[GRASS-SVN] r70004 - grass-addons/grass7/raster/r.denoise
svn_grass at osgeo.org
Mon Dec 5 11:52:09 PST 2016
Author: guano
Date: 2016-12-05 11:52:09 -0800 (Mon, 05 Dec 2016)
New Revision: 70004
Added:
grass-addons/grass7/raster/r.denoise/description.html
r.denoise (python version)
Added: grass-addons/grass7/raster/r.denoise/description.html
--- grass-addons/grass7/raster/r.denoise/description.html (rev 0)
+++ grass-addons/grass7/raster/r.denoise/description.html 2016-12-05 19:52:09 UTC (rev 70004)
@@ -0,0 +1,54 @@
+<h2>REQUIREMENTS</h2>
+<em><b>r.denoise</em></b> requires that <em>mdenoise</em>, the executable version of Sun et al.'s (2007) denoising algorithm, is available on the $PATH. <em>mdenoise</em> can be compiled and installed as follows:
+<div class="code"><pre>
+wget http://www.cs.cf.ac.uk/meshfiltering/index_files/Doc/mdsource.zip
+unzip mdsource.zip
+cd mdenoise
+g++ -o mdenoise mdenoise.cpp triangle.c
+ln -s `pwd`/mdenoise /some/directory/on/the/$PATH
+</pre></div>
+<br>
+The python version of <em>r.denoise</em> uses <a href="https://github.com/jswhit/pyproj">pyproj</a>:
+pip install pyproj
+</pre></div>
+<h2>DESCRIPTION</h2>
+<p>
+Sun et al.'s (2007) <a href="http://www.cs.cf.ac.uk/meshfiltering/index_files/Page342.htm">denoising algorithm</a> is a feature-preserving mesh denoising algorithm that smooths the surfaces of computer models of three dimensional objects such as those used in computer-aided design and graphics. It removes random noise while preserving sharp features and smoothing with minimal changes to the original data. <em>r.denoise</em> is a UNIX shell script that allows the algorithm to be run on DEMs from within <em>GRASS</em>. Denoising DEMs can improve clarity and quality of derived products such as slope and hydraulic maps.
+<p>
+The amount of smoothing is controlled by the <em>threshold</em> and <em>iterations</em> parameters. Increasing the <em>threshold</em> decreases how sharp a feature needs to be to be preserved e.g. decreases the smoothing. To preserve ridge crests in mountain areas, T > 0.9 is recommended. Setting T too high results in the preservation of noise. For SRTM data, which is already partly smoothed by NASA, T = 0.99 can be used. Increasing the number of <em>iterations</em> increases the smoothing and the range of spatial correlation of the output dataset. A small number, e.g. 5 or fewer, typically gives the best results. See the REFERENCES for more detailed information.
+<h2>NOTES</h2>
+<p>
+<em>r.denoise</em> works with a cartesian coordinate system. Thus data in geographic (lat-long) coordinates require projection during processing. The script is able to do this if the <a href="http://www.epsg-registry.org/">EPSG code</a> of a suitable coordinate system is provided.
+<h2>REFERENCES</h2>
+<ul>
+ <li>For further information on denoising DEMs, see: <a href="http://personalpages.manchester.ac.uk/staff/neil.mitchell/mdenoise/">Using Sun's denoising algorithm on topographic data</a>.
+ <li>Sun X, Rosin PL, Martin RR, Langbein FC (2007) Fast and Effective Feature-Preserving Mesh Denoising. IEEE Transactions on Visualisation and Computer Graphics, 13(5):925-938 <a href="http://dx.doi.org/10.1109/TVCG.2007.1065">doi:10.1109/TVCG.2007.1065</a></li>
+ <li>Stevenson JA, Sun X, Mitchell NC. (2009) Despeckling SRTM and other topographic data with a denoising algorithm. Geomorphology, <i>Article in press, Accepted manuscript</i>. <a href="http://dx.doi.org/10.1016/j.geomorph.2009.07.006">doi:10.1016/j.geomorph.2009.07.006</a></li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.stats.html">r.stats</a>,
+<a href="r.in.xyz.html">r.in.xyz</a>,
+<a href="r.neighbors.html">r.neighbors</a>,
+<a href="r.topidx.html">r.topidx</a>,
+</em>
+<h2>AUTHOR</h2>
+John A Stevenson<br>
+johnalexanderstevenson <i>at</i> yahoo <i>dot</i> co <i>dot</i> uk<br><br>
+The module was written as part of a project funded by <a href="http://www.epsrc.ac.uk">EPSRC</a> Grant no. EP/C007972/1 (P.I. Paul Rosin, Cardiff University).<br>
+Module ported to Python by <a href="http://carlosgrohmann.com/">Carlos H. Grohmann</a><br>
+<p>
+<i>Last changed: $Date: 2016-12-05 11:56:45 +0000 (Mon, 05 Dec 2016) $</i>
