[GRASS-SVN] r69321 - grass-addons/grass7/raster/r.viewshed.cva
svn_grass at osgeo.org
Wed Aug 31 06:23:32 PDT 2016
Author: annakrat
Date: 2016-08-31 06:23:32 -0700 (Wed, 31 Aug 2016)
New Revision: 69321
grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
r.viewshed.cva: more pep8 compatible
Modified: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py 2016-08-31 13:16:27 UTC (rev 69320)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py 2016-08-31 13:23:32 UTC (rev 69321)
@@ -109,7 +109,6 @@
#%end
import sys
import os
grass_install_tree = os.getenv('GISBASE')
@@ -117,16 +116,16 @@
import grass.script as grass
-#main block of code starts here
+# main block of code starts here
def main():
- #bring in input variables
+ # bring in input variables
elev = options["input"]
vect = options["vector"]
viewshed_options = {}
for option in ('observer_elevation', 'target_elevation', 'max_distance', 'memory', 'refraction_coeff'):
viewshed_options[option] = options[option]
out = options["output"]
- #assemble flag string
+ # assemble flag string
flagstring = ''
if flags['r']:
flagstring += 'r'
@@ -136,17 +135,22 @@
flagstring += 'b'
if flags['e']:
flagstring += 'e'
- #get the coords from the vector map, and check if we want to name them
+ # get the coords from the vector map, and check if we want to name them
if flags['k'] and options["name_column"] is not '':
- output_points = grass.read_command("v.out.ascii", flags='r', input=vect, type="point", format="point", separator=",", columns=options["name_column"]).strip() # note that the "r" flag will constrain to points in the current geographic region.
+ # note that the "r" flag will constrain to points in the current geographic region.
+ output_points = grass.read_command("v.out.ascii", flags='r', input=vect, type="point",
+ format="point", separator=",", columns=options["name_column"]).strip()
else:
- output_points = grass.read_command("v.out.ascii", flags='r', input=vect, type="point", format="point", separator=",").strip() # note that the "r" flag will constrain to points in the current geographic region.
+ format="point", separator=",").strip()
grass.message(_("Note that the routine is constrained to points in the current geographic region."))
- #read the coordinates, and parse them up.
+ # read the coordinates, and parse them up.
masterlist = []
for line in output_points.splitlines():
masterlist.append(line.strip().split(','))
- #now, loop through the master list and run r.viewshed for each of the sites, and append the viewsheds to a list (so we can work with them later)
+ # now, loop through the master list and run r.viewshed for each of the sites,
+ # and append the viewsheds to a list (so we can work with them later)
vshed_list = []
for site in masterlist:
@@ -156,11 +160,13 @@
grass.verbose(_('Calculating viewshed for location %s,%s (point name = %s)') % (site[0], site[1], ptname))
tempry = "vshed_%s" % ptname
vshed_list.append(tempry)
- grass.run_command("r.viewshed", quiet = True, overwrite=grass.overwrite(), flags=flagstring, input=elev, output=tempry, coordinates=site[0] + "," + site[1], **viewshed_options)
- #now make a mapcalc statement to add all the viewsheds together to make the outout cumulative viewsheds map
+ grass.run_command("r.viewshed", quiet=True, overwrite=grass.overwrite(), flags=flagstring,
+ input=elev, output=tempry, coordinates=site[0] + "," + site[1], **viewshed_options)
+ # now make a mapcalc statement to add all the viewsheds together to make the outout cumulative viewsheds map
grass.message(_("Calculating \"Cumulative Viewshed\" map"))
- grass.run_command("r.series", quiet=True, overwrite=grass.overwrite(), input=(",").join(vshed_list), output=out, method="count")
- #Clean up temporary maps, if requested
+ grass.run_command("r.series", quiet=True, overwrite=grass.overwrite(),
+ input=(",").join(vshed_list), output=out, method="count")
+ # Clean up temporary maps, if requested
if flags['k']:
grass.message(_("Temporary viewshed maps will not removed"))
else:
