[GRASS-SVN] r69965 - grass/trunk/raster/r.texture
svn_grass at osgeo.org
Thu Dec 1 12:30:33 PST 2016
Author: mmetz
Date: 2016-12-01 12:30:33 -0800 (Thu, 01 Dec 2016)
New Revision: 69965
grass/trunk/raster/r.texture/h_measure.c
grass/trunk/raster/r.texture/h_measure.h
grass/trunk/raster/r.texture/main.c
r.texture: add flag to allow NULL cells
Modified: grass/trunk/raster/r.texture/h_measure.c
--- grass/trunk/raster/r.texture/h_measure.c 2016-12-01 17:09:56 UTC (rev 69964)
+++ grass/trunk/raster/r.texture/h_measure.c 2016-12-01 20:30:33 UTC (rev 69965)
@@ -119,21 +119,36 @@
int set_vars(int **grays, int curr_row, int curr_col,
- int size, int offset, int t_d)
+ int size, int offset, int t_d, int with_nulls)
int R0, R45, R90, R135, x, y;
int row, col, row2, col2, rows, cols;
+ int rowmin, rowmax, colmin, colmax, wrows, wcols, rowd, cold;
int itone, jtone;
int cnt;
rows = cols = size;
+ wrows = Rast_window_rows();
+ wcols = Rast_window_cols();
/* Determine the number of different gray scales (not maxval) */
for (row = 0; row <= PGM_MAXMAXVAL; row++)
tone[row] = -1;
cnt = 0;
- for (row = curr_row - offset; row <= curr_row + offset; row++) {
- for (col = curr_col - offset; col <= curr_col + offset; col++) {
+ rowmin = curr_row - offset;
+ if (rowmin < 0)
+ rowmin = 0;
+ rowmax = curr_row + offset;
+ if (rowmax > wrows - 1)
+ rowmax = wrows - 1;
+ colmin = curr_col - offset;
+ if (colmin < 0)
+ colmin = 0;
+ colmax = curr_col + offset;
+ if (colmax > wcols - 1)
+ colmax = wcols - 1;
+ for (row = rowmin; row <= rowmax; row++) {
+ for (col = colmin; col <= colmax; col++) {
if (grays[row][col] < 0) { /* No data pixel found */
continue;
@@ -146,8 +161,9 @@
/* what is the minimum number of pixels
- * to get reasonable texture measurements ? */
- if (cnt < t_d * t_d * 4)
+ * to get reasonable texture measurements ?
+ * at the very least, any of R0, R45, R90, R135 must be > 1 */
+ if (cnt < size * size / 4 || (!with_nulls && cnt < size * size))
return 0;
/* Collapse array, taking out all zero values */
@@ -180,35 +196,49 @@
/* Find gray-tone spatial dependence matrix */
for (row = 0; row < rows; row++) {
row2 = curr_row - offset + row;
+ if (row2 < 0 || row2 >= wrows)
+ continue;
for (col = 0; col < cols; col++) {
col2 = curr_col - offset + col;
+ if (col2 < 0 || col2 >= wcols)
+ continue;
if (grays[row2][col2] < 0)
continue;
x = bsearch_gray(tone, Ng, grays[row2][col2]);
- if (col + t_d < cols &&
- grays[row2][col2 + t_d] >= 0) {
- y = bsearch_gray(tone, Ng, grays[row2][col2 + t_d]);
+ rowd = row2;
+ cold = col2 + t_d;
+ if (col + t_d < cols && cold < wcols &&
+ grays[rowd][cold] >= 0) {
+ y = bsearch_gray(tone, Ng, grays[rowd][cold]);
P_matrix0[x][y]++;
P_matrix0[y][x]++;
R0 += 2;
- if (row + t_d < rows &&
- grays[row2 + t_d][col2] >= 0) {
- y = bsearch_gray(tone, Ng, grays[row2 + t_d][col2]);
+ rowd = row2 + t_d;
+ cold = col2;
+ if (row + t_d < rows && rowd < wrows &&
P_matrix90[x][y]++;
P_matrix90[y][x]++;
R90 += 2;
- if (row + t_d < rows && col - t_d >= 0 &&
- grays[row2 + t_d][col2 - t_d] >= 0) {
- y = bsearch_gray(tone, Ng, grays[row2 + t_d][col2 - t_d]);
+ cold = col2 - t_d;
+ col - t_d >= 0 && cold >= 0 &&
P_matrix45[x][y]++;
P_matrix45[y][x]++;
R45 += 2;
- if (row + t_d < rows && col + t_d < cols &&
- grays[row2 + t_d][col2 + t_d] >= 0) {
- y = bsearch_gray(tone, Ng, grays[row2 + t_d][col2 + t_d]);
+ col + t_d < cols && cold < wcols &&
P_matrix135[x][y]++;
P_matrix135[y][x]++;
R135 += 2;
Modified: grass/trunk/raster/r.texture/h_measure.h
--- grass/trunk/raster/r.texture/h_measure.h 2016-12-01 17:09:56 UTC (rev 69964)
+++ grass/trunk/raster/r.texture/h_measure.h 2016-12-01 20:30:33 UTC (rev 69965)
@@ -26,6 +26,6 @@
float h_measure(int);
void alloc_vars(int);
int set_vars(int **grays, int curr_rrow, int curr_col,
- int size, int offset, int t_d);
+ int size, int offset, int t_d, int with_nulls);
int set_angle_vars(int angle, int have_px, int have_py,
int have_pxpys, int have_pxpyd);
Modified: grass/trunk/raster/r.texture/main.c
--- grass/trunk/raster/r.texture/main.c 2016-12-01 17:09:56 UTC (rev 69964)
+++ grass/trunk/raster/r.texture/main.c 2016-12-01 20:30:33 UTC (rev 69965)
@@ -92,7 +92,7 @@
RASTER_MAP_TYPE out_data_type;
struct GModule *module;
struct Option *opt_input, *opt_output, *opt_size, *opt_dist, *opt_measure;
- struct Flag *flag_ind, *flag_all;
+ struct Flag *flag_ind, *flag_all, *flag_null;
struct History history;
char p[1024];
@@ -157,6 +157,11 @@
flag_all->key = 'a';
flag_all->description = _("Calculate all textural measurements");
+ flag_null = G_define_flag();
+ flag_null->key = 'n';
+ flag_null->label = _("Allow NULL cells in a moving window");
+ flag_null->description = _("This will also avoid cropping along edges of the current region");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -313,10 +318,21 @@
offset = size / 2;
- first_row = first_col = offset;
- last_row = nrows - offset;
- last_col = ncols - offset;
+ if (!flag_null->answer) {
+ first_row = first_col = offset;
+ last_row = nrows - offset;
+ last_col = ncols - offset;
+ else {
+ /* no cropping at window margins */
+ first_row = first_col = 0;
+ last_row = nrows;
+ last_col = ncols;
Rast_set_f_null_value(fbuf[0], ncols);
for (row = 0; row < first_row; row++) {
for (i = 0; i < n_outputs; i++) {
Rast_put_row(outfd[i], fbuf[0], out_data_type);
@@ -337,7 +353,7 @@
/*process the data */
for (col = first_col; col < last_col; col++) {
- if (!set_vars(data, row, col, size, offset, dist)) {
+ if (!set_vars(data, row, col, size, offset, dist, flag_null->answer)) {
Rast_set_f_null_value(&(fbuf[i][col]), 1);
continue;
