[GRASS-SVN] r69318 - in grass-addons/grass7/vector: . v.strds.stats
svn_grass at osgeo.org
Wed Aug 31 02:25:49 PDT 2016
Author: lucadelu
Date: 2016-08-31 02:25:48 -0700 (Wed, 31 Aug 2016)
New Revision: 69318
Added:
grass-addons/grass7/vector/v.strds.stats/
grass-addons/grass7/vector/v.strds.stats/Makefile
grass-addons/grass7/vector/v.strds.stats/v.strds.stats.html
grass-addons/grass7/vector/v.strds.stats/v.strds.stats.py
v.strds.stats: first commit
Added: grass-addons/grass7/vector/v.strds.stats/Makefile
--- grass-addons/grass7/vector/v.strds.stats/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.strds.stats/Makefile 2016-08-31 09:25:48 UTC (rev 69318)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.strds.stats
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.strds.stats/v.strds.stats.html
--- grass-addons/grass7/vector/v.strds.stats/v.strds.stats.html (rev 0)
+++ grass-addons/grass7/vector/v.strds.stats/v.strds.stats.html 2016-08-31 09:25:48 UTC (rev 69318)
@@ -0,0 +1,27 @@
+<h2>DESCRIPTION</h2>
+<em>v.strds.stats</em> calculates univariate statistics from given space-time raster datasets
+(STRDS) based on a vector map and uploads statistics to new attribute columns.
+<h2>NOTES</h2>
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+v.strds.stats input=myvector strds=mystrds output=newvector
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.what.rast.html">v.what.rast</a>,
+<a href="t.vect.observe.strds.html">t.vect.observe.strds</a>
+</em>
+<h2>AUTHOR</h2>
+Luca Delucchi, Fondazione Edmund Mach
+<p>
+<i>Last changed: $Date: 2014-03-27 17:21:58 +0100 (Thu, 27 Mar 2014) $</i>
Added: grass-addons/grass7/vector/v.strds.stats/v.strds.stats.py
--- grass-addons/grass7/vector/v.strds.stats/v.strds.stats.py (rev 0)
+++ grass-addons/grass7/vector/v.strds.stats/v.strds.stats.py 2016-08-31 09:25:48 UTC (rev 69318)
@@ -0,0 +1,233 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: v.what.strds
+# AUTHOR(S): Luca delucchi
+# PURPOSE: Calculates univariate statistics from given space-time raster datasets based on a vector map
+# COPYRIGHT: (C) 2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculates univariate statistics from given space-time raster datasets based on a vector map
+#% keyword: vector
+#% keyword: temporal
+#% keyword: statistics
+#% keyword: univariate statistics
+#% keyword: querying
+#% keyword: attribute table
+#% keyword: time
+#% keyword: zonal statistics
+#%end
+#%option G_OPT_V_INPUT
+#%end
+#%option G_OPT_STRDS_INPUTS
+#% key: strds
+#%end
+#%option G_OPT_V_OUTPUT
+#%end
+#%option G_OPT_DB_WHERE
+#%end
+#%option G_OPT_T_WHERE
+#% key: t_where
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: The methods to use
+#% answer: number,minimum,maximum,range,average,stddev,variance,coeff_var,sum,first_quartile,median,third_quartile,percentile
+#% required: no
+#% multiple: yes
+#%end
+#%option
+#% key: percentile
+#% type: integer
+#% description: Percentile to calculate
+#% answer: 90
+#% required: no
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+from grass.pygrass.utils import copy as gcopy
+from grass.pygrass.messages import Messenger
+from grass.pygrass.vector import Vector
+from grass.exceptions import CalledModuleError
+class Sample(object):
+ def __init__(self, start=None, end=None, raster_names=None,
+ strds_name=None):
+ self.start = start
+ self.end = end
+ if raster_names is not None:
+ self.raster_names = raster_names
+ else:
+ self.raster_names = []
+ self.strds_name = strds_name
+ def __str__(self):
+ return "Start: %s\nEnd: %s\nNames: %s\n" % (str(self.start),
+ str(self.end),
+ str(self.raster_names))
+ def printDay(self, date='start'):
