=False)
t[0] = resultlist
if self.debug:
@@ -1329,14 +1404,13 @@
print(map.cmd_list)
def p_s_numeric_condition_if(self, t):
- # Examples:
# if(s_var_expr, 1)
# if(A == 5, 10)
- expr : IF LPAREN s_var_expr COMMA number RPAREN
- | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN RPAREN
+ expr : IF LPAREN s_var_expr COMMA number RPAREN
+ | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN RPAREN
| IF LPAREN ts_var_expr COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN RPAREN
resultlist = []
@@ -1348,7 +1422,8 @@
# Iterate over condition map list.
for map_i in ifmaplist:
- cmdstring = self.build_command_string(map_i, numinput, cmd_type = 'condition')
+ cmdstring = self.build_command_string(map_i, numinput,
@@ -1361,23 +1436,24 @@
print(map.cmd_list)
def p_s_expr_condition_if_relation(self, t):
- # Examples:
# if({equal||during}, s_var_expr, A)
- expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr RPAREN
+ expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr RPAREN
relations, temporal, function, aggregation = self.eval_toperator(t[3],
- optype = 'relation')
+ optype='relation')
ifmaplist = self.check_stds(t[5])
thenmaplist = self.check_stds(t[7])
+ thenmaplist,
elselist=None,
condition_topolist=relations,
+ temporal='r',
+ null=False)
t[0] = resultlist
if self.debug:
@@ -1385,13 +1461,12 @@
print(map.cmd_list)
def p_s_expr_condition_elif(self, t):
- # Examples:
# if(s_var_expr, A, B)
- expr : IF LPAREN s_var_expr COMMA stds COMMA stds RPAREN
- | IF LPAREN s_var_expr COMMA stds COMMA expr RPAREN
- | IF LPAREN s_var_expr COMMA expr COMMA stds RPAREN
- | IF LPAREN s_var_expr COMMA expr COMMA expr RPAREN
+ expr : IF LPAREN s_var_expr COMMA stds COMMA stds RPAREN
+ | IF LPAREN s_var_expr COMMA stds COMMA expr RPAREN
+ | IF LPAREN s_var_expr COMMA expr COMMA stds RPAREN
+ | IF LPAREN s_var_expr COMMA expr COMMA expr RPAREN
| IF LPAREN ts_var_expr COMMA stds COMMA stds RPAREN
| IF LPAREN ts_var_expr COMMA stds COMMA expr RPAREN
| IF LPAREN ts_var_expr COMMA expr COMMA stds RPAREN
@@ -1402,11 +1477,13 @@
elsemaplist = self.check_stds(t[7])
# Create conditional command map list.
+ thenmaplist,
elselist=elsemaplist,
+ temporal='r',
+ null=False)
t[0] = resultlist
@@ -1415,21 +1492,19 @@
print(map.cmd_list)
def p_s_numeric_condition_elif(self, t):
- # Examples:
# if(s_var_expr, 1, 2)
# if(A == 5, 10, 0)
- expr : IF LPAREN s_var_expr COMMA number COMMA number RPAREN
- | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
- | IF LPAREN s_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN ts_var_expr COMMA number COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
+ expr : IF LPAREN s_var_expr COMMA number COMMA number RPAREN
+ | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
+ | IF LPAREN s_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
- resultlist = []
