[GRASS-SVN] r69326 - grass/trunk/vector/v.to.rast
Wed Aug 31 17:37:04 PDT 2016
Author: wenzeslaus
Date: 2016-08-31 17:37:04 -0700 (Wed, 31 Aug 2016)
New Revision: 69326
   grass/trunk/vector/v.to.rast/local.h
   grass/trunk/vector/v.to.rast/support.c
   grass/trunk/vector/v.to.rast/vect2rast.c
v.to.rast: just leave the color table to be the default
Modified: grass/trunk/vector/v.to.rast/local.h
--- grass/trunk/vector/v.to.rast/local.h	2016-08-31 20:47:22 UTC (rev 69325)
+++ grass/trunk/vector/v.to.rast/local.h	2016-09-01 00:37:04 UTC (rev 69326)
@@ -43,11 +43,9 @@
 /* support.c */
 int update_hist(const char *, const char *, long);
-int update_colors(const char *);
 int update_dbcolors(const char *, const char *, int, const char *, int, const char *);
 int update_labels(const char *, const char *, int, const char *, int, int, const char *);
 int update_cats(const char *);
-int update_fcolors(const char *);
 /* vect2rast.c */
 int vect_to_rast(const char *, const char *, const char *, const char *, int, int,
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c	2016-08-31 20:47:22 UTC (rev 69325)
+++ grass/trunk/vector/v.to.rast/support.c	2016-09-01 00:37:04 UTC (rev 69326)
@@ -39,37 +39,6 @@
     return 0;
-int update_colors(const char *raster_name)
-    struct Range range;
-    struct Colors colors;
-    CELL min, max;
-    Rast_read_range(raster_name, G_mapset(), &range);
-    Rast_get_range_min_max(&range, &min, &max);
-    Rast_make_rainbow_colors(&colors, min, max);
-    Rast_write_colors(raster_name, G_mapset(), &colors);
-    return 0;
-int update_fcolors(const char *raster_name)
-    struct FPRange range;
-    DCELL min, max;
-    Rast_read_fp_range(raster_name, G_mapset(), &range);
-    Rast_get_fp_range_min_max(&range, &min, &max);
-    Rast_make_rainbow_colors(&colors, (CELL) min, (CELL) max);
-    return 0;
 int update_cats(const char *raster_name)
     /* TODO: maybe attribute transfer from vector map?
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c	2016-08-31 20:47:22 UTC (rev 69325)
+++ grass/trunk/vector/v.to.rast/vect2rast.c	2016-09-01 00:37:04 UTC (rev 69326)
@@ -202,17 +202,12 @@
     if (rgbcolumn) {
 	if (use != USE_ATTR && use != USE_CAT) {
 	    G_warning(_("Color can be updated from database only if use=attr"));
-	    update_colors(raster_map);
 	else {
 	  update_dbcolors(raster_map, vector_map, field, rgbcolumn, is_fp,
 			  column);
-    else if (use == USE_D)
-	update_fcolors(raster_map);
-    else
     update_cats(raster_map);