+ if date == 'start':
+ return str(self.start).split(' ')[0].replace('-', '_')
+ elif date == 'end':
+ return str(self.end).split(' ')[0].replace('-', '_')
+ else:
+ grass.fatal("The values accepted by printDay in Sample are:"
+ " 'start', 'end'")
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ strds = options["strds"]
+ tempwhere = options["t_where"]
+ methods = options["method"]
+ percentile = options["percentile"]
+ overwrite = grass.overwrite()
+ quiet = True
+ if grass.verbosity() > 2:
+ quiet = False
+ if where == "" or where == " " or where == "\n":
+ where = None
+ # Check the number of sample strds and the number of columns
+ strds_names = strds.split(",")
+ # Make sure the temporal database exists
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ samples = []
+ first_strds = tgis.open_old_stds(strds_names[0], "strds", dbif)
+ # Single space time raster dataset
+ if len(strds_names) == 1:
+ rows = first_strds.get_registered_maps("name,mapset,start_time,end_time",
+ tempwhere, "start_time",
+ dbif)
+ if not rows:
+ dbif.close()
+ grass.fatal(_("Space time raster dataset <%s> is empty") %
+ first_strds.get_id())
+ for row in rows:
+ start = row["start_time"]
+ end = row["end_time"]
+ raster_maps = [row["name"] + "@" + row["mapset"], ]
+ s = Sample(start, end, raster_maps, first_strds.get_name())
+ samples.append(s)
+ else:
+ # Multiple space time raster datasets
+ for name in strds_names[1:]:
+ dataset = tgis.open_old_stds(name, "strds", dbif)
+ if dataset.get_temporal_type() != first_strds.get_temporal_type():
+ grass.fatal(_("Temporal type of space time raster "
+ "datasets must be equal\n<%(a)s> of type "
+ "%(type_a)s do not match <%(b)s> of type "
+ "%(type_b)s" % {"a": first_strds.get_id(),
+ "type_a": first_strds.get_temporal_type(),
+ "b": dataset.get_id(),
+ "type_b": dataset.get_temporal_type()}))
+ mapmatrizes = tgis.sample_stds_by_stds_topology("strds", "strds",
+ strds_names,
+ strds_names[0],
+ False, None,
+ "equal", False,
+ False)
+ for i in range(len(mapmatrizes[0])):
+ isvalid = True
+ mapname_list = []
+ for mapmatrix in mapmatrizes:
+ entry = mapmatrix[i]
+ if entry["samples"]:
+ sample = entry["samples"][0]
+ name = sample.get_id()
+ if name is None:
+ isvalid = False
+ break
+ else:
+ mapname_list.append(name)
+ if isvalid:
+ entry = mapmatrizes[0][i]
+ map = entry["granule"]
+ start, end = map.get_temporal_extent_as_tuple()
+ s = Sample(start, end, mapname_list, name)
+ samples.append(s)
+ # Get the layer and database connections of the input vector
+ if where:
+ try:
+ grass.run_command("v.extract", input=input, where=where,
+ output=output)
+ except CalledModuleError:
+ dbif.close()
+ grass.fatal(_("Unable to run v.extract for vector map"
+ " <%s> and where <%s>") % (input, where))
+ else:
+ gcopy(input, output, 'vector')
+ msgr = Messenger()
+ perc_curr = 0
+ perc_tot = len(samples)
+ pymap = Vector(output)
+ try:
+ pymap.open('r')
+ except:
+ dbif.close()
+ grass.fatal(_("Unable to create vector map <%s>" % output))
+ pymap.close()
+ for sample in samples:
+ raster_names = sample.raster_names
+ # Call v.what.rast for each raster map
+ for name in raster_names:
+ day = sample.printDay()
+ column_name = "%s_%s" % (sample.strds_name, day)
+ try:
+ grass.run_command("v.rast.stats", map=output, raster=name,
+ column=column_name,
+ method=methods, percentile=percentile,
+ quiet=quiet, overwrite=overwrite)
+ dbif.close()
+ grass.fatal(_("Unable to run v.what.rast for vector map"
+ " <%s> and raster map <%s>") %
+ (output, name))
+ msgr.percent(perc_curr, perc_tot, 1)
+ perc_curr += 1
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