# Select input for r.mapcalc expression based on length of PLY object.
if len(t) == 9:
numthen = t[5]
@@ -1447,10 +1522,13 @@
numelse = str(numelse)
print(numthen + " " +numelse )
- resultlist = self.build_condition_cmd_list(ifmaplist, numthen, numelse,
+ numthen,
+ numelse,
+ temporal='r',
+ null=False)
t[0] = resultlist
@@ -1459,26 +1537,25 @@
print(map.cmd_list)
def p_s_numeric_expr_condition_elif(self, t):
- # Examples:
# if(s_var_expr, 1, A)
# if(A == 5 && C > 5, A, null())
- expr : IF LPAREN s_var_expr COMMA number COMMA stds RPAREN
- | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
- | IF LPAREN s_var_expr COMMA number COMMA expr RPAREN
- | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
- | IF LPAREN s_var_expr COMMA stds COMMA number RPAREN
- | IF LPAREN s_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN s_var_expr COMMA expr COMMA number RPAREN
- | IF LPAREN s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN ts_var_expr COMMA number COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA number COMMA expr RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
- | IF LPAREN ts_var_expr COMMA stds COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN ts_var_expr COMMA expr COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ expr : IF LPAREN s_var_expr COMMA number COMMA stds RPAREN
+ | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
+ | IF LPAREN s_var_expr COMMA number COMMA expr RPAREN
+ | IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
+ | IF LPAREN s_var_expr COMMA stds COMMA number RPAREN
+ | IF LPAREN s_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN s_var_expr COMMA expr COMMA number RPAREN
+ | IF LPAREN s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA stds COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA expr COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
@@ -1498,10 +1575,13 @@
elseinput = str(t[7] + t[8] + t[9])
- resultlist = self.build_condition_cmd_list(ifmaplist, theninput, elseinput,
+ theninput,
+ elseinput,
+ temporal='r',
+ null=False)
t[0] = resultlist
@@ -1510,28 +1590,27 @@
print(map.cmd_list)
def p_s_numeric_expr_condition_elif_relation(self, t):
- # Examples:
# if({during},s_var_expr, 1, A)
# if({during}, A == 5, A, null())
- expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA number COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA number COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA number RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA number RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA number RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA number RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA number COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA number COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA number RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA number RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA number RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA number RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
- relations, temporal, function, aggregation = self.eval_toperator(t[3], optype = 'relation')
+ relations, temporal, function, aggregation = self.eval_toperator(t[3], optype='relation')
if len(t) == 11:
@@ -1550,10 +1629,13 @@
elseinput = str(t[9] + t[10] + t[11])
+ theninput,
+ elseinput,
+ temporal='r',
+ null=False)
t[0] = resultlist
@@ -1561,30 +1643,31 @@
for map in resultlist:
print(map.cmd_list)
def p_s_expr_condition_elif_relation(self, t):
- # Examples:
# if({equal||during}, s_var_expr, A, B)
- expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA expr RPAREN
+ expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA expr RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA expr RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA expr RPAREN
elsemaplist = self.check_stds(t[9])
- resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist, elsemaplist,
+ thenmaplist,
+ elsemaplist,
+ temporal='r',
+ null=False)
t[0] = resultlist
@@ -1600,18 +1683,18 @@
# IMPORTANT: Only the intersection of map lists in conditionals are
# exported.
- ts_var_expr : s_var_expr AND AND t_var_expr
- | t_var_expr AND AND s_var_expr
- | t_var_expr OR OR s_var_expr
- | s_var_expr OR OR t_var_expr
+ ts_var_expr : s_var_expr AND AND t_var_expr
+ | t_var_expr AND AND s_var_expr
+ | t_var_expr OR OR s_var_expr
+ | s_var_expr OR OR t_var_expr
| ts_var_expr AND AND s_var_expr
| ts_var_expr AND AND t_var_expr
- | ts_var_expr OR OR s_var_expr
- | ts_var_expr OR OR t_var_expr
- | s_var_expr AND AND ts_var_expr
- | t_var_expr AND AND ts_var_expr
- | s_var_expr OR OR ts_var_expr
- | t_var_expr OR OR ts_var_expr
+ | ts_var_expr OR OR s_var_expr
+ | ts_var_expr OR OR t_var_expr
+ | s_var_expr AND AND ts_var_expr
+ | t_var_expr AND AND ts_var_expr
+ | s_var_expr OR OR ts_var_expr
+ | t_var_expr OR OR ts_var_expr
if self.run:
