[GRASS-SVN] r70019 - grass/branches/releasebranch_7_2/lib/init
svn_grass at osgeo.org
Tue Dec 6 14:15:58 PST 2016
Author: neteler
Date: 2016-12-06 14:15:58 -0800 (Tue, 06 Dec 2016)
New Revision: 70019
grass/branches/releasebranch_7_2/lib/init/grass7.html
grass7 manual: exec interface description (shell and python) expanded (with support of veroandreo)
Modified: grass/branches/releasebranch_7_2/lib/init/grass7.html
--- grass/branches/releasebranch_7_2/lib/init/grass7.html 2016-12-06 22:10:13 UTC (rev 70018)
+++ grass/branches/releasebranch_7_2/lib/init/grass7.html 2016-12-06 22:15:58 UTC (rev 70019)
@@ -285,14 +285,14 @@
Region issues ignored.
-Create a new Location based on a geodata file's projection (<b>-c</b>)
-and exit (<b>-e</b>):
+Creating a new Location based on a geodata file's projection (<b>-c</b>)
+and exit (<b>-e</b>) immediately:
<div class="code"><pre>
grass72 -c elevation.tiff -e /path/to/grassdata/test1/
</pre></div>
-Link external raster data to PERMANENT Mapset:
+Linking external raster data to PERMANENT Mapset:
grass72 /path/to/grassdata/test1/PERMANENT/ --exec r.external input=basins.tiff output=basins
@@ -311,14 +311,61 @@
grass72 /path/to/grassdata/test1/PERMANENT/ --exec g.gui.mapswipe first=elevation second=basins
</pre></div>
+<h4>Execution of shell and Python scripts instead of single commands</h4>
+A sequence of commands can be bundled in a script and executed using the
+exec interface.
<p>
-Note: The exec interface is also able to execute entire scripts.
+<b>Shell script example:</b> the command to execute a shell script might be:
-<p><b>Troubleshooting</b>:
+<div class="code"><pre>
+grass72 /path/to/grassdata/test1/PERMANENT/ --exec sh test.sh
+</pre></div>
+A very simple bash script ("test.sh") may look like this:
+#!/bin/bash
+g.region -p
+g.list type=raster
+r.info elevation
+</pre></div>
+<p>
+<b>Python script example:</b> the command to execute a Python script might be:
+grass72 /path/to/grassdata/test1/PERMANENT/ --exec python test.py
+</pre></div>
+A very simple Python script ("test.py") may look like this:
+#!/usr/bin/env python
+# import GRASS Python bindings (see also pygrass)
+import grass.script as gscript
+import grass.script.setup as gsetup
+gscript.message('Current GRASS GIS 7 environment:')
+print gscript.gisenv()
+gscript.message('Available raster maps:')
+for raster in gscript.list_strings(type = 'raster'):
+ print raster
+gscript.message('Available vector maps:')
+for vector in gscript.list_strings(type = 'vector'):
+ print vector
+</pre></div>
+<h4>Troubleshooting</h4>
Importantly, to avoid an <tt>"[Errno 8] Exec format error"</tt> there must be a
<a href="https://en.wikipedia.org/wiki/Shebang_%28Unix%29">shebang</a> line at the top of
the script (like <tt>#!/bin/sh</tt>, <tt>#!/bin/bash</tt>, or <tt>#!/usr/bin/env python</tt>)
-indicating which interpreter to be used for the script.
+indicating which interpreter to be used for the script. The script file must
+have its executable bit set.
<h3>Other examples</h3>
