[GRASS-SVN] r69959 - grass-addons/grass7/raster/r.resamp.tps
svn_grass at osgeo.org
Thu Dec 1 00:07:42 PST 2016
Author: mmetz
Date: 2016-12-01 00:07:42 -0800 (Thu, 01 Dec 2016)
New Revision: 69959
grass-addons/grass7/raster/r.resamp.tps/pavl.c
grass-addons/grass7/raster/r.resamp.tps/tps.c
r.resamp.tps: count weighted averages
Modified: grass-addons/grass7/raster/r.resamp.tps/pavl.c
--- grass-addons/grass7/raster/r.resamp.tps/pavl.c 2016-11-30 21:54:47 UTC (rev 69958)
+++ grass-addons/grass7/raster/r.resamp.tps/pavl.c 2016-12-01 08:07:42 UTC (rev 69959)
@@ -264,20 +264,20 @@
assert(tree != NULL && item != NULL);
- if (tree->pavl_root == NULL)
- return NULL;
p = tree->pavl_root;
dir = 0;
- cmp = tree->pavl_compare(item, p->pavl_data);
- while (cmp != 0) {
+ while (p != NULL) {
+ cmp = tree->pavl_compare(item, p->pavl_data);
+ if (cmp == 0)
+ break;
dir = cmp > 0;
p = p->pavl_link[dir];
- if (p == NULL)
- return NULL;
+ if (p == NULL)
+ return NULL;
item = p->pavl_data;
q = p->pavl_parent;
Modified: grass-addons/grass7/raster/r.resamp.tps/tps.c
--- grass-addons/grass7/raster/r.resamp.tps/tps.c 2016-11-30 21:54:47 UTC (rev 69958)
+++ grass-addons/grass7/raster/r.resamp.tps/tps.c 2016-12-01 08:07:42 UTC (rev 69959)
@@ -977,7 +977,7 @@
CELL *maskbuf;
int solved;
int pfound;
- double distmax, mindist;
+ double distmax;
int mask_fd;
FLAG *mask_flag, *pnt_flag;
struct tps_out tps_out;
@@ -987,6 +987,7 @@
int rmin, rmax, cmin, cmax, rminp, rmaxp, cminp, cmaxp;
int irow, irow1, irow2, icol, icol1, icol2;
int wsize;
+ unsigned int wacnt;
double dxyw;
#ifndef USE_RC
double i_n, i_e;
@@ -1088,6 +1089,7 @@
wmin = 10;
wmax = 0;
+ wacnt = 0;
if (overlap > 1.0)
overlap = 1.0;
@@ -1168,7 +1170,6 @@
i_n = dst->north - (row + 0.5) * dst->ns_res;
i_e = dst->west + (col + 0.5) * dst->ew_res;
- mindist = -1;
result = 0;
wsum = 0;
maxweight = 0;
@@ -1189,7 +1190,7 @@
weight = exp(-dist2 * 4.0);
/* weight for tps */
- if (mindist > dist2 || mindist > 0)
+ if (maxweight < weight)
maxweight = weight;
wsum += weight;
@@ -1205,6 +1206,8 @@
tps_out.val += result * weight;
tps_out.wsum += weight;
Segment_put(out_seg, (void *)&tps_out, row, col);
+ wacnt++;
continue;
@@ -1340,6 +1343,7 @@
G_debug(1, "wmin: %g", wmin);
G_debug(1, "wmax: %g", wmax);
+ G_debug(1, "wacnt: %u", wacnt);
flag_destroy(pnt_flag);