# Check input stds.
@@ -1622,12 +1705,16 @@
aggregate = t[2]
- topolist=relations, compare_cmd=True,
- compop=function, aggregate=aggregate,
+ s_var_exprB,
+ compare_cmd=True,
+ compop=function,
+ aggregate=aggregate,
convert=True)
temporal=temporal)
t[0] = resultlist
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -370,8 +370,8 @@
vectormap = VectorDataset(vectorname + "@" + get_current_mapset())
if vectormap.map_exists() and self.overwrite == False:
self.msgr.fatal(_("Error vector maps with basename %s exist. "
- "Use --o flag to overwrite existing file") \
- %(vectorname))
+ "Use --o flag to overwrite existing file") \
+ %(vectorname))
for map_i in t[3]:
if "cmd_list" in dir(map_i):
# Execute command list.
@@ -381,7 +381,7 @@
# otherwise v.overlay will break
if cmd.name == "v.overlay":
for name in (cmd.inputs["ainput"].value,
- cmd.inputs["binput"].value):
+ cmd.inputs["binput"].value):
#self.msgr.message("Check if map <" + name + "> exists")
if name.find("@") < 0:
name = name + "@" + get_current_mapset()
@@ -400,10 +400,11 @@
# print the command that will be executed
self.msgr.message("Run command:\n" + cmd.get_bash())
cmd.run()
if cmd.popen.returncode != 0:
- self.msgr.fatal(_("Error starting %s : \n%s") \
- %(cmd.get_bash(), \
- cmd.popen.stderr))
+ self.msgr.fatal(_("Error starting %s : \n%s")
+ %(cmd.get_bash(),
+ cmd.popen.stderr))
mapname = cmd.outputs['output'].value
if mapname.find("@") >= 0:
map_test = map_i.get_new_instance(mapname)
@@ -438,9 +439,10 @@
newident = self.basename + "_" + str(count)
map_result = map_i.get_new_instance(newident + "@" + self.mapset)
- if map_test.map_exists() and self.overwrite == False:
- self.msgr.fatal("Error raster maps with basename %s exist. Use --o flag to overwrite existing file" \
- %(mapname))
+ if map_test.map_exists() and self.overwrite is False:
+ self.msgr.fatal("Error raster maps with basename %s exist. "
+ %(mapname))
map_result.set_temporal_extent(map_i.get_temporal_extent())
map_result.set_spatial_extent(map_i.get_spatial_extent())
@@ -459,10 +461,10 @@
if len(register_list) > 0:
# Create result space time dataset.
- resultstds = open_new_stds(t[1], self.stdstype, \
- 'absolute', t[1], t[1], \
- "temporal vector algebra", self.dbif,
- overwrite = self.overwrite)
+ resultstds = open_new_stds(t[1], self.stdstype,
+ 'absolute', t[1], t[1],
+ "temporal vector algebra", self.dbif,
+ overwrite=self.overwrite)
for map_i in register_list:
# Check if modules should be executed from command list.
if hasattr(map_i, "cmd_list") or hasattr(map_i, "is_new"):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -109,7 +109,7 @@
def test_common_granularity_2(self):
"""Testing the common granularity function year to month samping. """
- ta = tgis.TemporalAlgebraParser(run = True, debug = True)
+ ta = tgis.TemporalAlgebraParser(run=True, debug=True)
expr = 'R = A : C'
ret = ta.setup_common_granularity(expression=expr)
@@ -129,7 +129,7 @@
def test_common_granularity_3(self):
"""Testing the common granularity function with gaps. """
expr = 'R = A : D'
@@ -149,7 +149,7 @@
def test_common_granularity_4(self):
"""Testing the common granularity function year to month with gaps. """
expr = 'R = C : D'
@@ -168,7 +168,7 @@
expr = 'R = C : D'
@@ -187,7 +187,7 @@
def test_common_granularity_5(self):
expr = 'R = A : C : D'
@@ -206,7 +206,7 @@
def test_common_granularity_6(self):
expr = 'R = if(start_month(A) > 2, A : C : D)'
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -77,14 +77,14 @@
D.select()
maplist = D.get_registered_maps_as_objects()
self.assertEqual(D.metadata.get_number_of_maps(), 2)
- self.assertEqual(D.metadata.get_min_min(), 2)
- self.assertEqual(D.metadata.get_max_max(), 3)
+ self.assertEqual(D.metadata.get_min_min(), 2)
+ self.assertEqual(D.metadata.get_max_max(), 3)
start, end = D.get_absolute_time()
self.assertEqual(start, datetime.datetime(2001, 1, 2))
self.assertEqual(end, datetime.datetime(2001, 1, 4))
self.assertEqual( D.check_temporal_topology(), False)
self.assertEqual(D.get_granularity(), u'2 days')
ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True, dry_run=True)
pc = ta.parse(expression="R = A {:,during,r} C", basename="r", overwrite=True)
@@ -717,6 +717,30 @@
self.assertEqual( D.check_temporal_topology(), True)
self.assertEqual(D.get_granularity(), u'1 day')
+ def test_capacity_1(self):
+ """Arithmetic test with temporal intersection"""
+ tra = tgis.TemporalRasterAlgebraParser(run=True, debug=True)
+ expr = "R = (((((((A + A) - A) * A) / A) % A) - td(A)) - (A # A))"
+ tra.parse(expression=expr, basename="r", overwrite=True)
+ D = tgis.open_old_stds("R", type="strds")
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 4)
+ self.assertEqual(D.metadata.get_min_min(), -2)
+ self.assertEqual(D.metadata.get_max_max(), -2)
+ start, end = D.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual(end, datetime.datetime(2001, 1, 5))
+ self.assertEqual( D.check_temporal_topology(), True)
+ self.assertEqual(D.get_granularity(), u'1 day')
+ tra = tgis.TemporalRasterAlgebraParser(run=True, debug=True, dry_run=True)
+ pc = tra.parse(expression=expr, basename="r", overwrite=True)
+ self.assertEqual(len(pc["register"]), 4)
+ self.assertEqual(len(pc["processes"]), 4)
+ self.assertEqual(pc["STDS"]["name"], "R")
+ self.assertEqual(pc["STDS"]["stdstype"], "strds")
if __name__ == '__main__':
test()
Modified: grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -63,6 +63,10 @@
#% description: Use granularity sampling instead of the temporal topology approach
#%end
+#%flag
+#% key: d
+#% description: Perform a dry run, compute all depenencies and module calls but don't run them
+#%end
import grass.script
import grass.temporal as tgis
@@ -75,6 +79,7 @@
spatial = flags["s"]
register_null = flags["n"]
granularity = flags["g"]
+ dry_run = flags["d"]
# Check for PLY istallation
try:
@@ -86,14 +91,23 @@
"t.rast.algebra without PLY requirement."))
tgis.init(True)
- p = tgis.TemporalRasterAlgebraParser(run = True, debug=False, spatial = spatial, nprocs = nprocs, register_null = register_null)
+ p = tgis.TemporalRasterAlgebraParser(run = True,
+ debug=False,
+ spatial=spatial,
+ nprocs=nprocs,
+ dry_run=dry_run)
if granularity:
if not p.setup_common_granularity(expression=expression, lexer = tgis.TemporalRasterAlgebraLexer()):
grass.script.fatal(_("Unable to process the expression in granularity algebra mode"))
- p.parse(expression, basename, grass.script.overwrite())
+ pc = p.parse(expression, basename, grass.script.overwrite())
+ if dry_run is True:
+ import pprint
+ pprint.pprint(pc)
if __name__ == "__main__":
options, flags = grass.script.parser()
sys.exit(main())
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -74,8 +74,10 @@
"""Testing the conditional time dimension bug, that uses the time
dimension of the conditional statement instead the time dimension
of the then/else statement."""
- self.assertModule("t.rast.algebra", expression="R = if({contains}, B == 5, A - 1, A + 1)",
- basename="r")
+ self.assertModule("t.rast.algebra", expression="R = if({contains}, B == 5, "
+ "A - 1, A + 1)", basename="r", flags="d")
+ "A - 1, A + 1)", basename="r")
@@ -90,9 +92,10 @@
def test_simple_arith_hash_1(self):
"""Simple arithmetic test including the hash operator"""
- self.assertModule("t.rast.algebra", expression='R = A + (A {#, equal,l} A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = A + (A {#, equal,l} A)', basename="r", flags="d")
+ self.assertModule("t.rast.algebra", expression='R = A + (A {#, equal,l} A)', basename="r")
@@ -106,7 +109,8 @@
def test_simple_arith_td_1(self):
"""Simple arithmetic test"""
- self.assertModule("t.rast.algebra", expression='R = A + td(A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = A + td(A)', basename="r", flags="d")
+ self.assertModule("t.rast.algebra", expression='R = A + td(A)', basename="r")
@@ -120,7 +124,8 @@
def test_simple_arith_td_2(self):
- self.assertModule("t.rast.algebra", expression='R = A / td(A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = A / td(A)', basename="r", flags="d")
+ self.assertModule("t.rast.algebra", expression='R = A / td(A)', basename="r")
@@ -134,7 +139,8 @@
def test_simple_arith_td_3(self):
- self.assertModule("t.rast.algebra", expression='R = A {+,equal} td(A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = A {+,equal} td(A)', basename="r", flags="d")
+ self.assertModule("t.rast.algebra", expression='R = A {+,equal} td(A)', basename="r")
@@ -148,7 +154,8 @@
def test_simple_arith_td_4(self):
- self.assertModule("t.rast.algebra", expression='R = A {/, equal} td(A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = A {/, equal} td(A)', basename="r", flags="d")
+ self.assertModule("t.rast.algebra", expression='R = A {/, equal} td(A)', basename="r")
@@ -163,7 +170,8 @@
def test_simple_arith_if_1(self):
"""Simple arithmetic test with if condition"""
- self.assertModule("t.rast.algebra", expression='R = if({equal}, start_date(A) >= "2001-01-02", A + A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = if({equal}, start_date(A)'
+ ' >= "2001-01-02", A + A)', basename="r")
@@ -177,7 +185,7 @@
def test_simple_arith_if_2(self):
- self.assertModule("t.rast.algebra", expression='R = if({equal}, A#A == 1, A - A)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = if({equal}, A#A == 1, A - A)', basename="r")
@@ -191,8 +199,9 @@
def test_complex_arith_if_1(self):
"""Complex arithmetic test with if condition"""
- self.assertModule("t.rast.algebra", expression='R = if(start_date(A) < "2001-01-03" && A#A == 1, A{+, starts,l}C, A{+, finishes,l}C)', \
- basename="r")
+ self.assertModule("t.rast.algebra", expression='R = if(start_date(A) < "2001-01-03" && A#A == 1,'
+ ' A{+, starts,l}C, A{+, finishes,l}C)',
+ basename="r")
@@ -206,7 +215,7 @@
def test_simple_arith_1(self):
- self.assertModule("t.rast.algebra", expression="R = A {*, equal} A {+, equal} A", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {*, equal} A {+, equal} A", basename="r")
@@ -220,7 +229,7 @@
def test_simple_arith_2(self):
"""Simple arithmetic test that creates an empty strds"""
- self.assertModule("t.rast.algebra", expression="R = A {*, during} A {+, during} A", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {*, during} A {+, during} A", basename="r")
self.assertEqual(D.metadata.get_number_of_maps(), 0)
@@ -228,7 +237,7 @@
def test_simple_arith_3(self):
- self.assertModule("t.rast.algebra", expression="R = A / A + A*A/A", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A / A + A*A/A", basename="r")
@@ -242,7 +251,7 @@
def test_temporal_intersection_1(self):
"""Simple temporal intersection test"""
- self.assertModule("t.rast.algebra", expression="R = A {+,equal,i} B", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {+,equal,i} B", basename="r")
@@ -250,7 +259,7 @@
def test_temporal_intersection_2(self):
- self.assertModule("t.rast.algebra", expression="R = A {+,during,i} B", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {+,during,i} B", basename="r")
@@ -264,7 +273,7 @@
def test_temporal_intersection_3(self):
- self.assertModule("t.rast.algebra", expression="R = A {+,starts,i} B", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {+,starts,i} B", basename="r")
@@ -278,7 +287,7 @@
def test_temporal_intersection_4(self):
- self.assertModule("t.rast.algebra", expression="R = A {+,finishes,intersect} B", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {+,finishes,intersect} B", basename="r")
@@ -292,7 +301,7 @@
def test_temporal_intersection_5(self):
- self.assertModule("t.rast.algebra", expression="R = A {+,starts|finishes,i} B", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {+,starts|finishes,i} B", basename="r")
@@ -306,7 +315,7 @@
def test_temporal_intersection_6(self):
- self.assertModule("t.rast.algebra", expression="R = B {+,overlaps,u} C", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = B {+,overlaps,u} C", basename="r")
@@ -320,7 +329,7 @@
def test_temporal_intersection_7(self):
- self.assertModule("t.rast.algebra", expression="R = B {+,overlapped,u} C", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = B {+,overlapped,u} C", basename="r")
@@ -334,7 +343,7 @@
def test_temporal_intersection_8(self):
- self.assertModule("t.rast.algebra", expression='R = A {+,during,l} buff_t(C, "1 day") ',
+ self.assertModule("t.rast.algebra", expression='R = A {+,during,l} buff_t(C, "1 day") ',
basename="r")
@@ -349,7 +358,7 @@
def test_temporal_neighbors_1(self):
"""Simple temporal neighborhood computation test"""
- self.assertModule("t.rast.algebra", expression='R = A[-1] + A[1]',
+ self.assertModule("t.rast.algebra", expression='R = A[-1] + A[1]',
basename="r")
@@ -364,7 +373,7 @@
def test_temporal_neighbors_2(self):
- self.assertModule("t.rast.algebra", expression='R = A[0,0,-1] + A[0,0,1]',
+ self.assertModule("t.rast.algebra", expression='R = A[0,0,-1] + A[0,0,1]',
basename="r")
@@ -379,7 +388,7 @@
def test_tmap_function1(self):
"""Testing the tmap function. """
- self.assertModule("t.rast.algebra", expression='R = tmap(singletmap)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = tmap(singletmap)', basename="r")
@@ -396,7 +405,7 @@
def test_tmap_function2(self):
- self.assertModule("t.rast.algebra", expression='R = tmap(singletmap) + 1', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = tmap(singletmap) + 1', basename="r")
@@ -413,7 +422,7 @@
def test_map_function1(self):
"""Testing the map function. """
- self.assertModule("t.rast.algebra", expression='R = map(singlemap) + A', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = map(singlemap) + A', basename="r")
@@ -430,7 +439,7 @@
def test_map_function2(self):
- self.assertModule("t.rast.algebra", expression='R = A * map(singlemap)', basename="r")
+ self.assertModule("t.rast.algebra", expression='R = A * map(singlemap)', basename="r")
@@ -447,7 +456,7 @@
def test_temporal_select(self):
"""Testing the temporal select operator. """
- self.assertModule("t.rast.algebra", expression="R = A : A", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A : A", basename="r")
@@ -463,7 +472,7 @@
- self.assertModule("t.rast.algebra", expression="R = A : D", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A : D", basename="r")
@@ -479,7 +488,7 @@
def test_temporal_select_operators1(self):
"""Testing the temporal select operator. Including temporal relations. """
@@ -495,7 +504,7 @@
def test_temporal_select_operators2(self):
- self.assertModule("t.rast.algebra", expression="R = A {!:,during} C", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {!:,during} C", basename="r")
@@ -512,7 +521,7 @@
"""Testing the temporal select operator. Including temporal relations and
different temporal operators (lr|+&)"""
- self.assertModule("t.rast.algebra", expression="R = A {:,during,d} B", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {:,during,d} B", basename="r")
@@ -529,7 +538,7 @@
- self.assertModule("t.rast.algebra", expression="R = A {:,equal|during,r} C", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A {:,equal|during,r} C", basename="r")
@@ -550,7 +559,7 @@
def test_temporal_hash_operator1(self):
"""Testing the temporal hash operator in the raster algebra. """
- self.assertModule("t.rast.algebra", expression="R = if(A # D == 1, A)", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = if(A # D == 1, A)", basename="r")
@@ -566,7 +575,7 @@
def test_temporal_hash_operator2(self):
- self.assertModule("t.rast.algebra", expression="R = A # D", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = A # D", basename="r")
@@ -582,7 +591,7 @@
def test_temporal_hash_operator3(self):
- self.assertModule("t.rast.algebra", expression="R = C {#,contains} A", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = C {#,contains} A", basename="r")
@@ -598,7 +607,7 @@
def test_temporal_hash_operator4(self):
- self.assertModule("t.rast.algebra", expression="R = if({contains},A # D == 1, C {#,contains} A)", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = if({contains},A # D == 1, C {#,contains} A)", basename="r")
@@ -614,7 +623,7 @@
def test_raster_arithmetic_relation_1(self):
- self.assertModule("t.rast.algebra", expression="R = B {+,contains,l} A ", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = B {+,contains,l} A ", basename="r")
@@ -630,7 +639,7 @@
def test_raster_arithmetic_relation_2(self):
- self.assertModule("t.rast.algebra", expression="R = B {*,contains,l} A ", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = B {*,contains,l} A ", basename="r")
@@ -646,7 +655,7 @@
def test_raster_arithmetic_relation_3(self):
@@ -661,9 +670,9 @@
def test_raster_arithmetic_relation_4(self):
- self.assertModule("t.rast.algebra", expression="R = B {+,contains,r} A ", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = B {+,contains,r} A ", basename="r")
self.assertEqual(D.metadata.get_number_of_maps(),4)
@@ -678,7 +687,9 @@
def test_raster_arithmetic_relation_5(self):
"""Complex arithmetic test with temporal intersection"""
- self.assertModule("t.rast.algebra", expression="R = tmap(singletmap) {+,equal| precedes| follows,l} A + map(singlemap)", basename="r")
+ self.assertModule("t.rast.algebra", expression="R = tmap(singletmap) "
+ "{+,equal| precedes| follows,l} "
+ "A + map(singlemap)", basename="r")
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -78,6 +78,7 @@
def test_1(self):
"""Simple arithmetik test"""
expr = "R = if(C == 9, A - 1)"
+ self.assertModule("t.rast.algebra", expression=expr, flags="gd", basename="r")
self.assertModule("t.rast.algebra", expression=expr, flags="g", basename="r")
@@ -94,6 +95,7 @@
def test_2(self):
expr = "R = if(D == 11, A - 1, A + 1)"
@@ -110,6 +112,7 @@
expr ='R = A + (A # A)'
@@ -125,6 +128,7 @@
expr = 'R = A + td(A:D)'
@@ -141,6 +145,7 @@
expr = 'R = if(start_date(A) >= "2001-02-01", A + A)'
@@ -155,6 +160,7 @@
expr = 'R = if(A#A == 1, A - A)'
@@ -169,6 +175,7 @@
expr = 'R = if(start_date(A) < "2001-03-01" && A#A == 1, A+C, A-C)'
@@ -183,6 +190,7 @@
def test_temporal_neighbors(self):
expr ='R = (A[0,0,-1] : D) + (A[0,0,1] : D)'
@@ -197,6 +205,7 @@
def test_map(self):
"""Test STDS + single map without timestamp"""
expr = "R = A + map(singletmap)"
@@ -211,6 +220,7 @@
def test_tmap_map(self):
"""Test STDS + single map with and without timestamp"""
expr = "R = tmap(singletmap) + A + map(singletmap)"
Modified: grass/trunk/temporal/t.select/t.select.py
--- grass/trunk/temporal/t.select/t.select.py 2016-08-31 06:56:41 UTC (rev 69314)
+++ grass/trunk/temporal/t.select/t.select.py 2016-08-31 06:59:10 UTC (rev 69315)
@@ -71,9 +71,8 @@
pc = p.parse(expression, stdstype, overwrite=grass.overwrite)
if dry_run is True:
- import simplejson
- s = simplejson.dumps(pc)
- print(s)
+ import pprint
+ pprint.pprint(pc)
